NOTE: Since fb2k 0.9.5.3 this functionality is built into the player (with the difference that it removes all instances of a track from the queue, not just one). I'll leave this component here for those who use an older version, or prefer that only the last instance of a multiply-queued item be removed.
This is a little foobar2000 component that allows one to remove items from the playback queue with context menu/shortcut key. I use it to achieve similar behaviour to Winamp (Q to add to queue, SHIFT+Q to remove from queue, foo_cwb_hooks (http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Components_0.9/Cwbowron%27s_Title_formating_%28foo_cwb_hooks%29) can be used to display queue index in the playlist).
If an item is queued multiple times, first those instances are removed that are at the end of the queue.
[attachment=3487:attachment]
thank you .. its a nice addition to my queuemanager. works perfectly.
Yes, thanks. I' ve used it a few days now and it has done fine.
It's a great addition to the hooks dll.
I'm using it on Windows 2000 but on my Windows XP it doesn't work, I don't know why.
It just says :
Failed to load DLL: foo_removefromqueue.dll
Reason: Cette application n'a pas pu démarrer car la configuration de l'application est incorrecte. Réinstaller l'application pourrait résoudre ce problème.
Which is equivalent to this message on english systems I guess:
Reason: This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.
Any idea ?
I just installed the lates version of foobar2000 0.9.4.4, the same I'm using on Windows 2000.
EDIT: I also tried that without success :
http://www.microsoft.com/downloads/details...F5-25634C3BF043 (http://www.microsoft.com/downloads/details.aspx?FamilyID=10CC340B-F857-4A14-83F5-25634C3BF043)
http://support.microsoft.com/kb/259403 (http://support.microsoft.com/kb/259403)
You don't need those packages.
I am not really sure, but my best guess is that you need this (http://www.microsoft.com/downloads/details.aspx?FamilyID=32BC1BEE-A3F9-4C13-9C99-220B62A191EE) package. Let me know if it solves the problem.
I tried both the english and the french version of this but I still have the error when loading this plugin on my Windows XP SP2.
Sorry, but I have no idea. Have you tried a clean foobar2000 install (back up you configuration first, so you can restore it)?
Well… I still have CTL+Q which erases the whole queue. So untill I reinstall everything I will just do without removefromqueue (SHIFT+Q).
Thank you anyway
same problem on XP SP2 Russian with VC redist
The manifest states 8.0.50727.762. I'd guess you'd need this (http://www.microsoft.com/downloads/details.aspx?familyid=200B2FD9-AE1A-4A14-984D-389C36F85647&displaylang=en) redist instead?
Thanks Spoon! I can't test it because the plugin came to work I don't know why some weeks ago!
I'll see if I need this next time
Thanks, FrozenSpoon! I'm not into Windows programming (haven't used VisualStudio for anything else but two very simple fb2k plug-ins), and Google didn't help much in figuring out what the problem was.
I was really hoping this would fix my play list issues but it doesn't.
I'm running PanelsUI 14.9 with the Dark1.5c config and I can never remove 1 single track from my current playlist or any other by right clicking and going through the context menu to remove it or by clicking it to select the track then hitting delete on the keyboard. Am i missing something or maybe something like that could be made into a plugin?
WWNSX: This plugin is only for removing tracks from the queue (not playlist) with the context menu/keyboard shortcut.
Removing tracks from playlists is of course already built-in, and does not need any setting up.
yeah i know it's just for the queue. i was just hoping it'd affect the playlist as well. is there anyway to display the actual queue like the playlist is displayed or no? I'll try defaulting back to standard foobar ui i guess and see if it works how i want to or figure something else out.
WWNSX: You don't need anything special for removing tracks from the playlist. This is a basic function of foobar---just use the delete key or the right click menu. If it doesn't work, try assigning the delete key to the edit->selection->remove action. This shouldn't be necessary, but I have never used panels ui, so I don't know.
foo_pqview (http://foosion.foobar2000.org/0.9.5/)
Basically, you select one playlist to act as playback queue viewer.
Actually i went back to the default display of foobar 0.9.5 and what i wanted is right there it just seems not to work in PanelsUI so I'll have to figure it out.
thanks I'll check that out.
