Topic: DevProposal: mono.wav -> mono.ogg (Read 4583 times) previous topic - next topic
Hello,
I would find it very usefull if one could use the ogg codec also for:
mono.waves -> mono.oggs
(mono.oggs  -> mono.waves)
(mono.oggs  -> stereo.waves)
klf
Your post makes no sense to me. What is it you want?
Why would you want to decode a mono ogg to stereo wave?
For processing? Just duplicate channels!
And you make mono Vorbis files from mono waves by default.
ruxvilti'a
You encode mono WAVs the same way you encode stereo WAVs. No change for decoding mono Oggs either.
I can't see why you would want to decode a mono Ogg to a stereo WAV.
You might want to go here to pick up some CLI encoders/decoders and some nice GUIs.
Edit: Why is this in the dev forum?
Hard work might not kill you, but why take any chances?
I know exactly one reason to add this function:
for burning mono files to CD as CD Audio.
ruxvilti'a
Hello,
@AstralStorm: wright - this ONE thing is what I want to do with mono oggs: burning.
... and I did not find a way to duplicate channels in an easy way.
@anthrax: hmmh... When I want to decode mono wave with oggdropXP 1.6.11e I get the error, that it only processes stereo waves?!
I have some recording I made (own songs) in mono that I can only ogg, when I insert them in an music-productions App and downmix them again, which is quit a hassle...
Greetz,
KLF
PS: somebody of the german ogg-community told me to send this to the dev forum (for to reach john33?).
dBpowerAMP Music Converter will convert a mono wave to Stereo ogg, no problems.
Hello,
oggdropXPd 1.7, and most of it's predecessors, will encode a mono wave file to a mono ogg file and back to a mono wave file, without error.
Correct me if I'm wrong, but you want to decode a mono ogg file to a 2 channel mono/mono file?
Hello,
@john:
I have now downloaded&installed oggdropXPd 1.7 - now it accepts mono waves! :-)
No - not quite... I want to decode the mono oggs to 16/44,1k stereo interleave wave - the format to burn them on CD. It would be great if I have this Decoding option in my oggdropXP, but if this isn`t possible...
@spoon:
... I will have a look at the dBpowerAMP Music Converter.
Greetings,
klf
Hello,
@john:
I think we are talking about the same thing.  You want the decoded mono stream to be written into both channels, ie mono stream copied into left channel and right channel?
As long as it's sampled at 44.1kHz, 16-bits, then most CD writing applications will happily burn a mono .wav file onto an audio CD, converting it to "stereo" as it goes. This is one kind of on-the-fly conversion that is easy and trivial, and you can trust almost any CD writing software to do it correctly.
Has someone told you that you must convert first, or have you found that your CD writing software will not accept mono 44.1kHz 16-bit .wavs?
David.
