Topic: foo-infobox crashlog (Read 2994 times) previous topic - next topic
Hi! My foobar crashed while using the special file infobox (v1.3.6a). I looked at the fileinfo of a single MP3 file, which had the standard and a few non-standard tags. I highlighted a non-standard tag name in the list and clicked on the button above, labeled "Copy". A short moment later foobar crashed with this log. I can reproduce this behaviour.
Sorry I haven't updated to foobar 0.8.1 yet.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0124842Ch
Access violation, operation: read, address: FFFFFFFFh
Call path:
WinMain=>app_mainloop
Code bytes (0124842Ch):
012483ECh:  0F 85 B1 FD FF FF 5E 5B 5F C9 C3 56 8B 74 24 08
012483FCh:  8B CE E8 42 C1 FF FF 8D 44 24 10 C7 46 10 02 00
0124840Ch:  00 00 50 C7 06 AC B4 24 01 FF 74 24 10 56 E8 5B
0124841Ch:  FD FF FF 83 C4 0C 8B C6 5E C3 8B 4C 24 04 33 C0
0124842Ch:  38 01 74 0D 3B 44 24 08 73 07 40 80 3C 08 00 75
0124843Ch:  F3 C3 8B 4C 24 04 33 C0 66 83 39 00 74 0B 3B 44
0124844Ch:  24 08 73 05 40 41 41 EB EF C3 56 8B 74 24 0C 57
0124845Ch:  8D 46 01 50 FF 15 C4 B0 24 01 8B F8 59 85 FF 74
Stack (0068F8C8h):
0068F8A8h:  00000187 00010246 0068F8C8 0000018F
0068F8B8h:  386F006F FF6F0002 FF6F006F FF6F006F
0068F8C8h:  012484DF 00000000 FFFFFFFF 019A6520
0068F8D8h:  0124B190 00000000 01244702 00000000
0068F8E8h:  FFFFFFFF 019A6520 10002BA1 00000000
0068F8F8h:  02EC0FFE 00BB0143 00C10147 00BB0148
0068F908h:  00C10147 895A0148 000012D8 386F8926
0068F918h:  000012FA 00000000 29123B06 005C08C6
0068F928h:  16D00687 88926686 0124B190 00000000
0068F938h:  00000000 00000000 00000000 00000000
0068F948h:  068766D4 00000000 000B0000 66860000
0068F958h:  0A5F1FCA 1FCA0011 014700BB 0124B190
0068F968h:  00000000 00000000 00000000 00000000
0068F978h:  00000000 0068FA88 0124A984 00000002
0068F988h:  000003EA 01244EF0 019591B4 10002FC4
0068F998h:  019A6520 0068FA94 00000000 00000000
0068F9A8h:  00000000 00000FFE 00001A5B 0003000A
0068F9B8h:  00008AB6 000089D0 01770000 0258013D
0068F9C8h:  00000000 00000001 18BE267B 00080377
0068F9D8h:  119E89F4 00000000 00000000 00040000
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00000000, EDX: 10002FC3
ESI: 0124B190, EDI: 0068F964, EBP: 0068F988, ESP: 0068F8C8
Failed to get module/symbol info.
Version info:
foobar2000 v0.8
ANSI
Sorry,I can't reproduce this with 0.8.1 in winxp sp1.
In fact I haven't tested foo_infobox in Win98/me,but it should work
What "copy command formatting string" did you use?
"Copy" command copy the info of the highlighted track to clipboard,using formatting string saved in foo_infobox's config page.So which tag name was highlighted had no effect on "Copy" button.
Hi /\/irana - thanks for replying!
I've upgraded to foobar 0.8.1 now and I can still reproduce the crash when clicking on "Copy". The new crashlog is below. From your reply it sounds as if the problem might be unrelated to the foo_infobox, and instead be due to the foobar "Copy" command itself. So I've tried to highlight the file on playlist and click "Copy" in the context menu - this works fine.
