Topic: New foo_input_reverse by Peter - a request for changes (Read 3188 times) previous topic - next topic
Some may have noticed, some not, that right now we have an official component that allows reversed playback of our music:
http://www.foobar2000.org/components/view/foo_input_reverse
However this not new idea - in the past other developer (as far as I remember banned from here) has also released foo_input_reverse. There are 2 main differences beytween those 2x foo_input_reverse :
- older one required additional library (libmmd.dll) to operate
- older worked immediately and straightforward. New one does not...
Dear @Peter - I would like to ask you for making some changes to this plugin:
- could it work without adding a new playlist? Creating new playlist might be good idea, if someone tried it on an Autoplaylist entry, but on standard playlist it's bit odd. Could this behavior be differentiated based on playlist type (std - no new playlist / autoplaylist - new playlist is created)?
- could it work immediately? I mean - even if new playlist is created, then I would expect foobar to simply jump playback to that playlist and start playing there. If I choose command like "Play reverse" from keyboard shortcut it means for me that I want it now - not when track finishes nor when playlist finishes, and especially not after additional special clicking (changing focus and firing playback on new playlist).
Re: New foo_input_reverse by Peter - a request for changes
How about doing reverse like I would have suggested some time ago? Instead of pre-processing the track completely, seeking backwards in 5-10 second increments and playing blocks of audio data, and trusting whatever it is to support speedy and consistent seeking.
Because then emulated formats will suffer due to needing to decode up to that point.
I tested the current component and it works great on USFs. Though my CPU is a i7 4790.
Hm, Is it possible to simply read headers, and then go to the very end of the file and read it from the back? And make the seekbar works backwards? Of course for all those emulated formats still full decode and caching would be necessary...
What's in a name, but ... a name foo_input_bar suggests it provides a way to decode some format/codec <bar>.
Thats not how input services in fb2k's ecosystem work. The reverse decoder is simply a proxy which decodes files with the input services registered, reverses the samples, and then plays that temp file back.
Theres no way to force input decoders to go backwards.
