taken from the main WSH panel mod thread....
A semi-offtopic suggestion:
Maybe the script exchange business could take place elsewhere, so this topic would be left for the general component discussion only? By that I mean information about new releases, feature requests, bug reports and other support, while the creations of the users and stories about the others struggling to use them would be kept separate.
definitely a great idea. so here's a new thread for it.
to get us started, here's a replacement artwork panel i made. it does a few things the standard CUI/DUI* panels can't do...
http://javascript.pastebin.com/f7aeaaa1b (http://javascript.pastebin.com/f7aeaaa1b)
-if you edit/add artwork for the currently playing track, use the "Refresh" context menu item to see the changes without having to restart playback.
-changes made in the foobar display preferences also take effect immediately if you use the "Refresh" command. currently, the DUI/CUI artwork panels require a foobar restart for those changes to take effect.
-displays artwork for the previously played/selected track on foobar startup.
-you can lock the panel size in pixels. no more messing around locking splitters. both CUI and DUI obey the limits set in the panel.
-tooltip to show if the artwork is embedded or not. it also shows the actual image dimensions plus the currently displayed size.
-it has the usual context menu options you would expect to set front/back/cover/artist/etc
(*for those that aren't aware - WSH panel mod can now run in DUI natively without dockable panels)
for people who are new to WSH panel mod, remember to download the samples (http://code.google.com/p/foo-wsh-panel-mod/downloads/list) as there's lots of good stuff to get you going.
nice G!
here's another script. this is for DUI only. it allows you to create your own buttons of any size, using any images you like. by default it uses the DUI background colour (it changes colour as you change theme).
(http://k5sbdw.blu.livefilestore.com/y1pnSC1mxAv6zhmAM9tfE2dwzsyFDhkqYGiuFMesBndW9eoZHe5qxCOF5yc8mNhFPclrKdUihbbhFwnKRIm9kqrQBlCbLdfhstS/buttons1.png)
but it also has an option to set the background to the same colour as the splitter or your own custom colour which you can specify in the script.
(http://k5sbdw.blu.livefilestore.com/y1pJxLDqo4xDIfZw7SeL2pG3laazoPtzxyubTBVq5ROMGuWuTLukt86QIh4o4ZTRdRJUv27cmgxN9J9C89OPv2tKvIiOMrNkWU-/buttons2.png)
it does require a little tinkering to get going so here's a guide. first of all download and save this script....
http://javascript.pastebin.com/f77d9e62f (http://javascript.pastebin.com/f77d9e62f)
you need to create a folder called scripts inside your main foobar directory. make sure you save the file inside this folder and name it dui_buttons.js
next you need to add a WSH panel to your layout. copy/paste this
http://javascript.pastebin.com/f1c08ceca (http://javascript.pastebin.com/f1c08ceca)
into your panel and read the comments (sorry for the rambling). here are the images i've used.
http://cid-649d3bfeaf541fbb.skydrive.live....uide/images.zip (http://cid-649d3bfeaf541fbb.skydrive.live.com/self.aspx/.Public/foobar/guide/images.zip)
extract into your foobar install directory.
it should at least be a starting point for anyone wanting to create their own button toolbars.
Hi marc,
The custom WSH panel based album art viewer is cool. Would it be possible make it keep its aspect ratio constant, instead of keeping the dimensions fixed as foobar2000 changes sizes?
Anish
you mean what i put in the very first 2 lines of the script?
//edit this line or comment it out if you don't want a fixed size....
window.MinWidth = window.MinHeight = window.MaxWidth = window.MaxHeight = 375;
and you use the context menu to control the aspect ratio of the image itself, just like the standard artwork panel.
Wow... great work, marc! Thank you very much for this.
Just an idea: Might it be possible to open the art-containing folder by doubleclick? I mean, like in the default album art-panel (DUI).
sorry but i don't think that is possible with this component.
Ok, thanks for your answer.
here's another script for DUI. it's a ratings panel that displays the current rating and of course lets you set it. it works with the official playback statistics component. it has the same context menu options as the "buttons" panel above to set the background colour.
when foobar is playing it sticks to now playing. and when playback is stopped, it follows the cursor.
just copy/paste this code into a new panel and download these images and extract them to your foobar folder.
(credit to NEMO7538 for providing the original rating code)
script: http://javascript.pastebin.com/f5450d71a (http://javascript.pastebin.com/f5450d71a)
images: http://cid-649d3bfeaf541fbb.skydrive.live....uide/rating.zip (http://cid-649d3bfeaf541fbb.skydrive.live.com/self.aspx/.Public/foobar/guide/rating.zip)
screenshot: http://k5sbdw.blu.livefilestore.com/y1pQER...-BTE/rating.png (http://k5sbdw.blu.livefilestore.com/y1pQEROMvP8PeG-iiDic9gDEb2TxQrfW45PGezY61A9hdyduzWqDXS-Sa3RLcYHr9lLW4ecDYwTRkyiy1DHBRx9fqlsVp9B-BTE/rating.png)
Yes, just like that. I'm an idiot.
I recall some poster somewhere talking about a WSH version of the biography component that could be used with the DUI. Was there any progress on that?
interesting idea. getting the text from last.fm feeds is fairly trivial as i'm already doing this with another script. but how to get the images, i don't know.
Actually, what I want is slightly different from this (I really shouldn't post in the middle of the night when I'm half asleep). I want behavior that is similar to the DUI & CUI, when the album view panel is not locked, except the panel keeps its aspect ratio constant.
Anish
i have absolutely no idea what you're talking about. there is a "Correct Aspect Ratio" option on the context menu which behaves exactly the same as the normal DUI/CUI panels.
+1
drool... do want
Here my new mod of the album art panel. There is now buttons on the panel which will fade when entering. Actually there is one button to refresh, prev, play/pause/next and one buttons i use to launch Album Art Downloader.
Right now buttons are placed at the bottom but i will make it configurable through the menu.
To make it work you must change that line
window.SetProperty("BtnimageDirectory", fb.FoobarPath + "Images/tintin/buttons/");
To the path that will contain your buttons images. You must have a Prev.png, Pause.png, next.png. reload.png, albumart.png.
This is a work in progress!
//edit this line or comment it out if you don't a fixed size....
//window.MinWidth = window.MinHeight = window.MaxWidth = window.MaxHeight = 200;
var RefreshInterval = 50;
//no need to edit anything below here///////////////////////////////////////////////////////////////////////////////////////////
var g_metadb = fb.GetFocusItem();
var NewImage, CurImage, new_width, new_height = null;
var CurSize = null;
var NewSize = null;
var ww = window.Width;
var wh = window.Height;
var opacity = 255;
var step = Math.min(Math.ceil(255*RefreshInterval/300),255);
var timer = null;
var cur_btn = null;
var g_tooltip = window.CreateTooltip();
var hover = null;
var dui = window.InstanceType;
window.GetProperty("aspect",1);
window.GetProperty("id",0);
window.GetProperty("Buttons", 1);
function RGB(r,g,b) {
return (0xff000000|(r<<16)|(g<<8)|(b));
function on_timer(id) {
Buttons.OnTimer && Buttons.OnTimer(id);
if (timer && id==timer.ID) {
if (opacity>0) {
opacity = Math.max(opacity-step,0);
window.Repaint();
} else {
CurImage = NewImage;
CurSize = NewSize;
NewImage = null;
NewSize = null;
opacity = 255;
timer && window.KillTimer(timer);
timer = null;
CollectGarbage(); // Release memory.
//window.RepaintRect(this.x, this.y, this.width, this.height);
function on_size() {
ww = window.Width;
wh = window.Height;
Buttons.OnResize && Buttons.OnResize(ww, wh);
function on_colors_changed() {
window.Repaint();
function on_paint(gr) {
gr.FillSolidRect(0, 0, ww, wh, dui ==1 ? window.GetColorDUI(1) : window.GetColorCUI(3));
var Img, size;
if (Img = CurImage) {
currentopacity = opacity;
size = CurSize;
gr.DrawImage(Img, size.x, size.y, size.width, size.height, 0, 0, Img.width, Img.height, 0, opacity);
if (Img = NewImage) {
currentopacity = 255-opacity;
size = NewSize;
gr.DrawImage(Img, size.x, size.y, size.width, size.height, 0, 0, Img.width, Img.height, 0, 255-opacity);
//gr.DrawImage(g_img, pos_x, pos_y, new_width, new_height, 0, 0, g_img.Width, g_img.Height);
if(dui == 1)
gr.DrawRect(0,0, window.Width, window.Height, 1.0, RGB(160,160,160));
Buttons.OnPaint && Buttons.OnPaint(gr);
function CalcNewImgSize(img) {
var size = {x:0, y:0, width:ww, height:wh};
if (img) {
if(window.GetProperty("aspect") == 1) {
var scale_w = ww / img.Width;
var scale_h = wh / img.Height;
scale = Math.min(scale_w, scale_h);
if (scale_w < scale_h)
size.y = (wh - g_img.height * scale) / 2;
else if (scale_w > scale_h)
size.x = (ww - img.Width * scale) / 2;
size.width = img.Width * scale;
size.height = img.Height * scale
return size;
function on_playback_new_track(){
Buttons.SetPauseStatus && Buttons.SetPauseStatus();
changeImage();
function on_playback_pause(state) {
window.Repaint();
function on_playback_stop(reason){
function changeImage() {
g_metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
is_embedded = "No";
if(g_metadb) {
type = window.GetProperty("id");
g_img = utils.GetAlbumArtEmbedded(g_metadb.rawpath, type);
if(g_img) {
is_embedded = "Yes";
} else {
g_img = utils.GetAlbumArtV2(g_metadb, type);
if (NewImage) {
CurSize = NewSize;
opacity = 255;
NewImage = g_img;
NewSize = CalcNewImgSize(NewImage);
if (!timer) timer = window.CreateTimerInterval(RefreshInterval);
window.Repaint();
//if ( fb.IsPlaying) return;
function on_item_focus_change()
if (!fb.IsPlaying)
changeImage();
changeImage();
function on_mouse_move(x,y) {
Buttons.OnMouseMove && Buttons.OnMouseMove(x, y);
if(!hover) {
if (NewImage)
g_tooltip.Text = "Embedded image: " + is_embedded + ". Actual size: " + NewImage.Width + " x " + NewImage.Height + ". Current size: " + Math.round(NewSize.width) + " x " + Math.round(NewSize.height) + ".";
else if (CurImage)
g_tooltip.Text = "Embedded image: " + is_embedded + ". Actual size: " + CurImage.Width + " x " + CurImage.Height + ". Current size: " + Math.round(CurSize.width) + " x " + Math.round(CurSize.height) + ".";
g_tooltip.Activate();
hover = true;
function on_mouse_leave() {
Buttons.OnMouseLeave && Buttons.OnMouseLeave();
g_tooltip.Deactivate();
hover = null;
function on_mouse_lbtn_down(x,y){
Buttons.OnLbtnDown && Buttons.OnLbtnDown(x, y);
Buttons.OnLbtnUp && Buttons.OnLbtnUp(x, y);
function on_mouse_rbtn_up(x, y) {
var MF_SEPARATOR = 0x00000800;
var MF_STRING = 0x00000000;
var _menu = window.CreatePopupMenu();
var idx;
_menu.AppendMenuItem(MF_STRING, 1, "Refresh");
_menu.AppendMenuItem(MF_SEPARATOR, 0, 0);
_menu.AppendMenuItem(MF_STRING, 2, "Correct Aspect Ratio");
_menu.AppendMenuItem(MF_STRING, 4, "Front Cover");
_menu.AppendMenuItem(MF_STRING, 5, "Back Cover");
_menu.AppendMenuItem(MF_STRING, 6, "Disc");
_menu.AppendMenuItem(MF_STRING, 7, "Icon");
_menu.AppendMenuItem(MF_STRING, 8, "Artist");
//_menu.AppendMenuItem(MF_STRING, 9, "Properties");
_menu.AppendMenuItem(MF_STRING, 10, "Configure...");
_menu.CheckMenuItem(2, window.GetProperty("aspect") == 0 ? 0x0 : 0x8);
_menu.CheckMenuRadioItem(4, 8, window.GetProperty("id")+4);
idx = _menu.TrackPopupMenu(x, y);
switch(idx) {
case 1:
changeImage();
break;
case 2:
window.GetProperty("aspect") == 0 ? window.SetProperty("aspect", 1) : window.SetProperty("aspect", 0);
changeImage();
window.Repaint();
break;
case 4:
case 5:
case 6:
case 7:
case 8:
window.SetProperty("id", idx-4);
changeImage();
break;
case 9:
window.ShowProperties();
break;
case 10:
window.ShowConfigure();
break;
_menu.Dispose();
return true;
//if (window.GetProperty("Buttons") == 1) {
if (true) {
var Buttons = new function () {
var BtnDir = window.GetProperty("BtnimageDirectory");
var Position = 4;
this.x = 100;
this.y =0;
this.width = 0;
this.height = 0;
var opacity = 0;
var defaultOp = 150;
var hbtn = null;
var dbtn = null;
var timer = null;
var step = 40;
var dstOp = 0;
var _this = this;
this.BtnsArray = new Array();
// Define button class ------------------------------------------------
var Button = function (x, y, img, OnClick, tiptext) {
this.x = x;
this.y = y;
this.width = img.width;
this.height = img.height;
this.Img = img;
this.tiptext = tiptext;
this.state = 0; // 0=normal, 1=hover, 2=down, 3=disabled
this.enabled = true;
this.OnClick = OnClick;
var Tooltip = g_tooltip;
this.isXYinBtn = function (x, y) {
if (!this.enabled) return false;
return (x >= this.x && y >= this.y && x<= this.x + this.width && y <= this.y + this.height) ? true : false;
this.Draw = function (gr, op) {
if (!opacity) return;
gr.DrawImage(this.Img, this.x, this.y, this.width, this.height, 0, 0, this.width, this.height, 0, opacity);
this.ChangeState = function (s, enabled) {
//if (!this.enabled && !enabled) return;
if (enabled===undefined) {
if (s==this.state)
return;
else
this.state = s;
} else {
this.enabled = enabled;
this.state = enabled ? 0 : 3;
if (s==1) {
Tooltip.Text = this.tiptext;
Tooltip.Activate();
} else
Tooltip.Deactivate();
if (opacity)
window.RepaintRect(Math.max(0, this.x), Math.max(0, this.y),
Math.min(window.width,this.width), Math.min(window.height, this.height));
// Create buttons --------------------------------
var img_play = gdi.image(BtnDir+"Play.png");
var img_pause = gdi.image(BtnDir+"Pause.png");
var img_next = gdi.image(BtnDir+"Next.png");
var img_prev = gdi.image(BtnDir+"Prev.png");
var img_reload = gdi.image(BtnDir+"reload.png");
var img_albumart = gdi.image(BtnDir+"albumart.png");
var xOffset = this.x;
this.BtnsArray.push(new Button(xOffset, this.y, img_reload, function(){changeImage();}, "Refresh"));
xOffset += this.BtnsArray[this.BtnsArray.length-1].width;
this.BtnsArray.push(new Button(xOffset, this.y, img_prev, function(){fb.Prev();}, "Previous"));
this.BtnsArray.push(PlayBtn = new Button(xOffset, this.y, img_play, function(){fb.PlayOrPause();}, ""));
this.BtnsArray.push(new Button(xOffset, this.y, img_next, function(){fb.Next();}, "Next"));
this.BtnsArray.push(new Button(xOffset, this.y, img_albumart, function(){fb.RunContextCommand("Run service/AlbumArt");}, "NexAlbumArt"));
PlayBtn.tiptext_play = "Play";
PlayBtn.tiptext_pause = "Pause";
PlayBtn.tiptext = fb.IsPaused ? PlayBtn.tiptext_play : PlayBtn.tiptext_pause;
PlayBtn.img_pause = img_pause;
PlayBtn.img_play = img_play;
PlayBtn.Img = fb.IsPlaying ? PlayBtn.img_pause : PlayBtn.img_play;
PlayBtn.ChangeState(null, true);
this.PlayBtn = PlayBtn;
this.width = xOffset-this.x;
this.height = PlayBtn.height;
this.SetPauseStatus = function () {
if (fb.IsPlaying && !fb.IsPaused) {
PlayBtn.Img = PlayBtn.img_pause;
PlayBtn.tiptext = PlayBtn.tiptext_pause;
} else {
PlayBtn.Img = PlayBtn.img_play;
PlayBtn.tiptext = PlayBtn.tiptext_play;
var isXYinBtns = function (x, y) {
return (x >= _this.x && y >= _this.y && x<= _this.x + _this.width && y <= _this.y + _this.height) ? true : false;
var Fading = function (dstop) {
if (dstOp==dstop) return;
dstOp = dstop;
this.OnPaint = function (gr) {
for (var i=0; i<this.BtnsArray.length; i++)
this.BtnsArray[i].Draw(gr, opacity);
this.OnMouseMove = function (x, y) {
if (isXYinBtns(x, y)) {
if (opacity!=255) {
dstOp = 255;
opacity = 255;
} else if (opacity!=defaultOp)
Fading(defaultOp);
if (dbtn) {
if (dbtn.isXYinBtn(x, y))
dbtn.ChangeState(2);
else
dbtn.ChangeState(1);
} else {
for (var i=0; i < this.BtnsArray.length ; i++)
if (this.BtnsArray[i].isXYinBtn(x,y)) {
if (hbtn!=this.BtnsArray[i]) {
if(hbtn) hbtn.ChangeState(0);
hbtn = this.BtnsArray[i];
hbtn.ChangeState(1);
break;
if (i==this.BtnsArray.length) {
if (hbtn) {
hbtn = null;
this.OnLbtnDown = function (x, y) {
if (hbtn) {
dbtn = hbtn;
this.OnLbtnUp = function (x, y) {
if (dbtn) {
if (dbtn.state==2) {
dbtn.OnClick();
dbtn = null;
this.OnMouseMove(x, y);
this.OnMouseLeave = function () {
Fading(0);
if (hbtn) {
hbtn = null;
this.OnTimer = function (id) {
if (opacity==dstOp) {
timer = null;
} else {
if (opacity<dstOp)
opacity = Math.min(opacity+step, dstOp);
else
opacity = Math.max(opacity-step, dstOp);
this.OnResize = function (ww, wh) {
if (Position==1 || Position==4)
this.x = (ww-this.width)/2;
else if (Position==2 || Position==5)
this.x = ww-this.width;
if (Position>2)
this.y = wh-this.height;
var x = this.x;
for (var i=0; i<this.BtnsArray.length; i++) {
this.BtnsArray[i].x = x;
x += this.BtnsArray[i].width;
if (Position>2)
this.BtnsArray[i].y = wh-this.BtnsArray[i].height;
else this.BtnsArray[i].y = 0;
this.width = x-this.x;
this.OnResize(window.Width, window.Height);
} else
var Buttons = {};
work in progress of text only bio panel for DUI.
[a href="http://k5sbdw.blu.livefilestore.com/y1pPOpFoa7lzRfqT7f4wY_qJxB5ZCBSqi3ON2CXShGq84Oe67KFT7tdZLopO_jmF-pYnYeY7wX2cuqIV63p_t1u2_WkBj7Js7az/bio.png" target="_blank"]
That's pretty cool. What would be really awesome is if your fading effects could somehow be merged with marc2003's button script to easily create buttons that fade between the normal state and hover state.
Sorry but i dont see what script. May be i can do it.
This one here: http://javascript.pastebin.com/f77d9e62f (http://javascript.pastebin.com/f77d9e62f)
Ok so that s the first one i used but i dont want it because you cant hae centered buttons. in this script the buttons have fixed position.
super!
i cant script JS but this looks so brilliant, i'm gonna learn it and make an awesome DUI interface!
thanks so much! keep more scripts coming!
here's my text only biography display.
you'll need a last.fm api key to use it. register here.... http://www.last.fm/api/account (http://www.last.fm/api/account) and then edit the first line of the script.
[removed]
it caches the results in a folder called lastfm_bio inside your profile folder (this is created automatically for you). but you can force an update through the context menu should you want to.
it has no other features. it's for display purposes only.
and sorry if there is too much text to fit in a panel. i don't have the skills or inclination to learn how to do such a thing. just make it bigger.
Awesome. I always loved the functionality of the biography plugin, but it always causes at least a split second stutter when switching tracks (and considerably more than that if I want to display artist art) on the DUI. This works very well.
Great job marc2003.
Just one thing. You know that biography view can get those info for you and cache them. As it works as a background process i suppose it also works with DUI.
i am using biograview tags to do what you do.
Great job marc2003.
Yes, it can. But it causes some minor pauses (for me at least) when switching tracks even when only running as a background process. Not relying on the biography plugin seems to solve that problem.
Great job marc2003.
Oh i didnt know that. Sorry
It might not be the case for CUI, but I can notice it on DUI. If you use a crossfader (I do) or gapless playback, there's a small (yet noticeable) blip between tracks. Additionally, this "blip" also freezes the UI display, so it effectively breaks the fading effect in your new album art script.
i didn't. but at least mine gives people a blank canvas to work with. it could easily be expanded to use the foobar artreader for images, adding backgrounds, styling, buttons, etc.
Yes you are right. Great job
an update on my bio panel. just a little bug fix.
Moderation: (Link removed by [a href='index.php?act=findpost&pid=682249']request[/a].)[/size]
carmenm, be sure to post your similar artists script when you get to a point where you think it's stable, that looks amazing!
Thanks i will. But seeing problems people have with Biography view, i am writing a background script to do its caching job. All my other lastfm scripts will depend on it. Will post as soon as it is stable.
I have a script to share, it's an album art/lyrics view. Also, I made a quick script to get the colours and font, name it getColoursFonts.js in your scripts directory: http://pastebin.com/f194f3496 (http://pastebin.com/f194f3496)
Now here is my art viewer. It has the following features: double click to swap between prefer now playing and prefer focused track, middle click to swap between prefer art and prefer lyrics, and mouse scroll to change art type or to scroll lyrics. http://pastebin.com/f3d25a237 (http://pastebin.com/f3d25a237)
I haven't got a fade transition on the art, and I'm not sure the lyrics scroll quite right. It also doesn't handle synced lyrics, but it probably could be modified to.
thanks for those tom. can't believe i didn't think of using the mouse wheel to scroll my biography panel.
updated version with scrolling support.
@tom, your script needs a little fixing. starting foobar with an empty playlist causes your panel to crash.
Hey Marc, I don't want to discourage your efforts, but take a look at the biography view thread: http://www.hydrogenaudio.org/forums/index....5&start=225 (http://www.hydrogenaudio.org/forums/index.php?showtopic=70955&st=225&start=225)
oh well....
i hope ssenna ports over his other components to DUI. library tree and ELPlaylist would be amazing
Wow that s a great news.
I wanted to show what i managed to build with WSH panel Mod. Every panel is made with WSH.
I have no Biography View. There is a background wsh that download everything necessary from Lastfm. All the others are just triggered for new data.
I could use biography view to do so, but syncing with my panel would be hard and would still have to communicate with lastfm for love, etc ... And i prefer to limit the number of connections.
Moreover the back script does not only download data for the playing track, it also download small artist images for similar.
All images are cached.
For the similar artists, those are buttons that link to the lastfm page
I will released as soon as possible. I still need to debug and use an ini file for all panels.
Hope you like it
(http://img685.imageshack.us/img685/3060/61533844.th.jpg) (http://img685.imageshack.us/i/61533844.jpg/)
my menu is better than yours....
Thanks, I think I fixed it: http://pastebin.com/f1e4b9ee6 (http://pastebin.com/f1e4b9ee6)
..ZIP..
I want to make a buttonpanel. I use your scripts.
I setup a run service to aktivate Album Art Downloader with the Artist and Title of the selected song.
If I press the button nothing happends. Only if I play the song the button will work.
Can I change this ?
you can add add this to your script.....
function on_item_focus_change() {
if (g_metadb) window.UnwatchMetadb();
if (g_metadb) {
on_metadb_changed();
window.WatchMetadb(g_metadb);
function on_playlist_switch() {
on_item_focus_change();
if(!g_metadb) return;
//you need to move your buttons declaration into here
Buttons = {
but1: new Button(0,0,bw,bh, {normal: images + "stop.png", hover: images + "stop_h.png"}, function(){fb.Stop();}, "Stop"),
but2: new Button(bw,0,bw,bh, {normal: images + "pause.png", hover: images + "pause_h.png"}, function(){fb.Pause();}, "Pause"),
but3: new Button(bw*2,0,bw,bh, {normal: images + "play.png", hover: images + "play_h.png"}, function(){fb.Play();}, "Play"),
but4: new Button(bw*3,0,bw,bh, {normal: images + "previous.png", hover: images + "previous_h.png"}, function(){fb.Prev();}, "Previous"),
but5: new Button(bw*4,0,bw,bh, {normal: images + "next.png", hover: images + "next_h.png"}, function(){fb.Next();}, "Next")
you need to use this as your function
fb.RunContextCommandWithMetadb("context menu command goes here", g_metadb);
also, be aware that WSH panel mod can only run commands on the selected/playing
item only and not a selection.
This is a simple demo that using GdiDrawText() with scroll (mouse):
EDIT: Improved
EDIT2: Improved again, now both mouse whell and mouse drag work.
http://pastebin.ca/1758754 (http://pastebin.ca/1758754)
var DT_TOP = 0x00000000;
var DT_CENTER = 0x00000001;
var DT_VCENTER = 0x00000004;
var DT_WORDBREAK = 0x00000010;
var DT_CALCRECT = 0x00000400;
var DT_NOPREFIX = 0x00000800;
String.prototype.repeat = function( num ) {
return new Array( num + 1 ).join( this );
var g_font = gdi.Font("Tahoma", 12);
var g_text = ("Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.\n" +
"Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.\n" +
"Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.\n" +
"Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.\n\n").repeat(5);
var ww = 0, wh = 0;
var g_textcolor = 0xff000000;
var g_backcolor = 0xffffffff;
var g_need_calc = true;
var g_textheight = 0;
var g_offset = 0;
var g_drag = false;
var g_drag_y = 0;
// START
ww = window.Width;
wh = window.Height;
reset();
gr.FillSolidRect(0, 0, ww, wh, g_backcolor);
if (g_need_calc) {
calc();
} else {
gr.GdiDrawText(g_text, g_font, g_textcolor, 0, g_offset, ww, wh - g_offset, DT_CENTER | DT_WORDBREAK | DT_NOPREFIX);
function on_mouse_lbtn_down(x, y) {
g_drag = true;
g_drag_y = y;
g_drag = false;
if (g_drag) {
applyDelta(y - g_drag_y);
g_drag_y = y;
function on_mouse_wheel(step) {
applyDelta(step * 20);
function calc() {
// Using a temp IGdiGraphics interface
var temp_bmp = gdi.CreateImage(1, 1);
var temp_gr = temp_bmp.GetGraphics();
// Calculate
arr = temp_gr.GdiDrawText(g_text, g_font, g_textcolor, 0, 0, ww, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX).toArray();
g_textheight = arr[3] - arr[1];
g_offset = wh / 2;
g_need_calc = false;
// Free the resources
temp_bmp.ReleaseGraphics(temp_gr);
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
window.Repaint();
function applyDelta(delta) {
var temp = g_offset + delta;
if ((temp <= wh / 2) && (temp >= wh / 2 - g_textheight)) {
g_offset = temp;
window.Repaint();
function reset() {
g_need_calc = true;
g_offset = 0;
It s faster than with the other method. I like it a lot.
Using it right now.
MediaInfo panel
Grab script: http://pastie.org/787344 (http://pastie.org/787344)
Screenshot:
(http://i29.photobucket.com/albums/c276/saivert/th_fb2k-mediainfo-wshpanel-2.jpg) (http://s29.photobucket.com/albums/c276/saivert/fb2k-mediainfo-wshpanel-2.jpg)
Requires:
MediaInfo CLI version (http://mediainfo.sourceforge.net/en/Download/Windows)
Notes:
Using the WshShell.Exec to grab output from a console application via STDOUT will throw up a console window for a fraction of a second. This is ugly so we have get the output from MediaInfo in a different manner. Instead I use WshShell.Run to run my app via CMD so I can redirect output to a text file and then read this text file back to a variable. This is a roundabout way because WshShell.Exec is badly implemented (should have hidden the console window).
function get_mediainfo() {
if (!g_metadb) return;
var tmp = fb.ProfilePath+"tmp.txt";
//if (fso.FileExists(tmp)) fso.DeleteFile(tmp); // permission denied?
var e = "cmd /C \"\"" + mediainfo_path + "\" \"" + g_metadb.Path + "\">\""+tmp+"\"\""; // Mind the quotes!
//fb.trace(e);
wsh.Run(e, 0, true); // Run hidden and wait for it
var text = fso.OpenTextFile(tmp, 1, false);
g_text = text.ReadAll();
I create a simple lyrics panel and have one question about how to remove the timestamps.
For now i use:
replace(/\[\d+:\d+.\d+\]/g,"")
This removes the timestamps, but not the info parts at the beginning of such timestamped lyrics files.
Has anybody an idea how i can remove all "squared brackets" parts?
So [ar:Peter Gabriel] and [01:56.32] for instance will be removed completely?
Is there any "wildcard" in jscript so i could use something like: replace(/\[*\]/g,"")
Try replace(/\[.*\]/g,"")
replace(/\[.+\]/g,"")
maybe?
I knew it must be something easy...
Seems to work both.
Where are the differences?
EDIT: Nevermind, i found it. Thanks again
Hi guys, I am currently trying to make some buttons that act more like the main menu, that is, you click once to open the menu and click again to close it. The problem is my buttons at the moment only open the menu. I can't figure out how to stop it from opening in a way that doesn't break it. Here is a simplified script , the red rectangle is the button to open the menu:
var colour = 0xffff0000;
var menu_on = false;
function menu()
var basemenu = window.CreatePopupMenu();
basemenu.AppendMenuItem(0x00000000, 1, "Hi");
menu_on = true;
ret = basemenu.TrackPopupMenu(20, 60);
menu_on = false;
if(ret) fb.trace("Hello there");
basemenu.Dispose();
gr.FillSolidRect(0,0,window.Width,window.Height,0xffffffff);
gr.FillSolidRect(20,20,40,40,colour);
if(x>=20 && x<=60 && y>=20 && y<=60)
colour = 0xff0000ff;
window.Repaint();
colour = 0xff00ff00;
else
window.Repaint();
menu();
window.Repaint();
if(!menu_on)
window.Repaint();
If anyone could suggest anything I'd really appreciate it
The difference is in the quantifier, * for 0 or more and + for 1 or more.
But [font= "Courier New"]/\[[^\]]*\]/g[/font] is best (a literal [, then any number of chars not being a ], then the closing bracket itself).
I don't know if it matters here, but the previous patterns are greedy and would replace for example "foo[123]bar[456]2000" to "foo2000" instead of "foobar2000".
Seems to work both.
replace(/\[.+\]/g,"") matches for example
- but not [], whereas replace(/\[.*\]/g,"") matches also []. For the expression from marc2003 there has to be at least one character between the brackets.
Edit: Yirkha was faster. If it is supported by JScript /\[.*?\]/g should also work as a non-greedy expression.
Thanks Yirkha
(and of course thanks to fbuser and marc2003 too )
Now my little lyrics panel will become perfect (in time...)
EDIT:
@fbuser
Your last suggestions works too (tried it with the foo[123]bar[456]2000 sample from Yirkha )
Its shorter, so i'll use it.
Thanks again.
The last.fm bios panel annoyed me with always starting the text half-way down in the panel so I fixed it.
fixed on_paint function:
if(window.InstanceType == 1) gr.DrawRect(0,0, ww, wh, 1.0, RGB(160,160,160));
if(g_metadb) {
try {
if(fso.FileExists(folder + "\\" + filename)) {
ts = fso.OpenTextFile(folder + "\\" + filename,1);
g_text = ts.ReadAll();
ts.close();
if (g_need_calc) {
calc();
} else {
//old: gr.GdiDrawText(g_text, g_font, g_textcolor,
// 5, g_offset, ww-5, wh - g_offset, DT_WORDBREAK | DT_NOPREFIX);
5, g_offset-(wh/2), ww-5, wh*2-g_offset, DT_WORDBREAK | DT_NOPREFIX);
} catch(e) {}
oh yuck. you shouldn't be loading the text file in on_paint like that - but it looks like you took the example i posted so that's entirely my fault for posting awful code. trouble is with these forums i can't edit my posts.
the opening text file bit should be in on_metadb_changed().
sorry to be a nuisance, but could a moderator delete these posts.
http://www.hydrogenaudio.org/forums/index....st&p=680709 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=680709)
http://www.hydrogenaudio.org/forums/index....st&p=680754 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=680754)
http://www.hydrogenaudio.org/forums/index....st&p=680791 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=680791)
from now i'll post snippets on my own webspace so if i **** them up i can edit them without having to pester you guys. sorry.
@tedgo: You might also want to delete the blank lines at the beginning of the text, try this as well:
replace(/^(\r?\n)+/g,"")
I'm not sure it's best to delete everything inside square brackets. You could use multi-line mode and only match square bracketed stuff at the beginning of each line:
replace(/^\[.*\]/mg,"")
I'm not using laziness because I've found some lyrics that have multiple time stamps at the beginning of some lines.
Hi guys, I am currently trying to make some buttons that act more like the main menu...
Try this instead.
//var menu_on = false;
var g_t = null;
function menu()
var d = new Date();
if (d.getTime()-g_t < 200) return;
//menu_on = true;
d = new Date();
g_t = d.getTime();
//menu_on = false;
basemenu.Dispose();
window.Repaint();
else
window.Repaint();
menu();
window.Repaint();
//if(!menu_on)
// colour = 0xffff0000;
//window.Repaint();
//bscly!
This should do it I guess. It is indeed a hack since TrackPopupMenu is a blocking function and there is no proper way around that fact.
Notes:
Having a global variable which you set before opening the menu and reset after TrackPopupMenu returns doesn't work. It is of no use in the interim as the script simply doesn't run at that time. As long as the menu is visible (not dismissed) the script is waiting.
Maybe if WSH Panels had a callback function for menus so you call a non-blocking version of TrackPopupMenu and then handle the menu ID clicked in a callback function. This would require WSH Panel to handle the menu in a separate thread, which I'm not sure would work properly.
Which is what was proposed earlier by Yirkha. Post scripts on pastebin (or your own webspace) or something instead of using ugly codeboxes on the forum.
Why not using gitshub ?
https://github.com/ (https://github.com/)
lets people contribute on scripts online. versioning etc.
er yes. it was me who started the thread on the advice of Yirkha. the snippets in those posts are all on pastebin.
the problem with pastebin is that making changes generates a new url so the links in my posts are still pointing towards the original duff code which i can't delete.
@TomBarlow
You mean like this?
lyrics.replace(/\[.*?\]/g,"").replace(/^(\r?\n)+/g,"")
Seems to work...
Try this instead.
Thanks very much, it works well. Unfortunately I do need something under on_mouse_leave as it is called when the menu is opened, and I want my buttons to be in the 'down' state.
Tedgo, I think this should work?
.replace(/^(\[.*?\])+/mg,"").replace(/^(\r?\n)+/g,"")
It should turn this:
[1234][2345]tra la la [huh] la la
into this:
As well as getting rid of empty lines at the start.
Yes, it does.
Thanks again
Hi everyone,
I wanted to show you guys what i am working on. SO here is a screenshot.
(http://img683.imageshack.us/img683/2253/66899230.th.jpg) (http://img683.imageshack.us/i/66899230.jpg/)
THere is an lot of features behind that config like:
- automatic download and caching of artists bio, big, similar artists small arts. And all that is done in the background.
- All other panels are informed when a new info related to them is available so that they update themselves
- the 2 art panels you see are actually the same config. Huge amount of options like my new fillImage algorithm that you can see in use in the artist panel. You can also add button, choose the position. The art panel allows you to use an external program(aad here) to change the current image. And the panel will automatically update itself afterwards.
- THe similar panels has a lot of options like a custom right click menu for each artists with multiple search engines and opening the artist radio with lastfm_radio!
- the biography panel doesnt have so much options yet
- All those back features are controled by one background config that does the works and can inform you of any errors.
- All those panels config are saved and loaded from ini in a smart way. Change a common option from the back wsh and all other panels will update themselves.
I would love to release it today but there are still things i want to change. Like more options for buttons and everything. And i also use the hours i spend using it to correct all the possible bugs(like with artists names). Yet i couldnt resist showing you what i have so far.
Hope you like it.
And i couldnt have done any of this without TPWang and marc2003 so thanks a lot to both of you!
That sounds great. I'm really looking forward to it!
@carmenm: Absolutely great, that's what I'm looking for... so where you're going to release it?
To be true i could just release it now. It works great and is already very configurable. but I dont want to release it too fast and then have to make updates that will break your configs. So i just need a little time to make it more configurable.
In fact what i want is for you never to have to modify anything in the code itself.
I dont have so much time here at work.
Will do as much as i can tomorrow.
I hope to release it this we then.
@carmenm: Good luck! I'm really looking forward to try your work. Especially the upper half of your design fits totally my expectations on a design I always tried to build on my own, but I hadn't this success (maybe based on a lack of time) you have - chapeau!
wow carmenm, can't wait to try it out!
(sorry, I originally posted this in the WSH Panel Mod thread without seeing this script discussion one and can't delete my post there)
I installed this plugin and used the MainMenuManager All-In-One sample so I can access the entire foobar menu just by clicking the panel. My question is, how do I make the wsh panel look better by making it display text "Menu" or an icon button?
g_img = gdi.Image(fb.FoobarPath + "path\\to\\image.png");
gr.DrawImage(g_img, 0, 0, g_img.Width, g_img.Height, 0, 0, g_img.Width, g_img.Height);
EDIT: Improved
it doesn't work here on WSH Pnale Mod 1.3.0 beta 4 + foobar 1.0
WSH Panel Mod (GUID: DD259EC0-0DA3-4856-BFD4-B8402D106108): initliased in 0.0000006 s
Error: WSH Panel Mod (GUID: DD259EC0-0DA3-4856-BFD4-B8402D106108): Erreur d'exécution Microsoft JScript:
Cet objet ne gère pas cette propriété ou cette méthode
Ln: 70, Col: 1
<no source text available>forgot, it's ok with v1.3.0 final...
Thanks marc2003! I pasted it into the window and I changed "path\\to\\image.png" to "images\\image.jpg" to point it to my foobar\images directory. But it still just shows a blank window. Sorry, I have very little knowledge about this stuff.
the script would error if the image wasn't found. not sure what's going on there.
Doh, made a little typo when putting it in. Now works perfectly, thanks again marc!
Updates the Bios panel:
http://gist.github.com/285324 (http://gist.github.com/285324)
Changes:
- Doesn't open text file in on_paint anymore
- Prints "#EOF" in red at end of text to avoid confusion as to where the text actually ends.
Plans:
- Proper scrollbar (coding a scrollbar from scratch should be feasible, but such a waste (http://www.hiddenpixels.com/javascript/custom-javascript-scrollbar/)).
- Autoscrolling (need to use timer)
Actually adding real scrollbar to the panel window and then having some events in the js code for handling scrollbar messages would be better.
Might take a look at the WSH Panels Mod source and see what I can do.
I imagine something like:
var SCROLLBAR_NONE = 0;
var SCROLLBAR_VERTICAL = 1;
var SCROLLBAR_HORIZONTAL = 2;
// to get both use OR
window.enableScrollbar(SCROLLBAR_VERTICAL);
window.setScrollbarExtent(SCROLLBAR_VERTICAL, 100);
function on_scrollbar_message(which, pos) {
// etc...
I actually don't like that other separate Bios component. It is buggy and slow. Coding my own with WSH Panels Mod is much better.
It is buggy.
but yours is pretty buggy as well.
#EOF gets printed over the text a lot (it's position on a previous artist isn't updated when switching to a new artist)
it can't save text files with special characters in (see this post on how to fix - http://www.hydrogenaudio.org/forums/index....t&p=682074) (http://www.hydrogenaudio.org/forums/index.php?showtopic=70363&view=findpost&p=682074))
text sometimes disappears completely when scrolling.
text doesn't always update when changing tracks with different artists (random)
sometimes can't scroll back to top
edit: try this one (it doesn't support dragging though, only mouse scrolling)
api_key = "";
DT_END_ELLIPSIS = 0x00008000;
ColorTypeCUI = {
text: 0,
selection_text: 1,
inactive_selection_text: 2,
background: 3,
selection_background: 4,
inactive_selection_background: 5,
active_item_frame: 6
FontTypeCUI = {
items: 0,
labels: 1
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
FontTypeDUI = {
defaults: 0,
tabs: 1,
lists: 2,
playlists: 3,
statusbar: 4,
console: 5
function get_font() {
if (g_instancetype == 0) {
g_font = window.GetFontCUI(FontTypeCUI.items);
} else if (g_instancetype == 1) {
g_font = window.GetFontDUI(FontTypeDUI.defaults);
function get_colors() {
g_textcolor = window.GetColorCUI(ColorTypeCUI.text);
g_textcolor_hl = window.GetColorCUI(ColorTypeCUI.text);
g_backcolor = window.GetColorCUI(ColorTypeCUI.background);
g_textcolor = window.GetColorDUI(ColorTypeDUI.text);
g_textcolor_hl = window.GetColorDUI(ColorTypeDUI.highlight);
g_backcolor = window.GetColorDUI(ColorTypeDUI.background);
get_colors();
window.Repaint();
function on_font_changed() {
get_font();
window.Repaint();
if (g_metadb) {
try { on_metadb_changed(); } catch(e) {}
g_instancetype = window.InstanceType;
get_font();
get_colors();
function lastfm(url, user_agent, func, debug) {
xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
xmlhttp.open("GET", url + "&s=" + Math.random(), true);
xmlhttp.setRequestHeader('User-Agent',user_agent);
xmlhttp.send();
xmlhttp.onreadystatechange = function() {
if (xmlhttp.readyState == 4) {
if (xmlhttp.status == 200) {
if(debug) fb.trace(xmlhttp.responsetext);
func();
} else {
var artist = g_text = '';
folder = fb.ProfilePath + "wsh_lastfm";
fso = new ActiveXObject("Scripting.FileSystemObject");
WshShell = new ActiveXObject("WScript.Shell");
if(!fso.FolderExists(folder)) fso.CreateFolder(folder);
String.prototype.count=function(s1) {
return (this.length - this.replace(new RegExp(s1,"g"), '').length) / s1.length;
function get_bio() {
url = "http://ws.audioscrobbler.com/2.0/?method=artist.getinfo&api_key=" + api_key + "&artist=" + encodeURIComponent(artist);
lastfm(url, "foo_wsh_lastfm_bio", function() {save_file();},0);
function save_file() {
xmlDoc = xmlhttp.responseXML;
try {
g_text = xmlDoc.getElementsByTagName("content")[0].childNodes[0].nodeValue;
g_text = g_text.replace(/<\/?[^>]+(>|$)/g, "");
doc = new ActiveXObject("htmlfile");
doc.open();
div = doc.createElement("div");
div.innerHTML = g_text.replace(/\n/g, "<br>");
g_text = div.innerHTML;
g_text = g_text.replace(/<BR>/g,"\n");
g_text = g_text.replace(/&/g,"&");
} catch(e) {
g_text = "This artist does not have a biography page on Last.fm.";
try {
ts = fso.OpenTextFile(filename, 2, true, -1);
ts.WriteLine(g_text);
ts.close();
} catch(e) {
g_text = "Error saving biography for this artist.";
calc();
ww = window.Width;
wh = window.Height;
calc();
if(g_metadb) {
gr.GdiDrawText(g_text, g_font, g_textcolor, 6, offset + 36, ww-16, wh-offset,DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
gr.FillSolidRect(0, 0, ww, 38, g_backcolor);
gr.GdiDrawText(artist, gdi.Font("Segoe UI", 16, 1), g_textcolor_hl, 6, 5, ww-77, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.DrawLine(5, 29, ww-10, 29, 1, RGB(137,140,149));
if(!g_metadb || artist == fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb)) return;
artist = fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb)
filename = folder + "\\" + fb.TitleFormat("$crc32(%artist%).txt").EvalWithMetadb(g_metadb);
if(fso.fileExists(filename)) {
try {
ts = fso.OpenTextFile(filename,1, false, -1);
ts.close();
} catch(e) {
g_text = "Error opening file!";
calc();
} else {
get_bio();
function calc() {
arr = temp_gr.GdiDrawText(g_text, g_font, g_textcolor, 0, 0, ww, wh,DT_CENTER| DT_WORDBREAK | DT_VCENTER | DT_CALCRECT | DT_NOPREFIX).toArray();
textheight = arr[3] - arr[1] + (wh/2) + (g_text.count("\n") * 3);
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
offset = 0;
window.Repaint();
var idx;
_menu.AppendMenuItem(MF_STRING, 1, "Force update");
_menu.AppendMenuItem(MF_STRING, 2, "Configure...");
if(idx == 1) get_bio();
if(idx == 2) window.ShowConfigure();
_menu.Dispose();
return true;
function on_mouse_wheel(delta) {
step = g_font.height * 5;
offset += (delta * step);
if(offset > 0 || textheight < wh) {
offset = 0;
} else {
temp = -textheight + wh;
if(offset < temp) offset = Math.round(temp / step) * step;
window.Repaint();
Excellent code marc2003! You have simplified a lot. Good idea getting rid of all the "var" stuff. Really not needed with JS being a loosely typed language.
I didn't want to edit too much on the previous code I borrowed from you. I know it still needed a lot of work.
But why not use the preprocessor features and import flags.txt and handlers.txt. I think a standard install of WSH Panels mod should have a scripts directory in foobar2000 folder with those standard includes. This would slim down the scripts even further and makes things really clean.
// ==PREPROCESSOR==
// @import "%fb2k_path%scripts\flags.txt"
// @import "%fb2k_path%scripts\helpers.txt"
// ==/PREPROCESSOR==
Oh, I really like this one. The non-scrolling artist header is a cool idea.
But JS has "scope", without "var" it's declared in global scope, and will confuse you if you are constructing a closure and use that variable in and it's hard to locate bugs if all variables are in global scope, eg:
function func1() {
i = 1;
fb.trace('"i" in func1() is :', i); // i = 1
function test2() {
// Call func1() here, and see what happens
i = 2;
func1();
fb.trace('"i" in func2() is :', i); // i = 1 !!!
test2();
doesn't hurt to use var everywhere. but the script mostly avoided "var" on the global variables (outside closures).
i do already. and stuff like the sample colour/font changing stuff goes into an external file as well. then i have an external last.fm script to store my credentials and xmlhttp function - so i can share it between multiple panels.
i just merged it all into a single script above because i couldn't be bothered to explain myself.
Last.fm records the number of times I play a track by a specific artist in order to come up with the "top artists" stats. Is this information available to the API? If so, how would I access this in WSH Panel Mod? Thanks.
Edit: I've got it.
In case anyone's interested, I modified marc2003's bio script to create a Windows 7 style bio panel and lyrics panel. Screenshots:
(http://imgur.com/3hlZC.png)
(http://imgur.com/aVNwB.png)
The code for the bio panel:
var username = "";
var api_key = "";
var image_path = fb.FoobarPath + "images\\";
ColorTypeCUI = {
text: 0,
selection_text: 1,
background: 3,
FontTypeCUI = {
items: 0,
labels: 1
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
FontTypeDUI = {
defaults: 0,
tabs: 1,
lists: 2,
playlists: 3,
statusbar: 4,
console: 5
get_colors();
window.Repaint();
get_font();
window.Repaint();
if (g_metadb) {
get_font();
get_colors();
xmlhttp.send();
func();
else {
var artist = g_text = playcount = '';
var g_img = gdi.Image(image_path + "header.png");
get_playcount();
url = "http://ws.audioscrobbler.com/2.0/?method=artist.getinfo&api_key=" + api_key + "&username=" + username + "&artist=" + encodeURIComponent(artist);
function get_playcount() {
lastfm(url, "foo_wsh_lastfm_bio", function() {extract_playcount();},0);
try {
playcount = xmlDoc.getElementsByTagName("userplaycount")[0].childNodes[0].nodeValue;
doc.open();
catch(e) {
playcount = "0";
try {
ts.close();
catch(e) {
calc();
function extract_playcount() {
try {
catch(e) {
playcount = "0";
window.Repaint();
ww = window.Width;
wh = window.Height;
calc();
if(g_metadb) {
gr.GdiDrawText(g_text, g_font, g_textcolor, 21, offset + 60, ww-42, wh-offset,DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
gr.FillSolidRect(0, 0, ww, 55, g_backcolor);
gr.DrawImage(g_img, 0, 0, 830, 55, 0, 0, 830, 55);
gr.FillGradRect(830, 0, ww - 820, 55, 0, RGB(252,252,252), RGB(255,255,255));
gr.GdiDrawText(artist, gdi.Font("Segoe UI", 18, 0), RGB(0, 120, 50), 21, 4, ww-77, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText("Artist Playcount:", gdi.Font("Segoe UI", 13, 0), RGB(90, 103, 121), 21, 29, ww-16, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(playcount, gdi.Font("Segoe UI", 13, 0), RGB(42, 102, 212), 120, 29, ww-16, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.DrawLine(21, 54, ww-21, 54, 1, RGB(214,229,245));
gr.FillGradRect(6, 54,15, 1, 0, RGB(255,255,255), RGB(214,229,255));
gr.FillGradRect(ww-21, 54,10, 1, 0, RGB(214,229,255),RGB(255,255,255));
get_playcount();
artist = fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb);
try {
ts.close();
catch(e) {
calc();
else {
get_bio();
get_playcount();
function calc() {
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
offset = 0;
window.Repaint();
var idx;
_menu.AppendMenuItem(MF_STRING, 2, "View on Last.fm");
_menu.AppendMenuItem(MF_STRING, 3, "Configure...");
if(idx == 2) WshShell.run("http://www.last.fm/music/" + encodeURIComponent(artist));
if(idx == 3) window.ShowConfigure();
_menu.Dispose();
return true;
offset = 0;
else {
window.Repaint();
The code for the lyrics panel:
var lyrics_tag = "%lyrics%";
if (g_metadb) {
var artist = '';
var title = '';
var lyrics = '';
ww = window.Width;
wh = window.Height;
calc();
gr.FillSolidRect(0, 0, ww, wh, RGB(255,255,255));
if(g_metadb) {
gr.GdiDrawText(lyrics, gdi.Font("Segoe UI", 13, 2), RGB(0, 0, 0), 0, offset + 65, ww-16, wh-offset,DT_CENTER|DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
gr.FillSolidRect(0, 0, ww, 55, RGB(255,255,255));
gr.GdiDrawText(title, gdi.Font("Segoe UI", 18, 0), RGB(0, 120, 50), 0, 4, ww-16, 24,DT_CENTER|DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(artist, gdi.Font("Segoe UI", 13, 0), RGB(90, 103, 121), 0, 29, ww-16, 24,DT_CENTER|DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
title = fb.TitleFormat("%title%").EvalWithMetadb(g_metadb);
lyrics = fb.TitleFormat(lyrics_tag).EvalWithMetadb(g_metadb);
if (lyrics == "?") lyrics = "No Lyrics Available";
window.Repaint();
function calc() {
arr = temp_gr.GdiDrawText(lyrics, gdi.Font("Segoe UI", 13, 2), RGB(0, 0, 0), 0, 0, ww, wh,DT_CENTER| DT_WORDBREAK | DT_VCENTER | DT_CALCRECT | DT_NOPREFIX).toArray();
textheight = arr[3] - arr[1] + (wh/2) + (lyrics.count("\n") * 3);
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
offset = 0;
window.Repaint();
var idx;
_menu.AppendMenuItem(MF_STRING, 2, "Edit Lyrics");
if(idx == 1) window.Repaint();
if(idx == 2) fb.RunContextCommandWithMetadb("edit",g_metadb);
_menu.Dispose();
return true;
step = gdi.Font("Segoe UI", 13, 2).height * 5;
offset = 0;
else {
window.Repaint();
The required header image (needs to be named "header.png"):
(http://imgur.com/z23iK.png)
Finally, in order to get the "edit lyrics" command working, you need this component:
http://www.hydrogenaudio.org/forums/index....showtopic=36598 (http://www.hydrogenaudio.org/forums/index.php?showtopic=36598)
In order to preserve the Windows 7 styling, these scripts don't really play nice with the CUI/DUI default colors. Hopefully someone finds these useful.
that needs some serious reworking. you're making 3 requests to last.fm for the same file all at once.
edit: and it just caused my foobar to crash when starting.....
Ok, this should make fewer calls to Last.fm. Hopefully it also fixes any crashes:
var username = "";
var api_key = "";
if (g_metadb) {
get_bio();
g_font = gdi.Font("Segoe UI", 12, 0);
g_textcolor = RGB(0,0,0);
g_backcolor = RGB(255,255,255);
lastfm(url, "foo_wsh_lastfm_bio", function() {save_file();extract_playcount();},0);
xmlhttp.send();
func();
else {
try {
doc.open();
catch(e) {
playcount = "0";
try {
ts.close();
catch(e) {
calc();
try {
catch(e) {
playcount = "0";
window.Repaint();
ww = window.Width;
wh = window.Height;
calc();
if(g_metadb) {
try {
ts.close();
catch(e) {
calc();
else {
get_bio();
function calc() {
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
offset = 0;
window.Repaint();
var idx;
_menu.Dispose();
return true;
offset = 0;
else {
window.Repaint();
you should be making one call. it's the same file. why are you fetching it twice?
and you might as well scrap the idea of caching files being as though you're fetching the file on every new track.
Ok, so I'm (obviously) new at this. What I was
trying to do was always download the xml file on each new track to obtain the artist playcount. However, I wanted to use the cached artist bio if available (as your code does). Yes, I understand that much of the usefulness of the cached data is lost in this implementation, but displaying the bio info itself should still be quick (cached data) and only the playcount itself will always have a slight delay. So, it should have worked like this:
if no bio is cached, it makes 1 request for the xml file and extracts the bio and playcount.
if a bio is cached, it makes 1 request for the xml file and extracts the playcount only.
I made some stupid mistakes in the previous versions, however, I've reworked the code again (last time for the night), and I
think this does what I want it to:
var username = "";
var api_key = "";
if (g_metadb) {
var artist = g_text = playcount = url = '';
xmlhttp.send();
func();
else {
try {
doc.open();
catch(e) {
playcount = "0";
try {
ts.close();
catch(e) {
calc();
try {
catch(e) {
playcount = "0";
window.Repaint();
ww = window.Width;
wh = window.Height;
calc();
if(g_metadb) {
playcount = '';
get_playcount();
try {
ts.close();
catch(e) {
calc();
else {
get_bio();
function calc() {
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
offset = 0;
window.Repaint();
var idx;
_menu.Dispose();
return true;
offset = 0;
else {
window.Repaint();
@carmenm, how did you parse the feeds to get image urls? i'm stuck doing this.
Can you wait 1 or 2 days? i am on the verge of releasing the manager that will do all that for you.
If you cant tell me and i ll put a code here.
i'm only interested in downloading 1 image per artist - the one in the artist.getinfo
<image size="small">http://userserve-ak.last.fm/serve/34/34848663.png</image>
<image size="medium">http://userserve-ak.last.fm/serve/64/34848663.png</image>
<image size="large">http://userserve-ak.last.fm/serve/126/34848663.png</image>
<image size="extralarge">http://userserve-ak.last.fm/serve/252/34848663.png</image>
<image size="mega">http://userserve-ak.last.fm/serve/_/34848663/Jem++PNG+6.png</image>
i just want to know how to get the url for the "mega" bit and that is all. i tried that activex thing you posted and that works fine if i put in the url manually so i'm happy using that.
Yes that s exactly what my manager does, i wont spoil all the fun I am kidding.
With that line you get all artist tags
var artistsArray = xmlDoc.getElementsByTagName("artist");
then with this one you get the mega picture
var artistpicture = (artistsArray[i].childNodes[7].childNodes[0])?artistsArray[i].childNodes[7].childNodes[0].nodeValue:"";
thanks.
I finally released (http://www.hydrogenaudio.org/forums/index.php?showtopic=78166)my suite.
Enjoy
where is the updated Bios panel without multi last .fm requests. I just want a simple codebase to work from.
no fluff or useless crap. Don't understand why you guys have to go overboard with your scripts. Keep it simple stupid. Less is more, etc... etc..
updated biography panel which caches the whole xml repsonse which means you can save/display all data. rather than parse the response, it now parses the cached file if it exists during on_metadb_changed. uses external js files so check those as well.
http://cid-649d3bfeaf541fbb.skydrive.live....astfm%20bio.zip (http://cid-649d3bfeaf541fbb.skydrive.live.com/self.aspx/.Public/foobar/guide/lastfm%20bio.zip)
(it doesn't display any new data but i've put in samples of how to do it)
marc2003;
Thank you for the above script. I can't seem to get it working though.
Any idea whats going wrong?
popup:
Scripting Engine Initialization Failed (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82, CODE: 0x80020101)
Check the console for more detailed information (Always caused by unexcepted script error).
console output:
WSH Panel Mod (GUID: DA503407-4725-42B8-B2D7-A823F69425D5): initliased in 0.0000371 s
WSH Panel Mod (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82): Parsing file "C:\Program Files (x86)\foobar2000\scripts\marc2003\fonts_colours_flags.js"
WSH Panel Mod (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82): Parsing file "C:\Program Files (x86)\foobar2000\scripts\marc2003\lastfm.js"
Error: WSH Panel Mod (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82): Microsoft JScript runtime error:
Automation server can't create object
Ln: 8, Col: 1
<source text only available in compile time>
file>preferences>tools>wsh panel mod>uncheck "safe mode". restart foobar.
Great...
Works now!
Can some kind soul convert the playback section of this theme (buttons, progress, volume etc) to a script for someone like me who doesn't know even a little but of jscript
http://fanco86.deviantart.com/art/MonoLite-122756120 (http://fanco86.deviantart.com/art/MonoLite-122756120)
With some bio's it fetches I see
codes in there. Is it easy to replace these with normal spaces via your script? What line should I edit where etc?
Are you in the process of writing a new script that fetches the artist images from last.fm? Something in the same manner that the bio plugin does. If so I'm lookig forward to it! Now that I think of it a configurable amount of images per artist would be a nice to have too (than it will have all I like from the bio plugin without the overhead).
i've been thinking about image support but it's not something i'm particularly bothered about. my main motivation is always going to be making something that i'm going to use. sharing it requires no effort at all. maybe i'll consider it when i'm really bored.
can you point me towards a page that shows the  ?
After checking alot of artists in my collection when I came back from work it seems a very minor issue. I coud only find one bio so far. I seem to have hit the same artist alot last night or something.
Here's the link btw but don't feel rushed to fix it. It seems the only one as stated above:
http://www.last.fm/music/The+Temper+Trap (http://www.last.fm/music/The+Temper+Trap)
you can just open "scripts\marc2003\lastfm.js" and at the end, you'll see this line of code....
return value.replace(/&/g,"&");
just add this on the line before it.
value = value.replace(/ /g," ");
BTW, i'm just finishing off a panel to download
album artist art from last.fm. i'll post it later on.
screenshot (http://k5sbdw.blu.livefilestore.com/y1pH2jz98PKrmlL_iFEMcM9pF4dCbQIcynL2KIS4fMba0lsU_jFo-A42p0W0puJuWxOYIV5MuOM3Qr_eQIIg_BougUohy5KB3Yy/artist%20art.png)
edit: damn typo.
Is it possible to Graphical Browser for WSH?
marc2003;
Thanks for the fix.
The screenshot looks great, I'm looking forward to it!
right i've bundled all my scripts into 1 package. these should be usable by anybody even without scripting knowledge. if you know how add panels to a layout and use things like an "import" button, you pass the test.
download here: http://cid-649d3bfeaf541fbb.skydrive.live....ide/samples.zip (http://cid-649d3bfeaf541fbb.skydrive.live.com/self.aspx/.Public/foobar/guide/samples.zip)
i normally leave a trail of dead links but i'll make sure this one stays. any updates will use this link
the usage of this assumes you have WSH panel mod installed and that safe mode is disabled (File>Preferences>Tools>WSH panel mod>uncheck "Safe mode")
extract the scripts folder from zip into your main foobar directory. overwrite any files if prompted. i've used my username as a subfolder so it shouldn't conflict with anybody else's scripts. now you just need to edit this file foobar path\scripts\marc2003\lastfm.js (this file is compatible with my "playcount stats" script. all settings go in this single file. i hope the comments are self explanatory. and you can just ignore the ones for the panels you're not using. for most people, just adding their username and api key will be enough - an api key is something needed to access lastfm's webservices. get one here (http://www.last.fm/api/account)
then add as many WSH panels as you want to use to your layout and import 1 or more of text files. no further configuration should be required.
list of panels:
enhanced artwork panel
meant to be a straight replacement for the default CUI/DUI artwork panels.
features:
--always prioritise embedded album art if present
--full support of patterns set in display preference
--on the fly refresh. this means you can add/edit artwork for the currently playing track and use the "Refresh" context menu item to update the panel. with the standard panels, you have to restart playback.
--tooltip to show image dimensions and current display size. also shows if image is embedded or not.
--has the usual context menu items to set front/back/artist/correct aspect etc
simple text only biography panel
--built in caching support so it doesn't update on every track change (default expiry time is 24 hours because it shows your playcount for each artist. i figured an update every day would be enough)
--button to launch last.fm radio / browse last.fm website
simple seekbar
--shows realtime seek position when dragged.
--move mouse out of bounds downwards to automatically release the drag in the currently playing position
last.fm artist art panel
--download and display artist artwork from last.fm. must be triggered manually using the context menu.
--option to set the number of images to download in the aforementioned configuration file. i've set a default of 5. be warned, some of the images can be very large. i've had some 2-3mb files.
--when images are downloaded, you can scroll through them with your mouse wheel. also, double clicking the panel will open the current image in your default viewer.
--shows new random image on each new track (assuming there are images present for that artist)
--does not use the foobar artreader at all - it stores it's owns files. panel has "open containing folder" option for easy access.
playback buttons
--sample buttons for use in DUI. supports any size images you like. you can replace the included images with your own.
all panels support the default colouring scheme of CUI and DUI as can be seen in this screenshot i posted above (http://k5sbdw.blu.livefilestore.com/y1pH2jz98PKrmlL_iFEMcM9pF4dCbQIcynL2KIS4fMba0lsU_jFo-A42p0W0puJuWxOYIV5MuOM3Qr_eQIIg_BougUohy5KB3Yy/artist%20art.png).
Hey Marc,
great work... thank you very much.
But I'm getting the following error if I want to use your "simple biography":
WSH Panel Mod (GUID: 8CFF1E32-BA19-428C-9A98-4852EAFD9818): Microsoft JScript runtime error:
Invalid procedure call or argument
Ln: 112, Col: 2
Line 112 is:
arr = temp_gr.GdiDrawText(g_text, g_font, g_textcolor, 0, 0, ww, wh-40,DT_CENTER| DT_WORDBREAK | DT_VCENTER | DT_CALCRECT | DT_NOPREFIX).toArray();
I'm an absolute beginner in this JScript-thing and I don't know what it means. Do you have an idea?
have you definitely got the scripts folder from the zip extracted into your foobar install directory? i can't think what else would cause that. also, are you running the very latest version of WSH panel mod?
http://code.google.com/p/foo-wsh-panel-mod/downloads/list (http://code.google.com/p/foo-wsh-panel-mod/downloads/list)
Yes, I run the latest version and I extracted the "scripts"-folder into the foobar install directory. I checked not only once.
I deleted the "foo_uie_wsh_panel_mod.dll.cfg"-file in the configuration-folder and tried it again, too, but no luck.
In the line 112 it's about text and font. Perhaps it's a missing font? It seems that you use "Segoe UI", or? But I have it on my system. No idea...
i've been testing in columns UI and default UI all along and other people have been using that script for quite awhile without problems. just now i did a clean portable install and used only the files in the download to setup from scratch and it all works as it should. i even booted into my xp install and that works with no problems as well. i'm totally stumped.
Is there a way to use a WSH panel to cycle through images in a folder path like \Artist Images\%artist%\%artist%*.jpg, cycling either by mouse click/wheel, or preferably by changing every X seconds?
I've tried to look at some of the scripts posted here and elsewhere but finding a difficult time to glean the appropriate lines. Any help would be appreciated!
i've updated my sample package a few posts up with a crude image cycling script. might not be tested as much it should. give it a try. settings have to be set inside the script.
you can ignore all the waffle about configuring the last.fm script - obviously not needed. just extract scripts folder and import the image cycler script.
Thank you marc2003.
Can't wait to test them out tonight. As it's a complete package of your scripts, I'm missing the rating panel and the last.fm playback stats sync panel. Any reason why you left them out? (Not as good as you want them to be yet?)
The image cycle script works great out of the box, but I can't figure out how to point to my image folder.
I've tried changing the line
folder_title_format = "$directory_path(%path%)\\";
to many different methods to point to M:\Artist Images\%artist% both with and without the $directory_path function without success. Is this the line I should be editing or is it elsewhere? Can you help?
did you use double backslashes to separate folders like the comments said?
folder_title_format = "M:\\Artist Images\\%artist%\\"
sorry i forgot to mention to include trailing slashes for the folder- only the example showed this.
you've just made me cry.
the last.fm playback stats has it's own thread and i must admit, i totally forgot about rating - this is because i don't use it. but i'll include it later on.
edit: oh flip. double post. sorry mods.
Marc - The image cycle script works perfectly! Thanks for the help!
I'm still working on my lyrics display but have some questions on how to do some things i still need to improve in the script.
Here is the current script:
http://pastebin.de/3519 (http://pastebin.de/3519)
- It displays all lyrics as plain text (doesn't supports timestamps, only ignores the stamps on display).
- Can be switched to "Autoscroll" via context menu (only for lyrics longer than the panel)
- a "fading effect" can also be turned on (only when autoscroll option for long texts is active, because it may "disguise" textparts otherwise . Maybe i change it next time...)
- a manual "reset" option is available via context menu, too (if one adds an external textfile to the search path folder during playback it will be displayed immediately)
- via "Properties" padding settings can be made
- also in "Properties" search paths for Lyrics can be changed
- and - if foo_lyricsgrabber or foo_lyricsdb is present in the components folder - a online search command can be executed (set up in Properties as well).
My Problems:
1.) I don't know exactly if i have used Dispose() correctly...
2.) As you can see i have two Properties for lyrics path, one for TXT-files, one for LRC-files.
I'd have them in one Property but have no idea about, how i can make it that utils.ReadTextFile auto-recognizes the file ending and only uses txt or lrc.
I asked T.P Wang still and he said to me, i could use utils.Glob() for this (as var arr = utils.Glob("{$filename}.*").toArray();), but i have no clue how to add it (haven't seen any sample using it and you have to know: i'm a scripting-idiot... )
And then i had to test this array with /\.(lrc|txt)$/m.
Can anyone give me an example how to use/include it in my script?
I think these are my only problems.
If someone finds any errors in my script or have ideas improving it, please let me know
EDIT:
After reading my own post, if haven't understood myself...
So let me specify:
I want something like this:
var ext_lyrics = window.GetProperty("Lyrics Path", "$directory_path(%path%)\\%artist% - %title%");
var filetype = (This is my problem... How can i make it to only recognise "lrc" and "txt" and prefer "lrc" when both are in the search path?)
var reading = utils.ReadTextFile(fb.TitleFormat(ext_lyrics).Eval() + filetype);
Anybody an idea?
Or a better solution?
something like
var lrc = utils.Glob(ext_lyrics + ".lrc").toArray();
var txt = utils.Glob(ext_lyrics + ".txt").toArray();
arr = lrc.concat(txt);
if(arr.length > 0) file = arr[0];
or maybe use fso.FileExists with an if else if?
No, i want to avoid using FSO.
I want it working without user action (with FSO "Safe mode" has to be disabled first).
Thanks for this snippet.
Maybe i found out how to use it in my script with that fb.Titleformat
(i want to call fb.Titleformat only once, not more than necessary)
I'd need to call it twice with this snippet, do I?
var lrc = utils.Glob(fb.TitleFormat(ext_lyrics).Eval() + ".lrc").toArray();
var txt = utils.Glob(fb.TitleFormat(ext_lyrics).Eval() + ".txt").toArray();
var reading = utils.ReadTextFile(file);
Is it correct?
(You see, i really have only basic knowledge about what i'm doing... )
What the utils.Glob() do is using wildcards and return a VBArray of matched items:
e.g:
var arr = utils.Glob("D:\\something.*").toArray();
will match:
D:\something.txt
D:\something.dat
D:\something.blah
and then iterate that array, exclude unnecessary items:
for (var i = 0; i < arr.length; ++i) {
if (arr[i].match(/\.txt$/m) {} // text file
else if (arr[i].match(/\.lrc$/m) {} //lrc file
Ah, thanks, now its more clear
Haven't found anything about utils.Glob() except the short description in "Interfaces.txt".
(And you know, i need looooooooooong descriptions and explanations always twice ).
Thanks again
Thanks for the last.fm script Marc, it works well. The only problem I have with it is it seems immensely slow when it comes to scrolling. I think it is because of the longs lines that have to be wrapped, I have a lyric panel that is far far quicker to scroll. I wonder if it would be possible to wrap the text before painting it then paint that?
just once. what i'd do is this...
//outside of any functions so it gets set (if needed) on script load
//inside your function
var lyrics_path = fb.TitleFormat(window.GetProperty("Lyrics Path")).Eval();
var lrc = utils.Glob(lyrics_path + ".lrc").toArray();
var txt = utils.Glob(lyrics_path + ".txt").toArray();
if(arr.length > 0) var reading = utils.ReadTextFile(arr[0]);
hehe, i have no idea what any of that means. i'm still very noob at this. i'm using the sample script T.P provided to calculate the height. maybe you can ask him?
if that's the case, can't you just modify the on paint bits from that into the biog script?
Thanks, i'll try it, too
I think i got it:
var arr = utils.Glob(fb.TitleFormat(ext_lyrics).Eval() + ".*").toArray();
if (arr[i].match(/\.lrc$/m)) d = utils.ReadTextFile(arr[i]);
else if (arr[i].match(/\.txt$/m)) d = utils.ReadTextFile(arr[i]);
Seems to work at least...
It excludes all files beside lrc and txt.
But it prefers txt files over lrc, although i ask for lrc first.
Any idea how to solve this?
(Or did i made again an error?)
I want to prefer lrc because it is always a lyrics file, but txt may contain something else than lyrics...
you'll want to break the loop when the first file is found. your problem is that the last file in the array is used.
as the filenames are the same, this should be safe to do because .lrc comes before .txt alphebetically.
And how can i solve it? Any idea?
just thinking about it, it's a bit presumptuous of me to assume the files will be in the array in alphabetical order. let's hope so.
to break out of a loop....
break;
(or increase i beyond the maximum boundary)
edit: just had another thought. i'd never really noticed that utils.ReadTextFile function before. wouldn't it be easier just to try and load the files with that? as you only have 2 possibilities, it saves messing about with all this array nonsense.
I don't think that break would help here.
I guess the problem is utils.ReadTextFile(arr).
It seems that this arr will always match the last one in alphabetical order...
(Renamed lrc to xxx and tried it again. now it is loaded no matter if i ask for it first or last...)
EDIT (to your edit):
Is one other solution, yes.
But i wanted a more elegant way
Should work, though (why i haven't had this idea by myself? Grrr... )
2nd edit... (sorry for the misinformation before)
loop:
if (arr[i].match(/\.lrc$/m)) {
break loop;
} else if (arr[i].match(/\.txt$/m)) {
break loop;
3rd edit: my original post using 2 arrays and concat would have preferred lrc files but you went with T.Ps code...
this is getting very messy.
Looked more logical.
I'll see what i do now...
EDIT:
You break loop doesn't change anything.
) still prefers the last file in an alphabetical row.
How the hell could i make this to LRC?
Or i advice all the possible users of my script to delete all their lrc's, would be the easiest to code
works for me. try fb.trace to see if they are in order like mine....
arr = new Array("a.lrc", "a.txt");
fb.trace(arr[0]);
fb.trace(arr[1]);
loop:
for(var i = 0; i < arr.length; i++) {
d = arr[i];
break loop;
d = arr[i];
break loop;
fb.trace(d);
//console output
a.lrc
a.txt
a.lrc
//confirmed by removing break statement
a.lrc
a.txt
a.txt
Guess what?
It is working now. Thanks
Maybe i made a typo before, but now it works.
Now i can finish my lyrics panel
I have taken marc2003's lastfm biography code and modified it to display lyrics stored within ID3 tags.
I liked the style of the lastfm code, so I created this to work around that.
link (http://www.netsoc.tcd.ie/~jmccroha/simple_lyrics.txt)
Very short code
But why do you create a context menu with the default context menu entries only?
You could delete the whole on_mouse_rbtn_up() section.
Here is my current preliminary lyrics panel script:
http://pastebin.de/3533 (http://pastebin.de/3533)
Maybe someone finds it useful
If anybody has ideas to improve it, please let me know.
Guys any idea why
WshShell.run("http://www.last.fm/music/" + encodeURIComponent(artist).replace(/\s+/,"+"));
doesn't replace the space in the artist name with a + ?
try
"http://www.last.fm/music/" + artist.replace(/\s+/g,"+")
i only use encodeURIComponent for accessing the webservices.
just another update to my samples....
as my old pack contained 3 separate artwork panels, i've taken a big hammer and merged them all into one. it has 3 modes.
-default foobar artreader
-lastfm artist art with built in download facility (uses this command line tool made by paradog (http://www.hydrogenaudio.org/forums/index.php?showtopic=77425&hl=PARADOG) (runs silently - you won't notice it at all). you don't need to download it - i've included it. it's just 8kb in size. and the effort it's saved me is untrue. )
-cycle folder. you just set some title formatting and it will automatically cycle all the images. options are off, 5, 10 and 20 seconds.
(the last.fm mode supports this cycling as well.)
everything is controlled via context menu except the path for the "cycle folder". you need to edit the script itself to set that.
marc can you please take a shot at this?
the playback controls and background are panel stack splitter. the volume control, seekbar and playback order button are 3 separate WSH scripts. you can right click those, select configure to open the editor and then export the contents to a text file. or you can use the columns UI layout page to copy panels between layouts. i
edit: question removed. totally unrelated to the scripting.
Hi i want to make a seek bar with WSH panel mod but i dont know nothing about script's.Any help? Here is a pic of my Foobar
Thanks in advance.
(http://img222.imageshack.us/img222/9840/foob.png)
By wizard20 (http://profile.imageshack.us/user/wizard20) at 2010-01-30
here is what i use:
SEEKBARfunction RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
var g_font = gdi.Font("Segoe UI", 12, 0);
var g_drag = 0;
function on_paint(gr){
gr.SetTextRenderingHint(5);
var ww = window.Width;
var wh = window.Height;
var pos = 0;
var length = fb.PlaybackLength;
if (length>0){
if(g_drag){
pos = ww * g_drag_seek;
} else {
pos = ww * (fb.PlaybackTime / length);
var txt = "Seekbar";
gr.DrawRect(0,0,ww-1,wh-1,1.0,RGB(0,0,0));
gr.FillSolidRect(1,1,ww-2,wh-2,RGB(28,28,28));
var dio1 = 0.375*(wh-2);
var dio2 = 0.625*(wh-2);
gr.FillSolidRect(1,1,pos-1,dio1,RGB(119,187,255));
gr.FillSolidRect(1,1+dio1,pos-1,dio2,RGB(51,153,255));
function on_mouse_lbtn_down(x,y){
g_drag = 1;
// on_mouse_move(x,y);
g_drag = 0;
g_drag_seek = x / window.Width;
g_drag_seek = (g_drag_seek<0) ? 0 : (g_drag_seek<1) ? g_drag_seek : 1;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
window.Repaint();
function on_mouse_move(x,y){
if(g_drag){
window.Repaint();
function on_playback_new_track(info){
window.Repaint();
function on_playback_stop(){
window.Repaint();
function on_playback_seek(time){
window.Repaint();
function on_playback_time(time){
window.Repaint();
//EOF
Thank you,is very good.anything for playbak order? I ask too much...
I tried that but it is not possible to remove borders for wsh panel, I thought there would be a way to draw the whole thing using one wsh panel
marc can you please provide a snippet to convert the play button into a play/pause button. I have no idea how to switch images and I am using the layout
that's way beyond my capabilities.
as for the buttons, i already told you, they're done in panel stack splitter for that config. there isn't much need to make buttons in WSH panel mod when you're using columns UI/PSS because you already have much easier ways (using standard columns UI toolbar or $imagebutton in PSS).
Here is something that might come in handy, but I don't know exactly what your script looks like Icedtea so it probably won't work without some tweaking.
buttons.pop.icon=gdi.Image(dir+"play"+".png");
buttons.pop.tooltiptxt="Play";
window.Repaint();
function on_playback_pause(is_paused)
buttons.pop.icon=is_paused?gdi.Image(dir+"play"+".png"):gdi.Image(dir+"pause"+".png");
buttons.pop.tooltiptxt=is_paused?"Play":"Pause";
window.Repaint();
function on_playback_starting(cmd, is_paused)
window.Repaint();
sorry for the confusing message
What I meant was in the button example in your samples is there a way to convert the play button to a Play/Pause button. The function replacement fb.PlayOrPause() works ok but I have no idea on how to switch the images between play and pause i.e. when the playback is paused the button should be play.png and when the song is playing the button should be pause.png, with the hover effects of course.
Tom I am trying to implement your suggestion but image switching isn't working for me
image_path = fb.FoobarPath + "\\scripts\\images\\";
play_image = gdi.Image(image_path + "play.png");
pause_image = gdi.Image (image_path + "pause.png");
display_image = play_image;
function on_playback_new_track(){
display_image = pause_image;
window.Repaint();
function on_playback_pause() {
window.Repaint();
function on_playback_starting(){
window.Repaint();
function on_paint(gr) {
gr.DrawImage(display_image, 0, 0, 32, 28, 0, 0, 32, 28, 0, 255);
on starting playback I get pause.png OK
on pausing playback I get play.png OK
What am I doing wrong?
Hi, on_playback_pause() is called when playback is either paused or unpaused, so you need to alternate between the play and pause images there, like this.
window.Repaint();
function on_playback_pause(is_paused) {
display_image = is_paused?play_image:pause_image;
window.Repaint();
function on_playback_starting(cmd, is_paused){
window.Repaint();
Very short code
I uploaded an old version accidentally.
The current version refreshes the displayed lyrics.
Thanks Tom
I got everything else to work but lost hover somehow in the process. That is the only thing left and I would appreciate the help
// ==PREPROCESSOR==
// @import "%fb2k_path%scripts\tooltip_buttons.js"
var image_path = fb.FoobarPath + "\\scripts\\images\\";
var play_image = image_path + "play.png";
var pause_image = image_path + "pause.png";
var previous_image = image_path + "previous.png";
var next_image = image_path + "next.png";
var display_image = play_image;
var bw = 32;
var bh = 28;
var window_color = RGB(240,240,240);
var dui = window.InstanceType
var top_margin = 2;
var left_margin = 4;
window.MinWidth = window.MaxWidth = 104;
window.MinHeight = window.MaxHeight = bh + 4;
function RGB(r,g,b) {
window.Repaint();
window.Repaint();
window.Repaint();
function on_size() {
ww = window.Width;
wh = window.Height;
Buttons = {
but1: new Button(left_margin,top_margin,bw,bh, {normal: previous_image, hover: image_path + "previous_h.png"}, function(){fb.Prev();}, "Previous"),
but2: new Button(bw + left_margin,top_margin,bw,bh, {normal: display_image, hover: image_path + "play_h.png"}, function(){fb.PlayOrPause();}, "Play/Pause"),
but3: new Button((bw*2) + left_margin,top_margin,bw,bh, {normal: next_image, hover: image_path + "next_h.png"}, function(){fb.Next();}, "Next")
gr.FillSolidRect(0, 0, ww, wh, window_color);
buttonsDraw(gr);
tooltip_buttons.js is from marc2003's examples
Have a look under on_paint where the buttons are defined, there is a line starting with "but2: new button..." - there is a bit inside there that looks like this: {normal: display_image, hover: image_path + "play_h.png"}, you need to change that to {normal: display_image, hover: display_image_h} for example and then change display_image_h at the same time you change display_image.
That is not the problem hover images aren't shown at all even when they are defined and that included the static previous and next buttons. I suspect there is something in tooltip_buttons.js that is causing it but I cannot wrap my head around that script.
the original tooltip button code is by T.P Wang and tedgo. i don't understand it that well either.
i'll try and work it out from what Tom posted.
in the meantime, i've updated my samples. they've all had their options updated to be accessible from the context menu only. no more script editing should be needed (one exception is setting the image size and margins for buttons).
samples include
rating script by NEMO7538
simple seekbar
simple biography
playback buttons
web links (myspace, youtube, lastfm)
3 in 1 artwork panel
-the first is a straight replacement for the default art panel. it always prefers embedded album art if it exists. it then falls back on the usual display options set in the foobar preferences.
-last.fm artist art panel. can download multiple images from last.fm and cycle through them. it must be triggered manually using the context menu
-cycle folder option. can cycle through images in a folder at 5, 10 or 20 second intervals
so no instructions needed really. just extract the scripts folder into your foobar directory. add panels and import the samples you want and right click them to see the various options.
EDIT: in the unlikely event someone downloaded this between 1:35-150pm today, please download it again. i didn't update the zip with my newest files.
@icedtea
Don't create the buttons in on_paint(), that's all
EDIT:
I rewrote your script (should work now)
// ==PREPROCESSOR==
var play_image = {normal: image_path + "play.png", hover: image_path + "play_h.png"};
var pause_image = {normal: image_path + "pause.png", hover: image_path + "play_h.png"};
var previous_image = {normal: image_path + "previous.png", hover: image_path + "previous_h.png"};
var next_image = {normal: image_path + "next.png", hover: image_path + "next_h.png"};
var bw = 32;
var bh = 28;
var dui = window.InstanceType;
var top_margin = 2;
Buttons.but2.alterImage(genPPImageSrc());
Buttons.but2.repaint();
function on_playback_pause(state) {
ww = window.Width;
wh = window.Height;
buttonsDraw(gr);
function genPPImageSrc() {
return (fb.IsPlaying && !fb.IsPaused) ? pause_image : play_image;
Buttons = {
but1: new Button(left_margin,top_margin,bw,bh, previous_image, function(){fb.Prev();}, "Previous"),
but2: new Button(bw + left_margin,top_margin,bw,bh, genPPImageSrc(), function(){fb.PlayOrPause();}, "Play/Pause"),
but3: new Button((bw*2) + left_margin,top_margin,bw,bh, next_image, function(){fb.Next();}, "Next")
You need this tooltip_buttons.js for this: http://pastebin.de/3644 (http://pastebin.de/3644)
(has some additional lines to repaint the play/pause button only)
thanks tego! I will try to understand it if I can
this post is aimed at people who are happy enough writing their own scripts.
this little snippet allows you to present the user with a text input box, save this text and use it in your scripts.
(http://public.blu.livefilestore.com/y1puPG5Nwn4hzpr7mnfWVhGBiTghQJ-FCPOnm2Li6vRAXbTVfdSHDvymO8S03FVENGFF4Vyboto6KYnWZRtI1bM9Q/easy2.png)
javascript doesn't have a text input box but vbscript does so i found this code (http://wsh2.uw.hu/ch08c.html) online to do the work. it has to be saved in an external file and we can call it using WshShell.Run.
first of you need my modified version of the script from that link. save this as "input.wsf" in your "scripts" directory...
<?xml version="1.0" encoding="ISO-8859-1"?>
<job id="IncludeExample">
<script language="VBScript">
<![CDATA[
Function WSHInputBox(Message, Title, Value)
WSHInputBox = InputBox(Message, Title, Value)
End Function
</script>
<script language="JScript">
<![CDATA[
args = WScript.Arguments;
var WshShell = WScript.CreateObject("WScript.Shell");
var fso = new ActiveXObject("Scripting.FileSystemObject");
try {
ts = fso.OpenTextFile(args(2), 1, false, -1);
s = ts.ReadLine();
ts.close();
} catch(e) {
s = ''
var result = WSHInputBox(args(1), args(0), s);
if (result != null) {
try {
ts = fso.OpenTextFile(args(2), 2, true, -1);
ts.WriteLine(result);
ts.close();
} catch(e) {
Wscript.Echo("Error saving data!");
</script>
</job>
this is the script to go in your panel. i'm pretty crap at explaining things so i hope the comments make some sort of sense. it's pretty simple really....
var DT_CENTER = 0x00000001;
var DT_VCENTER = 0x00000004;
var DT_WORDBREAK = 0x00000010;
var DT_CALCRECT = 0x00000400;
var DT_NOPREFIX = 0x00000800;
function text_input_box(title, message, filename) {
WshShell.Run("\"" + wsf + "\" \"" + title + "\" \"" + message + "\" \"" + filename + "\"", 0, true);
return read(filename);
function read(fn) {
try {
var f = fso.OpenTextFile(fn, 1, false, -1);
var s = f.Readline();
f.Close()
return s;
} catch(e) {
return '';
///////this is the bit you'll want to customise for your own usage//////
var WshShell = new ActiveXObject("WScript.Shell");
var wsf = fb.FoobarPath + "scripts\\input.wsf";
//need to be somewhere with "write" access
var settings_path = fb.ProfilePath + "text_input_settings\\";
if(!fso.FolderExists(settings_path)) fso.CreateFolder(settings_path);
//each variable you want to use needs an associated file.
//the input box saves input to this file and then WSH panel mod can read it.
g_text_file = settings_path + "g_text";
//check to see if a value already exists and use it
g_text = read(g_text_file);
//now we a need a function to trigger our input
//the text_input box will read the file and present the current value as the default text.
//when you click ok, the external script will then save the result to the text file
//wsh panel mod can then read this updated file and return the new value
//in this simple example, it will just be updating the display using window.Repaint().
g_text = text_input_box("Message Title", "Enter some text:", g_text_file);
window.Repaint();
ww = window.Width;
wh = window.Height;
gr.GdiDrawText(g_text, gdi.Font("Segoe UI", 16), RGB(0,0,0), 0, 0, ww, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
marc2003 is it possible to get a wikipedia image for the links? better yet a template where we can create similar icons.
i just got those images from google image search. try it yourself.... (there wasn't a wikipedia icon in the pack that i used)
marc2003 whenever you get the time please consider making a button to switch playback modes i.e. shuffle, default etc
there's already one in T.P's samples i think.
the samples are on the same download page as the component.
Hello there, fellow alien cats!
I've been experimenting with WSH Panel Mod (DUI) for quite a while now but there's still something I'd like to have in my config but can't manage to script. Well, about that... I should mention that I have nearly no clue of scripting whatsoever. All I did before was copy&paste-ing and changing some numeric values. ^^
So here's what I wanna do: I want a heart-shaped love button like I’ve seen in marc2003’s or carmenm’s configs. But it should work without LastFM. I aleady used NEMO7538's rating buttons and created a column named "Loved" that displays a heart when a track has a 5-rating.
But for several reasons I don’t wanna handle it this way. One of them is that you’re not able to uncheck a “loved” song (I could only give it a <5rating). So, I’d love to see a script that can either
1) create a rating-tag and fills it with the value 5
or
2) create a %loved%-tags (by using customdb i.e.).
I’d be really really grateful for any helping hand! =)
is it appropriate to make requests here?
i'm no coder, and the scripting for this panel, whatever it is, flies straight over my head.
what i'd like to see is a config that divides its host panel into 9 equal areas - basically a 3x3 grid. each area is filled with a solid colour.
each area is also assigned a number, 1-9, based on the layout of a standard keypad (1 bottom-left and 9 top-right).
clicking on a coloured box sends the box's number to the %mood% tag of the currently playing track.
the whole idea is that the horizontal axis represents tempo, and the vertical axis is mood. mimicking the layout of a keypad would make it work well with global hotkeys.
it would also be easy to implement each track's 'color' into a CUI playlist view, and you could build great autoplaylists based on the values.
i really have no idea how difficult this would be to implement, but if anyone is inclined to put it together, i think people would find it useful!
inspired by:
http://www.crayonroom.com/moody.php (http://www.crayonroom.com/moody.php)
You are lucky, I just coded such a panel with a 5x5 grid. It is available as a ready theme for DUI in this ZIP file (http://www.openaudio.eu/wsh_mood_annotation.zip) on openaudio.eu (http://www.openaudio.eu/) (link is at the bottom of the page). It is configured to set the tags %valence% (sad to happy) and %arousal% (calm to active) on a scale from -2 to 2.
I also added tagging scripts for foo_masstag to "move" a track's rating in this grid with 4 keyboard shortcuts (I use the keys W,A,S,D).
This is how a portable installation looks after loading the theme:
(http://www.ojdo.de/screenshots/wsh_mood_annotation_v2.png)
ojdo, that is tremendous! it integrates perfectly with my CUI config.
now i just have to build a massive playlist column script to show each track's color
thanks for sharing. i am very lucky indeed!
@catchyfourwordphrase, i've made you a script. it's totally separate from the rating script so just use that as usual.
you'll need the latest version of my samples zip.
it contains updates since my last post (plus i've fixed the ratings panel to let you customise the background colour)
now you'll need to configure customdb. on the "fields" page, create a new field called "LOVE". set the "name" and "display" as this. for the "key", you should select "custom" and add
%artist%,%title%
now restart foobar. now go to the "actions" page and add these 2 actions
Display: Love
Field: LOVE
Update: ContextMenu
Set Value: 1
Display: Unlove
Field: LOVE
Update: ContextMenu->Erase
now add a panel and download this code
http://pastebin.com/f7baf0174 (http://pastebin.com/f7baf0174)
use a tag named %love% in your playlist to display a heart if it equals 1.
In single every sctipt of yours i got error
"Cant create object" in common.js on line 237
did i missed somthing so much mandatary that it wasnt even in readme?
i keep meaning to make some proper documentation but i never quite get around to it.
solved. thx for swift response.
Thanks a ton, marc2003!!
Worked like a charm...at least until foobar decided to crash several times because of customdb. It's kind of weird - I've been running fb2k with four dockable panels (one of them is a chronflow panel in nearly fullscreen) and haven't experienced any crashes at all but as soon as I want to add a tiny little heart to my screen, foobar goes bananas
But nevertheless, thanks again for helping me out. Members like you are one of the reasons why I love foobar and its community so much.
Well, is there any work around to get along with foo_customdb's buggyness? If not, I'd be totally happy with a heart button which generates a 5 in the %rating%-tag and can also erase it. Right now, I'm trying to change your script to do so but the only result was the lovely "ping" sound of a script error
So, sorry to bother you again, but could you please help me again with this?
i experienced a few crashes with foo_customdb during my very first hour of use. and i think it's related to the default fields/actions being triggered during playback. because as soon as i removed them all and just used my own settings, i've not had a single problem. i've been using it for pushing on 2 months now with my last.fm script and it's behaved perfectly.
so try removing all the defaults and leave just your own settings - make sure you restart foobar when done.
For me it seems like this actually did the trick, no crash so far.
So, thanks again!
I completely rewrote my form and keyboard input scripts - and wasted way to much of my time. The result is much more universal and probably useful for others:
FormsAndButtons.zip (http://cid-229871a834d2fa56.skydrive.live.com/self.aspx/.Public/FormsAndButtons%20v1.zip)
It includes a demonstration to show the different elements (harmless to your files):
(http://j5xrtg.bay.livefilestore.com/y1p_BlVeQhULp-hy8ItXyrxTLByp9rnC66pazmJbLtNrwRO-8_WMcltV6cCKPY38jCyRF4dzahWZuizQzgZtWdsbLBOEDhrXv84/screenshot.jpg)
I implemented the possibility for keyboard-only use, for details see FormsAndButtons.js
There are a few issues:
- I do call window.Repaint() in on_size, although it is recommended not to do (anyone a suggestion how to it otherwise if I need to get the window size?)
- I get a windows sound if I show a pop-up menu after pressing enter (see: this post (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=70363&view=findpost&p=685958))
- I wrote this script for an US-international keyboard layout (supporting dead keys and alt-gr) and there is (as far as I know) currently no way in WSH panel mod to find out which layout is used or to decode vkeys depending on keyboard layout. So anyone who wants to use this script with another keyboard layout should manually rewrite KeyboardHandling.js.
- Graphically my elements are plain and simple and that is the way I prefer it, so anyone who wants them otherwise is free to alter the script, but I am not going to do it. Colours could be changed in FormsStyle.js
Comments (or bug reports) are welcome!
In my current setup, I've created a "now playing" panel showing artist/album/title information. It works pretty well, but there's a bit of a discrepancy when playing streaming audio.
Some of my streams provide the artist/title information for the currently playing track, and this displays properly in the playlist viewer. Unfortunately, my now playing WSH panel only displays the radio station's name. Additionally, if I right-click on the playing track in the playlist viewer and go to properties, the artist and title fields do not represent the currently playing track, but rather the radio station's name.
Therefore, it seems like the now playing WSH panel is displaying the metadata information "properly", but I'm not sure how to access the streaming artist/title. Any ideas?
You can get it with on_playback_dynamic_info_track() and the Eval() method (not EvalWithMetadb() ).
Thanks, this replacement worked well.
Hi.
If this could be the place for a request - there it is, if not - please move it.
The only thing I actually miss in foobar2000 DUI is a panel allowing to tag files easily. Constantly visible, as opposed to Properties, that has some pre-set buttons, configurable preferably, such as "Genre: rock/blues/blah...", same for %date%. Just easier, quicker that quicktagger component, without right-click-menus-in-menus. It would be GREAT to have a field to fill with Artist, Title, Album names manually. Sometimes it's the only option.
I can't write it myself but maybe someone can?
It is exactly therefore that I wrote my FormsAndButtons script, which I posted last week. As soon as I find some time I will make an (easy to customise) example of how to use it for tag input.
How can i select DSP preset within WSH script? I tried fb.RunMainMenuCommand("Playback/DSP Settings/[Preset Name]") but it does not work.
does anyone know how i can compare to strings to eachother in the WSH_Panel_Mod?
I have searched on MSDN and tried to use some of the code from there,
but it gives me errors.
For instance if i put this in my code:
public static function Compare(
strA : String,
strB : String
) : int
i get the error Expected ';'
Oh Yeah, i'm a total newbie in using Jscript.
At first I always try to change little code from existing codes.
But in this case i couldn't find one that suites me.
cheers
keeping it simple.
function compare(a,b) {
(a == b) ? return true : return false;
var result = compare("apples", "oranges");
keeping it simple.
Marc,
when is use the first code i get an
Syntax error,
when using the second it says
Object expected.
As I said i'm a newbie
oops, should have tested...
if(a == b) return true
else return false;
Even simpler:
function compare(a, b) { return a==b; }
If you want to learn the syntax, try here: http://msdn.microsoft.com/en-us/library/4y...28VS.85%29.aspx (http://msdn.microsoft.com/en-us/library/4yyeyb0a%28VS.85%29.aspx)
This might also help: http://www.w3schools.com/js/default.asp (http://www.w3schools.com/js/default.asp) It's for JavaScript on the web, but it's the same syntax.
doh!
Thanks Tom/Marc for the help and links.
I'm got a little reading to do now
cheers
If i may request something then i would ask for an enhancement for some of marc2003s scripts and tedgos lyrics script wich are now limited to show info about now playing track. It would be useful if they would respond to the Dui option in preferences -> display to prefer playing track or selection. Does the WSH Panel at all let you grab this option?
no, it's not possible to get that preference. you can edit my script to always follow the selection. open
scripts\marc2003\v2\common.js
line 108 should be this....
g_metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
replace it with...
g_metadb = fb.GetFocusItem();
restart foobar (or reload script) for changes to take effect.
I updated my FormsAndButtons script: FormsAndButtons v1.1.zip (http://cid-229871a834d2fa56.skydrive.live.com/self.aspx/.Public/FormsAndButtons%20v1.1.zip)
Besides some fixed bugs it now includes an example of how to make a tag editor with it.
It still had the issue that it only supports the US or US-international (QWERTY) keyboard layout, unless one edits the KeyboardHandling.js file. @T.P Wang: couldn't you implement windows' MapVirtualKeyEx function (http://msdn.microsoft.com/en-us/library/ms646307(VS.85).aspx)?
hi, guys! I know I`m insane, but how send all Media Library`s fields to array?
@nosatyj
No offense but... you better use use C++ and the official SDK.
WSH Panel mod can retrieve metadata of only ONE track at any point.
i took pieces from here and there and i made a simple text based playback order drop down
it's based on the marc23's scripts lib (bground options, etc) and his scripting style, vars etc
Here's my result for my controls bar
(http://ypxvpa.bay.livefilestore.com/y1pztV9vJY4cheu5Szt0Wa5oT5LLXF67Sj0IFmnHw7guvdPzO8-Rr0J4LBXKWIciQa4RIQR8B8eOTpnYX2MkFnCoYsdN62wyfv6/myfb2k_ctrl.gif)
// ==PREPROCESSOR==
// @import "%fb2k_path%scripts\marc2003\v2\common.js"
var panel_id = window.GetProperty("panel_id", window.id);
var custom_background_file = settings_path + panel_id + "buttons_background";
var custom_background = read(custom_background_file);
var top_margin = 0;
var bw = 16;
var bh = 16;
var mypbo = [];
mypbo[0] = "Default";
mypbo[1] = "Repeat (Playlist)";
mypbo[2] = "Repeat (Track)";
mypbo[3] = "Random";
mypbo[4] = "Shuffle (tracks)";
mypbo[5] = "Shuffle (albums)";
mypbo[6] = "Shuffle (folders)";
function on_size()
ww = window.Width;
wh = window.Height;
function on_mouse_lbtn_down(x, y) {
var pbo = window.CreatePopupMenu();
var i;
var ret;
for(i = 0; i < mypbo.length; i++)
pbo.AppendMenuItem(MF_STRING, i+1, mypbo[i]);
pbo.CheckMenuRadioItem(1, i, fb.PlayBackOrder + 1);
ret = pbo.TrackPopupMenu(x, y);
if (ret >= 1 && ret <= i)
fb.PlayBackOrder = ret - 1;
pbo.Dispose();
buttons_background(gr);
icon = gdi.Image(images_path + "arrow_down.png");
gr.DrawImage(icon,left_margin,top_margin,bw,bh,0,0,icon.Width,icon.Height);
gr.DrawString("Order: " + mypbo[fb.PlayBackOrder], g_font, g_textcolor, left_margin+bw, top_margin, ww, wh, 0);
function on_playback_order_changed(new_order_index)
window.Repaint();
function on_mouse_rbtn_up(x, y) {
buttons_menu(x,y);
return true;
you will need to put a small arrow img in in the folder \scripts\marc2003\v2\images named arrow_down.png
here's one for you (http://ypxvpa.bay.livefilestore.com/y1p5q3i9RwFCUDSFgLLZn9p1XcN3BRcXq8wUw8ULFimz7s5PfYLV2E7d9Nq9fd398kwvRNs33NyAnD7fAB5tQY5y_QPPzGer2mK/arrow_down.png)
Is there any way to determine if certain title formatting fields have multiple values, and if so, choose a custom separator? For instance, this works:
artist = fb.TitleFormat("$replace(%artist%,',', &)").Eval();
Now all of my multiple artist tracks have variable "artist" equal to "Artist A & Artist B" (more suitable for compatibility with Last.fm). The problem with this method is that if the artist field naturally has a comma in it, the script mistakenly sees it as a multiple artist field. Is there any way around this? Thanks.
have a look here...
http://wiki.hydrogenaudio.org/index.php?ti...ence#Metadata_2 (http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Titleformat_Reference#Metadata_2)
Thanks, that worked. Additionally, I've noticed that the foo_softplaylists component doesn't work on tracks with multiple artists. It only recognizes the first artist.
Could someone help me get a script working? I've built a little menu that searches shoutcast based off of the genre of the playing track:
// ==PREPROCESSOR==
// @import "%fb2k_path%scripts\common.js"
gr.FillSolidRect(0,0,ww,wh,RGB(220,220,220));
//Split multiline tags into an array
function split_tag(t) {
var splitstrings = [", ",",","; "," - "," "];
var tag=fb.TitleFormat("$caps(%"+t+"%)").EvalWithMetadb(g_metadb);
//if (tag = "?") return;
var foo = -1;
do {
foo++;
var splitcheck = tag.indexOf(splitstrings[foo]);
while (splitcheck == -1 && foo < 6)
return tag.split(splitstrings[foo]);
//doesn't work
//Create a dynamic menu for a tag
function scast_menu(t,m,n) {
var tag = t;
var menu_index = m;
var menu_name = n;
fb.trace(tag.toString());
var times = tag.length;
var foo = -1;
do {
foo++;
_child4.AppendMenuItem(MF_STRING,foobar++,"Search for "+tag[foo]+" stations");
while (foo < times-1)
//Menu Commands
var basemenu = window.CreatePopupMenu();
var ret;
basemenu.AppendMenuItem(MF_STRING, 50, "Open a custom station...");
basemenu.AppendMenuItem(MF_SEPARATOR, 0, 0);
var genres = split_tag("genre");
var times = genres.length;
var foo = -1;
var foobar=52;
do {
foo++;
basemenu.AppendMenuItem(MF_STRING,foobar++,"Search for "+genres[foo]+" stations");
basemenu.AppendMenuItem(MF_STRING, 51, "Most popular stations");
var ret = basemenu.TrackPopupMenu(x, y);
if (ret == 0)
return;
switch (ret)
case 50:
var scast_station = text_input_box("Shoutcast Radio","Search for a Shoutcast station","scast")
var shout = "http://www.shoutcast.com/radio/"+scast_station;
WshShell.Run(shout);
break;
case 51:
var shout = "http://www.shoutcast.com/most-popular-radio-stations";
break;
default:
var shout = "http://www.shoutcast.com/radio/"+encodeURIComponent(genres[ret - 52]);
break;
basemenu.Dispose();
Seems like the way to do it is would be to have on_metadb_changed() call window.Repaint(), and call the function that draws the menu in on_paint(gr), but hell if I can get it working.
Thanks if someone can help, I'll probably bumble my way to victory eventually but this is driving me up the wall.
@unclean:
You must use window.WatchMetadb(IFbMetadbHandle)
See interfaces.txt and the example file Watch Metadb Change (Base).txt
it looks like unclean is importing the scripts i uploaded (common.js). this already contains the on_item_focus_change() function which takes care of setting g_metadb.
but this function still needs to be called inside each panel using...
on_item_focus_change();
//also need to call it when the script initialises as well
@Harm:
I've add a callback
on_char in WSH Panel Mod 1.3.2 Beta 1
You can receive proper char code now:
function on_char(code) {
char_string = String.fromCharCode(code);
And don't forget to use window.DlgCode property:
// See flags.txt
// DLGC_WANTCHARS will enable on_char() callback
window.DlgCode = DLGC_WANTALLKEYS | DLGC_WANTCHARS;
things change. T.P has released a new version which supports this.
Thanks marc, that was a really easy fix.
I updated my FormsAndButtons script: FormsAndButtons v1.2.zip (http://cid-229871a834d2fa56.skydrive.live.com/self.aspx/.Public/FormsAndButtons%20v1.2.zip)
Thanks to T.P Wang it should now work with any keyboard layout.
Overview of available elements:
//FORM ELEMENTS
//General comments:
//- If 'x', 'y', 'w', or 'h' depends on the size of the screen this value should be placed between brackets. For example:
// FormIButton("ww - 20", 0, 20, 20, skip, imgscr, func);
//- One can jump from element to element using the left, right, up and down arrow keys, although if 'skip' is set true the element will be skipped.
//- 'font' should be of type IGdiFont
//- 'func' should always be a function that if called without argument returns the value to be displayed and that will be called if this value is changed by the form element.
//- For single line text elements with a fixed width a tool tip shows the value on mouse over if clipping occurs.
//- Elements should be put in the array 'intobject' to work
//- These functions should be called in the corresponding callback functions:
// forms_on_size();
// forms_on_paint(gr);
// forms_on_mouse_move(x, y);
// forms_on_mouse_lbtn_up(x, y); //Does call wondows.Repaint()!
// forms_on_key_down(vkey);
// forms_on_char(code);
// forms_on_focus(is_focused); //Does call wondows.Repaint()!
// forms_on_timer(id);
//function FormIButton(x, y, w, h, skip, imgsrc, func)
//Draws a button using images.
//Using keyboard:
// Enter: switch button
// Left: jump to previous element
// Up: jump to previous element
// Right: jump to next element
// Down: jump to next element
//imgsrc:
// array of form {inactive: <<path to image>>, active: <<path to image>>, inactiveon: <<path to image>>, activeon: <<path to image>>}
//func: boolean func(boolean);
//function FormTButton(x, y, w, h, skip, text, font, func)
//Draws a button using text.
//Using keyboard:
//if w is set 0 it will be based on marginx, if h is set 0 it will be based on marginy
//function FormTButtonAlt(x, y, skip, text, font, func)
//Draws a button which is nothing more than a line of text which can be set or not set.
//Using keyboard:
//function FormTextBox(x, y, w, h, skip, font, func)
//Draws a text box for editing multiple lines of text.
//Using keyboard (not in edit mode):
// Enter: enter edit mode
// PgUp: scroll to start
// PgDn: scroll to end
// Up: if possible scroll up, otherwise jump to previous element
// Down: if possible scroll down, otherwise jump to next element
//Using keyboard (edit mode):
// Bksp,
// Enter,
// Left,
// Up,
// Right,
// Down,
// Ins,
// Del: like expected in a text editor
// Esc: exit edit mode and send value if changed
// PgUp: cursor to start of text
// PgDn: cursor to end of text
// End: cursor to end of row
// Home: cursor to start of row
// Ctrl-Z: undo change
//func: string func(string);
//function FormText(x, y, w, h, skip, font, func)
//Draws multiple lines of text.
//Using keyboard:
//func: string func();
//function FormTextInput(x, y, w, skip, font, func)
//Draws single line text input.
// Bksp,
// Left,
// Right,
// Ins,
// Enter: exit edit mode and send value if changed
//function FormTextLine(x, y, w, skip, font, func)
//Draws single line of text.
//Using keyboard:
//function FormMVTextInput(x, y, w, skip, font, func)
//Draws single line text input to edit an array of values.
// Bksp,
// Left,
// Right,
// Ins,
//func: array func(array);
//function FormMVSTextInput(x, y, w, skip, font, func)
//Draws single line text input to edit an array of values in which the odd ones are the main values and the even ones the separators.
// Bksp,
// Left,
// Right,
// Ins,
//func: array func(array); where this array contains the values as odd elements and the separators as even elements
//function FormMVTextLine(x, y, w, skip, font, func)
//Draws single line showing the content of an array of values.
//Using keyboard:
//func: array func(); where this array contains the values as odd elements and the separators as even elements
//function FormKeyWords(x, y, w, skip, font, list, func)
//Draws single line showing the content of an array of key words and add new ones from a drown-down list.
//Using keyboard:
// Enter: execute selected button
// End: jump to last value
// Home: jump to first value
// Left: if possible jump to previous button, otherwise jump to previous element
// Ctrl-left:
// move selected value to the left
// Right: if possible jump to next butten, otherwise jump to next element
// Ctrl-right:
// move selected value to the right
// Ins: insert value after selected value
// Del: remove selected value
//list: array of possible values
//function FormKeyWordsH(x, y, skip, font, list, func)
//Draws single line showing a list of key words which can be set or not set.
//Using keyboard:
// Enter: add or remove selected value
// Left: if possible select previous value, otherwise jump to previous element
// Right: if possible select next value, otherwise jump to next element
//function FormKeyWordsHS(x, y, skip, font, list, func)
//Draws single line showing a list of key words of which only one can be set.
//Using keyboard:
// Enter: set or remove selected value
//function FormRating(x, y, skip, font, max, func)
//Draws line of stars to edit rating.
//Using keyboard:
// Enter: set selected rating or if this rating is set, set rating to 0
// End: jump to maximum
// Home: jump to 1
// Left: if possible select previous rating, otherwise jump to previous element
// Right: if possible select next rating, otherwise jump to next element
//func: int func(int);
//max: maximum rating
//function FormDrawString(x, y, font, colour, str)
//Draws string.
Change log:
v1.2:
- Bugs fixed
- Added blinking cursor
- Solved issue with calling window.Repaint() in on_size
- Now works on all keyboard layouts
- Solved issue with enter key
- No need to include KeyboardHandling.js anymore
- Added forms_on_timer(id) to be called in on_timer(id)
- Added forms_on_char(code) to be called in on_char(code)
- Improved documentation
- Requires wsh panel mod v1.3.2
v1.1:
- Bugs fixed
- Added tag editing example
I don't find any of these in the archive.
// @import "%fb2k_path%scripts\Flags.txt"
// @import "%fb2k_path%scripts\Helpers.txt"
// @import "%fb2k_path%scriptsFlags.txt"
// @import "%fb2k_path%scriptsHelpers.txt"
These are in the docs directory of the zip file, so you have to copy them to the scripts directory.
That is: of the wsh panel mod zip file - it is part of the documentation
i've updated my samples - http://cid-649d3bfeaf541fbb.skydrive.live....ide/samples.zip (http://cid-649d3bfeaf541fbb.skydrive.live.com/self.aspx/.Public/foobar/guide/samples.zip)
contains a bug fix for the artwork panel. it also has a new feature to double click the panel in "foobar artreader" mode and it will open the image in your default image viewer. (the lastfm/cycle folder modes already had this feature).
also contains a new "now playing" artwork panel. it looks like this.....
http://public.blu.livefilestore.com/y1py0e...ad%20200210.png (http://public.blu.livefilestore.com/y1py0euzN8nsGejHcHE15HuKXBYV7qDwAvGpTUV5TuFt9dvfbxB7A_dImGQnU0GclLOXlFGvVBvJlsp4PpE9KEI8g/dui%20appearance%20thread%20200210.png)
(credit really must go ojdo for the idea. his original panel can be found here (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=77413&view=findpost&p=688718).)
it uses last.fm to download artist art for the background. you have to use the context menu to trigger the download manually. it can download either 1,3,5 or 10 images. optionally it can cycle through the images at set intervals. you can also use the mouse wheel to scroll. (it's the same code from the "last.fm" mode of my previous artwork panel so if anybody has a cache of artwork built up already, it will use that).
it then uses the built in foobar artreader to display the album cover.
readme included in the download.
Your "now playing" Panel looks really nice
For my personel needs i've changed the size of the embeded cover and also of the fonts. Some properties may be useful ?
new version uploaded. (http://cid-649d3bfeaf541fbb.skydrive.live.com/self.aspx/.Public/foobar/guide/samples.zip)
contains a few variables at the top of the script. i can't be bothered to build a menu to set these values.
For me it's all i need
thanx
This is very impressive and I just tried it on my setup and it is working smoothly. I did not (yet) dig deep and just ask: Is it possible to have the ArtistArt automatically downloaded if none is present?
edit:
Ok - I succesfully hacked it in myself by changing the function "on_playback_new_track()" to:
image_set = null;
WshShell.Run("\"" + script_path + "art.exe\" \"" + artist + "\" \"" + folder + "\" " + limit, 0, true);
image_set = null;
on_metadb_changed();
I have no clue if this is forbidden/disrecommended. It works.. :-)
shouldn't be a problem. just one minor change i'd make...
image_set = null;
//arr is an array that contains all the images. only try if there are no images.
if(arr.length == 0) {
image_set = null;
That's exactly what I was thinking about. Thank you for implementing it right away. Before I had no muse to look for a nice way to achieve this. Is this jScript or VBScript you are writing?
Another thing I might play around with is that albumart is resized according to the width of the WSH-Panel. In my case the panel is rather narrow and thus hardly nothing of the title is displayed. I resolved this for now by making the albumart smaller, though a more elegant way would be to resize the albumart with both an upper and a lower border.
mess about with the on_size function (edit the one that already exists in the script)
ww = window.width;
wh = window.height;
//new line of code....
album_img_size = ww * 0.25;
or you might want to try a fixed size of 90. that makes it fit nicely inside the "text" box.
i'll look at tidying up the art.exe bits of code. what i posted was just a quick fix to prevent un-necessary queries to last.fm.
Oh well - did not see your answer. This is what I came up with:
This goes into the user settings: (remove the var album_img_size there)
var album_img_size_percent = 25;
var album_img_size_min = 90;
var album_img_size_max = 280;
This goes in "on_paint":
if(album_img) {
var album_img_size = album_img_size_percent * ww / 100;
if (album_img_size > album_img_size_max ) album_img_size = album_img_size_max;
if (album_img_size < album_img_size_min ) album_img_size = album_img_size_min;
text_x = album_img_size + 40;
Fun playing around :-)
edit:
Wouldn't it be beautiful to set up a svn on google code? I guess I would have fun playing around a little.
mar2003 wouldn't it be more suitable to save the xml files in the format lastfmfolder<mbid>.xml with a fallback of saving as <artist>.xml if mbid doesn't exist. This would be suitable when bands or artists have the same name as mbid is unique but it needs to be read from the xml first.
PS: AFAIK mbid exists for an overwhelming majority of artists.
Does anyone know how to justify text in a panel?
Hi, I am using this & it works quite well.
I have one issue, however.
Many songs in my library are duets/sung by multiple artists & I use the standard foobar ; to separate them.
The script is not able to either download or display the artist image for these songs.
I used to use the following code to cycle the images of different artists in a wsh mod script :
G:\music\art\artist\$meta(artist,0).*||G:\music\art\artist\$meta(artist,1).*||G:\music\art\artist\$meta(artist,2).*||G:\music\art\artist\$meta(artist,0)_01.*||G:\music\art\artist\$meta(artist,1)_01.*||G:\music\art\artist\$meta(artist,2)_01.*||G:\music\art\artist\$meta(artist,0)_02.*||G:\music\art\artist\$meta(artist,1)_02.*||G:\music\art\artist\$meta(artist,2)_02.*
Can it be done in your script ?
mar2003 wouldn't it be more suitable to save the xml files in the format lastfmfolder\<mbid>.xml with a fallback of saving as <artist>.xml if mbid doesn't exist. This would be suitable when bands or artists have the same name as mbid is unique but it needs to be read from the xml first.
what xml files are you talking about now? my biography panel? i save them in a folder named after $crc32(%artist%). this means i don't have to worry about filename validation / illegal characters in tags. i'm not using MBID because that would require that i have every single file in my library tagged with correct musicbrainz info. if that's the way your library is set up, feel free to make your own modifications.
@gurubhai, i haven't tested this but you can try replacing this....
var jpg = utils.Glob(folder + "\\*.jpg").toArray();
var png = utils.Glob(folder + "\\*.png").toArray();
var gif = utils.Glob(folder + "\\*.gif").toArray();
arr = jpg.concat(png, gif);
with
var artist0 = utils.Glob("G:\\music\\art\\artist\\" + fb.TitleFormat("$meta(artist,0)*.*").EvalWithMetadb(g_metadb)).toArray();
var artist1 = utils.Glob("G:\\music\\art\\artist\\" + fb.TitleFormat("$meta(artist,1)*.*").EvalWithMetadb(g_metadb)).toArray();
var artist2 = utils.Glob("G:\\music\\art\\artist\\" + fb.TitleFormat("$meta(artist,2)*.*").EvalWithMetadb(g_metadb)).toArray();
arr = jpg.concat(png, gif, artist0, artist1, artist2);
thanks marc2003 , It works provided I don't use the wild card but for some reason it is also checking on the text files lying in the folder (its actually my biography plugin folder)
so basically it shows first artist picture then blank and then artist2 & so on.
how do I solve this?
well i put *.* because i wrongly assumed that all your files in a folder named "art" would be image files. just change it to *.jpg
Sorry,I should have spotted that. this works fine.
However, this way I have to keep two sources, one from your script & other being my current art folder.
I would like to switch exclusively to your script if possible.
you could modify the script yourself to fetch the artwork for multiple artists. or you could use field remapping with $meta_sep.
http://wiki.hydrogenaudio.org/index.php?ti...28name.2Csep.29 (http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Titleformat_Reference#.24meta_sep.28name.2Csep.29)
marc2003 do you remember the url from which you got the web links button?
i didn't keep a link but i've just spent a few minutes googling and i can't find it again.
edit: found them....
http://www.freeiconsweb.com/Social-Network-Icon-Pack.html (http://www.freeiconsweb.com/Social-Network-Icon-Pack.html)
Does anyone know how to get the text width using GdiDrawText() in pixels for a given font and font size?
Can anyone help me change applyDelta() in Scroll with GdiDrawText.txt to implement a "floor" so that when offset = 0 you can't drag the text down as there is no text on top. Every method I try ends up cutting some text from the bottom
Scratch my last question, I chose to work around that. New question: Is there a way to specify where the popup menu appears? Using the command provided in the samples, it always appears wherever the mouse cursor is. However, I'm making a "toolbar-like" panel, and it would look a lot better if the popups appeared directly under the command, rather than where the cursor is. Thanks.
i'm guessing you have this in your menu?
idx = _menu.TrackPopupMenu(x, y);
simply replace x and y with the x co-ordinate and height of your object that is being clicked.
@icedtea, this is the formula i use to work out the height of my text. it's not perfect but it's close enough.
String.prototype.count=function(s1) {
return (this.length - this.replace(new RegExp(s1,"g"), '').length) / s1.length;
textheight = arr[3] - arr[1] + wh + (g_text.count("\n") * 3);
offset = 0;
Some minor changes (quick and dirty ) i've made at marc2003s "now playing"-script
for multple artists i use
folder = data_folder + fb.TitleFormat("$crc32($meta(artist,0))").EvalWithMetadb(g_metadb);
var folder1= data_folder + fb.TitleFormat("$crc32($meta(artist,1))").EvalWithMetadb(g_metadb);
var folder2= data_folder + fb.TitleFormat("$crc32($meta(artist,2))").EvalWithMetadb(g_metadb);
var artist1 = utils.Glob(folder1 + "\\*.jpg").toArray();
var artist2 = utils.Glob(folder2 + "\\*.jpg").toArray();
arr = jpg.concat(png, gif, artist1, artist2);
and in the scale-function to show the upper part of an portrait picture in an landscape panel
function scale(gr, img, pos_x, pos_y, width, height, mth) {
var s = mth == "max" ? Math.max(width / img.width, height / img.height) : Math.min(width / img.width, height / img.height);
var nw = img.width * s;
var nh = img.height * s;
pos_x += ((width - nw) / 2);
pos_y += ((mth == "max") && (img.width < img.height)) ? 0 : ((height - nh) / 2);
// pos_y += ((height - nh) / 2);
gr.DrawImage(img, pos_x, pos_y, nw, nh, 0, 0, img.width, img.height);
it could surely done better, but maybe it's useful for some. I haven't found a good multi-language & multi-artist solution for the bio-panel.
greetz dalover
you can change the language for the biography panel (line 25)
lastfm("&lang=XX&method=artist.getinfo&artist=" + encodeURIComponent(artist), "foo_wsh_lastfm_bio", function() {save_file();});
lang (Optional) : The language to return the biography in, expressed as an ISO 639 alpha-2 code.
i know - that's my solution with a language variable
function get_bio_lang() {
switch(biolang) {
case 1:
lastfm("&lang=de&method=artist.getinfo&artist=" + encodeURIComponent(artist), "foo_wsh_lastfm_bio", function() {save_file();});
break;
case 2:
lastfm("&lang=jp&&method=artist.getinfo&artist=" + encodeURIComponent(artist), "foo_wsh_lastfm_bio", function() {save_file();});
break;
case 0:
default:
lastfm("&method=artist.getinfo&artist=" + encodeURIComponent(artist), "foo_wsh_lastfm_bio", function() {save_file();});
it's a non automatic solution. i change the biolang-var in the update part
offset = 0;
marc2003 what are you using for applyDelta?
I am using this from Hitchhiker427 but the panel's text gets frozen occasionally i.e. does not drag
function applyDelta(delta) {
var temp = offset + delta;
if (offset > 0 || (offset == 0 && delta > 0) || textheight < wh) {
offset = 0;
} else if (offset > -delta) {
offset = 0;
window.Repaint();
} else if (offset > -textheight + wh) {
offset = temp;
window.Repaint();
} else if (delta > 0) {
offset = temp;
window.Repaint();
i haven't bothered with drag support - it uses the mouse wheel only. i'm using the font height as a measurement unit so the text always lines up at the top of the panel.
function on_mouse_wheel(delta) {
step = g_font.height * 5;
offset += (delta * step);
if(offset > 0 || textheight < wh) {
offset = 0;
} else {
temp = -textheight + wh;
if(offset < temp) offset = Math.round(temp / step) * step;
window.Repaint();
marc2003 another thing I needed your help with
I am using your bio panel with some modifications. I was trying to switch between artist summary and details using
if (idx == 1) {
cont = 'summary';
artist='';
if (idx == 2) {
cont = 'content';
artist='';
and passing cont to the metadb function. This works ok but where I am failing is getting the selection to stick between sessions using window.SetProperty(); and then using window.GetProperty() to set MF_CHECKED/MF_UNCHECKED for the option.
@icedtea,
You mentioned that you were using a script from me for scrolling. Is that the same bio script I sent you a while ago? If so, I've fixed a number of bugs (some to do with scrolling) and added a few features. I haven't noticed any scrolling issues in my latest version. Do you want me to send you what I have? Maybe you can dissect it and figure out a solution to the problem.
@icedtea,
I would really appreciate that.
marc2003 please ignore the previous message I made it work by using
bio_text = xmlDoc.getElementsByTagName(window.GetProperty("mode") ? "summary" : "content")[0].childNodes[0].nodeValue;
_menu.AppendMenuItem(window.GetProperty("mode") ? MF_CHECKED : MF_UNCHECKED, 1, "Summary");
_menu.AppendMenuItem(window.GetProperty("mode") ? MF_UNCHECKED : MF_CHECKED, 2, "Details");
if (idx == 1) {
window.SetProperty("mode", 1);
artist = '';
need_calc = true;
if (idx == 2) {
window.SetProperty("mode", 0);
artist = '';
need_calc = true;
Just wanted to check if there is a more optimum way
@marc2003
I'm trying to change the fonts and background from your excellent biography panel
this is what i have so far
gr.FillSolidRect(0, 0, ww, wh, g_backcolor);
if(username.length == 0 || api_key.length != 32) {
gr.GdiDrawText("Last.fm username and/or API KEY is not set.", g_font, g_textcolor, 0, 0, ww, wh,DT_CENTER | DT_VCENTER | DT_CALCRECT | DT_NOPREFIX);
} else if(g_metadb) {
gr.GdiDrawText(g_text, g_font, g_textcolor, 6, offset + 65, ww-16, wh-offset,DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
gr.FillSolidRect(0, 0, ww, 56, g_backcolor);
gr.GdiDrawText(artist, gdi.Font("Calibri", 26, 1), g_textcolor_hl, 6, 5, ww-77, 32,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(addCommas(listeners) + " listeners, " + addCommas(userplaycount) + " plays in your library.", gdi.Font("Calibri", 22, 0), g_textcolor_hl, 6, 33, ww-16, 28,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.DrawImage(lfm_img, ww-60, 8, 50, 18, 0, 0, 50, 18);
gr.DrawLine(5, 35, ww-10, 35, 1, g_textcolor_hl);
} else {
gr.GdiDrawText("[no selection]", g_font, g_textcolor, 0, 0, ww, wh,DT_CENTER | DT_VCENTER | DT_CALCRECT | DT_NOPREFIX);
now i want to change the background color to black, all fonts to some kind of light grey and the size of the biography text font to let's say 18 or 20.
Help would be much appreciated.
just put these 4 variables anywhere in the script (not inside any function).
g_backcolor = RGB(0,0,0);
g_textcolor = RGB(180,180,180);
g_textcolor_hl = RGB(200,200,200);
g_font = gdi.Font("Segoe UI", 20, 0);
obviously you can play around with the colours yourself.
thank you.
Works perfectly!
just one thing - the panel will change colour if you change the text/background colours in the DUI/CUI settings. you'll have to reload the script to get your colours back. shouldn't be much of an issue but i thought i'd mention it.
EDIT: i suppose you could move those variables inside on_paint right at the start. then you won't have any problems. i should have just said this in the first place.
Thx
only one more question:
where are those icons for youtube, myspace, lastfm from?
It would be great if it were a button set because I need a google, wikipedia, discogs and a
rate your music button which fit your buttons and to combine them to a nice web toolbar
in my foobar htpc mod.
If you made them yourself then I have to say good work! if not please tell me where
you downloaded them...
edit: nevermind...found them on top of this page
Hi everybody. As I'm totally new at scripting I have a simple question - where and what should I add/change to the seekbar script to get "Stopped" displayed in the middle of the seekbar when no song is playing? Currently of course it is not displaying anything
I compiled this code from different sources out here.
text_colour = RGB(50,50,50);
background_colour = RGB(240,240,240);
/*you can set 2 colours here for a gradient effect on the seekbar. this sample replicates the aero blue found in windows 7.
if you want a solid colour, set
bar_colour_2 = "none";
(then only bar_colour_1 will be used)*/
bar_colour_1 = RGB(240,240,240);
bar_colour_2 = RGB(190,190,190);
/////////////////////////end user settings//////////////////////////////////////////////////////////////////////////////////////////////////////
var g_font = gdi.Font("Segoe UI", 12, 1);
var g_drag = 0;
var g_drag_seek = 0;
var g_timer, txt;
ww = window.Width;
wh = window.Height;
gr.FillSolidRect(0, 0, ww, wh, background_colour);
if(fb.IsPlaying) {
if(fb.PlaybackLength > 0) {
if(g_drag){
t = fb.PlaybackLength * g_drag_seek;
h = Math.floor(t/3600)
m = Math.floor((t-=h*3600)/60);
s = Math.floor(t-=m*60);
txt = (h > 0 ? h + ":" + (m <10 ? "0" + m : m) : m) + ":" + (s < 10 ? "0" + s : s) + " / " + length;
} else {
pos = ww * (fb.PlaybackTime / fb.PlaybackLength);
txt = fb.IsPaused ? "Paused" : fb.titleformat("Playing | %codec% | %bitrate% kbps | %samplerate% Hz | $caps(%channels%) | %playback_time%").Eval() + " / " + length;
if(bar_colour_2 == "none") {
gr.FillSolidRect(0, 0, pos, wh, bar_colour_1);
} else {
gr.FillGradRect(0, 0, pos, wh, 90, bar_colour_1,bar_colour_2);
} else if(fb.PlaybackTime > 0.1) {
txt = fb.IsPaused ? "Paused" : fb.titleformat("Playing | %codec% | %bitrate% kbps | %samplerate% Hz | $caps(%channels%) | %playback_time%").Eval() + " / LIVE";
gr.DrawString(txt, g_font, text_colour, 0, 0, ww, wh,0x11005000);
if(window.InstanceType == 1) gr.DrawRect(0,0, ww, wh, 1.0, RGB(137,140,149));
if(fb.IsPlaying && fb.PlaybackLength > 0) g_drag = 1;
if(g_drag) {
g_drag = 0;
g_drag_seek = x < 0 ? 0 : x > ww ? 1 : x / ww;
function on_mouse_mbtn_down(x,y){
if(fb.IsPlaying && fb.PlaybackTime > 0) fb.RunMainMenuCommand("View/Columns playlist/Activate now playing");
if(y > wh) g_drag = 0;
if(g_drag) {
window.Repaint();
length = fb.TitleFormat("%length%").Eval();
g_timer = window.CreateTimerInterval(100);
function on_playback_stop() {
if(g_timer) window.KillTimer(g_timer);
window.Repaint();
CollectGarbage();
window.Repaint();
function on_timer(id){
window.Repaint();
fb.PlaybackTime = fb.PlaybackTime + 5*delta;
if(fb.isplaying) on_playback_new_track();
replace your on_paint function with this...
if(fb.IsPlaying) {
if(g_drag){
} else {
} else {
} else {
txt = "Stopped";
thank you very much Marc! I was adding the same "else" code, but my mistake was that i was adding it at the very end of on_paint(gr) function
a real noob
I'm trying to get an action when I roll over an image.
Can someone show some basic stuff on this?
Cheers
Hey guys, I'm thinking of writing a script to grab stuff from allmusic.com (biography, work info, etc...)
Since I've never written any VBScript or JScript, did anyone write a sample or script that I could be useful?
For example how to load an html page, parse, etc...
Thanks in advance!
@ marc2003
if(!g_metadb) return;
var myspace = fb.TitleFormat("http://www.myspace.com/$replace(%artist%, ,)").EvalWithMetadb(g_metadb);
var lastfm = fb.TitleFormat("http://www.last.fm/music/$replace(%artist%, ,+,/,'%'252F)/_/$replace(%title%, ,+,/,'%'252F)").EvalWithMetadb(g_metadb);
var youtube = fb.TitleFormat("http://www.youtube.com/results?search_query=$replace(%artist%+%title%, ,+,'(',,')',,/,+,&,and)").EvalWithMetadb(g_metadb);
var google = fb.Titleformat ("http://www.google.com/search?q=$replace(%artist%+%album%, ,+)&ie=utf-8").EvalWithMetadb(g_metadb);
Buttons = {
but1: new Button(left_margin,top_margin,bw,bh, {normal: images_path + "myspace.png", hover: images_path + "myspace_h.png"}, function(){WshShell.run(myspace);}, myspace),
but2: new Button(left_margin + bw,top_margin,bw,bh, {normal: images_path + "lastfm.png", hover: images_path + "lastfm_h.png"}, function(){WshShell.run(lastfm);}, lastfm),
but3: new Button(left_margin + (bw*2),top_margin,bw,bh, {normal: images_path + "youtube.png", hover: images_path + "youtube_h.png"}, function(){WshShell.run(youtube);}, youtube)
but4: new Button(left_margin + (bw*3),top_margin,bw,bh, {normal: images_path + "google.png", hover: images_path + "google_32.png"}, function(){WshShell.run(google);},google)
If I understand correctly:
The first part is for definition of the variables or rather search strings. In my case i added google.
The second part is for placing the buttons. (bw*3 goes 32 pixels to the right,) right?
The only thing I can think of is that my search string is wrong.....
I've borrowed that string from run services...
I'm really trying to figure this out now, so any help and explanation is greatly appreciated...
you need to add a comma at the end of the line of code that begins with "but3".
thank you very much.
Hi there,
I'm using Marc's code to retrieve the biographie of the current artist by last.fm.
Is there any chance to get this biographie in another language as the standard code does (English)?
I do not see any paramter for this within the script at all.
http://www.hydrogenaudio.org/forums/index....st&p=689990 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=689990)
Great - thanks a lot!
I must say I don't know a thing about scripting, though I managed to learn to decipher some portions. Still, I have a question: in marc2003's "Now Playing" panel is there any way to make it use artist pics stored in a folder on my hdd?
Here's the script:
// ==PREPROCESSOR==
// ==/PREPROCESSOR==
var title_tf = fb.TitleFormat("%title%");
var album_tf = fb.TitleFormat("$if2(%album%,)");
var artist_tf = fb.TitleFormat("%artist%");
var g_font_title = gdi.Font("Agency FB", 34, 0);
var g_font_album = gdi.Font("Agency FB", 20, 0);
var g_font_artist = gdi.Font("Agency FB", 24, 0);
var album_img = null;
var artist_img = null;
var cycle = window.GetProperty("cycle", 200) - 200;
var limit = window.GetProperty("limit", 305) - 300;
var album_img_size = window.GetProperty("album_img_size", 490) - 400;
if(fb.IsPlaying) on_playback_new_track();
function on_playback_time(time) {
if(cycle > 0 && arr.length > 1 && (time % cycle == 0)) on_mouse_wheel(1);
function on_playback_stop(reason) {
if(album_img) album_img.Dispose();
if(artist_img) artist_img.Dispose();
g_metadb = album_img = artist_img = null;
if(reason != 2) window.Repaint();
g_metadb = fb.GetNowPlaying();
artist = artist_tf.EvalWithMetadb(g_metadb);
title = title_tf.EvalWithMetadb(g_metadb);
album = album_tf.EvalWithMetadb(g_metadb);
album_img = utils.GetAlbumArtEmbedded(g_metadb.rawpath, 0);
if(album_img) {
window.Repaint();
} else {
utils.GetAlbumArtAsync(window.ID, g_metadb, 0);
folder = data_folder + fb.TitleFormat("$crc32(%artist%)").EvalWithMetadb(g_metadb);
index = Math.floor(Math.random()*arr.length)
load_image();
if(arr.length < 2) return;
index += delta;
if(index < 0) index = arr.length-1;
if(index == arr.length) index = 0;
load_image();
function load_image() {
artist_image_path = arr[index];
artist_img = gdi.Image(artist_image_path);
window.Repaint();
function on_mouse_lbtn_dblclk() {
try {WshShell.Run("\"" + artist_image_path + "\""); } catch(e) {}
function on_get_album_art_done(metadb, art_id, im, ip) {
album_img = im;
window.Repaint();
ww = window.width;
wh = window.height;
if(artist_img) {
gr.FillSolidRect( 0, 0,ww, wh, RGBA(0,0,0,200));
scale(gr, artist_img, 0, 0, ww, wh, "min")
} else {
gr.FillSolidRect( 0, 0,ww, wh, RGB(240,240,240));
gr.FillSolidRect(20,wh-130,ww - 40,110,RGBA(90,90,90,175));
if(album_img) {
text_x = album_img_size + 25;
scale(gr, album_img, 10, wh-10-album_img_size, album_img_size, album_img_size, "min");
} else {
text_x = 30;
if(fb.IsPlaying) {
gr.GdiDrawText(title, g_font_title, RGB(255,255,255), text_x, wh-130, ww-text_x-40, wh,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(album, g_font_album, RGB(255,255,255), text_x, wh-80, ww-text_x-40, wh,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(artist, g_font_artist, RGB(255,255,255), text_x, wh-55, ww-text_x-40, wh,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
var _menu = window.CreatePopupMenu();
var _cycle = window.CreatePopupMenu();
var _limit = window.CreatePopupMenu();
var _album = window.CreatePopupMenu();
var idx;
_cycle.AppendMenuItem(MF_STRING, 200, "Off");
_cycle.AppendMenuItem(MF_STRING, 205, "5 seconds");
_cycle.AppendMenuItem(MF_STRING, 210, "10 seconds");
_cycle.AppendMenuItem(MF_STRING, 220, "20 seconds");
_cycle.CheckMenuRadioItem(200, 220, window.GetProperty("cycle"));
_limit.AppendMenuItem(MF_STRING, 301, "1");
_limit.AppendMenuItem(MF_STRING, 303, "3");
_limit.AppendMenuItem(MF_STRING, 305, "5");
_limit.AppendMenuItem(MF_STRING, 310, "10");
_limit.CheckMenuRadioItem(301, 310, window.GetProperty("limit"));
_album.AppendMenuItem(MF_STRING, 490, "Small");
_album.AppendMenuItem(MF_STRING, 600, "Large");
_album.CheckMenuRadioItem(490, 600, window.GetProperty("album_img_size"));
_menu.AppendMenuItem(g_metadb ? MF_STRING : MF_GRAYED, 11, "Download artist art from Last.fm");
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _limit.ID, "Limit");
_menu.AppendMenuItem(MF_SEPARATOR, 0, 0);
_menu.AppendMenuItem(artist_img? MF_STRING : MF_GRAYED, 12, "Open containing folder");
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _cycle.ID, "Cycle");
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _album.ID, "Cover image size");
//_menu.AppendMenuItem(MF_STRING, 99, "Properties");
_menu.AppendMenuItem(MF_STRING, 100, "Configure...");
switch(idx) {
case 200:
case 205:
case 210:
case 220:
window.SetProperty("cycle", idx);
cycle = idx - 200;
break;
case 301:
case 303:
case 305:
case 310:
window.SetProperty("limit", idx);
limit = idx - 300;
break;
case 490:
case 600:
window.SetProperty("album_img_size", idx);
album_img_size = idx - 400;
window.Repaint();
break;
case 11:
break;
case 12:
WshShell.Run("explorer /select," + artist_image_path);
break;
case 99:
window.ShowProperties();
break;
case 100:
window.ShowConfigure();
break;
_menu.Dispose();
_cycle.Dispose();
_limit.Dispose();
_album.Dispose();
return true;
function RGBA(r, g, b, a) { return ((a << 24) | (r << 16) | (g << 8) | (b)); }
Edit: and another one: using marc2003's "Playback Buttons", how would I go about adding other buttons (mainly 'media library search' and 'playback statistics/rate/5')? I need the "function(){fb.
XXX()" bit.
Could a mod please remove my previous comment? It's no longer relevant.
Nevermind the previous questions, I managed to find a workaround for my design. What I'd still like to know is if it's possible to add a background jpg/png to the "now playing" and "artwork 3in1" panels.
out of boredom i've updated my biography panel with full language support as an option accessible via the context menu. it now caches the text indefinitely and it won't automatically update when you switch language. to update, you have to use the context menu. (it still automatically downloads when no biography exists)
(http://k5sbdw.blu.livefilestore.com/y1p3AQAhRqijp_UKFsjz1YxrVtwjciutm5P8Md7e8EypPyWXfi7KLKx9Zm1EGpuPYRzDIauh3nUFXTWZFc2pKGUA7_Gf_CkpE2s/languages.jpg)
Thanks a lot! I was able to change the language based on your helpful comment, but this is nicer.
i just had to re-upload it because i got the code for sweden wrong. i doubt this will affect many people here but you never know.
Hi marc.
I'm trying to integrate one of your scripts (artwork 3in1) into tedgo's DarkOne v2.0 (http://tedgo.deviantart.com/art/DarkOne-v2-0-156697932) but I get the following error:
Scripting Engine Initialization Failed (GUID: FF1A308A-F5B2-49E1-B98F-594F180E0BA6, CODE: 0x80020101)
Check the console for more detailed information (Always caused by unexcepted script error).
In the console I see:
WSH Panel Mod (GUID: FF1A308A-F5B2-49E1-B98F-594F180E0BA6): Parsing file "C:\Programmi\foobar2000\scripts\marc2003\v2\common.js": Failed to load
Error: WSH Panel Mod (GUID: FF1A308A-F5B2-49E1-B98F-594F180E0BA6): Errore di run-time di Microsoft JScript:
'settings_path' non è definito
Ln: 6, Col: 1
<source text only available in compile time>
which basically means the variable settings_path is undefined. I tried investigating and discovered it should be set in common.js but its inclusion seems to be commented in all your scripts, so perhaps I shoud set it elsewhere.
Can you assist me?
TIA.
Alessandro
you need to extract the "scripts" folder from my download into your foobar folder. that is in the readme.
Thanks for taking time to reply.
Please forgive my newbieness but what do you mean exactly? My foobar folder is C:\Programmi\foobar2000 and I extracted you zip in C:\Programmi\foobar2000\scripts, so I now have the following structure:
- C:\Programmi\foobar2000\scripts\other WSH samples (new)
- C:\Programmi\foobar2000\scripts\scripts\marc2003
- C:\Programmi\foobar2000\scripts\scripts\marc2003\v2
Is that correct?
Regards.
Alessandro
Never mind: got it. Apologies for wasting your time.
i meant the "scripts" folder from the zip should go inside your foobar folder. like this
- C:\Programmi\foobar2000\scripts\marc2003
- C:\Programmi\foobar2000\scripts\marc2003\v2
edit: you sorted it. good stuff.
Oh my, I'm really embarassed: I extracted the zip directly into the foobar folder (not in the scripts subfolder) and it seemed to work, but after restarting foobar I'm back to square one.
What am i missing?
Alessandro
Edit: ok, it's official: I'm DUMB. Sorry.
removed. wrong topic. sorry
Hi marc,
me again, apologies for being a PITA.
I'm using your artwork 3in1 and it works fine in
Artreader mode both for Front and Artist image (I don't use Back, Disc and Icon). As it worked right out of the box, I suppose it uses the settings found in
Preferences -> Display -> Front Cover & Artist tabs.
I didn't manage to make the
Cycle Folder option work, though: in
Set Cycle Folder I entered the same string I have in the above mentioned
Artist tab:
E:\My Music\artists\substr(%artist%,1,1)\%artist%_*.*
but no image is shown. Am I misunderstanding how this option works?
Would it be possible to let it cycle using the same sources of
Artreader mode (which, in my case, would mean showing the front cover and the artist image(s) at regular intervals)?
Alessandro
typo? that should be $substr. or you could use $abbr(%artist%) instead.
Yep that was a typo here (looks like I'm not even able to copy and paste, geez).
I re-checked (and re-copied) and the Cycle folder contains exactly the same string as the Artist tab in preferences:
E:\My Music\artists\$substr(%artist%,1,1)\%artist%_*.*
Also tried $abbr (thanks for the tip, didn't know that):
E:\My Music\artists\$abbr(%artist%)\%artist%_*.*
but doesn't seem to make any difference.
Alessandro
PS: oh, and Cycle IS set to 5 secs, not off.
@mobyduck
As you wrote you use DarkOne v2.0, i enhanced my cover panel to auto-cycle artreader or up to 5 custom pictures.
Maybe you want to try it instead: http://pastebin.de/4550 (http://pastebin.de/4550)
Cycle-Interval can be changed by right-click --> Properties "Auto Cycle Image Interval in s" (its preconfigured to 15s like Biography view panel).
Btw. how is your correct path named? $abbr(%artist%) gives DM for Depeche Mode, but A for Abba.
oh sorry. that's me confusing things. go back to $substr if it's just the first letter. i thought that's all $abbr did as well.
Thanks both for your assistance.
Yes, in my case $substr is the correct function to use: thanks for the clarification.
@tedgo: I tried your script but it appears only to cycle between the front cover and the FIRST artist image (and yes, I have more that one image for the current artist). What else should I check?
Regards.
Alessandro
Oh, yes it only cycles the first image found.
Sorry, its by design of the panel...
I don't wanted to rewrite it completely.
But you could add up to 5 images as "Custom Pictures" and cycle between them (right-click in the panel --> Properties and type-in the paths to the 5 images to the according "Picture x").
The panel can only cycle between album art OR custom pictures, not all in a row.
Maybe i change this behaviour but i guess not...
Oh, I see...
Well, perhaps I should go back to the old albumart panel: after all it worked well for me and didn't cause any crashes. I'll try and study if and how it can replace your wsh panel.
Thanks again.
Alessandro
try my script again but remove the *.*. it already has wildcard support (but is limited to jpg/png/gif files).
Sorry marc, still no go.
Let me know if there's anything else I can do to track down the problem.
Cheers.
Alessandro
@mobyduck
Does your string work in artreader?
I guess your path to an artist picture is like: E:\My Music\artists\M\Michael Jackson_01.jpg
(this is what your string suggests, although you could also use $left(%artist%,1) instead $substr())
i see the problem now. it's because i only meant the script to use folders. if you change your pattern to
.. that should work.
but if there are other images in that folder you don't want displayed, you'll have to edit the script. remove the \\ on lines 90-92 and change your pattern back to the original. then if you want to use folders at a later time, you'll need to add a trailing slash yourself in the dialog box.
Right on the mark! Thanks so much.
Alessandro
Yeah, your guess is right. But, forgive me, what do you mean by
artreader exactly?
And thanks for the $left suggestion: learning a lot today!
Alessandro
artreader = Preferences --> Display
Well, it works AFAICT, but only the first image that matches is returned.
Alessandro
Edit: that's just speculation on my part, haven't tested extensively.
samples updated (http://cid-649d3bfeaf541fbb.skydrive.live.com/self.aspx/.Public/foobar/guide/samples.zip)
-added transition effect to "now playing" panel. track info and album art slide into view when playback starts
-known issue: it's not always smooth when changing artists as the script has to scan your hard disk for images
-you can toggle the effect on or off via the context menu
The transition looks great! What would I need to change to make the "Now playing" panel show artist images (embedded forst)? I was looking over the code, but my lack of scripting skills clearly shows.
this uses the foobar artreader instead....
http://pastebin.org/114502 (http://pastebin.org/114502)
edit: cleaned up code a bit by removing all last.fm related stuff
http://pastebin.org/114479 (http://pastebin.org/114479)
This will do nicely! You just saved my entire afternoon.
i have a little problem with now playing script when i turn foobar off and on again i receive error on line 108
with console text "title not defined"
i suspect its some issue with script being evaluated before playback start but do not know how to resolve it
are you sure you downloaded it from the link you quoted and it's totally un-modified? it should never generate an error like that.
mmm pretty sure... but it does not generate this error everytime which kind of bugs me as its not easily redoable. just from time to time all i see instead of "now playing" is "script error"
im not sure if i translated the error msg correctly (as i dont run English windows and error is in my native lang). What is debuger trying to say is that "variable title" is not defined.
maybe something like this could help
if (!isset(title)) { title="";}
but imnot sure if something like this is possible in wshpanel[/s]
edit: Interesting think just happened and ive found out that i used previous version of now playing script... will continou explore
I'm currently using the Main Menu manager (All in one) script. It works fine, but I'd really like to have a button in it (right now clicking anywhere in the panel shows the menu from that point). Can anyone help me with it?
This is the script I'm talking about:
http://www.pastebin.org/116881 (http://www.pastebin.org/116881)
@Keesface, the on_mouse_lbtn_up function can use "x" and "y" to do just that. Find the x and y coordinates of your button's boundaries x1, x2, y1, y2.
This can be done easily by putting this function in your script and watching the console:
function on_mouse_move (x,y) {
fb.trace("x: " + x);
fb.trace("y: " + y);
Now, just encase the entirety of the menu command you posted within:
if(x > x1 && x < x2 && y > y1 && y < y2) {
<MENU COMMANDS>
That should work. Now, the menu only comes up when you click within the specified boundaries.
Getting a script error when I try to use this... Hm. I'm using the latest WSH panel mod (1.3.2)
I am VERY interested in those scripts too, to be integrated in the fabulous DarkOne skin.
But I can't seem to be able to download samples.zip.
Is the link still OK ? http://cid-649d3bfeaf541fbb.skydrive.live....ide/samples.zip (http://cid-649d3bfeaf541fbb.skydrive.live.com/self.aspx/.Public/foobar/guide/samples.zip)
I'm trying to add a 4th link to marc "web links" sample, i would like to add a link to rateyourmusic.com artist page or album...
i write this in the script:
(http://img534.imageshack.us/img534/3604/immagineon.th.jpg) (http://img534.imageshack.us/i/immagineon.jpg/)
but i got a link to rateyourmusic home page and not to artist page, anyone knows why?
Thanks anyway.
@Fractal_Mortality, you do realise that script was a modification of my samples. it requires files from the zip file linked above. perhaps you are missing that?
@joe30, no problems with the link my end. it's always been reliable for me.
@nickdc, your $replace doesn't serve any purpose. try removing it. also, if you hover your mouse over the button, a tooltip will show the actual link before you click so that should help you troubleshoot it as well.
Ah, my bad Marc, thanks.
Ok i wrote this in the script:
var rym = fb.TitleFormat("http://rateyourmusic.com/artist/$replace(%artist%, ,)").EvalWithMetadb(g_metadb);
now, when i go with mouse over the button i read
http://rateyourmusic.com/artist/JohnLennon (http://rateyourmusic.com/artist/JohnLennon),
but the right link on artist page on rym is:
http://rateyourmusic.com/artist/john_lennon (http://rateyourmusic.com/artist/john_lennon)
so i think i need to replace the caps letters with no caps, and replace the space between the words with a "_" to get the right link, do you know how to do?
if thats all you want:
$lower($replace(%artist%,' ','_'))
Awesome cart, it works good, thanks
Sadly I can't use Lyrics Show Panel 2 anymore, it became too unstable...
Is there any script out there that can download lyrics without having to store them somewhere before?
I'll write my own Lyrics panel but I have no idea how to download the lyrics from a site such as LyricWiki.
Any help is appreciated!
To xbullethammer.
1. I have problems with english.
2. I have problems with jscript.
I do not know how, but I wrote this script and it works for me .
http://rghost.ru/1260945 (http://rghost.ru/1260945)
These scripts are not completed, but things that may help you are in a folder "scripts".
Hey thanks for this, it works great!
I'll start to work on this once I finish my homework
@marc2003
I have a few suggestions for your awesome now playing panel:
1.) Save artist images to foobarpath\lastfm\artist 1...artist 2...artist 3...
like biography panel does. This way, we will be able to find the images later on
and also download images by ourselves and put it in the appropriate folder
to display them in the panel.
2.) Option for downloading artist images automatically.
3.) Display something like "foobar2000" on panel startup/no track playing.
You would do me (and maybe others too) a huge favour.
i have no intention of changing the file path for saved images. the reason i use foobar title formatting $crc32(%artist%) to generate the folder name is so i don't have to worry about windows filename validation. regardless of language/alphabet/special characters/punctuation, it just works. and it also means you can put this in the foobar artreader options so other components can use the same images.
you can right click the panel and use "Open containing folder" if you want to remove/edit/insert your own images in there for rotation (playback would have to be restarted for the script to detect the new files).
Ok, will do so for rotating images.
What about automatic downloading?
I've tried to do automatic downloading, but there is one problem with art.exe. I wrote about it .here (http://www.hydrogenaudio.org/forums/index.php?showtopic=77425&view=findpost&p=694656)
When creating request for nonexistent artist's name in database last.fm. art.exe not self-closing, and remains in Task Manager.
// ==PREPROCESSOR==
var title = fb.TitleFormat("[%title%]").Eval();
var artist_tf = fb.TitleFormat("%artist%").Eval();
var g_font_title = gdi.Font("Calibri", 16, 0);
var g_font_album = gdi.Font("Calibri", 18, 0);
var g_font_artist = gdi.Font("Calibri", 18, 0);
var artist = old_artist = null;
var g_timer = null;
var offset = 0;
var limit = window.GetProperty("limit", 325) - 300;
var transition = window.GetProperty("transition", 801) - 800;
ww = window.width;
wh = window.height;
var arr = new Array();
function on_timer(id) {
offset--;
if(offset == 0) {
CollectGarbage();
window.Repaint();
if(transition == 1) {
g_timer = window.CreateTimerInterval(1);
offset = 30;
if(artist) old_artist = artist;
artist_out = fb.TitleFormat("[%artist%]").EvalWithMetadb(g_metadb);
artist = fb.TitleFormat("$replace($lower(%artist%),.,)").EvalWithMetadb(g_metadb);
if(!album_img) utils.GetAlbumArtAsync(window.ID, g_metadb, 0);
if(artist != old_artist) {
folder = data_folder + fb.TitleFormat("$replace($lower(%artist%),.,)").EvalWithMetadb(g_metadb);
index = Math.floor(Math.random()*arr.length);
load_image();
index += delta;
load_image();
window.Repaint();
album_img = im;
window.Repaint();
function on_size() {
ww = window.width;
wh = window.height;
function on_paint(gr) {
if(artist_img) {
gr.FillSolidRect(0,0,ww,wh,RGBA(17,19,49,255)); //background
scale(gr, artist_img, 0, 0, ww, wh, "min");
} else {
gr.FillGradRect(0, 0, ww, wh, 90,g_backcolor, g_textcolor_hl);
gr.FillSolidRect(20,wh-130,ww - 40,110,RGBA(0,0,0,156));
if(album_img) {
scale(gr, album_img, (-offset * 20) + 30, wh-30-album_img_size, album_img_size, album_img_size, "min");
} else {
text_x = 30;
if(fb.IsPlaying) {
gr.GdiDrawText(title, g_font_title, RGB(255,255,255), text_x, (offset * 15) + wh - 100, ww-text_x-40, wh,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(album, g_font_album, RGB(255,255,255), text_x, (offset * 20) + wh - 55, ww-text_x-40, wh,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(artist_out, g_font_artist, RGB(255,255,255), text_x, (offset * 10) + wh - 130, ww-text_x-40, wh,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
var _transition = window.CreatePopupMenu();
var idx;
_limit.AppendMenuItem(MF_STRING, 325, "25");
_limit.CheckMenuRadioItem(301, 325, window.GetProperty("limit"));
_transition.AppendMenuItem(MF_STRING, 800, "Off");
_transition.AppendMenuItem(MF_STRING, 801, "On");
_transition.CheckMenuRadioItem(800, 801, window.GetProperty("transition"));
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _transition.ID, "Transition effects");
switch(idx) {
case 200:
case 205:
case 210:
case 220:
cycle = idx - 200;
break;
case 301:
case 305:
case 310:
case 325:
limit = idx - 300;
break;
case 490:
case 600:
window.Repaint();
break;
case 800:
case 801:
window.SetProperty("transition", idx);
transition = idx - 800;
break;
case 11:
break;
case 12:
break;
case 99:
break;
case 100:
break;
_menu.Dispose();
_cycle.Dispose();
_limit.Dispose();
_transition.Dispose();
_album.Dispose();
return true;
I rewrote Marc2003's lastfm and art scripts. They do not need art.exe anymore.
