Topic: Primitive SoundCloud integration (Read 15377 times) previous topic - next topic
The script: view download
Can be used with foo_run or foo_uie_biography or both. Usage is simple:
1. foo_run action command:
wscript soundcloud.vbs
2. foo_uie_biography run external script command:
cscript soundcloud.vbs "%path%"
[a href="http://imgur.com/bfQuE.png" target="_blank"][/url]
As other scripts parsing XML, it's fast and I guess it would be most useful to electronic music fans
Streams are seekable
Cheers
Thanks going to give this a try now
Awesome work, using it now, will be interesting to see if you develop it further, thanks for sharing
Added some new options: https://gist.github.com/4d06d0994c1b8ae61ef5
1. it's possible to paste soundcloud url in input box and script will retrieve the tracks from it:
2. user can search for specific soundcloud user or group (as noted in simple dialog) and receive the tracks accordingly
3. I added option for downloading waveform image (disabled by default). Idea was to embed the image in waveform seekbar, as background, but I couldn't test it as it seems my graphic card doesn't support that feature, perhaps someone can play with it. To enable this feature, just set the variable on 1st line to True.
Bugreport: The newest version does not always work when giving it a direct URL (https://soundcloud.com/falscherhase for instance). The old script works however...
Thanks for reporting, issue is corrected
Problem appears with direct links to user or group profile resource, in which case soundcloud resolver doesn't return playlist. Also in this case you could have used "user=falscherhase" as a workaround, but of course issue is valid and user is to be expecting that soundcloud link with tracks should work
BTW, previous script can't do this
Problem fixed indeed. The search function is nice btw. Thanks for the handy script.
I can't seem to get the waveform working however, there's seem to be no waveform.png being saved (not anywhere was able to find it anyway).
If `waveform` variable (1st line in the script) is set to True, then waveform.png should be saved in foobar's default folder, which should be %ProgramFiles%\foobar2000. Also, you would have to add the script in "Biography view" external scripts - that one triggers it on track change.
I just added now `folder` variable on 2nd line, where you can set custom path for saved waveform (path should be valid existing folder).
So, if you know how to set Waveform seekbar shader script, that would be great test.
I hope seekbar wouldn't mind that image is delivered couple of seconds after the track starts.
Usage is simple:
Thanks for your work!
Many users will install foo_run just for your script, so:
Why not drop a line about where to save the script? (and to be sure, where to paste the call)
Is it %APPDATA%\foobar2000\user-components\foo_run ?
About waveform png: Never save to %PROGRAM FILES%, rather use %APPDATA%\foobar2000\
If you save it in foobar folder, you can call it just by name (like in screenshot example), otherwise you'll have to call it with full path
Waveform download is disabled by default. If you want to enable it, you'll have to edit the script, and set the folder that suites you most
^the trouble with using program files is that UAC will block write access for most people. it's not good advice telling people to disable it. (not that you did - i'm just saying)
i think that's why blausand was suggesting to use %appdata% instead. obviously that does add more complexity.
How exactly is this meant to work?
I added some more features:
Please report valid issues, in which case I may consider rewriting the script, or making it HTA with more friendly interface if there is base for it
Excellent work dude, using it now, i look forward to more features, please keep on working on it
Hey I like this script, thanks!
Can you tell me how you go about generating the (what I assume is OAuth?) token for the "toc" variable?
I would like to just add /stream but it appears that when I do so that it's logged in as your account, so the music isn't coming from those I'm following.  I assume that if I can generate the "toc" variable using my account credentials then it would be streaming from my friends instead.
Much appreciated!
Kati, "toc" variable although suggests OAuth token is in fact just "Client Secret code"
Here is script that you can easily use with your own keys: https://gist.github.com/8d2854646688dbd13036
You can get your keys by logging to SoundCloud and registering new app.
Will you be able to play non-public tracks this way, I don't know.
how do i install it? how do i run it?
i just installed foo_run ... and now?^^
If you can't set foo_run action, just double-click the script and enter your query, then program set to handle PLS file format will handle the rest
Ty  its working now!! awesome work!
This works pretty well but towards the end of every song it just stops and foobar2000 gives the following error:
Decoding failure at 1:13:26.884 (Connection error):
"http://api.soundcloud.com/tracks/1823680/stream?client_id=da9f7d4fd2b404de52146325215f7e40&secret_token=33f6070b6f49b3d5877868b7daae2f8c"
^ That is from a mix with a 1:13:45 duration, it changes based on the duration, I've tried short single songs and the same error occurs with a different duration time in relation to the last 30 Seconds - 2 minutes of the song.
Thanks for this! It works great!
Guys ,Please help to make foo_uie_biography work...
via foo_run your plugin works just great, but still no success with biography...so i have "soundcloud.vbs" in the root foobar2000 folder (& since foo_run works with - it's probably ok to have it there). My foo_uie_biography configuration :
Maybe instead of "%path%" i should type in my "soundcloud.vbs" destination.. or ?  Please, Help ..!
That should work. Try the same command line in Album tab instead Artist tab, or double click on your Biography View panel or similar...
Guys let me quote myself, that this script continues here:
This continues here: http://www.hydrogenaudio.org/forums/index....howtopic=104954
Help file that comes with the program also explains how to have "Now playing" info rendered in Biography View, or how to show current albumart
Your ideas are welcomed
My bad . I've forgotten to add "run external script" in the "current source list". But image still doesn't work    - empty space instead of image
UPD:
And frankly this feature isn't that helpful since i can't copy from description
