Linear PCM is crap, SACD is best
Reply #42 – 2004-04-02 11:59:43
I am really starting to wonder if this guy is for real. Yes, I am real but also a guy who doesn't care to row against streams. suprisingly ignorant of basic topics Well, a basic topic in LPCM is bitresolution and that is (and only that) my concern. This is an example of rowing against streams. I wil not debate if the Dynamic Range is large enough, because that is the case already in 16bit/44k1. Dynamic Range is more than enough, apractical number of a DA used in audio is 117 dB for a 24 bits system and this much more than enough.The resulting wave of a LPCM sampling process has a limited bandwidth (Fs/2) and raised noise floor (due to sample quantisation). That is all. If one applies the sampling theorem and assumes that an infinite number of bits is used (NOT TO CREATE Dynamic Range, but to be able to reconstruct the original waveform) and ideal filtering is applied. Well, the latter constraint is obviously reached in 192 or 96kHz systems, or in oversampled systems. To emphasis it one more time, my (and a lot of other researchers oround here) problem with LPCM is the limited number of bits to sample low-level signals. Large signals are out of the question, here is LPCM good enough.Signals professor He also knows that low-level content is heavily distorted in LPCM. Here, where the CD is invented, the assumption was made that the probabilty of those low-level content is that low that it could be ignored. At that time, the number of bits was limited and these two arguments form the basis for the CD as it is. Very soon after the introduction of the CD this flaw was "recognized" by high-end audio people. I know of one small company (because I worked there) which was sewed in court by trying to spread this word. As a consequence this small company had to be silent for 3 years. They also row against streams.Even on playback this holds no water as DVDA still has the better characteristics. I'm quite sure that what comes out of your SACD won't bear much resemblance to what went in, especially at those high frequencies you were just ealier claiming to be so important. The entire working of DSD is based on it. Next week I will try to get some examples of such a wave, sampled with DSD technology. Basicaly, the working principle of DSD is as follows: you have a comparator and this will compare the input signal with a sawtooth. As long as the signal is above the hysterese of this comparator, it will detect the input signal. And since the frequency is insane high (2.8MHz) every subtle change at any level will be detected. This also causes a lot of ultrasonic crap and this is a drawback. Modern systems however can accomodate with that and it is doable. Research can help to think of systems to reduce these artifacts.We are talking about a 144dB dynamic range from DC ~ 96kHz for goodness sake Yes, but this at his best (the 144 dB) and it shows clearly that many peolpe see in Dynamic Range the answer to all their problems. Today, in consumer DAC's the DSD and 24bits LPCM modes has a Dynamic Range of 114 and 117 dB respectively (CS4398). This can be a political statement of coarse, but I do believe it since there is also some electronics involved after the DA itself. Another "proof" can be found in a completely different type of application. In our lab we deal with systems where modulation and demodulation is done with I/Q signals. Has nothing to do with audio, but here is where the limitation of LPCM comes in. I and Q signals (bandpass representations of an RF signal) must be exactly 90 degrees out of fase, otherwise demodulation is crapped. To test a transceiver you need an I/Q signal generation and these signals must have excellent quality, because degration of your DeviceUnderTest is to be investigated. One additional BNC connector in the leads towards the I/Q modulator is enough to spoil a measurement, to give an idea of how exact things must be. It is found that if the digital stream is not with full resolution, no measurement can be done. The setup is: digital generated file->DAC->I/Q modulator. Experiment proves that if one uses signals below 0 dBFS, the mismatch between the signals is (slightly) different than 90 degrees. The lower the signal the more mismatch. So this must be rejected:That is all. However different the waves may look, these are the only differences. since there is also a difference in time (phase) and/or amplitude... Oversampling is used to minimize this problem, not to overcome. cheers, Jacco
