Topic: .ACT audio format (Read 12130 times) previous topic - next topic
.ACT audio format
    There is several mp3 flash players with recording functions, and several of them record in a unknown format with the extension .ACT. The only tool I saw which can convert this files to .WAV is in this url: http://www.geocities.com/sound_converter/ (I think there is more, but this seems to be the "standard" one)
    As a linux user, I want to know if there is another tools for treating .ACT files in my O.S. And I want to know what kind of quality/compression can deliver this format, specifications, who developed it, etc.
Thanks in advance.
.ACT audio format
Stupid question, have you tried renaming to .mp3 or .wav? I had a player that simply renamed the extension to something else.
Kristian
.ACT audio format
Don´t know much about the format, but I have the cheap & popular "S1 MP3 Player" and also wondered what´s up with this ACT format. Quality is quite bad ( it´s 8kbps only!), but you can record much more time than using 32kbps IMA ADPCM.
I only know about the Sound Convert app that came with the player (Windows only i guess). This tool decodes ACT files to much bigger WAV files (foobar2000 says 128kbps PCM). The decoded WAV files are approximately 16 times the size of the original ACT (128kbps/8kbps=16).
It is kind of a useless format to me, unless you have a flash player with very little memory. I can record around 16 hours of audio encoded to 32kbps IMA ADPCM with a small 245MB player (256MB - system files=245MB).
Yesterday I had to use ACT because I didn´t want to delete a lot of important data I had on the player. I had free memory for only 13 minutes of 32kbps IMA ADPCM recordings, but for 8kbps ACT I had around 1 hour left.
.ACT audio format
Kristian
[a href="index.php?act=findpost&pid=344109"][{POST_SNAPBACK}][/a]
That´s not the kind of attitude one expects from a regular HA member.
In fact, renaming to mp3 or wav is completely useless.
.ACT audio format
Megaman, I think kritip was saying that his was a stupid question.
Clarification: I.e.: "have you tried renaming to .mp3 or .wav?" is a stupid question.
I'm on a horse.
.ACT audio format
@ Megaman -- Synthetic Soul was correct, i was mearly implying that my suggestion was a bit of a stupid one, not that Reztho was stupid
Only reason i suggested it was because it worked for me with an old cheap chinese flash player i had a while back, granted the file extension was different but i didn't think it hurt to mention it.
Kristian
.ACT audio format
Kristian
[a href="index.php?act=findpost&pid=344121"][{POST_SNAPBACK}][/a]
Sorry, I misunderstood your post in a really "stupid" way  . Sometimes happens when posting in foreign language forums.
.ACT audio format
Thanks for the fast responses!
Yes, ACT is crap I know (because of the very low bitrate for sure), but I think it's very very rare than there is no software in Linux for treating those files. That format seems to be very common among cheap and non-really cheap mp3 flash players. And at least I don't want to refuse the possibility to record things in ACT (if I in need of, like Megaman did) because of the software.
I think I must try Wine with the Windows tools after all.
.ACT audio format
Greetings...
Does anyone know where an ACT to WAV convertor is on the web?
I tried to use Konvertor, and it didn't work...
Also, the JP's version is in chinese, and that programme didn't work either.
.ACT audio format
Can you upload some very small file anywhere? I want to look at it little bit closer.
.ACT audio format
Contact me via email, and I'll send you a file...
What is looks like to me, when I drop it into a text editor is RIFF WAV format? I don't know.  At least that's what it says when I look at it.  I haven't tried fiddling with it, by changing it's .EXT.
John "Imagicka" Blackthorne
MSN: Imagicka @ hotmail    ICQ: 13682963
AOL: Imagicka  Yahoo: Imagicka23
GoogleTalk: Imagicka23 @ gmail
http://www.CajunNights.com
http://www.zephn.com/cgi-bin/ib/ikonboard.cgi
http://www.enworld.org      http://rpol.net/
.ACT audio format
Rats. Now I have the same problem. I tried "Sound Convertor 2.0" it just doesn't work (complained of an unregistered OCX, tried downloading and registering the OCX and there's an error).
Any tips?
.ACT audio format
Thanks! I'll try 'em one-by-one and see if I can hit the jackpot
If I fail, well, there's always the souncard line-in...
.ACT audio format
anything work out for ya?
perhaps i can do some pruning
later
