Topic: Foobar Stuttering/lagging ... issue (Read 4540 times) previous topic - next topic
Hello :)
I know there are already some topics about this problem but i couldn't find a solution there.
Basically it doesn't matter which output i am using(wasapi / asio or the default on (ds) ) the music has always this stottering / Sound away for less than a second..
I tried reinstalling my uni xonar driver for my asus stx II (original dont work on win 10 or dont show the gui).
Has anybody any new idea ...
I don't have that problem with other players and it doesn't matter if it is mp3 or flac. I'm just to fascinated by foobar to just give it up.
Edit: latency/buffer is high enough
Re: Foobar Stuttering/lagging ... issue
sorry for double post.
But i'm really annoyed: I just tried it on old v0.9.5.2 Version and its smooth...
Can somebody explain this?!?!
Possible explanation: I've found Asus's sound cards to be quite crappy. Bad drivers, bad sound chip, and big problems. They're highly sensitive to DPC latency (check with LatencyMon), and also have poor circuit isolation. I tried my front panel connection with them, and unlike my onboard audio, they had noticeable crosstalk between the front microphone and the front headphone output.
mmmh I think its a problem with certain versions of foobar or possibly just too much dsp's and settings / changes etc.
Because a fresh portable version of latest foobar is smooth
ok i know what caused that problem, i was using a vst "voxengo prime eq" which makes that lag appear.
Don't knwo why but..  i solved that .. :)
