Topic: Nero Releases FREE Reference Quality MPEG-4 Audio Encoder (Read 475936 times) previous topic - next topic
Reply #175
Linux is actually on the way
Oh man, I don't even know what to say. I've been rebooting into windows and going through the whole EAC + Itunes encode + Itunes fiasco to encode my new CDs. This way I'll be able to do it all from KAudioCreator!
Reply #176
When i try to encode using the -br method, it just says SBR not found?
You probably didn't read the help closely enough. (bits != kilobits)
Reply #177
Why HE profile can be used with higer rates than 160kbs, i try to encode to 256kbs with sbr
neroAacEnc.exe -he -cbr 256000 -if Track 07.wav -of Track 074.mp4
i get error message
ERROR: no valid SBR configuration found
And can you define what is max bitrates for all modes including 5.1, Thanks
Reply #179
I am doing some tests, a wanna see something. btw in 5.1 encoding i think is better to use for example 192kbs HE than LC
Reply #180
SBR works up to 192 kbps for 5.1 content - so basically there are two things that could be done:
a) erroring out (like it is done now)
b) adding presets for 256 kbps, but spitting out warning that LC-AAC might actually be a better choice
We will look into possibility b)  whether it is feasible.
Reply #181
Thanks Ivan, but i have only to see how codec works on 88.2khz.
I think implementing SBR High Bitrate like CT then no posibilites to get erroring, like add switch -highsbr or something like this, and what you think about various stereo modes like CT.
Reply #182
I had seen it work @88.2 kHz some time ago ;-)
Although our encoder does algorithmically support "downsampled SBR" or "single-rate SBR" or "high-bitrate SBR"  we do not export this option to the frontend.
The reason for this choice is because this particular codec mode puts tremendous burden to the audio decoder (cuts the decoding speed in half), while bringing no audible advantage over LC mode at the same bit-rate, and this has been tested in various listening tests by now.
I would like to point out - that the power of Nero Digital Audio will also be devices that play it in the future - with all the great features ND Audio brings.
If we allowed the single-rate SBR, I am afraid that many mobile device vendors would not be able to support this, as it would require very strong DSPs or embedded CPUs to support this - with no quality gains.
My opinion was always to leave encoder to decide what to use (LR, M/S, IS, etc...) - and thresholds for decision were set during the tuning process.
There is no need to allow modification I think, as there is much higher chance for non-experienced users to make settings that actually damage sound quality - and generate bad image for the complete technology when they listen to songs they made with "tweaked" codec (e.g. like with old MP3 encoders)
Reply #183
Good old encoder ;-)
You think Nero automaticly downsample 88->44khz. Why, i newer have bad things with CT encodings and devices
Thas is good reason, but i not say that for example 192kbsSBR is better than 192NONSBR. Did someone do tests with SBR @ higer rates comparing to LC
About IS, can you tell me when is activated. This is one of many reason to include this tweak. Me and many user want to know what is used in encoding. In my some test with AAC encoding M/S encoding not have sense at very high rates 220> like LR in very low rates <128. That aslo valid for MP3
This is codec for Pro users Right, then if somebody not know how to use codec, so then exist default settings like now. I just wanna make this tweak like LC,HE,HEv2 switches.
And i almost forgot i see that in mp3 section, ReplyGain. Until now somebody told that ReplyGain and AAC can't be. Can you confirm that.
Reply #184
Is there a way to specify MONO output from a dual-channel monaural file? For example, if an old album was recorded in mono, and I have the CD, ripping the CD will still produce a stereo *.wav.
Pesky, I know. Who listens to mono?  (I do.)
    - M.
Reply #185
Great work!  I have tested out this encoder and it works like a charm!  Could use a few little things like a better help section and a progress bar during the encoding process but this is just simply awesome either way.  I've been waiting for something like this from Nero!  There is now a viable and easy way to convert your music collection to Nero AAC.  I can now use it easily with any ripper that supports command line encoders and the best part is it is free.
BTW, I'm not sure if I missed this in the above posts but how do you implement tagging with this encoder?  Any switches to do that?
