Topic: Foobar v2.24.1: FLAC, unsupported format or corrupted file (Read 2798 times) previous topic - next topic
Hey,
I have a problem with a few files from a certain single. Foobar doesn't play them at all, it reports a flac stream error, unsupported format or corrupted file. After removing any metadata with MP3TAG the file becomes readable. flac.exe reports something like this.
04-vibeout-im_just_more_(discorockerz_remix)-repack.flac: *** Got error code 4:FLAC__STREAM_DECODER_ERROR_STATUS_BAD_METADATA
04-vibeout-im_just_more_(discorockerz_remix)-repack.flac: ERROR while decoding metadata
                                                          state = FLAC__STREAM_DECODER_SEARCH_FOR_FRAME_SYNC
Below is a link to one of the files. What's metadata wrong with it?
Is there a way to workaround the problem or do I have to edit the file?
Moderator: removed link
Re: Foobar v2.24.1: FLAC, unsupported format or corrupted file
Another case of FLAC 1.4.x becoming stricter and preventing decoding. I can understand encoder being strict and refusing to encode nonsense, but I don't like that decoder fails to handle so many files in circulation. Flac -t using v1.3.x or v1.2.x don't complain anything about the file and could happily decode it.
If you don't want to touch the files and indeed want a workaround, you could install FFmpeg Decoder Wrapper and configure FLAC to be handled by the wrapper.
Or use command line decoder to decode with flac 1.3x. Thanks.
Regardless, I'm curious what exactly he doesn't like and what's wrong with these tags.
Interestingly, metaflac does not complain.
Of course if decoders are not zealous enough, then someone malicious could suitably corrupted flac file that has "a flac stream" hidden in metadata, and so that decoder X plays this part and decoder Y plays that part - but it is getting questionable that not even flac -F can get anything out of something that used to decode just fine.
@ktf  ... something for 1.5?
Just to be on the safe side, I won't delete the file from Dropbox for the foreseeable future so it can be used for further research.
And I don't want to be responsible for yet another security hole somewhere. This file is in fact a perfect example where a naive parser/decoder could run into buffer overflow problems.
The case here: the Vorbis comment block says there are only 11 tags, while there are in fact 19. When I change the byte at offset 0x34B from 0x0B to 0x13, the file parses correctly, and metaflac shows 19 tags instead of 11.
A naive parser could reserve space for 11 tags, but when processing the 12th tag (as the metadata block length says it isn't finished yet) you get a heap overflow -> security hole. Of course one could, like FLAC 1.3.x just assume the block length is correct, but it could very well be the number of tags is correct instead.
I agree the `flac` command line utility should be able to salvage the audio, which it currently cannot.
There is no chance of buffer overflow if you verify the indexes at every step. Like the comment parser super carefully does.
Old FLAC just skipped over the extra bytes. In my opinion the correct behavior would be to see that there is extra comment data and try to parse those too.
I would like FLAC to do the right thing too, but salvaging broken metadata is at the bottom of my list. It is hard to get right, there are a lot of possible scenarios and I don't have a lot of time to work on FLAC. I've been working for months to get the last bugs out of the multithreading code and the code to parse chained files, and fuzzing keeps throwing new ones at me.
So, I could use a little help. If someone wants to improve corrupt metadata handling, I would gladly accept PRs on GitHub or patches over email.
