Topic: foo_ui_panels (Read 1305670 times) previous topic - next topic
foo_ui_panels
Reply #1800
Hello all.
I'm new to Panels UI, and i've spent some time reading this topic (but not all of it, though).
So if my questions have been answered already, please bear with me and spend some time pointing onto answers =)
Is it possible to do the following using Panels UI?
  1. Overlay album art panel/spectrum analyzer with (partially)transparent image (like shown below)
  2. Implement some kind of multipositional dial switch (same image)
i thought of making invisible buttons and redrawing image of dial pointing on specific button on click , but if there is another way to do so...
  3. Implement something with customizable appearance that behaves like slider control (again, in some other way than by using multiple invisible buttons and images redrawn upon them)
Thanks in advance.
foo_ui_panels
Reply #1801
No! (Sadly) you cannot get tags for more than a selected or playing track. The way other people are creating albumrating is by manual estimating and creating a tag for all the songs in the album.
But it should be possible to implement a function like this, cause %_itemcount% is working very well
@terrestrial
Thank you for Panels UI!
foo_ui_panels
Reply #1802
Hello all.
Thanks in advance.
no, no, and no
foo_ui_panels
Reply #1803
Hallo.
Thank you terrestial for this plugin.
But my foobar always crash when I click on Edit Layout button.
This is the message:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7C947C37h
Access violation, operation: read, address: 001DB000h
Call path:
entry=>app_mainloop
Code bytes (7C947C37h):
7C947BF7h:  CC CC CC CC CC 85 C0 74 25 8B 4D 0C 56 0F B6 31
7C947C07h:  48 41 66 83 3C 75 60 D0 97 7C 00 74 06 85 C0 74
7C947C17h:  0A 48 41 42 42 85 C0 75 E4 EB 02 42 42 5E 8B 45
7C947C27h:  08 89 10 E9 82 1B FE FF 85 C0 74 1D 8B 55 0C 57
7C947C37h:  0F B7 0A 8B 3D 60 E2 97 7C 66 8B 0C 4F 42 42 46
7C947C47h:  84 ED 74 01 46 48 75 E8 5F 8B 45 08 89 30 E9 97
7C947C57h:  BA FC FF 8B 7D 0C 8B 7F 04 66 8B 3C 4F 66 3B 3D
7C947C67h:  74 E4 97 7C 0F 84 28 52 FE FF C6 45 FF 00 E9 24
Registers:
EAX: 00010759, EBX: 00000000, ECX: 00000000, EDX: 001DB000
ESI: 00011278, EDI: 7FFB7C22, EBP: 00000110, ESP: 00000118
Crash location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeSListHead" (+0000EC27h)
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
MSCTF                            loaded at 74720000h - 7476B000h
msctfime                        loaded at 755C0000h - 755EE000h
tiptsf                          loaded at 47FB0000h - 47FE8000h
OLEAUT32                        loaded at 77120000h - 771AC000h
OLEACC                          loaded at 74C80000h - 74CAC000h
MSVCP60                          loaded at 76080000h - 760E5000h
VERSION                          loaded at 77C00000h - 77C08000h
PSAPI                            loaded at 76BF0000h - 76BFB000h
Secur32                          loaded at 77FE0000h - 77FF1000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
mslbui                          loaded at 605D0000h - 605D9000h
foo_abx                          loaded at 00C40000h - 00C73000h
foo_albumlist                    loaded at 00CA0000h - 00CE7000h
foo_browser                      loaded at 00D10000h - 00D49000h
foo_burninate                    loaded at 00D70000h - 00DA7000h
foo_cdda                        loaded at 00DD0000h - 00E05000h
foo_common                      loaded at 00E30000h - 00E6A000h
foo_converter                    loaded at 00E90000h - 00EF9000h
foo_cwb_hooks                    loaded at 00F20000h - 00F56000h
foo_dbsearch                    loaded at 00F80000h - 00FDC000h
foo_dsp_bs2b                    loaded at 01000000h - 0101C000h
foo_dsp_centercut                loaded at 01040000h - 01065000h
foo_dsp_crossfader              loaded at 01090000h - 010ED000h
libmmd                          loaded at 01100000h - 013B1000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_dsp_crossfeed                loaded at 013E0000h - 01404000h