So I assume the crash is related to foo_infobox.
Also, here's the copy string that I've got in the foobar setup.
[$num(%_playlist_number%,$len(%_playlist_total%)). ][%artist% - ]$if(%title%,['['%album%[ #[%disc%/]$num(%tracknumber%,2)]'] ']%title%,%_filename_ext%)[ '['%_length%']']
Crashlog below.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0125842Ch
Call path:
Code bytes (0125842Ch):
012583ECh:  0F 85 B1 FD FF FF 5E 5B 5F C9 C3 56 8B 74 24 08
012583FCh:  8B CE E8 42 C1 FF FF 8D 44 24 10 C7 46 10 02 00
0125840Ch:  00 00 50 C7 06 AC B4 25 01 FF 74 24 10 56 E8 5B
0125841Ch:  FD FF FF 83 C4 0C 8B C6 5E C3 8B 4C 24 04 33 C0
0125842Ch:  38 01 74 0D 3B 44 24 08 73 07 40 80 3C 08 00 75
0125843Ch:  F3 C3 8B 4C 24 04 33 C0 66 83 39 00 74 0B 3B 44
0125844Ch:  24 08 73 05 40 41 41 EB EF C3 56 8B 74 24 0C 57
0125845Ch:  8D 46 01 50 FF 15 C4 B0 25 01 8B F8 59 85 FF 74
Stack (0068F8C8h):
0068F8B8h:  0210006F FF6F0002 FF6F006F FF6F006F
0068F8C8h:  012584DF 00000000 FFFFFFFF 019B1F10
0068F8D8h:  0125B190 00000000 01254702 00000000
0068F8E8h:  FFFFFFFF 019B1F10 10002BA1 00000000
0068F8F8h:  05E412F6 00CC0143 00D20107 00CC0108
0068F908h:  00D20107 895A0108 000012D8 33A78926
0068F918h:  000012FA 00000000 0D0B3506 005C0916
0068F928h:  15D806D7 889294AE 0125B190 00000000
0068F948h:  06D794FC 00000000 000B0000 94AE0000
0068F958h:  0AAF1292 12920011 010700CC 0125B190
0068F978h:  00000000 0068FA88 0125A984 00000002
0068F988h:  000003EA 01254EF0 007DA854 10002FC4
0068F998h:  019B1F10 0068FA94 00000000 00000000
0068F9A8h:  00000000 000012F6 00001A5B 0003000A
0068F9B8h:  00008AB6 000089D0 01770000 028B00FD
0068F9C8h:  00000000 00000001 18BE267B 000803C7
Registers:
ESI: 0125B190, EDI: 0068F964, EBP: 0068F988, ESP: 0068F8C8
Crash location: "FOO_INFOBOX", loaded at 01250000h - 01263000h
Loaded modules:
DBGHELP                          loaded at 7D2A0000h - 7D2CD000h
IMAGEHLP                         loaded at 7B960000h - 7B983000h
INDICDLL                         loaded at 7B810000h - 7B817000h
IMM32                            loaded at BFE00000h - BFE04000h
FOO_DELETE                       loaded at 012E0000h - 012F3000h
FOO_SCROLL                       loaded at 012D0000h - 012D7000h
FOO_DSP_SKIP_SILENCE             loaded at 012C0000h - 012CA000h
FOO_DSP_NOGAPS                   loaded at 012B0000h - 012BA000h
FOO_DSP_CROSSFADE                loaded at 012A0000h - 012AA000h
FOO_SHUFFLE                      loaded at 01290000h - 0129E000h
FOO_DBSEARCH                     loaded at 01270000h - 0128A000h
FOO_INFOBOX                      loaded at 01250000h - 01263000h
FOO_CONVOLVE                     loaded at 01220000h - 0124C000h
FOO_MPEG4U                       loaded at 011F0000h - 0121C000h
FOO_BURNINATE                    loaded at 011E0000h - 011EB000h
FOO_OUT_DSOUND_EX                loaded at 011D0000h - 011D9000h
DSOUND                           loaded at BEAF0000h - BEB65000h
VERSION                          loaded at BFE50000h - BFE56000h
FOO_DSP_EXTRA                    loaded at 011B0000h - 011C5000h
FOO_ID3V2                        loaded at 01180000h - 011AE000h
MSVCP60                          loaded at 780C0000h - 78121000h
FOO_STFU                         loaded at 01170000h - 01177000h
FOO_UNPACK                       loaded at 00C20000h - 00C51000h
OLEAUT32                         loaded at 7FE80000h - 7FF15000h
