I have a the same problem with my soundcard "Audiotrak Prodigy 7.1"
The first ASIO plugin I have a the same message:
"Unrecoverable playback error: Querying ASIO channel information (1,0) failed : Invalid parameter"
And the second one is
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 100012DBh
Access violation, operation: read, address: FFFFFFFFh
Call path:
audio_postprocessor::run
Code bytes (100012DBh):
1000129Bh: 7F 00 0F 7F 50 08 4A 8D 40 10 75 CB 0F 77 C2 08
100012ABh: 00 CC CC CC CC 8B 44 24 04 0F 6E 7C 24 08 85 D2
100012BBh: 0F 62 FF 74 27 0F 6F 01 0F 6F 49 08 0F 0F C7 B4
100012CBh: 0F 0F CF B4 8D 49 10 4A 0F 0F C0 1D 0F 0F C9 1D
100012DBh: 0F 7F 00 0F 7F 48 08 8D 40 10 75 D9 0F 0E C2 08
100012EBh: 00 CC CC CC CC 83 EC 10 85 C0 56 8B 74 24 18 57
100012FBh: 8B F8 74 62 D9 02 D8 4C 24 20 D9 5C 24 08 D9 44
1000130Bh: 24 08 DF 7C 24 10 8B 4C 24 14 8B 44 24 10 83 C2
Stack (01B6FE3Ch):
01B6FE1Ch: 7C92EE18 7C930570 FFFFFFFF 00150178
01B6FE2Ch: 00000028 00150000 00000000 001808D0
01B6FE3Ch: 100018CA FFFFFFFF 4F000000 01B6FF24
01B6FE4Ch: 00000400 009EF2E8 4F000000 01B6FEBC
01B6FE5Ch: 00408DDE 00F26520 00000400 FFFFFFFF
01B6FE6Ch: 3F800000 00000020 00000020 00000400
01B6FE7Ch: FFFFFFFF 00F26520 CF000000 80000000
01B6FE8Ch: 00000400 00000000 0009001F 03000300
01B6FE9Ch: 00000000 00000000 00000000 00000000
01B6FEACh: 01B6FF0C 004A46D1 00000001 00000000
01B6FEBCh: 01B6FF18 00EE5AD2 01B6FF24 01B6FF3C
01B6FECCh: 00000020 00000020 7FFDE000 3F800000
01B6FEDCh: B04AB196 00000000 01822FD8 000001E4
01B6FEECh: 00000000 00000000 00000000 00000000
01B6FEFCh: 00000000 00000000 00000000 01B6FEDC
01B6FF0Ch: 01B6FFDC 00EF98AA 00000002 B7EF8C24
01B6FF1Ch: 804DD2B2 804DD2BA 00EFD604 00000400
01B6FF2Ch: 0000AC44 00000001 00000004 00F26520
01B6FF3Ch: 00EFD6A4 00001000 00001000 FFFFFFFF
01B6FF4Ch: 00000001 00000000 00000000 00000010
Registers:
EAX: FFFFFFFF, EBX: 00F26520, ECX: 00F26530, EDX: 000000FF
ESI: 00000400, EDI: FFFFFFFF, EBP: 01B6FE58, ESP: 01B6FE3C
Crash location: "shared", loaded at 10000000h - 1002A000h
Loaded modules:
foobar2000 loaded at 00400000h - 004F0000h
ntdll loaded at 7C920000h - 7C9B5000h
kernel32 loaded at 7C800000h - 7C91D000h
COMCTL32 loaded at 77180000h - 77282000h
msvcrt loaded at 77BE0000h - 77C38000h
ADVAPI32 loaded at 77DA0000h - 77E47000h
RPCRT4 loaded at 77E50000h - 77EE1000h
GDI32 loaded at 77EF0000h - 77F37000h
USER32 loaded at 77D10000h - 77D9E000h
SHLWAPI loaded at 77F40000h - 77FB6000h
SHELL32 loaded at 7D590000h - 7DD83000h
ole32 loaded at 76990000h - 76ACD000h
shared loaded at 10000000h - 1002A000h
comdlg32 loaded at 76320000h - 76367000h
IMM32 loaded at 76300000h - 7631D000h
LPK loaded at 621F0000h - 621F9000h
USP10 loaded at 73FA0000h - 7400B000h
uxtheme loaded at 5A410000h - 5A447000h
MSCTF loaded at 74680000h - 746CB000h
msctfime loaded at 73640000h - 7366E000h
Secur32 loaded at 77FC0000h - 77FD1000h
CLBCATQ loaded at 76FA0000h - 7701F000h
COMRes loaded at 77020000h - 770BB000h
OLEAUT32 loaded at 770F0000h - 7717C000h
VERSION loaded at 77BD0000h - 77BD8000h
foo_abx loaded at 00AB0000h - 00AE3000h
foo_albumlist loaded at 00B10000h - 00B50000h
foo_cdda loaded at 00B70000h - 00BA5000h
foo_converter loaded at 00BD0000h - 00C3A000h
foo_dsp_std loaded at 00C60000h - 00CA1000h
foo_input_monkey loaded at 00CD0000h - 00D1A000h
foo_input_std loaded at 00D40000h - 00E49000h
foo_masstag loaded at 00E70000h - 00EBF000h
foo_out_asio loaded at 00EE0000h - 00F0E000h
foo_out_ks loaded at 00F30000h - 00F5A000h
