Topic: Filter for Playlists (Read 1485 times) previous topic - next topic
I believe Facets for the Default UI provides this functionality, but I haven't had the opportunity to test it out yet. Plus I would instead like to stick with the CUI interface I already have setup. What I am looking for is a filter component that I can apply to any playlist. The built-in filter feature for CUI will only filter my entire library.
As far as I am aware, there is no component that specifically filters playlists for Columns UI. You can use Facets with CUI, but Facets can only be opened in a separate window (Library > Facets), i.e. it cannot be added to your CUI layout.
