Topic: foo_discogs (Read 1388901 times) previous topic - next topic
Re: foo_discogs
Reply #2925
That does appear to be a bug.
Out of curiousity - if you can you reproduce iton your end - are there plans to fix or leave as is ?
Unfortunately, I have no plans to continue working on foo_discogs at this time. If I were to do so, I'd have to migrate my development environment to Linux which I now use exclusively.
Thanks for the info zoomorph - what a bummer... end of an era then, seemingly.
But, a lot more thanks for all the work you have invested in this component since you took over and have carried it for years!
Fingers crossed someone else with the skills required feels strongly about this and takes over from you some time - source is all here:
https://bitbucket.org/zoomorph/foo_discogs/src/master/
correct ?
Cheers & all the bestest!
c.
Re: foo_discogs
Reply #2926
Is anyone else finding that this is now incredibly slow? 10+ minutes to find results?
Re: foo_discogs
Reply #2927
Same here, been slow for the past week or so for me.
Maybe Discogs are doing some rate limiting?
Re: foo_discogs
Reply #2928
Many thanks zoomorph (and all the people helping with tests and proposals)
I hope you'll find the way to continue working with this component, maybe under Linux...
Done a fine work anyway!
Quote from: alec.tron on 2020-11-24 20:33:08
    Quote from: zoomorph on 2020-11-10 16:45:19
@alec.tron, in the meantime, if you'd like, please check:
https://bitbucket.org/fooDaYuyu/foo_discogs
Contains sources and binary to include foo_discogs into fb2k preferences panel
and a rookie attempt to solve the tag write/update bug.
Best regards,
(sorry for bad english)
X
Re: foo_discogs
Reply #2929
Hello  @da yuyu
I gave it a spin - and write+update seems to work now and spotted no other issues on a hand ful of test runs.
Thanks muchly for taking on the bug fix!!!
All the best.
c.
Re: foo_discogs
Reply #2930
 ...in the meantime, if you'd like, please check:
Thanks for this. Is there any way to watch this page for any new releases? https://bitbucket.org/fooDaYuyu/foo_discogs/downloads/. I cannot see anything like github where you can subscribe to any new releases.
Re: foo_discogs
Reply #2931
You are welcome, I am glad the fix is working so far!
Well, I found a crash scenario, clicking on 'Write tags..." followed by closing fb2k (having
wrong OAuth settings and/or no internet connection). Did not happen on zoomorph's original v2.23.
It is now fixed in the latest mod release.
Thanks for the suggestion, that could surely come quite handy...
(repository is now located at GitHub: https://github.com/ghDaYuYu/foo_discogs)
Although the intention was just fixing the write/update and next mod updates will surely focus on solving
glitches introduced by the mod itself.
Best regards
Re: foo_discogs
Reply #2932
@da yuyu‍
Thanks. Seeing as the original plugin is no longer being developed, this seems like a good alternative, thanks to @zoomorph for working on it til now.
Re: foo_discogs
Reply #2933
I can't get this plugin to work. The plugin is installed but the tag writing display under preferences doesn't appear and therefore discogs doesn't appear.
Re: foo_discogs
Reply #2934
I got it to work. For the new release it appears under Tagging. Did you have to get a Pin number from Discogs. I did.
Re: foo_discogs
Reply #2935
Hmm i wish the Foobar Devs would implement it
Re: foo_discogs
Reply #2936
Hi all. Via tag mappings it is possible to write to different tags based on the file format?
My library is mostly FLAC with some MP3 and M4As, and I use foo_discogs to prepare my files before adding them to musicbee. I use the "Grouping" field in MusicBee but for some reason it writes this to %CONTENTGROUP% on FLAC files and %GROUPING% in MP3/M4A files.
Ideally I'd like foo_discogs to write to %CONTENTGROUP% on FLACs and %GROUPING% for everything else. Thanks for any help
EDIT: I'm not 100% sure this perfect but I think it works:
%CONTENTGROUP%: $if($stricmp($ext(%path%),flac),,blah)
%GROUPING%: $if($stricmp($ext(%path%),flac),blah,)
Re: foo_discogs
Reply #2937
foobar is dead without this tool, thats for sure!
