Exact Audio Copy v1.5 released
Homepage
http://www.exactaudiocopy.de/
Download
http://www.exactaudiocopy.de/en/index.php/resources/download/
Changelog:
- Fixed a problem with M3U8 files
- Fixed a problem with Log file creation
- Fixed a problem in the AcousticID plugin
No new features. This release did address the following reported issues:
'[Test & ]Copy Image & Create CUE Sheet' and 'Copy Range' created an extraction log file that included the 1st encoder only * (https://hydrogenaud.io/index.php?msg=979375)
EAC 1.4 produces faulty playlists (https://hydrogenaud.io/index.php?topic=118834.0)
EAC v1.4 always writes log for 2nd compressor (https://hydrogenaud.io/index.php?topic=118811.0)
Checking "Replace spaces by underscores" on Filename tab in the EAC options, spaces in the export directory name will also be converted to underscores (created a new directory). It was not converted in version 1.3. I don't know if it's a specification or a bug, but it's inconvenient :'(
e.g.
version 1.3: /foo bar/filename_01.wav
version 1.5: /foo_bar/filename_01.wav
Log files are output to the correct directory (version 1.5: /foo bar/logfile.log)
Reported. This is a bug. Though inconvenient, the fix may be shelved until additional fixes/features necessitate another release.
Thanks for reporting on my behalf :)