Here is the include file, to see how it works:
function BioInfo() {
this.ArtistList = [];
this.Elements = [];
this.AlbumArtist = "";
this.Album = "";
this.Selected = 0;
this.Bio = function() {
if (this.Elements.length > 0) return this.Elements[this.Selected].Bio;
else return "";
this.Similar = function() {
var tarr = [];
for (var i in this.Elements) {
for (var j in this.Elements[i].Similar) {
var d = false;
for (var k in tarr) {
if (this.Elements[i].Similar[j] == tarr[k]) d = true;
for (var k in this.ArtistList) {
if (this.Elements[i].Similar[j] == this.ArtistList[k]) d = true;
if (!d) tarr.push(this.Elements[i].Similar[j]);
return tarr;
this.Tags = function() {
var tarr = [];
for (var j in this.Elements[i].Tags) {
var d = false;
if (this.Elements[i].Tags[j] == tarr[k]) d = true;
if (!d) tarr.push(this.Elements[i].Tags[j]);
return tarr;
this.Url = function() {
if (this.Elements.length > 0) return this.Elements[this.Selected].Url;
else return "";
this.Get = function(artistlist, albumartist, album, force) {
if (artistlist.toString() != this.ArtistList.toString() || force) {
if (artistlist.toString() != this.ArtistList.toString()) {
this.ArtistList = artistlist;
this.Selected = 0;
GetLastFMArtistPics(artistlist[0]);
this.Elements = [];
for (var i in artistlist) {
this.Elements[i] = new BioElement();
this.Elements[i].Get(artistlist[i]);
if (albumartist != this.AlbumArtist || album != this.Album) {
this.AlbumArtist = albumartist;
this.Album = album;
GetLastFMAlbumPics(albumartist, album);
this.Force = function() {
this.Elements[this.Selected].Get(this.ArtistList[this.Selected], true);
this.Select = function(artist) {
var tmp = 0
for (var i in this.ArtistList) {
if (artist == this.ArtistList[i]) tmp = i;
if (tmp != this.Selected) {
this.Selected = tmp;
GetLastFMArtistPics(this.ArtistList[this.Selected]);
} else {
this.Force();
//artalb: 0 for artist, 1 for album, 2 for both
this.GetImages = function(artalb) {
if (artalb == 0 || artalb == 2) GetLastFMArtistPics(this.ArtistList[0]);
if (artalb == 1 || artalb == 2) GetLastFMAlbumPics(this.AlbumArtist, this.Album);
function BioElement() {
this.Artist = "";
this.Bio = "";
this.Similar = [];
this.Tags = [];
this.Url = "";
this.Get = function(artist, force) {
if (artist != this.Artist || force) {
this.Artist = artist;
this.Bio = "";
this.Similar = [];
this.Tags = [];
this.Url = "";
var filename = datafolder + crc32(artist).toString(16) + ".xml";
try {
if(fso.fileExists(filename)) {
var file = fso.Getfile(filename);
if(Date.parse(Date()) - Date.parse(file.DateLastModified) < 86400000) {
var text = "";
try {
ts = fso.OpenTextFile(filename,1, false, -1);
text = ts.ReadAll();
ts.close();
} catch(e) {}
if(text.length > 0) {
var xmldom = new ActiveXObject("Microsoft.XMLDOM");
xmldom.async = "false";
xmldom.loadXML(text);
try {this.Bio = decodeXML(xmldom.getElementsByTagName("content")[0].childNodes[0].nodeValue)} catch(e) {}
try {
var similar = xmldom.getElementsByTagName("similar");
for (var i = 0; i < similar[0].getElementsByTagName("name").length; i++) {
this.Similar.push(decodeXML(similar.item(0).getElementsByTagName("name")[i].childNodes[0].nodeValue));
} catch(e) {}
try {
var tags = xmldom.getElementsByTagName("tags");
for (var i = 0; i < tags[0].getElementsByTagName("name").length; i++) {
this.Tags.push(decodeXML(tags.item(0).getElementsByTagName("name")[i].childNodes[0].nodeValue));
} catch(e) {}
try {this.Url = decodeXML(xmldom.getElementsByTagName("url")[0].childNodes[0].nodeValue)} catch(e) {}
} else {
GetLastFMArtist(artist);
} else {
} catch(e) {
fb.trace("ERROR BioElement.Get");
var LastFMAPI = ""; // put your lastfm api here
var LastFMUserName = ""; put your lastfm username here
var fso = new ActiveXObject("Scripting.FileSystemObject");
var datafolder = "D:\\Music\\LastFMBio\\"
if(!fso.FolderExists(datafolder)) fso.CreateFolder(datafolder);
function GetLastFMArtist(artist) {
try {
var xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
xmlhttp.open("GET", "http://ws.audioscrobbler.com/2.0?&api_key=" + LastFMAPI + "&username=" + LastFMUserName + "&method=artist.getinfo&artist=" + encodeURIComponent(artist) + "&s=" + Math.random(), true);
xmlhttp.setRequestHeader('User-Agent', "foo_wsh_lastfm_bio");
xmlhttp.send();
xmlhttp.onreadystatechange = function() {
if (xmlhttp.readyState == 4) {
if (xmlhttp.status == 200) {
savetextfile(datafolder + crc32(artist).toString(16) + ".xml", xmlhttp.responsetext);
} else {
fb.trace(xmlhttp.responsetext);
datareload = true;
window.Repaint();
} catch(e) {
fb.trace("ERROR GetLastFMArtist");
function savetextfile(filename, content) {
try {
ts = fso.OpenTextFile(filename, 2, true, -1);
ts.WriteLine(content);
ts.close();
} catch(e) {
fb.trace("ERROR savetextfile");
function GetLastFMArtistPics(artist) {
window.NotifyOthers("artist", artist);
try {
xmlhttp.open("GET", "http://ws.audioscrobbler.com/2.0?&api_key=" + LastFMAPI + "&method=artist.getImages&artist=" + encodeURIComponent(artist) + "&limit=5&s=" + Math.random(), true);
xmlhttp.send();
xmldom.loadXML(xmlhttp.responsetext);
var urls = [];
try {
var images = xmldom.getElementsByTagName("image");
for (var i = 0; i < images.length; i++) {
var sizes = images[i].getElementsByTagName("size");
for (var j = 0; j < sizes.length; j++) {
if (sizes[j].attributes.getNamedItem("name").value == "original") urls.push(decodeXML(sizes[j].childNodes[0].nodeValue));
} catch(e) {}
for (var i in urls) {
GetWebPicture(urls[i], artist, "artist", i == (urls.length - 1));
} else {
} catch(e) {
fb.trace("ERROR GetLastFMArtistPics");
function GetLastFMAlbumPics(artist, album) {
window.NotifyOthers("album", artist + album);
try {
xmlhttp.open("GET", "http://ws.audioscrobbler.com/2.0?&api_key=" + LastFMAPI + "&method=album.getInfo&artist=" + encodeURIComponent(artist) + "&album=" + encodeURIComponent(album) + "&s=" + Math.random(), true);
xmlhttp.send();
var url = null;
try {
if (images[i].attributes.getNamedItem("size").value == "extralarge") url = decodeXML(images[i].childNodes[0].nodeValue);
} catch(e) {}
if (url) GetWebPicture(url, artist + album, "album", true);
} else {
} catch(e) {
fb.trace("ERROR GetLastFMAlbumPics");
function GetWebPicture(url, str, type, last) {
try {
var filename = datafolder + crc32(str).toString(16) + "\\" + crc32(url).toString(16) + url.slice(url.lastIndexOf("."));
if (!utils.FileTest(filename, "e")) {
if(!fso.FolderExists(datafolder + crc32(str).toString(16))) fso.CreateFolder(datafolder + crc32(str).toString(16));
xmlhttp.open("GET", url, true);
xmlhttp.send();
savebinaryfile(filename, xmlhttp.responseBody);
if (last) window.NotifyOthers(type, str);
} else {
} catch(e) {
fb.trace("ERROR GetWebPicture");
function savebinaryfile(filename, content) {
try {
var ostream = new ActiveXObject("adodb.stream");
ostream.Type = 1 //binary
ostream.Open();
ostream.Write(content);
ostream.SaveToFile(filename, 2);
} catch(e) {
fb.trace("ERROR savebinaryfile");
function decodeXML(value) {
try {
value = value.replace(/<\/?[^>]+(>|$)/g, "");
doc = new ActiveXObject("htmlfile");
doc.open();
div = doc.createElement("div");
div.innerHTML = value.replace(/\n/g, "<br>");
value = div.innerHTML;
value = value.replace(/<BR>/g,"\n");
value = value.replace(/>/g,">");
value = value.replace(/</g,"<");
value = value.replace(/ /g," ");
return value.replace(/&/g,"&");
} catch(e) {
fb.trace("ERROR decodeXML");
function crc32(str) {
var table = "00000000 77073096 EE0E612C 990951BA 076DC419 706AF48F E963A535 9E6495A3 0EDB8832 79DCB8A4 E0D5E91E 97D2D988 09B64C2B 7EB17CBD E7B82D07 90BF1D91 1DB71064 6AB020F2 F3B97148 84BE41DE 1ADAD47D 6DDDE4EB F4D4B551 83D385C7 136C9856 646BA8C0 FD62F97A 8A65C9EC 14015C4F 63066CD9 FA0F3D63 8D080DF5 3B6E20C8 4C69105E D56041E4 A2677172 3C03E4D1 4B04D447 D20D85FD A50AB56B 35B5A8FA 42B2986C DBBBC9D6 ACBCF940 32D86CE3 45DF5C75 DCD60DCF ABD13D59 26D930AC 51DE003A C8D75180 BFD06116 21B4F4B5 56B3C423 CFBA9599 B8BDA50F 2802B89E 5F058808 C60CD9B2 B10BE924 2F6F7C87 58684C11 C1611DAB B6662D3D 76DC4190 01DB7106 98D220BC EFD5102A 71B18589 06B6B51F 9FBFE4A5 E8B8D433 7807C9A2 0F00F934 9609A88E E10E9818 7F6A0DBB 086D3D2D 91646C97 E6635C01 6B6B51F4 1C6C6162 856530D8 F262004E 6C0695ED 1B01A57B 8208F4C1 F50FC457 65B0D9C6 12B7E950 8BBEB8EA FCB9887C 62DD1DDF 15DA2D49 8CD37CF3 FBD44C65 4DB26158 3AB551CE A3BC0074 D4BB30E2 4ADFA541 3DD895D7 A4D1C46D D3D6F4FB 4369E96A 346ED9FC AD678846 DA60B8D0 44042D73 33031DE5 AA0A4C5F DD0D7CC9 5005713C 270241AA BE0B1010 C90C2086 5768B525 206F85B3 B966D409 CE61E49F 5EDEF90E 29D9C998 B0D09822 C7D7A8B4 59B33D17 2EB40D81 B7BD5C3B C0BA6CAD EDB88320 9ABFB3B6 03B6E20C 74B1D29A EAD54739 9DD277AF 04DB2615 73DC1683 E3630B12 94643B84 0D6D6A3E 7A6A5AA8 E40ECF0B 9309FF9D 0A00AE27 7D079EB1 F00F9344 8708A3D2 1E01F268 6906C2FE F762575D 806567CB 196C3671 6E6B06E7 FED41B76 89D32BE0 10DA7A5A 67DD4ACC F9B9DF6F 8EBEEFF9 17B7BE43 60B08ED5 D6D6A3E8 A1D1937E 38D8C2C4 4FDFF252 D1BB67F1 A6BC5767 3FB506DD 48B2364B D80D2BDA AF0A1B4C 36034AF6 41047A60 DF60EFC3 A867DF55 316E8EEF 4669BE79 CB61B38C BC66831A 256FD2A0 5268E236 CC0C7795 BB0B4703 220216B9 5505262F C5BA3BBE B2BD0B28 2BB45A92 5CB36A04 C2D7FFA7 B5D0CF31 2CD99E8B 5BDEAE1D 9B64C2B0 EC63F226 756AA39C 026D930A 9C0906A9 EB0E363F 72076785 05005713 95BF4A82 E2B87A14 7BB12BAE 0CB61B38 92D28E9B E5D5BE0D 7CDCEFB7 0BDBDF21 86D3D2D4 F1D4E242 68DDB3F8 1FDA836E 81BE16CD F6B9265B 6FB077E1 18B74777 88085AE6 FF0F6A70 66063BCA 11010B5C 8F659EFF F862AE69 616BFFD3 166CCF45 A00AE278 D70DD2EE 4E048354 3903B3C2 A7672661 D06016F7 4969474D 3E6E77DB AED16A4A D9D65ADC 40DF0B66 37D83BF0 A9BCAE53 DEBB9EC5 47B2CF7F 30B5FFE9 BDBDF21C CABAC28A 53B39330 24B4A3A6 BAD03605 CDD70693 54DE5729 23D967BF B3667A2E C4614AB8 5D681B02 2A6F2B94 B40BBE37 C30C8EA1 5A05DF1B 2D02EF8D";
var crc = 0;
var x = 0;
var y = 0;
crc = crc ^ (-1);
for (var i = 0, iTop = str.length; i < iTop; i++) {
y = (crc ^ str.charCodeAt (i)) & 0xFF;
x = "0x" + table.substr (y * 9, 8);
crc = (crc >>> 8) ^ x;
return crc ^ (-1);
Maybe I'll write an example of how to use it soon, together with an example for my by now largely upgraded input FormsAndButtons script.
Thank you for posting this. It stays in the task manager but it works just fine.
That would be awesome. Thank you!
Edit: Deleted some misunderstood things...
I'm using the excellent lyrics viewer by alex1nax. I've made some changes to the code fit it to my taste; however, there's a problem I can't solve.
To make things (I believe) faster, the panel draws the lyrics in a IGdiBitmap which is then drawn into the panel. The problem is that it appears that GdiDrawText() draws the text blended on a black background rather than on a transparent one. I tried switching rendering methods but it appears that DrawString() has the same problem. Is there any way to draw text correctly on a non-black image?
edit: samples NOT updated
something caused it to crash so script removed.
2nd attempt: samples updated.
changes to "now playing" panel only
-transitions removed. behaviour too random.
-automatically download artist art from lastfm if no artist images exist (you can turn this on/off via the context menu)
-shows text when playback is stopped. you can set this yourself at the top of the script.
-modded "art.exe" that doesn't hang in task manager when artist doesn't exist on last.fm
-minor appearance tweak
Excellent update marc!
Works flawlessly...
Thank you!
This looks awesome. Could you please tell how to use this exactly ?
follow the instructions inside the zip. at the end, the file you need to import is named "now playing.txt". you can control most of the script options via the context menu.
a couple of things which aren't documented:
you can double click the panel to open the current image in your default viewer
use your mouse wheel to cycle through the images
Hi. Could you please help me pointing me the right direction or some tips to achieve my will.
I would like to reproduce a Simple Volume Knob, inspired by AbeltonLive.
I made an exemple with photoshop in 4 states : 0% 30% 60% and 100% of the volume.
(http://img200.imageshack.us/img200/5134/voltest.png) (http://img200.imageshack.us/i/voltest.png/)
I've read the script of some knobs config (Kameleon and Xchange, by Falstaff) and tried to simplify the code to my purpose.
But i have to say that JScript is for me, much more difficult to understand and learn than TitleFormat Script.
So maybe someone can point me the way to find a very simple code, to start learning JScript, and achieve my knob project.
I put the example image specially to have your comment about how much images/overlays i will need.
Any help would be very appreciated. WSH scares me a bit very much!
I uploaded a new version of my FormsAndButtons script for buttons and keyboard text input. I also included, a modified version of Marc2003's last.fm script, which doesn't need art.exe anymore (it is possible to download binary files in jscript!).
To show how it works I included an example layout.
[a href='index.php?showtopic=80035']See this topic for screenshots and to download[/a]
Kabuki: Here is something to start you off. I don't know how to get the two colour effect, I think it would be quite hard. You really need to be able to draw curves I guess. Or figure out how to put a polygon on top that masks the right part- you need to define a set of points that depend on the angle so that it ends up looking how you want. Not easy...
function pos2vol(pos) {
return (50 * Math.log(0.99 * p + 0.01) / Math.LN10);
function vol2pos(v){
return (Math.pow(10, v / 50) - 0.01) / 0.99;
var vcol = window.InstanceType?window.GetColorDUI(0):window.GetColorCUI(0);
var bg = window.InstanceType?window.GetColorDUI(1):window.GetColorCUI(3);
var radius = 16;
var line = 3;
var offset = 3;
var voldrag = false;
var p = vol2pos(fb.Volume);
var ang = (3/4)*Math.PI + (3/2)*Math.PI*p;
gr.FillSolidRect( 0, 0, ww, wh, bg);
gr.SetSmoothingMode(4);
gr.DrawEllipse(offset, offset, 2*radius, 2*radius, line, vcol);
gr.DrawLine(radius*(1+Math.cos(ang))+offset, (radius)*(1+Math.sin(ang))+offset, radius+offset, radius+offset, line, vcol);
function on_size()
ww = window.Width;
wh = window.Height;
function on_mouse_lbtn_down(x,y)
voldrag = true;
y_old = y;
function on_mouse_lbtn_up(x,y)
voldrag = false;
function on_mouse_move(x,y)
if(voldrag)
p = p - (y-y_old)/80;
p = (p>1)?1:(p<0)?0:p;
fb.Volume = pos2vol(p);
y_old = y;
p = p + delta/10;
function on_volume_change(val)
p = vol2pos(val);
window.Repaint();
the reason i use foobar title formatting $crc32(%artist%) to generate the folder name ... you can put this in the foobar artreader
Ive never thought of that... man its brilliant THANKS!
Thank you TomBarlow for having taken time to specially code this. Yes i will step by step learn JScript, since i suppose that more and more components will use this instead of TF.
Now, thanks to you i have a simple code to start.
Cheers
@ marc2003, do u know how to add item details (title, album, artist) in your aero seekbar script? I think it would be nice...
samples updated with glass playback buttons.
this has additonal requirements compared to the other scripts:
1) requires columns UI and a specially modified version of WSH panel mod -
http://sites.google.com/site/jk7800/foobar...?attredirects=0 (http://sites.google.com/site/jk7800/foobar2000/foo_uie_wsh_panel_mod.dll?attredirects=0)
2) the panel must be placed at the bottom of a vertical splitter with both the status bar and status pane turned off
and it looks like this....
(http://k5sbdw.blu.livefilestore.com/y1pC1eZ2OXF2PyCcZb78W9RK1u8rDxnagB3sKqGEsiEAUPbXd3US9vYveX8xdnunvwHRiHH_cjxJ28PiAM9LkrVrCKFxfo3pG2H/glass%20buttons.png)
I like that .
Any ideas about this?
^No, since AA/ClearType text doesn't like alpha channel, so you need to have a solid background in that case.
hi, maybe i can reach another time some help from you, here.
2 questions:
- is-it possible to make a knob that will change playback order (and show the appropriate text below the knob), instead of a button? I mean a knob with a defined number of "hard state" (in opposite of smooth drag as volume does - somelike the "source selector" in our old Hi-Fi amplificator for those who remember ) but would react with mouse scroll and/or mouse drag, more than specified lbtn_up/down zone?
TomBarlow gave me a very good start for a volume knob, but i was curious if i could get same design for playback order, because my volumeknob is feeling a bit alone in my panel
- then: script/code bug ... and i don't know what could be the cause:
i've "compiled" (mix from here and there) a rating star panel whith following code:
// ==PREPROCESSOR==
// @import "%fb2k_path%docs\Flags.txt"
// @import "%fb2k_path%docs\Helpers.txt"
//===================================== RATING
var ww = window.Width;
var wh = window.Height;
var bg = RGBA(212, 203, 159, 255);
var g_drag = 0;
var bool;
var g_metadb;
var rating;
var nrating;
var lrating;
var hofset=0;
var imgw=12;
var g_tfo = fb.TitleFormat("%rating%");
var g_font = gdi.Font("wingdings", 12, 0);
var opt_read = 1
function on_paint(gr){
gr.SetTextRenderingHint(5);
if (g_metadb) {
if (fb.isplaying || fb.ispause) {
this.RatedStar = RGB(52, 52, 52);
}else{
var RatedStar = RGB(190, 186, 129);
var NotRatedStar = RGB(190, 186, 129);
for (i = 1; i < 6; i++) {
color = ( ((i > (g_drag ? lrating : rating)) ? NotRatedStar : RatedStar ) );
gr.GdiDrawText("", g_font,color,hofset+imgw*(i-1) ,0 ,56 ,26 , 0);
else{}
if(opt_read==1) {
if (lrating !=rating) {if (g_metadb) {
bool = g_metadb.UpdateFileInfoSimple("RATING",lrating);
else {
bool = g_metadb.UpdateFileInfoSimple("RATING","");}
} else {
bool = fb.RunContextCommandWithMetadb("Rating/"+((lrating==0) ? "<not set>" : lrating),g_metadb);
else {
bool = fb.RunContextCommandWithMetadb("Rating/<not set>",g_metadb);}
if (g_metadb) {
g_drag = 1;
nrating = Math.ceil((x-hofset)/imgw);
if (nrating > 5) nrating = 5;
if (nrating != lrating) {
lrating = nrating;
window.Repaint();
function on_mouse_leave() {
on_metadb_changed()
function on_item_focus_change() {
if (g_metadb) {window.UnwatchMetadb();}
g_metadb = fb.GetFocusItem();
if (fb.IsPlaying | fb.IsPaused) g_metadb = fb.GetNowPlaying();
if (g_metadb) {
window.WatchMetadb(g_metadb);
g_drag = 0;
if (g_metadb) {rating = g_tfo.EvalWithMetadb(g_metadb);}
if (rating == "?") {rating = 0;}
lrating = rating;
window.Repaint();
function on_playback_new_track(metadb) {
on_item_focus_change();
function on_mouse_rbtn_down(x, y) {
ShiftDown = utils.IsKeyPressed(0x10) ? true : false;
function on_mouse_rbtn_up(x, y) {
if (ShiftDown) {
_menu.AppendMenuItem(MF_STRING, 1, "Properties");
_menu.AppendMenuItem(MF_STRING, 2, "Configure...");
switch (idx) {
case 1:
break;
case 2:
break;
return true
//EOF
everything is ok, i've selected transparent bg, even if, just in case i've declared a bg color that match with the panel below. And rating/unrating works great.
But when foobar start, all the WSH panel background, and only this one, is black during 2 seconds. Ok, i can live with that (mouhaha), but, my knowledge of JScript goes step by step, and this could help me to understand more things.
acting normaly:
(http://img651.imageshack.us/img651/1686/normalyf.png) (http://img651.imageshack.us/i/normalyf.png/)
strange behaviour during foobar start:
(http://img8.imageshack.us/img8/2913/strangebehaviouratstart.png) (http://img8.imageshack.us/i/strangebehaviouratstart.png/)
Thx
coverflow(http://www.abload.de/img/coverflow10ckgu.jpg) (http://www.abload.de/image.php?img=coverflow10ckgu.jpg)
prerequisite:
- in foobar2000: Library | Search | %tracknumber% IS 01 | Create Playlist
- select all tracks in playlist | rightclick | Utilities | Text Tools | Advanced | Track Pattern: "%path%", | Copy
- open editor (notepad++) | Paste | replace \ by \\ and remove last comma
- Insert created paths in WSH Panel mod script at line 20 (array) | Apply
//coverflow by grimes
//fb2k 1.0+, WSH Panel Mod 1.3.2+ required
//DUI/CUI ready
function RGB(r, g, b) {
return (0xff000000 | (r << 16) | (g << 8) | (b));
var dui = window.InstanceType;
//var g_font = gdi.Font("Segoe UI", 12, 0);
var g_font = dui === 1 ? window.GetFontDUI(0) : window.GetFontCUI(0);
//var color = RGB(200,0,0);
var color = dui === 1 ? window.GetColorDUI(2) : RGB(200, 0, 0);
//var color2 = RGB(0,0,0);
var color2 = dui === 1 ? window.GetColorDUI(0) : window.GetColorCUI(0);
var id = 0;
var zz = 0;
var ww = 0,
wh = 0;
var patharray = new Array(
//insert paths
var g_img;
var g_img2;
var g_img3;
var g_img4;
var g_img5;
function get_image() {
g_img = utils.GetAlbumArt(patharray[zz], id);
g_img2 = utils.GetAlbumArt(patharray[zz - 2], id);
g_img3 = utils.GetAlbumArt(patharray[zz - 1], id);
g_img4 = utils.GetAlbumArt(patharray[zz + 1], id);
g_img5 = utils.GetAlbumArt(patharray[zz + 2], id);
get_image();
gr.FillSolidRect(0, 0, ww * 6, wh, dui === 1 ? window.GetColorDUI(1) : window.GetColorCUI(3));
if (g_img && g_img2 && g_img3 && g_img4 && g_img5) {
var scale = 0;
var y = 0;
var scale_w = ww / g_img.Width;
var scale_h = wh / g_img.Height;
if (scale_w * 2 <= scale_h) {
scale = scale_w * 2;
y = (wh - g_img.Height * scale) / 2;
} else {
scale = scale_h;
var scale2 = 0;
var y2 = 0;
var scale_w2 = ww / g_img2.Width;
var scale_h2 = wh / g_img2.Height;
if (scale_w2 <= scale_h2) {
scale2 = scale_w2;
y2 = (wh - g_img2.Height * scale2) / 2;
} else {
scale2 = scale_h2;
var scale3 = 0;
var y3 = 0;
var scale_w3 = ww / g_img3.Width;
var scale_h3 = wh / g_img3.Height;
if (scale_w3 <= scale_h3) {
scale3 = scale_w3;
y3 = (wh - g_img3.Height * scale3) / 2;
} else {
scale3 = scale_h3;
var scale4 = 0;
var y4 = 0;
var scale_w4 = ww / g_img4.Width;
var scale_h4 = wh / g_img4.Height;
if (scale_w4 <= scale_h4) {
scale4 = scale_w4;
y4 = (wh - g_img4.Height * scale4) / 2;
} else {
scale4 = scale_h4;
var scale5 = 0;
var y5 = 0;
var scale_w5 = ww / g_img5.Width;
var scale_h5 = wh / g_img5.Height;
if (scale_w5 <= scale_h5) {
scale5 = scale_w5;
y5 = (wh - g_img5.Height * scale5) / 2;
} else {
scale5 = scale_h5;
gr.DrawImage(g_img, ww * 3 - g_img.Width * scale / 2, y, g_img.Width * scale, g_img.Height * scale, 0, 0, g_img.Width, g_img.Height);
gr.DrawImage(g_img2, 0, y2, g_img2.Width * scale2, g_img2.Height * scale2, 0, 0, g_img2.Width, g_img2.Height);
gr.DrawImage(g_img3, ww, y3, g_img3.Width * scale3, g_img3.Height * scale3, 0, 0, g_img3.Width, g_img3.Height);
gr.DrawImage(g_img4, ww * 5 - g_img4.Width * scale4, y4, g_img4.Width * scale4, g_img4.Height * scale4, 0, 0, g_img4.Width, g_img4.Height);
gr.DrawImage(g_img5, ww * 6 - g_img5.Width * scale5, y5, g_img5.Width * scale5, g_img5.Height * scale5, 0, 0, g_img5.Width, g_img5.Height);
gr.GdiDrawText(zz + 1, g_font, color, 10, 5, window.Width - 10, window.Height, 0x00000010);
} else {
gr.GdiDrawText("error: no stub image path defined", g_font, color2, 10, 5, window.Width - 10, window.Height, 0x00000010);
ww = window.Width / 6;
wh = window.Height;
window.Repaint();
function on_mouse_lbtn_down(x, y) {
if (x > ww * 3 && y < wh) {
if (zz === patharray.length - 1) {
zz = 0;
} else if (zz < patharray.length - 1) {
zz += 100;
if (zz >= patharray.length - 1) {
zz = patharray.length - 1;
if (x < ww * 3 && y < wh) {
if (zz === 0) {
} else if (zz > 0) {
zz -= 100;
if (zz < 0) {
zz = 0;
if (g_img) {
get_image();
window.Repaint();
function on_mouse_move() {
if (g_img) window.SetCursor(32649);
for (i = 0; i < delta; i++) {
zz++;
for (i = 0; i < -delta; i++) {
zz--;
if (zz < 0) {
} else if (zz > patharray.length - 1) {
zz = 0;
if (g_img) {
get_image();
window.Repaint();
var MF_SEPARATOR = 0x00000800;
var MF_STRING = 0x00000000;
var idx;
_menu.AppendMenuItem(MF_STRING, 1, "cover");
_menu.AppendMenuItem(MF_STRING, 2, "back");
_menu.AppendMenuItem(MF_STRING, 3, "disc");
_menu.AppendMenuItem(MF_STRING, 4, "icon");
_menu.AppendMenuItem(MF_STRING, 5, "artist");
//_menu.AppendMenuItem(MF_STRING, 5, "Properties");
_menu.AppendMenuItem(MF_STRING, 6, "Configure...");
_menu.CheckMenuRadioItem(1, 5, id + 1);
switch (idx) {
case 1:
id = 0;
break;
case 2:
id = 1;
break;
case 3:
id = 2;
break;
case 4:
id = 3;
break;
case 5:
id = 4;
break;
case 5:
break;
case 6:
_menu.Dispose();
if (g_img) {
get_image();
window.Repaint();
return true;
function on_colors_changed() {
window.Repaint();
function on_font_changed() {
window.Repaint();
Looks good. Are you planning to improve the script further
so that user don't have to go through the steps described above?
At this point this is only a testversion. The steps are only necessary after adding new albums to media library.
These new albums are simply missing in coverflow.
Maybe new albums could be added to the array by playing a track of the new album, but i don't plan to add this feature.
I would like to add something like reflection or 3d effect, but i don't know the graphic abilities of WSH panel mod, especially IGdiGraphics interface.
Maybe someone could give more information, what is possible?
samples updated: http://cid-649d3bfeaf541fbb.skydrive.live....ide/samples.zip (http://cid-649d3bfeaf541fbb.skydrive.live.com/self.aspx/.Public/foobar/guide/samples.zip)
2 minor changes
"artwork 3 in 1" now fills the panel instead of leaving gaps when the image doesn't fit. aspect is still maintained so edges will be clipped if necessary.
"simple biography" panel now stops scrolling at the right place.
i've also re-jigged lots of background stuff that you won't notice. hopefully i didn't break anything in the process.
for this, you should look at ojdo's HTPC panels thread in the uploads section. his script has reflections in.
I've got a request for a script that can do the following:
1. show tags directly from last.fm (like the biography panel)
2. write them to a tag with a button click
3. filters for tags you want to exclude/include (like in the last.fm plus plugin for picardtagger).
Would this be possible, and would anyone like to create a script like this if it is?
its possible
even without scripting experience you can do this yourself.
all you have to do is edit the scripts that are floating around here.
just take the lastfm script from marc2003 and change it so that it gets the tags from the last fm api.
filtering is the easiest part where you just add a new column with [%lastmf_tags%] for example
When I try and use any of your samples I get a script error, the only one that works is aero seekbar. I am trying to get the glass buttons and I have the modded version of wsh panel you linked too.
did you follow the instructions regarding extracting the zip into your foobar folder and turning off safe mode in the WSH panel mod preferences?
got it working, I forgot to put the scripts folder in the install dir, but I do have one issue, the playback icons for me look much blurrier than in the screenshot. here is a screen:
http://img245.imageshack.us/img245/3935/22007058.png (http://img245.imageshack.us/img245/3935/22007058.png)
that looks fine to me??
but in my screen shot i'm not using standard windows aero. i'm using a theme called win7blend found on devinatart.
They get sharper if I change the code where it says 160 / 2 to 160 / 200 (which moves them all to the left side) basically anywhere but the middle they look much shaprer, as soon as I put them back in the middle they are quite noticeably blurry for me though.
Y'll should use integer values as coordinates! Just use Math.round()
The images look blurry because they are being rendered at non-integer values i.e. 12.5 pixels.
thanks for the tip. but i still can't tell the difference. .
for anybody using this script change line 22:
pos = Math.round((ww-160) / 2);
i've updated the hosted file as well.
Thanks guys! worked great. they look perfectly sharp now.
your "rating" work in "other WSH samples (new)" have a sad problem.
when i click on the star ,nothing happens, it can't rate the song, another word , your work can only show the rating , it can't rate the rating.
i'm thinking perhaps my issue with not be able to see so clearly is that i have a crappy old CRT monitor....
anyway, samples updated with a proper readme detailing what each script does and all relevant instructions.
Pardon my ignorance but I couldn't find a way to align text drawn with the new IStyleTextRender. How do I do it?
In MainMenuManager All-In-One.txt can someone please show my how I can append the preferences entry?
add these 2 lines just before "ret = 0".
basemenu.AppendMenuItem(MF_SEPARATOR, 0, 0);
basemenu.AppendMenuItem(MF_STRING,2000,"Preferences");
then add this as the first item in the switch statement just below.
case(ret == 2000):
fb.ShowPreferences();
break;
thanks marc2003 can you please give me the code for adding a rating submenu as well contextman.Init("Rating") doesn't seem to do the trick for me.
I need help with this code:
function createPattern(w,h){
var bg = gdi.CreateImage(w,h);
var mask = gdi.CreateImage(w,h);
var g = mask.GetGraphics();
g.FillSolidRect(0,0,w,h,0xff000000);
for (i = 0; i < Math.round(h/2); i++){
g.FillSolidRect(0,i*2+1,w,1,0xffffffff);
mask.ReleaseGraphics(g);
g = bg.GetGraphics();
g.FillSolidRect(0,0,w,h,0xffffffff);
bg.ReleaseGraphics(g);
bg.ApplyMask(mask);
return bg;
This thing creates a pattern I use to paint a volume bar, my panel calls this in the on_size callback. Everything works when I press the OK button. My problem appears to be on foobar2000 startup. The console throws this: Microsoft JScript runtime error: 'null' is null or not an object Ln: 23, Col: 5 which is the line: var g = mask.GetGraphics();
Does anyone see anything stupid there?
New version of
cover browser (formerly coverflow)
(http://www.abload.de/img/coverbrowser1gyzw.jpg) (http://www.abload.de/image.php?img=coverbrowser1gyzw.jpg)
Updated instructions for filling array and arrayupdate (prerequisite):
- Select all tracks of generated playlist | rightclick | Utilities | Text Tools | Advanced | Track Pattern: "%path%", | Copy
- open an Editor (z.B. Notepad++) | Paste | Replace \ by \\ and remove last comma
- Repeat step2 with Track Pattern: "%album%", and remove last comma
- Insert in line 45 and 49 of WSH Panel mod script | Apply
http://pastebin.de/5265 (http://pastebin.de/5265)
updates and information: http://foobar-users.de/index.php?topic=200...g16441#msg16441 (http://foobar-users.de/index.php?topic=2000.msg16441#msg16441)
Marc I could not find a way to get the rating menu from the context menu so instead I created a custom menu and used fb.RunContextCommandWithMetadb. Is there a way to just populate using the context playback statistics rating menu?
nope, not possible. re-creating it with your own custom menu is the only way.
Where can I find some scripts for displaying album art with some nice effects such as reflection or shadow?
Marc I was looking through your updated samples and noticed that you switched to DrawString from GdiDrawText. I wanted to know why because according to the docs the latter is faster.
i changed because using MeasureString() to calculate text dimensions is accurate. using the gdi method isn't.
as for speed, could you really tell them apart if you had 2 panels side by side? i don't think so.
I noticed that with DrawString some characters overlap and hinting doesn't seem as good as GDIDrawText
overlapping characters? i've not seen that before. have you got a screenshot? (not that i could anything about it - i'm just curious)
I'll try to get one for you. Will have to re edit my script. Maybe it only happens with Segoe UI
Shouldn't we be able to do?
_menu.EnableMenuItem(ID, !fb.IsPlaying);
instead of
_menu.EnableMenuItem(ID, fb.IsPlaying ? 0 : 1);
is it possible to create a button for a masstagger script
and edit multiple files with it?
I Managed to do that to the now playing file, but not more than that one.
r3v0
@grimes
I have been enjoying using your cover browser script.
I did have a few issues with regard to getting working arrays.
tagarray[0]
This did not fully work for me as I have a number of compilation albums that do not have track 01 where I have removed needless duplicate tracks.
I ended up creating a playlist of my whole library and using a text format in text tools as below with skip duplicate/repeating lines ticked.
"$cut(%path%,3)\$directory(%path%,6)\\$directory(%path%,5)\\$directory(%path%,4)\\$directory(%path%,3)\\$directory(%path%,2)\\$directory(%path%,1)\\",
Obviously the number of required paths will depend on the folder structure and the last comma still needs deleting.
tagarray[1]
Using the track pattern "%album%", yielded two problems. Firstly, albums with names such as "Heroes" ended up as ""Heroes"" which causes a script error. "\"Heroes\"" needs to be used instead. Secondly, there are problems when there is more than one album of the same name, e.g. I have several called Greatest Hits but by different artists, and with these the show playing album setting often fails to display the correct cover. I ended up creating a playlist of my whole library and using a track pattern of [%album artist%] -[ '['%date%']'][ %album%] with skip duplicate/repeating lines ticked in text tools. This is much more robust and ensures all have a unique name. I changed the var album definition accordingly.
Also if you end up playing tracks not in the array, e.g. something like a playlist generated by the last.fm plug-in, where the covers are available then no covers show at all in the cover browser. It may be worth considering showing at least the central cover for tracks not in the array but where the cover is available.
It's also a pity that you cannot click on a cover and send it to a playlist or select it in the playlist.
Try to implement this feature. First Test-Version here: http://pastebin.de/5387 (http://pastebin.de/5387)
Don't know if this is possible but thought I'd ask anyway 'cos I'm totally new to scripting for WSH but trying to get to grips with it.
Basically, I've altered slightly a code from Tombarlow (thanks!) to use as a volume knob as follows -
var vcol = window.InstanceType?window.GetColorDUI(0):window.GetColorCUI(1);
var radius = 16;
var line = 3;
var offset = 3;
//gr.FillSolidRect( 0, 0, ww, wh, bg);
//gr.DrawEllipse(offset, offset, 2*radius, 2*radius, line, vcol);
function on_size()
ww = window.Width;
wh = window.Height;
voldrag = true;
y_old = y;
voldrag = false;
if(voldrag)
y_old = y;
function on_mouse_wheel(delta)
p = p + delta/10;
p = vol2pos(val);
window.Repaint();
Which works great over a .png to give a vintage "knob" style volume control, but I'm now trying to do the same thing as a seekbar dial and I'm completely baffled as to where to even start
Anyone any ideas?
@grimes
Cover browser rc5. This is working nicely. The change to using path instead of album seems to make it unnecessary to use array [1], the album array, unless sorting by array [1] is considered essential. At least I have it working fine without filling array [1] with the text previously displayed by this being directly retrieved using titleformatting.
A small bug is that the side reflection often disappears on track change. This seems to be a problem with evaluating: !(g_img2.Width * scale < ww - 0.01) in: if (reflectionside && !(g_img2.Width * scale < ww - 0.01)) as using: if (reflectionside) alone works fine.
Personally for tracks not in the array I prefer having something other than the stub images for img2, 3, 4 & 5. Currently I put the artist as img2 & 5 and repeated the front cover as img 3 & 4, but this is not necessarily ideal (I have no back, disc or icon images). Also if a track not in the array is playing and you interact with cover browser (e.g. mouse wheel scroll) it reverts to the array covers, which is fine, but it seems that you cannot then go back to the playing track cover.
@grimes
Thanks for cover browser rc6. All is working fine so far. May be the warning message something like "no stub image path defined in foobar2000 preferences" needs to go back in because if just one of the images is missing - especially for tracks not in the array - no images display. I had this problem initially and it took me a while to realise what was going on. The cursor change on mouse move over certain images with tracks not in the array is also somewhat confusing as it does nothing and it would be best if it did not happen.
Hello all,
im using
Dark-One 1.6 theme by br3tt and i came across the cool component
foo_menu_addons by Acropolis and i wanted to implement the A-B repat function in the interface on the WSH pane using JScript.
I put 4 buttons
[E] [A] [R]
E to enable the repeat
A and B to set the markers
R to reset.
What i can do :
- A and B cannot be turned ON if E is not turned ON (and it works )
- Toggle A, B and E on and off (and works)
- When i press R the E button should stay enabled and toggle off only A and B ( i didnt do that yet but i think i can figure this out easily)
What i cant do:
- when i skip track E should get disabled and disable automatically also A and B markers. Anyone can help on this?
i used this code :
var A_on = {normal: imgPath + "AOn.png", hover: imgPath + "AOn.png"};
var A_off = {normal: imgPath + "AOff.png", hover: imgPath + "AOn.png"};
var a_tooltip = "Set A Marker";
var B_on = {normal: imgPath + "BOn.png", hover: imgPath + "BOn.png"};
var B_off = {normal: imgPath + "BOff.png", hover: imgPath + "BOn.png"};
var b_tooltip = "Set B Marker";
var E_on = {normal: imgPath + "EOn.png", hover: imgPath + "EOn.png"};
var E_off = {normal: imgPath + "EOff.png", hover: imgPath + "EOn.png"};
var e_tooltip = "Enable A-B";
var R_on = {normal: imgPath + "ROn.png", hover: imgPath + "ROn.png"};
var R_off = {normal: imgPath + "ROff.png", hover: imgPath + "ROn.png"};
var r_tooltip = "Reset A-B";
var a_sw = false;
var b_sw = false;
var e_sw = false;
function genAImageSrc() {
return (a_sw & e_sw) ? A_on : A_off;
function switch_a() {
a_sw = !a_sw;
Buttons.A.alterImage(genAImageSrc());
Buttons.A.repaint();
function genBImageSrc() {
return (b_sw & e_sw) ? B_on : B_off;
function switch_b() {
b_sw = !b_sw;
Buttons.B.alterImage(genBImageSrc());
Buttons.B.repaint();
function genEImageSrc() {
return (e_sw) ? E_on : E_off;
function switch_e() {
e_sw =!e_sw
Buttons.E.alterImage(genEImageSrc());
Buttons.E.repaint();
if (!e_sw){
Buttons.A.alterImage(A_off);
Buttons.B.alterImage(B_off);
Buttons["E"] = new Button(0, 0, 13, 11, genEImageSrc(), function () { fb.RunMainMenuCommand("Playback/Repeat A-B/Enable");switch_e();}, e_tooltip);
Buttons["A"] = new Button(10, 0, 13, 11, genAImageSrc(), function () {fb.RunMainMenuCommand("Playback/Repeat A-B/Mark A");switch_a();}, a_tooltip);
Buttons["B"] = new Button(20, 0, 13, 11, genBImageSrc(), function () {fb.RunMainMenuCommand("Playback/Repeat A-B/Mark B");switch_b();}, b_tooltip);
Buttons["R"] = new Button(30, 0, 13, 11, R_off, function () {fb.RunMainMenuCommand("Playback/Repeat A-B/Reset");}, r_tooltip);
That's the first time i use JScript so dont blame me if the code is lame =P
Any help would be really appreciated
Thanks !
@powernemo:
Dark-One 1.6 is a theme by tedgo, not me
Sorry
my bad, btw seems like i cant edit so...
@powernemo:
Ok, figured out myself
(any more elegant solution of course is much appreciated)
a_sw = !a_sw;
if (a_sw) {A_active = true};
b_sw = !b_sw;
if (b_sw) {
B_active = true
if (!A_active) { // That's cause if we press B before pressing A the song will start looping frm the beginning to marker B so we wanna turn on A (even if its not so necessary)
A_active = true
a_sw = true
e_sw =!e_sw
if (!e_sw){
if ((e_sw) & (A_active)) {
Buttons.A.alterImage(A_on);
if ((e_sw) & (B_active) ){
Buttons.B.alterImage(B_on);
function reset_sw(){
a_sw = false;
b_sw = false;
e_sw =false
A_active = false
B_active = false
Buttons.E.alterImage(E_off);
function on_playback_new_track(){
reset_sw()
Buttons["R"] = new Button(30, 0, 13, 11, R_off, function () {fb.RunMainMenuCommand("Playback/Repeat A-B/Reset");reset_sw();}, r_tooltip);
a_sw = !a_sw;
b_sw = !b_sw;
if (b_sw) {
B_active = true
A_active = true
a_sw = true
e_sw =!e_sw
if (!e_sw){
a_sw = false;
b_sw = false;
e_sw =false
A_active = false
B_active = false
reset_sw()
next time you can use "codebox" bbtag and omit those horid long posts
I was using marc2003's rating script but it's not working anymore, nor is another one i found in another topic. They both show up just fine but when i click on the stars to set a rating, nothing happens.
Is there any change I could have done in the settings to brake it ?
have you got the official playback statistics component? it requires that....
http://www.foobar2000.org/components/view/foo_playcount (http://www.foobar2000.org/components/view/foo_playcount)
Yeah, it's there.
And if I right-click a song and use the Quicktagger to set the rating it works.
the script doesn't use quick tagger. what if you try and use the context menu "Playback Statistics>Rating"? if that entry isn't there, you need to enable it under preferences>display>context menu. (the script needs this enabled to work)
also, the tracks you're trying to rate must be monitored as part of the media library.
You're right. I had removed it from the context menu, I'd never figure that out lol.
Is there a way to retrieve playlist sizes and lengths?
I want to create my own playlist switcher but, I need that information.
Help required :
i want to use the SendKeys method to write in a dialog box somthing, and first, opening this dialog Box
in a WSH panel, i call this on left mouse button up :
var WshShell = new ActiveXObject("WScript.Shell");
WshShell.SendKeys("(^P)");
it should open Preferences window, but it does nothing ... i think that the focus is on the WSH panel hosting this command, so maybe i should send a {TAB} key to swap to another panel of the foobar window BEFORE trying to send Ctrl+P (^ = Ctrl key) :
WshShell.SendKeys("{TAB}");
any idea ?
@marc2003
Issue 1: still having issues with the "now playing" script. All others work and safe mode is turned off.
Whenever I turn auto download off it shows no artist pictures, not even from the tags. As soon as I stop playing a track without an artist pic the panel goes into SCRIPT ERROR. Starts working again after right click -> configure -> apply, but still without tag images. Foobar can't be closed before I do this step because art.exe stalls it. I have to manually end art.exe from the task manager and then close foobar.
Note I use your scripts from: 4/26/2010 11:47 AM.
Issue 2: a while back (page 12. posts 285, 286), I asked you if there was a way for "now playing" to display cover art instead of artist pic (swap them). You then posted the code for this on pastebin (and it worked great, many thanks), but when I checked again today, the code was gone. Would you mind re-uploading it?
Issue 3: this is probably easy, but since I'm not a coder, I only mix and match to get a result; can't quite create something new. Is it possible for "now playing" to have a three color gradient?
i have no idea why you're getting an error. check the console, see which line it is and then post what it is. auto-download is turned off by default and it's the setting i always use. you shouldn't have any problems if there are no images, it just looks like this...
(http://k5sbdw.blu.livefilestore.com/y1pEzRc3_sPI-fDYl2UCcuIpw5JWR0zyBDlP7BkkPreGsTZs-J2Wx98dbPLMj7x4F6ac-m2Gox_DUzQENe_0QC6QxFRCZszJC_j/no%20art.png)
did you overwrite all files when downloading the zip. there was a problem with art.exe hanging if artists weren't found on last.fm. i've since re-compiled it to fix that. (note i didn't write that program but the author (paradog (http://www.hydrogenaudio.org/forums/index.php?showuser=53710)) published the source code. the reason it hung is that it was waiting for user input but i hide the program so that wasn't possible. i just commented out one line of code so it exits by itself)
i suppose i can modify it not to use last.fm and the artreader instead. i'll do that later.
and no, you can't have a 3 colour gradient.
edit: i lied. you can have 3 colours if you spilt the panel. i'll post how to do that later as well.
I deleted everything related and redownloaded: seems to be working fine now, but I don't know why, since it's exactly what I did an hour before (I did a new portable install today due to getting a new hard drive). Well, if it works...
In any case, I took a short screencast (http://drop.io/f2kissue) (1min.) for reference if you should need it in the future. The error was:
Error: WSH Panel Mod (GUID: BA3A201A-5E28-425F-9B01-A3245A424D5F): Microsoft JScript runtime error:
Object required
Ln: 269, Col: 2
I'll wait patiently for your other info and "thanks" in advance.
i'm sure i told pastebin to keep it forever last time but here it is again.
http://pastebin.com/zHQxxwns (http://pastebin.com/zHQxxwns)
there are 3 variables at the top of the script to set 3 colours top_c, mid_c and bot_c
as for the error, i can only assume you were using a new script with an old version of the scripts folder in your foobar directory??
EDIT: link updated due to a small error.
Superb! I won't have time to fiddle with it now since it's midnight for me, but I'll be sure to post tomorrow if something comes up.
As for the error, yeah I guess it's possible. Since I did a fresh Windows install today I had folders and files scattered all over the desktop for me take a look at; something could have snuck by. In any case, thanks a lot for the prompt response.
I'm not really sure if this is the right place to ask, but since I'm scripting with WSH Panel mod.. Is there a way to find out the possible position of text 'live' (case insensitive) within string. For example, if I have "Song2 (live)" function would return 7 (as first character is 0).
var title = fb.TitleFormat("%title%").EvalWithMetadb(g_metadb);
var pos = title.toLowerCase().indexOf("live");
There is a script for viewing album covers on the panel has buttons to switch Folder\CD\Artist\etc. Please help make switch tracks for this buttons Previous\Play\Pause\Next.
function RGBA(r,g,b,a){
var res = 0xff000000|(r<<16)|(g<<8)|(b);
if (a!=undefined) res = (res & 0x00ffffff) | (a << 24)
return res;
// Properties Object =======================================
/* All settings store here */
var Properties = new function (){
this.Panel = {
// 0: Never, 1: When not playing, 2: Always.
FollowCursor: window.GetProperty("Panel.FollowCursor", 1),
// Where the images folders in.
WorkDirectory: fb.FoobarPath+fb.TitleFormat(window.GetProperty("Panel.WorkDirectory", "Images\\EIKO\\WSH Cover\\")).Eval(true),
// "cn": Chinese, "en": English, "auto": Auto choose, base on foobar2000 core language.
lang: window.GetProperty("Panel.Language", "auto").toLowerCase(), // Language
// Separate with comma, like "255,255,255"
BackGroundColor: window.GetProperty("Panel.BackGroundColor", ""),
Tooltip: window.CreateTooltip() // Create button's tooltip
if (typeof(this.Panel.FollowCursor)!="number")
this.Panel.FollowCursor = 1;
else if (this.Panel.FollowCursor<0)
this.Panel.FollowCursor = 0;
else if (this.Panel.FollowCursor>2)
this.Panel.FollowCursor = 2;
if (this.Panel.lang != "cn" && this.Panel.lang != "en")
this.Panel.lang = (fb.TitleFormat("$meta()").Eval(true)=="[未知函数]") ? "cn" : "en";
try {
this.Panel.FSO = new ActiveXObject("Scripting.FileSystemObject");
} catch(e) {
// Impossible to work without FSO.
fb.ShowPopupMessage(this.Panel.lang=="cn" ? "无法创建FSO对象, WSH Cover面板无法工作." : "Can not create File System Object (FSO), WSH Cover Panel can't work.", "WSH Cover Panel", 1);
new ActiveXObject("Scripting.FileSystemObject"); // End scripts running.
if (!this.Panel.FSO.FolderExists(this.Panel.WorkDirectory))
fb.ShowPopupMessage(this.Panel.lang=="cn" ? "无效的工作路径." : "Invalid work directory.", "WSH Cover Panel", 1);
if (this.Panel.BackGroundColor) {
this.Panel.BackGroundColor = this.Panel.BackGroundColor.replace(/ | /g, "");
this.Panel.BackGroundColor = this.Panel.BackGroundColor.split(",");
for (var i in this.Panel.BackGroundColor) {
if (this.Panel.BackGroundColor[i]<0)
this.Panel.BackGroundColor[i] = 0;
else if (this.Panel.BackGroundColor[i]>255)
this.Panel.BackGroundColor[i] = 255;
if (this.Panel.BackGroundColor.length<4)
this.Panel.BackGroundColor.length = 4;
this.Cycle = {
// Enable image cycle.
Enable: window.GetProperty("Cycle.Enable", true),
// Interval period.
Period: window.GetProperty("Cycle.Period", 10000),
// Cycle all the wildcard match files in image SourceFormat.
CycleInWildCard: window.GetProperty("Cycle.CycleInWildCard", true),
// Pause images cycle automatic when following cursor.
AutoPauseWhenFollowCursor: window.GetProperty("Cycle.AutoPauseWhenFollowCursor", true),
// Animations on image's changing. Not only in image cycle, but also in track switching.
Animation: {
Enable: window.GetProperty("Cycle.Animation.Enable", true),
RefreshInterval: window.GetProperty("Cycle.Animation.RefreshInterval", 50),
Duration: window.GetProperty("Cycle.Animation.Duration", 400)
if (typeof(this.Cycle.Period)!="number")
this.Cycle.Period = 7000;
else if (this.Cycle.Period<100)
this.Cycle.Period = 100;
if (typeof(this.Cycle.Animation.RefreshInterval)!="number")
this.Cycle.Animation.RefreshInterval = 50;
else if (this.Cycle.Animation.RefreshInterval<10)
this.Cycle.Animation.RefreshInterval = 10;
if (typeof(this.Cycle.Animation.Duration)!="number")
this.Cycle.Animation.Duration = 300;
else if (this.Cycle.Animation.Duration<10)
this.Cycle.Animation.Duration = 10;
this.Image = {
// Separate paths by "||"; use "|||" to separate default images and other images, only can be used once; "<embed>" means embed cover, must be a individual path in sourceformat.
SourceFormat: window.GetProperty("Image.SourceFormat", "<embed>||$directory_path(%path%)\\cover.*||$directory_path(%path%)\\folder.*"),
// In same group, if SourceFormat not changed, panel will not check any new files, and the images cycle will not be reset.
GroupFormat: window.GetProperty("Image.GroupFormat", "%album%"),
// Default image path.
DefaultImagePath: fb.TitleFormat(window.GetProperty("Image.DefaultImagePath", "Images\\EIKO\\Default.jpg")).Eval(true),
// File larger than this value will not be loaded. <=0 means no limit.
MaxFileSize: window.GetProperty("Image.MaxFileSize", 2097152),
// Keep images aspect ratio.
KeepAspectRatio: window.GetProperty("Image.KeepAspectRatio", true),
// Stretch images to fit panel.
Stretch: window.GetProperty("Image.Stretch", false),
// Images is stored after resize, so you can set this value larger if your panel size is not very large.
ImageCacheCapacity: window.GetProperty("Image.ImageCacheCapacity", 10),
// This panel also stores path search result, only stores the strings.
PathCacheCapacity: window.GetProperty("Image.PathCacheCapacity", 20),
// Only these types of files can be displayed. Not necessary to modify this at most times.
SupportTypes: new Array("jpg", "jpeg", "png", "gif", "bmp"),
// Image smoothing mode.
SmoothingMode: window.GetProperty("Image.SmoothingMode", 0),
// Image interpolation mode in resizing.
InterpolationMode: window.GetProperty("Image.InterpolationMode", 0)
if (typeof(this.Image.MaxFileSize)!="number")
this.Image.MaxFileSize = 2097152;
else if (this.Image.MaxFileSize<0)
this.Image.MaxFileSize = 0;
if (typeof(this.Image.ImageCacheCapacity)!="number")
this.Image.ImageCacheCapacity = 10;
else if (this.Image.ImageCacheCapacity<0)
this.Image.ImageCacheCapacity = 0;
if (typeof(this.Image.PathCacheCapacity)!="number")
this.Image.PathCacheCapacity = 20;
else if (this.Image.PathCacheCapacity<0)
this.Image.PathCacheCapacity = 0;
if (typeof(this.Image.SmoothingMode)!="number")
this.Image.SmoothingMode = 0;
else if (this.Image.SmoothingMode<-1)
this.Image.SmoothingMode = -1;
else if (this.Image.SmoothingMode>4)
this.Image.SmoothingMode = 4;
if (typeof(this.Image.InterpolationMode)!="number")
this.Image.InterpolationMode = 0;
else if (this.Image.InterpolationMode<-1)
this.Image.InterpolationMode = -1;
else if (this.Image.InterpolationMode>7)
this.Image.InterpolationMode = 7;
this.Buttons = {
// Whether display the control buttons.
Display: window.GetProperty("Buttons.Display", true),
// 0: topleft, 1:topright, 2:bottomleft, 3:bottomright
Position: window.GetProperty("Buttons.Position", "4")
if (typeof(this.Buttons.Position)!="number")
this.Buttons.Position = 4;
else if (this.Buttons.Position<0)
this.Buttons.Position = 0;
else if (this.Buttons.Position>5)
this.Buttons.Position = 5;
// Three funtions ==========================================
/* Calculate image's new size and offsets in new width and height range.
Use panel's default settings of stretch and ratio if they are not specified */
function CalcNewImgSize (img, dstW, dstH, srcW,srcH, strch, kar) {
if (!img) return;
if (!srcW) srcW = img.width;
if (!srcH) srcH = img.height;
if (strch==undefined) strch = Properties.Image.Stretch;
if (kar==undefined) kar = Properties.Image.KeepAspectRatio;
var size;
if (strch) {
size = {x:0, y:0, width:dstW, height:dstH};
if (kar) {
size.width = Math.ceil(srcW*dstH/srcH);
if (size.width>dstW) {
size.width = dstW;
size.height = Math.ceil(srcH*dstW/srcW);
} else {
size = {x:0, y:0, width:srcW, height:srcH};
if (kar) {
if (srcH>dstH) {
size.height = dstH;
size.width = dstW;
} else {
size.width = Math.min(srcW, dstW);
size.height = Math.min(srcH, dstH);
size.x = Math.floor((dstW-size.width)/2);
size.y = Math.floor((dstH-size.height)/2);
return size;
/* Reisze image to new width and height */
function ResizeImg (img, dstW, dstH) {
if (!img || !dstW || !dstH) return img;
if (img.width==dstW && img.height==dstH) return img;
var newimg = gdi.CreateImage(dstW, dstH);
var g = newimg.GetGraphics();
g.DrawImage(img, 0, 0, dstW, dstH, 0, 0, img.width, img.height);
newimg.ReleaseGraphics(g);
CollectGarbage(); // Release memory.
return newimg;
/* Remove an element from "this" array, return the removed element */
function RemoveFromArray (index) {
if (index==0)
return this.shift();
else if (index==this.length-1)
return this.pop();
var c = this[index];
var rest = this.slice(index+1);
this.length = index;
this.push.apply(this, rest);
return c;
// Define Image Loader ====================================
/* Loader image file from specified path. It contains a image cache.
Primarily provides the "GetImg()" method */
var ImageLoader = new function (Prop) {
var ImgCacheCapacity = Prop.Image.ImageCacheCapacity;
if (ImgCacheCapacity) {
// Cache array is always sorted, sort by last accessed.
// Array's length never change.
// No empty element, only empty "cacheitem".
// No item will really be deleted, only be deassigned.
var ImgsCache = new Array;
// Admissible size error in cache reading.
ImgsCache.ImgSizeError1 = 10; // For enlarge.
ImgsCache.ImgSizeError2 = 50; // For shrink.
// Class of the items in cache.
ImgsCache.cacheItem = function (path, imgobj) {
this.Path = path; // String.
this.ImgObj = imgobj; // Object, gdi.image() object, or empty.
this.srcW = 0; // Source width.
this.srcH = 0; // Source height
// Fill the cache array with empty cacheitems.
for (var i=0; i<ImgCacheCapacity-1; i++)
ImgsCache.push(new ImgsCache.cacheItem(null, null));
// Remove element from cache array, return the removed element.
ImgsCache.remove = RemoveFromArray;
// Store item in the beginning of the cache array. Duplicate item's "ImgObj" will be overwritten.
ImgsCache.Store = function (path, imgobj, srcW, srcH) {
var c;
if (this.SearchFor(path)) {
c = this[0]; // This is the one just found.
c.ImgObj = imgobj;
if (srcW) c.srcW = srcW;
if (srcH) c.srcH = srcH;
} else if (c = this.pop()) {
c.Path = path;
c.ImgObj = imgobj;
c.srcW = srcW ? srcW : (imgobj ? imgobj.width : 0); // Store source width.
c.srcH = srcH ? srcH : (imgobj ? imgobj.height : 0); // Store source height.
this.unshift©;
// Search in cache, find the image object.
// Resize "ImgObj" to "dst" size, if current size is not enough, and the source size is closer, remove this item and return nothing.
// Or, move it to the beginning of the cache array, then resize image, then return this cache item.
// If no result found, return nothing.
ImgsCache.SearchFor = function (path, dstW, dstH) {
var i = 0;
for (i; i<this.length; i++) // Find it.
if (this[i].Path==path)
break;
if (i<this.length) {
var c = this.remove(i);
var img = c.ImgObj;
// For resizing------------------------
if (img && dstW && dstH) {
var size = CalcNewImgSize(img, dstW, dstH, c.srcW, c.srcH);
// If image should be enlarged and it still can be enlarged...
if ((size.width>img.width && img.width<c.srcW) || (size.height>img.height && img.height<c.srcH)) {
// If the dst size is not too large...
if (size.width-img.width<this.ImgSizeError1 && size.width<c.srcW && size.height-img.height<this.ImgSizeError1 && size.height<c.srcH)
img = ResizeImg(img, size.width, size.height); // Only resize, no cache.
else {
// Return to reload image file.
this.push©;
return;
// If it's shrinking...
} else if (size.width<img.width || size.height<img.height) {
// If the dst size is too small...
if (img.width-size.width>this.ImgSizeError2 || img.height-size.height>this.ImgSizeError2) {
img = ResizeImg(img, size.width, size.height); // Resize and cache.
c.ImgObj = img;
} else
img = ResizeImg(img, size.width, size.height); // Resize and don't cache.
} else {
size = CalcNewImgSize(img, dstW, dstH);
c.ImgObj = img;
this.unshift©;
return (img || true); // If path was found, return something "true" at all times.
// Clear cache, only reset all cache items indeed.
ImgsCache.Clear = function () {
for (var i=0; i<this.length-1; i++) {
this[i].Path = null;
this[i].ImgObj = null;
this[i].srcW = 0;
this[i].srcH = 0;
// Load image file from specified path, generate gdi.image() object, resize it, cache it, then return it.
// If path invalid or file corrupt, return nothing.
this.GetImg = function (path, dstW, dstH, NoCache) {
if (!path) return;
var imgobj;
if (!NoCache && ImgsCache)
imgobj = ImgsCache.SearchFor(path, dstW, dstH);
if (imgobj) {
if (typeof(imgobj)!="object") imgobj = null; // Maybe it's a boolean value.
} else {
if (path.charAt(0)=="<") // Embed image.
imgobj = utils.GetAlbumArtEmbedded(path.substring(1, path.length-1), 0);
else
imgobj = gdi.image(path);
var srcW, srcH;
if (imgobj) {
srcW = imgobj.width;
srcH = imgobj.height;
if (dstW && dstH) {
var size = CalcNewImgSize(imgobj, dstW, dstH);
imgobj = ResizeImg(imgobj, size.width, size.height);
// Store every path, even no valid image exists.
ImgsCache && ImgsCache.Store(path, imgobj, srcW, srcH);
if (imgobj)
return imgobj;
this.ClearCache = function () {
ImgsCache && ImgsCache.Clear();
} (Properties);
var GetImg = ImageLoader.GetImg;
// Define Path Checker =====================================
/* Find matches image files in directorys. It contains a paths cache.
Primarily provides the "GetImgPaths()" method */
var PathChecker = new function (Prop, ImgLoader) {
var FSO = Prop.Panel.FSO;
var ImgSrcFmt = Prop.Image.SourceFormat;
var ImgSrcStr = "";
var SupportTypes = Prop.Image.SupportTypes;
var MaxFileSize = Prop.Image.MaxFileSize;
var CycleInWildCard = Prop.Cycle.CycleInWildCard;
var GetEmbedImg = ImgLoader;
var FoundFiles = new Array;
var PathsArray;
var PathCacheCapacity = Prop.Image.PathCacheCapacity;
if (PathCacheCapacity) {
// This cache array is similar to the images cache array.
var PathsCache = new Array;
PathsCache.FSO = FSO;
PathsCache.cacheItem = function (path, files) {
this.MatchFiles = files; // Must an array, path array.
for (var i=0; i<PathCacheCapacity-1; i++)
PathsCache.push(new PathsCache.cacheItem(null, null))
PathsCache.remove = RemoveFromArray;
// Duplicate item will be overwritten.
PathsCache.Store = function (path, files) {
var c;
this[0].MatchFiles = files;
c.Path = path;
c.MatchFiles = files;
this.unshift©;
// Search in cache, returns the search result, and move it to the beginning of the cache array.
// All files in result array will be checked before return, if one or more files doesn't exist, remove this item and return nothing.
PathsCache.SearchFor = function (path) {
var i = 0;
break;
var rslt = c.MatchFiles;
for (var j=0; j<rslt.length; j++) // Check whether all the files are exist.
if (!this.FSO.FileExists(rslt[j])) {
c.Path = null;
this.push©;
return;
this.unshift©;
return rslt;
PathsCache.Clear = function () {
this[i].MatchFiles = null;
// Union Array2 into Array1.
var unionArray = function (Array1, Array2 ) {
var seen = {};
for (var i=0; i<Array1.length; i++)
seen[Array1[i]] = true;
for (var i=0; i<Array2.length; i++)
if (!seen[Array2[i]])
Array1.push(Array2[i]);
// Calculate ImageSourceFormat, and replace <embed> with <rawpath>.
var CalcPathFmt = function (pathfmt, metadb) {
if (metadb)
var paths = fb.TitleFormat(ImgSrcFmt).EvalWithMetadb(metadb)
else
var paths = fb.TitleFormat(ImgSrcFmt).Eval();
paths = paths.replace(/<embed>/gi, "<"+metadb.RawPath+">");
return paths;
// Check file type and file size.
var IsFilePropOK = function (file) {
var ext = FSO.GetExtensionName(file).toLowerCase();
for (var i=0; i<SupportTypes.length; i++) {
if (ext==SupportTypes[i] && (MaxFileSize<=0 || file.Size<=MaxFileSize))
return true;
return false;
// Find matches image files in "ImgSrc", cache relational paths, return the valid paths array.
// If "ImgSrc" has nothing changed, return the previous array directly.
// If no valid path found, return an empty array.
this.GetImgPaths = function (metadb) {
var newsrc = CalcPathFmt(ImgSrcFmt, metadb);
if (newsrc==ImgSrcStr)
return FoundFiles; // If the source format has nothing changed, return the previous results directly.
else
ImgSrcStr = newsrc;
PathsArray = ImgSrcStr.split("||");
var NewFoundFiles = new Array;
for (var i=0; i<PathsArray.length; i++) {
var Path = PathsArray[i];
var SearchResults = PathsCache ? PathsCache.SearchFor(Path) : null;
if (!SearchResults) {
SearchResults = new Array;
var EmbedPath = Path.match(/<.*>/);
if (EmbedPath) { // Check embed cover.
EmbedPath = EmbedPath.toString();
if (GetEmbedImg(EmbedPath))
SearchResults.push(EmbedPath);
} else if (Path.indexOf("*")==-1 && Path.indexOf("?")==-1) { // If not wildcard exist.
if (!FSO.FileExists(Path)) continue;
SearchResults.push(Path);
} else { // Search in wildcard.
var foldername = FSO.GetParentFolderName(Path);
if (!FSO.FolderExists(foldername)) continue;
if (CycleInWildCard) {
// Check file type and size first -----------------
var ValidFiles = PathsCache ? PathsCache.SearchFor(foldername+"\\*") : null; // Search in cache first.
if (!ValidFiles) {
ValidFiles = new Array;
var e = new Enumerator(FSO.GetFolder(foldername).Files);
for (; !e.atEnd(); e.moveNext()) {
var file = e.item();
if (IsFilePropOK(file))
ValidFiles.push(file.Path);
PathsCache && PathsCache.Store(foldername+"\\*", ValidFiles); // Store this step's result in cache.
// Then match wildcard ------------------
var exp = FSO.GetFileName(Path);
if (exp!="*" && exp!="*.*") {
for (var j=0; j<ValidFiles.length; j++) {
if (utils.PathWildcardMatch(exp, FSO.GetFileName(ValidFiles[j])))
SearchResults.push(ValidFiles[j]);
} else
SearchResults = ValidFiles;
} else {
if (IsFilePropOK(file) && utils.PathWildcardMatch(exp, file.Name)) {
SearchResults.push(file.Path);
break; // One file per path is enough.
PathsCache && PathsCache.Store(Path, SearchResults); // Store search results for this path.
// Merge these files of this path into the final results, duplicate files will only keep one.
unionArray(NewFoundFiles, SearchResults);
if (NewFoundFiles.join()!=FoundFiles.join()) // If the result has nothing changed, return the previous results directly.
FoundFiles = NewFoundFiles;
return FoundFiles;
PathsCache && PathsCache.Clear();
ImgSrcStr = "";
} (Properties, GetImg);
var GetImgPaths = PathChecker.GetImgPaths;
// Define Display Style =====================================
/* Define style, display image and animation.
Primarily provides the "ChangeImage()" method */
var Display = new function (Prop, ImgLoader) {
this.margin = {top: 0, left: 0, bottom: 0, right: 0};
this.x = this.margin.left;
this.y = this.margin.top;
this.width;
this.height;
var EnableFading = Prop.Cycle.Animation.Enable;
var RefreshInterval = Prop.Cycle.Animation.RefreshInterval;
var step = Math.min(Math.ceil(255*RefreshInterval/Prop.Cycle.Animation.Duration),255);
var DefaultImg = gdi.image(Prop.Image.DefaultImagePath);
var ext = FSO.GetExtensionName(Prop.Image.DefaultImagePath).toLowerCase();
var DefaultRaw = null;
if (DefaultImg && ext!="png" && ext!="gif")
DefaultRaw = DefaultImg.CreateRawBitmap();
var ImgPath = null;
var CurImage = DefaultImg;
var CurRaw = DefaultRaw;
var CurSize = null;
var NewImage = null;
var NewSize = null;
var CanBeCreateRaw = true;
var opacity = 255;
var timer = null;
if (ImgLoader)
var GetImg = ImgLoader;
else
var GetImg = function () {
return gdi.image(path);
// Change now displaying image to the new one.
// "path" is a string object, or empty.
// When "path" is empty, means change to style default image (DefaultImg).
// "GroupChanged" means "GroupFormat" calculate result changes.
this.ChangeImage = function (path, GroupChanged) {
if (path==ImgPath) return;
ImgPath = path;
var newimg;
if (ImgPath) {
newimg = GetImg(ImgPath, this.width, this.height);
var ext = FSO.GetExtensionName(ImgPath).toLowerCase();
CanBeCreateRaw = ext!="png" && ext!="gif";
} else
newimg = DefaultImg;
if (EnableFading) {
if (NewImage) {
CurImage = NewImage;
//CurRaw = NewImage==DefaultImg ? DefaultRaw : (CanBeCreateRaw ? CurImage.CreateRawBitmap() : null);
CurSize = NewSize;
opacity = 255;
NewImage = newimg;
NewSize = CalcNewImgSize(NewImage, this.width, this.height);
if (!timer) timer = window.CreateTimerInterval(RefreshInterval);
} else {
CurImage = newimg;
CurRaw = ImgPath ? (CanBeCreateRaw ? CurImage.CreateRawBitmap() : null) : DefaultRaw;
CurSize = CalcNewImgSize(CurImage, this.width, this.height);
window.RepaintRect(this.x, this.y, this.width, this.height);
this.Refresh = function () {
if (ImgPath) {
CurImage = GetImg(ImgPath, this.width, this.height, true); // Get image bypass cache.
if (CurRaw) CurRaw = CurImage.CreateRawBitmap();
} else {
if (CurImage)
if (NewImage)
window.Repaint();
this.OnPaint = function (gr) {
var Img, size;
if (Img = CurImage) {
size = CurSize;
if (opacity==255 && CurRaw)
// This funtion is much more faster.
gr.GdiDrawBitmap(CurRaw, this.x+size.x, this.y+size.y, size.width, size.height, 0, 0, Img.width, Img.height);
else
gr.DrawImage(Img, this.x+size.x, this.y+size.y, size.width, size.height, 0, 0, Img.width, Img.height, 0, opacity);
if (Img = NewImage) {
size = NewSize;
gr.DrawImage(Img, this.x+size.x, this.y+size.y, size.width, size.height, 0, 0, Img.width, Img.height, 0, 255-opacity);
this.OnTimer = function (id) {
if (timer && id==timer.ID) {
if (opacity>0) {
opacity = Math.max(opacity-step,0);
} else {
CurSize = NewSize;
NewImage = null;
NewSize = null;
opacity = 255;
timer && window.KillTimer(timer);
timer = null;
//window.RepaintRect(this.x, this.y, this.width, this.height);
this.OnResize = function (ww, wh) {
this.width = ww-this.margin.left-this.margin.right;
this.height = wh-this.margin.top-this.margin.bottom;
if (ImgPath) {
CurImage = GetImg(ImgPath, this.width, this.height);
if (CurImage)
if (NewImage)
// Define Main Controler ====================================
/* Main controler of the panel,
controls images loading, changing, cycle, and paths checking */
var Controler = new function (Prop, GetImgPaths, Dsp) {
var CycleEnabled = Prop.Cycle.Enable;
this.CycleActivated = false;
var CyclePeriod = Prop.Cycle.Period;
var GroupFmt = Prop.Image.GroupFormat;
var GroupStr = null;
var ImgPaths = null;
this.CurImgPath = null;
var CurImgIdx = 0;
this.Paused = window.GetProperty("Cycle.Paused", !CycleEnabled);
var timer = null;
var _this = this;
var ChangeImg = function (arg, GroupChanged) {
switch (arg) {
case 2: // Last
CurImgIdx = ImgPaths.length-1;
break;
case 1: // Next
CurImgIdx = CurImgIdx+1<ImgPaths.length ? CurImgIdx+1 : 0;
break;
case -1: // Previous
CurImgIdx = CurImgIdx-1>=0 ? CurImgIdx-1 : ImgPaths.length-1;
break;
case -2: // First
CurImgIdx = 0;
break;
default: // Default
arg = 0;
var path = arg ? ImgPaths[CurImgIdx] : null;
toDefault(path ? false : true);
if (!GroupChanged && path==_this.CurImgPath)
return;
else
_this.CurImgPath = path;
Dsp.ChangeImage(_this.CurImgPath, GroupChanged);
var ResetTimer = function () {
if (!timer) return;
timer = window.CreateTimerInterval(CyclePeriod);
this.Play = function () {
this.Paused = false;
window.SetProperty("Cycle.Paused", this.Paused);
if (!this.CycleActivated) return;
if (!timer) timer = window.CreateTimerInterval(CyclePeriod);
this.Pause = function (p) {
if (!p) {
this.Paused = true;
if (timer) {
timer = null;
this.Next = function () {
ResetTimer();
ChangeImg(1);
this.Previous = function () {
ResetTimer();
ChangeImg(-1);
this.First = function () {
ResetTimer();
ChangeImg(-2);
this.Last = function () {
ResetTimer();
ChangeImg(2);
this.OnNewTrack = function (metadb, followcur) {
var NewImgPaths = GetImgPaths(metadb);
if (metadb)
var groupstr = fb.TitleFormat(GroupFmt).EvalWithMetadb(metadb)
else
var groupstr = fb.TitleFormat(GroupFmt).Eval();
if (GroupStr!=groupstr) {
GroupStr = groupstr;
var IsNewGroup = true;
} else
var IsNewGroup = false;
if (ImgPaths!=NewImgPaths || IsNewGroup) {
ImgPaths = NewImgPaths;
if (ImgPaths.length<=1)
SetCycleStatus(false);
else
SetCycleStatus(CycleEnabled);
ResetTimer();
ChangeImg(-2, IsNewGroup);
if (followcur && Prop.Cycle.AutoPauseWhenFollowCursor) {
this.Pause(true);
if (CurImgIdx!=0)
ChangeImg(-2);
} else
!this.Paused && this.Play();
this.OnStop = function (reason) {
if (reason<=1)
ChangeImg();
if (reason!=2) {
this.Pause(true);
ImgPaths = null;
CurImgIdx = 0;
GroupStr = null;
this.Next();
} (Properties, GetImgPaths, Display);
// Define Control Buttons ===================================
/* All button's funtions are calls of Controler's method */
if (Properties.Buttons.Display && Properties.Cycle.Enable) {
var Buttons = new function (Prop, Ctrl) {
var BtnDir = Prop.Panel.WorkDirectory + "Buttons\\";
var lang = Prop.Panel.lang;
var Position = Prop.Buttons.Position;
this.x = 0;
this.y = 0;
this.width = 0;
this.height = 0;
var opacity = 0;
var defaultOp = 150;
var hbtn = null;
var dbtn = null;
var timer = null;
var RefreshInterval = 50;
var step = 40;
var dstOp = 0;
var _this = this;
this.BtnsArray = new Array();
// Define button class ------------------------------------------------
var Button = function (x, y, img, OnClick, tiptext) {
this.x = x;
this.y = y;
this.width = img.width/4;
this.height = img.height;
this.Img = img;
this.tiptext = tiptext;
this.state = 3; // 0=normal, 1=hover, 2=down, 3=disabled
this.enabled = false;
this.OnClick = OnClick;
var Tooltip = Prop.Panel.Tooltip;
this.isXYinBtn = function (x, y) {
if (!this.enabled) return false;
return (x >= this.x && y >= this.y && x<= this.x + this.width && y <= this.y + this.height) ? true : false;
this.Draw = function (gr, op) {
if (!opacity) return;
gr.DrawImage(this.Img, this.x, this.y, this.width, this.height, this.state*this.Img.width/4, 0, this.width, this.height, 0, opacity);
this.ChangeState = function (s, enabled) {
//if (!this.enabled && !enabled) return;
if (enabled===undefined) {
if (s==this.state)
return;
else
this.state = s;
} else {
this.enabled = enabled;
this.state = enabled ? 0 : 3;
if (s==1) {
Tooltip.Text = this.tiptext;
Tooltip.Activate();
} else
Tooltip.Deactivate();
if (opacity)
// Create buttons --------------------------------
var img_play = gdi.image(BtnDir+"Play.png");
var img_pause = gdi.image(BtnDir+"Pause.png");
var img_next = gdi.image(BtnDir+"Next.png");
var img_prev = gdi.image(BtnDir+"Prev.png");
var xOffset = this.x;
this.BtnsArray.push(new Button(xOffset, this.y, img_prev, function(){Ctrl.Previous();}, lang=="cn" ? "上一张图片" : "Previous Image"));
xOffset += this.BtnsArray[this.BtnsArray.length-1].width;
this.BtnsArray.push(PlayBtn = new Button(xOffset, this.y, img_play, function(){SetPauseStatus(Ctrl.Paused)}, ""));
this.BtnsArray.push(new Button(xOffset, this.y, img_next, function(){Ctrl.Next();}, lang=="cn" ? "下一张图片" : "Next Image"));
PlayBtn.tiptext_play = lang=="cn" ? "循环封面" : "Cycle Covers";
PlayBtn.tiptext_pause = lang=="cn" ? "暂停循环" : "Pause Cycle";
PlayBtn.tiptext = Ctrl.Paused ? PlayBtn.tiptext_play : PlayBtn.tiptext_pause;
PlayBtn.img_pause = img_pause;
PlayBtn.img_play = img_play;
PlayBtn.Img = Ctrl.Paused ? PlayBtn.img_play : PlayBtn.img_pause;
PlayBtn.ChangeState(null, true);
this.PlayBtn = PlayBtn;
this.width = xOffset-this.x;
this.height = PlayBtn.height;
this.SetCycleStatus = function (s) {
this.BtnsArray[0].ChangeState(null, s);
this.BtnsArray[2].ChangeState(null, s);
this.SetPauseStatus = function (s) {
if (s) {
PlayBtn.Img = PlayBtn.img_pause;
PlayBtn.tiptext = PlayBtn.tiptext_pause;
} else {
PlayBtn.Img = PlayBtn.img_play;
PlayBtn.tiptext = PlayBtn.tiptext_play;
var isXYinBtns = function (x, y) {
return (x >= _this.x && y >= _this.y && x<= _this.x + _this.width && y <= _this.y + _this.height) ? true : false;
var Fading = function (dstop) {
if (dstOp==dstop) return;
dstOp = dstop;
for (var i=0; i<this.BtnsArray.length; i++)
this.BtnsArray[i].Draw(gr, opacity);
this.OnMouseMove = function (x, y) {
if (isXYinBtns(x, y)) {
if (opacity!=255) {
dstOp = 255;
opacity = 255;
} else if (opacity!=defaultOp)
Fading(defaultOp);
if (dbtn) {
if (dbtn.isXYinBtn(x, y))
dbtn.ChangeState(2);
else
dbtn.ChangeState(1);
} else {
for (var i=0; i < this.BtnsArray.length ; i++)
if (this.BtnsArray[i].isXYinBtn(x,y)) {
if (hbtn!=this.BtnsArray[i]) {
if(hbtn) hbtn.ChangeState(0);
hbtn = this.BtnsArray[i];
hbtn.ChangeState(1);
break;
if (i==this.BtnsArray.length) {
if (hbtn) {
hbtn = null;
this.OnLbtnDown = function (x, y) {
if (hbtn) {
dbtn = hbtn;
this.OnLbtnUp = function (x, y) {
if (dbtn) {
if (dbtn.state==2) {
dbtn.OnClick();
dbtn = null;
this.OnMouseMove(x, y);
this.OnMouseLeave = function () {
Fading(0);
if (hbtn) {
hbtn = null;
if (opacity==dstOp) {
timer = null;
} else {
if (opacity<dstOp)
opacity = Math.min(opacity+step, dstOp);
else
opacity = Math.max(opacity-step, dstOp);
if (Position==1 || Position==4)
this.x = (ww-this.width)/2;
else if (Position==2 || Position==5)
this.x = ww-this.width;
if (Position>2)
this.y = wh-this.height;
var x = this.x;
for (var i=0; i<this.BtnsArray.length; i++) {
this.BtnsArray[i].x = x;
x += this.BtnsArray[i].width;
this.BtnsArray[i].y = this.y;
this.width = x-this.x;
} (Properties, Controler);
} else
var Buttons = {};
// Functions Menu ========================================
var FuncMenu = new function (Prop, Ctrl, Dsp, Btns, ImgLoader, ImgFinder) {
// Flags ----------
var MF_ENABLED = 0x00000000;
var MF_GRAYED = 0x00000001;
var MF_DISABLED = 0x00000002;
var MF_UNCHECKED = 0x00000000;
var MF_CHECKED = 0x00000008;
var MF_POPUP = 0x00000010;
var MF_RIGHTJUSTIFY = 0x00004000;
var ItemList = {};
var ItemID = 1;
var BuildMenu = function (items) {
var menu = window.CreatePopupMenu();
var mf, id, radio;
for (var i=0; i<items.length; i++) {
mf = items[i].Flag || MF_STRING;
id = items[i].ID || ItemID++;
menu.AppendMenuItem(mf, id, items[i].Caption);
if (i==items.Radio)
radio = id;
ItemList[id] = items[i];
radio && menu.CheckMenuRadioItem(1, items.length, radio);
return menu;
// Submenu: Follow Cursor -------------------------
var Menu_FC_Items = new Array(
Caption: lang=="cn" ? "仅在非播放时" : "Only when not playing",
Func: function(){
if (Prop.Panel.FollowCursor==1) return;
Prop.Panel.FollowCursor = 1;
window.SetProperty("Panel.FollowCursor", 1);
Menu_FC_Items.Radio = 0;
if (fb.IsPlaying)
on_playback_new_track(fb.GetNowPlaying());
else
on_item_focus_change(fb.GetFocusItem());
RebuildMenu();
Caption: lang=="cn" ? "总是" : "Always",
Func: function(){
if (Prop.Panel.FollowCursor==2) return;
Prop.Panel.FollowCursor = 2;
window.SetProperty("Panel.FollowCursor", 2);
Menu_FC_Items.Radio = 1;
RebuildMenu();
Caption: lang=="cn" ? "从不" : "Never",
Func: function(){
if (Prop.Panel.FollowCursor==0) return;
Prop.Panel.FollowCursor = 0;
window.SetProperty("Panel.FollowCursor", 0);
Menu_FC_Items.Radio = 2;
if (fb.IsPlaying)
else
on_playback_stop(0);
RebuildMenu();
var fc = Prop.Panel.FollowCursor;
Menu_FC_Items.Radio = fc==1 ? 0 : fc==2 ? 1 : fc==0 ? 2 : null;
var Menu_SubItem_FC = {
Flag: MF_POPUP,
Caption: lang=="cn" ? "光标跟随模式" : "Follow Cursor",
// Submenu: Image Stretching ----------------------
var Menu_IS_Items = new Array(
Flag: Prop.Image.Stretch ? MF_CHECKED : MF_UNCHECKED,
Caption: lang=="cn" ? "拉伸图像" : "Stretch Image",
Func: function(){
Prop.Image.Stretch = !Prop.Image.Stretch;
window.SetProperty("Image.Stretch", Prop.Image.Stretch);
this.Flag = Prop.Image.Stretch ? MF_CHECKED : MF_UNCHECKED;
Dsp && Dsp.Refresh();
RebuildMenu();
Flag: Prop.Image.KeepAspectRatio ? MF_CHECKED : MF_UNCHECKED,
Caption: lang=="cn" ? "保持比例" : "Keep Aspect Ratio",
Func: function(){
Prop.Image.KeepAspectRatio = !Prop.Image.KeepAspectRatio;
window.SetProperty("Image.KeepAspectRatio", Prop.Image.KeepAspectRatio);
this.Flag = Prop.Image.KeepAspectRatio ? MF_CHECKED : MF_UNCHECKED;
RebuildMenu();
var Menu_SubItem_IS = {
Flag: MF_POPUP,
Caption: lang=="cn" ? "图像拉伸" : "Image Stretching",
// Main menu --------------------------------
var Item_cycle = {
Flag: MF_ENABLED,
cap_play: lang=="cn" ? "继续循环" : "Resume Cycle",
cap_pause: lang=="cn" ? "暂停循环" : "Pause Cycle",
Caption: null,
Func: function () {Ctrl && SetPauseStatus(Ctrl.Paused);}
Item_cycle.Caption = Ctrl.Paused ? Item_cycle.cap_play : Item_cycle.cap_pause;
var Item_VWEV, Item_OIF;
var Menu_Items = new Array (
Item_cycle,
Flag: MF_GRAYED,
Caption: lang=="cn" ? "上一张图片" : "Previous Image",
Func: function(){Ctrl & Ctrl.Previous();}
Flag: MF_GRAYED,
Caption: lang=="cn" ? "下一张图片" : "Next Image",
Func: function(){Ctrl && Ctrl.Next();}
Flag: MF_GRAYED,
Caption: lang=="cn" ? "第一张图片" : "First Image",
Func: function(){Ctrl && Ctrl.First();}
Flag: MF_GRAYED,
Caption: lang=="cn" ? "最后一张图片" : "Last Image",
Func: function(){Ctrl && Ctrl.Last();}
Item_VWEV = {
Flag: MF_GRAYED,
Caption: lang=="cn" ? "在外部查看器中查看" : "View With External Viewer",
Func: function(){
var path = Ctrl.CurImgPath;
if (!path) return;
if (path.charAt(0)=="<") {
fb.ShowPopupMessage(lang=="cn" ? "当前图片为内嵌图片,无法用外部查看器显示" : "This image is embed image, can't be displayed in external viewer", "WSH Cover Panel", 1);
return;
if (!Prop.Panel.ShellObj)
Prop.Panel.ShellObj= new ActiveXObject("Shell.Application");
Prop.Panel.ShellObj.ShellExecute('"' + path + '"', "", "", "open", 1);
Item_OIF = {
Flag: MF_GRAYED,
Caption: lang=="cn" ? "打开图片所在目录" : "Open Containing Folder",
Func: function(){
if (!path) return;
path = path.substring(1, path.length-1);
Prop.Panel.ShellObj.ShellExecute("explorer", '/select,\"' + path + '"', "", "open", 1);
Flag: MF_SEPARATOR // Insert separator.
Menu_SubItem_IS // Insert "Image Stretching" submenu.
Menu_SubItem_FC // Insert "Follow Cursor" submenu.
Flag: MF_SEPARATOR
Caption: lang=="cn" ? "刷新图片" : "Refresh Image",
Func: function(){Dsp && Dsp.Refresh();}
Flag: (Prop.Image.ImageCacheCapacity || Prop.Image.PathCacheCapacity) ? MF_ENABLED : MF_GRAYED,
Caption: lang=="cn" ? "清除缓存" : "Clear Cache",
Func: function () {
ImgLoader && ImgLoader.ClearCache();
ImgFinder && ImgFinder.ClearCache();
Flag: MF_SEPARATOR
Caption: lang=="cn" ? "WSH Cover 参数设置..." : "WSH Cover Properties...",
Func: function(){window.ShowProperties();}
Caption: lang=="cn" ? "帮助..." : "Help...",
Func: function(){
var HelpFile = Prop.Panel.WorkDirectory + "WSH_Cover_Properties_Help.txt";
if (!Prop.Panel.FSO.FileExists(HelpFile)) {
fb.ShowPopupMessage(Prop.Panel.lang=="cn" ? "找不到 "+HelpFile+" 文件." : "Can not find file "+HelpFile+" .", "WSH Cover Panel", 1);
return;
var file = Prop.Panel.FSO.OpenTextFile(HelpFile, 1);
var txt = file.ReadAll();
fb.ShowPopupMessage(txt, "WSH Cover Panel", 2);
file.Close();
this.ViewWithExternalViewer = Item_VWEV.Func;
this.Menu_Items = Menu_Items;
var Menu, Menu_FC;
var RebuildMenu = function(){
ItemList = {};
ItemID = 1;
Menu_FC = BuildMenu(Menu_FC_Items);
Menu_SubItem_FC.ID = Menu_FC.ID;
Menu_IS = BuildMenu(Menu_IS_Items);
Menu_SubItem_IS.ID = Menu_IS.ID;
Menu = BuildMenu(Menu_Items);
this.RebuildMenu = RebuildMenu;
RebuildMenu();
this.Show = function (x, y) {
var ret = Menu.TrackPopupMenu(x, y);
if (ret!=0)
ItemList[ret].Func();
for (var i=1; i<5; i++)
Menu_Items[i].Flag = s ? MF_ENABLED : MF_GRAYED;
RebuildMenu();
if (s)
Item_cycle.Caption = Item_cycle.cap_pause;
else
Item_cycle.Caption = Item_cycle.cap_play;
RebuildMenu();
var IsDefaultImg = true;
this.toDefault = function (s) {
if (s==IsDefaultImg) return;
IsDefaultImg = s;
Item_VWEV.Flag = s ? MF_GRAYED : MF_ENABLED;
Item_OIF.Flag = s ? MF_GRAYED : MF_ENABLED;
RebuildMenu();
} (Properties, Controler, Display, Buttons, ImageLoader, PathChecker);
function SetCycleStatus (s) {
Controler.CycleActivated = s;
Buttons.SetCycleStatus && Buttons.SetCycleStatus(s);
FuncMenu && FuncMenu.SetCycleStatus(s);
function SetPauseStatus (s) {
if (s)
Controler.Play();
else
Controler.Pause();
Buttons.SetPauseStatus && Buttons.SetPauseStatus(s);
FuncMenu && FuncMenu.SetPauseStatus(s);
function toDefault (s) {
FuncMenu && FuncMenu.toDefault(s);
// BackGround ===========================================
var bgcolor = Properties.Panel.BackGroundColor;
if (bgcolor)
bgcolor = RGBA(bgcolor[0], bgcolor[1], bgcolor[2], bgcolor[3]);
function on_paint(gr){
gr.SetSmoothingMode(Properties.Image.SmoothingMode);
gr.SetInterpolationMode(Properties.Image.InterpolationMode);
if (bgcolor)
gr.FillSolidRect(0, 0, ww, wh, bgcolor);
Display.OnPaint && Display.OnPaint(gr);
Buttons.OnPaint && Buttons.OnPaint(gr);
function on_size(){
if (!window.Width || !window.Height) return;
ww = window.Width;
wh = window.Height;
Display.OnResize && Display.OnResize(ww, wh);
Buttons.OnResize && Buttons.OnResize(ww, wh);
// Track events ---------------------------------------------
function on_item_focus_change(){
if (fb.GetFocusItem() && (Properties.Panel.FollowCursor==2 || (Properties.Panel.FollowCursor==1 && !fb.IsPlaying)))
Controler.OnNewTrack && Controler.OnNewTrack(fb.GetFocusItem(), true);
function on_playback_new_track(metadb){
if (Properties.Panel.FollowCursor<=1)
Controler.OnNewTrack && Controler.OnNewTrack(metadb);
function on_playback_stop(reason){
var metadb = fb.GetFocusItem();
if (Properties.Panel.FollowCursor==0 || !metadb)
Controler.OnStop && Controler.OnStop(reason);
else if (Properties.Panel.FollowCursor==1 && reason!=2)
Controler.OnNewTrack && Controler.OnNewTrack(metadb, true);
// Mouse events --------------------------------------------
var rbtnDown, ShiftDown, mbtnDown;
function on_mouse_move(x,y){
Buttons.OnMouseMove && Buttons.OnMouseMove(x, y);
function on_mouse_lbtn_down(x,y){
Buttons.OnLbtnDown && Buttons.OnLbtnDown(x, y);
Buttons.OnLbtnUp && Buttons.OnLbtnUp(x, y);
function on_mouse_leave(){
Buttons.OnMouseLeave && Buttons.OnMouseLeave();
function on_mouse_rbtn_down(x, y, vkey){
rbtnDown = true;
ShiftDown = vkey==6 ? true : false;
function on_mouse_rbtn_up(x, y, vkey){
if (!rbtnDown) return true;
rbtnDown = false;
if (ShiftDown)
return; // If shift key was pressed down, show default right click menu.
else {
FuncMenu.Show(x,y); // Show customize menu.
return true; // Disable default right click menu.
function on_mouse_mbtn_down(x, y, mask) {
mbtnDown = true;
function on_mouse_mbtn_up(x, y, mask) {
if (!mbtnDown) return;
FuncMenu.ViewWithExternalViewer();
mbtnDown = false;
function on_mouse_wheel(delta){
if (delta>0)
Controler && Controler.Previous();
else
Controler && Controler.Next();
function on_timer(id){
Controler.OnTimer && Controler.OnTimer(id);
Display.OnTimer && Display.OnTimer(id);
Buttons.OnTimer && Buttons.OnTimer(id);
http://maf.freedom-vrn.ru/Images.zip (http://maf.freedom-vrn.ru/Images.zip)
I have used Songbird before and they have a add-on called MashTape. I like the plugin and was wondering if there was a WSH script to get some similar functionality.
What I really like is the reviews. Has anyone developed a script to pull down reviews from say AMG or something?
marc2003 an idea for a panel
Using http://www.youtube.com/rssls (http://www.youtube.com/rssls) to display popular videos (links to) in a panel.
Marc2003: I'm using your Now Playing - panel but it seems that autodownload doesn't work with artists with "&" in their names (like Emerson, Lake & Palmer). Is there any way to make this work besides copying the images manually from last.fm?
there shouldn't be any problem with & in the artist name - i have plenty of images downloaded just fine.
i'm unable to test that artist because i'm running linux at the moment and WSH panel mod doesn't work in it.
I tried this with different artists, and it seems to retrieve anything before "&", for example "B.B. King & Eric Clapton" gets images from "B.B. King", "Echo & the bunnymen" downloads images from artist called "Echo" etc.
i see. i'll take another look when i'm back on windows again.
it was an old version of art.exe (http://www.hydrogenaudio.org/forums/index.php?showtopic=77425&st=0) not handling the & that was the problem. but the author (paradog (http://www.hydrogenaudio.org/forums/index.php?showuser=53710)) has fixed it ages ago.
as before, you can't use that version as it will hang waiting for user input when the artist doesn't exist. so you'll need my modified version. i've updated my samples with it....
http://cid-649d3bfeaf541fbb.skydrive.live....ide/samples.zip (http://cid-649d3bfeaf541fbb.skydrive.live.com/self.aspx/.Public/foobar/guide/samples.zip)
Much appreciated, works fine now.
@marc2003: I just discovered your "now playing.txt" script. It is exactly what I was looking for:
- automatic artist images download
- and cycle them
- display the song infos on top of that
==> THANK YOU!
How would I make a "text button," as in display a string that acts like a hyperlink button? I want to do something like this:
Now playing: Title (http://) by Artist (http://)
Where the
Title is a text button for
Quicksearch for Same / Title, and the
Artist text button for
Quicksearch for Same / Artist
Is it possible with WSH Panel Mod to change the active tab in CUI? I want to switch to my Now Playing Tab when playback starts.
I have two questions:
Is there a way to drop a shadow in real-time, without additional graphics?
How can I make the reflection effect seen in CUI playlist viewer?
I use gr.GdiDrawBitmap for displaying album art at the moment.
i'm having problems with the rating script in marc2003's sample package.
it shows my track ratings just fine, but i can't set them. clicking on stars has no effect.
i have foo_playcount installed...
any thoughts?
check "playback statistics" is enabled on your context menu.
that fixes it, thanks!
another question for you, marc2003
in this post you put up a script for a button that tags tracks with %love%
http://www.hydrogenaudio.org/forums/index....st&p=685807 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=685807)
but it uses foo_customdb. is there a way to have a Love button like this that actually writes to the tag?
i use quick tagger right now to set %love% to 1 or 0 with keyboard shortcuts, but would like to have a button too.
thanks
use that same script on pastebin but change
line 29:
func = function() { g_metadb.UpdateFileInfoSimple("love", ''); }
line 34:
func = function() { g_metadb.UpdateFileInfoSimple("love", 1); }
cool, thanks
Hello, everyone. I am very new to creating WSH panel mod scripts. I've managed to read enough to learn how to make a working volume and playback slider so I have a basic understanding of how things work but I'm trying to create a track info "ticker" that scrolls the now playing info across a window (not bounce back and forth) and it seems to be quite a bit more complicated. I'm not asking for someone to do my work for me, I'm just hoping someone could point me/tell me if I'm headed in the right direction as far as how I might go about creating this. Anyways, here are my attempts to understand how I might go about doing this:
on a new track, use this titleformatting script of the now playing item as a string "%track% - %artist% - %album%" and constantly make it scroll to the right by 1px increments
get the last character of the string
get the width of the last character of the string
delete the last character of the string
insert the last character of the string at beginning when the string has been scrolled to the right a distance equal to the width of the last character which was just deleted
To instruct the info to be gathered each time a new track is played I know I'll need to use: function on_playback_new_track(metadb) {}
I will need to update these variables each time the string is scrolled a distance equal to the width of the last character (I am going to use "hello" as an example string because I am unsure of how to get the "%track% - %artist% - %album%" of the currently playing track at the moment).
var ww = window.Width;
var wh = window.Height;
var txt = "hello"
var lastpos = txt.length-1;
var info = txt.replace(txt.charAt(-1), txt.charAt(lastpos));
var info_new = info.slice(0, -1)
I don't think I've got this quite right yet but this is the effect I want to acheive:
hello
then "hello" continues to scroll to the right until the o is no longer visible in the window at which time it will be inserted before h...
ohell
then "ohell" continues to scroll to the right until the l is no longer visible in the window at which time it will be inserted before o...
lohel
etc...
What I DON'T want is for it to happen like this:
hello
ohell
oohell
ooohell
etc...
Maybe I'm going about this task completely wrong and you know a much more simple way. In that case I'd love to hear it. Thanks
Thank you so much for any advice.
here is one example: http://www.hydrogenaudio.org/forums/index....st&p=670657 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=70363&view=findpost&p=670657)
Thanks. I saw one similar to that but the one thing I wanted to do differently is to have it scroll in just one direction over and over again. I might be wrong, but it seems like achieving this would require something very different than how the script does it there.
Maybe you looking something like this?
function RGB(r, g, b) {
return (0xff000000 | (r << 16) | (g << 8) | (b));
var g_font = gdi.font("Tahoma", 24, 0);
var g_timer;
var i = 0;
var interval = 20;
var tw = 0;
function on_paint(gr) {
gr.SetTextRenderingHint(5);
var text = fb.TitleFormat("%title% - %artist% - %album%").Eval();
tw = gr.CalcTextWidth(text, g_font);
if (fb.IsPlaying) {
if (g_timer) {
gr.GdiDrawText(text, g_font, RGB(0, 0, 0), ww - i, 20, ww + tw, g_font.height + 5, format = 0)
function on_timer(id) {
i = i + 1 * 1;
if (i == ww + tw) i = 0;
window.RepaintRect(ww - i -10, 17, tw + 20, g_font.height + 6);
function on_size() {
ww = window.Width;
wh = window.Height;
if (i == 0) g_timer = window.CreateTimerInterval(interval);
i = 0;
window.Repaint();
Thank you so much, ExtremeHunter! Hahaha I can't believe I how complicated my ideas were compared to this.
While I was trying to figure out how to get the automated scrolling, i managed to modify one of the wsh panel mod samples so that it allows the info to be dragged horizontally back and forth in case the window isn't displaying all of the text. I'm sure there is a better way of doing this too but I thought I'd share it since it took me so much work to figure out (you'll probably notice some strange things going on here since i'm not very experienced, but it works just fine):
var DT_VCENTER = 0x00000004;
var DT_CALCRECT = 0x00000400;
var DT_NOPREFIX = 0x00000800;
var DT_SINGLELINE = 0x00000020;
var DT_END_ELLIPSIS = 0x00008000;
var DT_WORD_ELLIPSIS = 0x00040000;
var g_text;
var g_font = gdi.Font("Tahoma", 10);
var ww = 0, wh = 0;
var g_textcolor = 0xff787878;
var g_need_calc = true;
var g_textheight = 0;
var g_offset = 0;
var g_drag = false;
var g_drag_x = 0;
var g_textwidth;
var title_tf = fb.TitleFormat("%title%");
var album_tf = fb.TitleFormat("%album%");
var artist_tf = fb.TitleFormat("%artist%");
var title;
var album;
var artist;
ww = window.Width;
wh = window.Height;
reset();
if(fb.IsPlaying) on_playback_new_track();
g_metadb = fb.GetNowPlaying();
artist = artist_tf.EvalWithMetadb(g_metadb);
title = title_tf.EvalWithMetadb(g_metadb);
album = album_tf.EvalWithMetadb(g_metadb);
g_text = title + " - " + artist + " - " + album;
g_textwidth = gr.CalcTextWidth(g_text, g_font);
if (g_need_calc) {
calc();
} else {
if(fb.IsPlaying) {
gr.GdiDrawText(g_text,g_font, g_textcolor, g_offset, 1, ww - g_offset, wh, DT_VCENTER | DT_END_ELLIPSIS | DT_NOPREFIX | DT_SINGLELINE);
function on_mouse_lbtn_down(x) {
g_drag = true;
g_drag_x = x;
function on_mouse_lbtn_up(x) {
g_drag = false;
g_offset=0;
window.Repaint();
function on_mouse_move(x) {
if (g_drag) {
applyDelta(x - g_drag_x);
g_drag_x = x;
function calc() {
var temp_bmp = gdi.CreateImage(1, 1);
var temp_gr = temp_bmp.GetGraphics();
arr = temp_gr.GdiDrawText(g_text, g_font, g_textcolor, 0, 0, ww, wh, DT_VCENTER | DT_SINGLELINE | DT_CALCRECT | DT_NOPREFIX).toArray();
g_offset = 0;
g_need_calc = false;
temp_bmp.ReleaseGraphics(temp_gr);
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
window.Repaint();
function applyDelta(delta) {
var temp = g_offset + delta;
if ((temp <= ww / 2) && (temp >= ww / 2 - g_textwidth)) {
g_offset = temp;
window.Repaint();
function reset() {
g_need_calc = true;
g_offset = 0;
Gentlemen, I wonder if any of you good scripters might be up to a bit of a challenge?
I've seen quite a few nice title bar panels throughout the thread, but I don't quite have the knowledge to figure out exactly what I need to make this work.
First of all, here's a picture of my setup:
(http://img38.imageshack.us/img38/7632/foobarsetup.jpg)
What I'd like is a panel that replicates the behavior of titlebar (highlighted in red), but better. Perhaps having the time segment permantly placed at the left hand side without having to make two seperate panels as in this instance. I also wouldn't mind having color controls over different parts of the tag information.
But anyway, I realize this isn't a request thread, but if anyone has a script that might help me get started, please let me know. Thanks.
maybe a easy task?
what's the current panel that shows time and info now?looks so bad
if my brain works,i guess what you want is a panel which can show the info and time in fixed places.
pin out your idea in a picture to let me get the right idea in your brain.....or what you want is just a WSH panel which can realize the effect in your current photo?
. And like I said, I'd also love if it had $rgb support.
here you go-
function RGB(r,g,b) {
return (0xff000000|(r<<16)|(g<<8)|(b));
var DT_CENTER = 0x00000001;
var ww = 0, wh = 0;
var g_textcolor = RGB(19,240,236);
var g_backcolor = RGB(0,0,0);
var g_font = gdi.Font("Segoe UI", 26,1);
ww = window.Width;
wh = window.Height;
gr.FillSolidRect(0, 0, ww, wh, g_backcolor);
if(fb.IsPlaying) {
gr.GdiDrawText(fb.TitleFormat("%playback_time%[ / %length%]").Eval(), g_font, g_textcolor, 0, 0, 250, wh, DT_VCENTER | DT_CENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(fb.TitleFormat("[%tracknumber% [/ %totaltracks% ]- ]%title%").Eval(), g_font, g_textcolor, 250, 0, ww-270, wh, DT_VCENTER | DT_CENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
window.Repaint();
function on_playback_stop(reason) {
if(reason != 2) window.Repaint();
function on_playback_time() {
window.Repaint();
I love you
Hello ExtremeHunter, I have this old script that is a scrollbar with now playing info. It works well (for me) except for the scroll speed that is very slow. Do you think that your script can be adapted to this? Or you know another way to make this modify? I'm not a programmer so I don't know how to make working changes
Many thanks in advance
Fabio
var weight_normal =400;
var weight_bold =800;
var italic_no =0;
var italic =1;
var uline_no =0;
var uline =1;
var align_top =0;
var align_middle=1;
var align_bottom=2;
var align_left =0;
var align_center=1;
var align_right =2;
var trim_no =0;
var trim_chara =1;
var trim_word =2;
var trim_elips_chara =3;
var trim_elips_word =4;
var trim_elips_path =5;
var flag_rtl =0x0001;
var flag_vert =0x0002;
var flag_nofit =0x0004;
var flag_dispctrl =0x0020;
var flag_nofallback =0x0400;
var flag_trailspace =0x0800;
var flag_nowrap =0x1000;
var flag_linelimit =0x2000;
var flag_noclip =0x4000;
function StrFmt(alignH,alignV,trim,flag){ return ((alignH<<28)|(alignV<<24)|(trim<<20)|flag); }
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
function RGBA(r,g,b,a){ return ((a<<24)|(r<<16)|(g<<8)|(b)); }
function TimeFmt(t){
var zpad = function(n){
var str = n.toString();
return (str.length<2) ? "0"+str : str;
var h = Math.floor(t/3600); t-=h*3600;
var m = Math.floor(t/60); t-=m*60;
var s = Math.floor(t);
if(h>0) return h.toString()+":"+zpad(m)+":"+zpad(s);
return m.toString()+":"+zpad(s);
var g_font = gdi.Font( "bitstream vera sans mono",40);
var g_font1 = gdi.Font( "bitstream vera sans mono",40);
var g_timeFmt = fb.TitleFormat("%playback_time%[ / %length%]");
var g_titleFmt = fb.TitleFormat("%ARTIST% - %title%");
var g_fileinfo = null;
var g_drag = 0;
var g_drag_seek = 0;
var tic_ArtistAlbumText= { size:26, step:1};
var tic_SongTimeText= { size:20, step: 2};
resetTics();
var pos = 0;
var length = fb.PlaybackLength;
var songTimeText;
var artistAlbumText;
if(length > 0){
if(g_drag){
pos = window.Width * g_drag_seek;
songTimeText= "Seek " + TimeFmt(g_drag_seek * length) + " / " + TimeFmt(length);
} else{
pos = window.Width * (fb.PlaybackTime / length);
songTimeText= g_timeFmt.Eval();
artistAlbumText = g_titleFmt.Eval();
gr.FillGradRect( 0, 0, pos, wh, 90, RGB(5,150,35), RGB(5,100,35)); //green scroll
gr.FillGradRect(pos, 0, ww-pos, wh, 90, RGB(0,0,0), RGB(0,0,0)); //black background
if(artistAlbumText==null) artistAlbumText= "";
gr.DrawString(getScrolledText(artistAlbumText, tic_ArtistAlbumText), g_font, RGB(255,255,255), 0, 0, ww, wh, StrFmt(align_left, align_center, trim_no, flag_nowrap | flag_noclip));
if(songTimeText==null) songTimeText= "";
gr.DrawString(getScrolledText(songTimeText, tic_SongTimeText), g_font1, RGB(255,255,255), 0, 0, ww, wh, StrFmt(align_right, align_center, trim_no, flag_nowrap | flag_noclip));
function getScrolledText(txt,tic) {
if(txt.length<=tic.size)
return txt;
if(tic.val>=(txt.length+tic.spacer.length))
tic.val= 0;
else
tic.val+= tic.step;
return (txt+tic.spacer+txt).substring(tic.val, tic.val+tic.size);
function resetTics() {
tic_ArtistAlbumText.val=0;
tic_ArtistAlbumText.spacer= "";
for(var i=0; i<=(tic_ArtistAlbumText.size/2); i++) tic_ArtistAlbumText.spacer+=' ';
tic_SongTimeText.val=0;
tic_SongTimeText.spacer= "";
for(var i=0; i<=(tic_SongTimeText.size/2); i++) tic_SongTimeText.spacer+=' ';
function on_size(){
resetTics();
function on_focus(focused){
//fb.trace("focus " + focused);
function on_key_down(key){
//fb.trace("key " + key);
g_drag = 1;
if(g_drag){
g_drag = 0;
g_drag_seek = x / window.Width;
g_drag_seek = (g_drag_seek<0) ? 0 : (g_drag_seek<1) ? g_drag_seek : 1;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
if(g_drag){
window.Repaint();
//fb.trace("wheel " + delta);
function on_playback_starting(cmd, paused){
resetTics();
function on_playback_new_track(info){
resetTics();
window.Repaint();
function on_playback_stop(){
resetTics();
window.Repaint();
function on_playback_seek(time){
window.Repaint();
function on_playback_pause(state){
function on_playback_edited(){
function on_playback_dynamic_info(){
function on_playback_dynamic_info_track(){
function on_playback_time(time){
window.Repaint();
function on_volume_change(val){
//EOF
@Fabio258
Well your scroll uses per second window update and mine uses different timing, so they cannot be overlaped like this, but i made a little compromise . It's a quick and ugly hack but ...
link (http://pastebin.com/MTpeeKRs)
@Fabio258
Many thanks, but it returns me this error:
Error: WSH Panel Mod (GUID: 97DC514D-0A5C-4D8F-875B-57D83D56C051): Errore di compilazione di Microsoft JScript:
Errore di sintassi
Ln: 242, Col: 7
else
Fabio
How is that possible? There is only 206 lines in the script and your error is in line 242.
I'm sorry, my mistake, having hurry to try before going to work, I didn't realize that copying and pasting the script had been added strange characters.
Now it works fine. I'm sorry that it's not possible to group all in one line because I use a seven inch touch screen monitor and have optimized the layout for this size, but obviously I can't have everything.
Thanks again
Fabio
samples updated:
http://cid-649d3bfeaf541fbb.office.live.co...ide/samples.zip (http://cid-649d3bfeaf541fbb.office.live.com/self.aspx/.Public/foobar/guide/samples.zip)
contains a new script that displays thumbnails of images in a folder.
-no support for scrolling in thumbnail view if you have too many images to fit in the panel (in full view, you can use the mouse wheel to scroll through all images)
-it chokes a bit if you have a folder full of lots of large images
Hello
I'm trying to open album art with default Windows image viewer using wscript.shell. For some reason I get "source text only available in compile time" error with below script. g_metadb is defined.
var img_path = fb.titleformat("$replace(%path%,%filename_ext%,front.jpg)").EvalWithMetadb(g_metadb);
function(){WshShell.run("file://" + img_path);}
I tested a simple version (below) which works fine, so problem is with img_path variable. Also seems to work without "file://".
function(){WshShell.run("file://C:/1.png");}
Just a little update with my problem. Figured WScript.Shell doesn't like backslashes or spaces. img_path.replace(/\\/g, "/") sorted the slashes but I have no clue what to do with spaces. Googleing suggested using double or triple quotes but these give errors in wsh panel.
Maybe this helps.
var WshShell = new ActiveXObject("WScript.Shell");
function on_mouse_lbtn_dblclk() {
g_metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
try {
WshShell.Run("\"" + img_path + "\"");
} catch (e) {};
Thanks "\"" + img_path + "\"" worked
[a href="http://matthijsb.deviantart.com/art/foo-silk-4-0-beta-4-170546750" target="_blank"]
i've updated my scripts with some last.fm charts as well....
(http://k5sbdw.blu.livefilestore.com/y1pHULdeilWf2E7ivYcLNqXXY1_Y5o9eMVLsY3_EQe5EthfocPbttGVRSBGHhgd_-jPTmPNN3YYviNqAJLw3rBCmQIBHxjifpaj/lastfm%20charts.png)
features:
click the last.fm logo in the top right to switch between artist, album and track. you can also change the period.
the text is clickable and it will open the corresponding page in your web browser
the artist charts have "play" buttons which will launch last.fm radio directly in foobar (requires foo_lastfm radio (http://www.unkempt.co.uk/fb2k/foo_lastfm_radio.html))
charts update once a day but you can force an update using the context menu if you really must
samples updated: http://cid-649d3bfeaf541fbb.office.live.co...ide/samples.zip (http://cid-649d3bfeaf541fbb.office.live.com/self.aspx/.Public/foobar/guide/samples.zip)
just a bug fix for the last.fm charts - they'd never update automatically as i got my cached file age calculation wrong.
I´m trying to add some fields and edit a little this track info script (http://www.hydrogenaudio.org/forums/index.php?showtopic=79057&st=0&p=714222&#entry714222), thanks Hitchhiker427 and Marc2003 for the code! and I kind a need some help...
I´m using the line "playback = fb.TitleFormat("%playback_time%").EvalWithMetadb(g_metadb);" along with the gr.GdiDrawText one
to display the playback time but it always shows up "?".
Also how can I align the text to the left instead of using the "center of the word/field" so that I can align all the info such as playback time, bitrate, etc in the left like using a tab? Maybe replacing the "DT_CENTER" value?
Is it possible as well, to display the sample rate "in the natural behavior" like %filesize_natural% such that if it´s "48000 Hz" it displays "48 Khz" and what´s the syntax of the volume say in db to display it too? I couldn´t find it in the help files.
Here´s what I´m using:
var image_path = fb.FoobarPath + "colores personalizados\\";
var g_img = gdi.Image(image_path + "Fondo Azul.bmp");
var background_width = 220;
var background_height = 300;
var artist = title = album = track = '';
var bgcolor = RGB(238,246,253);
var textcolor1 = RGB(249, 249, 249);
var textcolor2 = RGB(249, 249, 249);
var font1 = gdi.Font("Segoe UI", 14, 1);
var font2 = gdi.Font("Segoe UI", 14, 1);
var font3 = gdi.Font("Segoe UI", 10, 0);
g_metadb = fb.GetFocusItem();
on_item_focus_change();
gr.DrawImage(g_img, 0, 0, ww, wh, 0, 0, background_width, background_height);
if(g_metadb) {
gr.GdiDrawText(title, font1, textcolor1, 0, 0, ww, 24, DT_CENTER | DT_END_ELLIPSIS | DT_NOPREFIX);
gr.GdiDrawText(artist, font2, textcolor2, 0, 17, ww, 24, DT_CENTER | DT_END_ELLIPSIS | DT_NOPREFIX);
gr.GdiDrawText(album, font3, textcolor2, 0, 40, ww, 24, DT_CENTER | DT_END_ELLIPSIS | DT_NOPREFIX);
gr.GdiDrawText(track, font3, textcolor2, 0, 50, ww, 24, DT_CENTER | DT_END_ELLIPSIS | DT_NOPREFIX);
gr.GdiDrawText(channels, font3, textcolor2, 148, 3, ww, 24, DT_CENTER | DT_END_ELLIPSIS | DT_NOPREFIX);
gr.GdiDrawText(playback, font3, textcolor2, 144, 16, ww, 24, DT_CENTER | DT_END_ELLIPSIS | DT_NOPREFIX);
gr.GdiDrawText(bitrate, font3, textcolor2, 155, 29, ww, 24, DT_CENTER | DT_END_ELLIPSIS | DT_NOPREFIX);
gr.GdiDrawText(samplerate, font3, textcolor2, 155, 42, ww, 24, DT_CENTER | DT_END_ELLIPSIS | DT_NOPREFIX);
ww = window.Width;
wh = window.Height;
artist = fb.TitleFormat("$replace([%artist%],_, )$replace($stripprefix($substr([%title%],1,$sub($strstr(%title%,-),2)),-),_, )").EvalWithMetadb(g_metadb);
title = fb.TitleFormat("$replace($stripprefix($substr([%title%],$strstr(%title%,-),1000),-),_, )").EvalWithMetadb(g_metadb);
album = fb.TitleFormat("[%album%] ['('%date%')']").EvalWithMetadb(g_metadb);
track = fb.TitleFormat("[Track # %tracknumber%]").EvalWithMetadb(g_metadb);
channels = fb.TitleFormat("%channels%").EvalWithMetadb(g_metadb);
bitrate = fb.TitleFormat("%bitrate% Kbps").EvalWithMetadb(g_metadb);
samplerate = fb.TitleFormat("%samplerate% Hz").EvalWithMetadb(g_metadb);
window.Repaint();
function on_item_focus_change() {
if (g_metadb) window.UnwatchMetadb();
if (g_metadb) {
on_metadb_changed();
window.WatchMetadb(g_metadb);
@Wooops:
For the playback time, try using "playback = fb.TitleFormat("%playback_time%").Eval()".
For left aligning, try just removing DT_CENTER altogether... I think that will work.
Next, I'm not sure what to do about the natural sample rate. I'm almost sure that there's an easy way to do it. However, here's a brute-force method. This will get the job done, but hopefully someone can post something more efficient:
sample_rate = fb.TitleFormat("%samplerate%").Eval();
if(sample_rate.substring(sample_rate.length - 3, sample_rate.length) == "000") sample_rate = sample_rate.substring(0,sample_rate.length - 3);
else {
sample_rate = sample_rate.substring(0,sample_rate.length - 3) + "." + sample_rate.substring(sample_rate.length - 3,sample_rate.length);
if(sample_rate.substring(sample_rate.length - 1, sample_rate.length) == "0") sample_rate = sample_rate.substring(0, sample_rate.length - 1);
sample_rate = sample_rate + " kHz";
Finally, the volume is just "fb.Volume"
Now, I have a question for myself. I'm trying out Columns UI, and I'm just wondering if there's a way to show/hide panels with WSH Panel Mod. If so, how would I go about doing that? I know this is possible with PSS, but I'm unfamiliar with that scripting language, and would prefer to use WSH Panel Mod if at all possible. Thanks.
@Hitchhiker427
or just
gr.GdiDrawText(sample_rate/1000+" kHz", font, textcolor, 155, 42, ww, 24, 0);
I don't think that can be done without PSS.
@Hitchhiker427
uh well I had been playing... The playback and the volume show up, but they don´t get updated I´ve to manually refresh* the panel each time...
and with the volume I used the code from another sample to limit the decimals "volume = fb.TitleFormat(Math.ceil(fb.volume)+" dB").EvalWithMetadb(g_metadb); though It would be better with two decimals as F2K does.
Also I realized that sometimes the title overlapped the right side info, so I limited it´s width "gr.GdiDrawText(title, font1, textcolor1, 0, 0, 305, 24, D.." but then the title is no longer centered so I created a "DT_CENTER2" for the title, with no luck with the values so far.
"For left aligning, try just removing DT_CENTER altogether... I think that will work."
Removing it worked perfectly and both sample rate script works great too.
Thanks for the help.
Edit: In asking there´s no trick so I wonder is it possible to move the title to the bottom (more centered) when there´s no album or track info?
samples updated:
Great!
There is some request.
1. Multiple folder support.
2. Image size fit to panel size.
3. External viewer launch mode.
4. Thumbs centering.(now exist rest on right)
5. Glow effect.
6. Thumbs size editing.
Of course, It is not compulsion.
1) done, just remember it will be slow if you have too many images. use | to separate folders in custom folder dialog box.
2) there was already an option to fill the panel (with cropping). you can untick the "Fill" context menu item to show the whole image.
3) done
4) already does??
5) not really sure what you mean by this??
6) i haven't added an option for editing as such but i've added some choices for size on the context menu.
^i just re-uploaded because i totally fudged the multiple folder support. it should work now.
3) done
4) already does??
Oh..., Thank you!!!
1. How I can Limit number of image each folder?
or..., Is it possible add paging function same as google image search?
And 'slow' mean inside WSH Panel Mod panel? or affect fb2k playback?
2. I see. Thank you.
3. Thank you.
4. Umm, Like iTunes grid view, it is centering total.
5. I'm sorry. misstake. "glass effect" is correct. like cd art display skins.
Also I thinking reflection effect.(like iTunes cover flow.)
6. Thank you.
There is new ideas.
7. If panel area is spacious, Thumbs and big image show same time.
8. Use concurrent Last.fm artist art mode and Custom folder mode.
Now I operate "set 'data_folder + $crc32(%artist%)' to Custom folder->get lastfm image->set custom folder mode".
9. "Open this image" assign to Middle click.
10. Edit Last.fm artist art download folder path.
I want use like this.
C:\Image\Artist\$replace(%artist%,\,-,/,-,:,-,*,-,?,-,",-,<,-,>,-,|,-)\
Well, please develop and maintain this script.
You may not do all.
You need not conform to these.
Of course, you can say "Do it yourself.".
OK. Thank you.
1) it only slows down the panel. you might find clicking on an image to "maximise" it is slow. and also scrolling images if they are too many to fit in the panel can also be slow. i might think about adding pagination support.
5) if you have an overlay image i could use, i could add it....
7) & 8) maybe i'll think about it.
9) done. download again using the link above
10) you can change the path used by last.fm mode by editing the title formatting on line 83.
I´ve got the playback and volume refreshing adding
gr.GdiDrawText(fb.TitleFormat("%playback_time%").Eval(), font3, textcolor2, 310, 16, ww, 24, DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(fb.TitleFormat(Math.ceil(fb.volume)+" dB").Eval(), font3, textcolor2, 307, 29, ww, 24, DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
window.Repaint();
function on_volume_change(val) {
window.Repaint();
Solved the position of the title too.
About moving the title to the bottom when there´s no album/track. I tried this:
g_metamiss = fb.TitleFormat("(%album% MISSING) AND (%tracknumber% MISSING)");
g_metahas = fb.TitleFormat("(%album% PRESENT) OR (%tracknumber% PRESENT)");
if(g_metadb) {
if(g_metahas) {
gr.GdiDrawText(title, font1, textcolor1, 0, 0, 305, 24, DT_CENTER | DT_END_ELLIPSIS | DT_NOPREFIX);
if(g_metamiss) {
gr.GdiDrawText(title, font1, textcolor1, 0, 30, 305, 24, DT_CENTER | DT_END_ELLIPSIS | DT_NOPREFIX);
It displays two titles and not sure what to do/try next. Help is appreciated. btw if the questions are too silly just point me to the documentation/samples. Thanks
you're trying to use query stuff like MISSING / PRESENT in standard title formatting and you can't do that. have a look at $meta and $meta_test
http://wiki.hydrogenaudio.org/index.php?ti...ence#Metadata_2 (http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Titleformat_Reference#Metadata_2)
Thank you very much.
1) I see. another idea: Like autopagerize.(userscript on modern browser. auto addition page when scroll.)
5) I have some overlay image. but these are small on maximized image. umm.
I do not think glass effect are necessary.
But now this script gui appearance is very simplicity.(Yes, I know this is sample script.)
I may want little decorate.
9) Thank you.
10) OK. but I hope this script get function that use custom folder and lastfm artist image simultaneous.
Thank you.
Hello everybody,
I would like to understand more how works WSH Panel Mod and I'm trying to understand some scripts. I would like to do a button that fade on and out, between normal and hover state. I would like to know if someone has a "little" script in order to do that ? I found some ideas in Br3tt skin, but a little help would be welcome !
Thanks !
Take a look to my Duifoon (http://browse.deviantart.com/customization/skins/media/foobar2000/#/d2u7d16) button scritpts, you may get some ideas. I have there image and text button script with fading effect.
Thank you, I will take a look !
Would like to know if it is possible to do something like this : Create buttons in PSS and I would like to make a border that will fade around that button with WSH.
I have found how to draw my button in front of the WSH panel. Here is my code for the WSH panel
var g_foc = 0;
if(g_foc){
gr.FillSolidRect(0,0,window.Width,window.Height,RGB(0,0,0));
else {
gr.FillSolidRect(0,0,window.Width,window.Height,RGB(100,100,100));
g_foc = 1;
window.Repaint();
function on_mouse_leave(x,y){
if(g_foc){
g_foc = 0;
window.Repaint();
I wanted just for a test make the WSH panel become black when the mouse pass on and grey when it is not focused.
Here is what I have first:
(http://img38.imageshack.us/img38/5757/27491813.jpg)
When the mouse is on the WSH panel (it works fine)
(http://img192.imageshack.us/img192/7329/16045676.jpg)
But when the mouse focused the button in PSS, the WSH panel seems to not be still focused.
(http://img341.imageshack.us/img341/4824/40592805.jpg)
So my question, is it possible that the WSH panel is still focused (so black) when the button is pointing ?
Hey guys,
This is my work in progress, right now it is currently 3 WSH panels, I will eventually merge them into 1 hopefully soon.
One question, I put both Similar Artist & Rating codes together, and I can't figure out how to isolate the RATING button click to just the stars area.
Whenever I click in the panel, the star rating will correspond with the X axis position, so clicking on the similar artists doesn't go to their last.fm website.
(http://img525.imageshack.us/img525/9213/sidebar1r.jpg)
The code is a little messy, let me know if you need more details, since I hope to release this DUI eventually.
// ==PREPROCESSOR==
// @import "%fb2k_path%scripts\simple_buttons.js"
// @import "%fb2k_path%scripts\utils.js"
// @import "%fb2k_path%scripts\marc2003\v2\common.js"
// ==/PREPROCESSOR==
var bw = 13;
var bh = 13;
var left_margin = 48;
var top_margin = 89;
var Buttons;
var g_metadb;
var section = "SIMILARPANEL";
var rating;
var nrating;
var lrating;
var img;
var panel_id = window.GetProperty("panel_id", window.id);
var custom_background_file = settings_path + panel_id + "buttons_background";
var custom_background = read(custom_background_file);
var g_drag = 0;
var g_tfo = fb.TitleFormat("%rating%");
var artist = ""
var album = ""
var title = ""
var codec = ""
var bitrate = ""
var played = ""
var codecprofile = ""
var played = ""
var genre = ""
var lastartist = ""
var lastplay = ""
var rating = ""
var last1 = ""
var last2 = ""
var last3 = ""
var last4 = ""
var playing = "0"
var playcount = "0";
var year = 0;
var date = 0;
var difyear = 0;
var date2 = 0;
var avgdate = 0;
var difdate = 0;
var today = 0;
var ar_days = 0;
var ar_years = 0;
var ar_days2 = 0;
var ar_years2 = 0;
var ar_days3 = 0;
var ar_years3 = 0;
var ar_days4 = 0;
var ar_years4 = 0;
var bitrate = 0;
var days = 0;
var hours = 0;
var minutes = 0;
var seconds = 0;
var on_playback_new_track2 = 0;
var playcount2 = 0;
var playcount3 = 0;
var playcount4 = 0;
var avgplaycount = 0;
var minplaycount = 0;
var maxplaycount = 0;
var ranplaycount = 0;
var devplaycount = 0;
var test = 0;
var test2 = 0;
var dui = window.InstanceType;
var g_font = dui == 1 ? window.GetFontDUI(0) : window.GetFontCUI(0);
//var color = RGB(200,0,0);
var color = dui == 1 ? window.GetColorDUI(2) : RGB(200,0,0);
//var color2 = RGB(0,0,0);
var color2 = dui == 1 ? window.GetColorDUI(0) : window.GetColorCUI(0);
var color3 = RGB(255,99,71);
//global Variables for text field
var DT_TOP = 0x00000000;
var DT_LEFT = 0x00000000;
var DT_RIGHT = 0x00000002;
var DT_BOTTOM = 0x00000008;
var DT_WORDBREAK = 0x00000010;
var DT_EXPANDTABS = 0x00000040;
var DT_TABSTOP = 0x00000080;
var DT_NOCLIP = 0x00000100;
var DT_EXTERNALLEADING = 0x00000200;
var DT_INTERNAL = 0x00001000;
var DT_EDITCONTROL = 0x00002000;
var DT_PATH_ELLIPSIS = 0x00004000;
var DT_MODIFYSTRING = 0x00010000;
var DT_RTLREADING = 0x00020000;
var DT_NOFULLWIDTHCHARBREAK = 0x00080000;
var DT_HIDEPREFIX = 0x00100000;
var DT_PREFIXONLY = 0x00200000;
var defaultartistimage = "";
var lastfmdatapath = "";
var g_tooltip = window.CreateTooltip();
var g_down = false;
var timer = null;
var btn_down = null;
var cur_btn = null;
window.GetProperty("currentArtists", "");
window.GetProperty("bio_played", "");
function reloadConf(inipath)
skinpath = translatePath(utils.ReadINI(inipath, "SKIN", "imgpath", ""),true);
window.GetProperty("buttons.show", utils.ReadINI(inipath, section, "showbuttons", "0"));
window.GetProperty("buttons.list", utils.ReadINI(inipath, section, "buttons", ""));
window.GetProperty("font.name", utils.ReadINI(inipath, section, "fontname", "Segoe UI"));
window.GetProperty("font.size", utils.ReadINI(inipath, section, "fontsize", "10"));
window.GetProperty("buttons.width", utils.ReadINI(inipath, section, "buttonswidth", "110"));
window.GetProperty("buttons.height", utils.ReadINI(inipath, section, "buttonsheight", "38"));
lastfmdatapath = translatePath(utils.ReadINI(inipath, "LASTFM", "datapath"),true);
updateButtons();
reloadConf(inipath);
function on_script_unload()
utils.WriteINI(inipath, section, "showbuttons", window.GetProperty("buttons.show"));
utils.WriteINI(inipath, section, "buttons", window.GetProperty("buttons.list"));
utils.WriteINI(inipath, section, "fontname", window.GetProperty("font.name"));
utils.WriteINI(inipath, section, "fontsize", window.GetProperty("font.size"));
utils.WriteINI(inipath, section, "buttonswidth", window.GetProperty("buttons.width"));
utils.WriteINI(inipath, section, "buttonsheight", window.GetProperty("buttons.height"));
function ArtistButton(x, y, w, h, img, func, tiptext, url) {
this.left = x;
this.top = y;
this.w = w;
this.h = h;
this.right = x + w;
this.bottom = y + h;
this.func = func;
this.url = url;
this.font = gdi.Font(window.GetProperty("font.name"), window.GetProperty("font.size"), 0);
this.color = RGB(255,255,255);
this.state = ButtonStates.normal;
this.img= img;
this.lastfmcommand = url;
this.alterImage = function(img_src) {
this.img= img_src ? gdi.Image(img_src) : null;
this.changeState(this.state);
this.traceMouse = function (x, y) {
var b = (this.left < x) && (x < this.right) && (this.top < y) && (y < this.bottom);
if (b)
g_down ? this.changeState(ButtonStates.down) : this.changeState(ButtonStates.hover);
else
this.changeState(ButtonStates.normal);
return b;
this.changeState = function (newstate) {
if (newstate != this.state)
window.RepaintRect(this.left, this.top, this.w, this.h);
this.state = newstate;
switch (this.state)
case ButtonStates.normal:
break;
case ButtonStates.hover:
case ButtonStates.down:
this.font = gdi.Font(window.GetProperty("font.name"), window.GetProperty("font.size"), 4);
this.color = RGB(0,92,185);
break;
default:
this.img = null;
this.draw = function (gr) {
gr.DrawRect(this.left, this.top, this.h, this.h, 1.0, RGB(170,170,170));
this.img && gr.DrawImage(this.img, this.left + 2, this.top + 2, this.h -3, this.h -3, 0, 0, Math.min(this.img.Width, this.img.Height), Math.min(this.img.Width, this.img.Height));
gr.GdiDrawText(this.tiptext, this.font, this.color, this.left + this.h + 3, this.top + 3, this.w - this.h - 3 , this.h -3, DT_VCENTER | DT_NOPREFIX | DT_WORDBREAK|DT_END_ELLIPSIS);
this.onClick = function () {
this.func && this.func(x,y);
this.onRightClick = function (x,y)
var _menu = window.CreatePopupMenu();
var idx;
var buttontocreate = window.GetProperty("buttons.list").split(";");
var numbersearchengines = 0;
if (buttontocreate != null)
for (var i in buttontocreate)
var text = getWebServiceName(buttontocreate[i], this.tiptext);
if (text != "")
_menu.AppendMenuItem(MF_STRING, numbersearchengines +1, text);
numbersearchengines += 1;
_menu.AppendMenuItem(MF_SEPARATOR, 0, 0);
_menu.AppendMenuItem(MF_STRING, numbersearchengines + 1, "Update LastFM data");
_menu.AppendMenuItem(MF_SEPARATOR, numbersearchengines + 2, 0);
_menu.AppendMenuItem(MF_STRING, numbersearchengines + 3, getWebServiceName("lastfmsimilarradio", this.tiptext));
_menu.AppendMenuItem(MF_SEPARATOR, numbersearchengines + 4, 0);
_menu.AppendMenuItem(MF_STRING, numbersearchengines +5, "Properties");
//_menu.AppendMenuItem(MF_STRING, 7, "Configure...");
idx = _menu.TrackPopupMenu(x, y);
if (idx <= numbersearchengines)
launchWebService(buttontocreate[idx - 1], this.tiptext);
else if (idx == numbersearchengines + 1)
window.NotifyOthers("ask_lastfm_data", "");
else if (idx == numbersearchengines + 3)
launchWebService("lastfmsimilarradio", this.tiptext);
else
_menu.Dispose();
this.onMouseIn = function() {
g_tooltip.Text = this.tiptext;
g_tooltip.Activate();
this.onMouseOut = function() {
g_tooltip.Deactivate();
function buttonsDraw(gr) {
for (i in Buttons) {
Buttons[i].draw(gr);
function buttonsTraceMouse(x, y) {
var btn = null;
if (Buttons[i].traceMouse(x, y) && !btn)
btn = Buttons[i];
return btn;
updateButtons();
timer = null;
CollectGarbage(); // Release memory.
var btn = buttonsTraceMouse(x, y);
if (btn != cur_btn) {
cur_btn && cur_btn.onMouseOut();
btn && btn.onMouseIn();
cur_btn = btn;
function on_mouse_lbtn_down(x, y) {
if (g_metadb) {
g_drag = 1;
nrating = Math.ceil((x - left_margin) / bw);
if (nrating > 5) nrating = 5;
if (nrating != lrating) {
lrating = nrating;
window.Repaint();
g_down = true;
btn_down = cur_btn;
if (cur_btn) {
cur_btn.changeState(ButtonStates.down);
function on_mouse_lbtn_up(x, y, mask) {
if (mask & MK_SHIFT)
window.ShowConfigure();
else
if (cur_btn) {
cur_btn.changeState(ButtonStates.hover);
if( btn_down == cur_btn )
cur_btn.onClick(x, y);
g_down = false;
if (lrating !=rating && g_metadb) bool = fb.RunContextCommandWithMetadb("Rating/"+((lrating==0) ? "<not set>" : lrating),g_metadb);
function on_mouse_leave() {
on_metadb_changed()
if (cur_btn) {
cur_btn.changeState(ButtonStates.normal);
function on_mouse_rbtn_up(x, y) {
buttons_menu(x,y);
return true;
ww = window.Width;
wh = window.Height;
updateButtons();
g_drag = 0;
rating = g_tfo.EvalWithMetadb(g_metadb);
if (rating == "?") rating = 0;
lrating = rating;
window.Repaint();
// Background
gr.FillSolidRect(0, 0, ww, wh, RGB(0,0,0));
buttons_background(gr);
if (g_metadb) {
for (i = 1; i < 6; i++) {
img = gdi.image(images_path + ((i > (g_drag ? lrating : rating)) ? "off.png" : "on.png"));
gr.DrawImage(img, left_margin + bw * (i-1), top_margin, bw, bh, 0, 0, img.Width, img.Height);
buttonsDraw(gr);
gr.GdiDrawText("Artist: " + artist, g_font, color, 5, 5, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
gr.GdiDrawText("Title: " + title, g_font, color, 5, 25, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
if (playing === 1){
gr.GdiDrawText("Album: " + album +" " + "("+ date + ")", g_font, color, 5, 45, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
gr.GdiDrawText("Album:", g_font, color, 5, 45, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
gr.GdiDrawText("Genre: " + genre, g_font, color2, 5, 65, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
gr.GdiDrawText("Rating: ", g_font, color2, 5, 85, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
if (playing === 1){
if (playcount === 0){
gr.GdiDrawText("Played: never", g_font, color2, 5, 105, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
if (playcount === 1){
gr.GdiDrawText("Played: " + playcount + " time", g_font, color2, 5, 105, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
gr.GdiDrawText("Played: " + playcount + " times", g_font, color2, 5, 105, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
gr.GdiDrawText("Played:", g_font, color2, 5, 105, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
if (playing === 1){
gr.GdiDrawText("Codec: " + codec +"-"+ codecprofile + " -- " + bitrate+" "+"Kbit/s", g_font, color2, 5, 125, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
gr.GdiDrawText("Codec:", g_font, color2, 5, 125, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
if (playing === 1) {
if (Math.floor(ar_years) === 0) {
gr.GdiDrawText("Added: " + ar_days, g_font, color2, 5, 145, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
gr.GdiDrawText("Added: " + ar_days + " (" + Math.floor(ar_years) + " years)", g_font, color2, 5, 145, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
gr.GdiDrawText("Added:", g_font, color2, 5, 145, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
if (playing === 1){
if (playcount === 0) {
gr.GdiDrawText("First Played: never", g_font, color2, 5, 165, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
gr.GdiDrawText("Last Played: never", g_font, color2, 5, 185, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
if (Math.floor(ar_years2) === 0) {
gr.GdiDrawText("First Played: " + ar_days2, g_font, color2, 5, 165, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
gr.GdiDrawText("First Played: " + ar_days2 + " (" + Math.floor(ar_years2) + " years) ", g_font, color2, 5, 165, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
if (Math.floor(ar_years3) === 0) {
gr.GdiDrawText("Last Played: "+ ar_days3, g_font, color2, 5, 185, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
gr.GdiDrawText("Last Played: "+ ar_days3 + " (" + Math.floor(ar_years3) + " years) ", g_font, color2, 5, 185, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
gr.GdiDrawText("First Played:", g_font, color2, 5, 165, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
gr.GdiDrawText("Last Played:", g_font, color2, 5, 185, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
// gr.GdiDrawText("Artist Playcount: " + last1, g_font, color2, 5, 205, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
gr.GdiDrawText("Artist Listeners: " + last2, g_font, color2, 5, 235, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
gr.GdiDrawText("Album Playcount: " + last3, g_font, color2, 5, 255, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
if (playing === 1){
gr.GdiDrawText("Artist Played: " + window.GetProperty("bio_played")+ " times", g_font, color2, 5, 205, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
else{
gr.GdiDrawText("Artist Played:", g_font, color2, 5, 205, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
gr.GdiDrawText("Similiar Artists:", g_font, color2, 5, 285, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
function on_notify_data(name, info)
switch (name)
case "lastfm_similarArtists":
window.SetProperty("currentArtists", info);
updateButtons();
break;
case "config_updated":
reloadConf(info);
break;
case "lastfm_bio":
var res = info.split("%separator%");
window.SetProperty("bio_played", res[2]);
if ( window.GetProperty("bio_played") == "")
window.SetProperty("bio_played","0");
window.Repaint();
default:
break;
function updateButtons() {
delete Buttons;
Buttons = null;
if(window.GetProperty("currentArtists") != "")
var x = 10;
var y = 310;
varartistsArray = window.GetProperty("currentArtists").split(";");
Buttons = new Array (varartistsArray.length);
var currentartist = "";
for (var i in varartistsArray)
switch (i % 2)
case 0:
currentartist = varartistsArray[i];
break;
case 1:
//skinpath
var currentartisturl = varartistsArray[i];
if (currentartist != "")
var img = gdi.Image(lastfmdatapath + ansi(currentartist) + "_small.jpg");
if(img == null)
img = gdi.Image(lastfmdatapath + ansi(currentartist) + "_small.png");
if(img == null)
img= gdi.Image(lastfmdatapath + ansi(currentartist) + "_small.gif");
if(img == null)
img= gdi.Image(skinpath + "Last.fm.small.png");
Buttons[i] = new ArtistButton(x, y, parseInt(window.GetProperty("buttons.width")), parseInt(window.GetProperty("buttons.height")), img, function(){WshShell.run(this.lastfmcommand);}, currentartist, currentartisturl);
if (x + 2*window.GetProperty("buttons.width") + 5 > ww)
y = y + parseInt(window.GetProperty("buttons.height")) + 5;
x = 10;
else
x = x + parseInt(window.GetProperty("buttons.width")) + 5;
break;
window.Repaint();
on_playback_new_track2++;
artist = fb.Titleformat("%artist%").Eval();
album = fb.TitleFormat("%album%").Eval();
title = fb.TitleFormat("%title%").Eval();
genre = fb.Titleformat("%genre%").Eval();
codec = fb.Titleformat("%codec%").Eval();
bitrate = fb.Titleformat("%bitrate%").EvalWithMetadb(g_metadb);
codecprofile = fb.Titleformat("%codec_profile%").Eval();
rating = fb.TitleFormat("$if(%rating%,$repeat($char(9733),%rating%),)").Eval();
last1 = fb.Titleformat("%lastfm_artist_playcount%").EvalWithMetadb(g_metadb);
last2 = fb.Titleformat("%lastfm_artist_listeners%").EvalWithMetadb(g_metadb);
last3 = fb.Titleformat("%lastfm_album_playcount%").EvalWithMetadb(g_metadb);
last4 = fb.Titleformat("%lastfm_album_listeners%").EvalWithMetadb(g_metadb);
playing = 1;
playcount = fb.TitleFormat("%play_count%");
playcount = playcount.Eval();
playcount = parseInt(playcount);
playcount2 += playcount;
playcount4 += playcount;
playcount3 += (playcount * playcount);
if (on_playback_new_track2 === 1) {
minplaycount = playcount;
maxplaycount = playcount;
last1 = addCommas(last1)
last2 = addCommas(last2)
last3 = addCommas(last3)
last4 = addCommas(last4)
date = fb.TitleFormat("%date%");
date = date.Eval();
date = parseInt(date);
dt = new Date();
year = dt.getFullYear();
difyear = year - date;
date2 = date2 + date;
if (on_playback_new_track2 >= 2) {
avgdate = date2 / on_playback_new_track2;
avgdate = Math.round(avgdate);
difdate = year - avgdate;
today = new Date();
var fpy = fb.TitleFormat("$year(%added%)").Eval();
var fpm = fb.TitleFormat("$sub($month(%added%),1)").Eval();
var fpd = fb.TitleFormat("$day_of_month(%added%)").Eval();
var fday = new Date(fpy, fpm, fpd);
var one_day = 1000 * 60 * 60 * 24;
if (fday > 0) {
ar_days = Math.floor((today.getTime() - fday.getTime()) / one_day);
ar_years = ar_days / 365;
fpy = fb.TitleFormat("$year(%first_played%)").Eval();
fpm = fb.TitleFormat("$sub($month(%first_played%),1)").Eval();
fpd = fb.TitleFormat("$day_of_month(%first_played%)").Eval();
if (fday > 0) {
ar_days2 = Math.floor((today.getTime() - fday.getTime()) / one_day);
ar_years2 = ar_days2 / 365;
} else {
ar_days2 = 0;
fpy = fb.TitleFormat("$year(%last_played%)").Eval();
fpm = fb.TitleFormat("$sub($month(%last_played%),1)").Eval();
fpd = fb.TitleFormat("$day_of_month(%last_played%)").Eval();
if (fday > 0) {
ar_days3 = Math.floor((today.getTime() - fday.getTime()) / one_day);
ar_years3 = ar_days3 / 365;
} else {
ar_days3 = 0;
fpy = fb.TitleFormat("$year(%last_modified%)").Eval();
fpm = fb.TitleFormat("$sub($month(%last_modified%),1)").Eval();
fpd = fb.TitleFormat("$day_of_month(%last_modified%)").Eval();
if (fday > 0) {
ar_days4 = Math.floor((today.getTime() - fday.getTime()) / one_day);
ar_years4 = ar_days4 / 365;
} else {
ar_days4 = 0;
if (ar_days === 0) {
ar_days = "today"
if (ar_days === 1) {
ar_days = "yesterday"
if (ar_days >>> 1) {
ar_days = ar_days + " days ago"
if (ar_days2 === 0) {
ar_days2 = "today"
if (ar_days2 === 1) {
ar_days2 = "yesterday"
if (ar_days2 >>> 1) {
ar_days2 = ar_days2 + " days ago"
if (ar_days3 === 0) {
ar_days3 = "today"
if (ar_days3 === 1) {
ar_days3 = "yesterday"
if (ar_days3 >>> 1) {
ar_days3 = ar_days3 + " days ago"
window.Repaint();
function on_playback_stop() {
artist = ""
album = ""
title = ""
genre = ""
ar_days = 0;
ar_days2 = 0;
ar_days3 = 0;
ar_days4 = 0;
ar_years = 0;
ar_years2 = 0;
ar_years3 = 0;
ar_years4 = 0;
date = 0;
difyear = 0;
playcount = "";
last1 = "";
last2 = "";
last3 = "";
last4 = "";
rating = "";
bitrate = 0;
playing = 0;
window.Repaint();
function on_item_played() {
playcount++;
playcount4++;
var test = window.GetProperty("bio_played")
var test = parseInt(test)
var test2 = test + 1
window.SetProperty("bio_played",test2);
ar_years3 = 0;
ar_days2 = "today"
ar_days3 = 0;
ar_days3 = "today"
window.Repaint();
function on_playlist_switch() {
window.Repaint();
function on_colors_changed() {
color = dui ==1 ? window.GetColorDUI(2) : RGB(200,0,0);
color2 = dui ==1 ? window.GetColorDUI(0) : window.GetColorCUI(0);
window.Repaint();
function on_font_changed() {
window.Repaint();
Any help would definitely be appreciated, thanks so much!!!
Version without the rating problem ( just strictly text )
I also cleaned it up a bit
Clicking through playlists seems much smoother without the rating stars problem
// ==PREPROCESSOR==
var bw = 13;
var bh = 13;
var Buttons;
var g_metadb;
var rating;
var nrating;
var lrating;
var img;
var g_drag = 0;
var artist = ""
var album = ""
var title = ""
var codec = ""
var bitrate = ""
var played = ""
var played = ""
var genre = ""
var lastartist = ""
var lastplay = ""
var rating = ""
var last1 = ""
var last2 = ""
var last3 = ""
var last4 = ""
var playing = "0"
var year = 0;
var date = 0;
var difyear = 0;
var date2 = 0;
var avgdate = 0;
var difdate = 0;
var today = 0;
var ar_days = 0;
var ar_years = 0;
var ar_days2 = 0;
var ar_years2 = 0;
var ar_days3 = 0;
var ar_years3 = 0;
var ar_days4 = 0;
var ar_years4 = 0;
var bitrate = 0;
var days = 0;
var hours = 0;
var minutes = 0;
var seconds = 0;
var playcount2 = 0;
var playcount3 = 0;
var playcount4 = 0;
var test = 0;
var test2 = 0;
var g_down = false;
var timer = null;
var cur_btn = null;
updateButtons() ;
this.left = x;
this.top = y;
this.w = w;
this.h = h;
this.right = x + w;
this.func = func;
this.tiptext = tiptext;
this.url = url;
this.img= img;
if (b)
else
return b;
switch (this.state)
break;
break;
default:
this.img = null;
var idx;
if (text != "")
numbersearchengines += 1 ;
else
_menu.Dispose();
var btn = null;
btn = Buttons[i];
return btn;
if (timer && id==timer.ID) {
updateButtons() ;
timer && window.KillTimer(timer);
timer = null;
cur_btn = btn;
g_down = true;
btn_down = cur_btn;
if (cur_btn) {
else
if (cur_btn) {
g_down = false;
//function on_mouse_lbtn_up(x,y){
// if (lrating !=rating && g_metadb) bool = fb.RunContextCommandWithMetadb("Rating/"+((lrating==0) ? "<not set>" : lrating),g_metadb);
// function on_mouse_move(x, y) {
// if (g_metadb) {
// g_drag = 1;
// nrating = Math.ceil((x - left_margin) / bw);
// if (nrating > 5) nrating = 5;
// if (nrating != lrating) {
// lrating = nrating;
// window.Repaint();
// on_metadb_changed()
if (cur_btn) {
function on_mouse_rbtn_down(x, y)
on_mouse_move(x, y);
if (cur_btn)
cur_btn.onRightClick(x, y);
else
var idx;
_menu.AppendMenuItem(MF_STRING, 1, "Refresh");
_menu.AppendMenuItem(MF_STRING, 2, "Properties");
_menu.AppendMenuItem(MF_STRING, 3, "Configure...");
switch(idx) {
case 1:
updateButtons() ;
break;
case 2:
break;
case 3:
break;
_menu.Dispose();
return true;
ww = window.Width;
wh = window.Height;
updateButtons();
//function on_metadb_changed() {
// g_drag = 0;
// rating = g_tfo.EvalWithMetadb(g_metadb);
// if (rating == "?") rating = 0;
// lrating = rating;
// Background
//buttons_background(gr);
//if (g_metadb) {
// for (i = 1; i < 6; i++) {
// img = gdi.image(images_path + ((i > (g_drag ? lrating : rating)) ? "off.png" : "on.png"));
// gr.DrawImage(img, left_margin + bw * (i-1), top_margin, bw, bh, 0, 0, img.Width, img.Height);
buttonsDraw(gr);
if (playing === 1){
else{
gr.GdiDrawText("Rating: "+ rating , g_font, color2, 5, 85, window.Width - 10, window.Height, DT_TOP | DT_LEFT | DT_NOPREFIX | DT_SINGLELINE | DT_END_ELLIPSIS);
if (playing === 1){
else{
else{
else{
if (playing === 1){
else{
else{
else{
if (playing === 1){
else{
else{
else{
else{
if (playing === 1){
else{
switch (name)
updateButtons();
break;
reloadConf(info);
break;
case "lastfm_bio":
window.Repaint();
default:
break;
delete Buttons;
Buttons = null;
var x = 10;
var y = 310;
switch (i % 2)
case 0:
break;
case 1:
//skinpath
if(img == null)
if(img == null)
if(img == null)
Buttons[i] = new ArtistButton(x, y, parseInt(window.GetProperty("buttons.width")), parseInt(window.GetProperty("buttons.height")), img, function(){WshShell.run(this.lastfmcommand);}, currentartist, currentartisturl) ;
x = 10 ;
else
break;
window.Repaint();
playing = 1;
date = date.Eval();
dt = new Date();
today = new Date();
if (fday > 0) {
if (fday > 0) {
} else {
ar_days2 = 0;
if (fday > 0) {
} else {
ar_days3 = 0;
if (fday > 0) {
} else {
ar_days4 = 0;
ar_days = "today"
ar_days2 = "today"
ar_days3 = "today"
window.Repaint();
artist = ""
album = ""
title = ""
genre = ""
ar_days = 0;
ar_days2 = 0;
ar_days3 = 0;
ar_days4 = 0;
ar_years = 0;
ar_years2 = 0;
ar_years3 = 0;
ar_years4 = 0;
date = 0;
difyear = 0;
playcount = "";
last1 = "";
last2 = "";
last3 = "";
last4 = "";
rating = "";
bitrate = 0;
playing = 0;
window.Repaint();
playcount++;
playcount4++;
ar_years3 = 0;
ar_days2 = "today"
ar_days3 = 0;
ar_days3 = "today"
window.Repaint();
window.Repaint();
scripts updated: http://cid-649d3bfeaf541fbb.office.live.co...ide/samples.zip (http://cid-649d3bfeaf541fbb.office.live.com/self.aspx/.Public/foobar/guide/samples.zip)
contains a new script called "thumbs2.txt"
(http://k5sbdw.blu.livefilestore.com/y1pQZLbMEuYlv6pP3wtfMAv2sy5ijmJdzdnyIY_Hv32xAlCaSR2U3T3tUAHuRTMe03Nksu7ta9TAfJKElEi-aL7be1Yl3BL3MEW/thumbs2.png)
-support for downloading last.fm artist art like all my other scripts
-multiple custom folder support
-hover mouse over thumbnails and use mouse wheel to scroll through all images
-single click thumbnail to show larger version
-single click large image to open in external viewer
-right click large image and you can delete it using the context menu
-check the context menu for all other options
marc2003, if I was a woman, i would run to you, jump at your neck and give you a kiss that would made your wife jealous!
thx a lot for this update! thumbnails below the cover, that what i was expecting from your script.
Now I can play a bit with it to:
-center the thumbnails under cover when (cover width) is bigger than (thumbs widtht x number of thumbs)
-reduce a bit thumbs size and draw a nice border around
edit:typo
although it's possible, i think it's easier to lock the panel width. otherwise you have to take into account the margins when tracking the mouse pointer for selecting/opening images. i guess it shouldn't be that hard - i'm just lazy.
hold shift while right clicking and that will show "properties" on the context menu. you can change the "thumb_size" variable there. if you want to draw a better border, you'll need to edit scripts\marc2003\v2\common.js and find the "scale" function.
I was a bit confuse that changing size in "configure..." windows returns no effect. Thx again.
i've now updated the "thumbs2" script so the thumbnails are centered.
(http://k5sbdw.blu.livefilestore.com/y1pi9ESBKspFzJdi0qDnykrMQiKpXMOzugbK_9Z2TBX6-NfMbYcVfs3rU8OS45qPKNbj53wTeiew-RCdT09OaH8Fq_FOamxDx2A/centered.png)
Marc, about Thumbs script...I would like to make a suggestion, not for design this time.
I've not entered yet to your script to see if it would be difficult or not.
As you know, the bigger image does not keep focus on the selected thumbs.
The focus change, and go back to the first image contained in the folder, when playback changes, or even when selection changes.
I dont know what was your plan when you began to script this panel. And surely maybe? my suggestion will not go in your way.
mainly: Is it possible to keep cover focused on the selected thumb and no reset to first image?
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]What i have in mind, is more a combination between artreader/thumb script 1/thumb script 2.
When you click on a thumb, it show bigger one; if you (double) click on the bigger image, it acts like thumbs1/artreader: thumbnails disappear to extend bigger image, with a kind of diaporama.
Next, clicking on the extended big image, that will switch to the combined display (Thumbs+Big cover). If you middle click on thumbs, it could extend thumbs (big cover disappear, for browsing thumbs)... and if needed, another action to open it in external viewer.
I'm not asking anything, just sharing what, with a maximum effort, i'll try to achieve starting with your scripts.[/size]
sorry but i have no idea what you're on about? :/
edit: i'll just explain how it works and maybe you can tell me what your problem is.
when foobar is playing, it follows the "now playing" item. it only resets when the playing artist changes, resize the panel or use the context menu to delete an image.
when foobar isn't playing it follows the cursor. but again, it only resets when the selected artist changes. this is because i assume most people who want to display multiple images will be using either last.fm mode or using their own collection of art using %artist% titleformatting in the custom folder setup.
EDIT2: i see what the problem is now. i only set the artist in last.fm artist mode and not custom folder mode. my mistake, i've uploaded fixed versions of "thumbs" and "thumbs2".
EDIT3:
now i've uploaded another "fix". in last.fm mode, it still changes on the artist as before. but in custom folder mode, it only changes when the evaluated custom title formatting changes. i think that makes more sense.
Great!!!!! Thank you so much.
I have some idea.
1) If area of panel is oblong and small, thumbnail place is left side.(Now preview image very small if panel height is short.)
2) Download Last.fm images on Custom folder mode.
3) Support multiple value on download lastfm image function. Select artist on context menu.(default use $meta(%tag%,0))
I use original meta tag(e.g. %original artist%) on multiple artist track.
Some tracks %artist% is "A and B", "A feat. B", "A,B", "A with B" etc.
In these, I set "A;B" on original artist field.
I use the following TF on biography view(Remap meta).
$if2(%<original artist>%,%artist%)
I will use like the following TF on custom folder path If this function added.
C:\image\$meta(original artist,0)\;
C:\image\$meta(original artist,1)\;
C:\image\$meta(original artist,2)\;
C:\image\$meta(original artist,3)\;
4) work for focused item on playlist permanently.(Can I use this script in multiple?)
5) High quality image resize algorithm on thumb.
6) Thumb size config not available?
7) Put arrow that suggest more image exist on thumb.
8) Config priority on Last.fm Image downloading.(e.g. newest, popular)
9) Store already exist image on Last.fm image downloading and limit show image.(choice is random)
10) Background color config.
Please examine these.
This is a proposal.
Thank you.
changing the background is easy enough. on line 103, replace "g_backcolor" with "RGB(x,y,z)".
as for the rest. have fun.....
Thank you.
11) Download progress images.
12) Auto download Last.fm images.
13) NG image function.(Some time, very small image and no relation image downloaded.)
14) If wheel scroll on big image, show next image.
15) If image count is 1, not show thumb.
16) Stands out current thumb.
17) Config image sort order.(filename, folder path, random)
i see we have a comedian in the house.
a few things make sense and i might implement. i can't do progress but i should be able to show it's doing something when downloading images. and automatic downloading would be handy.
@Watercolor:
Point 6 is already possible
@Marc:
point 14 could have sense if we could switch between "BigImage+Thumbs" and "only BigImage display".
point 15 have sense, even for you, using only lastFM mode.
As, marc, you only use this script for lastfm artist, i suppose you will not mess the code to give us the possibility to chose the name of the first image (e.g. Front, instead of Back...). It is not a priority, but it would be cool, later, one day, maybe, perhaps...
Greets
edit: details for 14 & 15
@marc, sorry to spam you about this script:
could you point me the direction and place in your code where I could change the ratio of thumbs (is it possible)?
actually, i don't want you to make it for me, i want just to change that part, so all thumbs would be square.
Thx
edit:typo
@Watercolor:
OK. but old version have context menu that config thumb size. Thank you.
Everyone, sorry my bad English.
If can not understand something in my post, please ask for me.
I will effort explain.
I know that too, but as you have 17 asking points, maybe some "conceding" could help .As, I suppose, you will not change the thumbs size every minute, maybe it is not so important to have it in context menu or not.
Windows 7 Explorer have slider that config thumb size.
...Sorry, I only change thumb size when panel layout changed.
Thank you.
EDIT3:
I'm really ashamed to
knock hammer at your door that way.
Actually it changes to another custom folder
only if artist changes... (but the focus is ok now).
if it only changes when the artist changes, then you must be using %artist% in your title formatting. :/
RE: square thumbnails, you need to look at the maths calculations in the scale function. it's in the external file "scripts\marc2003\v2\common.js" inside the scale() function. this function is shared between lots of my scripts so you might want to make a copy and call it by another name.
i'm using this:
$replace(%path%,%filename_ext%,)\Cover\
maybe i m doing wrong, so i will fix and find it by myself.
but if not, if there is a "bug" with custom folder definition, there is no emergency about that.
i'm not asking you to focus about that, i know you are about multiple thing at once.
remove the trailing slash.
thumbs & thumbs2
-added square thumbnail option (it's the default).
-added auto download option. it only works on the start of a new track and if no images are found. you can turn if off via the context menu.
thumbs2
-added configurable thumbnail size
-scrolling over large image cycles through them (thumbnails do not track it at the moment)
-don't show thumbnails if there is only 1 image
now playing.txt
-bugfix. script may have errored if scrolling too fast.
note: changes were made to the "scripts" folder so make sure you extract the contents, overwriting the old files.
i'm such a half-wit. i didn't bundle the new files in the zip. i just re-uploaded.
I was self-silenced by my shame to hammered you all the day... So i was silently waiting that you see that by yourself.
so, thx for all. Now everyting is ok. The square format is nice (and you decide to crop image, keeping aspect ratio. Good choice)
And, beside everything, now custom folder change, even if artist is the same.
THANK YOU for your reactivity and your patience. If you were my neighbor, i would offer you some drink... or make you some cookies
Now, i keep my mouth closed, and my hands out of the keyboard until september. Nothing more to ask, except that I wish you a nice summertime.
Wonderful!
I am wishing this script to become better.
p.s.
I posted some ideas that I wanted.
