Appreciate suggestions on 3rd party drivers for the X-Fi Titanium that might improve recording sound? I've never tried any, but read some swear by them.
Opinions of real value of 3rd party drivers for cards in this class?
I really don't see the point. Is something wrong with the recording made with original drivers?
Not that I know of. But that means nothing. I'm only repeating what I've read or been told directly. I wouldn't know if made a diff until tried it, so asking for others' experience w/ using them.
Assume it's along same lines as 3rd party software for DSL routers that allow using open source firmware (like some Linksys). Advanced users swear by those as well, claiming better control & even somewhat increased throughput.
Long time ago I used kx drivers with Soundblaster Live. Except for ASIO support, nothing else was really different.
AFAIK, those 3rd party 'driver' bundles made for Creative cards are rather hacks for to enable features in cards not having them enabled by the manufacturer than improvements in driver level (especially when talking 'bout quality improvements).
I would use ASIO, WDM/KS or WASAPI (Win7) driver models for recording .... but, that also depends on what type of audio I would be recording (live instruments into a sequencer/multitracking software (ASIO), audio from TT/Cassette/etc. similiar external devices (any available driver model), etc.).
Juha
Juha
Thanks all.
For recording LPs w/ best noise suppression results & least impact on music, are there "gold standards?" I suppose the most accurate would be record w/ no suppression, then test various prgms / techniques. I have the Nero 9 full suite - there are many others, even free.
For extracting CD audio, EAC seems to have more options than Nero. Though I've never compared note for note, Nero at it's best settings w/ EAC on its highest accuracy for ripping a CD w/ some scratches.
Re: ASIO - I'm familiar w/ concept of latency & read up a bit on ASIO4all. As mentioned, may not be much of an issue recording from LP / similar analog sources, or digital input directly to sound card. That's my main focus now, though may do some live recording later.
This card & driver ver supports ASIO. Question is, in many recent, full featured recording prgms, would ASIO be an option to enable / disable, or just "used" by the software, if supported? I've looked at a couple & documentation & don't find reference. Just X-Fi's specs that it supports ASIO.
It's an option in those software that are ASIO compatible.
Here's an example:
(http://img59.imageshack.us/img59/8265/audiodeviceoptions.th.jpg) (http://img59.imageshack.us/i/audiodeviceoptions.jpg/)
Audacity as for an example, isn't ASIO compatible recording software.
Juha
Thanks Juha,
Very interesting. I'm not an expert on (modern) recording software - obviously. Back in the day - way back... on equipment, maybe.
Which prgm is in the posted image?
I've looked most of Nero 10's documentation & in spite of its bells / whistles, find nothing. Nothing in the software incl w/ the X-Fi card (not surprising). May not need that feature so much now, just curious for future.
It's just a player software called Native Instruments TRAKTOR... .
AFAIK, Nero isn't ASIO compatible software ... same state with the recording software bundled with X-Fi (though, I have not checked if the new Wave Studio is ASIO compatible).
If you don't have some other multitracking/sequencer software (from Cakewalk, Steinberg, Ableton, etc.) in hands, I suggest to start with Coscos Reaper (http://www.reaper.fm/) which is easy to use and capable ASIO compatible software.
Juha
