foobar20000 0.9.5 beta 9 has been released.
Download foobar2000 0.9.5 beta 9 (http://www.foobar2000.org/beta/index.html)
Changelog (http://foobar2000.org/changelog.html)
Known issues / issues fixed in beta 9 (http://www.hydrogenaudio.org/forums/index.php?showtopic=58351)
Feature proposals (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=58351&view=findpost&p=525549)
HighlightsNew Default User InterfaceThe new Default User Interface allows complex layout using building blocks that are called UI Elements. The Default User Interface puts a focus on instant usability and easy configuration; it deliberately does not offer total visual customization and reduces the use of title formatting. The Quick Appearance Setup window lets users choose from a set of predefined layouts, color schemes, and playlist configurations. The layout editing mode and scratchboxes allow in-place configuration of the layout with Copy & Paste functionality. The current configuration can be exported as a theme for archiving or transfer to another foobar2000 installation.
(http://foobar2000.org/releasenotes-095/images/default_user_interface.th.png) (http://foobar2000.org/releasenotes-095/images/default_user_interface.png) (http://foobar2000.org/releasenotes-095/images/default_user_interface2.th.png) (http://foobar2000.org/releasenotes-095/images/default_user_interface2.png) (http://foobar2000.org/releasenotes-095/images/default_user_interface3.th.png) (http://foobar2000.org/releasenotes-095/images/default_user_interface3.png) (http://foobar2000.org/releasenotes-095/images/default_user_interface4.th.png) (http://foobar2000.org/releasenotes-095/images/default_user_interface4.png) (http://foobar2000.org/releasenotes-095/images/default_user_interface5.th.png) (http://foobar2000.org/releasenotes-095/images/default_user_interface5.png)
The following UI Elements are included by default:
- Containers: horizontal and vertical Splitter, Tabs, Playlist Tabs, Toolbar Header
- Media Library Viewers: Album List
- Playlist Renderers: Playlist View
- Selection Properties: Album Art Viewer, Selection Properties
- Utility: Console, Equalizer, Playlist Manager
ContainersContainers provide the ability to structure the main window layout. Splitters arrange two elements horizontally or vertically. Tabs allow switching between multiple elements. The Playlist Tabs element displays a tab for each playlist and hosts a single element which is normally a playlist view. The Toolbar Header element allows to position a toolbar area above or below another element.
(http://foobar2000.org/releasenotes-095/images/container_example.th.png) (http://foobar2000.org/releasenotes-095/images/container_example.png)
Quick Appearance SetupThe Quick Appearance Setup window can be opened from the main menu (View > Layout > Quick Setup) or from the Default User Interface preferences page (Quick Setup button in the Theme Management section).
(http://foobar2000.org/releasenotes-095/images/quick_appearance_setup.th.png) (http://foobar2000.org/releasenotes-095/images/quick_appearance_setup.png)
Spectrum (UI Element)The Spectrum element displays a spectrogram visualisation. By default it uses global theme colors, but it can also be configured to use custom colors.
(http://foobar2000.org/releasenotes-095/images/spectrum_2.th.png) (http://foobar2000.org/releasenotes-095/images/spectrum_2.png)
Toolbar Header (UI Element)The Toolbar Header element is a container that hosts a single element and displays a toolbar area with one or more toolbars above or below it.
(http://foobar2000.org/releasenotes-095/images/toolbar_header.th.png) (http://foobar2000.org/releasenotes-095/images/toolbar_header.png)
File Operations (Component)The File Operations component is used to rename, copy and move files according to specified schemes. Those schemes can be saved as presets and are accessible from the context menu. This component replaces the corresponding features of the deprecated Masstagger component.
(http://foobar2000.org/releasenotes-095/images/file_operations_setup.th.png) (http://foobar2000.org/releasenotes-095/images/file_operations_setup.png)
Improved File Properties DialogThe improved Properties Dialog now integrates tagging-features which previously were part of the Masstagger.
For a full overview of what's new, see the release notes page (http://foobar2000.org/releasenotes-095/releasenotes.html).
Upgrade from previous versionsThese upgrade notes extend the general upgrade notes from the FAQ (http://www.foobar2000.org/FAQ.html).
You can install foobar2000 0.9.5 on top of an existing foobar2000 0.9.x installation.
Component compatibilityfoobar2000 0.9.5 is compatible with most components made for older 0.9.x versions of foobar2000 with the following exceptions:
- It is not recommended to mix official component DLLs from 0.9.5 with those from earlier versions due to inter-component dependencies in the new version.
- foo_pqview (Playback Queue Viewer): The new version will not load foo_common as it contains a prototype for global appearance configuration that is unused but could confuse users. Users of foo_pqview should upgrade to a 0.9.5 compatible version.
- foo_utils (Utilities): The Copy & Paste functions from foo_utils have been integrated into the core. Users of foo_utils should either upgrade to a 0.9.5 compatible version or remove the component if they do not require the component's additional functions.
Updated versions of
foo_pqview and
foo_utils are available from here (http://foosion.foobar2000.org/0.9.5/).
Configuration, media library, and playlistsThe media library and existing playlists are unaffected by upgrading to 0.9.5. The configuration should be unaffected except for Default User Interface settings and certain keyboard shortcuts.
Default User Interface and Title FormattingThe title formatting strings previously located on the Display > Title Formatting can now be found on the Advanced preferences page in the Display / Legacy title formatting settings branch. These strings are no longer used by the new Default User Interface.
Keyboard shortcutsIn order to minimize potential interference with typing in the new Default User Interface, existing single-letter shortcuts without Alt or Control modifier keys are removed on the first run after installing 0.9.5. Manually re-adding these shortcuts, while possible, is not recommended due to the issues stated above.
Requires XP or newer.
Looks like I need to wait until this evening to check on my laptop.
Sounds interesting though.
Wow, this is an amazing release
unbelievable
Wow, this is awesome.
As much as I've loved PanelsUI, I'd gladly switch to an interface that focuses on usability and reliability.
This is just what foobar needs. Thanks for listening to your user base for this one.
New Album List component
*Updates automatically with Media Library content changes (“Refresh” command no longer needed)
thank you!
Oh my gosh! What a surprise for a big fan of foobar2000! Thank you!
This new standard interface enriched with built-in presets is really a great improvement! Now I get foobar2000 looks pleasant without any effort (I didn't followed any UI improvement since two years and I didn't have the time to understand this whole scripting & components system).
In my opinion this is the most important release since years... maybe the most important one ever.
Congrats, and thank you very much
This version is one of those Pringles moments; Once you pop, you can't stop. The usability is great (not that I had any problems with previous versions either) and all the new features in default UI are great.
Thanks Peter
Ha ha ha I just have a thought "Foobar developer must secretly doing something big for sure. base on the hint here and there." and BOOM this come out.
And it's great
It didnt made it into the releasenotes, but its worth mentioning, how easy it is now to create autoplaylists via Albumlist.
Sure, it's a very small improvement. But they have a loooooooooong way to go if they wanna match up to panels or columns ui. The new ui looks far from elegant.
This is nice surprise to see a new beta, and wow! what a great beta it is!
I was never a big fan of columns/panels UI, but the disadvantages of those two are gone in 0.9.5. It works all so great together and now it's really easy to set up.
The scratchbox is great, too! I also like the Facets plugin.
Well done!
"They" have no interest in doing that. Maybe you didn't read the UI intro properly
FLAC library updated on 0.95b1.
Just for fun: one decoding speed benchmark based on one single CDImage.
[!--sizeo:4--][span style=\"font-size:14pt;line-height:100%\"][!--/sizeo--]
0.9.4.5: [/size][!--sizeo:4--][span style=\"font-size:14pt;line-height:100%\"][!--/sizeo--]Speed (x realtime): 197.780[/size]
Settings:
Buffer entire file into memory: no
High priority: yes
Passes: 4
File: N:\au_LONG\Mozart - [Manze, Egarr] Violin Sonatas, 1781\CDImage.flac
Run 1:
Length: 1:11:42.160
Opening time: 0:00.025
Decoding time: 0:21.943
Speed (x realtime): 196.063
Run 2:
Length: 1:11:42.160
Opening time: 0:00.046
Decoding time: 0:22.019
Speed (x realtime): 195.381
Run 3:
Length: 1:11:42.160
Opening time: 0:00.012
Decoding time: 0:21.498
Speed (x realtime): 200.121
Run 4:
Length: 1:11:42.160
Opening time: 0:00.117
Decoding time: 0:21.549
Speed (x realtime): 199.646
Total:
Opening time: 0:00.012 min, 0:00.117 max, 0:00.050 average
Decoding time: 0:21.498 min, 0:22.019 max, 0:21.752 average
Speed (x realtime): 195.381 min, 200.121 max, 197.780 average
Total:
Length: 4:46:48.640
Opening time: 0:00.200
Decoding time: 1:27.009
0.9.5 beta 1: [/size][!--sizeo:4--][span style=\"font-size:14pt;line-height:100%\"][!--/sizeo--]Speed (x realtime): 354.446[/size]
Settings:
High priority: yes
Passes: 4
Run 1:
Length: 1:11:42.160
Opening time: 0:00.002
Decoding time: 0:12.049
Speed (x realtime): 357.065
Run 2:
Length: 1:11:42.160
Opening time: 0:00.029
Decoding time: 0:12.228
Speed (x realtime): 351.833
Run 3:
Length: 1:11:42.160
Opening time: 0:00.033
Decoding time: 0:12.319
Speed (x realtime): 349.229
Run 4:
Length: 1:11:42.160
Decoding time: 0:11.955
Speed (x realtime): 359.857
Total:
Opening time: 0:00.002 min, 0:00.033 max, 0:00.022 average
Decoding time: 0:11.955 min, 0:12.319 max, 0:12.138 average
Speed (x realtime): 349.229 min, 359.857 max, 354.446 average
Total:
Length: 4:46:48.640
Opening time: 0:00.089
Decoding time: 0:48.551
0.9.5 with flac 1.2.1 decoding library is now...
79,21% faster!!! While it has no importance on playback it significantly speeds up transcoding (from flac source). [EDIT: only one core is used with both fb2k version]
I also noticed that the number of encoding thread can be set (useful when transcoding from source located on optical media).
_
configuration:
Core2Duo E6300
1GB Ram
cheap motherboard
FLAC file: 304 MB at 593 kbps
Thanks everyone who made this, it's truly brilliant!
Excellent work guys.
I think it's good enough for most users (including myself). I prefer easier to use user interfaces over comples ones, but I think here they actually found a good compromise between usability and the amount features.
The Facets plugin is a good showcase of what's possible now and how a more elegant UI element should be created.
BTW, you can still use the old panels/columns UI interface but I doubt its development will be continued, will it?
...or when having no
real multi-cores...
An informal post will maybe made soon, which will among other things echo what you wrote above :)
I just tried the new beta, but it crashes when i use columns UI and the fancy new spectrum visual.
Here is the crash info, i hope you guys will find it useful
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="foobar2000.exe" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="foobar2000.exe" SIZE="1056768" CHECKSUM="0x9B7E79B7" BIN_FILE_VERSION="0.9.5.0" BIN_PRODUCT_VERSION="0.9.5.0" PRODUCT_VERSION="0, 9,
5, 0" FILE_DESCRIPTION="foobar2000 Application" PRODUCT_NAME=" foobar2000 Application" FILE_VERSION="0, 9, 5, 0" ORIGINAL_FILENAME="foobar2000.exe"
INTERNAL_NAME="foobar2000" LEGAL_COPYRIGHT="Copyright © 2001-2007 Peter Pawlowski" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4"
VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFF03F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.9.5.0" UPTO_BIN_PRODUCT_VERSION="0.9.5.0"
LINK_DATE="10/19/2007 10:47:23" UPTO_LINK_DATE="10/19/2007 10:47:23" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="libcurl.dll" SIZE="95292" CHECKSUM="0x5E5957DE" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="01/02/2004
19:07:03" UPTO_LINK_DATE="01/02/2004 19:07:03" />
<MATCHING_FILE NAME="libmmd.dll" SIZE="2814044" CHECKSUM="0x38345C3E" BIN_FILE_VERSION="9.1.9.2" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.1"
FILE_DESCRIPTION="Math Library for Intel® Compilers (thread-safe)" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Intel® C Compiler, Intel® C++
Compiler, Intel® Fortran Compiler" FILE_VERSION="9.1.9.2" ORIGINAL_FILENAME="libmmd.dll" INTERNAL_NAME="libmmd.dll" LEGAL_COPYRIGHT="Copyright ©
1985-2005 Intel Corporation" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x0" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0"
LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="9.1.9.2" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="02/16/2007 14:29:27" UPTO_LINK_DATE="02/16/2007 14:29:27"
<MATCHING_FILE NAME="libpng13.dll" SIZE="203264" CHECKSUM="0x394974A9" BIN_FILE_VERSION="1.2.8.1799" BIN_PRODUCT_VERSION="1.2.8.1799"
PRODUCT_VERSION="1.2.8.1799" FILE_DESCRIPTION="LibPng: PNG image compression library" COMPANY_NAME="LibPng" PRODUCT_NAME="LibPng" FILE_VERSION="1.2.8.1799"
ORIGINAL_FILENAME="libpng13.dll" INTERNAL_NAME="libpng13" LEGAL_COPYRIGHT="© 2004 Glenn Randers-Pehrson" VERFILEDATEHI="0x0" VERFILEDATELO="0x0"
VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3E738" LINKER_VERSION="0x10002" UPTO_BIN_FILE_VERSION="1.2.8.1799"
UPTO_BIN_PRODUCT_VERSION="1.2.8.1799" LINK_DATE="12/04/2004 00:09:31" UPTO_LINK_DATE="12/04/2004 00:09:31" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="shared.dll" SIZE="159744" CHECKSUM="0x2A451A6A" MODULE_TYPE="WIN32" PE_CHECKSUM="0x28C8E" LINKER_VERSION="0x0" LINK_DATE="10/18/2007
12:02:27" UPTO_LINK_DATE="10/18/2007 12:02:27" />
<MATCHING_FILE NAME="uninstall.exe" SIZE="354515" CHECKSUM="0x3FFA175F" BIN_FILE_VERSION="0.9.5.0" BIN_PRODUCT_VERSION="0.9.5.0"
FILE_DESCRIPTION="foobar2000" COMPANY_NAME="foobar2000.org" PRODUCT_NAME="foobar2000" FILE_VERSION="0.9.5 beta 1" ORIGINAL_FILENAME="foobar2000_0.9.5 beta
1.exe" LEGAL_COPYRIGHT="© Peter Pawlowski. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1"
MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.9.5.0" UPTO_BIN_PRODUCT_VERSION="0.9.5.0" LINK_DATE="09/29/2007 12:50:33"
UPTO_LINK_DATE="09/29/2007 12:50:33" VER_LANGUAGE="Language Neutral [0x0]" />
<MATCHING_FILE NAME="zlib1.dll" SIZE="59904" CHECKSUM="0x7697A3DC" BIN_FILE_VERSION="1.2.3.0" BIN_PRODUCT_VERSION="1.2.3.0" PRODUCT_VERSION="1.2.3"