But I especially want function is
"Multiple value tag support",
"Last.fm Artist Art and Custom Folder can be used at the same time" and
"Blacklist of image".
Multiple value tag support:Support %<tag>% or delimiter(like "$meta_sep($if(%original artist%,original artist,artist),|)". I will use more complex TF.).
Same as custom folder path config.
art.exe will run multiple time(number of tag value).
Plus, I want the setting of the condition disregarding downloading.(Like "$if(%nolastfm%,1)".)
Also I think ignore conditon set by use artist TF.(e.g. "$if(%nolastfm%,,$if(%original artist%,original artist,artist),|))")
Last.fm Artist Art and Custom Folder can be used at the same time:For example, If I play soundtrack of movie, I want to see some photograph of the movie and liner notes.
Also I want to see composer(%artist% in this case) images.
I think mode changing is tedium. All images should show same time.
Blacklist of image:Whenever a trivial photograph is seen, I get irritated.
Then, I delete those images.
However, these revive again when downloading again.
Accordingly, I think need function that exclude these images.
I do not understand how to this.(filename? md5? crc32?)
Thank you.
i just re-uploaded to fix a bug in thumbs2. i didn't implement "don't show thumbnails if there is only 1 image" properly.
i can't stop art.exe downloading images. maybe blacklisting could be added to my script. i'll have to have a think on how to implement that.
as for merging last.fm/custom folder mode and multiple tag support, that's not likely to happen.
difficulty? or not needed?
Anyway, I see. I am sorry for saying a trivial demand.
I might make them by myself.
Thank you.
small update for thumbs2.
(http://k5sbdw.blu.livefilestore.com/y1pekBJpHxOPjI6EVXtCnX2Zx08Hb7zvEcn-0gGLPvydYyI8JG042Co_aRIq2k9a_Qyl3Q7WWtguUTibHf03ZaQ_5X0WSqlW3gC/thumbs2%20arrows.png)
-added forward/back buttons to show when there are more thumbnails. (scripts folder contains new images so make sure you extract that as well)
another update for thumbs2. http://cid-649d3bfeaf541fbb.office.live.co...ide/samples.zip (http://cid-649d3bfeaf541fbb.office.live.com/self.aspx/.Public/foobar/guide/samples.zip)
-when deleting images in last.fm mode, you can now blacklist them to prevent them showing again. although i can't stop them being downloaded again, the script deletes them when checking the folder. you can turn off blacklisting or clear the blacklist from the context menu.
EDIT: yet again, i didn't put all the new files in the zip. still, it was only 10 minutes before i realised this time. i just re-uploaded....
Nice update.
OK. There is new idea!
18) Put loading image when downloading.(animation gif is easy?)
19) Thumbs scrollbar.
20) Show total images count. Show current image offset number. (Like 12/20.) Show number that assignment to thumbs.
21) Do fade effect(or some effect) when current image is changed.
22) New mode.(Goolgle image, MySpace, Flickr etc. ...also use custom folder same time. hehehe. )
23) Mouseover effect.(Thumb, big image etc.)
24) Config auto cycle.(Stop, Start, Interval, Order)
25) A lot of image downloading over 50. Plus, limit use image about under 20-30.(Number is rough.)
26) Config search query TF that use download.(Can I use delimiter? Oh, sorry. )
27) Config identification TF that use change image set.
28) Support skin.(maybe image file set and color settings.)
29) Reload function that useful in custom folder mode when put some images at playing music.
30) Favorite(or whitelist) image function.(If a image is added to favorite(or whitelist), this image not delete when redownload. And warn alert appear when exec manual delete.)
31) Config limit (min|max) download image's (filesize|pixel|height|width|filetype|date).
32) Another external program execute menu or mouse operation.(to edit image. not viewer. like PhotoShop, Paint.Net, Gimp etc.)
33) additional download function.(5+,10+) This cause too many image problem. but if can limit show image count, it is no problem.
34) Search toolbar or prompt. Any artist images can preview by this.
Thank you!
go **** yourself.
Hey all, I have a quick question I hope someone can help me with. I'm trying to use the UpdateFileInfoSimple function to write data to some of my file tags, but I occasionally receive the following error when the file being changed is currently playing:
Could not update tags (Sharing violation) on:
"<filename>"
It doesn't happen all the time, but when it does it's annoying. Is there any way to suppress this error message? Thanks.
you'd get the same dialog if you tried updating the tags manually. there's nothing i don't think there is anything you can do in WSH panel mod to suppress it.
of course, you could look at what's locking the files in the first place. maybe some other components or 3rd party programs??
Whatever is locking the files is only temporary. If I try re-running the script after getting that error it almost always works. So there's no way in WSH Panel Mod to test whether a file is locked?
so you have an idea what it is? this is what you need to look at to prevent the errors.
like i said, the message you're seeing is a standard foobar dialog so as far as WSH panel mod is concerned, the "UpdateFileInfoSimple" function has run successfully.
No I don't, but I guess I'll have to figure it out. I just figured that foobar was locking it because it was currently playing. I guess that's not the case. Thanks for your help.
i've made scripts that can update the tags of the currently playing file so it's definitely not that.
marc2003, I think your samples zip is missing a few files. All I see is the pdf and the v2 folder.
i just checked and you're right. i have no idea what happened there. anyway, i've updated it....
little update for thumbs & thumbs2 to improve the image quality when resizing....
i only just noticed this really bad example.
(http://k5sbdw.blu.livefilestore.com/y1p5tF8j_ZKhZbNeoZCrLICM9aKD02b8cFA3muLOdIK0Z9mVaRTyKhj0iX4b1SSVd5uBC24UrnKd2dPMpzxBosp57UBaPx_mmvR/beforeafter.png)
before / after
This script has greatly improved the enjoyment of foobar2000.
Thank you.
Something I would like to see: A script that allowed me to love/unlove/ban/unban tracks on last.fm. These api calls do exist (http://www.hydrogenaudio.org/forums/index.php?showtopic=82170&view=findpost&p=715947) and if fb2k had them, it would put it above all other last.fm compatible players.
thumbs / thumbs2 bugfix. ' ( ) [ ] weren't handled correctly in custom folder mode.
So does anyone feel like taking marc2003's "thumbs 2" and turning it into a graphical browser for the media library...
there is already EsPlaylist which can browse the library and show covers. it's impossible for WSH panel mod to do anything like that.
Hey, thank you for constantly improving your script.
but...this doesn't work anymore:
$replace(%path%,%filename_ext%,)Cover
something bad from my side, that i should now change?
doh, i'm an idiot. i'll have to revert back to how it was before.
if your folder path contains those characters '()[], they'll have to be escaped manually much like when you want to display them when using foobar normally.
doh, i'm an idiot.
I would have not said that! But we are changing you to a weathercock!
Sorry to make you play yoyo with your script, now it is i-m-p-e-c-a-b-l-e (for me).
i was messing about using absolute folder paths which had () in the name. i made that change totally forgetting it would break anything using title formatting functions.
edit: BTW i uploaded another new version earlier. it contains a bugfix for the "thumbs" script only. "cycle" mode was broken but now it's fixed.
Marc, I'm playing with your scripts and I have one quick question: in the rating script, how would I go about aligning the stars to the center of the panel?
put this line to function on_size
left_margin = ww/2-bw*5/2;
like this
function on_size() {
ww = window.Width;
wh = window.Height;
Great, thank you!
i've just uploaded a new version of the rating script as well. it's centered horizontally and vertically and the hover effect only responds when actually over the stars as opposed to the whole panel like it was before.
EDIT: just uploaded another new version. it now checks if foo_playcount is installed and will prompt you if it isn't.
I would like to know if someone can help me : I try to measure the width of a string that contains \n :
var txt = "line 1\nline2";
I tried with CalcTextWidth but it returns the width of line 1 + line 2 but I'd like to obtain the value of the greater line ! I tried also with CalcTextHeight but I don't understand how it works and can't find samples here !!
split the text into an array like this...
var some_text = "some text\nsome more text";
arr = some_text.split("\n");
arr[0] //some text
arr[1] //some more text
you could loop through the array and check the length of each line and keep the longest one.
Thank you Marc ! Works fine
i've added "similar artists" to my "simple biography" script.
samples updated.
i decided to split "similar artists" into it's own script and have reverted "simple biography" to how it was before.
each "similar artist" now has a "search spotify" button as i think this is more useful than using foo_lastfm_radio.
(http://k5sbdw.blu.livefilestore.com/y1py2PzGMIBgFJt2H7rdfwlSbuZTWKw1zQEIt4bAwgI87HMJod13yPDP_ljIjDPIGL4bCYtLkp2v9OOymaSIS-2U9spbVV4sGGI/similar%20artists.png)
I'm looking at your previous screenshot and I just have to ask something:
(http://i.imgur.com/WRrwb.png)
Is the rounded edge (see arrow) part of the button design or is it part of a script?
it's just rounded rectangles offset with negative numbers so you don't see the top...
function on_paint(gr) {
gr.FillGradRect(0, 0, ww, wh, 270, utils.GetSysColor(15), RGB(255,255,255));
gr.SetSmoothingMode(2);
gr.FillRoundRect(5, -8, ww-10, 48, 8, 8, RGB(210, 210, 210));
gr.FillRoundRect(7, -6, ww-14, 44, 8, 8, RGB(245, 245, 245));
gr.FillRoundRect(11, -2, ww-22, 40, 8, 8, RGB(245, 247, 246));
drawAllButtons(gr);
samples updated.
Nice script!
But multiple tag value is not supported, it is sad.
Marc, I've tried your Similar Artists panel, but I can't get the spotify buttons to work. I guess I have to install the spotify protocol on my machine, but I don't know how. Do I need to install the despotify frontend?
Can you help a newbie like me?
i have spotify free installed. i have no idea what despotify is? when you install the spotify app, the "spotify:" protocol automatically links in so it opens the app with the search results listed.
Thanks. Unfortunately, spotify is not available here (Belgium), and I can't download it.
Despotify is an open source implementation of the spotify app. I don't know it, and I will not try to install it, as I prefer to stay in foobar for all audio and radio related stuff.
Maybe you should consider to make the spotify buttons optional, as spotify is available only in a few lands, and anyway, some users may prefer to not have to download the official app just to use that buttons. (I have already replaced them with "play last.fm artist radio' buttons, so I don't need an update, but I think other users may need it.)
ok, i can add an option to make them optional. i'll do it over the weekend sometime.
edit: i didn't realise it was so restricted. i just checked and you can only get it in
Sweden, Norway, Finland, the UK, France, Spain and the Netherlands
i knew it wasn't available in the US but i thought more european users could use it. oh well.
Where is your favorite band on tour?
FooTour
(http://www.abload.de/img/footour3b7bj.jpg) (http://www.abload.de/image.php?img=footour3b7bj.jpg)
Script Download: http://pastebin.de/9052 (http://pastebin.de/9052)
Updates: http://foobar-users.de/index.php?topic=200...g17454#msg17454 (http://foobar-users.de/index.php?topic=2000.msg17454#msg17454)
Yes, except in Belgium! :-(
IMO, instead of the option to make the spotify buttons optional, the user should be able to chose the old behaviour (play last.fm radio). It's also less work for you. You have just to change the icon, the tooltip and the command, and you don't have to do different calculations for the layout of the window.
BTW, I have had to modify several of your panels, as they don't work well when a radio is playing, because the dynamic track info is not monitored.
I realized too that I don't want to permanently save the xml and images files downloaded from last.fm for the radio artists, as I don't necessarily like all artists I hear on the radios. So, I have modified the scripts so that, when a radio is playing, it saves its files in my temp folder (with the artist name in the file names), and it removes them when the script is unloaded (when foobar is closed). Unfortunately, I had to hardcode the temp folder, because I don't know how to retrieve the %temp% environment variable of Windows. Do you know how to do it? Is it possible?
done.
google?
var WshShell = new ActiveXObject("WScript.Shell"); //this line is already in my common.js
var envVars = WshShell.Environment("USER");
var temp_path = envVars.Item("TEMP");
var fso = new ActiveXObject("Scripting.FileSystemObject");
var temp = fso.GetSpecialFolder(2)
is possible too ( http://msdn.microsoft.com/en-us/library/a7...28VS.85%29.aspx (http://msdn.microsoft.com/en-us/library/a72y2t1c%28VS.85%29.aspx) )
Thanks to you both! I've googled, of course, and found the Environment object, but I'm new to the Windows programming environment, and I find the doc pages confusing. I did not know that it was possible to link WScript.Shell.Environment together. (Finding the right objects is the major difficulty in object oriented programming imo. I will have to study that stuff...)
I know this is off current discussion but it says : "discussion/help" and I need some help with the following:
1. Panels switching inside Foobar only shows after resizing the main window. Should be immidiate. "Tech" was able to do it right but I dunno how.
2. Fade back transition from hover to normal is not smooth how to fix ?
3. How to tell the button to remain in changeState(2) which is the active state until hitting another button ?
Thanks for helping me out
WSH Panel Code:
// ==PREPROCESSOR==
// @import "%fb2k_path%\skins\foooffice\scripts\Flags.txt"
// @import "%fb2k_path%\skins\foooffice\scripts\Helpers.txt"
// @import "%fb2k_path%\skins\foooffice\scripts\Buttons.txt"
var DT_CENTER = 0x00000001;
var DT_VCENTER = 0x00000004;
var DT_CALCRECT = 0x00000400;
var DT_NOPREFIX = 0x00000800;
var DT_END_ELLIPSIS = 0x00008000;
var g_timer_started = false;
var g_timer;
var button_font = gdi.font("Calibri", 12, 0);
var gen_font = gdi.font("Calibri", 12, 0);
var codec_font = gdi.font("segoe ui", 14, 0);
var settings_dir = fb.FoobarPath + "skins\\foooffice\\settings\\";
var img_dir = fb.FoobarPath + "skins\\foooffice\\images\\";
var script_dir = fb.FoobarPath + "skins\\foooffice\\scripts\\";
Foobar_hWnd = utils.GetHWND("{E7076D1C-A7BF-4f39-B771-BCBE88F2A2A8}");
utils.CreateGlass(Foobar_hWnd, 0, 0, 30, 0)
gr.FillSolidRect(0, 0, ww, 30, 0xFF000000);
for (var i in $buttons) {
$buttons[i].draw(gr);
ww = window.Width;
wh = window.Height;
if (ww <= 0 || wh <= 0) return;
$buttons = {
button_1: new Button(5, 5, FILETAB.width / 3, FILETAB.height, FILETAB, function () {
update_option("panel_id",1);
button_2: new Button(60, 5, PLAYINGTAB.width / 3, PLAYINGTAB.height, PLAYINGTAB, function () {
update_option("panel_id",2);
window.Repaint();
buttons_on_mouse_move(x, y);
buttons_on_lbtn_down(x, y);
buttons_on_mouse_lbtn_up(x, y);
buttons_on_mouse_leave();
function on_timer(id) {
button_on_timer(id);
function update_option(optname, optvalue) {
var fso, f1, ts, s;
var ForReading = 1;
var ForWriting = 2;
ts = fso.OpenTextFile(settings_dir + optname + ".txt", ForReading);
s = ts.ReadLine();
ts.Close();
f1 = fso.MoveFile(settings_dir + optname + "_" + s, settings_dir + optname + "_" + optvalue);
ts = fso.OpenTextFile(settings_dir + optname + ".txt", ForWriting);
ts.WriteLine(optvalue);
ts.Close();
return optvalue;
function read_option(optname, initvalue) {
var fso, ts, ts2, s;
var ForReading = 1;
var ForWriting = 2;
if (file_exists(settings_dir + optname + ".txt") == true) {
s = ts.ReadLine();
ts.Close();
return s;
} else {
ts = fso.CreateTextFile(settings_dir + optname + ".txt", ForWriting);
ts.WriteLine(initvalue);
ts.Close();
ts2 = fso.CreateTextFile(settings_dir + optname + "_" + initvalue, ForWriting);
ts2.Close();
return initvalue;
This is the imported Buttons.txt
var imgPath = fb.FoobarPath + "skins\\foooffice\\images\\";
var FILETAB = gdi.Image(imgPath +"buttons\\tab_file_sprite.png");
var PLAYINGTAB = gdi.Image(imgPath +"buttons\\tab_playing_sprite.png");
var button_timer = false;
var button_timeout;
var button_font = gdi.font("Lucida Sans Unicode", 10, 0);
var g_font = gdi.font("segoe_ui", 14, 0);
var xy = false;
var hbtn;
var dbtn;
function Button(x, y, w, h, o, onclick) {
this.x = x;
this.y = y;
this.w = w;
this.h = h;
this.o = o;
this.onclick = onclick;
this.oldstate = 0;
this.state = 0;
this.opacity = 0;
this.refresh = 0;
this.xy = function (x, y) {
return (this.x <= x) && (x <= this.x + this.w) && (this.y <= y) && (y <= this.y + this.h);
this.changeState = function (state) {
if (!button_timer) button_timer = window.CreateTimerInterval(60);
this.oldstate = this.state;
this.state = state;
this.opacity = 0;
this.refresh = 1;
switch (state) {
case 0:
this.step = 35;
window.SetCursor(32512);
break;
case 1:
this.step = 55;
window.SetCursor(32649);
break;
case 2:
this.step = 75;
break;
// =================================== Image Button
if (this.opacity < 255) gr.DrawImage(this.o, this.x, this.y, this.w, this.h, this.oldstate * this.w, 0, this.w, this.h, 0, 255);
if (this.opacity) gr.DrawImage(this.o, this.x, this.y, this.w, this.h, this.state * this.w, 0, this.w, this.h, 0, this.opacity);
this.RefreshOpacity = function () {
if (this.opacity < 255) this.opacity = Math.min(this.opacity + this.step, 255);
else {
this.opacity = 0;
this.refresh = 0;
if (this.opacity == 0) button_timeout = window.CreateTimerTimeout(5000);
window.RepaintRect(this.x, this.y, this.w, this.h+2);
this.onclick && this.onclick();
buttons_on_mouse_move = function(x, y){
xy = false;
if ($buttons[i].xy(x, y)) {
xy = true;
if (hbtn != $buttons[i]) {
if (hbtn) hbtn.changeState(0);
hbtn = $buttons[i];
hbtn.changeState(1);
if (xy == false) {
if (hbtn) {
hbtn = undefined;
buttons_on_lbtn_down = function (x, y) {
if (hbtn) {
dbtn = hbtn;
dbtn.changeState(2);
hbtn = undefined;
buttons_on_mouse_lbtn_up = function (x, y) {
if (dbtn) {
dbtn.changeState(1);
dbtn.onClick();
dbtn = undefined;
buttons_on_mouse_leave = function () {
if (hbtn) {
hbtn = undefined;
on_size();
window.Repaint();
button_on_timer = function (id) {
if (button_timeout && id == button_timeout.ID) {
if (button_timer) window.KillTimer(button_timer);
if ($buttons[i].refresh) {
$buttons[i].RefreshOpacity();
Here you can download the pack for use in columnsUI
http://hotfile.com/dl/63610538/4ccaadb/foooffice.zip.html (http://hotfile.com/dl/63610538/4ccaadb/foooffice.zip.html)
Wshpanel Pastebin (http://pastebin.de/9246)
Buttons.txt Pastebin (http://pastebin.de/9247)
Hi marc2003, your sample scripts are awesome! Finally something a newbie can use without cracking his head!
I just have problems making the scripts (e.g. "now playing") to follow the current selection instead of the song played. I tried this, but it didnt work (replaced line #131):
no, it's not possible to get that preference. you can edit my script to always follow the selection. open
line 108 should be this....
g_metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
replace it with...
g_metadb = fb.GetFocusItem();
restart foobar (or reload script) for changes to take effect.
Any ideas?
Does anyone know of a way to differentiate whether or not the current playlist is an autoplaylist? If there's no variable available to WSH Panel Mod is there a component that can automatically append something to the playlist's name that I can parse in WSH Panel Mod? Thanks.
Any ideas?
If you're running Vista or Win7, maybe you have not edited the right file. Due to the way Windows now redirects your changes in protected directories to %AppData%\Local\VirtualStore, your edits are not stored where WSH expects to find them. You should copy common.js somewhere where you have all access rights, edit it, and copy the modified version in the scripts folder, overwriting the original file.
(I'm not sure it's really your problem, but I've faced a similar problem under Win7.)
BTW, Marc, could you consider to change the default location of your scripts? With UAC enabled, it is a pain to modify them in the foobar installation folder. Anyway, the Program Files folder should never be modified directly by the user. And now, the new beta version of foobar stores the optional components in the user's profile directory. It seems logical to do the same thing for the WSH scripts.
Any ideas?
Thanks for the help, but this wasn't the problem. I just figured out I made a mistake in testing and also some of the scripts needed some tweaking to work.
FooTheEchoNestProvides information from http://developer.echonest.com (http://developer.echonest.com)
- Song (screenshot)
- Biography
- Review
- Blog
- News
- Terms
- Similar Artists
(http://www.abload.de/img/footheechonest108wsb.jpg) (http://www.abload.de/image.php?img=footheechonest108wsb.jpg)
Installation:
Download of "Powered By The Echo Nest" banner:
http://the.echonest.com/media/images/logos/140x50_dk.gif (http://the.echonest.com/media/images/logos/140x50_dk.gif)
Copy banner to (Profile)\foobar2000\pictures\
Script download: http://pastebin.de/9468 (http://pastebin.de/9468)
Updates: http://foobar-users.de/index.php?topic=200...g17505#msg17505 (http://foobar-users.de/index.php?topic=2000.msg17505#msg17505)
Hallo,
I'm looking to create a button that changes when you mouse over it, like you get with the standard panel stack splitter behavior. I'm mostly sorted except I cant find out what function I need to create the mouse over behavior. Is it on_mouse_over I need or something similar?
Cheers
Marc, having trouble with your similar artists script in regards to playing a last.fm radio station...
I have foo_lastfm_radio installed, with my username and pass filled in, as well as all associations regarding last.fm:// squared away, yet I'm still getting the error message when I try to click on a radio link.
function on_mouse_move(x,y) {
Fixed this by inseting sa_artists[index] into line 156 instead of whatever was there before for the artist name
oops. i've fixed the online version as well. i stupidly copy/pasted that section from another script which uses different names.
I have got an working code from tedgo and i want to add
Costum Database Rating %RATING_CD%
and if it is possible love and unlove for LastFM
(I use the LastFM script from marc2003)
Could anyone help me please?
that's my foobar skin Silent Night for fb2k v.1+ (http://arnie77.deviantart.com/#/d2k323j)
Global Button Script.js// Global Button Script
// Code by T.P Wang and tedGo
var ButtonStates = {normal: 0, hover: 1, down: 2, hide: 3};
var Buttons = {};
var g_down = false;
// ----- CREATE BUTTON OBJECT --------------------------------------
var g_tooltip;
function Button(x, y, w, h, img_src, func, tiptext) {
this.left = x;
this.top = y;
this.w = w;
this.h = h;
this.right = x + w;
this.func = func;
this.img_normal = img_src && img_src.normal ? gdi.Image(img_src.normal) : null;
this.img_hover = img_src && img_src.hover ? gdi.Image(img_src.hover) : this.img_normal;
this.img_down = img_src && img_src.down ? gdi.Image(img_src.down) : this.img_hover;
this.img = this.img_normal;
this.traceMouse = function(x, y) {
if (this.state == ButtonStates.hide) return false;
if (b)
else
return b;
this.changeState = function(newstate) {
newstate != this.state && window.RepaintRect(this.left, this.top, this.w, this.h);
switch (this.state) {
break;
this.img = this.img_hover;
break;
this.img = this.img_down;
break;
default:
this.img = null;
this.changePos = function(x, y, w, h) {
this.left = x;
this.top = y;
this.w = w;
this.h = h;
this.right = x + w;
this.draw = function(gr) {
this.img && gr.DrawImage(this.img, this.left, this.top, this.w, this.h, 0, 0, this.w, this.h);
this.repaint = function() {
this.onClick = function() {
this.func && this.func();
g_tooltip.Dispose();
for (var i in Buttons) {
var btn = null;
btn = Buttons[i];
return btn;
// ----- MOUSE ACTIONS ---------------------------------------------
var cur_btn = null;
var btn_down;
cur_btn = btn;
g_down = true;
(btn_down = cur_btn) && cur_btn.changeState(ButtonStates.down);
if (cur_btn) {
btn_down == cur_btn && cur_btn.onClick(x, y);
g_down = false;
cur_btn && cur_btn.changeState(ButtonStates.normal);
Popup-Rating Menu
// Popup-Rating Menu
// Code by tedGo
// ==PREPROCESSOR==
// @import "%fb2k_path%Silent Night\scripts\Global Button Script.js"
var ww = 0; wh = 0;
// ----- CREATE BUTTON ---------------------------------------------
var imgPath = fb.FoobarPath + "Silent Night\\images\\";
Buttons.RAT = new Button(0, 0, 39, 20, {normal: imgPath + "Rate.png", hover: imgPath + "Rate1.png"}, getRatingMenu);
// ----- CREATE MENU -----------------------------------------------
function RateMode() {
rm = window.GetProperty("Rating Mode", 0);
if (typeof rm < 0 || rm > 1) rm = 0;
return rm;
RateMode();
function getRatingMenu(x, y) {
x = Buttons.RAT.left;
y = Buttons.RAT.top;
var a = window.CreatePopupMenu();
var g_metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
var isRating = fb.TitleFormat("$if2(%rating%,0)").EvalWithMetadb(g_metadb);
var delRating = isRating > 0 ? 0 : 1;
var idx;
a.CheckMenuRadioItem(101, 102, rm + 101);
a.AppendMenuItem(0, 101, "Database Rating");
a.AppendMenuItem(0, 102, "Tag Rating");
a.AppendMenuItem(2048, 0, 0);
a.AppendMenuItem(0, 1, "Rating 1 - ★");
a.AppendMenuItem(0, 2, "Rating 2 - ★★");
a.AppendMenuItem(0, 3, "Rating 3 - ★★★");
a.AppendMenuItem(0, 4, "Rating 4 - ★★★★");
a.AppendMenuItem(0, 5, "Rating 5 - ★★★★★");
a.CheckMenuRadioItem(1, 5, isRating);
a.AppendMenuItem(delRating, 6, "Remove Rating");
idx = a.TrackPopupMenu(x, y);
switch (true) {
case (idx >= 101 && idx <= 102):
window.SetProperty("Rating Mode", idx - 101);
RateMode();
break;
case (idx >= 1 && idx <= 5):
rm == 0 ? fb.RunContextCommandWithMetadb("Rating/" + idx, g_metadb) : g_metadb.UpdateFileInfoSimple("Rating", idx);
break;
case (idx == 6):
fb.IsMetadbInMediaLibrary(g_metadb) ? fb.RunContextCommandWithMetadb("Rating/<not set>", g_metadb) : g_metadb.UpdateFileInfoSimple("Rating", "");
break;
a.Dispose();
//Fixed coords for menu
function on_mouse_rbtn_down(x, y) {
}function on_mouse_rbtn_down(x, y, vkey){
rbtnDown = vkey==6 ? true : false;
function on_mouse_rbtn_up(x, y, vkey){
if (rbtnDown) {
rbtnDown=false;
return vkey==4 ? false : true;
} else
return true;
// ----- DRAW ------------------------------------------------------
buttonsDraw(gr);
// ----- EVENTS ----------------------------------------------------
ww = window.Width;
wh = window.Height;
Buttons.RAT.changePos(0, 0, 39, 20);
Allways thanks to grimes and marc2003
Well,how to display console on the WSH-MOD?
Please help me,foo_cosole is only system color
little update for my lastfm script
(http://th02.deviantart.net/fs70/300w/i/2010/244/e/6/foo_silk_lastfm_1_0_by_matthijsb-d2xrp69.png) (http://matthijsb.deviantart.com/art/foo-silk-lastfm-1-0-177652017)
Vertical scrollbar
After some (laborious) studies, I have finally written a script that you may find useful. It's a file to import in your script to easily define a viewport in the WSH window, with a vertical scrollbar that the user can use to scroll the content of a bitmap vertically. Keyboard and mouse scrolling are also supported (but are optional).
The scrollbar is configurable. For example, it can be automatically hid when the mouse leave the WSH window or when it is useless, it can be placed on the left side of the viewport, you can change the colors (including the alpha channel), etc....
Download: main site (no wait) (http://download.videohelp.com/r0lZ/scrollbar_0.1.zip) or alternate download link (4shared) (http://www.4shared.com/file/mxsqG0Tc/scrollbar_01.html)
The archive contains scrollbar.js. It's the main script, to import in your application. It is fully documented.
There are also two demo scripts:
scrollbar_demo.js is a totally useless and stupid demo, with many comments.
info_text_viewer.js is a somewhat more useful script, that displays the content of the "info.txt" file in the folder containing the currently playing or focussed audio file, or, if that file doesn't exist, the first .txt file it finds in the folder. (See image below.)
You will probably have to change the @import directive in the demo files, as my scripts are in "%fb2k_profile_path%\wsh_scripts\".
Feel free to report bugs or post suggestions in this thread.
info_text_viewer.js:
(http://img340.imageshack.us/img340/2162/textviewer.png)
I am having trouble reversing the fading of the button states. Currently it's fading in when mouseover and simply dissappearing when mouseout. I want it the other way round. Like fade-in on_mouseover and disappearing when mouseout.
Image fade buttons (http://javascript.pastebin.com/dbWMmziw)
If you need the images for testing simply put any image into either the defined folder or change img_path and var sprite to your likeness.
Hope someone can figure this out.
No one who could help me ? Either simplify this script or fix the fading ? If so maybe someone can tell me how to adress the output of a timer to use it as input of a function which changes the alpha
It's really strange that foobar has so many troubles with providing lyrics (to me at least)
Only valid component seems to be made years ago by author - ssenna, with elements still in alpha stage and accessible by Columns UI users only. OTOH other users have choice of primitive text display element for displaying general tags and maybe lyrics if they contain novel
However I made simple CGI VBS (http://pastebin.com/LzWQ47Es) for biography view some time ago http://www.hydrogenaudio.org/forums/index....st&p=717583 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=70955&view=findpost&p=717583), based on foo_lyricsdb interaction, kindly provided and maintained by dug, and it's working great but biography view can have only one instance with contents, so it's pretty useless generally. I also tried to access Winamp's lyricsplugin.com but they made some ajax trick not beatable by VBS scripting (unless you evoke IE panel)
So to cut this crap, is there ready-made WSH panel that can display provided text as lyrics. I found some posts with dead links so can't say
Not that it would be elegant foobar solution, but perhaps better then all those crash-ware available
afaik no. But i've planned to code a such panel (WSH panel Mod) all i need is free time now, the community will informed when it will be done ... or maybe some will code one before me
Thanks for confirmation... looking forward to your solution
@romor: try this: http://matthijsb.deviantart.com/art/nfoo-V...r-1-1-170638369 (http://matthijsb.deviantart.com/art/nfoo-Viewer-1-1-170638369)
it searches the directory of the music you're playing for .nfo, .txt & .log files and displays them in a wsh panel.
you could change the code a bit so it reads the lyrics tag for example, or let it search a txt file for the lyrics you need.
I made a track display panel that shows lyrics, it doesn't do synced lyrics though. It would be possible to make it do that, but since I don't have synced lyrics I can't be bothered. If anyone wants to modify it so it does, feel free.
You'll need something like lyricsgrabber2 to get the lyrics.
I can't remember if I posted this already, oh well.
Download: http://www.hydrogenaudio.org/forums/index....showtopic=83696 (http://www.hydrogenaudio.org/forums/index.php?showtopic=83696)
Marc, how tough would it be to implement a cycle mode for Thumbs 2?
@marc2003
just a quick question:
My "now playing" panel doesn't downloads artist pictures automatically even if it's ticked in the right click menu.
I always have to download them manually choosing "download artist art from lastfm".
Newest WSH_Panel, Samples, Columns_Ui and Foobar.
Since I have no Idea why it would be nice if you could help me out.
Hello,
Ok, so here is my lyrics script for WSH panel Mod ... it maybe needs some code optimization but it works fine apparently
get it here : http://pastebin.com/NHSLyrHu (http://pastebin.com/NHSLyrHu)
Lyriks 1.0 (build 20101012.0815) - a WSH lyrics module by Br3tt
- This WSH script get lyrics from TAG first then from local file in foobar2000\lyrics\
then it displays them (scrolling)
- It handles TXT and LRC format (sync handled), but not the LRC Enhanced format
(it translates eLRC to a normal LRC text)
- Comments, Blank lines, Info lines are ignored.
- Manual Scrolling possible with the mousewheel (double click on the panel to re-center on the active line)
- Requirements :
1) foobar2000
2) WSH Panel Mod component
3) this script in a WSH panel
4) Optional: a lyrics grabber (i.e: Lyric Show Panel by hidding the panel, foo_lyricsDB, ...)
- Some settings are available by using the panel Properties (right click on WSH panel -> Properties)
Please, gimme feedback
not that tough. laziness is a factor though.
my mistake. i've uploaded a fixed version or you can just change this on line 54...
if(arr.length == 0 && window.GetProperty("auto") == 1001) {
to this
if(arr.length == 0 && window.GetProperty("auto")) {
Thanks, it works now.
It's cool. I actually switched to Thumbs 1 now, so I don't even care anymore
I thought I'd asked this before, but I can't seem to find the question or answer anymore.
Anyway, is there a tutorial where I can learn the basics of what is needed to fully understand the structure of the code that is used in the WSH Panel Mod.
I'm able to alter the code (is it Jscript or Javascript?) here and there from existing scripts, but to start one from scratch is something different.
cheers r3v0
@marc2003
For some reason I´m having troubles with thumbs & thumbs2. I´m getting 0xc0000135 error from art.exe when trying to download the images.
If I set the custom folder mode say with "*.jpg" it always displays "no image". I´m using the latest version. Thanks in advanced.
^i think that error is because art.exe requires the net framework 2.0 installed.
as for custom folder mode simply put the path to a folder. you don't specify wildcards for filenames - it automatically reads all jpg files.
Falstaff - Just tried out your lyrics viewer script, and it works really well. I like it better than all the other lyrics display options. One request visually I would like is the option to use the default panel color. I tried to switch "plain color background" toggle to True in the properties, and I got a script error. I also tried to change the color values in the script itself and noticed you used RGBA instead of RGB so we can't edit that to match the rest of the panels.
Thanks for the script! Works great with synced and unsynced embedded lyrics! I don't have non-embedded lyrics so I can't attest to that performance.
Yep that was the reason. Got the config part as well.
Thanks marc2003, they are working nice
thanx for your feedback, i'll fix what you point to me with default background colour asap.
PS1: fix the script error by replacing line 168 : "g_bgcolour" by "g_plainbg_colour" ... my bad
PS2: RGBA() is like RGB() with just an alpha composant for adjusting tranparency ! just set the 4th value to 255 to obtain the same result of RGB()
WOW Falstaff, this is excellent script! Thanks for making it man
(http://i.imgur.com/2T88O.png)
- It would be nice "DEFAULT_OFFSET" to be synced with "LINE_HEIGHT"
- Some lyrics with timestamps aren't recognized. I couldn't find why
- Some time ago I made VBS that fetches lyrics automatically from dug's database: http://www.hydrogenaudio.org/forums/index....st&p=717583 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=70955&view=findpost&p=717583) Can you merge it somehow in your script if it is possible, as I don't understand JS?
can you give me this skin you make? it is very beautiful. please^^
Here is default UI theme (http://goo.gl/w2An)
@Falstaff: Also some lyrics aren't shown. I can't find reason why - same release, same tag scheme etc., but for some tracks lyrics are shown while for others not
gimme the lyrics file (if embedded lyrics, paste them in a .txt) that doesn't work, to check what's wrong with it.
*waits*
PS: maybe (if embedded lyrics) it's due to the TAG name used for the lyrics, not handled by my script ? I only check for %LYRICS%, %LYRIC%, %UNSYNCED LYRICS% and %UNSYNCED LYRIC% ...
Falstaff, those lyrics doesn't have CRLF separator, so line was too long perhaps?
For timestamped lyrics there are some issues. Valid format by your script is [mm:ss.cc]
- it will fail, if lyrics have millisecond [mm:ss.uuu]
- or if minute digit isn't padded with zero [m:ss.cc]
- or if any kind of lyrics have square brackets in it "["
So maybe you should check if string inside square brackets has ":" separators and separated parts are numbers. Maybe just translate any possible time stamp to 00:00.000 and then process it. Like if time stamp is m:ss then you quickly process it to mm:ss.000 and go
edit: perhaps even ":" as centisecond separator instead ".", can be found in some online services providing LRC. It shouldn't be too hard to consider all this different scenarios
hmm, weird LRC timestamp format btw ... but the script have to handle them, so ok, i'll try to include this schemes in bext version
your work is the best!! But it doesn't read (or load) the lrc file in the file's folder. for exam:" leka - trable is a friend.lrc"in the leka folder.
can you make it happen. because my lrc almost all exist with "lrc file" style
http://cid-7c6fa1eb8fb8f2b7.photos.live.co...%E5%9B%BE00.png (http://cid-7c6fa1eb8fb8f2b7.photos.live.com/self.aspx/Blog%20Images/%E6%88%AA%E5%9B%BE00.png)
as said in the comments of the script, "- This WSH script get lyrics from TAG first then from local file in foobar2000\lyrics\ "
be sure that your lrc files are stored in ...\foobar2000\
lyrics\ or just change this path by yours in the script ...
AND the filename must be
<artist> -<Track_title>.lrc (it's the syntax to respect for .lrc read from disk (generated by Lyrics Show panel 2, i used the same), but you can change the syntax from the script too if your is slightly different ==> in your screenshot, there is a blank char just after the "-", not in my syntax, so add a blank char in the script line 649
or wait for my fix, i will handle more filenames syntax to fit with more schemes
be sure that your lrc files are stored in ...\foobar2000\lyrics\ or just change this path by yours in the script ... AND the filename must be <artist> -<Track_title>.lrc (it's the syntax to respect for .lrc read from disk (generated by Lyrics Show panel 2, i used the same), but you can change the syntax from the script too if your is slightly different ==> in your screenshot, there is a blank char just after the "-", not in my syntax, so add a blank char in the script line 649
you didn't understand me
my music is under
"H:\music\Sarah\"
"H:\music\Michael Jackson\"
"H:\music\Westlife\"
"H:\music\Simon & Garfunkel\"
"H:\music\Carpenters\"
one artist's musics and lyrics are in one folder.
so how i write the code?
i try to write a code
var lyrics_dir =fb.Titleformat("$replace($replace(%path%,%filename_ext%,),\,\\)");
but it doesn't work,please help me
ps:the road in wsh is "\\"or "\“?
sorry, my bad.
let me check this and include that path as default too...
The samples that come with WSH Panel contain a script sample which lets you blur a text object and use that as a glow effect. Could someone with more experience in graphics programming explain to me how exactly this script works ?
Can this be applied to an image like a bitmap or png ?
- Simply defining an image as "img_to_blur" does not seem to have an effect.
Could this if the above works also be animated with a timerinterval object ?
Thanks for help.
How to overcome Laziness (http://www.wikihow.com/Overcome-Laziness) I'd like that, too. Any chance?
Vertical scrollbar
r0lZ
I am trying to use our scrollbar script with buttons in it.
I'm succeeding in defining the buttons (i'm using tooltip_buttons.js) I can use them,
but i can't see the buttons that are outside the view you start with, before you scroll.
I'm guessing the y-coordinate of the buttons should move also when you scroll,
but i can't seem to find where you defined it.
sorry, my bad.
when your modified work shows?
i really like this "lyriks" wsh code.
I will go to home , soon. Please hurry , thank you very very very very much
sorry, my bad.
// Paths
var metadb = fb.IsPlaying ? fb.GetNowPlaying() : false;
var lyrics_dir = fb.Titleformat("$replace($replace(%path%,%filename_ext%,),\,\\)").EvalWithMetadb(metadb);
g_lyrics_filename = artist.Eval() + " -" + title.Eval();
g_lyrics_filename = artist.Eval() + " - " + title.Eval();
// Paths
[s]var metadb = fb.IsPlaying ? fb.GetNowPlaying() : false;[/s]
var metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
function on_playback_new_track(info) {
g_playtimer && window.KillTimer(g_playtimer);
pos = 0;
g_scroll = 0;
g_is_scrolling = false;
get_lyrics();
change_focus();
if (g_lyrics_status > 0) {
g_playtimer = window.CreateTimerInterval(PLAYTIMER_VALUE);
To hejiame
- Requirements :
1) foobar2000
- This script don't make any changes to your files and write nothing on your system.
It's just a read&display data script.
// Text formatting function
function StringFormat() {
var h_align = 0,
v_align = 0,
trimming = 0,
flags = 0;
switch (arguments.length) {
// fall-thru
case 4:
flags = arguments[3];
case 3:
trimming = arguments[2];
case 2:
v_align = arguments[1];
case 1:
h_align = arguments[0];
break;
default:
return 0;
return ((h_align << 28) | (v_align << 24) | (trimming << 20) | flags);
StringAlignment = {
Near: 0,
Centre: 1,
Far: 2
var lc_stringformat = StringFormat(StringAlignment.Near, StringAlignment.Centre);
var cc_stringformat = StringFormat(StringAlignment.Centre, StringAlignment.Centre);
var rc_stringformat = StringFormat(StringAlignment.Far, StringAlignment.Centre);
// IO Mode
var ForReading = 1;
var ForWriting = 2;
var ForAppending = 8;
// Paths
if (metadb){
else{
var lyrics_dir = "C:\\"
//fb.trace(lyrics_dir);
lyrics_folder_exists();
// new object
sentence = function () {
this.type = null;
this.timer = 0;
this.text = "";
this.total_lines = 0;
this.ante_lines = 0;
function RGBA(r, g, b, a) {
return ((a << 24) | (r << 16) | (g << 8) | (b));
// ================================================/ TF
var len_seconds = fb.Titleformat("%length_seconds%");
var elap_seconds = fb.TitleFormat("%playback_time_seconds%");
var artist = fb.Titleformat("$replace(%artist%,'/','_')");
var title = fb.Titleformat("%title%");
var lyrics = fb.TitleFormat("[$if2(%LYRICS%,$if2(%LYRIC%,$if2(%UNSYNCED LYRICS%,%UNSYNCED LYRIC%)))]");
// ================================================/ Declarations
var g_font = gdi.Font("segoe ui", 12, 0);
var g_playtimer;
var ww = 0,
wh = 0;
var g_fso = new ActiveXObject("Scripting.FileSystemObject");
var g_file = null;
var g_tab = Array();
var g_scroll = 0;
var g_lyrics_filename;
var g_lyrics_status;
var focus = 0;
var focus_next = 0;
var g_plainbg_colour;
var g_ovbg_normalcolour;
var g_ovbg_highlightcolour;
var g_txt_normalcolour;
var g_txt_highlightcolour;
var g_txt_shadowcolour;
var centiemes = 0;
var g_is_scrolling = false;
var g_multi_balise = false;
var g_balise_total;
var g_balise_char_offset;
var g_tab_length;
var midpoint;
var pos;
// ================================================/ Settings
var PLAYTIMER_VALUE = window.GetProperty("Timer value in ms [10;100]", 10);
var LINE_HEIGHT = window.GetProperty("Line height [20;30]", 24);
var TEXT_SHADOW = window.GetProperty("Text shadow (true/false)", true);
var PLAIN_COLOR_BG = window.GetProperty("Plain colour background (true/false)", false);
var DITHER = window.GetProperty("Top & Botom dither (true/false)", true);
var H_PADDING = window.GetProperty("Horizontal padding [0;20]", 20);
var TXT_ALIGN = window.GetProperty("Text alignment (left/center/right)", "center");
var LIGHT_BG = window.GetProperty("Light background", true);
var DEBUG = false;
var DEFAULT_OFFSET = 29;
// START
var k;
ww = window.Width;
wh = window.Height;
// exit test on useless calls made (wsh tweak)
if (!ww && !wh) return true;
midpoint = wh / 2 - LINE_HEIGHT / 2;
// colours
g_plainbg_colour = RGBA(140, 200, 250, 255);
g_ovbg_normalcolour = RGBA(000, 000, 000, 130);
g_ovbg_highlightcolour = RGBA(020, 100, 240, 130);
g_txt_normalcolour = RGBA(200, 200, 210, 255);
g_txt_highlightcolour = RGBA(255, 255, 255, 255);
g_txt_shadowcolour = RGBA(000, 000, 000, 150);
if (fb.IsPlaying || fb.IsPaused) {
g_scroll = 0;
get_lyrics();
change_focus();
k = g_tab[focus].ante_lines * LINE_HEIGHT;
pos = midpoint - k;
} else {
delta = (g_tab[g_tab.length - 1].ante_lines + g_tab[g_tab.length - 1].total_lines);
pos = (wh / 2) - (delta * LINE_HEIGHT / 2);
PLAIN_COLOR_BG && gr.FillSolidRect(0, 0, ww, wh, g_bgcolour);
show_lyrics(gr, g_tab, pos);
DEBUG && gr.GdiDrawText(g_lyrics_status.toString(), g_font, g_normalcolour, 5, 5, ww, LINE_HEIGHT, DT_TOP | DT_LEFT | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
DITHER && gr.FillGradRect(0, 0, ww, 11, 90, g_txt_shadowcolour, RGBA(0, 0, 0, 0));
DITHER && gr.FillGradRect(0, wh - 11, ww, 11, 270, g_txt_shadowcolour, RGBA(0, 0, 0, 0));
function on_mouse_lbtn_dblclk(x, y, mask) {
on_size();
function on_mouse_leave() {
window.Repaint();
function on_playback_time(time) {
// at each new seconde, centiemes is reset to 0 (Increment on timer every 100ms)
centiemes = 0;
if (g_lyrics_status == 0) {
if (elap_seconds.Eval() == 3) {
on_size();
window.Repaint();
pos = 0;
g_scroll = 0;
get_lyrics();
change_focus();
// fb.trace(lyrics_dir);
function on_playback_seek(time) {
var k;
g_scroll = 0;
change_focus();
pos = midpoint - k;
window.Repaint();
function on_playback_stop(reason) {
if (reason == 0) {
// Stop
window.Repaint();
function on_mouse_wheel(delta) {
if (delta > 0) {
pos = (pos >= midpoint) ? pos : pos + LINE_HEIGHT;
} else {
pos = (pos <= (wh / 2 - g_tab_length * LINE_HEIGHT)) ? pos : pos - LINE_HEIGHT;
window.Repaint();
var t1 = elap_seconds.Eval() * 100 + centiemes;
var t2 = len_seconds.Eval() * 100;
var p1, p2;
if (t1 > t2 - 100) {
if (g_playtimer) {
if (g_playtimer.ID == id) {
if (!g_is_scrolling && t1 >= g_tab[focus_next].timer) {
p1 = g_tab[focus].ante_lines * LINE_HEIGHT;
p2 = g_tab[focus_next].ante_lines * LINE_HEIGHT;
g_scroll = p2 - p1;
change_focus();
g_is_scrolling = true;
if (g_scroll > 0) {
pos--;
g_scroll--;
window.Repaint();
} else {
centiemes = (centiemes > 98) ? 0 : (centiemes + 1);
function show_lyrics(gr, tab, posy) {
var i, k;
var text_colour;
var txt_align;
gr.SetTextRenderingHint(5);
switch (TXT_ALIGN.toUpperCase()) {
case "LEFT":
txt_align = lc_stringformat;
break;
case "CENTER":
txt_align = cc_stringformat;
break;
case "RIGHT":
txt_align = rc_stringformat;
break;
default:
if (posy >= 0) {
LIGHT_BG && gr.FillSolidRect(0, Math.floor(posy - wh / 2), ww, Math.floor(wh / 2), g_ovbg_normalcolour);
} else {
LIGHT_BG && gr.FillSolidRect(0, 0, ww, wh, g_ovbg_normalcolour);
for (i = 0; i < tab.length; i++) {
if (Math.round(posy) >= (LINE_HEIGHT * -4) && Math.round(posy) < wh) {
if (i == focus && g_lyrics_status == 1) {
text_colour = g_txt_highlightcolour;
} else {
} else {
text_colour = g_txt_normalcolour;
LIGHT_BG && gr.FillSolidRect(0, Math.floor(posy), ww, (tab[i].total_lines * LINE_HEIGHT - 0), (i == focus && tab[i].text.length > 1 && g_lyrics_status == 1) ? g_ovbg_highlightcolour : g_ovbg_normalcolour);
TEXT_SHADOW && gr.DrawString(tab[i].text, g_font, g_txt_shadowcolour, 1 + H_PADDING, Math.floor(posy) + 0, ww - H_PADDING * 2, (tab[i].total_lines * LINE_HEIGHT), txt_align);
TEXT_SHADOW && gr.DrawString(tab[i].text, g_font, g_txt_shadowcolour, 1 + H_PADDING, Math.floor(posy) + 1, ww - H_PADDING * 2, (tab[i].total_lines * LINE_HEIGHT), txt_align);
gr.DrawString(tab[i].text, g_font, text_colour, 0 + H_PADDING, Math.floor(posy), ww - H_PADDING * 2, (tab[i].total_lines * LINE_HEIGHT), txt_align);
posy = Math.floor(posy + LINE_HEIGHT + ((tab[i].total_lines - 1) * LINE_HEIGHT));
if (g_lyrics_status > 0 && posy <= wh) {
LIGHT_BG && gr.FillSolidRect(0, Math.floor(posy), ww, Math.floor(wh), g_ovbg_normalcolour);
function grab_timer(tab, str, count, timer_prec, balise) {
var tminutes, tsecondes, tcentiemes;
var balise_type = -1;
var i;
var redo = 0;
var f_sentence = new sentence;
var b = balise - 1;
while (balise_type < 0) {
if (g_lyrics_status == 1 && balise > 0) {
if (str.substring(0, 1) == "[") {
tminutes = str.substring(1 + (b * g_balise_char_offset), 3 + (b * g_balise_char_offset));
tsecondes = str.substring(4 + (b * g_balise_char_offset), 6 + (b * g_balise_char_offset));
// balise type test [99:99] or [99:99.99]
if (str.substring(6, 7) == "]") {
balise_type = 1;
tcentiemes = 0;
} else {
balise_type = 2;
tcentiemes = str.substring(7 + (b * g_balise_char_offset), 9 + (b * g_balise_char_offset));
switch (str.substring(1, 2)) {
case "0":
f_sentence.type = "ly";
f_sentence.timer = Math.round(tminutes) * 60 * 100 + Math.round(tsecondes) * 100 + Math.round(tcentiemes) - DEFAULT_OFFSET;
f_sentence.text = remove_enhanced_balises(str.substring(g_balise_char_offset * g_balise_total, str.length));
break;
case "1":
break;
case "2":
break;
case "3":
break;
default:
// technical info (not displayed)
f_sentence.type = null;
f_sentence.timer = 0;
f_sentence.text = "";
} else {
// no balise ==> line is set as a comment (as a blank line)
if (count == 0) g_lyrics_status = 2;
balise_type = 0;
f_sentence.timer = timer_prec;
} else {
f_sentence.type = "tx";
// check if it's not finally a synch lyrics (lrc) with some first lines with no timestamp!
g_lyrics_status = 1;
g_balise_char_offset = 7;
} else if (str.substring(9, 10) == "]") {
g_balise_char_offset = 10;
} else {
balise_type = 0;
f_sentence.text = str;
} else {
balise_type = 0;
redo++;
return f_sentence;
function load_file(filePath, fileName) {
var tab = Array();
var fline = new sentence;
var count = 0;
var enr = 0;
var str = "";
var balise;
var delta;
g_file = open_file(filePath, fileName, ForReading);
g_balise_shift = 0;
while (!g_file.AtEndOfStream) {
str = g_file.ReadLine();
g_balise_total = 0;
if (g_lyrics_status == 1) {
balise = 0; // b = # of balise
while (str.substring(balise * 7, balise * 7 + 1) == "[") {
balise += 1;
} else {
while (str.substring(balise * 10, balise * 10 + 1) == "[") {
balise += 1;
g_balise_total = balise;
} else if (enr == 0) {
g_balise_total = 1;
} else {
g_balise_total = 1;
if (g_balise_total > 1) g_multi_balise = true;
else g_multi_balise = false;
// str loop for each balise found for it ==> occurs created in the array
for (balise = 1; balise <= g_balise_total; balise++) {
fline = grab_timer(tab, str, count, (count > 0) ? tab[count - 1].timer : 0, balise);
if (fline.type != null) {
tab.push(fline);
count++;
enr += 1;
close_file(g_file);
// if file read is empty, set lyrics as not found to avoid script errors
if (count == 0) {
g_lyrics_status = 0;
g_tab = load_track_info();
return g_tab;
} else {
// add a default last sentence with a timer maximum (for ease of use focus line search method)
tab.push(new sentence);
tab[count].type = "ly";
tab[count].timer = 9999999;
tab[count].text = "---";
tab[count].total_lines = 1;
tab[count].ante_lines = tab[count - 1].ante_lines + tab[count - 1].total_lines;
return sort_tab(tab);
function parse_tag(tag) {
var t_tab = Array();
var i, j, count;
j = 0;
for (i = 0; i < tag.length; i++) {
if (tag.charCodeAt(i) == 10) {
t_tab.push(tag.substring(j, i));
j = i + 1;
return parse_line(t_tab);
function parse_line(tagtab) {
var tab = Array();
var count = 0;
var enr = 0;
var str = "";
var balise;
var delta;
g_balise_shift = 0;
for (enr = 0; enr < tagtab.length; enr++) {
str = tagtab[enr];
g_balise_total = 0;
balise += 1;
} else {
balise += 1;
g_balise_total = 1;
} else {
g_balise_total = 1;
tab.push(fline);
count++;
if (count == 0) {
return g_tab;
} else {
function load_track_info() {
var tab = Array(new sentence, new sentence, new sentence, new sentence);
var count = 0;
tab[count].type = "tx";
count++;
tab[count].text = artist.Eval();
count++;
tab[count].text = title.Eval();
count++;
count++;
return calc_lines(tab);
function open_file(filePath, fileName, ioMode) {
var fileInst = null;
var bool = file_exists(filePath + fileName);
if (bool) {
fileInst = g_fso.OpenTextFile(filePath + fileName, ioMode);
return fileInst;
function close_file(fileInst) {
fileInst.Close();
function read_file(fileInst) {
var line = fileInst.ReadLine();
return line;
function folder_exists(folderPath) {
var fso, bool;
bool = fso.FolderExists(folderPath);
return bool;
function file_exists(filePath) {
var fso, bool;
bool = fso.Fileexists(filePath);
return bool;
function lyrics_folder_exists() {
var fso;
var bool = 1;
if (folder_exists(lyrics_dir) == false) {
fso.CreateFolder(lyrics_dir);
bool = 0;
return bool;
function get_lyrics() {
var i = 0;
var nbl = 0;
var delta;
var tag;
var bool_tag = false;
// reset lyrics tab
if (g_tab.length > 0) g_tab.splice(0, g_tab.length);
pos = midpoint;
focus = 0;
window.Repaint();
// check TAGs
tag = lyrics.Eval();
if (tag.length > 0) {
bool_tag = true;
if (tag.substring(0, 1) == "[") g_lyrics_status = 1;
else g_lyrics_status = 2;
} else {
// check files
if (file_exists(lyrics_dir + g_lyrics_filename + ".lrc")) {
g_lyrics_filename = g_lyrics_filename + ".lrc";
} else {
if (file_exists(lyrics_dir + g_lyrics_filename + ".txt")) {
g_lyrics_filename = g_lyrics_filename + ".txt";
} else {
// if lyrics found
if (bool_tag) {
g_tab = parse_tag(tag);
} else {
g_tab = load_file(lyrics_dir, g_lyrics_filename);
// console dump of the memory tab loaded
for (i = 0; i < g_tab.length; i++) {
//fb.trace("line #"+i+" = "+g_tab[i].text + " / "+g_tab[i].timer + " / "+g_tab[i].total_lines + " / "+g_tab[i].ante_lines);
} else {
if (g_lyrics_status == 2) {
for (i = 0; i < g_tab.length - 1; i++) {
g_tab[i].timer = i * Math.floor(len_seconds.Eval() * 100 / g_tab.length);
function change_focus() {
var i, j;
// search line index just after actual timer
if (g_tab[i].timer > t1) break;
focus_next = i;
focus = (i > 0) ? i - 1 : 0;
// now i check if there are more than one line with the same timer as focus one & if found, i take it as new focus 'cause it's the first (not a blank line)
if (focus > 0) {
for (i = 0; i < focus; i++) {
if (g_tab[i].timer == focus) {
focus = i;
break;
function calc_lines(ctab) {
var i, j;
var padx = 0;
g_tab_length = 0;
for (i = 0; i < ctab.length; i++) {
// calc sentence #lines to display / window.width
if (ctab[i].type != null) {
var tmp_img = gdi.CreateImage(ww - (H_PADDING * 2) - padx, 100);
var gp = tmp_img.GetGraphics();
var lineh = gp.MeasureString(ctab[i].text, g_font, 0, 0, ww - (H_PADDING * 2) - padx, wh).Height;
ctab[i].total_lines = (lineh / LINE_HEIGHT) > Math.floor(lineh / LINE_HEIGHT) ? Math.floor(lineh / LINE_HEIGHT) + 1 : Math.floor(lineh / LINE_HEIGHT);
ctab[i].ante_lines = 0;
for (j = 0; j < i; j++) {
ctab[i].ante_lines += ctab[j].total_lines;
CollectGarbage();
g_tab_length += ctab[i].total_lines;
return ctab;
function sort_tab(tab2sort) {
var tab = Array();
var i, j;
var tmp = new sentence;
var smallest = 0;
for (i = 0; i < tab2sort.length; i++) {
for (j = i; j < tab2sort.length; j++) {
if (tab2sort[i].timer > tab2sort[j].timer) {
tmp = tab2sort[i];
tab2sort[i] = tab2sort[j];
tab2sort[j] = tmp;
tab.push(tab2sort[i]);
tab = calc_lines(tab);
return tab;
function remove_enhanced_balises(str) {
var i;
var chr1, chr2;
var new_str = "";
for (i = 0; i < str.length; i++) {
chr1 = str.substring(i, i + 1);
if (i + 10 <= str.length) chr2 = str.substring(i + 9, i + 10);
else chr2 = null;
if (chr1 == "<" && chr2 == ">") {
i = i + 9;
} else {
new_str = new_str + chr1;
return new_str;
hmmn.....
Think about the importance of the problem or goal. Is it something you can actually afford to ignore?
let me think about that.
samples updated:
thumbs2: added "cycle" image mode. default is off but can be set to 5, 10 or 20 seconds.
new script: themed toolbar buttons. can be seen here on this old screenshot. clicky (http://k5sbdw.blu.livefilestore.com/y1p7MP-0C-g5IZP0z79nL9BJxRtkCt5MOKjvxx7dLABSElo5kt4WOSI4ZKsyF5xOMSdMGsIpoDJW2VJcK2Bhf9xN5PUYUrRZuih/similar.png)
how they look depend on your windows theme - they don't work on windows classic. XP luna and aero/basic in vista/7 work fine as should all 3rd party themes.
sorry, my bad.
[00:32.13]?????????????
[00:37.96]?????????
[00:42.72]
[02:05.69][00:43.23]?????????
[02:10.61][00:47.96]?????????
[02:15.86][00:53.24]?????????????
[02:21.08][00:58.55]?????????
[02:26.04][01:03.72]
[03:08.01][02:26.39][01:04.13]????????????
a huge problem?the Blank lines can't show up
e.x.when it is [00:42.72][02:26.04][01:03.72]
check it
i'll see.
i'll see.
%lyric% can show blank line
.lrc file can't show blank line
Great job, Marc! Thx a lot ...
update!
Lyriks 1.1 (build 20101020.1225) - a WSH lyrics module by Br3tt
- This WSH script get lyrics from TAG first then from local file in Music folder then in foobar2000\lyrics\ and finally it displays them (scrolling+sync)
- It handles TXT and LRC format (sync handled), but not the LRC Enhanced format (translated to simple LRC format)
- exotics timestamps are now handled (like [9:99], [99:99.999], [9:99.999], [99:99:999] ...)
- filenames supported are : <%artist%> -<%title%>.lrc (or .txt) AND <%artist%> - <%title%>.lrc (or .txt)
- Comments, Blank lines (no timestamp) and Info lines (ar:, ti, ...) are ignored.
- Requirements :
1) foobar2000
3) this script!
- This script don't make any changes to your files and write nothing on your system, except the creation of the folder foobar2000/lyrics if not found
Get it from here:
http://pastebin.com/LPyVy09c (http://pastebin.com/LPyVy09c)
Quick Changelog:
- exotic timestamps => converted to my default : [99:99.99]
- lyrics in music folder ckecked
- blank lines not displayed on multi-timestamp lines => fixed
- tweaks...
*waits for feedback*
I love you Falstaff!!!!
So i bit the bullet and been trying to use code with WSH panel. It's at least far better than the old ways and also far more flexible. I picked up the simple bio script in marc2003 sample pack and modified it a little into this (http://pastebin.com/cRZ6SwQN) (basically it supports cache life time and I changed the last.fm button feature a little). I hope someone can help me with the flashing tooltip problem. Thanks and marc2003, you were great with these examples to help me pick up using this component.
Me too You are great
May I not leave you loose, but suggesting another feature? - If user clicks on timestamped lyrics row then seek the track to that position. I know you can do it, as you've made WSH seekbar among other things, but don't know what you think about it?
@romor :
it's a pretty good idea ... will be added asap!
@romor :
I have another idea.
why won't you add " drag lrc to control playing progress" capability
pic here (http://cid-7c6fa1eb8fb8f2b7.skydrive.live.com/self.aspx/Blog%20Images/QQ%e6%88%aa%e5%9b%be%e6%9c%aa%e5%91%bd%e5%90%8d.png)
another saying : "Drag lyric of a song controlling the playing progress of a song"
if you know chinese,I will say "??????????"
I think there is minor foobar or WSH component issue related to AAC encoded files with LYRICS tag (not your script, but why not report it):
(http://i.imgur.com/4stTJ.png)
text display component vs. WSH lyrics element
also Falstaff can you consider scripts to automagically supply lyrics to your WSH script, as I can make also VBS for lyrdb.com or some other?
weird, it should works as all other LYRICS tag!
is the tag well named : LYRICS or LYRIC ? Are you sure it's not due to my script ?
to check it, add this line in the script, just after line #634 (tag = lyrics.Eval();)
fb.trace("tag read="+tag);
replay the track to run the script, then check the console to check what's the value returned for tag variable!
if the result is not the whole lyrics text, so, it's probably a WSH component bug with tag in AAC files, BUT if it's correct, it's a bug from my script, so give me the lyrics for me testing and fixing the problem.
here is console output:
Opening track for playback: "C:\Users\Admin\Music\Library\Pink Floyd\Early Singles\08 - Julia Dream.m4a"
tag read=[artist:Pink Floyd][title:Julia Dream][album:Relics][0:08.200]Sunlight bright upon my pillow[0:12.200]Lighter than an eiderdown[0:16.400]Will she let the weeping willow[0:20.600]Wind his branches round[0:26.600]Julia Dream, dreamboat queen, queen of all my dreams[0:36.050][0:37.400]Every night I turn the light out[0:41.400]Waiting for the velvet bride[0:45.600]Will the scaly armadillo[0:49.600]Find me where I'm hiding[0:55.600]Julia Dream, dreamboat queen, queen of all my dreams[1:21.325][1:25.000]Will the misty master break me[1:29.000]Will the key unlock my mind[1:33.200]Will the following footsteps catch me[1:37.200]Am I really dying[1:42.450][1:43.200]Julia Dream, dreamboat queen, queen of all my dreams[1:51.600]Julia Dream, dreamboat queen, queen of all my dreams[2:00.000]Julia Dream, dreamboat queen, queen of all my dreams[2:08.400]Julia Dream, dreamboat queen, queen of all my nightmares[2:17.933][2:34.616]
@romor :
Falstaff, also this could maybe related to CRLF expectation by your script as posted before. This files that have LYRICS tag and have 0D as line separator:
(http://i.imgur.com/t5w4h.png)
so on a second thought, it's perhaps related to that issue rather then file format
edit: just try to enter lyrics tag with one long line and see what will happen
thanks, i understand what's the problem ==> no crlf after each line and lyrics begin with [infos], so, this single line is bypassed! and there is no lyrics to display after ...
==> should be fixed with this update (i test "[" as a line delimiter) : http://pastebin.com/G9fnCnXR (http://pastebin.com/G9fnCnXR)
@romor :
oops~??????????????????????????
What you suggested is the same as what romor suggested
Falstaff GJ~~
(http://i.imgur.com/36Zv9.png)
I'm discovering this mod and trying to make a seekbar.
Here is the code I am using, it works well except the bar is kinda green like Windows 7 status bar and I'd prefer it white.
What am I supposed to change to do so ?
Thanks in advance for your support.
var g_theme = window.CreateThemeManager("PROGRESS");
var g_bar_height = 4;
var g_cycles = 0;
var ww = 0,
wh = 0;
var top = 0;
var g_pos = 0;
var g_drag = false;
var g_length = 1;
function clamp(x, l, h) {
return (x < l) ? l : ((x > h) ? h : x);
ww = window.Width;
wh = window.Height;
top = (wh - g_bar_height) >> 1;
g_theme.SetPartAndStateID(1, 0);
g_theme.DrawThemeBackground(gr, 0, top, ww, g_bar_height);
if (fb.IsPlaying && g_length > 0) {
g_theme.SetPartAndStateID(5, fb.IsPaused ? 3 : 1);
g_theme.DrawThemeBackground(gr, 0, top, g_pos, g_bar_height);
function on_mouse_lbtn_down(x, y) {
if (g_length > 0) {
g_drag = true;
if (g_length > 0 && g_drag) {
g_drag = false;
fb.PlaybackTime = g_length * g_pos / ww;
if (g_drag) {
g_pos = clamp(x, 0, ww);
window.Repaint();
fb.PlaybackTime = fb.PlaybackTime + delta * 2;
if (!g_drag) {
if (g_length > 0) g_pos = ww * time / g_length;
window.Repaint();
function on_playback_seek() {
if (!g_drag && g_length > 0) window.Repaint();
function on_playback_pause() {
window.Repaint();
function on_playback_stop() {
g_length = 0;
g_pos = 0;
g_drag = false;
window.Repaint();
g_length = fb.PlaybackLength;
g_pos = 0;
g_drag = false;
window.Repaint();
if (fb.IsPlaying) on_playback_new_track();
Lyriks 1.1 (build 20101021.1105) - a WSH lyrics module by Br3tt
here is a fix, because the last script contains an error in synch when lyrics are read from a file (ok from a tag) :
http://pastebin.com/LJEFwEiu (http://pastebin.com/LJEFwEiu)
I tried to use your script Falstaff, but is it in LRC format that I must have a newline character at the end of my lyrics tag? My unsynced lyrics always has the last line missing.
For example, here's what in my lyrics tag:
At the very beginning, we were created, to live
together but soon, we hated in greed
and selfishness we, could never prosper,
created enemies against god's will.
and the last line is replaced by "---" by your code.
it was a bug (when lyrics in Tag), script updated :
http://pastebin.com/UUNQgJmN (http://pastebin.com/UUNQgJmN)
thanx for reporting!
I fixed my own problem. Basically don't set tooltip text inside the on_mouse_move function.
Lyriks 1.2 (build 20101023.1300) - a WSH lyrics module by Br3tt
new version of the script (optimized and cleaned)
http://pastebin.com/JsBSZx6v (http://pastebin.com/JsBSZx6v)
Next version will have reflection support and will look like this (for now)
(http://img543.imageshack.us/img543/8669/captureov.png)
I made an artist art panel based off samples from marc2003. In order to download artist art from correct artist name, I copied and modified the get() and load() functions from simple biography panel into lastfm_load(type) and lastfm_get(lang) and I put them into common.js. The lastfm_load function will set variable lastfm_artist with correct artist from lastfm and fire off an notification but somehow this notification doesn't fire and I'm stuck with my start() function doesn't get called. Please help me.
Relevant files. (https://docs.google.com/leaf?id=0By5oGIJU70FaZTZjM2NiYmYtZjQ0MS00MjllLTgzNzctYTRmZGUzYjU3MGQy&hl=en)
if you want an album art panel that automatically downloads artist art from last.fm then just modify the "now playing" script (by default it also shows the cover art and song details but you can easily remove this from the on_paint function)
(you might also be interested in the thumbs/thumbs2 scripts as they also download artist art as well)
@romor :
@romor :
nope, i prefer : user clicks on timestamped lyrics row then seek the track to that position.
@romor :
but not all lines show up. If a line doesn't show ,you click what? if the window is small, it can show rare ? very little ?lines?or say not too many lines),
so that the lines that you can click is not too much. but Drag can show more lines, becanse it doesn't restricted by the lines that the Lyrik window can show.
I've finally finished my config with WSH panels. It was pretty fun to do. I based my code on marc2003's, so some credits go to you, Marc2003 for doing the samples. If not for those I wouldn't have known left from right.
(http://thumbnails15.imagebam.com/10393/a97e62103928211.jpg) (http://www.imagebam.com/image/a97e62103928211) (http://thumbnails34.imagebam.com/10393/ed0fa8103928218.jpg) (http://www.imagebam.com/image/ed0fa8103928218) (http://thumbnails14.imagebam.com/10393/86dcfd103928232.jpg) (http://www.imagebam.com/image/86dcfd103928232) (http://thumbnails11.imagebam.com/10393/c99273103928247.jpg) (http://www.imagebam.com/image/c99273103928247) (http://thumbnails14.imagebam.com/10393/e0f930103928269.jpg) (http://www.imagebam.com/image/e0f930103928269)
Panels code (https://docs.google.com/leaf?id=0By5oGIJU70FaNGZkN2FmOTMtZTJkNi00Y2Q2LTk3ZGUtYmZkZmMyYzIwYjI4&hl=en)
Folks who can help me change the default seekbar script to look like on the pic ?
(http://thumbnails15.imagebam.com/10398/fde9c8103979607.jpg) (http://www.imagebam.com/image/fde9c8103979607)
I'm having trouble adjusting "on_mouse_move" after I set the margins. Any idea ? The default script is this
Themed seekbar (http://pastebin.com/JSMTuyRY)
var g_cycles = 0;
var ww = 0,
wh = 0;
var top = 0;
var g_pos = 0;
var g_drag = false;
var g_length = 1;
ww = window.Width;
wh = window.Height;
if (g_length > 0) {
g_drag = true;
g_drag = false;
if (g_drag) {
window.Repaint();
if (!g_drag) {
window.Repaint();
window.Repaint();
g_length = 0;
g_pos = 0;
g_drag = false;
window.Repaint();
g_pos = 0;
g_drag = false;
window.Repaint();
Try lowering or raising the values here
Sorry but I dunno if the thememanager contains a progressbar color of white.
a lrc file shows wrong when 01:00.00
please check it
song?download (http://cid-7c6fa1eb8fb8f2b7.office.live.com/self.aspx/.Public/Antoine%20Dodson%20-%20Bed%20Intruder%20Song.mp3)
lrc file?download (http://cid-7c6fa1eb8fb8f2b7.office.live.com/self.aspx/.Public/Antoine%20Dodson%20-%20Bed%20Intruder%20Song.lrc)
http://pastebin.com/yJW2NUwX (http://pastebin.com/yJW2NUwX)
change the variable "H_padding" to adjust the distance between the bar and the margins.
BTW, the function clamp can be altered by this
return Math.min(Math.max(x,l),h);
P.S. your "mint" tastes wonderful~
please check it
i'll check it asap (maybe a bug fixed yesterday for some kind of ts!!!), thanks for reporting, update to come with the fix
Please, could you give me very detailed explanation on how to install your package this with all the nice last.fm tabulations ?
I think you better create a new thread asking how to create tab in your specific user interface component (DUI or CUI), as it is unrelated to this thread. After you have create the tabs, all you need to do is to import my panels code. How to do that has been included in my pack to some details, if you still need help for that, you can ask here, then.
Lastly, the code inside my pack is old and has some problems with certain responses from last.fm. I have fixed these issues in my current code but I'm at work now, will update the pack later.
please check it
song:download (http://cid-7c6fa1eb8fb8f2b7.office.live.com/self.aspx/.Public/Antoine%20Dodson%20-%20Bed%20Intruder%20Song.mp3)
lrc file:download (http://cid-7c6fa1eb8fb8f2b7.office.live.com/self.aspx/.Public/Antoine%20Dodson%20-%20Bed%20Intruder%20Song.lrc)
Error: WSH Panel Mod ({96603E1C-15B1-4657-BEB3-A2A5389CA2BF}): Microsoft JScript 运行时错误:
无效的过程调用或参数
Ln: 769, Col: 5
<source text only available in compile time>
Ln: 769 is
var tpath = Array(lyrics_dir1.EvalWithMetadb(g_metadb), lyrics_dir2);
- Requirements :
1) foobar2000
3) this script!
var h_align = 0, v_align = 0, trimming = 0, flags = 0;
// fall-thru
case 4:
case 3:
case 2:
case 1:
break;
default:
return 0;
StringAlignment = {
Near: 0,
Centre: 1,
Far: 2
var lt_stringformat = StringFormat(StringAlignment.Near, StringAlignment.Near);
var ct_stringformat = StringFormat(StringAlignment.Centre, StringAlignment.Near);
var rt_stringformat = StringFormat(StringAlignment.Far, StringAlignment.Near);
var lb_stringformat = StringFormat(StringAlignment.Near, StringAlignment.Far);
var cb_stringformat = StringFormat(StringAlignment.Centre, StringAlignment.Far);
var rb_stringformat = StringFormat(StringAlignment.Far, StringAlignment.Far);
// Use with GdiDrawText()
var DT_LEFT = 0x00000000;
var DT_RIGHT = 0x00000002;
var DT_TOP = 0x00000000;
var DT_WORDBREAK = 0x00000010;
// IO Mode
var ForReading = 1;
var ForWriting = 2;
// Paths
var lyrics_dir1 = fb.Titleformat("$replace($replace(%path%,%filename_ext%,),\,\\)");
var lyrics_dir2 = fb.FoobarPath + "lyric\\";
// new objects
this.timer = 0;
this.text = "";
var len = fb.Titleformat("%length%");
var elap = fb.TitleFormat("%playback_time%");
var remain = fb.TitleFormat("%playback_time_remaining%");
var remain_seconds = fb.Titleformat("%playback_time_remaining_seconds%");
var g_font = gdi.Font("calibri", 12, 2);
var g_playtimer;
var g_metadb;
var ww = 0, wh = 0;
var DEBUG = false;
var g_file = null;
var g_scroll=0;
var g_lyrics_path;
var focus=0;
var focus_next=0;
var g_ovbg_lineseparatorcolour;
var centiemes = 0;
var g_balise_total;
var g_balise_char_offset = 10;
var g_tab_length;
var g_txt_align;
var midpoint;
var pos;
// START
function on_size() {
var k;
ww = window.Width;
wh = window.Height;
g_metadb = fb.IsPlaying ? fb.GetNowPlaying() : false;
if(!ww && !wh) return true;
// colour definitions
// g_plainbg_colour = RGBA(140, 200, 250, 255);
// g_ovbg_normalcolour = RGBA(000, 000, 000, 255);
// g_ovbg_lineseparatorcolour = RGBA(000, 000, 000, 255);
// g_ovbg_highlightcolour = RGBA(020, 100, 240, 130);
// g_txt_normalcolour = RGBA(200, 200, 210, 255);
// g_txt_highlightcolour = RGBA(255, 255, 255, 255);
// g_txt_shadowcolour = RGBA(000, 000, 000, 150);
g_ovbg_normalcolour = RGBA(255, 255, 255, 255);
g_ovbg_lineseparatorcolour = RGBA(255, 255, 255, 255);
g_ovbg_highlightcolour = RGBA(255, 255, 255, 255);
g_txt_normalcolour = RGBA(120, 120,120, 255);
// g_txt_highlightcolour = RGBA(148,148,239, 255);
g_txt_highlightcolour = RGBA(0,128,255, 255);
g_txt_shadowcolour = RGBA(255, 255, 255, 200);
if(fb.IsPlaying||fb.IsPaused) {
g_scroll=0;
get_lyrics();
change_focus();
if(g_lyrics_status>0) {
pos = midpoint - k;
} else {
delta = (g_tab[g_tab.length-1].ante_lines + g_tab[g_tab.length-1].total_lines);
function on_paint(gr) {
PLAIN_COLOR_BG && gr.FillSolidRect(0, 0, ww, wh, g_plainbg_colour);
DITHER && gr.FillGradRect(0, 0, ww, 11, 90, g_txt_shadowcolour, RGBA(0,0,0,0));
DITHER && gr.FillGradRect(0, wh-11, ww, 11, 270, g_txt_shadowcolour, RGBA(0,0,0,0));
DITHER && gr.FillGradRect(0, 0, ww, 1, 90, g_txt_shadowcolour, RGBA(0,0,0,0));
DITHER && gr.FillGradRect(0, wh-2, ww, 1, 90, RGBA(0,0,0,0), g_txt_shadowcolour);
on_size();
window.Repaint();
centiemes = 0;
if(g_lyrics_status==0) {
if(elap_seconds.Eval()==3) {
on_size();
window.Repaint();
pos=0;
g_scroll = 0;
get_lyrics();
change_focus();
var k;
g_scroll = 0;
change_focus();
pos = midpoint - k;
window.Repaint();
if(reason==0) {
// Stop
window.Repaint();
if(delta>0) {
pos = (pos>=midpoint)?pos:pos + LINE_HEIGHT;
} else {
pos = (pos<=(wh/2 - g_tab_length*LINE_HEIGHT))?pos:pos - LINE_HEIGHT;
window.Repaint();
var p1, p2;
if(t1>t2-100) {
if(g_playtimer) {
if(g_playtimer.ID == id) {
if(!g_is_scrolling && t1>=g_tab[focus_next].timer) {
p1 = g_tab[focus].ante_lines*LINE_HEIGHT;
p2 = g_tab[focus_next].ante_lines*LINE_HEIGHT;
g_scroll = p2 - p1;
change_focus();
if (g_scroll>0) {
pos -= 1;
g_scroll -= 1;
window.Repaint();
} else {
centiemes = (centiemes>98)?0:(centiemes+1);
var i, k, text_colour;
// decoding text alignment (from Properties)
switch(TXT_ALIGN.toUpperCase()) {
case "LEFT":
g_txt_align = lc_stringformat;
break;
case "CENTER":
g_txt_align = cc_stringformat;
break;
case "RIGHT":
g_txt_align = rc_stringformat;
break;
default:
if(posy>=0) {
LIGHT_BG && gr.FillSolidRect(0, Math.floor(posy - wh/2), ww, Math.floor(wh/2), g_ovbg_normalcolour);
} else {
for(i=0;i<tab.length;i++) {
if(Math.round(posy)>=(LINE_HEIGHT*-4) && Math.round(posy)<wh) {
if(i==focus && g_lyrics_status==1) {
} else {
} else {
if(!LIGHT_BG && i==focus && tab[i].text.length>1 && g_lyrics_status==1) {
gr.FillSolidRect(0, Math.floor(posy), ww, (tab[i].total_lines*LINE_HEIGHT), g_ovbg_highlightcolour);
} else {
LIGHT_BG && gr.FillSolidRect(0, Math.floor(posy), ww, (tab[i].total_lines*LINE_HEIGHT-1), (i==focus
&& tab[i].text.length>1 && g_lyrics_status==1)?g_ovbg_highlightcolour:g_ovbg_normalcolour);
LIGHT_BG && gr.FillSolidRect(0, Math.floor(posy+(tab[i].total_lines*LINE_HEIGHT-1)), ww, 1,
g_ovbg_lineseparatorcolour);
TEXT_SHADOW && gr.DrawString(tab[i].text, g_font, g_txt_shadowcolour, 1+H_PADDING, Math.floor(posy)-1, ww-
H_PADDING*2, (tab[i].total_lines*LINE_HEIGHT), g_txt_align);
TEXT_SHADOW && gr.DrawString(tab[i].text, g_font, g_txt_shadowcolour, 1+H_PADDING, Math.floor(posy), ww-
gr.DrawString(tab[i].text, g_font, text_colour, 0+H_PADDING, Math.floor(posy)-1, ww-H_PADDING*2, (tab
posy = Math.floor(posy+LINE_HEIGHT+((tab[i].total_lines-1)*LINE_HEIGHT));
if(g_lyrics_status>0 && posy<=wh) {
function grab_timer(t_tab) {
var i, k, f_sentence, b, c, delta, repeat_text;
var tab = Array();
for(i=0;i<t_tab.length;i++) {
if(g_lyrics_status==1) {
// sync lyrics
if(IsTimestamped(t_tab[i])) {
b = 0;
while(t_tab[i].substring(b*10, b*10+1)=="[") {
b++;
c = b;
repeat_text = remove_enhanced_balises(t_tab[i].substring(c*10, t_tab[i].length));
if(repeat_text.length==0) repeat_text = repeat_text + " ";
for(b=0;b<c;b++) {
tminutes = t_tab[i].substring(1+(b*10), 3+(b*10));
tsecondes = t_tab[i].substring(4+(b*10), 6+(b*10));
tcentiemes = t_tab[i].substring(7+(b*10), 9+(b*10));
f_sentence.timer = Math.round(tminutes)*60*100 + Math.round(tsecondes)*100 + Math.round(tcentiemes)
- DEFAULT_OFFSET;
if(f_sentence.timer<0) f_sentence.timer=0;
f_sentence.text = repeat_text;
tab.push(f_sentence);
} else {
// unsync lyrics
// if sync line in unsync lyrics, i remove timestamps in this line
b = 0;
while(IsTimestamped(t_tab[i].substring(b*10, b*10+10))) {
b++;
t_tab[i] = t_tab[i].substring(b*10, t_tab[i].length);
f_sentence.text = t_tab[i];
if(tab.length==0) {
delta = (tab[tab.length-1].ante_lines + tab[tab.length-1].total_lines);
} else {
f_sentence.timer = 9999999;
f_sentence.text = "---";
CollectGarbage();
return calc_lines(sort_tab(tab));
var i;
var str;
while(!g_file.AtEndOfStream) {
// blank lines are ignored
if(str.length>0) t_tab.push(str);
close_file(g_file);
return grab_timer(check_lyrics_type(t_tab));
function check_lyrics_type(t_tab) {
var i;
var count = 0;
var ts_percent;
var tab = Array();
// format timestamps to default syntax : [99:99.99]
tab.push(ts_analyzer(t_tab[i]));
// count # of sync lines
count++;
} else {
if(t_tab[i].length>0) tab.push(t_tab[i]);
// calc percent of sync lines, if more than 50% of the total filled lines, it's sync lyrics, else, unsync lyrics!
ts_percent = Math.round(count/tab.length*100);
if(ts_percent>50) {
// sync lyrics
} else {
// unsync lyrics
return t_tab;
function parse_tag(tag, delimiter) {
var i, j;
j = 0;
for(i=0;i<tag.length;i++) {
if(i==tag.length-1 || tag.charCodeAt(i)==10 || (i>0 && (i<tag.length-5) && (tag.substring(i, i+1)==delimiter) &&
(tag.substring(i-1, i)!="]"))) {
if(i==tag.length-1) {
t_tab.push(tag.substring(j, i+1));
} else {
if(tag.charCodeAt(i)!=10) {
j = i;
} else {
j = i+1;
var count = 0;
count++;
count++;
count++;
count++;
if(bool) {
return fileInst;
fileInst.Close();
return line;
var fso, bool;
return bool;
var fso, bool;
return bool;
function lyrics_folder_exists(folder_name) {
var fso;
var bool=1;
if (folder_exists(fb.ProfilePath + folder_name) == false) {
fso.CreateFolder(fb.ProfilePath + folder_name);
bool=0;
return bool;
var i, j;
var t1 = elap_seconds.Eval()*100+centiemes;
for(i=0;i<g_tab.length;i++) {
if(g_tab[i].timer>t1) break;
focus_next=i;
focus = (i>0)?i-1:0;
if(focus>0) {
for(i=0;i<focus;i++) {
if(g_tab[i].timer==focus) {
focus = i;
break;
var i, j;
var padx = 0;
var tmp_img;
var gp;
var lineh;
g_tab_length = 0;
if(ww==0) return ctab; // test to avoid errors if panel is hidden (ww=0)
tmp_img = gdi.CreateImage(ww-(H_PADDING*2)-padx, 100);
for(i=0;i<ctab.length;i++) {
lineh = gp.MeasureString(ctab[i].text, g_font, 0, 0, ww-(H_PADDING*2)-padx, wh).Height;
ctab[i].total_lines = (lineh/LINE_HEIGHT) > Math.floor(lineh/LINE_HEIGHT) ? Math.floor(lineh/LINE_HEIGHT) + 1 :
Math.floor(lineh/LINE_HEIGHT) ;
for(j=0;j<i;j++) {
CollectGarbage();
return ctab;
var tab = Array();
var i, j;
var smallest = 0;
for(i=0;i<tab2sort.length;i++) {
for(j=i;j<tab2sort.length;j++) {
if(tab2sort[i].timer > tab2sort[j].timer) {
tmp = tab2sort[i];
tab2sort[j] = tmp;
return tab;
var i;
var chr1, chr2;
var new_str="";
for(i=0;i<str.length;i++) {
chr1 = str.substring(i, i+1);
if(i+10<=str.length) chr2 = str.substring(i+9, i+10); else chr2=null;
if(chr1=="<" && chr2==">") {
i = i + 10 - 1;
} else {
return new_str;
function ts_analyzer(str) {
var i, j, ch, ts_len;
var str2 = "";
var state=0;
var deb = -1;
var fin = -1;
var sep1 = -1;
var sep2 = -1;
var suite=0;
ch = str.substring(i, i+1);
switch(state) {
case 0:
if(ch=="[" && IsNumeric(str.substring(i+1, i+2))) {
state=1;
deb=i;
fin=-1;
break;
case 1:
if(deb>=0 && ch==":") {
state=2;
sep1=i;
if(i>deb+3) {
deb=-1;
fin=-1;
sep1=-1;
sep2=-1;
state=0;
break;
case 2:
if(sep1>=0 && (ch==":" || ch==".")) {
state=3;
sep2=i;
if(sep1>=0 && sep2==-1 && ch=="]") {
state=4;
fin=i;
if(i>sep1+3) {
deb=-1;
fin=-1;
sep1=-1;
sep2=-1;
state=0;
break;
case 3:
if(deb>=0 && ch=="]") {
state=4;
if(i==str.length-1) {
str=str+" ";
fin=i;
if(i>deb+10) {
deb=-1;
fin=-1;
sep1=-1;
sep2=-1;
state=0;
break;
case 4:
ts_len=fin-deb+1;
switch(ts_len) {
case 6:
str2 = str2 + "[0" + str.substring(deb+1,deb+2) + ":" + str.substring(deb+3, deb+5) + ".00]";
break;
case 7:
str2 = str2 + str.substring(deb,deb+6) + ".00]";
break;
case 9:
str2 = str2 + "[0" + str.substring(deb+1,deb+2) + ":" + str.substring(deb+3, deb+5) + "." +
str.substring(deb+6, deb+8) + "]";
break;
case 10:
if(sep1==deb+2) {
} else {
str2 = str2 + str.substring(deb,deb+10);
break;
case 11:
str2 = str2 + str.substring(deb,deb+9) + "]";
break;
j += 10;
if(str.substring(fin+1,fin+2)=="[") {
suite = 1;
i = fin;
deb = -1;
fin = -1;
sep1 = -1;
sep2 = -1;
state = 0;
} else {
suite = -1;
i = str.length - 1;
str2 = str2 + str.substring(fin+1, str.length);
break;
return str2;
function IsNumeric(str) {
var ValidChars = "0123456789.";
if (ValidChars.indexOf(str.charAt(i)) == -1) {
return false;
return true;
function IsTimestamped(str) {
var ValidChars = "[0123456789:.]";
var count = 0;
for (i = 0; i < (str.length>10?10:str.length); i++) {
if (ValidChars.indexOf(str.charAt(i)) >=0) {
count++;
if(count>=6 && count <=11) {
return true;
} else {
return false;
function check_file(path, filename) {
if(file_exists(path+filename+".lrc")) {
g_lyrics_filename = filename+".lrc";
g_lyrics_path = path;
return true;
} else {
if(file_exists(path+filename+".txt")) {
g_lyrics_filename = filename+".txt";
return true;
return false;
var i, count, delta, tag;
var tfilename= Array(artist.Eval() + " -" + title.Eval(), artist.Eval() + " - " + title.Eval());
var bool_file = false;
// reset lyrics tab
if(g_tab.length>0) g_tab.splice(0, g_tab.length);
pos = midpoint;
focus = 0;
window.Repaint();
// check TAGs
if(tag.length>0) {
bool_tag = true;
if(tag.substring(0,1)=="[") g_lyrics_status = 1; else g_lyrics_status = 2;
} else {
// check files
i = 0;
while(!bool_file && i<2) {
j = 0;
while(!bool_file && j<2) {
bool_file = check_file(tpath[i], tfilename[j]);
j++;
i++;
// if lyrics found
if(bool_tag || bool_file) {
if(bool_tag) {
g_tab = parse_tag(tag, "[");
} else {
g_tab = load_file(g_lyrics_path, g_lyrics_filename);
} else {
if(g_lyrics_status==2) {
for(i=0;i<g_tab.length-1;i++) {
the original tooltip button code is by T.P Wang and tedgo. i don't understand it that well either.
i'll try and work it out from what Tom posted.
in the meantime, i've updated my samples. they've all had their options updated to be accessible from the context menu only. no more script editing should be needed (one exception is setting the image size and margins for buttons).
http://cid-649d3bfeaf541fbb.skydrive.live....ide/samples.zip (http://cid-649d3bfeaf541fbb.skydrive.live.com/self.aspx/.Public/foobar/guide/samples.zip)
samples include
rating script by NEMO7538
simple seekbar
simple biography
playback buttons
web links (myspace, youtube, lastfm)
3 in 1 artwork panel
-the first is a straight replacement for the default art panel. it always prefers embedded album art if it exists. it then falls back on the usual display options set in the foobar preferences.
-last.fm artist art panel. can download multiple images from last.fm and cycle through them. it must be triggered manually using the context menu
-cycle folder option. can cycle through images in a folder at 5, 10 or 20 second intervals
so no instructions needed really. just extract the scripts folder into your foobar directory. add panels and import the samples you want and right click them to see the various options.
EDIT: in the unlikely event someone downloaded this between 1:35-150pm today, please download it again. i didn't update the zip with my newest files.
Hi guys,
Do you have any good idea to achieve the Album cover panel automatically download and mobile display cover?
BTW, I want to set Album text cache path to the location “D: \ Program Files \ Foobar2000V1.1 \ lastfm \ album“, but I hope it can instead using relative path for that never to worry about when folder and system changes. Could you hope me? I really appreciate you first.
marc, my foo_lastfm_radio along with your script WSH panel does not work, even with the the plugin configured with a username and password whenever I try to use the panel "similar artists" or "charts" of the same error: "Unable to launch last. fm radio ...."
I'm using the google translator, sorry but I am Brazilian
Hi guys,
for album covers, you'd be better off using foo_discogs (http://www.hydrogenaudio.org/forums/index.php?showtopic=50523) or Album Art Downloader XUI (http://www.hydrogenaudio.org/forums/index.php?showtopic=57392)
as for the path, if you install foobar in portable mode (preferably not in "program files"), then it already uses relative paths to a folder inside your foobar installation directory.
however, to fully customise it, you can open this file in your favourite text editor.....
foobar install dir\scripts\marc2003\v2\common.js
and scroll right to the bottom. look at line 351.....
var data_folder = fb.ProfilePath + "wsh_lastfm\\";
and change it as required. remember to use double backslashes when separating folders.
but as mentioned above, fb.ProfilePath already points to the foobar install dir when in portable mode. you could use fb.FoobarPath to point to the install directory regardless of mode but remember, windows doesn't usually allow write access to folders/files inside "program files".
what happens if you try and use foo_lastfm radio normally either via "File>open last.fm radio" or use the "last.fm radio" context menu for any entry in your playlist.
it might be that last.fm doesn't allow streaming in your country.
Lyriks 1.3 released (bugs fix + tweaks)
Get it here : http://pastebin.com/CCeebA4x (http://pastebin.com/CCeebA4x)
marc, I tried to use the File> Open Last.fm Radio Station> Your recommended Last.fm radio and it worked
is only in your script that does not work: (
this funtion is where?
not done yet
Hi guys,
thanks for your reply, maybe your solution can help me, I will try some test.
Curious, was this redundant:
And please consider user defined color properties - every time I use new script I have to search this values inside script and make various adjustments by hand. What I'm saying is consider all "color definitions" in Properties
+ you changed the names of variables
Maybe also vertical height for gradient, which I always change to 32px, but it's easy to change parameter if it's only one
Timestamped lyrics aren't reseted when using seek-bar (seek back)
right, i've found this bug after posting v1.3, next version is fixed, i'll share it soon.
Scripting Engine Initialization Failed ({EA64722C-DA97-4460-94BB-B6B5A2C5FF14}, CODE: 0x86664004)
Check the console for more information (Always caused by unexcepted script error).
and
Can not create File System Object (FSO), WSH Cover Panel can't work.
I use Windows 7 and I think windows script host is installed by default.
here what I got in console:
Error: WSH Panel Mod ({EA64722C-DA97-4460-94BB-B6B5A2C5FF14}): Erro em tempo de execução do Microsoft JScript:
O servidor de automação não pode criar objeto
Ln: 45, Col: 3
WSH Panel Mod ({2ADCA884-84EB-4B29-9BCC-B9491ABFF805}): initialized in 16 ms
WSH Panel Mod ({2E67F0FF-131A-4E6C-8162-5D269CDC4B44}): initialized in 3 ms
WSH Panel Mod ({3560A5C6-455B-4269-A51D-4443144330A3}): initialized in 11 ms
WSH Panel Mod ({5D5CBB4E-09F1-4BC3-9329-6B485FC21525}): Parsing file "C:\Users\soe9113\AppData\Roaming\foobar2000\\skins\ZiX+\Scrollbar\scrollbar.js": Failed to load
WSH Panel Mod ({5D5CBB4E-09F1-4BC3-9329-6B485FC21525}): initialized in 118 ms
Error: WSH Panel Mod ({5D5CBB4E-09F1-4BC3-9329-6B485FC21525}): Erro em tempo de execução do Microsoft JScript:
'VPSize' não está definido
Ln: 58, Col: 1
WSH Panel Mod ({EA62CC17-FE36-4B8C-987D-EE4FE2D9285E}): initialized in 12 ms
WSH Panel Mod ({05FC3C9F-9AE7-4B2A-85F6-EBC5C6FBF042}): initialized in 26 ms
WSH Panel Mod ({0E317A12-BFF2-49A2-9965-3574476E9C06}): initialized in 12 ms
WSH Panel Mod ({AEFF8777-7709-4F68-B487-A99A9510830A}): initialized in 9 ms
Startup time : 0:01.784568
how can I solve this problem? I remember Appdata had some problems in other applications like mIRC
thanks
thanks
Is the Safe mode option unticked for WSH Panel Mod in File/Preferences?
ok, here is a new build that fix 2 bugs (reset position after a seek backward was wrong + bad scrolling length for some sync lyrics when the timer was higher to 10 ms)
+ colours in Properties panel
Lyriks 1.3 (build 20101103.2140) : http://pastebin.com/eVfJ2Ss8 (http://pastebin.com/eVfJ2Ss8)
Works great now, except:
Can you tell me how to adjust transition interval between active lines in timestamped lyrics? I think it was changed between versions and now it is too jumpy for my taste
I browsed your code and couple of your comments but nothing obvious there
and
Ln: 45, Col: 3
Ln: 58, Col: 1
thanks
A ZiX+ user, right?
well, when i was compiling the codes of scrollable trackinfo panel, it never occurred to me that many people choose to use the standard installation and i used the profile path in predecessor:(
BTW, please uncheck the safe mode in WSH panel.
I will fix this problem asap.
focus on my deviantart page.
now the timer should not be greater than 10 ms (if greater, it will cause bad scrolling offsets on certain sync lyrics!)
but you can change the scroll step value, actually set to 1 (max), change it for a lower value for a slower scrolling, like
0.5, it's line 39:
(http://img80.imageshack.us/img80/7822/lyriks.png)
samples updated:
http://cid-649d3bfeaf541fbb.office.live.co...ide/samples.zip (http://cid-649d3bfeaf541fbb.office.live.com/self.aspx/.Public/foobar/guide/samples.zip)
i've updated the "simple biograhy" script to use the new redirection feature made available in the last.fm API. this helps if your files are incorrect tagged.
old version of script with wrong tags / new script with spelling correction off
(http://k5sbdw.blu.livefilestore.com/y1pbnkRHixR13agC14VfKkVhGCwFIQ7JoAbDd2ZvEQ6fiFrDO2XwGTpaPQdAyXFuH0xN6fJFOqvOq9en25AoCEJ2FYbxzp3i16B/bio1.PNG)
new version of script, wrong tags, spelling correction on:
(http://k5sbdw.blu.livefilestore.com/y1px4CCP5b85Lbxcf4Jk7UZ5Ja5NgqNOLjgJ5FT3MuZE_1JFpSbhQySR8QqFcLjMIPDiYIzi2EqNaiGIwsm4nbX4qdZpkIEDZbY/bio2.PNG)
note this does not touch your file tagging at all. it's simply for display purposes.
I had one layout and it kept happening, I deleted it (manually though) and it keeps happening with a different layout (which wasn't written by me):
(http://i51.tinypic.com/2uyqhhv.png)
Sometimes it goes away when I right-click on a panel and press OK, but usually it doesn't and I have to restart a zillion times until it somehow, magically starts to work.
Safe Mode is disabled.
and
Ln: 45, Col: 3
Ln: 58, Col: 1
thanks
but you can change the scroll step value, actually set to 1 (max), change it for a lower value for a slower scrolling, like 0.5, it's line 39:
Thanks Falstaff
I've set it to 0.2
Now it's greater then ever
Cheers
thanks for all replies, I disabled safe mode and now is working ok. Thanks.
I like ZiX+ cause is a very clean and easy skin. I tried others but some other skin got lot of problems, maybe components not updated.
First, thanks to Marc and everyone else for their great scripts and tips. I've had some success tweaking various scripts to suit my needs, but I'm having trouble accomplishing one thing...
Basically I want to combine the custom folder mode from the Thumbs script and use that for the artist art in the Now Playing script. Can anyone help me achieve this?
I keep my artist art in the root folder of the artist: Music\Artist\Album\
Custom folder works perfectly for my needs I just need the option in the Now Playing script
you could do a quick and dirty edit of the "now playing" script, changing line 55 to something like...
folder = fb.TitleFormat("$replace($directory_path(%path%),%directory%,)").EvalWithMetadb(g_metadb);
Thank you that works perfectly.
I'm trying to figure simple way to add (or replace) variable to custom_db with WSH Panel Mod and could use some help since I have no experience with databases. Some sample code would be appreciated.
I have sqlite3.exe and foo_run present and have been trying to make some sense to marc2003's scripts but I'm afraid I will fuck something up with my db if I just copy those scripts...
you can just add actions in the settings of custom database. then in your script you can call those actions using fb.RunContextCommand([your_action])
Thanks. I got it working but it's kinda ugly:
function on_playback_time()
if (wait == 0) newsongready = 1;
if (newsongready == 1 && song_handled == 0)
g_metadb = fb.GetNowPlaying();
g_metadb.UpdateFileInfoSimple("artistinfo",lastfm_data[1][1]);
g_metadb.UpdateFileInfoSimple("albuminfo",lastfm_data[2][1]);
fb.trace("mdbc: "+lastfm_data[1][1]+" / "+lastfm_data[2][1]);
song_handled = 2;
fb.trace(song_handled+fb.TitleFormat(" art: %artistinfo% alb: %albuminfo%").Eval());
else if (song_handled == 2)
if (fb.TitleFormat("$if(%artistinfo%,$if(%albuminfo%,1,0),0)").Eval() == 1)
fb.RunContextCommand("Customdb SetArtistCount");
fb.RunContextCommand("Customdb SetAlbumCount");
song_handled = 1;
g_metadb.UpdateFileInfoSimple("artistinfo","");
g_metadb.UpdateFileInfoSimple("albuminfo","");
As you see, I have to first put my data to tags, then (when it's ready) use contextmenu to store it from tags to customdb and remove tags. If somebody knows better way of doing this I would be pleased.
i was looking for a way to bring up in my browser or foobar console a tinysong link to the song i'm playing. tinysong has an api
http://tinysong.com/api (http://tinysong.com/api)
i was wondering if this is compatible with wsh panel mod?
there is a chrome extension that makes use of it:
https://chrome.google.com/extensions/detail...aejpghooihfdipa (https://chrome.google.com/extensions/detail/dnecfmdnglboegjiaaejpghooihfdipa)
@Falstaff
I am enjoying using your Lyriks 1.3 script. However, I am having problems with the wrong characters being displayed for some lyric files. One example is below.
The initial part of the lrc file is shown below. The last line displays incorrrectly as:
I don’t think I know my way around
[encoding:windows-1250]
[ti:Your mistake]
[ar:Melanie C]
[al:This time]
[la:en]
[00:02.10]| Melanie C - Your mistake |
[00:02.70]| album: 'This time' 2007 |
[00:05.67]I should concentrate on slowing down
[00:10.33]Cause all I wanna do is drive fast
[00:13.42]I don’t think I know my way around
There are problems with other characters as well in certain lrc files. Is it possible to fix these errors? The display font is your default of Segoe UI.
yes, some chars (ansi, non-ascii) may not be rendered as well if the lyrics are grabbed from a file from disk BUT it's OK if the lyrics are stored in the file TAG.
this is due to the fact that WSH can't (or i've not find how to do...) read non-ascii characteres ==> read file function in javascript limitations, it took the encoding mode of the system you are running with (i think)
if someone know how to fix it, i'm interrested too, btw, i store my lyrics in TAG, not on disk, so i don't encounter this problem often.
Is you example stored on disk ?
Yes my lrc files are stored on disk.
iconv.exe -s -f CP1250 -t CP1252 input.txt > output.txt
iconv can be dl, i.e. from here (Binaries + Dependencies link): http://gnuwin32.sourceforge.net/packages/libiconv.htm (http://gnuwin32.sourceforge.net/packages/libiconv.htm)
if lyrics are stored in tags foo_chacon would be ideal
i will try it, thanx romor
... in the meantime I have put a replace function in to strip out unwanted characters which helps the display a lot. After line 603 I have put:
new_str = new_str.replace(/[^'-;:,.?!"&*()+=\w\d\s]/gi,'');
I am also getting the occasional crash due to a script error. This is with your unaltered code. Always it occurs when using another application and it happens when return to foobar2000.
'g_tab[...].timer' is null or not an object
Ln: 279, Col: 13
Is it possible to fix this?
Other than these points it is working extremely well.
Noticed same here unfortunatelly
And I thought your (Falstaff) question about encodings was general as I'm courious too if there is some VBS/JS conversion possible. At least conversion to ASCII or ANSI, and even only from European latin encodings (obviously if we are talking only about ASCII/ANSI)
As T.P mentions, he didn't consider any problem about file code when compiling WSH mod.
It's simply the problem from the component itself.
I was thinking again on this encodings subject and two ideas come to my mind:
- dictionary object referring character original and it's Unicode representation, or
- dictionary object referring only problematic European encodings to their 'best fit' ASCII equivalent
Then parsing lyrics text object through function using above dict
Both methods should work unnoticeable, as lyrics text is small text object
I'm going to implement second one in VBS for my file manager as it can't read filenames other than my locale and has VBS extensibility
update to above:
There is option to do conversion with [ADODB.Stream] for which you can define [.Charset], but the problem is how can you know in which charset are source (problematic) lyrics?
So I guess best option is to do 'best fit' ASCII conversion with dictionary object
[edit] or to just strip non-ascii chars: 32 < Asc(Chr) < 125
So why not consider using utils.ReadTextFile()? It handles ANSI, UTF8 (with BOM) and UTF16 (with BOM) files.
Problem are encоdings not covered by user's code page, for example your locale/code page/ANSI representation is in CP-1252 and file is CP-1250 encoded or similar
I wonder if you can hide external process window and accessing its stdin at the same time. I know how to hide the window with wshshell.Run() method and accessing stdin of an external process with wshshell.Exec() method but you can't access stdin with Run() method and similarly I can't run a hidden process with Exec() method. Is it possible, and how?
I'm kinda new to javascript so any help is appreciated.
Problem are enc?dings not covered by user's code page, for example your locale/code page/ANSI representation is in CP-1252 and file is CP-1250 encoded or similar
try v1.4.0
http://www.hydrogenaudio.org/forums/index....st&p=733166 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=70363&view=findpost&p=733166)
It's great that now there exist such a conversion function.
My point is how can you tell if lyrics file is CP1250 or CP1253 or whatever else encoded?
AFAIK there isn't smart way of knowing file encoding. You could eliminate some encodings, but it's impossible to know in which encoding is original file unless you do it visually by looking represented characters on monitor (through your code page).
For automated purpose I suggested "downsampling" to ASCII (which would work fine with some encodings). Similar to $ascii(), or even better $ansi() function in foobar TF. I overlooked in previous posts that foobar TF functions can be executed inside WSH code
IMHO all this should be leaved to user discretion, without trying to fix anything on other side. If user has lyrics files encoded in strange CP than he/she should take care of it (unfortunately I'd guess user is not aware of his lyrics file encodings, as they are mainly downloaded, shared etc.)
Maybe you can do simple check to see if file is UTF-8 encoded, then if it's not and byte stream values are not in ASCII or in user code page extended character representation, then do ASCII downsampling.
How do you plan to use this function inside your lyrics script, anyway?
I have made kind of intensive calculation function that takes about a minute to go through. During this foobar goes to "not responding"-state. How could I do this calculation "in the background" so it wouldn't affect the whole programs performance? (function mainly consist of one long while-loop that goes through all the tracks)
try v1.4.0
this download is bad for me
I can't download now
please give me another download address
@hejiamei:
i was not talking about my lyriks WSH script !!! but about WSH panel mod release... so there is no link to download something yet. later.
samples updated:
This doesnt appear to work for me. I have spelling correction turned off and whilst the biography details are of those it has redirected to, it doesnt display the "redirected from" text. Has this been removed from the latest samples script?
Example: Swedish House Mafia feat. Pharrell - One (Your Name)
The biography panel displays the info from the Swedish House Mafia page (http://www.last.fm/music/Swedish+House+Mafia) which when viewing in my browser states I have been redirected from Swedish House Mafia feat. Pharrell page (http://www.last.fm/music/+noredirect/Swedish+House+Mafia+feat.+Pharrell). The artist name in bold in the heading remains as Swedish House Mafia feat. Pharrell. As the thumbnails 2 panel displays the images from the Swedish House Mafia feat. Pharrell page.
I'm using tooltip_buttons.js found in 1 of the 2 WSH threads.
How can I get the coordinates-part into the on_paint{} part?
I want this for instance:
var Buttons = new Array;
Buttons[0]=new Button( 10, 80, 200, 75, {normal: images_BB + "Start_wide.png", hover: images_BB + "Start_wide.png"}, function(){blablabla}, "blablabla");
Buttons[1]=new Button( 10, 160, 200, 75, {normal: images_BB + "Start_wide.png", hover: images_BB + "Start_wide.png"}, function(){blablabla}, "blablabla");
var ChartType = 'Top2000';
var ChartType_img = gdi.Image(fb.FoobarPath + "foo\\f003\\BB\\"+ ChartType + ".png");
Buttons[0].draw(gr);
Buttons[1].draw(gr);
But this doesn't seem to work.
Can anyone give me a hint?
Hi All,
Apologies for involve everyone, I really appreciated can get someone‘s help.
I have used Tedgo’s version - DarkoneV3.01 for foobar2k, my question is How to simulate keyboard events through WSH script? There is no work for me after try to recode the Additional Buttons Panel script several times, I also search solution through internet,but...
I have make the two button point to the function(see below Additional Buttons Panel code)
Buttons.a = new Button(0, 22, 60, 14, {normal: imgPath + "AddOnAlone.png", hover: imgPath + "AddOnAloneMH.png"}, function(){fb.ShowConsole();});
Buttons.b = new Button(83, 22, 58, 14, {normal: imgPath + "AddOnLeft.png", hover: imgPath + "AddOnLeftMH.png"}, function(){fb.ShowPreferences();});
Buttons.c = new Button(141, 22, 57, 14, {normal: imgPath + "AddOnRight.png", hover: imgPath + "AddOnRightMH.png"}, function(){fb.RunMainMenuCommand("Equalizer");});
Change:
fb.RunMainMenuCommand("Show Status pane") to fb.ShowPreferences()
fb.RunMainMenuCommand("Show Status bar") to fb.RunMainMenuCommand("Equalizer")
I just want them more useful to me,there is a Third-party plugins ---Autolyric(http://www.autolyric.com/index_en.htm),it can make Lyrics display on the desktop, it's very cool, I have set global shortcut keys(Alt+W) to show desktop Lyrics because I only can set it in Autolyric Preferences not foobar Preferences.
So whether button mouse click simulate the keyboard events,how to recode JS or anyway solution for that? Maybe I need to modify the WSH mod inferface, jscript, DO Global Script.js, DO Global Button Script.js, I have test and try but have no idea.
Could anyone please help me,I just want to make Darkone more and more easy-to-use.
Thanks for all, my friends.
Mejor
Tedgo has replied to me, see below, but I hope can get more help, who have better idea? or how to use the function on_key_down(vkey){}...
~tedgo 18 hours ago has replied
Its not possible to handle third-party-components within WSH Panel mod (at least to my knowledge...).
Maybe its possible when using foo_run (optional component) to execute commands via command-line, if Autolyric is able to used via commandline.
Then you could create a button in WSH Panel mod (fb.RunContextCommand("Run services/Name of your action").
I must confess that i never used keyboard shortcuts via WSH Panel mod, so maybe you should ask in the WSH Panel mod thread on hydrogenaudio. There may be a solution i don't know (or never thought about, since WSH Panel mod offers the - from me - never used possibility to disable "Safe mode" and will then have an enhanced functionality, but is probably insecure...).
There are some callbacks, though:
function on_key_down(vkey){} and function on_key_up(vkey){}
And here are the "vkeys" to be used: [link]
So you could "persuade" WSH Panel mod to use shortcuts to run foo_run.
Its the only thing i can imagine of for the moment...
Is it possible to change the colour of text contained in brackets, similar to how it can be done with columns ui.
$replace(%title%,']',$rgb(0,0,0),'[',$rgb(255,0,0))
The $rgb function does not work with WSH Panel Mod.
WSH panel mod could only translate the TF that produces strings.
If you want to change the color of a character appearing on screen, you can only use DrawString or GdiDrawText by assigning a color parameter to either of them.
When is callback on_script_unload() get called? Is it only when foobar starts?
it's called on
exit, not on start
when will the script unload?
certainly at the end of this program.
Is there a way to declare a var only at the start of loading the panel?
If tried to use window.onload, but this gives me an error.
If you DONOT change the value assigned to a variable declared at the beginning of the panel's script, the variable is unchanged.
Actually, under current non-fast mode, all the variable do not need declaring when used.
EineVariable = 2;
is equal to
var EineVariable = 2;
EineVariable = 2;
is equal to
Maybe I need to explain what I want to do.
At start I want to read a string from an ini file,
that string I want to use as an default value in a var.
When there is an event, for instance a mouse click, another value is assigned to that var.
What you want is so weird, 'cause it's exactly how a program assign its own variables.
var EineVar = "Initialized";
function on_mouse_lbtn_down(x,y,mask){
fb.trace(EineVar);
EineVar = "Changed";
fb.trace(EineVar);
//the console looks like:
//Initialized
//Changed
Is it?
BTW, window.GetProperty is much more useful and opreatable than ReadINI.
fb.trace(EineVar);
fb.trace(EineVar);
//Initialized
//Changed
Is it?
That's right.
But, I tried to use what you described dozens of times.
I use the var to determine if value a or b is used.
And that value I use to decide whether image a or image b is shown.
When instead of an image I use a text, It works.
The difference between the image and the text is,
that to show the image, I put the var in another var to declare the path to the image.
I can't lay my finger on the problem.
fb.trace(EineVar);
fb.trace(EineVar);
//Initialized
//Changed
Is it?
That's right.
just tell me how did you "put the var in another var".
well, I put it something like this:
var c = gdi.image("path" +var a + ".png")
I got it.
"path" is a string.
//////////////////////////codes below should work
var Path = fb.FoobarPath+"skins\\boo_boo\\";
var a = "test";
var c = gdi.image(path + a + ".png");
//////////////////now, c is the object of Image.
I got it.
"path" is a string.
var a = "test";
Thanks so far.
gonna test it when i get home.
@falstaff, Neonphytismo: I intended to said exit but wrote start instead, got a hang over, but I guess that helped me get an answer faster. Thanks both of you.
Actually, I totally have no idea about how to use this callback function...
More exactly, I have no idea about most of those functions provided....
haha.
I got it.
"path" is a string.
var a = "test";
Neonphytismo,
I tried it but I get an
Invalid procedure call or argument error.
I pasted the entire code below:
var NewPlayList;
ww = window.Width;
wh = window.Height;
var NewPlayList= utils.ReadINI(fb.FoobarPath + "foo\\WSH_scripts\\foo7.ini", 'Playlists', 'ChartName');
function on_playlists_changed(){
window.Repaint();
var path = fb.FoobarPath + "foo\\f003\\BB\\";
var img = gdi.Image(path + NewPlayList +".png");
gr.DrawImage(img, 10, 80 , 200, 75, 0, 0, 200, 75);
Oh,no.
NEW CODE:
var ww,wh;
var NewPlayList;
ww = window.Width;
wh = window.Height;
NewPlayList= utils.ReadINI(fb.FoobarPath + "foo\\WSH_scripts\\foo7.ini", "Playlists", "ChartName");
NewPlayList= utils.ReadINI(fb.FoobarPath + "foo\\WSH_scripts\\foo7.ini", "Playlists", "ChartName“);
window.Repaint();
//var img = gdi.Image(path + NewPlayList +".png");
img && gr.DrawImage(img, 10, 80 , 200, 75, 0, 0, 200, 75);
Is IT?
Also, I recommend to use window.GetProperty() method, and String Data Type should only be quoted by " ";
ok, I'm gonna look into that method, and change the quotes. Didn't know that makes a difference.
Neonphytismo
I looked into the window.GetProperty() method,
but it doesn't completely fulfill my needs.
The addition of the var ww,wh; and the doubblequotes, did however work perfectly.
Thank You very much!
This was something what was puzzling me for weeks.
Hi everybody!
Could somebody tell me why this isn't working:
fb.RunMainMenuCommand("View/Switch to playlist/"+source_playlist_name);
fb.RunMainMenuCommand("Select All");
lista = fb.GetSelections(1);
It finds right playlist, switch to it and selects all files but fb.getSelections() still doesn't find anything (lista.Count remains 0). How could I get all files from specific playlist (or better yet, all items from media library) to MetadbHandleList with WSH Panel Mod?
EDIT:
I added "var sel_type = fb.GetSelectionType();" after mainmenu command "select all" and the result was 4 (now playing) even though all the files at the desired playlist appear selected.
EDIT2:
fb.getselections() seems to work only when selection is focused (when I click on playlist with mouse and press Ctrl+A this works)
it seems that GetSelections() is not working in all callbacks it's a shame. look at here : http://www.hydrogenaudio.org/forums/index....st&p=733756 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=70363&view=findpost&p=733756)
Thanks, I got it working. Would be nice feature though to get specific playlist as IFMetaDbHandleList with some function.
I have had ago at combining the Now Playing template with the Aero Seekbar template, though I have a problem and cannot get the album art to display correctly. Here is the code I am using:
// ==PREPROCESSOR==
// @name "Aero Seekbar"
// @author "marc2003"
// ==/PREPROCESSOR==
DT_VCENTER = 0x00000004;
DT_CALCRECT = 0x00000400;
DT_NOPREFIX = 0x00000800;
DT_END_ELLIPSIS = 0x00008000
var stopped_text = "foobar2000";
var title_tf = fb.TitleFormat("%title%");
var album_tf = fb.TitleFormat("[%album%]");
var artist_tf = fb.TitleFormat("%artist%");
var title_font = gdi.Font("Segoe UI", 30, 1);
var album_font = gdi.Font("Segoe UI", 22, 0);
var artist_font = gdi.Font("Segoe UI", 22, 0);
var title_colour = RGB(0, 255, 128);
var album_colour = RGB(0, 255, 128);
var artist_colour = RGB(0, 255, 128);
var blacklist_file = '';
var album_img = null;
var album_img_size = window.GetProperty("album_img_size", 510) - 400;
var g_font = gdi.Font("Segoe UI", 20, 1);
var g_drag = 0;
var g_drag_seek = 0;
var g_timer, txt;
function RGB(r,g,b) {
return (0xff000000|(r<<16)|(g<<8)|(b));
if(fb.isplaying) on_playback_new_track();
function on_playback_stop(reason) {
album_img && album_img.Dispose();
g_metadb = album_img = null;
if(reason != 2) window.Repaint();
if(g_timer) window.KillTimer(g_timer);
window.Repaint();
CollectGarbage();
artist = artist_tf.EvalWithMetadb(g_metadb);
title = title_tf.EvalWithMetadb(g_metadb);
album = album_tf.EvalWithMetadb(g_metadb);
length = fb.TitleFormat("%length%").Eval();
g_timer = window.CreateTimerInterval(100);
album_img = utils.GetAlbumArtEmbedded(g_metadb.rawpath, 0);
if(!album_img) utils.GetAlbumArtAsync(window.ID, g_metadb, 0);
function on_get_album_art_done(metadb, art_id, im, ip) {
album_img = im;
window.Repaint();
function on_playback_seek(time){
window.Repaint();
function on_timer(id){
window.Repaint();
function on_mouse_wheel(delta) {
fb.PlaybackTime = fb.PlaybackTime + delta;
ww = window.Width;
wh = window.Height;
gr.FillSolidRect( 0, 0,ww, wh, RGB(0,0,0));
if(album_img) {
text_x = album_img_size + 10;
// scale(gr, album_img, 0, wh-20-album_img_size, album_img_size, album_img_size);
} else {
text_x = 10;
if(fb.IsPlaying) {
if(fb.PlaybackLength > 0) {
if(g_drag){
t = fb.PlaybackLength * g_drag_seek;
h = Math.floor(t/3600)
m = Math.floor((t-=h*3600)/60);
s = Math.floor(t-=m*60);
pos = ww * g_drag_seek;
txt = (h > 0 ? h + ":" + (m <10 ? "0" + m : m) : m) + ":" + (s < 10 ? "0" + s : s) + " / " + length;
} else {
pos = ww * (fb.PlaybackTime / fb.PlaybackLength);
txt = fb.IsPaused ? "Paused" : fb.titleformat("%playback_time%").Eval() + " / " + length;
gr.FillGradRect( 0, 0, pos, wh-1, 90, RGB(128,128,128), RGB(0,0,0));
} else if(fb.PlaybackTime > 0.1) {
txt = fb.IsPaused ? "Paused" : fb.titleformat("%playback_time%").Eval() + " / LIVE";
gr.GdiDrawtext(txt, g_font, RGB(0, 255, 128), 0, 0, ww-10, wh, DT_VCENTER | DT_RIGHT | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(title, title_font, title_colour, text_x, wh -127, ww-text_x-10, wh, DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(album, album_font, album_colour, text_x, wh - 80, ww-text_x-10, wh, DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(artist, artist_font, artist_colour, text_x, wh - 55, ww-text_x-10, wh, DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.DrawRect(0,0, ww-1, wh-1, 1.0, RGB(137,140,149));
function on_mouse_lbtn_down(x,y){
if(fb.IsPlaying && fb.PlaybackLength > 0) g_drag = 1;
if(g_drag) {
g_drag = 0;
g_drag_seek = x < 0 ? 0 : x > window.Width ? 1 : x / window.Width;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
function on_mouse_move(x,y){
if(y > wh) g_drag = 0;
if(g_drag) {
window.Repaint();
Line 88 is causing the problem (which is currently commented out):
the console reports Object Expected error.
Could anyone help me out?
@djphatic:
Because you didn't have scale() function defined.
@djphatic:
Thanks, appeared I was missing this line at the top:
// @import "%fb2k_path%scripts\marc2003\v2\common.js"
Now to figure out how to keep the album art on top of the seekbar instead of painting over it. - DONE!
Using the thumbs2 script from the templates marc2003 posted, I keep getting a crashed message every so often when it is switching images:
[18:20:14] Error: WSH Panel Mod (Thumbs2 by marc2003): Microsoft JScript runtime error:
Object required
Ln: 326, Col: 3
Line 326: return true;
Anyone else having this issue?
i somehow fudged that. fixed version uploaded....
as for your error in the post above, i have no idea....
Updated WSH Panel Mod and it seems to be working ok now.
I have saved a PLS-File of an internet radio station and play this file in foobar. Now I want to get the path and the name of this playlist. How can I get this information?
Hi!
I would like to add a "save as..." command in the right-click menu in a Last.fm image viewer/downloader panel (such as marc2003's thumbs.txt or MatthijsB's foo_silk-artistart)
Can somebody help me? I can add another line in the Menu but I don't what to do after (in the additional "case")
Thanks in advance,
Decalicatan_Decalicatan
@Decalicatan_Decalicatan
Hi! (la compagnie créole te salue également )
You want to save a displayed image from a WSH to disk ? i don't think there is a such method to do this in the actual version of WSH panel Mod ... afaik
bye.
with my scripts you can click the image and this will open it in a default viewer for that particular file extension. you can then "save as...". additionally, you'll find a "open containing folder" option on the context menu which will open explorer.
if you really want, you could use the CopyFile (http://msdn.microsoft.com/en-us/library/e1wf9e7w%28v=vs.85%29.aspx) method in jscript. in my scripts the path to the current image is typically stored in this variable..
arr[index]
ok, thank you both for your quick answer. I will try with CopyFile or else I will use the open-file-then-save-as... method
Sorry posted this in wrong thread will post there please ignore this
I have an issue with marc2003's Now Playing script: If I quit foobar without stopping playback (for example after using Stop after current), the next time foobar starts the now playing panel crashes:
According to the console, it seems the problem is with the on_playback_new_track() which is called by: if(fb.IsPlaying) on_playback_new_track();
Error: WSH Panel Mod ({D58A2114-2A1E-492D-A9E3-8BB5AAD5F967}): Erreur d'exécution Microsoft JScript:
'title' est indéfini.
Ln: 110, Col: 3
Thanks in advance,
Decalicatan Decalicatan
http://www.hydrogenaudio.org/forums/index....=33&t=77883 (http://www.hydrogenaudio.org/forums/index.php?act=post&do=reply_post&f=33&t=77883)
under normal circumstances the script shouldn't error but i noticed it does if foobar is set to resume playback on startup which i hadn't accounted for. doh...
Is there a way to select multiple tracks and use a button to start for example
a contextmenu action, like Tagging/Discogs... ?
I created a button for it but when I select a couple of tracks and push the button,
nothing happens.
This is a little snippet:
$buttons = {
MB1: new SimpleButton(5, 5, 200, 16, "MusicBrainz (by TOC)", function () {
fb.RunContextCommand('Tagging/Get Tags From MusicBrainz (by TOC)');
Configure: new SimpleButton(5, 65, 80, 16, "Configure", function () {
fb.RunContextCommand('Tagging/Discogs/Write Tags...');
nothing happens.
$buttons = {
Bump..
Bump..
Try this:
$buttons = {
fb.RunContextCommandWithMetadb('Tagging/Get Tags From MusicBrainz (by TOC)', fb.GetSelections());
fb.RunContextCommandWithMetadb('Tagging/Discogs/Write Tags...', fb.GetSelections());
samples updated.
contains a new script called "thumbs3". exactly the same as thumbs2 except the thumbnail strip is vertical instead of horizontal.
(http://public.blu.livefilestore.com/y1pJ0UJCJex2NcUyhYzgHy8LueH8cQh7Tlc0EwOoqtdUmPbasEwW7gz7mv3cDQCr5aFjfmFGVNTTm3GnpJlw56aBQ/thumbs3.png)
Bump..
Try this:
$buttons = {
Thanks a million Hitchhiker427.
Couldn't figure this out.
It works!
I'm a total noob on this. Just wanted to update my old foobar config and changed from WSH Panel to WSH Panel
Mod but my scripts aren't running properly. My seekbar won't compile and the console says it's getting stuck at the following line:
gr.DrawImage(g_btn_img1,pos-3,7,8,8,0,0,8,8);
Think this is an easy one for you out there!
Thank you in advance!
EDIT:
Got it working!
Variable g_btn_img1 wasn't properly set, because of old components-folder!
there is an item "remove played tracks" in my main menu - playback. it is quite tedious to go there all the time just to have a look whether a tick is on or off right now. moreover, my main menu is hidden, so here i have some additional difficulties. checking the state of this item from context menu is more acceptable, but still it is not so convenient as it could be
is it possible to make a script that would allow me to create a button (with 2 different images for 2 states) for toggling the setting "remove played tracks"?
(i have such a script for "stop after current" and it is convenient and graphic as hell)
(i use: foo-bar 0.9.6.4; columns ui 0.3.6.4; remove played files 1.4.0; wsh panel (uie) 0.7.2; wsh panel mod 1.2.1)
This would be awesome.... You could make buttons for other functions like this as well like "Stop after current," "Playback follows cursor" etc.
yea, i know that it is possible to create these 3 buttons (stop after current, playback follows cursor, cursor follows playback). the point is that i never needed them at all (except for "stop after current"). i wanted to say that it would be nice to have a button for "remove played tracks" as well. unfortunately, i cannot make a script, so i would be grateful to a person who decides to write it
Wait, has a script already been written for these?
the possibility to make buttons for them is provided by component "foo_uie_ptb" (i have version 0.2)
so i don't know about scripts for those 2 items, but i have JScript for "stop after current" (taken from this site)
Mind directing me to that?
it's easier for me to post the script than to search for it. JScript for "stop after current":
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
var g_drag = 0;
var imgname;
var img;
function on_init(bool) {
imgname =bool ? "stop-after-current-on.png" : "stop-after-current-off.png";
img = gdi.image(fb.FoobarPath + "Images\\" + imgname);
window.Repaint();
on_init(fb.StopAfterCurrent);
function on_paint(gr){
gr.DrawImage(img, 0, 3, 20, 16, 0, 0, 20, 16);
function on_mouse_leave() {
if (g_drag==1) {
g_drag = 0;
fb.StopAfterCurrent = !fb.StopAfterCurrent;
window.Repaint();
// g_drag = 0;
function on_playlist_stop_after_current_changed(state) {on_init(fb.StopAfterCurrent);}
//EOF
Hm, I'm getting a script error on that.
edit: I probably need the images, lol
i only have 2 very unpretentious images (both - 21x20) that i drew myself:
1) stop-after-current-off.png - contains nothing but a grey background (my aim was to draw exactly the same grey colour as we can see, for example, around standard buttons like play, pause...)
2) stop-after-current-on.png - there is merely a simple thin black cross here (thus, when i see it, i immediately understand that "stop after current" is enabled; and when i don't see this cross near to my standard buttons, it is clear that "stop after current" is disabled)
Yeah, I just made some myself... So what's preventing this sort of script from working with "remove track after playback" and the like? Would it also work with "Stop After Current Album?" Isn't it just a matter of rewriting the commands?
Are all usermade content for WSH Panels Mod now following the new guidelines with regards to where components and associated files should be place? I.e in the foobar2000 user profile folder.
I would hate having to put junk in c:\program files\foobar2000 again.
Not all I think, mine is. IMO, profile path should be used because that would be the foobar folder for portable install anyway.
Just my mediainfo panel.
Needs Safe mode turned off I guess since it calls new ActiveXObject();
Also requires the wonderful scrollbar.js library.
// scrollbar_demo.js: totally useless and stupid demo of my scrollbar.
// written by r0lZ September 2003
// ==PREPROCESSOR==
// @import "%fb2k_profile_path%\wsh_scripts\scrollbar.js"
// Our own global variables
// the text that we display in the viewport
var g_text = "Shit";
//var g_font = g_dui == 1 ? window.GetFontDUI(0) : window.GetFontCUI(0);
var g_font = gdi.Font("Consolas", 12, 0);
// the bitmap that will be displayed in the viewport
var g_bitmap = null;
// flag set to true when the window size changes, as we will need to compute
// a new viewport size and redraw the bitmap.
var g_need_vp_refresh = true;
// font flags
DT_CENTER = 0x00000001;
DT_BOTTOM = 0x00000008;
DT_END_ELLIPSIS = 0x00008000;
// Configuration options for the scrollbar and the viewport
// foreground color of the scrollbar (alpha supported)
var sb_fg = window.InstanceType == 1 ? window.GetColorDUI(0) : window.GetColorCUI(0);
// background color of the scrollbar (alpha supported)
var sb_bg = 0x40FFFFFF; // transluscent white background
// scroll increment, in pixels, for the scrollbar arrows, the mouse wheel and the Up/Down keys
var sb_small_inc = g_font.Height * 3;
// allow drag the viewport with the mouse?
var sb_drag_enabled = true;
// allow scroll with the mouse wheel?
var sb_mouse_wheel_enabled = true;
// allow scroll with PageUp/Down and Cursor Up/Down?
var sb_keyboard_enabled = true;
// hide the scrollbar when the whole bitmap fits in the viewport?
var sb_hide_useless_scrollbar = true;
// hide the scrollbar when the mouse is not over it?
var sb_auto_hide_scrollbar = true;
// place the scrollbar at the left side of the viewport?
var sb_scrollbar_at_left_side = false;
// draw a 1 pixel border using the sb_fg color in the viewport?
var sb_draw_border = true;
////////////////// Example code ///////////////
function on_size()
// sets the flag telling that the viewport and bitmap must be reinitialized.
// compute the dimentions of our viewport
var x = 2;
var y = 2;
var w = window.Width-4;
var h = window.Height-4;
// draw elements that are outside the viewport
var bg = window.InstanceType == 1 ? window.GetColorDUI(1) : window.GetColorCUI(3);
gr.FillSolidRect(0,0, window.Width,window.Height, bg);
if (g_need_vp_refresh) {
// if necessary, create the bitmap and init the viewport
g_bitmap = draw_bitmap(x, y, w, h);
sb_init_viewport(x, y, w, h, g_bitmap);
// paint the viewport (without the scrollbar)
sb_paint_viewport(gr);
// and finally, draw the scrollbar
sb_paint_scrollbar(gr);
function getmediainfo(filename) {
//var fso = new ActiveXObject("Scripting.FileSystemObject");
var wsh = new ActiveXObject("WScript.Shell");
var pp = "cmd.exe /C\"\"H:\\codecs and players\\mediainfo_cli\\MediaInfo.exe\" \""+filename+"\" > h:\\out.txt\"";
//fb.trace(pp);
var app = wsh.Run(pp, 0, 1);
return utils.ReadTextFile("h:\\out.txt");
function on_selection_changed(metadb) {
if (metadb) {
g_text = getmediainfo(metadb.Path);
window.Repaint();
function init() {
var mdb = fb.GetSelection();
if (mdb) {
g_text = getmediainfo(mdb.Path);
window.Repaint();
// create and draw in the bitmap
function draw_bitmap(x, y, w, h)
g_need_vp_refresh = false;
// compute the height of the bitmap that will be scrolled through the viewport
var bitmapheight = sb_MeasureStringHeight(g_text, g_font, w)+8;
if (bitmapheight == -1) return;
if (bitmapheight < h) bitmapheight = h;
// create the bitmap
g_bitmap && g_bitmap.Dispose();
g_bitmap = gdi.CreateImage(w, bitmapheight);
// (the bitmap may be null when foobar starts, so we need to check it)
if (g_bitmap) {
// fill the bitmap with some colourful graphics
var bitmap_gr = g_bitmap.GetGraphics();
bitmap_gr.FillGradRect(x,y, w, bitmapheight, 0, 0xFFFFFFFF, 0xFF808080);
bitmap_gr.DrawString(g_text, g_font, 0xFF000000, 4, 4, w-8, DT_NOPREFIX);
// Do not forget to release the graphics!
g_bitmap.ReleaseGraphics(bitmap_gr);
return(g_bitmap);
// Page Down with middle mouse button
// Demonstrates how to use sb_set_bitmap_pos() and sb_set_bitmap_pos_percent()
function on_mouse_mbtn_down(x, y, mask)
if (! sb_bitmap) return;
var curpos = sb_offset/(g_bitmap.Height-sb_vp_h);
if (curpos > 0.999) {
sb_set_bitmap_pos(0, 1);
} else {
sb_set_bitmap_pos_percent(curpos + sb_vp_h / g_bitmap.Height * 0.8, 1);
// clean exit
function on_script_unload()
g_bitmap && g_bitmap.Dispose(); // Is it really necessary?
init();
Scrollbar.js (put in profile folder\wsh_scripts):
// scrollbar.js v0.1
// WSH script for foobar2000, written by r0lZ, september 2010.
// Requires foobar v1.0 with WSH Panel Mod v1.3.6 or greater.
// Define a viewport in your WSH window and a larger bitmap. This script generates a
// vertical scrollbar that you can draw in the viewport, and automatically scrolls the bitmap
// in the viewport according to the user actions.
// Additionnaly, the viewport can also be dragged with the mouse, and scrolled with the mouse
// wheel or the keyboard. Horizontal scrolling is not supported.
// Functions that you should use:
// function sb_init_viewport(x, y, width, height, bitmap, reset_scrollbar_position)
// Initialize the internal variables. You should call it each time you need to refresh the
// bitmap that is drawn in the viewport, or if you need to change the viewport position or size.
// The x, y, width and height parameters define the viewport window.
// The height of the viewport must be >= 30, or the slider is not drawn.
// The width of the bitmap should be identical (or greater but that's useless) than the width
// of the viewport.
// The height of the bitmap is normally greater than the height of the viewport (as otherwise
// the scrollbar is useless).
// If reset_scrollbar_position is true, the top of the bitmap will be shown. Otherwise,
// the previous position will be kept.
// The function returns true if the bitmap is not null.
// function sb_paint_viewport(gr)
// Paint the viewport. This function should be called from the on_paint() callback.
// sb_init_viewport() should have been called BEFORE this function.
// function sb_paint_scrollbar(gr)
// Paint the scrollbar (if it is currently visible)
// This function should be called from the on_paint() callback, after sb_paint_viewport().
// function sb_set_bitmap_pos(y_position, mode)
// change the Y position of the bitmap in the viewport
// y_position (in pixels): 0 = top, bitmap.Height-1 = bottom
// mode: 1=place specified bitmap position on top of the viewport,
// -1=on bottom, 0=center
// Return true if the bitmap has been moved.
// function sb_set_bitmap_pos_percent(y_percent, mode)
// same as sb_set_bitmap_pos(), but here the position is a float
// between 0 (top) and 1 (bottom)
// function sb_CenterStringHorizontally(gr, str, font, color, x, y, maxwidth, fontflags)
// Simple helper function, to draw multi-line text with word wrapping centered in the bitmap.
// It is necessary to use that function, as strings written with GdiDrawText() look horrible
// when they are drawn in a bitmap.
// The function returns the latest Y position, so you can use the return value to draw another
// string.
// function sb_MeasureStringHeight(str, font, maxwidth)
// This is a simple helper function that returns the height of a string to draw with the previous
// function. It can be used to compute the height of the bitmap.
// Callback functions used by this script:
// Several standard callback functions are used by this script, and are therefore not available
// directly in your own script. However, you can still use them (with some minor limitations),
// but you have to replace "on_" with "on_sb_" in the function name. For example, if you need
// to be notified when the mouse moves, you should define the function on_sb_mouse_move(x, y)
// instead of on_mouse_move(x, y).
// on_sb_mouse_lbtn_down(x, y, mask) // You will not recieve the mouse clicks on the scrollbar
// // (and on the viewport if sb_drag_enabled == true)
// on_sb_mouse_lbtn_up(x, y, mask) // No limitations
// on_sb_mouse_move(x, y) // No limitation, except when the user scrolls the bitmap
// on_sb_mouse_leave() // No limitation
// on_sb_mouse_wheel(offset) // Available only if sb_mouse_wheel_enabled == false
// on_sb_key_down(vkey) // The Up, Down, PgUp, PgDown, Home and End keys are not
// // available when sb_keyboard_enabled == true
// on_sb_timer(timerid) // No limitations
// It is your responsibility to rebuild the bitmap when needed. In most cases, it is sufficient
// to rebuild it when you have to change its content and when the WSH window size changes.
// Then, you should call sb_init_viewport(). Call sb_paint_viewport() and sb_paint_scrollbar()
// from on_paint() to draw the viewport and the slider.
// Notes:
// - The behavior of the scrollbar is determined by global variables. See below.
// - All functions and global variables defined in this script begin with "sb_".
// - The width of the scrollbar is 16 pixels. If you do not use the option to hide it automatically,
// You should not draw important things in the area occupied by the scrollbar.
// - You can define only one viewport and scrollbar per WSH window.
// - Unfortunately, GdiDrawText() doesn't work well when it writes in a bitmap. Use DrawString() or
// the helper functions above.
////// configuration variables that you can overwrite in your script (Do not modify them here!):
var sb_bg = window.InstanceType == 1 ? window.GetColorDUI(1) : window.GetColorCUI(3);
var sb_small_inc = 40;
// allow scroll with Up, Down, PgUp, PgDown, Home and End keys?
var sb_draw_border = false;
// if the bitmap is smaller than the viewport, center it
var sb_center_small_bitmaps = true;
////// end of configuration variables section
// Read-only global variables that you can examine. Do NOT overwrite them directly!
var sb_bitmap = null; // the bitmap
var sb_offset = 0; // Height of the bitmap zone that is above the top border of the viewport.
var sb_vp_x = 0; // Position of the viewport in the WSH window
var sb_vp_y = 0;
var sb_vp_w = window.Width; // Size of the viewport
var sb_vp_h = window.Height;
var sb_sb_x = window.Width-16; // X position of the scrollbar in the WSH window.
// Other global variables. You should not need them.
var sb_slider_y = sb_slider_h = 0;
var sb_drag_slider = sb_drag_bitmap = false;
var sb_drag_y = sb_mouse_y = 0;
var sb_is_hidden = sb_mouse_is_outside = true;
var sb_timer = null;
var sb_timer_increment = 0;
var sb_timer_big_jumps = false;
/////////////////////// main scrollbar functions ////////////////////////
// initialize the internal variables
sb_bitmap = bitmap;
sb_vp_x = x;
sb_vp_y = y;
sb_vp_w = width;
sb_vp_h = height;
if (sb_scrollbar_at_left_side) {
sb_sb_x = sb_vp_x;
} else {
sb_sb_x = sb_vp_x+sb_vp_w-15;
if (sb_bitmap && (sb_bitmap.Height == 0 || sb_bitmap.Width == 0)) sb_bitmap = null;
if (reset_scrollbar_position || ! bitmap) {
sb_offset = 0;
} else if (sb_offset > sb_bitmap.Height-sb_vp_h) {
sb_offset = sb_bitmap.Height-sb_vp_h;
if (sb_offset < 0) {
if (sb_center_small_bitmaps) {
sb_offset = Math.floor(sb_offset/2);
} else {
sb_offset = 0;
return sb_bitmap ? true : false;
// paint the content of the viewport
//gr.FillSolidRect(sb_vp_x,sb_vp_y, sb_vp_w,sb_vp_h, sb_bg);
if (sb_bitmap) {
var x = sb_vp_x;
var sbw = (sb_hide_useless_scrollbar && sb_bitmap.Height <= sb_vp_h) || sb_auto_hide_scrollbar ? 0:16;
if (sb_bitmap.Width < sb_vp_w-sbw && sb_center_small_bitmaps) {
x += Math.round((sb_vp_w-sbw - sb_bitmap.Width)/2);
gr.DrawImage(sb_bitmap, x,sb_vp_y, sb_vp_w,sb_vp_h, 0,sb_offset, sb_vp_w,sb_vp_h, 0, 255);
if (sb_draw_border) {
gr.DrawRect(sb_vp_x,sb_vp_y, sb_vp_w-1,sb_vp_h-1, 1,sb_fg);
// paint the scrollbar (if it is currently visible)
var arrow;
if (!sb_bitmap || (sb_hide_useless_scrollbar && sb_bitmap.Height <= sb_vp_h) || (sb_auto_hide_scrollbar && sb_mouse_is_outside) || sb_vp_h <= 30) {
sb_is_hidden = true;
return;
sb_is_hidden = false;
gr.FillSolidRect(sb_sb_x,sb_vp_y, 14,sb_vp_h, sb_bg);
gr.DrawRect(sb_sb_x,sb_vp_y, 14,sb_vp_h-1, 1,sb_fg);
gr.DrawLine(sb_sb_x,sb_vp_y+12, sb_sb_x+13,sb_vp_y+12, 1,sb_fg);
gr.DrawLine(sb_sb_x,sb_vp_y+sb_vp_h-13, sb_sb_x+14,sb_vp_y+sb_vp_h-13, 1,sb_fg);
arrow = new Array(sb_sb_x+2,sb_vp_y+9, sb_sb_x+12,sb_vp_y+9, sb_sb_x+7,sb_vp_y+3);
gr.FillPolygon(sb_fg,0,arrow);
arrow = new Array(sb_sb_x+3,sb_vp_y+sb_vp_h-9, sb_sb_x+12,sb_vp_y+sb_vp_h-9, sb_sb_x+7,sb_vp_y+sb_vp_h-4);
sb_draw_slider(gr);
// change y position of the bitmap in the viewport
if (!sb_bitmap) return(false);
if (mode == -1) {
y_position -= sb_vp_h-1;
} else if (mode == 0) {
y_position -= Math.round(sb_vp_h/2);
if (y_position < 0) {
y_position = 0;
} else if (y_position > sb_bitmap.Height-sb_vp_h) {
y_position = sb_bitmap.Height-sb_vp_h;
if (y_position != sb_offset) {
sb_offset = y_position;
window.Repaint();
return(true);
return(false);
// same as sb_set_bitmap_pos(), in percent
return(sb_set_bitmap_pos(Math.round(sb_bitmap.Height*y_percent), mode));
//////////////// the functions below should not be called directly
// scroll the bitmap by big increrment
function sb_big_increment(dir)
var incr;
var pc_shown = sb_vp_h/sb_bitmap.Height;
if (pc_shown >= 1) {
return;
} else {
incr = dir*sb_slider_h*1/pc_shown*Math.abs(sb_vp_h/(sb_vp_h-32));
if (incr > 0 && incr > sb_small_inc) incr -= sb_small_inc;
if (incr < 0 && incr < sb_small_inc) incr += sb_small_inc;
sb_increment_bitmap_pos(incr);
sb_timer_increment = incr;
sb_timer_big_jumps = true;
sb_timer = window.CreateTimerTimeout(500);
// scroll the bitmap by any number of pixels
function sb_increment_bitmap_pos(increment)
var tmp = sb_offset + Math.round(increment) * -1;
if (tmp < 0) {
tmp = 0;
} else if (tmp > sb_bitmap.Height-sb_vp_h) {
tmp = sb_bitmap.Height-sb_vp_h;
if (tmp != sb_offset) {
sb_offset = tmp;
window.Repaint();
return(true);
return(false);
// Called when the user moves the scrollbar slider
function sb_apply_scroll(y)
return;
} else {
delta = y - sb_drag_y;
if (sb_increment_bitmap_pos(delta*-1/pc_shown*Math.abs(sb_vp_h/(sb_vp_h-32)))) {
sb_drag_y = y;
// draw the slider in the scrollbar
function sb_draw_slider(gr)
if (!sb_bitmap || sb_is_hidden || (sb_hide_useless_scrollbar && sb_bitmap.Height <= sb_vp_h)) return;
var pc_shown, pc_offset;
var s_max = sb_vp_h-32;
pc_shown = 1;
pc_offset = 0;
} else {
pc_offset = sb_offset/sb_bitmap.Height;
if (pc_offset < 0) {pc_offset = 0}; // not necessary?
sb_slider_y = sb_vp_y + s_max * pc_offset + 14;
sb_slider_h = s_max * pc_shown + 4;
if (sb_vp_h > 50) {
gr.FillSolidRect(sb_sb_x+2,sb_slider_y, 11,sb_slider_h, sb_fg);
/////////////////////////// callbacks //////////////////////
function on_mouse_lbtn_down(x, y, mask)
sb_timer && window.KillTimer(sb_timer);
if (! sb_is_hidden && sb_bitmap && sb_bitmap.Height > sb_vp_h && x > sb_sb_x && x < sb_sb_x+15 && y > sb_vp_y && y < sb_vp_y+sb_vp_h) {
if (y < sb_vp_y+12) {
sb_timer_increment = sb_small_inc;
sb_increment_bitmap_pos(sb_timer_increment);
return;
if (y >= sb_vp_y+sb_vp_h-12) {
sb_timer_increment = sb_small_inc*-1;
return;
if (sb_vp_h > 50) {
if (y >= sb_slider_y && y < sb_slider_y+sb_slider_h) {
sb_drag_slider = true;
sb_drag_y = y;
return;
if (y >= sb_vp_y+12 && y < sb_slider_y) {
sb_big_increment(1);
return;
if (y < sb_vp_y+sb_vp_h-12 && y > sb_slider_y + sb_slider_h) {
sb_big_increment(-1);
return;
} else {
sb_timer_increment = sb_vp_h * -0.9;
if (sb_offset + sb_vp_h + 1 >= sb_bitmap.Height) {
} else {
return;
if (sb_drag_enabled && x > sb_vp_x && x < sb_vp_x+sb_vp_w && y > sb_vp_y && y < sb_vp_y+sb_vp_h) {
if (sb_bitmap && sb_bitmap.Height > sb_vp_h) {
sb_drag_bitmap = true;
sb_drag_y = y;
window.SetCursor(32645); // IDC_SIZENS
return;
// call user's callback function
try {on_sb_mouse_lbtn_down(x, y, mask)} catch(e) {}
return;
function on_mouse_lbtn_up(x, y, mask)
sb_drag_slider = false;
if (sb_drag_bitmap) {
window.SetCursor(32512); // IDC_ARROW
try {on_sb_mouse_lbtn_up(x, y, mask)} catch(e) {}
function on_mouse_move(x, y)
sb_mouse_y = y;
if (sb_drag_slider) {
sb_apply_scroll(y);
return;
sb_increment_bitmap_pos(y - sb_drag_y);
sb_drag_y = y;
return;
if (sb_is_hidden && sb_auto_hide_scrollbar && sb_bitmap && sb_bitmap.Height > sb_vp_h && x >= sb_sb_x && x <= sb_sb_x+15 && y >= sb_vp_y && y <= sb_vp_y+sb_vp_h) {
window.Repaint();
sb_mouse_is_outside = false;
try {on_sb_mouse_move(x, y)} catch(e) {}
if (! sb_is_hidden && sb_auto_hide_scrollbar) {
window.Repaint();
try {on_sb_mouse_leave()} catch(e) {}
function on_mouse_wheel(offset)
if (sb_mouse_wheel_enabled && sb_bitmap && sb_bitmap.Height > sb_vp_h) {
sb_increment_bitmap_pos(offset*sb_small_inc);
} else {
try {on_sb_mouse_wheel(offset)} catch(e) {}
if (sb_keyboard_enabled && sb_bitmap && sb_bitmap.Height > sb_vp_h) {
switch(vkey) {
case 33:
// PgUp
break;
case 34:
// PgDn
break;
case 35:
// End
sb_increment_bitmap_pos(sb_bitmap.Height*-1);
break;
case 36:
// Home
sb_increment_bitmap_pos(sb_bitmap.Height);
break;
case 38:
// Up
sb_increment_bitmap_pos(sb_small_inc);
break;
case 40:
// Down
sb_increment_bitmap_pos(sb_small_inc*-1);
break;
return;
try {on_sb_key_down(vkey)} catch(e) {}
function on_timer(timerid)
if (sb_timer && timerid == sb_timer.ID) {
if (sb_timer_big_jumps && sb_mouse_y >= sb_slider_y && sb_mouse_y < sb_slider_y+sb_slider_h) return;
if (sb_increment_bitmap_pos(sb_timer_increment)) {
sb_timer = window.CreateTimerTimeout(100);
return;
try {on_sb_timer(timerid)} catch(e) {}
//////////////////////////// helper functions ///////////////////////////////
// These functions are not necessary for the scrollbar. You can remove them.
// Draw multi-line text with word wrapping centered in the bitmap.
if (window.Height == 0) return(-1); // safety check: foobar enters in an infinite loop if bitmap.GetGraphics() is called when foobar is initializing.
var i, j, xpos, ypos, arr2;
var arr1 = str.split("\n");
ypos = y;
for (i=0; i<arr1.length; i++) {
arr2 = gr.EstimateLineWrap(arr1[i], font, maxwidth).toArray();
for (j=0; j<arr2.length; j+=2) {
xpos = x+(maxwidth-arr2[j+1])/2;
gr.DrawString(arr2[j], font, color, xpos, ypos, maxwidth, font.Height+50, fontflags);
ypos = ypos + font.Height;
return(ypos);
// Returns the height of a string to draw with the previous function.
var temp_bmp = gdi.CreateImage(1, 1);
var temp_gr = temp_bmp.GetGraphics();
var i, arr2;
var h = 0;
arr2 = temp_gr.EstimateLineWrap(arr1[i], font, maxwidth).toArray();
h = h + font.Height*arr2.length/2;
temp_bmp.ReleaseGraphics(temp_gr);
temp_bmp.Dispose();
return(h);
Too bad using wsh.Exec() shows the console dialog when running console applications and wanting to capture the output.
So the solution is to use wsh.Run() with cmd.exe to redirect the output to a temporary text file which you can then read with utils.ReadTextFile()
I struggled with getting this to work because cmd.exe requries a lot of quoting for the > character to be parsed correctly.
So I ended up with this:
cmd.exe /C""H:\codecs and players\mediainfo_cli\MediaInfo.exe" "E:\music\Above & Beyond - Trance Around The World\Above & Beyond - Trance Around the World 353 (2010-12-31).mka" > h:\out.txt"
as you can see the entire string after /C is quoted. then you got quotes for the long filenames. When escaped for use in javascript it looks even worse:
No wonder it is so easy to get tripped up here.
Someone ought to have made this simpler to do. Basically what I'm requesting is for a function in WSH panels mod that lets you run and capture output of console apps without this ugly code.
Hi!
I'm trying to create a very simple button to toggle on/off the Stop after Album function of the... Stop after album component http://www.hydrogenaudio.org/forums/index....c=83743&hl= (http://www.hydrogenaudio.org/forums/index.php?showtopic=83743&hl=)
I can toggle the value with
fb.RunMainMenuCommand("Control/Stop after album");
But how to access its value (which should be 0 or 1) ? I would like to change the state of the button depending of its value (if it's on, do blablabla, ... if it's off, do blablabla)
Thanks in advance for your help,
hi everyone!
I'm really bad at scripting. just wanted to ask, can i get this panel to show cover art dimensions?? (if not, any alternative solution will be really appreciated)
samples updated.
I have a few quick questions about your layout, I'd be glad if you answered them.
Is that tab stack on top made directly on WSH? I'm assuming since the toolbar looks like it was. Oh, and it looks awesome, by the way. And the Last.fm stuff was put on a Panel Stack, right? And is that tab stack a regular tab stack containing WSH panels?
i'm guessing that would require an SDK for the component to be opened up and then included in WSH panel mod. in short, not likely...
yup, what ever variable contains your image, you can get dimensions like this...
my_img.height
my_img.width
nope, the top "tabs" are buttons in Panel Stack Splitter. and yup, the WSH panels are in a standard tab stack (inside a parent PSS with a 10px margin around the edge).
Thanks for the reply. Buttons... I got Panel Stack today, I'm still playing with this a little bit.
Would you mind showing me the Library tab? I'm kinda curious to see what have you done with it since I really liked your previous designs.
erm ok. click (http://k5sbdw.blu.livefilestore.com/y1p4PSJwc8jsYXCwuSvXDieK7b1TZHMh1KCPXWUZAXOfYbbU9gtDeqzcCB_oDlkBDi8fMl1Ugid7B9drvHc0PJescQ4drXNw9ni/library%20tab.png)
Thank you for your answer. I was afraid of something like that. I guess I will try to create my own "stop after album" WSH panel mod script from scratch.
my_img.height
my_img.width
thx! jscript seems can do many things... must learn!)
must learn!
a good place to start is the documentation that comes with the component.
good point. i've decided to move all my shared files in to the profile folder.
samples updated: http://cid-649d3bfeaf541fbb.office.live.co...ide/samples.zip (http://cid-649d3bfeaf541fbb.office.live.com/self.aspx/.Public/foobar/guide/samples.zip)
Dude, what the fuck is wrong with the goddamn buttons? Every time I change something on them, foobar resets their parent Panel Stack and, well, its configuration on the grandparent Panel Stack too. Also, I can't have more than one button when its custom image isn't a square, right?
I know this isn't the thread but how can I change a Panel Stack border edge to grey, sunken and etc?
Okey dokey this is it a basic "Stop after album" script. It is just a simple button (width 126; height 20) that can toggle on/off the Stop After Current function for when the playback reach the last track of an album (that is when %tracknumber% = %totaltracks%)
If totaltracks is not defined it doesn't work.
As my skills in jscript are very low (I "learn" it trying to understand other people scripts) it must be written badly but it works.
If someone wants to modify it, feel free to do it but please post the modifed script here.
http://pastebin.com/K391Ksym (http://pastebin.com/K391Ksym)
// ==PREPROCESSOR==
// @name "Stop After Album v.1.0"
// @author "Decalicatan Decalicatan"
// width: 126
// height: 20
var tracknumber_tf = fb.TitleFormat("%tracknumber%");
var totaltracks_tf = fb.TitleFormat("[%totaltracks%]");
var totaltracks, tracknumber;
var SAA = "Stop after album";
var SAA_state = 0;
var font = gdi.Font("Calibri", 16, 1);
var hover = 0;
function on_mouse_mbtn_down(x, y) {
window.ShowConfigure();
function on_mouse_move() {
if (fb.IsPlaying) {
totaltracks = totaltracks_tf.EvalWithMetadb(g_metadb);
if (totaltracks == 0) {
hover = 0;
} else {
hover = 1;
window.Repaint();
} else hover = 1;
hover = 0;
window.Repaint();
function StringFormat(alignH, alignV, trim, flag) {
return ((alignH << 28) | (alignV << 24) | (trim << 20) | flag);
function RGB(r, g, b) {
return (0xff000000 | (r << 16) | (g << 8) | (b));
function on_playlist_stop_after_current_changed(new_order_index) {
window.Repaint();
g_metadb = null;
SAA_state = 0;
if (reason != 2) window.Repaint();
function on_mouse_lbtn_down(x, y) {
tracknumber = tracknumber_tf.EvalWithMetadb(g_metadb);
if (fb.StopAfterCurrent) fb.StopAfterCurrent = 0;
if (SAA_state !== 0) {
SAA_state = 0;
} else {
SAA_state = totaltracks_tf.EvalWithMetadb(g_metadb);
if (tracknumber == SAA_state) fb.StopAfterCurrent = 1;
function on_paint(gr) {
var ww = window.Width;
var wh = window.Height;
totaltracks = fb.TitleFormat("[%totaltracks%]").Eval();
tracknumber = fb.TitleFormat("[%tracknumber%]").Eval();
if (((fb.StopAfterCurrent) && (SAA_state != tracknumber)) || ((!fb.StopAfterCurrent) && (SAA_state == tracknumber))) SAA_state = 0;
if (hover == 0) {
gr.FillSolidRect(0, 0, ww, wh, RGB(255, 255, 255));
gr.GdiDrawText(SAA, font, RGB(205, 205, 205), 0, 0, ww, wh, DT_CENTER | DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
} else {
if (SAA_state) {
gr.GdiDrawText(SAA, font, RGB(0, 128, 192), 0, 0, ww, wh, DT_CENTER | DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
} else {
gr.GdiDrawText(SAA, font, RGB(105, 105, 105), 0, 0, ww, wh, DT_CENTER | DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
} else {
gr.FillSolidRect(0, 0, ww, wh, RGB(0, 128, 192));
gr.GdiDrawText(SAA, font, RGB(255, 255, 255), 0, 0, ww, wh, DT_CENTER | DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
@ marc2003
In your last revision of samples.zip, the folder marc2003\images\2010 is missing and so is the small lastfm.png icon for the Similar Artist script
oops. i was tidying up unused files and got a bit carried away. thanks for spotting that one. it should be fixed now.
Anyone knows how to implement network connection timeout inside wsh panels with activexcontrol Microsoft.XMLHTTP (last.fm was literally down for two previous days and taking forever to respond)? I've been trying to search for a solution to this problem but to no avail. I know of an alternative by using wget, but I don't want to go that way unless there's no other way. Any help is appreciated.