foo_dsp_skip_silence            loaded at 01430000h - 01443000h
foo_dsp_soundtouch              loaded at 01460000h - 01483000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_dsp_std                      loaded at 014A0000h - 014E1000h
foo_freedb2                      loaded at 01510000h - 01550000h
foo_infobox                      loaded at 01570000h - 015B0000h
foo_input_shorten                loaded at 015D0000h - 015FE000h
foo_input_std                    loaded at 01620000h - 01733000h
foo_lnk                          loaded at 01760000h - 01779000h
foo_lyricsdb                    loaded at 017A0000h - 017CF000h
WININET                          loaded at 42C10000h - 42CDF000h
Normaliz                        loaded at 017E0000h - 017E9000h
iertutil                        loaded at 42990000h - 429D5000h
foo_masstag                      loaded at 01A10000h - 01A5F000h
foo_playcount                    loaded at 01A80000h - 01AA8000h
foo_playcount_mod                loaded at 01AD0000h - 01AE5000h
foo_playlist_manager            loaded at 01B00000h - 01B46000h
foo_pqview                      loaded at 01B70000h - 01B8C000h
foo_random                      loaded at 01BB0000h - 01BEF000h
foo_rgscan                      loaded at 01C10000h - 01C58000h
foo_run                          loaded at 01C80000h - 01CAB000h
foo_sendtodevice                loaded at 01CD0000h - 01D0A000h
foo_tradersfriend                loaded at 01D30000h - 01D6D000h
foo_uie_albumart                loaded at 01D90000h - 01DCC000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_uie_albumlist                loaded at 01E00000h - 01E3D000h
foo_uie_explorer                loaded at 01E60000h - 01E9C000h
foo_uie_lyrics                  loaded at 01EC0000h - 01F1F000h
WINMM                            loaded at 76B40000h - 76B6D000h
foo_uie_lyrics_panel            loaded at 01FC0000h - 02028000h
foo_uie_peakmeter                loaded at 02050000h - 02076000h
foo_uie_playlists_dropdown      loaded at 020A0000h - 020DA000h
foo_uie_quicksearch              loaded at 02100000h - 02146000h
foo_uie_tabs                    loaded at 02170000h - 0219A000h
foo_uie_vis_egoh                loaded at 021C0000h - 021DD000h
foo_uie_wsh_panel                loaded at 021F0000h - 02226000h
foo_ui_columns                  loaded at 02370000h - 02407000h
foo_ui_panels                    loaded at 02430000h - 02519000h
foo_ui_std                      loaded at 02540000h - 02597000h
foo_unpack                      loaded at 025C0000h - 025EE000h
foo_utils                        loaded at 02610000h - 02649000h
foo_ui_minilyrics                loaded at 02670000h - 02692000h
MiniLyrics                      loaded at 048C0000h - 049C2000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
RICHED32                        loaded at 732E0000h - 732E5000h
RICHED20                        loaded at 74E30000h - 74E9C000h
Msimg32                          loaded at 76380000h - 76385000h
nbmaptip                        loaded at 029E0000h - 029E9000h
sptip                            loaded at 5C2C0000h - 5C300000h
SPGRMR                          loaded at 20000000h - 20011000h
xpsp2res                        loaded at 04AD0000h - 04D95000h
tipcomponentsps                  loaded at 727D0000h - 727DD000h
msctfp                          loaded at 60E70000h - 60E83000h
btkeyind                        loaded at 06300000h - 0630F000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Gapless Crossfader 0.3.2.2 (Intel SSE)  (foo_dsp_crossfader)
SoundTouch DSP 0.1 (Intel SSE)  (foo_dsp_soundtouch)
Shell link resolver 1.1  (foo_lnk)
Explorer Tree 1.04.6b  (foo_uie_explorer)
Playlist tools 0.5.7  (foo_utils)
cwbowron's title format hooks 1.1.1 [May  4 2007 - 12:39:47]  (foo_cwb_hooks)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]  (foo_ui_panels)
Run services 0.3.2  (foo_run)
Audio CD Writer 2.0.1  (foo_burninate)