SETUPAPI loaded at 76060000h - 761B6000h
foo_rgscan loaded at 00F80000h - 00FC5000h
foo_ui_columns loaded at 00FF0000h - 0108B000h
foo_ui_std loaded at 010B0000h - 01106000h
foo_unpack loaded at 01130000h - 0115E000h
dictnt loaded at 012C0000h - 012E8000h
DSOUND loaded at 73E70000h - 73ECC000h
WINMM loaded at 76B10000h - 76B3A000h
WINTRUST loaded at 76C00000h - 76C2E000h
CRYPT32 loaded at 765E0000h - 76672000h
MSASN1 loaded at 76DB0000h - 76DC2000h
IMAGEHLP loaded at 76C60000h - 76C88000h
wdmaud loaded at 72C90000h - 72C99000h
msacm32 loaded at 72C80000h - 72C88000h
MSACM32 loaded at 77BB0000h - 77BC5000h
midimap loaded at 77BA0000h - 77BA7000h
Pd71Asio loaded at 01800000h - 01811000h
DBGHELP loaded at 68CC0000h - 68D61000h
Stack dump analysis:
Address: 100018CAh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "audio_math::convert_to_int32" (+0000003Ah)
Address: 00408DDEh, location: "foobar2000", loaded at 00400000h - 004F0000h
Address: 004A46D1h, location: "foobar2000", loaded at 00400000h - 004F0000h
Address: 00EE5AD2h, location: "foo_out_asio", loaded at 00EE0000h - 00F0E000h
Address: 00EF98AAh, location: "foo_out_asio", loaded at 00EE0000h - 00F0E000h
Address: 00EFD604h, location: "foo_out_asio", loaded at 00EE0000h - 00F0E000h
Address: 00EFD6A4h, location: "foo_out_asio", loaded at 00EE0000h - 00F0E000h
Address: 00F07DF4h, location: "foo_out_asio", loaded at 00EE0000h - 00F0E000h
Address: 01801C70h, location: "Pd71Asio", loaded at 01800000h - 01811000h
Address: 7C802530h, location: "kernel32", loaded at 7C800000h - 7C91D000h
Symbol: "WaitForSingleObject" (+00000000h)
Address: 01801CF7h, location: "Pd71Asio", loaded at 01800000h - 01811000h
Address: 01801D2Ch, location: "Pd71Asio", loaded at 01800000h - 01811000h
Address: 0101D379h, location: "foo_ui_columns", loaded at 00FF0000h - 0108B000h
Address: 7C80B50Bh, location: "kernel32", loaded at 7C800000h - 7C91D000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C91D000h
Symbol: "FindAtomW" (+00000094h)
Address: 7C80B518h, location: "kernel32", loaded at 7C800000h - 7C91D000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 01801D10h, location: "Pd71Asio", loaded at 01800000h - 01811000h
Address: 01000100h, location: "foo_ui_columns", loaded at 00FF0000h - 0108B000h
Address: 010C01DAh, location: "foo_ui_std", loaded at 010B0000h - 01106000h
Address: 00E066A8h, location: "foo_input_std", loaded at 00D40000h - 00E49000h
Address: 00C100D4h, location: "foo_converter", loaded at 00BD0000h - 00C3A000h
Address: 01010001h, location: "foo_ui_columns", loaded at 00FF0000h - 0108B000h
Address: 01010000h, location: "foo_ui_columns", loaded at 00FF0000h - 0108B000h
Version info:
foobar2000 v0.9.3 beta 3
UNICODE
Additional info:
FLAC decoder 1.1.0 (foo_input_std)
Standard Input Array 1.0 (foo_input_std)
RAR reader 1.1 (foo_unpack)
ASIO support 1.2.2 (foo_out_asio)
Album List 3.2.0 (foo_albumlist)
ABX comparator 1.3 (foo_abx)
ZIP/GZIP reader 1.0 (foo_unpack)
Columns UI 0.1.3 beta 1v5 (foo_ui_columns)
ReplayGain Scanner 2.0.2 (foo_rgscan)
Masstagger 1.6 (foo_masstag)
Converter 1.0.1 (foo_converter)
Standard DSP array 1.0 (foo_dsp_std)
Monkey's Audio decoder 2.1.1 (foo_input_monkey)
Kernel Streaming Output 1.2.2 (foo_out_ks)
CD Audio Decoder 2.1.1 (foo_cdda)
Default User Interface 0.9acc (foo_ui_std)
I test it with foobar2000 0.9.3 beta 3 and WindowsXP Pro with SP2.
P.S. sorry for my poor English if anyone cannot understand what I type...