Managed to implement network timeout with ServerXMLHTTP ActiveX component. Not the recommended way as this component is supposed to work on server not client. Side effect is user have to enter proxy settings manually if they are behind a proxy (well they did have to do this for wget anyway).
if a user has proxy settings set in IE, couldn't you read it from the registry using WshShell.RegRead?
Does anyone have a good Last.fm love track script, one that doesn't require that SoftPlaylist component? It seems doable on the API, since the scrobbler I got on my Symbian phone has it and it works smoothly.
That would be much appreciated.
Mine have love feature, inside playing track info panel (the actual code is inside the bio panel though). You can get them here (http://www.hydrogenaudio.org/forums/index.php?showtopic=84592). Beware that I will soon update the pack though, tomorrow or the day after.
@Marc: thanks will do that, but that's only half way as I can't find where to read the authentication information in case the proxy server require it.
samples updated:
just a couple of minor changes.
simple biography -added arrows to indicate when there is more content that can fit in the panel. clicking them will scroll the text but using your mouse wheel is still the best way.
similar artists - added context menu option to remove artist name from the title (i recently added my biography panel and this panel into the same tab and i thought it looked stupid having the artist name displayed twice next to each other). i also squished a little bug where clicking on a blank area below the content would launch a browser/spotify for artists that you can't see on screen.
samples updated. link in the above post.
new script: cd jewel case.
(http://k5sbdw.blu.livefilestore.com/y1pMKDsCtSCgCTRT6lTAy7ndm_jZzSN3z_ruM7J3JJFoLmMY3uD33FP41jimkDz0N1QL3U1c1Mcvtfd4h-0CHQISY_NYxptpLaZ/cd.png)
it displays the front cover according to your foobar display preferences. the size is fixed and it will be centered regardless of how big the panel is. background colour will be dictated by your CUI/DUI colour settings. double click the panel and it opens the image in your default viewer (or locate the music file in explorer if it's embedded)
WSH Panel Mod (CD Jewel Case by marc2003): Parsing file "T:\PortableApps\foobar2000 - all\\marc2003\common.js": Failed to load
Error: WSH Panel Mod (CD Jewel Case by marc2003): Microsoft JScript runtime error:
Object expected
Ln: 9, Col: 1
<source text only available in compile time>
did i miss something? i did copied your script folder...
edit: if you saw my previous post, ignore it.
are you absolutely sure the "marc2003" folder is in the correct place? i don't think it is....
edit2: samples updated. i just tidied up the pre-processor stuff so it doesn't display 2 backslashes in the console output like the example above.
"T:\PortableApps\foobar2000 - all\\marc2003\common.js" <<bad
"T:\PortableApps\foobar2000 - all\marc2003\common.js" << good
luckily it had no effect over it working..
ah yeah, didnt saw your previous post lol
it's working now, thanks D:
i've got a problem with the now playing panel in default ui
it crashes when i want to load. here is the console log:
Error: WSH Panel Mod (Now Playing by marc2003): Laufzeitfehler in Microsoft JScript: (means runtime error)
Objekt erforderlich (means object required)
Ln: 307, Col: 2
WSH Panel Mod: Warning: Could not load file C:\Users\Hannes\AppData\Roaming\foobar2000\user-components\foo_uie_wsh_panel_mod\jscript.api
WSH Panel Mod: Warning: Could not load file C:\Users\Hannes\AppData\Roaming\foobar2000\user-components\foo_uie_wsh_panel_mod\interface.api
oops, my house cleaning of old images has come back to bite me again.
change line 119 from
scale(gr, gdi.Image(images_path + "foobar.png"), 0, 0, ww, wh - 130, "min");
to
scale(gr, gdi.Image(images_path + "new foo.png"), 0, 0, ww, wh - 130, "min");
edit: fixed version uploaded also.
thanks, mate
btw, what do i have to change, if i want to display the playback time and length next to the title, for example: title - 0:34/3:44 ?
would be very cool if you post the lines
replace the script with this....
http://pastebin.com/T3gMhSVu (http://pastebin.com/T3gMhSVu)
awesome
lastfm charts: fix last.fm radio buttons not working after other changes made last week.
similar artists: added option to pause playback when launching spotify.
WSH Tree Panel 1.0
(http://img14.imageshack.us/img14/7325/tree5.th.png) (http://img14.imageshack.us/i/tree5.png/)
Get the script from my DeviantArt account : http://br3tt.deviantart.com/art/WSH-Tree-E...r-1-0-196023730 (http://br3tt.deviantart.com/art/WSH-Tree-Explorer-1-0-196023730)
ampersands (&) don't show in folder/file names. you can fix this by using the DT_NOPREFIX flag.
i like how you've drawn all the images in the script. nice work.
edit: using the "send found tracks to playlist and play" option doesn't appear to work?? the files get added but it doesn't play.
edit2: i've realised this is due to me setting enqueue as the default action under "shell integration" in the preferences.
nice one Falstaff!!
this is one feature from mediamonkey that i hope exist in foobar2k and you brought that to us, thank you!
thanx for the reporting, i'll fix it
Edit: done
nice one Falstaff!!
thank you
Hi, I have a few questions about scripting in jscript
I dont know if this is possible, but, is there a function that is called automatically when the panel starts?
Is is possible to draw a rounded rectangle that is filled with a gradient?
1) you can create your own function and then call it like this...
function my_func() {
//blah
my_func();
2) i think you'll just have to bodge it by drawing a few rounded rectangles inside each other slowly changing the colours.
2) there is another solution : use a round rectangle as a Mask, draw a gradient rectangle and apply the mask on it to obtain the gradient-round-rectangle wanted ...
here is a function that do the job: function FillGradientRoundRect(gr, x, y, w, h, arc_width, arc_height, gradient_angle, bg_colour1, bg_colour2, focus) {
// drawing the Mask
var Mask_img = gdi.CreateImage(w+1, h+1);
var gb = Mask_img.GetGraphics();
gb.FillSolidRect(0,0,w,h,0xffffffff);
gb.SetSmoothingMode(2);
gb.FillRoundRect(0, 0, w-2, h-2, arc_width, arc_height, 0xff000000);
Mask_img.ReleaseGraphics(gb);
// drawing the gradient rect
var GradientRect_img = gdi.CreateImage(w+1, h+1);
gb = GradientRect_img.GetGraphics();
gb.FillGradRect(0, 0, w-2, h-2, gradient_angle, bg_colour1, bg_colour2, focus);
GradientRect_img.ReleaseGraphics(gb);
// resizing and applying the mask
var Mask = Mask_img.Resize(w+1, h+1);
GradientRect_img.ApplyMask(Mask);
Mask.Dispose();
// drawing the resulting image
gr.DrawImage(GradientRect_img, x, y, w-1, h-1, 0, 0, w, h, 0, 255);
and this is an example of call to use in on_paint:function on_paint(gr) {
FillGradientRoundRect(gr, 10, 10, 100, 60, 15, 15, 90, 0xffeeee22, 0xffff5533, 1.0);
... and the result is like this in a panel (http://img232.imageshack.us/img232/1271/roundgradrect.png)
^nice. i really should spend some time learning that stuff.
last.fm charts now uses a fluid layout so it can fit in narrower panels.
Wow thanks! I'm not a coder, and just kinda bs my way through code, so I'm sure I'll be back to ask more questions about that.
Im assuming that drawing images in the manner falstaff showed is more efficient than importing a picture of the image through DrawImage() right?
@ marc2003, is it possible to add a scroll bar to you "simple biography" panel? removing the up and down arrows...
i've thought about it in the past but i'm just too lazy. i just use my mouse wheel to scroll. i only added the arrows to indicate there is more content.
if you want proper scrollbars, you could use the full blown "biography view" component: http://foo2k.chottu.net/#bv (http://foo2k.chottu.net/#bv)
last.fm charts: bugfix. i must not assume last.fm will always return data in a format that i expect.
How can I access the main menu, and the right click menu or songs now playing, and highlighted songs?
check the samples on the component home page.
edit: "MainMenuManager All-In-One.txt" is what you want.
WSH Tree Panel 1.0
Do you plan an option for changing the background color?
I'm using DUI and would like to change the background to black.
WSH Tree Panel 1.0
no option for a so easy thing to add, just add this line in the on_paint() function, with the desired colour :
gr.FillSolidRect(0,0,ww,wh, <your back ground colour> );example with a black background (RGB values : 0,0,0) :
gr.FillSolidRect(0,0,ww,wh,RGB(0, 0, 0));
if(cline_counter==0 && !c_drag) {
scan_expanded(null, root, false);
... etc
Whoops I didn't explain my self clearly.
I meant to ask if there was a way to execute certain commands found within the foobar menus, from WSH panel. For example, can I create a button within WSH that executes the "fullscreen" option under the View menu, or execute the "Scan per file track gain" under the ReplayGain options found when I right click a song?
^look at fb.RunMainMenuCommand and fb.RunContextCommandWithMetadb.
as foo_lastfm_radio now looks defunct, i've removed the options to launch it from the following scripts:
simple biography
lastfm charts
similar artists (this still has spotify links but you can remove them using the context menu if it's not available in your region)
looks like my previous post was a little premature - last.fm radio is working again. the old scripts have been restored:
foo_lastfm_radio is not working properly with these last.fm components created by marco. When i click the play button close to an artist name (weather in "Similar artists" or "Lastfm charts" panel), i get this error:
"Unable to launch last.fm radio! Make sure foo_lastfm_radio is installed and that you have set your username and password in the preferences. Also, check foobar is set as the default handler for the lastfm:// protocol. Use the "Set program association" tool found under File>Preferences>Shell Integration."
I have entered my username and password on foo_lastfm, and i have associated lastfm with foobar under "shell integration". Foo_lastfm is still working great when creating custom stations, but not with these components. Does anyone know a fix? Maybe i should make some changes in the script itself (such as entering my last.fm username and/or removing spotify entries)?
as i mentioned in the other thread, i have no idea why it isn't working. all it's doing is launching foo_lastfm_radio like an external application. it's no different than you using start>run manually like this....
lastfm://artist/madonna/similarartists
what happens if you try that?
edit: i've updated the error message so it isn't so confusing. the component has it's own username/password checking/error dialog so i've removed the reference to that. i can also detect if the component is installed so all it says now is to check the file type associations.
edit2: i don't suppose you're running windows XP? at first glance, the file associations tool for the lastfm:// protocol doesn't appear to work properly.
Can someone make a script to display lyrics in a panel?
Also, there are no install instructions for the WSH Panel Mod, so I'm assuming I just had to install the .dll and everything else was there for no reason.
I am running windows xp. And i am not sure how can i run "lastfm://artist/madonna/similarartists" from inside foobar.
Thanks for helping
edit: if by "lastfm://artist/madonna/similarartists" you mean right clicking in a madonna song/Last.fm Radio/Open Madonnas Station..., this always creates a playlist automatically and everything works properly in the playlist.
Also under "Preferences/Shell integration/ File types" there is only one last.fm entry (extension:lastfm, description:Last.fm radio) and that one is ticked.
i meant the windows start button.
anyway, it doesn't matter now. i've tested it myself on XP properly and the file association thing doesn't work at all (that's either a foobar or component problem i can't do anything about)
but you can edit the script and make it work. in last.fm charts.txt on line 194, it starts like this....
try { WshShell.run("lastfm://artist/"..........
just change it so it begins like this....
try { WshShell.run("foobar2000.exe lastfm://artist/"..................
It works PERFECTLY. Thanks a lot!
I also wanted to ask you if there is a possibility to add Wikipedia and Rateyourmusic buttons to the script "web links" (found in your package)?
Could someone write a script to display artworks and automatically cycle between front/back/disc/artist.
The old foo_uie_albumart did that but it's not DUI and crashs pretty bad.
Take a look to my fooAero (http://browse.deviantart.com/customization/skins/media/foobar2000/?order=5&offset=24#/d30x7y5) cover panel script
here's the script for it but you'll need to find/make your own images. (a standard image and a "hover" image)
http://pastebin.com/78JiqwtW (http://pastebin.com/78JiqwtW)
take note of the filenames and they should go inside.
%appdata%\foobar2000\marc2003\images
Or try this http://ashiato1.blog62.fc2.com/blog-entry-40.html (http://ashiato1.blog62.fc2.com/blog-entry-40.html) if you can make it work.
Exactly what I was looking for. Thank a lot!
autoplaylists.txt
i've made a new panel for storing autoplaylists as favourites. some people don't like having them active all the time so this allows you to store them using nice names. you can of course edit the names, queries and sort patterns after they've been created.
(name and query are required. you can leave the sort dialog blank if you want)
known issues:
-there is no scroll function so you're limited to the size of your panel for how many favourites you can see. i'll probably fix this at a later date.
-there is no confirmation when deleting.
Thank You again and again!
autoplaylists.txt
known issues:
Continually getting errors on this script, Marc:
Named: Loved Tracks
Query: LASTFM_LOVED IS 1
Sort: none
gives me a script error as soon as I try to execute playlist
if there's a script error, can you post what the console says?
also, you need %LASTFM_LOVED% IS 1 - not that it should crash with an invalid query, you just get blank results. well mine does anyway...
Error: WSH Panel Mod (GUID: EAA8D0BB-9EB2-49F1-A631-2B3491B5D26A): Microsoft JScript runtime error:
Object doesn't support this property or method
Ln: 72, Col: 13
i'm confused. what you posted shouldn't make the script crash???
can you post the contents of
%appdata%\foobar2000\wsh_settings\autoplaylists
(or foobar dir\wsh_settings\autoplaylists if running portable mode)
anyway, i've uploaded a new script that shouldn't crash (but it won't run the query either )
This is the only thing in autoplaylists: Loved Tracks!!%LASTFM_LOVED% IS 1!!
It's not giving me a script error anymore, but now am just receiving the message: "There was a problem executing that query. Please check your name/query/sort syntax."
As far as I know there should be nothing wrong with that query.
i'm stumped- obviously there's nothing wrong with that text..... :/
what OS are you on?
irrelevant, i've just tested on windows 7 and XP.
windows 7
are you running the latest WSH panel mod?
DOH that seems to have been the issue... updated to newest wsh panel mod and it worked fine.
glad you sorted it.
however i've just uploaded a new version which breaks compatibility with the one i uploaded last night...
in the old script i was using !! to separate and store stuff internally but i then i thought it could be possible that people might use that in their playlist names or queries which would then break it. i've now changed it to a ¬ instead which hopefully no one will be using.
(%appdata%\foobar2000\wsh_settings\autoplaylists can be opened in notepad and find/replace can be performed with !! and ¬)
Marc, you might use ASCII unit and field delimiters instead http://en.wikipedia.org/wiki/Delimiter (http://en.wikipedia.org/wiki/Delimiter) . Won't ever run into problems theoretically.
thanks. i'll stick with ¬ for now.
autoplaylists: all those buttons are a bit fugly so i've updated it so they only show when hovering your mouse over each row...
(http://k5sbdw.blu.livefilestore.com/y1pFlgkw1vnYyDu4kRHLG8c_L43r2Lh9XEe7Y_r6oWLiNY0057mTqGuOjeaAnxcdXzHusDL015cDbxDD9feAnuUs4JYggUDNrpv/new%20ap2.png)
autoplaylists updated again. same link as above.
-added sanity checking to prevent spawning of multiple text input windows and deletion of favourites when they are being edited.
another update for autoplaylists
-now with scrolling support. mouse wheel is quickest but there are clickable buttons also....
(http://k5sbdw.blu.livefilestore.com/y1psBaAYn-t3kGKgqyj0pkpr-G0MSZd3NvpMXjwrwARHZtGzOrF_GRzQaGYPsy9_Hi2EWZJEYUASIFBPhhY9E9rrI8p17cDb37G/ap%20scroll.png)
your autoplaylists script looks beautiful, but it creates a new playlist every time i click the "execute" button. is there a way to use the autosend playlist instead?
do you mean send to the same playlist if one with the same name already exists? i'm not sure if that's possible although i should be able to delete old one before creating the new one. i'll have a play around....
new version of autoplaylists (http://cid-649d3bfeaf541fbb.office.live.com/self.aspx/.Public/foobar/guide/samples.zip)
-added restore menu for deleted items. this only remains for the current session. also, anything that causes the script to re-initialise (such as cut/pasting the panel in layout editing mode or editing the script itself) will lose the history.
-added option to remove playlists with duplicate names (it's on by default, use the context menu to turn it off)
wow, thanks! good solution
i have a question for anyone who has a moment.
i'm trying to replace my standard toolbar with a wsh toolbar.
i managed to modify the SimpleThemedButton sample to call functions from the main menu, but i'm wondering if it's possible to do something similar with the context menu?
i want a button that will run "ReplayGain/Scan selection as albums (by tags)" on the selected items. any hints on how to accomplish this would be appreciated
also marc2003, there is a script you published here, but it doesn't work with the lastest version of wsh_panel_mod.
http://www.hydrogenaudio.org/forums/index....mp;#entry685807 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&st=150&p=685807&#entry685807)
'settings_path' is undefined
Ln: 14, Col: 1
can you help me to fix it?
thanks again!
replace lines 2&3 with
// @import "%fb2k_profile_path%marc2003\common.js"
// @import "%fb2k_profile_path%marc2003\tooltip_buttons.js"
thank you!
can you make it show the numbers of each playlist?
although it is possible to fetch the item count for a given playlist i won't implement it because it could be too misleading. let's say i modify an active autoplaylist with a different query, you wouldn't want the favourite with the old query saved to show this new item count.
similar artists and last.fm charts:
-added scrolling support so you can see the full 50 records pulled from each feed.
-mouse wheel bugfix
-new option to add favourites to beginning or end of list
-new option to do nothing or execute query when adding/editing favourites
Marco, i seem to be having problems with autoplaylist. I just installed the latest autoplaylist.txt, and all i am getting is a blank playlist.
This is how i created the playlist:
Query: %LASTFM_LOVED% IS 1
Sort: None
I am on windows xp, and i have the latest WHS panel.
if you're using my main last.fm playcount sync script, it should be %LASTFM_LOVED_DB%
also, if in any doubt, use Library>Search to verify your queries.
from what i've read, this should act on all selected items, but it's only acting on the now playing item. what's wrong?
ReplayGain: new SimpleButton(104, 0, 20, 20, "▣", function () {
fb.RunContextCommandWithMetadb('ReplayGain/Scan selection as albums (by tags)', fb.GetSelections());
Another question Marco: is there a way to change the background and font color of last.fm panels?
my name isn't marco...
colours are dictated by the main foobar config found under foobar preferences>display>YOUR UI OF CHOICE>colours and fonts.
if you really want to customise them separately then you need to find the on_paint function in each script and add these as the first lines in it...
g_backcolor = RGB(0,0,0);
g_textcolor = RGB(255,255,255);
g_textcolor_hl = RGB(255,0,0);
Sorry...i thing i saw someone refering to you as Marco? Anyway, i will make sure to refer to you as marc2003 from now on
@marc:
I modified the script you provided me with (including wikipedia and rym), and i added a discogs entry. I did my best to add the entry as accuratly as possible, and i also placed discogs.png and discogs_h.png in the "C:\Documents and Settings\*\Application Data\foobar2000\marc2003\images" directory. But i am getting this error in the console:
WSH Panel Mod (Web Links by marc2003): Parsing file "C:\Documents and Settings\*\Application Data\foobar2000\marc2003\common.js"
WSH Panel Mod (Web Links by marc2003): Parsing file "C:\Documents and Settings\*\Application Data\foobar2000\marc2003\tooltip_buttons.js"
Error: WSH Panel Mod (Web Links by marc2003): Microsoft JScript compilation error:
Expected '}'
Ln: 34, Col: 9
but6: new Button (left_margin + (bw*2),top_margin,bw,bh,(normail: images_path + "discogs.png", hover: images_path + discogs_h.png"), function () Wshell.run(discogs);), discogs)
And here is the whole script:
// ==PREPROCESSOR==
// @name "Web Links"
var bw = 20;
var bh = 20;
var top_margin = 0;
var left_margin = 0;
var panel_id = window.GetProperty("panel_id", window.id);
var custom_background_file = settings_path + panel_id + "buttons_background";
var custom_background = read(custom_background_file);
on_item_focus_change();
function on_size() {
ww = window.Width;
wh = window.Height;
if(!g_metadb) return;
var wikipedia = fb.TitleFormat("http://en.wikipedia.org/wiki/$replace(%artist%, ,_)").EvalWithMetadb(g_metadb);
var rateyourmusic = fb.TitleFormat("http://rateyourmusic.com/artist/$lower($replace(%artist%, ,_))").EvalWithMetadb(g_metadb);
var discogs = fb. Titleformat ("http://www.discogs.com/artist/$lower($replace(%artist%, ,))").EvalWithMetadb(g_metadb);
Buttons = {
but4: new Button(left_margin + (bw*0),top_margin,bw,bh, {normal: images_path + "wikipedia.png", hover: images_path + "wikipedia_h.png"}, function(){WshShell.run(wikipedia);}, wikipedia),
but5: new Button(left_margin + (bw*1),top_margin,bw,bh, {normal: images_path + "rateyourmusic.png", hover: images_path + "rateyourmusic_h.png"}, function(){WshShell.run(rateyourmusic);}, rateyourmusic)
window.Repaint();
function on_mouse_rbtn_up(x, y) {
buttons_menu(x,y);
return true;
buttons_background(gr);
buttonsDraw(gr);
you're missing a comma at the end of the line that begins "but5:"
I added the coma at the end of the "but5:" line (right after the last bracket), but now i am getting this error:
Expected ')'
Ln: 34, Col: 73
you're not using squiggly brackets around the function like the other 2 entries. open your eyes.
Fixed
<3
Is there any script available that will open up "Tagging/Discogs/Write tags" from the context menu?
I am trying to make an icon change based on what the current playback order is. For instance, if the playback order is on default, a certain icon will be showing, but if the playback order is on shuffle, a different icon will be showing.
I want to use something similar to this:
function genPPImageSrc() {
return (fb.IsPlaying && !fb.IsPaused) ? pause_image : play_image;
I just dont know what to use instead of fb.isplaying and fb.ispaused. Is there something like this for default, shuffle, or repeat?
Alternatively I have tried using function on_playback_order_changed(new_order_index) but I cant get the numbers for new_order_index to return unless the playback is actually changed. Normally this would be okay, except for when foobar is first loaded. It loads the previously selected playback order, therefore, I cannot just assume that the initial playback order will always be the same.
Do any of you have any ideas or tips?
var pbo = fb.PlaybackOrder;
will give an index between 0 and 6.
also, check out the samples from the component homepage. there are a couple of playback order related examples.
Does anyone have a solution to toggle the visibility of a 'dockable panel' (in my example that would be chronflow in DUI and a panel with foo_run links) with one button?
Atm I modified marcs 'weblinks buttons' with the following commands, but it needs ugly two buttons per panel so far...
but11: new Button(left_margin,top_margin,bw,bh, {normal: images_path + "search.png", hover: images_path + "search.png"}, function(){ fb.RunMainMenuCommand("View/Dockable Panels/Activate/1 - Chronflow"); },coverflow),
but12: new Button(left_margin + bw,top_margin,bw,bh, {normal: images_path + "edit.png", hover: images_path + "edit.png"}, function () { fb.RunMainMenuCommand("View/Dockable Panels/Activate/2 - Panel Stack Splitter"); },run),
but21: new Button(left_margin,top_margin + bh,bw,bh, {normal: images_path + "cross.png", hover: images_path + "cross.png"}, function () { fb.RunMainMenuCommand("View/Dockable Panels/Collapse/Chronflow"); },coverflowoff),
but22: new Button(left_margin + bw,top_margin + bh,bw,bh, {normal: images_path + "cross.png", hover: images_path + "cross.png"}, function() { fb.RunMainMenuCommand("View/Dockable Panels/Collapse/Panel Stack Splitter"); },runoff)
Hey guys! Long time lurker, first time poster (let me know if I'm breaking any rules or such which I don't know of)
Anyways, on to the point. I've been using Marc2003s DUI for quite some time (it was lovely ) but now I'm trying to make something for myself, and, yes, my JScripting is horrible. Nonexistant, actually. So I tried "borrowing" from others but so far I've been unable to get anything done properly. I'm not really sure if I should ask this, but I'll go ahead! I'm trying to add a toggleable panel containing lyrics. I'm also trying to add a seekbar, play/pause/next/previous buttons. Now, the buttons I'm *fairly* certian I can manage myself. *Fairly*. But as for a toggleable panel my googling has been fruitless.
I've uploaded a picture of how I'd like it, and if someone experienced could tell me if it's possible and/or help me, that would be lovely, mmkay?
(http://data.fuskbugg.se/skalman02/WATUSAY.png)
The lyrics panel should obviously extend to the menu aswell, but such minor things I can probably manage myself. I haven't yet added the panel for the bottom buttons et.c., but that I can do myself, it's the coding I can't.
Thanks for any replies whatsoever on this topic. :>
you should use panel stack splitter for toggling panels on/off. it has functions to create buttons, show/hide panels and adjust the window size.
http://foo2k.chottu.net/#pss (http://foo2k.chottu.net/#pss)
I'm working on seekbar. then I found out skipping repaint();
In on_timer() function , called window.RepaintRect() or window.Repaint(), but It didn't repaint in no burden program is running.
for checking, use code " bar.test = <value>; " in on_timer function, and reset variable " bar.test = 0;" in on_paint function.
next recursive on_timer function, check bar.test is empty with " if (bar.test) echo("error"); "
within playing a song, lots of error was printed in console.
there is other window.RepaintRect(..); code in on_playback_time function. but same results popped though make it comment.
Is this a bug? or miss something?
This is whole source code
// ==PREPROCESSOR==
// @name "j-seekbar"
// @version "0.3.3b"
// @author "jk007"
// ==/PREPROCESSOR==
var pn = "js| ",
debug = window.GetProperty("debug", 0),
dragging = 0,
cc=0, c0=0,
dragging_seek = 0,
timer, timerbar, timeout, g_now,
fz_song=12,fz_album=12, fz_info=12, fz_time=12,
last_x,
ww, wh,
bar={time:0,pos:0,interval:10},
song={posTime:0}
window.GetProperty("AutoResize",0);
window.GetProperty("SkipInst", 1);
window.MinHeight = 37;
window.MaxHeight = 185;
DT_TOP = 0x00000000;
DT_LEFT = 0x00000000;
DT_RIGHT = 0x00000002;
DT_VCENTER = 0x00000004;
DT_WORDBREAK = 0x00000010;
DT_CALCRECT = 0x00000400;
DT_NOPREFIX = 0x00000800;
ColorTypeCUI = {
text: 0,
selection_text: 1,
inactive_selection_text: 2,
background: 3,
selection_background: 4,
inactive_selection_background: 5,
active_item_frame: 6
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
(function get_colors(){
if (window.InstanceType) {
clr_txt = window.GetColorDUI(ColorTypeDUI.text);
clr_txt_hl = window.GetColorDUI(ColorTypeDUI.highlight);
clr_bckgrnd = window.GetColorDUI(ColorTypeDUI.background);
else {
clr_txt = window.GetColorCUI(ColorTypeCUI.text);
clr_txt_hl = window.GetColorCUI(ColorTypeCUI.text);
clr_bckgrnd = window.GetColorCUI(ColorTypeCUI.background);
function on_size(){
debug && echo();
ww = window.Width;
wh = window.Height;
if (window.GetProperty("AutoResize") == 1)
window.MinHeight = window.MaxHeight = Math.max(37,ww * 185/2500);
else {
fz_song = Math.floor(Math.max(12,Math.min(0.52*wh-5,0.0345*ww+2)));
fz_time = Math.floor(Math.max(12,Math.min(0.5*wh-5,0.0338*ww+2)));
fz_album = Math.floor(Math.max(11,Math.min(0.26*wh,0.0175*ww+4)));
fz_info = Math.floor(Math.max(11,Math.min(0.24*wh,0.0159*ww+4)));
compute_timeInfoWidth();
if (fb.IsPlaying) {
compute_repaintBarInterval();
if (!fb.IsPaused) timerbar = window.CreateTimerInterval(bar.interval);
function parseHMS(seconds)
var h, m, s;
seconds = Math.round(seconds);
h = Math.floor(seconds/3600);
m = Math.floor((seconds-=h*3600)/60);
s = seconds % 60;
return (h ? h+":" + (m<10 ? "0"+m : m) : m) + ":" + (s<10 ? "0"+s : s);
var timeInfo=song.length, pos, now;
if (fb.IsPlaying && fb.PlaybackLength)
now = g_now || fb.PlaybackTime;
pos = Math.round(now * bar.w);
if (now == bar.time) {
bar.test = 0;
bar.pos = pos;
} else if (pos < bar.pos) pos = bar.pos;
gr.FillGradRect(0, 0, pos, wh, 90, 0xffff1303, 0xffbe1303);
timeInfo = (fb.IsPaused ? "Paused ":"") + parseHMS(now) + " / " + song.length;
if (dragging) {
timeInfo = "< "+parseHMS(fb.PlaybackLength * dragging_seek) +" > "+ timeInfo;
gr.FillGradRect(0, 0, ww*dragging_seek, wh, 90, 0xa0f000f0, 0xb04000f0);
debug && gr.FillSolidRect(song.posTime,0,song.timeInfoWidth,wh,0x304000f0)
gr.SetTextRenderingHint(5);
gr.DrawString(timeInfo, gdi.Font("Segoe UI", fz_time, 3), clr_txt, 0, 1, ww-10, wh, 0x20000000);
gr.DrawString(song.codec, gdi.Font("Segoe UI", fz_info, 1), song.colorCodec, 0, 0, ww-10, wh-3, 0x22000000);
gr.gdiDrawText(song.album , gdi.Font("Segoe UI", fz_album, 2),clr_txt,20,0,ww-80, wh-2, DT_CALCRECT | DT_NOPREFIX|DT_BOTTOM);
gr.gdiDrawText(song.title, gdi.Font("Segoe UI", fz_song, 1), clr_txt, 7, 1, ww-17-song.timeInfoWidth*2, wh, DT_CALCRECT | DT_NOPREFIX);
function on_timer(id)
var now = fb.PlaybackTime;
var gap = now - bar.time;
0&&debug && echo("\t"+now.toFixed(5));
if (gap > 0){
if (bar.test) echo("Error Didn't repaint @ "+ bar.time);
bar.test = g_now = bar.time = now;
gap = Math.round(now*bar.w) - bar.pos;
window.RepaintRect(bar.pos, 0, gap, wh);
function on_playback_time(time)
g_now = time;
window.RepaintRect(song.posTime,0,song.timeInfoWidth,wh);
debug && echo();
if (window.GetProperty("SkipInst") == 1 && fb.TitleFormat("%title%").Eval().match(/\(inst.|\(instrument|\(MR|instrumental\)/i))
fb.Next();
get_info();
//if (fb.isPaused) return;
start_timer();
function compute_repaintBarInterval()
debug && echo(" + "+/.+\)/.exec(arguments.callee)+" ~~ "+/.+\)/.exec(arguments.callee.caller));
if (!ww || !fb.PlaybackLength) return false;
g_now = bar.time = bar.pos = 0;
bar.interval = Math.max(10,Math.round(fb.PlaybackLength*1000/ww));
bar.w = ww / fb.PlaybackLength;
debug && echo("bar.interval="+bar.interval+", ww="+ww+", PlaybackLength="+fb.PlaybackLength);
debug && echo("bar.w="+bar.w+"\t"+(bar.w*bar.interval/1000));
function start_timer()
window.Repaint();
function get_info()
song.title = fb.TitleFormat("%artist% - %title%").Eval(true);
song.length = fb.TitleFormat("%length%").Eval(true);
song.album = fb.TitleFormat("%album%[ '(' %date% ')'] [Disk %discnumber%]").Eval(true);
song.codec = fb.TitleFormat("$replace(%codec%,Monkey$char(39)s Audio,APE,PCM,WAV)[ %__codec_profile%] %__bitrate%kbps$ifequal(16,%__bitspersample%,,[ %__bitspersample%bit])$ifequal(44100,%__samplerate%,, %__samplerate%Hz)$if($strcmp(stereo,%channels%),, %channels%)").Eval(true);
song.colorCodec = (fb.TitleFormat("%__encoding%").Eval() == "lossy") ? 0xffff0000 : 0xff0000ff;
function compute_timeInfoWidth()
// Using a temp IGdiGraphics interface
// Don't forget to call temp_bmp.ReleaseGraphics(temp_gr)!
song.timeInfoWidth = temp_gr.CalcTextWidth('/ '+song.length, gdi.Font("Segoe UI", fz_time, 3));
song.posTime = ww-10-song.timeInfoWidth*2;//*2.46;
// Free the resources
temp_bmp.Dispose();
function on_item_focus_change()
debug && echo();
if (fb.IsPlaying) return true;
get_info();
window.Repaint();
function on_playback_pause(state)
debug && echo();
if (state) {
timer && window.KillTimer(timer);
timeout && window.KillTimer(timeout);
timerbar && window.killTimer(timerbar);
CollectGarbage();
window.Repaint();
else
start_timer();
function on_playback_stop()
debug && echo();
window.Repaint();
CollectGarbage();
function on_playback_seek(time)
window.Repaint();
function on_mouse_lbtn_down(x,y)
if (fb.IsPlaying && fb.PlaybackLength > 0) {
dragging = 1;
dragging_seek = x < 0 ? 0 : x > ww ? 1 : x / ww;
last_x = x;
window.Repaint();
function on_mouse_lbtn_up(x,y)
if (dragging) {
g_now = bar.time = bar.pos = dragging = 0;
fb.PlaybackTime = fb.PlaybackLength * dragging_seek;
function on_mouse_move(x,y)
if (dragging && last_x != x) {
last_x = x;
if (y < 0 || wh < y) dragging = 0;
window.Repaint();
function on_colors_changed()
get_colors();
window.Repaint();
function echo(txt)
txt = txt || " + "+/.+\)/.exec(arguments.callee.caller);
fb.trace(pn+txt);
var MF_SEPARATOR = 0x00000800;
var MF_STRING = 0x00000000;
var _menu = window.CreatePopupMenu();
var idx;
_menu.AppendMenuItem(MF_STRING, 14, "Debug mode");
_menu.AppendMenuItem(MF_SEPARATOR, 0, 0);
_menu.AppendMenuItem(MF_STRING, 1, "Auto Resize");
_menu.AppendMenuItem(MF_STRING, 4, "Skip Instrumantal");
_menu.AppendMenuItem(MF_STRING, 2, "Properties");
_menu.AppendMenuItem(MF_STRING, 3, "Configure...");
_menu.CheckMenuItem(1, window.GetProperty("AutoResize")== 0 ? 0x0 : 0x8);
_menu.CheckMenuItem(4, window.GetProperty("SkipInst")== 0 ? 0x0 : 0x8);
_menu.CheckMenuItem(14, window.GetProperty("debug")== 0 ? 0 : 1);
idx = _menu.TrackPopupMenu(x, y);
switch (idx) {
case 1:
window.SetProperty("AutoResize", !window.GetProperty("AutoResize"));
on_size();
break;
case 2:
window.ShowProperties();
break;
case 3:
break;
case 4:
window.SetProperty("SkipInst", !window.GetProperty("SkipInst"));
break;
case 14:
window.SetProperty("debug", !window.GetProperty("debug"));
debug = window.Getproperty('debug');
break;
_menu.Dispose();
return true;
(function (){
if (fb.isplaying)
on_playback_new_track();
else
Hi, i am new to jscript and i'm still reading script examples found on this forum.
I want write a string with gradient effect, but i'm not able to find nothing like this, can someone suggest me how to do it or in alternative where i can look ?
Perhaps something similar at "glow text sample" script ?
I need some big help for start with this panel.
Hey there, all!
I'm having an issue with Br3tt's "WSH Tree Explorer", version 1.7.
note: I haven't changed anything in its code.
Problem: it doesn't display all folders on my D:\ drive. As it can be seen in the image below, the folders "Music" and "Video" don't show up in the tree. There' sno problem if "Video" doesn't show, but I'd kinda need "Music". At first I thought that it simply doesn't show folders containing music files with paths already added to the Library, but I added the "Spoken" folder (which contains mp3 podcasts and audiobooks) to the Library, but that one shows just fine. Then I added only a subfolder of "Spoken", but it still works fine. Also my C:\ drive shows up correctly.
Does anyone have an idea?
Explanation image:
(http://i.imgur.com/xo1wx.png)
A few notes:
- running on Win7 32bit SP1 fully updated
- using a foobar2000 1.1.5 portable install
- path to scripts is C:\foobar2000\WSH samples
- the link to Br3tt's script (posted a few pages back): deviantART page (http://br3tt.deviantart.com/art/WSH-Tree-Explorer-1-7-196023730?q=gallery%3Abr3tt%2F3063083&qo=2)
Another question, for marc2003: what would be the line I should put in your "now playing" script to display a placeholder image for tracks w/out artwork (having the placeholder png of course).
file>preferences>display>front cover>stub image path.
edit: removed "artist" from description - it doesn't use the foobar artreader
Great, thanks a bunch!
Hey there, all!
my script doesn't show all the "kind" of folder, for example, system folder are not shown. Maybe (surely in fact!) these 2 folders have an attribut "kind" value not allowed by my script.
check function FillTreeLevel (near line #530 ...), you find this test :
if(item_fld.Attributes==16 || item_fld.Attributes==17 || item_fld.Attributes==2064)only these 3 value are allowed in my script, you can add a line above this one to display to the console the value of item_fld.Attributes for each folder browsed, to check the value of this one for Music and Videos folders, like this:
fb.trace("fld name = "+item_fld.Name+" hase an attrb value = "+item_fld.Attributes);Once script launched, open the console (menu View->Console) and check the values of the trace method, and then modify the test in the script to add more values than 16, 17 and 2064 in order to fix the issue for you. Tell me too what's the missing value, i'm curious. Thanx.
HTH
Marc another question.. what parameteres should I give to Gdi.Drawtext so it would wrap text if at all possible.
@Falstaff: I'm going to read this for a while... kudos!
Edit: nevermind; got my code-monkey room-mate to help!
replace DT_END_ELLIPSIS with DT_WORDBREAK.
@Falstaff
Thanks for telling where the problem lied. In my casse there was a problem with folder attributes: both Music and Videos were set as "Ready for archiving" and this gave them an attribute of 48. Remove that, they became 16 and all was OK.
However, we noticed a few values which were viewable by default, but shouldn't, for security reasons (with some examples):
18 - C:\Program Data
21 - C:\Windows\assembly
22 - $RECYCLE.BIN, System Volume Information
1046 - C:\Documents and Settings
2064 - C:\Windows\System32\DRVSTORE
This being the case, we just negated those values (maybe others will add more) and went with the modified lines 536->543 :
for (; !oFolders.atEnd(); oFolders.moveNext()) {
item_fld = oFolders.item();
// ajout nouveau noeud
if(item_fld.Attributes!=22&&item_fld.Attributes!=21&&item_fld.Attributes!=18&&item_fld.Attributes!=2064&&item_fld.Attributes!=1046) {
node.addchild(item_fld.Name, item_fld.Path);
if(recursive) {
FillTreeLevel(item_fld.Path, node.child[node.child.length-1], true);
Sorry, I don't know how to format this ^, but I believe you'll manage it.
In any case, if you wish to remain with a syntax for allowing parameters, include 48; I believe this is done automatically once a folder reaches >10GB (don't quote me on that)
Hope this helps!
Hey
I love the uses people are finding for this component and I have a request of someone who might be able to code. I plan on trying to learn some JavaScript this summer but You guys might be able to whip this up really quickly.
What I am looking for is a comibnation of the nowplaying.txt and the artreader.txt last.fm scripts that I do believe were written by marc2003.
Instead of displaying the artist photo, I wanted it to display the album that is in the same folder as the album and called folder.jpg. But on top of that I want the band, track, and album. It's pretty much the same except the artist photo and album are switched.
Is this possible. It would be greatly appreciated.
http://pastebin.com/CJ4BkQKi (http://pastebin.com/CJ4BkQKi)
it still requires the files in place from my download.
Holy hell! That was such a fast reply! Thanks.
Is there anyway I can have it so that the full album are will always be shown? Right now it's cutting the top and bottom off the artwork.
I guess what I am looking for is the artwork to fit the window and have black bars on the side.
(http://i.imgur.com/P3CZp.jpg)
on line 57, replace "max" with "min".
then insert this before immediately before line 57.
gr.FillSolidRect(0, 0, ww, wh, g_backcolor);
the background will then match the default from the DUI colour preferences.
You are a god among men. Thank you so much. By the way, where is that you usually post the most up to date samples.zip. Is it in this thread usually?
this thread is it's home. the link doesn't change and i usually post whenever i update it - either for fixes or something new.
Great! Those samples are pretty much my whole config.
Hi!
I have a what I hope will be a fairly small request. I'm using marc2003's last.fm scripts and they're great for everything except classical music. By and large, classical music is tagged in such a way that it's impossible for last.fm to keep track of the artists (for example, they can't have a page for each of the combinations of musicians that Jacqueline du Pre has performed chamber music with). So, instead of having the last.fm panels looking for information on the artist, would it be possible to have the scripts look at the last.fm page for the composer when the genre is "Classical"? Specifically, I make use of the "Now Playing", "Simple Biography" and "Similar Artists" panels, but I assume the code would be transferrable between them.
A second (but much less important) question I have is, how would I create something like a 32x32 pixel box that numerically shows what the volume level is? I rely entirely on hotkeys to change my volume, so I removed the volume slidebar, but it would be nice to have an indication of the volume somewhere. If there's an existing volume slidebar similar to the "Aero Seekbar" I wouldn't mind using that either, but I haven't been able to find one yet.
Any help or advice on how to do this would be awesome
i'll add an option for last.fm artist field remapping in the next few days.
as for a volume indicator, just right click your status bar and enable it.
Thanks, that sounds great Just one thing, I would prefer to have it look at composer only if the genre is classical. For everything else artist is still best. Sorry if this is extra effort.
i'll make it so you can configure it yourself with standard foobar title formatting (http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Title_Formatting_Reference). %artist% would be the default but you could use something like this....
$if($stricmp(%genre%,classical),%composer%,%artist%)
Perfect! It took me about three hours yesterday to get a short 'if' script to work using the standard foobar title formatting, but after spending that much time working on the script I feel quite comfortable using standard foobar formatting now
i've updated the "simple biography" script with artist field remapping. the option is on the context menu. i'm too lazy to do the other scripts just yet.
for existing users, the files from the zip must be extracted again overwriting all as one has changed.
Thanks for the update It works great so far. Sorry if it's a lot of effort (I saw the file size for simple biography increased quite a bit), I thought it would be one or two lines of code... Much appreciated!
Marc,
it is not possible for me to set api_key and username true the context menu it won't open, i mean it will open the menu but if i click (set your lastfm username) same for (api_key) nothing happens.
So in the console the error pops up WSH Simple Biography: Can't contact Last.fm. Check your username / API KEY settings.
I hope you can help me.,
when you select that option from the menu, it calls an external script with a .wsf file extension. possible reasons it's not working
-file type associations have been messed with
-machine is locked down and scripts aren't allowed to run
-you're not running windows
workaround: browse to %appdata%\foobar2000\wsh_settings and create 2 files named
username
api_key
make sure they have no file extensions at all and then edit each one in notepad and save the relevant details in each one. the script will need reloading to pick up the new details.
username
api_key
Thx it is solved.
As you suggested it was the file association that was't correct.
Hello, I have a question. I'm using many of your samples, for which I wanna say my thanks. But I'm having issue with the aero seekbar. I want to change the colour of the timer, but the only variable I can link to the timer is this:
var g_font = gdi.Font("Segoe UI", 12, 0);
which only chooses the font. How can I change the font colour?
line 44:
gr.GdiDrawtext(txt, g_font, RGB(0,0,0), 0, 0, ww-10, wh, DT_VCENTER | DT_RIGHT | DT_CALCRECT | DT_NOPREFIX);
you can change the colour in the RGB function.
line 44:
Oh, FFS I've literally slept through that line. Thanks, that was a dumb question.
Ok, I've got another dumb question. I'm using your simple buttons for playback. I've also configured one to be a preferences button, but I've got a question. Is there a way to make another button which when pressed the file menu would open? Here's my code for the preferences button, I guess it'd be something similar, I just don't know the exact function.
but6: new Button((bw*17) + left_margin,top_margin,bw,bh, {normal: images_path + "pref.png", hover: images_path + "pref_h.png"}, function(){fb.ShowPreferences();}, "Preferences")
have a look at the samples from the component homepage. inside is an example of how to have the full menu pop out from a mouse click.
Marc, your Now Playing script doesn't appear to be downloading artist art... I've let it go while two songs were playing for an artist, and nothing ever changed from the default background.
seems to be working ok here. perhaps a temporary glitch at the last.fm end? and have you checked art definitely exists for the artist by visiting the page?
as for your PM request, i've updated the "now playing" script so you can turn off the front cover display via the context menu,
Thanks! Maybe I broke something when tinkering with your script, I'll try the update.
Hmmm.... still not working after playing 4 songs for the same artist. My settings are:
Last.fm Options: Automatically Download (check)
Limit: 20
Blacklist Deleted Images (check)
Cycle: 20 seconds
Font Cover Display: Off
I have edited things in the script (from lines 7-16), but I don't think it should make a difference:
// ==PREPROCESSOR==
// @name "Now Playing"
// @author "marc2003"
var stopped_text = "foobar2000";
var title_tf = fb.TitleFormat("[%discnumber%.]%tracknumber%'/'[%discnumber%.]%totaltracks% - %title%");
var album_tf = fb.TitleFormat("[%artist%]");
var artist_tf = fb.TitleFormat("$ifequal([%LASTFM_LOVED%],1,♥,)");
var title_font = gdi.Font("Segoe UI", 28, 1);
var album_font = gdi.Font("Segoe UI", 22, 1);
var artist_font = gdi.Font("Segoe UI", 22, 1);
var title_colour = RGB(40,179,255);
var album_colour = RGB(210, 210, 210);
var artist_colour = RGB(255,0,0);
var blacklist_file = '';
var title = '';
var artist = '';
var album = '';
var foobar_img = gdi.Image(images_path + "new foo.png");
var album_img = null;
var artist_img = null;
var arr = new Array();
var g_valid_tid = 0;
window.GetProperty("bl", true);
window.GetProperty("auto", true);
var cycle = window.GetProperty("cycle", 200) - 200;
var limit = window.GetProperty("limit", 305) - 300;
var album_img_size = window.GetProperty("album_img_size", 510) - 400;
if(fb.IsPlaying) on_playback_new_track();
function on_playback_time(time) {
if(cycle > 0 && arr.length > 1 && (time % cycle == 0)) on_mouse_wheel(-1);
function on_playback_stop(reason) {
album_img && album_img.Dispose();
artist_img && artist_img.Dispose();
g_metadb = album_img = artist_img = arr = null;
if(reason != 2) window.Repaint();
g_metadb = fb.GetNowPlaying();
artist = artist_tf.EvalWithMetadb(g_metadb);
title = title_tf.EvalWithMetadb(g_metadb);
album = album_tf.EvalWithMetadb(g_metadb);
album_img = utils.GetAlbumArtEmbedded(g_metadb.rawpath, 0);
if(!album_img) utils.GetAlbumArtAsync(window.ID, g_metadb, 0);
folder = data_folder + fb.TitleFormat("$crc32(%artist%)").EvalWithMetadb(g_metadb);
bl();
arr = read_images();
if(arr.length == 0 && window.GetProperty("auto")) {
download_images();
} else {
index = Math.floor(Math.random()*arr.length);
load_image();
function on_mouse_wheel(delta) {
if(!g_metadb || arr.length < 2) return;
index += -delta;
if(index < 0) index = arr.length - 1;
if(index >= arr.length) index = 0;
load_image();
function load_image() {
artist_image_path = arr[index];
g_valid_tid = gdi.LoadImageAsync(window.ID, artist_image_path);
function on_load_image_done(tid, image) {
if (g_valid_tid == tid) {
artist_img = image;
window.Repaint();
function on_mouse_lbtn_dblclk() {
try {WshShell.Run("\"" + artist_image_path + "\""); } catch(e) {}
function on_get_album_art_done(metadb, art_id, im, ip) {
album_img = im;
window.Repaint();
ww = window.width;
wh = window.height;
gr.SetInterpolationMode(6);
if(artist_img) {
scale(gr, artist_img, 0, 0, ww, wh, "max");
} else {
gr.FillGradRect(0, 0, ww, wh, 90,g_backcolor, g_textcolor_hl);
gr.FillSolidRect(0,wh-130,ww,110,RGBA(0,0,0,156));
if(album_img && album_img_size > 0) {
text_x = album_img_size + 10;
scale(gr, album_img, 0, wh-20-album_img_size, album_img_size, album_img_size, "min");
} else {
text_x = 10;
if(fb.IsPlaying) {
gr.GdiDrawText(title, title_font, title_colour, text_x, wh -127, ww-text_x-10, wh,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(album, album_font, album_colour, text_x, wh - 80, ww-text_x-10, wh,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(artist, artist_font, artist_colour, text_x, wh - 55, ww-text_x-10, wh,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
} else {
scale(gr, foobar_img, 0, 0, ww, wh - 130, "min");
gr.GdiDrawText(stopped_text, title_font, title_colour, 0, wh - 130, ww, 110,DT_CENTER | DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
var _album = window.CreatePopupMenu();
var _cycle = window.CreatePopupMenu();
var _lastfm_options = window.CreatePopupMenu();
var _limit = window.CreatePopupMenu();
var idx;
_menu.AppendMenuItem(g_metadb ? MF_STRING : MF_GRAYED, 11, "Download artist art from Last.fm");
_lastfm_options.AppendMenuItem(MF_STRING, 1000, "Automatically download");
_lastfm_options.CheckMenuItem(1000, window.GetProperty("auto"));
_limit.AppendMenuItem(MF_STRING, 301, "1");
_limit.AppendMenuItem(MF_STRING, 303, "3");
_limit.AppendMenuItem(MF_STRING, 305, "5");
_limit.AppendMenuItem(MF_STRING, 310, "10");
_limit.AppendMenuItem(MF_STRING, 320, "20");
_limit.CheckMenuRadioItem(301, 320, window.GetProperty("limit"));
_lastfm_options.AppendMenuItem(MF_STRING | MF_POPUP, _limit.ID, "Limit");
_lastfm_options.AppendMenuItem(MF_SEPARATOR, 0, 0);
_lastfm_options.AppendMenuItem(MF_STRING, 1001, "Blacklist deleted images");
_lastfm_options.CheckMenuItem(1001, window.GetProperty("bl"));
_lastfm_options.AppendMenuItem(fso.FileExists(blacklist_file) ? MF_STRING : MF_GRAYED, 1002, "Clear blacklist for this artist");
_lastfm_options.AppendMenuItem(MF_STRING, 1003, "Explain blacklisting");
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _lastfm_options.ID, "Last.fm options");
_cycle.AppendMenuItem(MF_STRING, 200, "Off");
_cycle.AppendMenuItem(MF_STRING, 205, "5 seconds");
_cycle.AppendMenuItem(MF_STRING, 210, "10 seconds");
_cycle.AppendMenuItem(MF_STRING, 220, "20 seconds");
_cycle.CheckMenuRadioItem(200, 220, window.GetProperty("cycle"));
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _cycle.ID, "Cycle");
_album.AppendMenuItem(MF_STRING, 400, "Off");
_album.AppendMenuItem(MF_STRING, 510, "Small");
_album.AppendMenuItem(MF_STRING, 620, "Large");
_album.CheckMenuRadioItem(400, 620, window.GetProperty("album_img_size"));
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _album.ID, "Front cover display");
_menu.AppendMenuItem(artist_img ? MF_STRING : MF_GRAYED, 12, "Open containing folder");
if(artist_img) _menu.AppendMenuItem(MF_STRING, 15, "Delete this image");
if(utils.IsKeyPressed(0x10)) _menu.AppendMenuItem(MF_STRING, 99, "Properties");
_menu.AppendMenuItem(MF_STRING, 100, "Configure...");
switch(idx) {
case 200:
case 205:
case 210:
case 220:
window.SetProperty("cycle", idx);
cycle = idx - 200;
break;
case 301:
case 303:
case 305:
case 310:
case 320:
window.SetProperty("limit", idx);
limit = idx - 300;
break;
case 400:
case 510:
case 620:
window.SetProperty("album_img_size", idx);
album_img_size = idx - 400;
window.Repaint();
break;
case 11:
download_images();
break;
case 12:
WshShell.Run("explorer /select," + artist_image_path);
break;
case 15:
try {
if(window.GetProperty("bl") == true) {
ts = fso.OpenTextFile(blacklist_file, 2, true, -1);
ts.WriteLine(blacklist + arr[index] + "|");
ts.close();
artist_img = null;
fso.DeleteFile(arr[index]);
} catch(e) {
fb.trace("Error: Could not delete " + arr[index]);
break;
case 99:
break;
case 100:
break;
case 1000:
window.SetProperty("auto", !window.GetProperty("auto"));
break;
case 1001:
window.SetProperty("bl", !window.GetProperty("bl"));
break;
case 1002:
try { fso.DeleteFile(blacklist_file); } catch(e) {}
break;
case 1003:
fb.ShowPopupMessage("When you delete an image, there is no way for this script to prevent it being downloaded again. As a workaround, you can \"blacklist\" images you don't want and they will be deleted after downloading is complete.", "Now Playing");
break;
_lastfm_options.Dispose();
_menu.Dispose();
_cycle.Dispose();
_limit.Dispose();
_album.Dispose();
return true;
After finally realizing the power and usability of this component thanks to marc2003's samples I decided to start with a small customizable Now Playing script to get my feet wet.
The script is available here : http://dl.dropbox.com/u/3317443/wsh_now_playing_scroll.txt (http://dl.dropbox.com/u/3317443/wsh_now_playing_scroll.txt)
Sample usage (the panel marked out in red):
Also, I'm having trouble displaying dynamic bitrate. Any suggestions? I've tried reloading g_metadb through the on_playback_dynamic)info callback to no avail.
@Fractal_Mortality
ah you can't edit "artist_tf" like that. what it displays is also used to query last.fm
edit: i've updated it so the display is completely independent of what is sent to last.fm. you can now change those fields as you like.
@Fractal_Mortality
You are the man. I'll try this when I get home.
function on_playback_dynamic_info() {
bitrate = fb.TitleFormat("%bitrate% kbps").Eval();
window.Repaint();
Thanks ^.^
I'm modifying your last.fm charts sample now for use with artist top tracks and albums, excellent sample. More and more I find my config being overtaken by wsh panels.
marc2003, I've been looking at the Last.fm webservices and I'm interested in creating a script that downloads the album art as denoted by the 'image size="large"' tag in the album.getInfo method. I was assuming your artist art downloader script performs a similar service and your art.exe could be used to download the album art as well, but I can see that its use is limited to artist art. Can you direct me to the tools I would need to create the album art downloader script (or perhaps merely to a similar already existing script)?
I guess if there's no other feasible option I could simply provide the url for the album art in the panel.
it is actually possible to download images directly using WSH panel mod.
http://www.hydrogenaudio.org/forums/index....mp;#entry680952 (http://www.hydrogenaudio.org/forums/index.php?showtopic=70363&st=600&p=680952&hl=download&#entry680952)
but as i was already happily using art.exe, i saw no reason to change. after all, it's only a few kb in size.
i didn't make the art.exe program. that was made by another forum member, paradog (http://www.hydrogenaudio.org/forums/index.php?showuser=53710).
http://www.hydrogenaudio.org/forums/index....c=77425&hl= (http://www.hydrogenaudio.org/forums/index.php?showtopic=77425&hl=)
thanks to him for providing the source code - i had to modify it slightly so it runs silently without any user intervention. and that's why i've bundled my changed source code with the .exe - i'm hopefully complying with the terms of the original license.
it's made in c# and can be modified/compiled using visual studio c# express edition. it's free but a fairly hefty download and it does install a fair amount of crap.
Thanks again! That piece of code works beautifully. The only problem is that the script locks up foobar while it downloads the file, a minor price to pay but is there a way to avoid this? Or possibly I'm doing something wrong?
The script: http://dl.dropbox.com/u/3317443/wsh_now_pl..._lastfm_art.txt (http://dl.dropbox.com/u/3317443/wsh_now_playing_lastfm_art.txt)
if you read that post again, the person who orginally made that snippet has the same issue. i wouldn't know if there is any way around it.
but it should be fairly trivial to modify the art.exe program. i'll have a look later on.
Oh... well, if you can make that modification to art.exe it would awesome. Otherwise, the way I have it setup right now I've bound the download to a click action so I can at least decide when to download the art and be ready for the freeze. Again, a very minor price to pay.
it took more effort than i expected. also, i don't know proper programming so it's a real hack job. it works though...
it takes 4 arguments
<artist> <album> <path> <filename with no extension>
eg
album.exe "Bat For Lashes" "Fur And Gold" "c:\music\bat for lashes\fur and gold" "folder"
it would then save as folder.jpg or folder.png depending on what it finds.
http://cid-649d3bfeaf541fbb.office.live.co...guide/album.zip (http://cid-649d3bfeaf541fbb.office.live.com/self.aspx/.Public/foobar/guide/album.zip)
Thanks a lot. That does the job perfectly I'm still keeping the last.fm webservices code I was using earlier as an option so I can download the mega version of some art if I want to, also my earlier script gives me an indication as to whether album.exe will find anything at last.fm or not.
it already downloads the "mega" image. with the few albums i tested, they aren't very big anyway.
Hah I was just about to edit my post to indicate that I meant large (300x300) and not mega I try and avoid the really huge album arts because they make my np script cpu heavy when repainting the panel with huge images.
Also, is there a way to export embedded album art via this panel? Like open it in an image object and write it to a file. I was looking through activexobjects, but couldn't find a solution.
i should be able to make it accept the size as an another argument on the commandline.
That would be great. Hope it's not too much trouble.
done. same link as above. now takes 5 arguments with size being the last one.
Nice. I peeked into the fetchArt.cs too, looks good
I have a small Request, I would like a script that shows recently played from Last.FM and if possible
a link to the last.FM page of the song.
If this is possible would you mind writing the script ?
Thanks in advance.
How can I make an image appear for a second? I have a panel that displays album art and now playing details and I have some basic gesture controls togo to next track, previous track, volume up, and volume down and I want an image to appear when one of these gestures is completed.
Here's my current (sloppy) code:
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
function RGBA(r, g, b, a) {return ((a << 24) | (r << 16) | (g << 8) | (b));}
var artist = fb.TitleFormat("$abbr(%artist%,19)");
var title = fb.TitleFormat("$abbr(%title%,19)");
var album = fb.TitleFormat("$abbr(%album%,19)");
var codec = fb.TitleFormat("%codec% $if($strcmp(%codec%,'MP3'),%codec_profile%)");
var bitrate = fb.TitleFormat("%bitrate%");
var playcount = fb.TitleFormat("%play_count%");
var ww=window.Width;
var wh=window.Height;
var col = RGB(255, 255, 255);
var col1 = RGB(255,0,0);
var col2 = RGB(255,128,0);
var col3 = RGB(255,255,0);
var col4 = RGB(0,255,0);
var hoffset = 4;
var paused;
var btndwn;
var x1;
var y1;
function on_item_played(metadb) {window.Repaint();}
function on_playback_edited(metadb) {window.Repaint();}
function get_album_art(metadb) {
if (metadb)
return utils.GetAlbumArt(metadb.RawPath, 0);
function on_mouse_lbtn_down(x, y, mask){
btndwn = true;
x1 = x;
y1 = y;
function on_mouse_lbtn_up(x, y, mask){
if (btndwn){
var tlrnce = 10;
btndwn = false;
if ( (x>x1 + tlrnce) && (y < y1 + tlrnce) && (y > y1 - tlrnce) ){
fb.Next();
if ( (x<x1 - tlrnce) && (y < y1 + tlrnce) && (y > y1 - tlrnce) ){
fb.Prev();
if ( (y<y1-tlrnce) && (x < x1 + tlrnce) && (x > x1 - tlrnce) ){
fb.VolumeUp();
fb.VolumeUp();
if ( (y>y1+tlrnce) && (x < x1 + tlrnce) && (x > x1 - tlrnce) ){
fb.VolumeDown();
fb.VolumeDown();
window.Repaint();
var g_img = null;
on_playback_new_track(fb.GetNowPlaying());
gr.FillSolidRect(0,0,ww,wh,RGB(96,96,96));
var font = gdi.Font("Verdana", 15, 1);
var spacing = 15;
var voffset = 4;
var img_size;
if(wh-spacing*6+10>ww){
img_size=ww;
}else{
img_size=wh-spacing*6+10;
if (g_img) {
gr.SetInterpolationMode(7); // Highest quality and also slowest
gr.DrawImage(g_img, 0, spacing*6+10, img_size, img_size, 0, 0, g_img.Width, g_img.Height);
if (paused){gr.DrawImage(gdi.image( fb.FoobarPath+"Images\\pause.png"), 0, spacing*6+10, img_size, img_size, 0, 0, 500, 500,0,255);}
if (fb.IsPlaying){
gr.GdiDrawText(artist.Eval()+"&", font, col, hoffset, voffset, ww, wh);
gr.GdiDrawText(title.Eval(), font, col, hoffset, voffset+spacing, ww, wh);
gr.GdiDrawText(album.Eval(), font, col, hoffset, voffset+2*spacing, ww, wh);
gr.GdiDrawText(codec.Eval(), font, col, hoffset, voffset+3*spacing, ww, wh);
if(bitrate.Eval()<=128){
gr.GdiDrawText(bitrate.Eval(), font, col1, hoffset, voffset+4*spacing, ww, wh);
}else{
if(bitrate.Eval()<=192){
gr.GdiDrawText(bitrate.Eval()+" kbps", font, col2, hoffset, voffset+4*spacing, ww, wh);
}else{
if(bitrate.Eval()<320){
gr.GdiDrawText(bitrate.Eval()+" kbps", font, col3, hoffset, voffset+4*spacing, ww, wh);
}else{
gr.GdiDrawText(bitrate.Eval()+" kbps", font, col4, hoffset, voffset+4*spacing, ww, wh);
if(playcount.Eval()==0){
gr.GdiDrawText("Never played", font, col, hoffset, voffset+5*spacing, ww, wh);
}else{
if(playcount.Eval()==1){
gr.GdiDrawText("Played once", font, col, hoffset, voffset+5*spacing, ww, wh);
}else{
if(playcount.Eval()==2){
gr.GdiDrawText("Played twice", font, col, hoffset, voffset+5*spacing, ww, wh);
}else{
gr.GdiDrawText("Played "+playcount.Eval()+" times", font, col, hoffset, voffset+5*spacing, ww, wh);
}else{
gr.DrawImage(gdi.image( fb.FoobarPath+"Images\\foobar.png"), 0, spacing*6+10, img_size, img_size, 0, 0, 500, 500);
function on_mouse_lbtn_dblclk(x, y, mask){
if (y>100)
fb.Pause();
function on_playback_pause(state){
paused=state;
window.Repaint();
function on_playback_time(time){
window.Repaint();
ww = window.Width;
wh = window.Height;
function on_playback_new_track(metadb) {
if (!metadb) return;
paused=false;
g_img = get_album_art(metadb);
window.Repaint();
function on_playback_stop(reason){
g_img=gdi.image( fb.FoobarPath+"Images\\foobar.png");
paused=false;
window.Repaint();
Also great thread I've learned a lot by looking at your codes so thanks a lot to everyone that posted here! And I apologize if anyone already answered this question I searched around for a bit but I didn't find an explanation on how to do it.
I updated my scripts recently using the latest samples.zip on you Windows Live space. I am getting some odd results with the last.fm simple biography script.
Some artists the biography appears fine and all text is visible and I am able to scroll up and down. Other artists only 2 or 3 lines appear followed by ... although there is plenty of space in the window for the remaining text. If I make the WSH panel wider then some of the text appears.
(http://img805.imageshack.us/img805/1345/bio1.png)
(http://img683.imageshack.us/img683/5226/bio2i.png)
(http://img585.imageshack.us/img585/7701/bio3.png)
Is there a sample on how to create something which you can drag? i.e. images or text.
@djphatic... and you haven't modified the script at all? i find it hard to believe that would happen with my original.
)[/size]
also, right click the panel and hit update. that will force it to download the page from last.fm again (but i really don't think that could be an issue either????? )
samples updated: http://cid-649d3bfeaf541fbb.office.live.co...ide/samples.zip (http://cid-649d3bfeaf541fbb.office.live.com/self.aspx/.Public/foobar/guide/samples.zip)
cd jewel case: added context menu option to toggle shadow/gloss effects on or off.
Hi to all.
How can I open DSP component from external button instead from main menu.The following comand doesn't work for DSP only for the Equalizer :
var imgPath = configPath + "Buttons\\Control\\";
Buttons.a = new Button(0, 22, 60, 14, {normal: imgPath + "AddOnAlone.png", hover: imgPath + "AddOnAloneMH.png"}, function(){fb.RunMainMenuCommand("View/Equalizer");});
Buttons.b = new Button(83, 22, 58, 14, {normal: imgPath + "AddOnLeft.png", hover: imgPath + "AddOnLeftMH.png"}, function(){fb.RunMainMenuCommand("View/DSP/Crossfader");});
No, haven't modified the script at all - exactly the same from the zip. I tried the force update but it didn't make any difference.
well sorry but i can't reproduce that at all. i know the width of the panel isn't the problem because the last.fm logo is drawn in the right place. very odd!
if you were using an older version of my scripts, did you overwrite the "marc2003" folder with files from the latest zip?
Yep, just done it again to make sure. I'll try a clean install of foobar later and let you know how I get on. It is odd how the script works fine for some artists and not others.
Hi to all.
what component are you using to see a "DSP" submenu on the "view" menu? because i don't see one, even when holding down shift?
EDIT: updated my samples as well.
now playing: fixed error when using foo_skip
Hi to all.
I use foo_vst_0903
if you look at file>preferences>keyboard shortcuts, under View>DSP, you'll see each option is
DSP #1 config
DSP #2 config
etc
if you use these in WSH panel mod, it works.
Clean install with latest versions of everything the script appears to be working fine in DUI and CUI.
DSP #1 config
DSP #2 config
etc
Thanks WORK!
Hi marc2003, first of all thanks for your amazing scripts. They really revolutionized my Foobar2k use. I have one question/request: I am using the thumbs2 script to show artist pictures. Would it be possible to combine both Last.fm + Custom folder at the same time? I have some unique artist pictures, but would like to see them at the same time as Last.fm pictures without the need to switch manually. Thanks a lot, Pintu.
For some reason marc2003 lastfm WSH script is producing some weird behavior in my config, does anyone know what's happening?
(http://i.imgur.com/v7eAK.jpg)
(http://i.imgur.com/OMg6Q.jpg)
(http://i.imgur.com/ybfEB.jpg)
(first screenshot if before adding the script)
I noticed that if I modify the size on this line, the size of that white box gets bigger or smaller, but I just don't know which values to use:
function on_size(){
window.MaxHeight = window.GetProperty("mini") == 0 ? 350 : 20;
that last.fm script is nothing to do with me. stuff like window.MaxHeight should only be used in default UI. as you've found out, it causes strange effects in columns UI. you could just try removing the line altogether. but for anymore help, go and ask who made it.
Same problem here..
(http://imgur.com/TNBK3.jpg)
Tried replacing all your code with a newer version.
Let me know if there's anything I can help with.
Amazing work by the way,
Thank you very much.
Roded
you guys have some strange setups.
My 2 cents are that there's something fishy about this line..
textheight = gr.MeasureString(g_text, g_font, 6, 0, ww-16, 9999999999).Height;
Doesn't seem to return the height of the entire string.
Setting textheight to a random large number fixes the issue although adds a lot of blank space at the bottom.
So I'm not sure it's the foobar setup which is causing this..
Roded
well the only variable there that can differ between setups is the font. it uses whatever is set in the default UI/columns UI main font preferences???
Tried playing with the font, didn't change much.
Another wild guess I can make is that there's a mixup somehow in the interface between the PageUnit/PageScale units being read with MeasureString and those being used to draw the rect.
But that's really just an uneducated guess.
The MeasureString call returns a height of 95.765625 for a 1044 character string using the Segoe UI font (9pt) with "ww" equaling 303.
It returns the chars member to be 151 and lines to 6.
Roded
Hey again Marc,
Firstly big thanks for providing all the examples. They're really helpful!
I am using the code you provided for the DUI buttons script, and it works just fine. I have two buttons which when clicked, will set track skip on or off in my custom database, which in turn I have a playlist column which displays a ♪ when a track is to be played and displays nothing when it to be skipped.
Is it possible to set to set up the panel so that when either of the buttons are pressed, it will update the tracks which I have selected instead of just the one that is currently playing? As if I was doing it through the legacy commands in the context menu?
nevermind, I've just realized I don't need what I asked for.
Why this is coming out:
Scripting Engine Initialization Failed (GUID: E4CCA7C1-561B-44DA-B13C-FA76F815948D, CODE: 0x80020101)
Check the console for more detailed information (Always caused by unexcepted script error).
if only there was some way of viewing more detailed information about the error.
Hey Marc! It's your favorite user back with an annoying question.
On your auto-playlist script, is there a title formatting I could use to limit a playlist in size? Ie if I wanted to generate a playlist that was no larger than 2000 songs?
not possible. all it does is support the standard query syntax that you use in the normal "Library>Search".
http://wiki.hydrogenaudio.org/index.php?ti...00:Query_syntax (http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Query_syntax)
i believe foo_random_pools is the only component that supports limiting of any kind.
Gotcha. Well, come to think of it, I can probably rig something up in random pools that will do what I want.
Hey marc2003,
I use your artist images script, and for some reason art.exe has stopped finding art on last.fm
Is it just me?
still working here. can you give an example of an artist? i assume you've checked the last.fm webpage to see that images do exist for a given artist?
Works for me also.
Yes, there are pictures on last.fm
An artist that isn't working is Elsiane.
http://www.last.fm/music/Elsiane (http://www.last.fm/music/Elsiane)
i've never heard of Elsiane so i tagged a dummy file just to make sure it works from within foobar. it does....
(http://dl.dropbox.com/u/22801321/elsiane2.png)
you can try running "art" from the command prompt to see if it gives any feedback.
(http://dl.dropbox.com/u/22801321/elsiane.png)
Hrmm...
(http://lulzimg.com/i23/33903c.png)
Elsine or Elsiane?
the typo doesn't matter. i don't see the "request was aborted" error message like that. i guess it's some networking issues between garbanzo.bean and last.fm. are other last.fm services (like scrobbling) working OK? (not the website -that's completely unrelated)
edit: although i'm absolutely certain my modification can't have broken the app (i only commented out a few lines that request a user to press a key), you could try the original version from here...
http://www.hydrogenaudio.org/forums/index....aded&start= (http://www.hydrogenaudio.org/forums/index.php?showtopic=77425&pid=684105&mode=threaded&start=)
and report your problem there if you're still not having any joy.
another edit:
you could try this in a new panel with your own api key. it might help troubleshoot?
// ==PREPROCESSOR==
var username = "blah";
var api_key = "1234......";
lastfm("&method=artist.getimages&artist=Elisane" , "foo_wsh_lastfm_bio", function() {fb.ShowPopupMessage(xmlhttp.responsetext);});
you should get a popup window like this when you click ok.
(http://dl.dropbox.com/u/22801321/elsiane3.png)
thanks for your continued help with this!
other services (scrobbling, pulling charts and similar artists through wsh) are working fine.
turning off my software firewall doesn't change anything.
here is what pops up with that new code using my API:
<?xml version="1.0" encoding="utf-8"?>
<lfm status="ok">
<images artist="Elisane" page="1" perPage="50" totalPages="1" total="1">
<image>
<title>417ms6ndI4L._SL500_AA240_</title>
<url>http://www.last.fm/music/+noredirect/Elisane/+images/27839077</url>
<dateadded>Sat, 2 May 2009 22:13:13</dateadded>
<format>jpg</format>
<owner type="user">
<name>trulla-penny</name>
<url>http://www.last.fm/user/trulla-penny</url>
</owner>
<sizes>
<size name="original" width="240" height="240">http://userserve-ak.last.fm/serve/_/27839077/Elisane+417ms6ndI4L_SL500_AA240_.jpg</size>
<size name="large" width="126" height="126">http://userserve-ak.last.fm/serve/126/27839077.jpg</size>
<size name="largesquare" width="126" height="126">http://userserve-ak.last.fm/serve/126s/27839077.jpg</size>
<size name="medium" width="64" height="64">http://userserve-ak.last.fm/serve/64/27839077.jpg</size>
<size name="small" width="34" height="34">http://userserve-ak.last.fm/serve/34/27839077.jpg</size>
<size name="extralarge" width="252" height="252">http://userserve-ak.last.fm/serve/252/27839077.jpg</size>
</sizes>
<votes>
<thumbsup>0</thumbsup>
<thumbsdown>0</thumbsdown>
</votes>
</image>
</images></lfm>
Is there a list or a guide for coding in the WSH Panel Mod?
I have seen that there are functions like fb.xxxxx
What are all these functions?
docs\interfaces.txt in the main component download.
thank you for the answer
Hi... I just set up a WSH panel for the 1st time to see if I could get it to query Wikipedia. I found Bryter's code from an earlier post (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=746784) that addressed this, and tried to fix the comma and squiggly bracket errors marc2003 pointed out. But I keep getting errors that FB2K's console keeps pointing to around the Line 34 Column 184 and Line 35 Column 5 locations.
I'm not a programmer. Notepad++ has been useful to find beginning and end points of some aspects of the code. I made copies of icon files included in the \images folder, and renamed them to match the filenames for the buttons in Bryter's script. But I just haven't been able to find the problem here. Could someone look over what I've got at this point?:
// ==PREPROCESSOR==
var bw = 20;
var bh = 20;
var top_margin = 0;
ww = window.Width;
wh = window.Height;
Buttons = {
but5: new Button(left_margin + (bw*1),top_margin,bw,bh, {normal: images_path + "rateyourmusic.png", hover: images_path + "rateyourmusic_h.png"}, function(){WshShell.run(rateyourmusic);}, rateyourmusic),
but6: new Button (left_margin + (bw*2),top_margin,bw,bh,{normail: images_path + "discogs.png", hover: images_path + discogs_h.png"}, function(){Wshell.run(discogs);}, discogs)
window.Repaint();
buttons_menu(x,y);
return true;
function on_paint(gr) {
buttonsDraw(gr);
Many thanks
TS
it says what line the error is on. if you can't see it, there isn't much hope. the colour coding used by the editor should help.
also Bryter introduced some strange code....
did people not learn in school that multiplying a number by 0 is 0.
there's not much point in multiplying by 1 either.
Any thoughts on my art.exe problem, marc2003?
... the colour coding used by the editor should help.
Yes, that is very helpful. I tried going back to square 1, and instead of using all of Bryter's code, I just copied his lines for the Wikipedia variable and button into the code in your "web links.txt" file:
var myspace = fb.TitleFormat("http://www.myspace.com/$replace(%artist%, ,)").EvalWithMetadb(g_metadb);
var lastfm = fb.TitleFormat("http://www.last.fm/music/$replace(%artist%, ,+,/,'%'252F,?,'%'3F)/_/$replace(%title%, ,+,/,'%'252F,?,'%'3F)").EvalWithMetadb(g_metadb);
var youtube = fb.TitleFormat("http://www.youtube.com/results?search_query=$replace(%artist%+%title%, ,+,'(',,')',,/,+,&,and)").EvalWithMetadb(g_metadb);
Buttons = {
but1: new Button(left_margin,top_margin,bw,bh, {normal: images_path + "myspace.png", hover: images_path + "myspace_h.png"}, function(){WshShell.run(myspace);}, myspace),
but2: new Button(left_margin + bw,top_margin,bw,bh, {normal: images_path + "lastfm.png", hover: images_path + "lastfm_h.png"}, function(){WshShell.run(lastfm);}, lastfm),
but3: new Button(left_margin + (bw*2),top_margin,bw,bh, {normal: images_path + "youtube.png", hover: images_path + "youtube_h.png"}, function(){WshShell.run(youtube);}, youtube),
FB2K didn't report any problems with the code after applying the changes, but there were still only 3 icons in the WSH panel. For some reason the 1st icon on the left edge had changed from the myspace icon to the lastfm icon that I had copied and named wikipedia.png. But the URL it was pointing to was still: www.myspace.com .. and the shading of the normal and highlighted wikipedia(lastfm) icons was very odd... not the shade of red they are supposed to be for some reason.
Then I tried changing the "strange code" Bryter had written for the Wikipedia button you pointed out: new Button(left_margin + (bw*0),top_margin,bw,bh,
And instead, used what you had for the lastfm button: new Button(left_margin + bw,top_margin,bw,bh,
Resulting in:
Buttons = {
but4: new Button(left_margin + bw,top_margin,bw,bh, {normal: images_path + "wikipedia.png", hover: images_path + "wikipedia_h.png"}, function(){WshShell.run(wikipedia);}, wikipedia)
Applying that code also got no complaints from FB2K. All 3 of the original buttons appeared correctly, but no new button for Wikipedia was displayed.
Not a big deal... I've been copying and pasting artist names and titles into the Wikipedia search engine in a web browser for ages now. Just thought this might be a handy shortcut.
TS
I think it should be (bw*3)
when i said this, i was referring to the console message you posted....
that's one line of code you had to double check.
Yes! That did the trick. FB2K always seems to be very picky about icon sizing. Not quite sure why the 1st 2 buttons didn't include (bw*1) and (bw*0) coding.
Previously I tried pasted the wikipedia URL into the line for the myspace variable, which applied and queried successfully. But marc2003's myspace query coding resulted in artist names bigger than one term being reduced to just one term, deleting spaces. But with (bw*3) set, the rest of Bryter's query string works great.
Thanks tnnds.
TS
if button's width=100
1st=0
2nd=100(width)
3rd=200(width*2)
1st=0
2nd=100(width)
3rd=200(width*2)
Yeah... and I got (bw*0) (bw*1) (bw*2) (bw*3) (bw*4) (bw*5) to work quite well by tweaking the code for myspace and lastfm a bit.
There were several little problems with the variable and button code Bryter had posted for querying discogs that I managed to work out. Here's the complete code for what I finally got to work after I included wikipedia, rateyourmusic and discogs to the myspace, lastfm and youtube URLs in marc2003's basic 'web links' script:
// ==PREPROCESSOR==
// @import "%fb2k_profile_path%marc2003\common.js"
// @import "%fb2k_profile_path%marc2003\tooltip_buttons.js"
var bw = 32;
var bh = 32;
var top_margin = 0;
ww = window.Width;
wh = window.Height;
var discogs = fb.Titleformat("http://www.discogs.com/artist/$replace(%artist%, ,+)").EvalWithMetadb(g_metadb);
Buttons = {
but1: new Button(left_margin + (bw*0),top_margin,bw,bh, {normal: images_path + "myspace.png", hover: images_path + "myspace_h.png"}, function(){WshShell.run(myspace);}, myspace),
but2: new Button(left_margin + (bw*1),top_margin,bw,bh, {normal: images_path + "lastfm.png", hover: images_path + "lastfm_h.png"}, function(){WshShell.run(lastfm);}, lastfm),
but4: new Button(left_margin + (bw*3),top_margin,bw,bh, {normal: images_path + "wikipedia.png", hover: images_path + "wikipedia_h.png"}, function(){WshShell.run(wikipedia);}, wikipedia),
but5: new Button(left_margin + (bw*4),top_margin,bw,bh, {normal: images_path + "rateyourmusic.png", hover: images_path + "rateyourmusic_h.png"}, function(){WshShell.run(rateyourmusic);}, rateyourmusic),
but6: new Button(left_margin + (bw*5),top_margin,bw,bh, {normal: images_path + "discogs.png", hover: images_path + "discogs_h.png"}, function(){WshShell.run(discogs);}, discogs)
window.Repaint();
buttons_menu(x,y);
return true;
buttonsDraw(gr);
I also googled and found png icons for those 3 websites and photoshopped them down to 32x32 dpi main and highlighted buttons that work with the whole setup.
Haven't been able to figure out if it's possible to center all 6 icons in the WSH panel tho', instead of all being left justified.
TS
var bw = 32;
var bh = 32;
you can change it to 24 or 16...any size you want
As long as it matches the actual pixel size of the graphics file you're using as a button. Otherwise...
I really love this component! The web links script lets me access a LOT more information about artists than what I get from Last.fm via the biography component.
Would it be possible to write code that could bring up a web browser and display information I've saved in HTML files in many of my album folders? I also have several PDF files with album info that would be great to have a button in FB2K to access.
If that's at all doable, would it be possible to have a button 'light up'/highlighted when playing a track with a matching HTML or MHT info file?
Thanks for all your good work on this component marc2003.
TS
^utils.FileTest can check for files.
samples updated and now using a new link: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
new script:
echonest is a webservice that can fetch summaries of various artist info online. use the context menu to change mode between "news", "reviews" and "blogs". it displays the title and a snippet of an article. if you click an article, it will open your default browser taking you to the source. tooltips will show the URL before you click. use the mouse wheel to scroll through all the items.
it looks like this:
(http://dl.dropbox.com/u/22801321/echonest_img.png)
if you currently use my older samples, make sure you overwrite all files and re-import any last.fm scripts because there are some new under the hood changes that will break the old versions.
Hello marc2003,
my dui layout consists of 4 sections: 1. all my library viewers, podcast manager, playlist manager and playlist search, 2. tabbed playlist view, 3. playback section with now playing panel, queuecontents editor, wave seekbar, visualisation, bookmark panel, playbackrelated buttons and 4. all the selection info viewers with a toolbar with many, many buttons related to context menu. What i like about the 4. section is that all is acting synchron and even the toolbar buttons are dependent of the global settings in preferences -> display so when i apply a command from button i can be sure that it will be applied on what i see and what i see is in every viewer the same.
There are a few samples you've created that i find quite amazing: similar artist, last fm biography and mainly the artist art thumbs, not to forget the last one that deals with echonest. I would like to place them in my selection info section/tab container but then the pretty synchronicity gets lost as your scripts follow a different logic than the typical dui ui-elements. I suppose that it is not realizable but i prefer to ask someone who knows.
3 points must be possible to make the scripts acting like an ui-element:
- Following the global option: prefer playing track or prefer selection. For the sake of synchronicity even the annoying parts (http://www.hydrogenaudio.org/forums/index.php?showtopic=76600&hl=) of ui-elements are adopted. Maybe T.P. Wang has implemented already such functions to mimic the behaviour of that type of dui-panels? This behaviour seems to be outside of the ui-elements influence. There is a simple reason to mimic that annoying behaviour: to not increase the confusion that already exists.
- Intelligent handling of multiple selections: f.e. a script can recognize if a multiple selection contains just one artist or multiple, so it shows similar artists or gives a note that selection contain multiple artists.
- Your willingness to realize that if you consider that as senseful and are asked kindly.
Edit: typo/comprehendibility
the way it currently behaves (follow now playing, follow selection when playback is stopped) is purely a selfish design choice by me for the way i use it. i guess i'll have to look at adding user options.
it's not helped by the fact i never plan things through before i start. i get bare functionality working first and then start layering crap on top and it gets harder to change.
An user option like "Dui selection info viewer" would make me ... amazingly happy? I don't know the right word in english!
If it shouldn't be possible technically and the third point - your willingsness - exists i can request what is needed from T.P. Wand in WSH Panel Mod thread. Thanks so far!
adding an option to prefer playing or selected track is trivial and i'll probably post an update in a few hours.
i'm not sure how to handle multiple selections though. i might look into it if i get really bored.
I am not sure if you've understood what i am after. I mean following what is set in global preferences in display. I often switch this option and the dui selection info viewer are following this.
It seems to me that you are planning a way that would perfectly fit in CUI and how musicmusic implemented his viewers: different options in context menu of the viewer rather than the global one.
it's possible to use that as well. this will take more time to test though because i need to make sure my scripts work in columns UI as well.
Thank you so much, i am very curious to see the results.
can you test this for me to see if it works as you expect. browse your profile\marc2003 folder and replace common.js with this.
http://dl.dropbox.com/u/22801321/common.js (http://dl.dropbox.com/u/22801321/common.js) <<this will break all other scripts
and then import this into a biography panel:
http://dl.dropbox.com/u/22801321/simple%20bio.txt (http://dl.dropbox.com/u/22801321/simple%20bio.txt)
Wow, except from one point it seems to fullfill every expectation. I should do more testing but i have to wake up at six for work - i will continue tomorrow in the early evening.
Let me sum up my little testing:
What works:
1. It follows the global: prefer selection or prefer playing track.
2. If selection is preferred and at same time a track is playing then playing track is displayed if selection looses focus
What not works:
3. If selection is preferred and at same time a track is not playing then [edit]on selection loosing focus[/edit] dui ui-element shows nothing and your biography shows furthermore the selection. It is the same logic like in (2.): If a selection looses focus (not sure if i am describing that behaviour in correct terms) then the selection isn't shown but either nothing or played track in case of playback. No question: that is somehow annoying and Peter already told that this is going to be changed someday but that's how it is now.
Good night!
marc2003, I updated your sample configs and the Thumbs panel still won't download album art. It displays images it got previously, but it won't get anything new. If this can't be fixed, could you tell me how to add images manually for the handful of artists in my library I don't yet have images for?
right click the panel>open containing folder and dump the images in explorer. then reload the script and it will display the images. i still have no idea why that program has stopped working for you.
one thing i forgot to mention about my latest update: the last.fm scripts now cache files using a different file extension meaning all the old files are now useless. you can delete all .xml files from your profile\wsh_lastfm folder. that should save a few kilobytes. the scripts now use JSON.
EDIT:
large update ahoy. the following scripts now have a new context menu option to choose "selection mode". because of large background changes, they all need re-importing.
artreader
cd jewel case
echonest
similar artists
simple biography
thumbs
thumbs2
thumbs3
by default, they will now use the main foobar display preferences but you can over ride this on a per panel basis.
(http://dl.dropbox.com/u/22801321/selection%20mode.png)
weblinks and rating now use the main foobar preference and there is no option to change it (for now).
lastfm charts and similar artists have had some little bugs squished. all other scripts unchanged.
download: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
if you use my last.fm playcount script, that will need updating to the latest version. it works exactly as before. you don't get a choice but it needed some background changes to work.
you can grab that here: http://dl.dropbox.com/u/22801321/playcount%20sync.zip (http://dl.dropbox.com/u/22801321/playcount%20sync.zip)
updated again: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
echonest: fixed crashes with broken content. my fault for not double checking in the first place.
If a selection looses focus ... then the selection isn't shown but either nothing or played track in case of playback.
That's how dui elements work. I gave expressed my complaint abut that confusing behaviour in an own thread more than one and a half ago. I was told that Peter announced that this going to be changed someday but till now nothing happened.
If it is possible and mainly not much work i would really appreciate if your scripts would show also nothing on selection focus lost in case of no playback. I can give a good reason why it is senseful to do so: If a selection info viewer doesn't show nothing then also the buttons in toolbar and all hotkeys defined by context menu commands also do nothing - the presence of information in your script can lead to confusion that buttons/hotkeys have a content to be applied on.
At last let me thank you not only for the last changes you've made but also for your effort to keep your scripts so userfriendly.
from what i can see there is no way for me to detect when a playlist item loses focus.
Oh, i think i should ask T.P.Wang for an function or just wait till Peter removes this fallback for viewers, buttons and hotkeys. At friday i am in vacation for two weeks and when i come back i will decide me.
Thanks so far!
@q-stankovic, i now remember experimenting with this selection problem quite awhile ago. see my post here....
http://www.hydrogenaudio.org/forums/index....mp;#entry689083 (http://www.hydrogenaudio.org/forums/index.php?showtopic=70363&st=720&p=689083&hl=getselection&#entry689083)
back then i think it worked the way you wanted it to. of course it was no good for me because i wanted to interact with the panel so T.P "fixed" it.
also, an update for echonest: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
-fix first item being highlighted on script startup.
It still works so in case of playback. In very rare cases even in case of no playback there is a fallback into no display - T.P didn't fix enough.
i don't really see what your issue is then. you say it's rare for playback to be stopped and when foobar is playing, it works like you expect....
I think you misunderstood me: if there is no playback then your scripts won't show the typical fallback. Just sometimes (2% of 100%) and for me not reproducable even your scripts are falling back synchron to ui-elements and doesn't show the selection which focus was lost. I wanted to make a silly joke that T.Ps fix you talked about wasn't perfect.
you're right, i don't understand.
currently the only issue is when playback is stopped, correct?
when you select single items it behaves exactly like the selection properties/default art panel.
when you select multiple items (or browse album list etc), it shows the first item selected and we have no control over that.
when you click on an blank area of a playlist or other UI element, selection properties updates to "nothing selected". at this point the script falls back onto the last item selected. what am i missing here?
samples updated: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
similar artists: i broke the last.fm radio links with my last update a few days ago. this fixes it.
i also renamed echonest to news-reviews-blogs so people will now have some clue what it is.
another update
news-reviews-blogs: improved date handling. should now show original article date if it exists. beforehand it only showed the date it was indexed.
Hmmm.... coding... I'm really lost on that one. Could someone provide an example line of code using it that would find .html and .pdf files in the audio file's folder and link it with a button?
Thx
TS
Is it possible to get the shouts about current playing song or artist?
@marc2003
your last update of news-reviews-blogs does not seem to work anymore: the panel always displays "Could not read this article"
Previous versions were working fine...
^oops, you're right, i forgot to update one of the files in the zip.
that's now fixed and i've also drastically reduced cpu usage when moving the mouse over it.
import the script and make sure you extract the marc2003 folder as well.
@tnds, yes it's possible. see http://www.last.fm/api (http://www.last.fm/api)
@marc
How do i change the script so i can reduce the size of this ratings "box":
(http://i.imgur.com/Gk6oA.png)
I am draging the box from both sides, but it is not getting smaller.
I think this script is missing these lines:
var top_margin = 0;
var left_margin = 0;
These are included in other scripts (playcount), but i am not sure how can incorporate them here.
you can resize it much smaller than that. the stars are automatically centred - that's why there are no margins to set.
more bugs squished in news-reviews-blogs
it's just the script needs importing. the other files haven't changed.
The news-revie.blog script crashes always on importing.
Here is what the console says:
WSH Panel Mod: Warning: Could not load file C:\Users\[…]\Desktop\foobar2000\user-components\foo_uie_wsh_panel_mod\jscript.api
WSH Panel Mod: Warning: Could not load file C:\Users\[…]\Desktop\foobar2000\user-components\foo_uie_wsh_panel_mod\interface.api
WSH Panel Mod (Echonest by marc2003): Parsing file "C:\Users\[…]\Desktop\foobar2000\marc2003\common.js"
WSH Panel Mod (Echonest by marc2003): initialized in 5 ms
Error: WSH Panel Mod (Echonest by marc2003): Laufzeitfehler in Microsoft JScript:
Das Objekt unterstützt diese Eigenschaft oder Methode nicht.
Ln: 161, Col: 3
try extracting the marc2003 folder again. i know i said the latest update didn't need it but the previous update did.
i suppose my standard disclaimer should be to extract the files every time but i know that's a PITA.
Oh, sorry for false alarm!
Is there any good volume script available?
@Bryter, check the samples on the component home page.
@TakuSkan, something to show a button for PDF files. first you need to import
web links and then replace the
on_metadb_changed function with this...
if(!g_metadb) return;
pdf_file = fb.TitleFormat("$directory_path(%path%)\\music.pdf").EvalWithMetadb(g_metadb);
if(fso.FileExists(pdf_file)) {
pdf_img = "pdf.png";
pdf_h_img = "pdf_h.png";
pdf_func = function () { try {WshShell.Run(pdf_file); } catch(e) {} }
pdf_tooltip = "Open PDF file";
} else {
pdf_img = "no_pdf.png";
pdf_h_img = "no_pdf.png";
pdf_func = null;
pdf_tooltip = "PDF file not found";
Buttons = {
but1: new Button(left_margin,top_margin,bw,bh, {normal: images_path + pdf_img, hover: images_path + pdf_h_img}, pdf_func, pdf_tooltip)
window.Repaint();
you need to make 3 images yourself and put them in
marc2003\imagespdf.png //to show when there is a pdf file
pdf_h.png //to show when is a pdf file and you're hovering your mouse over the button
no_pdf.png //to show when is no pdf file
@Bryter, here's the volume script from my foobar2000:
(Notes: Read the code comments)
(Settings: Script Engine: JScript | Edge Style: None | Grab Focus: checked)
// gdi.Font is changed, the last paramter is style flags
// FontStyleRegular = 0,
// FontStyleBold = 1,
// FontStyleItalic = 2,
// FontStyleBoldItalic = 3,
// FontStyleUnderline = 4,
// FontStyleStrikeout = 8
// Here is 0, means FontStyleRegular
var g_font = gdi.Font("Verdana", 10, 0);
var g_drag = 0;
function on_paint(gr){
gr.SetTextRenderingHint(5);
var ww = window.Width;
var wh = window.Height;
var volume = fb.Volume;
// var pos = window.Width * ((100+volume)/100); // <--------- Old linear calculation
var pos = window.Width * Math.exp(0.04*volume); // <--------- Logarithmic calculation (as used in default volume slider)
var txt = "volume " + (Math.ceil(volume)) + " dB";
gr.FillGradRect(0, 0, pos, wh, 0, RGB(40,42,57), RGB(204,0,0));
gr.FillGradRect(pos, 0, ww-pos, wh, 10, RGB(102,102,102), RGB(40,42,57));
gr.DrawString(txt, g_font, RGB(128,192,255), 0, 0, ww, wh, 0x11005000);
gr.DrawRect(0,0,ww-0, wh-0, 0.0, RGB(46,48,63));
function on_mouse_lbtn_down(x,y){
g_drag = 1;
on_mouse_move(x,y);
g_drag = 0;
function on_mouse_move(x,y){
if(g_drag){
var v = x / window.Width;
v = (v<0) ? 0 : (v<1) ? v : 1;
// v = -100 * (1-v); // <--------- Old linear scaling
v = 25 *Math.log(v+0.00001); // <--------- Logarithmic scaling (as used in default volume slider)
if(fb.Volume != v)
fb.Volume = v;
function on_mouse_wheel(delta){
if(delta>0)
fb.VolumeUp();
else
fb.VolumeDown();
function on_volume_change(val){
window.Repaint();
//EOF
Thank you marc and derty2
I am getting an "Aw, crashed " message on the art panel sometimes. This is what the console says:
"Error: WSH Panel Mod (Thumbs3 by marc2003): Microsoft JScript runtime error:
'g_img[...]' is null or not an object
Ln: 107, Col: 3
<source text only available at compile time>"
I have extracted the whole folder in the application data/foobar. I'm also using the playcount script that you created and i have extracted its files in the same folder (marc2003) where i have extracted the files for this samples.zip. Could that cause any issues?
Playcount script is also crashing sometimes. Console says:
"Error: WSH Panel Mod (Playcount Sync by marc2003): Microsoft JScript runtime error:
File not found
Ln: 145, Col: 6
using my playcount script and these samples work fine together but you need to make sure you're using versions downloaded at the same time together. you also need make sure you merge the marc2003 folders from both zips together. you can safely overwrite any files when prompted because the common files are the same in both zips.
given your playcount script error, i'd say you haven't done that because it's missing files that are only included in the playcount script download (either that or you haven't installed foo_customdb properly).
and that image script error is very odd because there is nothing on line 107 that would cause that??? and even if there was something related, the only thing i can think of is corrupted image files or problems reading from your hard disk???
Ok than ill give it another try. I will download samples.zip that you posted on June 30th and playcount sync.zip that was posted on June 26. Are these versions compatible with one another?
a lot of changes have been made since the 26th so you should download new versions of each one.
I re-added all the components again, and the problem hasn't appeared in the last 3-4 hours. So i guess it is ok now...
Marc, thanks for your efforts on some very useful scripts.
Anyone, I'm trying to modify the artreader.exe script to add a capabilty I really like in the thumb scripts, which is the ability to double click on an image that is embedded in my song and open it my default image viewer. I think I need to add code to save out the embedded image to a folder (perhaps in my profile folder) and then launch the image viewer.
I'm trying to add code just before the else statement below:
if(!g_metadb || !g_img) return;
if(is_embedded) {
fb.RunContextCommandWithMetadb("Open Containing Folder", g_metadb);
} else {
try {WshShell.Run("\"" + g_img_path + "\""); } catch(e) {}
But my attempts are garbage. If this is easy to do, any suggestions on what to add would be appreciated!
well you can't extract images from files using WSH panel mod. you could launch tagging>edit attached pictures from the context menu.
else you can maybe find an application to extract images via the command line which can be triggered via WSH panel mod. i think it's unlikely there is an app that would work with multiple formats though.....
Thanks for the suggestion. I think I can use dbpoweramp's command line features to extract the art to a convenient folder.
Assuming I figure that out (still working on it), what else would I need to add make this work?
While I've concluded that my current capabilites aren't sufficent to do what I want (modify the artreader script to be able to click on displayed embedded art and launch and view in my default image viewer), if there is someones else out there with both ability and interest, I've learned the following with respect to applications that can extract images via command line for multiple formats;
- dBpoweramp (reference version) can do it via command line and I have done it, with the caveat that the reference version is not free, and the invoked utility demands overwriting all tags in your file. So one would either need to be OK with that (dBpoweramp writes and overwrites tags reliably), or change all files to read-only
- MediaInfo seems capable of doing so via command line, but is far beyond my ability to figure out exactly how to do it. The links to this application and a post that more specifically speaks to art extraction capabilies:
http://sourceforge.net/projects/mediainfo/ (http://sourceforge.net/projects/mediainfo/)
http://sourceforge.net/projects/mediainfo/...0/topic/4495644 (http://sourceforge.net/projects/mediainfo/forums/forum/297610/topic/4495644)
MediaInfo::Get(Stream_General, 0, "Cover_Data"); You receive the cover in Base64 format, you need then to "transform" the base64 to binary (there are a lot of functions on the net for this)
that's not exactly working with the command line, is it?
I'm modifying marc's thumbs2 script to remove art.exe dependency, got it mostly working but have slight issue with keeping file names in the same format.
How would I return the bolded part of string "http://userserve-ak.last.fm/serve/_/11168693/Brendon+Moeller.jpg" with jscript? The "_" part of url varies (e.g. "http://userserve-ak.last.fm/serve/500/...")
that 8kb taking up too much disk space is it?
anyway, this assumes the number will always be before the last slash.
url = "http://userserve-ak.last.fm/serve/_/11168693/Brendon+Moeller.jpg";
temp_array = url.split("/");
num = temp_array[temp_array.length - 2];
Wow that was quick, thanks
Problem I have with art.exe is it sometimes hangs and I have to manually close it from task manager.
there was a problem with the original version where it would hang if the artist wasn't found. but i fixed that over a year ago.
I got the one from your latest samples.zip. Can't pinpoint the cause, it just seems to "time out" sometimes. Next time it happens I'll let it stay on and see if it finishes over time.
Does anybody know any way to merge two playlists using wsh panel mod? I have tried several things, but nothing seems to work. There is no dedicated method in IFbUtils and a sequence of fb.RunMainMenuCommand("Select all"), fb.RunContextCommand("Copy") and fb.RunContextCommand("Paste") does not work. Another strange thing is that fb.GetSelections() after fb.RunMainMenuCommand("Select all") only works with some delay and then only if the window is focused. Any suggestions are very welcome!
Marc, think I found a bug in your similar artists script. It crashes if no similar artists found. Tried fetching list for artist "Groy" (http://www.last.fm/music/Groy), which is misspelled (should be GR-OY).
Error: WSH Panel Mod (Similar Artists by marc2003): Microsoft JScript runtime error:
'artists[...].name' is null or not an object
Ln: 74, Col: 5
similar.json contains:
{"similarartists":{"#text":"\n","artist":"GrOy"}}
fixed: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
I noticed that in the newest versions of your scripts scrolling with mouse wheel works nicely so that the arrow up and down buttons are not necessary anymore. Can you make them optional or at least give me a hint where to take a look in your script to remove them on my own. My first attempt resulted in crashing the script.
scrolling has always been there - the up/down arrows are a relatively new addition.
anyway, the easiest way is to find the
on_size function and change the value for
but_xbut_x = -50;
should do it.
also, i just fixed a typo in
last.fm charts that would it to crash if you entered an invalid username - but then again it serves people right who can't spell it anyway....
Hmm, i think the problem i meant still exists and i can explain why i thought it was removed. Maybe it depends of my mouse wheel that doesn't lock or latch (sorry, don't found better words on leo dictionary) The less the speed of scrolling the bigger the probability that scrolling has no effect: I have to scroll quickly for an effect what i generally do.
Edit
It seems to be a problem with my mouse! In facets with coverview i have the same phenomen. I could swear that i didn't had the phenomen with facets coverview or with your scripts for quite a time. However, i decided to by a new one because the missing locking/latching annoys me extremely.
Marc, having a problem with the custom folder mode of your thumbs2 script.
Absolute path that has brackets (like E:\Music\B-C\Calibre\[2010] Even If) doesn't seem to work.
oh FFS. i did write a function to take care of reserved characters in foobar title formatting but i forgot to use it.....
on line 111 replace this....
folder = fb.TitleFormat(cycle_tf).EvalWithMetadb(g_metadb);
with
folder = fb.TitleFormat(tf(cycle_tf)).EvalWithMetadb(g_metadb);
i'll upload fixed versions for all my image scripts soon.
EDIT: fixed versions uploaded. this change means you can't use functions in title formatting so i've updated the text dialog as follows:
Enter a path to a folder. You can use title formatting tags like %artist% but not functions.
You can specify multiple folders using | as a separator.
i've decided to reverse my decision above and go back to how it was before. that way full title formatting functions can be used and if you want to include ()[] in your path then just wrap them in single quotes.
another update for last.fm charts. panel would crash if last.fm didn't respond as expected. i really hope i've sorted this once and for all.
in theory, no matter what last.fm does now, none of my panels should crash (i fully expect this statement to come and bite me on the behind hard )
Hehe I'm trying hard to find more bugs. And good call on the decision with reserved chars, rather use functions than absolute paths anyways.
Btw added couple of features to my panels which you might be interested in also. An auto download conditional option (auto_download_lib) to check if the file is in media library, as I don't want to fetch for new files. Maybe add some kind of "delete last.fm data if the artist has not been seen for X days" function?
function on_playback_time(time) {
if(cycle > 0 && arr.length > 1 && (time % cycle == 0)) on_mouse_wheel(-1);
if(window.GetProperty("auto_download_lib") && !fb.IsMetadbInMediaLibrary(g_metadb)) return;
if(window.GetProperty("mode") == 101 && time == 1 && arr.length == 0 && window.GetProperty("auto_download")) download_images();
And changed the thumbs scaling method to keep original size for small images, unless "Stretch small images to panel size" (scale) option is checked
var s = 1;
if (window.GetProperty("scale") || img.width >= width || img.height >= height)
s = Math.min(width / img.width, height / img.height);
var nw = Math.round(img.width * s);
var nh = Math.round(img.height * s);
pos_x += Math.round((width - nw) / 2);
pos_y += Math.round((height - nh) / 2);
Marc, an observation and suggestion:
I noticed when playing internet radio stations in Foobar that my Artist information panel (foo_uie_biography set to display artist information from last.fm or wikipedia) and my lyrics panel (foo_uie_lyrics2 set to display lyrics from viewlyrics.com and lyrdb.com) both were able to capture information from what was playing to correctly display the proper information.
I also had your scripts running for lyrics, thumbs3, similar artists, and news/reviews/blogs, and I did not see those display content related to what was playing. Your scripts didn't crash, they just displayed "[no image]" for Thumbs3, "nothing found" for News etc, Lyrics displayed the song name and artist correctly but never any lyrics, and Similar Artists tried to find artists that matched with "?".
It's far beyond my abilities to revise your scripts to have them grab the appropriate information from internet radio playback to work when listening to internet radio, but it would be great if you could consider such capabilies in the future. My optimism tells me that if the older components could do this, perhaps this is not a big deal to add to your scripts (other than Lyrics, since your script works locally and the component can download) but I'm not technically proficient in these matters.
Thanks again for some very useful scripts!
can you link me to a station so i can test?
edit: you could just try adding this function anywhere in a script and see if it works.
function on_playback_dynamic_info_track() {
on_item_focus_change();
Thanks for the fast reply. I inserted the code such that I'm confident I didn't put it into the middle of an existing function, and here's what I observed both after hitting "apply", and after exiting and reopening Foobar just in case that mattered:
lyrics - didn't try, since I have no local information for the script to work with
News, etc, Similar Artists, and Thumbs3 - no change - same result as before.
I could briefly see that Thumbs3 tried to fetch images because that flashes on the screen for a second before returning "no image".
How I play an internet radio station:
- in Foobar, go to File>Preferences>Shell Integration>manage file type associations>, check the box for .pls files
- go to shoutcast.com
- go to "help", "settings", and select "play shoutcast stations in default media player"
- find a radio station you want to hear, click on it, and save the .pls file locally
- in Foobar, create a playlist and load this .pls
- double click on the playlist to stream it
an example link:
http://yp.shoutcast.com/sbin/tunein-station.pls?id=1377200 (http://yp.shoutcast.com/sbin/tunein-station.pls?id=1377200)
test these: http://dl.dropbox.com/u/22801321/radio%20test.zip (http://dl.dropbox.com/u/22801321/radio%20test.zip)
I tried thumbs3, Similar Artists, and News-Reviews-Blogs - all perform perfectly. Very impressive - thanks!
i get the MonoLite Mod-Slim (http://pengspawnie.deviantart.com/art/Mono...-Slim-147924669 (http://pengspawnie.deviantart.com/art/MonoLiteMod-Slim-147924669))
and volume & playback order is crash :x
the following scripts have been updated to support dynamic info in radio streams.
news-reviews-blogs
similar artists
simple biography
thumbs
thumbs2
thumbs3
existing users make sure you extract the marc2003 folder again and overwrite all files.
The latest updates from post #995 all crash or fail to update with radio stations. The test scripts from post #992 still work with radio stations.
did you extract the marc2003 folder again as my post explicitly says? i did test before uploading...
one thing i did break with the last update is the ability to switch between last.fm and custom folder mode in the thumbs/thumbs2/thumbs3 scripts.
i've now merged them all into one script (simply thumbs) where you can select the thumbnail view. it wouldn't surprise me in the slightest if i've broken a load of stuff though.
EDIT2: oh balls. samples taken offline while i fix a major balls up.
I extracted and overwrote everything as you instructed. I also just tried deleting everything and then extracting and importing again in case overwriting wasn't happening - same crash results. Thanks for your efforts!
i've just taken the download offline because they are seriously messed up. they're not crashing though - but they are creating folders where they're not supposed to. if you use foobar in standard mode, check %appdata%\foobar2000 and delete all randomly numbered folders (or if portable mode, check your foobar folder).
hopefully fixed it http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
just to be absolutely sure of a clean setup:
extract the marc2003 folder and overwrite all files when prompted
before importing the script into a panel, first use tools>reset default and close the editor. now right click>properties and click clear
now import the script.
edit: *sigh* custom folder mode still not working as expected.
a few more bugfixes. not particlularly serious - afterall no one has reported these issues.
simple biographyfixed panel crash if changing the api key/username/language with no file selected
fixed broken artist remapping introduced a few days back (it still worked but not instantly after changing)
similar artistsfixed panel crash if changing the api key/username with no file selected
thumbs custom folder mode now working.
one thing i don't think i have mentioned before but it came up in the EsPlaylist thread yesterday - if you use my
thumbs script in last.fm mode and have a collection of artist art built up, you can configure foobar to use it as a source for other components.
file>preferences>display>artist here you need to put the full path to your foobar profile folder (or foobar folder if running portable mode) and append
wsh_lastfm\$crc32(%album artist%)\*.* to the end. examples:
C:\Users\marc\AppData\Roaming\foobar2000\wsh_lastfm\$crc32(%album artist%)\*.*
D:\applications\foobar2000\wsh_lastfm\$crc32(%album artist%)\*.*
facets and EsPlaylist are 2 components that can make great use of this.
thumbs restore open/delete image options to context menu. i forgot to enable this on the new all-in-one version. and hopefully fixed the last of the custom folder mode bugs. yes, i'm useless.....
as I know nothing about WSH Panel wanted to ask maybe you could do with a seekbar nyan cat like this:
(http://ibxk.com.br/76019/164692.jpg)
i don't normally do requests but i'm in a silly mood....
(http://dl.dropbox.com/u/22801321/nyan%20cat%20progress%20bar.gif)
zip contains new images so make sure the marc2003 folder gets extracted again.
oh yippee, a nyan cat seekbar update.
-now shows seek time when dragging
-can change background colour via the context menu
-when dragging, you can move the mouse out of bounds along the bottom of the panel to cancel seeking
(http://dl.dropbox.com/u/22801321/seekbar%20cat%202.png)
The Thumbs script has stopped working for me - I can't figure out what has changed in my config to cause this. I've reinstalled the WSH component, deleted and extracted all WSH script files, and reset the panel to defaults and cleared settings before re-importing.
The symptoms:
- upon starting play of a playlist, it tries to fetch images, but neither finds any to download nor finds what I've already downloaded (and kept in the default location)
- upon track change in the playlist, the panel crashes and the console shows the following:
Error: WSH Panel Mod (Thumbs by marc2003): Microsoft JScript runtime error:
Object expected
Ln: 145, Col: 18
Any suggestions appreciated.
that indicates it's looking for a function that doesn't exist and that can only happen if you're using the
marc2003 folder from a different zip download to the script itself???
try putting this at the start of the script and check the console output....
fb.trace(typeof bl);
fb.trace(typeof my_metadb_changed);
it should say
function
function
i suggest clearing your browser cache and trying again just to make sure you're not getting any old version. FWIW the dates of the files inside the zip of the latest version:
marc2003\common.js (last modified 2011-07-21 13:02)
other WSH samples (new)\thumbs.txt (last modified 2011-07-21 15:30)
I screwed up the extraction of the Marc2003 folder - instead of extracting it to the roaming/Foobar2000 folder, I extracted it in place in the wrong spot. Thanks again - everything works great!
i would have expected the script to fail before that error you posted if the entire folder was in the wrong place?? oh well, at least it's working now....
I can't download from this web site
why don't you use the skydrive?
you use skydrive before, why now you don't use it?
skydrive recently changed making it a complete nightmare to use. you can't post links to files anymore. also, dropbox allows to me work on stuff from all my computers and i don't have to consciously think about duplicating files. i just work on a file and then save it. it's much more convenient for me this way. i'm sorry if the link didn't work - i know the uptime isn't as good as skydrive but it's not usually down for long.
-high cpu usage bug fix no scripts need re-importing but i badly bodged a shared function causing 20-30% cpu usage in image heavy scripts like thumbs
existing users just extract the marc2003 folder overwrting older files.
samples updated again.
i've decided to implement orchid's idea of having different automatic download options for images from last.fm. this applies to the thumbs and now playing scripts.
(http://dl.dropbox.com/u/22801321/automatic%20download%20options.png)
just for info, the automatic download is only triggered when playback starts and there are no images on the system already. you can always force a manual download via the context menu.
Well, that darn art.exe still isn't working for me.
Do you think you would have the time and inclination to make a version of your artist image downloaded that doesn't rely on it? I remember you commenting a while back that artist images can be downloaded without it.
I really miss being able to automatically fetch pictures of newly added artists
can you test this .exe and see if it downloads images.
http://dl.dropbox.com/u/22801321/download.exe (http://dl.dropbox.com/u/22801321/download.exe)
you feed it 2 parameters - an image url and a folder.
download.exe http://userserve-ak.last.fm/serve/500/64564809/IVY++in+2011.png c:\test
That works for me just fine.
right, stick that .exe file inside the marc2003 folder and then test this script in a panel....
http://dl.dropbox.com/u/22801321/thumbs%20download%20exe.txt (http://dl.dropbox.com/u/22801321/thumbs%20download%20exe.txt)
I just get [No Image] for everything, even for artists that I already got images for when the art.exe used to work.
Note that the "Open containing folder" option is grayed out...
there is absolutely no difference between the way this displays art compared to the original. the only difference is how it downloads it.
but i've just made a change to the script that will now let you open the containing folder even when it can't find any images. try that.
Hmmm I was using one of your older thumbs scripts, back when you had different versions for different configurations (thumbs left, bottom, etc). Has the download location for pictures changed since then? Because if I download the latest "thumbs" script, it doesn't work either...
Anyway I tried the new script (same link as last one, yes?) but nothing changed.
Thank you for taking the time to help me with this!!
the folder location has never changed since the first release. so there must be something seriously wrong with your setup.
the original download not working is one thing but for the new versions not to display the old images is completely un-fathomable.
Haha great. Well that's bad news
I use a portable setup if that makes any difference....
Anyway the old scripts display the images just fine. The new ones do not. None download anything, whether using art.exe or download.exe...
Maybe it's time to reformat my machine and see if that helps!
can you paste one of the old working scripts on pastebin so i can take a look. i'm certain i haven't changed the location but i suppose i'd better double check.
and are you also saying the new script doesn't work with download.exe even though it works fine from the command line?
The new script does nothing at all. It won't display existing pictures, it won't download new ones... It just sits there saying [No Image]
Here's the script I've been using - this one shows existing pictures just fine.
http://pastebin.com/1y33k4t7 (http://pastebin.com/1y33k4t7)
just as i thought - no change in folder location. how that displays images but the new one doesn't is beyond me.
as for the new script, i've just noticed if you set the limit to 1, it doesn't work. that's something i need to look into.
new download.exe version fixed to work with a limit of 1. http://dl.dropbox.com/u/22801321/thumbs%20download%20exe.txt (http://dl.dropbox.com/u/22801321/thumbs%20download%20exe.txt)
thumbs: only trigger automatic download when selection is also the playing track.
Woah.
Wake up this morning, start up my machine, and for some reason your download.exe one is working for me just fine
it's either magic or PEBKAC. i know where my money is......
now playing now shows when it's fetching images
last.fm charts you can now toggle the artist display on/off when displaying track or album charts.
artist display on
(http://dl.dropbox.com/u/22801321/lastfm%20before.png)
artist display off
(http://dl.dropbox.com/u/22801321/lastfm%20after.png)
also, all other scripts cleaned up and are using a new shared file meaning the marc2003 folder must be extracted. a side effect of these changes could mean custom background colours for certain panels being lost. simply use the context menu to set them again.
Well, I wanted a script to edit the tag for the music to "%skip% 1" for use with foo_skip, again if I click "%skip% = 0", and that I can edit the button image
(Sorry google translator is bad...)
Marc2003, any idea why some artists get redirected to other artists in your last.fm bio script?
Trentemøller redirects to Talk Talk
Husky Rescue redirects to Bad Religion
Husky redirects to Troll Scientists
There are others I can't remember right now.
Interestingly, the artists that are redirected TO are also in my library...
if i had your computer, i'd have thrown it away by now. you always get the most unexplainable problems that i can't ever reproduce.
try using update from the context menu.
or if it's lots of artists, browse your foobar2000 profile in windows explorer and search for and delete all files named artistinfo.json - this clears the all the cached data. i really can't explain how the wrong data gets saved for an artist????
if that doesn't work, please use foo_uie_biography from here.
http://foo2k.chottu.net/#bv (http://foo2k.chottu.net/#bv)
Update works, thanks.
And I love my computer! It has... personality
Is anyone using the lyrics panel scritp from Br3tt? It works ok but for some reason, in some lyrics it won't respect the line breaks so I get gigantic wall of texts, making them really hard to read.
unless you post the script and an example of an lrc/txt file you're having problems with, it's impossible for anyone to help.
maybe because there is no line break in your lyrics! my panel doen't add line break itself, it just displays the lyrics as they are and some lyrics files are not correctly written (no line breaks at all), but that's not concerning me
simple biography now uses a fixed sized font instead of using foobar defaults. this makes it much more readable on windows XP and scrolling is much better.
existing users make sure the marc2003 folder is extracted from the zip as a few background changes have also been made.
Thank you for your effort!
@garbanzo.bean, it looks like i owe you an apology. i did manage to stumble across a bug that can cause the online info to get saved in the wrong place. it's hopefully fixed now: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
affected scripts:
last.fm charts
news / reviews / blogs
similar artists
simple biography
Hello.
I asked a while ago in the foo_utils thread if I could find a specific word in a text (EAC ripping log) file and copy "true" or "false" to clipboard (using context menu) if the said word exists and marc2003 suggested I post in this thread here because apparently WSH Panel Mod can do so, so here I am.
I don't know JScript nor VBScript but know the basics of scripting so if I could get help starting my script, I could do the rest myself.
If anyone has a few minutes to help me with it, here's what I want to do:
Select album in library view, right click and copy basic infos (%album%, %title%, etc..) to clipboard. This would be pretty easy I'm sure.
When I right click, I want the script to look for the .log file in the album folder and search for specific words in that log file and copy some infos to clipboard depending of the text it finds.
The .log file always has this line as the first one:
Exact Audio Copy V0.99 prebeta 4 from 23. January 2008
What I'm interested in copying to clipboard is the EAC Version from that line, so V0.99 prebeta 4 in this case, but it could be another version.
The script would have get the text after Exact Audio Copy and before the first instance of from.
I would also copy to clipboard "yes" or "no" depending if the script finds specific files in the album folder. For instance, if it finds a .CUE file then it's "yes".
And is there a way to get the image dimensions (width & height) from Cover.jpg in the album folder as well?
There are a few other things I'd like the script to do, like finding in the .log file how many tracks accurately ripped and how many didn't, but what I mentionned above would be a GOOD start.
Feel free to help me out, or not.
Thanks in advance or thanks anyway
you might want to check that thread again. there was no mention whatsoever of using this with the windows clipboard.
edit: i wasn't sure if it was possible to use the windows clipboard but i just found out how . i can copy/paste text just fine.
cuetools is far better suited for checking log files and verifying if rips are accurate. see the thread here: http://www.hydrogenaudio.org/forums/index....showtopic=66233 (http://www.hydrogenaudio.org/forums/index.php?showtopic=66233)
i already have an album art reading script. it did used to display image dimensions but i removed it. i guess it would be fairly trivial to add it back again.
samples updated: simple biography now has a context menu item to copy text to the clipboard. kinda pointless but meh.
too late to edit the last post again. another update, both the artreader and cd jewel case scripts now have a tooltip to show the image dimensions.
simple biography updated. if you set a non-english language and there is no bio found, it can check again and look for english. you can turn this behaviour off via the context menu if you don't want it.
EDIT: a few more updates:
because of the above changes, simple biography can now update automatically again. also, playback stats for the artist are back.
thumbs now has a feature where it can read a URL from the windows clipboard and download the image to the current folder. if in custom folder mode and there are multiple folders, it uses the first one. it has fairly rudimentary checking - the url must being with http:// and end with either png, jpg or gif. to use, simply right click an image in a browser and select copy image location (wording may depend on browser). now right click the panel and you should see the option Download clipboard link to this folder.
thumbs updated.
large improvements to performance when dealing with lots of images in a folder. the initial folder scan, panel resizing and settings change could still cause foobar to choke for a second or two but scrolling now works perfectly. i did this by stitching all the thumbnails into one image. just to note, this is only an issue when using silly amounts of images. using last.fm mode at the default of 5 or even the maximum of 20 is absolutely fine. it takes a fair bit more than that before you'd notice it.
@marc2003
request: last.fm charts panel without the "bar" and play button
example:
(http://img824.imageshack.us/img824/8615/imagecbo.png)
http://pastebin.com/43p5BRYN (http://pastebin.com/43p5BRYN)
thanks is beautiful *-*
simple request for the news/reviews/blogs script: if the script is still fetching, could that be displayed by f.e. "[fetching info]". Some searches take a long time (means: a few seconds) so that you can't be sure the first 4 - 5 seconds if the script is still fetching or nothing has been found.
I like this echonest stuff: it f.e. let me know that there is a movie about "a tribe called quest". Have you checked how useful the other sources are or could be? Biographies (maybe there is a better one than in last.fm), video, audio, urls and so on.
By the way: an idea for an new script (youtube videos of a certain artist):
(http://img828.imageshack.us/img828/2576/youtubeqm.jpg) (http://img828.imageshack.us/i/youtubeqm.jpg/)
(screenshot of amarok)
well i've never seen it take more than a second but i've added a "fetching info" message regardless...
i've looked at the echonest biographies and all they have is last.fm and wikipedia. the rest of the sources aren't even a full sentence. i won't use wikipedia as there are no line breaks. it's just a huge wall of text and is unreadable. also, i believe ssenna's proper biography view component has a built in wikipedia reader.
i might take a look at what other info i can get from echonest if i can be bothered.
as for youtube, i already have a buttons script (web links) that will open youtube in a browser with the artist/title as the search term. i see no point in previewing this within foobar because you'd have to open a browser anyway. i know this contradicts what news/reviews/blogs does but youtube is a single site and is much easier to navigate than doing a google search for all the info that echonest provides.
Thanks! (In some rare cases i have to wait indeed 4 or so seconds.)
samples updated: bug fix for all scripts that use a text input box. it wouldn't accept double quotes (") without crashing. this probably only affects the autoplaylists script. i doubt you would need " in anything else.
the marc2003 folder needs extracting again. no changes to the scripts themselves. edit: i forgot about some other changes i've made - scripts do need re-importing.
marc, your update get crashs in this panel (sry my bad english)
http://pastebin.com/axuWvmb4 (http://pastebin.com/axuWvmb4)
thanks
thanks alot for the samples and all the work youve put into this marc, one step closer to foobar utopia
Hey guys, I'm having an issue with the WSH panel mod for the first time & I have no clue what's going on. The plugin gave me absolutely no problems for months and then out of the blue I get these errors:
Scripting Engine Initialization Failed (GUID: 8AB1342D-F175-43E3-82E8-4E834CEBC60C, CODE: 0x80040154): Class not registered
Scripting Engine Initialization Failed (GUID: 91399579-7135-44E5-8F2B-327FF7E647C9, CODE: 0x80040154): Class not registered
Scripting Engine Initialization Failed (GUID: 75880344-BD08-43C4-8D12-2FFDE4EA5F0F, CODE: 0x80040154): Class not registered
Scripting Engine Initialization Failed (GUID: 2E87E20B-BC5E-4A94-8A78-F15135F3E277, CODE: 0x80040154): Class not registered
Scripting Engine Initialization Failed (GUID: 3034F0FE-42A2-4532-A8C4-34F84A6E0B2F, CODE: 0x80040154): Class not registered
I've been using this skin - http://browse.deviantart.com/?qh=§...foobar#/d2lapfr (http://browse.deviantart.com/?qh=§ion=&q=flex+foobar#/d2lapfr)
Again, no problems for months. I restarted my computer and these just popped up.
Marc2003,
Since i updated with sample.zip my playback buttons show but no hoover and action is being taken.
Hope you can help me with this.
Rhand
strange, i can't think of any changes that would make that happen. did you extract the marc2003 folder again?
Yes i did, i put the old marc2003 folder back and it's working again.
Ik think it's in the tooltip_buttons.js.
But i am not shure.
just checking the dates and i did update tooltip_buttons.js on the 27th august. the playback buttons script was also updated the same day. did you extract the folder to use another script but didn't import the updated playback buttons script in to your panel?
I use an modified playback button script. I added buttons to it.
Will try to use the updated playback button script, and then modify it with my one buttons.
And then i will let you now of the out coming.
Rhand
you should just need to add these 3 functions to your modified script.
buttonsMove(x, y);
buttonsUp(x, y);
function on_mouse_leave() {
buttonsLeave();
Rhand
Marc2003,
Thank you for your help.
I copied all the lines with button in it from the modified script to your original script, and that worked.
Rhand
Hi marc.
Is there anyway to use your last.fm charts to retrieve the artist/albuns/tracks in the media library instead of opening a last.fm page?
nope.
Is it a way to define a meaningful panel name, so that it will be displayed instead of (or in addition to) the GUID in the console? I have many WSH panels, and when an error message occurs, I have many difficulties to find at which panel the GUID of the error message refers.
Thanks in advance!
look at preprocessors.txt in the docs folder of the component download.
Great! Thanks!
So it is not possible to use the command "quicksearch for same..." that comes with the quicksearch toolbar in for example your similar artists panel? Would be really useful so if it is possible I'd be happy for some help as I am not very skilled; I am just trying to change the lastfm-radio to a wiki-link and that's proving to be hard enough for me
@Marc2003
About your Now Playing panel, do you think it is possible to add a kind of "auto-refresh" for when the tags of the now playing song are modified (just like with your rating panel)
I have modded your now playing panel to add display of genre & style but if I update them (with discogs information for example) I have then to manually refresh your panel
Thanks in advance,
Hi WSH friends
i'm currently working on a WSH palylist viewer panel, it progress in the right way until now, so here is a preview of the actual result :
http://www.youtube.com/watch?v=7-fH6l72iXw (http://www.youtube.com/watch?v=7-fH6l72iXw)
note: support small or big playlist as well
So the rating works only for selected tracks? Is there a way to make it rate songs that are playing now?
you talk about my wsh playlist viewer? no, live rating always works, regardless of the status of the rated line (playing, selected, normal), check the video more accurately, i show that point
add this function to the panel
function on_playback_edited() {
on_playback_new_track();
i'll update the zip file later.
@Falstaff, are you using the official WSH panel mod to do that playlist viewer or does it require a further modded version?
not the official one, because it still not provide the required API to do it, which are :
GetAnItem(index);> Get a metadb handle of any item in the active playlist determined by it's position.
SetFocusedItem(index);> Set the currently focused item in the active playlist.
SetSelectionSingle(index,selected);> Set a track either selected or not. The selected parameter should be either true or false.
ClearSelection();> Clear selection on the active playlist.
I hope T.P.Wang will add these features in the official one ASAP !
No i was talking about the original rating script from marc2003.
Thank you. It's so simple I feel really dumb. I guess I should have read docs for WHS Panel Mod more carefully.
I have found a way to do it with on_metadb_changed() as in your rating panel but your solution is more appropriate.
add
selection_mode = 1;
along with the other variables near the top of the script. it will now stick with the playing track while playing but follow the selection when playback is stopped.
@Falstaff, ah right, i was just wondering. i'm far too lazy to attempt this myself.
version 1.4.4 seem no longer support function gethwnd and CreateGlass?
So anyone show me other way to create aero glass?
it never supports these functions, maybe you have to use a non official version of WSH panel mod which provide these ones.
I want to add a imagebutton to panel stack splitter to sort elplaylist by artist, which command can i use in COMMAND argument of $imagebutton function?
wrong thread. what has any of that got to do with WSH panel mod?
but to point you in the right direction, look at using CONTEXT, not COMMAND. it's all in the readme.
i've spent bloody hours trying to make scrollbars for panels and it's almost working perfectly.... but my dilemma is that i'm using the height of the content to base my "grabber" size on. but now i'm trying to make a playlist and the grabber gets really small. i can't change the size artificially because it then messes up the maths need to calculate when to stop/start scrolling when dragging. i'm guessing i've approached this from entirely the wrong angle. i know other people have posted snippets before but they are too complex for me to implement in my script. any ideas on what i should have done....
I have written a "Viewport" object with a vertical scrollbar (no horizontal scrollbar so far), based on my first scrollbar attempt (that was not an object). The scrollbar is used to scroll a bitmap that is higher than the viewport.
I have exactly the same problem: when the bitmap is really big, the scrollbar's grabber becomes very small. But there are also arrows in the top and bottom edges of the scrollbar, and the user cam also click on the "empty space" between the arrows and the grabber to scroll by a page at a time. The keyboard and mouse wheel and drag can also be used to scroll the bitmap, so I haven't tried to solve the "grabber too small" issue.
I have used the viewport object in several panels (based on your Last.fm panels), but I have also modified completely the way they work, and they need a "global" panel to be notified of metadb or preferences changes. I can't give them here as examples of my Viewport object, because they will not work alone. I'll try to write a simple example when I'll have some time...
i suppose i shouldn't really concern myself too much. it's highly unlikely this script will ever see the light of day anyway. i'm really happy with the way it works for normal panels - it's only with 1000+ tracks in a playlist that i have a problem.
edit: if anybody else uses the theme manager, i made this snippet to easily find the part and state id...
var test = window.CreateThemeManager("scrollbar");
var size = 30;
function on_paint(gr) {
for(state = 0; state < 20; state++) {
for(part = 0; part < 20; part++) {
try {
test.SetPartAndStateId(part, state);
test.DrawThemeBackground(gr, state * size, part * size, size, size);
} catch(e) {
just change "scrollbar" to anything from this page: http://msdn.microsoft.com/en-us/library/wi...v=vs.85%29.aspx (http://msdn.microsoft.com/en-us/library/windows/desktop/bb773210%28v=vs.85%29.aspx)
now i can get the ID for what i want from this grid view.
(http://dl.dropbox.com/u/22801321/part%20and%20state.png)
(http://i305.photobucket.com/albums/nn222/neonmori/dd.png)
I made a WSH graphical browser.
The scroll bar is simple but effective enough.
@ marc2003, how can i change the font to your simple biography panel? i would like to switch to arial 8pt.
anywhere at the top of the script before on_item_focus_change();
normal_font = gdi.Font("Arial", 8);
to change the font of the stats display, use
list_font = .....
and for the artist header at the top..
title_font = gdi.font("super font", 16, 1);
add the 1 if you want to make it bold.
Thank you
how do i use on_metadb_changed() with a handle list? i've looked at the callback and preprocessor docs and i can't make any sense of it at all.
Marc, I've found a solution for the problem of the scrollbar grabber too small. It is extremely simple, and I have had to add only 3 lines of code.
I'll try top explain my method with a vertical scrollbar example:
---- y1: top of the scrollbar
Up button
---- y2: top of the area containing the grabber (The height of that area is in the variable "ah")
---- y3: top of the grabber
The grabber (Its height is in the variable "gh". It should be minimum 16.)
---- y4: bottom of the grabber
---- y5: bottom of the area containing the grabber
Down button
---- y6: bottom of the scrollbar
I suppose that, like me, you know the height of the portion of the scrollbar that is between the up and down buttons and that contains the grabber (ah, or y5-y2) and the height of the grabber (gh or y4-y3). gh is computed relatively to ah, to the height of the window (or viewport in my case) and to the total height of the data to display. The problem happens when the latter is too large relatively to the height of the window.
In my method, it's always the top border of the grabber (at y3) that determines the position of the data to display.
So, if y3 == y2, the first line of the data is shown on top of the display.
Similarly, if y4 == y5, the bottom line is shown on the bottom of the window. In this case, y3 = y5 - gh.
What I do to solve the problem is this:
When gh is computed, there can be two cases:
1: its height >= 16, and in that case, there is no problem.
2: its height is < 16. It is too small, so we must enlarge it. I force it to 16. But of course, if you move the grabber to the very bottom of the scrollbar, it will be drawn partially over the down button. To avoid that, it is sufficient to shrink the area containing the grabber (ah).
if (gh < 16) {
ah -= 16 - gh;
gh = 16;
Now, if you move the grabber to the bottom, it will stop just where it should, and all computations based on the position of the top of the grabber and the height of the area are still correct.
The thing to understand is that the height of the area in which the grabber can move does not have to be the height of the area containing the grabber. It can be smaller by a few pixels, and the grabber larger by that same number of pixels.
(In fact, there are still some problems to solve. For example, if the total height of the scrollbar is less than the height of the two buttons + 16 + some space to move the grabber, you have to draw the small grabber, or remove it completely and keep only the up and down arrows. But that's cosmetic stuff, simple enough to solve.)
If your method is similar than mine, you should be able to fix your code easily. Good luck!
thanks for that. it's always something simple.
edit: oops appearances can be deceiving - i might still have a problem. false alarm - scrolling works perfectly even with 100,000 items - it's my mouse click code that is broken.
Well, I had also some things somewhat broken, but it's perfect now. :-)
BTW, I have another problem. My viewport object is defined in an include file, and it is supposed to be easily reusable in any WSH panel. But it is not easy to handle the callbacks. For example, the scrollbar must be notified of mouse clicks and moves. But if, for any reason (for example if there are buttons in the panel), the panel needs also that information, the main code must also define the on_mouse_...() functions. So, the viewport object cannot steal them for its own use.
Currently, the object has on_mouse methods, and it is the responsibility of the main code to call them. The object's method returns false when it has used the event (for example, when the user has clicked on the scrollbar), so it is relatively easy to handle the remaining events in the WSH panel. But I'm not satisfied by that method, mainly because it is necessary to define the callbacks needed by the scrollbar in the main code, even if it doesn't need that callbacks for its own use, just to pass them to the main code.
I've tried to do the opposite: define the callback functions in the include, then pass the events to the object, and if they have not been used, call a function with a similar but somewhat different name in the main code (with try/catch so that the code will not fail if the function is not defined). But I don't like that method either, as it is necessary to define the callback functions if the include, and they cannot be methods of the object. Furthermore, it is necessary to define the callbacks in the main code with different names than the official ones. Also, it is difficult to define several viewports in the same panel.
I wonder if there is a better method. As far as I know, there is no way to receive the same callback info in the object and in the main code, without having to call one from the other. Right?
Is it possible to define the same callback twice? I could for example define the callbacks in the include, and they will be overwritten later if the main code redefine them (and in that case, of course, they will need to call the corresponding object methods). So, if the main code doesn't need a callback, it will not need to define it. But I don't know if it's possible.
How did you solve that problem? Do you write a single callback function where you do the stuff necessary to handle the events necessary for the scrollbar as well as any other events your panel may need?
(I hope I am clear enough. English is not my native language, and here in Belgium, it is late!)
i use
true like this...
switch(true) {
case obj1.trace(x, y):
obj1.click(x, y);
break;
case obj2.trace(x, y):
obj2.click(x, y);
break;
case ..... //neither of those objects was clicked so let's check something else....
i don't like this idea at all. i definitely prefer the proper callbacks in the panels themselves. i think it makes maintenance easier and gives you more flexibility to make changes.
as for duplicating functions, that's certainly possible as i discovered by mistake. if you declare them multiple times, only the last one gets called.
function test(a, b) {
return a + b;
return a * b;
fb.trace(test(5, 5)); //displays 25 in the console
i can't say i'm keen on this idea either but i'm not particularly fussy. so long as stuff works, there is no impact on performance and it doesn't crash - that's good enough.
Could you paste your script, please ?
thanks in advance.
Decalicatan Decalicatan
i use true like this...
I see. But your method implies that the code to handle the scrollbar and the code to handle the other things is in the same function. I really want to keep the viewport/scrollbar as independent as possible. So, I prefer this:
if ( ! viewportobj.on_mouse_lbtn_up(x, y) ) {
// main script stuff here...
obj2.click(x, y);
Of course, I can use switch/case too.
That's great to know. I suspected something like that. (I could have written the test myself BTW!)
I think I will adopt that method, and add the callbacks necessary for the toolbar in the include. If the main code doesn't need a callback, it will not need to define it, as it will already be defined in the include. Otherwise, the callback code can be copied from the include to the main script and modified to suit the panel's needs. That will keep the main script easier to maintain and read.
You might consider using the prototypal inheritance capabilities of JS for such cases:
http://javascript.crockford.com/prototypal.html (http://javascript.crockford.com/prototypal.html)
http://www.ruzee.com/blog/2008/12/javascri...es-and-closures (http://www.ruzee.com/blog/2008/12/javascript-inheritance-via-prototypes-and-closures)
thanks for the links. now let's see if i can i understand them.
my scrollbar is quite separate from my content. in on_paint, the position of the grabber is determined by the position in my array of items of where i want to start looping. if i have 100 items but only room for 10 rows and i want to display the last 10, i'll be starting at 90.
sbh = wh - 34; //scrollable height
gh = Math.floor(sbh * (rows / items)); //grabber height
gy = Math.floor((sbh / items) * offset[plman.ActivePlaylist]); y-cordinate of grabber. i'll add 17 when drawing to account for the up arrow
but if the scrollbar is being dragged, i need to reverse that and set the offset based on the position of the grabber. it's only a few lines in each case so i haven't even bothered making it reusable.
my code : http://www.hydrogenaudio.org/forums/index....st&p=771581 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=70363&view=findpost&p=771581)
HTH
thanks for posting that. now to *ahem* borrow some code.
a few issues: add a file and then add the same file again. aw, crashed
also, when you finally manage to add multiple files to the same playlist, it treats them all as the same track when selected or playing. not that i ever do this but you have to account for all possible actions.
using shift+click to select a range of files doesn't behave like a standard playlist. let's say i select track 5 with shift held down. now i click track 1 and tracks 1-5 are selected. so far, so good. but now i select track 10. the range should change from 5-10. but your playlist adds to the selection keeping 1-4 selected when they should be cleared.
i never have a track more than once in a playlist (crazy thing for me), but it should handle it as well, i'll check that, thanx for reporting.
i know this behaviour for shift selection, but not on the top of my todo list actually
EDIT: FYI, draw cover art just optimized, too much refresh done in the shared script, and cache engine optimized to handle a timer for each cover visible (not a full get'n draw like done in the shared script)
preview of the new cover cache engine : http://www.youtube.com/watch?v=rpDB1xhbMjA (http://www.youtube.com/watch?v=rpDB1xhbMjA)
for the crash issue on adding the same file, the fix is to change the function below with this (2 new lines in blue to add):
function on_playlist_items_selection_change() {
g_metadb_playlist = plman.GetPlaylistItems(fb.ActivePlaylist);
IC.list_total = fb.PlaylistItemCount(fb.ActivePlaylist);
When I see that, I think that it should be possible to create a big WSH panel to control entirely foobar2000 with a remote (sending keystrokes to the panel). IMO, it's something that is missing in F2k. It's a wonderful player to be used on a PC with a mouse, but currently, as far as I know, there is no way to integrate it easily in a multimedia-only PC, that has no keyboard or mouse.
Interested? ;-)
My method is totally different. All things to display are drawn in a bitmap (higher than the viewport), and the entire bitmap is scrolled totally automatically when needed. The advantage is that you have just to draw your stuff once. The viewport object does the rest automatically when the user uses the scrollbar. That's very fast, as the object has only to scroll the bitmap and refresh the scrollbar. There is no need to recreate all visible elements. (Of course, you need to recreate the bitmap if the width of the window changes or if the things to show must be updated.) Also, things that are outside the viewport (and are therefore at fixed positions) are not modified when the viewport refreshes itself. So, you need also to draw them once. Another advantage is that the viewport object holds constantly the X and Y mouse positions relatively to the top-left corner of the bitmap, so you don't need more or less complex calculations to find over what element the mouse is positioned: you can find it with X and Y.
My method has also some drawbacks. You must allocate a bitmap large enough to hold the entire display. For very big panels (such as important playlists), that could be a problem.
Also, in some cases, it is not easy to determine the height of the bitmap, and that's necessary before beginning to draw the elements. (For example, I have created a panel to display the current track information, and it uses different (big) fonts for the artist, title, composer, performers, etc... If a tag is missing, it must simply skip it, without leaving a blank space. It is currently not simple to compute the height of the panel, and I will probably add a "dummy" flag to the viewport's draw method to simulate the drawing of the elements and return the total height. It will then be sufficient to call the same function twice: once with the "dummy" flag to compute the height of the bitmap, and the second time to draw the stuff in the bitmap with the correct height.)
mind sharing script ?
Well, I am doing final debug and optimization, however, it would be a bad-efficient "component" as the original graphical browser, because it needs to evaluate all items inside a playlist.
ok, well, keep the good work and give us an optimized versions asap
I've just added a cool feature (take from ELP), just look at this
http://www.youtube.com/watch?v=ic14s4ahig0 (http://www.youtube.com/watch?v=ic14s4ahig0)
Hello marc2003,
In one dui tabstack i placed 4 of your autoplaylists script. I assume that they are expected to work independently. In that sense there seems to be a bug as they are not totally independent. Here a video that shows what i mean: http://www.youtube.com/watch?v=nRgIH0RoAjE (http://www.youtube.com/watch?v=nRgIH0RoAjE)
By the way: would be nice to have the opportunity to rename the caption "Autoplaylist" to something that matches the content of one list. When you have installed your script more than one time to achieve some sort of organization of autoplaylist some names like "Statistics", "By Artist", "By Genre" and so on would be helpful. I already did that by manipulating your script but after import of new versions of the script the names are lost.
it's not a bug - it's a feature. because i switch between columns UI and default UI regularly, they share the data file named simply
autoplaylists inside a folder named
wsh_settings in your profile folder. if i ever remove the panel from my layout and then add it back again later, my autoplaylists are retained. i never thought anyone would run multiple instances.
as for your video, the panel reads the file into memory. but as soon as any changes are made it gets saved immediately. there is no synchronisation between panels for the reasons i mentioned above although it is possible.
however, adding support to name your own panels with separate files for each should be fairly trivial. i'll see what i can do.
edit: actually, i won't be doing any script updates until WSH panel mod 1.5 is released. i have no idea when that will be as the developer hasn't posted on the forums for awhile although development is very active at the moment - i've been checking his google code page for updates.
if you want independent scripts right now, simply edit line 8
var autoplaylists_file = settings_path + "autoplaylists";
eg
var autoplaylists_file = settings_path + "autoplaylists_panel1";
var autoplaylists_file = settings_path + "autoplaylists_panel2";
That was the first i was thinking when starting the usage of your script. IMO several lists gives an better overview over a large amount of autoplaylists presets than a treeview could do.
Edit
Replaced the line in the txt.file, removed the wsh ui-elements, restarted foobar2000 and added again wsh ui-elements with importing autoplaylist script. It seems to have no effect.
well if you're editing the script before importing then of course all panels will still use the same file. i meant edit the panels.
try this instead....
var autoplaylists_file = settings_path + "autoplaylists_" + window.GetProperty("id", window.ID);
How could i know that!
Much thanks, now it works: all new added autoplaylist scripts start with a blank list.
Perf Test
http://www.youtube.com/watch?v=HyQQ7UDc5ss (http://www.youtube.com/watch?v=HyQQ7UDc5ss)
(http://i305.photobucket.com/albums/nn222/neonmori/WSHGraf.png)
95% finished.
The only question: can not easily get the position of now playing item by using IFbMetadbHandleList
you're kidding?
var nowplaying = plman.GetPlayingItemLocation();
var pid = nowplaying.PlaylistItemIndex;
you're kidding?
problem is i re-arranged the contents of the list.
you can find that the order in browser is different from the playlist.
Hey, guys. Recently I'm getting frequent crashes in foobar and the reports point to this component. Thing is that I haven't changed anything and can't trace it to which of my panels is doing it (I have 3). Any help?
Illegal operation:
Code: 80000003h, flags: 00000000h, address: 6C81B5ACh
Additional parameters: 00000000h
Call path:
entry=>app_mainloop
Code bytes (6C81B5ACh):
6C81B56Ch: 4D F4 64 89 0D 00 00 00 00 5F 5E 5B 8B E5 5D C2
6C81B57Ch: 0C 00 8B 75 08 83 C6 64 8D 5D 8C E8 04 C4 02 00
6C81B58Ch: 8B 4D CC 8B 01 8B 50 04 FF D2 50 8B C3 50 68 18
6C81B59Ch: 11 89 6C E8 0B D6 02 00 83 C4 0C E8 84 BC FF FF
6C81B5ACh: CC C7 45 FC FF FF FF FF B8 BA B5 81 6C C3 8B 75
6C81B5BCh: E8 8B 16 8B 42 08 8B 7D E4 56 FF D0 8B C7 8B 4D
6C81B5CCh: F4 64 89 0D 00 00 00 00 5F 5E 5B 8B E5 5D C2 0C
6C81B5DCh: 00 8B 75 08 83 C6 64 8D 9D 4C FF FF FF E8 A2 C3
Stack (0032E4A8h):
0032E488h: 00000000 FFFFFD34 000002E4 FFFFFD34
0032E498h: 000002CC 00000019 00000000 6C81B5AC
0032E4A8h: 6C87F0D7 0032F510 0032E748 0032E4C4
0032E4B8h: 0032F510 6C81B57E 0032F51C 0032E4F0
0032E4C8h: 6C87939D 6C81B57E 0032F510 00000100
0032E4D8h: 0032E548 6C87908B DEAF586F 6C89A954
0032E4E8h: 0032F510 00000001 0032E558 6C87E793
0032E4F8h: 0032F510 6C89A954 6C81B57E 00000000
0032E508h: 00000100 DEAF59EF 6C89A940 0032F510
0032E518h: 6C89A920 0032EB20 00000000 00000000
0032E528h: 00000000 00000000 0032E51C 0032F458
0032E538h: 6C87E581 6C81B57E 0032E50C 0032E06C
0032E548h: 0032E674 6C87AD00 B214D6FF 00000001
0032E558h: 0032E588 6C87EB1A 0032E748 0032F510
0032E568h: 00000001 6C89A954 00000000 00000100
0032E578h: 0032F510 0032E71C 6C89A954 00000000
0032E588h: 0032E5EC 6C87EEA5 0032E748 0032E798
0032E598h: 0032E71C 6C89A954 00E8297C 00000000
0032E5A8h: 00000000 E06D7363 1FFFFFFF 19930522
0032E5B8h: 77DBE0F2 00000011 00000000 6C89A940
Registers:
EAX: 00000000, EBX: 0032F4A8, ECX: 0032E4D8, EDX: 0000001D
ESI: 0764FDB4, EDI: 0032F510, EBP: 0032F51C, ESP: 0032E4A8
Crash location:
Module: foo_uie_wsh_panel_mod
Offset: B5ACh
Loaded modules:
foobar2000 loaded at 00D00000h - 00EF2000h
ntdll loaded at 77D90000h - 77F10000h
kernel32 loaded at 77090000h - 77190000h
KERNELBASE loaded at 77230000h - 77276000h
snxhk loaded at 736F0000h - 73724000h
COMCTL32 loaded at 75330000h - 754CE000h
msvcrt loaded at 77510000h - 775BC000h
GDI32 loaded at 75960000h - 759F0000h
USER32 loaded at 77790000h - 77890000h
ADVAPI32 loaded at 77280000h - 77320000h
sechost loaded at 77940000h - 77959000h
RPCRT4 loaded at 767D0000h - 768C0000h
SspiCli loaded at 75900000h - 75960000h
CRYPTBASE loaded at 758F0000h - 758FC000h
LPK loaded at 767C0000h - 767CA000h
USP10 loaded at 77190000h - 7722D000h
SHLWAPI loaded at 77890000h - 778E7000h
DSOUND loaded at 6C6B0000h - 6C722000h
ole32 loaded at 773B0000h - 7750C000h
WINMM loaded at 754D0000h - 75502000h
POWRPROF loaded at 6C680000h - 6C6A5000h
SETUPAPI loaded at 76A70000h - 76C0D000h
CFGMGR32 loaded at 76E10000h - 76E37000h
OLEAUT32 loaded at 77670000h - 776FF000h
DEVOBJ loaded at 769E0000h - 769F2000h
UxTheme loaded at 75220000h - 752A0000h
SHELL32 loaded at 759F0000h - 76639000h
zlib1 loaded at 5A4C0000h - 5A4D4000h
shared loaded at 6DE20000h - 6DE4B000h
imagehlp loaded at 77640000h - 7766A000h
dbghelp loaded at 74130000h - 7421B000h
COMDLG32 loaded at 775C0000h - 7763B000h
Secur32 loaded at 739F0000h - 739F8000h
CRYPT32 loaded at 768C0000h - 769DC000h
MSASN1 loaded at 77D60000h - 77D6C000h
gdiplus loaded at 74E50000h - 74FE0000h
IMM32 loaded at 76F10000h - 76F70000h
MSCTF loaded at 76E40000h - 76F0C000h
prio32 loaded at 10000000h - 10006000h
DockShellHook loaded at 02BB0000h - 02C88000h
CLBCatQ loaded at 77700000h - 77783000h
MMDevApi loaded at 69F60000h - 69F99000h
PROPSYS loaded at 75100000h - 751F5000h
dwmapi loaded at 75200000h - 75213000h
foo_prettypop loaded at 02AC0000h - 02B11000h
MSCOREE loaded at 6DCC0000h - 6DD0A000h
MSVCR80 loaded at 74B70000h - 74C0B000h
msvcm80 loaded at 6DBD0000h - 6DC4D000h
mscoreei loaded at 6DB60000h - 6DBC6000h
mscorwks loaded at 688F0000h - 68E9A000h
profapi loaded at 74220000h - 7422B000h
mscorlib.ni loaded at 67DF0000h - 688E8000h
mscorjit loaded at 6DB00000h - 6DB5B000h
CRYPTSP loaded at 73560000h - 73576000h
rsaenh loaded at 73520000h - 7355B000h
foo_fileops loaded at 6DAB0000h - 6DAF7000h
foo_out_ks loaded at 02D20000h - 02D4A000h
foo_uie_lyrics3 loaded at 06950000h - 06A50000h
WININET loaded at 76F90000h - 77085000h
urlmon loaded at 76640000h - 76776000h
iertutil loaded at 76C10000h - 76E0D000h
MSIMG32 loaded at 74FF0000h - 74FF5000h
foo_quicksearch loaded at 6DA50000h - 6DAA7000h
WindowsCodecs loaded at 75000000h - 750FB000h
foo_input_std loaded at 6D8E0000h - 6DA49000h
foo_tagbox loaded at 04640000h - 046C0000h
foo_out_wasapi loaded at 031B0000h - 031D6000h
foo_uie_albumlist loaded at 03460000h - 034A3000h
foo_masstag loaded at 04360000h - 043B4000h
foo_dsp_std loaded at 6D890000h - 6D8D8000h
foo_out_asio loaded at 044F0000h - 04526000h
foo_quicktag loaded at 6D780000h - 6D7B4000h
foo_rgscan loaded at 6D730000h - 6D77B000h
foo_discogs loaded at 6D6C0000h - 6D723000h
foo_audioscrobbler loaded at 06800000h - 06833000h
foo_ui_std loaded at 6D4A0000h - 6D5B9000h
foo_uie_vis_peakmeter_spectrum loaded at 06A60000h - 06A9F000h
foo_uie_wsh_panel_mod loaded at 6C810000h - 6C8B7000h
foo_run loaded at 06DB0000h - 06E0F000h
foo_albumlist loaded at 6C7B0000h - 6C80D000h
foo_httpcontrol loaded at 6C610000h - 6C67D000h
WS2_32 loaded at 76780000h - 767B5000h
NSI loaded at 76F70000h - 76F76000h
WSOCK32 loaded at 75770000h - 75777000h
MPR loaded at 73680000h - 73692000h
foo_cdda loaded at 6D450000h - 6D49E000h
foo_dsp_span loaded at 6D690000h - 6D6BE000h
foo_wlm loaded at 6D610000h - 6D631000h
foo_ui_columns loaded at 07D00000h - 07E8E000h
foo_unpack loaded at 6D140000h - 6D16E000h
foo_uie_playlists_dropdown loaded at 06E60000h - 06E9C000h
foo_queuecontents loaded at 073C0000h - 0742D000h
foo_textdisplay loaded at 6CCC0000h - 6CD0B000h
foo_playcount loaded at 6C5D0000h - 6C60E000h
foo_freedb2 loaded at 6C590000h - 6C5D0000h
foo_stop_after_queue loaded at 6D870000h - 6D888000h
foo_uie_panel_splitter loaded at 074A0000h - 074F9000h
foo_tlbRC loaded at 07140000h - 07167000h
foo_wave_seekbar loaded at 6C3F0000h - 6C58E000h
foo_keep_queue loaded at 6E1B0000h - 6E1BF000h
MSVCR90 loaded at 74320000h - 743C3000h
AUDIOSES loaded at 69D50000h - 69D86000h
apphelp loaded at 736A0000h - 736EB000h
DropboxExt.14 loaded at 07610000h - 07627000h
MSVCP71 loaded at 7C3A0000h - 7C41B000h
MSVCR71 loaded at 7C340000h - 7C396000h
EhStorShell loaded at 727C0000h - 727F1000h
GROOVEEX loaded at 72D00000h - 7310A000h
MSVCP90 loaded at 74290000h - 7431E000h
ATL90 loaded at 74640000h - 7466B000h
office loaded at 701A0000h - 705AF000h
GrooveIntlResource loaded at 6F930000h - 70194000h
ntshrui loaded at 6F850000h - 6F8BF000h
srvcli loaded at 73950000h - 73969000h
cscapi loaded at 740B0000h - 740BB000h
slc loaded at 72980000h - 7298A000h
SXS loaded at 6F700000h - 6F75F000h
frontend_direct2d loaded at 6C190000h - 6C1E7000h
d2d1 loaded at 6B8F0000h - 6B9BF000h
frontend_direct3d9 loaded at 6B880000h - 6B8E3000h
d3d9 loaded at 6AB20000h - 6ACE3000h
VERSION loaded at 75760000h - 75769000h
d3d8thk loaded at 6E1A0000h - 6E1A6000h
d3dx9_42 loaded at 6A680000h - 6A865000h
SciLexer loaded at 6B500000h - 6B591000h
AhAScr loaded at 6CCA0000h - 6CCC0000h
aswCmnBS loaded at 757A0000h - 757EE000h
aswCmnOS loaded at 75780000h - 7579A000h
aswCmnIS loaded at 743D0000h - 743F9000h
Aavm4h loaded at 73E80000h - 73ED2000h
PSAPI loaded at 76F80000h - 76F85000h
AavmRpch loaded at 73E60000h - 73E73000h
ashBase loaded at 74260000h - 7428F000h
aswEngLdr loaded at 74250000h - 7425D000h
USERENV loaded at 74230000h - 74247000h
ashTask loaded at 73FD0000h - 73FF6000h
aswAux loaded at 74000000h - 740A8000h
aswProperty loaded at 73EE0000h - 73F13000h
jscript loaded at 6CBE0000h - 6CC92000h
aswJsFlt loaded at 6CBC0000h - 6CBD9000h
RpcRtRemote loaded at 73DF0000h - 73DFE000h
wshom loaded at 6C3C0000h - 6C3E1000h
ScrRun loaded at 6C390000h - 6C3BA000h
tiptsf loaded at 745E0000h - 74638000h
System.ni loaded at 664F0000h - 66C89000h
System.Drawing.ni loaded at 6A4F0000h - 6A677000h
System.Windows.Forms.ni loaded at 652F0000h - 65ECE000h
mswsock loaded at 73850000h - 7388C000h
wshtcpip loaded at 73730000h - 73735000h
explorerframe loaded at 6C220000h - 6C38F000h
DUser loaded at 6C1F0000h - 6C21F000h
DUI70 loaded at 6ACF0000h - 6ADA2000h
avrt loaded at 6C160000h - 6C167000h
wship6 loaded at 745A0000h - 745A6000h
DNSAPI loaded at 73800000h - 73844000h
IPHLPAPI loaded at 737E0000h - 737FC000h
WINNSI loaded at 737D0000h - 737D7000h
rasadhlp loaded at 737C0000h - 737C6000h
msxml3 loaded at 6C020000h - 6C152000h
fwpuclnt loaded at 73740000h - 73778000h
ntmarta loaded at 752E0000h - 75301000h
WLDAP32 loaded at 778F0000h - 77935000h
RASAPI32 loaded at 728D0000h - 72922000h
rasman loaded at 73160000h - 73175000h
rtutils loaded at 73150000h - 7315D000h
sensapi loaded at 74550000h - 74556000h
Normaliz loaded at 76A00000h - 76A03000h
NLAapi loaded at 73890000h - 738A0000h
winrnr loaded at 737B0000h - 737B8000h
mlang loaded at 72790000h - 727BE000h
napinsp loaded at 737A0000h - 737B0000h
pnrpnsp loaded at 73780000h - 73792000h
msls31 loaded at 72A20000h - 72A4A000h
XmlLite loaded at 6CAB0000h - 6CADF000h
LINKINFO loaded at 6CAE0000h - 6CAE9000h
SearchFolder loaded at 6AA80000h - 6AB1F000h
StructuredQuery loaded at 6F5F0000h - 6F64C000h
thumbcache loaded at 66C90000h - 66CA6000h
SHDOCVW loaded at 73120000h - 7314E000h
ieframe loaded at 71AD0000h - 7254F000h
OLEACC loaded at 74560000h - 7459C000h
samcli loaded at 74420000h - 7442F000h
SAMLIB loaded at 6B860000h - 6B872000h
netutils loaded at 73970000h - 73979000h
NetworkExplorer loaded at 6A100000h - 6A298000h
drprov loaded at 705C0000h - 705C8000h
WINSTA loaded at 739A0000h - 739C9000h
ntlanman loaded at 6AE20000h - 6AE34000h
davclnt loaded at 6AE00000h - 6AE16000h
DAVHLPR loaded at 6E0A0000h - 6E0A8000h
wkscli loaded at 740C0000h - 740CF000h
NetworkItemFactory loaded at 6DE90000h - 6DE9D000h
dtsh loaded at 6D680000h - 6D68B000h
FirewallAPI loaded at 746F0000h - 74766000h
PortableDeviceApi loaded at 6A920000h - 6A9A9000h
wbemprox loaded at 6D180000h - 6D18A000h
wbemcomn loaded at 6A3E0000h - 6A43C000h
WINTRUST loaded at 77960000h - 7798D000h
PortableDeviceTypes loaded at 6A8F0000h - 6A91B000h
npmproxy loaded at 6F8C0000h - 6F8C8000h
EhStorAPI loaded at 6A3B0000h - 6A3D2000h
FunDisc loaded at 6A330000h - 6A35B000h
ATL loaded at 6ADE0000h - 6ADF4000h
msxml6 loaded at 6C8C0000h - 6CA17000h
fdproxy loaded at 6C7A0000h - 6C7AA000h
fdwcn loaded at 6A310000h - 6A327000h
wcnapi loaded at 6A2F0000h - 6A309000h
fdWNet loaded at 6B830000h - 6B839000h
dfscli loaded at 6B4F0000h - 6B4FD000h
browcli loaded at 6AA70000h - 6AA7D000h
ieproxy loaded at 6F650000h - 6F67B000h
dhcpcsvc6 loaded at 745D0000h - 745DD000h
dhcpcsvc loaded at 745B0000h - 745C2000h
actxprxy loaded at 6E030000h - 6E07E000h
zipfldr loaded at 6A0A0000h - 6A0F2000h
IconCodecService loaded at 72970000h - 72976000h
nvd3dum loaded at 64940000h - 652E9000h
Stack dump analysis:
Address: 6C87F0D7h (foo_uie_wsh_panel_mod+6F0D7h), symbol: "foobar2000_get_interface" (+36A37h)
Address: 6C81B57Eh (foo_uie_wsh_panel_mod+B57Eh)
Address: 6C87939Dh (foo_uie_wsh_panel_mod+6939Dh), symbol: "foobar2000_get_interface" (+30CFDh)
Address: 6C87908Bh (foo_uie_wsh_panel_mod+6908Bh), symbol: "foobar2000_get_interface" (+309EBh)
Address: 6C89A954h (foo_uie_wsh_panel_mod+8A954h), symbol: "foobar2000_get_interface" (+522B4h)
Address: 6C87E793h (foo_uie_wsh_panel_mod+6E793h), symbol: "foobar2000_get_interface" (+360F3h)
Address: 6C89A940h (foo_uie_wsh_panel_mod+8A940h), symbol: "foobar2000_get_interface" (+522A0h)
Address: 6C89A920h (foo_uie_wsh_panel_mod+8A920h), symbol: "foobar2000_get_interface" (+52280h)
Address: 6C87E581h (foo_uie_wsh_panel_mod+6E581h), symbol: "foobar2000_get_interface" (+35EE1h)
Address: 6C87AD00h (foo_uie_wsh_panel_mod+6AD00h), symbol: "foobar2000_get_interface" (+32660h)
Address: 6C87EB1Ah (foo_uie_wsh_panel_mod+6EB1Ah), symbol: "foobar2000_get_interface" (+3647Ah)
Address: 6C87EEA5h (foo_uie_wsh_panel_mod+6EEA5h), symbol: "foobar2000_get_interface" (+36805h)
Address: 00E8297Ch (foobar2000+18297Ch)
Address: 77DBE0F2h (ntdll+2E0F2h), symbol: "RtlAllocateHeap" (+ACh)
Address: 6C89A950h (foo_uie_wsh_panel_mod+8A950h), symbol: "foobar2000_get_interface" (+522B0h)
Address: 6C87F09Eh (foo_uie_wsh_panel_mod+6F09Eh), symbol: "foobar2000_get_interface" (+369FEh)
Address: 6C87907Bh (foo_uie_wsh_panel_mod+6907Bh), symbol: "foobar2000_get_interface" (+309DBh)
Address: 77E00AE5h (ntdll+70AE5h), symbol: "WinSqmSetIfMaxDWORD" (+35h)
Address: 77DD6AC9h (ntdll+46AC9h), symbol: "RtlDosSearchPath_Ustr" (+ADAh)
Address: 77DD6ADDh (ntdll+46ADDh), symbol: "RtlDosSearchPath_Ustr" (+AEEh)
Address: 77DD6A9Bh (ntdll+46A9Bh), symbol: "RtlDosSearchPath_Ustr" (+AACh)
Address: 6C88A5C0h (foo_uie_wsh_panel_mod+7A5C0h), symbol: "foobar2000_get_interface" (+41F20h)
Address: 77DD6A3Dh (ntdll+46A3Dh), symbol: "RtlDosSearchPath_Ustr" (+A4Eh)
Address: 69D59E29h (AUDIOSES+9E29h), symbol: "DllGetClassObject" (+5401h)
Address: 69D59E40h (AUDIOSES+9E40h), symbol: "DllGetClassObject" (+5418h)
Address: 69D56350h (AUDIOSES+6350h), symbol: "DllGetClassObject" (+1928h)
Address: 77DA010Fh (ntdll+1010Fh), symbol: "KiUserExceptionDispatcher" (+Fh)
Address: 7723B9BCh (KERNELBASE+B9BCh), symbol: "RaiseException" (+58h)
Address: 00E82C94h (foobar2000+182C94h)
Address: 00D08335h (foobar2000+8335h)
Address: 00E38CE1h (foobar2000+138CE1h)
Address: 00D0848Fh (foobar2000+848Fh)
Address: 6C892308h (foo_uie_wsh_panel_mod+82308h), symbol: "foobar2000_get_interface" (+49C68h)
Address: 00E3D30Dh (foobar2000+13D30Dh)
Address: 00D22A54h (foobar2000+22A54h)
Address: 07E011C4h (foo_ui_columns+1011C4h), symbol: "foobar2000_get_interface" (+4B7B4h)
Address: 00E6C830h (foobar2000+16C830h)
Address: 00D99646h (foobar2000+99646h)
Address: 00DAB995h (foobar2000+AB995h)
Address: 00D2DD58h (foobar2000+2DD58h)
Address: 6C848C3Eh (foo_uie_wsh_panel_mod+38C3Eh), symbol: "foobar2000_get_interface" (+59Eh)
Address: 6C848C99h (foo_uie_wsh_panel_mod+38C99h), symbol: "foobar2000_get_interface" (+5F9h)
Address: 00D9A3AEh (foobar2000+9A3AEh)
Address: 6C82C6D9h (foo_uie_wsh_panel_mod+1C6D9h)
Address: 00EA6CD8h (foobar2000+1A6CD8h)
Address: 6C888FD8h (foo_uie_wsh_panel_mod+78FD8h), symbol: "foobar2000_get_interface" (+40938h)
Address: 77683E75h (OLEAUT32+13E75h), symbol: "DispCallFunc" (+A6h)
Address: 77683CEFh (OLEAUT32+13CEFh), symbol: "LoadRegTypeLib" (+AC1h)
Address: 7767F958h (OLEAUT32+F958h), symbol: "VarBstrCmp" (+A0h)
Address: 77684037h (OLEAUT32+14037h), symbol: "DispCallFunc" (+268h)
Address: 77683D76h (OLEAUT32+13D76h), symbol: "LoadRegTypeLib" (+B48h)
Address: 6C81EC6Bh (foo_uie_wsh_panel_mod+EC6Bh)
Address: 6CBFDB58h (jscript+1DB58h), symbol: "DllGetClassObject" (+CA64h)
Address: 6CBF0B04h (jscript+10B04h)
Address: 6CBFDAACh (jscript+1DAACh), symbol: "DllGetClassObject" (+C9B8h)
Address: 6CBFDA1Fh (jscript+1DA1Fh), symbol: "DllGetClassObject" (+C92Bh)
Address: 77685D03h (OLEAUT32+15D03h), symbol: "LHashValOfNameSysA" (+35Eh)
Address: 6CBFE0D0h (jscript+1E0D0h), symbol: "DllGetClassObject" (+CFDCh)
Address: 6CBFDBAAh (jscript+1DBAAh), symbol: "DllGetClassObject" (+CAB6h)
Address: 6CBFD8E8h (jscript+1D8E8h), symbol: "DllGetClassObject" (+C7F4h)
Address: 6CBF51BAh (jscript+151BAh), symbol: "DllGetClassObject" (+40C6h)
Address: 6CBE9B9Eh (jscript+9B9Eh)
Address: 64CDEE9Ah (nvd3dum+39EE9Ah), symbol: "QueryOglResource" (+F25Ah)
Address: 64CE4752h (nvd3dum+3A4752h), symbol: "QueryOglResource" (+14B12h)
Address: 6CBF0001h (jscript+10001h)
Address: 6CBFF1DEh (jscript+1F1DEh), symbol: "DllGetClassObject" (+E0EAh)
Address: 64CF00F4h (nvd3dum+3B00F4h), symbol: "QueryOglResource" (+204B4h)
Address: 6CC76BA4h (jscript+96BA4h), symbol: "DllRegisterServer" (+19B83h)
Address: 6CBF5CBDh (jscript+15CBDh), symbol: "DllGetClassObject" (+4BC9h)
Address: 773F37D9h (ole32+437D9h), symbol: "CoGetComCatalog" (+458h)
Address: 6CBF5C1Bh (jscript+15C1Bh), symbol: "DllGetClassObject" (+4B27h)
Address: 773F8863h (ole32+48863h), symbol: "CoRevokeInitializeSpy" (+5C9h)
Address: 773F393Eh (ole32+4393Eh), symbol: "CoGetComCatalog" (+5BDh)
Address: 6CBF79C1h (jscript+179C1h), symbol: "DllGetClassObject" (+68CDh)
Address: 6CBF5E31h (jscript+15E31h), symbol: "DllGetClassObject" (+4D3Dh)
Address: 6CBEF416h (jscript+F416h)
Address: 77DBE38Ch (ntdll+2E38Ch), symbol: "RtlInitUnicodeString" (+164h)
Address: 6CC064FDh (jscript+264FDh), symbol: "DllGetClassObject" (+15409h)
Address: 6CBEEA52h (jscript+EA52h)
Address: 6CBEA1BCh (jscript+A1BCh)
Address: 6CBEA107h (jscript+A107h)
Address: 6CBEF620h (jscript+F620h)
Address: 6CBE966Eh (jscript+966Eh)
Address: 6C81B558h (foo_uie_wsh_panel_mod+B558h)
Address: 6C894790h (foo_uie_wsh_panel_mod+84790h), symbol: "foobar2000_get_interface" (+4C0F0h)
Environment:
App: foobar2000 v1.1.8
OS: Windows 6.1.7600 x64
CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 5200+, features: 3DNow!ex MMX SSE SSE2 SSE3
Audio: Speakers (Saffire Audio)
UI: Columns UI 0.3.8.7
Components:
Core (2011-09-14 09:11:28 UTC)
foobar2000 core 1.1.8
foo_albumlist.dll (2011-09-14 09:09:52 UTC)
Album List 4.5
foo_audioscrobbler.dll (2011-05-02 23:48:11 UTC)
Audioscrobbler 1.4.7
foo_cdda.dll (2011-09-14 09:09:40 UTC)
CD Audio Decoder 3.0
foo_discogs.dll (2011-08-13 15:44:57 UTC)
Discogs Tagger 1.30
foo_dsp_span.dll (2011-02-18 18:51:02 UTC)
Surround Pan 1.3
foo_dsp_std.dll (2011-09-14 09:10:12 UTC)
Standard DSP Array 1.0
foo_fileops.dll (2011-09-14 09:08:24 UTC)
File Operations 2.1.3
foo_freedb2.dll (2011-09-14 09:08:22 UTC)
freedb Tagger 0.6.4
foo_httpcontrol.dll (2011-08-22 13:14:20 UTC)
HTTP Control 0.97.12
foo_input_std.dll (2011-09-20 17:21:14 UTC)
Standard Input Array 1.0
foo_keep_queue.dll (2011-05-18 02:29:12 UTC)
Keep Queue 0.3.5
foo_masstag.dll (2011-02-09 19:18:10 UTC)
Masstagger 1.8.4
foo_out_asio.dll (2011-02-09 19:18:16 UTC)
ASIO support 1.2.7
foo_out_ks.dll (2011-09-05 01:16:23 UTC)
Kernel Streaming Output 1.2.2
foo_out_wasapi.dll (2011-02-09 19:18:25 UTC)
WASAPI output support 2.1
foo_playcount.dll (2011-07-14 14:02:18 UTC)
Playback Statistics 3.0.2
foo_prettypop.dll (2011-08-28 16:34:35 UTC)
Pretty Popup 1.2.5
foo_queuecontents.dll (2011-09-15 14:48:30 UTC)
Queue Contents Editor 0.4.5
foo_quicksearch.dll (2011-06-03 19:51:15 UTC)
Quick Search Toolbar 3.2
foo_quicktag.dll (2011-02-09 19:18:33 UTC)
Quick Tagger 1.0.3
foo_rgscan.dll (2011-09-14 09:09:32 UTC)
ReplayGain Scanner 2.1.2
foo_run.dll (2011-06-07 17:38:41 UTC)
Run services 0.3.7
foo_stop_after_queue.dll (2011-04-18 20:19:55 UTC)
Stop After Queue 0.1
foo_tagbox.dll (2011-03-17 21:47:47 UTC)
TagBox 0.212
foo_textdisplay.dll (2011-06-03 20:13:44 UTC)
Text Display UI Element 1.1 beta 1
foo_tlbRC.dll (2009-05-04 23:44:34 UTC)
TLB Remote Control 3.0
foo_ui_columns.dll (2011-02-09 19:18:43 UTC)
Columns UI 0.3.8.7
foo_ui_std.dll (2011-09-14 09:09:46 UTC)
Default User Interface 0.9.5
foo_uie_albumlist.dll (2011-02-28 22:30:56 UTC)
Album list panel 0.3.5
foo_uie_lyrics3.dll (2011-10-09 23:50:57 UTC)
Lyric Show Panel 3 0.1.4
foo_uie_panel_splitter.dll (2011-02-19 19:39:04 UTC)
Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_playlists_dropdown.dll (2011-05-25 02:20:44 UTC)
Playlists Dropdown 0.7.6
foo_uie_vis_peakmeter_spectrum.dll (2011-02-19 22:31:09 UTC)
Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_uie_wsh_panel_mod.dll (2010-06-19 15:52:06 UTC)
WSH Panel Mod 1.3.6
foo_unpack.dll (2011-09-14 09:09:06 UTC)
ZIP/GZIP/RAR Reader 1.6
foo_wave_seekbar.dll (2011-09-30 12:42:42 UTC)
Waveform seekbar 0.2.13.13
foo_wlm.dll (2011-02-27 22:01:51 UTC)
Windows Live Messenger Notifier 1.1.8a
Recent events:
Audioscrobbler: Submission succeeded.