FILE_DESCRIPTION="zlib data compression library" PRODUCT_NAME="zlib" FILE_VERSION="1.2.3" ORIGINAL_FILENAME="zlib1.dll" INTERNAL_NAME="zlib1.dll"
LEGAL_COPYRIGHT="© 1995-2004 Jean-loup Gailly & Mark Adler" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x10004" VERFILETYPE="0x2"
MODULE_TYPE="WIN32" PE_CHECKSUM="0xF587" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.2.3.0" UPTO_BIN_PRODUCT_VERSION="1.2.3.0" LINK_DATE="07/20/2005
09:48:10" UPTO_LINK_DATE="07/20/2005 09:48:10" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="components\foo_albumlist.dll" SIZE="329728" CHECKSUM="0x56C9E9D" MODULE_TYPE="WIN32" PE_CHECKSUM="0x54D3A" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:45:57" UPTO_LINK_DATE="10/19/2007 10:45:57" />
<MATCHING_FILE NAME="components\foo_albumlist_autoupdate.dll" SIZE="86016" CHECKSUM="0x70E82167" MODULE_TYPE="WIN32" PE_CHECKSUM="0x23820"
LINKER_VERSION="0x0" LINK_DATE="08/24/2006 22:08:42" UPTO_LINK_DATE="08/24/2006 22:08:42" />
<MATCHING_FILE NAME="components\foo_audioscrobbler.dll" SIZE="201216" CHECKSUM="0xF2256308" BIN_FILE_VERSION="1.3.6.0" BIN_PRODUCT_VERSION="1.3.6.0"
PRODUCT_VERSION="1, 3, 6, 0" FILE_DESCRIPTION="foo_audioscrobbler" PRODUCT_NAME=" foo_audioscrobbler" FILE_VERSION="1, 3, 6, 0"
ORIGINAL_FILENAME="foo_audioscrobbler.dll" INTERNAL_NAME="foo_audioscrobbler" LEGAL_COPYRIGHT="Copyright © 2004 Russ Garrett, © 2006-2007 Florian
Heidenreich" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x35FD1" LINKER_VERSION="0x0"
UPTO_BIN_FILE_VERSION="1.3.6.0" UPTO_BIN_PRODUCT_VERSION="1.3.6.0" LINK_DATE="05/13/2007 12:23:40" UPTO_LINK_DATE="05/13/2007 12:23:40" VER_LANGUAGE="English
(United Kingdom) [0x809]" />
<MATCHING_FILE NAME="components\foo_cdda.dll" SIZE="189440" CHECKSUM="0xF3AB60D3" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3A9E1" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:45:49" UPTO_LINK_DATE="10/19/2007 10:45:49" />
<MATCHING_FILE NAME="components\foo_common.dll" SIZE="225280" CHECKSUM="0x6F17E47C" BIN_FILE_VERSION="0.2.0.0" BIN_PRODUCT_VERSION="0.2.0.0"
PRODUCT_VERSION="0, 2, 0, 0" FILE_DESCRIPTION="foobar2000 Common Services component" PRODUCT_NAME="foobar2000 Common Services" FILE_VERSION="0, 2, 0, 0"
ORIGINAL_FILENAME="foo_common.dll" INTERNAL_NAME="foo_common" LEGAL_COPYRIGHT="Copyright © 2005 Holger Stenger" VERFILEDATEHI="0x0" VERFILEDATELO="0x0"
VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3896E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.2.0.0"
UPTO_BIN_PRODUCT_VERSION="0.2.0.0" LINK_DATE="03/11/2006 18:23:55" UPTO_LINK_DATE="03/11/2006 18:23:55" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="components\foo_converter.dll" SIZE="409600" CHECKSUM="0xD60EB172" MODULE_TYPE="WIN32" PE_CHECKSUM="0x703F7" LINKER_VERSION="0x0"
LINK_DATE="08/20/2007 15:02:03" UPTO_LINK_DATE="08/20/2007 15:02:03" />
<MATCHING_FILE NAME="components\foo_dsp_skip_silence.dll" SIZE="40960" CHECKSUM="0xA0C62553" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12567"
LINKER_VERSION="0x0" LINK_DATE="10/02/2006 09:38:50" UPTO_LINK_DATE="10/02/2006 09:38:50" />
<MATCHING_FILE NAME="components\foo_dsp_std.dll" SIZE="274944" CHECKSUM="0x4699D659" MODULE_TYPE="WIN32" PE_CHECKSUM="0x47D61" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:45:58" UPTO_LINK_DATE="10/19/2007 10:45:58" />
<MATCHING_FILE NAME="components\foo_dsp_vlevel.dll" SIZE="139264" CHECKSUM="0xB9C7B124" MODULE_TYPE="WIN32" PE_CHECKSUM="0x27C52" LINKER_VERSION="0x0"
LINK_DATE="03/24/2006 15:55:08" UPTO_LINK_DATE="03/24/2006 15:55:08" />
<MATCHING_FILE NAME="components\foo_fileops.dll" SIZE="269824" CHECKSUM="0x27294BA0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x49B8A" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:46:10" UPTO_LINK_DATE="10/19/2007 10:46:10" />
<MATCHING_FILE NAME="components\foo_freedb2.dll" SIZE="245760" CHECKSUM="0x3016211" MODULE_TYPE="WIN32" PE_CHECKSUM="0x442F5" LINKER_VERSION="0x0"
LINK_DATE="08/16/2007 15:27:44" UPTO_LINK_DATE="08/16/2007 15:27:44" />
<MATCHING_FILE NAME="components\foo_infobox.dll" SIZE="253952" CHECKSUM="0x552B5108" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4588F" LINKER_VERSION="0x0"
LINK_DATE="10/09/2006 13:17:11" UPTO_LINK_DATE="10/09/2006 13:17:11" />
<MATCHING_FILE NAME="components\foo_input_std.dll" SIZE="1173504" CHECKSUM="0x3A493319" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12B790" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:45:45" UPTO_LINK_DATE="10/19/2007 10:45:45" />
<MATCHING_FILE NAME="components\foo_msnalt.dll" SIZE="94208" CHECKSUM="0x84A5FB9D" MODULE_TYPE="WIN32" PE_CHECKSUM="0x17AB8" LINKER_VERSION="0x0"
LINK_DATE="04/10/2006 13:39:29" UPTO_LINK_DATE="04/10/2006 13:39:29" />
<MATCHING_FILE NAME="components\foo_random.dll" SIZE="249856" CHECKSUM="0x41188E58" MODULE_TYPE="WIN32" PE_CHECKSUM="0x46633" LINKER_VERSION="0x0"
LINK_DATE="03/13/2006 10:35:03" UPTO_LINK_DATE="03/13/2006 10:35:03" />
<MATCHING_FILE NAME="components\foo_removeplayed.dll" SIZE="90112" CHECKSUM="0xEA0B980C" MODULE_TYPE="WIN32" PE_CHECKSUM="0x222D9" LINKER_VERSION="0x0"
LINK_DATE="09/02/2007 11:15:31" UPTO_LINK_DATE="09/02/2007 11:15:31" />
<MATCHING_FILE NAME="components\foo_rgscan.dll" SIZE="265728" CHECKSUM="0x1E469956" MODULE_TYPE="WIN32" PE_CHECKSUM="0x49F02" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:44:48" UPTO_LINK_DATE="10/19/2007 10:44:48" />
<MATCHING_FILE NAME="components\foo_uie_albumart.dll" SIZE="241664" CHECKSUM="0x274A87D" MODULE_TYPE="WIN32" PE_CHECKSUM="0x481CE" LINKER_VERSION="0x0"
LINK_DATE="01/16/2007 01:04:42" UPTO_LINK_DATE="01/16/2007 01:04:42" />
<MATCHING_FILE NAME="components\foo_uie_albumlist.dll" SIZE="261632" CHECKSUM="0x418C272F" MODULE_TYPE="WIN32" PE_CHECKSUM="0x44377" LINKER_VERSION="0x0"
LINK_DATE="06/11/2007 13:13:53" UPTO_LINK_DATE="06/11/2007 13:13:53" />
<MATCHING_FILE NAME="components\foo_uie_console.dll" SIZE="87040" CHECKSUM="0x3F531B12" MODULE_TYPE="WIN32" PE_CHECKSUM="0x169FD" LINKER_VERSION="0x0"
LINK_DATE="11/22/2006 12:59:04" UPTO_LINK_DATE="11/22/2006 12:59:04" />
<MATCHING_FILE NAME="components\foo_uie_peakmeter.dll" SIZE="200704" CHECKSUM="0x90957F0E" BIN_FILE_VERSION="0.0.4.1" BIN_PRODUCT_VERSION="0.0.4.1"
PRODUCT_VERSION="0, 0, 4, 1" FILE_DESCRIPTION="foo_uie_peakmeter is a foobar2000 plugin " COMPANY_NAME=" " PRODUCT_NAME="foo_uie_peakmeter" FILE_VERSION="0,
0, 4, 1" ORIGINAL_FILENAME="foo_uie_peakmeter.dll" INTERNAL_NAME="foo_uie_peakmeter" LEGAL_COPYRIGHT="Copyright © 2007 Matthias Brodrecht"
VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x38F8C" LINKER_VERSION="0x0"
UPTO_BIN_FILE_VERSION="0.0.4.1" UPTO_BIN_PRODUCT_VERSION="0.0.4.1" LINK_DATE="10/15/2007 18:24:49" UPTO_LINK_DATE="10/15/2007 18:24:49" VER_LANGUAGE="German
(Germany) [0x407]" />
<MATCHING_FILE NAME="components\foo_uie_vis_channel_spectrum.dll" SIZE="155648" CHECKSUM="0xC4DF7C04" MODULE_TYPE="WIN32" PE_CHECKSUM="0x297E9"
LINKER_VERSION="0x0" LINK_DATE="08/29/2007 13:55:45" UPTO_LINK_DATE="08/29/2007 13:55:45" />
<MATCHING_FILE NAME="components\foo_ui_columns.dll" SIZE="594944" CHECKSUM="0xDF3C348C" MODULE_TYPE="WIN32" PE_CHECKSUM="0x9B7E7" LINKER_VERSION="0x0"
LINK_DATE="11/22/2006 12:05:23" UPTO_LINK_DATE="11/22/2006 12:05:23" />
<MATCHING_FILE NAME="components\foo_ui_panels.dll" SIZE="942080" CHECKSUM="0x25BA9F54" MODULE_TYPE="WIN32" PE_CHECKSUM="0xE8C74" LINKER_VERSION="0x0"
LINK_DATE="06/12/2007 17:28:21" UPTO_LINK_DATE="06/12/2007 17:28:21" />
<MATCHING_FILE NAME="components\foo_ui_std.dll" SIZE="715776" CHECKSUM="0x7F920A40" MODULE_TYPE="WIN32" PE_CHECKSUM="0xBE0BC" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:45:11" UPTO_LINK_DATE="10/19/2007 10:45:11" />
<MATCHING_FILE NAME="components\foo_unpack.dll" SIZE="165888" CHECKSUM="0x9847132B" MODULE_TYPE="WIN32" PE_CHECKSUM="0x31AE1" LINKER_VERSION="0x0"
LINK_DATE="04/20/2007 19:35:15" UPTO_LINK_DATE="04/20/2007 19:35:15" />
<MATCHING_FILE NAME="components\foo_utils.dll" SIZE="225280" CHECKSUM="0x7F1B89AD" BIN_FILE_VERSION="0.5.0.0" BIN_PRODUCT_VERSION="0.5.0.0"
PRODUCT_VERSION="0, 5, 0, 0" FILE_DESCRIPTION="Utilities for foobar2000" COMPANY_NAME=" " PRODUCT_NAME="foo_utils" FILE_VERSION="0, 5, 0, 0"
ORIGINAL_FILENAME="foo_utils.dll" INTERNAL_NAME="foo_utils" LEGAL_COPYRIGHT="Copyright © 2005 Holger Stenger" VERFILEDATEHI="0x0" VERFILEDATELO="0x0"
VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3CA24" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.5.0.0"
UPTO_BIN_PRODUCT_VERSION="0.5.0.0" LINK_DATE="05/09/2006 11:01:32" UPTO_LINK_DATE="05/09/2006 11:01:32" VER_LANGUAGE="Language Neutral [0x0]" />
<MATCHING_FILE NAME="components\foo_verifier.dll" SIZE="175104" CHECKSUM="0x70597674" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2EE36" LINKER_VERSION="0x0"
LINK_DATE="08/29/2006 20:09:17" UPTO_LINK_DATE="08/29/2006 20:09:17" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="kernel32.dll" SIZE="930304" CHECKSUM="0xCBCCF8A9" BIN_FILE_VERSION="5.1.2600.1106" BIN_PRODUCT_VERSION="5.1.2600.1106"
PRODUCT_VERSION="5.1.2600.1106" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows®
Operating System" FILE_VERSION="5.1.2600.1106 (xpsp1.020828-1920)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft
Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xE7ED3"
LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.1106" UPTO_BIN_PRODUCT_VERSION="5.1.2600.1106" LINK_DATE="08/29/2002 10:40:40"
UPTO_LINK_DATE="08/29/2002 10:40:40" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
And thanks for your hard work
I feel like I'm missing something here, because none of the old UI elements are showing up in the "replace element" list for me. I only see the default ones, and Id like to use the browser, bookmarks, lyrics, etc. Also, nothing is showing up in the new albumart panel, and I cant figure out how to get to any kind of settings dialogue for it. I also don't see anything about the "scratchbox " or "facets plugin."
edit: Ok, I found the facets plugin, which is awesome btw. I still really miss the old UI components but I love this new layout system. No chance of backward compatibility?
"Better than sliced bread!". Thanks to the foobar2000 team for the wonderful work so far.
I am sitting right now in an inet-cafe and has downloaded new beta and the brand new facet plugin - i know how i will spend the rest of my day. I expected many new things but not this: it seems to be amazing!
Thanks for your hard work!
One question just: is it a big work for developer of some panels (bookmarks, history, lyricshow, queuemanager...) to transfer their plugins?
Those components you have listed are panels for Columns UI, which is an entirely different user interface.
Panels were never part of the default UI.
From the footnote in the release notes:
UI Elements are conceptually similar to the panels introduced by Columns UI, but are incompatible with them so they were given a new name.
Whoa! The return of the Spectrum!! Many thanks!
Wow, a new beginning. I'll need some time for that...
BTW, the fb2k default icon has some ugly white pixels at the corner here, wxp, 16 bit colors.
Is there a way to reset the default UI settings only? Would be helpful especially at the beginning...
EDIT: OK I found the quick setup window. Great work.
The layout import/export/cut/copy/scratchbox: Very fine!
Oh ok, I understand. I hope eveyone updates their components to work in the new UI. One more thing I was wondering, how can I create custom button bars? I dont see an option anywhere for it.
Amazing release. Thanks. I am really glad that the default UI will be more attractive to a larger user base.
0.9.5 does not try to compete with Columns UI or Panels UI as far as total visual customization is concerned. Also, some people consider it elegant when an application blends in with the rest of the crowd; it is largely a matter of taste.
Now, a question
Is there a way to lock album art to now playing song only?
It's follow cursor only right now. and i don't see any setting anywhere.
There is no such setting in the beta.
There is no option for that.
Is Peter still the largest contributer to development (or sole developer) of foobar2000? Or is this release a work of other developers?
Edit: Thanks for the answers Frank Bicking and foosion.
Any plans to include that someday? That would be the last element to let foobar look like a normal windows application, beside of the functionality to have quick access to often used commands (without going to main or context menu and without remebering hundreds of shortcuts)
Peter is still responsible for almost everything in the installer and for everything on the optional components page. As far as actual code goes, my contribution is limited to foo_freedb2 and some pieces of code used in foobar2000 itself (edit: all of those predate 0.9.5 by the way). The components on other pages (Frank's and mine, for example) are the work of their respective author. picmixer has made the new icons (the foobar2000 and file type icons). Then there is a bunch of people who did testing and helped with the release preparations.
yes he is
edit: halo thar redundancy. the foosion is fastI just tried the new beta, but it crashes when i use columns UI and the fancy new spectrum visual.
Try no tusing Columns UI, and instead try the new default UI... this is where it's at
Joy to the world
the new release is come
This release look FANTASTIC. can't wait to check it out. Big thanks to the foobar2000 developers.
As a general observation: people in this thread are too focussed on configuration rather than usage and doing stuff with foobar. A significant amount of minor features... and possibilities to combine new features - havent been discovered yet, because people are more concerned with configuration rather than usage.
Thnaks to the dev team for this great and unexpected version!! Lots of new features, it must have been a lot of work.
The new easily configurable UI is great and should attract new users. I was able to almost replicate my playlist tree config in a few clicks! Except for some custom queries so I hope it'll be possible to create custom "views" in the tree intead if the default one listed in the "view" combo
This is just awesome. And I eagerly wait for Navigator for the new Defaul UI =)
i think activating UI ELEMENTS by mouse-over would be nice
Thanks for reporting. I'll fix that when I get the time to the next few days. I have to admit that I didn't really check the 16 bit version on different backgrounds.
Well, all else I have left to say to everyone is, enjoy the beta. We are all very glad to see how well received it is by the users and hope you enjoy it as much as we have during the lengthy period of alpha testing.
Whoa...entirely new foobar2000 interface it will make it easier for me to recommend it to the slightly experienced to no experienced user now. Plus it looks and functions great, granted there will be bugs and kinks to workout but the new approach is awesome.
