Topic: cant find components for x64 architecture (Read 1366 times) previous topic - next topic
Good afternoon. I want to follow the steps in this video: TUTORIAL
I downloaded the components but when I try to install them it says they are for x32 and not x64. I can't find where the components for the x64 architecture are. Can you help me please?
Thank you very much.
Re: cant find components for x64 architecture
X64 architecture plugins are available in the regular component repository along with 32-bit:
https://www.foobar2000.org/components
ONLY X64 plugins are listed here, although it may be missing newer ones from the first link:
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Components
Case has updated many older 32-bit plugins to x64 and they are listed on his site here:
https://foobar.hyv.fi/
Searching the Forum for specific plugins will usually find a few more updates from different authors.
Thanks sveakul but the x64 are not along with 32. I´m looking for WASAPI output support 3.4 (x64) and RAM-Disk 1.0 (x64) and there is none. In the link that you kindly gave me for Only x64 they can't be found either.
If you are talking about the official component registry the x64 are posted along with the x86 but on the same plugin page;  because they are not available for every component there, you have to look through them by name yourself.
Wasapi output, both Shared and Exclusive, is now built-in by default to all 64-bit versions of Foobar;  there is no more need for a separate plugin.  Wasapi Exclusive output options will show with the [exclusive] suffix added to the output device.
RAM-disk has not been updated to 64-bit.
Thanks a lot sveakul.