Album list panel 0.2.2  (foo_uie_albumlist)
Skip silence 0.1 (Intel SSE)  (foo_dsp_skip_silence)
Converter 1.0.1  (foo_converter)
Playlists Dropdown 0.5.7.5  (foo_uie_playlists_dropdown)
bs2b 2.1.0  (foo_dsp_bs2b)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
Peakmeter Panel 0.0.2  (foo_uie_peakmeter)
Album Art Panel 0.2.6  (foo_uie_albumart)
Database search 1.3.1 beta 11  (foo_dbsearch)
Center Cut 1.0.1  (foo_dsp_centercut)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Common services 0.1  (foo_common)
ABX Comparator 1.3.1  (foo_abx)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Lyrics panel 0.34.1  (foo_uie_lyrics_panel)
RAR reader 1.1  (foo_unpack)
Randomized playlist entry 1.2.3  (foo_random)
Special file info box 2.0.4  (foo_infobox)
ZIP/GZIP reader 1.0  (foo_unpack)
Lyric Show Panels 0.3.1.1  (foo_uie_lyrics)
CD Audio Decoder 2.1.1  (foo_cdda)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Egoh Spectrum analyser (uie) 1.1.2  (foo_uie_vis_egoh)
Play Count Mod 1.0.2  (foo_playcount_mod)
Playlist Manager 1.0  (foo_playlist_manager)
Default User Interface 0.9acc  (foo_ui_std)
FLAC Decoder 1.1.0  (foo_input_std)
Crossfeed 0.92  (foo_dsp_crossfeed)
Standard DSP array 1.0  (foo_dsp_std)
Album List 3.2.0  (foo_albumlist)
Shorten decoder 0.4.2a  (foo_input_shorten)
WSH Panel (uie) 0.7.1  (foo_uie_wsh_panel)
WMA Decoder 1.1  (foo_input_std)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
freedb Tagger 0.5.2a  (foo_freedb2)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
Play Count 1.9.2  (foo_playcount)
foobar2000 core 0.9.4.3  (Core)
Masstagger 1.6  (foo_masstag)
Send to Device 1.1.0 (beta) [Dec 20 2006 - 16:40:06]  (foo_sendtodevice)
Live show tagger 0.6.1  (foo_tradersfriend)
I really need to fix this problem. Please help.
Thank you. Sorry for my English.
foo_ui_panels
Reply #1804
please post the complete crash log (in a codebox)
foo_ui_panels
Reply #1805
I am sorry, but where can I find the complete crash log?
foo_ui_panels
Reply #1807
I think you should use Applocale. change locale to "english"
You are true, with foobar locale english I can open Edit Layout. Why not work in Japanese?
Thank you very much!
My foobar using localization patch to Japan. Do this relate?
foo_ui_panels
Reply #1808
Can someone help me with this code?
$button(220,$get(butY),0,0,15,15,$get(dir1)lyricswiki.png,$get(dir1)lyricswiki.png,EXEC:'http://www.google.com',)
It doesn't seem to work. I have no clue what I am doing wrong . Help?
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
foo_ui_panels
Reply #1809
Well, if you're using the latest version of PanelsUI, it has a small problem using foo_run, at least until the next update...
So, the call to EXEC (foo_run)  won't work until that bug is addressed...
foo_ui_panels
Reply #1810
sorry dude. thats not true. the EXEC command has nothing to do with foo_run
@Keikonium:
for me, this code works:
EXEC:http'://'www.google.com/search?hl=en&q=$replace(%artist%, ,+)
for you (not tested):
$button(220,$get(butY),0,0,15,15,$get(dir1)lyricswiki.png,$get(dir1)lyricswiki.png,EXEC:http'://'www.google.com,)
btw, to go to wikipedia:
EXEC:http'://'en.wikipedia.org/wiki/$replace(%artist%,' ','_')
good night
foo_ui_panels
Reply #1812
Hello all.
Thanks in advance.
  • Currently you can overlay panels over images, images over other images, panels over other panels, but not images over panels (though you can always request that feature)
  • You could makea dial similar to the one pictured, by making 10 buttons placed over each of the numbers on the perimiter of the dial, and having 10 different dial images (there is currently no way to rotate images using PanelsUI commands), one for each button,  The new position of the dial could even  be changed on mousover.  It looks like you are trying to make it control volume, though, and there is currently no command for changing the volume (except volume up, maybe with some creativity and luck you could use that somehow...?)