Nice job, foobar200 team.
The WYSIWIG edition of the layout + scrachbox is just brilliant!
I suppose the next version of the SDK will allow wrinting of UI Elements and to port existing ui panels ?
Highlights of the new release for me:
- Improved drag and drop support.
- Improved clipboard support.
- Properties dialog is even better (I rarely use Masstagger now).
- The File Operations context menu options rock my world.
The user interface has really been completely overhauled and is so much more pleasant to work with. Excellent job!
When you say blend in I assume you mean that it looks like any other app for XP/Vista. The thing is that it barely does. Foobar truly has potential to be a great player with a simple yet appealing UI. I realize this is beta but here are some things that are bothering me. It's all about the details.
1. The progressbar and volume control are both oversized, as well as the splitters.
2. It would look a lot better if all elements had border style options (including splitters). The default borders look terrible.
3. Formating for album art? Like... albumart\[%album%].jpg. Would be nice with album art in the playlist as well, like in iTunes.
4. Autosizing of columns in playlist view / playlist manager / playlist search.
5. Would be nice if toolbar panels were separate from the toolbar container.
Keep up the good work.
- Still unobtrusively goes to system tray and plays whatever I throw at it.
Yay for mundane.
In the "File Operations - Rename" diaglog: preview doesn't work until I didn't change the "File Name Patters" field
Wow... new version!! And the new default interface gives Columns UI and Panels UI a run for their money by far! The new interface is an unexpected, wonderful treat for all foobar2000 users, especially for new to novice users who want to experiment with the interface w/o dealing with too much code. I would assume that more experienced users are having a blast with all of the tinkering. It's shocking that this is a beta, since it runs quite smoothly, no hitches. Probably a personal preference, but I wish that a lyrics panel will be added... or maybe it's there, but can't find it. Anyways, an amazing job by the people who make foobar!!!
I've split some posts about - I guess - different people's approach to using foobar2000. Please stay on topic and avoid being hostile to users who do not share your opinion.
Additional reminder: please post bug reports in separate threads.
While all feedback is appreciated, we would like to avoid the typical "beta thread syndrome" in the long run.
Threads with many pages can make it quite difficult to keep track of the numerous proposals and error reports. This would most likely cause concerns to be repeated, and might in the worst case even result in bugs remaining unfixed. That said, please try to stick to one topic when posting, instead of covering a broad range of completely different aspects. This will make it much easier to properly split posts into comprehensible separate threads, which we will continue to do if necessary.
Please do also consider to start a new topic, especially for bug reports, as mentioned by foosion.
Just include "0.9.5" somewhere in its title to catch our attention.
To those who have tried the beta so far, is it "stable"?
stable so far, if you removed all the unneeded components (uie_albumart etc...)
Wow. This is a masterful upgrade.
In a couple of minutes I had a display that looks just as good as my old ColumnsUI layout.
And I notice that real Random Play is back!
You guys rock.
wow I usually lurk but this release is AMAZING
it might take a bit till the DefaultUI is as pretty as some of the Panels/ColumnsUI stuff (which i think most are pretty gaudy, cluttered, and not very ergonomic anyways) but this release is soo elegant, fast, and intuitive!! I already like my new 0.9.5 + facets component layout better than my old buggyass Panels UI config which I've been using for about a year!
THANK YOU DEV TEAM THIS THING FUCKING ROCKS
Damn, this is so mighty!
Thumbs up for your work!
Nice changes, setting up a nice usable UI is a lot simpler now. But it still needs some polishing, especially those oversized element borders are ugly as hell, an option to turn them off (better) or make them only 1px thick would be nice. Also a setting for minimum/maximum size of UI elements/elements position locking would be useful, same as an option to disable albumart upscaling (looks ugly).
elements position locking would be useful, (...)
Locking the size of an element is already possible, although the option is somewhat hidden.
Activate the Layout Editing Mode (menu View, Layout), right-click on a splitter, that means on the frame between two elements, and choose between "Lock Left Pane Width" and "Lock Right Pane Width" (or top and bottom height, respectively).
Impressive work, folks, really. You've taken the one major hole I've seen in this program (a lack of an easy and effective out-of-the-box setup) and plugged it effectively, and with style.
It crashes in my Columns UI config, but that's probably due to the redundant components I've got installed. I haven't had a chance to play around with the new Default UI very much, and will probably not switch to it immediately, if at all (at least until/unless I can get the same or better functionality to the setup I have now) (so I'm still using 9.4.5 for the moment), but it's still a remarkable piece of work.
I do hope you folks won't completely throw customizability out the window; making it *unnecessary* (as it seems you have) is certainly the right way to go.
I felt satisfied very much with the changes~~~
Thank you~~~
Hi foobar 0.9.5 is really good but i have some question
Is there a mean to add a panel to see artist image ?
Is there a mean to focus the album art panel only on the current playing song and not on the selected ?
Thanks by advance for your help
the default ui is really impressive.
I appreciate all the work that the developer of ColumnsUI has put in, but realistically, the basic ColumnsUI functionality is something that always ought to have been in the default program. Not to suggest the Foobar developers are wrong for not doing this sooner, or that the ColumnsUI developer was wasting his time. The Foobar developers started with whats arguably more important, making sure it plays music efficiently. Meanwhile, the development of ColumnsUI has been an excellent stop-gap while we waited.
At any rate, 0.9.5 beta 1 is precisely what I've always wanted Foobar to be. All I need now is a UI element equivalent for the Show Lyrics Panel (the one that grabs lyrics from an on-line database).
It's been so long since changes this big made for foobar. Looks like I have to spend this weekend on foobar instead of bioshock hehe.
I've been using foobar for quite some time with ColumnsUI set up. The changes in this new beta version are a real improvements as well as a time saver. Great works dev team!
@nbv4: do you have your wine set up to function as Windows XP, since this new beta requires XP and above? run 'winecfg' if you're not sure.
yes it is. if I set it to Win2000 or something, it'll bring up a popup window saying "this only works in XP [OK]"
I would just like to say WOW, very please by the changes and additions in the new beta, seems like 9.4.5 only just went final and now we get a great new version to play with. I think one thing everyone in here is guilty of is loving new releases to find all the awesome work that Peter and Co have put into the music player... best ui designer - even my mum could make a custom design and this is the way it should be, not over the top programming language to learn and I think you for that. Out of the box Foobar is pretty much a complete package now, there are very few extra components one would need. I can start culling now to run a smaller footprint.. nice work once again
I signed up just to say that in my opinion, your customizable UI system is revolutionary: I've never seen anything this convenient and efficient before. I wish all UI-driven programs could be customized this way.
One small bug: Setting the interface transparent in the preferences dialog doesn't 'stick', ie. the window only remains transparent while the prefs dialog is open. Fresh install running on Vista with only 1 extra component, Facets.
Aside from that (and who needs transparency anyway) this release is absolutely incredible, foobar2000 now actually lives up to it's reputation as most configurable player - and the configuration can be done in a matter of seconds using only one hand (ie. the mouse).
Drag and drop support is awesome, building playlists is effortless and completely intuitive.
I love everything in the new UI EXCEPT
1. The Seekbar is kinda ugly with the white empty line inside, IMO doesn't feel native because all other windows apps have seekbars like the one in 0.9.4
2. The new icon, I think adding the gloss effect over the icon kinda ruined it...it was perfect before
Not a bug (and not new either I think). The transparency is only applied to the main window when it is not active.
Sorry if this is a stupid question .... but how can I remove a UI element in layout editing mode?
For instance, when I add a splitter I can "cut" the UI element in it but did not find any way of removing the splitter itself.
Replace the splitter itself or paste another element in its place. Right-click on the splitter's separator line to do so.
Waouh !
What a change.
Nothing during years, and now... BOOM.
It's far from Panels UI, but it's a pleasure to see developers consider the GUI at last.
I personally find it a bit harsh to dismiss Columns UI as a stop-gap. While it is true that Peter neglected the Default UI while he focused on the backend, there are features in Columns UI that he does not wish to include in 0.9.5 and possibly not even in later versions. Examples for this are extended formatting capabilities in the playlist view (tab and color rendering found in the status bar and in old versions) as well as configurable UI Element borders. We do hope that 0.9.5 and beyond will decrease the need and desire to switch to another user interface, but I don't think it will completely replace Columns UI.
I hope musicmusic is not too annoyed because we prepared all this in secret. It would be sad day for the community to lose a capable developer who has been creating good components for so long. So cheers to musicmusic: I hope you prove me right that Columns UI is more than a "stop-gap"! It is always good to have some competition.
There wll be now two standards for writing panel plugins: ui panels and ui elements. Will it be possible for a component to be both without having 2 versions of the DLL (which would be very messy) ?
I know you guys needed to do your work in secret but seriously I think everyone could of benefited if you guys worked with Musicmusic, I am not saying the work on default ui is making his component redundant but I think if you all worked together on one solution we would have something twice as good, so Musicmusic is just adding the finishing touches to the default rather then writing from scratch.
Either way everyone benefits with the latest version, I just hope musicmusic doesn't feel slapped in the face, the least you guys could of done is tell him early or something surely..?
I have been using 9.5 not for a long stint and not come up with any errors, so lookins pretty rock solid.
I remember of some people criticizing Panels UI for his complexity but this interface is also complicated if we want to customize...
What about having a directory in components directory called "UI Element" ? Because there will be a lot of panels in some time and it will be complicated to find which components we have.
It looks like Album Art Viewer is very limited (1 preference in advanced option ?).
"Facets" is a very nice idea, but if we don't have a well-tagged database, it's not so powerful.
For panels developers, is it simple to allow UI Element compatibility ? Or do they have a "How To" ?
In any case, congratulations for such an improvement.
For those who do not use tags, there is a Folder Structure view.
If your folders are not properly organized either, I'm afraid there is not much you can demand from a library viewer.
Since foo_uie_album_art source code is available someone will convert it to an UI element sooner or later...
My folders are well-organized, or at least I find them well-organized. With Folder Structure, you only see directories, and problem is... sometimes you have directories AND files.
The ideal is to have a well-tagged database, but I would need one year to be the case.
I just would like to express my gratitude towards the developers for such an amazing music player! And their continuous effort for making it better. Finally a real random function! Hoooraaay!
Either way everyone benefits with the latest version, I just hope musicmusic doesn't feel slapped in the face, the least you guys could of done is tell him early or something surely..?.
Just to make sure that there are no misconceptions. Musicmusic did certainly know how to get access to the alpha builds ever since the early 0.9 branch if he wanted to. He has access to one of the development channels if he chooses to and we certainly never actively tried to hide anything from him. We just happened to not be in contact for quite some time now.
As far as I know it was his choice to keep developing columns UI on his own. In no way I hold this against him since decisions like this are entirely up to the developers themselves. I do hold musicmusic in the dearest respect, since he has done a lot for this community and I have been an avid columns UI user myself before Peter started developing the new UI. We also by no means made the new UI to drive columns UI out, but simply started it because we felt there was the need for a new user friendly and easily configurable UI and never saw this as direct competition to columns UI.
Columns UI and the new default UI where developed independently simply because things took a turn that way and certainly not because of any hostilities, secrecies or anything the like.
I just want to make sure that this is clear before any rumors spread again that we actively try to drive away developers. It seems that some developers are a bit over sensitive to critisism (and by this I don't mean musicmusic by any means). Now if these developers decide to leave the fb2k community this certainly isn't our responsibility either and entirely their own decision.
Are there any good reason a WYSIWYG layout manager for Columns UI couldn't have been done instead, to preserve plugin compatibility ?
Is it intentional, that the media library is now case sensitive?
We don't blame developers because of Terrestrial leaving. It's just that criticisms have sometimes been a bit rude (not always from moderators besides). When you have Foosion and some users who say Panels_UI is a bad written component, it's difficult to receive. Even if it's the case, you should choose the right words or explain it in PM.
But I don't want to be involved in controversy. I prefer to enjoy this new interface.
Hello all,
I am really happy that you all like this new version. I am very sorry to break the flow of positive comments but new playlist view is inaccessible. People using screen-reading solutions are not available to access playlist content with this new beta.
I believe this can be fixed as the playlist view is perhaps not entirely completed yet. I don't want to criticize the dev team I just would like to discuss accessibility issues properly. I have started a topic here (http://www.hydrogenaudio.org/forums/index.php?showtopic=58366) so please look into it if you are interested in accessibility for visually impayred people.
Hello, I am very happy with my current panels_ui config, but I would like to try this out. How would I do that without anything geting lost? I have an external hard drive, would it help to install it there?
It looks like it's impossible to delete a splitter without delete several (or all) UI elements.
@sylla: you won't lose anything. In preferences > Display, just select Default User Interface. And when you want to come back to Panels UI, just choose Panels_UI interface.
Cut the UI Element which you would like to keep, and paste it over the splitter.
Screenshots: 1 (http://img215.imageshack.us/img215/6920/11729883ds4.png), 2 (http://img215.imageshack.us/img215/6568/52944400mi8.png), 3 (http://img215.imageshack.us/img215/7108/91497562fr1.png), 4 (http://img215.imageshack.us/img215/1919/89339657cy3.png)
Well, what would you expect to happen when you delete a container with several (more than one) elements in it?
Excellent release ! Thank you for this easy to configure layout!
One question though, how do you obtain the playlist shown in the first screenshot http://foobar2000.org/releasenotes-095/ima...nterface.th.png (http://foobar2000.org/releasenotes-095/images/default_user_interface.th.png) ? I mean, how you changed the font size of the yellow titles ? (or maybe it's set at a slightly bigger font but is not customizable ?)
Also what is the scratchbox for exactely ? Testing out some panels adjustments before cut+paste on the main window ?
Btw highlighted line in playlist has its text in white, I have not seen how to change that is the Colors and Fonts section (screenshot (http://img210.imageshack.us/img210/1659/tempqb7.jpg))
how to specify album art covers from folders in advanced option??
Read what Frank has written about it in this thread (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=58322&view=findpost&p=523851).
It's for specifying a "placeholder" image for albums
without cover art.
The playlist view in the screenshot has grouping enabled. The color of group headers can be changed through the Highlight color.
Exactly.
The color of selected text is either black or white depending on the background color. It is not configurable.
How do you access the scratchbox?
Menu View, Layout, Create Scratchbox.
First kudos to all developers for their efforts!
Second: I'm not sure this is the right place to ask, but... is it possible to add an option in order to get tags from a local Freedb database (as in EAC and Plextools) ?
Wow. A big thank you to the foobar2000 developer team.
Feature request: when album list view is sorted by directory structure can it bemade so folders are added to the list first and files are appended to the bottom?
has anyone been able to get the installer to work in wine? I keep getting this:
nbv5@nbv5-desktop:~$ wine /home/nbv5/Desktop/foobar2000_0.9.5\ beta\ 1.exe
err:ntlm:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path.
ntlm_auth error can be fixed by upgrading your samba (ntlm_auth is a part of samba), but unfortunately this does not help to go further with installation (installer just hangs).
Eventually I installed it on WinXP box and copied foobar2000 dir to .wine/drive_c/Program Files/ and it works quite good (though you can simply crash it by pressing unassigned shortcut )
great stuff, tnx.
a. can i get my multiline input field back thought? (window title, status bar..)
b. how do i right align data in custom column?
c. can we have replacable buttons? (load bitmap would do just fine)
d. titleformat_help.html is still missing some basic tags, like: %__replaygain_track_gain%
e. whitecrap still displaying in spectrogram when switched to quality other than low.
Very nice work!
Backwards compatibility with components seems VG; the only components I have "lost" are "panels", but that is to be expected with the new layout.
Lack of Customizable Track Info is my only major "sticking" point for completely leaving 0.9.4; but I am **sure** it is coming (wink, wink)
Does the new default layout allow for third party "panels" ---sorry, I know that term is attached to columns ui, but I hope you get the point? Need to get Lyrics and album art browsing back....
Random rocks!
Facets is very slick.
Now, to try to figure out what my autoplaylist queries were to import them into the filter...
Also, any trick to getting graphical ratings indicators into a playlist panel? None of my code works; currently stuck with 4 / 5 etc. EDIT
$if(%rating%,$get(info)$get(result)%rating% / $get(high)5,)
works (no color choices available ATM, as far as I can tell)
A nice step in the right direction. What I'm missing at first glance is cycling album art through various freely defined filemasks and a lyrics display element.
