Topic: REACT 2 Released (Read 1291585 times) previous topic - next topic
REACT 2 Released
Reply #1475
Hi!
Once i managed to setup REACT2 with EAC to do automatic rip into FLAC image and also to create MP3 copy in MP3 Folder. So that its looking something like this:
http://img510.imageshack.us/my.php?image=48426718.jpg
In Flac directory flac images and in MP3 directory mp3 files...
But now when i start REACT and go ripping with F10 react creates only FLAC image. MP3 folder is empty with only albumart in it.
How to reconfigure this that REACT will create both FLAC image and MP3 files?
REACT 2 Released
Reply #1476
I have been using REACT2 with EAC for about a year now and have managed to rip a lot of my CDs. Today however I have hit a problem which is really frustrating me.
Every time I run either REACT or EAC (I have two seperate icons) it just hangs and I get the normal window for a few seconds which then turns white and the hour glass just continues to show. I have to use task manager to close it down. When running REACT2 I get an EAC icon in the systemtray which says "script paused" with a tick but I cannot seem to untick it. I don't get this if I just run the EAC icon, but they both end up hanging.
I have uninstalled and reinstalled EAC and reinstalled REACT2 and the subsequent Mods but its made no difference. I don't know what else to do.
The only software I installed since I last ran EAC/REACT2 successfully was an update to Daemon Tools which I have subsequently uninstalled and an IE toolbar which I have also removed now. But I still get the problem. I also tried removing the whole EAC config section in the registry but that made no difference either.
I think its either something to do with the metadata popup screen (which does not appear when trying to run REACT). Once I got an Autoit error message but it was only once.
Any ideas?
REACT 2 Released
Reply #1477
If you have followed the instructions correctly, then i'm guessing that acdir throws a dependency error(msvcr71.dll)...
Try to run acdir through a command-prompt(in '%programfiles%\REACT2\tools' by default) and see if it works or not...
If it works, then post your ini...
REACT 2 Released
Reply #1478
It does work. I cant manage to setup it correctly... Now REACT leaves mp3 in root directory and even doesnt move MP3 files into MP3 folder. Only creates artist\album directory with only artwork inside.
I also get error: unable to move cuesheet when i try to rip CD? I tried several times with no success...
Anyway here is REACT ini:
[Settings]
Version=2.0.ssb16
ImageExt=flac
ImageNaming=$artist$ - [$year$] $album$
ImageHotKey={F10}
TracksHotKey={F4}
TracksHotVal=+{F5}
VA=Various Artists
CreateAllCuesheets=1
RunCoverDownloader=1
CoverDownloader=D:\Audio\AlbumArtDownloader\albumart.exe
CoverDownloaderXUI=1
EAC=D:\Audio\Exact Audio Copy\EAC.exe
Tools=D:\Audio\REACT2\tools
MinimizeCompressionWindow=1
ProcessPriority=1
Sla_Bks_Col_Qst_Bar_Quo_Ast_Lt_Gt=-|-|-||!|'|#|[|]
Test=0
[UserTrackFormats]
Flac=0
Wavpack=0
Tak=0
LameMP3=1
NeroAac=0
iTunesAac=0
OggEnc2=0
[UserOutputNames]
OutRoot=@f:\music@\
ImageDir_Flac=@OutRoot@\FLAC\$cdartist$\[$year$] $album$
ImageDir_Wavpack=@OutRoot@\WV Images\$cdartist$\[$year$] $album$
ImageDir_Tak=@OutRoot@\TAK Images\$cdartist$\[$year$] $album$
ImageDir_MP3=@OutRoot@\MP3 Images\$cdartist$\[$year$] $album$
TrackDir_Flac=@OutRoot@\FLAC\$cdartist$\[$year$] $album$
TrackDir_Wavpack=@OutRoot@\WV\$cdartist$\[$year$] $album$
TrackDir_Tak=@OutRoot@\TAK\$cdartist$\[$year$] $album$
TrackDir_MP3=@OutRoot@\MP3\$cdartist$\[$year$] $album$
TrackDir_AAC=@OutRoot@\AAC\$cdartist$\[$year$] $album$
TrackDir_OGG=@OutRoot@\OGG\$cdartist$\[$year$] $album$
TrackName_SA=$track$ - $title$
TrackName_VA=$track$ - $title$ [$artist$]
TrackName_SA_acdir=$n - $~t
TrackName_VA_acdir=$n - $~t [$~a]
[UserSettings]
Debug=0
Comment=Created with EAC/REACT2, @curdate@
EmbedCover=1
ReplayGain=0
ApplyAlbumGain=0
AdjustAlbumGain_dB=+3.0
AddCuesheetAG=0
UseWaveGainAG=0
Opt_Flac=-8 -f
Opt_Wavpack=-hmy
Opt_Tak=-pN -overwrite
Opt_LameMP3=-V0 --vbr-new --noreplaygain --nohist
Opt_NeroAac=-lc -q 0.21
Opt_iTunesAac=-d -s 2000
Opt_OggEnc2=-q 3.0
Ver_Flac=1.2.1
Ver_Wavpack=4.40
Ver_Tak=1.0.1
Ver_LameMP3=3.98.2
Ver_NeroAac=1.0.0.2
Ver_OggEnc2=2.83 Lancer aoTuV b5
[DefaultMetaData]
discnumber=1
totaldiscs=1
discname=
Edit: i am using Windows 7 right now. Maybe is that reason?
