Topic: Unknown error code (0x887D0003) (Read 1712 times) previous topic - next topic
Hello dear Community and foobar2k team,
I try to get on point fast as i could. I want to excuse me for my bad english i hope you can help anyway.
Main Problem:
Wehn i try to play a song with foobar2k the following error occurse, a window pup up named (Playback error):
Unrecoverable playback error: Unknown error code (0x887D0003)
I did chose a standard output divice!
The funy thing is i CAN play the song with "Windows Media Player" so the file is 100% not corrupt. The problem occures on all other songs all so.
I tryed to play the songs with Winamp and i got the same issure only WinMediaPlayer is able to play the files actualy, NO problem in "Windows Media Player" to play the files!
In my optinion there was a software change who induce the problem.
I tryed to install other codecs because i thought there maybe some broken codec.
no changes after taht.
I heared its possible to see errors in cosole!? but am a newbie in C++
System: Windows 10 Pro 64bit
Thanks in advance for all your help.
best regards Wammbo
Re: Unknown error code (0x887D0003)
What file format are the songs you try to play? Can you check properties and tell the sample rate and number of channels.
I think the error message means that the output format isn't supported. Do you have some special sound card? You can see your audio device in Device Manager under Sound, video and game controllers.
Btw, you don't need to change the output device normally. The default "Primary Sound Driver" setting will use the default output device, which should be the same as Windows Media Player uses.
thanks for reply
File-Format is MP3-File (.mp3)
Sample rate!? Hope u mean bitrate : 192k Bit/s
16 bit @ 48000 HZ
Mainboard: ROG Crosshair VI Hero
Onboard Sound: Realtek High Definition Audio
ROG SupremeFX 8-Kanal High Definition Audio CODEC S1220
Audio Feature :
- Gold-plated jacks
- optischer S/PDIF-Ausgang an der Gehäuserückseite
- Sonic Radar III
- Sonic Studio III
- Impedance sense for front and rear headphone outputs
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- ESS® ES9023P
- Supports up to 32-Bit/192kHz playback *2
like i say Winamp is all so NOT working, but WindowsmediaPlayer is working fine.
Ok i reinstall my realtek audio driver to latest version it fixed for me the problem please close thread. thx for the help.