It is great that "Play" is now available as a context menu item! Now it is possible to set the default action to "Play" in foosion's Database Search without the need of installing additional components (the other features of which I would not use anyway).
This comes surprising as ever since I learned columns ui I asked myself if there could be a simpler, wysiwyg configuration method. Since the script coding madness of panels ui (no rant) foobar's gone wild for a while and possibly new-comers were distracted by the complexity, foobar's main dev now responding, reining complexness and creating a nice proportion of effective user configurability and complexity... - my gratulations!
I'm missing the ability to use different patterns for sorting and displaying in a playlist. For example, I want to sort rows by track gain. On the one hand, the unmodified string cannot be used for it because it is sorted like -10.00 < -10.50 < -9.00, so a conversion is necessary. On the other hand, the converted string cannot be used for display. This was possible in Columns UI.
I read through the 5 pages so far, and I have 2 questions:
1. Will this update be okay with my current configuration and database? I don't want anything lost, overwritten, or removed if I update. Normally I wouldn't ask, but this update seems fairly large.
2. I use Panels UI as my main interface. Does this new build of foobar add anything to that? Like, are there any new panels I can add into my config? I like the new playlist and the spectrum analyzer. Can those be added into a Panels UI interface?
I mainly want to make sure this update wont harm my current install.
Thank you .
0.9.5 should be compatible with most components. However since this is a beta this hasn't been tested thoroughly and there might be some incompatibiltity with certain components. However nothing should happen to your database.
In case of doubt simply install to a different folder and make a clean install of 0.9.5 and reinstall your needed components there.
No this version will not add anything to Panels UI since Panels UI is an interface designed by a third party and has nothing to do with the main fb2k development team. It uses elements from cloumns UI wich are not compatible with the new default UI. You can not use the playlist and the spectrum analizer to panels UI.
Normally, nothing should be lost except of the things mentioned in the upgrade notes. If you want to be absolutely safe however, just make a copy of the entire foobar folder and its configuration-file (depending on your settings, this file will be in the foobar folder, or somewhere in your windows profile folder).
PanelsUI is a 3rd party component - it is unrelated to the official components of foobar2000 and the new default UI. Panels UI is an entirely different UI than the new Default UI mentioned in the releasenotes and there is no interoperability.
- Lyx
Thank you very much for your replies picmixer and Lyx. I shall make a backup, and install the new version .
Thanks for clearing things up picmixer, I know you guys are all really good people so there was never a doubt that that there were bad intentions or anything like that. I just wanted to know/confirm that musicmusic had a means of keeping up with the latest dev info.
Loving the latest version - keep em coming
Is there a way to remove the "number of sub-items" thing from the Album List?
I've noticed that highlighting a track in the playlist (using facets) and right-clicking and selecting "tag in tagger window" does nothing. Has this feature not been implemented yet?
I love the new features, keep up the great work!
I only have one request, and its regarding the playlist view...would it be possible to have playlist specific groupings? The only reason I ask is because it would be nice to have one grouping for albums and one for singles!
I have never seen this "Tag in tagger window" command before. I think it must be from some third-party component you have installed.
after playng around a little, just a word:
WOW!
Thanks for all your work! You guys are reading my mind? All the new/different functions I've found are exactly what I was hoping...
And now, some notes.
A little visual glicht:
preferences/display/default user interface/colors and fonts : the fonts section is not aligned (win xp sp2 here, with noting special installed)
and: still no plan for different language support?
Thanks again!
No, still no plans for different language support and as stated many times before this will most likely never happen.
I think Franck's screenshot should be expressive (I wanted to delete an empty container):
Besides, how have you got this background graduation for the playlist ?
In future development (since interface looks like in todo list), would it be possible to have a "font service" plugin, I mean fonts which could be used by others plugins. This font service would allow others plugins to use effects like shadow, etc. I suppose I dream, but why not transparency, etc.
Edit: why changing icons ? I suppose it's because of the change and I will get used to, but for now, I rue old icons.
It comes with newer versions of cwb_hooks.
The "tagger window" is a panel, so it will not work w/ the default ui.
What about adding "Previous" and "Next" in the Properties dialog?
What about naming your motives for a proposal?
You can for example open the Properties dialog for multiple files, double-click on the field you would like to edit, and enter all values at once.
Screenshot (http://www.audiohq.de/articles/foobar/tagging/properties_metadata_individual_values.png)
I don't know if this is the right place to ask, but here it goes anyway.
Is it possible to add an option for the columns to auto scale when the window is resized? If there is such an option I haven't seen it.
I'll admit upfront that it is not such a big deal since I usually set the window size and leave it like that almost forever, but I just thought it was a nice feature of ColumnsUI.
Frank Bicking sorry, I didn't know about this feature.
What does the Clean Up command in the properties Dialog do?
Please read the description in the status bar.
I got an error when I tried to convert a file to FLAC,
I'm using FLAC 1.2.1b
"Error writing to file (管道正關閉中。 ) : file://G:\Converted\01.flac"
I really don't know what it means.
Don't know if it's been mentioned, I apologize for being redundant if it has, but renaming file with the new utils component, deletes the play_count statistics.
Great new interface, btw, definitly a step in the right direction! Keep up the stellar work, guys!
Not if you use the recently released official foo_playcount 2.0 (http://www.hydrogenaudio.org/forums/index.php?showtopic=58233).
Nice work, but isn't it possible to give all the metadata in the selection properties, so also the data that I have entered myself? Or maybe make it possible to customize this window?
Great new interface by the way
new foobar is just *AMAZING*...
ALBUMART from the tag just kicked the world's butt !!!
Fantastic player and audio file manager.
Add your metadatas to the string in Foobar Preferences -> Advanced -> Display -> Propesties Dialog -> Standard Fields. IOW it uses the same config as Properties Dialog's Standard Fields.
Is there any way to turn off albums and tracks counter in Album list ???
I noticed when you add 2 toolbar headers and restart foobar one header dissapears.
Also it's impossible for me to switch windows when foobar is maximalised. So when I want to look up something on say firefox I need to minimalise foobar before I can do this.
Great work guys
I was scared it would take me a week to transfer old layout to new foobar, but it took like half an hour.
.. he does not wish to include in 0.9.5 and possibly not even in later versions. Examples for this are extended formatting capabilities in the playlist view (tab and color rendering found in the status bar and in old versions) ...
Coloring is what I miss in the new playlistview. If the old $rgb() will not be supported, the possibility of setting the font color for each column (in the playlist view) would be great.
BTW. very nice to have the advanced setting "thread count" for the converter. (With the availability of Quad-core CPUs the harddisk would become so stressed that there would be hardly speed gain.)
I also would like to know if it is possible. $tab() does not seams to work and I can't think of another way to do it. I would like to create a custom duration column aligned right with a * when replay gain data is missing.
Is it possible to sort groups on something else than is displayed.
I have the catalog number/ album and artist displayed but I would like to first sort on date before the rest. I also don't want the date displayed before the catalog number in the group. Is this possible? or can it be made possible?
That is not possible at the moment. Custom columns are always left-aligned. I'll add it as a known feature proposal.
Excellent. It took a couple of minutes to get used to, but the scratchbox is my best friend. I've never been more pleased with the customisation in f2k.
In order to add a toolbar header to an Element, you have to choose "Replace UI Element..." and then choose Toolbar head from a prompt titled "Replace xxxxx with..."
This doesn't seem to be the most intuitive way to
add a toolbar header that
doesn't replace anything, IMO.
[edit]
Furthermore, in the "Replace xxxxx with..." prompt, for the Toolbar header the description reads "Adds a toolbar to another UI Element." Which may be an attempt to clarify the above problem (although it's a bandage, not a cure), but this description causes another discrepancy: If I cut and paste an element that has a toolbar header, the toolbar header does not move and is not effected, which leads me to believe that it is actually added to
the container, and not the actual element, as the description reads.
So really, the current implementation is really confusing.
Simpler solutions would be:
- Either the toolbar headers need to actually belong to the UI Element (that is move with them) and we need a separate way of enabling this separate idea,
- or they should become their own UI element outright, and require a splitter, as all other elements do.
Could we possibly have changeable buttons on the toolbar?
What is the syntax for images/resources/colour changes in the playlist?
Both already listed here (http://www.hydrogenaudio.org/forums/index.php?showtopic=58351).
It wouldn't hurt to actually read that before posting feature requests.
I've never tried scripting before and enjoyed the easy columns ui and album art. First thing to say, yay finally noobs can get awesome layouts as well.
Now we get to the 'problem'
I see the album art is covered as cover art. Great, no need for the album art plugin. But umm, how do configure that? I found Album art stub image path in preferences->Advanced but eh... no clue what to fill into.
The album art did great with the following script
$replace(%path%,%filename_ext%,)*
-$replace(%path%,%filename_ext%,)Scans\*
-$replace(%path%,%filename_ext%,)..\*
--components\default.*
What is a smilar script to get the cover art working?
Thx in advance.
Hirvine: Please read the album art viewer discussion thread (http://www.hydrogenaudio.org/forums/index.php?showtopic=58322).
Sweet release.
I'm too stupid to work out how to use the Scratchbox properly though!
+1
It's ridiculous.. Hotkeys get caught during renaming? Spacebar can't be used for PAUSE (some people use their whole keyboards for quick actions / tagging / etc :) ?
PS 0.9.5 is a good step towards becoming "not only for aliens" software :)
(Btw, does Preferences/Display/DUI/Icon/UseCustomIconFromFile change anything?)But it will never reach power and popularity until it is (core that sits between db/ui/output) is really flexible (any UI, any "SQL" db) and friendly (LUA scripting) enough.
Yes a great release, certainly the way you can change the layout of the UI is a good idea, but I'll stick to panels, also the file renaming/moving/copying feature has been reworked and is quite hard to get to grips with the first time you use it. I had a few crashes when viewing album art but it seems fairly stable.
Thanks foosion, I haven't notice the thread somehow.
First of all, thank you for your work!
I only have one question. When i add a folder to my playlist it appears a window with "Processing Files". Is there any way to disable it? Thank you very much!
Hm.. that window is there for ages. I think it is nice to see the progress as it reads file tags. What else do you expect?
If your file paths are withing the paths that are configured in your media library preferences this will not happen the second time you add them. Since the metadata will be stored in the media library and therefore fb2k will not have to read it from the files again. This has always been like that and is not new in the beta.
That setting is contained in an group box labeled "System Notification Area"; coincidentally it changes the icon in the notification area.
I find your sentence structure and curious use of punctuation a bit confusing, so I am not quite sure what exactly you mean. foobar2000 has had a modular structure from day one; the ability to use a different user interface module has existed since 0.8.* (or even longer, I am too lazy to check). Scripting would be a powerful addition, and I personally like Lua* for this purpose, but as it is users with no prior programming experience have already enough trouble when dealing with non-trivial title formatting scripts, so I do not think that "friendly" is the right word there.
*) The proper capitalization of "Lua" does not use all-caps; it is not an acronym.
I immediately liked the new Default UI a lot, but after using it for about a week now, I have couple of things I'd like to say.
A) This is an easy one and it's probably coming for the next version anyway, but I couldn't quickly find anything mentioned about it. What I'm missing is the ability to change font sizes more accurately. I'm using a remote control and I'm not always in front of the computer when I'm skipping or rating a song. It'd be nice to see the current song more further away and so far I've managed to set up this layout with two ridiculously looking playlist views: foobarDUI.jpg (http://koti.mbnet.fi/piqquam/foobarDUI.jpg)
B) I was really excited to see the new kind of spectrum. The way it shows how the song is played is something I've been looking for as a visualization since I played around in CoolEdit back in '67 or so. But the bad thing is that it goes the wrong way! It shows the history, what has been played already. What I'd really like to see, is the future: "Oh man, listen to this guitar solo, see, there it comes!"
(Not like "Oh man, did you hear that guitar solo? See, there it goes..? What do you mean you missed it!?")
i have similar problem, i used "track display panel" for large artist-title captions and additional info. that's one thing i really miss in current default ui (others are lyrics display, bookmark capability and some small tweaks). i would like to see it alongside with current "selection properties" element.
as for spectrum, i don't agree, it works just the way every spectrum is supposed to work. it is one of the reasons i can't drop 0.9.5 beta and downgrade. it gives you possibility to spot transcodes right in your player and that's essential for me, i've been trying to get something like that for years
it has some minor tweaks that should be adjusted, like default background color that isn't set on start-up but on beginning of a draw, so you have scrolling rectangle until it fills with your chosen color.
The one gripe I currently have with this interface is my seeming inability to remove the orange highlighting on the tabs. I've linked to a picture for more clarification.
(http://img90.imageshack.us/img90/265/mainsy0.jpg) (http://imageshack.us)
Relatively minor complaint all told, but still something that I feel should be changeable (and probably is, I'm just not sure how to.)
You have to change your visual theme in Windows for that. There is not - and will not be - and option for this in the Default User Interface.
What is "selection properties" supposed to do? I can't rename tags in it, should I? (it starts to blink as if I would be able) It would be great to be able to do that.
Another possibility would be to have links on everything so that if you double-click on the artist for example, the playlist would fill up with everything else in your library from that artist. Just an idea.
Nice to see an option to set additional directory for Wavpack correction files.
But I can't make to work a directory with variables, eg. d:\correction files\%artist% - %title%
I really like the new design, great job.
But I have a little problem with %bitrate% column!
All my CD rips are mp3 VBR, but the bitrate in the column doesn't gets updatet during the playtime.
Under "advanced" the VBR bitrate updates per second is set to 2.
Changing the value doesn't help.
The default UI does not support dynamic information such as vbr bitrate or playback time. Only the status does.
The Selection Properties element displays information about the selected tracks similar to the Properties dialog though it does not allow tag editing.
... unfortunately.
Edit: Just out of curiosity, is there a specific reason why it is not allowed to edit tag entries from Selection Properties Element? Security I guess? Having an Element version of File Properties Dialog would push a step ahead foobar as the perfect tag editing tool in my opinion.
When i start foobar the seekbar slider does not appear until i play a song.
Congratulations for the new release. I have been fooling around with it and it really is very easy to configure with very little titleformat editing. Really powerful.
I have some observations/questions:
1. The components page says that Autoplaylists and Masstagger are "deprecated components and that similar functionality is available on other still-mantained components". To which components do you refer? I cannot mimic their functionality with the current beta, specially masstagger scripting for entire playlists and creating autoplaylists.
2. Is there any easy way to search a playlist (former playlist_search functionality)?
3. There seems to be a bug in the components preferences page when you scroll the list down:
(http://www.divshare.com/img/thumb/2484825-fac.PNG) (http://www.divshare.com/download/2484825-fac)
WinXP with a 19' monitor 1280x1024px
1) autoplaylists can be created using
*album list - right click on nodes, or enter any query you need in filter box then right click all top node
*facets - right click on anynode you need
for mass tagging - sselect multiple files, go to properties window, right click in various places
2) tried pressing F3
A few requests:
-A "Now Playing Properties" panel along with the Selection Properties panel (or the ability to switch between now playing/selection mode). This would be useful for quickly getting info about the currently playing song without having to change the selection.
-Ability to edit tag info directly in the properties panel, just like you do in the properties window (but maybe have a confirmation dialog or the option to turn editing off to avoid accidental changes).
-Next/Previous buttons in properties dialog. I know this was asked for already and didnt get a good response, but I really do find myself wishing they were there. Ive been retagging my collection, and it would be really convenient to be able to scroll through songs in the properties window to check for errors and make quick fixes. I know about the "edit individual values" feature, but in most cases this is a hassle and I've nearly screwed up tags several times by not having songs in the right order.
Also, why are there no custom button toolbars? Wasn't this a standard default UI feature (or am I thinking of columnsUI)?
Yep. It would be easier to create, and the only difference would be that your playlist would have a Header.
Moderation: Removed unnessecary image quote
Phew.. Thanks.
Phew.. Thanks.
Remember that you will lose the ability to color text strings inside the new playlist element.
The deprecated masstagger component has now been replaced by the improved properties dialog, Quick Tagger(optional official component) and the 'File Operations' component in the installer, which isn't installed by default.
