Topic: cuesplit.exe Alpha (Read 37746 times) previous topic - next topic
cuesplit.exe Alpha
Reply #75
Do you really use "REM SERIES", "REM VOLUME", "REM MEDIASET", etc? Can you retrieve such information from some source (like freedb)?
Yes I really use them. No I cannot retrieve them from any database. I edit the cuesheet and add them by myself. Well it's not too difficult to guess them, if you have something like "DreamDance 35 CD1"
Considering the implementation simplicity, I don't want to implement the conditional expression like $if{PERFORMER=Various} because I must change ACDIR source code a lot.
Yes you're right. I understand that.
In contrast, I can implement another conditional expression like $if{MEDIASET} (i.e., without operators and arguments) and find it useful for other occasions, for example, $if{GENRE}{--tg $#R{GENRE}} (if REM field "GENRE" exist, add and set "--tg" option).
I will add this to the 0.12 todo list.
[a href="index.php?act=findpost&pid=309219"][{POST_SNAPBACK}][/a]
Thanks, that helps a lot.
cuesplit.exe Alpha
Reply #76
It seems, that in acdir special characters are not replaced before a file is created. After encoding an album, the one with a "?" in the title was missing afterwards.
If this is the problem, please replace the characters, which are not alowed in Fat32 or Linux.
These are my suggestions, maybe you find them adequate
":" -> " -" (there is a space!)
"?" -> "" (null string)
""" -> "''" (two single ')
thanks
cuesplit.exe Alpha
Reply #77
thanks
[a href="index.php?act=findpost&pid=309622"][{POST_SNAPBACK}][/a]
Did you use the modifier that legitimates variable vales to be suitable for a filename such as $~t, $~o, etc?
cuesplit.exe Alpha
Reply #78
[a href="index.php?act=findpost&pid=309630"][{POST_SNAPBACK}][/a]
Sorry, I used lamecs.bat and did not understand all the %$#~-possibilities:
@acdir --output "$n - $t - $a.mp3" --pipe "lame --tt $#t --ta $#a --tl $#T --tn $#n $x - $#o" %1 %2 %3 %4 %5 %6 %7 %8 %9
So, I should modify it that way?:
@acdir --output "$~n - $~t - $~a.mp3" --pipe "lame --tt $#t --ta $#a --tl $#T --tn $#n $x - $#o" %1 %2 %3 %4 %5 %6 %7 %8 %9
OK, now I understand # and ~, but what is the difference between % and $? In you're batch-examples, you seem to use only $?
cuesplit.exe Alpha
Reply #79
You can just use:
"$n - $~t - $~a.mp3"
.. as $n - the track number - should never include any illegal characters.  (Similarly you should be able to use $n instead of $#n as it should never contain spaces.)
NB: All illegal characters are replaced with a space.
$ and % are interchangable.  I always use $ as using % in a batch file will confuse matters. If you are running from the command line you can use either.
I'm on a horse.
cuesplit.exe Alpha
Reply #80
I released version 0.12 alpha. Changes are:
1) Fixed a serious bug that was introduced with 0.10 alpha. ACDIR 0.10-0.11 alpha could not pass a valid filename to Monkey's Audio decoder in some case. ACDIR might not open an Monkey's Audio file if either the filename and pathname contains a character other than US-ASCII.
2) Added #ifdef, #ifndef, #else, #endif to describe a flexible command-line with conditions.
3) Improved batch files to use brand new #ifdef...#endif block and legitimated variable (e.g., $~t) for a filename.
Because of 1), ACDIR could not handle APE cuesheets that point to an APE file whose filename contains characters other than US-ASCII or that is located under a path with characters other than US-ASCII. I suppose this caused tycho's trouble. I confirmed that ACDIR 0.12 handles a Japanese pathname correctly.
As for the usage of 2), please refer to the batch files. The typical example would be:
--genre #ifdef$r{GENRE}$#r{GENRE}#else$qNo genre$q#endif
If a cuesheet contains REM GENRE "Rock", this will be:
--genre "Rock"
If not:
--genre "No genre"
http://nyaochi.sakura.ne.jp/xoops/modules/...php?cid=1&lid=2
cuesplit.exe Alpha
Reply #81
Something that would be cool:
Having a cue and a corresponding wav. Splitting the wav with acdir using the cue and getting multiple wavs and a new cue created out of all infos of the old cue and the new wavs.
I think this could be usefull if you decide that your achive with one wav per cd was wrong but don't want to re-rip everything.
cuesplit.exe Alpha
Reply #82
I've got some code in Wack that currently does this, but I haven't created a standalone application do it. Maybe I could do that in the future.
