auCDtect - is a program for determining the authenticity of musical CD records, using the character of the audio information it contains, and predict its possible source is it an original studio record or a
reconstruction from a lossy encoded data (for example, MP3).
Current version: 0.6
Accuracy: >95% (for detecting mp3s)
[span style='font-size:7pt;line-height:100%']The following has been moved by moderation from Bern's post to save space on HA portal. (See TOS # 14 (http://www.hydrogenaudio.org/forums/index.php?showtopic=3974#entry149486))[/span]
___________________________________________________________________
Features:
- Console-based
- Supports wildcards
- Detects wavs converted from MP3-s with different quilities (starting from lame -k, till lame -alt-preset standard)
- pretesting shows detetction of some files converted from MP3-s with --alt-preset insane --alt-preset extreme and --r3mix .
- Pretesting on some reconversions from OGGs too, shows approximately 80% accuracy for -q 8 and -q 9
License: Freeware
ftp://tta.iszf.irk.ru/aucdtect-lastest.zip (http://ftp://tta.iszf.irk.ru/aucdtect-lastest.zip) (Windows version)
ftp://tta.iszf.irk.ru/aucdtect-lastest.tgz (http://ftp://tta.iszf.irk.ru/aucdtect-lastest.tgz) (Linux (i386) version)
Technical details:
http://tta.iszf.irk.ru/index.php?menu=aucd (http://tta.iszf.irk.ru/index.php?menu=aucd)
We hope, it will be useful program...
[span style='font-size:7pt;line-height:100%']Original post by atherean:[/span]
Thanks, been looking for something like this for a while, some of the russian cds i own sound suspiciously bad
It actually works pretty well, it even detected some --xtreme mpcs
However, whenever dither is selected in the output options it never detects ANY wav as coming from a lossy source.
just tried...
ripped from original cd to wav... aucdtect couldnt complain...
encoded to musepack -xtreme +xlevel
set playback options in foobar set to dither strong ATH Noise
converted to Wav PCM Fixed Point
aucdtect complains. file being from lossy source
Small test:
aucdtect -m0 *.wav
auCDtect: CD records authenticity detector, version 0.6
Copyright (c) 2004 Oleg Berngardt. All rights reserved.
Copyright (c) 2004 Alexander Djourik. All rights reserved.
Processing file: [MP3 - Dithered.wav]
Data analysis: [100%]
This track looks like a high-quality CD record
Processing file: [MP3-No Dither.wav]
This track looks like an MP3 decoded record
Processing file: [MPC - Dithered.wav]
Could not determine the source of this record
Processing file: [MPC - No Dither.wav]
Processing file: [Original.wav]
Processing file: [Vorbis - Dithered.wav]
Processing file: [Vorbis - No Dither.wav]
The MP3 was --alt-preset standard. the mpc was --xtreme -xlevel and the vorbis version was GTune 3 beta 2 @ q8. All were encoded from Original.wav and decoded with foobar2000 with and without Strong ATH noise shaping.
The problem could be that dithering adds noise in the high side of the spectrum, so the analisis of the lowpass is borked (specially since the lowpass in APS is 19Khz anyway).
I must be missing something obvious, but I can't get the program to work. I downloaded the zip file (for Windows) and put the files in their own directory. When I double-click on the auCDtect.exe nothing happens. Someone please tell me what I have missed.
I am running WinXP Pro.
John
@Johncan.
It does not have a GUI, so you need to run it from a Command Prompt!
Solaris
Solaris,
Thanks! I got it going now.
John
Nice work. Running the program directly from the command line it functions as described; however, for some reason it does not want to function with Speek's Batchenc (http://home.wanadoo.nl/~w.speek/batchenc.htm) frontend. Using the line
auCDtect <infile> on "test.wav", it gives the following message:
error: can not open file test.wav
- M.