  • Unfortunately, right now there is no PanelsUI function that allows for ckick-and-drag interfacing.
foo_ui_panels
Reply #1813
@Keikonium:
good night
Those codes don't work for me either . I have Panels UI 0.13.8 beta, windows XP SP2, and it doesn't work. Here is my code:
// Global
$puts(dir1,'C:\Program Files\foobar2000\FoOrby\buttons\')
// Background
//$drawrect(0,0,0,0,pencolor-null brushcolor-SYSCOL-15)
$align(center,middle)
// PerTrack
$puts(butY,2)
$button(0,$get(butY),0,0,15,15,$get(dir1)sort2.png,$get(dir1)sort1.png,'SORT:All|%artist% %album% %tracknumber% %date% %title% %rating% %__bitrate% %length%',)
$button(20,$get(butY),0,0,15,15,$get(dir1)pref2.png,$get(dir1)pref1.png,Preferences,)
$button(40,$get(butY),0,0,15,15,$get(dir1)stop2.png,$get(dir1)stop1.png,Stop,)
$button(60,$get(butY),0,0,15,15,$get(dir1)previous2.png,$get(dir1)previous1.png,Previous,)
$button(80,$get(butY),0,0,15,15,$get(dir1)play2.png,$get(dir1)play1.png,Play,)
$button(100,$get(butY),0,0,15,15,$get(dir1)foward2.png,$get(dir1)foward1.png,Next,)
$button(120,$get(butY),0,0,15,15,$get(dir1)pause2.png,$get(dir1)pause1.png,Pause,)
$button(140,$get(butY),0,0,15,15,$get(dir1)random2.png,$get(dir1)random1.png,Random,)
$button(160,$get(butY),0,0,15,15,$get(dir1)mute2.png,$get(dir1)mute1.png,Volume Mute,)
$button(180,$get(butY),0,0,15,15,$get(dir1)wikipedia.png,$get(dir1)wikipedia.png,Wiki Album,)
$button(200,$get(butY),0,0,15,15,$get(dir1)songmeanings.png,$get(dir1)songmeanings.png,SM Song Title,)
$button(220,$get(butY),0,0,15,15,$get(dir1)lyricswiki.png,$get(dir1)lyricswiki.png,EXEC:http'://'www.google.com/search?hl=en&q=$replace(%artist%, ,+),)
$button(240,$get(butY),0,0,15,15,$get(dir1)nowplaying.png,$get(dir1)nowplaying.png,Activate now playing,)
// PerSecond
foo_ui_panels
Reply #1814
hey guys is there a wat to remove the vertical green scroll bar?
foo_ui_panels
Reply #1815
The only way that I know of is to alter the $panel code so that the panel is aprox 18 pixels wider.  That will end up making the panel run off the side of the window, effectively hiding the scroll bar.
Someone else may have a better solution, however........
foo_ui_panels
Reply #1816
oh ye it's a good temporary solution, But I dont see a 3mm blue line I've at the right now.
however I've a another little question:
when I dont play a song, So I stopped it or just opend FB. I dont wanna see this button:
$button(506,$eval($get(mini)+5),0,0,26,26,/images\exit14.png,,stop,TOOLTIP:"Stop")
This is what I tried:
$if(%_isplaying%,
but this ruined my Fb, everything disappears.
foo_ui_panels
Reply #1817
$if(%_isplaying%,
Well, I have not tested it, but from just looking at your code, I think it needs to be like this to even have a chance to work:
$if(%isplaying%,
$button(506,$eval($get(mini)+5),0,0,26,26,/images\exit14.png,,Stop,TOOLTIP:"Stop")
Give that a try......
foo_ui_panels
Reply #1818
Is it possible to make backgrounds transparent to see the desktop/applications behind?
Edit: Probably impossible. The configurations are based on backgrounds inside foobar.
foo_ui_panels
Reply #1819
On Vista it is
foo_ui_panels
Reply #1820
On Vista it is
Possible or impossible? I saw the Br3tt thread, and in his changelog he mentions true transparancy?
foo_ui_panels
Reply #1821
on Vista it is possible..
foo_ui_panels
Reply #1822
I have 2 questions. It might have been discussed before, but I couldn't find anything.
1) In titlebar now fb2k only displays "PanelsUI". How can I change it to display f.e. actually playing artist and track?
2) Is it possible to create buttons in SCP which would allow to set track rating, but not only for the currently playing track? I'd like to make buttons for each track which would allow to set rating, like it is in AmaroK. Is it possible?
foo_ui_panels
Reply #1823
I don't use buttons with Panels UI so I can only answer your first question.
You can use something like this:
$settitle(%artist% - %title%)
foo_ui_panels
Reply #1824
You can't use buttons in SCPL as far as I know. The way around this currently is to create another panel (thats set to follow cursor) that has the rating stars. Then make those into buttons. Select the song you want to rate, click the button. Use the arrow keys to move up or down (or click whatever) to the next song and rate that one. Repeat as needed.
Thats what I have done to rate mine.
