Topic: Replaygain changes have instant effect - EXCEPT when using shortcut keys. Bug? (Read 851 times) previous topic - next topic
Hi all
As far as I know, in the past - a month or two ago and previous to that - if you changed the replaygain setting (none, track, album) "on the fly" it had no effect  It would only take effect if the track was stopped and re-started, or when the next track came on
So it was a pleasant surprise today when by accident I found that changing the RG setting does now make the change "on the fly" / instantly.  However, it only does this when using the drop down menu.  When I use shortcut keys to change the RG status it does not happen.  I tend to always use my shortcut keys, and I guess that's why I had not noticed the change.
Whether it is a bug or not I don't know.  But is it something that can be fixed?
Ta
Re: Replaygain changes have instant effect - EXCEPT when using shortcut keys. Bug?
Noted, thanks for reporting.
My pleasure.  Thanks for listening :)  And for everything else you do...
