Topic: New in 1.1.12—if chosen radio is offline, playback error—how to avoid? (Read 2275 times) previous topic - next topic
With 1.1.12 when i lanch my radio playlist, if radio is offline, display a popup "PLAYBACK ERROR". With previous versions did not appear and was going on. It is possible to avoid it?
when I launch
Foobar2000.exe /playlist -activate : Mp3 /rand
with the new version if it is active at launch another FM radio playlists with these compared to the first run on the command line. It is possible to avoid it?
I must to use:
Foobar2000.exe /stop /playlist -activate:Mp3 /rand
but does not always work
Try updating to 1.1.12a.
Again, when i click the random button, song change but the item in the playlist not.
1.1.12a not solve
do it is bugs?
I misread your topic. It makes perfect sense that you would get a playback error when trying to connect to a dead server. Although, technically, I thought the player switched to auto advancing after a delay.