Opening track for playback: "D:\Desktop\Mp3\Alice In Chains\Mp3\Albums\1992 - Dirt\Alice In Chains - 13. Would.mp3"
Audioscrobbler: Submitting track...
Opening track for playback: "D:\Desktop\Mp3\Alice In Chains\Mp3\Albums\1995 - Alice In Chains\Alice In Chains - 01. Grind.mp3"
Wave cache: finished analysis of "D:\Desktop\Mp3\Alice In Chains\Mp3\Albums\1995 - Alice In Chains\Alice In Chains - 02. Brush Away.mp3"
WSH Panel Mod (GUID: AE664E54-40B4-4288-9423-88FEB9A327FA): Unhandled C++ Exception: "The handle is invalid. (0x80070006)", will crash now...
Additional Info:
==> IDispatch::Invoke: flag="DISPATCH_PROPERTYPUT", name="Volume", uuid="BAE2E084-6545-4A17-9795-1496A4EE2741"
hi,
first, you pollute the thread with such long post, the good way is to use [ codebox ] ... [ /codebox ] balises instead of [ code ] [ /code ]
bad topic, you should post that to the WSH panel mod developer topic : http://www.hydrogenaudio.org/forums/index....c=70363&hl= (http://www.hydrogenaudio.org/forums/index.php?showtopic=70363&hl=)
then i see :
WSH Panel Mod 1.3.6
so, you should try the last version v1.4.4 which may fix your issue?
HTH
Sorry, i`m a newbie in wsh coding, but i learning
i wrote some function:
function HomePage() {
var icon_test;
icon_test = gdi.CreateImage(60, 60);
gp = icon_test.GetGraphics();
gp.fillroundrect(1,1,58,58,3,3,RGB(0,0,0));
icon_test.ReleaseGraphics(gp);
CollectGarbage();
var icon_test_h;
icon_test_h = gdi.CreateImage(60, 60);
gp = icon_test_h.GetGraphics();
gp.fillroundrect(1,1,58,58,3,3,RGB(50,50,50));
icon_test_h.ReleaseGraphics(gp);
CollectGarbage();
var icon_test_c;
gp.fillroundrect(1,1,58,58,3,3,RGB(150,150,150));
CollectGarbage();
function btn_image(regular,hover,click) {
this.regular=regular;
this.hover=hover;
this.click=click;
hp_buttons_temp={
b1:new btn_image(icon_test,icon_test_h,icon_test_c),
b2:new btn_image(icon_test,icon_test_h,icon_test_c)
my_hp_buttons_temp=new Array(
hp_buttons_temp.b1,
hp_buttons_temp.b2
hp_buttons=[];
for (var i in my_hp_buttons_temp ) {
hp_buttons.push(my_hp_buttons_temp[i]);
return hp_buttons;
could anybody explain me, why in other function, like on_paint, i cant draw like "hp_buttons[0].regular" or "hp_buttons[0].hover"?
is there some way to put this image in function Button(x,y,function etc)?
and one more question: i need to run some script when some usb-drive or cd is inserted, have wsh any callback for it, or some way to create it?
I have discovered v1.5 and I think it's really wonderful! I wanted to do a script to play the content of the active playlist in "Shuffle Sets" mode, and v1.5 contains everything needed to do it! :-)
The difference between the native Shuffle Albums and my Shuffle Sets mode is that Shuffle Sets uses a special "MEDLEY" tag that must be set to true when the track continues seamlessly with the next track (ie when there is no silence at the end of the current track and it is not the last track of a disc).
When the tracks are correctly tagged and Shuffle Sets is enabled, the script builds a temporary IFbMetadbHandleList containing the first track of each set. In on_playback_new_track, it verifies if the current track is the last one in a set, and if it's the case, it selects another set in the temp list, and adds it to the playback queue. When a set is played, it is removed from the temp list, and when the list is empty, the playback stops.
I have 3 questions.
1. My script works already well, but I would like to be able to save the temp list to disc when foobar is closed, to be able to continue the shuffle when it is restarted. I haven't found a way to save a IFbMetadbHandleList to disc (and to reload it, of course). Is it possible?
2. Also, currently, to begin the playback of a specific item of the current playlist when foobar is not already playing something, I have to clear the playback queue, add the item to the queue, and call fb.Play(). That works well, but I wonder if it is possible to play an item from the active playlist without having to add it to the playback queue first. I would like something like plman.PlayItem(playlist, item), but afaik that command doesn't exist. Is it a way to do it?
(BTW, I suppose it is possible to set fb.PlayingPlaylist=playlist, and change the currently focussed item to the item to play, and finally call Play(). But it's not a better solution, as I don't like to change the focus.)
3. My script has a function that tries to add automatically the "MEDLEY" tags in the items of the active playlist. It works relatively well, but the method I use is somewhat cumbersome. It is necessary to add and configure the Skip Silence DSP manually, and the script plays the last 5 seconds of each track, and detects in on_playback_time() if the DSP has skipped some seconds. I don't like the fact that it is necessary to reconfigure the DSP chain, and, more importantly, the function fails to detect the silence if it is too short. Furthermore, when the playlist contains many tracks, foobar2000 crashes sometimes. I don't know why.
Do you think there is a better method? Do you know a DSP or extension that could tag the currently playing item when the overall volume of the last second is below a certain threshold?
Thanks in advance.
you can get the path of a metadb handle so use that to build an m3u playlist and save it to file. (look at the interfaces doc)
i don't know about the other stuff.
Good idea. Thanks!
Good idea. Thanks!
Hum, sorry, but IMO that doesn't work. I can save the paths to a m3u (or an INI or text file) and reload them when I need them, but I have no way to rebuild a new IFbMetadbHandleList from the paths. Have I missed something?
you need to use the standard foobar methods of loading a playlist. i don't know what else you were thinking.
Well, I don't want to load the items in the GUI. The list is not a playlist accessible by the user, but just a "variable" maintained by my script internally. In other words, I just need the handles. I want to recreate the temp IFbMetadbHandleList from the path stored in the file, to remember what sets of the active playlist have not been played during the last foobar session, and continue to play them randomly.
I could of course load the m3u in a playlist, copy the playlist in the IFbMetadbHandleList, and delete the playlist. But it's slow, the playlist will probably appear in the GUI for a short time, and the method is not clean.
I was thinking that it should be possible to load some files from disc directly to an IFbMetadbHandleList. But I think now that it's probably not possible, as the files tags and properties must be parsed by foobar to create the handles. If that means that creating a playlist in the GUI is necessary, then there is no good solution, and I will have to create a temp playlist.
Anyway, thanks again for your suggestion.
I'm now trying to add a "Sort Playlist: Randomize by Sets" function to my script, but I can't get InsertPlaylistItems() to work.
The function gets the content of the current playlist in a IFbMetadbHandleList, then reorder that list by sets, empties the current playlist, and use InsertPlaylistItems() to replace the items of the IFbMetadbHandleList in the playlist. The first part works as expected, but when I use InsertPlaylistItems(), I have always a type mismatch error.
What are exactly the types of the arguments of InsertPlaylistItems(playlistIndex, base, handles, select = false) ?
I assume this:
UINT playlistIndex
UINT base
IFbMetadbHandleList handles
bool select
The comment about InsertPlaylistItems() in the doc says "Inserts new items into specified playlist, at specified position.", so I assume that base is the "specified position".
You can check the problem with this simplified code, that should duplicate all elements of the active playlist, but crashes:
var pl = plman.ActivePlaylist;
var all_handles = plman.GetPlaylistItems(pl);
plman.InsertPlaylistItems(pl, 0, all_handles);
Error message:
[13:51:37] Error: WSH Panel Mod ({8B5414E5-92F3-4BE8-BBB3-A7CF680847A7}): Microsoft JScript runtime error:
Type mismatch
Ln: 3, Col: 1
What am I doing wrong?
I have a few "requests" or how to say, I think these would be useful, and lack the knowledge to write them myself.
- last.fm tag cloud, or just listing of tags. Would be useful to quickly see what genre or subgenre to tag music by.
- last.fm comments, maybe with the option to choose between song, artist and album comments.
- last.fm recommended artists, listed with links to google or wiki pages.
- songmeanings.net comments?
I don't know though if these are even possible to do, or if they've already been done. If so I cannot find them, and would be happy to be pointed to the code.
@r0lZ:
What a shame, it's a bug, thanks for reporting...
@r0lZ:
Don't be ashamed; it's still a beta!
Anyway, I'm glad to help.
BTW, to remove all items in the playlist, currently, I do this:
plman.ClearPlaylistSelection(pl);
plman.SetPlaylistSelectionSingle(pl, 0, true);
plman.RemovePlaylistSelection(pl, true);
plman.RemovePlaylistSelection(pl, false);
Seems a bit complicated!
Can you add the functions RemovePlaylistItemRange(playlistIndex, from, num) and RemovePlaylistAllItems(playlistIndex) ?
Oh, another thing. I need to create an empty IFbMetadbHandleList, but I haven't found the way to do it. Currently, I need to retrieve the list from any playlist, and remove all elements from the list.
Is this supposed to work?
handles = new IFbMetadbHandleList();
It produces the error: 'IFbMetadbHandleList' is undefined
[EDIT] Sorry, I've found the way to create an empty list:
handles = fb.GetSelections(0);
Yo marc2003!!!
I have a question for the thumbs WHS script from your samples.
I want to add an custom folder but it doesn't work...
...i tryed
E:\foobar 2000\lastfm\artist\%artist%*.*
.\lastfm\artist\%artist%*.*
...please help me
will not always create a empty list, it might include the now playing item inside this list.
handles = fb.GetSelections(1);
is more reasonable.
Looking for a simple script to list the playback queue in a WSH panel.
I've found 2 components but they kinda suck. Any suggestions solutions?
Never mind. I'm sorry, my friend is silly. Ignore me.
is more reasonable.
You're right. fb.GetSelections(0) returns the playing item. I've tested the function when foobar was not playing. Thanks for the tip!
But GetSelections(1) returns the active playlist selection, and therefore the playing item, or more items! It is not suitable either.
So, it seems that is not possible to create an empty list with a single instruction. I will have to use my old and cumbersome method. :-(
@Jango, it's just the path to a folder. don't use wildcards as it automatically reads all images.
should work.
Sorry i explained it wrong to you.
I use the Biography View 0.4.2.4 (foo_uie_biography) to download my bio and the artist pictures.
everything is downloadet in to one folder in the foobar directory...
... E:\foobar 2000\lastfm\artist\
...would it be possible to edit the script a litle bit to support the foo_uie_biography
grouping and naming scheme.
Thank You!
i'm not modifying the script to use the same filename patterns as the biography component. it can already download images from last.fm by itself so it seems rather pointless using the 2 in combination. pick one or the other.
I need to retrieve the handle of the first item in the playback queue, but currently I can't do it.
Not sure how to use GetPlaybackQueueContents(), but this code prints nothing in the console, even when there are items in the queue.
if (plman.IsPlaybackQueueActive()) {
var arr = plman.GetPlaybackQueueContents();
fb.trace(arr.length);
The returned VBArray seems always undefined or empty.
What's wrong with that code?
you typically need to use toArray() whenever VBarray is mentioned in the docs. try this....
var arr = plman.GetPlaybackQueueContents().toArray();
Yeah, that works! Thanks!
not tested yet, but according to the doc, it's maybe an array of handles, so you can't display the content, it will always display nothing. Use APi from the doc to get idenx of an handle or try to browse the array to find an handle by using .Compare() method.
Thanks for the precision, but it's exactly what I had the intention to do.
ie, my code will be something like this:
var handle = plman.GetPlaybackQueueContents().toArray()[0].Handle;
// then I use fb.TitleFormat to get the content of the handle.
Marc2003, maximum respect for the CD Jewel Case script for WSH Panel Mod. Is there a similar script to show the rear CD artwork in a case?
Many thanks
Dan
i don't have any back images so it's not something i've ever considered.
Fair enough. I have rear images for most of my music. Would you be willing to tweak the script and create a rear image one too?
well i don't have a CD back template. if you can find one i might take a look.
and it won't be for a week or so. i'm away from home and don't really have the time at the moment.
if you don't need the template, simply use my artreader script (or default artwork panel) as they both have options to display the back image.
Hi Marc,
How about something like this:
(http://i54.tinypic.com/31775uu.jpg)
It's fairly basic but would nicely complement your front CD case script, and would look good when viewed together on the screen. The rear artwork would just sit inside the edges of the box. The user would be able to "trim" the spines of the image or have them showing.
Dan
Error message:
Type mismatch
Ln: 3, Col: 1
The InsertPlaylistItems() bug seems still present in beta 1, although the error message has changed:
[21:02:43] Error: WSH Panel Mod ({8B5414E5-92F3-4BE8-BBB3-A7CF680847A7}): Microsoft JScript runtime error:
Variable uses an Automation type not supported in JScript
Ln: 3, Col: 1
I still need some help.
I need to call fb.RunMainMenuCommand("Sort by File Path") to sort the whole playlist. But currently, the function launches the command from the Edit -> Selection -> Sort menu, instead of the same command from the Edit -> Sort menu (probably because WSHPM stops searching the command in the menus as soon as it is found).
Is it a way to specify from which menu the command should be launched?
For example with a path like this:
fb.RunMainMenuCommand("Edit/Sort/Sort by File Path");
I know that I can select everything before calling Sort by File Path, but I would prefer to leave the selection unchanged. Is it possible?
[EDIT] Forgive me!
It works just as I suggested!
For the "thumbs" script, can I get it to show images in the directory from the selected music file, rather than from a specified directory?
Excellent, many thanks! Is it possible to enlarge the images by clicking on them? At the moment it only enlarges them within the confines of the panel (which is fairly small). I'd like the ability to view them full size (without having to open containing folder and then click on them again).
when thumbnails are set to either left or bottom, single clicking the main image opens it in your default external viewer -when in grid mode you can right click and select "open this image".
Thanks. I don't get "open this image" - only "open containing folder" (in grid mode).
it only works on an enlarged image, not thumbnails.
also, when an image is enlarged, you can scroll using your mouse wheel to save clicking back and forth between thumbnails and enlarged images.
I see, thanks! It would be nice to be able to open the image without having to enlarge it first, maybe an option to add to the list
BW
Dan
just a note to say my samples now require WSH panel mod 1.5.0 or above.
http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
@danhackley, middle clicking a thumbnail in grid mode now opens it in an external viewer. middle click does not have any affect in any other mode.
I searched "amperstamp" but came up empty.
Just wondering where the fault is in parsing the & sign in artist names (and elsewhere). When using scripts which access last.fm or google, the amperstamp and anything after is dropped. So, as an example, Angus & Julia Stone becomes Angus and the wrong band shows up.
the term you wanted was ampersand. edit: i had a quick google and it seems amperstamp is a genuine term - sorry but i'd never heard of it before.
anyway, you want to be using encodeURIComponent on your variable.
edit2: just uploaded a fix for my samples. some panels would crash with radio streams (this only applies to the new version i uploaded earlier today- previous versions should be fine)
Quick question re. the show images in a directory script. When I add more images to the directory, the thumbnails listed do not update. Do I have to do anything to get them to update? Thanks!
there wasn't a practical way - you either had to open the editor and close it again or switch to a track with a different artist and back again. but i've just added a "re-scan folder" option to the context menu which should be easier.
Marc, I've stolen your InputBox code for one of my scripts, but I can't get it to work properly:
var vb = new ActiveXObject('ScriptControl');
vb.Language = 'VBScript';
function InputBox(message, title, value) {
message = message.replace(/"/g, '" + Chr(34) + "');
message = message.replace(/\n/g, '" + Chr(13) + "');
title = title.replace(/"/g, '" + Chr(34) + "');
value = value.replace(/"/g, '" + Chr(34) + "');
var temp_value = vb.eval("InputBox" + "(\"" + message + "\", \"" + title + "\", \"" + value + "\")");
return typeof temp_value == "undefined" ? value : temp_value.trim();
val = InputBox("This is a test", "test", "");
The
temp_value.trim() instruction crashes with the "Object doesn't support this property or method" error message. Seems the string returned by vb.eval() is not a regular string object.
However, InputBox() works fine in your autoplaylists script, so I suppose I've missed something in your code (or in common2.js), but I don't know what. Can you help?
And BTW, have you noticed that InputBox lets you type as many characters as you want, but it silently truncates the string after 254 characters? It's a real problem with some of my playlists. For example, the autoplaylist "Related to Hatfield and the North" needs this query (312 characters):
ARTIST HAS "Hatfield and the North" OR ALBUM ARTIST HAS "Hatfield and the North" OR COMPOSER HAS "Hatfield and the North" OR PERFORMER HAS "Hatfield and the North" OR COMMENT HAS "Hatfield and the North" OR DISCOGS_ALBUM_CREDITS HAS "Hatfield and the North" OR DISCOGS_TRACK_CREDITS HAS "Hatfield and the North"
Do you know a solution, or is it a VisualBasic limitation?
add this somewhere. (it's in the common file, you must have missed it)
String.prototype.trim = function() {
return this.replace(/^\s+|\s+$/g,"");
as for your 2nd question, sorry i have no idea. as a workaround, maybe you could just add
Hatfield and the North via the input box and have the script build the query to check all those different fields?
Thanks a lot! Yes, I've missed the prototype.
as for your 2nd question, sorry i have no idea. as a workaround, maybe you could just add Hatfield and the North via the input box and have the script build the query to check all those different fields?
It's exactly what I am doing. I have a "New 'Related to artist' autoplaylist" menu that duilds the playlist properties automatically. But if the user wants to edit it after its creation, the InputBox function truncates the query, and the playlist doesn't work any more.
I think I will create a GUI to get the playlist properties with AutoHotkey. It will need to read and write the arguments to a file (like your old input function did), but at least, there will be a single dialog for all parameters (and I can add "Force-sorted" and the options to add the playlist to the top or bottom of the list, to run it immediately and to remove the dupes in the same dialog). If you are interested, I can post it here when it will be ready...
Thats great thanks marc - what do I need to do to reinstall with that option - just re-load the new script or add other stuff as well? PS any further thoughts on the rear album jewel case?
BW
D
just re-importing the script should work in most cases. but if you ever see an error, always extract the marc2003 folder, overwrite the existing files and restart foobar before coming back here to report it.
as for this CD case thing, i'm not sure about it really. my main problem is the fact i have no idea what aspect the images are going to be. with the front it's easy to assume they're all square but i can't do that with the back. call me lazy but i find it hard to get motivated for something i'll never use myself.
@r0lZ, yup i'd be interested in seeing what you do.
OK, I will port the dialog and WSH script here, when they will be ready.
BTW, I have a new problem. I need to parse the file created by the autoplaylist dialog to put the playlist name, query, sort pattern and force-sorted flag in an array. The file has one line per argument. That works fine when the sort pattern is not empty, but when it is empty, this code doesn't work:
arr = filecontent.split(/\r?\n/g);
The empty line that corresponds to the sort pattern is skipped, the force-sorted flag is stored in arr[2] instead of arr[3] and arr[3] is undefined.
I have never really studied the regular expressions, and I have been unable to modify it to include empty elements in the array. Can you give me the correct regexpr syntax?
No worries marc. If you did consider it, you could assume that the rear covers are standard CD rear jewel case sizes. Maybe even have an option to choose CD (rectangular) or vinyl (square) rear art size.
WSH 1.4.4 is still listed as the current version (you say your scripts now need WSH panel mod v1.5).
@r0lZ, you're asking the wrong person. i don't know regex at all. everything used in my scripts was courtesy of mr google.
maybe ReadLine would work?
http://msdn.microsoft.com/en-us/library/h7...v=vs.85%29.aspx (http://msdn.microsoft.com/en-us/library/h7se9d4f%28v=vs.85%29.aspx)
@danhackley, i assume you're looking at the first post in the WSH panel mod thread? just follow the download link and you'll see 1.5.0 beta3 is available.
direct link: http://code.google.com/p/foo-wsh-panel-mod/downloads/list (http://code.google.com/p/foo-wsh-panel-mod/downloads/list)
marc, just tried your updated thumbs script. It crashes the window (error "scripting engine initialisation failed ... CODE 0x80020101).
Is this to do with the WSH panel mod version I have installed? Thanks!
Yes, ReadLine will certainly work, but split() is so smart! I would prefer it.
Another solution would be to swap the 3rd and 4th arguments. Only the sort pattern argument can be empty, and it will be easy to check if the last element of the array is undefined.
Thanks anyway.
my latest scripts absolutely require 1.5.0 beta3. it's not optional.
Thanks again marc - I installed the latest WSH panel mod (1.5.0 beta3 showing in list of installed components).
Still get the same error with your new thumbs script - error "scripting engine initialisation failed ... CODE 0x80020101.
Edit: works now, but i had to copy the new marc2003 folder to the foobar profile directory after all !
One other request - is it possible to have the script scan one folder higher if it doesn't find any art in the colder? E.g. if there is a folder structure
Arist - Album
- Disc 1
- Disc 2
And the images are in the root directory artist-album, could the script look there IF there are no images in the disc folders?
Marc - I've just figured out what was wrong with the thumbs script - it recognises only .jpg files, not .jpeg. Could you fix it to recognise .jpeg also? Thanks!
support for jpeg files added. this time the script hasn't changed - just files inside the marc2003 folder. so extract that and make sure you restart foobar.
you can use foobar title formatting to get to the parent folder
$replace($directory_path(%path%),\%directory%,)
Thanks again marc 2003. Where do I put that code?
Marc, I've finished the Autoplaylist Properties Dialog exe. You can download the source code and the exe here: http://www.4shared.com/file/Ufb_EfTk/Autop...tiesDialog.html (http://www.4shared.com/file/Ufb_EfTk/AutoplaylistPropertiesDialog.html)
(http://img208.imageshack.us/img208/4702/autoplprop.png) (http://imageshack.us/photo/my-images/208/autoplprop.png/)
The archive contains also a working WSH script, that demonstrates its usage, but currently, it displays only a simple menu when you left-click the panel. It should be easy to bind it to a button.
Note that the script uses hardcoded paths. The exe file must be placed in fb.ProfilePath\wsh_scripts\, and it saves the autoplaylist file in fb.ProfilePath\wsh_settings\ (but the script filename can be changed with the windows properties, for users who want to implement it in several panels).
Also, the autoplaylist file format is not compatible with your file format, because my script saves the force-sorted flag too. Anyway, the default filename is different.
Look at GetAutoplaylistProperties() in the WSH panel code and the comments in f2k_autoplaylist_dialog.ahk if you want to use the exe for your own code. If you need some minor modifications (such as removing the "do not add to list" option), let me know. I can recompile the exe easily...
@danhackley. you are kidding, right? i haven't told you to edit anything so where do you think it should go?
@r0lZ, thanks. that autohotkey thing looks interesting. i might have to learn that myself.
Well, it is wonderful to automate repetitive tasks that you cannot do easily manually, as it can control most application windows (and simulate clicks on precise controls, independently of the position and size of the window - something that most automation tools cannot do), but building GUIs is not as easy as it sounds (because they use fixed positions for everything), and the AutoHotkey language is terrible (with many discrepancies in the syntax, missing flow-control instructions, and so on). I much prefer jscript, but I use AutoHotkey to build simple GUIs and for its automation power.
Luckily, AutoHotkey_L is born. It is a new project, based on the source code of AutoHotkey, but maintained by other guys. They have already added the objects and real arrays, and there are plans to completely revamp the syntax of the language. Maybe one day it will become a really good language. Anyway, if you want to try it, be sure to download the AutoHotkey_L installer (here (http://www.autohotkey.net/~Lexikos/AutoHotkey_L/)).
well to be honest, i was only interested in making a unified input for Last.fm username and API key at the same time. i'm hoping that will be easy enough if i can dissect what you've done.
Yes, that should be easy. Feel free to ask for some help.
(http://dl.dropbox.com/u/22801321/lfm%20ahk.png)
done. here's the source if you wouldn't mind giving a quick look over. no comments but it's simple enough.
http://pastie.org/2769555 (http://pastie.org/2769555)
Seems OK. You learn quickly!
But you don't check if the user has typed something in both editboxes. IMO, you should add, in ButtonOK, something like this:
ButtonOK:
Gui, Submit, NoHide; get the content of the GUI, but do not hide it
if (username == "" || api_key == "") return
Of course, you can do better tests, for example test the length of the API key.
If you want to display easily simple error messages, you can add a status bar to your window, or use MsgBox.
In my script, I've opted for another solution: the OK button becomes active only when all required fields have some contents. Look at CheckGui:
And I've also used a powerful feature of AutoHotkey to force the window to be always on top of the Foobar window: DialogAlwaysOnTop:
But your script should work fine as it is.
[EDIT]
#SingleInstance force
is used to force a new instance to silently REPLACE the already running instance. Not sure it's what you want. It could be better to use
#SingleInstance ignore
With ignore, the first instance continues to run, and the second one doesn't open its window and exits immediately.
BTW, I wonder if it is possible to run an external app and grab what it writes to stdout from WSH. That would make the temp_file thing useless. (I know that, for your last.fm scripts, you need to write the two output files anyway, but for a more general usage, the possibility to grab the stdout channel could permit to write complex input dialogs with AutoHotkey, and get the values in your panel easily.)
Do you think it's possible? With WshShell.Exec() ?
i've had to ditch that autohotkey thing. it doesn't always write to file when clicking OK so it has to go.
as for capturing stdout with WSH, if you google i think you'll find pretty much everyone says write to file. i checked this ages ago - before i discovered the VBscript thing i'm currently using and that's fine for the simple values i use.
Strange. Are you sure it's an AutoHotkey problem? I have never had problems when writing a file (except the usual and normal 'access denied' or 'disc full' problems).
Oh, another thing: when passing the path to the wsh_settings dir via the command line, be sure to remove the tailing slash, or it will be interpreted as an escape character, and therefore removed, and replaced by the closing quotes. Another way to handle it is to double the backslash. For example:
"\"" + fb.FoobarPath + "\\\""
BTW, maybe you could change your output files to an unified INI file. Autohotkey and WSHPM have the functions to read and write them.
The VBscript method is elegant, but unfortunately, I had to find another way to edit the arguments, due to the 254 characters limitation of the InputBox. (And it's why I can't use INI files either, as the INI values are also limited to 256 characters or so. Pity!)
I'll stick with the current "temp file" method.
Oh, I have discovered several bugs in my Autoplaylist Properties Dialog script and in the demo script. I think I've fixed most of them, and I have improved the dialog (now, the edit boxes are ComboBoxes, with a dropdown menu with some useful default values) but this time I will check it carefully before updating the new version...
I have also a question about the Autoplaylist query syntax. I have an autoplaylists panel (foo_softplaylists, not written with WSHPM) that can maintain autoplaylists with a query that changes dynamically when the now playing track changes. For example, it can generates an autoplaylist with all titles in CDs by the currently playing artist, with this query:
%artist% HAS $nowplaying{%artist%} OR %album artist% HAS $nowplaying{%artist%} OR %artist% HAS $nowplaying{%album artist%} OR %album artist% HAS $nowplaying{%album artist%}
I can't get $nowplaying{%artist%} to work with fb.CreateAutoPlaylist(). Also, there is no mention of that $nowplaying{} function in the title formatting help page, and the syntax with {} instead of () is strange, so I suppose that that syntax is handled specifically by the foo_softplaylists panel, and is not "official". Note also that foo_softplaylists doesn't really create the autoplaylist, but it stores it in its own panel, and I can see the number of hits changing when the nowplaying artist changes. However, when the real playlist is created, a normal (not auto) playlist is created.
Anyway, I wonder if it is possible to create real autoplaylists that change dynamically when the currently playing (or focussed) artist, album, track or whatever changes. A playlist that shows constantly, for example, all albums by the currently playing artist would be nice. But I wonder if the autoplaylist syntax is powerful enough, or if it's the responsibility of the panel to update the playlist query when it's necessary. (BTW, I think that currently, it is not possible to change the query of an existing autoplaylist from WSH without having to delete and recreate the playlist. Correct?)
well you've seen my source. there is no validation on input and the files should get written to if OK is clicked no matter what. but it's failed a good few times today. re-running again afterwards works so i'm pretty sure it can't be a problem with the code/path to files. maybe it is a permissions problem but i really can't be arsed to troubleshoot it because a) i'm not familiar with it and b) i'm lazy
as for that $nowplaying thing, i have no idea what that is. i'm guessing you can't put it into Library>Search. whatever works there should work in WSH panel mod.
Hum, I will try to find what's wrong with your ahk script.
Do you run if from WSH in compiled (exe) form? If it's the case, perhaps the parsing of the command line doesn't work the same way than with the source version.
yup, i'm running an exe version. it's reading the command line parameters just fine because it's loading the old values from the files and populating the input fields just like it should. i also pass a variable to be used as the window title and that also works perfectly.
it works most of the time when clicking OK by writing the new values. but the fact it's failed several times randomly means it's not fit for other people to use.
Of course, I agree. But I wonder what's happening. As far as I know, there are some bugs in AutoHotkey, but not in the file I/O functions. It's why I want to check your script here...
I suppose you are sure that the files are not being read or accessed by your WSH panels when the dialog is running. Right?
well i do know for sure my other scripts aren't trying to access the files. they only read them after the .exe has completely exited with no exit code - i copied that part from your script. i wouldn't bother wasting your time. what i have now is perfectly fine. it's come a long way since i was getting people to edit the script with their preferences.
Right, but I'm puzzled. I don't understand the problem and I don't like that. I have also to be sure that the same problem doesn't happen with my autoplaylist dialog. So, I'll have a look anyway...
samples updated: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
bugfix for simple biography, similar artists and last.fm charts. it would still let you click stuff you can't see when no username/api key was set.
autoplaylists updated to support multiple instances. use the context menu to set it to use either a common file (default) or a unique file per panel. you can also change the panel title.
@q-stankovic, i see you're reading the thread just as i posted this. spooky.
all the seekbar scripts require WSH panel mod 1.5.0 beta 4. all the other scripts require beta 3 as a minimum.
latest WSH panel mod beta 4 is available here: http://code.google.com/p/foo-wsh-panel-mod/downloads/list (http://code.google.com/p/foo-wsh-panel-mod/downloads/list)
edit: just uploaded again to fix a silly problem with autoplaylists. doh!
Does it go under the "configure" bit where you have to paste the scripts ? Sorry for not understanding
right click the panel>image source>set custom folder.
Thanks. That code doesn't seem to work if the images are in the same directory as the music files though?
well yes, that code only works for the parent folder. but you can use it together with the code for the current folder. the dialog tells you how.
Thanks for your patience! And one final request - code also to look in subfolders?
you'd have to specify them manually by name (or title formatting). eg
$directory_path(%path%)\images
tiny little bugfix for my
autoplaylists script. http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
samples updated. link as above.
nyan cat seekbar and simple seekbar now use a tooltip to show the seek time. thanks to T.P for the new tooltip tracking code.
requires WSH panel mod 1.5.0 beta4 (http://code.google.com/p/foo-wsh-panel-mod/downloads/list) (or later)
edit: forgot to mention for existing users, the marc2003 folder needs extracting again as background changes have been made.
nyan cat seekbar
After a few days of playing with JScript and WSH panel, I've created a simple playlist switcher with the following features:
- drag to switch playlist order
- drag and drop support
- double-click to rename (or press F2 after focusing)
- mouse wheel to switch playlists
(http://www.deviantpics.com/images/NIeuO.png)
http://pastie.org/2783951 (http://pastie.org/2783951)
Feel free to comment/reuse/modify!
i'll give it a try asap, to compare it with mine which provides same features. Thanx for sharing.
simple text reader added to samples. it only has 2 options on the context menu: the path to the file which can be full foobar title formatting and selection mode (now playing or selected track). file extension doesn't matter so long as it is plain text. colours and font come from your UI preferences. although it has buttons to scroll, using the mouse wheel is far quicker.
How can I get the playlist context menu (with options to change autoplaylist options, save, etc)? I guess it has something to do with the InitContext() function, but I don't know how to use it.
here is an example used under WSHPanelMod v1.5.0 to get context on the selection (one or more item selected), it should help you with InitContext
//=========// Item Context Menu
function new_context_menu(x, y, id, array_id) {
var MF_STRING = 0x00000000;
var MF_SEPARATOR = 0x00000800;
var MF_GRAYED = 0x00000001;
var MF_DISABLED = 0x00000002;
var _menu = window.CreatePopupMenu();
var Context = fb.CreateContextMenuManager();
Context.InitContext(plman.GetPlaylistSelectedItems(fb.ActivePlaylist));
Context.BuildMenu(_menu, 1, -1);
var ret = _menu.TrackPopupMenu(x, y);
Context.ExecuteByID(ret - 1);
falstaff, i think you've mis-understood the question although he has confused things by mentioning InitContext . i believe jermija wants the context menu you get when right clicking on playlist tabs or the playlist manager view. you''ll just have to build that menu manually.
Thank you both! Yes, marc2003 is right, but what's bothering me is that I don't know how to access/launch the autoplaylist options dialog.
(http://www.giantpygmy.net/sections/pause/archive/img/DAR_v1.6.2_autoplaylist_properties.png)
read the docs. you can tell if a playlist is an autoplaylist by using
var active = plman.ActivePlaylist;
if (fb.IsAutoplaylist(active)) _menu.AppendMenuItem(MF_STRING, 10, "Autoplaylist properties");
then later on....
idx = _menu.TrackPopupMenu(x, y);
switch(idx) {
case 10:
fb.ShowAutoPlaylistUI(active);
break;
edit: i just realised you probably won't be using the active playlist like my example but you'll have your own mouse tracking code to get the selected playlist.
Thank you very much! Didn't know about the ShowAutoPlaylistUI() method...
Thank you Marc for all these samples, I use many of them and love them a lot. Especially the thumbs script is so great!
Now, I'm a totally newbie at jscript and most of the things I can accomplish are done with copy & paste from scripts and a lot of trial and error...but now I have a question I simply cannot find a step into the right direction.
I would love to display the filename of the image (main image) from the thumbs plugin. Or even all, doesnt matter. Now I'd need a hint into the right direction...I know how to write a string (I guess) but as to how to retrieve the filename, I am totally lost.
well the full path to the main image is stored in
arr[index]. you'll want to grab this value in on_paint because the value of
index can change whenever the mouse is moved. then to get the filename we can get the string from the last backslash to the end.
file_path = arr[index];
file_name = file_path.substring(file_path.lastIndexOf("\\") + 1);
Thanks so much for your reply, I will try this out now!
first video preview of my actual WIP : a WSH playlist viewer
http://www.youtube.com/watch?v=d-9L8DcsriE (http://www.youtube.com/watch?v=d-9L8DcsriE)
script release should be for this month, i have to add some features that are missing
Uhm. Okay, I have to admit I couldnt get the filename stuff done. It seems, wherever I put that second line, the script returns an error.
But Marc, you don't have to do it for me, I read somewhere you are about to move house, and I can imagine you have your hands pretty full.
I should really start trying to learn at least basics of Jscript, but right now it is no good timing (too much real life stuff going on).
But I have another request
I would really really love a very simple recent tracks script. Right now I am using an old one from someone else; the code is not compliant with the wsh mod changes and I *think* it might be part of a problem I currently have with refresh of the scripts - they dont load at start of foobar. I have the wsh scripts in a PSS with custom code, but I had the author of the PSS script look into the code again to see if I messed something up and he couldnt find a mistake. It is no big deal really, as soon as I right-click the PSS, click settings and hit okay (without changing anything) the wsh scripts load fine.
Maybe you get the chance to write something like that after your move?
Hello! I have some questions:
i need for a callback, which will execute some script when i put in my usb player or cd. I havant any idea, except to check number of drives on timer, but i think it bery busy for cpu.
i need to new a cpu`s count (with hyper threading)
for example i launch the lame.exe encoder. how could i now that he already done his task?
is it possible to get a list of javascript files (js) in some folder and include them?
i will be very glad if this issues have any way to solve
also, i want to ask: is it possible to read and edit foobars core cfg-files through wsh?
@Emerelle, those lines i gave need to go inside the switch statement when it's established there is at least one image in the array. one that beings
case thumbnails == would be good.
or if you don't want it inside the switch statement, check the
arr array contains at least one value...
if(arr.length > 0) {
//do something
Can someone help me using the new AppendTo method?
This is a sample code:
function CustomMenu(x, y) {
var a = window.CreatePopupMenu();
var idx;
a.AppendMenuItem(0, 1, "Keep aspect ratio");
a.AppendMenuItem(0, 2, "Noexpansion");
a.AppendMenuItem(0, 3, "Stretch");
a.CheckMenuRadioItem(1, 3, ar + 1);
a.AppendMenuItem(2048, 0, 0);
a.AppendMenuItem(0, 4, at ? "Album Art" : "Custom Pictures");
if (!ac) {
for (var i = 0; i < c_arr.length; i++) {
a.AppendMenuItem(0, 5 + i, c_arr[i]);
a.CheckMenuRadioItem(5, 9, g_state + 5);
a.AppendMenuItem(ac ? 8 : 0, 10, "Auto Cycle Image");
ac && a.AppendMenuItem(ct ? 8 : 0, 11, "Faded Transition");
a.AppendMenuItem(0, 12, "Properties");
a.AppendMenuItem(0, 13, "Configure...");
idx = a.TrackPopupMenu(x, y);
switch (true) {
case (idx >= 1 && idx <= 3):
window.SetProperty("Aspect ratio", idx - 1);
aspectRatio();
window.Repaint();
break;
case (idx == 4):
switchType();
break;
case (idx >= 5 && idx <= 9):
g_state = idx - 5;
getRightImage(false);
getTimer();
break;
case (idx == 10):
window.SetProperty("Auto Cycle Image", ac ? false : true);
ac = window.GetProperty("Auto Cycle Image");
break;
case (idx == 11):
window.SetProperty("Auto Cycle Transition Fader on", ct ? false : true);
ct = window.GetProperty("Auto Cycle Transition Fader on");
break;
case (idx == 12):
window.ShowProperties();
break;
case (idx == 13):
window.ShowConfigure();
break;
a.Dispose();
How to rewrite it now by using AppendTo instead of AppendMenuItem?
Or is this new method only needed for the MainMenuManager (since its the only sample script that uses it now) to create the main menu?
I'm confused...
you only use AppendTo when creating sub-menus.
an example:
old:
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _child.ID, "Background");
new:
_child.AppendTo(_menu, MF_STRING, "Background");
BTW, MF_STRING seems not necessary. This works fine too:
_child.AppendTo(_menu, 0, "Background");
Ok, so in my script sample there's no need to replace. Thanks!
EDIT:
Again a question...
How to use the new window.SetInterval() and window.SetTimeout()?
I tried replacing window.CreateTimerInterval(50) with window.SetInterval(50) but got a crash...
What's wrong?
What's wrong?
here is an example that works, it refresh the display (paint) only after 50 ms when used, i use this to optimize refresh in the callback on_mouse_wheel() ;-)
// Globals
var mousewheel_timerID = false;
if(!mousewheel_timerID) {
mousewheel_timerID = window.SetTimeout(function() {
window.Repaint();
}, 25);
Thanks, i just found the "timer" sample in the samples-folder
Wow, have to rewrite my scripts now.
EDIT:
Is function on_timer(timer_id) now obsolete, too, since the function is called inside SetInterval/Timeout now?
I'm way more confused...
Thank you once again Marc, I will see if I can get it done!
afaik, yep it is!
Time to share my 2 new scripts : a Tabbed Playlist Manager panel and a Simple Playlist Viewer panel
[Requirements]
* foobar2000 v1.1 or better ( >> http://foobar2000.org) (http://foobar2000.org))
* WSH panel Mod v1.5.0 or better ( >> http://http://code.google.com/p/foo-wsh-pa...downloads/list) (http://http://code.google.com/p/foo-wsh-panel-mod/downloads/list))
* Fonts :
- guifx v2 transports ( >> http://http://blog.guifx.com/2009/04/02/gu...transport-font) (http://http://blog.guifx.com/2009/04/02/guifx-v2-transport-font))
- lucida console (bundled with Windows)
- tahoma (bundled with Windows)
Get them by importing this DefaultUI theme file: [link] (http://br3tt.online.fr/files/WSH/foo_WSH_test_v0.7.0.fth.zip)
Falstaff, one question -
I am using CUI and I would love to try your playlist viewer; can I get it via importing the above file wiithout loosing my layout? If not, could you possibly offer that one seperately?
Bravo Falstaff, it work like a charm!
Very impressive.
Falstaff, the tabbed playlist manager don't populate in CUI.
How come?
thanks.
right click panel (columns header for the playlist viewer / a button for the taabed playlist manager) > Configure
it will open the edit window, there is a button 'Tools' on bottom left, use it to export/import script or just select the text of the script and copy/past it to another new WSH panel to one of your config, CUI or DUI
nothing more to do
How come?
thanks.
of course it does, you maybe haven't right copied/pasted it into you WSH panel in your CUI config, try again please
EDIT: have you the last version of WSH panel Mod installed (v1.5.0 final) ?
small bug, if you use the mouse wheel up even if the playlist is already on top, it starts to scroll down, weird but funny
not a bug due to my script, i've encountered a such bug on a laptop, it's the mouse driver that is missing, the default driver of windows is not enough. apparently, it seems that WSH panel mod requires you install the good mouse driver of your mouse model.
try, (i've fixed it this way), it will fix your issue
Uhm, I thought the fth files go into the DUI dialog...importing a script into wsh panel mod is no problem - anyway, will look into that now, thanks.
EDIT: My problem is, the zip only contains the fth file, so I cant get the script out of it without loading that, hence the question
[/quote]
Yes, I do (just re-installed it, to be sure), and I also re-export both your scripts from a DUI to my CUI, both scripts works well in DUI, but the tab won't populated in CUI.
Too bad for me.
It works because
MF_STRING = 0x00000000, but it is really not a good idea to replace constants by their value.
Too bad for me.
it works fine for me under CUI, i can't reproduce your problem.
Has somebody else tested the script under CUI ?
Too bad for me.
I can not even make the tabs work under DUI. fb says there is something wrong in line
when i import the fth file, a message pops out:
Scripting Engine Initialization Failed (WSH Tabbed Playlist Manager v3.0 by Br3tt, CODE: 0x80020101)
Check the console for more information (Always caused by unexcepted script error).
solved!!
line 227 should be:
pad_right : bt_w * 2, scroll : false, scroll_step : 40, pos : 0
delete the comma at last.
.zip updated with original scripts ! the ones shared before have been compressed to remove comments and to adjust indentations .... that coukd brought some bug apparently !
so, for those who had problem, download the new .zip to fix your issues, they should be gone!
or here is direct link to the script :
* tabbed playlist manager : http://pastebin.com/Lf3uqjaz (http://pastebin.com/Lf3uqjaz)
* simple playlist viewer : http://pastebin.com/k87s135g (http://pastebin.com/k87s135g)
well I use the latest Intellipoint driver (microsoft mouse), but I'll test it later on my PC (no trackball/touchpad)
thanks
can anybody answer me? i writed below. its important to me
i dunno
yes, it's possible to check content of a folder and read/write text files with jscript, and so, with WSH panel Mod, check msdn javascript for examples, i'm not at home and i haven't samples on the hand right now.
.cfg are binaries files, so afaik, it's not possible to read/write them from WSH panel mod.
very sad. Id like to write something like ipod manager for foobar, but for converting music to regular usb player, because inner foobars converter isnt handy. seems, i need to learn how to write a dll-plugins
Falstaff: just to be sure, I try both your scripts on a fresh fb installation, with the correct WSH panel mod and the proper interface.api and jscript.api, both script works very well with DUI, but the tabbed playlist still don't work with CUI and there is no error message on the console.
Anyways, your simple playlist did became my default playlist.
Great work.
Great work.
very weird, i'm curious to find another case for who it doesn't work too under CUI ...?? you should be more accurate please
bugfix: simple biography & simple text reader row height is now dynamic dependent on font instead of the fixed size it was before.
(existing users need to extract the marc2003 folder again and import the updated script)
Firstly, I must say I have no clue how to script with this component, and I've been scratching my head for a long time thinking it might be nice to learn. Unfortunately I find no structured way of 'learning'. All the documentation I have ever found seems to be like looking at the 'Oxford English Dictionary'; it's useful if you know how to use the English language, otherwise there is no structured guidance.
Having said that, here is my problem...
One of the "essential" panels in my foobar2000 layout is a fantastic WSH artwork viewer which has auto-scrolling and other built-in functions. This script has been part of my layout for a long time. I copied the script from someone else's foobar2000 skin (named EIKO).
A few days ago I updated "WSH_Panel_Mod.dll" to version 1.5.0, and when I view the console output after foobar2000 has started I now see these lines:
WSH Panel Mod: Warning: Obsolete: window.CreateTimerInterval() is now obsolete, please use window.SetInterval() in new script.
WSH Panel Mod: Warning: Obsolete: window.CreateTimerTimeout() is now obsolete, please use window.SetTimeout() in new script.
WSH Panel Mod: Warning: Obsolete: Please use AppendTo() method to create sub menu instead of AppendMenuItem()
I opened the config of my WSH Artwork Viewer panel and conducted a text search. I found references to the "old" WSH Panel Mod methods !
What do I do now? There is no way I am ever going to remove my WSH Artwork Viewer, and I have no capability to edit the script !
Do I simply replace all instances of the text window.CreateTimerInterval() with window.SetInterval() ...is that it? ...or does the function need to be re-written?
It seems to me that unless I somehow learn how to edit WSH Panel Mod scripts on my own, I am going to have to NOT update this component anymore !!??
Replace window.CreateTimerInterval(delay) with window.SetInterval(on_timer, delay)
For example, if the delay is 500 ms, replace window.CreateTimerInterval(500) with window.SetInterval(on_timer, 500)
It will work, at least if there is only one timer used in your script.
(You can also rename on_timer and the on_timer() function to something else, but it's not necessary.)
For AppendMenuItem(), see here: http://www.hydrogenaudio.org/forums/index....st&p=773643 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=70363&view=findpost&p=773643)
@r0lz,
thanks for the guidance +++
What about window.SetTimeout() . Do you have info on that one?
@ marc2003,
I just added your Autoplaylists script to a tabbed panel ...it is brilliant ...much nicer than loading these things at foobar2000 startup.
Unfortunately, it is taking the background color of my general display preferences, but I have a different custom color scheme for my tabbed panel.
I right-click on your WSH Panel, but I don't see a Properties page entry. How do I edit the colors?
The background color I want is BROWN-BLACK (RGB: 28,28,28), with WHITE Foreground/Font (RGB: 255,255,255)
Same thing: replace CreateTimerTimeout(timeout) with SetTimeout(on_timer, timeout)
Have a look at Interfaces.txt. The syntax for each function is listed (but without much explanation).
So I tried to edit one of the three obsolete methods --->
CreateTimerIntervalOne line in my script contained:
this.ChangeTimer = window.CreateTimerInterval(Prop.ChangeAnimation.RefreshInterval);Nine other lines in my script contained:
this.GetImageTimer = window.CreateTimerInterval(200); (the integer varied between 200, 120, 50)
I changed One line to:
this.ChangeTimer = window.SetInterval(on_timer, Prop.ChangeAnimation.RefreshInterval);I changed Nine other lines to:
this.GetImageTimer = window.SetInterval(on_timer, 200); (the integer varied between 200, 120, 50)
WSH Panel Mod:
Aw, crashed ):Console:
Error: WSH Panel Mod ({FFF2B498-2C93-4683-9C3B-504C9370EC6B}): Microsoft JScript runtime error:Console:
Object doesn't support this property or methodConsole:
File: <main>Console:
Ln: 1233, Col: 3Console:
<source text only available at compile time>--------------------------------------------------------------------------------------------------------------------------------
It seems like the info by
r0lz is not enough ... any other suggestions?
Line 1233 in the script looks like this:
1231 function KillGetImageTimer (){
1232 if (Image.GetImageTimer){
1233 Image.GetImageTimer.Dispose();
1234 Image.GetImageTimer = null;
1235 CollectGarbage();
1236 }
1237 }
Falstaff i tried your WSH playlist on a fresh install (CUI) with the latest WSH Panel Mod installed. It displays everything fine, but double-clicking a track does nothing. Any ideas?
I don't know why your changes do not work. Can you post the original script somewhere?
r0lz, I appreciate your effort for trying get my script to work +++
Here is an upload of my original script with all its support files, so you can make it work 'out of the box' (make sure to read the README):
WSH_Artwork_Viewer uploaded at filebeam (500 KB) (http://filebeam.com/209586a9b235a19e57066545e991fa97)
no. it should play the track. it does for me (CUI and DUI)
@derty2, you can set those colours right at the start of the on_paint() function
g_backcolor = RGB(28, 28, 28); //background
g_textcolor = RGB(255, 255, 255); //text
g_textcolor_hl = RGB(255, 255, 255); //title text
I just noticed the new autoplaylist script with abilty to change name - somehow i missed it two weeks ago. I won't use the common file panel mode but it should be mentioned that it can be quite confusing that changes in one panel aren't reflected suddenly in the other ones. I mean confusing in that sense that if a new user don't know this feature and starts using several panels he will be wondering that after restarting foobar2000 all panels will be overwritten with last saved panel. Mabe it is a good idea to make unique file mode the default one (after importing script)
A little request for convenience: it would be nice to have all settings for autoplaylist: name, query, sorting and option for force-sorting in one window rather than clicking from window to window and having global option for force-sorting.
ah yes, i forgot to implement synchronisation between common autoplaylist panels. that's now fixed.
marc2003, Thanks for the color code +++
I just created 12 Autoplaylists for myself, and I ended up with 12 extra playlists...
I tried restarting foobar2000 and it took a long time to start. I would like to have only one Autoplaylist existing at any point in time; this means I would prefer if all new Autoplaylist queries overwrote each other. Is it possible to have a preference for this?
i won't be adding more options but you can stop the panel automatically generating playlists. right click>on successful creation/edit>do nothing.
By the way: i have this option enabled and because of that the option "replace existing playlists with same name" is greyed out and hence not available although it makes sense to have it.
you've completely lost me.
obviously that option is grayed out for a reason. you've explicitly chosen the option do nothing so how can that action even be performed? you do know what replace means, right?
My scripts are now centralized here : http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
new versions uploaded of my playlist viewer and tabbed playlist manager
@marc2003
well, when you execute a query from icon with option "do nothing" enabled then the created autoplaylist will replace or not replace already existing ones with same name - depending from check state of grayed out option "replace ..."
ok, i see what you mean now. clicking that button doesn't really fit in with those options. anyway, the option is no longer grayed out and i might look into re-arranging the menu sometime.
After doing a fresh install of foobar on a new Windows install, I'm met with this error which seems to be coming from my WSH panel script. Keep in mind that I've altered nothing in this script between installs.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 64E93A43h
Access violation, operation: read, address: 00000050h
Call path:
entry=>app_mainloop
Code bytes (64E93A43h):
64E93A03h: 00 00 0F 84 90 56 0A 00 8B 55 C4 8D 45 C0 50 6A
64E93A13h: 00 8D 4D B8 51 52 E8 41 48 FD FF 89 45 E8 8B 45
64E93A23h: 0C 85 C0 74 15 8B 8B 5C 01 00 00 8B 51 50 8B 4D
64E93A33h: C0 50 E8 54 4C FD FF 89 45 E0 8B 83 5C 01 00 00
64E93A43h: 8B 48 50 85 F6 8B 75 E8 0F 95 C2 88 91 74 05 00
64E93A53h: 00 85 F6 0F 88 A2 4E 04 00 8D 47 04 50 FF 15 68
64E93A63h: 13 E6 64 85 C0 0F 85 35 87 FD FF 8B 47 34 C7 07
64E93A73h: FC C7 E6 64 85 C0 0F 85 C2 56 0A 00 8B 47 0C 8B
Stack (0040EA9Ch):
0040EA7Ch: 00000000 FFFFFD34 000002E4 FFFFFD34
0040EA8Ch: 000002CC 00000019 00000000 0040EAD0
0040EA9Ch: 483ADF8E 00000000 0040EB40 0012EF48
0040EAACh: 07D45CB0 00000000 00000000 0012E640
0040EABCh: 07D45CB0 0012E640 00000000 00000000
0040EACCh: 00000000 07D4F120 08E45BE0 082D6E00
0040EADCh: 0012A994 025D3278 00000008 00000000
0040EAECh: 00000004 00000000 025D2420 80020101
0040EAFCh: 0012EF48 0040EA9C 0040EBA4 64FFC075
0040EB0Ch: 00000001 0040EBB4 64E938B7 0012EF48
0040EB1Ch: 00000000 00000000 483ADFB6 08DA5960
0040EB2Ch: 00000000 08DA5962 77281ECD 00000000
0040EB3Ch: 0012DD88 00000000 00000000 00000000
0040EB4Ch: 00000000 00000000 00000000 00000000
0040EB5Ch: 00000000 08DA5960 00000000 0040EBFC
0040EB6Ch: 0012A450 64E922D4 00000000 00000000
0040EB7Ch: 00000009 00000000 00000000 00000000
0040EB8Ch: 00000000 00001D68 00000000 00000001
0040EB9Ch: 483ADFAA 00000000 0040EC74 64FFC0C9
0040EBACh: 00000000 75ED14DD 0040EC00 64E84915
Registers:
EAX: 00000000, EBX: 0012EF48, ECX: 0040EAC8, EDX: 07D4F120
ESI: 00000000, EDI: 025D2420, EBP: 0040EB10, ESP: 0040EA9C
Crash location:
Module: jscript9
Offset: 33A43h
Symbol: "DllGetClassObject" (+A337h)
Loaded modules:
foobar2000 loaded at 00BA0000h - 00D92000h
ntdll loaded at 77210000h - 77390000h
kernel32 loaded at 75EC0000h - 75FD0000h
KERNELBASE loaded at 76280000h - 762C6000h
COMCTL32 loaded at 6CF00000h - 6D09E000h
msvcrt loaded at 762D0000h - 7637C000h
GDI32 loaded at 765F0000h - 76680000h
USER32 loaded at 75890000h - 75990000h
ADVAPI32 loaded at 76540000h - 765E0000h
sechost loaded at 76790000h - 767A9000h
RPCRT4 loaded at 75990000h - 75A80000h
SspiCli loaded at 74900000h - 74960000h
CRYPTBASE loaded at 748F0000h - 748FC000h
LPK loaded at 74AE0000h - 74AEA000h
USP10 loaded at 75FD0000h - 7606D000h
SHLWAPI loaded at 76190000h - 761E7000h
DSOUND loaded at 6DD40000h - 6DDB2000h
ole32 loaded at 75B10000h - 75C6C000h
WINMM loaded at 72F20000h - 72F52000h
POWRPROF loaded at 6C980000h - 6C9A5000h
SETUPAPI loaded at 75CF0000h - 75E8D000h
CFGMGR32 loaded at 74990000h - 749B7000h
OLEAUT32 loaded at 75A80000h - 75B0F000h
DEVOBJ loaded at 74B00000h - 74B12000h
UxTheme loaded at 6CA80000h - 6CB00000h
SHELL32 loaded at 74BE0000h - 7582A000h
zlib1 loaded at 5A4C0000h - 5A4D4000h
shared loaded at 6DE20000h - 6DE4B000h
imagehlp loaded at 75E90000h - 75EBA000h
dbghelp loaded at 641E0000h - 642CB000h
COMDLG32 loaded at 75C70000h - 75CEB000h
Secur32 loaded at 70100000h - 70108000h
CRYPT32 loaded at 749C0000h - 74ADD000h
MSASN1 loaded at 74AF0000h - 74AFC000h
gdiplus loaded at 6C630000h - 6C7C0000h
IMM32 loaded at 75830000h - 75890000h
MSCTF loaded at 76840000h - 7690C000h
CLBCatQ loaded at 761F0000h - 76273000h
MMDevApi loaded at 6C400000h - 6C439000h
PROPSYS loaded at 6C300000h - 6C3F5000h
dwmapi loaded at 6C9D0000h - 6C9E3000h
foo_input_std loaded at 68490000h - 685FD000h
foo_channel_mixer loaded at 6DDE0000h - 6DE1F000h
foo_discogs loaded at 6B2E0000h - 6B343000h
WININET loaded at 76070000h - 7618A000h
Normaliz loaded at 765E0000h - 765E3000h
iertutil loaded at 76380000h - 76538000h
urlmon loaded at 76680000h - 76790000h
foo_uie_albumlist loaded at 10000000h - 10043000h
foo_burninate loaded at 6DC30000h - 6DC6E000h
foo_playcount loaded at 6AFC0000h - 6AFFE000h
foo_uie_playlists_dropdown loaded at 00410000h - 0044C000h
foo_jesus loaded at 6DE60000h - 6DE7A000h
foo_out_ks loaded at 00450000h - 0047A000h
foo_input_tak loaded at 6AF10000h - 6AF54000h
tak_deco_lib loaded at 004C0000h - 004E0000h
foo_rgscan loaded at 69C50000h - 69C9B000h
foo_input_dvda loaded at 699C0000h - 69A1B000h
foo_dsp_resampler loaded at 02FD0000h - 03095000h
foo_masstag_addons loaded at 005D0000h - 005EF000h
foo_input_dsdiff loaded at 00600000h - 0062D000h
foo_skip loaded at 69990000h - 699BD000h
foo_facets loaded at 661D0000h - 66385000h
MSIMG32 loaded at 69900000h - 69905000h
foo_uie_peakmeter loaded at 00B50000h - 00B83000h
foo_dop loaded at 07820000h - 079F3000h
WS2_32 loaded at 76910000h - 76945000h
NSI loaded at 771E0000h - 771E6000h
QUARTZ loaded at 68270000h - 683E7000h
foo_dsp_effect loaded at 027A0000h - 027DA000h
foo_uie_typefind loaded at 02D70000h - 02DA0000h
foo_simplaylist loaded at 66400000h - 6654C000h
foo_simplaylist_manager loaded at 660F0000h - 661C8000h
foo_ac3 loaded at 02DF0000h - 02E20000h
foo_cdda loaded at 69940000h - 6998E000h
foo_uie_panel_splitter loaded at 031C0000h - 03219000h
foo_input_ht loaded at 07BC0000h - 07CC8000h
foo_freedb2 loaded at 69880000h - 698C0000h
foo_out_asio loaded at 06CE0000h - 06D16000h
foo_out_wasapi loaded at 06F70000h - 06F96000h
foo_audioscrobbler loaded at 070C0000h - 070F3000h
foo_input_ds loaded at 07100000h - 0712D000h
foo_random loaded at 07190000h - 071CD000h
foo_masstag loaded at 07280000h - 072D4000h
foo_input_reverse loaded at 07150000h - 07176000h
foo_uie_tabs loaded at 071D0000h - 071F8000h
foo_fileops loaded at 68440000h - 68487000h
foo_input_tta loaded at 072E0000h - 07322000h
foo_autoupdate loaded at 67340000h - 6738C000h
foo_ui_std loaded at 652E0000h - 653F9000h
foo_ui_columns loaded at 08470000h - 08600000h
foo_input_sacd loaded at 66390000h - 663FC000h
foo_input_alac loaded at 07340000h - 0735D000h
foo_converter loaded at 66070000h - 660EC000h
foo_albumlist loaded at 66010000h - 6606D000h
foo_unpack loaded at 69910000h - 6993E000h
foo_texttools loaded at 67300000h - 67334000h
foo_chacon loaded at 68240000h - 68264000h
foo_dsp_crossfeed loaded at 07770000h - 07798000h
foo_input_monkey loaded at 07B00000h - 07B49000h
foo_verifier loaded at 07CD0000h - 07D13000h
foo_dsp_xgeq loaded at 652A0000h - 652D4000h
foo_dsp_std loaded at 65250000h - 65298000h
foo_uie_wsh_panel_mod loaded at 65170000h - 65243000h
foo_input_dtshd loaded at 65020000h - 6516A000h
AUDIOSES loaded at 6C2A0000h - 6C2D6000h
SXS loaded at 6C9F0000h - 6CA4F000h
jscript9 loaded at 64E60000h - 6501B000h
VERSION loaded at 73270000h - 73279000h
WindowsCodecs loaded at 747B0000h - 748AB000h
apphelp loaded at 6E7D0000h - 6E81C000h
EhStorShell loaded at 64160000h - 64191000h
ntshrui loaded at 64080000h - 640F0000h
srvcli loaded at 6B2A0000h - 6B2B9000h
cscapi loaded at 67390000h - 6739B000h
slc loaded at 641D0000h - 641DA000h
IconCodecService loaded at 748B0000h - 748B6000h
sud loaded at 64C20000h - 64CDB000h
ADVPACK loaded at 68410000h - 6843E000h
DUI70 loaded at 64B60000h - 64C12000h
WINTRUST loaded at 74960000h - 7498D000h
CFNetwork loaded at 72790000h - 729F0000h
iphlpapi loaded at 72C30000h - 72C4C000h
WINNSI loaded at 72C20000h - 72C27000h
CoreFoundation loaded at 72FD0000h - 730D9000h
MSVCR80 loaded at 73130000h - 731CB000h
pthreadVC2 loaded at 72FC0000h - 72FD0000h
WSOCK32 loaded at 72FB0000h - 72FB7000h
objc loaded at 72F90000h - 72FAD000h
MSVCP80 loaded at 731D0000h - 73257000h
libdispatch loaded at 72F80000h - 72F8E000h
libicuin loaded at 72DE0000h - 72F1A000h
libicuuc loaded at 72CF0000h - 72DD3000h
icudt46 loaded at 4AD00000h - 4BC8B000h
ASL loaded at 72C90000h - 72CA1000h
SQLite3 loaded at 720B0000h - 7211F000h
libxml2 loaded at 71F70000h - 720A3000h
iTunesMobileDevice loaded at 62A40000h - 62B8E000h
dnssd loaded at 72BF0000h - 72C05000h
icuin40 loaded at 6DE50000h - 6DE56000h
profapi loaded at 73100000h - 7310B000h
mswsock loaded at 72B80000h - 72BBC000h
wshtcpip loaded at 72B70000h - 72B75000h
CRYPTSP loaded at 72F60000h - 72F76000h
rsaenh loaded at 72CB0000h - 72CEB000h
Stack dump analysis:
Address: 64FFC075h (jscript9+19C075h), symbol: "DllUnregisterServer" (+7D369h)
Address: 64E938B7h (jscript9+338B7h), symbol: "DllGetClassObject" (+A1ABh)
Address: 77281ECDh (ntdll+71ECDh), symbol: "WinSqmSetIfMaxDWORD" (+35h)
Address: 64E922D4h (jscript9+322D4h), symbol: "DllGetClassObject" (+8BC8h)
Address: 64FFC0C9h (jscript9+19C0C9h), symbol: "DllUnregisterServer" (+7D3BDh)
Address: 75ED14DDh (kernel32+114DDh), symbol: "HeapFree" (+14h)
Address: 64E84915h (jscript9+24915h), symbol: "JsVarToScriptDirect" (+22CA9h)
Address: 64E9230Ah (jscript9+3230Ah), symbol: "DllGetClassObject" (+8BFEh)
Address: 65179DA5h (foo_uie_wsh_panel_mod+9DA5h)
Address: 65210FF4h (foo_uie_wsh_panel_mod+A0FF4h), symbol: "foobar2000_get_interface" (+5CA34h)
Address: 65208058h (foo_uie_wsh_panel_mod+98058h), symbol: "foobar2000_get_interface" (+53A98h)
Address: 651799C4h (foo_uie_wsh_panel_mod+99C4h)
Address: 758B12A5h (USER32+212A5h), symbol: "PostMessageW" (+0h)
Address: 652080CAh (foo_uie_wsh_panel_mod+980CAh), symbol: "foobar2000_get_interface" (+53B0Ah)
Address: 651ABFD9h (foo_uie_wsh_panel_mod+3BFD9h)
Address: 758A6D91h (USER32+16D91h), symbol: "GetThreadDesktop" (+12Eh)
Address: 758A6D51h (USER32+16D51h), symbol: "GetThreadDesktop" (+EEh)
Address: 758A6CE9h (USER32+16CE9h), symbol: "GetThreadDesktop" (+86h)
Address: 7590A61Eh (USER32+7A61Eh), symbol: "VTagOutput" (+54h)
Address: 758A965Eh (USER32+1965Eh), symbol: "GetWindow" (+3F0h)
Address: 6CF2B495h (COMCTL32+2B495h), symbol: "ImageList_GetIcon" (+567h)
Address: 758CD0F5h (USER32+3D0F5h), symbol: "SendDlgItemMessageW" (+0h)
Address: 6517F518h (foo_uie_wsh_panel_mod+F518h)
Address: 6517F39Bh (foo_uie_wsh_panel_mod+F39Bh)
Address: 65205FC8h (foo_uie_wsh_panel_mod+95FC8h), symbol: "foobar2000_get_interface" (+51A08h)
Address: 652082AAh (foo_uie_wsh_panel_mod+982AAh), symbol: "foobar2000_get_interface" (+53CEAh)
Address: 651ABED5h (foo_uie_wsh_panel_mod+3BED5h)
Address: 65197E52h (foo_uie_wsh_panel_mod+27E52h)
Address: 6520FDECh (foo_uie_wsh_panel_mod+9FDECh), symbol: "foobar2000_get_interface" (+5B82Ch)
Address: 652083D0h (foo_uie_wsh_panel_mod+983D0h), symbol: "foobar2000_get_interface" (+53E10h)
Address: 65197747h (foo_uie_wsh_panel_mod+27747h)
Address: 651AB797h (foo_uie_wsh_panel_mod+3B797h)
Address: 65214D0Ch (foo_uie_wsh_panel_mod+A4D0Ch), symbol: "foobar2000_get_interface" (+6074Ch)
Address: 65199200h (foo_uie_wsh_panel_mod+29200h)
Address: 758A62FAh (USER32+162FAh), symbol: "gapfnScSendMessage" (+332h)
Address: 758CF943h (USER32+3F943h), symbol: "GetCursor" (+263h)
Address: 758CF8FBh (USER32+3F8FBh), symbol: "GetCursor" (+21Bh)
Address: 758CF784h (USER32+3F784h), symbol: "GetCursor" (+A4h)
Address: 758CF860h (USER32+3F860h), symbol: "GetCursor" (+180h)
Address: 758CF889h (USER32+3F889h), symbol: "GetCursor" (+1A9h)
Address: 758A6D3Ah (USER32+16D3Ah), symbol: "GetThreadDesktop" (+D7h)
Address: 758A9679h (USER32+19679h), symbol: "SendMessageW" (+0h)
Address: 758A96C5h (USER32+196C5h), symbol: "SendMessageW" (+4Ch)
Address: 6CFA4601h (COMCTL32+A4601h), symbol: "GetEffectiveClientRect" (+3409h)
Address: 6CFA4663h (COMCTL32+A4663h), symbol: "GetEffectiveClientRect" (+346Bh)
Address: 6CFA44EDh (COMCTL32+A44EDh), symbol: "GetEffectiveClientRect" (+32F5h)
Address: 768439F5h (MSCTF+39F5h)
Address: 76843F35h (MSCTF+3F35h), symbol: "TF_GetAppCompatFlags" (+16Dh)
Address: 758A77C4h (USER32+177C4h), symbol: "CharPrevW" (+138h)
Address: 758A788Ah (USER32+1788Ah), symbol: "DispatchMessageW" (+Fh)
Address: 758CC81Fh (USER32+3C81Fh), symbol: "IsDialogMessageW" (+11Eh)
Address: 758CCDE7h (USER32+3CDE7h), symbol: "DialogBoxIndirectParamW" (+1F4h)
Address: 758CCF5Ch (USER32+3CF5Ch), symbol: "DialogBoxIndirectParamAorW" (+108h)
Address: 758CCE8Ah (USER32+3CE8Ah), symbol: "DialogBoxIndirectParamAorW" (+36h)
Address: 65170000h (foo_uie_wsh_panel_mod+0h)
Address: 65233B38h (foo_uie_wsh_panel_mod+C3B38h), symbol: "foobar2000_get_interface" (+7F578h)
Address: 651992B0h (foo_uie_wsh_panel_mod+292B0h)
Address: 758CD009h (USER32+3D009h), symbol: "DialogBoxParamW" (+3Fh)
Address: 651AF02Dh (foo_uie_wsh_panel_mod+3F02Dh)
Address: 651AC548h (foo_uie_wsh_panel_mod+3C548h)
Address: 65214D30h (foo_uie_wsh_panel_mod+A4D30h), symbol: "foobar2000_get_interface" (+60770h)
Address: 758A6DE8h (USER32+16DE8h), symbol: "GetThreadDesktop" (+185h)
Address: 651F1950h (foo_uie_wsh_panel_mod+81950h), symbol: "foobar2000_get_interface" (+3D390h)
Address: 651C10CFh (foo_uie_wsh_panel_mod+510CFh), symbol: "foobar2000_get_interface" (+CB0Fh)
Address: 758A6DF3h (USER32+16DF3h), symbol: "GetThreadDesktop" (+190h)
Address: 65214D40h (foo_uie_wsh_panel_mod+A4D40h), symbol: "foobar2000_get_interface" (+60780h)
Address: 651ADC67h (foo_uie_wsh_panel_mod+3DC67h)
Address: 65208956h (foo_uie_wsh_panel_mod+98956h), symbol: "foobar2000_get_interface" (+54396h)
Address: 651ADC76h (foo_uie_wsh_panel_mod+3DC76h)
Address: 651AC9FFh (foo_uie_wsh_panel_mod+3C9FFh)
Address: 758B0D4Dh (USER32+20D4Dh), symbol: "CallWindowProcW" (+1Bh)
Address: 00440406h (foo_uie_playlists_dropdown+30406h), symbol: "foobar2000_get_interface" (+23966h)
Address: 758A6F9Eh (USER32+16F9Eh), symbol: "GetThreadDesktop" (+33Bh)
Address: 758A702Ch (USER32+1702Ch), symbol: "GetWindowLongW" (+2Eh)
Address: 65208A34h (foo_uie_wsh_panel_mod+98A34h), symbol: "foobar2000_get_interface" (+54474h)
Address: 651B225Fh (foo_uie_wsh_panel_mod+4225Fh)
Address: 0043FBA8h (foo_uie_playlists_dropdown+2FBA8h), symbol: "foobar2000_get_interface" (+23108h)
Address: 651F1AE1h (foo_uie_wsh_panel_mod+81AE1h), symbol: "foobar2000_get_interface" (+3D521h)
Address: 75910230h (USER32+80230h), symbol: "ShutdownBlockReasonDestroy" (+59A2h)
Address: 758A90C9h (USER32+190C9h), symbol: "LoadStringW" (+210h)
Address: 758A6E57h (USER32+16E57h), symbol: "GetThreadDesktop" (+1F4h)
Address: 758B291Fh (USER32+2291Fh), symbol: "GetKeyState" (+0h)
Address: 7722011Ah (ntdll+1011Ah), symbol: "KiUserCallbackDispatcher" (+2Eh)
Address: 77220080h (ntdll+10080h), symbol: "KiUserApcDispatcher" (+48h)
Address: 758A6A8Ch (USER32+16A8Ch), symbol: "gapfnScSendMessage" (+AC4h)
Address: 758A6AE9h (USER32+16AE9h), symbol: "gapfnScSendMessage" (+B21h)
Address: 651ACC2Dh (foo_uie_wsh_panel_mod+3CC2Dh)
Address: 6CA90D73h (UxTheme+10D73h)
Address: 6646EC2Fh (foo_simplaylist+6EC2Fh)
Address: 65382667h (foo_ui_std+A2667h)
Address: 00C0D9C7h (foobar2000+6D9C7h)
Address: 758A78E2h (USER32+178E2h), symbol: "GetMessageW" (+0h)
Address: 75ED11A9h (kernel32+111A9h), symbol: "SetLastError" (+0h)
Address: 00CEBDD8h (foobar2000+14BDD8h)
Address: 00C0DB06h (foobar2000+6DB06h)
Environment:
App: foobar2000 v1.1.9
OS: Windows 6.1.7601 Service Pack 1 x64
CPU: Intel® Core i7 CPU M 640 @ 2.80GHz, features: MMX SSE SSE2 SSE3 SSE4.1 SSE4.2
Audio: SPDIF Interface (MUSILAND Monitor 03 US); Speakers (MUSILAND Monitor 03 US); Line 1 (Virtual Audio Cable); Speakers (USB PnP Sound Device); Speaker/HP (Realtek High Definition Audio)
UI: Default User Interface 0.9.5
Components:
Core (2011-11-04 14:08:40 UTC)
foobar2000 core 1.1.9
foo_ac3.dll (2011-11-10 00:29:34 UTC)
AC3 decoder 0.9.5
foo_albumlist.dll (2011-11-04 14:07:12 UTC)
Album List 4.5
foo_audioscrobbler.dll (2011-11-10 00:29:34 UTC)
Audioscrobbler 1.4.7
foo_autoupdate.dll (2011-11-10 00:29:34 UTC)
Automatic Updater 1
foo_burninate.dll (2011-11-10 00:29:34 UTC)
Audio CD Writer 3.0.3
foo_cdda.dll (2011-11-04 14:07:04 UTC)
CD Audio Decoder 3.0
foo_chacon.dll (2011-11-10 00:29:34 UTC)
Chacon 3
foo_channel_mixer.dll (2011-11-10 00:29:34 UTC)
Channel Mixer 0.9.6.7
foo_converter.dll (2011-11-04 14:06:48 UTC)
Converter 1.5
foo_discogs.dll (2011-11-10 00:29:34 UTC)
Discogs Tagger 1.30
foo_dop.dll (2011-11-10 00:29:34 UTC)
iPod manager 0.6.9.7
foo_dsp_crossfeed.dll (2011-11-10 00:29:34 UTC)
Crossfeed 1.01
foo_dsp_effect.dll (2011-11-10 00:29:34 UTC)
Effect DSP 0.9.2
foo_dsp_resampler.dll (2011-11-03 14:05:14 UTC)
SoX Resampler 0.7.6
foo_dsp_std.dll (2011-11-04 14:07:12 UTC)
Standard DSP Array 1.0
foo_dsp_xgeq.dll (2011-11-10 00:29:34 UTC)
Graphic Equalizer 0.2.1
foo_facets.dll (2011-11-10 00:29:34 UTC)
Facets 1.0
foo_fileops.dll (2011-11-04 14:06:12 UTC)
File Operations 2.1.3
foo_freedb2.dll (2011-11-04 14:06:12 UTC)
freedb Tagger 0.6.4
foo_input_alac.dll (2011-11-10 00:29:34 UTC)
ALAC Decoder 1.0.7
foo_input_ds.dll (2011-11-10 00:29:34 UTC)
DirectShow input 0.1
foo_input_dsdiff.dll (2011-11-10 00:29:34 UTC)
DSDIFF Decoder 1.4
foo_input_dtshd.dll (2011-11-10 00:29:34 UTC)
DTS-HD Decoder 0.1.3
foo_input_dvda.dll (2011-11-10 00:29:34 UTC)
DVD-Audio Decoder and Watermark Detector 0.4.8
foo_input_ht.dll (2011-11-10 00:29:34 UTC)
Highly Theoretical 2.0.7
foo_input_monkey.dll (2011-11-10 00:29:34 UTC)
Monkey's Audio Decoder 2.1.5
foo_input_reverse.dll (2011-11-10 00:29:34 UTC)
Reverse Playback 0.1.4 (SSE)
foo_input_sacd.dll (2011-11-11 11:11:10 UTC)
Super Audio CD Decoder 0.4.2
foo_input_std.dll (2011-11-04 14:06:56 UTC)
Standard Input Array 1.0
foo_input_tak.dll (2011-11-10 00:29:34 UTC)
TAK Decoder 0.4.4
foo_input_tta.dll (2011-11-10 00:29:34 UTC)
TTA Audio Decoder 3.1
foo_jesus.dll (2011-11-10 00:29:34 UTC)
Autosave & Autobackup 10
foo_masstag.dll (2011-11-10 00:29:34 UTC)
Masstagger 1.8.4
foo_masstag_addons.dll (2011-11-10 00:29:34 UTC)
Masstagger Addons 0.3.4 (SSE)
foo_out_asio.dll (2011-11-10 00:29:34 UTC)
ASIO support 1.2.7
foo_out_ks.dll (2011-11-10 00:29:34 UTC)
Kernel Streaming Output 1.2.2
foo_out_wasapi.dll (2011-11-10 00:29:34 UTC)
WASAPI output support 2.1
foo_playcount.dll (2011-11-10 00:29:34 UTC)
Playback Statistics 3.0.2
foo_random.dll (2011-11-10 00:29:34 UTC)
Randomized Playlist Entry 1.2.3
foo_rgscan.dll (2011-11-04 14:06:54 UTC)
ReplayGain Scanner 2.1.2
foo_simplaylist.dll (2011-11-10 00:29:34 UTC)
SimPlaylist 1.0
foo_simplaylist_manager.dll (2011-11-10 00:29:34 UTC)
SimPlaylist Manager 1.0
foo_skip.dll (2011-11-10 00:29:34 UTC)
Skip Track 1.7.4
foo_texttools.dll (2011-11-10 00:29:34 UTC)
Text Tools 1.0.5
foo_ui_columns.dll (2011-11-10 00:29:34 UTC)
Columns UI 0.3.8.8
foo_ui_std.dll (2011-11-04 14:07:18 UTC)
foo_uie_albumlist.dll (2011-11-10 00:29:34 UTC)
Album list panel 0.3.5
foo_uie_panel_splitter.dll (2011-11-10 00:29:34 UTC)
Panel Stack Splitter 0.3.8.2(alpha)
foo_uie_peakmeter.dll (2011-11-10 00:29:34 UTC)
Peakmeter Panel 0.0.4.2 beta
foo_uie_playlists_dropdown.dll (2011-11-10 00:29:34 UTC)
Playlists Dropdown 0.7.6
foo_uie_tabs.dll (2011-11-10 00:29:34 UTC)
Tabbed Panel Modified 0.2.7
foo_uie_typefind.dll (2011-11-10 00:29:34 UTC)
Typefind 0.2 beta 2
foo_uie_wsh_panel_mod.dll (2011-11-15 01:14:42 UTC)
WSH Panel Mod 1.5.0
foo_unpack.dll (2011-11-04 14:06:26 UTC)
ZIP/GZIP/RAR Reader 1.6
foo_verifier.dll (2011-11-10 00:29:34 UTC)
File Integrity Verifier 1.1
Recent events:
iPod manager: USB AMD enumerator: Found USB\VID_05AC&PID_1297\3FBF80AAA36084853D8114BEF797B08C9C58B596
iPod manager: Device properties: DBVersion: 5, SQLiteDB
iPod manager: 172 post process SQL commands, version 8
iPod manager: Apple iPod/iPhone connected. Device Instance Path: USB\VID_05AC&PID_1297\3FBF80AAA36084853D8114BEF797B08C9C58B596
WSH Panel Mod ({0E88C1C9-B018-4157-9403-14028A8D3B6A}): Parsing file "C:\Program Files (x86)\foobar2000\scripts\Helpers.txt"
WSH Panel Mod ({0E88C1C9-B018-4157-9403-14028A8D3B6A}): Parsing file "C:\Program Files (x86)\foobar2000\scripts\Flags.txt"
WSH Panel Mod ({0E88C1C9-B018-4157-9403-14028A8D3B6A}): Parsing file "C:\Program Files (x86)\foobar2000\scripts\getColoursFonts.js"
WSH Panel Mod ({0E88C1C9-B018-4157-9403-14028A8D3B6A}): Parsing file "C:\Program Files (x86)\foobar2000\scripts\buttons.js"
WSH Panel Mod ({0E88C1C9-B018-4157-9403-14028A8D3B6A}): Parsing file "C:\Program Files (x86)\foobar2000\scripts\menus.js"
Error: WSH Panel Mod ({0E88C1C9-B018-4157-9403-14028A8D3B6A}): Microsoft JScript runtime error:
Automation server can't create object
File: C:\Program Files (x86)\foobar2000\scripts\menus.js
Ln: 1, Col: 1
And this is the script:
// ==PREPROCESSOR==
// @import "%fb2k_path%scripts\Helpers.txt"
// @import "%fb2k_path%scripts\Flags.txt"
// @import "%fb2k_path%scripts\getColoursFonts.js"
// @import "%fb2k_path%scripts\buttons.js"
// @import "%fb2k_path%scripts\menus.js"
// ==/PREPROCESSOR==
window.MaxHeight = tpad+bth;
window.MinHeight = tpad+bth;
function on_size()
ww = window.Width;
wh = window.Height;
buttons = {
back: new button('back', function(){fb.Prev();},"Previous",lpad),
stop: new button('stop', function(){fb.Stop();},"Stop",lpad+btw),
pop: new button((fb.IsPlaying&&!fb.IsPaused)?'pause':'play',function(){fb.PlayOrPause();},(fb.IsPlaying&&!fb.IsPaused)?"Pause":"Play",lpad+2*btw),
sac: new button(fb.StopAfterCurrent?'sac_on':'sac',function(){fb.StopAfterCurrent=!fb.StopAfterCurrent;},"Stop After Current "+(fb.StopAfterCurrent?"(On)":"(Off)"),lpad+3*btw),
next: new button('fwd', function(){fb.Next();},"Next",lpad+4*btw),
cfp: new button(fb.CursorFollowPlayback?'cfp_on':'cfp',function() { fb.CursorFollowPlayback=!fb.CursorFollowPlayback; },"Cursor Follows Playback "+(fb.CursorFollowPlayback?"(On)":"(Off)"), ww-rpad-5*btw),
pfc: new button(fb.PlaybackFollowCursor?'pfc_on':'pfc',function() { fb.PlaybackFollowCursor=!fb.PlaybackFollowCursor; },"Playback Follows Cursor "+(fb.PlaybackFollowCursor?"(On)":"(Off)"), ww-rpad-4*btw),
pbo: new button(PBOArray[fb.PlayBackOrder],function() { playbackorder(); },"Playback Order ("+PBOArray[fb.PlayBackOrder]+")", ww-rpad-3*btw),
lfm: new button('lfm', function(){lastfm();},"Last.fm", ww-rpad-2*btw),
menu: new button('menu', function(){runmenu();},"Run", ww-rpad-btw)
function on_paint(gr)
gr.FillSolidRect(0,0,ww,wh,utils.GetSysColor(15));
//bg_theme = window.CreateThemeManager("BUTTON");
//try { bg_theme.SetPartAndStateId(1, 1); }catch(e) {}
//try { bg_theme.DrawThemeBackground(gr, lpad, tpad, ww-lpad-rpad, bth); } catch(e) {}
gr.SetSmoothingMode(4);
gr.FillGradRect(lpad+1, tpad+1, ww-lpad-rpad-2, bth-3, 90, 0xfff4f4f4, 0xffe1e1e1, 1);
gr.DrawRoundRect(lpad, tpad, ww-lpad-rpad-1, bth-1, 3, 3, 1, 0xffb2b2b2);
gr.DrawRoundRect(lpad+1, tpad+1, ww-lpad-rpad-3, bth-3, 3, 3, 1, 0xfffafafa);
drawAllButtons(gr);
///Seekbar
gr.SetTextRenderingHint(5);
//For normal playback
if(fb.PlaybackLength>0)
gap = gr.CalcTextWidth(len.Eval(),font_labels)+8;
if(fb.PlaybackLength > fb.PlaybackTime)
if(g_drag)
pos = (ww-(2*lpad+2*rpad+10*btw)-2*gap) * g_drag_seek;
else
pos = (ww-(2*lpad+2*rpad+10*btw)-2*gap) * (fb.PlaybackTime / fb.PlaybackLength);
else
pos=0;
seekbg.DrawThemeBackground(gr,2*lpad+5*btw+gap-2,6,ww-(2*lpad+2*rpad+10*btw)-2*gap+4,18);
gr.GdiDrawText(elap.Eval(), font_labels, txtcol, 2*lpad+5*btw, 7, gap, wh-1, DT_CENTER);
gr.GdiDrawText(remain.Eval(), font_labels, txtcol, ww-gap-2*rpad-5*btw, 7, gap, wh-1, DT_CENTER);
seekfill.DrawThemeBackground(gr,2*lpad+5*btw+gap,8,pos,14);
//For streams
else if(fb.IsPlaying && (fb.PlaybackLength < 0 || filetype_eval == "mms"))
seekbg.DrawThemeBackground(gr,2*lpad+5*btw+2,6,ww-(2*lpad+2*rpad+10*btw)-4,18);
gr.GdiDrawText(elap.Eval()+" (continuous)", font_labels, txtcol, 0, 9, ww, wh, DT_CENTER);
function on_playback_stop()
if(g_timer){window.KillTimer(g_timer);}
buttons.pop.icon=gdi.Image(dir+"play"+".png");
buttons.pop.tooltiptxt="Play";
window.Repaint();
function on_playback_pause(is_paused)
buttons.pop.icon=is_paused?gdi.Image(dir+"play"+".png"):gdi.Image(dir+"pause"+".png");
buttons.pop.tooltiptxt=is_paused?"Play":"Pause";
window.Repaint();
function on_playback_starting(cmd, is_paused)
g_timer = window.CreateTimerInterval(40);
window.Repaint();
function on_playlist_stop_after_current_changed(state)
buttons.sac.icon=state?gdi.Image(dir+"sac_on"+".png"):gdi.Image(dir+"sac"+".png");
buttons.sac.tooltiptxt="Stop After Current "+(state?"(On)":"(Off)");
window.Repaint();
function on_cursor_follow_playback_changed(state)
buttons.cfp.icon=state?gdi.Image(dir+"cfp_on"+".png"):gdi.Image(dir+"cfp"+".png");
buttons.cfp.tooltiptxt="Cursor Follows Playback "+(state?"(On)":"(Off)");
window.Repaint();
function on_playback_follow_cursor_changed(state)
buttons.pfc.icon=state?gdi.Image(dir+"pfc_on"+".png"):gdi.Image(dir+"pfc"+".png");
buttons.pfc.tooltiptxt="Playback Follows Cursor "+(state?"(On)":"(Off)");
window.Repaint();
function on_playback_order_changed(new_order_index)
buttons.pbo.icon=gdi.Image(dir+PBOArray[fb.PlayBackOrder]+".png");
buttons.pbo.tooltiptxt = "Playback Order ("+PBOArray[fb.PlayBackOrder]+")";
window.Repaint();
function on_playback_seek(time)
window.Repaint();
function on_playback_time(time)
if(!g_timer){g_timer = window.CreateTimerInterval(40);}
window.Repaint();
function on_playback_new_track(metadb)
filetype_eval = filetype.Eval();
window.Repaint();
function on_timer(id)
window.RepaintRect(2*lpad+5*btw,0,ww-(2*lpad+2*rpad+10*btw),wh);
////Seekbar
var g_drag = 0;
var g_drag_seek = 0;
//Titleformatting
var len = fb.Titleformat("%length%");
var elap = fb.TitleFormat("%playback_time%");
var remain = fb.TitleFormat("$if2(%playback_time_remaining%,continuous)");
var pos = 0;
var gap = 0;
var g_timer;
var filetype = fb.TitleFormat("$left(%path%,3)");
var filetype_eval;
var seekbg = window.CreateThemeManager("Progress");
try { seekbg.SetPartAndStateID(1,1); }
catch(e){}
var seekfill = window.CreateThemeManager("Progress");
try { seekfill.SetPartAndStateID(3,1); }
catch(e){}
function on_item_focus_change() { window.Repaint(); }
Any ideas?
Hi guys, i just read something interesting about the powershell.
Windows Powershell could realize the aero effect on any window rendered by DWM with calling dwmapi.dll.
We can use Powershell in WSH script (which i had tested, successfully.)
So....
Marc 2003, is there a way to get the thumbs script to show all non-audio files, rather than just the images? I'd like to have thumbnails of the images though also icons for other files such as .txt, which I could click on to open.
(Back to the timer...)
Just to ensure (to don't create a "memory leak" in my scripts ):
Does window.ClearInterval(g_timer) have the same effect as g_timer.Dispose() in older scripts?
Well, I have finished to convert the obsolete timer methods to the new ones, and the script works fine.
But I haven't converted AppendMenuItem(MF_POPUP...) to the new AppendTo() method, as this would require too many changes, due to the way the menu is built. (The method, based on arrays containing the menu items, is elegant but very complex and extremely difficult to change!) Anyway, IMO, changing that is not really necessary, as the old method continues to work as expected.
Also, I have noticed that the reflection of the image is not drawn in the panel. I have tried to find why, but without success. This line (near the end of the script) doesn't work:
Rimg.ApplyMask(mask);
I don't understand why, as it works fine with the original mask.png image if I extract the code that build the reflexion and I draw it directly in a panel. Also, I have verified that the original image and the mask are correctly loaded and that they can be displayed independently. It's only when the mask is applied to the image that the problem occurs.
Maybe it's because the script uses a strange approach: it draws the folder image and the reflection in a new bitmap, and the bitmap is finally drawn in the panel. Not sure why the original author has adopted that complex method. Could it be the problem? Anyway, again, the script is too complex to fix that problem easily.
Can you confirm that the reflection has never been visible, even with old versions of the wsh panel mod extension? If it worked in the past, that would mean that there is a new (undocumented) incompatibility in the current version.
[EDIT] Uploaded the new version here (http://www.4shared.com/file/jTKjPJaS/WSH_Artwork_Viewer_new.html), so you can test it...
it's certainly possible..... if you do it yourself.
sorry but i won't be adding that feature as i'd never use it. i only use it for last.fm artist images so extending the functionality of the custom folder mode doesn't really appeal to me.
r0lZ, a picture is worth a thousand words...
Screenshot with added comments --> (http://img88.imageshack.us/img88/2544/20111117002340.th.png) (http://img88.imageshack.us/img88/2544/20111117002340.png)
Hey, thanks again for your efforts +++
_________________________________________________________________________
EDIT: I tried the exact same thing in foobar2000 v1.1.7 with WSH Panel Mod 1.5.0 and... you are right, Reflection function no longer works !
Shucks, that's a let down... such a brilliant Artwork Viewer as this should not become abandonware !
__________________________________________________________________________
r0lZ, I installed your new version of the WSH Artwork Viewer (v1.1). Here is feedback...
- The script was accepted and the panel updated .
- I cleared the Console, restarted foobar2000, then viewed the Console:
WSH Panel Mod (WSH Artwork Viewer v1.1 by EIKO, mod by r0lZ): initialized in 8 ms
No more "obsolete" WSH errors reported !
- I played a track from an album group containing multiple artworks...
the Artwork Viewer did its thing and auto-scrolled,
Further enquiry revealed these problems:
- the "Reflection" function no longer works !
- If I play a new track, then hover and scroll with my mouse over the Artwork Viewer, WSH Panel Mod crashes:
Error: WSH Panel Mod (WSH Artwork Viewer v1.1 by EIKO, mod by r0lZ): Microsoft JScript runtime error:
File: <main>
Ln: 1173, Col: 3
Read my post above. I know that the reflection doesn't work. But it does not work with the original script either. I don't understand why. Are you sure it works with the script you have uploaded? Do you have another version of the script?
As I've explained in my previous post, the "obsolete" message about AppendTo() is normal. I have not fixed that. (Not sure why that message is only displayed when the panel crashes, but the crash is not related to that point.)
The crash is my fault. I forgot to change a timer (CursorFollowAutoTimer). There are many timers in that script! I have already fixed that bug. I will upload the new version when you will reply to my question about the reflection. If it's possible, I'll try to fix it too.
r0lZ, continuing the enquiry...
- I exited foobar2000 v1.1.7 (and components: WSH Panel Mod v1.5.0 | WSH Artwork Viewer mod by r0lZ v1.1 )
- I replaced WSH Panel Mod 1.5.0 with version 1.4.3
- I restarted foobar2000 and WSH Artwork Viewer panel is permanently crashed. Refreshing the config does nothing. Console reports this:
WSH Panel Mod ({56B397C4-98BA-4D69-A7B2-D58FC88697AB}): initialized in 0 ms
WSH Panel Mod ({970889CB-C7C8-4B6B-8307-E732076A7340}): initialized in 4 ms
Ln: 474, Col: 5
- Right-click crashed WSH Artwork Viewer panel > Configure > replaced the code with "WSH Artwork Viewer_original.txt" (from your .7z archive)
.... everything works fine again
.... "Reflection" function works
.... "Hover and scroll with mouse" function works
So, the "original" code inside your .7z package works using WSH Panel Mod v1.4.3. There is no other code; this "old" code is the only code I ever used in this panel.
To try and replicate my "fully working" old panel, here is an export of my "Properties" page for the panel:
"WSH Artwork Viewer_original.properties.wsp" uploaded at filebeam (http://filebeam.com/53572537a80cd30af79fd5bc59b69866)
Of course, the new version of the script cannot work with WSHPM 1.4, since I use the new methods available only in v1.5.
I would like to know if you can see the reflections with the old version of the script running in WSHPM 1.5. Please test that configuration. Here, I can't get them to work. I think therefore that v1.5 has introduced some kind of incompatibility. But I'm not sure. The problem could be on my side.
r0lZ, continuing my previous action...
- I am running foobar2000 v1.1.7 (and components: WSH Panel Mod v1.4.3 | WSH Artwork Viewer original script )
... everything works as expected, including the "Reflection" function.
- I exit foobar2000, and I replace WSH Panel Mod v1.4.3 with v1.5.0, and I restart foobar2000.
WSH Panel Mod ({FFF2B498-2C93-4683-9C3B-504C9370EC6B}): initialized in 8 ms
WSH Panel Mod ({970889CB-C7C8-4B6B-8307-E732076A7340}): initialized in 0 ms
"Reflection" function DOES NOT WORK any more (using "WSH Artwork Viewer original script" and "WSH Panel Mod v1.5.0")
i got a question again: maybe its possible to get items names in main menu? for example, i have menu->item 1, item 2... i dont need to get a submenu as popup, i need items. if its possible, i could make a fast dsp switcher as i dreamed.
also, previously i asked about query for transcoding files. i just forget thats windows shell waits until one process will be closed before starting new one. so i think its possible to create some poor script for transcoding.
OK, same thing here. So, that confirms that there is a bug somewhere in WSHPM 1.5.0 with ApplyMask(). I will try to isolate the problem to demonstrate the bug.
T.P Wang, any idea?
About Reflection:
use gr.DrawImage and set the height to a negative integer, you'll find the image has been reflected.
About Reflection:
I know how to turn an image upside down. That part of the script works well. The problem is that the image is fully transparent (or disappears somehow) when a mask is applied.
Here is the code that worked fine in WSHPM 1.4:
var Mimg = gdi.CreateImage(width, height);
var g = Mimg.GetGraphics();
Rimg = img.Clone(0, 0, img.Width, img.Height);
Rimg.RotateFlip(RotateFlipType.RotateNoneFlipY);
var mask = ReflectionMask.Resize(Rimg.Width, Rimg.Height);
g.DrawImage(Rimg, Rimgpos.x, Rimgpos.y, Rimgpos.w, Rimgpos.h, 0, 0, Rimg.Width, Rimg.Height, 0, Opacity);
RawBitmap = Mimg.CreateRawBitmap();
With the code above, nothing is drawn in the RawBitmap!
If I comment out the line
Rimg.ApplyMask(mask);, everything works as expected, but of course, the reflection is not "faded out" by the mask.
Also, if I comment out the same line and I replace
g.DrawImage(Rimg, ...); with
g.DrawImage(mask, ...);, then the gray mask is shown instead of the inverted image.
So, everything is correct, except that ApplyMask() doesn't work. However, it works fine if the image is drawn directly in the panel instead of in the temp bitmap.
Since the code above works perfectly in WSHPM 1.4, my conclusion is that there is a bug in v1.5.
OK, I have isolated the problem. I was wrong. It is not related to the fact that the image is drawn in a bitmap and the bitmap applied to the panel. It seems related to the fact that the image is resized before applying the mask.
I have written a little demo script. (It crashes if you minimize foobar or hide the panel somehow, but that's not the problem. I just wanted to keep the code as simple and short as possible.)
This code works as expected:
var g_img = gdi.Image(fb.ProfilePath + "\\wsh_scripts\\samples\\images\\image.jpg");
var g_mask = gdi.Image(fb.ProfilePath + "\\wsh_scripts\\samples\\images\\mask.png");
function on_paint(gr) {
var ww = window.Width;
var wh = window.Height;
var Rimg = g_img; // this line is OK
var Rmask = g_mask.Resize(Rimg.Width, Rimg.Height);
Rimg.ApplyMask(Rmask);
gr.DrawImage(Rimg, 0, 0, ww, wh, 0, 0, Rimg.Width, Rimg.Height);
Rimg.Dispose();
Rmask.Dispose();
Note that the original image is simply copied to the local variable Rimg, then the mask is resized and applied.
This code doesn't work:
var Rimg = g_img.Resize(ww, wh); // this line causes the bug!
Rimg.Dispose();
Rmask.Dispose();
The only difference is that the image is resized when it is placed in the Rimg variable.
If you remove the
Rimg.ApplyMask(Rmask); line, the image is correctly drawn, without transparency.
The conclusion is that there is a bug in the ApplyMask() or Resize() method, that makes them incompatible.
That bug was not present in WSHPM v1.4.
T.P. Wang, can you have a look?
@derty2:
I've found a workaround for the current ApplyMask() bug, so the reflection is visible again. :-) (Technical note: I do the resize after having applied the mask.)
I have also fixed the change I forgot to do in v1.1 and that caused the crashes.
You can download WSH_Artwork_Viewer v1.2 here (http://www.4shared.com/file/jTKjPJaS/WSH_Artwork_Viewer.html).
Note that the menus have not been modified (and I don't think I'll do it), so you might still have the warning "Please use AppendTo() method to create sub menu instead of AppendMenuItem()". I'm sure you can live with it! ;-)
Enjoy!
r0lZ, you are a real champion...
I can't concentrate real hard right now, my eyes are welling up.
My cat Astro... I had him put down and I can't concentrate.
He liked coming into my room and listening to music with me; I feel a bit lost.
I'm really sorry, man. I have a cat too, and I understand.
BTW, the ApplyMask() bug has been confirmed by T.P Wang (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=70363&view=findpost&p=775955), and will be fixed soon...
Hey all! I have a question about Marc's Web Links panel.
I'm trying to align 4 buttons relative to window.Width on the X-axis so they would remain centred on resize, but nothing I tried was successful:
Try #1:
I tried entering ww directly in their X coordinate:
but1: new Button(ww/2-bw*2,.....
but2: new Button(ww/2-bw,.....
but3: new Button(ww/2+bw,.....
but4: new Button(ww/2+bw*2,.....
etc.
Try #2:
define var left_margin as ww and then positioning from there:
var left_margin=ww/2
Try #3:
Similarly to the one above, I tried to use a flag to center the whole thing and then position them as
but1: new Button(-(bw*2),.....
but2: new Button(-bw,.....
but3: new Button(bw,.....
but I haven't yet managed to find the correct flag to use for them.
Could anyone help?
change your on_size function to this...
function on_size() {
ww = window.Width;
wh = window.Height;
left_margin = Math.round((ww - (bw * 4)) / 2); //4 is the number of buttons.
on_metadb_changed();
you shouldn't need to edit the x value where the buttons are defined except for any new buttons you've added.
(OT so pls ignore me....)
Derty; Im also very sorry - I have 3 cats That pain tears your heart out, awful.
Brilliant, Marc, thanks!
nobody can help me?
if thing i asking before is impossible, can i call a part of main menu? for example, i need only possible methods of sort from "Edit/Sort" menu
thanks in advance
p.s. sorry for my english - i`m from russia, our biggest foobar forum isnt exist anymore, so i rely on your help
that's not possible.
very sad. but i got a new idea: maybe its possible to read core.cfg with cmd.exe? find the string with dsp names (i saw them, there a string with them separeted by commas). but i havent imagination how to read these files throu cmd. could anybody help?
I've got a question: Is it possible to change groups and columns in SimPlaylist or default playlist (DUI) after switch to another playlist? Is it possible to change size of columns?
Thanks a lot
@romka18, not possible
@suaff, it looks like you're in the wrong thread
This is thread about scripts for WSH Panel Mod? Is it possible to write script for WSH Panel Mod plugin to change group/columns in playlist after switch to another playlist? (SimPlaylist or default playlist)
in that case, no.
the only way you can interact with other components is through main menu or playlist context menu commands (plus the documented core functions).
What about playlist header contex menu? Is it possible to interact with it?
Hi r0lZ,
Many thanks for the script. Is it possible to draw a shadow around the album art?
What is the point of copying that quote in full !!?? Why didn't you just ask r0lZ a question !!??
I just clicked the reply button on the right but forgot to delete the quotes
[!--sizeo:3--][span style=\"font-size:12pt;line-height:100%\"][!--/sizeo--]
— WSH TextFile Viewer —[/size]
A script for displaying a text file in a WSH panel
View a screenshot of my own foobar2000 rendering the script (upper right side): (http://img440.imageshack.us/img440/8417/screenshotaqp.th.png) (http://img440.imageshack.us/img440/8417/screenshotaqp.png)
!!Read this before using the script...
+ "WSH TextFile Viewer"
+ Displays a specified text file found in the same folder as the playing track in a foobar2000 panel.
+ When a track is played and the text file is not found, rather than display nothing, your panel will display:
+ _____________________________________________________
+ folder.txt
+ - To create the panel in your foobar2000 layout, use "WSH Panel Mod" component, and import this script.
+ It works with "Default User Interface" (DUI) or "Columns UI" (CUI).
+ - To display a text file with EVERY album one needs a very disciplined attitude to the presentation of his music collection;
+ it is time consuming, and essentially you are training yourself to be a professional librarian.
+ Personally, I find it highly educational and constructive.
+ - It is a good idea to create a standard name for your text file and stick to it;
+ My standard name for the text file is "folder.txt", which matches well with my standard name for all coverart "folder.jpg".
+ Also, for consistent display in foobar2000, try to create a standard template for your text file and stick to it;
+ To get you started, I have included a few sample templates further down this page.
+ Furthermore: If you discipline yourself to keep a TXT file in every album folder, it will be useful if
+ one day, filenames and tags are somehow all screwed up ...you have lost track of something,
+ you need to find where it is buried in your music collection...
+ So you fire up the Windows Command Prompt and type (example):
+ FINDSTR /I /S /P /M /C:"some string" "F:\my music" folder.txt
+ or for multiple items (example):
+ FINDSTR /I /S /P /M /C:"the beatles" "vinyl" "F:\my music" *.txt *.cue
+ and you have found your lost item(s) !!
+ - ALL text files MUST be saved with ANSI encoding (ie. not Unicode etc).
+ If you see wierd characters being rendered in your Panel, open the text file in "Notepad" and go to the menu:
+ File -> Save As... -> and choose "ANSI" from the Encoding drop-down.
+ - If your panel continues to show wierd characters instead of rendering the text file,
+ there may be more than one text file in the containing folder. Remove the other text files.
+ - You MUST use a Monospace Font if you want correct text indenting.
+ I chose "Arial monospace" as my personal favourite. Therefore, the default font in this script is set to "Arial monospace - size 10".
+ If it is not found, your Panel will default to your system font. To edit, go to the code section named "FONT SETTINGS".
+ - You can tweak text margins and alignments, if you wish. To edit, go to the code section named "DISPLAY PARAMETERS".
+ - I have edited this script to ONLY display text files named "folder.txt" ...ALL OTHER TEXT FILES WILL BE IGNORED !!!
+ If you prefer to change this to reading of ANY text file, then go to the code section named "TEXT FILE PARAMETERS" WSH_TextFile_Viewer.txt — Note: I have made this really easy and user friendly; guided comments and explanations are placed all through the script.
/* :::::::::::::::::::::: Script Engine: JScript :::::::::::::::::::::::::::::::
+ folder.txt
+ -- Enjoy ~derty2
+ -- This script is a modification of (".nfoo Viewer 1.1" ©2010 by Matthijs Brobbel). All credits go to him.
+ [http://code.google.com/p/foobar-silk/][http://matthijsb.deviantart.com/art/nfoo-Viewer-1-1-170638369]
// --- Useful Characters For Composing Your Text File (Keyboard Mappings)
— Em Dash Alt+0151
• Bullet Alt+0149
© Copyright Sign Alt+0169
// --- Useful Template for a Classical Music album - START TEXT FILE
Chicago Symphony Orchestra - Fritz Reiner, conductor
SERGEI PROKOFIEV (1891-1953): Lieutenant Kije, film score and symphonic suite for orchestra, Op.60 (1957)
IGOR STRAVINSKY (1882-1971): Song Of The Nightingale, symphonic poem for orchestra (1956)
• Composed, Classical, 20th Century, Orchestral Suite, Folk Tune, Tone Poem
• Most older listeners agree that Prokofiev's "Lieutenant Kije" suite was ideal repertoire for Fritz Reiner and the Chicago Symphony Orchestra. In this superb recording, Reiner and the Chicago were at the top of their form and their Kiji is witty, sassy, brave, ironic, and altogether hilarious. It was originally written for a movie. Contrastingly, Reiner and the Chicago were seemingly out of their element with Stravinsky's tone poem "Song of the Nightingale". With its spiky motifs, its primary colors, its hard harmonies, and its relentless rhythms, the repetoire did not seem a correct fit. But although their approach is essentially Straussian, Reiner and the Chicago still excel at Stravinsky's Nightingale. It was written as a tribute to Hans Christian Anderson.
____________________________________________________________________________________________________
_____
Vinyl LP 180g, RCA/Chesky #RC10, USA, Reissue from original 3-track master tape ~ Rip by NETTZ (Nov 2011)
———————— TRACKS ———————
Side 1
01. Prokofiev — Lieutenant Kije, Op.60
: The Birth of Kije
: Romance
: Kije's Wedding
: Troika
: The Burial of Kije
• Recorded: 1957
• Written: 1934; Paris, France
Side 2
02. Stravinsky — Song Of The Nightingale
: Presto
: Chinese March
: Song of The Nightingale
: The Mechanical Nightingale
: The Emperor's Displeasure at the departure of the real nightingale
: The Emperor's sickroom
: The real nightingale returns to thwart Death
: Funeral march and Finale
• Recorded: 1956
• Written: 1917; Switzerland
———————— CREDITS ———————
**Composed By – Igor Stravinsky, Sergei Prokofiev **Conductor – Fritz Reiner **Orchestra – Chicago Symphony Orchestra **Produced by - Richard Mohr **Recording Engineer - Lewis Layton ||| **Mastering Engineer – Jack Adelman **Executive Producers - David and Norman Chesky **Design [Photo] – Ben Rose **Liner Notes – Irving Kolodin
———————— NOTES ———————
Premium Vinyl Pressing HQ-180 (180 gram vinyl)
Audiophile re-issue of RCA LSC-2150
"Master Recordings Owned Exclusively by RCA Records, a label of BMG Music"
Prokofiev has alternative spelling of "Prokofieff" on this album.
This record was reproduced from the original three-track master session tape. The playback machine was an Ampex 300 series three track tape recorder totally retubed and rebuilt to the highest standards available today. The three tracks were mixed to two, using a modified Perfectionist Audio Components Pro Reference Tube Preamp. The signal was fed from the preamp directly into the lathe, bypassing the mixing console and all equalizers, thus eliminating one more set of electronic coloration.
———————— COMMENTS ———————
"..This (RC10) is one of Chesky’s best efforts, I like it better than the newer Classic Records version, and it's the LP that got me interested in RCA Living Stereo! Bravo Chesky.." ---vinylfanatics.com/analoglovers/page26.html
———————— RIP LOG ———————
Ripped by NETTZ | Nov 2011
Technical Info:
• Turntable: Roksan Radius III
• Tonearm: Audioquest PT-9
• Cartridge: Ortofon X5-MC (Moving Coil)
• Phono Cable: Van den Hul D-502 Hybrid
• Pre-amplifier: Counterpoint SA 5.1 (vacuum tube Sovtek 6922)
• Interconnect: balanced, Belden 1813A cable with Neutrik XLR connectors
• Analog to Digital Converter: EMU 1212M (configured for balanced input +4dBu, 0 dB Gain)
• Capture software: Goldwave 5.58
• Post processing: ClickRepair, setting: 20, reverse, wavelet x2
// --- Useful Template for a Classical Music album - END TEXT FILE
// --- Useful Template for a Popular Music album - START TEXT FILE
The Romantics — The Romantics (1980)
• Popular, Pop Rock, Power Pop, USA
• The Romantics didn't exactly reinvent the wheel with this album, but they sure knew how to make it roll, and for sheer party enhancing energy, this album is hard to beat. The songs are a glorious pastiche of period pop styles (think the Kinks and the Easybeats with a bit of the Hollies thrown in for melodic appeal) played with a hard-stomping energy and a genuine love for the vintage style that doesn't reek of nostalgia. The production is simple but smart enough to put the hooks at the energy end up front where they belong, and the Romantics never had a set of tunes this strong again.
CD Album, Nemperor/Epic(Sony) #ZK 36273, USA, ©1993 ~ Exact Audio Copy 1.0b2
———————— TRACKS ————————
01. When I Look In Your Eyes
02. Tell It To Carrie
03. First In Line
04. Keep In Touch
05. Girl Next Door
06. What I Like About You
07. She's Got Everything
08. Till I See You Again
09. Hung On You
10. Little White Lies
11. Gimme One More Chance
———————— CREDITS ————————
**Bass, Vocals – Rich Cole **Drums, Vocals – Jimmy Marinos **Lead Guitar, Vocals – Mike Skill **Rhythm Guitar, Vocals – Wally Palmar **Producer – Peter Solley **Engineer – Steve Brown **Mastered By – Greg Calbi
———————— RIP LOG ————————
*** CD Rip by "JOHN CITIZEN" | Nov 2011 ***
Exact Audio Copy V1.0 beta 2 from 29. April 2011
EAC extraction logfile from 15. July 2011, 20:20
Used drive : TDK CDRW4800B Adapter: 2 ID: 1
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 6
Overread into Lead-In and Lead-Out : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Used output format : Internal WAV Routines
Sample format : 44.100 Hz; 16 Bit; Stereo
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 3:01.10 | 0 | 13584
2 | 3:01.10 | 3:23.55 | 13585 | 28864
3 | 6:24.65 | 2:38.00 | 28865 | 40714
4 | 9:02.65 | 3:42.02 | 40715 | 57366
5 | 12:44.67 | 4:41.65 | 57367 | 78506
6 | 17:26.57 | 2:55.30 | 78507 | 91661
7 | 20:22.12 | 2:35.40 | 91662 | 103326
8 | 22:57.52 | 3:53.70 | 103327 | 120871
9 | 26:51.47 | 3:25.50 | 120872 | 136296
10 | 30:17.22 | 2:39.65 | 136297 | 148286
11 | 32:57.12 | 4:28.08 | 148287 | 168394
// --- Useful Template for a Popular Music album - END TEXT FILE
function readTXT(){
displaytext = "";
txt = "————————————————————————————————————————————————————————\nfolder.txt";
if (! fb.IsPlaying) return;
try{
var xpath = fb.TitleFormat("%path%").EvalWithMetadb(fb.GetNowPlaying());
var path = xpath.substring(0, xpath.lastIndexOf("\\")) + "\\";
var Folder = fso.GetFolder(path);
var filelist = new Enumerator(Folder.Files);
for (i=0;!filelist.atEnd();filelist.moveNext()) {
if (filelist.item().name.match(/.*\.txt$/)) {
// ================================================================================================= TEXT FILE PARAMETERS - START
//txtfile = fso.OpenTextFile(path + filelist.item().name, 1, -1); // <---------- THIS IS THE ORIGINAL CODE --- Enables reading of ANY text file found in folder of playing track --- !!KNOWN PROBLEM: it opens text files from wrong location in some instances, such as when opening URL STREAMS from a playlist ------------>
//txtfile = fso.OpenTextFile(path + "folder.txt", 1, -1); <---------- "-1" PARAMETER --- Always auto-creates a blank specified text file (if not exist) in the same folder as the track being played ------------>
// --- MY PREFERENCE: If specified text file (folder.txt) exists in folder of playing track, display it, ELSE show specified characters (at line 273).
txtfile = fso.OpenTextFile(path + "folder.txt", 1, 1);
// ================================================================================================= TEXT FILE PARAMETERS - END
txt = txtfile.ReadALL() + "\n\n";
txtfile.Close();
//displaytext = displaytext + txt;
displaytext = txt;
catch(e){
try {
txtfile.Close();
catch(f) {
calc();
window.Repaint();
// ================================================================================================= DISPLAY PARAMETERS - START
// <---------- You can tweak the text margins and alignments in the panel by adjusting the parameters here ---------->
// <---------- FYI: Centering text can be done with DT_CENTER . add it to the line like this: "gr.GdiDrawText(displaytext ... DT_NOPREFIX | DT_CENTER);" ---------->
function on_paint(gr){
gr.FillGradRect( 0, 0, ww, wh, 90, backcolor, backcolor);
gr.GdiDrawText(displaytext, gfont, txtcolor, 5, offset + 10, ww-10, 60*wh,DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
// <------------------------------------- Backup of Original Script -------------------------------------------------------->
// function on_paint(gr){
// gr.FillGradRect( 0, 0, ww, wh, 90, backcolor, backcolor);
// gr.GdiDrawText(displaytext, gfont, txtcolor, 10, offset + 10, ww-20, 50*wh,DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
// ================================================================================================= DISPLAY PARAMETERS - END
function on_mouse_rbtn_up(x, y){
var _backgroundcolor = window.CreatePopupMenu();
var _textcolor = window.CreatePopupMenu();
var _menu = window.CreatePopupMenu();
var idx;
_menu.AppendMenuItem(MF_STRING, 1, "Update");
_menu.AppendMenuItem(MF_SEPARATOR, 0, 0);
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _textcolor.ID, "Text Color");
_textcolor.AppendMenuItem(MF_STRING, 98, "Foobar Text");
_textcolor.AppendMenuItem(MF_STRING, 99, "Foobar Highlight");
_textcolor.AppendMenuItem(MF_STRING, 101, "White");
_textcolor.AppendMenuItem(MF_STRING, 102, "Red");
_textcolor.AppendMenuItem(MF_STRING, 103, "Green");
_textcolor.AppendMenuItem(MF_STRING, 104, "Blue");
_textcolor.AppendMenuItem(MF_STRING, 105, "Yellow");
_textcolor.AppendMenuItem(MF_STRING, 106, "Black");
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _backgroundcolor.ID, "Background Color");
_backgroundcolor.AppendMenuItem(MF_STRING, 210, "Foobar Background");
_backgroundcolor.AppendMenuItem(MF_STRING, 211, "White");
_backgroundcolor.AppendMenuItem(MF_STRING, 212, "Red");
_backgroundcolor.AppendMenuItem(MF_STRING, 213, "Green");
_backgroundcolor.AppendMenuItem(MF_STRING, 214, "Blue");
_backgroundcolor.AppendMenuItem(MF_STRING, 215, "Brown-Black");
_backgroundcolor.AppendMenuItem(MF_STRING, 216, "Black");
if(window.GetProperty("textcolor")==101){
_textcolor.CheckMenuItem(101, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==102)
{_textcolor.CheckMenuItem(102, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==103)
{_textcolor.CheckMenuItem(103, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==104)
{_textcolor.CheckMenuItem(104, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==105)
{_textcolor.CheckMenuItem(105, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==106)
{_textcolor.CheckMenuItem(106, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==98)
{_textcolor.CheckMenuItem(98, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==99)
{_textcolor.CheckMenuItem(99, window.GetProperty("textcolor"));}
if(window.GetProperty("backgroundcolor")==211){
_backgroundcolor.CheckMenuItem(211, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==212)
{_backgroundcolor.CheckMenuItem(212, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==213)
{_backgroundcolor.CheckMenuItem(213, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==214)
{_backgroundcolor.CheckMenuItem(214, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==215)
{_backgroundcolor.CheckMenuItem(215, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==216)
{_backgroundcolor.CheckMenuItem(216, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==210)
{_backgroundcolor.CheckMenuItem(210, window.GetProperty("backgroundcolor"));}
_menu.AppendMenuItem(MF_STRING, 8, "Configure");
idx = _menu.TrackPopupMenu(x, y);
switch(idx) {
case 1:readTXT();calc();window.Repaint();break;
case 8:window.ShowConfigure();break;
case 98:window.SetProperty("textcolor", 98);txtcolor = g_textcolor;window.Repaint();break;
case 99:window.SetProperty("textcolor", 99);txtcolor = g_textcolor_hl;window.Repaint();break;
case 101:window.SetProperty("textcolor", 101);txtcolor = RGB(255,255,255);window.Repaint();break;
case 102:window.SetProperty("textcolor", 102);txtcolor = RGB(255,50,50);window.Repaint();break;
case 103:window.SetProperty("textcolor", 103);txtcolor = RGB(50,255,50);window.Repaint();break;
case 104:window.SetProperty("textcolor", 104);txtcolor = RGB(150,150,250);window.Repaint();break;
case 105:window.SetProperty("textcolor", 105);txtcolor = RGB(255,255,50);window.Repaint();break;
case 106:window.SetProperty("textcolor", 105);txtcolor = RGB(10,10,10);window.Repaint();break;
case 210:window.SetProperty("backgroundcolor", 210);backcolor= g_backcolor;window.Repaint();break;
case 211:window.SetProperty("backgroundcolor", 211);backcolor= RGB(255,255,255);window.Repaint();break;
case 212:window.SetProperty("backgroundcolor", 212);backcolor= RGB(255,50,50);window.Repaint();break;
case 213:window.SetProperty("backgroundcolor", 213);backcolor= RGB(50,255,50);window.Repaint();break;
case 214:window.SetProperty("backgroundcolor", 214);backcolor= RGB(10,36,106);window.Repaint();break;
case 215:window.SetProperty("backgroundcolor", 215);backcolor= RGB(28,28,28);window.Repaint();break;
case 216:window.SetProperty("backgroundcolor", 216);backcolor= RGB(0,0,0);window.Repaint();break;}
_menu.Dispose();_textcolor.Dispose();_backgroundcolor.Dispose();return true;
DT_CENTER = 0x00000001;
DT_VCENTER = 0x00000004;
DT_WORDBREAK = 0x00000010;
DT_CALCRECT = 0x00000400;
DT_NOPREFIX = 0x00000800;
MF_SEPARATOR = 0x00000800;
MF_ENABLED = 0x00000000;
MF_UNCHECKED = 0x00000000;
MF_CHECKED = 0x00000008;
MF_STRING = 0x00000000;
MF_POPUP = 0x00000010;
var fso = new ActiveXObject("Scripting.FileSystemObject");
var dui = window.InstanceType;
var displaytext = "";
// ================================================================================================= FONT SETTINGS - START
// <---------- gdi.Font is changed, the last paramter is style flags ---------->
// <---------- Style Flags Reference: FontStyleRegular = 0 | FontStyleBold = 1 | FontStyleItalic = 2 | FontStyleBoldItalic = 3 | FontStyleUnderline = 4 | FontStyleStrikeout = 8 ---------->
// <---------- Choose Font: Un-comment the font you want to use !! Make sure the target font exists !! You MUST use a monospace font if you want correct text indenting ---------->
// --- MY PREFERENCE: Arial monospace has a good overall feature set. It renders a large set of characters, It displays well at small sizes, is easy to read, and has a dotted zero.
var gfont =gdi.Font("Arial monospaced for SAP", 10, 0);
// --- MY SECOND PREFERENCE: They are nearly identical. Have unembelished zero (No slashes or dots) which is quite nice.
// var gfont =gdi.Font("OCRBLetM", 10, 0);
// var gfont =gdi.Font("OCR-BczykNorm", 11, 0);
// ================================================================================================= FONT SETTINGS - END
var offset =0;
var ColorTypeDUI = {text: 0,background: 1,highlight: 2,selection: 3};
var ColorTypeCUI = {text: 0,selection_text: 1,inactive_selection_text: 2,background: 3,selection_background: 4,inactive_selection_background: 5,active_item_frame: 6};
String.prototype.count=function(s1){return (this.length - this.replace(new RegExp(s1,"g"), '').length) / s1.length;}
function RGB(r,g,b) {
return (0xff000000|(r<<16)|(g<<8)|(b));
function get_colors() {
if (dui) {
g_textcolor = window.GetColorDUI(ColorTypeDUI.text);
g_textcolor_hl = window.GetColorDUI(ColorTypeDUI.highlight);
g_backcolor = window.GetColorDUI(ColorTypeDUI.background);
} else {
g_textcolor = window.GetColorCUI(ColorTypeCUI.text);
g_textcolor_hl = window.GetColorCUI(ColorTypeCUI.text);
g_backcolor = window.GetColorCUI(ColorTypeCUI.background);
function on_size(){
ww = window.Width;
wh = window.Height;
calc();
window.Repaint();
function calc(){
temp_bmp = gdi.CreateImage(1, 1);
temp_gr = temp_bmp.GetGraphics();
arr = temp_gr.GdiDrawText(displaytext, gfont, g_textcolor, 0, 0, ww, wh-40,DT_CENTER| DT_WORDBREAK | DT_VCENTER | DT_CALCRECT | DT_NOPREFIX).toArray();
textheight = arr[3] - arr[1] + (wh) + (displaytext.count("\n") * 3);
temp_bmp.ReleaseGraphics(temp_gr);
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;offset = 0;
function on_mouse_wheel(delta){
step = gfont.height * 5;
offset += (delta * step);
if(offset > 0 || textheight < wh) {
offset = 0;}
else {
temp = -textheight + wh;
if(offset < temp) offset = Math.round(temp / step) * step;
window.Repaint();
function on_playback_new_track(){
readTXT();calc();
window.Repaint();
get_colors();
on_size();
tc = window.GetProperty("textcolor",98);
if(tc==98){txtcolor = g_textcolor}else if(tc==99){txtcolor=g_textcolor_hl}else if(tc ==101){txtcolor = RGB(255,255,255);}else if(tc==102){txtcolor=RGB(255,50,50)}else if(tc==103){txtcolor=RGB(50,255,50)}else if(tc==104){txtcolor=RGB(150,150,250)}else if(tc==105){txtcolor=RGB(255,255,50)}else if(tc==106){txtcolor=RGB(10,10,10)};
bc = window.GetProperty("backgroundcolor",210);
if(bc==210){backcolor = g_backcolor}else if(bc ==211){backcolor = RGB(255,255,255);}else if(bc==212){backcolor=RGB(255,50,50)}else if(bc==213){backcolor=RGB(50,255,50)}else if(bc==214){backcolor=RGB(10,36,106)}else if(bc==215){backcolor=RGB(28,28,28)}else if(bc==216){backcolor=RGB(0,0,0)};
readTXT();
window.Repaint();
Marc, i hope this question to you is in the right place:
I have been enjoying your "thumbs" script for WSH panel mod, and it has been showing thumbnails of the pictures in the directories where the music files are. So, if I click on an album, I can see the artwork in the same directory as that album - great!
Question - I have noticed that this has been slowing down browsing through my collection, in particular the loading of front & rear album artwork (the front is displayed in a CD jewel case using your script, and the back is just in an album art window). Any thoughts on how to improve this performance. Alternatively, could the script not scan the directory by default, but only when that particular tab is selected (or a button in the tab to scan is pressed)?
Sorry for hijacking the thread, sort of, but is it possible to merge two consistent panels with each other so they are viewed together, using WSH Panel Mod?
What I want to do is that I want the panel "Item details" displayed above "Channel spectrum panel", like this:
(http://filesmelt.com/dl/foobar2000itemdetailsplusspectrumpanel.png)
I'm quite new to scripting and all but I just wanted to know if it is possible or if there already is a script for this.
Marc, back once again for your help and guidance.
I have been using your last.fm similar artist script, and it works like a charm.
One thing, that i would like to know, how easy would it be, to change the output from
artist1
artist2
artist3
artist4
artist5
artist6
artist7
artist8
artist9
to this
artist1 artist2 artist3 artist4
artist5 artist6 artist7 artist8
artist9
And if it is possible, which function should i go scratch around in.
Thanks in advance,
Marc, I continue to enjoy your scripts - thanks very much! A question that I can't figure out: is there a way to configure your thumbs script to have a custom folder location for images to be saved and still have the script automatically download images from lastfm if there are no images found for that artist in the custom location? I have several portable installations of Foobar2000 around the house and only one standard installation, and I'd like all of the installations to share a common storage location for lastfm art without only having this custom location as the only source for all images (I still want the script to download images if it can't find any in the custom location). I could be misunderstanding how the current thumbs script works, but it seems to only allow automatic download of images for the default storage location.
Thanks for any thoughts.
@extracampine, i don't think i can do anything about performance. i suppose not re-drawing on artist change/panel refresh and triggering it manually could be done but i'm not very motivated to do it at the moment. sorry.
@endlesslyonline, to add support for columns would require tweaking several functions. there's
on_paint which controls the display but you'd also need to track the mouse pointer in
on_mouse_move and
on_mouse_lbtn_up@godrick. you can browse the
marc2003 folder you extracted and edit the file named
common4.js find
var data_folder = fb.ProfilePath + "wsh_lastfm\\";
you can edit this path to a common network share. note the double backslash to separate folder names. i'm not sure if UNC paths would work. you can test that.
var data_folder = "g:\\foobar stuff\\wsh_lastfm\\";
this affects all my scripts that display artist info so be aware of that. obviously you need to make sure the network share is writeable.
I'm trying to install the xch4nge skin and right now I'm receiving an error on opening foobar. The error messages are:
Scripting Engine Initialization Failed ({05B7045B-7957-4F5C-9D6D-28ECC5B7EE1E}, CODE: 0x800401f3): Invalid class string
and
Scripting Engine Initialization Failed ({3CF6B331-FD65-4FE2-A0CA-03BE6480BD13}, CODE: 0x800401f3): Invalid class string
I was wondering what I could do to fix this? I'm currently running WSH panel mod 1.5.0 and foobar 1.1.10
Thanks in advance
and
Thanks in advance
bad topic! but answer is that Xch4nge is not compliant with any official WSH panel Mod component, you have to use the one provided in the archive, nothing else.
Hi, I made few customizations to marc's web links script, most notably added Google, Discogs & Wikipedia search and improved title formating for Google & Dg (album aimed) search to optimize search results. Icons similar to icons already existing are included too. Panel is now alignable.
Feel free to download and share any part in your own builds, scripts packs etc, no credits needed
http://www.mediafire.com/?rpiuuxwcio4xhsr (http://www.mediafire.com/?rpiuuxwcio4xhsr)
@Marc2003, your advice on how to create a single image save location in #1310 shared across several Foobar2000 installations was perfect - everything works great with the changes. Since I have spotty internet connectivity in some of my locations throughout the house, this is a big improvement for me. Thanks very much!
@Tigermess, I downloaded your mod of marc2003's 'web links' script...
It failed to load and crashed AND it crashed my 'autoplaylists' script by marc2003.
You included 'common4.js' and 'tooltip_buttons.js' in your package; are they modified? marc2003 already provides these in his packages!
I compared the JS files in Beyond Compare and I see differences.
Thankfully, I made backups of marc2003's JS files and I restored my system. Therefore I am WARNING any potential user of Tigermess' mod ...be careful, do not just overwrite your foobar2000/marc2003 config with what Tigermess has provided.
In my opinion, you should have taken the time to include a README.TXT and documented, what exactly you did and what exactly you modified; what lines, what files.
What you could have done is isolated your path from marc2003's path like this (for example): var script_path = fb.ProfilePath + "scripts\\Tigermess\\";
and added your whole package in there. That way users don't have to destroy their marc2003 configurations just to test your "mod".
Hi, Derty, thanks for report. I apologize for causing you any trouble.
I'm not aware of including any modified files else than script itself. The *.js files shall be from latest marc2003 scripts pack which he ocassionally publishes via DropBox. I included them only for the sake of users who don't have marc's pack yet. If I included any other version, it's regretful mistake. Once I'll be at home, I'll check it and report.
@derty2, you're the one in the wrong here. those files match mine so it's your files that must be out of date. also the script runs without any errors so perhaps an apology is in order.
just checking the dates, i last made changes to mine on the 11th november.
edit: i do see a little problem with the google and discogs links. if your files have no album tag, the search query is blank. perhaps it could just search for the artist in these instances.
I'm glad if it is so.... thanks. Just to be sure I'll still compare the content of the files, 'coz I don't want to screw other people configs. I learned my lesson too, next time I'll include only modified files and include URL to your scripts repository. It will be up to the user if he already has the files or he chooses to download the latest version.
Is definitely good point. I can do that in next release. Actually I was thinking about creating some onClick content menu letting user choose if he wants to search for artist, artist+album or artist+title for each of the services.
Out of curiosity, I'd prefer to let it work with current selection instead of the now playing track. I am not sure if I have seen WSH script displaying anything for the current selection... OTOH you guys do marvelous playlist scripts which have to work with selections somehow. Before I'll spend hours trying, I want to ask just if there's no problem for WSH script to work with current selection instead of what's now playing?
just edit line 25 of your script....
selection_mode = 1;
0 uses the setting found under file>preferences>display>selection viewers
1 uses now playing but follows selection if playback is stopped.
2 always follows the selected item
edit: i should mention that my other scripts don't need editing like this. all the last.fm scripts, cd jewel case, artreader and news-reviews-blogs all default to 0 and have context menu items allowing the user to change the option. under no circumstances should people edit my last.fm playcount sync as changing this setting will break it. it's stuck on now playing whether you like it or not.
This is my marc2003 JS support script setup:
foobar2000\scripts\marc2003\common4.js ===> Date Modified: 2011-11-12 10:07 PM — CRC32: 425EE6C0
foobar2000\scripts\marc2003\common.js ===> Date Modified: 2011-04-14 7:21 PM — CRC32: B95550E7
foobar2000\scripts\marc2003\tooltip_buttons.js ===> Date Modified: 2011-10-30 11:34 PM — CRC32: 7B643F3F
So why did your "Autoplaylists" program script work without a hitch when I installed it?
foobar2000\scripts\marc2003\wsh_samples\autoplaylists.txt ===> 2011-11-12 8:46 PM — CRC32: F0065D32[/font]
So how am I supposed to "know" what are the exact requirements for running the modded script by Tigermess? He didn't leave any documentation with the download package. He didn't specify anything.
Is it not possible that my "test case" above could easily have happened to many other "ignorant" users. I think it is easily possible; and I think I have done ALL such users a BIG favour by outlining my experiences.
Since there is such a critical relationship between your JS support scripts and your program scripts, then why do you FAIL to provide clear verbose preamble comments in the headers of your JS support scripts and your program scripts?
Why don't you have a link to your file repository in your avatar, so people can easily find your "latest" stuff?
Don't you like cultivating an ongoing and updated README.TXT with your packages?
Would you like me to download and try Tigermess' script again? If yes, then point me to ALL NECESSARY REQUIREMENTS and I will try again.
Is it possible for a user to prefix/paste all the lines from the JS support scripts ("common4.js", "tooltip_buttons.js") into a program script such as ("web links.txt")? This way, your program script becomes self-contained and non-dependent on external support files. I would prefer to have things that way.
Thankyou.
ok, perhaps Tigermess should have said you need to be running my very latest scripts for it to be compatible. but you should have thought of this before throwing around accusations that he/she somehow broke it when they haven't made any changes at all.
now because the latest common files seemingly breaks your autoplaylists script, all you need to do is update it to the latest. i know it's a PITA when i change stuff but i do guarantee that if you have common files and scripts from the same zip, they do work.
I checked files... they matched. "Safe" pack is here - marc's web links+ (http://www.mediafire.com/?3elre0z4k9zl0b4).
selection_mode = 1;
I don't mind undocumented features.. thanks For me, it works perfectly in playlist, unfortunately not anywhere else. Is it supposed to work also with media library viewers? I use facets - and it ignores everything I select there.
[I have latest foobar (1.10), WSH Mod (1.5). I don't see file>preferences>display>selection viewers. Checked twice.]
it only works with library viewers if set to 0 and the foobar display preferences set to prefer current selection
as i mentioned above, i provide a nice menu option for most of my scripts. this is the only one that doesn't use it.
(http://dl.dropbox.com/u/22801321/selection%20mode.png)
Just got a chance to play with Tigermess' script
From the first tries, I found that in certain cases and when the album contaiins more than one word, discogs does not recognize it as one album name.
What I get in the search box is a little odd:
6 <omm Content="" With="" Blood="">
Where 6 <omm is the actual artist name, and Content With Blood the album title. Maybe this is due to the odd chars in the artist name? It is from taging via discogs though.
Hi marc2003,
I have a problem in your Simple Biography script that I think it might be a bug (a strange one). It was working all fine and then I played some music from Shlohmo (http://www.last.fm/music/Shlohmo), and then the script just crashed, and if you try to reload id while playing the same song then it crashes the entire Foobar.
I thought it could be a problem in my tags but it seems that it you just change the artist field with "Shlohmo" in any other artist then it reproduces the problem.
I suppose it's something coming from last.fm, but I don't know that
Thanks in advance!
i'm pretty sure it doesn't. the content for that artist from last.fm is indeed broken but it should only cause the panel to stop working, not bring down foobar entirely....
anyway, i've updated it so it displays an error instead.... http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
just import the
simple biogaphy.txt file. no other changes.
Yeah sometimes it crashed the entire foobar, other times just the panel. Here is the error report I got from the last crash if you want to see it, but anyway, it works like a charm now.
Thanks!!