Re: foo_discogs
Reply #2938
Do anyone know how to get the line breaks right for RELEASE_NOTES.
It's inserting just a line feed as opposed to CRLF $crlf().
The release is https://www.discogs.com/release/1714607 but this happens on all albums that have notes with \n in them and not \r\n.
I've tried
$trim($replace(%RELEASE_NOTES%,\n,$crlf()))
but no joy.
It currently looks like this in the edit tag info:
Whereas it should be:
Comes with Obi, a regular 4 sheets colour booklet and an extra 8 sheets black and white booklet in English/Japanese with all lyrics (among others).
℗ and © 2007 Kitchenware Records Ltd under exclusive license to Sony BMG Music Entertainment (UK) Limited.
Manufactured by BMG JAPAN, INC., Tokyo, Japan.
Printed in Japan.
Pressed by Sonopress - Hong Kong.
Re: foo_discogs
Reply #2939
@stevehero
Fixed CRLFs will be available soon in next release...
Thanks for noticing!
Re: foo_discogs
Reply #2942
Why I can't see "CD" in "Find release - Releases"?
Agreed, this has been like this for a while. It's odd because CDs and cassettes come through as just Album, but LPs are labelled.
Would be good if @da yuyu could look into this :)
Re: foo_discogs
Reply #2943
@AxelR8 @frogworth
Yes, LPs are labeled but not as 'Vinyl'...
I am currently testing some changes to the code (new %RELEASE_SEARCH_MAJOR_FORMATS% field in Config Panel->Searching sub-release string).
So far is working fine, hopefully a new mod release will be a available in a few days.
Regards
Re: foo_discogs
Reply #2944
That new field sounds great!
It would also be good if the format showed in the list of releases so you could easily pick which ones are CD versions.
Re: foo_discogs
Reply #2945
The screenshot below shows the release panel I am getting here,
I believe that´s what we are after, please correct me if not.
Also I've just found this...
Good question. The %RELEASE_SEARCH_FORMATS% field comes from this API endpoint, since it's a master release:
https://api.discogs.com/masters/164846/versions
foo_discogs currently uses the "format" field. It looks like "Cassette" is not in there, but it's below in a "major_formats" field. I'm not sure if it was always this way or if they changed it.
For releases that aren't part of a master release, %RELEASE_SEARCH_FORMATS% comes from the artists/<id>/releases API endpoint. That endpoint still returns "Cassette" in the "format" field, there is no "major_formats" field.
foo_discogs would need to be changed to better support this.
The new %RELEASE_SEARCH_MAJOR_FORMATS%  field will add major_formats support to foo_discogs.
I still need to double check the 'comes from the artists/<id>/releases' part in the code before packing the new release.
X
Re: foo_discogs
Reply #2946
Hi all
Hope you're well
Anyone else suddenly getting issues from the plugin? just tried searching a release and got the following:-
(FATAL) Error: HTTP Error (403)(url: https://discogs-images.discogs.com/R-34241-1268156664.jpeg?expiry=2021-02-17T19%3A09%3A16.258426&fit=contain&format=auto&height=150&quality=40&width=150&signature=3QbaPAHNCX/lSm7BHwUYZ7BioYGVzOwRS1F2cRcRTrY%3D)
[ESCAPE to close]
Any ideas?
Cheers
Re: foo_discogs
Reply #2947
New mod release update...
Reminder: This is a modified version of the original/official component available here
v2.23-mod.02
  • Format names (CD, Vinyl,...) available in Find Release panel.
  • Fix carriage returns turning into \n.
To add media descriptions, open Configuration panel > Searching tab
and modify Release & Master sub-release formatting as follows:
becomes
%RELEASE_SEARCH_MAJOR_FORMATS%,%RELEASE_SEARCH_FORMATS%
Regards  :))
v2.23-mod.02
Re: foo_discogs
Reply #2948
Hi da yuyu.
I got a question about the tag DISCOGS_ARTISTS_URLS.
In tag mapping the sintax is like DISCOGS_ARTISTS_MEMBERS but artist members writes a multivalue and artists urls a single value with all the urls.
How can I write the urls as multivalue?