Hello, thank you very much, new foobar is awesome (as always).
Is there some possibility that in future foobar`ll play last.fm stream radios? Like amarok does.
I love the new release and the Facets plugin and this is the first time I've been insprired to build a new config from scratch in a long time. Thanks guys.
Amazing version!
Now it's time to remove old Columns UI and no longer developed Navigator theme.
I'm impressed!
Two things:
- spectrum miss scale of measuring, I don't know if it is 16 kHz or 20 kHz? I don't know if some ape is really ape file (full spectrum to 20 kHz), or for example fake ape (made from mp3's) (spectrum to 15-16 kHz)
- the preview of scripts should be one tab or stand alone editor with BIG and not narrow preview pane. many preview panes of scripts are to short to display full results of my complex scripting, also editing pane is to small at i.e. converter scripting, file operations scripting, and so on... consider it in full version, PLEASE !
all other is BRILLIANT
Don't know if this was requested before, but:
When scrolling panels with mousewheel in 0.9.5 beta1, the active panel scrolls instead of the one that is under mouse pointer - this is very inconvenient and I guess this could be considered as a bug, since other popular software for Windows usually behaves differently (scrolling the element that is currently hovered)
Please add it to the list of requests or open issues.
I am looking forward to messing around with 0.9.5 when it comes out of beta. Easier configuration and fewer external plug-ins equals good to me.
There are absolutely no real serious issues known in the beta (certainly not if you only use offical components), only a few small quirks maybe that mainly affect a few tiny UI glitches. You definitely don't have to worry about it messing with your system or your files in any way.
So feel free to have a look in case you are curious. Up to you of course since I con't want to talk you into anything that you don't want. Beta software is to use at your own riks of course, but I really believe there is nothing to worry about.
Another small thing I would be very grateful for is an option to disable row alteration in playlist view. As I understand, currently there is no way to get rid of it.
And one more: option to set middle-click action in playlist view (the same as it is done in albumlist). E.g. I don't use autoscroll and would like to set it to "Add to playback queue".
I'm having two issues--which may be related:
1) If there is an album selected--and the tracks are displayed in Playlist--the Clear command is not functional (grayed out). Or....if I highlight the Tracks the Remove command is not functional.
Only way to clear is using 'New Playlist'.
2) If I attempt to play a new file (not in library) by clicking it, Foobar will start but--if there are items already sitting in the playlist--Foobar will not clear them and play the file. Foobar opens, I get a brief 'Please wait' pop-up....then nothing.
Mark
Are there any plans to make he new play-cut-copy-remove-crop context menu items removable via prefs->Display->Context Menu like all the other context menu items?
If no, then why not?
Those items are playlist-specific, while commands listed at Preferences, Context Menu appear in multiple controls, like Album List, Facets, Playlist Manager, status bar, notification area icon, etc.
Can it be made possible that when you click the status bar you can see a volume slider like the previous default interface? I liked this option better because I don't use it that much so I don't like to have it on screen but when I use it it should be easily accessible.
Right-click on the status bar, enable Show Volume.
Right click the status bar > Show volume
one thing I'm bother about is the next command. In previous versions it either took the next one in the playlist or, if the mode was in shuffle, took the next random track. Now it always takes the next one on the playlist whether or not the play mode is shuffle or default.
So now, next isn't as useful as before. I now must have two keys for going the the next song, one for next on the playlist and one for the a random song, which is annoying
Is this intended (I guess it is)? Or just an anomaly?
Greetings,
Cease
So far I really like the new release. Memory consuming UI plugins are no longer necessary.
I have a couple of small feature requests, though:
1) In the Album List, can "auto-collapse on expand" be implemented like in the ColumnsUI version?
2) The new file operations interface is excellent! Can the converter be redesigned to work this way too? It would be nice to be able to use presets for various converter settings.
Thanks for this great release, and your time.
I'd like to see copy feature in future versions. Sometimes I need to copy list of my songs or just single song or selected songs to txt file etc.
I couldnt also find option that would let me modify duration column. I used to have similar formatting to this example:
Not playing - [3:00] (will just show time of song)
Playing - [1:02 / 3:00]
The statusbar is updating in wine with beta 2, before I had to minimize and restore the foobar2000 main window to get it to update.
Thank you. I know you didn't fix it for wine especially and you probably don't care for it, my guess is you did it for improved usability with screen readers, but still thank you.
It wasn't such a big deal for me and I'm certainly not going to start posting bugs that only appear in wine.
Keep up the good work, we appreciate it.
You can bind a keyboard shortcut to this. Preferences > General > Keyboard Shortcut > Filter for "copy name(s)".
I get this crash (picture) as soon as I press some times the next-song (random) button. I already deacitvated quite some components, but had no success yet, finding the culprit.
(http://img225.imageshack.us/img225/9388/zwischenablage1sy2.th.jpg) (http://img225.imageshack.us/my.php?image=zwischenablage1sy2.jpg)
edit: Problem seems to be gone after updating foo_uie_albumart (http://cherans.bol.ucla.edu/fooplugins.html)
Man this is so great!!!
Just today I was gonna finally give a go to ColumnsUI but before that I decided to check for new versions and this comes up
Now I don't have to use ColumnsUI, love the fact everything seems to be getting centralized instead of having to rely on a lot of 3rd party components.
the only thing I don't like is the fact album art is "fixed" completely so you can't roll your own filters for the AA component to find it
I guess I'll have to rely on some 3rd party component that supports regex.
Why is the Copy command formatting string deprecated?
It's very difficult to edit in the Advanced preferences page now.
Yes, albeit those settings won't be changed everyday, structuring of navigation is overdone, not so well arranged anymore ihmo.
I've read the changelog but couldn't find the changes of the 0.9.5 Beta 2.
I found that the Spectrum now displays the channels correctly without the garbage at the top.
Now I realize that maybe the changelog hasn't been updated yet.
Focus question.
Why doesn't clicking on a tab give focus the the Element contain within that tab?
e.g. this is my layout:
(http://img265.imageshack.us/img265/5461/foobar095b2et6.th.png) (http://img265.imageshack.us/my.php?image=foobar095b2et6.png)
Say I have focus on my playlist. and by sidebar is currently o9n the playlist tab, like shown in the above pic.
If I click the albumlist tab, then move the mousewheel, I am expecting the albumlist element to scroll as it is the only thing in that tab. Instead, the playlist scrolls.
I remember Peter mentioning in IRC that the way the Copy command is handled will be changed in the not-so-distant future. It's only in Advanced for a little while until he decides where to place it.
Please see known issues and feature proposals (http://www.hydrogenaudio.org/forums/index.php?showtopic=58351) for the changes in beta 2.
The copy command string happens to be part of a deprecated API. There is no plan to get rid of the "Copy Name(s)" command as such; on the contrary it is likely that there will be an improved version of this command some time.
Album List auto refresh when Media Library content changes.
How does this work..... when I change a directorys name via windows explorer, does album list automatically know, a directory has been changed? Or do I have to rescan media library?
Thnx
Media Library content changes when you rescan it.
Hey there guys. I just did something really stupid. I opened my old foobar version and when I opened the beta all my playlist names had fubar'd. Is there anyway to get the old names back? Or should I just start again. Most of them were autoplaylists so even if I get the names back they won't update right?
(http://img48.imageshack.us/img48/2589/playlisterrorsr0.jpg) (http://imageshack.us)
I hope that pics not too big if it is heres the thumb
(http://img48.imageshack.us/img48/2589/playlisterrorsr0.th.jpg) (http://img48.imageshack.us/my.php?image=playlisterrorsr0.jpg)
Focus question.
[a href="http://img265.imageshack.us/my.php?image=foobar095b2et6.png" target="_blank"]
How doing that not give the element focus?
In 0.9.5 beta 2 I can't figure out how to tag music files using filenames and filepaths and a pattern like for example:
%artist% - %album%\%track% - %title%
Quick Tagger can't do it and File Operations is just the opposite (rename/move files based on tags instead of tagging based on folder and filename information). Neither do I see a way to achieve it using the Properties command. In former versions this was easy to do right clicking on selection.
Thx for clearing up.
And: Congrats for making fb2k better and better (and that's hard!) and keep it free
open the properties (metadata-tab) and you will find an entry "automatically fill values" in it's contextmenu.
by default the source is "file names". change it to "other..." and enter %path% instead of %filename%.
now your pattern should work!
(at least it works for me)
Using %path% would mean that you would have to specify the whole path to the file in your pattern (e.g. C:\Music\%artist% - %album%\%track% - %title%).
In contrast to that, you only need to specify parent folders with the "File Names" source:
Works fine for me.
By the way, guessing tags from the filenames (edit: in the Properties dialog) is not a 0.9.5-new feature, it has been possible since 0.9.3 (July 2006).
...you only need to specify parent folders with the "File Names" source...
LOL...ok, that is easier, of course. :-D
did not even try it as the expression "filename" does not naturally include the folder....but good to know it works though!
...works just with parent folders, too (obviously %path% and %filename% are not interpreted the way we expect them to)
The "Automatically Fill Values" is the trick thx. The most obvious or natural place to look for the option of tagging based on filename and path is in the rightclick menu "Tagging", as it was in v0.9.4.5, at least for me and I think for most people is.
If I click on a group header, all of the songs in the group are highlighted. If I then hit the page up key, it takes me to the top of the playlist instead of up one page. Is this a bug? 0.9.5 b1 and b2, default UI
Thanks for reporting. The issue is beeing looked into at the moment.
Edit: Fixed for upcoming beta 3.
Adding/enqueueing files in foobar 0.9.5 beta 2 causes a crash. This is reproducable with multiple different mp3s and flac files. For some reason I have one mp3 that works and enqueues and adds fine...
EDIT: Never mind! Updating the foo_ui_albumart component fixed the problem. I should have read the thread first.
I've browsed the topic here, but didn't find answer (or I just didn't saw it). I can't show console, cause when I'm doing that it just pop-up the window, but with a message 'Could not initialize console: Service not found' instead of standard console communicates.
Looks to me like you removed the new foo_ui_std.dll or are running with the old one.
Hm. I can't seem to find two things after upgrading:
- The playlist cut/copy paste options. The changelog says they are integrated to the core now; however, I can't seem to find them. When searching for strings under the keyboard shortcuts option, "Cut" and "Copy" only come up for layout options.
- Copy Info between files. This was a handy method of copy tags from a tagged album to one that was yet untagged. It's a part of the masstagger, and I don't see a simple to use function in the new file operation dialogs.
I've updated foo_utils as well.
Ctrl+X and Ctrl+C and Ctrl+V
They are also in the Playlist's context menu.
The Properties dialog has been better at this than mass tagger for a long time.
0.9.5.(b.2) - brilliant! Thanks to all developers!
Now just half an hour configuration instead of days...
Wishes It would be good to see in final release option "Stop after queue" and ability to assign keyb. shortcuts for DSP Manager presets. And maybe one crazy visual option: "Load random color scheme at foobar startup"
(http://img140.imageshack.us/img140/6958/image1yn3.th.png) (http://img140.imageshack.us/my.php?image=image1yn3.png)
When I filter the list for the keywords "cut" or "paste", I can only find options related to the layout. Theres a "copy" option, which describes itself as "Copies selected tracks to Windows Clipboard", but I can't find neither Cut nor Paste.
Is there a way to do it that doesn't involve opening multiple properties boxes? The masstagger one was compact, fast, and effective, and all it required was highlighting files next to each other, in order.
Edit: Another minor thing. I see it is now possible to set the number of work threads for the converter. Very handy option, since in dual core machines, you can now force 1 threads, which improves speeds when working with files on removable media (such converting files form a DVD).
However, forcing 1 work thread is a regression when I'm converting files from my HD, which can handle multiple simultaneous reads.
Would it be possible to set up the Converter so it uses 1 thread when converting from cd/dvd/drive number "x", and 2 threads on my hard drives/drive number "y, z"?
One thing i would like to see in a future version of foobar is the possibility to rightclick in the album list and select "delete from library" or something similar.
Edit: Sorry, i did not mean spam the forum. i understand that my question is not related to the beta testing
And thanks for pointing me in the right direction Frank
When I filter the list for the keywords "cut" or "paste", I can only find options related to the layout. (...) I can't find neither Cut nor Paste.
Cut/Copy/Paste commands cannot be assigned to custom keyboard shortcuts.
They only work in certain elements and are hardcoded to Ctrl+X/C/V (i.e. the Windows standard shortcuts).
No, but the solution is still fast enough, and you get a proper preview of how the tags are going to look like.
Select the source files, open Properties, select all fields (Ctrl+A), copy (Ctrl+C), then open Properties for the target files, and paste fields (Ctrl+Shift+V).
How is that related to 0.9.5 beta testing? Please do not spam this thread with random proposals.
And actually, it's already possible. Just add the "Remove File(s) from Library" command at Preferences, Display, Context Menu. Note that these files are going to be readded as soon as you rescan the library or add them to a playlist. If you want to physically delete the files, use File Operations, Delete Files. This requires the File Operations component which has to be selected manually during setup.
Does that include selected tracks in the playlist, because it doesnt seem function that way. It was something I used very, very frequently.
I know its possible to do it, but as I pointed out, opening multiple properties boxes is much slower.
Anyway, I still use the masstagger so its a moot point.
Yes, it does. You should also see the commands in the context menu. If that is not the case, then you don't use the Default User Interface.
That seems to be the case, as I use Columns UI. Any idea how can I reimplement it? It's one of my most often used shortcuts...
edit: nevermind, it seems to be a foo_utils issue. I downgraded it to the last 20070125 version, and the commands are back.
edit2: Some problems I noticed in the default uis custom playlist views. It is used for the search dialog (Which I custom mapped to ctrl+f under columns ui). The problem is that it does not override keyboard shortcuts like it used to do (and as every other panel does). So for example, if I have the Spacebar mapped to play/pause for quicker controls, I cannot type search strings with a space in them. It will instead pause the song as I attempt to do so. I realize that Foobar even warns me to not add common keys as shortcuts, but other then this new search window, I've experienced absolutely no issues.
This also makes it impossible to copy/paste phrases from notepad for example, as ctrl+v is mapped to playlist paste. Both of these issues exist using the default ui as well as columns.
And while I'm talking about the new search panel... It is not configurable under columns ui, the config page drops to the blank "another user interface is active" page.
Furthermore, quotes have no effect. Searching for "Dust and" will hit everything that has both the words "Dust" and "And" in them, instead of just dropping back the track that has the exact phrase "Dust and". I seem to recall this working fine in older versions, making it a regression.
edit: problem fixed
It'd be nice to see the option to disable multiline tabs in favor of left/right buttons.
oh hell, i'm really longing for a linux port
i tested it on xp, but the annoying thing remains: when i upgrade foobar (eg. uninstall prev version and install the new one) my preferences are lost (the config files are removed from application data), so i had to set it up every time a new version comes out. WHY?
Just install over, no need for uninstalling first and you can keep your configuration.
hell yeah, should be obvious to me, but it just doesnt always work this way. the installer may notify me that it will be a clean upgrade not some copy-over stuff
The new file-edit dialog is really great. Filecopy/move-dialog is also a great improvment. I first though: "Oh my - a lot of work to get it working the way I used to do it with masstagger" - but hey: brilliant!
I have little suggestion for the dialog: Could we get a drop down-history for the upper field too?
(http://img216.imageshack.us/img216/2677/zwischenablage1cn1.th.jpg) (http://img216.imageshack.us/my.php?image=zwischenablage1cn1.jpg)
It moreover would be nice, if the size would be saved. The dialog is too little.
Common practice is to backup both your settings and foobar folder before upgrading.
Or do it manually using 7zip, open the installer and overwrite appropriate files.
Foobar 0.9.5b2 is great, but there are some basic things that are missing IMO. It would be awesome if we could have the features of "album list panel" inside album list. I'm talking about basic features like the album view playlist with "auto send to playlist", that shows immediately the contents of the folders that are focused inside the album list.
Also, album art viewer doesn't show the contents of the focused items inside album list. It only shows the cover of specific focused tracks and not entire albums too, as it should be. Except the above two missing features, i found that when i am in "Layout Editing Mode", i can't delete a UI Element but only cut, copy or paste it. It would be veeery useful if you add the option to delete UI Elements when anyone wants. I'm sure that i'm not the only one who needs these features, because they are very basic and important,so please if you can, consider adding them.