Reply #186
I have little ac3 6ch 448 Kbps. I make these convertions:
file wav 6 chanels 6ch.wav
file wav 2 chanels 2ch.wav (default matrix 6ch->2ch conversion for BS)
six files wav FR.wav, FL.wav, C.wav, LFE.wav, SR.wav and SL.wav
1) Convertion with neroAacEnc.exe
I use this command line for all wav file
neroAacEnc.exe -q 0.3 -lc -if input.wav -of output.mp4
and I find these size for each mp4 files
2ch done 2497 Ko and 114 Kbps
6h done 8764 Ko
FL done 1574 Ko
FR done 1569 Ko
C done 1567 Ko
LFE done 725 Ko
SL done 1481 Ko
SR done 1533 Ko
well it's really curious:
- same quality level for individual chanel done less bitrate than 6ch conversion (8.32 Mo vs 8.55 Mo)
- for same quality level bitrate for 6ch and 2ch sould be simple scalling something like between x2.0-x2.5 ... here it's 3.5
2) Convertion with FAAC.exe
faac.exe input.wav -o output.mp4 --tns -q 100
2ch done 2552 Ko and 116 Kbps
6h done 6559 Ko
FL done 1212 Ko
FR done 1211 Ko
C done 844 Ko
LFE done 2497 Ko
SL done 1233 Ko
SR done 1240 Ko
well here it's normal:
- same quality level for individual chanel done more bitrate than 6ch conversion (7.00 Mo vs 6.40 Mo)
- for same quality level bitrate for 6ch and 2ch sould be simple scaling something like between x2.0-x2.5 ... here it's 2.57
If quality level is the same for each encoding (1.0, 2.0, 5.1 ... etc) then bitrate for q 0.3 6ch file should be in 5000-6500 Ko interval. Chanel coupling seem work for 2.0 but not for 5.1. Bug for multichanel or different quality level ... ???
Well I try with the old nero aac version (aac.dll and aacenc32.dll) and I find that:
profil LC with quality "internet"
for quality "high" size scalling is x2.62
2ch done 2860 Ko
6ch done 7518 Ko
for quality "fast" size scalling is x3.32
2ch done 2713 Ko
6ch done 9022 Ko
for quality "high + pns" size scalling is x2.28
2ch done 2121 Ko
6ch done 4405 Ko
for quality "fast + pns" size scalling is x2.80
2ch done 1727 Ko
6ch done 4842 Ko
Perhaps an old bug for the "fast" preset ... I don't know. 5.1 Chanel coupling seem not work only in "fast" mode but perhaps simply that these quality mode are not equivalent ... ???
Reply #187
Excellent work, thank you very much.
The time matches perfectly as I just bought my Samsung D608. I can put a lot of MP4 music into it. Thanks.
Reply #188
@ M: If you use foobar, you can use the "Downmix Channels to Mono" DSP when converting. I have no idea if this is possible in EAC. But since this encoder uses joint-stereo (at least I'm quite sure it does), the gain in filesize will be rather small. Nevertheless, it's a mono-track, so I think it should be encoded mono.
Reply #189
But there is no point to it (encoding at 88.2kHz) and it seems to bring lower quality.
Yes, of course. SBR starts being pointless at about 85-90kbps.
I am sorry but this is complete bullshit. AAC's stereo system is not comparable to MP3, it makes no point to say that AAC is using M/S or L/R because it will consistently use both modes at the same time! And there's definitely an advantage in it even at extremely high bitrates.
Yeah, and now people are trying 2 pass VBR and 192kbps stereo HE-AAC. Uhm, I think even "pro users" can do amazingly silly things.
Whoever told you that had absolutely no idea what they were talking about. Nero Digital supports ReplayGain, and for example foobar2000 also does.
    - M.
I'd recommend downmixing beforehand. But encoding it as stereo is fine too, because the encoder can and will figure out that it is really mono and encode it quite efficiently.
You will need to tag from an external application (for now).  Switches will be added at a later time.
Reply #190
REACT v1.0 (just released) has support for this encoder.
It includes the encoder and a tagger app.
Three configs are available: MP4 (mp4 tracks), WV_MP4 (Wavpack image or tracks + mp4 tracks).
The WV_MP4-image.txt config is particular advanced, which creates a tagged Wavpack image, and then tagged mp4 tracks from the ripped image.
http://www.hydrogenaudio.org/forums/index....showtopic=36261
Enjoy.
Reply #191
OK but if me show some tests to prove me.
What about IS (Intesivity Stereo), i think that for example 96kbs sounds beter with LC and IS, from some earlier Ivan's tests.
]I am sorry but this is complete bullshit. AAC's stereo system is not comparable to MP3, it makes no point to say that AAC is using M/S or L/R because it will consistently use both modes at the same time! And there's definitely an advantage in it even at extremely high bitrates.
