Topic: 'command-line executable' for aotuv? (Read 9936 times) previous topic - next topic
I just compiled aotuv beta 5 from source using your guide.  I used prefix=/usr/local
It says to
Call oggenc as
LD_PRELOAD=`echo /usr/local/lib/libvorbis*.so` oggenc -q4 foo.wav
Anyone know how to use it with a ripper like Grip?  I don't know what to enter for the command-line executable in the config section.  I have a static linux binary aotuv, but I'd rather us the one I compiled (on 64-bit ubuntu) since it's a lot faster.
I'd use "LD_LIBRARY_PATH=/usr/local/lib oggenc" instead (without the double quotes).
Doesn't work.
I guess I'll just have to be satisfied with the static binary or update my libvorbis libraries to use the aotuvb5 patch.
There's another way: make a wrapper script:
/usr/local/bin/aotuv
#!/bin/sh
LD_PRELOAD=`echo /usr/local/lib/libvorbis*.so` oggenc "$@"
chmod 755 /usr/local/bin/aotuv and use that path in grip.
another way is to compile vorbis-tools using the aotuv libs rather than the official libs, breakout oggenc and call it oggenc-aotuv.
that's what i did for rarewares to make it "easy"
later
#!/bin/sh
Thanks again.
The shell script seems to work great--it calls oggenc with the aotuv libs as it should at correct settings.  But then I check the file with ogginfo:
...Processing file "slavonic_dances_op72_no1__odzemek_molto_vivace.ogg"...
Warning: Hole in data found at approximate offset 4500 bytes. Corrupted ogg.
New logical stream (#1, serial: 09d5e62e): type vorbis
Vorbis headers parsed for stream 1, information follows...
Version: 0
Vendor: AO; aoTuV b5 [20061024] (based on Xiph.Org's libVorbis)
Channels: 2
Rate: 44100...
I ran it a number of times with different tracks. No change.  But if I run the command from the terminal, I get a perfect ogg, no error.
Strange.  I've made the script a couple of times now, and still the error.
I'll try your way next.
I think I may have found the reason for that error.
Grip is ripping the wavs and encoding fine, but something is happening in the tagging stage to change the mime-type to mp3!
In nautilus that's what it says, 'Type: MP3'...MIME type: audio/mpeg. Weird.
Everything else (media players, etc) show 'ogg'.  When did that start happening?  I never noticed because I have the browser set to view icons instead of list.  Good thing I use mostly abcde and eac!  Hope it's not a big deal otherwise and correctable.
yep, the id3v2 tags option was enabled for some reason.  That's the problem.
later
Can I ask you about how you did it exactly?
This is my guess on how you did it:
First you compiled the aotuv-libs by running
./configure --disable-shared && make
. Then you downloaded vorbis-tools from http://www.xiph.org/downloads/ and compiled oggenc in vorbis-tools by running
./configure --disable-shared CPPFLAGS=-I[PathToAoTuv]/include LDFLAGS=-L[PathToAoTuv]/lib --disable-ogg123--disable-oggdec--disable-ogginfo--disable-vcut && make
, where [PathToAoTuv] is where aotuv-libs was extracted.
Is this correct?
And can I check that the compiled oggenc uses aotuv by running "ogginfo [file]", where [file] is a file encoded with the new oggenc?
Regards