Except the above basic things i think that it would be very good if we could change the playback buttons with our "button kits". This could improve a little the UI. Also, inside the playlist, when we group by artist date and album, it could much more readable if artist and album/date were in different lines, because when album or artist names are long, its easier for the eye to recognise quicker the album title or the artist name (because they are in different places and not the one after the other). I believe that this saves time, and make playlist more organised.
Thank you very much for this great program!I'm going to miss UI Panels a lot, but i believe in easy and flexible design of the new Foobar.
Hi, was wondering if tagging features; manage scripts, and auto tracknumbers, are gone? Am I over looking these? Thanks.
herefornow
Tagging features can be found in the Properties dialog (right-click on a selection, Properties), including automatically setting track numbers and total tracks (right-click, Auto Track Number), filling values from the file names, formatting fields by means of titleformatting, capitalizing values, and so on; all in the context menus of said dialog. There also is a new Quick Tagger (http://www.hydrogenaudio.org/forums/index.php?showtopic=58234) component to set predefined values from the context menu or with keyboard shortcuts.
The Masstagger is no longer developed. It has been removed from the setup and is available at the "Optional components" site as a deprecated component.
Is it possible to process files per 'Automatically Fill Values'-pattern directly by context-menu or at least keyboard-shortcut, comparable with the masstagger-scripts ?
The 'Automatically Fill Values'-panel is nice and has some nice options, but sometimes you want to go the direct way, without click, click, click, click. At least 2 clicks and to much selection on the way IMHO.
The improved Properties Dialog now integrates tagging-features which previously were part of the Masstagger.
Deprecated components: ..Masstagger..
Thanks Frank, appreciate the help. Really searched before I asked, looked right past it! This version is working fine for me.
cheers,
herefornow
I'm really impressed with new UI and components. Finally changed from old-customized Navigator theme to something new. Organizing music is so much nicer now.
Besides of what is mentioned in feature proposals thread (colors, tabs, alignment, spectrum options are the most important for me) I dare to suggest a few other things:
- $caps2 feature in properties window
- Selected files count in statusbar (if playlist is long, there is no easier way to tell if what we see as selected, is all that its really selected)
- Would be nice if double clicking on row generated by grouping scheme (in playlist) could call properties window (or possibly be configured to anything else), now it plays first track from this selection (pointless IMO as the same can be achieved by double clicking one line below)
- In selection properties element - could there be added option to disable display of caption? In my case, this component is set up that each information (Metadata, Location etc) is displayed in its own tab - so the same information as in caption is already in tab name.
- Now its hard to include all information in grouping scheme, for me perfect would be: album artist, year, album, genre, AG, totaltracks for full information. I wish that there could be added second line to grouping scheme, preferably with smaller font.
- Borders for collumns
a (not small) feature request :
can see the album art in the playlist, like in Windows Media Player or in foo_ui_panels.
It would be very nice (and i think its also very easy to implement) if we could add a resizable space in the toolbar (like the one in the Firefox toolbar - only more precise). This would help to position the other ellements (like buttons or volume control) anywhere in the toolbar. Right now i had to use the "layout editing mode" button so i can keep the volume control on a normal size.
click for full size:
(http://xs121.xs.to/xs121/07444/foobar.png.xs.jpg) (http://xs.to/xs.php?h=xs121&d=07444&f=foobar.png)
+1
I doubt it will happen but its the only reason im sticking to panels. Gotta say the new default UI is a big improvement and step in the right direction
I love the new foobar beta. I appreciate that the authors are trying to make this incredible program more friendly for beginners (like me) whith the new default UI.
I was wondering if custom capitalization schemes will be possible in the future. Maybe a option in "Preferences" - ... - "Properties dialog" could be added for the "Capitalize" command.
Not all languages use the English capitalization scheme, and I prefer "feat." instead of "Feat." etc.
so wait... are most of the components i currently have installed going to be compatible with the new beta?
Yes. But maybe not the new default UI. But you can always use a different UI than the default.
first of all: you did a wonderful job! chapeau!
one tiny feature request: is it possible make the ui element over which the mouse pointer is hovering react to the scroll wheel instead of the currently active ui element? that would add a lot of usability to the interface!
thx,
frncle
--edit:
the volume slider already works like that, if you could extend this function to the other elements, it would be perfect!
request has already been posted by another user:
http://www.hydrogenaudio.org/forums/index....showtopic=58673 (http://www.hydrogenaudio.org/forums/index.php?showtopic=58673)
It allows too many nonsensical combinations. How would you sort %artist% by %tracknumber%, for example?
On one hand I'd say if the user really wants to do that nonsense, let him do, on the other hand I understand that this breaks the principle of easy configuration, because the user can unintenional do something he don't want to.
In Facets, you can already add both Artist and Artist Sort columns, sort by the Artist Sort column, and finally hide the column by resizing it to a width of 0px.
This is total sufficient. I didn't play too much with facets until now, so I didn't see this solution. But it can't be used for album list.
Another small feature request besides the 'use scrollwheel on mouse-over ui element instead of active ui element' one (foosion, could you add it to the request list so it won't be forgotten?):
Create a new playlist on double click in the playlist manager.
Having uninstalled CUI,
frncle
questions:
a. can i see the song that is curently playing in albumlist somehow? (i mean by clicking something)
b. is playback queue visualized someplace? (like playlist?)
c. is it possible to remember status, size, position of undocked components like eq or console? (they should survive the player restart)
Foosion's site ( http://foosion.foobar2000.org/0.9.5/ (http://foosion.foobar2000.org/0.9.5/) ) has foo_pqview, which allows you to turn a playlist into a queue viewer.
In the library/album list, I wish there was a "Clear" button to reset the search field
Sorry if this was already discussed, couldn't the Playlist Search being implented as an UI Element?
Select all, Delete.
This has been added with beta 3, check the new option at Preferences, General to activate it.
almost perfect
Works like a charm! Great!
frncle
I installed beta 3 under Vista (32, UAC enabled) with the setting "Install for all users" enabled and "Enable per user settings" disabled.
When starting Foobar I need to select a theme, but when I do this I get the error "Theme could not be written Access Denied".
Procmon says access is denied writing the file theme.fth.tmp in the foobar map itself.
The users profile switch should never be disabled under Vista. UAC does not allow unlimited access to folders such as "program files". Therefore programs themselves also can not write files to said folder without running into various issues.
Maybe the installer can be changed to warn users running Vista not to use this option? (Maybe it wasn't clear from my post but I'm well aware about the Vista rights in the program files folder)
The installer will either be changed so that this option will be greyed out where it really shouldn't be used or some other other option along those lines to warn users of this behaviour.
Select all, Delete.
Wow, I didn't know that I can do this. Thank you for pointing it out. I'm forever in your debt!
In 0.9.4 the current volume (in dB) was displayed in the lower righthand corner, is there any way of getting that back? As much as I like 0.9.5 I hate not seeing what volume foobar is set to, and I don't want to use the volumeslider.
Hint: Right-click on the status bar.
Too obvious, okay? Thank you so much!
Please only warn the user, as some ppl know how to deal with UAC and still use foobar with Enable user profile support disabled.
On a side note, if you use Vista with UAC and having problem with certain legacy program writing to protected folders, just install it in a different folder that you created. If it doesn't work at that time (due to Vista inability to virtualize it with VirtualStore folder or more like that legacy program likes to write to other protected folders too), you will have to run it in Administrator Compatibility mode. You will also have problem with programs like to write to HKLM tree in the registry.
[a href="http://img225.imageshack.us/my.php?image=zwischenablage1sy2.jpg" target="_blank"]
Even if the option to disable user profile support will be removed from the installer, it will still be possible to manually remove (or create) the user_profiles_enabled file so no functionality is lost.
seems an easy enough question, but once i create a new UI element space (by putting in a splitter, whatever), how do i delete it?
also: how do I make it so that the album art display only shows the now playing track instead of whatever i happen to be clicking on? if people are going to be using the Album List to create playlists and such, they'll be seeing that annoying [multiple items] message pop up waaaaaaay too often.
also: how do i remove the sub-item count from the album list panel? deselecting it in the preferences doesnt seem to do anything.
Some more proposals:
- Include the properties window font into the font and colors page and make it use the system font by default. The font can already be changed in the menu that hides behind the window icon (hard to find, i changed it about a year ago and it gave me a severe headache when i tried to find the option an hour ago...). Viewed from a usability perspective, the current solution is, well, not too good...
- Apparently, many people do not like the current buttons. What about switching to the simple white Tango media player icons (http://tango.freedesktop.org/Tango_Icon_Library) (fourth line from the bottom in both sets)? They are quite neutral and fit to many visual styles.
- Talking about matters of taste: I liked the old icon better as well (it has already been mentioned elsewhere). It's harder to recognize the logo now...
- I already mentioned it, but got no response: What about making the playlist manager create a new playlist if a blank line is double-clicked (like on a blank area of the playlist tab bar). Sorry to mention it again, but I use the manager instead of tabs in my new config and this function would come really handy.
Thanks to all devs for your hard work!
frncle
We'll see what we can do about that in the future. Tango icons? Certainly not. Also a matter of personal taste I'd say.
This has already been discussed extensively in the 0.9.5 icons thread (http://www.hydrogenaudio.org/forums/index.php?showtopic=58403).
Just posting to say a big thanks to the developers!
I'm loving the new ui configuration abilities, I prefer it by a mile to columns ui
Bug ?
The playlist switcher toolbar seems to always draw a vert scrollbar whether the list is scrollable or not.
foobar2000 0.9.5 beta 3
Default UI
Windows Vista
@Cosmo: weird, no such problem over here with the same configuration.
EDIT: Sorry, it does happen. I was looking at the playlist switcher element not the toolbar.
how can i remove the thick borders between the fields?
I have problem with new UI and specificly with the custom columns.
Those aren't working: %playback_time% and %playback_time_remaining%. They are OK in status bar.
Not a bug, that behaviour is intended. Playlist columns do not display that kind of dynamic playback information.
In FLAC 1.2.1 changelog I found this:
Ogg FLAC format:
This is not a format change, but changed default extension for Ogg FLAC from .ogg to .oga, according to new Xiph specification (SF #1762492).
So fb2k should support Ogg FLAC files with oga extension
I have a suggestion -- you can delete playlists by middle-clicking the tab, but it deletes immediately on mousedown; for such a destructive action, I think it'd be better if it deleted on mousedown+mouseup instead (feels more natural imo and gives the user a chance to abort). Thanks for the consideration and keep up the great work.
Ah, so i have a similar suggestion:
like in firefox, foobar could handle a middle click to a free area in the playlist tabs to restore the last deleted playlist! at the moment it just make a new one (just like a double click)
just a thought
any ideas? these are pretty key elements even considering the focus on usability over appearance.
The first one has been answered before: cut the element you want to keep and paste it in the place of the splitter. Alternatively cut the splitter without pasting it anywhere and add something completely different.
The other two things have been on the known feature proposals list for quite some time already, i.e. it is not possible to do that at the moment.
0.9.5 is amazing.
But one thing I would like to be restored from the old version : return the old volume bar setting, so it will be "log" and not "linear"
hi,
could you please include an "old playlist format" option?
coz i don't have tags in my tracks. the "File Name" option works for single files, but if i load a cuesheet, this is obviously not the way, coz all tracks on the album will have the same name. so i'd have to switch between file name and artist-title all the time
thanks in advance
0.9.5 is amazing.
Yes, amazing it is!
I just played around with my config again in order to create a more compact layout. Doing this, I realized that two or three things might facilitate gui configuration a lot:
- Include window sizes into exported config files. Very often, clean display of column widths and album art viewer sizes depend on pixel-exact window sizes, so it might be useful to include them into the export files. if someone (like me) plans to switch between two different views, (s)he doesn't have to do the resizing all the time...
- Closely related: I'd like to have an option to switch between two or more different configs (with different window sizes, see above). In a way, that's an evolution of the scratchbox approach..
- Last but not least, I'd love to be able lock the window size completely. I know I can lock the width of elements seperated by splitter bars, but I can still change the window size along the splitters (Do you get what I try to say?)
That's all for today,
frncle
Use Theme files. Preferences, Default User Interface, Import/Export Theme.
If they only contain layout or color settings and are stored in the themes subfolder, they will also be listed in the Quick Setup dialog.
Thanks for your quick reply!
That's exactly what I do for the time being.
Unfortunately, they contain more then this (all boxes checked). Since configs containing all the information will probably be exchanged quite often here, maybe it's worth adding a 'complete configs' window in the quick setup? Or a submenu for those, even better!
Lock both splitter panes of the top-level splitter.
Hmm, I've only got one left/right splitter in my layout. [My Config] (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=58574&view=findpost&p=527067) [My 'Shrinked' Config] (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=58574&view=findpost&p=528778) Both panes are already locked (width only), but I can still change the height. Since my two configs have different heights, I have to adjust it whenever I switch...
Enjoy your weekend,
frncle
+1 new beta is sweet (very very sweet), but i do miss being able to hit tagging scripts from the context menu.
Just wanted to say thanks for the new version. This one has me switched over completely to foobar now. Just wanted to suggest two things. When you deselect the program, but foobar is still visible, the Album Art of the currently playing song disappears and it says No Selection. I think it would be nicer if the picture would just stay. Furthermore an option to remove the splitter bars once you have everything set up would be nice.
There's a typo in the Fix VBR header dialog, second paragraph
...- Include window sizes into exported config files. Very often, clean display of column widths and album art viewer sizes depend on pixel-exact window sizes, so it might be useful to include them into the export files. if someone (like me) plans to switch between two different views, (s)he doesn't have to do the resizing all the time...
Try locking the splitters containing these elements (right click on the splitter bar).
I really love the new foobar2000.
What I miss is, though, where can I now add the formatting strings for the actual playlist?
Mind, with the new layout options I might not need it, but I had a really nice one which assigned random colors to artists and I might like something similar ...
Has anyone else noticed that foo_albumlist now seems to be dependent on foo_ui_std? If you remove the standard interface (and use columns ui or something), going to the library menu and clicking "album list", or going to the preferences and activating the list from there do nothing (no window shows up). Not good.
http://www.hydrogenaudio.org/forums/index....p;hl=foo_ui_std (http://www.hydrogenaudio.org/forums/index.php?showtopic=58795&hl=foo_ui_std)
So yeah. But in my defense, that post was NOT very search-friendly
!!!THANKS TO PETER FOR THE NEW GREAT DEFAULT UI!!!
(Now I don't know which UI to use: Default, Columns or Panels...)
I have a few proposals:
1. It would be nice if I could select a number of fields in Selection Properties panel and copy/cut/delete/paste them. And if preferences of the panel (table: metadata/location/general/replay gain/other) would appears when I right-click columns headers of the panel.
2. Antialiasing in Spectrum panel.
3. I would like Album Art Viewer panel to be much more configurable (i.e. I store pics in other folders, with other names...).
4. I would like to have Lyrics panel, Peakmeter panel.
5. It would be nice if the buttons (stop, play and other) would be configurable and skinable like in UI Columns.
Thanks for the advice!
However, as I explained some posts below, this doesn't help in my case, since the splitter lock only works in one direction... Furthermore, saving the window size in export files would make sharing configurations much easier. Actually, it's an important part of any DUI configuration, isn't it (even the display of maximised-window-configs is dependent on the screen resolution)?
frncle
I second fooruncle's request. It's quite inconvenient to resize window after importing some config or even just applying the layout from scratchbox.
Is there going to be another beta release, or should we expect the offical release next?
(I know the know/fixed issues page mentions beta4, but that may just be the official release)
Beta 4 is there since a couple hours.
Issues fixed in beta 4
* Bug: "Reset Page" doesn't reset playback state display formatting settings in Preferences / Display / Default User Interface.
* Glitch: When starting playback of slow-to-open files/streams, status bar still shows "stopped".
* Glitch: MP3 decoder was using wrong compiler settings, resulting in a slowdown.
* Regression: Some Converter error messages less readable than in pre-0.9.5.
* Usability: "Send to Playlist" dialog is modal.
* Usability: "Create Album List View from These Items" dialog content doesn't update with moving/deleting files.