You sorry me but for me is bigest important thing. I know what is answer can be and you devs always find some stupid reason. Leave MP3 and his old technology alone. I don't have problems with M/S AAC at all but M/S can disturb quality especialy in high bitrates and very silent songs. Me and many other ppl know that using M/S on very high rates only disturb quality, like L/R on very low rates. AAC tecnology is more smarter and knows what doing where to put M/S where L/R, but M/S is M/S, not always good.
]Whoever told you that had absolutely no idea what they were talking about. Nero Digital supports ReplayGain, and for example foobar2000 also does.
I think about ReplyGain like MP3
]Yeah, and now people are trying 2 pass VBR and 192kbps stereo HE-AAC. Uhm, I think even "pro users" can do amazingly silly things.
That is you mistake, you should put some info in readme, And i am i ppl area who tested VBR and 2-pass because this have sense.
Reply #192
It seems that you simply do not understand what are you talking about.
Prove it. You are welcome to post ABX test results for any aac encoder you wish.
This have NO sense at all.
NOTE: The special keys are for professionals.
If you do not understand, what is vbr and what is two pass, simply do not use them.
EDIT: to help you not to make such a mistake in the future: what is  vbr, cbr and abr
Reply #193
1. Where will you keep us informed on encoder updates? Here on validated news page? AAC forum?
2. I'm not into aac: Whats supposed to be the correct file extension? mp4 or m4a?
3. Will you support tagging via command line? (useful for eac)
Reply #194
I would recommend:
- Nero ABR (-br 128000)
- Nero 2-Pass (-br 128000 -2pass)
- Nero Quality VBR (-q 0.425)
I tried the latest neroAacEnc.exe with SE test files and got:
- Nero ABR (-br 128000)         => 130.7 kbit/s
- Nero 2-Pass (-br 128000 -2pass)  => 138.8 kbit/s
- Nero Quality VBR (-q 0.462)         => 128.0 kbit/s
Confused a little bit with 2-pass bitrate. Could someone clear up?
keeping audio clear together - soundexpert.org
Reply #195
In  Nero AAC Recommended Settings topic Garf said that 2 pass is no sense  with VBR.
Ivan said that 2 pass VBR can be usefull for long samples with speech, music etc. ( i.e. soundtracks)
Reply #196
VBR mode here is q mode. Garf want certainely say that -q X -2pass is no sense simply because -br X -2pass is already a VBR mode.
Ivan say that -br X -2pass is very good for very long source like movie simply because you use VBR with very variable complexity source with good target bitrate.
Reply #197
Very good encoder, wonderful gift, thank you very much, Nero devs.
I tried it on my 'standard problem samples' harp40_1, trumpet, and herding_calls.
-q 0.425 is enough to bring me to my not-at-all-annoying level.
Going lower qualitywise I tried -q 0.4, -q 0.37, and -q 0.31. Quality scales very well with these bad samples, and even -q 0.31 is quite acceptable.
If I will ever encode for my mobile phone again I guess I will use this encoder and a quality level of -q 0.37 or similar. As for this application I also tried -br 96000 -2pass and was a bit disappointed. Quality was pretty poor.
So it's very advisable to use the -q mode. It was aware of the samples being problematic and chose an average bitrate quite high compared to what is usually expected with these quality levels.
Excellent work, thanks again.
If I were allowed a wish and if it's not much work I'd welcome very much the possibility of outputting a raw aac file which I need for my mobile phone (Nokia 6230).
As for now I have to use mp4box, and I didn't manage to integrate it into foobar, and the foobar plugin I used with 0.8.3 for this purpose isn't available any more (at least I didn't find it).
lame3995o -Q1.7 --lowpass 17
Reply #198
Tagging *seems* to be handled through libmp4v2 - part of mpeg4ip. But then supplemental non-compliant information is appended. You can't call them atoms/boxes because they non-conforming to the ISO specification. It seems like the supplemental info was added to accommodate foobar2000 0.9.x similarly non-conforming (and redundant) tagging scheme.
From what I remember, these files won't stream, and the iPod Shuffle won't be able to play them either.
Reply #199
If you use EAC, REACT v1.0 will automatically tag the output files using AtomicParsley. There are configurations for either just creating MP4 track files, or creating additional Wavpack image or tracks in one go (WV_MP4 config).
The files play nicely with Winamp, and the tags shows up fine.
Note that AtomicParsley v0.8.0 win32 executable is included with REACT, as the latest v0.8.4 is buggy.
