Topic: Is ffmpeg or fdk-aac support AAC metadata and apply DRC? (Read 5115 times) previous topic - next topic
I've revised FDK-AAC and embedded DRC value in metadata and encoded an AAC stream.
But I found it was invalid when I used ffmpeg for decoding this stream, there was nothing changed in Audio gain value.
I confirmed DRC data already embedded in AAC stream, so what do you guys think of this problem? Thanks a lot.
Main revision as below:
(1)fdk-aac\libAACenc\src\aacenc_lib.cpp, modified below flag.
            config->userMetaDataMode   = 1;
  (2)  fdk-aac\libAACenc\src\metadata_main.cpp,modified below default setting.
  static const AACENC_MetaData defaultMetaDataSetup = {
         AACENC_METADATA_DRC_MUSICSTANDARD, //AACENC_METADATA_DRC_NONE,
         -(31<<16),
         -(31<<16),
         1, //0,
Re: Is ffmpeg or fdk-aac support AAC metadata and apply DRC?
ffmpeg's native AAC decoder does not support DRC metadata for AAC (they are parsed, but just thrown away).
You can download samples from https://www2.iis.fraunhofer.de/AAC/metadata.html and test yourself.
