Topic: Bitcompare Speed Issue (Read 2022 times) previous topic - next topic
Hello everyone
I have noticed that the bitcompare function in version 2.24 (64-bit) is significantly slower compared to version 1.6.18, approximately half the speed of the latter.
I saw that the changelog for foobar2000 mentioned:
New major revision of bitcompare code, improved performance of 64-bit build.
I wonder if this is related?
Thank you.
Re: Bitcompare Speed Issue
32-bit foobar2000 is faster than 64-bit foobar2000 in many audio related things. The internal audio format in 64-bit foobar2000 is also more precise, it uses 64-bit floating point samples. There is twice the amount of data to move and tricks that allowed for example processing four samples at once in 32-bit world may now only be able to process two samples at once.
But that particular changelog entry relates to the fact that Binary Comparator got almost twice as fast in 64-bit foobar2000 after the optimizations.
so 32bit foobar2000 uses floats and 64bit foobar2000 uses doubles?
Yes. Though if we are accurate, very old 32-bit foobar2000 versions before v0.9 also used doubles.
Thank you for providing useful information. I've learned more about foobar2000.