FOO_MASSTAG                      loaded at 00C10000h - 00C20000h
FOO_ALBUMLIST                    loaded at 00C00000h - 00C0A000h
FOO_DISKWRITER                   loaded at 00BE0000h - 00BF2000h
FOO_RGSCAN                       loaded at 00BD0000h - 00BDB000h
FOO_READ_HTTP                    loaded at 00BC0000h - 00BC9000h
WS2_32                           loaded at 73710000h - 73721000h
RASAPI32                         loaded at 7F7A0000h - 7F7DD000h
WSOCK32                          loaded at 736D0000h - 736D9000h
MSWSOCK                          loaded at 77D70000h - 77D84000h
SECUR32                          loaded at 7F780000h - 7F791000h
SVRAPI                           loaded at 7F870000h - 7F878000h
MSNET32                          loaded at 7FA30000h - 7FA43000h
MSPWL32                          loaded at 7FA70000h - 7FA7A000h
TAPI32                           loaded at 7F880000h - 7F89E000h
RPCRT4                           loaded at 7FAB0000h - 7FB04000h
NETAPI32                         loaded at 7F8B0000h - 7F8B5000h
NETBIOS                          loaded at 7F750000h - 7F758000h
MPR                              loaded at 7F160000h - 7F16E000h
WS2HELP                          loaded at 73700000h - 73705000h
FOO_CONSOLE                      loaded at 00BB0000h - 00BB7000h
FOO_SPC                          loaded at 00BA0000h - 00BAF000h
FOO_MOD                          loaded at 00B30000h - 00B39000h
BASS                             loaded at 00B40000h - 00B9A000h
FOO_SPEEX                        loaded at 00B10000h - 00B28000h
FOO_WAVPACK                      loaded at 00B00000h - 00B0B000h
FOO_APE                          loaded at 00AE0000h - 00AFF000h
FOO_FLAC                         loaded at 00AC0000h - 00AD6000h
FOO_CDDA                         loaded at 00AB0000h - 00ABE000h
FOO_VIS_MANAGER                  loaded at 00AA0000h - 00AA8000h
FOO_UI_STD                       loaded at 00A80000h - 00A97000h
FOO_OUTPUT_STD                   loaded at 00A70000h - 00A79000h
FOO_INPUT_STD                    loaded at 008B0000h - 00952000h
MSACM32                          loaded at 7A1E0000h - 7A1F9000h
WINMM                            loaded at BFDD0000h - BFDE0000h
FOOBAR2000                       loaded at 00400000h - 00451000h
UTF8API                          loaded at 10000000h - 1000D000h
COMDLG32                         loaded at 7FE00000h - 7FE33000h
SHELL32                          loaded at 7FBD0000h - 7FDFE000h
SHLWAPI                          loaded at 70A70000h - 70AD5000h
MSVCRT                           loaded at 78000000h - 78046000h
COMCTL32                         loaded at BFB70000h - BFBF8000h
OLE32                            loaded at 7FF20000h - 7FFE2000h
USER32                           loaded at BFF40000h - BFF51000h
GDI32                            loaded at BFF10000h - BFF3A000h
ADVAPI32                         loaded at BFE60000h - BFE70000h
KERNEL32                         loaded at BFF60000h - BFFE3000h
Stack dump analysis:
Address: 012584DFh, location: "FOO_INFOBOX", loaded at 01250000h - 01263000h
Address: 0125B190h, location: "FOO_INFOBOX", loaded at 01250000h - 01263000h
Address: 01254702h, location: "FOO_INFOBOX", loaded at 01250000h - 01263000h
Address: 10002BA1h, location: "UTF8API", loaded at 10000000h - 1000D000h
