Topic: fb2k x64 has white screens. How do I make it dark? (Read 1937 times) previous topic - next topic
I don't know why but fb2k 64-bit Standard installation installs with white screens. fb2k 64-bit Portable installation has dark screens. The screens on fb2k 32-bit are dark on both Standard and Portable.
Under Default User Interface/Colors and Fonts/Dark Mode it says "not supported on this system".  Why would the x64 not support Dark Mode on latest Windows 10 but the portable install does? Makes no sense.
Re: fb2k x64 has white screens. How do I make it dark?
Sounds like you have for some reason right clicked on the foobar2000 icon, opened the properties, navigated to Compatibility tab, and configured it to run in older OS compatibility mode. If that happened, perhaps try undoing the compatibility mode adjustment and try again.
You are correct. But I have no idea how it got set to that. I wasn't using the shortcut, I was using foobar2000.exe in the Program Files directory. Plus I deleted the previous install and installed 64_v2.24.1 from scratch.
Anyway, that was the issue. Thanks.