EDIT2:
i set debug to 1 and i get this errors in cmd:
flac 1.2.1, Copyright © 2000,2001,2002,2003,2004,2005,2006,2007  Josh Coalson
flac comes with ABSOLUTELY NO WARRANTY.  This is free software, and you are
welcome to redistribute it under certain conditions.  Type `flac' for details.
Ptmp54266.wav: wrote 334584547 bytes, ratio=0,557
F:\Music>MOVE /Y "F:\Music\Paul Motian Band - Garden of Eden.flac" "@f:\music@\\
FLAC\Paul Motian Band\[2006] Garden of Eden"
The filename, directory name, or volume label syntax is incorrect.
F:\Music>MOVE /Y "F:\Music\Paul Motian Band - Garden of Eden.cue" "@f:\music@\\F
F:\Music>IF 1 == 1 COPY /Y "F:\Music\Garden of Eden.jpg" "@f:\music@\\FLAC\Paul
Motian Band\[2006] Garden of Eden"\"Paul Motian Band - Garden of Eden.jpg"
        0 file(s) copied.
F:\Music>IF NOT EXIST "@f:\music@\\MP3\Paul Motian Band\[2006] Garden of Eden" M
KDIR "@f:\music@\\MP3\Paul Motian Band\[2006] Garden of Eden"
F:\Music>PUSHD "@f:\music@\\MP3\Paul Motian Band\[2006] Garden of Eden"
And i forgot something. When EAC is trying to rip cd... It runs everal time through UPC/ISRC...
REACT 2 Released
Reply #1479
I'm guessing that your INI should be changed to amend:
OutRoot=@f:\music@\
to:
OutRoot=f:\music
With regard to UPC/ISRC: Uncheck the relevant (uppermost) checkbox on the "Tools" tab of the "EAC Options" dialogue (F9 to open).
I'm on a horse.
REACT 2 Released
Reply #1480
In latest beta(2.0.akku.b03), then changing the ripping directory in EAC after doing CTRL+F2 dosen't have any effect, since EAC changes and uses the 'DirectorySpecification' regkey, while with REACT then the 'ActualPath' regkey is used instead for determining ripping directory.
Personally, then i would suggest to change it back as the way Neil had done it with the CTRL+F2  synching of ripping directories, as the new scheme IMHO dosen't make much sence even if it worked right, i mean, why ignoring the EAC defined ripping directory in favor of My Music???
It works in tracks mode (and for some reason back then when I tested it, it worked also in image mode, dunno why it worked then). Will be making changes to next version so that it works in both modes (I already know how to do it, so it will be a quick and easy change). Thanks for reporting, you were the 1st one.
Actually it's not REACT which reads/uses the "ActualPath" value when starting ripping, it's EAC itself and it's stupid mess of using two regkeys in different situations (tracks vs. image mode). The synching of these 2 regkey values are still present, it just that the synching does take place only when configuring REACT (just like in the original REACT), and after the "DirectorySpecification" value has been changed. EAC itself synchs these when you close EAC/REACT.. so no need to manually edit the registry.
REACT needs to set a default directory (for the temp files) because the EAC standard directory can't be set to "ask every time" and a valid directory must be then used in EAC settings, and the users my music directory is a safe choice. Believe me, it MUCH easier to do it like this (vs. looking for the current setting and verifying that it's a valid directory etc. problems)..
Also, i understand that the syntax of the CFGs is done with the old metamp3 in mind, but then isn't e.g. this wrong in the image cfg(new metamp3 beta syntax):
SET Disc_MP3=--frame "TXXX[setsubtitle]:@discname@"
I don't understand what's the problem here. There is a "REM" line above that line, why it's like that, I dunno. Synthetic Soul, do you have information about this?
