Solid, durable, well-built mouse
Reply #29 – 2005-10-30 19:37:59
Okay, after having used it for a week, here's a more detailed review on the m5000 (ratings go from 1(worst) to 5(perfect)): The two main buttons: While the buttons of most nowadays mice have got a high-pitched click and high sensivity, the m5000 has a soft but clearly noticable low-pitched click. The buttons are not as sensitive as those of other mice, but they also dont require too much force. You can safely rest your fingers on them without accidentelly clicking, but need to clearly "click" them. The feedback when clicking is clear and instant. The buttons seem more sturdy and robust that those of other mice. I made another observation of which i am not absolutely sure if its by design or a coincidence. Although the mouse is symmetrical(so for left as well as right hand use), the left mouse button seems to be a bit more "soft"... so while your fingers rest on it, you will be a bit more "near the trigger" with the left button, than with the right. To check if its by design, i opened the mouse and noticed that both buttons do not use the same kind of switches. This does not make the mouse unsuited for left-handed use, but with games, you will have a minor "edge" if you're right-handed........ rating: 5.0 The scrollwheel: Very sturdy, accurate and reliable. It definatelly requires a "wear-in"-phase to become usable, because right after taking the mouse out of the package the mousewheel requires alot of force to be scrolled(the exact opposite of most other mice). After about 50-60hours of use, it becomes more easy and IMHO almost optimal. Because of the robust built-quality of the wheel as well as clear "steps", it is no problem to "click" the wheel without accidentelly scrolling it. The placement of the wheel is also a little bit "higher" than with other mice, which i consider an advantage(i always disliked the too "integrated" placement of the wheel with other mice)....... rating: 4.0 The shape: It's very ergonomically shaped although it is usable by left as well as right-handed users. It is also a bit "longer" than most other similiar mice, which means that you can completely rest your hand on it. While not an "instant-at-home" shape, i completely adapted to it in about 20mins. The reason why its not instant is because although the shape is symmetrical, it has resting-positions for every single finger - thats great, but other mice dont have that, so it requires a few mins to "get it". My opinion is that it's *almost* the perfect shape for a "symmetrical" mouse..... therefore the rating: 4.5 The materials: The feeling of using it is comfortable, because of the already known "soft touch" surface, which feels soft yet still can be cleaned easily. However, the mouse for my taste is too lightweight. Its not horrible, but with a mouse of this kind i would have expected this thing to have robust surface-contact instead of just "gliding" over the surface. It just doesn't fit to this mouse, because although it overally feels "sturdy, reliable and just works", in terms of weight it feels like a cheap plastic toy. Well, yes, other mice in that pricerange are the same, but i choosed this one because i wanted something different.......... rating: 2.0 Accuracy: Just works reliable - neither bad nor deluxe....... rating: 4.0 Software-compatibility: Although a CD is in the package, it requires no drivers for any of its features(that also goes for linux). An USB->PS2-adapter is included....... rating: 5.0 Visuals: Its low profile and not fancy. No "blinking" during the night because of no transluscent parts(except of the wheel which glows red). Although the specs say "black", it is not black but instead "dark-grey". The shape clearly had its design-priority on being comfortable instead of looking cool........ rating: 4.0 if you like low-profile hardware / 1.0 if you like your hardware to be fancy eye-candy Price: aprox 12euro for the retail-version. Very low for such a mouse......... rating: 5.0 Summary: If - you need a cheap, comfortable and reliable mouse which just works - 3 buttons are enough for you - you dont care much about eye-candy / you prefer low-profile design - you can live with a lightweight mouse then the m5000 is for you.
