Topic: Toggle between Columns UI and Default (Read 451 times) previous topic - next topic
Is there a way to toggle between Columns UI and Default theme with a shortcut key?
I'm using foobar2000 v2.0 beta 24 [64bit]
With Columns UI Version 2.0.0 beta 1
Re: Toggle between Columns UI and Default
Not that I'm aware. A button / shortcut has to be a menu command. The option to switch DUI / CUI is only in Preferences. (And besides that it requires a restart, not like should need to switch that often?)
OK, thanks.
Best I can think of would be to have two portable installations. You can just copy the folder to keep the same preferences, change it to the other UI and launch whichever one you need at the moment. A bit clunky, but at least it's easy enough to keep just two updated.
Think millionaire, but with cannons.
Great idea.