REACT 2 Released
Reply #1481
The only software I installed since I last ran EAC/REACT2 successfully was an update to Daemon Tools which I have subsequently uninstalled..
I believe that it's the DTools SPTD (SCSI Pass Through Direct) driver. It's not uninstalled when you uninstall DTools normally.
From How to remove DAEMON Tools V4:
NOTE: DAEMON Tools V4 also uses SPTD (SCSI Pass Through Direct) driver to access cdroms and it is also automatically installed during DT setup. But SPTD is not removed during uninstallation because it may be used not only by DAEMON Tools but by other applications as well and its removal may disrupt these applications.
Nevertheless, if you suppose your problems are SPTD releated you can remove it as specified in this thread
I'm using the old version (Daemon Tools 3.47) because of the stupid problems with SPTD.. and I've no problems whatsoever with that old version.
P.S. When you run just EAC, you just run EAC, REACT is not started then.
P.P.S. Only write to either here or in my email, not both.. preferably here. Thanks.
REACT 2 Released
Reply #1482
@ElephantTLK: Or change to my mod (if you like) which fixes this problem (unable to move cuesheet) and you can keep the UPC/ISRC setting on.
This is due to the fact that all 4 cuesheets are generated with ssb mod, in my mod you can choose to create only one you need and the UPC/ISRC check is ran only once.
EDIT: And since you're using Windows 7, check this out (in case you are lazy to read the notes/manual ): my mod notes about Windows Vista (AFAIK applies also to Win7).
REACT 2 Released
Reply #1483
Now its working but with one new problem. There is NO artwork (cover) created...
Edit:
@Akkurat
i will try your mod right now to see difference. Thnx.
REACT 2 Released
Reply #1484
Its working fine.    Thanks Akkurat.
Edit: still one problem.  Why does REACT now dont create in FLAC folder image with this naming: $artist$ - [$year$] $album$. It creates only $artist" - $album$ with no year...
My old files look like this:
REACT 2 Released
Reply #1485
IIRC, the commented out line uses ID3v2 v2.4 syntax, but metamp3 is v2.3 compatible. I left it there in case metamp3 went on to support v2.4.
I'm on a horse.
REACT 2 Released
Reply #1486
Edit: Removed passage, as i realized that i was a moron!
Reg-editing is needed because when i press CTRL+F2 and then restart REACT and sets my ripping directory to 'D:\Temp', then REACT(because of your new scheme) will rip to My Music still! I can only fix this by editing the registry directly with your mod. That's not a problem for me at all, but just wanted to report it nonetheless...
Well, i still prefer the old way, though(Neil's way), but of course it's your choise. Your mod allready warns the user if the ripping directory in EAC hasen't been configured when launching REACT, so i don't see the problem in using the users own choise, rather than overwritng your own choise with a default value...
My point where that the --frame "TXXX[foo]:bar" syntax is the syntax of the newest metamp3 beta which isn't included in the REACT distro and that command isn't backwards compatible with the included metamp3 version...
Again, no problem for me, as i'm using the new beta and have ammended the CFG accordingly, but i just wanted to report it nonetheless...
Thanks for your reply, mate
REACT 2 Released
Reply #1487
Anyone? Why REACT now dont create flac image filename as: artist - [year] album?
My config in REACT for image naming is:
REACT 2 Released
Reply #1488
Brilliant - thanks Akkurat. I am up and running again now. Apologies for the double post.
G
REACT 2 Released
Reply #1489
Ok, you just bumped into one rarely occurring problem with my mod, the AutoIt version I'm using to compile REACT (newer than in ssb mod) has some strange problems dealing with controls in EAC windows. I've a 99% ready fix for this, needs just final test and tidy up the code.. would you like to test/use a special version before I get out the next public version? PM me your email and I'll get in touch with you soon (I'm very very busy this week), sorry.
@Martin H: I'll reply to your post as soon as I get more time.
REACT 2 Released
Reply #1490
I was maybe oversimplifying it and I meant it from our (REACT) POV.. sorry if I confused you.
I was partly  wrong, EAC doesn't always sync the regkey values when closing EAC (go figure). But, if I CTRL+F2 (EAC/REACT closes) -> start REACT -> F9 and set folder -> close EAC/REACT -> start REACT -> F10, the files are going in the path I set. So, like I said, no registry editing needed if you restart after changing the folder.