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 704B3A23h
Access violation, operation: read, address: 00000050h
Call path:
entry=>app_mainloop
Code bytes (704B3A23h):
704B39E3h: 00 00 0F 84 FC 57 0A 00 8B 55 C4 8D 45 C0 50 6A
704B39F3h: 00 8D 4D B8 51 52 E8 61 48 FD FF 89 45 E8 8B 45
704B3A03h: 0C 85 C0 74 15 8B 8B 5C 01 00 00 8B 51 50 8B 4D
704B3A13h: C0 50 E8 74 4C FD FF 89 45 E0 8B 83 5C 01 00 00
704B3A23h: 8B 48 50 85 F6 8B 75 E8 0F 95 C2 88 91 74 05 00
704B3A33h: 00 85 F6 0F 88 B2 4E 04 00 8D 47 04 50 FF 15 68
704B3A43h: 13 48 70 85 C0 0F 85 3D 87 FD FF 8B 47 34 C7 07
704B3A53h: E4 C7 48 70 85 C0 0F 85 2E 58 0A 00 8B 47 0C 8B
Stack (002FE3C4h):
002FE3A4h: 00000000 FFFFFD34 000002E4 FFFFFD34
002FE3B4h: 000002CC 00000019 00000000 002FE3F8
002FE3C4h: 68C6806F 00000000 002FE468 00FDB198
002FE3D4h: 04645CB0 00000000 00000000 0104B4E0
002FE3E4h: 04645CB0 0104B4E0 00000000 00000000
002FE3F4h: 00000000 049DCB40 049D0700 04798918
002FE404h: 01085C94 0106871C 00000008 00000000
002FE414h: 00000001 00000000 0A8B4780 80020101
002FE424h: 00FDB198 002FE3C4 002FE4CC 7061C165
002FE434h: 00000001 002FE4DC 704B3897 00FDB198
002FE444h: 00000000 00000000 68C68007 0395FF98
002FE454h: 00000000 0395FF9A 00000017 00000000
002FE464h: 010BE618 00000000 00000000 00000000
002FE474h: 00000000 00000000 00000000 00000000
002FE484h: 00000000 0395FF98 00000000 002FE524
002FE494h: 01085750 704B22B4 00000000 00000000
002FE4A4h: 00000003 00000000 00000000 00000000
002FE4B4h: 00000000 000028E5 00000000 00000001
002FE4C4h: 68C6800B 03CA0000 002FE5BC 7061C1B9
002FE4D4h: 00000000 0393F6E8 002FE528 704A48F5
Registers:
EAX: 00000000, EBX: 00FDB198, ECX: 002FE3F0, EDX: 049DCB40
ESI: 00000000, EDI: 0A8B4780, EBP: 002FE438, ESP: 002FE3C4
Crash location:
Module: jscript9
Offset: 33A23h
Symbol: "DllGetClassObject" (+A337h)
Loaded modules:
foobar2000 loaded at 011D0000h - 013CB000h
ntdll loaded at 77340000h - 774C0000h
kernel32 loaded at 75000000h - 75110000h
KERNELBASE loaded at 76610000h - 76656000h
COMCTL32 loaded at 746D0000h - 7486E000h
msvcrt loaded at 74A80000h - 74B2C000h
GDI32 loaded at 76430000h - 764C0000h
USER32 loaded at 74ED0000h - 74FD0000h
ADVAPI32 loaded at 76300000h - 763A0000h
sechost loaded at 74FE0000h - 74FF9000h
RPCRT4 loaded at 75110000h - 75200000h
SspiCli loaded at 74A20000h - 74A80000h
CRYPTBASE loaded at 74A10000h - 74A1C000h
LPK loaded at 75200000h - 7520A000h
USP10 loaded at 76150000h - 761ED000h
SHLWAPI loaded at 764C0000h - 76517000h
DSOUND loaded at 72DD0000h - 72E42000h
ole32 loaded at 76920000h - 76A7C000h
WINMM loaded at 731B0000h - 731E2000h
POWRPROF loaded at 72DA0000h - 72DC5000h
SETUPAPI loaded at 75E60000h - 75FFD000h
CFGMGR32 loaded at 76520000h - 76547000h
OLEAUT32 loaded at 76850000h - 768DF000h
DEVOBJ loaded at 76000000h - 76012000h
UxTheme loaded at 732A0000h - 73320000h
SHELL32 loaded at 75210000h - 75E5A000h
zlib1 loaded at 5A4C0000h - 5A4D4000h
shared loaded at 73410000h - 7343B000h
imagehlp loaded at 76550000h - 7657A000h
dbghelp loaded at 72CB0000h - 72D9B000h
COMDLG32 loaded at 74C90000h - 74D0B000h
gdiplus loaded at 72E80000h - 73010000h
Secur32 loaded at 73730000h - 73738000h
CRYPT32 loaded at 76730000h - 7684D000h
MSASN1 loaded at 74B60000h - 74B6C000h
IMM32 loaded at 762A0000h - 76300000h
MSCTF loaded at 76660000h - 7672C000h
guard32 loaded at 10000000h - 1004D000h
VERSION loaded at 73330000h - 73339000h
fltlib loaded at 73320000h - 73327000h
HsSrv loaded at 001B0000h - 001E7000h
CLBCatQ loaded at 76580000h - 76603000h
MMDevApi loaded at 749B0000h - 749E9000h
PROPSYS loaded at 748B0000h - 749A5000h
dwmapi loaded at 731F0000h - 73203000h
foo_albumlist loaded at 72A60000h - 72ABD000h
foo_fileops loaded at 73350000h - 73397000h
foo_uie_biography loaded at 72A00000h - 72A58000h
foo_cdda loaded at 729B0000h - 729FE000h
foo_scheduler loaded at 728D0000h - 729AC000h
foo_abx loaded at 028D0000h - 02902000h
foo_uie_wsh_panel_mod loaded at 727F0000h - 728C3000h
Msimg32 loaded at 743B0000h - 743B5000h
foo_ui_std loaded at 726D0000h - 727E9000h
foo_ui_columns loaded at 03AD0000h - 03C60000h
urlmon loaded at 76030000h - 76141000h
iertutil loaded at 74D10000h - 74EC8000h
WININET loaded at 74B70000h - 74C8B000h
Normaliz loaded at 74FD0000h - 74FD3000h
foo_audioscrobbler loaded at 02AA0000h - 02AD3000h
foo_rgscan loaded at 72680000h - 726CB000h
foo_masstag loaded at 03020000h - 03074000h
foo_converter loaded at 72600000h - 7267C000h
foo_wave_seekbar loaded at 72460000h - 725FE000h
WS2_32 loaded at 768E0000h - 76915000h
NSI loaded at 76020000h - 76026000h
foo_uie_console loaded at 02920000h - 0293A000h
foo_discogs loaded at 722E0000h - 72343000h
foo_uie_albumlist loaded at 03280000h - 032C3000h
foo_freedb2 loaded at 73450000h - 73490000h
foo_dsp_std loaded at 72290000h - 722D8000h
foo_input_std loaded at 72120000h - 72290000h
foo_burninate loaded at 720E0000h - 7211E000h
foo_dsp_xgeq loaded at 720A0000h - 720D4000h
foo_deskband_controls loaded at 73710000h - 7371F000h
MSVCR100 loaded at 71FE0000h - 7209E000h
foo_uie_panel_splitter loaded at 03A10000h - 03A69000h
foo_uie_vis_peakmeter_spectrum loaded at 03A80000h - 03ABF000h
foo_dsp_crossfader loaded at 03DB0000h - 03DE2000h
foo_keep_queue loaded at 73960000h - 7396F000h
MSVCR90 loaded at 71F30000h - 71FD3000h
foo_uie_graphical_browser loaded at 71E90000h - 71F24000h
AUDIOSES loaded at 74870000h - 748A6000h
WindowsCodecs loaded at 72B80000h - 72C7B000h
apphelp loaded at 73E70000h - 73EBC000h
DropboxExt.14 loaded at 04110000h - 04127000h
MSVCP71 loaded at 7C3A0000h - 7C41B000h
MSVCR71 loaded at 7C340000h - 7C396000h
EhStorShell loaded at 73DF0000h - 73E21000h
ntshrui loaded at 73D10000h - 73D80000h
srvcli loaded at 73E50000h - 73E69000h
cscapi loaded at 73E40000h - 73E4B000h
slc loaded at 73E30000h - 73E3A000h
SXS loaded at 71E30000h - 71E8F000h
frontend_direct2d loaded at 71DD0000h - 71E27000h
d2d1 loaded at 73B50000h - 73C0A000h
frontend_direct3d9 loaded at 71D60000h - 71DC3000h
d3d9 loaded at 708A0000h - 70A63000h
d3d8thk loaded at 73400000h - 73406000h
d3dx9_42 loaded at 706B0000h - 70895000h
SciLexer loaded at 71CC0000h - 71D51000h
jscript loaded at 71C00000h - 71CB2000h
CRYPTSP loaded at 73DD0000h - 73DE6000h
rsaenh loaded at 73D90000h - 73DCB000h
RpcRtRemote loaded at 73D80000h - 73D8E000h
wshom loaded at 70C10000h - 70C31000h
MPR loaded at 70BF0000h - 70C02000h
ScrRun loaded at 70BC0000h - 70BEA000h
msxml3 loaded at 70A80000h - 70BB3000h
mshtml loaded at 6F170000h - 6FD2B000h
PSAPI loaded at 77310000h - 77315000h
ntmarta loaded at 740B0000h - 740D1000h
WLDAP32 loaded at 761F0000h - 76235000h
msscript loaded at 73020000h - 7303A000h
vbscript loaded at 70640000h - 706AA000h
jscript9 loaded at 70480000h - 7063B000h
IEFRAME loaded at 6E1E0000h - 6EB26000h
OLEACC loaded at 70440000h - 7047C000h
mscms loaded at 738D0000h - 73949000h
USERENV loaded at 738B0000h - 738C7000h
profapi loaded at 738A0000h - 738AB000h
icm32 loaded at 70400000h - 70438000h
nvd3dum loaded at 6D830000h - 6E1D9000h
avrt loaded at 746C0000h - 746C7000h
MLANG loaded at 736E0000h - 7370E000h
explorerframe loaded at 73040000h - 731AF000h
DUser loaded at 73740000h - 7376F000h
DUI70 loaded at 72AC0000h - 72B72000h
mswsock loaded at 74040000h - 7407C000h
wshtcpip loaded at 74030000h - 74035000h
wship6 loaded at 73890000h - 73896000h
DNSAPI loaded at 73970000h - 739B4000h
IPHLPAPI loaded at 74090000h - 740AC000h
WINNSI loaded at 74080000h - 74087000h
rasadhlp loaded at 73880000h - 73886000h
fwpuclnt loaded at 73840000h - 73878000h
Stack dump analysis:
Address: 7061C165h (jscript9+19C165h), symbol: "DllUnregisterServer" (+7D173h)
Address: 704B3897h (jscript9+33897h), symbol: "DllGetClassObject" (+A1ABh)
Address: 704B22B4h (jscript9+322B4h), symbol: "DllGetClassObject" (+8BC8h)
Address: 7061C1B9h (jscript9+19C1B9h), symbol: "DllUnregisterServer" (+7D1C7h)
Address: 704A48F5h (jscript9+248F5h), symbol: "JsVarToScriptDirect" (+22C89h)
Address: 704B22EAh (jscript9+322EAh), symbol: "DllGetClassObject" (+8BFEh)
Address: 727F9A51h (foo_uie_wsh_panel_mod+9A51h)
Address: 74EF12A5h (USER32+212A5h), symbol: "PostMessageW" (+0h)
Address: 72890FF4h (foo_uie_wsh_panel_mod+A0FF4h), symbol: "foobar2000_get_interface" (+5CA34h)
Address: 012FE6CCh (foobar2000+12E6CCh)
Address: 728880CAh (foo_uie_wsh_panel_mod+980CAh), symbol: "foobar2000_get_interface" (+53B0Ah)
Address: 7282BFD9h (foo_uie_wsh_panel_mod+3BFD9h)
Address: 74F0D0F5h (USER32+3D0F5h), symbol: "SendDlgItemMessageW" (+0h)
Address: 74F0F212h (USER32+3F212h), symbol: "GetDlgItem" (+58h)
Address: 100344AFh (guard32+344AFh), symbol: "Exported" (+A5BFh)
Address: 74F0D127h (USER32+3D127h), symbol: "SendDlgItemMessageW" (+32h)
Address: 10019C3Ah (guard32+19C3Ah)
Address: 001D0926h (HsSrv+20926h), symbol: "removeCOMHook" (+1E286h)
Address: 727FF518h (foo_uie_wsh_panel_mod+F518h)
Address: 727FF39Bh (foo_uie_wsh_panel_mod+F39Bh)
Address: 72885FC8h (foo_uie_wsh_panel_mod+95FC8h), symbol: "foobar2000_get_interface" (+51A08h)
Address: 728882AAh (foo_uie_wsh_panel_mod+982AAh), symbol: "foobar2000_get_interface" (+53CEAh)
Address: 7282BED5h (foo_uie_wsh_panel_mod+3BED5h)
Address: 72817E52h (foo_uie_wsh_panel_mod+27E52h)
Address: 7288FDECh (foo_uie_wsh_panel_mod+9FDECh), symbol: "foobar2000_get_interface" (+5B82Ch)
Address: 728883D0h (foo_uie_wsh_panel_mod+983D0h), symbol: "foobar2000_get_interface" (+53E10h)
Address: 72817747h (foo_uie_wsh_panel_mod+27747h)
Address: 7282B797h (foo_uie_wsh_panel_mod+3B797h)
Address: 72894D0Ch (foo_uie_wsh_panel_mod+A4D0Ch), symbol: "foobar2000_get_interface" (+6074Ch)
Address: 72819200h (foo_uie_wsh_panel_mod+29200h)
Address: 74EE62FAh (USER32+162FAh), symbol: "gapfnScSendMessage" (+332h)
Address: 74F0F943h (USER32+3F943h), symbol: "GetCursor" (+263h)
Address: 74F0F8FBh (USER32+3F8FBh), symbol: "GetCursor" (+21Bh)
Address: 74F4A61Eh (USER32+7A61Eh), symbol: "VTagOutput" (+54h)
Address: 74F0F784h (USER32+3F784h), symbol: "GetCursor" (+A4h)
Address: 74F0F860h (USER32+3F860h), symbol: "GetCursor" (+180h)
Address: 74EE7038h (USER32+17038h), symbol: "GetWindowLongW" (+3Ah)
Address: 746FB4C9h (COMCTL32+2B4C9h), symbol: "ImageList_GetIcon" (+59Bh)
Address: 74F0F889h (USER32+3F889h), symbol: "GetCursor" (+1A9h)
Address: 74EE6D3Ah (USER32+16D3Ah), symbol: "GetThreadDesktop" (+D7h)
Address: 74EE6CE9h (USER32+16CE9h), symbol: "GetThreadDesktop" (+86h)
Address: 74EE965Eh (USER32+1965Eh), symbol: "GetWindow" (+3F0h)
Address: 74EE9679h (USER32+19679h), symbol: "SendMessageW" (+0h)
Address: 74EE96C5h (USER32+196C5h), symbol: "SendMessageW" (+4Ch)
Address: 1001B1D6h (guard32+1B1D6h)
Address: 74EF0F91h (USER32+20F91h), symbol: "GetParent" (+29h)
Address: 74EF0FDBh (USER32+20FDBh), symbol: "GetParent" (+73h)
Address: 74774601h (COMCTL32+A4601h), symbol: "GetEffectiveClientRect" (+3409h)
Address: 74774663h (COMCTL32+A4663h), symbol: "GetEffectiveClientRect" (+346Bh)
Address: 747744EDh (COMCTL32+A44EDh), symbol: "GetEffectiveClientRect" (+32F5h)
Address: 746FB495h (COMCTL32+2B495h), symbol: "ImageList_GetIcon" (+567h)
Address: 74EF21B1h (USER32+221B1h), symbol: "IsChild" (+0h)
Address: 03B33F9Eh (foo_ui_columns+63F9Eh)
Address: 74EE77C4h (USER32+177C4h), symbol: "CharPrevW" (+138h)
Address: 74EE788Ah (USER32+1788Ah), symbol: "DispatchMessageW" (+Fh)
Address: 74F0C81Fh (USER32+3C81Fh), symbol: "IsDialogMessageW" (+11Eh)
Address: 74F0CDE7h (USER32+3CDE7h), symbol: "DialogBoxIndirectParamW" (+1F4h)
Address: 74F0CF5Ch (USER32+3CF5Ch), symbol: "DialogBoxIndirectParamAorW" (+108h)
Address: 74F0CE8Ah (USER32+3CE8Ah), symbol: "DialogBoxIndirectParamAorW" (+36h)
Address: 727F0000h (foo_uie_wsh_panel_mod+0h)
Address: 728B3B38h (foo_uie_wsh_panel_mod+C3B38h), symbol: "foobar2000_get_interface" (+7F578h)
Address: 728192B0h (foo_uie_wsh_panel_mod+292B0h)
Address: 74F0D009h (USER32+3D009h), symbol: "DialogBoxParamW" (+3Fh)
Address: 7282F02Dh (foo_uie_wsh_panel_mod+3F02Dh)
Address: 7282C548h (foo_uie_wsh_panel_mod+3C548h)
Address: 72894D30h (foo_uie_wsh_panel_mod+A4D30h), symbol: "foobar2000_get_interface" (+60770h)
Address: 74EE80A9h (USER32+180A9h), symbol: "GetUserObjectInformationW" (+41h)
Address: 728410CFh (foo_uie_wsh_panel_mod+510CFh), symbol: "foobar2000_get_interface" (+CB0Fh)
Address: 74EE80BBh (USER32+180BBh), symbol: "GetUserObjectInformationW" (+53h)
Address: 72894D40h (foo_uie_wsh_panel_mod+A4D40h), symbol: "foobar2000_get_interface" (+60780h)
Address: 7282DC67h (foo_uie_wsh_panel_mod+3DC67h)
Address: 72888956h (foo_uie_wsh_panel_mod+98956h), symbol: "foobar2000_get_interface" (+54396h)
Address: 7282DC76h (foo_uie_wsh_panel_mod+3DC76h)
Address: 7282C9FFh (foo_uie_wsh_panel_mod+3C9FFh)
Address: 10034204h (guard32+34204h), symbol: "Exported" (+A314h)
Address: 03A8AE2Bh (foo_uie_vis_peakmeter_spectrum+AE2Bh)
Address: 764485C9h (GDI32+185C9h), symbol: "PolyPatBlt" (+EEh)
Address: 764485A2h (GDI32+185A2h), symbol: "PolyPatBlt" (+C7h)
Address: 72888A34h (foo_uie_wsh_panel_mod+98A34h), symbol: "foobar2000_get_interface" (+54474h)
Address: 72831146h (foo_uie_wsh_panel_mod+41146h)
Address: 7644DFB5h (GDI32+1DFB5h), symbol: "GetCharWidthA" (+2A4h)
Address: 7644DF8Ch (GDI32+1DF8Ch), symbol: "GetCharWidthA" (+27Bh)
Address: 7644DF13h (GDI32+1DF13h), symbol: "GetCharWidthA" (+202h)
Address: 7644DFC4h (GDI32+1DFC4h), symbol: "GetCharWidthA" (+2B3h)
Address: 74EE60E2h (USER32+160E2h), symbol: "gapfnScSendMessage" (+11Ah)
Address: 74EE7468h (USER32+17468h), symbol: "ReleaseDC" (+22h)
Address: 03A8C3E1h (foo_uie_vis_peakmeter_spectrum+C3E1h)
Address: 001E077Ah (HsSrv+3077Ah), symbol: "removeCOMHook" (+2E0DAh)
Address: 03A8E173h (foo_uie_vis_peakmeter_spectrum+E173h)
Address: 72871950h (foo_uie_wsh_panel_mod+81950h), symbol: "foobar2000_get_interface" (+3D390h)
Address: 74EE6F9Eh (USER32+16F9Eh), symbol: "GetThreadDesktop" (+33Bh)
Address: 74EE702Ch (USER32+1702Ch), symbol: "GetWindowLongW" (+2Eh)
Address: 72888BF2h (foo_uie_wsh_panel_mod+98BF2h), symbol: "foobar2000_get_interface" (+54632h)
Address: 72871AE1h (foo_uie_wsh_panel_mod+81AE1h), symbol: "foobar2000_get_interface" (+3D521h)
Address: 74F50230h (USER32+80230h), symbol: "ShutdownBlockReasonDestroy" (+59A2h)
Address: 74EE90C9h (USER32+190C9h), symbol: "LoadStringW" (+210h)
Address: 74EE6E57h (USER32+16E57h), symbol: "GetThreadDesktop" (+1F4h)
Address: 74EF291Fh (USER32+2291Fh), symbol: "GetKeyState" (+0h)
Address: 7735011Ah (ntdll+1011Ah), symbol: "KiUserCallbackDispatcher" (+2Eh)
Address: 77350080h (ntdll+10080h), symbol: "KiUserApcDispatcher" (+48h)
Address: 74EE6A8Ch (USER32+16A8Ch), symbol: "gapfnScSendMessage" (+AC4h)
Address: 74EE6AE9h (USER32+16AE9h), symbol: "gapfnScSendMessage" (+B21h)
Address: 7282CC2Dh (foo_uie_wsh_panel_mod+3CC2Dh)
Address: 74EE6B00h (USER32+16B00h), symbol: "gapfnScSendMessage" (+B38h)
Address: 03A8F1DBh (foo_uie_vis_peakmeter_spectrum+F1DBh)
Address: 03A8F1ECh (foo_uie_vis_peakmeter_spectrum+F1ECh)
Address: 77373472h (ntdll+33472h), symbol: "RtlImageNtHeader" (+30Eh)
Address: 70A3A661h (d3d9+19A661h), symbol: "DebugSetLevel" (+F1DB0h)
Address: 708A7641h (d3d9+7641h)
Environment:
App: foobar2000 v1.1.10
OS: Windows 6.1.7601 Service Pack 1 x64
CPU: Intel® Core2 Duo CPU E8400 @ 3.00GHz, features: MMX SSE SSE2 SSE3 SSE4.1
Audio: Altavoces (ASUS Xonar DX Audio Device)
UI: Columns UI 0.3.8.8
Components:
Core (2011-12-02 15:07:36 UTC)
foobar2000 core 1.1.10
foo_abx.dll (2009-04-25 14:44:30 UTC)
ABX Comparator 1.3.4
foo_albumlist.dll (2011-12-02 15:06:12 UTC)
Album List 4.5
foo_audioscrobbler.dll (2010-06-04 07:27:04 UTC)
Audioscrobbler 1.4.7
foo_burninate.dll (2011-03-02 22:43:13 UTC)
Audio CD Writer 3.0.3
foo_cdda.dll (2011-12-02 15:06:00 UTC)
CD Audio Decoder 3.0
foo_converter.dll (2011-12-02 15:05:44 UTC)
Converter 1.5
foo_deskband_controls.dll (2011-07-14 13:09:28 UTC)
Deskband Controls 0.2.0.0
foo_discogs.dll (2011-08-13 14:04:32 UTC)
Discogs Tagger 1.30
foo_dsp_crossfader.dll (2010-12-30 14:56:21 UTC)
Gapless Crossfader 1.3.4.1
foo_dsp_std.dll (2011-12-02 15:06:12 UTC)
Standard DSP Array 1.0
foo_dsp_xgeq.dll (2011-10-09 22:49:27 UTC)
Graphic Equalizer 0.2.1
foo_fileops.dll (2011-12-02 15:05:08 UTC)
File Operations 2.1.3
foo_freedb2.dll (2011-02-27 19:40:56 UTC)
freedb Tagger 0.6.3
foo_input_std.dll (2011-12-02 15:05:54 UTC)
Standard Input Array 1.0
foo_keep_queue.dll (2010-11-12 14:01:49 UTC)
Keep Queue 0.3.5
foo_masstag.dll (2010-08-24 21:09:39 UTC)
Masstagger 1.8.4
foo_rgscan.dll (2011-12-02 15:05:48 UTC)
ReplayGain Scanner 2.1.2
foo_scheduler.dll (2011-12-08 13:23:31 UTC)
Scheduler 4.09
foo_ui_columns.dll (2011-03-17 21:03:02 UTC)
Columns UI 0.3.8.8
foo_ui_std.dll (2011-12-02 15:06:24 UTC)
Default User Interface 0.9.5
foo_uie_albumlist.dll (2009-06-13 22:49:19 UTC)
Album list panel 0.3.5
foo_uie_biography.dll (2010-12-16 22:31:03 UTC)
Biography View 0.4.2.4
foo_uie_console.dll (2009-08-29 16:06:24 UTC)
Console panel 0.4
foo_uie_graphical_browser.dll (2008-04-20 03:37:54 UTC)
Graphical Browser rev015
foo_uie_panel_splitter.dll (2011-05-03 18:22:58 UTC)
Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_vis_peakmeter_spectrum.dll (2008-04-19 19:18:50 UTC)
Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_uie_wsh_panel_mod.dll (2011-11-29 19:52:42 UTC)
WSH Panel Mod 1.5.0
foo_wave_seekbar.dll (2011-12-15 21:30:38 UTC)
Waveform seekbar 0.2.14.2
Recent events:
Autoplaylists initialized in: 0:00.265743
"AP: Added" : 0:00.213486
"AP: Cola" : 0:00.052238
Opening track for playback: "E:\Musica\Coleccion\Clams Casino\2011 - Instrumental Mixtape\06 - What You Doin'.mp3"
Startup time : 0:02.388927
Audioscrobbler: Handshake successful.
Opening track for playback: "E:\Musica\Coleccion\Shlohmo\2011 - Bad Vibes\05 - Parties.mp3"
Error: WSH Panel Mod (Simple Biography by marc2003): Error en tiempo de ejecución de Microsoft JScript:
No se puede obtener valor de la propiedad 'name': el objeto es nulo o está sin definir
File: <main>
Ln: 117, Col: 5
WSH Panel Mod (Simple Biography by marc2003): Parsing file "E:\foobar2000\marc2003\common4.js"
File: <main>
Ln: 117, Col: 5
ah, i see the problem now. i couldn't reproduce the problem before because in the WSH panel mod editor, i only had jscript selected in the script engine dropdown box. if i select jscript9, then it really does cause foobar to crash. i think this is a bug in the component itself. it really should only generate script errors and not bomb out completely.
how can i make this transparent?
// background
gr.FillSolidRect(0, 0, ww, wh, RGBA(0, 0, 0, 255));
gr.DrawLine(0,0,ww,0,1.0,RGBA(20, 22, 25, 255));
gr.FillGradRect(0, 2, ww, wh-3, 90, RGB(000, 000, 000), RGB(20, 20, 20));
i tried rgba but didnt work..
After reading this post:
@Bryter, here's the volume script from my foobar2000:
(Notes: Read the code comments)
(Settings: Script Engine: JScript | Edge Style: None | Grab Focus: checked)
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
// gdi.Font is changed, the last paramter is style flags
// FontStyleRegular = 0,
// FontStyleBold = 1,
// FontStyleItalic = 2,
// FontStyleBoldItalic = 3,
// FontStyleUnderline = 4,
// FontStyleStrikeout = 8
// Here is 0, means FontStyleRegular
var g_font = gdi.Font("Verdana", 10, 0);
var g_drag = 0;
gr.SetTextRenderingHint(5);
var volume = fb.Volume;
// var pos = window.Width * ((100+volume)/100); // <--------- Old linear calculation
var pos = window.Width * Math.exp(0.04*volume); // <--------- Logarithmic calculation (as used in default volume slider)
var txt = "volume " + (Math.ceil(volume)) + " dB";
gr.FillGradRect(0, 0, pos, wh, 0, RGB(40,42,57), RGB(204,0,0));
gr.FillGradRect(pos, 0, ww-pos, wh, 10, RGB(102,102,102), RGB(40,42,57));
gr.DrawString(txt, g_font, RGB(128,192,255), 0, 0, ww, wh, 0x11005000);
gr.DrawRect(0,0,ww-0, wh-0, 0.0, RGB(46,48,63));
function on_mouse_lbtn_down(x,y){
g_drag = 1;
on_mouse_move(x,y);
g_drag = 0;
function on_mouse_move(x,y){
if(g_drag){
var v = x / window.Width;
v = (v<0) ? 0 : (v<1) ? v : 1;
// v = -100 * (1-v); // <--------- Old linear scaling
v = 25 *Math.log(v+0.00001); // <--------- Logarithmic scaling (as used in default volume slider)
if(fb.Volume != v)
fb.Volume = v;
if(delta>0)
fb.VolumeUp();
else
fb.VolumeDown();
function on_volume_change(val){
window.Repaint();
//EOF
... I decided to bounce together a volume control script which can be used to limit the fb2k volume control for safety protection against the risk of permanent hearing damage.
Because my new stereo system doesn't have any volume control whatsoever (except the one of fb2k) I needed some way to prevent big bad accidents. I could have bought a real preamp instead, but didn't. Preamps, and the interconnects they require, will be typically very expensive if you want them to be any good and besides, if all you do is play 24-bit files on a DAC unit which has 24-bit input then IMHO the volume control of fb2k is much better at keeping up the sound quality than an affordable analogue volume control would be, anyway.
The script I made is based on the script I quoted above. Thanks alot to derty2 and to the people who posted other examples, including the ones posted in the original thread:
http://www.hydrogenaudio.org/forums/index....showtopic=70363 (http://www.hydrogenaudio.org/forums/index.php?showtopic=70363)
Please note my modified version of the script is only considered "still a work in progress" and may slow down fb2k Visualization components (I think I have already pinned down the cause, however).
Please also note my volume control script changes the way the fb2k volume control should be handled by the user. The mouse scrollwheel should be used to adjust the safety limit of the volume control while hovering the mouse over the panel window. The safety limit is shown as a bar inside the volume bar and ranges from 5% up to 60% (these values can be edited manually in the script if needed, but anything below 5% will cause a bug). The safety limit is also shown as a percentage value, to the left. It's set to 25% by default at startup (again, this can be changed by manually editing it in the script if needed).
The fb2k volume itself can only be mousedragged and snaps to the mouse pointer only if the mouse pointer is positioned close enough to the edge of the volume bar while pressing left mouse button. The left panel border represents -100 dB (0%) and the right panel border represents the maximum allowed volume. The fb2k volume is set to -50 dB by default at startup (changeable by editing the script, but it has to be below the default safety limit to prevent a bug) and is also shown as a percentage value and a dB value, to the right.
var g_drag=0;
var sc1=173/170;
var sc2=7/384;
var p=25;
var pos=0;
var g_font=gdi.Font("Consolas",12,1);
var g_textrender=gdi.CreateStyleTextRender();
function RGB(r,g,b){return(0xff000000|(r<<16)|(g<<8)|(b))}
function RGBA(r,g,b,a){return((a<<24)|(r<<16)|(g<<8)|(b))}
var ww=window.Width;
var wh=window.Height;
var volume=fb.Volume;
pos=ww*sc1*Math.exp(0.04*volume)-sc2*ww;
pos=pos/(p/100);
gr.FillGradRect(0,0,pos,wh,0,RGB(40,42,57),RGB(p*2+55*g_drag,200-p*2+55*g_drag,Math.abs(100-p*2)+45*g_drag));
gr.FillGradRect(pos,0,ww-pos,wh,40,RGB(48,52,68),RGB(18,18,18));
gr.DrawLine(pos-1,0,pos-1,wh,2,RGB(55+p*2,200-p*2,Math.abs(50-p)));
gr.FillGradRect(0,wh/3,p/100*ww,wh/3,0,RGB(p*1.5,100-p/2,0),RGB(p+50,100-p,50-p/2));
gr.FillGradRect(p/100*ww,wh/3,(1-p/100)*ww+1,wh/3,350,RGB(68,74,82),RGB(48,48,48));
gr.DrawRect(-1,wh/3,ww+1,wh/3,1,RGB(55+p*2,200-p*2,Math.abs(50-p)));
gr.DrawLine(p/100*ww-2,wh/3+2,p/100*ww-2,wh*2/3-2,4,RGB(55+p*2,150-p*1.5,Math.abs(50-p)));
gr.SetSmoothingMode(4);
gr.SetInterpolationMode(4);
g_textrender.GlowText(RGB(240,240,255),RGBA(55+p*2,200-p*2,Math.abs(50-p),30),12);
g_textrender.EnableShadow(true);
g_textrender.ResetShadow();
var p2=Math.round(pos/ww*p);
var str_p=(p2<10?" ":p2<100?" ":"")+p2;
var v=fb.Volume;
var vol=-Math.ceil(-v)+1;
var voldec=""+Math.ceil(-Math.round((v-vol)*100)+100);
var str_vol=v==-100?"-100.00":" "+vol+"."+voldec.substr(1,2);
g_textrender.RenderStringRect(gr,str_p+" % "+str_vol+" dB",g_font,ww/2-80,0,ww,wh,0x11005000);
g_textrender.RenderStringRect(gr,(p<10?" ":p<100?" ":"")+p+" %",g_font,-ww/2+25,0,ww,wh,0x11005000);
if (Math.abs(pos-x)<window.Width/75) g_drag=1;
window.Repaint();
on_mouse_move(x,y);
g_drag=0;
window.Repaint();
if(g_drag){
var xpos=x>ww?ww:x;
xpos=xpos*(p/100);
var v=(xpos+sc2*ww)/sc1/ww;
v=25*Math.log((v<0?0:v<1?v:1)+0.00001);
if (fb.Volume!=v)fb.Volume=v;
if(!g_drag){
if(delta>0){
p=p+1;
p=(p>60)?60:p;
}else{
p=(pos<window.Width*4/5)?p-1:p;
p=(p<5)?5:p;
window.Repaint();
window.Repaint();
window.MinHeight=32;
window.MinWidth=320;
fb.Volume=-50.001;
I know, especially the calculations need some serious tidying up but I'm lazy, just like Marc2003.
Your suggestions to help me improve the script will be greatly appreciated, thanks in advance for that.
New and improved version of the adjustable volume control:
var g_drag=0;
var sc1=173/170;
var sc2=7/384;
var p=25;
var pos=0;
var g_font=gdi.Font("Consolas",14,1);
var g_font2=gdi.Font("Consolas",20,1);
var col1=RGB(205,205,205);
var col2=RGB(255,255,255);
var v=fb.Volume;
pos=ww*sc1*Math.exp(0.04*v)-sc2*ww;
pos=pos/(p/100);
gr.FillGradRect(pos,0,ww-pos,wh,40,RGB(88,82,98),RGB(18,18,18));
var vol=Math.ceil(Math.round(v*100)/100);
var voldec=""+Math.ceil(-Math.round((v+Math.ceil(-v)-1)*100)+100);
var xr=ww-144;
var xl=5;
gr.DrawString(str_p+" % "+str_vol+" dB",g_font2,RGB(0,0,0),xr+2,2,62,wh,0x11005000);
gr.DrawString((p<10?" ":p<100?" ":"")+p+" %",g_font2,RGB(0,0,0),xl-2,2,62,wh,0x11005000);
gr.DrawString(str_p+" % "+str_vol+" dB",g_font2,g_drag?col2:col1,xr,0,62,wh,0x11005000);
gr.DrawString((p<10?" ":p<100?" ":"")+p+" %",g_font2,g_drag?col2:col1,xl,0,62,wh,0x11005000);
window.Repaint();
on_mouse_move(x,y);
g_drag=0;
window.Repaint();
if(g_drag){
var xpos=x>ww?ww:x;
xpos=xpos*(p/100);
if(!g_drag){
if(delta>0){
p=p+1;
p=(p>60)?60:p;
}else{
p=(p<5)?5:p;
window.Repaint();
window.Repaint();
fb.Volume=-50;
anybody can explain me how get playlist item info, using new interface plman? for example, i need title. i knew about fb.titleformat, i need it for playlist. i just cant understand code of Br3tt
function on_paint(gr) {
var playlist = plman.GetPlaylistItems(plman.ActivePlaylist);
var playlist_item_count = plman.PlaylistItemCount(plman.ActivePlaylist);
for (var i = 0; i < playlist_item_count; ++i) {
var item = playlist.Item(i);
gr.GdiDrawText(fb.TitleFormat("%title%").EvalWithMetadb(item), gdi.font("Segoe Ui", 14, 0), RGBA(100, 100, 100), 0, 20*i, 500, 20, DT_CALCRECT | DT_VCENTER)
var handles = plman.GetPlaylistItems(plman.ActivePlaylist); //puts all playlist items into an array called handles.
fb.trace(handles.count); //output how many items in playlist
fb.trace(fb.TitleFormat("%title%").EvalWithMetadb(handles.item(0))); //output title of first item in playlist
fb.trace(fb.TitleFormat("%title%").EvalWithMetadb(handles.item(2))); //output title of third item in playlist
edit: bah, too slow.
i'm sad ...
thanks to everyone! heh, resuming my work
another one newbie question: i need for a groups? for example by artists. so i need to create a %artist% called massive. can anybody give me an example of thing like that?
edit: i jast want create a grouping like artist\album\track, i cant imaginehow create massive "artist" with undermassive "albums" with undermassive songs
is there any way to create a playlist from a folder or known path? folder isnt in library
I modified this modified version of Marc2003:s similar artists code a bit, but don't really understand the code. It works perfectly, but crashes when I select a track with multiple artists (seperated by ";"). Thought someone here might see what the problem is directly?
// ==PREPROCESSOR==
// @import "%fb2k_profile_path%marc2003\common.js"
// @name "Similar Artists"
// @author "marc2003"
// ==/PREPROCESSOR==
var username_file = settings_path + "username";
var username = read(username_file);
var api_key_file = settings_path + "api_key";
var api_key = read(api_key_file);
var lfm_img = gdi.Image(images_path + "lastfm_red_small.gif");
var spotify_img = gdi.Image(images_path + "spotify.png");
var lastfm_play_img = gdi.Image(images_path + "what.ico");
var lastfm_small_img = gdi.Image(images_path + "lastfm small.png");
var up_img = gdi.Image(images_path + "up.png");
var down_img = gdi.Image(images_path + "down.png");
var but_x = 0;
var offset = 0;
var rows = 0;
var title_font = gdi.Font(font, 12, 1);
var normal_font = gdi.Font(font, 11);
var artist = '';
var genre = '';
var g_text = '';
var toptags = new Array();
var g_tooltip = window.CreateTooltip();
var spotify = window.GetProperty("spotify", true);
window.GetProperty("show_artist", true);
window.GetProperty("pause", true);
on_item_focus_change();
function on_notify_data(name, data) {
if(name == "lastfm_update" && data == 1) {
load();
function get() {
if(username.length == 0 || api_key.length != 32) return(fb.trace("Top tags: Can't contact Last.fm. Check your username / API KEY settings."));
lastfm("&method=artist.getTopTags&artist=" + encodeURIComponent(artist), "foo_wsh_lastfm_similar", function() {save(xmlhttp.responsetext, filename); load(); });
function on_size() {
ww = window.Width;
wh = window.Height;
but_x = Math.round((ww - 15) / 2);
offset = 0;
rows = Math.floor((wh - 56) / 20);
gr.FillSolidRect(0, 0, ww, wh, g_backcolor);
gr.GdiDrawText("Tags" + (window.GetProperty("show_artist") ? " for " + artist : ''), title_font, g_textcolor_hl, 6, 6, ww-77, 24, DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.DrawImage(lfm_img, ww-60, 8, 50, 18, 0, 0, 50, 18);
gr.DrawLine(5, 29, ww-10, 29, 1, g_textcolor_hl);
switch(true) {
case (username.length == 0):
case (api_key.length != 32):
gr.GdiDrawText("Please use the context menu to set your Last.fm username and API KEY.", g_font, g_textcolor, 0, 0, ww, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
break;
case (!g_metadb):
gr.GdiDrawText("[no selection]", g_font, g_textcolor, 0, 0, ww, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
break;
case (toptags.length == 0):
gr.GdiDrawText("[no data]", g_font, g_textcolor, 0, 0, ww, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
break;
default:
for(l = 0; l < Math.min(rows, toptags.length); l++) {
gr.DrawImage(lastfm_small_img, 26, 45 + (l * 20), 20, 20, 0, 0, 20, 20);
gr.GdiDrawText(toptags[l + offset].name + " (" + toptags[l + offset].count + ")", normal_font, g_textcolor, 50, 46 + (l * 20), ww-66, 18, DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
if(offset > 0) gr.DrawImage(up_img, but_x, 32, 15, 15, 0, 0, 20, 20);
if(toptags.length > rows && offset < toptags.length - rows) gr.DrawImage(down_img, but_x, wh - 15, 15, 15, 0, 0, 20, 20);
function on_mouse_wheel(delta) {
if(toptags.length < rows) return;
offset -= delta * 3;
if(offset < 0) offset = 0;
if(rows + offset > toptags.length) offset = toptags.length - rows;
window.Repaint();
if(artist == fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb)) return;
load();
function load(gr) {
if(!g_metadb) return(window.Repaint());
artist = fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb);
artist_folder = data_folder + fb.TitleFormat("$crc32(%artist%)").EvalWithMetadb(g_metadb);
if(!fso.FolderExists(artist_folder)) fso.CreateFolder(artist_folder);
filename = artist_folder + "\\toptags.json";
limit = 0;
offset = 0;
if(fso.fileExists(filename)) {
file = fso.Getfile(filename);
ts = fso.OpenTextFile(filename,1, false, -1);
g_text = ts.ReadAll();
ts.close();
parsed_data = JSON.parse(g_text);
if(parsed_data.error != 6) toptags = parsed_data.toptags.tag;
if(Date.parse(Date()) - Date.parse(file.DateLastModified) > 86400000) get();
} else {
get();
window.Repaint();
function on_mouse_move(x,y) {
index = Math.floor((y - 45 ) / 20) + offset;
switch(true) {
case (toptags.length > 0 && x > 26 && x < 46 && index >= offset && index < offset + Math.min(rows,toptags.length)):
tt(toptags[index].url);
window.SetCursor(IDC_HAND);
break;
case (offset > 0 && x > but_x && x < but_x + 15 && y > 32 && y < 47):
case (toptags.length > rows && offset < toptags.length - rows && x > but_x && x < but_x + 15 && y > wh -15):
break;
default:
window.SetCursor(IDC_ARROW);
g_tooltip.Text = '';
g_tooltip.Deactivate();
break;
index = Math.floor((y - 45) / 20) + offset;
switch(true) {
try { WshShell.run(toptags[index].url); } catch(e) {}
break;
on_mouse_wheel(1);
break;
on_mouse_wheel(-1);
break;
function on_mouse_rbtn_up(x, y) {
var _links = window.CreatePopupMenu();
var _selection = window.CreatePopupMenu();
var idx;
_menu.AppendMenuItem(username.length > 0 && api_key.length == 32 && g_metadb ? MF_STRING : MF_GRAYED, 1, "Update");
_menu.AppendMenuItem(MF_STRING, 6, "Show artist name");
_menu.CheckMenuItem(6, window.GetProperty("show_artist"));
_menu.AppendMenuItem(spotify ? MF_STRING : MF_GRAYED, 7, "Pause playback when launching Spotify");
_menu.CheckMenuItem(7, window.GetProperty("pause"));
_links.AppendMenuItem(MF_STRING, 4, "Spotify");
_links.AppendMenuItem(MF_STRING, 5, "Last.fm radio");
_links.CheckMenuRadioItem(4, 5, window.GetProperty("spotify") ? 4 : 5);
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _links.ID, "Links");
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _selection.ID, "Selection mode");
_selection.AppendMenuItem(MF_STRING, 900, "Use display preferences");
_selection.AppendMenuItem(MF_STRING, 901, "Prefer now playing");
_selection.AppendMenuItem(MF_STRING, 902, "Follow selected track");
_selection.CheckMenuRadioItem(900, 903, selection_mode + 900);
_menu.AppendMenuItem(MF_STRING, 2, "Set your Last.fm username");
_menu.AppendMenuItem(MF_STRING, 3, "Set your API KEY");
if(utils.IsKeyPressed(0x10)) _menu.AppendMenuItem(MF_STRING, 9, "Properties");
_menu.AppendMenuItem(MF_STRING, 10, "Configure...");
switch(idx) {
case 1:
get();
break;
case 2:
username = text_input_box("Similar Artists", "Please enter your Last.fm username", username_file);
window.NotifyOthers("lastfm_update", 1);
load();
break;
case 3:
api_key = text_input_box("Similar Artists", "Please enter your Last.fm API KEY\n\nhttp://www.last.fm/api/account", api_key_file);
load();
break;
case 4:
case 5:
window.SetProperty("spotify", idx == 4 ? true : false);
spotify = window.GetProperty("spotify");
window.Repaint();
break;
case 6:
window.SetProperty("show_artist", !window.GetProperty("show_artist"));
window.Repaint();
break;
case 7:
window.SetProperty("pause", !window.GetProperty("pause"));
break;
case 9:
window.ShowProperties();
break;
case 10:
break;
case 900:
case 901:
case 902:
window.SetProperty("selection_mode", idx - 900);
selection_mode = window.GetProperty("selection_mode");
break;
_selection.Dispose();
_menu.Dispose();
_links.Dispose();
return true;
it doesn't crash for me.
also, it might help if you posted what the console says.
Seems like it happens for any artist not on Last.fm. I've got a panel with the original version of your script too, and that one works just fine.
Error: WSH Panel Mod (Similar Artists by marc2003): Körningsfel i Microsoft JScript: (error in Microsoft JScript)
'toptags.length' är null eller inte ett objekt (is null or not an object)
Ln: 68, Col: 9
replace line 113:
with
if (parsed_data.error > 0) fb.trace("Top tags: " + g_text);
else if (typeof parsed_data.toptags.tag == "object") toptags = parsed_data.toptags.tag;
i got some strange thing in wsh. i have the code:
function drawpl() {
this.traceplaylist = function (x,y) {
if (x>this.x && y>this.y && x<this.x+this.w && y<this.y+(this.h+5)*plcount) {
hh= Math.floor((y-this.y)/(this.h+5));
else hh= null;
return hh;
var prevplh=null;
if (x<=window.width && y<=window.height) {
hplaylist=traceplaylist(x,y);
//fb.trace("traceplaylist"+traceplaylist(x,y));
if (prevplh != hplaylist) {
window.Repaint();
fb.trace("repaint by changing highlighted playlist!"+Math.random());
prevplh=hplaylist;
drawpl();
some time ago this code works fine, but i tried to change assemblies location (for ui hacks). after that this code crashes on foobars start. before this crashes he redraws the panel without a window.repaint command (there was no messege in console ' repaint by ..."). now on start he crashes on line "hplaylist=traceplaylist(x,y);" in on_mouse_move - says <source text only available at compile time> and "suppose have an object" (i dont know how this string looks like in english, sorry if this not right). but after configure/apply this code works fine, just after replacements begin to work like he must - window redraws by repaint command.
this is not a whole code, just part which causes this crash
i would be very glad if somebody helps me - i really dont know why it crashes
jscript doesn't support static method.
javascript is much more similar to C++ instead of java.
you should instantiate a drawpl object, then use
hplaylist=obj.traceplaylist(x,y);
because traceplaylist is a member of class drawpl.
however you didn't post any more valuable information, it's a bit hard to determine what really happened.
i just noticed a typo in my previous reply. it should be
Thanks marc, it works perfectly now. I wouldn't be able to fix it myself, and it was extra kind of you to help since the code was altered.
to Lapis Lazuli
thanks, but how to do this? im newbie in coding, and learn jscript by codes for wsh.
can you explain why object better than function and where better use function or object.
about information - thats all i got about this error. this code works fine utill i change location of assamblies and change path to it in ui hacks. i dont understand how it relate with my problem
hi there....i m a newbie and want to learn to code wsh panel using jscript...but dont know how to start actually i read a lot of references about jscript but dont got any references like onpaint() function and the gr parameter inside it.... . So, is there any good writter reference for these type of scripts. U guyz there really rock, kindly give me the appropriate direction...
onpaint() function is just an example i gave, theres lot more i dont know....
eagerly w8ing for a reponse........
Hello.
First thanks for this panel and the great job.
Someone can explain me how to debug with the version 1.5.1, because after the 1.4.4 the debug check box disapear.
Thanks for answer
Serge
here's another script. this is for DUI only. it allows you to create your own buttons of any size, using any images you like. by default it uses the DUI background colour (it changes colour as you change theme).
(http://k5sbdw.blu.livefilestore.com/y1pnSC1mxAv6zhmAM9tfE2dwzsyFDhkqYGiuFMesBndW9eoZHe5qxCOF5yc8mNhFPclrKdUihbbhFwnKRIm9kqrQBlCbLdfhstS/buttons1.png)
but it also has an option to set the background to the same colour as the splitter or your own custom colour which you can specify in the script.
(http://k5sbdw.blu.livefilestore.com/y1pJxLDqo4xDIfZw7SeL2pG3laazoPtzxyubTBVq5ROMGuWuTLukt86QIh4o4ZTRdRJUv27cmgxN9J9C89OPv2tKvIiOMrNkWU-/buttons2.png)
it does require a little tinkering to get going so here's a guide. […]
Hey marc2003, any chance you have a similar script for CUI?
Also, how hard would it be to replace the play button with pause while tracks are playing?
that post is very out of date now. the current version is included in my pack of sample scripts here.
it's imaginatively named playback buttons.
Thanks!!
Can you tell me what this script (Playback Buttons) uses from your external JS files (common4.js and tooltip_buttons.js) other then the location of the images?
Would it be possible to make it so it doesn't require the two external files?
if the presence of 2 files that take up 17kb of space bothers you, i suggest you turn off your computer and don't bother using it again. :/
Funny, but I have no issue with the presence of the files. I'm teaching myself how to code by understanding your scripts. I can follow your WSH script and make sense of it but when I start trying to connect the dots to the other two JS files, I get lost.
just copy the contents of both the files into the panel and remove the the preprocessor bit at the start that references them. the whole of tooltips.js is needed but admittedly a lot of functions in common4.js aren't used in playback buttons. try removing them one by one, clicking the apply button in the editor to see if the panel crashes or not. if it does, then undo the deletion you've just made.
i have a string. i need to know, on which language it written. it is possible to do that? for example, by chars or something like that.
to marc2003
your examples are great, but i think there a lack of examples about javascript, not wsh functions. could you make some? i think it will be very helpfull for newbies and begginers. examples which you could see in foobars wsh panel, just for easy understanding. if you, or someone make it, it will very great
p.s. i asked previously, is it possible to add to playlist folder by path string? anybody know? is there some simple method or i need script which searches files in deep of folder tree?
Hello,
I'm playing with the CD Jewel Case Code and have modified it to some extent. It works more or less now, but my knowledge in coding is limited, and I have to ask some things about the following section:
function update_image() {
if (!g_metadb) return;
is_embedded = null;
g_img && g_img.Dispose();
g_img = utils.GetAlbumArtEmbedded(g_metadb.rawpath, 0);
if (g_img) {
is_embedded = true;
window.Repaint();
} else {
utils.GetAlbumArtAsync(window.ID, g_metadb, 0);
-Does this code prefer embedded artwork to image-files in the folder?
-What does 'g_img && g_img.Dispose();' do? My panel crashes, the console gives an error in this line. If i deactivate it the crash does not happen and the code seems to work fine without it, so what is it for?
-why is 'utils.GetAlbumArtEmbedded(g_metadb.rawpath, 0);' assigned to g_img, but 'utils.GetAlbumArtAsync(window.ID, g_metadb, 0);' is not?
sorry to ask this, but I just cannot work it out...
-yes it does prefer embedded artwork. it falls back on whatever patterns you have set in the display preferences if none is found. i find this better than the random nature of letting the foobar core decide for itself. it's supposed to work on quality but it doesn't always appear to do that. also, if your files have artwork embedded in them, why wouldn't you want it to show? if the better artwork is to be found in the folder, then strip the images from your files and free up some space.
-i'm not sure g_img.Dispose() is necessary but it only runs if g_img is set so it shouldn't ever crash. mine never has. it frees up memory i think. i copied it from one of T.P Wang's samples.
-that last function invokes this callback and that is where the image gets assigned to g_img.
function on_get_album_art_done(metadb, art_id, im, ip) {
g_img_path = ip;
g_img = im;
window.Repaint();
thanks for your post, I could work out some of my issues.
I don't know why but I always preferred artwork files in the folder. Right now my mobile phone uses only embedded art, so i have scaled down images embedded in the files and full scale images in the folder.
I see I cannot attach files here? I wanted to share my modified code here, but a png file will be needed, so is there any way to attach a file to a post here?
you just replace the function with this then....
thanks!
but could it be made optional, just like the original code, just with changed priorities? So it will fall back to embedded art if possible, in case that no image file is present?
that's what I did to your original code:
is_embedded = null;
if (g_img) {
} else {
if (g_img) {
is_embedded = true;
Is this OK or do you see a problem?
that's not needed. my snippet above it all you need. utils.GetAlbumArtAsync will still read embedded album art if the foobar core decides that is best quality (or no other art exists).
edit: i just realised that will break my double click code for finding the source file in explorer. replace the
on_mouse_lbtn_dblclk() function with this.
function on_mouse_lbtn_dblclk() {
if (!g_metadb || !g_img) return;
WshShell.Run("explorer /select," + g_img_path);
great! thanks!!!
In case someone might be interested i have uploaded my modified version of the CD-Jewel-Case Panel.
http://www.file-upload.net/download-408795...ified-.zip.html (http://www.file-upload.net/download-4087959/cd-jewel-case--modified-.zip.html)
It seems to work, but I don't really know how to code so it is not elegant and probably not error-free.
It is auto-resizing and it provides a 'DigiPak'-feature:
'DigiPak' On: a cover art image that is non square (the threshold can be adjusted in the code) will be shown WITHOUT the CD-Case. A subtle 'gloss'-effect (highlight and shadow) will be added to the edges to support the impression of a DigiPak box.
'DigiPak' Off: the cover art image will always be shown in the CD-Case. Images below a certain threshold (the threshold can be adjusted in the code) will be stretched, images beyond that threshold will be shown in their original aspect ratio (which will leave part of the CD-Case image uncovered.)
in the attached zip is the code example and the 'digipak_gloss.png'-file which will be needed. place the 'digipak_gloss.png'-file into the marc2003/images folder.
I have been using this themed progress bar code for a while, I got it here someplace. Can someone please tell me how to change the background color - or to just force it to use my theme's background color?
// vi:set ft=javascript ff=dos ts=4 sts=4 sw=4 et:
// This is just a demo so is buggy.
var g_theme = window.CreateThemeManager("PROGRESS");
var g_bar_height = 15;
var g_cycles = 0;
var ww = 0,
wh = 0;
var top = 0;
var g_pos = 0;
var g_drag = false;
var g_length = 1;
function clamp(x, l, h) {
return (x < l) ? l : ((x > h) ? h : x);
ww = window.Width;
wh = window.Height;
top = (wh - g_bar_height) >> 1;
g_theme.SetPartAndStateID(1, 0);
g_theme.DrawThemeBackground(gr, 0, top, ww, g_bar_height);
if (fb.IsPlaying && g_length > 0) {
g_theme.SetPartAndStateID(5, fb.IsPaused ? 3 : 1);
g_theme.DrawThemeBackground(gr, 0, top, g_pos, g_bar_height);
function on_mouse_lbtn_down(x, y) {
if (g_length > 0) {
g_drag = true;
on_mouse_move(x, y);
if (g_length > 0 && g_drag) {
g_drag = false;
fb.PlaybackTime = g_length * g_pos / ww;
if (g_drag) {
g_pos = clamp(x, 0, ww);
window.Repaint();
fb.PlaybackTime = fb.PlaybackTime + delta * 2;
function on_playback_time(time) {
if (!g_drag) {
if (g_length > 0) g_pos = ww * time / g_length;
window.Repaint();
function on_playback_seek() {
if (!g_drag && g_length > 0) window.Repaint();
function on_playback_pause() {
window.Repaint();
function on_playback_stop() {
g_length = 0;
g_pos = 0;
g_drag = false;
window.Repaint();
g_length = fb.PlaybackLength;
g_pos = 0;
g_drag = false;
window.Repaint();
if (fb.IsPlaying) on_playback_new_track();
Found another bug in my adjustable volume control script, which occurred on right-click while left mouse button was being held down. The following code should be added to my script:
function on_mouse_rbtn_down(x,y){
g_drag=0;
window.Repaint();
function on_mouse_rbtn_up(x,y){
g_drag=0;
window.Repaint();
At last, I have eliminated (most of) the problems in my adjustable volume control script.
- The safety limit percentage value can now be correctly scrolled down to the biggest (integer) value greater than the volume setting's percentage (real) value.
- Changed the minimum and maximum safety limit positions to 1% and 100%, respectively.
- Fixed a problem which caused the foobar2000 volume to be set slightly above -100 dB instead of truly at -100 dB. Also, when the scrollwheel position is set to 100%, the volume bar's maximum volume position will also truly be at 0 dB.
- The displayed volume setting's percentage value is now properly rounded down.
- Fixed a problem which caused the script to show weird behavior when using the foobar2000 volume control.
However, please note the foobar2000 volume control COMPLETELY overrides the safety limit!
The safety limit is the ONLY reason why I wrote the script! The user of my script should :
- Follow the usual safety recommendations regarding potential loudness fluctuations in an audio track.
- Consider the use of ReplayGain, especially if playing a seqence of multiple, unequally loud, audio tracks.
- Hide the foobar2000 volume control, to prevent accidental overriding the safety limit of the script.
- Hide the foobar2000 status bar because it also has volume control.
- Either bypass the Windows mixer or be careful with its settings, etcetera, because the script ignores them (personally, I am using ASIO4ALL for this purpose because, for one reason or another, the ASIO component for foobar2000 works better for me than WASAPI, and I haven't yet tried Kernel Streaming).
- Not assign a hotkey, consisting of only a single key, to increase the volume. Keys can get stuck.
- Watch out with the mouse. Keep it away from children.
- Remember overall system security. Consider getting a separate PC for playback and storage of your music files. (personally, I am using just a cheap netbook that's very very silent in my listening room and, thanks to foobar2000 being so easy on the system resources, as well as thanks to the highly optimized USB device driver of my external DAC unit, the cheap computer has the processing power it takes for me to be able to play all my Hi Res FLAC files without hiccups.
I hope this helps anyone who might be looking to avoid the thermal noise typically caused by analogue volume control and / or the cost of adding a decent preamp.
Any suggestions to further improve my script are still always welcome.
var g_drag=0;
var sc1=1.01865;
var sc2=0.01865;
var p=25;
var pos=0;
var g_font=gdi.Font("Consolas",16,1);
var g_font2=gdi.Font("Consolas",18,1);
function on_paint(gr){
var ww=window.Width-1;
var v=fb.Volume;
var pos2=pos/(p/100);
if(!g_drag) p=pos2>ww+1?Math.ceil(pos*100/ww): p;
pos=pos/(p/100);
gr.FillGradRect(pos,0,ww-pos+1,wh,40,RGB(88,82,98),RGB(18,18,18));
gr.FillGradRect(p/100*ww,wh/3,(1-p/100)*ww+2,wh/3,350,RGB(68,74,82),RGB(48,48,48));
gr.DrawRect(-1,wh/3,ww+2,wh/3,1,RGB(55+p*2,200-p*2,Math.abs(50-p)));
var p2=-Math.ceil(-p*pos/ww);
var str_vol=vol+"."+voldec.substr(1,2);
str_vol=v<-99.99?"-100.00":v>-0.01?" 0.00":" "+(vol>-10?" ":"")+(vol==0?"-":"")+str_vol;
var xr=ww-126;
var xl=-1;
gr.DrawString((p<10?" ":p<100?" ":"")+p+" %",g_font,RGB(0,0,0),xl-2,2,62,wh,0x11005000);
gr.DrawString((p<10?" ":p<100?" ":"")+p+" %",g_font,g_drag?col2:col1,xl,0,62,wh,0x11005000);
window.Repaint();
on_mouse_move(x,y);
g_drag=0;
window.Repaint();
g_drag=0;
window.Repaint();
g_drag=0;
window.Repaint();
if(g_drag){
//var xpos=x>ww?ww:x;
var xpos=x>ww?ww:x;
xpos=xpos*(p/100);
v=v>-0.01?0:v<-99.99?-100:v;
function on_mouse_wheel(delta){
if(!g_drag){
if(delta>0){
p=p+1;
p=(p>100)?100:p;
}else{
p=(pos<window.Width-1)?p-1:p;
p=(p<1)?1:p;
window.Repaint();
window.Repaint();
fb.Volume=-50;
I am trying to add another item ("Open containing folder") to the right-click context menu of my "WSH TextFile Viewer" panel ...but I can't do it :-(
I tried editing my script by adding a few lines to this function group: (my additions are in red)
function on_mouse_rbtn_up(x, y){
var _backgroundcolor = window.CreatePopupMenu();
var _textcolor = window.CreatePopupMenu();
var _menu = window.CreatePopupMenu();
var idx;
_menu.AppendMenuItem(MF_STRING, 1, "Update");
_menu.AppendMenuItem(MF_SEPARATOR, 0, 0);
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _textcolor.ID, "Text Color");
_textcolor.AppendMenuItem(MF_STRING, 98, "Foobar Text");
_textcolor.AppendMenuItem(MF_STRING, 99, "Foobar Highlight");
_textcolor.AppendMenuItem(MF_STRING, 101, "White");
_textcolor.AppendMenuItem(MF_STRING, 102, "Off-White");
_textcolor.AppendMenuItem(MF_STRING, 103, "Green");
_textcolor.AppendMenuItem(MF_STRING, 104, "Blue");
_textcolor.AppendMenuItem(MF_STRING, 105, "Yellow");
_textcolor.AppendMenuItem(MF_STRING, 106, "Black");
_menu.AppendMenuItem(MF_STRING | MF_POPUP, _backgroundcolor.ID, "Background Color");
_backgroundcolor.AppendMenuItem(MF_STRING, 210, "Foobar Background");
_backgroundcolor.AppendMenuItem(MF_STRING, 211, "White");
_backgroundcolor.AppendMenuItem(MF_STRING, 212, "Red");
_backgroundcolor.AppendMenuItem(MF_STRING, 213, "Green");
_backgroundcolor.AppendMenuItem(MF_STRING, 214, "Blue");
_backgroundcolor.AppendMenuItem(MF_STRING, 215, "Brown-Black");
_backgroundcolor.AppendMenuItem(MF_STRING, 216, "Black");
if(window.GetProperty("textcolor")==101){
_textcolor.CheckMenuItem(101, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==102)
{_textcolor.CheckMenuItem(102, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==103)
{_textcolor.CheckMenuItem(103, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==104)
{_textcolor.CheckMenuItem(104, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==105)
{_textcolor.CheckMenuItem(105, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==106)
{_textcolor.CheckMenuItem(106, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==98)
{_textcolor.CheckMenuItem(98, window.GetProperty("textcolor"));}
else if (window.GetProperty("textcolor")==99)
{_textcolor.CheckMenuItem(99, window.GetProperty("textcolor"));}
if(window.GetProperty("backgroundcolor")==211){
_backgroundcolor.CheckMenuItem(211, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==212)
{_backgroundcolor.CheckMenuItem(212, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==213)
{_backgroundcolor.CheckMenuItem(213, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==214)
{_backgroundcolor.CheckMenuItem(214, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==215)
{_backgroundcolor.CheckMenuItem(215, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==216)
{_backgroundcolor.CheckMenuItem(216, window.GetProperty("backgroundcolor"));}
else if (window.GetProperty("backgroundcolor")==210)
{_backgroundcolor.CheckMenuItem(210, window.GetProperty("backgroundcolor"));}
_menu.AppendMenuItem(MF_STRING, 8, "Configure");
[color=#FF0000] _menu.AppendMenuItem(MF_STRING, 9, "Open containing folder");[/color]
idx = _menu.TrackPopupMenu(x, y);
switch(idx) {
case 1:readTXT();calc();window.Repaint();break;
case 8:window.ShowConfigure();break;
[color=#FF0000]case 9:
if (! fb.IsPlaying) return;
var xpath = fb.TitleFormat("%path%").EvalWithMetadb(fb.GetNowPlaying());
var path = xpath.substring(0, xpath.lastIndexOf("\\")) + "\\";
var Folder = fso.GetFolder(path);
try { WshShell.Run("explorer \"" + Folder + "\""); }
catch(e) {}[/color]
case 98:window.SetProperty("textcolor", 98);txtcolor = g_textcolor;window.Repaint();break;
case 99:window.SetProperty("textcolor", 99);txtcolor = g_textcolor_hl;window.Repaint();break;
case 101:window.SetProperty("textcolor", 101);txtcolor = RGB(255,255,255);window.Repaint();break;
case 102:window.SetProperty("textcolor", 102);txtcolor = RGB(255,255,227);window.Repaint();break;
case 103:window.SetProperty("textcolor", 103);txtcolor = RGB(50,255,50);window.Repaint();break;
case 104:window.SetProperty("textcolor", 104);txtcolor = RGB(150,150,250);window.Repaint();break;
case 105:window.SetProperty("textcolor", 105);txtcolor = RGB(255,255,50);window.Repaint();break;
case 106:window.SetProperty("textcolor", 105);txtcolor = RGB(10,10,10);window.Repaint();break;
case 210:window.SetProperty("backgroundcolor", 210);backcolor= g_backcolor;window.Repaint();break;
case 211:window.SetProperty("backgroundcolor", 211);backcolor= RGB(255,255,255);window.Repaint();break;
case 212:window.SetProperty("backgroundcolor", 212);backcolor= RGB(255,50,50);window.Repaint();break;
case 213:window.SetProperty("backgroundcolor", 213);backcolor= RGB(50,255,50);window.Repaint();break;
case 214:window.SetProperty("backgroundcolor", 214);backcolor= RGB(10,36,106);window.Repaint();break;
case 215:window.SetProperty("backgroundcolor", 215);backcolor= RGB(34,28,28);window.Repaint();break;
case 216:window.SetProperty("backgroundcolor", 216);backcolor= RGB(0,0,0);window.Repaint();break;}
_menu.Dispose();_textcolor.Dispose();_backgroundcolor.Dispose();return true;
The context menu item ("Open containing folder") is showing but nothing happens when I choose it.
I'm sure the answer is a simple one, unfortunately I am not knowledgeable enough in JS syntax to analyse this for myself.
Thanks for any help +++
(by the way, that code I added is copy/paste from other example scripts; I have no idea basically speaking)
fb.RunContextCommandWithMetadb("Open Containing Folder", fb.GetNowPlaying());
Thanks, I'll try that
marc +++
should I replace all lines at
case 9: with your line, or just one of the lines?
does anything there look redundant to you?
--- EDIT (1) ---Thanks
marc, it works +++
case 9:
try { fb.RunContextCommandWithMetadb("Open Containing Folder", fb.GetNowPlaying()); }
catch(e) {}
break;
--- EDIT (2) ---OK, you don't need to answer my first question, I got the answer...
The code was redundant; this works too:
case 9:
catch(e) {}
break;
Can you advise me some more please...
The code will only work if the track is Playing or Paused.
What do I need to do to make it work for track Stopped as well ?
fb.RunContextCommandWithMetadb("Open Containing Folder", fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem());
Excellent, it works, thankyou ExtremeHunter +++
Thanks again for the help guys
Hi marc2003,
first of all thanks for all your work and excellent scripts.
A question out of curiousity (and little knowledge so far) concerning the lastfm charts script.
Would it be possible to select/change the properties
- either by using a context menu
- or by an easier dialogue in the properties e.g. the selection of the period by a drop down menu with explaining text (0 = "Overall", 1 = "Last 7 days", 2 = "3 month", etc.)
Thanks for an answer in advance and keep up the good work!
from the readme:
Click the Last.fm logo to select the different chart types and time periods.
(http://dl.dropbox.com/u/22801321/charts%20menu.png)
I always wonder what these strange readme files' purpose was...
Thanks a lot. Awesome.
Is there a way to use similar artists panel to add artists that are in my collection to my playlist?
To extent this question:
Is it possible to use the main menu command "Quicksearch" and send a parameter or query to use in this quicksearch?
I think we both have the same aim: To find e.g. similar artists (or most played albums or tracks from last.fm charts, etc.) in our libraries.
samples updated: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
similar artists now has a 3rd option under links and that is to create an autoplaylist based on the artist name.
(http://dl.dropbox.com/u/22801321/similar%20auto.png)
(edit: if your preference was for last.fm radio with the old script, this will get reset back to spotify as i had to change the way settings are stored. this only happens once. your setting should stick after that.)
I really like this function. I will try to change it so that it is the text that creates the autoplaylist, and make an assigned playlist for this instead of a new for every artist.
Another idea I got, but that I don't think I'm able to do myself, is a panel with the same layout as "lastfm charts", but with the artist charts instead, and with the same autoplaylist-functionality. Then you could easily see what the most popular tracks are by a certain artist, and play them if they are in your library.
you can't edit an existing autoplaylist but if you have a set name, you can loop through all playlists and delete it if the name matches before creating a new one.
on line 187, replace this....
case link == "auto" && in_range && x > 6 && x < 26:
fb.CreateAutoPlaylist(fb.PlaylistCount, artists[index].name, "artist HAS " + artists[index].name);
fb.ActivePlaylist = fb.PlaylistCount - 1;
break;
with
playlist_name = "similar";
i = 0;
while(i < fb.PlaylistCount) {
if (fb.GetPlaylistName(i) == playlist_name) fb.RemovePlaylist(i);
else i++;
fb.CreateAutoPlaylist(fb.PlaylistCount, playlist_name, "artist HAS " + artists[index].name);
break;
Thanks! Works a charm, and as usual, I realise I wouldn't be able to do that myself...
I think some of your other scripts would benefit from having similar functions... External links are nice, but I find it's even nicer to be able to browse my own library using information that's taken from for instance last.fm.
the reason i only put last.fm/spotify links on my scripts was to help me easily find new stuff to listen to. i'd find using it to locate music i already have a bit redundant - but maybe that is because my collection is so tiny.
Many , many Thanks !!! This is exactly what I wanted....
Hello everyone, I modified Mar2003's similar artist script to display top artist tracks instead. I'm not familiar with scripting but I took a look at the script's code and last.fm api and figured it out.
This is the code in the modified lines:
Line 102
filename = folder + "\\toptracks.json";
Line 110
else if (typeof parsed_data.toptracks.track == "object") artists = parsed_data.toptracks.track;
Line 120
lastfm("&method=artist.gettoptracks&artist=" + encodeURIComponent(artist), "foo_wsh_lastfm_toptracks", function() { save(xmlhttp.responsetext, fn); load(); });
Line 9
var script_name = "Top Tracks";
I've been using this for almost 2 weeks with no issues other than the last.fm/spotify search links not working, I'm not familiar with regular expressions...
If I may ask, some questions regarding excellent Marc's scripts:
1- how can I use a complex titleformatting string for defining the path and name of the stored scripts data; json files for both biography view and similar artist?
2- how can I display the number of listeners before the artist name.
I also noted that while playing mp4 files the last.fm panels crashed, and when setting a very long string in the remapping artist field option of the bio script, it gets trimmed. I worked-around it by adding the setting directly in the properties panel dialog.
Similar to Motorhorst, I thought if it was possible to add a search button for the displayed artist to run a query in the media library search component, is it possible or not tooo tricky? I've used the similar artist panel to discover new music as well though unlucky for me, it always reports that is unable to open the default browser, which means that I have to type everytime the search url /name of the artist in last.fm for each artist. If is not too much to ask perhaps just like in the biography panel, there could be an option to copy the artist names to clipboard, which would save me some steps
Line 102
Line 110
Line 120
Line 9
Also I modified this script, I removed the button spotify, last.fm, auto playlist
// ==PREPROCESSOR==
// @import "%fb2k_profile_path%marc2003\common4.js"
// @name "Top Tracks"
// @feature "v1.0"
// @feature "watch-metadb"
var lastfm_play_img = gdi.Image(images_path + "lastfm_play.png");
var auto_img = gdi.Image(images_path + "search_small.png");
var but_x = 0;
var offset = 0;
var rows = 0;
var artist = "";
var folder = "";
var g_text = "";
var artists = [];
var link = window.GetProperty("link", "spotify");
var show_artist = window.GetProperty("show_artist", true);
var pause = window.GetProperty("pause", true);
if (name == "lastfm_update" && data == 1) {
artist = Date();
ww = window.Width;
wh = window.Height;
offset = 0;
rows = Math.floor((wh - 58) / 20);
up_btn = new sb(but_x, 32, 15, 15, up_img, "offset > 0", function () { on_mouse_wheel(1); });
down_btn = new sb(but_x, wh - 15, 15, 15, down_img, "offset < artists.length - rows", function () { on_mouse_wheel(-1); });
switch(true) {
case username.length == 0:
case api_key.length != 32:
gr.GdiDrawText("Please use the context menu to set your Last.fm username and API KEY.", normal_font, g_textcolor, 10, 0, ww - 20, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
break;
case !g_metadb:
gr.GdiDrawText("[no selection]", normal_font, g_textcolor, 0, 0, ww, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
break;
default:
gr.GdiDrawText(script_name + (show_artist ? " to " + artist : ""), title_font, g_textcolor_hl, 6, 6, ww - 77, 24, DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.DrawImage(lfm_img, ww - 60, 8, 50, 18, 0, 0, 50, 18);
gr.DrawLine(5, 29, ww - 10, 29, 1, g_textcolor_hl);
if (artists.length == 0) {
gr.GdiDrawText("[no data]", normal_font, g_textcolor, 0, 0, ww, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
} else {
for (l = 0; l < Math.min(rows, artists.length); l++) {
gr.DrawImage(lastfm_small_img, 5, 45 + (l * 20), 20, 20, 0, 0, 20, 20);
gr.GdiDrawText(artists[l + offset].name, list_font, g_textcolor, 30, 46 + (l * 20), ww - 66, 18, DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
up_btn.draw(gr);
down_btn.draw(gr);
function on_playback_dynamic_info_track() {
my_metadb_changed("%artist%", function() { load(); });
function load() {
artists = [];
offset = 0;
if (!fso.FolderExists(folder)) fso.CreateFolder(folder);
if (fso.fileExists(filename)) {
ts = fso.OpenTextFile(filename, 1, false, -1);
ts.close();
if (parsed_data.error > 0) fb.trace(script_name + ": " + g_text);
if (Date.parse(Date()) - Date.parse(file.DateLastModified) > 86400000) get();
} else {
get();
window.Repaint();
function get() {
var fn = filename;
if (artists.length < rows) return;
if (offset < 0) offset = 0;
if (rows + offset > artists.length) offset = artists.length - rows;
window.Repaint();
in_range = index >= offset && index < Math.min(offset + rows, artists.length);
switch(true) {
case !g_metadb:
return;
case in_range && x > 5 && x < 25:
var url = (artists[index].url.indexOf("www.") == 0 ? "http://" : "") + artists[index].url;
tt(url);
break;
case up_btn.trace(x, y):
case down_btn.trace(x, y):
break;
default:
g_tooltip.Text = "";
break;
switch(true) {
case !g_metadb:
return;
try { WshShell.run(artists[index].url); } catch(e) { MsgBox("Unable to launch your default browser.", 0, script_name); }
break;
up_btn.click(x, y);
break;
down_btn.click(x, y);
break;
var idx;
_menu.AppendMenuSeparator();
_menu.AppendMenuItem(MF_STRING, 11, "Show artist name in heading");
_menu.CheckMenuItem(11, show_artist);
_menu.AppendMenuItem(link == "spotify" ? MF_STRING : MF_GRAYED, 7, "Pause playback when launching Spotify");
_menu.CheckMenuItem(7, pause);
_links.AppendMenuItem(MF_STRING, 6, "Autoplaylist");
_links.CheckMenuRadioItem(4, 6, link == "spotify" ? 4 : link == "lastfm" ? 5 : 6);
_links.AppendTo(_menu, MF_STRING, "Links");
_selection.AppendTo(_menu, MF_STRING, "Selection mode");
_menu.AppendMenuItem(MF_STRING, 2, "Set your Last.fm username...");
_menu.AppendMenuItem(MF_STRING, 3, "Set your API KEY...");
if (utils.IsKeyPressed(0x10)) _menu.AppendMenuItem(MF_STRING, 9, "Properties");
switch(idx) {
case 1:
get();
break;
case 2:
set_username();
artist = Date();
break;
case 3:
set_api_key();
artist = Date();
break;
case 4:
case 5:
case 6:
link = idx == 4 ? "spotify" : idx == 5 ? "lastfm" : "auto";
window.SetProperty("link", link);
window.Repaint();
break;
case 11:
show_artist = !show_artist;
window.SetProperty("show_artist", show_artist);
window.Repaint();
break;
case 7:
pause = !pause;
window.SetProperty("pause", pause);
break;
case 9:
break;
case 10:
break;
case 900:
case 901:
case 902:
selection_mode = idx - 900;
window.SetProperty("selection_mode", selection_mode);
break;
_menu.Dispose();
_links.Dispose();
return true;
Possibly My library is quite large and can be hard to browse sometimes, and for me it's more often "what should I listen to now" than "what should I get to listen to later". So the info is great for me in cases where there are connections between artists/tracks that are not apparent through the %tags%, but my lazy side wants to be able to directly browse the library by clicking this info...
We will never be able to use commands like "quicksearch for same..." or soft playlists in these lists right? It would be great to get a list of all popular tags for a specific song, and then click on one to create a playlist with other songs in the library with the same tag.
Ok, the silence is deafening. In my newbiness I looked into the common file.js it seems that here I should change the folder where the data is stored. The $CRC32 string may account for the folder names while the var data_folder line for the parent folder wsh_lastfm.
I've attempted using "fb.TitleFormat("")" strings for a custom path, it returns error in the console.
Edit: In the last.fm scripts there's "var folder = "";" line, attempted as well to add title formatting syntax.
Edit2: @gxavz1 I guess that's a way to fix it or the spartan version!
So far what I've got trying to display the number of listeners
var artists = [];
var listeners = [];
Line 111
listeners = parsed_data.toptracks.listeners;
What I haven't figured out yet is how to append the listeners value to the beginning of the artist value.
why do you care where the cached file is saved? it's not like any it has any use for anything else. the best place for it is under one subfolder in your foobar profile. if you really feel the need to change the path, you need to make sure the folders exist first.
as for trying to access listener data, you need to see if the toptracks feed even contains it. i recommend using notepad++ and the jsmin plugin. this allows you to make JSON files readable. when you open a JSON file, it's just a single line of text but pressing ctrl+alt+m expands it so you can see how it's structured like this.....
(http://dl.dropbox.com/u/22801321/listeners.png)
I prefer to keep artist/album related info into it's artist/album directory, in the same way I store album art, cue and log files. Tracks from artists/albums that are organized in a defined directory structure will already have existing directories, in case a track whos artist/album is not present, can't a directory be created using the same scheme? via titleformatting anyone can adequate their script to match their music structure, if desired.
It does contain it (in the whole feed duh, not in the node, thanks for the hint!), quite cool and useful plugin to view the data structure. Looking at the screenshot and the listeners data tree looks like parsed_data.toptracks.tracks.listeners Anyway I'll take a second look with the plugin.
of course you'd keep cue/log files in your own organised structure because they actually are of some use to you and once created they (usually) don't change.
but outside of these panels, these JSON files serve no purpose at all. remember they are only temporary -they get updated if more than 24 hours old. there simply is no reason to store these files alongside your music.
if you really must persist then you need to look at using the FolderExists and CreateFolder jscript functions. there are examples in the script already. also, if a folder doesn't exist, you can't create it unless the parent folder exists so you need to check the existence of that and so on.
I guess it comes down to some work philosophy, I prefer to work whenever possible with offline files & data. Even if they are updated regulary I know I have a copy in case something unlikely happens, or I can no longer access the service, etc. That gives more freedom to do/use that data in other forms too. Sometimes month happens till I get an idea/use for some data I have been keeping a record of. Overall, I grant you the point that is a crazy philosophy, but for me it pays off in sometimes very unexpected ways.
Now I started using Notepad++ with the java language view for the scripts, the biography script shows listener's data along with some other, but the code is quite different. I'm not feeling that I'm doing some huge progress but anyways... Hum in other words it has to recursively check the directories. So it seems that the place I should insert the custom title formatting string is in the line 406 in common.js, after line 407 I should check if the folder exists (that includes if the folder didn't exist but it was successfully created). In the case it didn't exist and it wasn't created, create a folder using the same custom path but with one upper directory level. Repeat this process. And there's the folder name specified in the lines 72 and 81, maybe I can just strip it to the data folder var.
I would like to send one ore more files to an external application.
I do this with foo_run like this...
Label: Mp3 Tag File (for the active file only one)
Path: "E:\MiniFoo\Applications\Mp3tag\Mp3tagPortable.exe" "%path%"
and...
Label: Mp3 Tag Folder (for the active folder)
Path: "E:\MiniFoo\Applications\Mp3tag\Mp3tagPortable.exe" "$substr(%_path%,0,$strrchr(%_path%,'\'))"
I want to make this only with WHS Pannel and no longer with foo_run.
I tested many variations in my WHS Script (Pop Up Menue) but nothing is working propper...
case 1:
try {WshShell.Run("\"" + (fb.FoobarPath + "themes\\" +name+ "\\Applications\\Mp3tag\\Mp3tagPortable.exe") + "\"");} catch (e)
try {WshShell.Run("\"" + (fb.FoobarPath + "themes\\" +name+ "\\Applications\\Mp3tag\\Mp3tagPortable.exe") + fb.TitleFormat("%_path%"));} catch (e)
try {WshShell.Run("\"" + (fb.FoobarPath + "themes\\" +name+ "\\Applications\\Mp3tag\\Mp3tagPortable.exe") + fb.TitleFormat("$directory(%path%,2)"));} catch (e)
try {WshShell.Run(fb.FoobarPath + "themes\\" +name+ "\\Applications\\Mp3tag\\Mp3tagPortable.exe");} catch (e)
try {WshShell.Run("\"" + (fb.FoobarPath + "themes\\" +name+ "\\Applications\\Mp3tag\\Mp3tagPortable.exe") + fb.TitleFormat("%path%"));} catch (e)
try {WshShell.Run("E:\MiniFoo\minifoo8\themes\TURBO\Applications\Mp3tag\Mp3tagPortable.exe");} catch (e)
try {WshShell.run("E:\\MiniFoo\\minifoo8\\themes\\TURBO\\Applications\\Mp3tag\\Mp3tagPortable.exe" + fb.TitleFormat("%path%").Eval(true));} catch (e) {};
try {WshShell.run("E:\\MiniFoo\\minifoo8\\themes\\TURBO\\Applications\\Mp3tag\\Mp3tagPortable.exe" + fb.TitleFormat("%path%"));} catch (e) {};
break;
Any Idea??
Here is a first sharing of my new WSH playlist viewer v2, just for testing and have some feedback about performances and possible issues (that explain the packed version for now)
This new version is optimized compare to my previous one and has a behaviour pretty close of a classic playlist viewer now. Note that group header are now well handled
get script here: http://pastebin.com/BQWjjYqM (http://pastebin.com/BQWjjYqM)
then paste it in a WSH panel Mod panel (version 1.5.2 minimum is required)
(http://img845.imageshack.us/img845/8157/newwshplaylistv2preview.png)
use jscript and not jscript9 engine
to Falstaff
can you describe what have you do for optimization?
where in this script anything about playlist?
to Falstaff
script is packed because i want to finish it before publish it. optimization are everywhere, i've started from scratch the playlist populate, i can't describe it here. the best way is you wait for the final script
but for now you can play with this demo
what is the point of trying to obfuscate your script? all you have to do is put it into a site like http://jsbeautifier.org (http://jsbeautifier.org) to read it again.
A simple rating panel script using text instead of images. It uses the CUI/DUI configured fonts and colors by default. Font options, what characters to use for the ratings, text alignment ('left', 'center' or 'right' for the X axis, 'top', 'center' and 'bottom' for the Y axis) can be changed in properties. Ratings show a nice little visual feedback (glow) when the rating is changed and a new track comes in. Some screenshots:
(http://i.imgur.com/zotk0.png)
Now the script:
http://pastebin.com/s2ByGKtF (http://pastebin.com/s2ByGKtF)
EDIT: Forgot to mention, this script is in the public domain, do as you want with it, no restrictions.
EDIT2: It obviously requires the Playback Statistics component if you want to change the ratings.
i have this function
function Function() {
var draw_x;
this.Draw = Function(x) {
this.x=x;
draw_x=this.x;
//using draw_x;
Function()
Function().Draw(x);
i need to use draw_x after it draws, but it returns nothing. How can i do that?
-very minor bugfixes/tidy up. existing users should overwrite the marc2003 folder in their profile folder.
-similar artists remove last.fm button from each artist. click the text to open the last.fm website.
-autoplaylists remove lightning button. clicking the text runs the query.
-rating if foo_playcount is not found, your browser will open on the download page automatically
the mouse pointer changes to a hand when hovering and there are tooltips so you can't really miss these changes.
edit: i just a made a boo boo. if anybody downloaded this in the 30 minutes since i posted, please download and extract the marc2003 folder again.
WSH CoverFlow v1 beta1 now available here : [LINK] (http://br3tt.deviantart.com/art/foobar2000-WSH-CoverFlow-v1-beta1-290788027)
(http://img846.imageshack.us/img846/5251/wshcoverflowpreview001.png)
Good Attempt ! I tried it and it works well, just a little slow.
(I want something like the good-old 'Album Art Panel' for scanned artworks.
I use it,this source codes :
$replace(%path%,%filename_ext%,)*.*\*.*\*
$replace(%path%,%filename_ext%,)*.*\*.* ..........)
thanx for feedback, but what do you mean by "slow" ? maybe if you make the panel too big, but it's a panel, not a screen
WSH CoverFlow v1 beta2
(http://img85.imageshack.us/img85/2602/wshcoverflowpreview003.png) (http://imageshack.us/photo/my-images/85/wshcoverflowpreview003.png/)
jscript:
[code]// ==PREPROCESSOR==
// @name "WSH CoverFlow v1"
// @version "0.0.2.20120318.1815"
// @author "Br3tt"
// @feature "v1.4"
// @feature "dragdrop"
// [Requirements]
// * foobar2000 v1.1 or better >> http://foobar2000.org (http://foobar2000.org)
// * WSH panel Mod v1.5.2 or better >> http://code.google.com/p/foo-wsh-panel-mod/downloads/list (http://code.google.com/p/foo-wsh-panel-mod/downloads/list)
// [/Requirements]
// [Informations]
// * change colors and fonts in foobar2000 Preferences > DefaultUI or ColumsUI
// * Some Settings can be changed in window Properties (right click empty space > Properties)
// * double click on album text infos > Show Now Playing album
// * middle click on centered cover > Send album tracks to specific playlist "WSH CoverFlow"
// * keyboard keys : left/right arrows, Home/End, page up/down, spacebar to set focus on the centered album
// [/Informations]
SM_CXVSCROLL = 2;
SM_CYHSCROLL = 3;
DLGC_WANTARROWS = 0x0001;
DLGC_WANTALLKEYS = 0x0004;
MF_STRING = 0x00000000;
MF_SEPARATOR = 0x00000800;
MF_GRAYED = 0x00000001;
MF_DISABLED = 0x00000002;
MF_POPUP = 0x00000010;
IDC_ARROW = 32512;
IDC_IBEAM = 32513;
IDC_WAIT = 32514;
IDC_CROSS = 32515;
IDC_UPARROW = 32516;
IDC_SIZE = 32640;
IDC_ICON = 32641;
IDC_SIZENWSE = 32642;
IDC_SIZENESW = 32643;
IDC_SIZEWE = 32644;
IDC_SIZENS = 32645;
IDC_SIZEALL = 32646;
IDC_NO = 32648;
IDC_APPSTARTING = 32650;
IDC_HAND = 32649;
IDC_HELP = 32651;
DT_LEFT = 0x00000000;
DT_RIGHT = 0x00000002;
DT_TOP = 0x00000000;
DT_CENTER = 0x00000001;
DT_VCENTER = 0x00000004;
DT_WORDBREAK = 0x00000010;
DT_SINGLELINE = 0x00000020;
DT_CALCRECT = 0x00000400;
DT_NOPREFIX = 0x00000800;
DT_EDITCONTROL = 0x00002000;
DT_END_ELLIPSIS = 0x00008000;
VK_BACK = 0x08;
VK_RETURN = 0x0D;
VK_SHIFT = 0x10;
VK_CONTROL = 0x11;
VK_ALT = 0x12;
VK_ESCAPE = 0x1B;
VK_PGUP = 0x21;
VK_PGDN = 0x22;
VK_END = 0x23;
VK_HOME = 0x24;
VK_LEFT = 0x25;
VK_UP = 0x26;
VK_RIGHT = 0x27;
VK_DOWN = 0x28;
VK_INSERT = 0x2D;
VK_DELETE = 0x2E;
VK_SPACEBAR = 0x20;
KMask = {
none: 0,
ctrl: 1,
shift: 2,
ctrlshift: 3,
ctrlalt: 4,
ctrlaltshift: 5,
alt: 6
function GetKeyboardMask() {
var c = utils.IsKeyPressed(VK_CONTROL) ? true : false;
var a = utils.IsKeyPressed(VK_ALT) ? true : false;
var s = utils.IsKeyPressed(VK_SHIFT) ? true : false;
var b = KMask.none;
if (c && !a && !s) b = KMask.ctrl;
if (!c && !a && s) b = KMask.shift;
if (c && !a && s) b = KMask.ctrlshift;
if (c && a && !s) b = KMask.ctrlalt;
if (c && a && s) b = KMask.ctrlaltshift;
if (!c && a && !s) b = KMask.alt;
return b
ColorTypeCUI = {
text: 0,
selection_text: 1,
inactive_selection_text: 2,
background: 3,
selection_background: 4,
inactive_selection_background: 5,
active_item_frame: 6
FontTypeCUI = {
items: 0,
labels: 1
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
FontTypeDUI = {
defaults: 0,
tabs: 1,
lists: 2,
playlists: 3,
statusbar: 4,
console: 5
function StringFormat() {
var a = 0,
v_align = 0,
trimming = 0,
flags = 0;
switch (arguments.length) {
case 3:
trimming = arguments[2];
case 2:
v_align = arguments[1];
case 1:
a = arguments[0];
break;
default:
return 0
return ((a << 28) | (v_align << 24) | (trimming << 20) | flags)
StringAlignment = {
Near: 0,
Centre: 1,
Far: 2
var lt_stringformat = StringFormat(StringAlignment.Near, StringAlignment.Near);
var ct_stringformat = StringFormat(StringAlignment.Centre, StringAlignment.Near);
var rt_stringformat = StringFormat(StringAlignment.Far, StringAlignment.Near);
var lc_stringformat = StringFormat(StringAlignment.Near, StringAlignment.Centre);
var cc_stringformat = StringFormat(StringAlignment.Centre, StringAlignment.Centre);
var rc_stringformat = StringFormat(StringAlignment.Far, StringAlignment.Centre);
var lb_stringformat = StringFormat(StringAlignment.Near, StringAlignment.Far);
var cb_stringformat = StringFormat(StringAlignment.Centre, StringAlignment.Far);
var rb_stringformat = StringFormat(StringAlignment.Far, StringAlignment.Far);
function RGB(r, g, b) {
return (0xff000000 | (r << 16) | (g << 8) | (b))
function RGBA(r, g, b, a) {
return ((a << 24) | (r << 16) | (g << 8) | (b))
function getAlpha(a) {
return ((a >> 24) & 0xff)
function getRed(a) {
return ((a >> 16) & 0xff)
function getGreen(a) {
return ((a >> 8) & 0xff)
function getBlue(a) {
return (a & 0xff)
function num(a, b) {
var i;
var c = a.toString();
var k = b - c.length;
if (k > 0) {
for (i = 0; i < k; i++) {
c = "0" + c
return c.toString()
function TrackType(a) {
var b;
var c;
switch (a) {
case "file":
b = 1;
c = 0;
break;
case "cdda":
b = 1;
c = 1;
break;
case "FOO_":
b = 0;
c = 2;
break;
case "http":
b = 0;
c = 3;
break;
case "mms:":
b = 0;
c = 3;
break;
case "unpa":
b = 0;
c = 4;
break;
default:
b = 0;
c = 5
return c
ButtonStates = {
normal: 0,
hover: 1,
down: 2
button = function (d, e, f) {
this.img = Array(d, e, f);
this.w = this.img[0].Width;
this.h = this.img[0].Height;
this.state = ButtonStates.normal;
this.update = function (a, b, c) {
this.img = Array(a, b, c)
this.draw = function (a, x, y, b) {
this.x = x;
this.y = y;
this.img[this.state] && a.DrawImage(this.img[this.state], this.x, this.y, this.w, this.h, 0, 0, this.w, this.h, 0, b)
this.display_context_menu = function (x, y, a) {};
this.repaint = function () {
window.RepaintRect(this.x, this.y, this.w, this.h)
this.checkstate = function (a, x, y) {
this.ishover = (x > this.x && x < this.x + this.w - 1 && y > this.y && y < this.y + this.h - 1);
this.old = this.state;
switch (a) {
case "down":
switch (this.state) {
case ButtonStates.normal:
case ButtonStates.hover:
this.state = this.ishover ? ButtonStates.down : ButtonStates.normal;
break
break;
case "up":
this.state = this.ishover ? ButtonStates.hover : ButtonStates.normal;
break;
case "right":
if (this.ishover) this.display_context_menu(x, y, id);
break;
case "move":
break
break;
case "leave":
this.state = this.isdown ? ButtonStates.down : ButtonStates.normal;
break
if (this.state != this.old) this.repaint();
return this.state
function get_system_scrollbar_width() {
var a = utils.GetSystemMetrics(SM_CXVSCROLL);
return a
function get_system_scrollbar_height() {
var a = utils.GetSystemMetrics(SM_CYHSCROLL);
return a
var nocover;
var nocover_img;
var streamcover;
var star_img_off;
var star_img_on;
var star_img_hov;
var star_img_kill;
var toggle_scrollbar;
var menu_button;
cover2load = function () {
this.create = function (a, b) {
this.item = a;
this.timer = window.SetInterval(function () {
window.ClearInterval(mycover2load[0].timer);
mycover2load[0].item.cover_img = g_image_cache.getit(mycover2load[0].item);
mycover2load.shift();
if (a.show) {
window.RepaintRect(0, cover.pad_top_mid, ww, wh - cover.pad_top_mid)
} else {
a.show = true
}, b)
var mycover2load = Array();
image_cache = function () {
this._cachelist = {};
this.hit = function (a) {
var b = this._cachelist[a.cover_path + a.album];
if (typeof b == "undefined") {
mycover2load.push(new cover2load);
mycover2load[mycover2load.length - 1].create(a, (75 + mycover2load.length * 1) * mycover2load.length)
return b
this.getit = function (a) {
var b = refresh_cover(a);
this._cachelist[a.cover_path + a.album] = b;
return b
var g_image_cache = new image_cache;
function FormatCover(a, w, h) {
if (!a || w <= 0 || h <= 0) return a;
return a.Resize(w, h, 2)
function refresh_cover(a) {
var b = 0;
var c;
var d = (cover.w - cover.margin * 2) * cover.quality / 100;
var e = (cover.h - cover.margin * 2) * cover.quality / 100;
if (a.track_type != 3) {
if (a.metadb) {
c = FormatCover(utils.GetAlbumArtEmbedded(a.metadb.rawpath, b), d, e);
if (!c) {
c = FormatCover(utils.GetAlbumArtV2(a.metadb, b), d, e);
if (!c) {
c = FormatCover(nocover, d, e);
a.cover_type = 0
} else {
a.cover_type = 1
} else {
a.cover_type = 2
} else if (fb.IsPlaying && fb.PlaybackLength) {
c = FormatCover(streamcover, d, e);
a.cover_type = 3
} else {
a.cover_type = 0
return c
function reset_cover_timers() {
for (var i in mycover2load) {
mycover2load.timer && window.ClearInterval(mycover2load.timer)
mycover2load.splice(0, mycover2load.length)
ItemStates = {
normal: 0,
hover: 1,
selected: 2
item = function (g, h, j) {
var i;
if (typeof this.id == "undefined") {
if (g < 0) {
this.id = g;
this.idx = h;
this.gh_id = j;
this.metadb = false;
this.albumartist = "";
this.album = "";
this.track_type = null;
this.cover_path = "";
this.date = "";
this.genre = ""
} else {
this.id = g;
this.idx = h;
this.gh_id = j;
this.metadb = list.handlelist.Item(this.id);
if (this.metadb) {
this.albumartist = tf_albumartist.EvalWithMetadb(this.metadb);
this.album = tf_album.EvalWithMetadb(this.metadb);
this.track_type = TrackType(this.metadb.rawpath.substring(0, 4));
this.cover_path = tf_cover_path.EvalWithMetadb(this.metadb);
this.date = tf_date.EvalWithMetadb(this.metadb);
this.genre = tf_genre.EvalWithMetadb(this.metadb)
this.update_infos = function () {
if (this.metadb) {
} else {
this.album = "";
this.date = "";
this.genre = ""
this.draw = function (a, b, c, d, e) {
this.show = e;
if (list.mid == c) {
this.w = cover.w;
this.h = this.w;
this.y = cover.pad_top_mid;
this.x = Math.floor((ww / 2) - (cover.w / 2));
this.cut = 1
} else {
this.w = Math.abs(d) == 1 ? cover.w - cover.normal_delta * 1 : cover.w - cover.normal_delta * 2;
this.h = this.w;
this.x = Math.abs(d) == 1 ? Math.floor((ww / 2) - (this.w / 2)) - (d * (this.w - 5)) : Math.floor((ww / 2) - (this.w / 2)) - (d * this.w);
this.y = Math.abs(d) == 1 ? cover.pad_top_mid + Math.ceil(cover.normal_delta / 2) : cover.pad_top_mid + cover.normal_delta;
this.cut = Math.abs(d) == 1 ? 1 : 0
if (this.id >= 0 && cover.show && cover.visible) {
this.cover_img = g_image_cache.hit(this);
if (e && this.cover_img) {
a.DrawImage(this.cover_img, Math.floor(cover.margin / 2) + this.x, this.y + this.h * 2 - 2, this.w, -1 * this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 0, 255);
a.DrawRect(Math.floor(cover.margin / 2) + this.x, this.y + this.h + 1, this.w - cover.margin * 2 + 1, this.h - cover.margin * 2 + 1, 2.0, RGB(0, 0, 0));
a.DrawRect(Math.floor(cover.margin / 2) + this.x, this.y + this.h + 1, this.w - cover.margin * 2, this.h - cover.margin * 2, 1.0, RGB(255, 255, 255));
a.FillGradRect(Math.floor(cover.margin / 2) + this.x - 1, this.y + this.h - 1, this.w + 0 - this.cut, this.h + 1, 90, g_backcolor & 0xccffffff, g_backcolor, 1.0);
a.FillGradRect(Math.floor(cover.margin / 2) + this.x - 1, this.y + this.h - 1, this.w + 0 - this.cut, this.h + 1, 90, g_backcolor & 0x66ffffff, g_backcolor, 1.0);
a.DrawImage(this.cover_img, Math.floor(cover.margin / 2) + this.x, this.y, this.w, this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 0, 255);
a.DrawRect(Math.floor(cover.margin / 2) + this.x, this.y, this.w - cover.margin * 2 + 1, this.h - cover.margin * 2 + 1, 2.0, RGB(0, 0, 0));
a.DrawRect(Math.floor(cover.margin / 2) + this.x, this.y, this.w - cover.margin * 2, this.h - cover.margin * 2, 1.0, RGB(255, 255, 255))
} else {
a.DrawImage(nocover_img, Math.floor(cover.margin / 2) + this.x, this.y + this.h * 2 - 2, this.w, -1 * this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 0, 255);
a.DrawImage(nocover_img, Math.floor(cover.margin / 2) + this.x, this.y, this.w, this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 0, 255);
if (this.gh_id == list.selected_gh_id) {
a.SetSmoothingMode(2);
a.DrawRoundRect(Math.floor(cover.margin / 2) + this.x - 1, this.y - 1, this.w - cover.margin * 2 + 2, this.h - cover.margin * 2 + 2, 2, 2, 3.0, g_backcolor_sel);
a.DrawRoundRect(Math.floor(cover.margin / 2) + this.x - 2, this.y - 2, this.w - cover.margin * 2 + 4, this.h - cover.margin * 2 + 4, 3, 3, 1.0, RGBA(255, 255, 255, 60));
a.SetSmoothingMode(0);
a.DrawRect(Math.floor(cover.margin / 2) + this.x + 1, this.y + 1, this.w - cover.margin * 2 - 2, this.h - cover.margin * 2 - 2, 1.0, g_backcolor_sel);
a.DrawRect(Math.floor(cover.margin / 2) + this.x + 1, this.y + 1, this.w - cover.margin * 2 - 2, this.h - cover.margin * 2 - 2, 1.0, RGBA(0, 0, 0, 40))
this.checkstate = function (a, x, y, b) {
if (this.id >= 0 && y > cover.pad_top_mid) {
this.ishover = (x > this.x && x < this.x + this.w && y >= this.y && y < this.y + this.h)
} else {
this.ishover = false
switch (a) {
case "down":
if (!list.down_timerID && this.id >= 0) {
if (plman.IsPlaylistItemSelected(fb.ActivePlaylist, this.id)) {
if (this.ishover) {
SelectGroupItems(this.id, this.gh_id);
g_saved = this
} else {
if (this.ishover) {
if (utils.IsKeyPressed(VK_SHIFT)) {
if (list.focus_id != this.id) {
if (list.SHIFT_start_id != null) {
SelectAtoB(list.SHIFT_start_id, this.id)
} else {
SelectAtoB(list.focus_id, this.id)
} else if (utils.IsKeyPressed(VK_CONTROL)) {
plman.SetPlaylistFocusItem(fb.ActivePlaylist, this.id);
plman.SetPlaylistSelectionSingle(fb.ActivePlaylist, this.id, true)
} else {
g_saved = this
break;
case "dblclk":
if (this.id >= 0 && g_saved != null) {
if (this.id == g_saved.id) {
plman.ExecutePlaylistDefaultAction(fb.ActivePlaylist, list.hlist[g_saved.gh_id]);
g_saved = null;
window.Repaint()
break;
case "mid":
if (this.ishover && this.idx == list.mid) {
if (plman.GetPlaylistName(plman.ActivePlaylist) != "WSH CoverFlow") {
var c = false;
var d = 0;
var e = plman.ActivePlaylist;
for (var i = 0; i < plman.PlaylistCount; i++) {
if (plman.GetPlaylistName(i) == "WSH CoverFlow") {
c = true;
d = i;
break
if (!c) {
d = plman.PlaylistCount;
plman.CreatePlaylist(plman.PlaylistCount, "WSH CoverFlow")
plman.ActivePlaylist = d;
fb.ClearPlaylist();
var f = fb.PlaylistItemCount(d);
plman.InsertPlaylistItems(d, f, plman.GetPlaylistSelectedItems(e), false);
plman.SetPlaylistFocusItem(d, 0)
break;
case "right":
new_context_menu(x, y, this.id, this.idx)
break;
case "up":
break;
case "move":
if (this.ishover) {}
break;
case "leave":
break
return this.state
var tf_path = fb.TitleFormat("$left(%_path_raw%,4)");
var tf_cover_path = fb.TitleFormat("$replace(%path%,%filename_ext%,)");
var tf_tracknumber = fb.TitleFormat("$num($if2(%tracknumber%,1),2)");
var tf_artist = fb.TitleFormat("$if(%length%,%artist%,'Stream')");
var tf_title = fb.TitleFormat("%title%");
var tf_albumartist = fb.TitleFormat("$if(%length%,%album artist%,'Stream')");
var tf_album = fb.TitleFormat("$if2(%album%,$if(%length%,'Single','web radios'))");
var tf_disc = fb.TitleFormat("$if2(%discnumber%,0)");
var tf_disc_info = fb.TitleFormat("$if(%discnumber%,$ifgreater(%totaldiscs%,1,' - [disc '%discnumber%$if(%totaldiscs%,'/'%totaldiscs%']',']'),),)");
var tf_rating = fb.TitleFormat("$if2(%rating%,0)");
var tf_playcount = fb.TitleFormat("$if2(%play_counter%,$if2(%play_count%,0))");
var tf_length = fb.TitleFormat("$if2(%length%,' 0:00')");
var tf_date = fb.TitleFormat("$if2($year(%date%),)");
var tf_genre = fb.TitleFormat("$if2(%genre%,'Other')");
var tf_playback_time = fb.TitleFormat("%playback_time%");
var tf_playback_time_remaining = fb.TitleFormat("$if(%length%,-%playback_time_remaining%,'0:00')");
var tf_group_key = fb.TitleFormat("%album artist%%album%");
var g_instancetype = window.InstanceType;
var g_font = null;
var g_font_headers = null;
var ww = 0,
wh = 0;
var mouse_x = 0,
mouse_y = 0;
var g_textcolor = 0,
g_textcolor_sel = 0,
g_textcolor_hl = 0,
g_backcolor = 0,
g_backcolor_sel = 0;
var g_metadb;
var bool_on_size = false;
var g_search_string = "";
var incsearch_font = gdi.Font("lucida console", 9, 0);
var incsearch_font_big = gdi.Font("lucida console", 20, 1);
var clear_incsearch_timer = false;
var incsearch_timer = false;
var g_saved = null;
panel = {
max_height: window.GetProperty("panel.maximum.height", 300),
arr_buttons: Array(),
button_total: 2,
show_text: window.GetProperty("panel.album.info.visible", true),
custom_textcolor: window.GetProperty("panel.custom.text.color.normal", ""),
custom_textcolor_selection: window.GetProperty("panel.custom.text.color.selection", ""),
custom_backcolor: window.GetProperty("panel.custom.background.color", ""),
custom_textcolor_highlight: window.GetProperty("panel.custom.text.color.hightlight", "")
list = {
first_launch: true,
total: 0,
total_gh: 0,
start_id: 0,
nbvis: 0,
mid: 0,
item: Array(),
hlist: Array(),
handlelist: null,
metadblist_selection: plman.GetPlaylistSelectedItems(fb.ActivePlaylist),
focus_id: 0,
selected_gh_id: 0,
gh_id: 0,
mousewheel_timer_value: 50,
key_timer_value: 60,
nowplaying: 0,
SHIFT_start_id: null,
SHIFT_count: 0,
inc_search_noresult: false,
nb_cover_to_draw: 0,
buttonclicked: false
hscrollbar = {
theme: false,
themed: window.GetProperty("list.hscrollbar.themed", true),
show: window.GetProperty("list.hscrollbar.visible", true),
visible: true,
hover: false,
x: 0,
y: 0,
default_h: get_system_scrollbar_height(),
w: 0,
button_total: 2,
step: 3,
letter: null,
timerID: false
button_up = {
img_normal: null,
img_hover: null,
img_down: null,
x: 0,
y: 0,
w: hscrollbar.default_h,
h: hscrollbar.default_h,
timerID: false
button_down = {
img_normal: null,
img_hover: null,
img_down: null,
x: 0,
y: 0,
timerID: false
cursor = {
bt: null,
img_normal: null,
img_hover: null,
img_down: null,
popup: null,
x: 0,
y: 0,
w: hscrollbar.default_h + 3,
default_w: hscrollbar.default_h + 3,
hover: false,
drag: false,
grap_x: 0,
timerID: false,
last_x: 0
cover = {
show: true,
visible: true,
margin: 2,
w: 0,
h: 0,
top_offset: 0,
pad_top_mid: 35,
pad_bot_mid: 30,
normal_delta: 20,
quality: window.GetProperty("list.covers.quality.percent", 100)
function refresh_spv_cursor(a) {
var b = (cursor.x - hscrollbar.x) / (hscrollbar.w - cursor.w);
if (b > 1) b = 1;
if (b < 0) b = 0;
var r = Math.round(b * list.total_gh);
set_gh_id(a, list.hlist[r - 1]);
window.Repaint()
function set_gh_id(a, b) {
reset_cover_timers();
list.item.splice(0, list.item.length);
if (list.total_gh <= 0) return true;
list.gh_id = get_gh_id(b);
if (list.gh_id == null) {
list.gh_id = 0
var r = list.gh_id - list.mid;
if (r < 0) {
list.start_id = Math.abs®;
r = 0
} else {
list.start_id = 0
for (var k = 0; k < list.nbvis; k++) {
if (k >= list.start_id && r < list.total_gh) {
list.item.push(new item(list.hlist[r], k, r));
r++
} else {
list.item.push(new item(-1, k, -1))
function scrollup_spv(a) {
var r = list.item[list.mid].gh_id;
if (r > 0) {
var s = list.item[0].gh_id;
if (s > 0) {
list.item.unshift(new item(list.hlist[s - 1], 0, s - 1))
} else {
list.item.unshift(new item(-1, 0, -1))
list.item.pop()
for (var i = 0; i < list.item.length; i++) {
list.item.idx = i
setcursorx()
function scrolldown_spv(a) {
if (r < list.total_gh - 1) {
var s = list.item[list.item.length - 1].gh_id;
if (s > 0 && s < list.total_gh - 1) {
list.item.push(new item(list.hlist[s + 1], 0, s + 1))
} else {
list.item.push(new item(-1, 0, -1))
list.item.shift()
list.item.idx = i
setcursorx()
function refresh_spv(a, b) {
list.gh_id = get_gh_id(list.focus_id);
init_active_pls();
return true
list.selected_gh_id = list.gh_id;
if (r < 0) {
r = 0
} else {
list.start_id = 0
r++
} else {
if (hscrollbar.show) {
if (list.total_gh < 2) hscrollbar.visible = false;
else hscrollbar.visible = true
} else {
cursor.w = Math.round(hscrollbar.w / list.total_gh);
if (cursor.w > hscrollbar.w) cursor.w = hscrollbar.w;
if (cursor.w < cursor.default_w) cursor.w = cursor.default_w;
set_scroller();
setcursorx()
function get_gh_id(a) {
var b = Math.floor(list.total_gh / 2);
if (a < list.hlist) {
var c = 0
} else {
var c = b
for (var i = c; i < list.total_gh; i++) {
if (i < list.total_gh - 1) {
if (a >= list.hlist && a < list.hlist[i + 1]) {
return i
} else {
if (a >= list.hlist) {
return i
} else {
fb.trace("error: gh_id not found");
return null
function setcursorx() {
var a = Math.floor(list.item.length / 2);
var b = list.item[a].gh_id;
var c = b / (list.total_gh - 1);
cursor.x = hscrollbar.x + Math.round(c * (hscrollbar.w - cursor.w))
function init_active_pls() {
var a;
var b;
list.hlist.splice(0, list.hlist.length);
list.handlelist = plman.GetPlaylistItems(fb.ActivePlaylist);
list.total = list.handlelist.Count;
for (var i = 0; i < list.total; i++) {
b = tf_group_key.EvalWithMetadb(list.handlelist.Item(i));
if (a != b) {
list.hlist.push(i);
a = b
list.total_gh = list.hlist.length
function on_font_changed() {
get_font();
window.Repaint()
function on_colors_changed() {
get_colors();
init_icons();
nocover_img = FormatCover(nocover, (cover.w - cover.margin * 2) * cover.quality / 100, (cover.h - cover.margin * 2) * cover.quality / 100);
init_hscrollbar_buttons();
set_scroller();
CollectGarbage();
window.Repaint()
function on_init() {};
function on_size() {
if (!window.Width || !window.Height) return;
window.DlgCode = DLGC_WANTALLKEYS;
bool_on_size = true;
if (g_instancetype == 0) {
window.MinWidth = 200;
window.MinHeight = 170;
window.MaxHeight = panel.max_height
} else if (g_instancetype == 1) {
ww = window.Width;
wh = window.Height;
if (wh < 170) wh = 170;
get_font();
get_colors();
init_icons();
cover.w = wh - cover.pad_top_mid - cover.pad_bot_mid;
cover.h = cover.w;
list.nbvis = Math.floor(ww / (cover.w - cover.normal_delta * 2)) + 2;
if (list.nbvis / 2 == Math.floor(list.nbvis / 2)) {
list.nbvis--
if (list.nbvis > 13) list.nbvis = 13;
list.mid = Math.floor(list.nbvis / 2);
list.nb_cover_to_draw = list.nbvis;
if (hscrollbar.themed) {
hscrollbar.theme = window.CreateThemeManager("scrollbar")
} else {
hscrollbar.theme = false
button_up.x = 0;
button_up.y = wh - hscrollbar.h;
button_down.x = ww - button_down.w;
button_down.y = wh - hscrollbar.h;
hscrollbar.x = button_up.w;
hscrollbar.w = ww - button_up.w - button_down.w;
cursor.y = wh - hscrollbar.h;
cursor.x = hscrollbar.x;
if (list.first_launch) {
list.first_launch = false;
on_playlist_switch()
} else {
CollectGarbage();
refresh_spv(fb.ActivePlaylist, true);
window.Repaint()
function on_paint(a) {
a.FillGradRect(0, 0, ww, wh, 90, g_backcolor, g_backcolor & 0xd0ffffff, 0.3);
if (list.item.length > 0) {
var b;
var c = (list.nb_cover_to_draw - 1) / 2;
list.item[list.mid].draw(a, list.item[list.mid].id, list.mid, 0, true);
for (var d = 1; d < list.mid + 1; d++) {
if (d > 1 && d <= c) {
b = true
} else {
b = false
mid2 = list.mid - d;
if (mid2 >= 0 && mid2 <= list.item.length - 1) {
list.item[mid2].draw(a, list.item[mid2].id, mid2, d, b)
mid2 = list.mid + d;
list.item[mid2].draw(a, list.item[mid2].id, mid2, d * -1, b)
mid2 = list.mid - 1;
list.item[mid2].draw(a, list.item[mid2].id, mid2, 1, true)
mid2 = list.mid + 1;
list.item[mid2].draw(a, list.item[mid2].id, mid2, -1, true)
if (panel.show_text) {
var f = 30;
var g = ww - 60;
if (list.item[list.mid].id >= 0) {
if (list.item[list.mid].date.length > 0) {
a.GdiDrawText(list.item[list.mid].albumartist + " | " + list.item[list.mid].album + " (" + list.item[list.mid].date + ")", g_font, g_textcolor, f, 0, g, cover.pad_top_mid - 4, DT_CENTER | DT_CALCRECT | DT_VCENTER | DT_END_ELLIPSIS | DT_NOPREFIX)
} else {
a.GdiDrawText(list.item[list.mid].albumartist + " | " + list.item[list.mid].album, g_font, g_textcolor, f, 0, g, cover.pad_top_mid - 4, DT_CENTER | DT_CALCRECT | DT_VCENTER | DT_END_ELLIPSIS | DT_NOPREFIX)
if (list.total_gh > 0 && hscrollbar.visible && hscrollbar.show) {
try {
hscrollbar.theme.SetPartAndStateId(4, 1);
hscrollbar.theme.DrawThemeBackground(a, 0, wh - hscrollbar.h, ww, hscrollbar.h);
a.FillSolidRect(0, wh - hscrollbar.h - 1, ww, 1, RGBA(0, 0, 0, 10))
} catch (e) {
a.FillSolidRect(0, wh - hscrollbar.h, ww, hscrollbar.h, g_backcolor);
a.FillGradRect(0, wh - hscrollbar.h, ww, hscrollbar.h, 0, RGBA(0, 0, 0, 100), g_backcolor, 0.5);
a.FillGradRect(0, wh - hscrollbar.h, ww, hscrollbar.h, 0, 0, RGBA(255, 255, 255, 25), 0.5);
try {
cursor.bt.draw(a, cursor.x, cursor.y, 255)
} catch (e) {};
try {
hscrollbar.theme.SetPartAndStateId(8, 1);
hscrollbar.theme.DrawThemeBackground(a, cursor.x, wh - hscrollbar.h + 0, cursor.w, cursor.h)
} catch (e) {};
for (i = 0; i < hscrollbar.arr_buttons.length; i++) {
switch (i) {
case 0:
hscrollbar.arr_buttons.draw(a, button_up.x, button_up.y, 255);
break;
case 1:
hscrollbar.arr_buttons.draw(a, button_down.x, button_down.y, 255);
break
if (cursor.drag) {
hscrollbar.letter = list.item[Math.floor(list.nb_cover_to_draw / 2)].albumartist.substring(0, 1).toUpperCase();
cursor.popup && a.DrawImage(cursor.popup, cursor.x + Math.floor(cursor.w / 2) - Math.floor(cursor.popup.Width / 2), wh - hscrollbar.h - cursor.popup.Height, cursor.popup.Width, cursor.popup.Height, 0, 0, cursor.popup.Width, cursor.popup.Height, 0, 155);
cursor.popup && a.GdiDrawText(hscrollbar.letter, gdi.Font("segoe ui", 14, 0), g_backcolor, cursor.x + Math.floor(cursor.w / 2) - Math.floor(cursor.popup.Width / 2), wh - hscrollbar.h - cursor.popup.Height, cursor.popup.Width, cursor.popup.Height - 5, DT_CENTER | DT_CALCRECT | DT_VCENTER | DT_END_ELLIPSIS | DT_NOPREFIX)
for (i = 0; i < panel.arr_buttons.length; i++) {
switch (i) {
case 0:
panel.arr_buttons.draw(a, 5, 5, 255);
break;
case 1:
panel.arr_buttons.draw(a, ww - 22 - 5, 5, 255);
break
a.FillGradRect(0, 0, ww, 1, 0, 0, g_textcolor & 0x25ffffff, 0.5)
list.item.checkstate("down", x, y, i)
if (cursor.bt.checkstate("down", x, y) == ButtonStates.down) {
cursor.drag = true;
cursor.grap_x = x - cursor.x;
cursor.last_x = cursor.x
if (hscrollbar.hover && !cursor.drag) {
hscrollbar.step = Math.floor(list.nb_cover_to_draw / 2);
if (hscrollbar.step < 1) hscrollbar.step = 1;
if (x < cursor.x) {
if (!list.buttonclicked) {
list.buttonclicked = true;
on_mouse_wheel(hscrollbar.step);
button_up.first_timerID = window.SetTimeout(function () {
button_up.timerID = window.SetInterval(function () {
if (hscrollbar.hover) {
if (mouse_y > wh - hscrollbar.h && cursor.x > mouse_x) {
}, list.key_timer_value)
}, 400)
} else {
on_mouse_wheel(-1 * hscrollbar.step);
button_down.first_timerID = window.SetTimeout(function () {
button_down.timerID = window.SetInterval(function () {
if (mouse_y > wh - hscrollbar.h && cursor.x + cursor.w < mouse_x) {
}, 400)
switch (i) {
case 0:
if (hscrollbar.arr_buttons.checkstate("down", x, y) == ButtonStates.down) {
on_mouse_wheel(1);
window.Repaint();
on_mouse_wheel(1);
window.Repaint()
}, 400)
break;
case 1:
on_mouse_wheel(-1);
window.Repaint();
on_mouse_wheel(-1);
window.Repaint()
}, 400)
break
switch (i) {
case 0:
if (panel.arr_buttons.checkstate("down", x, y) == ButtonStates.down) {
ShowNowPlaying()
break;
case 1:
if (list.total_gh >= 2) {
hscrollbar.show = !hscrollbar.show;
} else {
} else {
window.SetProperty("list.hscrollbar.visible", hscrollbar.show);
window.Repaint()
break
function on_mouse_lbtn_dblclk(x, y, a) {
if (y < cover.pad_top_mid) {} else if (y < wh - cover.pad_bot_mid) {
list.item.checkstate("dblclk", x, y, i)
} else {
list.buttonclicked = false;
hscrollbar.timerID && window.ClearTimeout(hscrollbar.timerID);
hscrollbar.timerID = false;
button_up.first_timerID && window.ClearTimeout(button_up.first_timerID);
button_up.first_timerID = false;
button_down.first_timerID && window.ClearTimeout(button_down.first_timerID);
button_down.first_timerID = false;
button_up.timerID && window.ClearInterval(button_up.timerID);
button_up.timerID = false;
button_down.timerID && window.ClearInterval(button_down.timerID);
button_down.timerID = false;
if (list.total_gh > 0) {
cursor.bt.checkstate("up", x, y);
for (var i = 0; i < hscrollbar.arr_buttons.length; i++) {
hscrollbar.arr_buttons.checkstate("up", x, y)
for (var i = 0; i < panel.arr_buttons.length; i++) {
panel.arr_buttons.checkstate("up", x, y)
if (cursor.drag) {
window.RepaintRect(0, wh - hscrollbar.h, ww, hscrollbar.h);
cursor.drag = false
} else {
for (i = 0; i < list.item.length; i++) {
list.item.checkstate("up", x, y, i)
setcursorx();
window.Repaint()
function on_mouse_mbtn_down(x, y, a) {
list.item.checkstate("mid", x, y, i)
function on_mouse_rbtn_down(x, y) {
list.item.checkstate("right", x, y, i)
if (x == mouse_x && y == mouse_y) return true;
hscrollbar.hover = (y >= wh - hscrollbar.h && y <= wh && x >= hscrollbar.x && x <= hscrollbar.x + hscrollbar.w);
cursor.hover = (x >= cursor.x && x <= cursor.x + cursor.w && y >= cursor.y && y <= cursor.y + cursor.h);
cursor.bt.checkstate("move", x, y);
hscrollbar.arr_buttons.checkstate("move", x, y)
if (cursor.drag && mouse_x != x) {
cursor.x = x - cursor.grap_x;
if (cursor.x < hscrollbar.x) cursor.x = hscrollbar.x;
if (cursor.x > hscrollbar.x + hscrollbar.w - cursor.w) cursor.x = hscrollbar.x + hscrollbar.w - cursor.w;
if (!cursor.timerID) {
cursor.timerID = window.SetTimeout(function () {
refresh_spv_cursor(fb.ActivePlaylist);
window.Repaint();
cursor.timerID && window.ClearTimeout(cursor.timerID);
cursor.timerID = false
}, 30)
for (var j = 0; j < panel.arr_buttons.length; j++) {
panel.arr_buttons[j].checkstate("move", x, y)
mouse_x = x;
mouse_y = y
function on_mouse_wheel(a) {
if (!hscrollbar.timerID) {
if (Math.abs(a) >= 1) {
if (a > 0) {
for (var i = 0; i < Math.abs(a); i++) {
scrollup_spv(fb.ActivePlaylist)
hscrollbar.timerID = window.SetTimeout(function () {
window.Repaint();
}, list.mousewheel_timer_value)
} else {
scrolldown_spv(fb.ActivePlaylist)
window.Repaint();
function on_mouse_leave() {
list.item.checkstate("leave", 0, 0, i)
window.Repaint()
function on_playlist_switch() {
if (fb.ActivePlaylist < 0 || fb.ActivePlaylist > fb.PlaylistCount) {
if (fb.PlaylistCount > 0) {
fb.ActivePlaylist = 0
init_active_pls();
list.focus_id = plman.GetPlaylistFocusItemIndex(fb.ActivePlaylist);
if (list.focus_id < 0) {
list.focus_id = 0
window.Repaint()
function on_playlist_items_added(a) {
if (a == fb.ActivePlaylist) {
plman.SetActivePlaylistContext()
function on_playlist_items_reordered(a) {
function on_selection_changed(a) {};
function on_playlist_items_selection_change() {};
function on_playlists_changed() {};
function on_item_focus_change(a, b, c) {
list.focus_id = c;
plman.SetActivePlaylistContext();
refresh_spv(fb.ActivePlaylist, bool_on_size);
window.Repaint()
function on_metadb_changed(a, b) {
list.item.update_infos()
window.Repaint()
function on_focus(a) {};
function on_key_up(a) {};
function on_key_down(a) {
var b = GetKeyboardMask();
if (b == KMask.none) {
switch (a) {
case VK_SHIFT:
list.SHIFT_count = 0;
break;
case VK_BACK:
break;
case VK_ESCAPE:
case 222:
break;
case VK_SPACEBAR:
var c = list.item[Math.floor(list.nb_cover_to_draw / 2)].id;
plman.SetPlaylistFocusItem(fb.ActivePlaylist, c);
plman.ClearPlaylistSelection(fb.ActivePlaylist);
plman.SetPlaylistSelectionSingle(fb.ActivePlaylist, c, true);
break;
case VK_LEFT:
on_mouse_wheel(1);
break;
case VK_RIGHT:
on_mouse_wheel(-1);
break;
case VK_PGUP:
break;
case VK_PGDN:
on_mouse_wheel(hscrollbar.step * -1);
break;
case VK_RETURN:
plman.ExecutePlaylistDefaultAction(fb.ActivePlaylist, list.focus_id);
break;
case VK_END:
plman.SetPlaylistFocusItem(fb.ActivePlaylist, list.total - 1);
plman.SetPlaylistSelectionSingle(fb.ActivePlaylist, list.total - 1, true);
break;
case VK_HOME:
plman.SetPlaylistFocusItem(fb.ActivePlaylist, 0);
plman.SetPlaylistSelectionSingle(fb.ActivePlaylist, 0, true);
break;
case VK_DELETE:
if (!fb.IsAutoPlaylist(fb.ActivePlaylist)) {
plman.RemovePlaylistSelection(fb.ActivePlaylist, false);
plman.SetPlaylistSelectionSingle(fb.ActivePlaylist, plman.GetPlaylistFocusItemIndex(fb.ActivePlaylist), true)
break;
default:
break
} else {
switch (b) {
case KMask.shift:
break;
case KMask.ctrl:
if (a == 65) {
fb.RunMainMenuCommand("Edit/Select all");
window.Repaint()
if (a == 70) {
fb.RunMainMenuCommand("Edit/Search")
if (a == 78) {
fb.RunMainMenuCommand("File/New playlist")
if (a == 79) {
fb.RunMainMenuCommand("File/Open...")
if (a == 80) {
fb.RunMainMenuCommand("File/Preferences")
if (a == 83) {
fb.RunMainMenuCommand("File/Save playlist...")
break;
case KMask.alt:
if (a == 65) {
fb.RunMainMenuCommand("View/Always on Top")
break
function on_playback_new_track(a) {
g_metadb = fb.GetNowPlaying();
window.Repaint()
function on_playback_stop(a) {
if (a == 0) {
g_metadb = fb.GetFocusItem();
on_metadb_changed()
function on_playback_pause(a) {};
function on_playback_time(a) {};
function get_font() {
g_font = window.GetFontCUI(FontTypeCUI.items);
g_font_headers = window.GetFontCUI(FontTypeCUI.labels)
g_font = window.GetFontDUI(FontTypeDUI.playlists);
g_font_headers = window.GetFontDUI(FontTypeDUI.tabs)
function get_colors() {
g_textcolor = window.GetColorCUI(ColorTypeCUI.text);
g_textcolor_sel = window.GetColorCUI(ColorTypeCUI.selection_text);
g_textcolor_hl = window.GetColorCUI(ColorTypeCUI.active_item_frame);
g_backcolor = window.GetColorCUI(ColorTypeCUI.background);
g_backcolor_sel = window.GetColorCUI(ColorTypeCUI.selection_background)
g_textcolor = window.GetColorDUI(ColorTypeDUI.text);
g_textcolor_sel = window.GetColorDUI(ColorTypeDUI.selection);
g_textcolor_hl = window.GetColorDUI(ColorTypeDUI.highlight);
g_backcolor = window.GetColorDUI(ColorTypeDUI.background);
g_backcolor_sel = g_textcolor_sel
try {
if (panel.custom_textcolor.length > 0) g_textcolor = eval(panel.custom_textcolor);
if (panel.custom_textcolor_selection.length > 0) g_textcolor_sel = eval(panel.custom_textcolor_selection);
if (panel.custom_backcolor.length > 0) g_backcolor = eval(panel.custom_backcolor);
if (panel.custom_textcolor_highlight.length > 0) g_textcolor_hl = eval(panel.custom_textcolor_highlight)
} catch (e) {};
g_backcolor_R = getRed(g_backcolor);
g_backcolor_G = getGreen(g_backcolor);
g_backcolor_B = getBlue(g_backcolor)
function set_scroller() {
var a;
try {
cursor.img_normal = gdi.CreateImage(cursor.w, cursor.h)
} catch (e) {
cursor.h = cursor.default_h;
a = cursor.img_normal.GetGraphics();
try {
hscrollbar.theme.SetPartAndStateId(2, 1);
hscrollbar.theme.DrawThemeBackground(a, 0, 0, cursor.w, cursor.h)
} catch (e) {
a.FillSolidRect(0, 1, cursor.w - 0, cursor.h - 2, g_backcolor);
a.FillSolidRect(0, 1, cursor.w - 0, cursor.h - 2, RGBA(0, 0, 0, 100));
a.FillSolidRect(0, 1, cursor.w - 1, cursor.h - 3, g_textcolor & 0x77ffffff);
a.FillSolidRect(1, 2, cursor.w - 2, cursor.h - 4, g_backcolor);
a.FillSolidRect(1, 2, cursor.w - 2, cursor.h - 4, RGBA(255, 255, 255, 25))
cursor.img_normal.ReleaseGraphics(a);
cursor.img_hover = gdi.CreateImage(cursor.w, cursor.h);
a = cursor.img_hover.GetGraphics();
try {
hscrollbar.theme.SetPartAndStateId(2, 2);
} catch (e) {
a.FillSolidRect(0, 1, cursor.w - 0, cursor.h - 2, RGBA(0, 0, 0, 70));
a.FillSolidRect(0, 1, cursor.w - 1, cursor.h - 3, g_textcolor & 0x99ffffff);
a.FillSolidRect(1, 2, cursor.w - 2, cursor.h - 4, RGBA(255, 255, 255, 50))
cursor.img_hover.ReleaseGraphics(a);
cursor.bt = new button(cursor.img_normal, cursor.img_hover, cursor.img_hover)
function init_hscrollbar_buttons() {
var i, gb;
cursor.popup = gdi.CreateImage(22, 27);
gb = cursor.popup.GetGraphics();
gb.SetSmoothingMode(2);
gb.FillRoundRect(0, 0, 22 - 1, 22 - 1, 3, 3, g_textcolor);
gb.DrawRoundRect(0, 0, 22 - 1, 22 - 1, 3, 3, 1.0, RGBA(0, 0, 0, 150));
var a = Array(7, 22 - 2, 11, 22 - 2 + 6, 22 - 7, 22 - 2);
gb.FillPolygon(g_textcolor, 0, a);
gb.DrawPolygon(RGBA(0, 0, 0, 150), 1.0, a);
gb.SetSmoothingMode(0);
gb.FillSolidRect(6, 22 - 4, 22 - 10, 3, g_textcolor);
cursor.popup.ReleaseGraphics(gb);
button_up.img_normal = gdi.CreateImage(button_up.w, button_up.h);
gb = button_up.img_normal.GetGraphics();
try {
hscrollbar.theme.SetPartAndStateId(1, 9);
hscrollbar.theme.DrawThemeBackground(gb, 0, 0, button_up.w, button_up.h)
} catch (e) {
gb.FillSolidRect(0, 0, button_up.w - 0, button_up.h - 0, g_backcolor);
gb.FillSolidRect(0, 0, button_up.w - 0, button_up.h - 0, RGBA(0, 0, 0, 100));
gb.FillSolidRect(0, 0, button_up.w - 1, button_up.h - 1, g_textcolor & 0x77ffffff);
gb.FillSolidRect(1, 1, button_up.w - 2, button_up.h - 2, g_backcolor);
gb.FillSolidRect(1, 1, button_up.w - 2, button_up.h - 2, RGBA(255, 255, 255, 25));
gb.SetTextRenderingHint(4);
gui_font = gdi.Font("guifx v2 transports", 12, 0);
gb.DrawString(".", gui_font, RGBA(255, 255, 255, 25), 0, 1, button_up.w - 0, button_up.h, cc_stringformat);
gb.DrawString(".", gui_font, g_textcolor, 0, 0, button_up.w - 0, button_up.h, cc_stringformat)
button_up.img_normal.ReleaseGraphics(gb);
button_up.img_hover = gdi.CreateImage(button_up.w, button_up.h);
gb = button_up.img_hover.GetGraphics();
try {
hscrollbar.theme.SetPartAndStateId(1, 10);
} catch (e) {
gb.FillSolidRect(0, 0, button_up.w - 0, button_up.h - 0, RGBA(0, 0, 0, 70));
gb.FillSolidRect(0, 0, button_up.w - 1, button_up.h - 1, g_textcolor & 0x99ffffff);
gb.FillSolidRect(1, 1, button_up.w - 2, button_up.h - 2, RGBA(255, 255, 255, 50));
gb.DrawString(".", gui_font, RGBA(255, 255, 255, 50), 0, 1, button_up.w - 0, button_up.h, cc_stringformat);
button_up.img_hover.ReleaseGraphics(gb);
button_up.img_down = gdi.CreateImage(button_up.w, button_up.h);
gb = button_up.img_down.GetGraphics();
try {
hscrollbar.theme.SetPartAndStateId(1, 11);
} catch (e) {
gb.FillSolidRect(0, 0, button_up.w - 0, button_up.h - 0, g_textcolor & 0x77ffffff);
gb.FillSolidRect(0, 0, button_up.w - 1, button_up.h - 1, RGBA(0, 0, 0, 100));
button_up.img_down.ReleaseGraphics(gb);
button_down.img_normal = gdi.CreateImage(button_down.w, button_down.h);
gb = button_down.img_normal.GetGraphics();
try {
hscrollbar.theme.SetPartAndStateId(1, 13);
hscrollbar.theme.DrawThemeBackground(gb, 0, 0, button_down.w, button_down.h)
} catch (e) {
gb.FillSolidRect(0, 0, button_down.w - 0, button_down.h - 0, g_backcolor);
gb.FillSolidRect(0, 0, button_down.w - 0, button_down.h - 0, RGBA(0, 0, 0, 100));
gb.FillSolidRect(0, 0, button_down.w - 1, button_down.h - 1, g_textcolor & 0x77ffffff);
gb.FillSolidRect(1, 1, button_down.w - 2, button_down.h - 2, g_backcolor);
gb.FillSolidRect(1, 1, button_down.w - 2, button_down.h - 2, RGBA(255, 255, 255, 25));
gb.DrawString(",", gui_font, RGBA(255, 255, 255, 25), 0, 1, button_down.w - 0, button_down.h, cc_stringformat);
gb.DrawString(",", gui_font, g_textcolor, 0, 0, button_down.w - 0, button_down.h, cc_stringformat)
button_down.img_normal.ReleaseGraphics(gb);
button_down.img_hover = gdi.CreateImage(button_down.w, button_down.h);
gb = button_down.img_hover.GetGraphics();
try {
hscrollbar.theme.SetPartAndStateId(1, 14);
} catch (e) {
gb.FillSolidRect(0, 0, button_down.w - 0, button_down.h - 0, RGBA(0, 0, 0, 70));
gb.FillSolidRect(0, 0, button_down.w - 1, button_down.h - 1, g_textcolor & 0x99ffffff);
gb.FillSolidRect(1, 1, button_down.w - 2, button_down.h - 2, RGBA(255, 255, 255, 50));
gb.DrawString(",", gui_font, RGBA(255, 255, 255, 50), 0, 1, button_down.w - 0, button_down.h, cc_stringformat);
button_down.img_hover.ReleaseGraphics(gb);
button_down.img_down = gdi.CreateImage(button_down.w, button_down.h);
gb = button_down.img_down.GetGraphics();
try {
hscrollbar.theme.SetPartAndStateId(1, 15);
} catch (e) {
gb.FillSolidRect(0, 0, button_down.w - 0, button_down.h - 0, g_textcolor & 0x77ffffff);
gb.FillSolidRect(0, 0, button_down.w - 1, button_down.h - 1, RGBA(0, 0, 0, 100));
gb.FillSolidRect(1, 1, button_down.w - 2, button_down.h - 1, g_backcolor);
gb.FillSolidRect(1, 1, button_down.w - 2, button_down.h - 1, RGBA(255, 255, 255, 25));
button_down.img_down.ReleaseGraphics(gb);
hscrollbar.arr_buttons.splice(0, hscrollbar.arr_buttons.length);
for (i = 0; i < hscrollbar.button_total; i++) {
switch (i) {
case 0:
hscrollbar.arr_buttons.push(new button(button_up.img_normal, button_up.img_hover, button_up.img_down));
break;
case 1:
hscrollbar.arr_buttons.push(new button(button_down.img_normal, button_down.img_hover, button_down.img_down));
break
function init_icons() {
var a;
var b = gdi.Font("guifx v2 transports", 15, 0);
nocover = gdi.CreateImage(200, 200);
a = nocover.GetGraphics();
a.FillSolidRect(0, 0, 200, 200, g_textcolor);
a.FillGradRect(0, 0, 200, 200, 90, g_backcolor & 0xbbffffff, g_backcolor, 1.0);
a.SetTextRenderingHint(3);
b = gdi.Font("guifx v2 transports", 132, 0);
a.DrawString("x", b, RGB(0, 0, 0), 1, -2, 200, 200, cc_stringformat);
a.DrawString("x", b, RGB(255, 255, 255), 1, 2, 200, 200, cc_stringformat);
a.DrawString("x", b, g_backcolor, 1, 0, 200, 200, cc_stringformat);
a.DrawString("x", b, g_textcolor & 0x88ffffff, 1, 0, 200, 200, cc_stringformat);
nocover.ReleaseGraphics(a);
streamcover = gdi.CreateImage(200, 200);
a = streamcover.GetGraphics();
b = gdi.F
thumbs: the thumbnails in grid mode are now horizontally centred. also added new thumbnail size: 250px.
WSH CoverFlow v1 beta3 (optimized and new settings in properties!)
// @version "0.0.3.20120320.2015"
// @author "Br3tt"
// @feature "v1.4"
// ==/PREPROCESSOR==
// [Requirements]
// [/Requirements]
// [Informations]
// * for custom colors in Properties, use e.g. RGB(255,255,255) for white color, RGB(0,0,0) for black color, ...
// [/Informations]
SM_CXVSCROLL = 2;
SM_CYHSCROLL = 3;
IDC_ARROW = 32512;
IDC_IBEAM = 32513;
IDC_WAIT = 32514;
IDC_CROSS = 32515;
IDC_SIZE = 32640;
IDC_ICON = 32641;
IDC_SIZEWE = 32644;
IDC_SIZENS = 32645;
IDC_NO = 32648;
IDC_HAND = 32649;
IDC_HELP = 32651;
var DT_LEFT = 0x00000000;
var DT_RIGHT = 0x00000002;
var DT_TOP = 0x00000000;
var DT_CENTER = 0x00000001;
var DT_VCENTER = 0x00000004;
var DT_WORDBREAK = 0x00000010;
var DT_SINGLELINE = 0x00000020;
var DT_CALCRECT = 0x00000400;
var DT_NOPREFIX = 0x00000800;
var DT_EDITCONTROL = 0x00002000;
var DT_END_ELLIPSIS = 0x00008000;
var VK_BACK = 0x08;
var VK_RETURN = 0x0D;
var VK_SHIFT = 0x10;
var VK_CONTROL = 0x11;
var VK_ALT = 0x12;
var VK_ESCAPE = 0x1B;
var VK_PGUP = 0x21;
var VK_PGDN = 0x22;
var VK_END = 0x23;
var VK_HOME = 0x24;
var VK_LEFT = 0x25;
var VK_UP = 0x26;
var VK_RIGHT = 0x27;
var VK_DOWN = 0x28;
var VK_INSERT = 0x2D;
var VK_DELETE = 0x2E;
var VK_SPACEBAR = 0x20;
var KMask = {
none: 0,
ctrl: 1,
shift: 2,
ctrlshift: 3,
ctrlalt: 4,
ctrlaltshift: 5,
alt: 6
var b = KMask.none;
return b
ColorTypeCUI = {
text: 0,
selection_text: 1,
background: 3,
FontTypeCUI = {
items: 0,
labels: 1
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
FontTypeDUI = {
defaults: 0,
tabs: 1,
lists: 2,
playlists: 3,
statusbar: 4,
console: 5
var a = 0,
v_align = 0,
trimming = 0,
flags = 0;
case 3:
case 2:
case 1:
a = arguments[0];
break;
default:
return 0
StringAlignment = {
Near: 0,
Centre: 1,
Far: 2
return (a & 0xff)
var i;
if (k > 0) {
c = "0" + c
return c.toString()
var b;
var c;
switch (a) {
case "file":
b = 1;
c = 0;
break;
case "cdda":
b = 1;
c = 1;
break;
case "FOO_":
b = 0;
c = 2;
break;
case "http":
b = 0;
c = 3;
break;
case "mms:":
b = 0;
c = 3;
break;
case "unpa":
b = 0;
c = 4;
break;
default:
b = 0;
c = 5
return c
ButtonStates = {
normal: 0,
hover: 1,
down: 2
this.x = x;
this.y = y;
switch (a) {
case "down":
break
break;
case "up":
break;
case "right":
break;
case "move":
break
break;
case "leave":
break
return this.state
return a
return a
var nocover;
var nocover_img;
var streamcover;
var star_img_off;
var star_img_on;
var star_img_hov;
var star_img_kill;
var menu_button;
cover2load = function (a, b) {
this.item = a;
this.timer = window.SetTimeout(function () {
if (mycover2load.length > 0) {
mycover2load[0].timer && window.ClearTimeout(mycover2load[0].timer);
utils.GetAlbumArtAsync(window.ID, mycover2load[0].item.metadb, 0, true, false, false)
}, b)
mycover2load.push(new cover2load(a, (80 * (mycover2load.length > 0 ? 1 : 0)) + (10 * mycover2load.length)))
return b
return b
var b = 0;
var c;
if (a.metadb) {
if (!c) {
if (!c) {
a.cover_type = 0
} else {
a.cover_type = 1
} else {
a.cover_type = 2
a.cover_type = 3
} else {
a.cover_type = 0
return c
function on_get_album_art_done(a, b, c, d) {
for (var i = 0; i < mycover2load.length; i++) {
if (mycover2load[0].item.metadb.Compare(a)) {
mycover2load.item.cover_img = g_image_cache.getit(mycover2load.item, c, d);
if (mycover2load.item.show) {
window.RepaintRect(mycover2load.item.x - 15, cover.pad_top_mid, mycover2load.item.w + 30, wh - cover.pad_top_mid)
} else {
mycover2load.item.show = true
mycover2load.splice(i, 1);
break
ItemStates = {
normal: 0,
hover: 1,
selected: 2
item = function (g, h, k) {
var i;
if (g < 0) {
this.id = g;
this.idx = h;
this.gh_id = k;
this.album = "";
this.group_info = ""
} else {
this.id = g;
this.idx = h;
this.gh_id = k;
if (this.metadb) {
this.group_info = tf_group_info.EvalWithMetadb(this.metadb)
if (this.metadb) {
} else {
this.album = "";
this.show = e;
this.w = cover.w;
this.h = this.w;
this.cut = 1
} else {
this.h = this.w;
if (this.id >= 0) {
if (this.show && typeof (this.cover_img) != "undefined") {
var f = 255 - Math.floor(cover.reflect_strength_percent * 2.55);
if (cover.draw_reflection && f > 0 && cover.reflect_strength_percent > 0) {
a.DrawImage(this.cover_img, Math.floor(cover.margin / 2) + this.x, this.y + this.h * 2 - cover.margin - 1, this.w, -1 * this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 0, 255);
if (cover.draw_border) {
} else {
a.DrawRect(Math.floor(cover.margin / 2) + this.x, this.y + this.h + 1, this.w - cover.margin * 2, this.h - cover.margin * 2, 1.0, RGB(127, 127, 127))
a.FillGradRect(Math.floor(cover.margin / 2) + this.x - 1, this.y + this.h - 1, this.w - this.cut, this.h + 1, 90, RGBA(g_backcolor_R, g_backcolor_G, g_backcolor_B, f), g_backcolor, 1.0)
} else {
a.DrawRect(Math.floor(cover.margin / 2) + this.x, this.y, this.w - cover.margin * 2, this.h - cover.margin * 2, 1.0, RGB(127, 127, 127))
if (cover.draw_shadows) {
if (d == 0 || d == 1 || d == -1) {
for (var j = 0; j < 7; j++) {
if (this.gh_id > 0) {
a.FillSolidRect(Math.floor(cover.margin / 2) + this.x - j - cover.margin + 1, this.y + cover.normal_delta / 2, 1, this.h - cover.normal_delta - cover.margin - 1, RGBA(0, 0, 0, 150 - j * 25))
if (this.gh_id < list.total_gh - 1) {
a.FillSolidRect(Math.floor(cover.margin / 2) + this.x + this.w - cover.margin + j - 1, this.y + cover.normal_delta / 2, 1, this.h - cover.normal_delta - cover.margin - 1, RGBA(0, 0, 0, 150 - j * 25))
} else {
a.DrawImage(nocover_img, Math.floor(cover.margin / 2) + this.x, this.y + this.h * 2 - cover.margin - 1, this.w, -1 * this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 0, 255);
} else {
} else {
if (cover.draw_focus_border && this.gh_id == list.selected_gh_id) {
} else {
switch (a) {
case "down":
if (this.ishover) {
g_saved = this
} else {
if (this.ishover) {
if (list.SHIFT_start_id != null) {} else {}
} else {
g_saved = this
break;
case "dblclk":
g_saved = null;
window.Repaint()
break;
case "mid":
var c = false;
var d = 0;
c = true;
d = i;
break
if (!c) {
fb.ClearPlaylist();
break;
case "right":
break;
case "up":
break;
case "move":
break;
case "leave":
break
return this.state
var tf_group_key = fb.TitleFormat(window.GetProperty("_group Key", "%album artist%%album%"));
var tf_group_info = fb.TitleFormat(window.GetProperty("_group TF text info", "%album artist%[ | %album%][ | %date%]"));
var g_font = null;
var ww = 0,
wh = 0;
var mouse_x = 0,
mouse_y = 0;
g_textcolor_hl = 0,
g_backcolor = 0,
var g_metadb;
var g_saved = null;
panel = {
button_total: 2,
list = {
first_launch: true,
total: 0,
total_gh: 0,
start_id: 0,
nbvis: 0,
mid: 0,
item: Array(),
hlist: Array(),
handlelist: null,
focus_id: 0,
selected_gh_id: 0,
gh_id: 0,
mousewheel_timer_value: 20,
nowplaying: 0,
SHIFT_count: 0,
hscrollbar = {
theme: false,
visible: true,
hover: false,
x: 0,
y: 0,
w: 0,
button_total: 2,
step: 3,
letter: null,
timerID: false
button_up = {
img_normal: null,
img_hover: null,
img_down: null,
x: 0,
y: 0,
timerID: false
button_down = {
img_normal: null,
img_hover: null,
img_down: null,
x: 0,
y: 0,
timerID: false
cursor = {
bt: null,
img_normal: null,
img_hover: null,
img_down: null,
popup: null,
x: 0,
y: 0,
hover: false,
drag: false,
grap_x: 0,
timerID: false,
last_x: 0
cover = {
margin: 2,
w: 0,
h: 0,
top_offset: 0,
pad_top_mid: 35,
pad_bot_mid: 30,
normal_delta: 20,
quality: window.GetProperty("list.covers.quality.percent", 100),
draw_border: window.GetProperty("cover.draw.border", true),
draw_reflection: window.GetProperty("cover.draw.reflection", true),
reflect_strength_percent: window.GetProperty("cover.reflection.percent", 25),
draw_shadows: window.GetProperty("cover.draw.shadows", true),
draw_focus_border: window.GetProperty("cover.draw.focus.border", true)
if (b > 1) b = 1;
if (b < 0) b = 0;
window.Repaint()
list.gh_id = 0
if (r < 0) {
r = 0
} else {
list.start_id = 0
r++
} else {
if (r > 0) {
if (s > 0) {
} else {
list.item.pop()
list.item.idx = i
setcursorx()
} else {
list.item.shift()
list.item.idx = i
setcursorx()
init_active_pls();
return true
if (r < 0) {
r = 0
} else {
list.start_id = 0
r++
} else {
} else {
set_scroller();
setcursorx()
var c = 0
} else {
var c = b
return i
} else {
return i
} else {
return null
var a;
var b;
if (a != b) {
list.hlist.push(i);
a = b
get_font();
window.Repaint()
get_colors();
init_icons();
set_scroller();
CollectGarbage();
window.Repaint()
ww = window.Width;
wh = window.Height;
var a = window.GetProperty("_group TF text info", "%album artist%[ | %album%][ | %date%]");
if (a == "") window.SetProperty("_group TF text info", "%album artist%[ | %album%][ | %date%]");
get_font();
get_colors();
init_icons();
cover.h = cover.w;
list.nbvis--
if (list.nbvis > 23) list.nbvis = 23;
} else {
button_up.x = 0;
} else {
CollectGarbage();
window.Repaint()
var b, mid2;
for (var c = 1; c < list.mid + 1; c++) {
if (c > 1 && c <= list.mid) {
b = true
} else {
b = false
mid2 = list.mid - c;
list.item[mid2].draw(a, list.item[mid2].id, mid2, c, b)
mid2 = list.mid + c;
list.item[mid2].draw(a, list.item[mid2].id, mid2, c * -1, b)
var d = 30;
var f = ww - 60;
a.GdiDrawText(list.item[list.mid].group_info, g_font, g_textcolor, d, 0, f, cover.pad_top_mid - 4, DT_CENTER | DT_CALCRECT | DT_VCENTER | DT_END_ELLIPSIS | DT_NOPREFIX)
try {
} catch (e) {
try {
} catch (e) {};
try {
} catch (e) {};
switch (i) {
case 0:
break;
case 1:
break
if (cursor.drag) {
switch (i) {
case 0:
break;
case 1:
break
function on_mouse_lbtn_down(x, y) {
cursor.drag = true;
if (x < cursor.x) {
}, 400)
} else {
}, 400)
switch (i) {
case 0:
on_mouse_wheel(1);
on_mouse_wheel(1)
}, 400)
break;
case 1:
on_mouse_wheel(-1);
on_mouse_wheel(-1)
}, 400)
break
switch (i) {
case 0:
ShowNowPlaying()
break;
case 1:
} else {
} else {
window.Repaint()
break
} else {
if (cursor.drag) {
cursor.drag = false
} else {
setcursorx();
window.Repaint()
window.Repaint();
}, 30)
mouse_x = x;
mouse_y = y
if (a > 0) {
window.Repaint();
} else {
window.Repaint();
window.Repaint()
init_active_pls();
list.focus_id = 0
window.Repaint()
list.focus_id = c;
window.Repaint()
window.Repaint()
switch (a) {
case VK_SHIFT:
break;
case VK_BACK:
break;
case VK_ESCAPE:
case 222:
break;
case VK_SPACEBAR:
break;
case VK_LEFT:
on_mouse_wheel(1);
break;
case VK_RIGHT:
on_mouse_wheel(-1);
break;
case VK_PGUP:
break;
case VK_PGDN:
break;
case VK_RETURN:
break;
case VK_END:
break;
case VK_HOME:
break;
case VK_DELETE:
break;
default:
break
} else {
switch (b) {
case KMask.shift:
break;
case KMask.ctrl:
if (a == 65) {
window.Repaint()
if (a == 70) {
if (a == 78) {
if (a == 79) {
if (a == 80) {
if (a == 83) {
break;
case KMask.alt:
if (a == 65) {
break
window.Repaint()
if (a == 0) {
on_metadb_changed()
try {
} catch (e) {};
var a;
try {
} catch (e) {
try {
} catch (e) {
try {
} catch (e) {
var i, gb;
try {
} catch (e) {
try {
} catch (e) {
try {
} catch (e) {
try {
} catch (e) {
try {
} catch (e) {
try {
} catch (e) {
Falstaff, is your coverflow script horizontal scrolling only? If so, any chance for a vertical scrolling one?
only horizontal for now. maybe a vertical one later, i can't say when.
WSH CoverFlow v1 beta4
What's New in beta4:
- lock current playlist button: allow you to use the coverflow as an album browser, in your playlist, when lock is on, you only have the tracks of the selected cover album!
- scrollbar button replaced by a menu button
- cover loading engine modded to get better perfs.
- new scrollbar style (not themed one)
- many tweaks ... i can't remember all the changes since beta3
(http://img849.imageshack.us/img849/3716/wshcoverflowpreview005.png) (http://fav.me/d4t4lh7)
// @name "CoverFlow View v1"
// @version "0.0.4.20120324.1412"
// @author "Br3tt"
// @feature "v1.4"
// @feature "watch-metadb"
// [Requirements]
// [/Requirements]
// * !!! Keep a reasonable size for the panel to avoid bad perf! Loading and Displaying too big or too much covers can be a nightmare for your CPU!
// [Informations]
// * middle click on centered cover > Send album tracks to specific playlist "CoverFlow View"
// [/Informations]
SM_CXVSCROLL = 2;
SM_CYHSCROLL = 3;
IDC_ARROW = 32512;
IDC_IBEAM = 32513;
IDC_WAIT = 32514;
IDC_CROSS = 32515;
IDC_SIZE = 32640;
IDC_ICON = 32641;
IDC_SIZEWE = 32644;
IDC_SIZENS = 32645;
IDC_NO = 32648;
IDC_HAND = 32649;
IDC_HELP = 32651;
var VK_BACK = 0x08;
var VK_ALT = 0x12;
var VK_PGUP = 0x21;
var VK_PGDN = 0x22;
var VK_END = 0x23;
var VK_HOME = 0x24;
var VK_LEFT = 0x25;
var VK_UP = 0x26;
var VK_DOWN = 0x28;
var KMask = {
none: 0,
ctrl: 1,
shift: 2,
ctrlshift: 3,
ctrlalt: 4,
ctrlaltshift: 5,
alt: 6
var b = KMask.none;
return b
ColorTypeCUI = {
text: 0,
selection_text: 1,
background: 3,
FontTypeCUI = {
items: 0,
labels: 1
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
FontTypeDUI = {
defaults: 0,
tabs: 1,
lists: 2,
playlists: 3,
statusbar: 4,
console: 5
var a = 0,
v_align = 0,
trimming = 0,
flags = 0;
case 3:
case 2:
case 1:
a = arguments[0];
break;
default:
return 0
StringAlignment = {
Near: 0,
Centre: 1,
Far: 2
return (a & 0xff)
var i;
if (k > 0) {
c = "0" + c
return c.toString()
var b;
var c;
switch (a) {
case "file":
b = 1;
c = 0;
break;
case "cdda":
b = 1;
c = 1;
break;
case "FOO_":
b = 0;
c = 2;
break;
case "http":
b = 0;
c = 3;
break;
case "mms:":
b = 0;
c = 3;
break;
case "unpa":
b = 0;
c = 4;
break;
default:
b = 0;
c = 5
return c
ButtonStates = {
normal: 0,
hover: 1,
down: 2
this.x = x;
this.y = y;
switch (a) {
case "down":
break
break;
case "up":
break;
case "right":
break;
case "move":
break
break;
case "leave":
break
return this.state
return a
return a
var nocover;
var nocover_img;
var streamcover;
var star_img_off;
var star_img_on;
var star_img_hov;
var star_img_kill;
var menu_button;
this.item = a;
}, b)
if (list.drag_stop && typeof b == "undefined") {
mycover2load.push(new cover2load(a, (80*(mycover2load.length>0?1:0))+(9*mycover2load.length)));
return b
this.getit = function (a, b) {
var c;
if (a.metadb) {
c = FormatCover(b, d, e);
if (!c) {
a.cover_type = 0
} else {
a.cover_type = 1
a.cover_type = 3
} else {
a.cover_type = 0
this._cachelist[a.cover_path + a.album] = c;
return c
if (cover.draw_glass_effect) {
var b = a.Resize(w, h, 2);
var c = b.GetGraphics();
c.FillGradRect(0, 0, w, h, 90, RGBA(255, 255, 255, 60), RGBA(255, 255, 255, 10), 1.0);
c.SetSmoothingMode(2);
c.FillEllipse(-20, 25, w * 2 + 40, h * 2, RGBA(0, 0, 0, 30));
b.ReleaseGraphics©;
return b
} else {
function refresh_cover(a, b) {
var c = 0;
var d;
var e = (cover.w - cover.margin * 2) * cover.quality / 100;
var f = (cover.h - cover.margin * 2) * cover.quality / 100;
if (a.metadb) {
d = FormatCover(b, e, f);
if (!d) {
d = FormatCover(nocover, e, f);
a.cover_type = 0
} else {
a.cover_type = 1
d = FormatCover(streamcover, e, f);
a.cover_type = 3
} else {
a.cover_type = 0
return d
mycover2load.timer && window.ClearTimeout(mycover2load.timer)
if (mycover2load.item.metadb.Compare(a)) {
mycover2load.item.cover_img = g_image_cache.getit(mycover2load.item, c);
window.RepaintRect(mycover2load.item.x - 2, cover.pad_top_mid, mycover2load.item.w + 4, wh - cover.pad_top_mid)
} else {
break
ItemStates = {
normal: 0,
hover: 1,
selected: 2
var i;
if (g < 0) {
this.id = g;
this.idx = h;
this.gh_id = k;
this.album = "";
} else {
this.id = g;
this.idx = h;
this.gh_id = k;
if (this.metadb) {
if (this.metadb) {
} else {
this.album = "";
this.show = e;
this.w = cover.w;
this.h = this.w;
this.cut = 1
} else {
this.h = this.w;
if (this.id >= 0) {
} else {
} else {
} else {
} else {
} else {
list.focus_id_item_idx = this.idx;
} else {
switch (a) {
case "down":
if (plman.IsPlaylistItemSelected(panel.active_playlist, this.id)) {
if (this.ishover) {
if (panel.lock_playlist) {
this.checkstate("mid", x, y, b)
SelectGroupItems(this.id, this.gh_id, true);
g_saved = this;
refresh_spv(panel.active_playlist, bool_on_size)
} else {
if (this.ishover) {
} else {
} else {
g_saved = this;
g_saved.checkstate("mid", x, y, b)
break;
case "dblclk":
plman.ExecutePlaylistDefaultAction(panel.active_playlist, list.hlist[g_saved.gh_id]);
g_saved = null
} else {
g_saved = null;
window.Repaint()
break;
case "mid":
if (this.ishover) {
if (plman.GetPlaylistName(panel.active_playlist) != "CoverFlow View") {
var c = false;
var d = 0;
var e = panel.active_playlist;
if (plman.GetPlaylistName(i) == "CoverFlow View") {
c = true;
d = i;
break
if (!c) {
plman.CreatePlaylist(plman.PlaylistCount, "CoverFlow View")
fb.ClearPlaylist();
break;
case "right":
if (this.ishover) {
SelectGroupItems(this.id, this.gh_id, false);
break;
case "up":
break;
case "move":
break;
case "leave":
break
return this.state
var g_font = null;
var ww = 0,
wh = 0;
var mouse_x = 0,
mouse_y = 0;
g_textcolor_hl = 0,
g_backcolor = 0,
var g_metadb;
var g_saved = null;
panel = {
button_total: 3,
custom_textcolor_highlight: window.GetProperty("panel.custom.text.color.hightlight", ""),
lock_playlist: window.GetProperty("panel.lock.playlist.enabled", false),
active_playlist: window.GetProperty("panel.active.playlist", 0)
list = {
first_launch: true,
total: 0,
total_gh: 0,
start_id: 0,
nbvis: 0,
mid: 0,
item: Array(),
hlist: Array(),
handlelist: null,
metadblist_selection: plman.GetPlaylistSelectedItems(panel.active_playlist),
focus_id: 0,
focus_id_item_idx: 0,
selected_gh_id: 0,
gh_id: 0,
nowplaying: 0,
SHIFT_count: 0,
buttonclicked: false,
drag_stop: true,
drag_timer: false
hscrollbar = {
theme: false,
visible: true,
hover: false,
x: 0,
y: 0,
w: 0,
button_total: 2,
step: 3,
letter: null,
timerID: false
button_up = {
img_normal: null,
img_hover: null,
img_down: null,
x: 0,
y: 0,
timerID: false
button_down = {
img_normal: null,
img_hover: null,
img_down: null,
x: 0,
y: 0,
timerID: false
cursor = {
bt: null,
img_normal: null,
img_hover: null,
img_down: null,
popup: null,
x: 0,
y: 0,
hover: false,
drag: false,
grap_x: 0,
timerID: false,
last_x: 0
cover = {
margin: 2,
w: 0,
h: 0,
top_offset: 0,
default_pad_top_mid: 35,
default_pad_bot_mid: 30,
pad_top_mid: 35,
pad_bot_mid: 30,
normal_delta: 20,
draw_border: window.GetProperty("cover.draw.contrasted.border", false),
draw_reflection: window.GetProperty("cover.draw.ground.reflection", true),
reflect_strength_percent: window.GetProperty("cover.ground.reflection.percent", 20),
draw_focus_border: window.GetProperty("cover.draw.focus.border", true),
draw_glass_effect: window.GetProperty("cover.draw.glass.effect", false)
if (b > 1) b = 1;
if (b < 0) b = 0;
window.Repaint()
list.gh_id = 0
if (r < 0) {
r = 0
} else {
list.start_id = 0
r++
} else {
if (r > 0) {
if (s > 0) {
} else {
list.item.pop()
list.item.idx = i
setcursorx()
} else {
list.item.shift()
list.item.idx = i
setcursorx()
init_active_pls();
return true
if (r < 0) {
r = 0
} else {
list.start_id = 0
r++
} else {
} else {
set_scroller();
setcursorx()
var c = 0
} else {
var c = b
return i
} else {
return i
} else {
return null
} else {
var a;
var b;
var c;
list.handlelist = plman.GetPlaylistItems(panel.active_playlist);
if (i > 0 && i < list.total - 1) {
i++;
if (a != b) {
if (i > 0) {
c = tf_group_key.EvalWithMetadb(list.handlelist.Item(i - 1));
if (a != c) {
list.hlist.push(i - 1)
if (c != b) {
list.hlist.push(i)
} else {
list.hlist.push(i)
a = b
} else {
if (a != b) {
list.hlist.push(i);
a = b
function old_init_active_pls() {
var a;
var b;
if (a != b) {
list.hlist.push(i);
a = b
get_font();
get_colors();
init_icons();
set_scroller();
CollectGarbage();
ww = window.Width;
wh = window.Height;
get_font();
get_colors();
init_icons();
cover.pad_bot_mid = cover.default_pad_bot_mid
} else {
cover.pad_bot_mid = cover.default_pad_bot_mid - hscrollbar.default_h
cover.pad_top_mid = cover.default_pad_top_mid
} else {
cover.pad_top_mid = cover.default_pad_top_mid - 16
cover.h = cover.w;
list.nbvis--
list.nb_cover_to_draw = Math.floor(ww / (cover.w - cover.normal_delta * 2)) + 2;
} else {
button_up.x = 0;
} else {
CollectGarbage();
refresh_spv(panel.active_playlist, true)
var b, mid2;
b = true
} else {
b = false
var d = panel.lock_playlist ? 32 : 60;
var f = panel.lock_playlist ? ww - 64 : ww - 120;
try {
} catch (e) {
a.FillSolidRect(0, wh - hscrollbar.h, ww, hscrollbar.h, g_backcolor & 0x77ffffff);
a.FillSolidRect(0, wh - hscrollbar.h, ww, 1, RGBA(0, 0, 0, 20))
try {
} catch (e) {};
try {
} catch (e) {};
switch (i) {
case 0:
break;
case 1:
break
if (cursor.drag) {
hscrollbar.letter = list.item[Math.floor(list.nbvis / 2)].albumartist.substring(0, 1).toUpperCase();
switch (i) {
case 0:
if (!panel.lock_playlist) {
panel.arr_buttons.draw(a, 30, 5, 255)
break;
case 1:
break;
case 2:
break
a.FillGradRect(0, 0, ww, 1, 0, 0, g_textcolor & 0x15ffffff, 0.5)
cursor.drag = true;
if (x < cursor.x) {
}, 400)
} else {
}, 400)
switch (i) {
case 0:
on_mouse_wheel(1);
on_mouse_wheel(1)
}, 400)
break;
case 1:
on_mouse_wheel(-1);
on_mouse_wheel(-1)
}, 400)
break
} else {
if (list.drag_timer) {
window.ClearTimeout(list.drag_timer);
list.drag_timer = false;
list.drag_stop = true
switch (i) {
case 0:
if (panel.arr_buttons.checkstate("up", x, y) == ButtonStates.hover) {
ShowNowPlaying()
break;
case 1:
settings_menu(x, y)
break;
case 2:
panel.lock_playlist = false;
window.SetProperty("panel.lock.playlist.enabled", panel.lock_playlist);
plman.ActivePlaylist = panel.active_playlist
} else {
panel.lock_playlist = true;
panel.active_playlist = plman.ActivePlaylist;
window.SetProperty("panel.active.playlist", panel.active_playlist);
var a = Math.floor(list.nbvis / 2);
a = list.focus_id_item_idx;
list.item[a].checkstate("mid", list.item[a].x + 5, list.item[a].y + 5, a)
panel.arr_buttons[2].update(lock_button_normal, lock_button_hover, lock_button_down)
} else {
panel.arr_buttons[2].update(unlock_button_normal, unlock_button_hover, unlock_button_down)
break
if (cursor.drag) {
cursor.drag = false
} else {
setcursorx();
window.Repaint()
if (cursor.drag) {
list.drag_stop = false;
list.drag_timer = window.SetTimeout(function () {
list.drag_stop = true;
window.Repaint()
}, 260)
} else {
refresh_spv_cursor(panel.active_playlist);
}, 30)
mouse_x = x;
mouse_y = y
if (a > 0) {
scrollup_spv(panel.active_playlist)
window.Repaint();
} else {
scrolldown_spv(panel.active_playlist)
window.Repaint();
window.Repaint()
if (plman.ActivePlaylist < 0 || plman.ActivePlaylist > fb.PlaylistCount) {
plman.ActivePlaylist = 0
init_active_pls();
list.focus_id = plman.GetPlaylistFocusItemIndex(panel.active_playlist);
list.focus_id = 0
refresh_spv(panel.active_playlist, true);
window.Repaint()
if (a == panel.active_playlist) {
panel.lock_playlist = !panel.lock_playlist;
list.focus_id = c;
refresh_spv(panel.active_playlist, bool_on_size);
window.Repaint()
window.Repaint()
switch (a) {
case VK_SHIFT:
break;
case VK_BACK:
break;
case VK_ESCAPE:
case 222:
break;
case VK_SPACEBAR:
plman.SetPlaylistFocusItem(panel.active_playlist, d);
plman.ClearPlaylistSelection(panel.active_playlist);
plman.SetPlaylistSelectionSingle(panel.active_playlist, d, true);
var c = Math.floor(list.nbvis / 2);
list.item[c].checkstate("mid", list.item[c].x + 5, list.item[c].y + 5, c)
} else {
var d = list.item[Math.floor(list.nbvis / 2)].id;
SelectGroupItems(d, get_gh_id(d), true)
break;
case VK_LEFT:
on_mouse_wheel(1);
break;
case VK_RIGHT:
on_mouse_wheel(-1);
break;
case VK_PGUP:
break;
case VK_PGDN:
break;
case VK_RETURN:
plman.ExecutePlaylistDefaultAction(panel.active_playlist, list.focus_id);
break;
case VK_END:
plman.SetPlaylistFocusItem(panel.active_playlist, list.total - 1);
plman.SetPlaylistSelectionSingle(panel.active_playlist, list.total - 1, true);
break;
case VK_HOME:
plman.SetPlaylistFocusItem(panel.active_playlist, 0);
plman.SetPlaylistSelectionSingle(panel.active_playlist, 0, true);
break;
case VK_DELETE:
if (!fb.IsAutoPlaylist(panel.active_playlist)) {
plman.RemovePlaylistSelection(panel.active_playlist, false);
plman.SetPlaylistSelectionSingle(panel.active_playlist, plman.GetPlaylistFocusItemIndex(panel.active_playlist), true)
break;
default:
break
} else {
switch (b) {
case KMask.shift:
break;
case KMask.ctrl:
if (a == 65) {
window.Repaint()
if (a == 70) {
if (a == 78) {
if (a == 79) {
if (a == 80) {
if (a == 83) {
break;
case KMask.alt:
if (a == 65) {
break
window.Repaint()
if (a == 0) {
on_metadb_changed()
try {
} catch (e) {};
var a;
try {
} catch (e) {
try {
} catch (e) {
a.FillSolidRect(0, 3, cursor.w, cursor.h - 5, g_textcolor & 0x44ffffff)
try {
} catch (e) {
a.FillSolidRect(0, 3, cursor.w, cursor.h - 5, g_textcolor & 0x88ffffff)
var i, gb;
try {
} catch (e) {
gb.DrawString("<", gui_font, RGBA(255, 255, 255, 25), 1, 0, button_up.w, button_up.h, cc_stringformat);
gb.DrawString("<", gui_font, g_textcolor & 0x44ffffff, 0, 0, button_up.w, button_up.h, cc_stringformat)
gb = bu
marc2003: Could you please help me to add a little space between the stars in your ratings script?
using paint.net you could make the images with a gap around the edge. you need to edit on.png and off.png in the marc2003\images folder. image menu>canvas size and make sure the anchor is in the middle. then select and delete the border so it's transparent.
then update the bw and bh variables at the top of the script to the size of these new images.
