Topic: foo_quicksearch (Read 265349 times) previous topic - next topic
Re: foo_quicksearch
Reply #475
Hello, if I search through all playlists, how can I see which playlist the entry I found belongs to?
It would be a dream if I could then jump directly to this playlist/title by double-clicking on the entry...
Thanks! Steffen
Re: foo_quicksearch
Reply #476
in the Context menu search album had faild of (Aimer special concert with スロヴァキア国立放送交響楽団 "ARIA STRINGS")
console log
Search for same did not return any result
but it's work in the search bar use (%album% IS Aimer special concert with スロヴァキア国立放送交響楽団 "ARIA STRINGS")
Re: foo_quicksearch
Reply #477
It's a bug on the component with quotes, which are not parsed properly on the internal query. If you remove them from the album and do the same search, it works.
For reference, the JSP3 and SMP counterparts of quicksearch work fine in such cases.
Re: foo_quicksearch
Reply #478
@Fanicary
QSearch
https://marc2k3.github.io/component/qsearch/
Download - foo_qsearch-1.1.0.fb2k-component
https://github.com/marc2k3/marc2k3/releases
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Re: foo_quicksearch
Reply #479
That doesn't help because...
1. Dev is known to remove support at any day and nuke components. (so please stop recommending their components without warning as alternative)
2. It's hardcoded to specific tag, contrary to this one.
Anyway, as already said... the bug can be bypassed in this component by using:
$replace(%ALBUM%,$char(34),)
instead of
%ALBUM%
Re: foo_quicksearch
Reply #480
Meanwhile.... you're continuing to use and promote components posted by me. This gif clearly illustrates that...
https://hydrogenaud.io/index.php/topic,124385.msg1057830.html#msg1057830
And visiting the download page for your script is also hosting my compile...
https://github.com/regorxxx/Not-A-Waveform-Seekbar-SMP/releases
For any comment about my reliability to stick, you would not touch anything I've done but you can't help yourself. You're just making yourself look more of a dick every time you post.
Re: foo_quicksearch
Reply #481
QSearch - Note
As stated there, for example, if you click Shift + artist IS (context menu), the Media Library Search will launch with "artist IS" pre-populated.
Artist: (G)I-"DLE" tested
Preferences > Advanced > Tools > QSearch
You can select the type of playlist when you click on an item in the context menu.
Re: foo_quicksearch
Reply #482
Thanks marc for more trolling, not sure what your reply has to do with answering the user's problem. Not even bothering replying your absolutely absurd post (specially when you are talking about a compile of someone else's component which is hosted by me precisely because you delete everything you touch xd).  ::)
I have already shown foo_quicksearch can be edited to work properly with quotes. No need to promote other components on this thread.
Re: foo_quicksearch
Reply #483
Are you serious? can't believe it.
Your answer seems to be the only correct one.
Are you the owner of this thread?
I found someone extraordinary.
You seem to be the only one who wants to be praised and treated specially.
"I'm special." "I'm absolute."
There may not be just one answer.
To me, it's normal to see multiple answers when you look around.
Re: foo_quicksearch
Reply #484
Air Ken the user had a problem with THIS component. I already replied with a solution using THIS component, with enough hints for the dev to fix it at some point.
It has nothing to do with marc, me being correct or who is the owner of the thread. Which is the foo_quicksearch thread btw  ::)
TOS 5. All members that post to the Hydrogenaudio community must acknowledge and discuss only acceptable topics when starting a new thread.  If posting to an already existing thread, they must continue in the vein of discussion that the thread has already manifested; if they wish to change topics, they must start a new thread.
https://hydrogenaud.io/index.php/topic,3974.html#post_tos5
Your replies have nothing to do with answering the user's problem.
You are just telling him to use another component. You already did it 2 times, without attempting to solve their problem at all, even if the problem has already been solved using  this component.  Note the user did not create their own thread for it asking for replacements, this is the foo_quicksearch thread, and posted a bug report.
I mean, doing it once... ok. Doing it a second time after it has been solved... If you don't see how this is just changing topics, well... I get you are not a native English speaker, so I will  not take it personally. But you are clearly choosing a bad timing here to write such personal attacks without any reason. I will not fall into that kind of conversation by anyone, so I'm out.
Re: foo_quicksearch
Reply #485
It's a jumbled mess, too long to read.
Is there a problem?