The warning is there to warn users who might set the option to "ask every time" after configuring REACT. It's much easier for the not-so-advanced users to configure & start using REACT from the get go using just CTRL+F2, rather than pestering them with warning messages. And besides, the "my music" folder is very much used, aaaannnd what does it matter where the temp files (from REACT POV) go? You're the first one to dislike (publicly) this feature. Users are free to change it (and with the future fix, it's going to work with image rips also without restarting first) and I made a note of it in my "manual". And in the end, how many times do you have to press the CTRL+F2?? I've done it once (counting out the times when developing/testing). Anyways, your voice has been heard..
Yes yes, now I see it, you're absolutely right, how very perceptive of you.. thanks. Funny how long this have been in the config files without anyone noticing. Synthetic Soul should've used --user-text switch instead.. an easy mistake to make if the ID3v2 v2.4 TSST frame was there first and then in the end going with 2.3 TXXX frame (EDIT: especially if Synthetic Soul was already using the 0.92beta5 version privately back then). This will be corrected automatically when I update the metamp tool. It's good that there's now even bigger pressure to release a new version, "forces" me to hurry.
REACT 2 Released
Reply #1491
Apologies for any confusion.
The script in question was originally submitted as part of an upgrade article in the wiki, "Adding Support For Disc Information", in which, under "Requirements", I did state that the beta version is required.
I think the configs were updated to include this update (and others) just before I ceased developing, when perhaps more thought should have been applied.
Edit: Yes, it looks like the configs were updated for 2.0.ssb16n.
I'm on a horse.
REACT 2 Released
Reply #1492
@Akkurat
Just wanted to say thanks for your reply, mate
CU, Martin.
REACT 2 Released
Reply #1493
@Synthetic Soul: ah, ok it happened that way, I should have guessed that my guess would be totally wrong.
@Martin H: no problem, thanks for your feedback. I'm off to watch the Germany-Denmark match right now, I hope you win.
REACT 2 Released
Reply #1494
I've just tried this, and it still dosen't work, even with the extra shutdown...
Btw, i don't have any My Music folder(i'm using Win2k with FDV's IE/Junk Removal Fileset), and so REACT sets '\' as default ripping directory, and hence, %systemdrive% is now used, even though 'D:\Temp' is defined...
Again, i have fixed this through registry editing(which is the only way with your mod), but just wanted to let you know nonetheless...
CU, Martin.
REACT 2 Released
Reply #1495
How I'm not so surprised (it works in my pc but not in yours).. shows exactly how stupid that EAC setting/regkey mess is. Quote from EAC options: "Standard directory for extraction" (label), "You can specify a directory to where all extractions are targeted" ("Use this directory" tooltip).. all extractions.. really?!
REACT 2 Released
Reply #1496
Hi people,
REACT suddenly started to complain about "Unable to move cuesheet. File does not exist......". When I hit F4 I can see that EAC is creating a cuesheet file (album_title.cue), but when I look in the debugging.txt REACT says the following:
2009-05-09 18:15:04  Waiting for the cuefile to appear
2009-05-09 18:15:04  Unable to move 'X:\musikk\.CUE'. File does not exist
Ini settings:
CreateCuesheet=m|mg|s (I tried without creating cuesheets as well, still the same error)
OutRoot=x:\musikk
Running Windows 7 beta and EAC 0.99b5/Akku.b03
Have anyone experienced this issue before? And could tell me how to fix it?
REACT 2 Released
Reply #1497
Well it seems that Andre changed the cuesheet generation in the latest version. Use EAC prebeta 4.. I'll fix this problem in the next mod version.
EDIT: removed horsesh#t.
REACT 2 Released
Reply #1498
Sorry, I misread (or rather my brains fudged up totally) your post a bit, for some reason the album_title.cue you wrote messed up my thinking, I thought that Andre changed the filename (the underscore probably messed me), but he did not. I just tested with the prebeta5 and I didn't have this problem you're having.
Did you try with prebeta4? Did that work? Have you recently installed "Sony Ericsson PC suite"? If yes, try closing the program from the systray icon and try REACT again.
@everybody:
Do NOT use EAC prebeta5 with REACT (any mod)!!! Andre has changed (without notifying about this in the changelog ) the command line switches so that %s and %d doesn't have full filenames (drive+path+filename) anymore! Use prebeta4 or earlier for the time being!
REACT 2 Released
Reply #1499
Quote from: Akkurat link=msg=0 date=
Yes, I did get the same error with the prebeta4. However, I also recently installed "Sony Ericsson PC Suite". And you were right, closing the systray icon solved the problem
That's really a strange problem, isn't it? Anyway, thank you so much for quick reply and solving my problem.