That was simple. Thanks.
WSH CoverFlow v1 beta6
[code]// ==PREPROCESSOR==
// @name "CoverFlow View v1 beta6"
// @version "0.0.6.20120330.1917"
// @author "Br3tt"
// @feature "v1.4"
// @feature "dragdrop"
// [Requirements]
// * foobar2000 v1.1 or better >> http://foobar2000.org (http://foobar2000.org)
// * WSH panel Mod v1.5.2 or better >> http://code.google.com/p/foo-wsh-panel-mod/downloads/list (http://code.google.com/p/foo-wsh-panel-mod/downloads/list)
// [/Requirements]
// [Informations]
// * change colors and fonts in foobar2000 Preferences > DefaultUI or ColumsUI
// * Some Settings can be changed in window Properties (right click empty space > Properties)
// e.g. for custom colors in Properties, use e.g. RGB(255,255,255) for white color, RGB(0,0,0) for black color, ...
// * middle click on cover > Send album tracks to specific playlist "CoverFlow View"
// * keyboard keys : left/right arrows, Home/End, page up/down, spacebar to set focus on the centered album, Return key to play ...
// [/Informations]
SM_CXVSCROLL = 2;
SM_CYHSCROLL = 3;
DLGC_WANTARROWS = 0x0001;
DLGC_WANTALLKEYS = 0x0004;
MF_STRING = 0x00000000;
MF_SEPARATOR = 0x00000800;
MF_GRAYED = 0x00000001;
MF_DISABLED = 0x00000002;
MF_POPUP = 0x00000010;
IDC_ARROW = 32512;
IDC_IBEAM = 32513;
IDC_WAIT = 32514;
IDC_CROSS = 32515;
IDC_UPARROW = 32516;
IDC_SIZE = 32640;
IDC_ICON = 32641;
IDC_SIZENWSE = 32642;
IDC_SIZENESW = 32643;
IDC_SIZEWE = 32644;
IDC_SIZENS = 32645;
IDC_SIZEALL = 32646;
IDC_NO = 32648;
IDC_APPSTARTING = 32650;
IDC_HAND = 32649;
IDC_HELP = 32651;
var VK_BACK = 0x08;
var VK_ALT = 0x12;
var VK_PGUP = 0x21;
var VK_PGDN = 0x22;
var VK_END = 0x23;
var VK_HOME = 0x24;
var VK_LEFT = 0x25;
var VK_UP = 0x26;
var VK_DOWN = 0x28;
var KMask = {
none: 0,
ctrl: 1,
shift: 2,
ctrlshift: 3,
ctrlalt: 4,
ctrlaltshift: 5,
alt: 6
function GetKeyboardMask() {
var c = utils.IsKeyPressed(VK_CONTROL) ? true : false;
var a = utils.IsKeyPressed(VK_ALT) ? true : false;
var s = utils.IsKeyPressed(VK_SHIFT) ? true : false;
var b = KMask.none;
if (c && !a && !s) b = KMask.ctrl;
if (!c && !a && s) b = KMask.shift;
if (c && !a && s) b = KMask.ctrlshift;
if (c && a && !s) b = KMask.ctrlalt;
if (c && a && s) b = KMask.ctrlaltshift;
if (!c && a && !s) b = KMask.alt;
return b
ColorTypeCUI = {
text: 0,
selection_text: 1,
inactive_selection_text: 2,
background: 3,
selection_background: 4,
inactive_selection_background: 5,
active_item_frame: 6
FontTypeCUI = {
items: 0,
labels: 1
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
FontTypeDUI = {
defaults: 0,
tabs: 1,
lists: 2,
playlists: 3,
statusbar: 4,
console: 5
function StringFormat() {
var a = 0,
v_align = 0,
trimming = 0,
flags = 0;
switch (arguments.length) {
case 3:
trimming = arguments[2];
case 2:
v_align = arguments[1];
case 1:
a = arguments[0];
break;
default:
return 0
return ((a << 28) | (v_align << 24) | (trimming << 20) | flags)
StringAlignment = {
Near: 0,
Centre: 1,
Far: 2
var lt_stringformat = StringFormat(StringAlignment.Near, StringAlignment.Near);
var ct_stringformat = StringFormat(StringAlignment.Centre, StringAlignment.Near);
var rt_stringformat = StringFormat(StringAlignment.Far, StringAlignment.Near);
var lc_stringformat = StringFormat(StringAlignment.Near, StringAlignment.Centre);
var cc_stringformat = StringFormat(StringAlignment.Centre, StringAlignment.Centre);
var rc_stringformat = StringFormat(StringAlignment.Far, StringAlignment.Centre);
var lb_stringformat = StringFormat(StringAlignment.Near, StringAlignment.Far);
var cb_stringformat = StringFormat(StringAlignment.Centre, StringAlignment.Far);
var rb_stringformat = StringFormat(StringAlignment.Far, StringAlignment.Far);
function RGB(r, g, b) {
return (0xff000000 | (r << 16) | (g << 8) | (b))
function RGBA(r, g, b, a) {
return ((a << 24) | (r << 16) | (g << 8) | (b))
function getAlpha(a) {
return ((a >> 24) & 0xff)
function getRed(a) {
return ((a >> 16) & 0xff)
function getGreen(a) {
return ((a >> 8) & 0xff)
function getBlue(a) {
return (a & 0xff)
function num(a, b) {
var i;
var c = a.toString();
var k = b - c.length;
if (k > 0) {
for (i = 0; i < k; i++) {
c = "0" + c
return c.toString()
function TrackType(a) {
var b;
var c;
switch (a) {
case "file":
b = 1;
c = 0;
break;
case "cdda":
b = 1;
c = 1;
break;
case "FOO_":
b = 0;
c = 2;
break;
case "http":
b = 0;
c = 3;
break;
case "mms:":
b = 0;
c = 3;
break;
case "unpa":
b = 0;
c = 4;
break;
default:
b = 0;
c = 5
return c
ButtonStates = {
normal: 0,
hover: 1,
down: 2
button = function (d, e, f) {
this.img = Array(d, e, f);
this.w = this.img[0].Width;
this.h = this.img[0].Height;
this.state = ButtonStates.normal;
this.update = function (a, b, c) {
this.img = Array(a, b, c)
this.draw = function (a, x, y, b) {
this.x = x;
this.y = y;
this.img[this.state] && a.DrawImage(this.img[this.state], this.x, this.y, this.w, this.h, 0, 0, this.w, this.h, 0, b)
this.display_context_menu = function (x, y, a) {};
this.repaint = function () {
window.RepaintRect(this.x, this.y, this.w, this.h)
this.checkstate = function (a, x, y) {
this.ishover = (x > this.x && x < this.x + this.w - 1 && y > this.y && y < this.y + this.h - 1);
this.old = this.state;
switch (a) {
case "down":
switch (this.state) {
case ButtonStates.normal:
case ButtonStates.hover:
this.state = this.ishover ? ButtonStates.down : ButtonStates.normal;
break
break;
case "up":
this.state = this.ishover ? ButtonStates.hover : ButtonStates.normal;
break;
case "right":
if (this.ishover) this.display_context_menu(x, y, id);
break;
case "move":
break
break;
case "leave":
this.state = this.isdown ? ButtonStates.down : ButtonStates.normal;
break
if (this.state != this.old) this.repaint();
return this.state
function get_system_scrollbar_width() {
var a = utils.GetSystemMetrics(SM_CXVSCROLL);
return a
function get_system_scrollbar_height() {
var a = utils.GetSystemMetrics(SM_CYHSCROLL);
return a
var nocover;
var nocover_img;
var streamcover;
var streamcover_img;
var loading;
var loading_img;
var star_img_off;
var star_img_on;
var star_img_hov;
var star_img_kill;
var toggle_scrollbar;
var menu_button;
image_cache = function () {
this._cachelist = {};
this.hit = function (a) {
var b = this._cachelist[a.metadb.Path];
if (!cover.load_timer) {
cover.load_timer = window.SetTimeout(function () {
utils.GetAlbumArtAsync(window.ID, a.metadb, 0, true, false, false);
cover.load_timer && window.ClearTimeout(cover.load_timer);
cover.load_timer = false
}, 35)
return b
var c;
var d = (cover.w - cover.margin * 2) * cover.quality / 100;
var e = (cover.h - cover.margin * 2) * cover.quality / 100;
if (a.track_type != 3) {
if (a.metadb) {
if (!c) {
c = nocover_img;
a.cover_type = 0
} else {
a.cover_type = 1
} else if (fb.IsPlaying && fb.PlaybackLength) {
c = streamcover_img;
a.cover_type = 3
} else {
c = nocover_img;
a.cover_type = 0
this._cachelist[a.metadb.Path] = c;
return c
var g_image_cache = new image_cache;
function FormatCover(a, w, h) {
if (!a || w <= 0 || h <= 0) return a;
b.ReleaseGraphics©;
return b
} else {
c.DrawRect(0, 0, w, h, 2.0, RGB(110, 110, 110));
b.ReleaseGraphics©;
return b
function reset_cover_timers() {
var e = list.item.length;
for (var i = 0; i < e; i++) {
if (list.item.metadb) {
if (list.item.metadb.Compare(a)) {
list.item.cover_img = g_image_cache.getit(list.item, c);
if (list.item.show) {
if (panel.vertical_mode) {
window.RepaintRect(cover.pad_left_mid, list.item.y - 2, ww - cover.pad_left_mid, list.item.h + 4)
} else {
window.RepaintRect(list.item.x - 2, cover.pad_top_mid, list.item.w + 4, wh - cover.pad_top_mid)
} else {
list.item.show = true
break
ItemStates = {
normal: 0,
hover: 1,
selected: 2
item = function (h, k, l) {
var i;
if (typeof this.id == "undefined") {
if (h < 0) {
this.id = h;
this.idx = k;
this.gh_id = l;
this.metadb = false;
this.albumartist = "";
this.track_type = null;
} else {
this.id = h;
this.idx = k;
this.gh_id = l;
this.metadb = list.handlelist.Item(this.id);
if (this.metadb) {
this.albumartist = tf_albumartist.EvalWithMetadb(this.metadb);
this.track_type = TrackType(this.metadb.rawpath.substring(0, 4));
this.update_infos = function () {
if (this.metadb) {
} else {
this.draw = function (a, b, c, d, e) {
this.show = e;
if (list.mid == c) {
this.h = cover.h;
this.w = cover.h;
this.x = cover.pad_left_mid;
this.y = Math.floor((wh / 2) - (cover.h / 2));
this.cut = 1
} else {
this.h = Math.abs(d) == 1 ? cover.h - cover.normal_delta * 1 : cover.h - cover.normal_delta * 2;
this.w = this.h;
this.y = Math.abs(d) == 1 ? Math.floor((wh / 2) - (this.h / 2)) - (d * (this.h - 5)) : Math.floor((wh / 2) - (this.h / 2)) - (d * this.h);
this.x = Math.abs(d) == 1 ? cover.pad_left_mid + Math.ceil(cover.normal_delta / 2) : cover.pad_left_mid + cover.normal_delta;
this.cut = Math.abs(d) == 1 ? 1 : 0
if (this.id >= 0) {
this.cover_img = g_image_cache.hit(this);
if (d != -1 && this.gh_id > 0) {
a.FillSolidRect(this.x + cover.normal_delta / 2, Math.floor(cover.margin / 2) + this.y - j - cover.margin + 1, this.w - cover.normal_delta - cover.margin - 1, 1, RGBA(0, 0, 0, 150 - j * 25))
if (d != 1 && this.gh_id < list.total_gh - 1) {
a.FillSolidRect(this.x + cover.normal_delta / 2, Math.floor(cover.margin / 2) + this.y + this.h - cover.margin + j - 2, this.w - cover.normal_delta - cover.margin - 1, 1, RGBA(0, 0, 0, 150 - j * 25))
a.DrawImage(this.cover_img, this.x, Math.floor(cover.margin / 2) + this.y, this.w, this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 0, 255)
} else {
a.DrawImage(loading_img, this.x, Math.floor(cover.margin / 2) + this.y, this.w, this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 0, 255);
if (this.gh_id == list.selected_gh_id) {
if (cover.draw_focus_border) {
a.SetSmoothingMode(2);
a.DrawRoundRect(this.x - 1, Math.floor(cover.margin / 2) + this.y - 1, this.w - cover.margin * 2 + 2, this.h - cover.margin * 2 + 2, 2, 2, 3.0, g_backcolor_sel);
a.DrawRoundRect(this.x - 2, Math.floor(cover.margin / 2) + this.y - 2, this.w - cover.margin * 2 + 4, this.h - cover.margin * 2 + 4, 3, 3, 1.0, RGBA(255, 255, 255, 60));
a.SetSmoothingMode(0);
a.DrawRect(this.x + 1, Math.floor(cover.margin / 2) + this.y + 1, this.w - cover.margin * 2 - 2, this.h - cover.margin * 2 - 2, 1.0, g_backcolor_sel);
a.DrawRect(this.x + 1, Math.floor(cover.margin / 2) + this.y + 1, this.w - cover.margin * 2 - 2, this.h - cover.margin * 2 - 2, 1.0, RGBA(0, 0, 0, 40))
} else {
this.show = e;
this.w = cover.w;
this.h = cover.w;
this.y = cover.pad_top_mid;
this.x = Math.floor((ww / 2) - (cover.w / 2));
this.cut = 1
} else {
this.w = Math.abs(d) == 1 ? cover.w - cover.normal_delta * 1 : cover.w - cover.normal_delta * 2;
this.h = this.w;
this.x = Math.abs(d) == 1 ? Math.floor((ww / 2) - (this.w / 2)) - (d * (this.w - 5)) : Math.floor((ww / 2) - (this.w / 2)) - (d * this.w);
this.y = Math.abs(d) == 1 ? cover.pad_top_mid + Math.ceil(cover.normal_delta / 2) : cover.pad_top_mid + cover.normal_delta;
if (this.id >= 0) {
a.DrawImage(this.cover_img, Math.floor(cover.margin / 2) + this.x + this.w, this.y + this.h - cover.margin - 1, -1 * this.w, this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 180, 255);
a.FillSolidRect(Math.floor(cover.margin / 2) + this.x + this.w - cover.margin + j - 2, this.y + cover.normal_delta / 2, 1, this.h - cover.normal_delta - cover.margin - 1, RGBA(0, 0, 0, 150 - j * 25))
a.DrawImage(this.cover_img, Math.floor(cover.margin / 2) + this.x, this.y, this.w, this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 0, 255)
} else {
a.DrawImage(loading_img, Math.floor(cover.margin / 2) + this.x + this.w, this.y + this.h - cover.margin - 1, -1 * this.w, this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 180, 255);
a.DrawImage(loading_img, Math.floor(cover.margin / 2) + this.x, this.y, this.w, this.h, 0, 0, cover.w * cover.quality / 100, cover.h * cover.quality / 100, 0, 255)
a.DrawRoundRect(Math.floor(cover.margin / 2) + this.x - 1, this.y - 1, this.w - cover.margin * 2 + 2, this.h - cover.margin * 2 + 2, 2, 2, 3.0, g_backcolor_sel);
a.DrawRoundRect(Math.floor(cover.margin / 2) + this.x - 2, this.y - 2, this.w - cover.margin * 2 + 4, this.h - cover.margin * 2 + 4, 3, 3, 1.0, RGBA(255, 255, 255, 60));
a.DrawRect(Math.floor(cover.margin / 2) + this.x + 1, this.y + 1, this.w - cover.margin * 2 - 2, this.h - cover.margin * 2 - 2, 1.0, g_backcolor_sel);
a.DrawRect(Math.floor(cover.margin / 2) + this.x + 1, this.y + 1, this.w - cover.margin * 2 - 2, this.h - cover.margin * 2 - 2, 1.0, RGBA(0, 0, 0, 40))
this.checkstate = function (a, x, y, b) {
if (this.id >= 0) {
this.ishover = (x > this.x && x < this.x + this.w && y >= this.y && y < this.y + this.h)
} else {
this.ishover = false
switch (a) {
case "down":
if (!list.down_timerID && this.id >= 0) {
if (this.ishover) {
g_saved = this;
} else {
if (this.ishover) {
if (utils.IsKeyPressed(VK_SHIFT)) {
if (list.focus_id != this.id) {
} else if (utils.IsKeyPressed(VK_CONTROL)) {
} else {
} else {
g_saved = this;
break;
case "dblclk":
if (this.id >= 0 && g_saved != null) {
if (this.id == g_saved.id) {
g_saved = null
} else {
g_saved = null;
window.Repaint()
break;
case "mid":
if (this.ishover) {
var c = false;
var d = 0;
var f = plman.PlaylistCount;
for (var i = 0; i < f; i++) {
c = true;
d = i;
break
if (!c) {
panel.adding_coverflow_playlist = true;
d = plman.PlaylistCount;
plman.ActivePlaylist = d;
fb.ClearPlaylist();
var g = fb.PlaylistItemCount(d);
plman.InsertPlaylistItems(d, g, plman.GetPlaylistSelectedItems(e), false);
plman.SetPlaylistFocusItem(d, 0)
break;
case "right":
if (this.ishover) {
new_context_menu(x, y, this.id, this.idx)
break;
case "up":
break;
case "move":
if (this.ishover) {}
break;
case "leave":
break
return this.state
var tf_path = fb.TitleFormat("$left(%_path_raw%,4)");
var tf_albumartist = fb.TitleFormat("$if(%length%,%album artist%,'Stream')");
var tf_album = fb.TitleFormat("$if2(%album%,$if(%length%,'Single','web radios'))");
var g_instancetype = window.InstanceType;
var g_font = null;
var g_font_headers = null;
var ww = 0,
wh = 0;
var mouse_x = 0,
mouse_y = 0;
var g_textcolor = 0,
g_textcolor_sel = 0,
g_textcolor_hl = 0,
g_backcolor = 0,
g_backcolor_sel = 0;
var g_metadb;
var bool_on_size = false;
var g_search_string = "";
var incsearch_font = gdi.Font("lucida console", 9, 0);
var incsearch_font_big = gdi.Font("lucida console", 20, 1);
var clear_incsearch_timer = false;
var incsearch_timer = false;
var g_saved = null;
panel = {
max_width: 250,
max_height: 250,
arr_buttons: Array(),
button_total: 3,
show_text: window.GetProperty("panel.album.info.visible", true),
custom_textcolor: window.GetProperty("panel.custom.text.color.normal", ""),
custom_textcolor_selection: window.GetProperty("panel.custom.text.color.selection", ""),
custom_backcolor: window.GetProperty("panel.custom.background.color", ""),
active_playlist: window.GetProperty("panel.active.playlist", 0),
adding_coverflow_playlist: false,
vertical_mode: true
list = {
first_launch: true,
total: 0,
total_gh: 0,
start_id: 0,
nbvis: 0,
mid: 0,
item: Array(),
hlist: Array(),
handlelist: null,
focus_id: 0,
selected_gh_id: 0,
marker_id: 0,
gh_id: 0,
key_timer_value: 60,
nowplaying: 0,
SHIFT_start_id: null,
SHIFT_count: 0,
inc_search_noresult: false,
nb_cover_to_draw: 0,
drag_stop: true,
drag_timer: false
scrollbar = {
theme: false,
themed: window.GetProperty("list.scrollbar.themed", false),
show: window.GetProperty("list.scrollbar.visible", true),
visible: true,
default_step: window.GetProperty("list.scrollbar.step", 3),
step: 3,
letter: null,
button_total: 2,
timerID: false
hscrollbar = {
hover: false,
x: 0,
y: 0,
default_h: get_system_scrollbar_height(),
w: 0
vscrollbar = {
hover: false,
x: 0,
y: 0,
default_w: get_system_scrollbar_width(),
h: 0
scrollbarbt = {
timerID1: false,
timerID2: false,
timer1_value: 400,
timer2_value: 60
button_up = {
img_normal: null,
img_hover: null,
img_down: null,
x: 0,
y: 0,
w: hscrollbar.default_h,
h: hscrollbar.default_h
button_down = {
img_normal: null,
img_hover: null,
img_down: null,
x: 0,
y: 0,
cursor = {
bt: null,
img_normal: null,
img_hover: null,
img_down: null,
popup: null,
x: 0,
y: 0,
h: hscrollbar.default_h,
default_w: hscrollbar.default_h + 3,
hover: false,
drag: false,
grap_x: 0,
timerID: false,
last_x: 0
cover = {
margin: 2,
w: 0,
h: 0,
top_offset: 0,
pad_top_mid: 35,
pad_bot_mid: 30,
default_pad_left_mid: 15,
default_pad_right_mid: 28,
pad_left_mid: 15,
pad_right_mid: 28,
normal_delta: 20,
draw_glass_effect: window.GetProperty("cover.draw.glass.effect", false),
load_timer: false
function refresh_spv_cursor(a) {
var b = (cursor.y - vscrollbar.y) / (vscrollbar.h - cursor.h)
} else {
var b = (cursor.x - hscrollbar.x) / (hscrollbar.w - cursor.w)
if (b > 1) b = 1;
if (b < 0) b = 0;
var r = Math.round(b * list.total_gh);
set_gh_id(a, list.hlist[r - 1]);
window.Repaint()
function set_gh_id(a, b) {
reset_cover_timers();
list.item.splice(0, list.item.length);
if (list.total_gh <= 0) return true;
list.gh_id = get_gh_id(b);
if (list.gh_id == null) {
list.gh_id = 0
var r = list.gh_id - list.mid;
if (r < 0) {
list.start_id = Math.abs®;
r = 0
} else {
list.start_id = 0
for (var k = 0; k < list.nbvis; k++) {
if (k >= list.start_id && r < list.total_gh) {
list.item.push(new item(list.hlist[r], k, r));
r++
} else {
list.item.push(new item(-1, k, -1))
function scrollup_spv(a) {
var r = list.item[list.mid].gh_id;
if (r > 0) {
var s = list.item[0].gh_id;
if (s > 0) {
list.item.unshift(new item(list.hlist[s - 1], 0, s - 1))
} else {
list.item.unshift(new item(-1, 0, -1))
list.item.pop()
var b = list.item.length;
for (var i = 0; i < b; i++) {
list.item.idx = i
setcursorx()
function scrolldown_spv(a) {
if (r < list.total_gh - 1) {
var s = list.item[list.item.length - 1].gh_id;
if (s > 0 && s < list.total_gh - 1) {
list.item.push(new item(list.hlist[s + 1], 0, s + 1))
} else {
list.item.push(new item(-1, 0, -1))
list.item.shift()
list.item.idx = i
setcursorx()
function refresh_spv(a, b) {
list.gh_id = get_gh_id(list.focus_id);
init_active_pls();
return true
list.selected_gh_id = list.gh_id;
if (r < 0) {
r = 0
} else {
list.start_id = 0
r++
} else {
if (scrollbar.show) {
if (list.total_gh < 2) scrollbar.visible = false;
else scrollbar.visible = true
} else {
cursor.h = Math.round(vscrollbar.h / list.total_gh);
if (cursor.h > vscrollbar.h) cursor.h = vscrollbar.h;
if (cursor.h < cursor.default_w) cursor.h = cursor.default_w
} else {
cursor.w = Math.round(hscrollbar.w / list.total_gh);
if (cursor.w > hscrollbar.w) cursor.w = hscrollbar.w;
if (cursor.w < cursor.default_w) cursor.w = cursor.default_w
set_scroller();
setcursorx()
function get_gh_id(a) {
var b = Math.floor(list.total_gh / 2);
if (a < list.hlist) {
var c = 0
} else {
var c = b
for (var i = c; i < list.total_gh; i++) {
if (i < list.total_gh - 1) {
if (a >= list.hlist && a < list.hlist[i + 1]) {
return i
} else {
if (a >= list.hlist) {
return i
} else {
return null
function setcursorx() {
if (list.item.length > 0) {
var a = Math.floor(list.item.length / 2);
var b = list.item[a].gh_id;
var c = b / (list.total_gh - 1);
cursor.y = vscrollbar.y + Math.round(c * (vscrollbar.h - cursor.h))
} else {
cursor.x = hscrollbar.x + Math.round(c * (hscrollbar.w - cursor.w))
} else {
} else {
function init_active_pls() {
var a;
var b;
var c;
list.hlist.splice(0, list.hlist.length);
list.total = list.handlelist.Count;
for (var i = 0; i < list.total; i++) {
i++;
b = tf_group_key.EvalWithMetadb(list.handlelist.Item(i));
if (a != b) {
if (i > 0) {
if (a != c) {
if (c != b) {
list.hlist.push(i)
} else {
list.hlist.push(i)
a = b
} else {
if (a != b) {
list.hlist.push(i);
a = b
list.total_gh = list.hlist.length
var a;
var b;
if (a != b) {
list.hlist.push(i);
a = b
function on_font_changed() {
get_font();
function on_colors_changed() {
get_colors();
init_icons();
redraw_stub_images();
init_hscrollbar_buttons();
set_scroller();
CollectGarbage();
function on_init() {};
function on_size() {
if (!window.Width || !window.Height) return;
window.DlgCode = DLGC_WANTALLKEYS;
bool_on_size = true;
if (g_instancetype == 0) {
window.MinWidth = 170;
window.MinHeight = 170
} else if (g_instancetype == 1) {
ww = window.Width;
wh = window.Height;
if (ww > wh) {
panel.vertical_mode = false;
window.MaxHeight = panel.max_height;
window.MaxWidth = 2000;
if (wh < 170) wh = 170
} else {
panel.vertical_mode = true;
window.MaxWidth = panel.max_width;
window.MaxHeight = 2000;
if (ww < 170) ww = 170
get_font();
get_colors();
init_icons();
cover.pad_right_mid = cover.default_pad_right_mid
} else {
cover.pad_right_mid = cover.default_pad_right_mid - vscrollbar.default_w
cover.h = ww - cover.pad_left_mid - cover.pad_right_mid;
cover.w = cover.h;
list.nbvis = Math.floor(wh / (cover.h - cover.normal_delta * 2)) + 2;
if (list.nbvis / 2 == Math.floor(list.nbvis / 2)) {
list.nbvis--
list.mid = Math.floor(list.nbvis / 2);
list.nb_cover_to_draw = Math.floor(wh / (cover.h - cover.normal_delta * 2)) + 2;
if (scrollbar.themed) {
scrollbar.theme = window.CreateThemeManager("scrollbar")
} else {
scrollbar.theme = false
init_vscrollbar_buttons();
button_up.x = ww - button_up.w;
button_up.y = 0;
button_down.x = ww - button_down.w;
button_down.y = wh - button_down.h;
vscrollbar.y = button_up.h;
vscrollbar.h = wh - button_up.h - button_down.h;
cursor.x = ww - vscrollbar.w;
cursor.y = vscrollbar.y;
cursor.w = vscrollbar.w
} else {
} else {
if (panel.show_text) {
} else {
cover.w = wh - cover.pad_top_mid - cover.pad_bot_mid;
cover.h = cover.w;
list.nbvis = Math.floor(ww / (cover.w - cover.normal_delta * 2)) + 2;
list.nbvis--
} else {
button_up.x = 0;
button_up.y = wh - hscrollbar.h;
button_down.y = wh - hscrollbar.h;
hscrollbar.x = button_up.w;
hscrollbar.w = ww - button_up.w - button_down.w;
cursor.y = wh - hscrollbar.h;
cursor.h = hscrollbar.h
if (list.first_launch) {
list.first_launch = false;
} else {
CollectGarbage();
function on_paint(a) {
a.FillSolidRect(0, 0, ww, wh, g_backcolor);
var b, mid2;
list.item[list.mid].draw(a, list.item[list.mid].id, list.mid, 0, true);
b = true
} else {
b = false
if (mid2 >= 0 && mid2 <= list.item.length - 1) {
mid2 = list.mid - 1;
list.item[mid2].draw(a, list.item[mid2].id, mid2, 1, true)
mid2 = list.mid + 1;
list.item[mid2].draw(a, list.item[mid2].id, mid2, -1, true)
if (!panel.vertical_mode) {
if (list.item[list.mid].id >= 0) {
if (list.total_gh > 0 && scrollbar.visible && scrollbar.show) {
try {
scrollbar.theme.SetPartAndStateId(6, 1);
scrollbar.theme.DrawThemeBackground(a, ww - vscrollbar.w, 0, vscrollbar.w, wh)
} catch (e) {
a.FillSolidRect(ww - vscrollbar.w, 0, vscrollbar.w, wh, g_backcolor & 0x77ffffff);
a.FillSolidRect(ww - vscrollbar.w, 0, 1, wh, RGBA(0, 0, 0, 20))
cursor.bt.draw(a, ww - vscrollbar.w, cursor.y, 255);
try {
scrollbar.theme.SetPartAndStateId(9, 1);
scrollbar.theme.DrawThemeBackground(a, ww - vscrollbar.w, cursor.y, cursor.w, cursor.h)
} catch (e) {};
for (i = 0; i < scrollbar.arr_buttons.length; i++) {
switch (i) {
case 0:
scrollbar.arr_buttons.draw(a, ww - vscrollbar.w, button_up.y, 255);
break;
case 1:
scrollbar.arr_buttons.draw(a, ww - vscrollbar.w, button_down.y, 255);
break
if (cursor.drag) {
cursor.popup && a.DrawImage(cursor.popup, ww - vscrollbar.w - cursor.popup.Width - 00, cursor.y + Math.floor(cursor.h / 2) - Math.floor(cursor.popup.Height / 2), cursor.popup.Width, cursor.popup.Height, 0, 0, cursor.popup.Width, cursor.popup.Height, 0, 155);
cursor.popup && a.GdiDrawText(scrollbar.letter, gdi.Font("segoe ui", 14, 0), g_backcolor, ww - vscrollbar.w - cursor.popup.Width - 00, cursor.y + Math.floor(cursor.h / 2) - Math.floor(cursor.popup.Height / 2), cursor.popup.Width - 5, cursor.popup.Height, DT_CENTER | DT_CALCRECT | DT_VCENTER | DT_END_ELLIPSIS | DT_NOPREFIX)
} else {
try {
scrollbar.theme.SetPartAndStateId(4, 1);
scrollbar.theme.DrawThemeBackground(a, 0, wh - hscrollbar.h, ww, hscrollbar.h);
a.FillSolidRect(0, wh - hscrollbar.h - 1, ww, 1, RGBA(0, 0, 0, 10))
} catch (e) {
try {
cursor.bt.draw(a, cursor.x, cursor.y, 255)
} catch (e) {};
try {
scrollbar.theme.SetPartAndStateId(8, 1);
scrollbar.theme.DrawThemeBackground(a, cursor.x, wh - hscrollbar.h + 0, cursor.w, cursor.h)
} catch (e) {};
switch (i) {
case 0:
scrollbar.arr_buttons.draw(a, button_up.x, button_up.y, 255);
break;
case 1:
scrollbar.arr_buttons.draw(a, button_down.x, button_down.y, 255);
break
if (cursor.drag) {
cursor.popup && a.DrawImage(cursor.popup, cursor.x + Math.floor(cursor.w / 2) - Math.floor(cursor.popup.Width / 2), wh - hscrollbar.h - cursor.popup.Height, cursor.popup.Width, cursor.popup.Height, 0, 0, cursor.popup.Width, cursor.popup.Height, 0, 155);
cursor.popup && a.GdiDrawText(scrollbar.letter, gdi.Font("segoe ui", 14, 0), g_backcolor, cursor.x + Math.floor(cursor.w / 2) - Math.floor(cursor.popup.Width / 2), wh - hscrollbar.h - cursor.popup.Height, cursor.popup.Width, cursor.popup.Height - 5, DT_CENTER | DT_CALCRECT | DT_VCENTER | DT_END_ELLIPSIS | DT_NOPREFIX)
for (i = 0; i < panel.arr_buttons.length; i++) {
switch (i) {
case 0:
panel.arr_buttons.draw(a, 5, 30, 255)
} else {
break;
case 1:
panel.arr_buttons.draw(a, 5, wh - 22 - 5, 255)
} else {
panel.arr_buttons.draw(a, ww - 22 - 5, 5, 255)
break;
case 2:
panel.arr_buttons.draw(a, 5, 5, 255);
break
var a = list.item.length;
for (var i = 0; i < a; i++) {
list.item.checkstate("down", x, y, i)
if (cursor.bt.checkstate("down", x, y) == ButtonStates.down) {
cursor.drag = true;
cursor.grap_y = y - cursor.y;
cursor.last_y = cursor.y
if (vscrollbar.hover && !cursor.drag) {
scrollbar.step = Math.floor(list.nb_cover_to_draw / 2);
if (scrollbar.step < 1) scrollbar.step = 1;
if (y < cursor.y) {
if (!list.buttonclicked) {
list.buttonclicked = true;
on_mouse_wheel(scrollbar.step);
scrollbarbt.timerID1 = window.SetTimeout(function () {
scrollbarbt.timerID1 && window.ClearTimeout(scrollbarbt.timerID1);
scrollbarbt.timerID1 = false;
scrollbarbt.timerID2 && window.ClearInterval(scrollbarbt.timerID2);
scrollbarbt.timerID2 = window.SetInterval(function () {
if (hscrollbar.hover) {
if (mouse_x > ww - vscrollbar.w && cursor.y > mouse_y) {
}, scrollbarbt.timer2_value)
}, scrollbarbt.timer1_value)
} else {
on_mouse_wheel(-1 * scrollbar.step);
if (mouse_x > ww - vscrollbar.w && cursor.y + cursor.h < mouse_y) {
} else {
cursor.drag = true;
cursor.grap_x = x - cursor.x;
cursor.last_x = cursor.x
if (hscrollbar.hover && !cursor.drag) {
if (x < cursor.x) {
if (mouse_y > wh - hscrollbar.h && cursor.x > mouse_x) {
} else {
if (mouse_y > wh - hscrollbar.h && cursor.x + cursor.w < mouse_x) {
switch (i) {
case 0:
if (scrollbar.arr_buttons.checkstate("down", x, y) == ButtonStates.down) {
on_mouse_wheel(1);
on_mouse_wheel(1)
break;
case 1:
on_mouse_wheel(-1);
on_mouse_wheel(-1)
break
for (var i = 0; i < panel.arr_buttons.length; i++) {
panel.arr_buttons.checkstate("down", x, y)
function on_mouse_lbtn_dblclk(x, y, a) {
if (x < cover.pad_left_mid) {} else if (x < ww - cover.pad_right_mid) {
list.item.checkstate("dblclk", x, y, i)
} else {
} else {
if (y < cover.pad_top_mid) {} else if (y < wh - cover.pad_bot_mid) {
} else {
list.buttonclicked = false;
scrollbar.timerID && window.ClearTimeout(scrollbar.timerID);
scrollbar.timerID = false;
scrollbarbt.timerID2 && window.ClearTimeout(scrollbarbt.timerID2);
scrollbarbt.timerID2 = false;
if (list.total_gh > 0) {
cursor.bt.checkstate("up", x, y);
for (var i = 0; i < scrollbar.arr_buttons.length; i++) {
scrollbar.arr_buttons.checkstate("up", x, y)
switch (i) {
case 0:
ShowNowPlaying()
break;
case 1:
settings_menu(x, y)
break;
case 2:
} else {
} else {
break
if (cursor.drag) {
window.RepaintRect(0, wh - hscrollbar.h, ww, hscrollbar.h);
cursor.drag = false
} else {
for (i = 0; i < b; i++) {
list.item.checkstate("up", x, y, i)
setcursorx();
window.Repaint()
function on_mouse_mbtn_down(x, y, a) {
list.item.checkstate("mid", x, y, i)
function on_mouse_rbtn_down(x, y) {
list.item.checkstate("right", x, y, i)
if (x == mouse_x && y == mouse_y) return true;
if (cursor.drag) {
window.Repaint()
}, 25)
} else {
vscrollbar.hover = (x >= ww - vscrollbar.w && x <= ww && y >= vscrollbar.y && y <= vscrollbar.y + vscrollbar.h);
cursor.hover = (x >= cursor.x && x <= cursor.x + cursor.w && y >= cursor.y && y <= cursor.y + cursor.h);
cursor.bt.checkstate("move", x, y);
scrollbar.arr_buttons.checkstate("move", x, y)
if (cursor.drag && mouse_y != y) {
cursor.y = y - cursor.grap_y;
if (cursor.y < vscrollbar.y) cursor.y = vscrollbar.y;
if (cursor.y > vscrollbar.y + vscrollbar.h - cursor.h) cursor.y = vscrollbar.y + vscrollbar.h - cursor.h;
if (!cursor.timerID) {
cursor.timerID = window.SetTimeout(function () {
refresh_spv_cursor(fb.ActivePlaylist);
window.Repaint();
cursor.timerID = false
}, 30)
} else {
hscrollbar.hover = (y >= wh - hscrollbar.h && y <= wh && x >= hscrollbar.x && x <= hscrollbar.x + hscrollbar.w);
if (cursor.drag && mouse_x != x) {
cursor.x = x - cursor.grap_x;
if (cursor.x < hscrollbar.x) cursor.x = hscrollbar.x;
if (cursor.x > hscrollbar.x + hscrollbar.w - cursor.w) cursor.x = hscrollbar.x + hscrollbar.w - cursor.w;
window.Repaint();
cursor.timerID && window.ClearTimeout(cursor.timerID);
}, 30)
for (var j = 0; j < panel.arr_buttons.length; j++) {
panel.arr_buttons[j].checkstate("move", x, y)
mouse_x = x;
mouse_y = y
function on_mouse_wheel(a) {
var b = Math.abs(a);
if (!scrollbar.timerID) {
if (b >= 1) {
if (a > 0) {
scrollbar.timerID = window.SetTimeout(function () {
window.Repaint();
}, list.mousewheel_timer_value)
} else {
window.Repaint();
WSH CoverFlow v1 beta7
(http://img600.imageshack.us/img600/7755/capturewsh.png) (http://www.youtube.com/watch?v=1ELS0DmkntY)
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]click me![/size]
// @name "CoverFlow View v1 beta7"
// @version "0.0.7.20120401.1646"
// @author "Br3tt"
// @feature "v1.4"
// [Requirements]
// [/Requirements]
// [Informations]
// [/Informations]
SM_CXVSCROLL = 2;
SM_CYHSCROLL = 3;
IDC_ARROW = 32512;
IDC_IBEAM = 32513;
IDC_WAIT = 32514;
IDC_CROSS = 32515;
IDC_SIZE = 32640;
IDC_ICON = 32641;
IDC_SIZEWE = 32644;
IDC_SIZENS = 32645;
IDC_NO = 32648;
IDC_HAND = 32649;
IDC_HELP = 32651;
var VK_BACK = 0x08;
var VK_ALT = 0x12;
var VK_PGUP = 0x21;
var VK_PGDN = 0x22;
var VK_END = 0x23;
var VK_HOME = 0x24;
var VK_LEFT = 0x25;
var VK_UP = 0x26;
var VK_DOWN = 0x28;
var KMask = {
none: 0,
ctrl: 1,
shift: 2,
ctrlshift: 3,
ctrlalt: 4,
ctrlaltshift: 5,
alt: 6
var b = KMask.none;
return b
ColorTypeCUI = {
text: 0,
selection_text: 1,
background: 3,
FontTypeCUI = {
items: 0,
labels: 1
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
FontTypeDUI = {
defaults: 0,
tabs: 1,
lists: 2,
playlists: 3,
statusbar: 4,
console: 5
var a = 0,
v_align = 0,
trimming = 0,
flags = 0;
case 3:
case 2:
case 1:
a = arguments[0];
break;
default:
return 0
StringAlignment = {
Near: 0,
Centre: 1,
Far: 2
return (a & 0xff)
var i;
if (k > 0) {
c = "0" + c
return c.toString()
var b;
var c;
switch (a) {
case "file":
b = 1;
c = 0;
break;
case "cdda":
b = 1;
c = 1;
break;
case "FOO_":
b = 0;
c = 2;
break;
case "http":
b = 0;
c = 3;
break;
case "mms:":
b = 0;
c = 3;
break;
case "unpa":
b = 0;
c = 4;
break;
default:
b = 0;
c = 5
return c
ButtonStates = {
normal: 0,
hover: 1,
down: 2
this.x = x;
this.y = y;
switch (a) {
case "down":
break
break;
case "up":
break;
case "right":
break;
case "move":
break
break;
case "leave":
break
return this.state
return a
return a
var nocover;
var nocover_img;
var streamcover;
var loading;
var loading_img;
var star_img_off;
var star_img_on;
var star_img_hov;
var star_img_kill;
var menu_button;
}, 35)
return b
var c;
if (a.metadb) {
if (!c) {
c = nocover_img;
a.cover_type = 0
} else {
a.cover_type = 1
} else {
a.cover_type = 3
return c
b.ReleaseGraphics©;
return b
} else {
c.DrawRect(0, 0, w, h, 2.0, g_backcolor);
c.DrawRect(0, 0, w, h, 2.0, g_textcolor & 0x33ffffff);
b.ReleaseGraphics©;
return b
} else {
} else {
break
ItemStates = {
normal: 0,
hover: 1,
selected: 2
var i;
if (h < 0) {
this.id = h;
this.idx = k;
this.gh_id = l;
} else {
this.id = h;
this.idx = k;
this.gh_id = l;
if (this.metadb) {
if (this.metadb) {
} else {
this.show = e;
this.h = cover.h;
this.w = cover.h;
this.cut = 1
} else {
this.w = this.h;
a.FillSolidRect(this.x + 1, this.y + 1, this.w - 4, this.h - 4, g_backcolor);
if (this.id >= 0) {
} else {
} else {
this.show = e;
this.w = cover.w;
this.h = cover.w;
this.cut = 1
} else {
this.h = this.w;
if (this.id >= 0) {
a.FillGradRect(Math.floor(cover.margin / 2) + this.x, this.y + this.h, this.w - cover.margin * 2 + 2, this.h + 1, 90, RGBA(g_backcolor_R, g_backcolor_G, g_backcolor_B, f), g_backcolor, 1.0)
} else {
if (this.id >= 0) {
} else {
switch (a) {
case "down":
if (this.id >= 0) {
if (this.ishover) {
} else {
g_saved = this;
} else {
if (this.ishover) {
} else {
} else {
g_saved = this;
break;
case "dblclk":
g_saved = null
} else {
g_saved = null;
window.Repaint()
break;
case "mid":
if (this.ishover) {
var c = false;
var d = 0;
c = true;
d = i;
break
if (!c) {
bypass.on_playlists_changed = true;
fb.ClearPlaylist();
break;
case "right":
if (this.ishover) {
list.selected_gh_id = this.gh_id;
list.focus_id = this.id;
bypass.on_item_focus_change = true;
} else {
break;
case "up":
break;
case "move":
break;
case "leave":
break
return this.ishover
var g_font = null;
var ww = 0,
wh = 0;
var mouse_x = 0,
mouse_y = 0;
g_textcolor_hl = 0,
g_backcolor = 0,
var g_metadb;
var incsearch_timer_lock = false;
var g_saved = null;
var hand = false;
bypass = {
on_item_focus_change: false,
on_playlists_changed: false
panel = {
max_width: 250,
max_height: 250,
button_total: 3,
vertical_mode: false
list = {
first_launch: true,
total: 0,
total_gh: 0,
start_id: 0,
nbvis: 0,
mid: 0,
item: Array(),
hlist: Array(),
handlelist: null,
focus_id: 0,
selected_gh_id: 0,
marker_id: 0,
gh_id: 0,
nowplaying: 0,
SHIFT_count: 0,
drag_stop: true,
drag_timer: false
scrollbar = {
theme: false,
visible: true,
step: 3,
letter: null,
button_total: 2,
timerID: false
hscrollbar = {
hover: false,
x: 0,
y: 0,
w: 0
vscrollbar = {
hover: false,
x: 0,
y: 0,
h: 0
scrollbarbt = {
timerID1: false,
timerID2: false,
timer1_value: 400,
timer2_value: 60
button_up = {
img_normal: null,
img_hover: null,
img_down: null,
x: 0,
y: 0,
button_down = {
img_normal: null,
img_hover: null,
img_down: null,
x: 0,
y: 0,
cursor = {
bt: null,
img_normal: null,
img_hover: null,
img_down: null,
popup: null,
x: 0,
y: 0,
hover: false,
drag: false,
grap_x: 0,
timerID: false,
last_x: 0
cover = {
margin: 2,
w: 0,
h: 0,
top_offset: 0,
pad_top_mid: 35,
pad_bot_mid: 30,
default_pad_left_mid: 24,
default_pad_right_mid: 20,
pad_left_mid: 24,
pad_right_mid: 20,
normal_delta: 20,
load_timer: false
} else {
if (b > 1) b = 1;
if (b < 0) b = 0;
window.Repaint()
list.gh_id = 0
if (r < 0) {
r = 0
} else {
list.start_id = 0
r++
} else {
if (r > 0) {
if (s > 0) {
} else {
list.item.pop()
list.item.idx = i
setcursorx()
} else {
list.item.shift()
list.item.idx = i
setcursorx()
init_active_pls();
return true
if (r < 0) {
r = 0
} else {
list.start_id = 0
r++
} else {
} else {
} else {
set_scroller();
setcursorx()
var c = 0
} else {
var c = b
return i
} else {
return i
} else {
return null
} else {
} else {
} else {
var a;
var b;
var c;
i++;
if (a != b) {
if (i > 0) {
if (a != c) {
if (c != b) {
list.hlist.push(i)
} else {
list.hlist.push(i)
a = b
} else {
if (a != b) {
list.hlist.push(i);
a = b
var a;
var b;
if (a != b) {
list.hlist.push(i);
a = b
get_font();
on_playlist_switch()
get_colors();
init_icons();
set_scroller();
CollectGarbage();
ww = window.Width;
wh = window.Height;
if (ww > wh) {
} else {
get_font();
get_colors();
init_icons();
cover.pad_right_mid = cover.default_pad_right_mid + vscrollbar.default_w
} else {
cover.w = cover.h;
list.nbvis = Math.floor(wh / (cover.h - cover.normal_delta * 2)) + 2 + 10;
list.nbvis--
} else {
button_up.y = 0;
} else {
} else {
} else {
cover.h = cover.w;
list.nbvis = Math.floor(ww / (cover.w - cover.normal_delta * 2)) + 2 + 10;
list.nbvis--
} else {
button_up.x = 0;
} else {
CollectGarbage();
var b, mid2;
b = true
} else {
b = false
var d = 32;
var f = ww - 64;
} else {
if (fb.PlaylistCount > 0) {
var g = fb.GetPlaylistName(fb.ActivePlaylist);
var h = "This playlist is empty"
} else {
var g = "Br3tt's WSH CoverFlow";
var h = "Create a playlist to start!"
a.SetTextRenderingHint(5);
a.DrawString(g, gdi.Font("Tahoma", 17, 0), g_textcolor, 0, -20, ww, wh, cc_stringformat);
a.DrawString(h, gdi.Font("Tahoma", 13, 0), g_textcolor, 0, 20, ww, wh, cc_stringformat);
a.FillGradRect(40, Math.floor(wh / 2), ww - 80, 1, 0, 0, g_textcolor, 0.5);
a.FillSolidRect(0, 0, ww, wh, g_backcolor & 0xbbffffff)
try {
} catch (e) {
try {
} catch (e) {};
switch (i) {
case 0:
break;
case 1:
break
if (cursor.drag) {
} else {
try {
} catch (e) {
try {
} catch (e) {};
try {
} catch (e) {};
switch (i) {
case 0:
break;
case 1:
break
if (cursor.drag) {
switch (i) {
case 0:
panel.arr_buttons.draw(a, 4, 4, (list.total_gh > 0) ? 255 : 80)
break;
case 1:
panel.arr_buttons.draw(a, 4, wh - 22 - 4, (list.total_gh > 0) ? 255 : 80)
} else {
panel.arr_buttons.draw(a, ww - 22 - 4, 4, (list.total_gh > 0) ? 255 : 80)
break;
case 2:
panel.arr_buttons.draw(a, 4, 4, 255)
} else {
break
if (g_search_string.length > 0) {
var j = Math.floor((ww / 2) - ((g_search_string.length * 13) + (10 * 2)) / 2);
var k = Math.floor(wh / 2) - 30;
var l = ((g_search_string.length * 13) + (10 * 2));
var m = 60;
a.FillRoundRect(j, k, l, m, 5, 5, RGBA(0, 0, 0, 150));
a.DrawRoundRect(j, k, l, m, 5, 5, 2.0, RGBA(255, 255, 255, 200));
a.DrawRoundRect(j + 2, k + 2, l - 4, m - 4, 3, 3, 1.0, RGBA(0, 0, 0, 150));
a.GdiDrawText(g_search_string, incsearch_font_big, RGB(0, 0, 0), j + 1, k + 1, l, m, DT_CENTER | DT_NOPREFIX | DT_CALCRECT | DT_VCENTER);
a.GdiDrawText(g_search_string, incsearch_font_big, list.inc_search_noresult ? RGB(255, 75, 75) : RGB(250, 250, 250), j, k, l, m, DT_CENTER | DT_NOPREFIX | DT_CALCRECT | DT_VCENTER)
var b = 0;
if (!list.item[list.mid].checkstate("down", x, y, list.mid)) {
for (var i = 1; i < list.mid + 1; i++) {
b = list.mid - i;
if (b >= 0 && b <= a - 1) {
if (list.item.checkstate("down", x, y, b)) {
break
b = list.mid + i;
break
cursor.drag = true;
if (y < cursor.y) {
} else {
} else {
cursor.drag = true;
if (x < cursor.x) {
} else {
switch (i) {
case 0:
on_mouse_wheel(1);
on_mouse_wheel(1)
break;
case 1:
on_mouse_wheel(-1);
on_mouse_wheel(-1)
break
switch (i) {
case 0:
break;
default:
} else {
} else {
} else {
switch (i) {
case 0:
ShowNowPlaying()
break;
case 1:
settings_menu(x, y)
break;
case 2:
break
if (cursor.drag) {
cursor.drag = false
} else {
for (i = 0; i < a; i++) {
setcursorx();
window.Repaint()
var b = false;
var c = list.mid;
if (list.item[list.mid].checkstate("right", x, y, list.mid)) {
b = true
} else {
c = list.mid - i;
if (c >= 0 && c <= a - 1) {
if (list.item[c].checkstate("right", x, y, c) == true) {
b = true;
break
c = list.mid + i;
b = true;
break
if (b) {
new_context_menu(x, y, list.item[c].id, list.item[c].idx)
function on_mouse_rbtn_up(x, y) {
if (!utils.IsKeyPressed(VK_SHIFT)) {
return true
hand = false;
if (cursor.drag) {
window.Repaint()
}, 25)
} else {
The panel crashes when 1. playlist is empty and 2. the option button (upper right corner) is pressed.
Edit
The size of the ui-elemnt is locked when it reaches a certain size: i can't make it bigger. Therefore (when it is placed in a tabstack) all other tabs are limited to coverflow maximum size. Somehow annoying!
Edit
it seems the paste in this forum has added unwanted characters, that's weird, so, download this script from here: http://fav.me/d4t4lh7 (http://fav.me/d4t4lh7)
e.g: "if ( c ) {" is translated "if © {", that make the script crashing of course.
all is fine there.
yep, i've limited size to 300 pixel height.
Edit
all is fine there.
I downloaded it from your link and did it once again, but still crashes!
edit
Any chance to make the panel sizeable again but without making the thumbnails larger than necessary, means: than in 300 pixel panel? I have no space to place it outside a tabstack.
I seem to get a lot of crashes on line 378 (vertical mode) and line 380 (horizontal mode) in CUI when switching between layouts with and without the panel. But I haven't encountered them yet in DUI when switching between tabs. Otherwise it's excellent work & fast too.
Error: WSH Panel Mod (CoverFlow View v1 beta7 v0.0.7.20120401.1646 by Br3tt): Microsoft JScript runtime error:
Overflow
File: <main>
Ln: 378, Col: 13
Overflow
File: <main>
Ln: 380, Col: 13
***EDIT***
Also it doesn't always identify the correct now playing cover, especially if minimise foobar2000, use another program and then return to foobar2000 after a track change. It sometimes gets stuck on the previous track's cover. Even pressing the music note button causes it to highlight the wrong cover. Again CUI & seen in horizontal mode.
Ah, sorry: forgot the console output
Error: WSH Panel Mod (CoverFlow View v1 beta7 v0.0.7.20120401.1646 by Br3tt): Laufzeitfehler in Microsoft JScript:
'list.item[...]' ist Null oder kein Objekt
File: <main>
Ln: 1329, Col: 3
thanx for feedback, i've mainly tested it on DUI, i'll check your reports to see what's the issue.
EDIT: with the paste problem on this topic, i'd be sure every use the same script, so, please, thanx to test it again from here this time (i've made a little fix about the lines pointed by WilB):
http://pastebin.com/X8xdSZkA (http://pastebin.com/X8xdSZkA)
btw, i can't reproduce any crash on DUI or CUI from my side.
thanx by advance.
i will remove this limitation, asap all your issues will be fixed
Thanks for your fast response. Unfortunately, the crashes are still occurring (e.g. line 380 when in vertical mode). I also spotted another issue added as an edit to my previous post.
before getting further, i'd like to know if you test my panel in a config that conatins other WSH panels? i ask that because if timers are badly handled in them, it can (often) affect other WSH panels as the CoverFlow panel that use timers too.
could you tell me what's your situation please?
btw, replacing line 380 by these 3 lines:
try {
window.RepaintRect(cover.pad_left_mid, list.item[i].y - 2, ww - cover.pad_left_mid, list.item[i].h + 4);
} catch(e) {};
and line 384 by these 3 lines:
try {
window.RepaintRect(list.item[i].x - 2, cover.pad_top_mid, list.item[i].w + 4, wh - cover.pad_top_mid);
} catch (e) {};
should avoid crash for you... at least at these lines
EDIT: any other feedback from new user would be really appreciated, especially when it works fine too. So thanx by advance.
here the console output with the script from pastebin:
Error: WSH Panel Mod (CoverFlow View v1 beta7.1 v0.0.7.20120401.2320 by Br3tt): Laufzeitfehler in Microsoft JScript:
File: <main>
Ln: 1333, Col: 2
File: <main>
Ln: 1333, Col: 2
ok for this bug, fixed in this new version normally:
http://pastebin.com/WdkYVzrn (http://pastebin.com/WdkYVzrn)
thanx for the feedback
WSH CoverFlow v1 beta 8 : http://pastebin.com/2srRwRXp (http://pastebin.com/2srRwRXp)
maximum height/width limit removed.
Falstaff
In my configuration (foo_playlist_attributes) played tracks removed from playlist after playing.
But covers of this tracks not deleted automatically from WSH Coverflow panel. It is possible add this future in next version of coverflow script.
@Falstaff
I am pleased to say that I am no longer experiencing crashes with beta 8; the catch (e) seems to have solved the problem.
I have troubleshooted the sticking cover issue further. Essentially it's a similar problem to that reported by pIv above. The problem occurs when using foo_lastfm_radio but not when playing tracks in the media library. foo_lastfm_radio removes played tracks from the playlist, but covers of these tracks remain in coverflow and so coverflow is not updating to reflect the changed playlist. If I remain in foobar2000 when a track change occurs the correct cover is nonetheless highlighted. If I toggle away from foobar2000 while a track change occurs the incorrect previous cover is often highlighted as the now playing cover (not corrected by pressing the music note button).
Thanks for your hard work on this. Previously I have been using a wsh coverflow based on the Grimes code but yours automatically updates and is visually an improvement.
Falstaff
...But covers of this tracks not deleted automatically from WSH Coverflow panel. It is possible add this future in next version of coverflow script.
i'll check that, should not be a big deal to fix ....
...The problem occurs when using foo_lastfm_radio but not when playing tracks in the media library. foo_lastfm_radio removes played tracks from the playlist, but covers of these tracks remain in coverflow and so coverflow is not updating to reflect the changed playlist.
are you sure of that, i've just tested lastfm_radio component (lastest version) and coverflow updates as well the tracks change!
I have just retested under DUI & CUI with foo_lastfm_radio 0.5.7e which I believe is the latest. On track change I see the track and cover of the played track disappear from the playlist but the cover remains in coverflow (the only exception to this is if there are less than ~4 tracks in the playlist and the playlist updates by adding new tracks, then coverflow updates correctly). This behaviour is confirmed on 2 different PCs. Clicking refresh coverflow on the menu will, however, update coverflow.
I have just retested under DUI & CUI with foo_lastfm_radio 0.5.7e which I believe is the latest. On track change I see the track and cover of the played track disappear from the playlist but the cover remains in coverflow. This behaviour is confirmed on 2 different PCs. Clicking refresh coverflow on the menu will, however, update coverflow.
v 0.5.7e here too but different behaviour here, weird, i'll try on another PC...
New simplified and revised map only version of WSH-Script FooTour.
Download: http://pastebin.de/24891 (http://pastebin.de/24891)
Screenshot:
(http://www.abload.de/img/foobar2000_2012-04-02dqd7h.png) (http://www.abload.de/image.php?img=foobar2000_2012-04-02dqd7h.png)
Installation: Download world map and FooTour banner from
http://eoimages.gsfc.nasa.gov/images/image...w_topo_2048.jpg (http://eoimages.gsfc.nasa.gov/images/imagerecords/57000/57752/land_shallow_topo_2048.jpg)
http://www.abload.de/image.php?img=footouro74r.png (http://www.abload.de/image.php?img=footouro74r.png)
credits: NASA
http://foobar-users.de/index.php?topic=200...g17454#msg17454 (http://foobar-users.de/index.php?topic=2000.msg17454#msg17454)
and put pictures in new created (profile)\foobar2000\pictures folder
@falstaff
no more crashes!
@q-stankovic
ok, i see what you mean now, i've not understood, because coverflow refresh when lastfm radio add a new track to the playlist, and so, your issue is when a track is played, it should be removed immediatly. i'll see if i can catch this event! well see.
Yes there's that plus the presumably knock-on effect with foo_lastfm_radio (may be also when foo_playlist_attributes is set to remove tracks as posted above) that the cover highlighted/centred & the displayed information soon get out of sync with the playing track. For example, with foo_lastfm_radio, in my hands pressing play next track a few times soon results in it sticking on the wrong cover/info.
HTH
WSH CoverFlow v1 beta 8.1 : http://pastebin.com/Etr6TkDG (http://pastebin.com/Etr6TkDG)
What's New in beta8.1:
- added coverflow refresh on track removed
@Falstaff
Thanks for beta 8.1. All is now working well.
@WilB
ok, thank you for the tests and feedback
is this fixed for you with beta 8.1 ? thanx by advance for your feedback about the use of foo_playlist_attributes with my script now (should be ok)
New version beta 8.1 work now very good!
@pIv
thank you
Maybe it makes sence to add mouse gestures to scroll ? It works, it is convenient. I made it very easy (in other script) :
var gest_x1, gest_y1, gest_x2, gest_y2;
function on_mouse_lbtn_down(x, y) {
gest_x1 = x;
gest_y1 = y;
function on_mouse_lbtn_up (x, y) {
gest_x2 = x;
gest_y2 = y;
if ( (gest_y2 - gest_y1 < 10) && (gest_y2 - gest_y1 > -10)) {
if (gest_x2 - gest_x1 > 30) {Cover.NextCover(); window.Repaint();};
if (gest_x2 - gest_x1 < -30) {Cover.PrevCover(); window.Repaint();}
samples updated: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
news / reviews / blogs: fix condition where artist pages with no info would never get checked for updates.
WSH CoverFlow v1 beta 9 : http://pastebin.com/uEcgtjq6 (http://pastebin.com/uEcgtjq6)
What's New in beta9:
- added a transition effect (scroll) on cover change (option in settings, top/right button of the panel)
WSH CoverFlow v1 beta 9.1 : http://pastebin.com/ANFNNA3Q (http://pastebin.com/ANFNNA3Q)
What's New in beta9.1:
- transition effect enhanced on cover change, and propagated to mousewheel and keys now
- small glitch on cover reflection fixed
@Falstaff
I'am enjoying your WSH Coverflow very much. thanks for that.
@grimes
you're welcome
WSH CoverFlow v1 beta 10 : http://pastebin.com/5wKb799f (http://pastebin.com/5wKb799f)
What's New in beta 10:
- bugs fixed (transition, reflection, behaviour, ...)
- new FLAT MODE added
- Settings Menu enhanced
- tweaks
(http://img703.imageshack.us/img703/4221/wshcoverflowpreview019.png) (http://imageshack.us/photo/my-images/703/wshcoverflowpreview019.png/)
WSH CoverFlow v1 beta 11 (latest beta before final) : http://pastebin.com/rfe2B6K4 (http://pastebin.com/rfe2B6K4)
What's New in beta 11:
- keep aspect ratio added (can be disabled in Properties)
- Properties reordered, users can modify those than begin with *USER_xxx ... other ones SYSTEM_xxx are to not change!
- new properties to change default images by custom ones (for stream, nocover and loading)
- tweaks
WSH CoverFlow v1.0.0 final : http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
[a href="http://pastebin.com/u/Br3tt" target="_blank"]
enjoy!
Thanks for this nice script. Is it possible to take the whole music library as source, instead of the playlist?
no. but just create an autoplaylist of your library (query like that: %path% PRESENT), and lock it in the coverflow, so, you'll be able to browse your full library with this panel regardless of the playlist activated
WSH Playlist Viewer v2 beta 2 : http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
first "true" beta of this jscript for WSH Panel Mod component (v1.5.2)
(http://i.imgur.com/9I7MU.png) (http://fav.me/d4se96u)
Don't remember the state of "Show scrollbar". Hiding the scrollbar does not work after restart.
@onv
ty, will be fixed for next beta
WSH Playlist Viewer v2 beta 3 : http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
What's new in beta3:
- aspect ratio on covers (can be disabled in properties)
- playcount info added
- drag an item in the playslit to reorder it manually
- optimization around the display of the rating
- bugs fixing
- tweaks
video: http://youtu.be/gse_017s2hk (http://youtu.be/gse_017s2hk)
i found a new for me callback in documentation "on_tooltip_custom_paint(gr)", but i dont understand when it calls. in preprocessor tooltip set as "custom-paint-no-background". could anybody explain how it works and what i can get?
I'm very new to WSH Mod, and have never really programmed before (but I can read code and learn and try and draw conclusions).
I just want a plugin for the DUI which allows me to view a slideshow of Artist pictures stored on the computer, under H:\Music\%Artist%\01.jpg, 02.jpg, 03.jpg - etc.
I think WSH panel mod would be able to help me with this but I might be in way over my head. I've had a look at the few samples and LoadImageASync would be great except that the path is absolute and not relative (I have no idea how to tell it how to look at the relative artist that is playing's folder). Before I go too deep into this, is something like what I want possible?
@NoiseAround
it's looks very possible to do
You can try to mod my WSH Coverflow script to browse "%artist% image folder" instead of the content of the current playlist... should not be too difficult if the path pattern for artist images has to be always the same e.g. H:\Music\%artist%\
i'll try to give it a try when possible.
Hey thanks man!
I actually ended up finding a neat solution though, so don't worry about it!
Here it is:
http://www.hydrogenaudio.org/forums/index....showtopic=92685 (http://www.hydrogenaudio.org/forums/index.php?showtopic=92685)
But I'm completely addicted to WSH Panel Mod. Going to try working in your Coverflow into my foobar! It looks amazing.
anybody knows something about my question?
(my 1st post on HA, but using foo since 09.4.3.1)
I really love all this amazing WSH stuff, it's ... euhm making foobar even more IFF foo, bar, foo.
Marc, i noticed the autoplaylist script in your samples has a 255 character limit. Any chance this can be expanded? Or could you warn users by doing a stringlength check? It did cost me at least two cups of coffee to restore my playlists.
Falstaff, your coverflow is almost too sweet, maybe some artistflow would make the sugarlevels rise even more... (subtle hinting)
sorry but 255 characters is the limit of the inputbox i use. i don't know how else to get user input into a script.
an ugly workaround would to be to edit the data file in a text editor. close foobar2000 and then browse to your foobar2000 profile folder and then open the file named
autoplaylists in the
wsh_settings folder. if you already have some autoplaylists you'll see it takes this format...
name¬query¬sort pattern
if there is no sort pattern, it will look like this
name¬query¬
just make sure each query is on it's own line.
sorry but 255 characters is the limit of the inputbox i use. i don't know how else to get user input into a script...
an ugly workaround...
Hehe, skipping the input box ain't that ugly, great workaround. Thx alot for the quick and solid respons.
Does somebody know why popup menu always expand to the left ?? it drives me mad, it should be to the right when there is enough place to display it right, as the arrow point...
but maybe i miss something ... if not maybe a weird behaviour due to WSH panel mod?
(http://i.imgur.com/3fqAi.png)
i've never seen that happen before when there is room for it. this screenshot is against the right side of my screen with just enough space...
(http://dl.dropbox.com/u/22801321/menu%20ok.png)
EDIT: i downloaded your script and the console says you're using obsolete method (this changed in 1.5.0)
WSH Panel Mod: Warning: Obsolete: Please use AppendTo() method to create sub menu instead of AppendMenuItem()
will try to use the new method. thank you.
EDIT: AppendTo method used for creating Popup, but popup still appears to the left
any idea or any sample that work, i can't figure out what's wrong, example below:
function sort_group_menu(x, y) {
var idx;
var _menu = window.CreatePopupMenu();
var _sort = window.CreatePopupMenu();
var _groupby = window.CreatePopupMenu();
_sort.AppendTo(_menu, MF_STRING, "Sort");
_sort.AppendMenuItem(MF_STRING, 100, "Sort by album");
_sort.AppendMenuItem(MF_STRING, 110, "Sort by file path");
_sort.AppendMenuItem(MF_STRING, 120, "Sort by artist");
_groupby.AppendTo(_menu, MF_STRING, "Group by");
_groupby.AppendMenuItem(MF_STRING, 200, "Group by album");
_groupby.AppendMenuItem(MF_STRING, 210, "Group by file path");
_groupby.AppendMenuItem(MF_STRING, 220, "Group by artist");
idx = _menu.TrackPopupMenu(x, y);
switch(idx) {
case 100:
fb.RunMainMenuCommand("Edit/Sort/Sort by album");
break;
case 110:
fb.RunMainMenuCommand("Edit/Sort/Sort by file path");
break;
case 120:
fb.RunMainMenuCommand("Edit/Sort/Sort by artist");
break;
case 200:
panel.sort_group_mode = 0;
window.SetProperty("SYSTEM.sortgroup.mode", panel.sort_group_mode);
var new_group_key = "%album artist%%album%%discnumber%";
window.SetProperty("SYSTEM.group Key", new_group_key);
tf_group_key = fb.TitleFormat(new_group_key);
break;
case 210:
panel.sort_group_mode = 1;
var new_group_key = "$replace(%path%,%filename_ext%,)";
break;
case 220:
panel.sort_group_mode = 2;
break;
_sort.Dispose();
_groupby.Dispose();
_menu.Dispose();
return true;
thanx by advance
EDIT 2:hmm weird, just tested on another PC (my laptop), and it's working on it! will try again on my desktop PC tomorrow...
a windows theme issue??
maybe, but theme used on both PC is the same : Shine 2.0 for 7
using the same theme on both machines rules that out. so.... i have no idea.
your snippet works for me ok. what about context menus in other components such as a standard playlist? i'm guessing they use the same "system" functions for making menus (i could be talking out of my backside - i have no idea about "proper" windows programming )
I may be able to help, I've had that problem on Vista before.
http://www.askvg.com/how-to-change-menu-po...-windows-vista/ (http://www.askvg.com/how-to-change-menu-position-from-left-to-right-in-windows-vista/)
Hope that helps!
@Dennis68
Thanx a bunch, that has fixed the problem, i'd to chose Left-Handed instead of Right :S
not me, can't make it working better than you, not changes if PREPROCESSOR feature used or not
Hi there,
I've written a script which displays a vertical volume bar with a tooltip showing the volume (based on "Simple Seekbar" by marc2003 and "Volbar with GdiDrawText" by T.P. Wang). The code is below if anyone is interested
// ==PREPROCESSOR==
// @name "Volume-bar with tooltip"
// @author "rawny"
// ==/PREPROCESSOR==
// Based somewhat on:
// -> "Volbar with GdiDrawText" by T.P Wang
// -> "Simple Seekbar" by marc2003
var a = 25;
var g_drag = 0;
var g_drag_seek = 0;
var g_tooltip = window.CreateTooltip();
var g_trackingMouse = false;
var old_x;
var old_y;
return (0xff000000 | (r << 16) | (g << 8) | (b));
return ((a << 24) | (r << 16) | (g << 8) | (b));
ww = window.Width;
wh = window.Height;
function on_paint(gr){
var ww = window.Width;
var wh = window.Height;
var pos = 0;
var volume = fb.Volume;
if(g_drag){
pos = wh * g_drag_seek;
}else{
pos = wh * Math.exp(fb.Volume/a);
gr.FillGradRect(0, wh-pos, ww, wh, 90, RGB(0,0,255), RGB(70,90,200));
gr.FillGradRect(0, 0, ww, wh-pos, 90, RGB(0,0,0), RGB(50,50,50));
gr.DrawRect(0,0, ww-1, wh-1, 1.0, RGB(100,100,100));
function on_mouse_move(x,y){
g_drag_seek = 1-y/wh;
g_drag_seek = (g_drag_seek<Math.exp(-100/a)) ? Math.exp(-100/a) : (g_drag_seek<1) ? g_drag_seek : 1;
if(x > ww){
g_drag = 0;
if(g_drag){
window.Repaint();
if(!g_trackingMouse){
g_tooltip.Activate();
g_tooltip.TrackActivate = true;
g_trackingMouse = true;
if(x != old_x || y != old_y){
txt = Math.ceil(a*Math.log(g_drag_seek))+"dB ("+Math.ceil(g_drag_seek*100)+"%)";
g_tooltip.Text = txt;
g_tooltip.TrackPosition(x,y-20);
old_x = x;
old_y = y;
function on_mouse_leave(){
g_tooltip.TrackActivate = false;
function on_mouse_lbtn_down(x,y){
g_drag = 1;
if(!g_drag){
return;
g_drag = 0;
var v = 1-y/wh;
v = (v<Math.exp(-100/a)) ? Math.exp(-100/a) : (v<1) ? v : 1;
fb.Volume = a*Math.log(v);
function on_mouse_wheel(delta){
if(delta>0){
fb.VolumeUp();
}else{
fb.VolumeDown();
function on_volume_change(val){
window.Repaint();
Also, does anyone know how to produce glowing text with GdiDrawText?
As in this sample (but with GdiDrawText):
// ==PREPROCESSOR==
// @name "Glow Text Sample"
// @author "T.P Wang"
var g_font = gdi.Font("Segoe UI", 22, 1);
var g_drag = false;
var g_textrender = gdi.CreateStyleTextRender();
var g_bkclr = RGB(0, 0, 0);
function on_paint(gr) {
gr.SetTextRenderingHint(5);
gr.SetSmoothingMode(4);
gr.SetInterpolationMode(7);
// Draw background first
gr.FillSolidRect(0, 0, ww, wh, g_bkclr);
g_textrender.GlowText(RGB(0, 0, 64), RGBA(255, 255, 0, 30), 12);
// Clear previous shadow setting
g_textrender.EnableShadow(true);
g_textrender.ResetShadow();
g_textrender.RenderStringRect(gr, "Glow Text Sample", g_font, 0, 0, ww, wh, 0x11005000);
My current poor-man's version is to draw multiple copies of the text in the glow colour underneath the actual text:
// ==PREPROCESSOR==
// @name "Poor-man's glowing Gdi text"
// @author "rawny"
var text = "foobar2000";
var textFont = gdi.Font("Tahoma", 50, 1);
var textX = 100;
var textY = 100;
var glowSpacing = 4;
var rightGlowTextX = textX+glowSpacing;
var rightGlowTextY = textY+glowSpacing;
var actualTextX = textX+(glowSpacing/2);
var actualTextY = textY+(glowSpacing/2);
var bgColour = RGB(0,0,0);
var glowColour = RGBA(0, 0, 255, 222);
var textColour = RGBA(255, 255, 255, 222);
ww = window.Width;
wh = window.Height;
gr.FillSolidRect(0, 0, ww, wh, bgColour);
gr.GdiDrawText(text, textFont, glowColour, textX, textY, ww, wh);
gr.GdiDrawText(text, textFont, glowColour, textX, rightGlowTextY, ww, wh);
gr.GdiDrawText(text, textFont, glowColour, rightGlowTextX, textY, ww, wh);
gr.GdiDrawText(text, textFont, glowColour, rightGlowTextX, rightGlowTextY, ww, wh);
gr.GdiDrawText(text, textFont, textColour, actualTextX, actualTextY, ww, wh);
I'm fairly happy with this effect, but I was wondering if there was a way to do it properly?
WSH Playlist Viewer v2 beta 5 : http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
example of use in a CUI config (opacity set to 0 in Properties of the panel in order to see the background which is a PanelStack Splitter that display the artist image of the current track)
(http://i.imgur.com/PQcuN.jpg)
Playlist Viewer Beta 5. I would like to have a 1 line group header. This is what I get -
Streaming Radio - Streaming | undefinedundefined
FLAC Files - Artist | undefinedundefined
Is this how it should be? Beautiful playlist. Thank you.
nope, a small bug, sorry will be fixed in next beta
Playlist Viewer Beta 6. Group header bug fixed, thank you. In the Appearance settings I have turned off the light shadow border. But there is still a shadow border after last item in playlist. Is it possible to turn that off also? Thank you.
no. but you can edit the script to fit your needs, just remove the lines of code that draw this shadow (near line 622)
if (this.id == list.total - 1) {
gr.FillSolidRect(this.x, this.y + this.h + 0, this.w - vscrollbar.w, 1, RGBA(0, 0, 0, 75));
gr.FillSolidRect(this.x, this.y + this.h + 1, this.w - vscrollbar.w, 1, RGBA(0, 0, 0, 35));
gr.FillSolidRect(this.x, this.y + this.h + 2, this.w - vscrollbar.w, 1, RGBA(0, 0, 0, 12))
Thank you, that worked perfectly. Excellent playlist.
Whenever I try to sort either by Album or Artist using Playlistviewer Beta 6 it keeps crashing, this is what's coming up in the console:
Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 6 v0.0.6.20120423.2349 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): Microsoft JScript runtime error:
Object doesn't support property or method 'SortByFormat'
File: <main>
Ln: 3482, Col: 3
try updating WSH panel mod to the latest version. http://code.google.com/p/foo-wsh-panel-mod/downloads/list (http://code.google.com/p/foo-wsh-panel-mod/downloads/list)
Awesome that's fixed it, many thanks
don't forget to read Informations in the top of the script, like :
// [Requirements]
// * foobar2000 v1.1 or better >> http://foobar2000.org (http://foobar2000.org)
// * WSH panel Mod v1.5.3.1 or better >> http://code.google.com/p/foo-wsh-panel-mod/downloads/list (http://code.google.com/p/foo-wsh-panel-mod/downloads/list)
// [Requirements]
Doh
Falstaff, i get an error at startup (with a filled autoplaylist selected):
Foobar2000 v1.1.11 + Windows Scripting Host Panel Modded v1.5.3.1 (Build: 19:48:41, Apr 20 2012)
W7x64
Console:
Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 6 v0.0.6.20120423.2349 by Br3tt aka Falstaff >> [url=http://br3tt.deviantart.com):]http://br3tt.deviantart.com):[/url]
Object doesn't support this property or method
File: <main>
Ln: 541, Col: 4
something goin' wrong at:
if (this.metadb) {
541 this.group_key = tf_group_key.EvalWithMetadb(this.metadb);
But after that is seems to run ok.
thanx Mod-Ular, it has already be reported to me (same bug), it should be fixed for the next beta
WSH Playlist Viewer v2 beta 7 : http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
- bug on launch (for who's encountered it) fixed (i hope, tell me about it)
- queue info added for queued tracks + special "Queue content playlist" added to see the queued tracks as a special playlist (check settings menu from the toolbar)
Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 7 v0.0.7.20120424.2339 by Br3tt aka Falstaff >> [url=http://br3tt.deviantart.com):]http://br3tt.deviantart.com):[/url] Microsoft JScript runtime error:
'list.item[...].id' is null or not an object
File: <main>
Ln: 1814, Col: 3
Still getting an error.. .
The same, with 1.5.3.1 & with 1.5.2.
File: <main>
Ln: 1814, Col: 3
yep, but not the same
could you gimme more info on how it happens ? (playlist content (large, small number of items), action you where doing, ... all that could help me because i can't reproduce this bug, thanx)
Fallstaff,
In my case the script only fails at fb2k startup. (with a huge Media Library, not tested otherwise)
Medium sized Autoplaylists containing 75-125Gig and 5,000-7500 items.
Everything autosorted by %path_sort%
I see u added queueing functions. Maybe worthwhile to mention the related components i use?
foo_keep_queue: Keep Queue 0.3.5 (by Andreas "Qtax" Zetterlund, Prevents the playback queue from being removed when changing song manually or exiting)
foo_queuecontents: Queue Contents Editor 0.5.1 (by Sami Salonen)
Good luck bug-hunting
@Mod-Ular
thanx for the reply, i've tried both (foo_queuecontents and foo_keep_queue) but i can't make it crashes ...
have you installed the last version of WSH panel mod at least? v1.5.3.1 ?
have you try to clear the panel Properties ?
Yes, Windows Scripting Host Panel Modded v1.5.3.1 (Build: 19:48:41, Apr 20 2012)
I've reset the properties. (I only adjusted a few settings in the USER-fields.)
But i'm getting the same error at Foobar Startup as mentioned above.
In console i see the script initialising without problems:
WSH Panel Mod (WSH Playlist Viewer v2 beta 7 v0.0.7.20120424.2339 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): (http://br3tt.deviantart.com):) initialized in 10 ms
After console shows startup time (everything is loaded), it crashes:
Startup time : 0:37.911965
Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 7 v0.0.7.20120424.2339 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): (http://br3tt.deviantart.com):) Microsoft JScript runtime error:
File: <main> Ln: 1814, Col: 3 <source text only available at compile time>
could you try with this debug version it adds some info to the console before the crash. thanx for reporting to me the content of the console with this version please.
http://br3tt.free.fr/files/WSH/v2_wsh_play...beta7_DEBUG.zip (http://br3tt.free.fr/files/WSH/v2_wsh_playlist_859_shared_beta7_DEBUG.zip)
Fallstaff, I cannot open that zip-archive. Downloaded it 3 times but it seems to be corrupted...
sorry, fixed, try again
DEBUG: list.total=4094/list.item.length=1/list.tocut=1/from=refresh_spv
File: <main>
Ln: 1819, Col: 3
I use last DEBUG version:
DEBUG: list.total=82/list.item.length=1/list.tocut=1/from=refresh_spv
Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 7 v0.0.7.20120424.2339 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): (http://br3tt.deviantart.com):) Ошибка выполнения Microsoft JScript:
'list.item[...].id' - есть null или не является объектом
File: <main>
Ln: 1819, Col: 3
This error appears only if foobar (when it start) open autoplaylist.
thanx for the reports, i still can't reproduced the issue, but it may be fixed in beta 7.1: http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
let me know...
Falstaff
In v. 7.1 foobar started with autoplaylist selected - WSH Playlist Viewer not crash more.
Thanx for new version.
Falstaff
good
Br3tt, regarding the RemoveAccents function:
-- Why does "Æ" translate to "A" and not "Ae"?
-- Why does "Õ" translate to "0" (zero) and not an "O"?
-- Why does "ß" translate to a single "S" instead of double "Ss" (as it is in German)?
By the way, I really, really like this, and I think that you should continue working on this (and other WSH) scripts instead of configurations that utilize ELPlaylist and that Panel Stack thingy (which have been left without updates for quite some time).
Falstaff, confirmed 7.1 starts without errors. Good work.
(I always wondered how to fix bugs you cant reproduce, I imagine it has something to do with skills & magical wizardry ^^)
Damn.
On track change i get that bug again:
Startup was okee, first track played fine,
then a track was skipped (no error),
the third track opens with an error:
Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 7.1 v0.0.7.20120426.0820 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): (http://br3tt.deviantart.com):) Microsoft JScript runtime error:
File: <main>
Ln: 1674, Col: 3
Crashing on startup was 'somehow' better...
ok, the fix was just a workaround and this new bug is close from the previous one, but NOW i may have found the source of the problem
beta 7.2 this evening, should fix these crash issues
WSH Playlist Viewer v2 beta 7.2: http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
let me know if it fixes the reported crash... (it should) ... thanx.
* bug fixes
* new toolbar's button look
Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 7.2 v0.0.7.20120426.1300 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): (http://br3tt.deviantart.com):) Microsoft JScript runtime error:
File: <main> Ln: 1675, Col: 3 <source text only available at compile time>
Same circumstance. Startup OK, 1st track OK, skipping a second track, and ERROR at third track.
@Mod-Ular
#@! ... you have a special thing or do a special thing that i don't, now i'd like to find what ...
is queue list empty or not when it crashes? what are the components installed on your system, and what panels are used in your config (is there other wsh panel mod?)
thank you
@Mod-Ular / Falstaff
for reproducing or understanding what someone does a picture is worth more than thousand words ... even better: i prefer a short video.
Perfect for my recent needs is a neat little tool named Jing ... uploads pictures or short (flv) videos (5 mins), no special player for viewing req.
http://www.techsmith.com/jing.html (http://www.techsmith.com/jing.html)
No advertising intended ... there are other similar tools, just wanna help u guys
This is going to be a long reply.
Core (2012-02-04 13:05:48 UTC)
foobar2000 core 1.1.11
foo_albumlist.dll (2012-02-04 13:04:12 UTC)
Album List 4.5
foo_audioscrobbler.dll (2012-02-18 20:01:21 UTC)
Audioscrobbler 1.4.7
foo_cdda.dll (2012-02-04 13:03:52 UTC)
CD Audio Decoder 3.0
foo_converter.dll (2012-02-04 13:04:00 UTC)
Converter 1.5
foo_discogs 1.30.dll (2012-02-18 20:01:21 UTC)
Discogs Tagger 1.30
foo_dsp_std.dll (2012-02-04 13:04:14 UTC)
Standard DSP Array 1.0
foo_dsp_xgeq.dll (2012-04-05 19:13:11 UTC)
Graphic Equalizer 0.3.7
foo_fileops.dll (2012-02-04 13:03:02 UTC)
File Operations 2.1.3
foo_freedb2.dll (2012-02-04 13:03:02 UTC)
freedb Tagger 0.6.4
foo_input_monkey.dll (2012-02-18 20:01:21 UTC)
Monkey's Audio Decoder 2.1.5
foo_input_shorten.dll (2012-02-18 20:01:21 UTC)
Shorten decoder 0.4.2.2
foo_input_std.dll (2012-02-04 13:05:10 UTC)
Standard Input Array 1.0
foo_keep_queue.dll (2012-03-02 03:55:28 UTC)
Keep Queue 0.3.5
foo_masstag.dll (2012-02-18 20:01:21 UTC)
Masstagger 1.8.4
foo_musicbrainz.dll (2012-03-02 03:55:37 UTC)
MusicBrainz Tagger 0.3 beta 2
foo_playcount.dll (2012-02-18 20:01:21 UTC)
Playback Statistics 3.0.2
foo_queuecontents.dll (2012-03-14 20:09:57 UTC)
foo_quicksearch.dll (2012-02-18 20:01:21 UTC)
Quick Search Toolbar 3.2
foo_rgscan.dll (2012-02-04 13:03:48 UTC)
ReplayGain Scanner 2.1.2
foo_run.dll (2012-02-18 20:01:21 UTC)
Run services 0.3.7
foo_runcmd.dll (2012-02-18 20:01:21 UTC)
Run Command 1.1
foo_skip.dll (2012-02-18 20:01:21 UTC)
Skip Track 1.7.4
foo_ui_columns.dll (2012-02-18 20:01:21 UTC)
Columns UI 0.3.8.8
foo_ui_std.dll (2012-02-04 13:04:08 UTC)
Default User Interface 0.9.5
foo_uie_albumlist.dll (2012-02-18 20:01:21 UTC)
Album list panel 0.3.5
foo_uie_biography.dll (2012-02-18 20:01:38 UTC)
Biography View 0.4.2.4
foo_uie_console.dll (2012-02-18 20:01:21 UTC)
Console panel 0.4
foo_uie_elplaylist.dll (2012-02-18 20:01:38 UTC)
ELPlaylist 0.6.9.1.2(beta)
foo_uie_esplaylist.dll (2012-02-18 20:01:38 UTC)
EsPlaylist 0.1.3.9
foo_uie_library_tree.dll (2012-02-18 20:01:38 UTC)
Library Tree 0.3.4.6
foo_uie_lyrics3.dll (2012-04-24 20:32:23 UTC)
Lyric Show Panel 3 0.3.2
foo_uie_panel_splitter.dll (2012-02-18 20:01:38 UTC)
Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_playlists_dropdown.dll (2012-02-18 20:01:21 UTC)
Playlists Dropdown 0.7.6
foo_uie_wsh_panel_mod.dll (2012-04-24 08:36:03 UTC)
WSH Panel Mod 1.5.3.1
foo_utils.dll (2012-02-18 20:01:38 UTC)
Playlist Tools 0.6.2 beta 6
foo_vis_shpeck.dll (2012-02-18 20:01:38 UTC)
Shpeck - Winamp vis plugins wrapper 0.3.7
foo_whatsnew.dll (2012-02-18 20:01:21 UTC)
Feature Watcher 1.0.7
I have build myself a nice but HUMONGOUS pss CUI. Over 200 splitters in it.
WSH MODs:
In this i am using some of marc2003's samples (Autoplaylist, his LastFM-Scripts and Thumbs) your own Coverflow & this nice new Playlist, all without major adjustments on my side,
and i modded a sample Seekbar + your own (old) Round-Volume Knob. I only made visual changes, no real codehacks.
(+ i have different themed versions of each panel, so a lot of WSH panels. Some have 6 versions, nite/day x3 automatic color-accent modes.)
I've tempered a bit with marc's preproccessor, but only some custom path and again appearance stuff, never expierenced any problems with it. My foobar runs 12-16h-a-day, and has been flawwless for ages.
PROBLEMATIC COMPONENTS: (see component list in codebox to see them all)
Furthermore on the side of 'not recommended' components, aside from the Panel Stacker Splitters I am also using a bunch of Es-playlists. Ssenna also provides me with Library Tree and the Biography panel.
I know these have to name to be unstable but they don't give me any problems if i take account of stuff that make them unstable (like handling my large library)
You can also see EL, but this config isn't using it at this moment.
LIBRARY:
As mentioned before I also have a rather big Media Library +/-2TB atm. Thx to Marc's WSH-Autoplaylists i recently been able to reduce my playlistfolder from 1gig+ to roundabout 200MB, wich is very reasonable imo. In total i have 70 playlists (has been +350), all autosorted, most by %path_sort%.
PLAYBACK:
I use foobar as a private inhouse radiostation. So playback order is always on Random.
The autoplaylist give me the right mood by filtering by category, genre and style. The right tracks come by rating, playcount and lastplay filters.
On top of that there is a skip script running for additional filtering.
TESTING:
I have no real testsetup where i can test what is goin' wrong. Been to much absorbed by my own config and all kind of side-configs that i kind of lost control.
Restarting foobar can be a real pain. It takes 10-15mins before my library is completetly initialized.
I've been struggling with my mammoth library and should configure myself a lighter library for this purpose... to begin with...
I really like your scripts so i don't mind putting a little effort in it myself, glad to be able to help a bit by testing.
Okee, i hope this provides you with some useable info, i am goin to provide my with some fresh coffee..
/edit, forgot about the queue. No tracks queued.
thank you for the reply
you told previously "skipping track #2 .... then crash on track #3" ==> i see you have foo_skip component, is it this kind of skip you're talking about ? it's a clue for me, i'll test track skipping with this foo_skip component to check if my script handle well this kind of feature...
more news asap ... i'm going to prepare more coffee
Yup, foo_skip. Can't live without it. As addicting as coffee. ^^
Atm i use:
(%rating% LESS 3) OR (((%rating% LESS 4) AND (((%play_count% GREATER 5) AND (%last_played% DURING LAST 39 WEEKS)) OR ((%play_count% GREATER 4) AND (%last_played% DURING LAST 26 WEEKS)) OR ((%play_count% GREATER 3) AND (%last_played% DURING LAST 13 WEEKS)))) OR ((%rating% LESS 5) AND (((%play_count% GREATER 14) AND (%last_played% DURING LAST 13 WEEKS)) OR ((%play_count% GREATER 11) AND (%last_played% DURING LAST 8 WEEKS)) OR ((%play_count% GREATER 9) AND (%last_played% DURING LAST 4 WEEKS)))) OR ((%rating% IS 5) AND (((%play_count% GREATER 19) AND (%last_played% DURING LAST 4 WEEKS)) OR ((%play_count% GREATER 15) AND (%last_played% DURING LAST 2 WEEKS)) OR ((%play_count% GREATER 11) AND (%last_played% DURING LAST 7 DAYS)))))
as skip setting.
autoplaylistsnow you can specify "force sort" on a per playlist basis (the old version had a global setting which affected all playlists)
IMPORTANT NOTE FOR EXISTING USERS WITH MULTIPLE PANELS/SAVE FILESthere are now 8 slots which you can choose from the context menu. this has nothing do with how many autoplaylist queries that can be saved per panel - i'm sure it can far exceed any number you can think of.
you need to take some steps to rename the files. with foobar not running, browse your foobar2000 profile and then the
wsh_settings folder. all files begin with "autoplaylists". number these between 1 and 8 with no spaces like this.
autoplaylists1
autoplaylists8
@Mod-Ular or someone who encoutered such crash ...
beta 7.3 uploaded, it's a version based on beta6 that do not include the playlist queue content feature, could you test it please, that could help me... thanx
EDIT: if problem still present, a cool thing from you would be to test the playlist in your config without any other WSH panel script, this wouls assure me that the problem is not due to a memory overflow caused by another wsh script, so if you could make a copy of your config, and for each wsh panel mod (except playlist), reset it to the default or just clear its script... Would be great to do because i've already encoutered a such issue in the past with another wsh panel mod that has nothing to do with playlist, but has a bad handle of timers or using old methods outdated....
Hmm, Falstaff okee.
I loaded last version. Let it play for 15 mins while i did the dishes. No errors so far
Gonna restart foobar after a few more songs, btw skipping goes fine, always did before the error surfaced.
If i get the error i'll save my config as is and start removing the WSH-mod panels (most supicious 1st, my own seekbar and volumeknob hacks, i updated the timing methods myself, so they are very prown for errors.. You might be right with you're intuition on the issue.
I 'll remove them all if needed but gonna do it step by step so it might take some time.
I'll report back as soon as i get some results.
*waits* but sounds already good
list.item[...].id' is null or not an object File: <main> Ln: 1678, Col: 3
Gonna start dumping all other WSH-panels
@Mod-Ular: sorry about that, i hope it will help ... something specific to your config is in fault ... another option is that you zip me your config, that could help me if i could reproduce the crash to find the source of the problem. as you want.
@everyone: WSH CoverFlow View v1.1 released, minor changes but better version than v1.0 >>> http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
It is very possible that my seekbar or volumeknob have some problem.
Somehow i hope the problems can be eliminated be removing my WSH stuff.
Zipping my config ain't gonna be a simple solution as i never coded it to be useable elsewhere. (Read my config probably is heavily gonna search paths it cannot find and criple foobars efficiency)
It's a standalone setup so that part is easy. But nevertheless gonna be one big file due to all my images (backgrounds 200+, and loads of selfmade icons, for almost everything) I can prepare it a bit, but hope we can avoid that. (All my slick graphics in your hands can be dangerous for the foobar community ^^)
Removed my seekbar and still get the same error, same situation, startup ok, 1st playback okee, 2nd playback ERROR (no skip this time)
WSH Removal Stage 1 complete. It was not my seekbar.
Removing the old volumeknob is next.
not sure that images à required, just the components and the configuration folder should be enough for me, shouldn't be so big ...
Testing without my volumeknob atm. That should eliminate all 'clumsy' n00b-WSH-scripts, the rest is clean stuff from you or marc2003, so i am afraid they're not gonna make a big difference.
'list.item[...].id' is null or not an object File: <main> Ln: 1678, Col: 3
I think further removal of all the WSH-panels is not gonna solve it as those scripts should be fine. What do you think? Just do it, or start prepping my config to send?
I thought u needed my complete setup. Total foo folder is 'round 200MB zipped. Database.dat is 80 MB But yeah noprob. I'm not afraid of sharing my artwork, that is no prob, but really component and config folders are enough? Just tell me what u need and i'll send you my setup.
/quickedit, BTW i noticed the script doesn't crash when i load it from scratch in a default WSHmod-panel. IT only crashes AFTER a startup on the 2nd track that plays.
@Mod-Ular, to rule out other scripts/components, i'd install another copy of foobar in portable mode.
copy configuration and playlist folders from your existing install.
i'd also install foo_playcount and foo_skip so your autoplaylists still work.
also copy database.dat and whatever file contains foo_playcount data (index-data folder i think??)
now add a WSH panel in default UI and see if you still get errors.
Hmm, Marc good Idea. Thx
But now i know my own WSH-mods aren't causing this error, so at least i am not guilty of wasting falstaffs time due to my own bad coding
i don't know if it's another wsh panel mod that can be interact badly, or another component, for me the only way to find what's wrong with my script and your config, is to remove panels/components one by one and test it each time. As said, i don't need your database or playlist files, just the content of the components folder and the contents of the configuration folder. not so big
Falstaff, I followed Marc's advice and set up a fresh standalone install. Basic DUI just added a console and WSH-panel with your playlist. No errors so far.
/edit If this gives an error i can send you this basic setup. Otherwise no prob to send my own setup but that might take a bit more time.
/edit bis. Sorry for my slowness, indeed comp, user-comp and config folder are just 7.12MB, i can send them very quickly if you want.
/last edit: Falstafff i send you a PM to get my zip in your hands. So far i get no errors in the simple DUI config, so yes step by step removing and excluding things seems to only way to go. A tedious job if you ask me (i've had enough for the moment) I you feel up to it, you're welcome to bore yourself with my config. But please don't do it if you want to get it working just for me. Only put your time into it if you want your script to work everywhere (including here) ^^
reloaded my own config a while ago and guess what: no more errors...
PM just answered (was gone a while)
As said above all of a sudden i am unable to reproduce the error. Even with the setup that triggered it before. I'll keep you informed if it re-appears but for now it seems to 'solved' in a non-logical way.
/edit doublepost
yep, done too quickly, i'll fix that translation, thank you
Hello.
This panel is really an interesting tool, however it's hard to get started writing own script.
I've never scripted for WSH before. I have a basic understanding of JavaScript and a small experience with other languages. I had hoped reading the documentation and looking at some smaples would be enough to get started, but i'm having some issues and would like some clarifications.
- In many samples, i've seen only functions and variables declarations. In normal JavaScript, functions are not called just by declaring them, they need to be called by the code somewhere. I havn't seen this in those samples. However i've seen various functions with names like on_something. Those are listed in the callbacks help file. Does it mean functions with those names will be automatically run when some events occur in foobar, without the need to link those functions to user actions?
- Is there any syntax list for the foobar objects? Interfaces lists a small number of objects (window - IFbWindow // gdi - IGdiUtils // fb - IFbUtils // utils - IWSHUtils // plman - IFbPlaylistManager) so i understand if i want to know the paused (or not) status i need to read the fb.IsPaused property. But what if i want to access an interface that is not linked to an object, let's say "IFbTooltip". Can i access those using object statements with the name of the interface directly (like, say IFbTooltip.Activate() )
- Does fooWSH have access otherl windows objects such as FileSystemObject ?
- How do i declare an option to appear in the properties window of the panel?
1) yes
2) at the start of the script...
var myvar = window.CreateTooltip();
then you typically use it within the on_mouse_move callback
myvar.Text = "blah blah";
myvar.Activate();
3) yes. i use all these...
var WshShell = new ActiveXObject("WScript.Shell");
var fso = new ActiveXObject("Scripting.FileSystemObject");
var xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
var doc = new ActiveXObject("htmlfile");
var vb = new ActiveXObject("ScriptControl");
you need to disable "safe mode" under file>preferences>tools>wsh panel mod for them to work.
4) look at window.GetProperty and window.SetProperty
Thanks. I think i'll be able to better understand the examples now that i'll stop searching for function call statements
Just one more precision.
Thanks for the example. If i got it right, any of the interfaces that's not in the "big 5" needs to be created as a new object first, by calling a method that's inside one of the "big 5"
@ Falstaff
Is there a way to change the sorting of albums in your coverflow script? I like having albums sorted by date rather than title. I tried changing user.Group KEY setting as it was set to %albumartist%%album% and this was the way they were sorted but this didn't work.
@r0k
group key is the way tracks will be grouped, not sorted !
the coverflow panel has no sort option, because it's a panel that is for me in an add-on of a playlist viewer. So just sort your playlist or even without any playlist viewer, you can sort by using foobar2000 menu EDIT>Sort
if sorting pattern need to be adapted to your needs (those from File>Edit>Sort), you can modify them in foobar2000 File>Preferences>Advanced>Display>Standard Sort Pattern field
so, you can sort how you want, and group how you want too (that point you find it alone in Properties of the Coverflow panel)
I got some more indications Falstaff,
The crash re-occured but now i know i little bit more.
It ONLY happens after a fresh foobar startup. Doesn't matter if it's restarted in foobar or closed and re-started. Fresh boot, fresh windows login, all the same.
It does NOT happen after a fresh foobar start if i open the properties or configuration dialog of your playlist and hit OK (thus re-apply all settings?) before playback.
It does NOT happen if i use another standalone foobar before a fresh foobar start with my own config.
It does NOT happen if i've reloaded-renamed-re-imported a random or my own CUI-(pss-)config.
I recently noticed a very irritating stroboscope-like flickering when i load my setup. This could be just related to foo_uie_panel_splitter havin' some trouble reading my enormous stack. But sometimes its clearly just the WSHmod panels that go epileptic. Even without my own noobishly modded WSH-scripts. But i really suspect panelstacksplitter in bein the trigger for this behavior.
And i also suspect foo_uie_esplaylist from having some (or more) memoryleaks. (If i enable Browse Library my RAM thinks its getting free beer)
BTW, got another one for you
[14:21:11] Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 7.3 v0.0.7.20120426.1900 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): (http://br3tt.deviantart.com):) Microsoft JScript runtime error:
Object expected File: <main> Ln: 2541, Col: 5 <source text only available at compile time>
This happened after updating my interface with an pss-button (no commands just an imagebutton with the REFRESH option)
The effect achieved is that all splitters are hidden/rescaled/reshown and so refreshing all the scripts they contain.
I've done this a zillion times without any problems (while using your playlist)
But this time i did queue-up some tracks, within your playlist. (via contextmenu)
The tracks played like they should. On the last queued track before trackchange to the next (end of queue so in my usercase a) random track i did the 'Refresh'.
You're script halted on opening the next track. Not been able to reproduce. Tried several times witth the same procedure and some slight variations.
thank you for all these informations, i ain't tested your config, i will asap, but no time for now, maybe next tuesday, i'll give you feedback about my investigations!
The issue is that edit->sort needs to be re-done each time the playlist is refreshed as it's not memorized by the playlist. At least i didn't found a way to have the Library Selection playlist remember sorting options (even playlist attributes does not help for sorting).
I'm using Coverflow as the final selection step after filtering my collection with Facets. I have Facets set to send selection to Library Selection and coverflow locked on Library Selection. Works great except for sorting.
What do you mean by
File>Edit>Sort? Do you mean the patterns from
Edit>Sort? There is no Edit submenu in my File menu. (i have foobar2000 v1.1.11)
EDIT : Found this method
SortByFormat(playlistIndex, pattern, selOnly = false) in
IFbPlaylistManager interface. I guess that's what i need to add some sorting if i can't find a built-in way to sort Library Selection playlist. Modding your Coverflow will be one of my first real exercises in JScript coding if you don't mind
@Falstaff Take your time, there is nothing urgent about it. I'm just trying to keep you informed and hopefully avoid some work on your bughunt:)
Meanwhile, i had the last one again. Microsoft JScript runtime error: Object expected File: <main> Ln: 2541, Col: 5 <source text only available at compile time>
Did nothing special, foobar playing in the background while surfing a bit.
LOL sorry, this error is a "true" bug, my fault on beta 7.3, so try to
install again beta 7.3 from here !! this bug has nothing to do with previous ones, still a mistery from now !!!!
http://pastebin.com/Cj94ZBWE (http://pastebin.com/Cj94ZBWE)
EDIT: testing your config (you're mad, you know!!) , but not crash for me
Thx, updated.
Yup, i know i'm mad. Even got an official certificate for it. ^^
@r0k
(http://i.imgur.com/F8qh9.png)
of course you can mod the coverflow panel to fit your needs
OK. That's the sort i used. As you wrote File>Edit>Sort i was unsure whether there was a hidden submenu somewhere. foobar2000 is the sort of programs where you can find new functions even after using it for a long time (and i havn't used it for such a long time actually).
funny you should say that.... you can find many more commands on the menus if you hold down the shift key before clicking.
WSH Playlist Viewer v2 beta 8: http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
* bug fixes (cursor ain't follow focus on selection change in another panel (e.g. Coverflow))
* playlist for the queue Removed for now (not reliable engough for now, will be back later)
* 2 new sort presets (by date & by genre)
Hey, Falstaff.
I find bug in WSH Playlist Viewer v. 2 beta 8:
Select autoplaylist created with option "Force-sorted". In this case the order of sorting is determined in the stage of the creation of playlist and cannot be changed.
That is right for "Playlist view", "ESplaylist", "Simplaylist" panels. But when I use WSH Playlist Viewer, sorting playlist is available. That is wrong.
@ pIv, It's not a bug, it's a feature?
I think Falstaff has put a lot of effort in making it possible. BTW forcesorted autoplaylist can also be re-arranged by the ES-playlist aside from the default foobar fixed order. (It doesn't affect the actual order of the playlist contents, but reorders the "display order".) Don't how Falstaffs pulls this trick but to me it's really an enhancement of default foobar behavior.
+1
This is very bad feature!
Usually I create random selection from my library. When any song played it removed from playlist. Then I use second autoplaylist "Last 3 days". In it I can see all song played in revers order from the beginning to the end of this period.
I do not want even so that this autoplaylist would sorted out as a result negligent use by menu of sorting.
It is possible whether to hide the points of sort menu in this case, or at least ask me about this?
Aha, you got a little point there.
Not that it is a bad feature, it's a great feature, but it would be greater if you could exlude some playlist that needs a fixed order.
Would indeed be better for historical stuff like:
Played during last Day
More than a Year Ago
i think it's a limitation of the WSH panel mod component that you can't detect whether an autoplaylist is force sorted or not. it would need to be added as a new feature.
I'd like to be able to create a button that disables/enables the audioscrobbler component (foo_audioscrobbler I think), however the component doesn't have any main menu commands, the only way to disable/enable it is from its preferences page.
Would it be possible for disable/enable methods (and ideally a flag for retrieving the current state) to be added to WSH panel mod, or would this require modification of the audioscrobbler component beforehand/instead?
@ rawny
Maybe it is possible to directly popup Preferences>Tools\Audioscrobbler with a button or shortcut. But i know nothing of the developper side of this. The only popupscreens that do this have a normal main menu command (like: Library/Configure)
It should be possible to button everything you can find under "Preferences>Keyboard Shortcuts>Action" Aside from main menu commands there are also a lot of context commands to discover in that section. But as you stated yourself there are none for audioscrobbler.
Isn't it more logical for Florian Heidenreich (foo_audioscrobbler dev) to provide them?..
And if it really should be done trough WSH-mod you could ask T.P. Wang himself in the component thread? But i think it isn't his task to solve other components shortcomings...
/edit, quick spellcheck
@ falstaff
As i declared in last PM i had no crashes with WSH Playlist v2 beta 8. I presume thas was because you disabled the queueplaylist like you told.
I am now running the last (not yet released here, but online) version and, If you re-implemented the disabled part Then i can confirm the bug is gone (can not reproduce).
But it's not really clear to me. What do you mean with "playlist for the queue" ?
I don't see any new playlist show up in my standard playlist switcher panel,
so if you mean the green queueindex indicator that appears instead of the tracknumber, i still had those in v2b8 Working perfectly
No errors for me since v2b8. I almost can't wait for a final so i can start tweaking it for my insane UI.
Great work, once again.
/edit: semantics
@Mod-Ular
green queue index wasn't the only feature around queue adds in my script! there was an entry in the settings menu (from the toolbar) to create or show a special playlist named 'queue content ' that contained only the queued tracks, that's what i've removed
@mod-ular: Yeah it is possible to open the preferences page for audioscrobbler via button/keyboard shortcut etc. which is a little quicker for enabling/disabling it.
I agree that it would be logical for Florian to provide main menu commands for audioscrobbler as opposed to T.P. providing them, yes, (and if they existed then I could create the button I want ) but that wasn't what I was trying to say. My question was really whether Florian would need to add anything to the foo_audioscrobbler component before T.P. can expose it's enabled/disabled state as an interface property, e.g. fb.AudioscrobblerEnabled. I believe that each property has to be exposed manually by T.P. as otherwise fb.StopAfterCurrent would have been part of the interface from the beginning.
given that foo_audioscrobbler hasn't been updated for nearly 2 years, i wouldn't hold your breath. simply adding a menu command wouldn't be enough either. you'd need a callback to detect when the setting has changed. this would mean an SDK for foo_audioscrobbler would have to be released AND it would then have to be implemented in WSH panel mod. in short, not very likely.
there are various ways you get foo_audioscrobbler not to scrobble your music. i personally have it set to scrobble only music in my library. for most people this is enough as they can rip/download music, listen to it without scrobbling before deciding whether it's good enough to become part of their main library.
also, you can use the field-remapping options in the preferences. through title formatting, you could set the artist to be blank for tracks with a rating of 1. eg
$ifequal(%rating%,1,,[%artist%])
tracks with a rating of 1 won't get submitted because there is no artist specified. you can adapt this with any title formatting you like.
WSH Playlist Viewer v2 beta 8.2: http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
* bug fixes
@marc2003: Ah, I hadn't thought about the callback (although I suppose it would be possible to make a non-intelligent toggle button without it).
Yeah I already have it set to only scrobble music in my library but my library contains some stuff that shouldn't really be in my library It's in there mostly because it's easier to manage as it's making its way into the library (i.e. I'm tagging it). I guess I could make it do some %path% matching to determine whether to scrobble, which might alleviate my need to enable/disable audioscrobbler in most cases. Cheers for the fresh angle
@rawny I didn't know you could popup audioscrobblers preferences, but i knew it should be possible and only one mouseclick away from what you want.
I gotta check it out soon because i also use lastFM and love making buttons myself (Two mouseclicks is acceptable within my personal 'user-ergonomic' rules ^^)
@marc2003, nice trick, once again.. I just delete misscrobbled track on lastfm. (This has the advantage you can flipflop bad decisions by undeleting (http://playground.last.fm/demo/undelete).
@falstaff, upgraded to v2b8.2, still no errors,
but as mentioned before, still some broken features in the toolbars rightside menu.
- Sorting doesn't work for me (it did work when i checked it in v2b7-something).
- I see no blue indicator-dot that pre-b8 showed-up in the goup/order menu.
- Another strange thing is that i started losing mousescroll capabilities in all my panels. (Happened 2 times).
Not reproduceable but also occurs since v2b7.3+. I am not saying its your script that blocks mousescrolling, it's just something i thought was worth reporting.
could you give details? sort or group/sort or both ? are you sure of that, just tested all, and they works, try to randomize playlist before to be sure that nothing is sorted, and could you tell wich preset seems broken and what does it do really?
normal i've removed this indicator which has no sense because it wasn't binded to a playlist but was just a general indicator, so if you sort a group a playlist with a group present, then if you switch to another playlist with another group preset, it keeps with the last used, so that wasn't logic to display it.
this looks like a timer overflow in another wsh panel that freeze all other timers used in all others wsh panels. You must have a wsh panel that doesn't handle correctly timer objects (issue already encourtered for me with my wsh seekbar in my config slate. e.g. timers was never cleared on track chang ...)
so, that's not the playlist script in cause.
1. Sort doesn't re-order the playlist. Yes i tried Randomize and Reverse first. None of the presets reorder the list. Group/Sort doesn't reorder either, but it does give the different groupheaders.
CORRECTION: But only on FORCE-SORTED autoplaylists. This got me confused If i disable the force-sorted checkbox for the active autoplaylist it DOES work perfectly.
But what were pIv and marc2003 talkin' about then?
2. Okee, that makes sense.
3. Okee, i'll try to get that fixed if i can find the cause. Clean code is euhm.. clean? But it's not a big problem as it does not happen often & refreshing solves it.
1. sure!! force sorted feature on autoplaylist, as naled, force the sort order, so no other can be applied if it's enabled, logic. so all is ok.
3. hard to find where is the bug (which other panel), but if you use timers in your wsh seekbar panels, i'd start from here
WSH Playlist Viewer v2 beta 9: http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
What's new in beta9:
- columns options added (play icon, tracknumber)
- CTRL+C and CTRL+V now supported to copy/paste tracks from a playlist to another (e.g.)
- come back of the Queue Playlist feature!
- little bug fixed for the display of the year when tag %date% is not to the format YYYY-MM-DD but YYYY/MM/DD or YYYY.MM.DD
- tweaks
While editing in a 'WSH Panel Mod Configuration' window, how do I activate the auto-dropdown list of functions when a trigger key is pressed
such as the "F" key, which should cause the fb.xxxxxxx functions drop-down list to activate next to the cursor.
In my latest foobar2000 layout, the drop-down feature is not activating !!
I started an archived foobar2000 installation on my hard drive (with WSH Panel Mod 1.4.2) and the drop-down feature works.
looks like the interface.api and jscript.api files are missing from your component folder.
if you installed the component via the proper methods, this wouldn't happen.
marc, thanks for answering.
In my current foobar2000, I have WSH Panel Mod files placed like so:
...\foobar2000\user-components\foo_uie_wsh_panel_mod\foo_uie_wsh_panel_mod.dll
...\foobar2000\user-components\foo_uie_wsh_panel_mod\interface.api
...\foobar2000\user-components\foo_uie_wsh_panel_mod\jscript.api
As I far as I know, my file placement is correct.
Does anybody here have more answers ?
file>preferences>tools>wsh panel mod>editor properties
check the value of
api.jscript
$(dir.component)jscript.api;$(dir.component)interface.api
edit: i assume your files were in the correct place before i mentioned it. if you put them there manually, you'll probably need to restart.
Preferences are exactly like yours marc; so no problem there.
Any more answers?
Hi again,
I'm trying to display the bitrate for the now playing track and would like it to change dynamically for VBR tracks. I'm trying to use the following code, but for some reason it doesn't update as the track plays. I'm not sure why it's not working - I thought that
on_playback_dynamic_info() should cover the updating of the display when the bitrate changes. Anyone got any pointers?
function RGB(r, g, b) {
var bitrateTF = fb.TitleFormat("%bitrate%' kbit/s'");
var textFont = gdi.Font("Tahoma", 10, 1);
var textColour = RGB(255, 255, 255);
if (fb.IsPlaying){
update();
function on_size() {
ww = window.Width;
wh = window.Height;
function update() {
g_metadb = fb.GetNowPlaying();
if (!g_metadb) return;
bitrate = bitrateTF.EvalWithMetadb(g_metadb);
window.Repaint();
gr.FillSolidRect(0, 0, ww, wh, RGB(0,0,0));
gr.GdiDrawText(bitrate, textFont, textColour, 0, 0, ww, wh);
function on_playback_dynamic_info() {
update();
function on_playback_dynamic_info_track() {
update();
to make it work you have to eval the TF with true, just by testing if a track is playing... here is the fix (note: bitrate wasn't declared as global ==> added too)
var bitrate;
if (fb.IsPlaying){
update();
ww = window.Width;
wh = window.Height;
function update() {
if (fb.IsPlaying) bitrate = bitrateTF.Eval(true);
window.Repaint();
update();
update();
Using WSH Playlist Viewer Beta 9. I have the playlist, album list and album art viewer all visible. Start playing a FLAC file and correct cover art is visible in album art viewer. Highlight a different FLAC file in album list and the cover art for that file is now visible. Click back on FLAC that is playing and cover art does not change back. With ES Playlist cover art changes back to the playing FLAC cover art. It is like a disconnect with WSH Playlist Viewer after highlighting a file in album list. Not sure if that is how it has to work.
sorry but it's not really clear ...
ok, art viewer, so not my wsh playlist... let's go next
why you say "now" wasn't ok before in playlist? "visible", where ? in art viewer or playlist or both ?
what do you mean by "Click back on" ? could you explain on what you click please, and when you said "cover art does not change back, yu mean in playlist or art viewer ?
*waits for details and answers*
thanks by advance
Sweet that fixed it and I missed bitrate being a global when I converted it to a simpler example
It may be worth mentioning that I had to change the
on_paint function to the following:
if (fb.IsPlaying) {
And I also had to add a call to the
update function from an
on_playback_stop handler.
Cheers for the help
WSH CoverFlow v1.2: http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
- cover placement enhanced by adding a toolbar (like my in my WSH playlist viewer)
- tweaks
(http://i.imgur.com/CVfrX.jpg)
- tweaks
I would love to be able to use this, but it massively lags foobar when I try and scroll through the album art (even if I just scroll one cover either direction). I reduced the size of the panel which helped but it's still laggy enough to disrupt the audio as the cover changes
It may well just be a side-effect of the fact I'm running foobar under WINE, but I was wondering if anyone might have any ideas on reducing the lag in any way. No worries if not.
@rawny:
running it under linux is for sure not a benefit for performances... you can still try to disable all effects like glass effect, scroll transition ...
but i don't think it's made for the use you make, try it under windows and you'll see the difference
EDIT: ...my script may lag too under Android with a virtualized windows partition
@Falstaff:
Hehe well I'm not running Linux (Ubuntu specifically) to try and get good performance from your coverflow, I'm just trying to see if I can achieve better performance in the Ubuntu that I was already running
(And I know that this will inevitably have a bottleneck and I'll probably not be able to use it. I wanted to try and push it anyway just in case it is usable - 'cause I would love to have a coverflow if possible )
How do I disable said effects? Should I just look for them in the code and comment them out?
Edit: I found the window.getProperty part in the code and changed all the graphics related-ones (reflection, focus rectangle, glass, scroll animation) to return false straight off (and I changed flat style to true) and it's reduced the lag a fair bit. It still lags a tad but it's nowhere near as bad as it was.
WSH Playlist 9. Sorry, that was clear as mud. I have the cover art turned off in WSH Playlist. I strictly view cover art in the Album Art Viewer as I like to view it a little larger. On the left top is the album list, left bottom is the album art viewer, and on the right is WSH playlist. It looks really nice thanks to you.
If I start a FLAC file playing, the details are in the WSH playlist (right), and the correct cover art is in the foobar2000 art viewer (lower left). If I click, without actually starting playback, on another FLAC file in the album list (upper left), the album art changes to that file in album art viewer. Nothing changes in WSH playlist as cover art is turned off. Then I click back on a track actually playing in WSH playlist, and the cover art does not change to the playing FLAC cover. In ES playlist it does as I used that set up for a while. Thank you.
@marc2003, thanks very much for your "similar artists" WSH script and others. Concerning the "similar artists" script, I'd like to suggest a tweak or enhancement that is beyond my ability to code. Context: I use the "artist" tag to include all of the performers for a given song. Most of the time, it just contains a band name or the name of the person I consider the primary artist for the song, and everything integrates perfectly with your script. But for some songs I have multiple persons or bands in a single "artist" tag to reflect featured performers, ad-hoc ensembles, etc. In these cases, the "similar artist" script correctly searches for the string of the entire content of the "artist" tag and returns nothing.
To handle the cases where I have multiple artists in the "artist" tag, I'd like a way to manually enter which artist to search for in the "similar artist" script, perhaps from a context menu prepopulated with the current "artist" content so I can delete all but one artist for a search. I think a method of manual entry and override of the default action would be the most efficient way to meet this need, instead of trying to identify, parse, select, and search for multiple artists, but I certainly defer to you if there is an easier way to do it.
I think many others use the "artist" tag in a simlar manner and thus this tweak would be of use to many others as well, but if that assumption is incorrect then please let me know. Thanks again for your efforts!
you could replace %artist% on line95 with $meta(artist,0) and that would use the first artist.
changing the setting per artist isn't really feasible.
That will work well enough, and I can just change the zero to another number to select another artist. Thanks!
if you are going to tinker with that value for different artists, you might want to comment out line 123 as that will try to fetch updated info from last.fm if the stored data is more than 1 day old. obviously it would use the current setting and not whatever was used to fetch the original data.
2 Falstaff
If I want use coverflow panel for my media library now - I must create seperate playlist and load in it all song from media library.
It is possible in future use coverflow with media library without playlist with media library content?
2 Falstaff
actually not.
Maybe if T.P. Wang is kind enough to give us a new feature like GetLibraryItems then it would be possible.
updates!
WSH Playlist Viewer v2.0 (final)
WSH CoverFlow v1.4
* Scripts available at http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
* I have included them in a simple DefaultUI config (just a .fth to import), for those who are interested, get it at http://fav.me/d4z1j0w (http://fav.me/d4z1j0w)
samples updated: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
changes to news / reviews / blogs, now playing, thumbs and similar artists scripts only.
added artist field remapping option to context menu.
(http://dl.dropbox.com/u/22801321/dialog.png)
(simple biography already has this feature)
edit: added feature to news / reviews / blogs as well.
I have added mouse hover-seek popup info to my 'WSH volume control', but it has a small problem;
This is correct:
When I mouse click-drag-seek, the text display range in the 'WSH volume control' main window goes from -100dB at left end to 0dB at right end.
This is
NOT correct:
When I mouse hover-seek, the text display range in the 'WSH volume control' hover popup goes from
-287dB at left end to 0dB at right end.
Is anybody here familiar with the mathematics of the volume display?
Could you please review my code for the hover info function and tell me what is wrong.
Here is the relevant function (the problem lines are in red):
function on_mouse_move(x,y) {
window.SetCursor(32649);
if(g_drag) {
var v = x / window.Width;
v = (v<0) ? 0 : (v<1) ? v : 1;
v = 25 * Math.log(v+0.00001);
if(fb.Volume != v)
fb.Volume = v;
g_hover_seek = null;
g_hover_seek = x / window.Width;
g_hover_seek = (g_hover_seek<0) ? 0 : (g_hover_seek<1) ? g_hover_seek : 1;
g_hover_seek = 25 * Math.log(g_hover_seek+0.00001);
g_hover_seek = (Math.ceil(g_hover_seek)) + "dB";
g_hover = x + 4;
window.Repaint();
i'm not really sure what you're doing there???
i took the sample Volbar with GdiDrawText.txt and added hover tooltip support here....
http://pastebin.com/j2JNZHBA (http://pastebin.com/j2JNZHBA)
I tried out your code there marc.
As soon as my mouse entered hover coordinates, WSH Panel Mod crashed with error: Line 39, Column 9, Object doesn't support property or method.
So I commented out line 39 and tried again.
As soon as my mouse entered hover coordinates, WSH Panel Mod crashed with error: Line 47, Column 9, Object doesn't support property or method.
I am using WSH Panel Mod version 1.4.3 .
I refuse to upgrade to newer versions because my WSH auto-cycling Artwork Viewer doesn't work perfectly with newer versions .
The function code I posted before works perfectly except for the mathematical calculation of the decibel range for the tooltip.
The mathematics of 25 * Math.log(g_hover_seek+0.00001) gives the same scaling as the built-in foobar2000 volume slider (logarithmic).
Here is the full code posted online (it works perfect except for the tooltip info calculation error): http://textsnip.com/my/wsh_volume_control/jscript (http://textsnip.com/my/wsh_volume_control/jscript)
heh, i was using the linear example and it also uses new tooltip functions only found in 1.5.0+. yours doesn't use tooltips so your description is a bit misleading....
i'm not editing your whole script because it makes my head hurt but the main change is here....
if(g_drag && fb.Volume != v) fb.Volume = v;
window.Repaint();
i've removed "var v=..." because it needs to be global. v needs to be used as the hover text in on_paint.
Thanks for the help marc, but...
you've just cleaned up a subroutine which was already working (notwithsatnding the removal of "var v=...").
In fact, the "g_hover_seek" section –which you removed– was working too except for one small problem:
When moving the hovered mouse cursor to the extreme left position, the tooltip display should stop at -100dB; but it doesn't, it stops at -287dB.
Nothing else is wrong with my code; the dB display in the WSH window and the tooltip are syncing correctly when I hover seek all through '0db to -100dB';
except the dB display in the the tooltip continues to increase as I go left beyond -100dB.
The mathematics of "window width vs tooltip dB display" are wrong somewhere in my code; my code fully works.
Your final comment "v needs to be used as the hover text in on_paint." seems to be resolving the issue.
How exactly do I use v in on_paint? Do I have to declare "v" as a variable again at "on_paint(gr)", or is it called from your new "on_mouse_move(x,y)" subroutine.
well the maths is too much for my poor brain. but i did find some different code by fbuser. you could try it instead....
on_paint
pos = window.Width * Math.pow((100+fb.Volume)/100,2);
on_mouse_move
v = (v < 0) ? 0 : (v < 1) ? v : 1;
v = 100 * (Math.pow(v,1/2) - 1);
if (g_drag) fb.Volume = v;
v is the text string you want to use in on_paint
gr.GdiDrawText(v + "dB", g_font, RGB(255,255,255).....
This is too much for my poor brain too marc; I'm giving up.
For all intents and purposes the code works; one has to try very hard to actually notice the tooltip problem, it is that minor.
Thanks for the help +++
Hey,
If possible I would like to be able to get the IFbMetadbHandle for the item that will become the playing item when playback is started.
Let's imagine that I have a playlist containing tracks A, B and C and that I also have cursor follows playback and playback follows cursor disabled. I currently have track A selected and I'm actually playing track B. Then I hit stop and, after the playback stops, I restart foobar. When I hit play, track B will be played again.
I wish to get the IFbMetadbHandle for track B on start-up. So before playback is started and regardless of whether another track, such as A, is selected - is this possible and how?
Cheers
is there any way to get info from embedded cue in playlist?
@Falstaff
Using WSH Playlist Viewer 2.0. I have the Group Header set to 3 lines so tracks, codec, genre line shows. If the stream is WMA V2 then the codec shows as ? (question mark). Codec shows up okay in the status bar (codec & codec profile). MP3 and AAC look okay.
Is this just my computer? Also is it possible to have that line as black text instead of grey?
Thank you.
@amalone
have you and @ of WMA stream for me testing please?
@Falstaff
These 3 radios streams do it
mms://streaming.sbsradio.se/03872_Studio_low
mms://81.173.117.102/ArrowAudio01
mms://81.173.117.102/ArrowAudio02
Thank you.
Thanks, T.P. Wang.
I am wondering if there a way to change mp3 these tags by foobar?
ex. plman.SetPlaylistSelectionTag(target, val)
or XXX.SetProperty(name, val)
(http://img232.imageshack.us/img232/4981/tagss.jpg)
Is there anyone can help me?
Thank you!
look at UpdateFileInfoSimple in interfaces.txt
Wow, you are so fast.
Thank you for help.
I should remain "docs" folder in the past. XD
Is it can only be uses in one song at one time?
Can it be able to use in multi-song at one time?
you could loop through an array of items something like this...
items = plman.GetPlaylistSelectedItems(plman.ActivePlaylist);
for (i = 0; i < items.count; i++) {
items.item(i).UpdateFileInfoSimple("title", "test");
I've updated my vertical volume bar script so that the tooltip showing the volume will update while the mouse-wheel is being scrolled on the bar. Code below
// ==PREPROCESSOR==
// @name "Volume-bar with tooltip"
// @author "rawny"
// ==/PREPROCESSOR==
// Based somewhat on:
// -> "Volbar with GdiDrawText" by T.P Wang
// -> "Simple Seekbar" by marc2003
var a = 25;
var g_drag = 0;
var g_drag_seek = 0;
var g_tooltip = window.CreateTooltip();
var g_trackingMouse = false;
var old_x;
var old_y;
return (0xff000000 | (r << 16) | (g << 8) | (b));
function RGBA(r, g, b, a) {
return ((a << 24) | (r << 16) | (g << 8) | (b));
ww = window.Width;
wh = window.Height;
function on_paint(gr){
var ww = window.Width;
var wh = window.Height;
var pos = 0;
var volume = fb.Volume;
if(g_drag){
pos = wh * g_drag_seek;
}else{
pos = wh * Math.exp(fb.Volume/a);
gr.FillGradRect(0, wh-pos, ww, wh, 90, RGB(0,0,255), RGB(70,90,200));
gr.FillGradRect(0, 0, ww, wh-pos, 90, RGB(0,0,0), RGB(50,50,50));
gr.DrawRect(0,0, ww-1, wh-1, 1.0, RGB(100,100,100));
function on_mouse_move(x,y){
// Set the cursor to the hand symbol:
g_drag_seek = 1-y/wh;
g_drag_seek = (g_drag_seek<Math.exp(-100/a)) ? Math.exp(-100/a) : (g_drag_seek<1) ? g_drag_seek : 1;
if(x > ww){
g_drag = 0;
if(g_drag){
window.Repaint();
if(!g_trackingMouse){
g_tooltip.Activate();
g_tooltip.TrackActivate = true;
g_trackingMouse = true;
if(x != old_x || y != old_y){
txt = Math.ceil(a*Math.log(g_drag_seek))+"dB ("+Math.ceil(g_drag_seek*100)+"%)";
g_tooltip.Text = txt;
g_tooltip.TrackPosition(x+10,y-10);
old_x = x;
old_y = y;
function on_mouse_leave(){
g_tooltip.TrackActivate = false;
function on_mouse_lbtn_down(x,y){
g_drag = 1;
if(!g_drag){
return;
g_drag = 0;
var v = 1-y/wh;
v = (v<Math.exp(-100/a)) ? Math.exp(-100/a) : (v<1) ? v : 1;
fb.Volume = a*Math.log(v);
function on_mouse_wheel(delta){
if(delta>0){
fb.VolumeUp();
}else{
fb.VolumeDown();
g_tooltip.Text = Math.ceil(fb.Volume)+"db ("+Math.ceil((Math.exp(fb.Volume/a))*100)+"%)";
var ttY = wh-(wh * Math.exp(fb.Volume/a));
g_tooltip.TrackPosition(10, ttY-8);
function on_volume_change(val){
window.Repaint();
Thank you!
Can you tell me why GetPlaylistSelectedItems need to use count and item?
I have used following codes yesterday:
var items = plman.GetPlaylistSelectedItems(plman.ActivePlaylist);
for (i=0; i<items.length; i++) {
items[i].UpdateFileInfoSimple("title", "test");
But nothing happen.
from the docs...
interface IFbMetadbHandleList
Properties:
(readonly) uint Count;
// [1.5.0 Preview 6]: Changed, now writable.
(read, write) IFbMetadbHandle Item(idx);
from the docs...
Properties:
Thank you, and sorry for stupid questions.
I never learn programming language from teachers or books.
I even can't understand whole files in docs very well.
So, I'm very appreciate your teaching.
When I have other questions can I ask you by PM?
Thank you!
it's better to ask questions in this thread. other people can answer and also others can learn if they get stuck doing the same kind of thing.
Given a reference to a track (e.g. the currently playing track), is there any way to get an IFbMetadbHandleList of the group that it resides in within EsPlaylist?
Edit: I guess my best alternative option is to fake it by having the script create an autoplaylist based on the same query that forms the group. Unless anyone can think of any better ideas?
XD But my questions are very stupid, isn't it?
The new question is:
Can we change .txt or .lrc in WSH Panel Mod script?
I want to replace some words in .txt or .lrc files.
@Falstaff
WSH Playlist Viewer 2.0.1
Thanks for the awful nice item for DUI very nicely in the "se7en", but in XP selected mouse line has completely white background (I have a dark theme and it is very contrasting).
(http://savepic.net/2811464.png)
what part of the code, you can assign a color to the selected row?
@San_dr
you know there are options in my script? Just disable Themed style in settings! untick this menu item :
(http://i.imgur.com/dAuPg.png)
@San_dr
(http://savepic.net/2810443.png)
Now re-unpacked wsh_playlist_viewer_v2_0_1_by_br3tt-d4se96u.zip and applied the "pure" script. But no change. This may not be related to the settings XP? In the "7" gray highlighted line (with a black background). And I want to ask - in the properties panel, the first item *USER.background.image.enabled - True
Do I understand that you can add your background picture? I can not do it. Desired image background.jpg 800x600 placed in Foobar2000\images...
Thanks for the prompt
on your screenshot, "USe Themed Style" is ticked, so it's normal that you have a styled lined (white), so just untick it, and show me the result please, normally, no more white background line ==> ok?
i need to collect some statistics, so i need a kind of database. can i somehow connect with sql base or i can store data in text files without longer search time?
toSan_dr are you russian too?
San_dr[/b] are you russian too?
??,?????. ???????. ?????? http://foobar2000.0pk.ru/viewtopic.php?id=392 (http://foobar2000.0pk.ru/viewtopic.php?id=392) (Yes,
'romka18', Kharkov, come in)
When I try and rename my playlist tabs or sort the playlist, WSH mod crashes. Using foobar 1.1.11 wsh panel mod 1.5.3.1 any help would be appreciated
Might help to name/describe the scripts you are using, how many WSH panels you have open, which playlist components you are using etc.
for the crash on rename (i assumed you use my WSH tabbed playlist manager script), just untick (as usual) the "Safe Mode" option in WSH settings in foobar2000 Preferences pages!
for the crash issue on sort, if you talk about the search menu from my WSH playlist viewer, it should work except if you're not using the last version of WSH PAnel Mod which is 1.5.3.1, or you said you got it (verify please in Preferences> Components...), so thanx to give here more details or most of all the content of the console (error message + line number in error) ==> menu View>Console.
HTH
Hi again.
I have another issue trying to understand some examples. I'm looking at the sample scripts drawing buttons. Both the basic samples and those provided by marc2003 use the same constructor function. I'm clueless on this part :
this.draw = function (gr) {
if (this.state == ButtonStates.hide) return;
switch (this.state)
... <snip> ...
g_theme.DrawThemeBackground(gr, this.x, this.y, this.w, this.h);
gr.GdiDrawText(this.text, g_font, RGB(0,0,0), this.x, this.y, this.w, this.h, DT_CENTER| DT_VCENTER | DT_CALCRECT | DT_NOPREFIX);
The method defined here receives an argument called
gr and uses it as an argument to g_theme.DrawThemeBackground. However, whenever a <button>.draw method is called in any sample i've seen, the argument passed to it is also simply
gr. But nowhere i found a statement defining
gr I found a reference to gr in callbacks but it states it's invalid outside of two specific callbacks :
on_tooltip_custom_paint and
on_paint. Here it's used by drawAllButtons(gr) function.
Surely i'm missing something. I guess i could just copy-paste working scripts without wondering how they are working but this looks like a sure-way to big mistakes later on.
Also, there is also this
gr.GdiDrawText() method used in the sample. According to what i understood from the doc this method belongs to an
IGdiGraphics interface that fist has to be created by the method
GetGraphics() of an
IGdiBitmap interface, itself created by some methods of the "first-level" interfaces
window or
gdi. Again, i guess i missed something.
Can someone help me understand how this works?
HTH
Thanks, I've solved both problems. Loving the scripts!
I found a reference to gr in callbacks but it states it's invalid outside of two specific callbacks : on_tooltip_custom_paint and on_paint. Here it's used by drawAllButtons(gr) function.
drawAllButtons is just a function called from within on_paint. you can pass
gr to any other function you want.
as for your 2nd point, you don't reallly need to think about using GetGraphics. that's only for more complex tasks such as creating images from scratch. for displaying images frin disk or drawing text, using gr.GdiDrawText or gr.DrawImage is more than enough.
OK, i managed to find the original on_paint call. Sometimes it's hard to find where the original call lies when you did not write the script
This also means i can't use those methods outside of an on_paint call to e.g. repaint only one button rather than the whole panel. Is it an issue performance wise or am i again "over-thinking" the issue?
And something totally unrelated to those. Is there a way to update an auto-playlist query (from some jscript code i mean, not with the playlist properties pane) after it was created? Currently i'm removing the auto-playlist and then re-create it but the drawback is that a play-list view showing this auto-playlist won't update correctly and will be left empty.
I guess i could activate the playlist but i don't really like this approach as it tends to interfere with playback.
with more complex panels, it's more efficient to use window.repaintrect() where you can supply x, y, w and h. but for the example buttons scripts, the panels are likely be to be pretty small so it's ok to repaint the whole panel. also, if you look in the code in mouse move sections, the functions exit if nothing has changed. window.repaint only gets called if it needs to be.
and no, it's not to possible to directly edit an existing autoplaylist. removing and re-creating is the way i do it.
i have no idea what's going on there. it works perfectly fine for me.
Thanks for pointing this one. It will perfectly fit the toolbar object i'm building to hold buttons.
Well, the example script is just that. I already borrowed/stole the code and put it in a bigger panel, thus my question about performances.
I have a Playlist Tab splitter with NG Playlist on it (columns UI as you have guessed). When the tab for my auto-playlist is active, if i remove-create it to change the query, the playlist view is left empty until i switch to another tab and back.
I could probably work this around using two playlists, one normal and one auto but i would prefer to use only one.
There is no method to populate a non auto playlist directly from the library is there? I didn't found a way to get a metaDbHandlesList directly from the library or more precisely, I didn't found a way to select using jscript code items from the library so i can get handles with fb.GetSelections.
I could probably make a temporary autoplaylist to get the handles and then keep the metaDbHandleList object in memory rather than dispose of it after use but i'm not sure how big it can grow
if you only have one playlist active and remove/re-create it, then it makes sense to switch focus to it through the script. i can't see why you wouldn't want to do this.
I have several playlists. Some are autoplaylists and others are not. I don't like the idea of activating a playlist through the script because i noticed that when some components activate a playlist, playback will jump to that playlist after the current track finishes even thought there are still tracks on the currently playing playlist. This might have something to do with the obscure playing queue (i wish i could disable it completely) but as i'm not sure why this happens, i prefer not to "activate" playlists at all.
foobar2000 is great but the way playlists interact with each other and with the playing queue is kind of confusing.
That's why i'm (probably over-)cautious about playlist activation. I think i found a way of doing what i have in mind by storing metaHandles in an object. If what i understood of Falstaff coverflow script is right, he's keeping metaHandles in memory for it to work. If those are just what the name suggest, they shouldn't be that big.
You could disable the playback from following the cursor, which would prevent it following the change in playlists. You could either do this manually (via toggling the playback menu -> playback follows cursor) or from your script:
fb.PlaybackFollowCursor = false;
This could also be combined with having the script to store a reference to the playing playlist when it starts and then making sure that it sets that playlist as the active one once the script finishes everything else it's doing.
well that's not right. where playback goes after the current track has finished depends on what
playback follows cursor and
cursor follows playback settings you have on the main
playback menu.
edit: too slow.
Hehe, only just
Thanks both. Now i know what those settings do.
I always wondered what my mouse cursor had to do with playback
I have both un-set by default so i guess the issue came from some component or script overwriting them.
similar artists has been merged into a new panel which can fetch more feeds. as always, use the mouse wheel to scroll and the text is clickable taking you to pages on the last.fm website...
(http://dl.dropbox.com/u/22801321/new%20lastfm%20panel.png)
Falstaff, VU-meter specifically for your style
(http://savepic.net/2852121.png)
@San_dr
hmm, i'm not conviced by its style ... but thank you
take care, you are off topic here, this had to be placed in the VU Meter topic : http://www.hydrogenaudio.org/forums/index....c=33939&hl= (http://www.hydrogenaudio.org/forums/index.php?showtopic=33939&hl=)
new script: musicbrainz releases
-like romor's script, it will use MUSICBRAINZ_ARTISTID if it exists in your tags, otherwise it will do a simple text match
-click the text to open the musicbrainz website which will give more details
-unlike romor's script, there is no pagination because i'm lazy. i've countered this slightly by using release-group instead of release so there shouldn't be as many results.
IMPORTANT: existing users of my scripts need to extract the marc2003 folder again.
Your last update(s) are looking great marc2003. A pitty, i've no time to play with them at the moment.
Been trying to understand the json-file you pull from lastfm in your other scripts as i was planning on constructing something similar. No more need for that now by the looks of it.
I've no scripting skills higher than markuplanguage-abuse (aka. titleformatscript), but i've been reading/digging/gazing trough your scripts for some time now.
I've reached the stage in wich i can tweak some custom visual stuff and update things without crashes... & planning on really learning some jscript whenever i find the motivation (= time) for it.
It would make my foobar much more futureproof for sure.
Great work and a good job on sharing it, thanks.
(PS, Always found it a bit tricky to keep track of your 'samples.zip' versions. As they have no version indication at all a.f.a.i.k. I rename 'samples.zip' with a timestamp when i download them which helps a bit.
So last version(s) will be 12-05-22_marc2003_samples. (...and 12-05-23_marc2003_samples, you go fast, lol) Ever considered introducing some kind of versionnumbers?)
no.
perhaps i should but i never keep old work. i always overwrite everything thinking newer is better. dropbox keeps backups of recent changes for 30 days so that's enough to restore files if i make catastrophic changes and need to revert.
also:
-update to
musicbrainz releases just uploaded. there was a possibility the text would overlap with the date. also changed the scroll step from 1 to 3. oops...
-update to
news / reviews / blogs. the main title has been changed to make it consistent with all my other panels where it now follows
artist: description
Good idea, that is the way to go, I updated my script accordingly
Additionally I limit to Album/EP/Single
marc2003 awesome new script
i've shamelessly stolen that idea also. script updated.
edit: updated again. i've now added a toggle on the context menu for 'live' releases which people can turn on or off.
You're also pretty shameless about admitting your shameless-ness
Does anyone have a track details script? Something with a bit more customisation possibilities than foo_textdisplay. Custom font sizes, colours, etc. Defaultui seems to be lacking in that area, columns has track info mod as well as 'Item Details'
edit: would it be possible to sort the discography? Would be nice to have the releases displaying in date-descending order.
dates are now sorted in reverse order.
How do i determine when resizing is done?Hello again. I hope i'm not too much of a PITA
As there is no on_size_done() callback in WSH panel mod, I'm trying to write a function that will do it. I'd like to be able to call some methods for recalculating the layout of my panel, then repainting it
after it has been resized rather than
while it's being resized. I guess on_size is called many times while the user is resizing a panel, thus this note in callbacks.txt :
// NOTE: DO NOT Call window.Repaint() and such to repaint window in this function
As i don't have access to WScript object, i can't use WScript.sleep and i need some delay at some point to allow size to "stabilize" before calling "
on_size_done", so i wrote this function :
function is_resizing(_callback,_timerId) {
_timerId = true;
__w1 = window.Width; __h1 = window.Height;
function check_resizing() {
__w2 = window.Width; __h2 = window.Height;
if (__h2 == __h1 && __w2 == __w1) {
_callback();
} else {
window.SetTimeout(is_resizing, 100);
window.SetTimeout(check_resizing, 300);
It's called using this statement in
on_size function
function on_size() { // on_size will also run once when the script first starts.
if (!($system.is_resizing) && ($system.panelW != window.Width || $system.panelH != window.Height))
is_resizing(on_size_done,$system.is_resizing);
And it will call
on_size_done that resets
$system.is_resizing back to
false (and does other useful tasks).
However, some console output i added to
on_size_done shows me that it will run many times, making it no better than using
on_size directly. I guess i made some coding error here but really, i need better glasses to be able to see it (or a better brain)
BTW, my first approach was to make a single function check this and call it repeatedly with
window.SetInterval() but the script will crash when i try to stop it using
window.ClearInterval().
If someone can help me debug my function, or give me another way of doing this, i would be grateful.
Forget previous postI can't edit it unfortunately
I got the function working. I had to pass the functions as anonymous functions using an ugly construct rather than simply refer them by their variable. I still didn't fully understand the logic behind passing functions as arguments to other functions.
Here are the corrected functions in case anyone wants to use them.
How to build on_size_done() functionCurrent WSH panel mod includes
on_size callback that's called each time the panel is resized. Unfortunately,
"each time the panel is resized" means
while resizing as well. Just test it using fb.trace("resize") in on_size function, resize the panel or the window for a couple seconds and then look at your console
This means that to avoid wasting CPU cycles, it's best not to use ressource hungry methods like
window.redraw() in on_size. However there are times when you want your panel to adapt to changes in size, and thus redraw after resizing. An
on_size_done callback that would only trigger when resizing is actually finished is what we need, but there is no such callback. Here is how to build it.
In
on_size, include the following statement :
if (!($system.is_resizing)) {
$system.is_resizing = true
is_resizing(function() {on_size_done();});
Define an
is_resizing function :
function is_resizing(_callback) {
function check_resizing(_callback) {
_callback();
} else {
window.SetTimeout(function () {is_resizing(_callback);}, 100);
window.SetTimeout(function () {check_resizing(_callback);}, 300);
Finally, define an
on_size_done function
function on_size_done() {
$system.is_resizing = false;
$system.panelW = window.Width; $system.panelH = window.Height;
You can add any statements you want in this function, including window.redraw(). This function will only be called when size is stable for 300 ms, which unless you are particularily slow means you have finished resizing your panel/window.
You can use different names. Especially
$system.is_resizing in this example is a property of custom object $system that in my script holds every data needed for the script to run. Just be sure to define the variable you use to check if you already called is_resizing outside any function.
Can I contribute a script?
(http://i.imgur.com/Eh00g.png)
Not very impressive I understand, but I'm pleased with how it looks. Mouse over and scroll wheel to change the volume with a digital readout. Double click on it and it goes to full volume. The font you need is called Letters Laughing (at their Execution) (http://www.fontspace.com/glyphobet-font-foundry/letters-laughing).
var DT_TOP = 0x00000000;
var DT_CENTER = 0x00000001;
var DT_RIGHT = 0x00000002;
var DT_VCENTER = 0x00000004;
var DT_WORDBREAK = 0x00000010;
var DT_SINGLELINE = 0x00000020;
var DT_CALCRECT = 0x00000400;
var DT_NOPREFIX = 0x00000800;
var IDC_HAND = 32649;
//-------------------------------- START
function on_paint(gr) {
gr.SetTextRenderingHint(5);
var text = Math.round(fb.Volume) + " dB ";
gr.FillSolidRect(0, 0, ww, wh, RGB(23,22,20));
gr.GdiDrawText(text, gdi.Font("Letters Laughing", 18, 0), RGB(255,0,0), 0, 0, ww, wh, DT_RIGHT | DT_VCENTER | DT_SINGLELINE);
function on_volume_change(val) {
window.Repaint();
if (val < -60) fb.Volume = -60;
function on_mouse_lbtn_dblclk(x, y) {
fb.Volume = 0;
function on_mouse_wheel(delta) {
if (delta > 0) fb.VolumeUp();
else fb.VolumeDown();
function on_mouse_move() {
window.SetCursor(IDC_HAND);
//-------------------------------- END
hi marc,
i tried to use your "last.fm-Similar artists" and i'm receiving this on the console:
Error: WSH Panel Mod (Last.fm by marc2003): Microsoft JScript runtime error:
Invalid procedure call or argument
File: <main>
Ln: 73, Col: 4
WSH Panel Mod: Warning: Obsolete: Please use AppendTo() method to create sub menu instead of AppendMenuItem()"
any ideas?
thanks a lot
Your WSH Playlist Viewer with WSH VU-meter by
DRON http://www.youtube.com/watch?v=mJNP5QH07uI...eature=youtu.be (http://www.youtube.com/watch?v=mJNP5QH07uI&feature=youtu.be)
a WSH VU-meter!? where can we find it ?
http://foobar2000.org.ru/forum/viewtopic.p...;p=40213#p40213 (http://foobar2000.org.ru/forum/viewtopic.php?f=2&t=4061&p=40213#p40213)
thanks, first try, it crashes foobar2000 (twice) but was when adjusting the script found at the adress above, i'd to complete the missing parts, but now it seems to work, great improvment from DRON, now easy to personalize it
EDIT: now, going to code a "good looking" VU Meter WSH panel based on this, and theme compliant to fit perfectly any VS
Yes, it deserves to be based on it to make a really beautiful thing.
DRON is very knowledgeable and creative thinking programmer. I get the product from its great fun.
WSH VU Meter : my first preview ... i think i'm on the good way
http://youtu.be/p4xVT21MtEg (http://youtu.be/p4xVT21MtEg)
Do you want to just first make an analog VU-meter (you're absolutely right are using L,R) ? This task is more complicated than the peak-meter in WSH (with LM & RM)
@onv
yep, harder, but it's what i want to code first
@onv
The right decision, respect. But in this case it is desirable in my opinion to combine analog arrow with peak LED
P.S. It might be better to discuss it in the appropriate thread ? What do you think about this?
any ideas?
are you using the latest WSH panel mod component? 1.5.3.1 i think...
if you've used previous versions of my scripts, did you extract the
marc2003 folder from the latest zip over-writing all the old files?
any ideas?
if you've used previous versions of my scripts, did you extract the marc2003 folder from the latest zip over-writing all the old files?
I did, actually i re-installed the whole shebang; win 7 64bit, all my software, new 1T hard drive... after my old one crashed, so it is all from scratch...
I get a message that art.exe lacks a guilty digital signature, why is that? What changes has been made?
that's odd then. i use windows 7 64bit myself and i can't make any sense of the error you posted because there's nothing on that line that would cause that.
@sylla, art.exe hasn't changed in over 2 years and no one else has reported that problem.
WSH VU Meter v1.0.0 jscript, to use with the last version of the component foo_vis_vumeter 2012-05-27 (ActiveX Object)
(http://i.imgur.com/007sN.png)
script available here: http://pastebin.com/u/Br3tt (http://pastebin.com/u/Br3tt)
images available here: http://br3tt.free.fr/files/R/images.zip (http://br3tt.free.fr/files/R/images.zip)
Falstaff,
does the WSH VU Meter script work with Mono (1 channel) audio as well as 2 channel (stereo)?
I am thinking of replacing the peakmeter from "foo_uie_vis_peakmeter_spectrum", but before I do I would like to know if your script can render mono audio too.
I like to collect as 1-channel Mono any albums which were originally produced as Mono, therefore I need the meter visualization to accept input from three channels:
Left-Front AND Right-Front AND Centre.
Congratulations, good job. The speed of your programming is comparable with a machine gun
Falstaff,
afaik, VU Meter component only provide Left, Right or Mixed to Mono Channels. My Scirpt use the ActiveX Object provided by the VU Meter component, it can display two VU meter for Left and Right Channels, or just one VU Meter, in this case, i calc the average value for level >> (Left level +Right level)/2 and for the Peak >> (Left Peak+Right Peak)/2. For mono tracks, Left and Right channels (level and Peak) provided by the component are the same.
HTH
thank you, it's just a first try, many things to adjust, and better skins to do now
In the non-WSH version of Dron, you can easily switch between different skins on the fly by left- and right flips. Put 10 different skins - and choose the one that is now more like
It would be useful to implement such a possibility in WSH - version
to use with the last version of the component foo_vis_vumeter 2012-05-27]
Last - 2012-05-28
Falstaff
I use your CoverFlow View v1.4 script in CoverFlow tab panel.
(http://i.imgur.com/00157.png)
Now I download new version of this script - 1.4.2.
I replace text of script in wsh panel and that is what I see:
(http://i.imgur.com/l89VL.png)
I could not change size of CoverFlow tab panel and I return in previous state only by deleting Coverflow tab and creating it again.
@pIv
sorry, my bad... v1.4.3 uploaded that fix this issue.
@pIv
Thank you very much for the quick correction of this bug.
@Falstaff
In WSH VU Meter does not work Keep Aspect Ratio in CUI. You need to add transparency fields (wh -hVU)/2 to top and bottom or (ww-wVU)/2 to left and right in mono ( (ww-2wVU)/2 in stereo)
Last - 2012-05-28
The site for foo_vis_vumeter is still on 2012-05-12
The last version i could find on foobar2000.ru is from 2012-05-23.
U got a better link for us
onv? Thanks
Last - 2012-05-28
U got a better link for us onv? Thanks
http://foobar2000.org.ru/forum/viewtopic.p...1&start=135 (http://foobar2000.org.ru/forum/viewtopic.php?f=2&t=4061&start=135) --> http://rghost.ru/38330606 (http://rghost.ru/38330606)
Last - 2012-05-28
Could I get a link to the latest version of the VU Meter component, I can only find the one dated 2012-05-12.
so its possible to use wsh panel as host for another panels?
Falstaff can you write how to use it for other panels?
as i understand, i need to write something like this:
Panel = new ActiveXObject("esplaylist");
Panel.RegisterWindow(window.ID);
PWindow = Panel.CreateWindow(window.ID);
PWindow.SetBounds(50,50,200,200);
PWindow.Visible=true;
PWindow.Enabled=false;
but it crashes
Marc, your scripts are like little christmas presents all year long! =)
One request - any chance to get the MusicBrainz release sorted chronologically?
thanks for your hard work!
.Mike
@mjm716
http://www.hydrogenaudio.org/forums/index....st&p=796454 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=796454)
1. afaik not, should be a feature to implement in the WSH Panel Mod component, ask to T.P Wang if something is possible...
2. i've nothing to explain, what you talk about is the use of an activeX object provided by a component : VU Meter... it's not a common feature for any component !
@mjm716
Ho Ho Ho! Merry Christmas!
Hi all Army FB2K !!!
I need Default Volume Bar script such as this: (http://img-fotki.yandex.ru/get/6110/52957509.f5/0_7e67c_d0e45717_M.jpg)
Please help, Thx.
P.S.Sorry for bad English :]
Falstaffits sad, but possible make same trick with other visualisation - channel spectrum panel?
T.P Wang i think i could make some interesting things, if there will be function or method to get name of main or context item - like "properties" or "open containing folder" in context. this items are known, but some plugins make dynamic items name, or related to settings of plugin. anyone agree with my point?
on line 102, use 2 slashes to comment it out....
//temp_arr.reverse();
now it should be in ascending order.
EDIT: i missed this post.
if you're happy with descending order then of course you don't have to change anything.
What does "gr.SetTextRenderingHint" do?
@marc
I downloaded the samples new but they aren't working with latest wsh panel mod, may be i am missing something. Requesting for the updated script if possible.
it affects the way text is displayed with DrawString() api (smoothness, ... etc), check the doc (interface.txt) bundled with the component
Screensaver "Flying VU", the next update from DRON
http://www.youtube.com/watch?v=ZcnQBA1DrfU...eature=youtu.be (http://www.youtube.com/watch?v=ZcnQBA1DrfU&feature=youtu.be)
@marc
i always use the latest version of WSH panel mod so it's not that.
perhaps being more descriptive with your problem might help. if you get "aw crashed" in the panel, then make sure you post the full message from the foobar console found on the
view menu. if the panel appears to load ok but crashes if you do something, then post the steps to re-produce.
You may grab it here:
WSH digital Vu meter
http://pastebin.com/H26MujCP (http://pastebin.com/H26MujCP)
D'oh. The one place I didn't look. Thanks.
Can "gr.SetTextRenderingHint(5);" be set globally at the beginning of the script instead of in "function on_paint(gr)" ?
Is there anything wrong with doing that?
No it can't (and therefore what's wrong with it is that it won't work unfortunately).
The reason it won't work is that you need access to the
gr object in order to call the function
gr.SetTextRenderingHint(...). This access is granted by
gr being provided to the
on_paint function as a parameter.
You could, however, set a global variable to the value you want and then refer to this in the
on_paint function, but I'm not sure if that will be of any use to you.
First off, if this request is in the wrong place please forgive my ignorance.
Might be best to quickly read an old post of mine dated Jan 21 2012, 13:44 to best describe my issue.
http://www.hydrogenaudio.org/forums/index....st&p=783162 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=92416&view=findpost&p=783162)
Can anyone help? Please?
Thanks in advance.
Brett.
i can't be bothered to make something nice
var ww = 0;
var wh = 0;
ww = window.Width;
wh = window.Height;
gr.FillSolidRect(0, 0, ww, wh, fb.StopAfterCurrent ? RGB(255,0,0) : RGB(0,255,0));
function on_playlist_stop_after_current_changed() {
window.Repaint();
function on_mouse_lbtn_up() {
fb.StopAfterCurrent = !fb.StopAfterCurrent;
green panel: stop after current disabled
red panel: stop after current enabled
click the panel to toggle the state and it will also update if you use the playback menu.
I made a small piece of code, use it as WSH panel on its own or place it into your other script. Clicking on the panel will toggle SACT mode and inform you what is going on.
var font_1 = gdi.Font("Tahoma",10,1);
var color_1 = RGB(235,235,235);
var DT_LEFT = 0x00000000;
var ww,wh;
ww = window.Width;
wh = window.Height;
if(fb.IsPlaying){
text = (fb.IsPlaying && fb.StopAfterCurrent) ? "SACT" : "NO SACT";
gr.GdiDrawText(text, font_1, color_1, 0, 0, 60, 10, DT_LEFT);
function RGB(r, g, b){
function on_mouse_lbtn_down(x, y, mask){
if(!fb.IsPlaying) return;
fb.RunMainMenuCommand("Playback/Stop After Current");
function on_playlist_stop_after_current_changed(state){
window.Repaint();
@Brett (from Brett)
my contrib extracted from by fooRazor config as a stand alone panel, here is a more elaborated button than combine playback order button with Stop After Current button,
just copy/paste this script in a WSH panel, grab it here:
http://pastebin.com/gv0sWFq5 (http://pastebin.com/gv0sWFq5)
(http://img829.imageshack.us/img829/481/pbo2.png)
The reason it won't work is that you need access to the gr object in order to call the function gr.SetTextRenderingHint(...). This access is granted by gr being provided to the on_paint function as a parameter.
I see.... So I can't put "SetTextRenderingHint(5);" instead to make it a global setting either I take it?
Nope, that function would fail because it doesn't exist. What are you trying to avoid by not calling gr.SetTextRenderingHint inside on_paint?
Nothing. Just learning.
Hi!
Is there a way, in a WSH panel, to get information (%title%, %album%...) about the song to be played next in the playing playlist (assuming the playback order is default, of course) ?
I'm trying to write a panel for a "Stop after Album" button but for now all I can do is to compare the track number of the playing track with the %totaltracks% defined for the track that was playing when I triggered the button (sorry if I'm not clear)
Most of the time it works but sometimes no: if there is no %totaltracks% defined or if, in my playlist, the last song from one certain album to be played (before playing another track from another album) is not the actual last track of this album (for with %tracknumber% == %totaltracks%)
Thanks in advance
I've got two themes, one of which I'd like to disable the toolbar in.