* Bug: When using the copy command in album list and pasting the result in search filter the last letter is not copied
* Usability: Open Audio CD dialog: "Add To Playlist" button not disabled when currently active playlist is an autoplaylist
* Usability: Open Audio CD dialog: "Open Audio CD..." menu command spawns another dialog instead of activating already existing one when one already exists
* Usability: Open Audio CD dialog: "Rip" button not always grayed out when Converter component is not available
i don't like the new equalizer, there's no numbers for the level, can't u add them like in the old version?
when I do a file operations rename - there is no way to auto capitalize file names, like there is when you tag files.
i guess the work around is to tag first and then rename the files accordingly
additionally when i do a file rename and when changing one file to another based on my naming standards - sometimes I get a duplicate - it it possible to have an option to delete if already exists perhaps based on name / file size / bit rate - I think this would be a good option.
i like the notification to say there were failed attempts to rename but maybe a better dialogue box could be created or a list of left hand side vs right hand side and then you can tick the file to keep and the one to overwrite..
But foo_utils is still 0.6.2 beta 3 (http://foosion.foobar2000.org/0.9.5/). Does this mean anything? Because usually there was a new foo_utils for every new core beta...
No, foobar2000 0.9.5 betas and foo_utils 0.6.2 betas are not correlated.
Just registered to say Thank You! to all the folks who made this release possible.
I am in love with the new Default UI. Everything is stable and working well.
There are a few things i would like to suggest / ask though:
1• I used to have keyboard shortcuts to some of the context-menu Tag Scripts to rate the current playing file quickly. What would be the alternative now that it seems there are is no Edit Tag dialogue? It is simply too cumbersome to open the Properties dialog and fill in the RATING tag manually.
2• What happened to the Buttons? even the buttons with beta3 seemed to be fine, pretty nice and simple. The buttons with beta4 seem to be distorted and uglier siblings. Custom buttons would be fine as suggested earlier, if the process can it can be kept simple, but the default buttons should at least be usable!
3• It would be nice if there were some option to customize at least the Group Header Text in the Playlist View Groups, or some way to shade groupings.
4• Is there a way i can customize the filenames that the new Album Art Viewer searches for in a folder. What does it look for by default?
5• I prefer the default seekbar slider prior to 0.9.5. It was 'Sharper'. (I am on XP with Themes disabled.)
6• Numbers indicating the amplification levels in the Equalizer (as it used to be earlier) would be great.
Thats all as of now. Will Play some more and get back.
Thank you Again.
The masstagger is not an optional component, its command is now called "Tagging/Manage Scripts". However, for simple things like rating, the new Quick Tagger is easier. See the optional components (http://www.foobar2000.org/components/) page for both.
You can already create custom grouping schemes. See Preferences > Display > Default User Interface > Playlist View.
See Known Issues and Feature Proposals (http://www.hydrogenaudio.org/forums/index.php?showtopic=58351) and recent posts for answers to your other questions.
thanks Foosion for your reply and patience. didn't notice the Quick Tagger optional component earlier.
i meant customizing the color/font/background/border etc. i guess:
# Feature: Color and tab rendering in custom columns ($rgb and $tab)
would be a step in that direction.
and here are some more Thoughts...
1• one thing i haven't been able to achieve is the display of lyrics without the use of UIpanels in the default UI. I think the Selection Properties UI Element can be made more powerful if one can choose what information is displayed via Title Formatting, thereby displaying embedded Lyrics if i want it to. Also, as of now when i click on the fields in Selection Properties it shows an editable box, but i can't edit the data. If the data could be directly edited for some of the fields, it would be quite useful to edit some tags quickly e.g. Comments etc. (In a way it would intuitively provide the functionality of the InfoBox plugin)
2• the search box could be available as an UI Element, displaying/updating the results in a Playlist.
3• i have always missed the ability to browse the playlist with keyboard alphabets i.e. for example, in iTunes, if the playlist is sorted by artist and i press the 'R' key on the keyboard, i am brought to the first artist track that starts with R and so on... Its a default Explorer behaviour. It would a nice addition that would make browsing simpler (though i don't know if its simple to implement!).
4• is there a way to save the sorting schemes (formatting patterns) in Edit>Sort>Sort by.... (i am sorry if this is too generic a question and not appropriate for this thread.)
foosion,
The feature proposals post (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=58351&view=findpost&p=525549) wasn't updated for 3 weeks, maybe it's time to do so? This would be great. Thanks!
That's because they don't want you to know how many dB's you in- or decrease an eq-band
But that doesn't matter actually... it's always those gigantic 1 dB-steps... a very special feature for more or less deaf people, courtesy of foobar
would it be possible to add an option to ditch that gradient shading of every toolbar component in final?
it ain't working on customized layout, my foobar looks like patched up frankenstein. also if that "order" word could be kicked out of "playback order" component it would be great.
[a href="http://img135.imageshack.us/my.php?image=clipboard03ay4.jpg" target="_blank"]
Bug in
Preferences->File types:
When I press column header "Discription", icons in left column did not sort out correctly.
I loved the 0.9.5 beta 3, so I was really excited to upgrade to b4. I used that new customizable interface as much as I could: nothing fancy only the elements that came standard in the interface designer.
However, now whenever I have FB2K running and switch windows, and come back to FB2K, the previous window image is "stuck" in the playlist window. Even if I minimize and bring the window back, it does not show the playlist section. I uninstalled everything from the b4 and went back to the b3 but the bug persists, which makes this more frustrating.
I take immaculate care of my computer. This is getting annoying since I haven't installed anything new. Any one else experience this problem?
I've had it on and off with all the betas. My problems always occured in the facet windows, but have stopped since the upgrade to the 11/10 versions of facets.
Problem with last version (0.9.5beta5) - not work "install for all users"...
Works fine for me though ...
A totally fresh install or an update above beta 4? Since I did an install above beta 4, "install for all users". I don't know whether it's vital information, but describing the situation can't be too bad.
bug
when i have a playlist that shows the playlise file size eg 1.6gb and i slowly start removing files and i get to 1.1gb and removed one more file so you would asume it would go to something like 1.09gb but instead it shows 1.9gb all the way down to 1gb... i can do this reliably, it comes in to play quite a bit cause i try and make playlists for my ipod and keep overshooting, so i need to keep trimming the list until i get it right.. but when i remove 900mb and all of a sudden the playlist says its 1.9gb again its really strange...
im an guessing its just a formatting issue or something?
I find the following usability issues with the new beta which in my view need revision
F3 or CTRL + F only instigates search if a playlist has focus. It will not work if another ui element has focus. This seriously compromises the utility of the search function.
Search text box crashes if backspace is used. (beta 3 - unconfirmed on beta 5)
Keyboard arrows no longer work position slider. (I am aware of the present policy on keyboard shortcuts but this one seems unnecessary and very limiting)
Position and volume sliders are large and ugly.
Having the search box as Ui Element (Toolbar like old foo_playlist_find for 0.8) would indeed be nice: founded tracks are highlighted and you can navigate through them by up and down arrow keys.
An own playlist for displaying results is a little bit too much. Once the quicksearch plugin is ported you will have that feature anyway.
it must be a forget, they'll add it in next version
I was just curious about if it's on purposse that fb2k needs to be maximized and closed two times after eachother before the maximized window state is remembered/retained ? Just currious, since i know that it wasen't behaving this way in v0.9.4.5.
Where can I find COPY options in Foobar 0.9.5 ? I meen Copy text, not files ...
All of the 0.9.5 betas seem to forget their window positions on both of my computers as well. I have to resize and move the window every time I restart foobar.
They have been moved to the Advanced prefernces. You can find them at Preferences -> Advanced -> Display -> Legacy title formatting settings.
Thanks !
This bug's been around for awhile:
I have foobar semi-transparent on a second monitor. After right clicking folders/files in an explorer window and playing or adding to the queue with explorer's context menu, foobar becomes opaque even though it doesn't receive focus and I have to give focus to foobar and then click off it for the transparency to return.
vista and 0.9.5 beta 5
Pick a frequency band. Pick a source sample. I bet you can't ABX the equalized version from the source with a 1dB difference in any given frequency band. +1dB on all frequencies is hard enough to ABX. Yeah, 1dB is a reasonably significant change. Still, it's sufficiently small for the application. You don't seriously need sub-decibel equalizer resolution, do you? For what purpose?
Is it just me, or did anyone else think that Wavpack decoding speed has dropped dramtically?
In foobar2000 0.9.5 beta 6 mpc files decoding speed is less than in beta 5 (I use decoding speed test plugin - foo_benchmark)???
Looks like importing project files from MSVC8 to MSVC9 disabled speed optimizations on some of decoders. The issue will be addressed in the next beta.
Issues fixed in beta 6
* Usability: Single-keystroke keyboard shortcut mappings taking priority over typing into editboxes.
Thank you, this so much made my day. I'm glad this annoying issue has been taken care of.
Note that the workaround for single-keystroke keyboard shortcuts stealing input from editboxes in beta 6 is partial/incomplete, it will be fixed properly in beta 7; at the moment, keys such as plus/minus signs (mapped to volume control by default in older versions of foobar2000) still can't be typed if they're assigned.
After this is properly fixed, please return default key-mappings of pre-0.9.5 foobar2000 versions. Thank you!
Using pre-0.9.5 style default keyboard mappings is a bad idea, they clash with Album List navigation (auto-search by typing item name) as well as with auto-search in playlist that will be implemented in one of upcoming releases. You can re-add them manually without ruining any important functionality now, but that doesn't mean they don't break anything.
# Usability: Single-keystroke keyboard shortcut mappings taking priority over typing into editboxes.
Thank you, Peter!! For me, this is the single most useful (immediately visible) fix since beta 1. Playlist search was unusable if there were any single key shortcuts, even when using Columns UI.
Show my respect to Foobar2000 community.
What a nice surprise !!! So I was looking around for some automation around album art, and what do I find: a nice new beta, allowing to configure it graphically much quicker than before.
Thx guys, way to go.
The beta version is awesome! I am officially wiping Winamp from my system and using foobar2000 exclusively. There are a few things I noted, though, that I think would improve usability and make the program more polished. I hope some of them will make it to the final version.
PREFERENCES
- BUG: In "Context Menu" (under Display), window does not scroll up when dragging items to the top edge
- option to send/add Album List and Playlist items to a Default list by double-clicking or clicking using middle button (similar to the "Always send to playlist: Default" option in General)
LIBRARY
- option to exclude subfolders from scans
PLAYLIST VIEW
- show stop symbol in "Playing" column when playback stops so we can tell which song was just played and which song is next. Currently, if you don't have the current song selected, there is no way to tell what the current position is on the playlist when it's stopped. This is particularly problematic when using the "stop after current" option
- show queue order in "Playing" column
- mouse shortcut for queueing songs (middle button or alt-click)
- always highlight current position even when another song is selected
- "clear search" button for Playlist Search
- toolbar buttons for clearing and removing playlists (useful when using switcher instead of tabs, which can be removed by middle-clicking)
- it would be very useful for the "Show Now Playing" command to select the current position even when playback is stopped
LAYOUT
- command to save/export current layout
- ability to undo layout changes
- option to make some layout and toolbar elements fixed size instead of relative size
PLAYLIST MANAGER
- preferences for playlist manager similar to those for album list (i.e., double-click and middle-click action, start playback when sending selection to playlist)
- something to visually distinguish autoplaylists from normal playlists
- column for autoplaylist search query and ability to edit query
- a playlist manager view element that displays the contents of a playlist selected in the manager (separate from the main playlist view, which would show the active playlist). This way, I can preview a playlist before activating it or add only a selection of songs from it to my current playlist
PLAYLIST SWITCHER
ALBUM LIST
- "clear search" button for search filter, please!
- syntax to allow for pre-expanded categories
- transparent or grey corners for the expand/minimize (+/-) signs would make colour themes a lot more attractive
OTHER
BUG: status bar sometimes cuts off text even though there is more room
- Pressing 'Esc' on keyboard when dragging seekbar slider should cancel seeking and return slider to current position without interrupting playback
- ability to display total playlist duration on status bar
- volume slider tool tip should be displayed above the slider instead of below it where it is blocked by the mouse cursor
- playback history component
I use foobar for about 2 years, but i'm confused about the pros and the cons between the new Winamp 5.5 and the new Foobar. For me, Foobar had the best layout with UI panels. To be more specific:
Current playlist is not good at all compared to the old (UI panels) had. The ability to have the cover art inside playlist and the name of the artist and album in different lines (the one above the other, sorted by album etc..) was something unique and veeery practical. Its very important to be able to see all the info at once. When we have the artist and the album info in the same line, it's not so well organised. What happens if names are long? The line could be "endless" and hard to read.
Also the current album list element is not so good as the previous album list panel and album art should be able to read info from folders too.
Personally i will keep the previous foobar2000 and hope that the new one will have the basic features that we had with panels UI. How can you compare the usability of panels UI playlist with current one? IMO the new playlist its not good and needs improvement.
Why devs didn't make default UI as panels UI? Ok, some things should have to be out to make it more stable and easy to use, but it would be faaar better..
Anyway, thank you for your efforts Foobar devs, you made a very special and unique player and i hope that you will keep it like this.
Nothing prevents you from using Panels UI (people still do that, for some unknown likely-masochistic reason) with the new version, regardless of changes to the Default UI.
Why didn't foobar developers make something like Panels UI? You can answer that yourself - Just think of what foobar development has concentrated on so far, and what Winamp and other 3rd party devs worked on. Do remember in an application like foobar, Functionality should come before looks - Or at least, That's how i understand foobar.
As you've stated PanelsUI is very hard to use.
Let me give you an example:
The K-Meleon browser is extremely customizable. With it's macro language, you can do anything you want interface wise. But you probably have never heard of it, because it can be extremely frustrating to use. Instead, you might use Firefox or Opera, because they're much easier to use and customize, even if their not as powerful.
Simplicity and good UI design make extreme customization obsolete and unnecessary.
I just noticed, that the "Capitalize" command in Properties doesn't work correctly with multiline tags as it doesn't capitalize words on the beginning of lines.
I am using this beta on Windows Vista Home Premium (32bit). When I attempt to write tags to mp3 files, I get an Access Denied error: "Could not update tags (Access denied)". I checked and the permissions on the files seem fine, so I reverted to 0.9.4.5 and that writes the tags with no problem. Anyone else having this problem and/or know of a solution?
I have had no issue with any foobar installation and version on Home Premium x86 here. Where are the files you're trying to write to are located, and where is foobar installed?
The files are on an external drive, and foobar is installed in Program Files. The odd thing is that the current stable version writes the tags fine while beta 6 fails with the Access Denied. Beta 6 has no problem renaming the files based on tag patterns - it just fails on writing the tags.
I am having a file association problem with the new beta 6:
An error occurred while changing file type associations. If you are using a limited account, please contact your system administrator.
I am running WinXP Home SP2 as an admin (I am the only account on this computer). The file extensions that I can't seem to associate foobar with are the following:
.wave
.oga
.fth
.fla
I don't [currently] use these file extensions for any of my songs so it isn't a big deal, but those are the ones that show up in the 'file types' list in preferences.
What happens if you run foobar elevated? (right click on the exe, Run As Administrator)
I actually just tried that before checking back here and it worked fine. Does the new beta handle permissions differently from 0.9.4.5? I ran that without telling to run as Admin and it had no problem writing the tags.
Moderation: Removed unnecessary fullquote.
This release is amazing! totally different than 0.9.4.5!
It allowed me to compact my fb2k by adding those artist/album/year header(because then I didn't need more columns for artist, album and year)
Also will probably attract more people to fb2k
OK - it looks like the reason that 0.9.4.5 worked is because the installer forces Foobar to run in Admin mode. So when I ran it immediately after installing it, (from the option "Launch foobar now" in the installer) it was already running with elevated privs. The beta installer looks to be fixed so Foobar launches with normal permissions. Thanks to the guys in #foobar2000 for that info! Once that was straightened out, it was just a matter of kicking Vista hard enough to set the file permissions correctly.
I really think you guys did a great job and all but one of the things I like about foobar is the minimalism. The columns and stuff just throw me off, reminds me of iTunes. Any way you would ever consider adding an option for "old style UI" or just a way to remove columns so the info was all just written on one line like the good ol' days?
one line = one column
i wanted the same thing too. all i did was made a custom column which contained the string from the 'playlist' title formatting in the older style foobar. however, i had to add two other columns; one for the now playing indicator and another for the track length. in essence, there are three columns altogether, but it looks very similar to the old style default ui
Okay, thanks for the tip. I already jumped the gun and went back to 9.4.5 but I'll give it another shot tomorrow.
