Topic: Questions about VBR Opus (Read 8661 times) previous topic - next topic
I'm curious about Opus VBR mode, every thing I throw at it, the bitrate tends around my target bitrate very tightly +-5%, unlike say vorbis or lame which wildly fluctuate, 'ball park' style bitrates.
Here is an extreme example:
sox.exe -n -t sox - synth 30 brownnoise brownnoise gain -3 lowpass 180 | ffmpeg -f sox -i - -q:a 10 -y output.ogg
This generates 30 seconds of brownnoise with a lowpass filter over the top, sounds like the warp engine of the Enterprise.
Basically Ogg vorbis at quality 10, nominal 500kbps~, but the actual output is only 183.8kbps because of the simplicity of the audio sample.
Opus on the other hand:
sox.exe -n -t sox - synth 30 brownnoise brownnoise gain -3 lowpass 180 | ffmpeg -f sox -i - -b:a 510k -vbr on -y output.opus
The output is 499.2kbps, this is not exactly what I expected vbr mode to do.
too me this looks like ABR, does Opus' VBR just need more time to mature?
Opus VBR varies as expected for me.  Probably an ffmpeg issue.  What version of libopus do you have?  Have you tried with opusenc?  libopus 1.1 supports unconstraint VBR (-vbr), constrained VBR (-cbr), and CBR (--hard-cbr).  Older versions did not support true unconstrained VBR.
opusenc does the same thing, at least on my specific example, I tried running a movie soundtrack through opusenc and got a bitrate of about 60kbps for 64kbps, but the 'instant bitrates' were 30-130kbps, Still find it odd that it allocates so much to such a similar sample.
By "similar sample" you mean brown noise?  I wouldn't call noise very similar to a movie sound track at all.  Noise has very high entropy.
Opus is not at all like Vorbis, so it's no surprise that the VBR behavior differs between the two. Try encoding something else, you might be surprised by the results.
Here's a graph of the bitrates of each track from two CDs encoded at a target bitrate of 64kbps. I chose these CDs specifically for their variety of genres, so these results might be exaggerated somewhat. However, it should be apparent that there is (almost?) no correlation between the VBR behaviors of these codecs.
(Bonus if you can guess what type of music the top-left point represents.)
Classic  or some 8 bit computer game music
While Opus has some similarity with AAC and Vorbis it also has come important differences.  Even two encoders of the same format can have different VBR approaches.
Vegetarian Progressive Metal?
Sorry guys I meant simple (for Vorbis), not similar. My brain had a fart.
I was considering noise had pretty high entropy, but at the same time Vorbis didn't struggle nearly as much.
Maybe some more sane settings will produce far lower bitrates.
As someone already pointed out, if you were using a 1.0.x encoder, then you'll get nearly no variation on the final size because 1.0.x never had true unconstrained VBR, only ABR. OTOH, with 1.1.x, you'll see large differences between files. Noise should end up at a lower bitrate and tonal content should end up at a higher bitrate.
Definitely the latest opusenc from their website, 0.1.9, and a fairly new version of ffmpeg (build within days of the post), both output extremely high 500kbps~ streams.
Here's the final bitrates from encoding three samples: lowpassed brown noise, the 8-bit game music from before, and something loud with lots of distortion and dubstep-like bass.
        Brown    8-bit     Loud
  Rate  noise    Nintendo  music
     8    8.018    9.012     7.219
    12   12.00    11.94     11.75
    16   16.01    15.63     15.53
    24   23.81    25.30     23.80
    32   32.01    33.97     31.98
    48   47.47    61.61     46.07
    64   63.03    91.31     57.46
    96   95.14   129.6      84.81
   128  126.1    163.0     114.0
   192  189.4    232.4     174.7
   256  250.5    291.8     235.8
   384  378.5    415.7     360.2
   512  502.3    501.0     479.9
This looks normal to me. If you don't see enough variation in bitrate, choose something lower than 510kbps.
Or, as I said earlier:
Try encoding something else.
