Problems With Joint Stereo (LAME)
Reply #32 – 2003-12-08 12:36:39
1. I didn't do ONE blind test, I've spent DAYS blind testing and made something like 10 tests, with up to 14 FILES and I always hear the distortion. This sounds like you have passed the test. If you blindly tested original vs. copy with correct results 10x in a row, the probability you were guessing is 0.5^10 = 0.1 %.Sometimes (for the 128kbps samples) I can hear it in less than 3 seconds. 2. tell you where is the distortion ? Did you actually listen to the 128kbps samples I've provided ? Surely not!! you wouldn't even ask. I don't regard this as polite. I spend time answering, trying to help you to find out if the problem is caused by playback conditions used etc. and you're not willing to give a simple answer to a simple question. Have you thought of this - maybe what I use for playback (good soundcard, player with replaygain enabled) makes the problem disappear for me? In fact I've listened to the 128kbps samples and with some concentration there are several positions where I can ABX (8/8) both from the original, but mostly because of things like pre-echo and watery sounding high pitched noisy sounds (cymbals etc.). I haven't noticed any position with particularly bad distortion. So again, could you please answer my question?Still, I've started this topic with two 128kbps small samples that show a STRIKING difference between TS and JS. And I didn't get any reply about it. See above. I'd like to verify your findings and reply, but I need your reply for this.
