Topic: downsampling lossless before converting to MP3 (Read 4196 times) previous topic - next topic
hell everyone,
I know that bit depth reduction is pretty much useless to do before converting from lossless to MP3; what about downsampling? for example, if I want a 88.2kHz MP3, and I have a 96kHz source, will LAME downsample, or do everything (including low pass filtering) in the frequency space? Will it introduce artefacts, than could be avoided with another program? (eg sox)
Thanks for the answers!
MP3 does not support that sample rate.  For the sake of discussion, I'll pretend you said one of the supported rates (8kHz, 11.025kHz, 12kHz, 16kHz, 22.05kHz, 24kHz, 32kHz, 44.1kHz, or 48kHz).
The last time I checked, LAME has a separate sample rate converter and lowpass, although there was interest in combining the two. As far as I know, the encoding portion that operates after the SRC and lowpass takes its input in the time domain, not the frequency domain.
I suspect the MP3 compression will introduce more artifacts than the SRC/lowpass used by LAME. However, you could use an external program to perform those steps if you want to compare.
thank you for your answer
EDIT: removed some useless comment
So what? Max. supported samplerate for MP3 is 48 kHz  (which can contain frequencies up to 24 kHz).
  I'm tired/hungry, and read that answer too fast...sorry for the confusion
