Topic: How to differentiate a query-based autoplaylist and the others (Read 303 times) previous topic - next topic
To not pollute the other topic:
https://hydrogenaud.io/index.php/topic,62218.msg1046990.html#msg1046990
I want to check if a playlist is an Autoplaylist and also if it has a query associated or not.
This always returns 'Autoplaylist' in both cases.
playlist_manager::get()->playlist_lock_query_name(idx, component)
And this always return true.
autoplaylist_manager::get()->is_client_present(idx)
As you can see on the images, both are identified as autoplaylist but have different features available. How to do it in SDK?
Re: How to differentiate a query-based autoplaylist and the others
The implementer of the autoplaylist client... now you... needs to set the name.
In that component source facets_autoplaylist_client.h, it derives from autoplaylist_client
class foo_autoplaylist_client : public autoplaylist_client
If you update that to autoplaylist_client_v2, you have to implement these 3 extra methods, one of them doing what you want...
https://github.com/marc2k3/foobar2000-sdk/blob/76b762b974a6e6a6a50e912909e156da128ce5fc/foobar2000/SDK/autoplaylist.h#L50-L64
Yep, also noticed it.
The playlist in such case is reused by matching the name, since it is not locked anymore.