I've noticed a weird change in how playlist switching is working
Back in the 0.8.x days I had global shortcut keys bound to play/pause/random and next/previous playlist. while say.. playing a game - I used to be able hit my global for next playlist, and then random/play so I could listen to a different set of tracks.
A while back when I upgraded to 0.9 I noticed this stopped working properly, but I procrastinated in troubleshooting it. (until now)
Currently (.9.5 b6,b7) when you switch playlists via a shortcut or even in the UI, it doesn't truly activate until you select a track with a double click or the enter key. until you do that, no matter what you're looking at - global shortcut keys are manipulating the last-played playlist.
I can't seem to find anything like "activate currently selected playlist" in options/shortcuts.
Is this working as intended? or am I missing something amazingly obvious?
I noticed a small issue with the playlist search window in the default UI. I have a dual monitor set up and with fb2k open on the right monitor with the playlist search window open, if I click on an IE window on the left monitor and use the mouse scroll wheel both the IE window and the playlist search window scroll. This is with 0.9.5 Beta 7 on Vista (Logitech mouse and software if that matters).
Edit: Hmm .. but not always. Can't seem to make this happen consistently. Nevermind, must be something I'm doing!
I noticed something that may be related.
You can select a track in each playlist, when you switch playlists and do "shift click" (to select a couple of items from and including the already selected track), It acts weird, like it is still remembering the previously selected track in the other playlist.
I hope you see what I mean.
(WinXP SP2, 0.9.5b7)
From issues fixed in beta 7:
Regression: Slow decoding of certain file formats (wrong compiler settings).
In foobar2000 0.9.5 beta 7 mpc files decoding speed is less than in beta 5, anyway...
When tracks change within an album (track files in an album specific folder and cover art as 'folder.jpg') there is a 'flash' in album art viewer as it seems to reload the image for the new track.
I don't remember this behaviour before....?
Mark
Mark
I think it has been like that since beta 1 for me.
Yes, IIRC it was fixed but with beta 7 I have the same problem.
in foobar2000 0.9.5 beta 7 mpc files decoding speed is less than in beta 5
It's will be always?
Thank you take it for all the fans of foobar2000!
Observations about the beta:
1. Please add a way to increase the font size of the Metadata dialog as the text is nearly too tiny to read.
2. The buttons at the top are too tiny and close to each other to easily click.
3. I absolutely love the new ability to display embedded album art.
Click on the top left icon of the properties window's title bar. There's a menu called 'Font'. I suggested to move this to the fonts page in the preferences for consistency and usability reasons, but I got no feedback...
Thank you for this release!
I have to admit that even if I bitched on foobar when all my plugins went incompatible with 0.9.x (and some still aren't ported) this new version is very cool. The new interface is functional and lightweight, just as one would expect from this excellent player
I just hope the plugins format will not be changed anymore, or if it's done, that it will be possible to "emulate" the old ones (I'm not speaking about UI but at least audio control). A simple API taking care of UI things instead of direct windows API access like in winamp would be cool too (I don't know if it's the case currently in foobar) for future compatibility. Anyway it's sad that most people that make foobar plugins don't release their source, we would just need to recompile them else :/
Wow. Thanks fooruncle!
I NEVER would have thought of clicking on that little icon in a million years!
I'm with you, it should be in the fonts page in preferences where it belongs because, well, it's a font setting!
since the new 0.9.5 betas, the option to hide keyboard shortcuts in the menus, seems to be gone.
used to be under preferences/display.
I don't know whether this is a regression, since I haven't tried this with previous versions (or whether it is a bug at all). With version 0.9.5 beta 8, when I try to remove metadata associated with audio CD tracks using the "Remove tags from files(s)" command in the context menu, I get errors like Could not remove tags (Invalid path) from:
"cdda://01397A2E,01". The audio CD is still in the drive (and playable).
Are other people having this problem? Is this menu item not intended to work with audio CDs at all?
I'm using group headers for my playlist. They show Artist, Date, Album and Codec. Is it possible that if I have an album with various artists that the header says Various Artists rather than splitting the album up into several groups?
Set the "Album Artist" tag of such albums to "Various Artists".
Still the same in b8, this can be easiest tested right after startup.
this is great.
but i have one little request: it would be nice if i could hide the column headers in the playlist.
Mark
Fixed in beta 8-- Thanks!
Mark
Actually, That still happens here with beta8. Not that it matters, though.
I use foobar2000 with foo_playlist_tree.dll component.
With playlist_tree I create random queries by using $rand() function in "Population Order" field.
When I use command "Refresh Queries" I get new random list of songs.
Last working version for creating this queries is 0.95 beta6.
Now command "Refresh Queries" not work in 0.95 beta7 and 0.95 beta8.
For queries without using $rand() function command "Refresh Queries" work normal in last beta.
I use last version of foo_playlist_tree.dll.
Yeah, the $rand() function apparently got removed in Beta 7. There's a short discussion of this at: http://www.hydrogenaudio.org/forums/index....showtopic=59707 (http://www.hydrogenaudio.org/forums/index.php?showtopic=59707)
FB2K 0.9.5 has some great features - seems like a huge jump forward from 0.9.4.*, which was already a really good base.
There is, as is traditional, just one little thing that bugs me - in 0.9.4.*, the progress slider in the toolbar can get input focus. This means that I can scan through a series of tracks using just the cursor keys and Return, since left/right will jump the play position forwards and backwards. I use this an enormous amount to check for glitches in CD rips and it saves a lot of time. In 0.9.5 beta 8, I have to wave the mouse around trying to jump through the track by clicking along the progress bar.
Any chance of getting left/right to skip forwards and backwards through the track, probably by some percentage of total track length? Then 0.9.5 would be my new best friend
Preferences -> General -> Keyboard Shortcuts
'Seek back by XY seconds' and 'Seek ahead by XY seconds' for left and right key?
Where XY may be 1 second, 10 seconds, 30 seconds, 1 minute, 2 minutes, 5 minutes, 10 minutes
I'm talking to myself now...
Finding that "Ctrl+A" didn't work either, I had a look around the preferences and realised that a bunch of the keyboard shortcuts I'd previously taken for granted weren't defined. Using those, it's possible to set up all kinds of seek actions with the left/right keys. Could be neat to have a percentage-based seek option there too, but there's certainly no regression in functionality with the previous release as it stands.
So, new best friend it is, then!
(Post script - spotted bimbel's reply once I submitted the above - yes, that's the trick, many thanks).
Can you please make the Preferences window open center screen instead of the top left corner. Thanks!
i noticed that in the beta 8 the Album Art is no longer blinking[probably loading] when i select other tracks from the same playlist, thanks:D
Is Random (in the playback order listbox) working properly in beta 8? It's now behaving the same as Default for me. In prior versions, if I set Random and hit the key I have associated with Next track, it would go to a random track. Now it goes to the next track in the playlist. Shuffle (tracks) seems to be functioning properly.
Just to be clear, I'm not trying to use $rand()
Doesn' t work for me either.
foobar2000 FAQ (http://www.foobar2000.com/FAQ.html#random_shuffle_playback_order)
Bind the "Random-button" instead.
Why does the behavior described in the FAQ make any sense? Isn't the idea of Random order that the order is random and that the next track will be played at random? In other modes, the Next command goes to the next track indicated by the Order listbox.
A couple of remarks/questions:
- It appears that tracks are added to playlists unsorted (using Send to Playlist from the Album List). Only autoplaylists use the sorting string in Preferences > General > Sort incoming files by...
- When using Shuffle Albums, albums by Various Artists will play only one track and then jump to another album (or do I need to fill in Album Artist for this to work correctly?). It would be nice if Shuffle Albums would play tracks according to the way the playlist is grouped.
- Is it possible to create a 'tab' or a different alignment in the Grouping string? I'd like to have a divider like this:
Artist - Album (Date) [aligned left] --------- Codec / Bitrate [aligned right]
- Is it possible to exclude articles and other small words (a, the, and, on, in, from, etc.) from the Capitalize option? A configurable option in Preferences would be great for this function.
Concerning random order & next track action I'd like to request revival of action "Next/Random Track (Based on playback order)".
I think it has been requested already but I would like to add my voice to request a more customizable grouping headers in playlist view, and in other places in general (metadata properties).
Is it impossible to show text in a given panel with 2 different font faces with current architecture? If showing more than one font face at the same time it would be nice at least being able to customize background color, format (bold, cursive, ALL CAPS) and point size.
Also the grouping headers background does not change colour when you click on them and stay selected, they only get framed around. A different background color state for the headers when selected and frame the whole playlist instead of just the header would be much more visually clear to represent the whole playlist or group as being selected.
This is a little graphical mockup of what I'm talking about:
(http://img265.imageshack.us/img265/1658/foobarmockupafterfy3.th.png) (http://img265.imageshack.us/my.php?image=foobarmockupafterfy3.png)
compared to how it looks in reality:
(http://img170.imageshack.us/img170/4327/foobarmockupbeforefc1.th.png) (http://img170.imageshack.us/my.php?image=foobarmockupbeforefc1.png)
Autoplaylist item create with album list (with always sorted) are sort using "sort incoming files by" but doesn't remember it. am i correct?
If it is, it's a shame cause you cannot create multiple Autoplaylists with different auto sort string.
Converter + DSP bug!?
When I use the converter to create mp3 or m4a the cmdline-program (lame.exe, neroaacenc.exe) gets high cpu priority if the DSP-processing is enabled and SSRC or SRC resampler ist used. This nearly stops your PC.
If PPHS is used instead the priority of lame.exe is correct (lower than normal).
Bug or feature? (I'm using beta 8 + XP, but seems to exist also in older versions.)
Hi, using Foobar2000 v0.9.5.beta8. Did a search of this thread and the Foobar 2000 forum using the word disappear. Looked up and down My Foobar settings. Checked the F.A.Q. When tagging using the FreeDB context menu, files disappear. After scanning directories, files will appear and are properly tagged. Is this the way tagging is suppose to work in Foobar2000?
cheers,
herefornow
You mean files disappear from playlist? Are you using foo_dirwatch?
Might be Facet related? I think that after doing things. Like applying RG or renaming files or tagging them Facet reloads everything and whatever is marked in Facet will appear in the playlist. That is very annoying if you just put a new folder in your library but haven't reloaded the Media Library.
Likewise, if it's an Autoplaylist, changing the tags could well result in the disappearance of files from that playlist (since the files may no longer meet the criteria that generated the playlist in the first place).
eddy@ You mean files disappear from playlist? Are you using foo_dirwatch?
Yes I am using foo dirwatch. Thought this component might fix this problem. Don't remember Foobar2000 ever doing this until the .9xx branch.
cheers,
herefornow
I am wondering, when will the 256*256 foobar2000 icon come back?
it has been appeared in the pervious beta version of v0.9.5.
thanks
Thanks for b9. The 256x256 icon is back! I'm not on Vista, but use rocketdock, which likes huge icons...
The speed to convert files is faster than ever in beta 9. Thank you, the fb2k dev team.
??? I doubt there were changes and additionally conversion speed is mainly a matter of the encoder speed, and a bit a matter of decoding the source speed.
Oops.....I don't have technical material. Sorry for any imprecise information.
(http://img89.imageshack.us/img89/1737/85864138sh5.th.png) (http://img89.imageshack.us/my.php?image=85864138sh5.png)
Help the n00b!
How to resize this?! I can't drag it... And how I can insert splitters like Columns UI?
The problem seems gone in b9, good work guys.
hi - I am running the latest beta 9 and without properly testing but noticed 1 or 2 betas ago the album list component is running like a dog for me...
I have a music collection approx 500gb but the context menus even struggle to come up the memory footprint spikes to 120+ mb or RAM, this was not the case in earlier versions and renders the component un usable
it slow up happens ad soon as i right click > now I struggle to clear / scan my dead entries and I recently redid my folder structure the component is lagging badly... not sure what info you need form me troubleshooting wise.. its worked fine in the past I have xp sp2 (latest updates) p4 2.8ghz + 2gb ram should run smooth...
when i minize foobar to tray the memory footprint goes to 1mb.. just seems to be the album list not liking me...
Help the n00b!
you need to be in Layout Edition Mode. Go to View -> Layout -> Enable Layout Editing Mode. You can resize the panels there. To Insert Splitters, Right click the panel you want to put a splitter into, then click Replace UI Element, then one of the first few options will be Left/Right or Top/Bottom splitters.
Hope that helps.
Yes, there's gotta be something wrong with Album List. I have rather small music collection, 186 GB, and Album List freezes Foobar for minutes everytime I try to do something with it.
EDIT: Ok, only View by folder structure does this.
ok yes to clairfy this only happens in view by folder...
I am also using foo_dirwatch > even with dir watchh disabled its still painfully slow and often results in nothing happening other then a screen refresh of the albumlist window... please advise what extra info you require to fix the problem
also in my media library I have 2 directories...
c:\music and f:\music
not sure if that helps
also when viewing by other "views" the right click functionality is really quick and usable and switching between tabs is also faster.. it was extra slow before
hope it gets fixed otherwise I don't use the component in any other mode but by folder list.
also can the selection properties component please be updated to allow inline editing, I think this would be an awesome feature and quite intuitive if implemented nicely.. the fact that you can click in a field and get the typing cursor (not sure of correct name) makes you think you can type something in after you double click an entry when in fact nothing changes
we would also need to asume or decide that this is only possible for meta data and not location or general...
Album List's folder view will be made faster in the next version, thanks for reporting the issue.
thanks Peter, any idea what changed in the most recent versions to "provoke" this slow down? perhaps something similar to the decoder/encoder performance issues we saw when the project was moved to the latest visual studio?
thanks again > foobar community is the best, where else can I report a bug/issue and have it acknowledged by the dev and have something done about it my hats off to your sir - happy new year make sure you have your share of drinks - we can all wait until the new year for the next beta
Ugh. Using right-click here is really conter-intuitive for me. I spent few days to find this message and realize that I could do all this nice things in properties dialog. Well, this may be pretty good way to go, but there should be hint in a dialog, that you could use right-click. Or a lot of users will miss, I guess.
Btw, one more feature request - could "Next track", "Previous track" buttons be added to properties dialog? It is usual for me to go through album's tracks and see is everything fine. And it is boring to do without ability to view properties for next/previous track.
(...) could "Next track", "Previous track" buttons be added to properties dialog?
Please see this topic (http://www.hydrogenaudio.org/forums/index.php?showtopic=58771). Such buttons are most likely not going to be added.
Aha, thanks for pointing to!
But, I was unable to imagine what I should do to perform such task. So, again, UI is very non-intuitive. There definitely should be a hint that this is possible. At first glance "Properties" dialog look very dumb and non interesting, useful only for setting single value to multiple files.
And, after all, seems name "Properties" does not show up the nature and functionality of this dialog. Something like "View/Edit tags" is better, but is not best too, imho. (could not think up good name from scratch).
PS Thank you for all you efforts to make foobar2000 coolest player over all!
Nice updates. Is there a chance to make the artist in the playlist appear above the album title? Developers what do you say about this? It was a very nice layout with panels ui because you can see quicker the info bout the artist and the album. Also it would be nice to select the colour for the artist and the album separately the one from the other.
Sorry if it's been posted before, but can someone give me a quick guide to coding custom grouping, or point me in the direction of one please? I'm not sure how to specify what tags to group by and how to arrange the display of the tags in the header.
Is there a way, or are there any plans, to make a playlist that contains whatever is selected in album list? I seem to remember this was possible in 0.8.3. Kind of like how Facets works with the playlist Facet selection. I know you can set the middle button to create a playlist of whatever you click in Album List, but that's not exactly what I'm going for. I want to be able to have one playlist that always has what is selected in album list, so I don't have to worry about deleting playlists after I create them.
This is my very reason to use the
facets plugin.
So yes
This is my very reason to use the facets plugin.
So yes
Yeah, but is there something like that for Album List? When I'm not searching, I prefer to navigate with Album List rather than Facets, but I'm really missing a playlist that is tied to whatever is selected in Album List
