Topic: Online CD database with cue sheets? (Read 12173 times) previous topic - next topic
I have ripped CD with EAC to a single file and I lost the cue sheet. The ape file wasm't created with track info or a tag either.
Is there an online database in existance that has cue sheets available for download? Or can I simply use the cddb info and convert it to a cue sheet? If yes, please tell me.
Regards
These are probably what you need:
Database : Cue Sheet Heaven.
CDDB -> CUE converter: CueMaster.
The latter could be introducting arbitrary gaps between tracks because CDDB info apparently do not carry information regarding gaps between tracks.
Thx a lot for the reply! That was quick.
As for the databse... I knew it existed! Hah! I've been there before... dutch server, simple design, always busy.  And now I know it's url again, thx.
Also, the tool seems to be very useful...
Maybe these infos should go into the FAQ... I think it doesn't say anything about a cue sheet database or a cddb2cue converter. I searched for it, found nothing. Not even in the other forums.