Well,this looks like the same company-developers which make tta lossless encoder,and i remember their post here when they were saying that their compressor will compress better then all present lossless codecs-at least they were claiming that????Somebody knows more about that like where to find a plugin for foobar couse i saw the binaries on their site and i wouldnt mind to test it to see it for muself
And one for developers-Any chance of making a gui for this piece of software??
Thanks!!
Well,this looks like the same company-developers which make tta lossless encoder, and i remember their post here when they were saying that their compressor will compress better then all present lossless codecs-at least they were claiming that????
Who said? If you speek about a comparisons results.. Yes sometimes it compress better, but never always. Please, be correctly.
TTA compressor comparisons results (http://tta.corecodec.org/index.php?menu=comp)
Somebody knows more about that like where to find a plugin for foobar..
Foobar, Apollo and Winamp plugins you can found in a TTA distribution package, also these plugins are available separately
TTA compressor download page (http://tta.corecodec.org/index.php?menu=download)
Yes, all of GUIs are planed, but only 2 developers work with TTA project and we are very busy at now.
P/S: New TTA format coming soon, which is made especially for hardware support. It's will be released as a TTA1 format. Its compression characteristics corresponds to TTA 2.0 encoder results in fast mode (-e1). Also we start a work with new TTA-based format (not hardware oriented), to reach a maximum compression results.
-- Alexander
Alexander can we upload files that gave the wrong information to improve auCDtect?
auCDtect.exe only works when the wave files are in the same directory.
Otherwise I get the following error:
D:\Console\Codec>auCDtect.exe d:\temp\test.wav
Copyright © 2004 Oleg Berngardt. All rights reserved.
Copyright © 2004 Alexander Djourik. All rights reserved.
D:\Console\Codec>
Yes. Its possible. I can open FTP, but it will be better if you would post a codec name, its settings and program log with -v parameter.
Thank you. It will be corrected quickly and also I'll inform you about it in this forum.
-- Alexander
Works pretty well with the current LAME and Musepack.
But has some problems with older LAME versions (post it next time).
(http://www.netjukebox.demon.nl/share/aucdtect_01.gif)
Not good detected or "Could not determine" from 26 mp3 files:
All files decoded with LAME 3.90.3
LAME 3.86 - CBR256 (Bomfunk MC's – Freestyler)
LAME 3.88 - ABR256 (Darude - Sandstorm)
LAME 3.87 - CBR256 (Paolo Conte - Via Con Me)
LAME 3.87 - CBR256 (Stardust - The Music Sounds Better With You)
LAME 3.87 - CBR256 (Brandy & Monica - The Boy Is Mine)
LAME 3.87 - CBR256 (Chef - Chocolat salty balls)
LAME 3.87 - CBR256 (Faithless - Don't Leave)
LAME 3.87 - CBR256 (Jennifer Paige – Crush)
LAME 3.87 - CBR256 (Moloko - The Time Is Now)
LAME 3.87 - CBR256 (Nomansland - 7 Seconds)
LAME 3.87 - CBR256 (Postmen – Crisis)
LAME 3.86 - CBR256 (Propellerheads - History Repeating (Shirley Bassy))
LAME 3.87 - CBR256 (Run DMC - It's Like That)
LAME 3.87 - CBR256 (The Artful Dodger – Rewind)
LAME 3.88 - ABR256 (Zita swoon - Hot hotter hottest)
Thank you for your tests! Going to test auCDtect with all of available versions of LAME encoder.
"Could not determine" - We going to reduce the count of such messages, at now its not a error.
This is a program error if its not true. For about of 200 of the tested albums we have approx. 5% of such files. At now the algorithm has only 2 of known unstable points for standard LAME 3.92 files and both of them are already fixed, but not released because the problem with dithered files is not resolved. Please wait for a version 0.7 for this tests. I think we can to release it in a next week.
P/S:
This version (0.6) may to show a wrong result for a very small count of files, but we think it can be usefull. Thus, all of the album tracks must be tested to determine the CD source.-- Alexander
I will test the program some more when version 0.7 arrives.