Symbol: "uSendMessage" (+00000000h)
Address: 0125A984h, location: "FOO_INFOBOX", loaded at 01250000h - 01263000h
Address: 01254EF0h, location: "FOO_INFOBOX", loaded at 01250000h - 01263000h
Address: 10002FC4h, location: "UTF8API", loaded at 10000000h - 1000D000h
Symbol: "uSetWindowLong" (+00000000h)
Address: BFF641CFh, location: "KERNEL32", loaded at BFF60000h - BFFE3000h
Address: BFF66963h, location: "KERNEL32", loaded at BFF60000h - BFFE3000h
Address: BFFBB4C0h, location: "KERNEL32", loaded at BFF60000h - BFFE3000h
Address: BFF6152Eh, location: "KERNEL32", loaded at BFF60000h - BFFE3000h
Address: BFF61547h, location: "KERNEL32", loaded at BFF60000h - BFFE3000h
Address: 012549D7h, location: "FOO_INFOBOX", loaded at 01250000h - 01263000h
Address: 0125AA3Ch, location: "FOO_INFOBOX", loaded at 01250000h - 01263000h
Address: 01257E4Dh, location: "FOO_INFOBOX", loaded at 01250000h - 01263000h
Address: 0125AB0Ah, location: "FOO_INFOBOX", loaded at 01250000h - 01263000h
Address: BFF63613h, location: "KERNEL32", loaded at BFF60000h - BFFE3000h
Address: BFF848F7h, location: "KERNEL32", loaded at BFF60000h - BFFE3000h
Address: BFF619B8h, location: "KERNEL32", loaded at BFF60000h - BFFE3000h
Address: BFF6186Dh, location: "KERNEL32", loaded at BFF60000h - BFFE3000h
Version info:
foobar2000 v0.8.1
ANSI
Your crashlog has showed that foo_infobox is the suspicious plugin caused crash.
foo_infobox's "Copy" command doesn't use title formatting of foobar,it has its own copy formatting string in config page
Could you please post your copy formatting string of foo_infobox(preferences->components->special file info box)?
Can you reproduce this with every track or just some special tracks?
Hi again!
Found the copy command string in the foo_infobox setup page... it's as follows.
Artist:$if2(%artist%,Unknown Artist)$char(13)$char(10)
Title:$if2(%title%,Unknown Title)$char(13)$char(10)
Album:$if2(%album%,Unknown Album)$char(13)$char(10)
I think I can reproduce with any track... I've tried it with a few different tracks, and some of them had non-standard tags that I could highlight. But after you said that the highlighting doesn't matter, I picked another random track and just clicked on Special File Info and then on Copy button in the new window (as before), and it crashes. I think it happens with every track and every time I do it, but let me just try once more...
Yes, the crash happened again, with a "random" song. I don't know if the crash occurs with every song, but I've tried about five different songs now and it happened every time. If you want another crashlog or any other information, let me know!
Most of my tags are MP3.
. . . Christian
Hmm
I think it should be unrelated to audio files,I just want to confirm this.And copy string looks well.
I have tested foo_infobox with 0.8.1 in win98(using VMware),but can't reproduce.So I have no idea now
I suggest you test it with a fresh installed foobar.
If this didn't fixed carsh,then I can do nothing but say sorry
delete foo_infobox.dll from components directory or just ban "evil" copy button
Hi again - thanks for your help! I only get this crash on the windows ME machine I have at home... and I think I totally misunderstood the function of that "copy" button in any case, so I won't have a real need to use it. I think I'll just avoid clicking it, as you said
