Topic: QAAC "-q" setting (Read 5947 times) previous topic - next topic
QAAC "-q" setting
Could someone please help me understand what the "-q" setting in QAAC does? The documentation only describes it as "aac encoding quality", with no additional details. What does a value of 2 do compared to 0? How does it differ from a high or low value of the "-V" setting?
R.
QAAC "-q" setting
https://github.com/nu774/qaac/wiki/Encoder-configuration
AAC output mode options take integer value (option argument) to specify bitrate or quality.  --tvbr  takes quality value between 0 to 127 (bigger result in better quality, larger file size).
there exists an another option named  --quality  ( -q ), and you might be confused by this. Unlike bitrate or TVBR quality, this option controls not quality/size trade off but quality/speed trade off. Bigger value means higher quality (or smaller file size), and slower encoding speed. By default, qaac chooses  --quality 2 . Probably you don't have to touch this option unless you have a special reason to do so.
QAAC "-q" setting
I would say there's no case to use this option because even my old two core laptop can convert in real-time with Q2 and singe thread.
Maybe only very ancient computer like Intel Pentium but that wouldnot work anyway because CoreAudioToolbox using SSE.
QAAC "-q" setting
Thank you!