It would be nice if the program can return different errorlevels for the source prediction.
I thought i saw a post before here,really apologize if it wasnt the case
Anyway just downloaded a package so will try to see how it goes.
LAME 3.86 - CBR256 (Bomfunk MC's - Freestyler)
Yes, well, this says more about the state of today's music than the state of LAME (God forbid ) or the state of the detection algorithms. How much you wanna bet some recordings come off the CD already having been compressed with a lossy codec?
Edit: Sorry, let alone have their dynamic range completely fuctwith as well.
Sorry for offtopic, about TTA:
TTA project has revived not for purposes of reaching a best results in compression.
I think it can be a goal of the next of our projects. At now we done our work with a simple and effective lossless audio format for hardware implementation. This format will be released at soon as TTA1 (based on encoder v3.0). New encoder compression characteristics corresponds to TTA v2.0 encoder results in fast mode (-e1), but its can be compiled and executed on a several different platforms, has a minimal system requirements (em85xx compatible), 30% faster, provides immediately seeking and can to decode partially corrupted files. Thus, you can to test TTA v2.0, but I recommend you to wait for the format release.
-- Alexander
D:\Console\Codec>
FIXED. Sorry for delay.
-- Alexander
hey ald,
bumping this thread to flag you down for this:
http://www.hydrogenaudio.org/show.php/showtopic/20462 (http://www.hydrogenaudio.org/show.php/showtopic/20462)
later
D:\Console\Codec>
-- Alexander
Thanks very much for the update.
Works perfect also tested with long file names and spaces in the path.
Why do you not increase the version number with this update?
I think its not required. Its not an update, just a small fixing ;-))
D:\Console\Codec>
-- Alexander
... and this fix also makes it usable with Speek's Batchenc (http://home.wanadoo.nl/~w.speek/batchenc.htm) frontend. Parameters are simply
auCDtect <infile> for default performance, or
auCDtect -m0 <infile> for "slow and most accurate."
- M.
wait, can this detect transcodes?
If you transcoded A to B and the program detected A as "a decoded MP3" to begin with (which it currently does extremely well for me), it will most certainly detect B as decoded as well.
EDIT: but not transcodes as in "looks like the file you've given me was first encoded to Musepack and then converted to MP3"; it will just give you the usual "this track looks like a decoded MP3"
Could source code be made available? A foobar plugin would be very useful IMO to check bootlegs. Saves time not having to decode.
100% agreed! Foo plugin will be great! But as far as i understand you may not need source code for making this plugin - it can work with binary, like CLI encoder, and show log somewhere in separate window or in console
Any chance seeing binary for OS X [or source btw]? That way I could bring my laptop, extract a track from someone's cd and test it out before purchasing the said cd from that person!
If you dont have any mac to compile it well I don't know if I can really help...
mat128,We plan to support Macs, but might be to the end of this year, when we will have enought financials to buy a mac . For now we support only INTELs.
About source code - unfortunately, we do not open the source code of this software
Best Regards,
Oleg Berngardt,
auCDtect developer.
auCDtect version 0.7 beta released
http://tta.iszf.irk.ru (http://tta.iszf.irk.ru)
Bern:
Would it be helpful to you to get some minidisc and digital FM results? Some friends and I are getting very high probability MPEG results on some known minidisc recordings. If auC is analyzing spectral characteristics, is there any way to refine its recognition of MD/FM compression vs. source MP3 compression?
Bern:
[a href="index.php?act=findpost&pid=227689"][{POST_SNAPBACK}][/a]
We are planning to detect more accurately some other lossy audio formats (say, OGG) ,
but for now we do not have FM or minidiscs tests in our plans.
Thank you very much for idea and help,
Best Regards,
Oleg.
Seems like a great program aucdtect. Is this project still active? I was looking for a program that could detect transcodes.