I added fb.RunMainMenuCommand("View/Show Toolbars") to my on_init which works great, but there's no way to determine whether the toolbars were toggled on or off. It always just returns true. I'm assuming the answer is no, but is there any way to get the check state of the menu command first?
I have a row of buttons in a WSH panel.
One of the buttons is for opening the containing folder, and this is the line in the script:
but8: new Button((bw*7) + left_margin,top_margin,bw,bh, {normal: images_path + "open-folder.png", hover: images_path + "open-folder_h.png"}, function(){fb.RunContextCommand("Open containing folder");}, "Show the NOW PLAYING item's containing folder")
My problem is the above button ONLY works with the now-playing item in the playlist, but I also want a button which will work with my selection(s).
That is, if I select item(s) in the playlist I would like to click a button which will open the containing folder of the selected items AND NOT the playing item.
Does anybody know the right code for this 'other' containing folder action? thanks.
Why is my requezt ignored, so you express your attitude to the Russian people?
Post #1611?
#1686
@bulletproof2k
Post #1686 was your question. Post #1611 is your answer, read it to find what you are looking for.
Post #1611?
Thanks for the answers, but I need just such as Screen Shot #1686
WSH digital VU meter updated!
video preview here (http://youtu.be/drsrpdOZYas)
script here (http://pastebin.com/H26MujCP)
WSH_Browser : first alpha
Hello. This time i'm not here for another stupid noob question . I have finally been able to get my WSH_browser to a working state.
This is a "graphical" (well, not really for now but it will become) library browser component for WSH panel mod.
) is the most efficient way to browse the library. It works but there might be something more elegent (such as working with an autoplaylist, but then i would have to get metadbhandles several times later).
@Fallstaff i would be really happy to know what you think of my approach as you have experience with sorting lots of tracks in WSH. I had a look at your CoverFlow but didn't really understood how you are storing the handles in groups. I was unable to store handles directly in an array so i had to create several IFbMetadbHandleList objects.
Here is the script on pastebin (http://pastebin.com/phpjnkfu)
You will also need two additional files : Constructors.js (http://pastebin.com/jjxxDkf4) and Helpers.js (http://pastebin.com/XWvYSnAB)
@r0k
good to see such project!
but ... first try, it doesn't work ==> foobar2000 not responding (for 5 minutes now....), my libray is big (~40k trks), i suspect your script is not for large library, but what's its maximum size to make it work?
before checking a script, i'd like to see it running well, if not, i'm not interrested ... other stuff is waiting, so i'll wait a next version of your script maybe with some restrcitions info in comments to indicate in which way somebody can test it
EDIT: hmm, works better on another try, lag just the time to populate the WSH playlist... i'll check your script asap. Careful, mousewheel make content disapear...
var ww,wh;
ww = window.Width;
wh = window.Height;
if(fb.IsPlaying){
window.Repaint();
Wow! Thanks for the speedy replies! Unfortunately for me, I have no scripting knowledge and do not fully comprehend the WSH Panel Mod.
I have a specific UI Layout and settings that never change on my player. I need to keep this layout and settings while adding the described option in this old post of mine...
** My only issue with foobar2000 is that I don't have visual notification when I have activated a "Stop After Current" command.
In my use, I have playback follows cursor. It would be great to have the highlighted cursor able to change color to red when stop after current is selected. **If someone out there is willing to create a script for me, and walk me through the setup, I would be more than happy to make a donation for their services to their PayPal account. Please send a PM if interested.
Has anyone written a media library browser such as an expandable tree view in wsh panel mod?
Not possible, because we cant get media library MetadbHandleList to WSH panel mod.
I hope this feature is added in the future.
you can't say that. It's possible through another way based on a playlist that contains the library, but for sure this method is not perfect because this playlist has to be populated before being available for the script.
yep, let's hope it's possible for T.P Wang
as we have:
// Get all items into an instance of IFbMetadbHandleList from specified playlist
IFbMetadbHandleList
GetPlaylistItems(playlistIndex);
we'd like to have too something like this:
// Get all items into of IFbMetadbHandleList from Media Library
IFbMetadbHandleList
GetMediaLibraryItems();
@r0k
Not sure what the maximum size is. My library is about 4500 tracks so much smaller than yours and this script has only been tested on my computer so far. Well, that's a feedback on it's own so i know i need to improve the way i gather handles.
I understand. I'll be improving it anyway. As stated i consider it an alpha, not even a beta, but i posted it anyway because a single experienced hint might improve the script more than one week of my noob work
In the current script, i have a check to prevent mousewheel from scrolling before line 1 but nothing to prevent it from scrolling past last line (this one has to be calculated first). Scrolling up should bring content back if you go too far. This will be added by the time i release the first "beta".
That's exactly the workaroud i used to gather the MetadbHandleList in my browser above. Actually, here is what i did (so you don't have to look at my code).
I have defined a MetaDB custom object constructor. In my script i create such an object. It has the following properties :
- ownId : this is simply it's name so i can refer it in console output.
- query : the query used to retrieve tracks. By default it's a single dot (.) that will get everything.
- sortBy : how to sort tracks
- groupBy : how to group tracks (eg : by genre)
- groups : an object containing group names based on groupBy (eg. Rock) and metaHandles sub-lists (those are full IFbMetadbHandleLists objects as i wasn't able to store metaHandles in simple jscript arrays).
The following methods are available :
- doListHandles : will retreive MetadbHandles from the library matching the query. Actually it will create a temporary auto-playlist with said query. Get all MetadbHandles then remove the auto-pl. It's quite an ugly workaround but it works, at least on small to medium libraries . MetadbHandles are stored twice, one as a "working" set and one as a "backup" set. I'm not sure how this impacts memory use and performances with big libraries. According to Falstaff's tests it's not working very well.
- doResetHandles : will reset the "working" set to match the "backup" set
- doFilterHandles : will filter the "working" set to exclude MetadbHandles not matching a filter passed as argument.
- doGroups : will sort the MetadbHandles from the "working" set and store copies of them in the groups object (MetadbHandles are thus stored three times, i hope they are not big memory eaters:unsure:)
- getGroups : will return the names of the groups to the script so they can be used to get the tracks in other statements.
I'm quite sure i can improve this, and of course it would be nice to skip the playlist step altogether (a probable cause of some delay with big libraries).
My browser could probably be modified to show a tree view. I might add it later, but it's currently an early alpha and i won't add features until it's working smoothly on bigger libraries and the current features and interface are polished enough.
WSH_Browser : first alpha!!!
http://www.flickr.com/photos/bulletproof2k/ (http://www.flickr.com/photos/bulletproof2k/) My genres for iTunes and foobar2000
In my system (core2duo E7400 2GB ram winxp) and with my 57000 tracks library, it works from the first run. There is a lag of about 5 seconds switching from alphabetic and genre view, like that switching in ColumnsUI filters; only facets in DUI is faster. I like your project because i need a simple interface to easily control with a 7" touchscreen monitor, but i'm not a programmer and my last one
) is very slow and not much user-friendly...
I can't help you in programming, but if you need a beta-tester with a large library... I'm here
Good work
Fabio
Thanks for the encouragement and feedback.
Actually, i didn't even think about touchscreens but i can see how a simple visual interface can be useful for those. I'll try to keep them in mind for further developpment.
"Beta test" will be open, so you are free to participate
Well, speaking of my script, i'm running into a bad hang currently. I'm trying to get the path that's common to all items in a group, in order to search this path for artwok to show (artist picture, album cover ...) and avoid the need to keep a copy of every artwork inside the artwok folder where non-path related artwork (eg genres will be kept). However my code is making foobar2000 hang idefinitely (like i'm running an endless loop )
I've narrowed the hang to this part of the code :
// Search for a common path to all items in the group.
__path = __hnd.Path;
if (this.groups[__groupName].path) { // if true there is already a path stored, find common path
__path = __path.split("\\"); // Split into an array of folder names.
__pathOld = this.groups[__groupName].path.split("\\");
for (var i = (__path.length-1); i>=0; i--) { // Check every item, starting by the end
if (i >= __pathOld.length) { // if current path is longer than stored path
void __path.pop(); // remove last item from current path
continue; // begin next iteration
} else if (__path[i] == __pathOld[i]) { // compare last item of stored and current path
this.groups[__groupName].path = __pathOld.join("\\");
break; // break the loop and keep the path as it is now
} else {
void __path.pop(); // reduce the path one level towards the root
void __pathOld.pop();
} else this.groups[__groupName].path = __path; // store path of the first track
And more precisely, the for loop part. It shouldn't loop forever, i'm decresing i at each loop and the condition is i>=0.
Can someone tell me what noobish mistake i made?
From a quick glance I can't see an obvious problem, however you could try using a reverse while-loop instead (as you're already decrementing). Something like:
var i = __path.length - 1;
while (i--) {
// (The stuff that was in the for loop goes here)
Replacing the loop should prove whether or not the problem is the loop (and a reverse while may be more efficient anyway).
adding fb.trace("i = "+i) in the loop may help you to find what's wrong with your loop ...
re: while loopI try to stay away from while loops as they seem more prone to endless loop (they are easier to code badly ) but i see the logic behind your example. I wouldn't have thought of grouping the condition and the increment/decrement. Thanks.
@FalstaffI already have some console output, thought not at this place. But i can't look at the console as fb2k itself will hang, not just the panel
EDIT : never mind, just found the "write log" checkbox in the console.
EDIT 2 : nay, even with "write log" checked, i don't get any console output at all when hangs occur. Not even output from statements that are executed before the loop goes crazy (actually : write log is not kept when fb2k restarts.
I tried to compare strings directly with what looks like simpler code, but i still have an endless hang. Got it working!
FINAL EDITOK, i got it working, but can someone explain me why :
var i=0;
do {
if (__path.charAt(i) != __pathOld.charAt(i)) break; // path no longer common, break the loop
} while(i++ < __pathLen);
__path = __path.substr(0,i); // keep only the common part
__path = __path.substr(0,__path.lastIndexOf("\\")); // don't consider path after the last backslash
Does not work, but
var __totoIsBack=0;
do {
if (__path.charAt(__totoIsBack) != __pathOld.charAt(__totoIsBack)) break; // path no longer common, break the loop
} while(__totoIsBack++ < __pathLen);
__path = __path.substr(0,__totoIsBack); // keep only the common part
does
Hi!
I've used the following function to add a stop-after-album feature. The important parts are plman.GetPlaylistItems(plman.PlayingPlaylist), which give you the playlist's tracks in order, and plman.GetPlayingItemLocation().PlaylistItemIndex, which gives the index of the current track.
function on_playback_new_track(current_track) {
var next_track = current_track;
// get next track
if (plman.IsPlaybackQueueActive()) {
// check first item in queue
next_track = plman.GetPlaybackQueueContents().toArray()[0].Handle;
} else {
var i = plman.GetPlayingItemLocation().PlaylistItemIndex;
var pl_items = plman.GetPlaylistItems(plman.PlayingPlaylist);
if (i + 1 == pl_items.Count) {
// current_track is the last item in playlist
} else if (i > pl_items.Count) {
// current_track is no longer in the playlist
fb.StopAfterCurrent = true;
return;
} else {
next_track = pl_items.Item(i+1);
// ALBUM_TF is something like fb.TitleFormat(window.GetProperty("ALBUM TF", "%album artist% %album%"));
if (ALBUM_TF.EvalWithMetadb(current_track) != ALBUM_TF.EvalWithMetadb(next_track)) {
} else {
fb.StopAfterCurrent = false;
I am not really familiar with WSH coding but I was wondering whether someone could solve the delay problem in marc playcount script? The delay is when a track is submitted for loved/unloved.
Got it working!
Glad to hear it
Without seeing all of your code I can't tell for sure. Off the top of my head, the only explanation I can think of is that
i is defined somewhere else (perhaps globally) and this is interfering with the loop. Beyond that...no idea...
... I was wondering whether someone could solve the delay problem in marc playcount script? ...
Well, delays tend to occur when the computer is busy doing something, so apart from removing some actions, i don't think it's possible.
Now, i don't find this particular script. Maybe he released a new version of his samples after i downloaded them.
Without seeing all of your code I can't tell for sure. Off the top of my head, the only explanation I can think of is that i is defined somewhere else (perhaps globally) and this is interfering with the loop. Beyond that...no idea...
Ha, i'm such a noob
I don't use variables such as "i" globally of course, only for loops ...
But this loop was nested inside another loop ... using i as a counter of course.
I was actually resetting i in the middle of the outer loop, causing it to become endless. And i was trying to find why the inner loop was endless
Ha, i'm such a noob
Haha, I've been there before!
It's sometimes more useful to use meaningful names for loop counters, just so when you get to the inner-loop you make sure you're using innerLoopIndex and not outerLoopIndex (although to be fair I only tend to do this when I'm coding something semi-serious, I should probably do it more often ).
Glad you got it all figured out
I had the first (outer) loop coded several days ago, but only yesterday i decided to add statements to gather informations about my track groups. I totally forgot about the first loop.
What i should have done is code the comparator as an external function and take benefit of local variables.
Speaking of local variables, it's probably obvious for some people, but in case it's not, i made a test.
// ==PREPROCESSOR== --> CONSOLE OUTPUT
// @name "test"
var toto = "toto is Global";
fb.trace("L6 "+toto); --> L6 toto is Global
function test() {
var toto = "toto is Local";
fb.trace("L10 "+toto); --> L10 toto is Local
function test2() {
toto = "Heavy Metal never dies";
fb.trace("L15 "+toto); --> L15 Heavy Metal never dies
test();
fb.trace("L19 "+toto); --> L19 toto is Global
test2();
fb.trace("L22 "+toto); --> L22 Heavy Metal never dies
If a local variable is defined inside a function using
var statement, even if a global variable has the same name, the global will not be overwritten. However, if var is omitted, the global will be overwritten.
Furthemore, if a local variable is defined with var, then the variable is changed to another value, like in this second test
// @name "test"
function test() {
fb.trace("L12 "+toto); --> L12 Heavy Metal never dies
test();
fb.trace("L16 "+toto); --> L16 toto is Global
The change will affect the local variable, and not the global one.
That's a good reason to get used to always use
var
That was exactly what I was looking for. Thank you
Is there anyway to hide the mouse cursor using WSH Panel? I'd love to be able to add a timeout in on_mouse_move to hide it after a few seconds of inactivity in my HTPC script.
Even if there is a way to do this, I'm not sure it's possible because I get continuous on_mouse_move events whether the mouse is moving or not. Is this the way it's supposed to be, because it seems like a bug. I verified that it wasn't weirdness with my mouse by turning off my mouse and not touching the trackpad on my laptop.
I can confirm
on_mouse_move seems to trigger continually as long as the mouse is in the WSH panel area.
One way to work around this would be to store
prevMouseXand
prevMouseY in some variable/object and make a conditional check in
on_mouse_move if (prevMouseX != x || prevMouseY != Y)
to know whether the mouse is actually moving or not.
Here is some working code you can use if you can find a way to actually hide the cursor. I tried
window.SetCursor(...); but there is no "hidden" option.
var prevMouseX = 0;
var prevMouseY = 0;
var mouseActive = true;
function hideCursor() {
if (mouseActive) return;
// Add some code to hide the mouse
if (prevMouseX != x || prevMouseY != y) {
prevMouseX = x;
prevMouseY = y;
mouseActive = true;
// Add some code to show the mouse
} else {
mouseActive = false;
window.SetTimeout(function () {hideCursor();},1000);
you can use a negative number to hide it.
window.SetCursor(-1);
Thanks for the tip marc2003 It's much simpler than i would have imagined.
Well, while i'm here i could as well ask something. Is there a simple way of preventing on_mouse_lbtn_up() from trigerring it's effect when you double-click. Currently, if i double click, it will trigger on_mouse_lbtn_up twice and on_mouse_lbtn_dblclk once. That's logical but not very practical.
I guess know i can call a delayed function in on_mouse_lbtn_up with a conditional check that would evaluate to false if on_mouse_lbtn_dblclk have been triggered but maybe there is something easier.
EDIT : Tested the delay, it works. Still willing to learn possible alternatives
Thanks for the suggestions r0k and marc. I've got it working perfectly now. Here's my final code if anyone is interested:
var state["mouse_x"] = 0;
var state["mouse_y"] = 0;
var hideCursor = 0;
if (x != state["mouse_x"] || y != state["mouse_y"]) {
window.SetCursor(32512); // arrow
state["mouse_x"] = x;
state["mouse_y"] = y;
window.ClearTimeout(hideCursor);
hideCursor = window.SetTimeout(function() {
window.SetCursor(-1); // hide cursor
}, 5000);
That's how I'd handle a
on_mouse_lbtn_up if forced to differentiate. I can't think of any other way right now.
after WSH VU meter appears im interested in other activex objects i can add to my wsh panel. i know about shell object, vbcontrol (but dont know how to use it), httpdocument, filesystem. and now its vumeter. is anybody knows any interesting object? as i remember, marc2003 posted somewhere script showing your soundcard name. can anybody writes something about it or show me where i can read abou that?
Well, there is AutoitX3 (http://www.autoitscript.com/site/autoit/) and DynamicWrapperX (http://www.script-coding.com/dynwrapx_eng.html) ActiveX components.
With these to components only the sky is the limit. You can send messages, get system handles, create 'AERO' glass and so on.
thanks, im also wanted for object to control file copy and transcoding audio by SOX otherwise shell. it will be nice if i get progress of each file.
now im using autoitx3 to control window size without standart windows borders, but in same way. and near aims - transcoding and file copy operations
samples updated: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
musicbrainz releases: entries with no date now appear at end of list instead of the beginning
I just tried some samples by pasting and replacing the content in my WSH Panel (coverflow) already pretty working but I get this:
||Scripting Engine Initialization Failed (Playback Buttons by marc2003, CODE: 0x80020101)
Check the console for more information (Always caused by unexcepted script error).||
thank you
Also big props Falstaff - your scripting has really made my layout appealing. But now the annoying request.
Is there any way to get the playlist to collapse the album views, so tracks could be displayed or not via click (e.g. on heading/arrow/icon to expand/contract) and bonus points if the now playing album automatically expands.
I'm essentially searching for something similar to ELplaylist that works in DUI.
For example, this direction is great: http://www.hydrogenaudio.org/forums/index....st&p=799256 (http://www.hydrogenaudio.org/forums/index.php?showtopic=63984&view=findpost&p=799256)
Artist overview (& album count) with chronologically listed albums, that then would expand to display track listings on click.
Dare to dream I know, but any tips towards this direction (in DUI) would be much appreciated.
thanks,
.Mike
Nice it's always those little things!
I hope you don't mind, but I added buttons for discogs & allmusic to your 'web links' (if it suits you, feel free to redistribute in your ZIP)
button preview: http://desmond.imageshack.us/Himg195/scale...amp;res=landing (http://desmond.imageshack.us/Himg195/scaled.php?server=195&filename=buttonsqu.png&res=landing)
New discogs+allmusic buttons here: http://www.mediafire.com/?kaywlua6nrtritl (http://www.mediafire.com/?kaywlua6nrtritl)
also note, the MySpace link has been updated to function correctly
// ==PREPROCESSOR==
// @import "%fb2k_profile_path%marc2003\common4.js"
// @import "%fb2k_profile_path%marc2003\tooltip_buttons.js"
// @name "Web Links"
// @author "marc2003"
// @feature "v1.4"
// @feature "watch-metadb"
var bw = 32;
var bh = 32;
var left_margin = 0;
var top_margin = 0;
var script_name = "Web Links";
var custom_background = window.GetProperty("custom_background", "");
var bg = window.GetProperty("bg", 102);
selection_mode = 1;
on_item_focus_change();
ww = window.Width;
wh = window.Height;
buttons_background(gr);
buttonsDraw(gr);
if (!g_metadb) return;
var myspace = fb.TitleFormat("http://www.myspace.com/search/music?q=$replace(%artist%, ,)").EvalWithMetadb(g_metadb);
var lastfm = fb.TitleFormat("http://www.last.fm/music/$replace(%artist%, ,+,/,'%'252F,?,'%'3F)/_/$replace(%title%, ,+,/,'%'252F,?,'%'3F)").EvalWithMetadb(g_metadb);
var youtube = fb.TitleFormat("http://www.youtube.com/results?search_query=$replace(%artist%+%title%, ,+,'(',,')',,/,+,&,and)").EvalWithMetadb(g_metadb);
var discogs = fb.TitleFormat("http://www.discogs.com/search?q=$replace(%artist%, ,+,'(',,')',,/,+,&,and)").EvalWithMetadb(g_metadb);
var allmusic = fb.TitleFormat("http://allmusic.com/search/artist/$replace(%artist%, ,+,'(',,')',,/,+,&,and)").EvalWithMetadb(g_metadb);
Buttons = {
but1: new Button(left_margin, top_margin, bw, bh, {normal: images_path + "myspace.png", hover: images_path + "myspace_h.png"}, function() { WshShell.run(myspace); }, myspace),
but2: new Button(left_margin + bw, top_margin, bw, bh, {normal: images_path + "lastfm.png", hover: images_path + "lastfm_h.png"}, function() { WshShell.run(lastfm); }, lastfm),
but3: new Button(left_margin + (bw * 2), top_margin, bw, bh, {normal: images_path + "youtube.png", hover: images_path + "youtube_h.png"}, function() { WshShell.run(youtube); }, youtube),
but4: new Button(left_margin + (bw * 3), top_margin, bw, bh, {normal: images_path + "discogs.png", hover: images_path + "discogs_h.png"}, function() { WshShell.run(discogs); }, discogs),
but5: new Button(left_margin + (bw * 4), top_margin, bw, bh, {normal: images_path + "allmusic.png", hover: images_path + "allmusic_h.png"}, function() { WshShell.run(allmusic); }, allmusic)
window.Repaint();
buttonsMove(x, y);
buttonsUp(x, y);
function on_mouse_leave() {
buttonsLeave();
function on_mouse_rbtn_up(x, y) {
background_menu(x, y);
return true;
From one of the WSH script (from musickarte skin), the following error is displayed when I updated my WSH panel mod to the latest version 1.5.2.
Error:
Object doesn't support this property or method
WSH error line:
var hWnd = utils.GetHWND("{E7076D1C-A7BF-4f39-B771-BCBE88F2A2A8});
It seemed that the method utils.GetHWND no longer exist in the latest version. I have no knowledge about WSH scripting and thus would need help on this issue. This issue had kept me from updating my previous WSH version (1.4.9) to the latest version
@D.Sync
official WSH Panel Mod had never used this method. It belongs to a modified version of WSH Panel Mod stuck in v1.4.x, support seems totally discontinued... to forget.
I want to have a volume control that only shows when the mouse cursor is over it. I've searched for any mouse-over examples so I could modify T.P Wang's volbar code example (http://code.google.com/p/foo-wsh-panel-mod/source/browse/samples/Volbar.txt?r=2d1014c706400e7a5240539e8228c8502cd6392f), but haven't found anything. I know next to nothing about coding, and my attempts to find javascript documentation and learn how to do this on my own have not gone well. So I'm hoping someone can point me to an example I can work from, or show how it's done.
@mjm716, thanks for those images. i've bundled them in and cleaned up the script a bit.
@Ryoma, you should read the error you posted.....
@trout, i don't have time now but if someone else doesn't answer before tomorrow, i might be able to knock something up for you.
Don't mind.
My mistake.
@ trout, http://pastebin.com/T50gNd9A (http://pastebin.com/T50gNd9A)
marc2003 - Thanks for your gracious help. Much appreciated!
@Falstaff
http://www.youtube.com/watch?v=zq8IpyuZZxI&feature=plcp (http://www.youtube.com/watch?v=zq8IpyuZZxI&feature=plcp)
left button down + move, without scrollbar, for CarPC & other touchscreen's
Hi Falstaff,
Any chance you can give some help trying to get your WSH playlist script to support 1/2 ratings, similar to $repeat(★,$meta(rating))$if($strchr($meta(rating),.),☆)?
I have a WSH script which reads and displays a textfile, here is the header description inside the script:
// Draws "<dir_containing_current_audio_file>\folder.txt" in a "WSH Panel Mod" panel,
// or if "folder.txt" is not present, will draw the first text file in that directory,
// or if no text file exists, will draw some default ASCII Art text.I always use the following template to format the textfile (folder.txt) the same way:
Artist – Album (Date)
<PRODUCT>A line of text is inserted here</PRODUCT/>
<GENRE>A line of text is inserted here</GENRE/>
<OVERVIEW>Multiple lines of text are inserted here
giving informative comments and reviews on the work</OVERVIEW/>
<TRACKS>01. Trackname
02. Trackname
03. Trackname
etc
etc</TRACKS/>
<CREDITS>JOHN SURNAME — guitar
PAUL SURNAME — vocals
GEORGE SURNAME — bass
RINGO SURNAME — drums</CREDITS/>
My script is NEARLY perfect but for one last problem. . .
I want the script to replace the "special words enclosed in angle brackets" with nothing.
That is, I would like the panel to end up displaying like this in foobar2000:
01. Trackname
02. Trackname
03. Trackname
etc
etc
JOHN SURNAME — vocals, guitar
PAUL SURNAME — vocals, bass
GEORGE SURNAME — guitar
I am pretty sure the search-and-replace method needs to be inserted into the
function on_paint(gr) section.
I'm not a javascript programmer and I need some help to realize this.
Some help from one of you javascript gurus would be highly appreciated.
P.S. -- I plan on sharing the script here with everyone once it is fully completed and tested.
add this to your script (safe mode needs to be disabled) -
var doc = new ActiveXObject("htmlfile");
function decode(value) {
try {
doc.open();
div = doc.createElement("div");
div.innerHTML = value.replace(/\n/g, "<br>");
return div.innerText;
} catch(e) {
return "Error reading content.";
then assuming the variable
mytext contains your text....
mytext = decode(mytext);
note: you don't need to add the first code section if you're importing common4.js from my scripts.
Thanks for that reply
marc, nice stuff to know. This script is not one of yours.
____________________________________________________________________________________
Anyhow, I just finished composing a reply to my Post #1754. . .so I might as well post it:
I solved it!. . .with a bit of luck and a bit of WWW Google searching with these two terms: (1) jscript replace text, (2) regex escape forward slash.
The relevant function in my script for performing this task is at
on_playback_new_track() AND NOT
on_paint(gr).
So, looking at an excerpt of the function, we see the code I needed to add (in red):
function on_playback_new_track(){
g_need_vp_refresh = true;
g_metadb = get_metadb();
if (! g_metadb) window.Repaint();
var new_dir = fb.TitleFormat("$directory_path(%path%)").EvalWithMetadb(g_metadb);
if (g_dir == new_dir) return;
var new_title = "";
var new_text = "";
var filename = new_dir + "\\folder.txt";
var filename_contents = utils.ReadTextFile(filename);
if (new_text == "") {
var arr = utils.Glob(fb.TitleFormat("$directory_path(%path%)").EvalWithMetadb(g_metadb) + "\\*.txt").toArray();
if (arr.length > 0) {
filename = arr[0];
try {
these_strings = /<(PRODUCT|\/PRODUCT\/|GENRE|\/GENRE\/|OVERVIEW|\/OVERVIEW\/|TRACKS|\/TRACKS\/|CREDITS|\/CREDITS\/)>/g;
new_text = filename_contents.replace(these_strings,"");
} catch(e) {
new_text = "";
window.Repaint();
When I'm finished with it all, I'll share this textfile viewer with everybody.
I have tested just about every textfile viewer script made for WSH Panel Mod
and this one here is UNBELIEVABLE. It is hands down the best I ever found (and modified:-).
Some of its features:
- Looks for your preferred text file name first, else looks for any text file, else displays contents of a default text file (ASCII Art ...see screenshots)
- Pop-out vertical scrollbar on mouse hover
- Up-Down page scroll with left mouse button drag anywhere on the window
- Up-Down page scroll with keyboard arrows/PgDn/PgUp
- Top-Bottom-Top-Bottom infinite chunk scroll with middle mouse clicks
- flat color or gradient color change views
- A thin header bar showing the name of the displayed text file.
- Right click menu: Open folder | Edit text file | Refresh | Configure
Screenshots of the WSH textfile viewer in my foobar2000...(Top shot is reading a text file, Bottom shot is reading "default.txt" aka no text file found):(http://img15.imageshack.us/img15/4923/wshtextfileviewer.th.jpg) (http://img15.imageshack.us/img15/4923/wshtextfileviewer.jpg)
derty2:You could simplify your regular expression somewhat based on the fact that the
/ is repeated:
these_strings = /<\/?(PRODUCT|GENRE|OVERVIEW|TRACKS|CREDITS)\/?>/g;
? means 0 or 1 occurrences of the character before it, in this case the
/However, it's possible that this might not work unless you group the escaping
\ with the
/ using brackets, as follows:
these_strings = /<(\/)?(PRODUCT|GENRE|OVERVIEW|TRACKS|CREDITS)(\/)?>/g;
Try it without the grouping first.
Also, is there any reason why your closing tags have
/ at both ends, i.e.
</GENRE/>
as opposed to
</GENRE>
which is the format of closing tags in most mark-up languages such as HTML and XML?
Thanks for the tips rawny.
The exact same contents of the text file also gets pasted into the %comment% tag field of the audio files.
I use those <special strings with angled brackets> as delimiters to retrieve string sections from the %comment% tag using foobar2000 title-formatting syntax.
I DO NOT use any other audio tags except these:
ARTIST | TRACKTITLE | ALBUM | DATE | GENRE | ALBUM ARTIST | TRACKNUMBER | DISCNUMBER | COMMENT
Therefore, I use the %comment% tag as an extra database containing custom "pseudo-tags" and "values".
The %comment% tag is a standard tag, and can be read by ANY music player.
I can create custom Playlists, Autoplaylists and Library Searches using fb2k title-formatting and selective searching inside the %comment% tag.
Given the %comment% tag and my text file (folder.txt) are the exact mirror of each other, I can extend my user-interface experience into another dimension;
If I accidentally lose the audio tags, the text file is my backup.
If I accidentally lose folder and file names, the text file contents can be read by command-line tools such as FINDSTR.
In a sense, I'm not just playing audio tracks in a music player but cultivating and indexing an audio collection like a professional librarian (from the old days...
...does anybody here remember the index cards in libraries ???)
I use forward slash at both ends of my closing tags because --after much trial and error-- I found retrieval of delimited string sections from the %comment% tag
using fb2k title-formatting syntax gave me more reliable output.
The standard syntax I use in fb2k to retrieve a delimited section of the %comment% tag looks like this example:
$if($strstr(%comment%,<PRODUCT>),$substr(%comment%,$add($strstr(%comment%,<PRODUCT>),$len(<PRODUCT>)),$sub($strstr(%comment%,</PRODUCT/>),1)),)
@marc2003, I'm chasing some weird problems on my computer and setup (I have a biography component script that seems identical but behaving differently than others), so with the caveat that I don't know if the following is a result of, cause of, or unrelated to the weirdness:
When using your lastfm - similar artists - top tags - top fans - top albums - top tracks script (which I downloaded per your post #1741), every time I hit "update" in the WSH panel I get the following in the console:
Last.fm:
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html>
<head>
<title>503 Service Unavailable</title>
</head>
<body>
<h1>Error 503 Service Unavailable</h1>
<p>Service Unavailable</p>
<h3>Guru Meditation:</h3>
<p>XID: 564881961</p>
<hr>
<p>Varnish cache server</p>
</body>
</html>
and sometimes I also get in the console:
Last.fm: HTTP error: 12152
I've removed all other scripts and settings related to last.fm other than this script and my last.fm username and API key. When I remove this script I never get these console errors. As far as the display of the WSH panel itself, the panel never crashes and frequently correctly shows the correct data. Sometimes it fails to find similar artists for artists I know last.fm has knowledge of and has previously displayed similar artist info.
Are you seeing this or have you seen this before? Any suggestions? Does it really mean anything? Thanks for any suggestions.
that one couldn't be more straightforward. it's a problem at last.fm's end and you'll just have to wait for them to fix it. you can check this page....
http://status.last.fm/ (http://status.last.fm/)
Web services is what you need to be looking at. at the time of me posting:
this one usually indicates local connectivity problems. i know i've seen it when i have no internet connection. but if your connection is fine, then it could well be linked to the above. you'll just have to wait it out.
Wow - you're right, of course. I guess I win today's genius award for not even considering the possibility of taking the error message literally. Thanks!
I would like one more bit of help with my 'WSH Textfile Viewer' panel (see Posts: #1754, #1756, #1757, #1758).
I need a Regular Expression pattern to do this:
If the text file has a line like this:
<IDX>B-52's, the</IDX/>The B-52's – Wild Planet (1980)
Then the WSH textfile viewer panel displays like this:
In other words, using regular expression syntax, how do I remove the "<TAGS>" and the string between them ???
In my previous posts, I solved how to remove the "<TAGS>", but this case is trickier.
If any RegEx gurus are reading this, can you show me the regex pattern which solves such a case ?
I have spent hours and hours trying to solve it but I can't !!
Thanks for your help.
Try something like this (won't work, if the string after </IDX/> contains a ">"):
"<IDX>B-52's, the</IDX/>The B-52's – Wild Planet (1980)".replace(/(<.+>)(.+)/,"$2")
Thanks for the reply
fbuser +++, I will keep your answer for future reference.
I eventually solved it, and the RegEx pattern to do this is quite simple looking:
(LEFT_DELIMITER).*(RIGHT_DELIMITER)What solved it for me was WWW Google searching with this term:
regex remove string between delimiterswhich led me to a solution at this webpage:
stackoverflow.com (http://stackoverflow.com/questions/10485903/regex-extract-value-from-the-string-between-delimiters)
So, looking at an excerpt of the relevant function in my 'WSH Textfile Viewer' script, we see the code I need (in red):
var new_title = "";
var new_text = "";
filename = arr[0];
try {
these_strings = /(<IDX>).*(<\/IDX\/>)|<PRODUCT>|<\/PRODUCT\/>|<GENRE>|<\/GENRE\/>|<OVERVIEW>|<\/OVERVIEW\/>|<TRACKS>|<\/TRACKS\/>|<CREDITS>|<\/CREDITS\/>/g;
} catch(e) {
new_text = "";
window.Repaint();
Before any RegEx gurus comment. . .
Yes, the RegEx pattern for
these_strings = ...; can be optimized and reduced, but I prefer it like this; a list of definite items.
The main reason I couldn't solve it is because I wasn't using parenthesis correctly while forming my RegEx pattern.
Cheers.
Before any RegEx gurus comment...
Yes, the RegEx pattern for these_strings = ...; can be optimized and reduced, but I prefer it like this; a list of definite items.
You called?
Your current expression won't match things like:
<PRODUCT>...</PRODUCT/>
It'll only match lines starting with
<IDX>, e.g.:
<IDX>...</PRODUCT/>
This may be more useful:
these_strings = /(<IDX>|<PRODUCT>|<GENRE>|<OVERVIEW>|<TRACKS>|<CREDITS>).*(<\/IDX\/>|<\/PRODUCT\/>|<\/GENRE\/>|<\/OVERVIEW\/>|<\/TRACKS\/>|<\/CREDITS\/>)/g;
Somewhat simplified:
these_strings = /<(IDX|PRODUCT|GENRE|OVERVIEW|TRACKS|CREDITS)>.*<\/(IDX|PRODUCT|GENRE|OVERVIEW|TRACKS|CREDITS)\/>/g;
However you'll notice that the list of possible values is repeated unnecessarily. To eliminate this - and the potential nuisance of editing both lists if you ever decide to add/remove a tag - you can use a backreference, like this:
these_strings = /<(IDX|PRODUCT|GENRE|OVERVIEW|TRACKS|CREDITS)>.*<\/\1\/>/g;
So the
\1 is replaced by whatever the first set of brackets in your expression matched ("PRODUCT", "GENRE", "OVERVIEW" etc.). For a better explanation of brackets and backreferencing, check this out: http://www.regular-expressions.info/brackets.html (http://www.regular-expressions.info/brackets.html)
Alternatively - although perhaps less to your liking as it doesn't involve any kind of definitive list - you could do something along the lines of what fbuser was suggesting and match any set of tags:
these_strings = /<(.+)>.*<\/\1\/>/g;
Thanks a lot for passing on your RegEx knowledge
rawny +++++++ Highly informative.
In my case, the only
<TAG>string</TAG/> I want fully removed from display is
<IDX>string</IDX/> .
For all the other <TAG>string</TAG/> items, I remove the tags but allow the string to be displayed .
I don't have any problems with my "defined items list" RegEx pattern; everything works for me as expected. . .
HOWEVER, there is a limitation which I am trying to solve
and if you would like to apply your RegEx skills to this it would help solve the final missing piece of the puzzle.
So far, the RegEx pattern I have will only work on single lines in the text file; it fails when operating over multiple lines.
I am in the process of creating another "fully removed" string section delimited by tags named
<CUT> and
</CUT/>, look at this example. . .
If we have these lines in the text file:
The Stone Roses were an English rock band formed in Manchester in 1983.
The band were part of<CUT> the declining punk-rock era, but changed their style
over time to alternative/indie rock. They were one of the pioneering groups of
</CUT/> the Madchester movement that was active during the late 1980s and
early 1990s.
Then the WSH Textfile Viewer panel should display this:
The band were part of the Madchester movement that was active during the late 1980s and
early 1990s.
BUT. . .as I stated before, the current RegEx pattern has limitations and cannot operate over multiple lines.
Any suggestions on solving this ?
*** EDIT ***I found a solution. . .at this webpage: delphifaq.com (http://www.delphifaq.com/faq/perl/f770.shtml)
This RegEx pattern works correctly:
(<CUT>)(\n|.)*(<\/CUT\/>)However, if I add a second pair of CUT tags further down the text file then I remove ALL text from the first/highest <CUT> to the last/lowest </CUT/> . . .which is wrong !
(continuation of Post #1766)
I solved my problem !!!
This Regular Expression pattern:
(START_DELIMITER)(\n|.)*?(END_DELIMITER) will match multiple occurrences of the expression as separate instances.
Therefore, in the case of my 'WSH Textfile Viewer' panel and the multiple occurrences of
<CUT>string</CUT/> in my text file,
I offer proof-of-concept results from a test run in my foobar2000. . .
Text file contains this text:
early 1990s.
They would often display no interest in<CUT> promoting themselves, and many journalists
were confused, and sometimes angered, when their questions were met with complete silence
from the four Stone</CUT/> Roses.
'WSH Textfile Viewer' displays this text:
early 1990s.
They would often display no interest in Roses.
Well. . .that is that; I have all the RegEx I need to control display output in the 'WSH Textfile Viewer' panel .
I hope this was interesting to some of you here, and I will share the 'WSH Textfile Viewer' script and support files with all of you . . .one day soon .
Goodbye and thanks for all the help .
last.fm charts: you can now access 1 month charts. (this is a recent addition to the last.fm api)
I'm currently refining an Album Cover panel which I started years ago.
And after learning so much from this thread and their regular posters,
I'm trying to clean up the mess I made in that code.
Anyway I wanted to share some pics:
(http://img542.imageshack.us/img542/4406/wshcoverscreen3.th.jpg) (http://imageshack.us/photo/my-images/542/wshcoverscreen3.jpg/)
(http://img268.imageshack.us/img268/7117/wshcoverscreen2.th.jpg) (http://imageshack.us/photo/my-images/268/wshcoverscreen2.jpg/)
(http://img839.imageshack.us/img839/6614/wshcoverscreen1.th.jpg) (http://imageshack.us/photo/my-images/839/wshcoverscreen1.jpg/)
I love album art so I created toggles for showing original art or the remastered version.
Further there are toggles for Gloss, Reflection, Label Icons, Progressbar & text alignment.
Also in the edit mode You can drag the different components (art, text, icon) to your favorite position.
In properties you can change that also and some additional settings.
It's still under construction though.
Hi, I'm currently refining an Album Cover panel which I started years ago. .................It's still under construction though.
Very nice ! Do you think to share it ?
When I finish it, maybe.
I have a script for a "Stop After Current" button. I've used gr.DrawLine() to draw an "X" , with the color depending on whether SAC is active. The problem is it does not display correctly when foobar2000 is started. It only draws a small portion of the line drawn top-left to bottom-right, and none of the second line. But - if I bring up the WSH panel config and just click on [Apply] or [OK], then it displays fully as expected.
Here is just the the meat of the script; enough to demonstrate the issue:
var ww = window.Width;
var wh = window.Height;
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
gr.DrawLine(3, 3, ww-4, wh-4, 2, fb.StopAfterCurrent ? RGB(128,128,128) : RGB(188,188,188));
gr.DrawLine(3, wh-4, ww-4, 3, 2, fb.StopAfterCurrent ? RGB(128,128,128) : RGB(188,188,188)); }
window.Repaint(); }
window.Repaint(); }
I'm using the most recent WSH Panel Mod (v1.5.3.1) (Inside a Panel Stack Splitter in Columns UI. But I checked it in a Default UI config and the problem was still present). Much appreciation for any feedback on whether it's something I've done wrong (
other than drawing an X with lines instead of just using text...), or what the problem is, and how it can be solved.
@trout:You need to stick an
on_size() function in there to make sure the graphical stuff is (re-)drawn relative to the panel's final size once it has finished whatever sizing calculations it's doing during foobar start-up.
Try replacing the lines defining
ww and
wh at the top of your code with:
var ww;
var wh;
function on_size() {
ww = window.Width;
wh = window.Height;
window.Repaint();
Hope that helps
rawny,
That's very helpful, thanks!
var ww;
var wh;
ww = window.Width;
wh = window.Height;
is enough. It's not recommended calling window.Repaint() in on_size() function; might trigger some problems.
see Notes&hints.txt in wsh panel mod package.
3. Don't call repaint functions such as window.Repaint() in callback function on_size() {}, especially in pseudo transparent mode.
Neonphytismo, thanks for that reminder!
I actually just saw such an example in the sample scripts, and it made me wonder. But I did not remember reading that warning.
I've always found that warning odd, because I'm not sure how it ensures the
on_size() call happens first and it worries me that on some occasion it might not...
Edit: However looking through all my scripts, only the one I glanced it to help
trout has
on_size() calling
Window.Repaint() unnecessarily. I have one other (type of) script which employ this as well - via an intermediate function - so far it seems necessary to this (type of) script, i.e. I took it out and it broke...I'm going to meddle with it a bit more, although my view of the warning is still the same.
I'm trying to tweak a java script to recognize each of the values in multivalue artist tag fields to generate paths to image folders that I've saved:
Currently, the script allows a user to add paths for images, and a user can add as many paths as desired. For example, I've entered the following:
(thanks to marc2003 for your script capturing and saving last.fm images that we can use elsewhere, as I'm doing here!)
The above entries work well for single value artist tag fields, but currently don't retrieve anything for multivalue artist tag fields (the crc function generates a crc for the string of all the artists in the tag field, and there is no such folder). But most of the time I've got image folders for each of the artists separately and I'd like to add paths to each of those artists, if possible.
Is there some kind of loop I could add that would generate the separate paths for each artist in a multivalue artist tag field, and if so what would that look like? Whether the right answer is a loop or not, any suggestions appreciated!
something like this....
crcs = [];
num = fb.TitleFormat("$meta_num(artist)").EvalWithMetadb(g_metadb)
for(i =0; i < num; i++) {
crcs[i] = fb.TitleFormat("$crc32($meta(artist," + i + "))").EvalWithMetadb(g_metadb);
Thanks, marc2003 - that code was the key to making it work!
I currently use a crude but effective way to download images for the nth artist for a track: I use your thumbs script and remap the artist field in the context menu to $meta(artist,n) and restart the song to trigger the search and download. If there is a more elegant way to grab images for all artiists for a multivalue artist track, suggestions are appreciated, including any tweaks to put in the thumbs script or common4.js.
i've shamelessly stolen romor's allmusic script from the foo_uie_biography thread.
this can display either album reviews or artist bios. the reason i've put this in a WSH panel is because i can support caching which means instant panel updates and offline usage after the initial download of each item. you can also switch between reviews and bios on the fly using the context menu.
existing users of my scripts need to extract the marc2003 folder from the zip as it contains a new file required by this script.
@godrick, i'll look into it.
Marc, I'm very grateful for your work. Just tried out your allmusic script - with each and everything I select I get "no text" - I am really sure I copied everything over to the appdata marc2003 folder. The console has no error at all.
Is there something I can do?
Wow thanks for this - you rule... and I'm not just sayin' it. =D
It works fine for me - returns results as regularly as the bio panel, however throws up errors occasionally (2 times so far in 10 tracks tested):
Error: WSH Panel Mod (Allmusic by marc2003, Uses a modded version of foo_allmusic.vbs by romor): Microsoft JScript runtime error:
Invalid procedure call or argument
File: <main>
Ln: 70, Col: 2
I can't offer more any more details than that yet as to 'causes...
UPDATE:
Different error:
further testing gives me steady script errors for %album artist% "Various Artists" (on albums that exist at Allmusic):
line 13; char 7
error Object doesn't support this property or method: 'i.firstchild.firstchild.getAttribute'
code 800A01B6
MS VBScript runtime error.
This error does not appear for albums that are not at Allmusic.
marc, how can I edit your .txt file reader to display preformatted text (such as EAC and CUETools logs)?
Thank you for all your work.
@Emerelle, do you not even see a "fetching info" message for a few seconds? if you see that before the "no text" message, it means the info wasn't found.
also, a limitation of the script is that the album must be on the allmusic site, even in artist bio mode. if there is no album tag, then the script won't run.
@mjm716, i've managed to stop the script erroring (extract marc2003 folder again and import the allmusic.txt into your panel) but i can't fix why it won't display various artist albums that do exist. you'll have to ask romor about that. i'm assuming they also fail in the foo_uie_biography panel as well???
@Dario, right click the panel and select "path to text file". use titleformatting to enter the filename. as an example, if the filename is "eac.log" and it sits in the same folder as the playing file then you would use
$directory_path(%path%)\eac.log
You didn't understand my query (or perhaps I didn't phrase it well).
I'm talking about something like this:
[CUETools log; Date: 23/08/2012 02:12:15; Version: 2.1.4]
[CTDB TOCID: EbOzQZA2.F7k_wn4ygo8ZQjbXW4-] found.
Track | CTDB Status
1 | (3/3) Accurately ripped
2 | (3/3) Accurately ripped
3 | (3/3) Accurately ripped
4 | (3/3) Accurately ripped
5 | (3/3) Accurately ripped
6 | (3/3) Accurately ripped
[AccurateRip ID: 000a4a8e-0036c64a-4c09cd06] found.
Track [ CRC | V2 ] Status
01 [3c12ca33|d6783547] (2+2/4) Accurately ripped
02 [ed4a2680|68c012ea] (2+2/4) Accurately ripped
03 [5c81b1b1|2a9cc5af] (2+2/4) Accurately ripped
04 [4a491601|508711d5] (2+2/4) Accurately ripped
05 [99538ce0|1aff3f26] (2+2/4) Accurately ripped
06 [24fccfc5|301d2fe3] (2+2/4) Accurately ripped
Track Peak [ CRC32 ] [W/O NULL] [ LOG ]
-- 97.7 [82DD0EAB] [E0DDA975] CRC32
01 97.7 [FC49B125] [C640A7E7]
02 97.7 [E1E665AD] [94E1D6EE]
03 97.7 [E707FB25] [B2326DDB]
04 97.7 [56C2CF85] [808E4293]
05 64.0 [F18C3285] [EE5A4EDB]
06 97.7 [5C5D1E5E] [2C20C7EA]
The whitespaces are preserved and the text is formatted properly, but if I were to just "paste" it, it'd end up being a mess (which is what the .txt reader ends up displaying).
Do fixed-width fonts such as Courier New not preserve whitespace when used within the panel?
Awesome. They do; but what am I supposed to change the normal_font variable with:
gr.GdiDrawText(text_array[i + offset], normal_font, g_textcolor, 6, 16 + (i * row_height), ww - 16, row_height, DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
It uses the generic font, in my case, Ubuntu Condensed, which isn't monospaced. I'd like to change it to Ubuntu Mono or Courier New (the latter preferred).
Marc yes I see that message as well - but no info gets displayed even on albums /artists that are on Allmusic (and the tags are intact).
Okay, I figured the way through my issue by myself. Reading the WSH Panel Mod docs can get you a long way. Thank you guys.
Adding examples to my post above:
Joy Division - has text, exactly one match in the artist panel (found straight away using the webbuttons of your samples)
Infected Mushroom - also has text, exactly one match, also found through the webbutton from the sample. Still no error in console.
Is it possibly incompatible with anything like the other bio panel?
PS: Ok, now I got for the first time the very same error like a couple of posts above - error in VB Script etc. It is the same message text as posted above.
the script searches for the album first and then tries to match the artist so it's no good searching for the artist on it's own. can you give some artist/album combinations to test?
also, if you're seeing script errors, that's not a good sign. but i did mention above that i updated the script so it doesn't display errors anymore. it now fails silently.
Different error:
this is now fixed. the script needs re-importing and the marc2003 folder needs extracting again.
I wasnt aware of an update, your post seemed not modified, I will download that again and report back. I also didnt know I should search for the album first, I will use this advance now.
PS: Ok, now I see the update
Different error:
YES! and YES! thank you so much.
I've tried about 50 tracks, and no errors, and I've finally been getting results from 'Various Artists' items - the approximate album name matching seems very robust.
Now comes the annoying follow-up wish! It would be fantastic to get it to scan the whole library instead of only the current track, to make a complete local data set. =D
[Hopefully that's something I can figure out if you're not interested.]
I do have one general question that doesn't make any sense to me.
The wsh script uses %album artist% (twice). I've tried changing that to %artist% instead (with the idea for example, that when it retrieves a compilation review, it could simply pull the normal artist bio). However, using %artist% returns no results, for regular albums or compilations (checked against known artists with bios).
am I missing something?
@mjm716, yes I think you are missing something
The search string in romor's script contains "URL = "http://www.allmusic.com/search/albums/...", for a very good reason if one is looking for both an album review and the right artist bio in one elegant search. So if you want an artist bio not linked to an album search result, you need to do a different search. I think the code you need to borrow is already in the script.
For example, consider replacing the "then" portion of of the following "if" statement in the current script:
If Lcase(ARG(0)) = "various artists" And ARG(2) = "bio" Then Wscript.Quit() End If
to execute a search using an artist search string:
URL = "http://www.allmusic.com/search/artists/" & LCase(Replace(ARG(0), " ", "+"))
So the "then" portion of the "if" statement above would conduct an artist search. I looked at the web page's source code for such a search result, and I believe you can use the same code as that used to assign artist_link in the current script to find an artist bio, keeping mind that the script will return the first matching search result, which may or may not be the artist you are looking for if it's a common name.
Make sure you quit the script at the end of this "then" section, and add an "else" line after your new code and just before the existing code that follows the "if" statement above so that the script continues to work as before for album artists that are not "various artists".
Thanks G - yes, for some reason, the script logic only sinks in briefly and disappears promptly again.
One other error to report:
If there is no internet connection, it really freaks out - sends many pop-up error reports that makes the app unresponsive.
vbs script error: line 34, char 3; system cannot locate the resource specified
code 800c0005; source msxml3.dll
with no connection, it should be pulling from a saved file if it exists, or otherwise dumping gracefully?
thanks for the good work guys!
yesterday i accidentally removed the part that hides popup errors. at the moment line 101 starts like this....
WshShell.Run(script_path....
edit it so it becomes...
WshShell.Run("cscript //nologo " + script_path...
i hope it doesn't hang in the background when it fails but i have no way to test this as i'm using a computer at my library where i have no control over any settings.
marc2003, regarding your Now Playing script...
Depending on the dimensions of the panel, some artist images work quite a lot better than others. And often, one particular image looks just right.
Would it be possible to add a function to lock a certain image into place? Or to have the panel remember the last image selected?
Alternately, a "delete all but current image" function would work too.
I know this can be accomplished manually, but with thousands of artists it would take a bit of time
that seemed to fix the no internet pop-ups.
however one other bug - if 'allmusic_bio.txt' exists, it's not being read.
if (fso.fileExists(filename)) g_text = read(filename);
I tested that filename path was correct and file exists = true; but if read is a function, it's missing?
another strange issue -
the WSH version only displays & saves to allmusic_bio.txt the 1st paragraph from allmusic, while the biography panel displays the whole bio text...
marc2003, can't you use WSC (http://msdn.microsoft.com/en-us/library/dd79w6c8) (wrap vbscript in XML and set parameters) then call it as object function from javascript?
I've done the opposite here (http://www.hydrogenaudio.org/forums/index.php?showtopic=86092), when needed crypto service from javascript function, not knowing that there is already crypto COM object exposed by .NET
Hope it helps instead complicate things
the read function is my common4.js file. it would error if missing plus no text from any cached files would display. although unlikely, it's possible the txt file is empty but it shouldn't be created unless there was something to save.
i have no idea why this is. i'll look into it. this is now fixed. just the script in the panel needs re-importing.
@romor, i'm not using your amazon script so i don't really have any idea what you're on about. if you look at the parameters, i'm just calling your allmusic script with a file path added to the end. rather than output the text using WScript.echo, i'm saving to text file which my script then reads.
i know it should be fairly trivial to port the whole thing into a WSH panel but i've don't have much access to a computer at the moment.
I was suggesting you use it as COM object instead using shell run. You could run any function from it as it was JS. Amazon script was working example
Nevermind...
Cheers
Concerning my problems with the allmusic script, I think I found out that I simply dont receive any info because that very album is not there, in spite of the artist info being there. I think that is the way it works? Its a pity though
I have another two questions for the simple text reader: Does the path to the text file need to be changed in both script and dialog? I tried to insert an if function because I wanted it to look in one level up if no info.txt is found, but that did not display anything.
Second question concerns the right margin: I managed to change both top and left text margins only the value for the right one is unclear to me which one I have to change in the script.
normally users would not need to edit the script as the dialog accepts any title formatting. your problem is that you cannot check for the existence of files using title formatting alone. i might add a hack to get around this.
as for the margins, you need to browse the
marc2003 folder in your foobar profile directory. edit
common4.js in a text editor. on line 286, you'll see
lines = temp_gr.EstimateLineWrap(paragraphs[i], normal_font, ww - 16).toArray();
ww - 16 is the relevant bit. increase the number to make the margin bigger. after changes have been saved you need to reload the script in your panel for it to pick the changes up.
also i should mention that playing with the top margin may break the calculation for how many rows to display. you might need to adjust the panel script on line 25.
rows = Math.floor((wh - 32) / row_height);
just the number 32 would need tweaking.
simple text reader you can now use multiple file paths in the
path to text file dialog. it will check each one in turn until a file is found. separate each entry using
| with no spaces.
unfortunately there is a limit of 255 characters for the standard input dialog. if you find yourself running into this limit, hold down
shift before right clicking the panel. select
Properties from the menu and then edit the value of
text_file in the popup dialog.
Awesome Marc, thanks so much for both your advice and the update.
EDIT - I figured it out - look in one folder up works like this
$directory_path($directory_path(%path%))\info.txt
And now it works for both the content folder plus one folder up using it like this:
$directory_path(%path%)\info.txt|$directory_path($directory_path(%path%))\info.txt
Awesome!
Has anyone tried Marc2003's scripts in OSX via wineskin? I have my config working very well, but use Marc2003's scripts heavily, and am getting errors all over the place. I have one other WSH panel working fine that doesn't any dependencies so I don't think it's a WSH panel problem.
I run them under Wine on Ubuntu and had errors at first. I basically had to comment out some parts of the
common4.js script. I think I figured out which ones by looking at the line number that was causing problems in the foobar console and going from there. I can specify which bits I effectively cut out if you like, although it may be a bit different for you. Also, naturally some of the scripts won't necessarily be usable if you do cut chunks out of the common script. Personally I'd rather have some than none so that's why I went down this route
I run them under Wine on Ubuntu and had errors at first. I basically had to comment out some parts of the common4.js script. I think I figured out which ones by looking at the line number that was causing problems in the foobar console and going from there. I can specify which bits I effectively cut out if you like, although it may be a bit different for you. Also, naturally some of the scripts won't necessarily be usable if you do cut chunks out of the common script. Personally I'd rather have some than none so that's why I went down this route
I was going to attempt that but the console wasn't helpful. It reads:
WSH Panel Mod (Thumbs by marc2003): Parsing file "C:\users\Sixth Street\Application Data\foobar2000\marc2003\common3.js"
The popup dialog box says:
Scripting Engine Initialization Failed (Thumbs by marc2003, CODE: 0x800a01ad): Unknown error code (2148139437)
Any help would be greatly appreciated!
If you copy the whole of the
common.js script into a panel above the script you're trying to use it for, or maybe even on its own to begin with, you should get more informative errors in the console. If your adding to a script though, make sure to remove the import line:
// @import "[...]common4.js"
i've had my scripts working in WINE. i found an old post where i detailed what i had to do...
save this somewhere as
winetrickshttp://www.kegel.com/wine/winetricks (http://www.kegel.com/wine/winetricks)
run it from a terminal
sh winetricks
select
gdiplus
ie8
wsh57
i suggest downloading my latest scripts (i can tell yours is old because you mention common3.js and i've been on common4.js for ages now).
edit common4.js in a text editor and comment out lines 401 & 402 like this...
//var vb = new ActiveXObject("ScriptControl");
//vb.Language = "VBScript";
doing this means input dialogs won't work from the context menu but if you copy the entire config from a working windows machine, it should just work. if you do need to set some variables then you might need to edit the script directly. give me a shout if you need any help.
save this somewhere as winetricks
sh winetricks
select
gdiplus
ie8
wsh57
I'm not sure whether this part will be applicable as
Sixth Street is running foobar on OSX via wineskin - they may have a
winetricks equivalent though...? (I don't know how much wineskin differs from pure WINE.)
oops, i missed that. i'd hazard a guess at WINE being installed though so it may work??
Wow epic formatting screw-up -.-
I was trying to say that it might work from the point of view that some WINE is probably in there.
I think the best thing to do would be for Sixth to update all your scripts first and then see what's happening after that.
writing playlist viewer like esplaylist - with grouping. i create an object - album, which contents the songs.
pl_album=function(name,content,metadb) {
this.display_image=utils.GetAlbumArtV2(this.metadb,0,true);
content=massive of objects contents the tracks
metadb=this.Items.item(i) - one item of playlist.
as i understand while creating groups i call for a cover, but callback on_album_image_load_done isnt called. what i doing wrong? or how better load images for albums on screen?
i don't think there is any such thing as on_album_image_load_done. there is on_get_album_art_done which is only called when using utils.GetAlbumArtAsync, not utils.GetAlbumArtV2.
Yup, you are correct. I should try the newest scripts first. It's just that I've heavily modified some of the scripts for my own usage and since they were working just fine never decided to update and have to try to re-create my modifications. I'll try the latest stock scripts and report back.
You could compare your modified versions and the new ones using some kind of text comparison program and then put your changes in, but yeah. Yell if you need any more help
I'm beating my head against a wall with something that seems simple, but I'm missing something - help appreciated!
I'm trying to invoke title formatting within a jscript to extract a portion of a path. For example, let e_1 equal the variable that contains the path. I echo e_1 to the console to ensure that e_1 really contains a path. For example, the console echoes
as I expect, which means the script recognizes e_1 and knows that it contains the string it echoed to the console.
But in the very next line of the script, when I try
y4 = fb.TitleFormat("$strrchr(e_1),_)").Eval(); (in this case I'm looking for the first occurrence of an underscore in the path stored in e_1),
y4 equals 2 instead of 10 per the console echo. The title formatting is treating "e_1" as the string it's evaluating, instead of treating e_1 as a variable and evaluating the string "c:\users\xyz\appdata\roaming\123456789_kjl.jpg". I played around with the name of my variable and moved around the underscore to ensure I was correct in my interpretation of what is happening.
I can't figure out how to get the command line to evaluate e_1's value. I also tried fb.TitleFormat("$strrchr($get(e_1)),_)").Eval(); but that didn't work either. I'm probably missing something simple as usual, but I can't figure it out. Thanks for any advice!
e_1 is your variable in the script but you're treating it as a plain text in your title formatting.
but you don't even need to use title formatting for this. javascript has indexOf.
y4 = e_1.indexOf("_");
I've got a suggestion for your "now playing" script marc2003.
Since it shows album art, I now use this panel instead of the album art viewer, the only downside is it takes a couple of clicks more to come to the directory of the currently playing track.
It's nice to be able to find the artist picture folder by double clicking, but if I double click on the albumart I would like to come to that directory instead. Just an idea, that I think makes sense?
that's a reasonable request. samples updated: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
now playing: double clicking the album art image locates the image in explorer. double clicking anywhere else in the panel opens the artist image.
wow, that's fast thanks!
Yes, marc2003 you are correct in describing the problem, and using javascript string object methods in this example does work. But I've got other sting formatting actions I'm trying to do that either require me to figure out a way to have e_1 recognized correctly in a fb.titleformat expression, or at least seem easier with title formatting than with javascript string object methods. I've successfully passed variables to fb.titleformat expressions previously and even in other places in the script I'm working on, but none of the other expressions involve string formatting - is there something I need to do in this or similar cases to have the variable recognized as such? Thanks for the help!
@Falstaff
is it possible to add this option to a WSH Playlist Viewer (item.cover_type=2) ?
(http://www.picshare.ru/uploads/120914/5q428S8F8A.jpg) (http://www.picshare.ru/view/268504/)
@godrick
fb.TitleFormat("$strrchr(" + e_1 + "),_)").Eval();
A function I made to make my life a bit easier: it can register object methods to be called as if they were global callbacks. The following example will print 3 messages in the logs whenever the playback state is changed: one for each of the objects that registered their own callbacks in their constructors, and one for the global callback, that was properly stored before replacement. Get the actual code at github (https://gist.github.com/3725305).
// Actual code ommited, grab the latest version from the link above!
// function registerFooCallbacks(obj);
function MyPlayMonitor(id)
this.id = id;
registerFooCallbacks(this);
MyPlayMonitor.prototype.on_play_order_changed = function(new_order_index)
fb.trace("Play order changed! (id = " + this.id + ")");
MyPlayMonitor.prototype.on_playback_pause = function(state)
fb.trace("Playback state changed! (id = " + this.id + ")");
function on_playback_pause(state)
fb.trace("Global callback, reporting for duty.");
var play_orders = [new MyPlayMonitor("foo"), new MyPlayMonitor("bar")];
@godrick
Wow, I should have been able to figure that out....but I didn't. Thanks very much marc2003, once again!
@onv
possible yep, from me no, sorry, there are better things that are waiting to be done imho.
musicbrainz releases has been renamed to musicbrainz. this is because it has a new mode and that is to show some clickable links to various pages online. unlike my weblinks script which attempts to guess URLs based on artist metadata, these are all official pages. you can switch between releases and URLs via the context menu.
(http://dl.dropbox.com/u/22801321/mb%20url.PNG)
Would it be possible to combine the artreader with the playback buttons so that the buttons are on top of the artwork and functional?
I previously did something similar with the normal artwork reader + rainmeter's NowPlaying plugin but it wasn't the cleanest solution.
I'm not asking for someone to do it - I'm just asking if it's possible.
Thx.
I think I'm out of luck of this, but I'll ask just in case: I'd like to deselect options in the main foobar2000 toolbar in a js script. I tried fb.RunMainMenuCommand and fb.RunContextMenuCommand but no joy. I wasn't surprised by that, since I understand those commands are limited to what you can select from the main menu and context menu for what is playing, and the toolbar selections are not normally available either of those ways. I also looked through all the commands exposed by foo_runcmd and also did not find anything on point. I'd like this to work for DUI, so I can't hide the toolbar or status pane as CUI does as has been discussed many times.
For what it's worth, I'd like to not display all main toolbar selections other than buttons when my display goes below a certain size, and restore the display of certain toolbars when the display goes above that size. I'd settle for turning all toolbars off instead of selective control if that were the only option.
Is there something I'm missing, or a workaround other than use CUI? Thanks for any advice as usual!
marc2003 and anyone interested - this is what I came up with to revise Thumbs to automatically download images for all artists in a multivalue artist tag field and other fields as defined in the code below. If one wanted this to also work for multivalue composer or conductor tag fields, this could be changed to accommodate that easily. The first function is an existing function revised to add a new call, and the following two functions are new. No other changes to Thumbs - the artist field remapping selection still works as it did before. Thanks for the help!
update_all_images();
// new function to update all artist, composer, conductor images
function update_all_images() {
crcs = [];
folderart = [];
num = fb.TitleFormat("$meta_num(artist)").Eval();
debug && fb.trace("Thumbs script: " + num + " total artists");
crcs[i] = fb.TitleFormat("$meta(artist," + i + ")").Eval();
folderart[i]= data_folder + fb.TitleFormat("$crc32(" + crcs[i] + ")").Eval();
debug && fb.trace("Thumbs script: artist " + i + " " + crcs[i]);
download_my_images();
crcs[i] = fb.TitleFormat("[%conductor%]").Eval();
if (crcs[i] != "") {
debug && fb.trace("Thumbs script: conductor " + crcs[i]);
download_my_images();}
crcs[i] = fb.TitleFormat("[%composer%]").Eval();
debug && fb.trace("Thumbs script: composer " + crcs[i]);
debug && fb.trace("Thumbs script: completed downloading");
update_image();
//borrowed from common4 and tweaked - custom function to download art
function download_my_images() {
working = true;
window.Repaint();
debug && fb.trace("Thumbs script: downloading art for " + crcs[i]);
WshShell.Run('"' + script_path + 'art.exe" "' + crcs[i] + '" "' + folderart[i] + '" ' + limit, 0, true);
working = false;
i've done it anyway - just a quick bodge together of the 2 scripts. http://dl.dropbox.com/u/22801321/art%20rea...k%20buttons.txt (http://dl.dropbox.com/u/22801321/art%20reader%20with%20playback%20buttons.txt)
i'm not really sure what you mean by this as you can't customise the menu in DUI. but you can re-create your own. look at the
MainMenuManager All-In-One script bundled in the samples folder that comes with the component. this allows you to use only partial submenus such as file, view, help etc so you could omit ones you don't use but this is only useful for columns where you can hide the original toolbar.
Sorry for not being clear: within a js script, for a DUI layout, if any of the following toolbar items are displayed, I want to not display them when my foobar2000 display size goes below a certain size:
- layout editing mode toggle
- playback order
- playlist switcher
- any visualization
- volume control
... and then restore the ones from the list above that were previously displayed when the screen size increases.
Anyone have any experience with something like autohotkey to control these (i.e., commands not accessible from the main menu or context menu for what is playing)?
Amazing. Thank you so much.
small update to my musicbrainz script - http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
it now has icons for the most popular websites...
(existing users need to extract the marc2003 folder again as it contains the new images)
@godrick, what you're asking is well beyond the scope of WSH panel mod.
panel stack splitter (for columns UI) can do this easily because you can hide the main toolbar and add each toolbar as a panel. you then have full control over what displays and what doesn't when panels are resized etc...
@godrick:
See references:
CalcTextHeight()
CalcTextWidth()
you'll probably want:
MeasureString()
I've struggled to find examples of any of these in an actual javascript to help me use them - if anyone has any js scripts that use these, or have written any js code to facilitate their use, it would be much appreciated if you could post or PM them to me.
ww = 0;
wh = 0;
text = "some text and some more text bifsdfsdf sf s fsdfsdf sfsdfsf ";
font = gdi.Font("Segoe UI", 14);
colour = RGB(255,0,0);
function RGB(r, g, b) {
return (0xff000000 | (r << 16) | (g << 8) | (b));
ww = window.Width;
wh = window.Height;
function on_paint(gr) {
gr.DrawString(text, font, colour, 0, 0, ww, wh, 0);
line_length = gr.MeasureString(text, font, 0, 0, ww, wh, 0).Width;
gr.DrawLine(0, 15, line_length, 15, 1, colour);
can i with this addons create a callback for cdrom tray insert and drives changed (for example, inserted usb device, disk to cdrom or hdd)?
simple text reader now has a toggle on the right click menu to enable/disable fixed width fonts.
(existing users must extract the marc2003 folder again as well as importing the new script)
i use window.repaintrect with constant size, but cpu loading depends on window size. is it normal?
marc2003, a belated thanks for the script showing MeasureString in actual js use. I can't thank you enough for the help!
no changes to scripts but the file foo_allmusic_mod.vbs inside the marc2003 folder has been updated to work with recent changes on the allmusic site. thanks to romor for his original script and providing this fix.
GdiDrawText-based text in panels doesn't automatically break words or phrases between e.g. () or "" nicely.
The parentheses and the quotation marks get widowed or orphaned:
Blah blah (
blah) blah.
Flip "flop
" flip flop.
The flag DT_WORDBREAK doesn't seem to handle (some?) glyphs and the like, or is the rub placed somewhere else?
Is it doable in JS or VBS to write a simple function that takes care of these situations?
As far as I can see, MSDN doesn't provide any solutions.
My limited mental capabilities prohibit me from composing a usable search string and google for a solution .
I'm very grateful to marc2003 for especially the Artreader and Allmusic scripts and of course to T.P Wang for making all this possible.
It's great fun reading the WSH fora.
(I'm not a programmer any more, it's 25 years since I made my last endless loop on a mainframe ... this GDI stuff is indeed terra incognita).
in new version (v1.5.5.1) this doesnt work:
//GetDeviceInfo by GiveMe9 http://www.hydrogenaudio.org/forums/index.php?showtopic=70363&view=findpost&p=770121
var wbemFlagReturnImmediately = 0x10;
var wbemFlagForwardOnly = 0x20;
//SoundDevice
g_text = "SoundDeviceInfo";
var objWMIService = GetObject("winmgmts:\\\\.\\root\\CIMV2");
var colItems = objWMIService.ExecQuery("SELECT * FROM Win32_SoundDevice", "WQL",wbemFlagReturnImmediately|wbemFlagForwardOnly); //<<<<<---error there
var enumItems = new Enumerator(colItems);
for (; !enumItems.atEnd(); enumItems.moveNext()){
var objItem = enumItems.item();
g_text += "\nProductName:"+objItem.ProductName;
g_text += "\nstatus:"+objItem.Status;
//END_GetDeviceInfo
any way to solve this problem?
also doesnt understand how custom tooltip works - cant put normally string on it
With the seemingly apparent death of foo soft Playlists... I'm wondering if any of you WSH script wizards could conjure up an easy way to aggregate a last. Fm user's loved tracks onto a Playlist. I relied heavily on this to as a quick and easy way update my tracks that had not yet been tagged in foobar as loved.
Here is stylesheet (xspf.xslt) that transforms last.fm XML response to XSPF playlist: view (http://db.tt/oXw2iewA) or download (http://db.tt/Dro9uP9t)
CLI Usage:
msxsl lastfm-response.xml xspf.xslt -o lastfm-response.xspfwhere lastfm-response.xml is response from i.e.:
GET http://ws.audioscrobbler.com/2.0/?method=user.getlovedtracks&user=some_user_name&api_key=some_api_key
Of course it's not limited to just 'user.getlovedtracks' call
Some thoughts:
- obviously there is no other way, except XSPF, to reference tracks w/o providing track location
- foo_softplaylist is the only component able to handle XSPF paired to local library (I've done this in COM server component by iterating library, but it's not that great)
- user has to access menu (load xspf...) and browse to XSPF location, to be able to see result
- I have no idea if msxsl tool comes by default with Windows or I got it from office or by d/l msxml tools, anyway it's not necessary for end user to have this tool, as XSLT can be easily done with WSH, this is just one raw possibility with a small battery inside
- maybe foo_softplaylist developer will wake up in the meantime
Blah blah (
blah) blah.
Flip "flop
" flip flop.
if you're talking about my scripts, then the problem is indeed elsewhere. i'm using the WSH panel mod
EstimateLineWrap function which seems to be the cause of this problem. the reason i started using this is to get an accurate height for long bodies of text so i can control when to stop scrolling.
can i get somewhere windows8 metro desktop colors of current user?
@marc2003
I am probably doing something stupid, but I cannot get the allmusic script to work even for popular albums that are at the allmusic site. Can you confirm that the actual foo_allmusic_mod.vbs and allmusic.txt scripts in the recent download link of post #1845 are the correct ones and working? I always get [fetching info] followed by [nothing found]. Or do you have any other suggestions or special instructions? The other internet search scripts like musicbrainz.txt & news-reviews-blogs.txt work fine.
@marc2003
Thank you for the reply.
Yes, I was talking about your very useful allmusic script; as it by nature is dual mode I have implemented it in two WSH Panel Mod tabs: AMG bio/AMG review). A third tab is used for another of your charms, Musicbrainz Releases.
Offline reading in fb2k is really time-saving!
Getting back on topic: I will dig deeper into allmusic.txt, common4.js, and your modded version of romor's foo_allmusic.vbs to get a better understanding of what's happening. Plus of course the WSH Panel Mod documentation.
I'll be back, as someone once said in a movie.
@romka18, maybe utils.GetSysColor(x). x is number, range 0 to 30 i *think*
@WilB, i doubt you're doing anything wrong - it does seem a bit temporamental. all i can suggest is try clearing the IE browser cache through its options and trying again.
@PeteG, in the allmusic script, inside the on_paint function, replace the
default: section with this...
gr.GdiDrawText(g_text, normal_font, g_textcolor, 6, 45 - (offset * row_height), ww - 16, text_rows * row_height, DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
gr.FillSolidRect(0, 0, ww, 45, g_backcolor);
gr.FillSolidRect(0, wh - 15, ww, 15, g_backcolor);
gr.GdiDrawText(allmusic_type == 1 ? "Allmusic review" : "Allmusic bio", title_font, g_textcolor_hl, 6, 6, ww - 77, 24, DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.DrawLine(5, 29, ww - 10, 29, 1, g_textcolor_hl);
up_btn.draw(gr);
down_btn.draw(gr);
it seems ok on XP. i can't test on vista/7 at tmoment.
hi please could someone post a nice volume bar script?
@PeteG, in the allmusic script, inside the on_paint function, replace the default: section with this...
Yes! Colour me impressed! Thank you very much, marc2003.
Your new code snippet is doing the job flawlessly, except for a minor drawback: words compounded with a hyphen - record-making, fine-tuning
- are no longer wrapped after the hyphen, they are sent to the next line as a whole. It's just an observation. I've got precisely what I
asked for and I'm a happy man.
Dare I suggest that you put the new lines in the allmusic scipt, commented out and with a single line of explanation (I mean, why waste good
code)? Or am I the only person on Planet Earth with these nitpicking idiosynchrasies in regard of parentheses and quotation marks?
By the way: I haven't got the faintest idea of what's happing. I can
see the difference between the new and the old
default: section,
that's all. I have a long piece of homework to do, I guess. In the end DIYing is (well, can be) much more satisfying than begging others for
help. But for now GDI coding is close to Sanskrit in my view; my old arteries a hardening just fine, thank you.
On Vista 32-bit and 7 64-bit: Tested & Passed. foobar2000 1.1.15, WSH Panel Mod 1.5.6.
I created two Popup Panels (v0.1.4) each with an instance of WSH PM, one running the old allmusic script, the other the new script.
And did a lot of resizing the panels.
i can improve the snippet i posted above. it's bit of an ugly hack but the main thing i wanted to test was appearance. now that's confirmed ok, i'll be updating all my scripts. infact i'm giving them all a major overhaul so it'll be a few weeks before i post the new version.
edit: samples updated with an updated allmusic script. just the marc2003 folder needs extracting. the script in the panel doesn't need updating. thanks to romor again - this is definitely working more consistently than before.
Argh - struggling to capture in a js script the maximum pixel resolution of a display. I thought window.MaxWidth was the correct command, but it returns a nonsensical answer of 2147483647. I tried window.width and it returns the correct pixel width of my current display window and correctly changes as I resize that window, so I would expect MaxWidth to also return a pixel width. For what it's worth, window.MaxHeight returns the same value of 2147483647 that I don't understand, while window.Height correctly returns the pixel height of my display window. Any advice appreciated!
use utils.GetSystemMetrics....
fb.trace(utils.GetSystemMetrics(16) + "x" + utils.GetSystemMetrics(17));
edit: this only gets the current resolution. i'm not sure if you can query what your monitor actually supports if you're running at a lower res.
window.Width and window.Height are the dimensions of the panel.
window.max/min width/height are for setting the max/min panel heights. this is useful if you want to lock the size.
Works great, and thanks for the explanation as well.
Heh, it is not really a nonsensical answer. 2 147 483 647 (2
31 ? 1) is the maximum value that 32-bit signed integer can have
2marc2003
no, GetSysColor() returns this colors:
(http://imageshack.us/a/img705/4479/explcolors.jpg) (http://imageshack.us/photo/my-images/705/explcolors.jpg/)
but i try to get this ones:
(http://imageshack.us/a/img89/332/metrocolorsl.jpg) (http://imageshack.us/photo/my-images/89/metrocolorsl.jpg/)
i searched it in registry but didnt find them.
Is there a script that replicates the information shown by CUI's Status Pane? I'd like to study such a thing for my own learning purposes.
i've done a close thing for a config, but it's more the status bar than the status pane, get it and check the script here : http://fav.me/d4maqsc (http://fav.me/d4maqsc)
I'm trying to use utils.glob to return directories in a path, instead of files in the path. This appears to be possible based off of the FILE_ATTRIBUTE_DIRECTORY flag, but it doesn't seem to work. I've tried passing:
"C:\\temp\\"
"C:\\temp\\*"
"C:\\temp\\*."
"C:\\temp\\."
etc. and I only get the files in that path, but never the directories in that path which is all I want. I've tried some of the other flags, but still no joy.
Anybody have any ideas?
I don't know of an elegant approach, but a crude method that works is to use utils.glob to grab the full file paths, then whack everything from the right up to the first \ for each array element, and then use a duplicate elimination function borrowed from ojdo's HTPC scripts with which you're probably familiar:
function eliminateDuplicates(arr) {
var i,
len = arr.length,
out = [],
obj = {};
for (i=0; i<len; i++) {
obj[arr[i]] = 0;
for (i in obj) {
out.push(i);
return out;
http://msdn.microsoft.com/en-us/library/e1...v=vs.84%29.aspx (http://msdn.microsoft.com/en-us/library/e1dthkks%28v=vs.84%29.aspx)
Any idea why I get an “invalid pointer” error on line 19 (http://pastebin.com/waz8PuYV) ever now and then (it has happened 3 times in 2 and a half months)?
Help welcome - I recently updated obsolete timer functions in all my scripts, only below script refuses to work when I replace window.CreateTimerInterval with window.SetInterval.
I'm a non-coder, so you're welcome to point out my mistakes, important stuff missing, redundant stuff, runaway timers, endless loops etc.
// ==PREPROCESSOR==
// @name "Cover Panel" by Br3tt, mod by Zin-Uru, mod by TEA
// ==/PREPROCESSOR==
var g_tooltip = window.CreateTooltip();
var hover = null;
var g_img = null;
cover = function () {
this.reset = function () {
this.x = 0;
this.y = 0;
this.update = function () {
this.x = img_info.x;
this.y = img_info.y;
this.swap = function (cover_source) {
this.image = cover_source.image;
this.x = cover_source.x;
this.y = cover_source.y;
var covers = Array(new cover, new cover);
var fader = 0;
var alphamax = 255;
var fading_step = 15.0;
var g_timer;
var g_refresh_timer = 40;
var g_metadb;
var is_stream = false;
var is_embedded;
var is_art;
var art_path = "";
var WshShell = new ActiveXObject("WScript.Shell");
var bg_dir = fb.FoobarPath + "\\skin\\";
var id = 0;
var img_info = {x: 0, y: 0, w: 0, h: 0};
function FormatImage(image, iw, ih) {
if (!image || !iw || !ih) return image;
var scale_w = ww / image.Width;
var scale_h = wh / image.Height;
var scale = Math.min(scale_w, scale_h);
var pos_x = 0,
pos_y = 0;
img_info.w = iw;
img_info.h = ih;
if (scale_w < scale_h) pos_y = (wh - image.height * scale) / 2;
else if (scale_w > scale_h) pos_x = (ww - image.Width * scale) / 2;
var tmp_img = gdi.CreateImage(img_info.w, img_info.h);
var gp = tmp_img.GetGraphics();
gp.DrawImage(image, pos_x, pos_y, image.Width * scale, image.Height * scale, 0, 0, image.Width, image.Height);
tmp_img.ReleaseGraphics(gp);
CollectGarbage();
return tmp_img;
function refresh_cover() {
covers[0].swap(covers[1]);
covers[1].reset();
if (fb.PlaybackLength > 0 || !fb.IsPlaying) {
is_stream = false;
g_metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
if (!g_metadb) {
on_playback_stop(4);
return;
utils.GetAlbumArtAsync(window.ID, g_metadb, 0);
is_embedded = false;
if (g_metadb) {
covers[1].image = FormatImage(utils.GetAlbumArtEmbedded(g_metadb.rawpath, 0), ww, wh, 7, 1, 0);
g_img = utils.GetAlbumArtEmbedded(g_metadb.rawpath, 0);
covers[1].update();
if (covers[1].image) {
is_embedded = true;
is_art = false;
} else {
covers[1].image = FormatImage(utils.GetAlbumArtV2(g_metadb, 0), ww, wh, 7, 1, 0);
g_img = utils.GetAlbumArtV2(g_metadb, 0);
covers[1].update();
if (!covers[1].image) {
is_art = false;
covers[1].image = FormatImage(gdi.Image(bg_dir + "no_cover.jpg"), ww, wh, 7, 1, 0);
covers[1].update();
} else if (fb.IsPlaying && fb.TitleFormat("$right($left(%path%,2),1)").Eval() != ":") {
is_art = false;
is_stream = true;
covers[1].image = FormatImage(gdi.Image(bg_dir + "stream.jpg"), ww, wh, 7, 1, 0);
covers[1].update();
window.Repaint();
function on_timer(id) {
if (g_timer) {
if (id == g_timer.ID) {
fader = (fader > 0) ? fader - fading_step : 0;
if (fader <= 0) g_timer && window.KillTimer(g_timer);
window.Repaint();
function on_playback_stop(reason) {
if (reason == 4 || (reason == 0 && !is_art)) {
covers[1].update();
fader = alphamax;
g_img = null;
g_timer = window.CreateTimerInterval(g_refresh_timer);
if (reason == 1 || reason == 0) {
refresh_cover();
function on_playback_new_track(info) {
refresh_cover();
fader = alphamax;
gr.FillSolidRect(0, 0, ww, wh, 0xFF000000);
if (fader > 0) covers[0].image && gr.DrawImage(covers[0].image, covers[0].x, covers[0].y, covers[0].image.Width, covers[0].image.Height, 0, 0, covers[0].image.Width, covers[0].image.Height, 0, fader);
covers[1].image && gr.DrawImage(covers[1].image, covers[1].x, covers[1].y, covers[1].image.Width, covers[1].image.Height, 0, 0, covers[1].image.Width, covers[1].image.Height, 0, 255 - fader);
ww = window.Width;
wh = window.Height;
refresh_cover();
function on_item_focus_change() {
if (!fb.IsPlaying) {
refresh_cover();
fader = alphamax;
function on_playlists_changed() {
if (!fb.IsPlaying) on_item_focus_change();
function on_get_album_art_done(metadb, art_id, image, image_path) {
art_path = image_path;
function on_mouse_lbtn_down(x, y) {
var meta = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
if (!meta || !is_art) return;
switch (true) {
case(art_path == ""):
break;
default:
// WshShell.run('"JPEGView.exe"' + '"' + art_path + '"');
break;
if (!hover && g_img) {
g_tooltip.Text = (is_embedded ? "Embedded - " : "External - ") + g_img.Width + " x " + g_img.Height;
g_tooltip.Activate();
hover = true;
function on_mouse_leave() {
g_tooltip.Deactivate();
hover = null;
here is the modded version with new timer api
// ==PREPROCESSOR==
var hover = null;
var g_img = null;
this.x = 0;
this.y = 0;
var fader = 0;
var alphamax = 255;
var g_timer = false;
var g_metadb;
var is_embedded;
var is_art;
var art_path = "";
var id = 0;
var pos_x = 0,
pos_y = 0;
img_info.w = iw;
img_info.h = ih;
CollectGarbage();
return tmp_img;
covers[1].reset();
is_stream = false;
if (!g_metadb) {
return;
if (g_metadb) {
covers[1].update();
is_embedded = true;
is_art = false;
} else {
covers[1].update();
is_art = false;
covers[1].update();
is_art = false;
is_stream = true;
covers[1].update();
window.Repaint();
covers[1].update();
fader = alphamax;
g_img = null;
g_timer && window.ClearInterval(g_timer);
g_timer = false;
g_timer = window.SetInterval(function () {
if (fader <= 0) {
g_timer = false;
window.Repaint();
}, g_refresh_timer);
refresh_cover();
refresh_cover();
fader = alphamax;
g_timer = false;
if (fader <= 0) {
g_timer = false;
window.Repaint();
ww = window.Width;
wh = window.Height;
refresh_cover();
refresh_cover();
fader = alphamax;
g_timer = false;
if (fader <= 0) {
g_timer = false;
window.Repaint();
switch (true) {
break;
default:
break;
hover = true;
hover = null;
I'm very familiar with ojdo's script (the one I'm working on is a HEAVILY modified version of his) but the remove duplicates function wouldn't really work for me. The problem was that I wanted to use wildcards in the folder paths. My use case is that I wanted to be able to detect other versions of an album on my hard drive. My folder naming convention is always the same, but I'll use differentiator tags at the end to denote other things. i.e. %Artist% - 2012 - %Album% [FLAC], etc. I wanted to be able to search for /%artist% - $year(%date%) - %album%*/ but it doesn't appear to be possible with what we have available in WSHPanelMod. I ended up creating a glob list and creating entries for each file type like so: "%artist% - $year(%date%) - %album% [FLAC]/*.flac" and "%artist% - $year(%date%) - %album% [dts]/*.dts" etc. Then if I get files returned from in that folder I know the folder exists.
How do you use this in WSHPanelMod? Can I just drop that JScript code in? I've never used ActiveX objects before.
sure it works. you just need to disable safe mode in the WSH panel mod preferences. i also modded the script a little as it's meant for web pages. see here:
http://dl.dropbox.com/u/22801321/folder%20list.png (http://dl.dropbox.com/u/22801321/folder%20list.png)
Wow, that's slick. I hereby dump the use of my crude method and will use this instead. Thanks for the suggestion and showing an example, marc2003.
Does anybody have an answer about this:
Is it possible that the
window global object is invalid in
on_paint(graphics)? If yes, what could cause such behavior?
step 6 from the notes & hints:
It's better to retrieve window width and height in callback function on_size(), because their values during startup is not reliable.
so i just follow the example that came in the scripts from the component developer....
var ww = 0, wh = 0;
ww = window.Width;
wh = window.Height;
then use ww & wh as you like in on_paint. never had any problems.
@Marc2003
It seems there is no allmusic script at http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
indeed. i saw no point in trying to keep up with the original script by romor because that now has it's own caching function. that's the only advantage mine had but now that his does it, there's no point. you'll need the foo_uie_biography component if you want to use it. check the last few pages of that thread for his script/updates.
Thanks to you both for developing your solutions - the review panels are excellent (essential!) additions to foobar. =)
hi, some real great examples here :)
@marc2003: the thumbs script works like a charm for fetching last.fm pics, but if i try to use custom folders there are some hickups: if the path contains some [] i have to envelope it inside single quotation marks and the title formatting does not seem to work at all (at least %path% and %path_sort% i tried).
i'm looking forward to all future updates of your scripts. i'm dreaming about musicbrainz script that shows url-rels for release and release group :3
however thx for all the great examples here and this great component, it's really appreciated
[] are indeed special characters that need to be wrapped in single quotes. the same applies anywhere else in foobar where title formatting is used. if you want to display them in your title bar or grouping pattern for your playlist, you need to use the single quotes. this script is no different. check the other section of the title formatting help found on the main help menu.
%path% won't work because it points to a file path. use $directory_path(%path%) to get all images in the same folder as the playing/selected file. and it should be fairly obvious why %path_sort% doesn't work. it needs to be a folder path and the script will automatically load all jpg, jpeg, png and gif files contained within.
Hi All,
not sure I'm in the connect forum page, but I have a question/request.
Using the all music script gets me no results, because I name most of my albums (titles) like this example: "album [Deluxe Edition]" or "album [Remastered]" or "album [cd release Number e.g. CPC2010]
Is there a way to tell the script to change the query string and ignore the part after "[" ... and search and return only the "album" ?
Thanks for your help
@marc2003
Thanks for all your hard work writing and maintaining these scripts. Unfortunately, I'm running into errors running your lastfm scripts. I actually noticed this about a month ago but I held off posting about this until I completed a hardware upgrade and did a clean re-install of Win7Pro x64. Unfortunately, the problem followed me to the new install
I'm getting the following error whenever I try to initialize any of your lastfm charts:
"Scripting Engine Initialization Failed (Last.fm Charts by marc2003, CODE: 0x80020101)
Check the console for more information (Always caused by unexcepted script error)."
This is what's coming up in the console:
Watching: N:\Music\Music
WSH Panel Mod (Now Playing by marc2003): Parsing file "C:\Users\Craig\AppData\Roaming\foobar2000\marc2003\common4.js"
WSH Panel Mod (Now Playing by marc2003): initialized in 29 ms
WSH Panel Mod (Simple Biography by marc2003): Parsing file "C:\Users\Craig\AppData\Roaming\foobar2000\marc2003\common4.js"
WSH Panel Mod (Simple Biography by marc2003): initialized in 6 ms
WSH Panel Mod (Last.fm by marc2003): Parsing file "C:\Users\Craig\AppData\Roaming\foobar2000\marc2003\common4.js"
WSH Panel Mod (Last.fm by marc2003): initialized in 5 ms
WSH Panel Mod (Thumbs by marc2003): Parsing file "C:\Users\Craig\AppData\Roaming\foobar2000\marc2003\common4.js"
WSH Panel Mod (Thumbs by marc2003): initialized in 3 ms
WSH Panel Mod (News / Reviews / Blogs by marc2003): Parsing file "C:\Users\Craig\AppData\Roaming\foobar2000\marc2003\common4.js"
WSH Panel Mod (News / Reviews / Blogs by marc2003): initialized in 4 ms
WSH Panel Mod (Last.fm Charts by marc2003): Parsing file "C:\Users\Craig\AppData\Roaming\foobar2000\marc2003\common4.js"
Error: WSH Panel Mod (Last.fm Charts by marc2003): Microsoft JScript compilation error:
Syntax error
File: <main>
Ln: 95, Col: 3
WSH Panel Mod (Web Links by marc2003, Images by komodomedia.com and mjm716): Parsing file "C:\Users\Craig\AppData\Roaming\foobar2000\marc2003\common4.js"
WSH Panel Mod (Web Links by marc2003, Images by komodomedia.com and mjm716): Parsing file "C:\Users\Craig\AppData\Roaming\foobar2000\marc2003\tooltip_buttons.js"
WSH Panel Mod (Web Links by marc2003, Images by komodomedia.com and mjm716): initialized in 6 ms
w7shell: init started
w7shell: GDI+ initialized
w7shell: COM initialized
w7shell: running on Windows NT 6.1.7601 Service Pack 1
w7shell: DWM composition disabled
w7shell: all green
Autoplaylists initialized in: 0:00.294776
"ALL" : 0:00.032938
"CLASSICAL" : 0:00.028919
"FOLK / WORLD" : 0:00.022914
"HIP-HOP / R&B" : 0:00.021197
"JAZZ / BLUES" : 0:00.022458
"RECENTLY ADDED" : 0:00.142174
"ROCK / POP" : 0:00.024107
Startup time : 0:01.567823
w7shell: taskbar button create notification got
I'm up-to-date with wsh panel mode 1.5.6 and running Java 7. The weird thing is that the scripts seem to work, at first, but then I start getting the errors after re-starting.
I'm totally at a loss as to how to debug this.
Hodge
Simple Biography just started crashing
WSH Panel Mod (Simple Biography by marc2003): Parsing file "D:\Apps\No Install\Audio\Players\foobar2000 DUI\marc2003\common4.js"
Error: WSH Panel Mod (Simple Biography by marc2003): Microsoft JScript compilation error:
Syntax error
File: <main>
Ln: 104, Col: 3
both scripts are working for me still so it might be a temporary glitch at last.fm's end spitting out some data that i'm not handling correctly.
can you both find this line in your scripts....
parsed_data = JSON.parse(g_text);
insert a new line before that:
fb.trace(filename);
now look in the foobar console and there should be a full path to a .json file. can you send/upload me the contents of the file so i can check it out.
to get things working straight away, you could try deleting all .json files from the
wsh_lastfm folder inside your foobar profile. this simply removes all cached files and will force the scripts to fetch updated versions online.
i've just updated all my scripts. http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
note for existing users: all major changes are behind the scenes so if the panels crash, you might need to reset the panel - this will cause per panel settings to be lost (right click>configure>tools>reset default. then close the dialog. right click>properties> clear. finally import the new script).
your last.fm username and autoplaylist configurations are stored separately so won't be affected by this.
a few noticeable changes-
in theory panels won't need updating when i push updates meaning the appearance can be customised by people and you won't have to think about making changes or not updating.
last.fm scripts no longer require an api key. i've supplied one in the script
now playing is a bit different. i'll explain later how to customise panels using multiple elements such as images, cd covers, ratings, buttons etc.
last.fm charts customise the bar colour using the context menu.
thumbs is missing. i'll update that soon.
@marc2003
I've updated your scripts. Everything works fine except the lastfm scripts. I just tried logging into my lastfm account through their web page and it looks I'm having problems connecting. The problem may be on their end and not w/ your scripts...
Sorry if this was a false alarm. I'll post an update if anything changes.
thanks again,
Hodge
@marc2003
I've confirmed that the problem was on my end...DNS server issues. Once I changed my DNS server, all of the lastfm scripts started working again!
Anyway, I really like how these scripts are evolving but I'd certainly love to see more config options for the "now playing" script.
thanks again,
Hodge
Cool. I've hacked together my own now playing that adds a little bit of info, I've been using it for a while and it's probably out of date. Anyway, I was just experimenting yesterday trying to get some custom buttons to show up on the right hand side of the shadow part (sort of opposite side of the albume art). No luck yet, but if I'm reading your post right it should be a little easier now?
I like the changes made to the now playing panel. Not sure yet if I like that you moved most code for all samples to common6, seems to make it less convenient to customize it?
Here is how I use your similar artist script by the way (clicking the text sends to autoplaylist called "similar", so I can actually browse my library through it )
(http://i.imgur.com/x79C4.png)
i was thinking of more simple appearance customisations. what you've done does require a bit more hacking.
i've updated
now playing again and have documented how to place panels and buttons etc. adding buttons is a bit more faffing around than i probably implied.
(http://dl.dropbox.com/u/22801321/now%20playing%20with%20buttons.png)
files changed:
marc2003\common6.js
samples\now playing.txt
samples\playback buttons.txt
samples\web links.txt
samples\artreader.txt
edit: bugfix for now playing just uploaded (just incase anyone downloaded in the 15 minutes since i posted- but that's unlikely)
Is there a some super-simple playlist script that just shows the groups, album art and titles list? Something very rough. I want to build my own, but it would kickstart me if I've got something to learn on and most of the skins available are too complex to learn from code.
the only person i know of on these boards who has a made a playlist is falstaff and i think his are probably a bit complex to get into. i did start awhile ago but gave up due to the lack of ability on my part.
added
thumbs from my old scripts. it does look a little different but pretty much works the same way.
files changed/added:
marc2003\common6.js
samples\thumbs.txt
samples updated: link/changed files as above post.
bugfix for thumbs: forgot to implement scrolling when in grid mode.
edit: also added some more images so the musicbrainz urls scripts look better on a dark background. existing users just extract the whole marc2003 folder again.
thumbs &
now playing updated again.
because most images are bound to be artist/group pics, they now focus on the top instead of the centre when cropping the image meaning the heads won't get cut off.
i also bodged the musicbrainz images update from earlier on. if anyone downloaded in the few hours since the last update, they need to extract them again.
files updated:
marc2003\common6.js
samples\thumbs.txt
added a new script: now playing with last.fm bio
because of the new way i've done my scripts, this only took around 10 new lines of code in the existing now playing panel. hopefully someone a bit more creative with design can make better looking stuff with what i've done. there are a few comments on how to position stuff in the panel.
screenshot: http://dl.dropbox.com/u/22801321/now%20pla...0with%20bio.png (http://dl.dropbox.com/u/22801321/now%20playing%20with%20bio.png)
link as above.
Now playing with bio crashes at startup, with this code: File:
C:\Users\Cioran\AppData\Roaming\foobar2000\marc2003\common6.js
Ln: 1068, Col: 4
ln 1068 is: "this.ratio = Math.min(this.w / this.case_img.Width, this.h / this.case_img.Height)"
Strangely, some of my old panels (the ones on my screenshot a few posts ago) crashes too now (but first when they try to show some info), they use common4.js so I don't know why they crash? Console points to this line in common4.js:
if (this.isVisible()) gr.DrawImage(this.img, this.x, this.y, this.w, this.h, 0, 0, this.img.Width, this.img.Height);
First I was on an old version of the plugin, but now I updated to 1.5.6 with the same error...
I have a WSH script which reads and displays a textfile, here is the header description inside the script:
// Draws "<dir_containing_current_audio_file>\folder.txt" in a "WSH Panel Mod" panel,
// or if "folder.txt" is not present, will draw the first text file in that directory,
// or if no text file exists, will draw some default ASCII Art text.
The WSH textfile viewer does not seem to work any more since the last WSH update - can anyone confirm or have a fix?
thanks much!
@sylla, the lines from both common4 and 6 refer to images that i bundle with the zip. somehow you've lost those from your folder structure?? they are inside the marc2003\images folder.
edit: samples updated. unlikely to affect anyone but now playing with last.fm bio didn't properly update when changes were made to the last.fm username. unlikely to affect anyone as once they've set it, it's unlikely to change but still.... just the script itself needs re-importing.
samples updated again: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
-musicbrainz releases / last.fm:added autoplaylist buttons to scripts to find music in your collection.
-thumbs: forgot to implement cycle mode.
files changed:
marc2003\common6.js
samples\thumbs.txt
Just posting to thank you for sharing these scripts. I've been using the last.fm bio and the now playing ones for a while.
I have a couple questions, though.
1) Some artists seem to make the bio script crash. I don't know exactly which ones, but so far I've come across _65daysofstatic_ and _...And You Will Know Us by the Trail of Dead_. It's not every now and then; it crashes reliably every time when I have one of those artists as my active selection. It says syntax error and points to line 2486 in the common6.js file. Any idea what might be causing it?
2) How does the rating feature in the now playing script work? I have the playback statistics component installed and I have some songs rated (in the DB, not tags) and the stars in the WSH panel don't do anything when I click them. However, if I've rated the track previously by using the stars in the playlist column, it shows the rating I gave it.
1) can't reproduce.
screenshot (http://dl.dropbox.com/u/22801321/bio%20test.png)
the line you reference is completely unrelated so you must be using a slightly outdated version. next time, can you post what code is on the line you mention.
all i can suggest for now is to browse your foobar profile\wsh_lastfm folder in windows explorer and search for and delete all .json files. this will clear all cached files and force a fresh download.
2) i think perhaps you've customised your context menu to hide the playback statistics\rating entries?? you can leave those settings as they are as i can get around that.
file changed:
marc2003\common6.js
I deleted the .json files and it doesn't crash anymore.
And the rating feature works just fine now with that update. Thank you!
marc2003: the "open image" menu item in your thumbs script has stopped working.
didn't double-click used to open the image too?
thanks for your efforts, i appreciate the work you do and the scripts you share for the foobar2000 community!
with my old scripts, a single click used to open the main image. with these updated versions, it now requires a double click. the context menu is working fine for me so it should be working as you expect???
the only instance where double clicking does not work is in grid mode and you have an image overlaid on top of the background thumbnails. because that requires a single click to "close" the image, i've disabled the double click action there.
edit: thinking about it, something may have gone wrong with the file associations on your system. all my script does is launch the full path of the file and it's upto windows to decide what program to use based on the file extension. i'd look into that if i was you.
Thanks for the comments. Nothing wrong with file associations. Images open as expected in explorer and elsewhere.
Open containing folder works in the context menu, and I can open images from there.
you can browse the marc2003 folder and edit common6.js in a text editor.
on line 798, replace
this.run = function(command) {
try {
this.WshShell.Run(command);
} catch(err) {
with
see what error you get after saving it and reloading the panel. i'd restore the previous function when done testing as well.
try {
} catch(err) {
with
Error: WSH Panel Mod (Thumbs by marc2003): The system cannot find the file specified. File: D:\Apps\No Install\Audio\Players\foobar2000 DUI\marc2003\common6.js
Ln: 799, Col: 13
i think i forgot to handle paths with spaces in, try this.
try {
this.WshShell.Run("\"" + command + "\"");
} catch(err) {
edit:
samples updated with above fix and also a fix for buggy scrolling behaviour in
thumbs script.
files changed:
marc2003\common6.js
Working, thanks for the fix
Hey marc, definitely loving your samples!
Just have a quick questions, where would I start if I wanted to attach similar artists' pictures next to the names on your panel? I would ultimately like it to auto download them as well like your nowplaying panel too.
Definitely appreciate any input / help... I'll do the dirty work, I just wanted to pick your brain.
Thanks!!!
i really don't want to encourage hitting last.fm for loads of artists at once. they've already removed documentation from their api for the artist.getimages method. it still works for now but it's not too encouraging for the future.
i'll explain how to access images you have cached already later. i don't have time right now.
there is now an
Online update feature on the context menu. as my scripts all now use an external file for the main code, it can update this when triggered. you will be prompted to restart foobar2000 when the download is complete.
files changed:
marc2003\common6.js
samples\*.txt (added version numbers to all panels)
gotcha, thanks Marc, I wasn't aware of that.
I only need the top three similar artists though, so if that's too much of a load I'll try and just have it look in the wsh_lastfm folder.
Thanks again!
thumbs: bug fix, quite a serious one. all image related context menu items would not show if no images in folder.
files changed:
marc2003\common6.js
if you're using a new version of my scripts (since 5th dec), you can use the
Online update feature on the context menu to avoid downloading the full zip.
If this doesn't exist already somewhere let me know and I'll write my own, but does anyone have a ContextMenu setup to do playlist rating?
I'm looking for something like this, but the "Library" menu doesn't have it built in:
(http://img.photobucket.com/albums/v379/Mordred2003/rating.png)
note for users of my playcount sync script: a "fix" i posted in this thread on the 5th december script broke the library import function. use the Online update option on the context menu to fix it.
Hey Marc anyway you've got an extra second to start me off for adding pictures to your similar artists code?
Also to limit the fetch to just 3 artists with their pictures?
Definitely appreciate any help!
So does anyone know why the sample scripts MainMenuManager All-In-One.txt and MainMenuManager.txt do not always give you all the menu options? The "View" file menu especially cuts off at an arbitrary point somewhere in the middle.
@morphguy12, make sure you download the latest
common6.js to your pc. use
Online update on the context menu or extract from the full zip (http://dl.dropbox.com/u/22801321/samples.zip) if you don't have that option.
i haven't tested this and also there is quite a major flaw with how i designed my original code for my image scripts. because the artist name source was always your file tags, the case didn't seem important as i thought it was something that isn't going to change. but downloading artist names from last.fm probably isn't going to match your tags 100% of the time.
in your simliar artist panel:
images = [];
if (li.metadb_changed()) {
//li.metadb returns true or false depending on whether the artist has changed. we don't want to update if the artist hasn't changed.
images = [];
files = [];
for (i = 0; i < Math.min(3, li.items); i++) {
files[i] = [];
var folder = p.data_folder + p.eval("$crc32(" + li.names[i] + ")");
if (p.fso.FolderExists(folder)) files[i] = files[i].concat(utils.Glob(folder + "\\*.jpg").toArray(), utils.Glob(folder + "\\*.jpeg").toArray(), utils.Glob(folder + "\\*.png").toArray(), utils.Glob(folder + "\\*.gif").toArray());
if (p.fso.FileExists(files[0])) images[i] = gdi.Image(files[0]);
window.Repaint();
then inside the on_paint function, you should have an array called images to use. images[0] being the first, images[1] the second and images[2] the third...
@neothe0ne, never had a problem with the menu not displaying properly.
samples updated: use
Online update or download the full package. http://db.tt/BInQ3Abm (http://db.tt/BInQ3Abm)
musicbrainz: bugfix, it never checked for new releases.
files changed
marc2003\common6.js
@morphguy12, make sure you download the latest common6.js to your pc. use Online update on the context menu or extract from the full zip (http://dl.dropbox.com/u/22801321/samples.zip) if you don't have that option.
images = [];
images = [];
files = [];
files[i] = [];
window.Repaint();
Thanks so much Marc,
Unfortunately I can't get any images to show under paint no matter what kind of code I put in there,
I'll keep trying, but have any suggestions?
Thanks!!
i'll try and test something over the next few days. the reason i didn't test before that is because i don't have any art to test with. i'm behind a proxy so i can't use the program i bundle with my script. i'll have to grab a few images manually.
samples updated: use the Online update feature on the context menu or download the full zip here. http://db.tt/BInQ3Abm (http://db.tt/BInQ3Abm)
last.fm biography: bugfix - last.fm logo button didn't work
simple seekbar / nyan cat seekbar: bugfix - tooltip only worked on first hover then stopped working after mouse had left area.
files changed:
marc2003\common6.js
there were loads of errors in that. i tested this one...
http://dl.dropbox.com/u/22801321/morphguy12.txt (http://dl.dropbox.com/u/22801321/morphguy12.txt)
(http://dl.dropbox.com/u/22801321/morphguy12.png)
the placeholder for artists that don't have images should already be on your system as it's bundled in the zip. obviously this was a quick bodge - you can mess around with placement yourself.
I have one silly problem - i can't add user picture for genre in the script - now playing with last.fm bio. place help me. tenx.
I want to create a button which runs a command from the Edit menu.
e.g., fb.RunMainMenuCommand("Edit/...");
I found plman.SetActivePlaylistContext(), however, I want to set the active focused playlist to a specific viewer. (I want it to select my SimPlaylist instead of my ElPlaylist). Is this possible?
i'm not really sure what you're asking. can you clarify?
simplaylist is default UI only and ELPlaylist is columns UI only. perhaps you meant ESPlaylist?
but i don't even know why i'm asking - it's not possible either way.
I exploded my foobar2000 into pieces via Popup Panels but left the main window on Default UI for Facets (unfortunately the instance of Facets has to be recreated in a dozen seconds every time you reopen Facets...)
likewise I was hoping to use SimPlaylist's Search window, because I prefer it's custom search window over the default
perhaps you could place ELplaylist popup panel over simplaylist to hide it?? probably a bit ugly though.
Marc You are awesome!!!
Thanks so much!!
Definitely appreciate it!
marc2003, your thumbs config changed recently. it used to center the image, center the thumbs, add arrows for scrolling through thumbs...
now it's very plain.
any plans on bringing back the nicer version?
also, i'm still having trouble with your biography script crashing now and then. certain artists always make it crash, like Massive Attack and They Might Be Giants...
Error: WSH Panel Mod (Last.fm Biography by marc2003): Microsoft JScript compilation error:
Syntax error
Ln: 2509, Col: 6
Is it possible to fb.RunMainMenuCommand while simulating the SHIFT key?
(I can get the behavior by holding SHIFT while clicking the button that does fb.RunMainMenuCommand, but would prefer to "bake" the shift key into the script...)
I would like to receive the following:
(http://img98.imageshack.us/img98/475/111vm.jpg) (http://img137.imageshack.us/img137/3295/333ioo.jpg)
this view I made after hard moding kabuki's script. I can not do it on wsh. place help me
nicer in your opinion. you can always continue to use the older version if you like. i just won't be updating it.
when i test those artists it works so i can only assume your downloaded cache files are corrupted. i need to check these files so find the
on_metadb_changed function inside your panel. add this as the first line...
p.run("notepad " + p.data_folder + p.eval("$crc32(" + p.artist_tf + ")") + "\\artist.getInfo.json");
copy/paste the contents into [codebox ] tags here.
Quick question about your 'text viewer' script - is there a way to use wildcard with it, e.g. path/*.txt ?
thanks in advance!
when i test those artists it works so i can only assume your downloaded cache files are corrupted. i need to check these files so find the on_metadb_changed function inside your panel. add this as the first line...
nothing happened but i found the file for Massive Attack. it was blank. so i deleted it and reloaded the panel, now it works.
thanks!
last.fm bio: better error handling. now prompts you to re-download if errors are encountered.
musicbrainz: now uses the json webservice instead of xml. you can delete all xml files from your profile\wsh_lastfm folder to tidy up.
simple text reader: added support for wildcards. it now supports the reading of txt and log files if you specify just the folder.
files changed:
marc2003\common6.js
samples updated:
with support like this, where's the 'donate' button?!
Quick question re. the "thumbs" script - it doesn't work and produces an error message in Foobar:
Scripting Engine Initialization Failed (Thumbs v6.2012-12-05.01 by marc2003, CODE: 0x80020101)
The only thing that I can see is that in the script, it has a line:
// @import "%fb2k_profile_path%marc2003\common6.js"
Whereas in the marc2003 directory, there are only common2, common3 and common4.js files.
Extracampine, you will find this file in the download Marc posted above. Just put it where the common4.js is and you're good.
Marc, once again I have to ask for your help in adjusting the row height in the new common6.js please. I produce nothing but errors :S
@extracampine, i'd extract the whole marc2003 folder again. a few images have been renamed/added since.
@Emerelle, i'd recommend not editing common6.js itself otherwise you wouldn't be able to update it without having to edit it everytime.
but assuming you mean for the last.fm bio/text reader, you can add this to your panel... this needs to go after the first line
var p = new panel....p.row_height = 26;
change 26 to whatever you like. the one downside to editing here is that if you change your font through the foobar preferences, this setting would revert to my default and you'd have to reload the panel.
if you meant row height for scripts with lists in like last.fm charts/similar artist/musicbrainz etc, you add these 2 lines to the
on_size function in your panel. make sure they go after
li.size();li.row_height = 20;
li.rows = Math.floor((li.h - 30) / li.row_height);
only edit the value of 20 on the first line.
edit: i forgot to mention you need to get the latest update for the list edit to work. use
Online update on the context menu.
Thanks so much Marc, you are always so helpful. Chaning just the row height in bio panel will do.
musicbrainz: bugfix. would crash if artist not found
last.fm - similar artists - top tags - top fans - top albums - top tracks: bugfix. would display info from previous artist if switching to an artist that doesn't have it's own info.
last.fm bio / simple text reader / now playing with last.fm bio: bugfix. text wouldn't update properly after changing font through the main preferences.
files changed:
marc2003\common6.js
@Emerelle. using this latest version, your custom line spacing should now stick even after changing fonts.
samples updated: http://db.tt/BInQ3Abm (http://db.tt/BInQ3Abm)
new script:
simple image viewerthese are the available options on the context menu.
(http://dl.dropbox.com/u/22801321/simple%20image%20menu.png)
it defaults to using the same folder as the playing/selected file for the source but you can change this using any title formatting you like. only specify the path to a folder. it will display all jpg/jpeg/png/gif files inside. you can scroll the images using your mouse wheel or by clicking the panel.
files added/changed:
marc2003\common6.js
samples\simple image viewer.txt
artreader / simple image viewer: now has 2 crop options. one focuses on the centre of the image and the other focuses on the top.
files changed:
marc2003\common6.js
for new users, an overview of the scripts contained in the package (skip to page 2):
http://dl.dropbox.com/u/22801321/wsh/samples%20readme.pdf (http://dl.dropbox.com/u/22801321/wsh/samples%20readme.pdf)
simple image viewer: display a message when no images are found. before you'd see a blank a panel.
samples readme: added how you can help yourself and me if you find errors.
files updated:
marc2003\common6.js
samples readme.pdf
all scripts now display their version in the foobar2000 console. you can check the latest versions here-
http://dl.dropbox.com/u/22801321/wsh/versions.txt (http://dl.dropbox.com/u/22801321/wsh/versions.txt)
as most code is inside common6.js which can be updated via the right click
Online update option, these will rarely if ever change assuming i don't find any more bugs.
Hi Marc, is it possible to make a script like the one for musicbrainz, but instead using discogs?
I have a problem with foo_uie_wsh_panel_mod. Some of my pictures embed in the song files are shown but some are not. What is the reason for that?
new script:
discogsthis is a quick and dirty bodge so report any bugs. it only contains
master releases and will only display the first 100. i won't be adding support for pagination.
i looked at using
releases to get more results but that can return thousands of hits for popular artists so i ditched that idea...
(http://dl.dropbox.com/u/22801321/discogs.png)
marc2003\common6.js
samples\discogs.txt
@ngonngon, use utils.GetAlbumArtEmbedded to always prefer embedded art. using the other methods, the core artreader may decide other images are better.
Hi everyone. Quick question about WSH Coverflow :
How can I increase the size of the font that displays the %album artist% - %album% information, without going through foobar's prefs > colors and fonts ?
I don't mind hardcoding that size in the script. I just need to know what to type and where to type it. Thank you.
Optionally, how can I set that same font to bold ? (within the script too).
Thanks marc2003! That's pretty much what I wanted.
There is just one thing I've changed (I can understand code but not write it ). I think because you are showing master releases, there is no need for showing the format of the release, because although it could say "vinil" it shows only the format of the oldest release (and the country of the publisher), not the other ones.
For me this is perfect to see if there are new releases from an artist, the format its not really so much important. Well, if I could see if it's an EP or a complete album it would be great, but I don't know how to do that hehe.
Thanks for your time again
F.e. :
function get_font() {
if (g_instancetype == 0) {
// g_font = window.GetFontCUI(FontTypeCUI.items);
g_font = gdi.Font("Segoe UI", 24, 1); // or any other
g_font_headers = window.GetFontCUI(FontTypeCUI.labels)
} else if (g_instancetype == 1) {
g_font = window.GetFontDUI(FontTypeDUI.playlists);
g_font_headers = window.GetFontDUI(FontTypeDUI.tabs)
Thanks onv ! Will try that !
makes sense. i've removed it now. use
Online update on the context menu to update the script.
edit: the
Online update option has now been renamed to
Script update. i changed it because some scripts have an
Update (as in content) option and they might be confusing when seen together.
marc2003 I could deal with problem alone which I have described before, by modifying lines in your "Now Playing with Last.fm Bio" script:
var genre = encodeURIComponent(p.eval("%genre%"));
b.buttons.but9 = new button(p.w - 540, 560, 544, 166, {normal: genre+".png", hover: "allmusic_h.png"}, function() { p.browser(allmusic); }, allmusic);
but now I have another problem - when genre style of two words like - smooth jazz -> genre image not displayed. Please help me.
replace %genre% with $meta(genre,0)
0 is the first value, 1 is the 2nd and so on
http://wiki.hydrogenaudio.org/index.php?ti...a.28name.2Cn.29 (http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Title_Formatting_Reference#.24meta.28name.2Cn.29)
also, you probably don't need encodeURIComponent there. you only need that if putting in genre as part of a link to a website.
You're the top, thank you very much. Merry Christmas and Happy New Year from me
Thanks - you mean download the file from here:
http://code.google.com/p/foo-wsh-panel-mod/downloads/list (http://code.google.com/p/foo-wsh-panel-mod/downloads/list)
And install again? I did this but it didn't change anything. I already had the latest version installed I think.
no i meant from my samples.zip download (it contains a folder named marc2003 as per my instruction above). you've already downloaded it because the script in your panel comes with it....
but here's the link incase you need it again... http://db.tt/BInQ3Abm (http://db.tt/BInQ3Abm)
Update script option on the right click menu or the full download is in the link above.
last.fm - similar artists - top tags - top fans - top albums - top tracks: spotify wouldn't launch due to typos in script.
files changed:
marc2003\common6.js
I'm really new when it comes to this but I edited together some scripts I found here and made some buttons. They work great except I can't figure one button out. Ideally, this button would send Last.fm a 'loved track' signal using softplaylists and also rate it 5 stars using playback stats. Is that even possible to do two commands?
I found this over in the softplaylists thread but it isn't working for me, nothing shows up in console when I press it either.
fb.RunContextCommand("Last.fm/Last.fm Love '" + fb.TitleFormat("%title%").Eval() + "' By '" + fb.TitleFormat("%artist%").Eval() + "'");
Here's the full code I'm using.
http://pastebin.com/wwVwcCmA (http://pastebin.com/wwVwcCmA)
Here's what it looks like. (Buttons on the right)
http://i.imgur.com/2Thw3.jpg (http://i.imgur.com/2Thw3.jpg)
Also! Two of the buttons are for switching DSP modes, is it possible to combine them into one? Up state would be my Gapless DSP (like a default) and the Down state would be my Headphone DSP. Maybe I'll save that for another day and see if I can get the Love track to work first.
Thanks you guys!
you typically process mouse click events on up, not down. also, you need quite a few more callbacks in there....
metadb = fb.GetFocusItem();
function on_selection_changed() {
function on_playlist_switch() {
//prefer playing item if playing. use selected item if playback is stopped.
then inside your click function
if (!metadb) return;
var artist = fb.TitleFormat("%artist%").EvalWithMetadb(metadb);
var title = fb.TitleFormat("%title%").EvalWithMetadb(metadb);
fb.RunContextCommandWithMetadb("Last.fm Love Track '" + title + "' by '" + artist + "'", metadb);
//more code to run other functions here
you can't check the DSP so it's not really possible to make a proper toggable button. you could try and bodge something by storing the state manually (see window.GetProperty and window.SetProperty) but this wouldn't update if that setting was changed via the menu/preferences.
Thanks Marc, you're a lifesaver! Works great. I'll probably be back when I inevitably have more trouble.
Edit: Too bad about the toggle, not really a big deal though. I'll keep it as two buttons.
Thanks once again Marc, I've got it up and running again. The thumbs script seems to show the thumbs without any space between them, and sometimes they overlap. Any idea how to fix this? I tried the "simple image viewer" script - this looks good, but it won't seem to show all the art in the directory at the same time - only one image at a time.
the images do not overlap. they're just cropped to be square.
new script: now playing with track list
you can hack around around and change the title formatting on lines 137-140.
marc2003\common6.js
samples\now playing with track list.txt
things it can't do-
everything else
from playcount, appears to be your album of the year - admit it though, you're just hot for Natasha
here's to a foobar rich 2013
Marc2003 you thought of making lyrics in wsh panel?
Oh yes, a simple lyrics panel in the look of your other panels (bigger and underlined font at the top) would be really great, Marc.
Perhaps something like this:
(http://www.abload.de/img/wsh-lyrics-panel_examchl44.png) (http://www.abload.de/image.php?img=wsh-lyrics-panel_examchl44.png)
nope. i have no interest in lyrics at all.
also, falstaff has already created a lyrics panel. search the thread - it's in here somewhere.
Hey marc, is there any easy way to remove the cover art and playback buttons from the now playing script (the regular one, not the one with bio or track list) so I can display the artwork in a separate panel and give more room for the artist name and track titles?
I tried editing some of the code myself but couldn't quite figure it out.
new script: ok, so i changed my mind and made a
simple tag reader. displays mutli-line tags in panel. looks a bit like Bollerkopp's screenshot above.
(http://dl.dropbox.com/u/22801321/simple%20tag.png)
marc2003\common6.js
samples\simple tag reader.txt
tip: you can edit my
now playing with last.fm bio panel to replace the bio with the tag display simply by editing the code on line 12
change this...
var p = new panel("Now Playing with Last.fm Bio", ["lastfm_bio", "remap", "cd", "images"]);
to
var p = new panel("Now Playing", ["simple_tag", "remap", "cd", "images"]);
@Reith. http://dl.dropbox.com/u/22801321/now%20playing%20mod.txt (http://dl.dropbox.com/u/22801321/now%20playing%20mod.txt)
Hey marc2003,
wow... that is really great. Thank you very much for this tag reader script. And for your general work here of course.
Thanks, it works great.
bugfix: addition of
simple tag reader script yesterday caused my
simple text reader script to break.
new:
simple text reader now has a customisable title like the tag reader.
misc:
now playing with tracklist. code tidyup.
files changed:
marc2003\common6.js
samples\now playing with tracklist.txt
samples\simple text reader.txt
you can check the latest versions of all scripts here: http://dl.dropbox.com/u/22801321/wsh/versions.txt (http://dl.dropbox.com/u/22801321/wsh/versions.txt)
Awesome new samples Marc! Many thanks for the new sample and changing your mind
One more question about adjusting the tag script...if I want to have a transparent background, I tried disabling the line "p.draw_background(gr);" but that seems to break the script. In the simple text reader script this worked for me though.
Any quick way to make the background transparent?
Again, many thanks for your hard work, love all of your samples.
are you sure? add double backslashes to comment it out and the text should turn green in the editor. or just delete it....
I always use double slash for commenting things out - the panel turned white causing me thinking I broke it with the comment; anyways I only forgot to tick "transparent background" in the editor - sorry mate!!
marc2003 this can serve to "Custom folder" in your scripts.
//Flags http://msdn.microsoft.com/en-us/library/bb773205.aspx
var BROWSEINFO_FLAG = 0x00000010 // BIF_EDITBOX
function showFolderDialog() {
var shell = new ActiveXObject("Shell.Application");
var folder = shell.BrowseForFolder(0, "Select the folder", BROWSEINFO_FLAG);
if (folder == null) {
return;
return folder.items().item().path;
fb.trace(showFolderDialog());
nice, i didn't know you could do that sort of thing.
but it's not really any use for my scripts because it would be extremely rare for anyone to specify a hardcoded single folder. most people will be using foobar2000 title formatting so the folder names are dynamic based on track metadata.
I have an idea for a script but I'm not sure if this is possible, maybe someone could comment on that.
I keep my playlists in a central container (e.g. a dropbox folder) and would like to use them on several computers (filepaths / libraries are the same on all machines).
I'd like a script that lists all playlists in that folder. By clicking on one of these files in foobar that list should be added as a playlist (and played, but that isn't the most important part).
As far as I see it, I need these functions:
- Read all files in a directory/folder
- File > Load Playlist after clicking the title of one file (something like fb.RunMainMenuCommand with the selected playlist as filename).
Is that possible?
Version 2:
There is another way how I could tackle my problem.
I can get my playlists via a web service (they're saved to a mysql-Database).
Then I could create a new playlist and add all the items sent as json.
In this case the functions I need are:
- Create a new playlist
- Add items to a specific playlist.
Is this possible? Easier than my first request?
i'm not sure why you don't get dropbox to monitor your normal playlists folder? then you can use the default
playlist manager???
but if you really want to add a new playlist....
fb.RunMainMenuCommand("New playlist");
then look at utils.glob for getting all files from a folder into an array. then loop through the array for displaying and mouse click code. then run foobar2000.exe with the /add parameter to the full path of one of your playlists.
Update script on the context menu or the full download is here: http://db.tt/BInQ3Abm (http://db.tt/BInQ3Abm)
last.fm charts: fix crash when switching between populated and empty feeds.
open containing folder did not work when path had spaces in.
files changed:
marc2003\common6.js
i'm not sure why you don't get dropbox to monitor your normal playlists folder? then you can use the default playlist manager???
Hi marc,
great idea, maybe too obvious for me...
Part 1 on computer 1 worked fine, I just have to check at home how it works out.
Edit/Resolved
Does anyone know where playlist organizer saves changes to folders, structures, order? Also in the playlists folder or somewhere else?
Answer: It's stored in theme.fthThanks for your help!
new script: discogs
this is a quick and dirty bodge so report any bugs. it only contains master releases and will only display the first 100. i won't be adding support for pagination.
i looked at using releases to get more results but that can return thousands of hits for popular artists so i ditched that idea...
marc2003\common6.js
samples\discogs.txt
You are a hero, thanks so much for this!
news/reviews/blogs: fix ugly text drawing bug
last.fm similar artists: the
top tags feed now has autoplaylist buttons to search your library for matching files against genre tags.
files changed:
marc2003\common6.js
although i try not to change panel scripts very much (as most code is in the common file), i've made a few minor changes over the last few days. you can check the versions here: http://dl.dropbox.com/u/22801321/wsh/versions.txt (http://dl.dropbox.com/u/22801321/wsh/versions.txt)
Hey guys, would really appreciate some help. I've updated from 1.3.x to the current version and two panels stopped working for me (aw crashed), volume and seekbar.
Maybe somene can quickly glance over it and find the corrupt code?
// Knob button by Br3tt
// Modified by T.P Wang
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
var g_drag = false;
// foobar path, SHOULD be replaced
var g_btn_img1 = gdi.Image(fb.ComponentPath.replace("components","images") + "curacao/bt/volbutton50.png");
var g_btn_img2 = gdi.Image(fb.ComponentPath.replace("components","images") + "curacao/bt/voldot.png");
var g_angle = 270;
var g_R = 12;
function calc_theta(x,y){
x = x - 25.5;
y = y - 25.5;
theta = Math.atan2(y,x) / Math.PI * 180;
if (theta <= 90 && theta > 45)
return g_angle;
if (theta > 90 && theta < 135)
return 0;
if (theta >= 0) {
if (theta > 90)
return theta - 135;
else
return theta + 225;
} else {
return theta + 225;
function on_paint(gr){
ww = window.Width;
wh = window.Height;
theta = (Math.pow(10, fb.Volume / 50) - 0.01) / 0.99 * g_angle;
// Volume 'Round Button' by Br3tt (13-08-2008)
posA = (theta - 45) * Math.PI / 180;
cosinusA = Math.cos(posA);
sinusA = Math.sin(posA);
posX = 25 - (cosinusA * 12) - 4 ;
posY = 25 - (sinusA * 12) - 4 ;
gr.FillGradRect( 0, 0, ww, wh, 90, RGB(042,042,047), RGB(042,042,047));
gr.DrawImage(g_btn_img1,-4,-4,55,55,0,0,55,55);
gr.DrawImage(g_btn_img2,posX,posY,5,5,0,0,5,5);
function on_mouse_lbtn_down(x,y){
g_drag = true;
on_mouse_move(x,y);
g_drag = false;
function on_mouse_move(x,y){
if (g_drag){
// Calc Volume
d = calc_theta(x,y) / g_angle;
v = 50 * Math.log(0.99 * d + 0.01) / Math.LN10;
if (fb.Volume != v)
fb.Volume = v;
function on_mouse_wheel(delta){
if(delta>0)
fb.VolumeUp();
else
fb.VolumeDown();
function on_volume_change(val){
window.Repaint();
//EOF
var weight_normal =400;
var weight_bold =800;
var italic_no =0;
var italic =1;
var uline_no =0;
var uline =1;
var align_top =0;
var align_middle=1;
var align_bottom=2;
var align_left =0;
var align_center=1;
var align_right =2;
var trim_no =0;
var trim_chara =1;
var trim_word =2;
var trim_elips_chara =3;
var trim_elips_word =4;
var trim_elips_path =5;
var flag_rtl =0x0001;
var flag_vert =0x0002;
var flag_nofit =0x0004;
var flag_dispctrl =0x0020;
var flag_nofallback =0x0400;
var flag_trailspace =0x0800;
var flag_nowrap =0x1000;
var flag_linelimit =0x2000;
var flag_noclip =0x4000;
"curacao/bt/seeker10.png");
function StrFmt(alignH,alignV,trim,flag){ return ((alignH<<28)|(alignV<<24)|(trim<<20)|flag);
function RGBA(r,g,b,a){ return ((a<<24)|(r<<16)|(g<<8)|(b)); }
function TimeFmt(t){
var zpad = function(n){
var str = n.toString();
return (str.length<2) ? "0"+str : str;
var h = Math.floor(t/3600); t-=h*3600;
var m = Math.floor(t/60); t-=m*60;
var s = Math.floor(t);
if(h>0) return h.toString()+":"+zpad(m)+":"+zpad(s);
return m.toString()+":"+zpad(s);
var g_titlefmt = fb.TitleFormat("");
var g_fileinfo = null;
var g_drag = 0;
var g_drag_seek = 0;
var ww = window.Width;
var wh = window.Height;
var pos = 0;
var length = fb.PlaybackLength;
var txt;
ww = ww-20;
if(length > 0){
if(g_drag){
pos = ww * g_drag_seek;
txt = "Seek " + TimeFmt(g_drag_seek * length) + " / " + TimeFmt
(length) + 00;
else{
pos = ww * (fb.PlaybackTime / length) + 00;
txt = g_titlefmt.Eval();
// background
gr.FillGradRect( 0, 0, window.Width+2, window.Height+2, 90, RGB(042,042,047), RGB
(042,042,047));
gr.FillGradRect( 11, 04, window.Width-22, 3, 90, RGB(0,0,0), RGB(0,0,0));
// orange progress bar
//gr.FillGradRect( 10, 04, pos+1, 3, 90, RGB(220,155,75), RGB(080,055,25));
//blue progress bar
gr.FillGradRect( 10, 04, pos+1, 3, 90, RGB(035,145,255), RGB(025,055,080));
//green progress bar
//gr.FillGradRect( 10, 04, pos+1, 3, 90, RGB(055,255,055), RGB(065,080,065));
gr.FillGradRect( 10, 03, window.Width-20, 1, 90, RGB(010,010,010), RGB(010,010,010));
gr.FillGradRect( 10, 08, window.Width-20, 1, 90, RGB(070,070,070), RGB(070,070,070));
gr.FillGradRect( 09, 04, 1, 4, 90, RGB(000,000,000), RGB(000,000,000));
gr.FillGradRect( window.Width-10, 4, 1, 4, 90, RGB(060,060,060), RGB(060,060,060));
gr.DrawImage(g_btn_img1,pos+2,1,17,17,0,0,17,17);
function on_size(){
function on_focus(gr){
//fb.trace("focus " + focused);
function on_key_down(key){
//fb.trace("key " + key);
g_drag = 1;
if(g_drag){
x = x-10;
g_drag = 0;
g_drag_seek = x / (window.Width-20);
g_drag_seek = (g_drag_seek<0) ? 0 : (g_drag_seek<1) ? g_drag_seek : 1;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
if(g_drag){
x = x-10;
window.Repaint();
//fb.trace("wheel " + delta);
function on_playback_starting(cmd, paused){
function on_playback_new_track(info){
window.Repaint();
function on_playback_stop(){
window.Repaint();
function on_playback_seek(time){
window.Repaint();
function on_playback_pause(state){
function on_playback_edited(){
function on_playback_dynamic_info(){
function on_playback_dynamic_info_track(){
function on_playback_time(time){
window.Repaint();
//EOF
i can't see anything in the code that wouldn't work in new versions. are you sure you have the external images in the right place?
Yes, nothing changed except the update of wsh plugin and I just rechecked with another path. I found the same knob script posted by Wang somewhere earlier in the thread and strangely it works (despite being the same). No luck with seekbar though
i just tested both and they work fine if i comment out the lines in on_paint which draw the images (because i obviously don't have them).
I'll try again, sorry if that was indeed the mistake, quite dumb from me then
br3tt, while I was trying to fix the seekbar I've tried all your other configs and now spending quite some time tinkering with foorazor which uses most of the scripts you posted here before. Is it possible in your WSH Playlist Viewer v2.1.0 to collapse non active groups (like elplaylist does) and is it possible to add an A-Z quick jump browser with WSH?
and I guess it's impossible to chande DUI's color of splitters/tabs/etc? It's controlled by OS?
right. but you can get 3rd party themes. check somewhere like deviantart.com
@ marc2003, Falstaff or someone, could you please help me a simple script using WSH panel mod which can make an image (like a vinyl disc) rotate/stop when playing/stopping a song? thank you in advance.
antheo Here's very simple script for rotating image on playback time.
var image = gdi.Image(fb.FoobarPath + "images\\vinyl.jpg");
var angle = 0;
function on_paint(gr) {
gr.DrawImage(image, 0, 0, 500, 500, 0, 0, image.width, image.height, angle);
if(angle >= 360) angle = 0;
angle += 60;
window.Repaint();
I tested it with this Vinyl image (http://www.senpaigamer.com/sites/default/files/news/sony/2012/03/21-black-panther-yakuza-2-ashura-original-vinyl-record-3.jpg)
too slow
antheo
var angle = 0;
angle += 60;
window.Repaint();
Thank ExtremeHunter so much for this script, I already tested it but as Falstaff said it too slow, could you give me a little time to make it rotate faster? (at least 12 frames/per second).
Here is my skin and I like to update it with a vinyl disc rotate as a new visualization
(http://i341.photobucket.com/albums/o396/htlogo2008/main_zpsdc3d0ba6.png)
Anyways, thank you again and look for your help.
Ok here's the faster one with timer .
Play with the values to make it faster/slower.
var vinylImage = gdi.Image(fb.FoobarPath + "images\\vinyl.jpg");
vinylImage = vinylImage.resize(300, 300);
var angle = 0;
var vinylX = 20;
var vinylY = 20;
var vinylW = vinylImage.width;
var vinylH = vinylImage.height;
gr.DrawImage(vinylImage, vinylX, vinylY, vinylW, vinylH, 0, 0, vinylW, vinylH, angle);
var rotationInterval = 50;
var rotationTimer;
var rotationTimerStarted = false;
function onRotationTimer() {
if (!rotationTimerStarted) {
rotationTimer = window.SetInterval(function () {
if (angle >= 360) angle = 0;
angle += 10;
window.RepaintRect(vinylX, vinylY, vinylH, vinylH);
}, rotationInterval);
rotationTimerStarted = true;
function stopRotationTimer() {
window.ClearInterval(rotationTimer);
if (reason != 2) {
stopRotationTimer();
function on_playback_pause(state) {
if (state) stopRotationTimer();
else onRotationTimer();
onRotationTimer();
var angle = 0;
var vinylX = 20;
var vinylY = 20;
var rotationTimer;
angle += 10;
if (reason != 2) {
onRotationTimer();
Haha, good job ExtremeHunter, it work well and I will try to fix it with seekbar so let them work look like a vinyl disc player with a (seekbar) needle.
Thank so much
That's a really nice disc spinner visualization you made there
ExtremHunter, congrats +++++
Unfortunately for me, it won't resize to fill the whole panel window. I drag the panel edges open and the disc wants to stay one size at top left.
Is there any chance you can add more code to (A) center the disc in the panel and (B) make the disc auto-resize to fit the whole panel.
Great job on this, it would be nice if you continued to develop the script with more features :-) . . . . . Just off the top of my head, a super-cool feature would be if you could right-click the panel and choose menu items "
Zoom In" or "
Zoom Out" in incremental steps . . . . for example, if we continue to zoom in, then the disc stays always centered in the panel but the image goes beyond the edges of the panel, so with high enough zoom-in level we are looking at the hole in the middle of the disc filling the whole panel !!
I added this preamble header to the current script:
// "Spinning Disc Image Viewer"
// WSH Panel Mod script by ExtremeHunter (Jan 23, 2013)
// creates a visual effect of a spinning disc as track is playing.
// script source:
// www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=821699
derty2
you can get zoomable/resizable version here (http://pastebin.com/EyKDiDQW) (zoom with Shift+mouse wheel or Shift+up/down arrow keys),
but keep in mind that larger your image goes, more CPU it takes.
Fantastic work
eXtremeHunter, the code works great +++++++
This looks really nice when using a PNG disc image with transparent background and a custom panel background color.
If anybody here wants to edit the script to have custom panel background colors then add these lines to the script:
add this:function RGB(r,g,b) { return (0xff000000|(r<<16)|(g<<8)|(b)); }
var backgrcolor = RGB(34,28,28) //<<<<<<<<<< color is dark brown
and add this:function on_paint(gr) {
gr.FillGradRect(0, 0, window.Width, window.Height, 90, backgrcolor, RGB(50,0,0)); //<<<<<<<<<< color is gradient dark brown-maroon
gr.DrawImage(resizedVinylImage, vinylX, vinylY, vinylW, vinylH, 0, 0, resizedVinylImage.Width, resizedVinylImage.Height, angle);
HOW TO CREATE A 'PNG' DISC IMAGE WITH TRANSPARENT BACKGROUNDFor this example I am using Photoshop CS3,
Open image in Photoshop,
At the left-side toolbar select the "Elliptical Marquee Tool",
Place the mouse cursor somewhere in the middle of the image,
Hold down SHIFT+ALT keys, then click-drag the mouse cursor outwards from the middle of the image,
You will see a perfect selection circle radiating out from the middle of the image,
Keep dragging outwards until you reach the edge of the disc,
Let go of the mouse cursor and then let go of the keys,
You should now have a perfect circular selection,
Right click in the selection and choose "Layer Via Copy",
At the right-side layers panel you will now have two Layers named "Layer 1" and "Background",
Click on the "eyeball" of the "Background" layer to de-select it,
You will now see the main image showing in Photoshop will have a checkerboard background pattern,
This checkerboard pattern means the background is transparent,
Save this image as 'PNG' and you are done.
!!! IMPORTANT !!! do not save as 'JPG' because you will lose the transparent background.
ExtremeHunter
great idea
http://www.youtube.com/watch?v=jzaoI8lru4s...eature=youtu.be (http://www.youtube.com/watch?v=jzaoI8lru4s&feature=youtu.be)
Mmm, good old times comes to mind
just a post to say if you use the right click>Update script option on my scripts from today, the last.fm charts and autoplaylists script panels will break. you just need to import those again from the full download here. http://db.tt/BInQ3Abm (http://db.tt/BInQ3Abm)
i've also tidied up a few things and bumped all the version numbers on my scripts but there are no functional changes.
eXtremeHunter, I have one more feature request for your "Spinning Disc Image Viewer" script please. . .
I am getting bored looking at the same spinning disc for every track.
Can you modify the code so that the script searches for a disc named "disc.png" at same directory as playing track,
else if "disc.png" is not found then default disc image is displayed.
Thankyou.
Updated Spinning disc script here (http://pastebin.com/Z8TCfmj7)
Added: Display now playing disc first, if not available display default disc image.
(set source in Preferences/Display-Album art Disc)
Added: gradient background.
Added: disc mask. (now you can display non transparent disc images like jpg. just use correctly cropped images (edge to edge)).
screen-shot with jpg disc image
(http://img33.imageshack.us/img33/360/24012013220819.png)
Thanks for the new code eXtremeHunter , it works great ++++
Here is a quick 'No Disc' image I made (1000x1000px, PNG): (http://img210.imageshack.us/img210/8297/foobar2000nodisc.th.png) (http://img210.imageshack.us/img210/8297/foobar2000nodisc.png)
Hey guys, my some of my wsh panels flicker on pause/play if I set the panels to pseudo transparency, is it fixable?
Can't edit the post, sorry for the double post
Can anyone please change this function from opening external program to playing/pausing foobar playback?
function on_mouse_lbtn_clk(x, y, mask) {
var path = Image.Items[Image.Index].path;
if (!path || hbtn) return;
if (path.indexOf("file://") >= 0 || path == Properties.Image.DefaultCoverPath) {
return;
ShellObj.ShellExecute('"' + path + '"', "", "", "open", 1);
not sure what callback you're trying to use there??
fb.PlayOrPause();
that's single click. if you want double click then use
on_mouse_lbtn_dblclk
fb.PlayOrPause();
that's single click. if you want double click then use on_mouse_lbtn_dblclk
That's a script from another config which opens the cover in the external image viewer on double click.
Your script works well, thanks, I was trying this function but with on_mouse_lbtn_
clk which doesn't work. But it counts my double clicks too so when I double click on the cover it quickly pauses and then keeps playing, is it possible to make wsh see the difference between a quick double click and a single click?
Hi everyone, i'm starting mod the PlaylistSwitcher in the skin Mizo (http://neonasahi.deviantart.com/art/Mizo-final-with-SP1-267685297).
Initially, I made it to show the number of songs in each playlist, but this number didn't change immediately every time I added or deleted some songs in playlist, can someone help me
Sorry for my bad English.
This is my script :
https://dl.dropbox.com/u/22999146/FB/playlistsw.txt (https://dl.dropbox.com/u/22999146/FB/playlistsw.txt)
kjllmeplzadd these functions to your script
function on_playlist_items_removed(){
RefreshPlaylists();
window.Repaint();
function on_playlist_items_added(){
RefreshPlaylists();
window.Repaint();
so fast
thanks u very much
i don't think so. perhaps you should make a pause button rather than have the whole panel respond to a single click.
I'm not a great wsh/foobar coder as you may have noticed I've been using an old Br3tt's config curacao (http://br3tt.deviantart.com/art/Curacao-v1-2a-Released-105580817) for four years now and constantly modify it. It has a pause button but it's very small so pausing on clicking album art is an important feature for me (which I added with your help). Does WSH recognize middle mouse clicks then? Maybe I could remap the double click to that. Anyway it's not that big of a deal, it's not like I'll be using double clicks much so it won't bother me.
Yes, there are several other mouse functions you could use, e.g.
function on_mouse_mbtn_down
function on_mouse_mbtn_up
function on_mouse_mbtn_dblclk
function on_mouse_rbtn_down
function on_mouse_rbtn_up
function on_mouse_rbtn_dblclk
See the callbacks doc that comes with wsh panel mod for more info.
Great, thanks a lot!
Hello ExtremeHunter,
- Thanks for your great script and the reel-to-reel tape rotated very smooth in CC direction (the blue arrow) but when I made it rotate in CCW direction as in the real (the red arrow) by changing this line: " angle += 10;" to " angle += -10;", the reel-to-reel tape to be shaken sometimes.
Once again, thank you so much.
antheo
Here's reel-to-reel (http://pastebin.com/2P1UsbT9) example.
now you only need some tape reels with transparent holes.
antheo
Wow, very quick! I'm very excited with your script in my new CUI layout.
Thank you for your kindness and help, I'll try it right now.
eXtremeHunter, your "Spinning Disc Image Viewer" only displays JPG files in path of playing track; it refuses to load other image file types.
Sometimes I want to save as GIF or PNG or BMP or TIF images. Is there any way you can make your code accept all other image files as input?
Even nicer would be a config field in Properties where the user can add a list of file extensions to suit himself.
I tried editing your script, but I can not see any reference to a file extension (except for the default disc image).
That reel-to-reel image above is giving me further questions . . . .
Is it possible to have a picture of a turntable as the background of the "Spinning Disc Image Viewer" panel, and then overlay the spinning disc on top of it?
One more question . . . .
Is it possible to make an animated GIF image from a video clip and make it "play" in a WSH Panel ?
What is on my mind here is this idea: Shooting a video clip of vertical vinyl cover turning around the North-South axis so we get to see all facets of the cover . . . Front-Turning-Spine-Turning-Back-Turning-Spine-Turning-Front . . . we make an animated GIF from the video and it plays inside a WSH Panel Mod panel . . . . . . . . . . . . . . . . . . . . . is this possible?
Thanks +++++
eXtremeHunter
now still have to add a different rotational speed for modes (play, rew, ff), two straight lines tangent to the roll with tape...
derty2
1. You can use wildcards to display different file types
example: foobar Preferences/Display-Album art Disc
*disc.*
*cd.*
*dvd.*
2. Yes, just add background image source and then use gr.DrawImage(background... before spinning disc and set spinning disc alpha to see through it.
3. AFAIC no. You can display only still gif images.
onv
just decrease rotationInterval value when rew/ff
it is clear, but the speed should vary smoothly, without jerks, just like in real life,
and during the change of mode, to play the short wav with a electromagnets click
Hi ExtremeHunter,
My layout looks so fine with your script, I recorded it here:
Tape reels screen capture (http://www.youtube.com/watch?v=w7J9XDggqyE)
As you see, the left tape reel runs from full to empty while the right runs from empty to full but it will look more real if the left and the right are decreased/increased speed gradually.
Anyways, I am now very satisfied with this script and thanks so much for your support
P/S: Thanks onv, derty2 and others for your useful suggestions.
you could extract all "frames" from a .gif then have WSH panel mod loop through them all on a timer.
Can anyone shed some light on this on the flicking part?
Methods:
// NOTE: Don't try to update tooltip text when tooltip is activated, because it will flick in Windows Vista/7.
void Activate();
var g_tooltip = window.CreateTooltip();
function tt(t) {
//t is a variable containing our tooltip text - usually called from on_mouse_move
//if it hasn't changed, don't try and update it....
if (g_tooltip.Text == t) return;
g_tooltip.Text = t;
g_tooltip.Activate();
tt("hello"); //obviously "hello" can be whatever text you like. it will probably change as you move over different things....
Is it possible to display whole biography from last.fm?
nope: http://www.last.fm/group/Last.fm+Web+Servi...21604/_/2201974 (http://www.last.fm/group/Last.fm+Web+Services/forum/21604/_/2201974)
last.fm themselves are preventing the full display of artist info.
and they've also broken the fetching of info on artists with an ampersand (&) in the name.
Marc, in your bio panel, can we disable the download of bio info, if that info already exists in the XML?
I would rather keep my full local data rather than having it replaced.
Seeing that lastfm messed up it'd be good idea to change the provider of biographies.
done. i really should have done this when i found out yesterday....
you can use
Script update on the context menu. (load a blank playlist with nothing selected before loading the panel otherwise the cache for the current artist would be cleared). or you can download the modified file here: http://dl.dropbox.com/u/22801321/wsh/marc2003/common6.js (http://dl.dropbox.com/u/22801321/wsh/marc2003/common6.js)
full download zip is here: http://db.tt/BInQ3Abm (http://db.tt/BInQ3Abm)
files changed:
marc2003\common6.js
and just incase people didn't realise, clicking the last.fm logo in the top right takes you to the full artist bio on the last.fm website.
very kind Marc - your support time is more than acceptable!
Hello marc2003,
continuing on from the previous thread,
So as mentioned the error has disappeared but I can still not display anything correctly atm,
Checking the console I see errors like this,
Last.fm Similar Artists: Unexpected Last.fm server error.
Last.fm Charts: Unexpected Last.fm server error.
Audioscrobbler: Handshake failed.
I know this mod does not support the Audioscrobbler but I feel the errors may be related
The following is a screenshot of the far right section of my config showing the last fm errors.
https://dl.dropbox.com/u/12109423/foobar_lfm.png (https://dl.dropbox.com/u/12109423/foobar_lfm.png)
working fine me.
). the fact your audioscrobbler is failing to connect might well be an indication of that.
Hey marc2003,
So it's all working
I noticed that foobar was version 1.2.2 - I downloaded the latest (1.2.3) installed it to my portable directory loaded everything up and after a few restarts Last.fm similar artists/charts/Bio/images all display - the console is also reporting that tracks from the cache are being submitted to last.fm. Thanks for all your help and excellent scripts!
new script: last.fm bio mod. due to changes made by last.fm which truncates the bio, this pulls the same info from another site. you lose all the stats, language and auto correct options but it'll do for most people.
this uses new filenames for caching so it won't affect any previously saved data from the old script and i've left the old one there for now incase last.fm revert this change.
old and new side by side: http://dl.dropbox.com/u/22801321/old%20new%20bio.PNG (http://dl.dropbox.com/u/22801321/old%20new%20bio.PNG)
changed / added files:
marc2003\common6.js
samples\last.fm biography mod.txt
Your mod script is nowhere to be found in the zip archive.
IMHO perhaps overkill but can last.fm bio mod and the orginial last.fm bio script be merged such that it pulls stats from the original and the full bio from the mod?
Also a bit unrelated perhaps but is there any way to convert add to tags all last.fm local data. My big issue with how data is stored right now is that is not that easily available for other applications/components/scripts. Still that doesn't seem to be a good solution. How would it be easier to call locally stored last.fm data for other components?
can't believe i forgot to put it in. i'll sort that out a bit later.
EDIT: done.
it's certainly possible but i'm not doing it.
as for your second point, i'm assuming you want to save the data downloaded into your file tags? the only way i know of doing that would be to write a new WSH panel mod script. not really something i'd take on.
the data is saved as JSON which is a pretty universal format but i don't know of any other components that can handle it.
Possible that you haven't replaced old common6.js? I get this error:
Scripting Engine Initialization Failed (Last.fm Biography mod v6.2013-02-21.01 by marc2003, CODE: 0x80020101)
Check the console for more information (Always caused by unexcepted script error).
Old script is working.
i did that properly but i can't believe i bodged the
last.fm biography mod.txt file itself.
i've updated the zip but you don't need to download the full thing again. just open the panel and change line 10 from
var p = new panel("Last.fm Biography", ["metadb", "lastfm_bio", "remap"]);
to...
var p = new panel("Last.fm Biography", ["metadb", "lastfm_bio_mod", "remap"]);
That's the problem
And converting json to a component-supported text format?
even if the bio was stored as plain text, i still don't know any components that would read it. which makes the format kind of irrelevant.
however, i could add a copy text option to the context menu. this will put the text on the windows clipboard and you can paste it into the properties dialog yourself. although scripts can write tags themselves, it's not really useful doing one file at a time. you'd want to apply it to all tracks by a given artist.
Ahh
Tags don't seem like the ideal way to go either. Adding a copy text option would help but is still a lot of work. A method similar to how lyrics are handed via foo uie lyrics? It's only that lyrics are per-track. For songs that haven't been tagged, I could at least get to display the info via a custom wsh script/text viewer. Integrating info as foo bio view does is awsome, but hum well after all dreaming is free
assuming you don't need the text outside of foobar, my cached files aren't going anywhere now because it no longer automatically updates. the reason i used auto-updates before is because the bio pages on the last.fm website are basically wiki's which are user editable. i even made changes to some pages myself so i always wanted the latest version displayed in foobar. but that idea is pretty much dead now unless last.fm revert the change.
all my data is saved in a folder called wsh_lastfm inside your foobar2000 profile folder so you can back that up if you like. it will always be readable by my scripts.
samples updated.
thumbs: improve appearance of edges by trimming them. i'd never noticed before how bad it can look with lots of images.
use
Script update from the context menu or the full download is here.... http://dl.dropbox.com/u/22801321/wsh/samples.zip (http://dl.dropbox.com/u/22801321/wsh/samples.zip)
files changed:
marc2003\common6.js
That's what I had been doing, though yes I would like if possible to make it easier to access/read the data not only by your scripts.
Not all the time I use Foobar, for those cases I can't read it.
I do hope as well Last.fm reverts bio change.
samples updated.
now playing (all variants). bugfix. when foo_playcount is not installed, the whole panel responded to single clicks telling you this but it should only do it when clicking the rating stars.
use
Script update from the context menu or the full download is here.... http://dl.dropbox.com/u/22801321/wsh/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
files changed:
marc2003\common6.js
samples updated. now playing (all variants). bugfix. when foo_playcount is not installed, the whole panel responded to single clicks telling you this but it should only do it when clicking the rating stars.
use Script update from the context menu or the full download is here.... http://dl.dropbox.com/u/22801321/wsh/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
files changed:
marc2003\common6.js
Thanks for all your posts very much!
Here is a question again:
How do I keep focus on WSH Panel when context menu is opening?
i don't know what you mean? explain what's happening and what you expect to happen.
also more samples updates: http://dl.dropbox.com/u/22801321/samples.zip (http://dl.dropbox.com/u/22801321/samples.zip)
i've removed the playback buttons on all
now playing for aesthetic reasons. i figure most people will have them already as a permanent fixture somewhere else on their layout plus it can look messy depending on the CD cover.
i've also fixed the
now playing with last.fm bio to use a 3rd party site to get the full bio again now that last.fm truncate theirs. that has been renamed to
now playing with last.fm bio modfiles changed:
samples\now playing.txt
samples\now playing with last.fm bio mod.txt
When the context menu shows in WSH Panel, and then mouse hover any other elements, there will no reaction, because the focus is on the context menu. And I don't want to change focus to context menu, is it possible?
i still don't understand. the right click behaviour is the same as any other component (try it). why the hell are you opening it if you you're not going to use it?
I want it open, but when it's open I also want to enable mouse hover function in WSH Panel, so that I can write a script which like toolbar (when menu is open, mouse hover other element, we can see the other element's menu).
Sorry, if you don't have answer, skip me.
well it's just not possible. when you execute this bit of code....
idx = _menu.TrackPopupMenu(x, y);
nothing happens until you click something. it will wait indefinitely.
Ok, I konw, thank you very much!
how to use? and where?
function on_tooltip_custom_paint(gr) {}
^i have no idea.
samples updated:
simple tag reader. no longer wrap text when using fixed width font.
use
Update script on the context menu or full download is here: https://dl.dropbox.com/u/22801321/samples.zip (https://dl.dropbox.com/u/22801321/samples.zip)
files changed:
marc2003\common6.js
samples updated: changed appearance of
themed toolbar buttons. also, the help button is now a popup of useful foobar2000 related web links. people might already have them bookmarked but meh.
screenshot (https://dl.dropbox.com/u/22801321/2013/march/new%20help%20button.png)
download: https://dl.dropbox.com/u/22801321/samples.zip (https://dl.dropbox.com/u/22801321/samples.zip)
files changed:
samples\themed toolbar buttons.txt
i accidentally broke my artreader script a few days back. it may say no image when there clearly should be one.
use Update script on the context menu to fix it.
just a note for users of my
last.fm biography mod script (which uses another site called echonest), you may find the bio not displaying. if you look in the foobar2000 console, you should see this message explaining why.
Now Playing with Last.fm Bio: {"response": {"status": {"version": "4.2", "code": 3, "message": "api_key - You are limited to 20 accesses every minute. You might be eligible for a rate limit increase, go to http://developer.echonest.com/account/upgrade"}}} (http://developer.echonest.com/account/upgrade"}}})
at the moment i'm using my own api key for everybody and i have no idea how many people are using it. maybe this is just a one off freak occurrence but i guess i'll try and apply for the upgrade.
edit: i've got the upgrade to 120 calls per minute. i can't get any more than that.
marc2003 : good work.
btw, could u make a script which get artist info from both echonest and lastfm.api ?
i notice that there are some artist that echonest can't get info from last.fm
for example :
http://www.last.fm/music/Toyosaki+Aki/+wiki (http://www.last.fm/music/Toyosaki+Aki/+wiki)
http://developer.echonest.com/api/v4/artis...me=toyosaki+aki (http://developer.echonest.com/api/v4/artist/biographies?api_key=16GBFCD4RSRXNAFOX&format=json&name=toyosaki+aki)
the whole point of me switching away from last.fm directly is because they truncate the text. my old version still works but it now displays this....
(https://dl.dropbox.com/u/22801321/2013/march/aki.png)
sorry, but there's no way i'm going to all the effort of mangling 2 scripts together just for that.
okay, i understand
i guess nobody uses my
musicbrainz script (in URLs mode) because they made a breaking change on the 25th feb and i've only just discovered it. it's fixed nonetheless.
use
Update script on the right click menu.
the full download zip here: https://dl.dropbox.com/u/22801321/samples.zip (https://dl.dropbox.com/u/22801321/samples.zip)
files changed:
marc2003\common6.js
for those unaware, my
musicbrainz script has 2 separate features rolled into one. the first mode displays up to 100
releases with clickable links taking you to the website where it will list all the details. you can toggle the mode on the right click menu to
urls and it displays clickable links to various official websites related to the artist. i've put 2 panels side by side in this screenshot (https://dl.dropbox.com/u/22801321/2013/march/musicbrainz.png).
another quick fix. discogs are sending line breaks back in their response where they shouldn't be.
now sorted. update instructions as above.
added a few more
favicon images to my
musicbrainz script (when in links mode).
marc2003\common6.js
Thanks for the fixes marc2003, I use both and I was aware of the problem with musicbrainz
i would have fixed it sooner had anyone said something. because i maintain quite a few scripts now, i don't have them all active in my layout at once.
i guess i should test them more often - especially with musicbrainz because i am using their beta JSON service which i know is subject to change. lesson learned.
How to update a cover panel made in WSH panel mod immediately (and automatically) when a cover is added to the file?
For now i had to update the panel by myself.
Is there any way?
Btw. i haven't made anything in wsh panel mod since a long time, but now i think its time to update my scripts.
So i have an additional question:
What is the advantage of GetAlbumArtAsync over GetAlbumArtV2?
i don't think it's possible. if you put this in a script and edit the tags of a playing song, it triggers...
function on_playback_edited() {
fb.trace("boo!");
but using the tagging context menu to add/remove images does not affect it. i have context menu item for users to manually refresh.
GetAlbumArtAsync used in conjunction with the on_get_album_art_done callback gets you the image and the path of the image. this is useful if you want to add mouse click/context menu options for finding/opening it. utils.GetAlbumArtV2 simply gives you an image object.
....and on that note i've actually just changed my script to use utils.GetAlbumArtV2 again because the other method causes the occasional flicker (or maybe my implementation was wrong ).
users of my
artreader /
cd jewel case script can use the
Update script option on the right click menu to update.
Is there any way?
sure ... if it's in file, metadb changed, so you can trap this tag update in this callback:
function on_metadb_changed(metadb_or_metadbs, fromhook) {}
NB: // @feature "watch-metadb" is to add in PREPROCESSOR section
the first one is asynchronous, it's useful when you have to load a lot of covers in a row to not block the script while reading/loading the coverfile, each load is "queued" and you trap the load over in another callback:
function on_get_album_art_done(metadb, art_id, image, image_path) {}
the art_id is the one used in the GetAlbumArtAsync args...
HTH
@marc2003
Ah, thanks.
I tried on_metadb_changed and on_playback_edited.
The only thing is that then it will be updated when playcounts or any other info has changed.
But the cover doesn't seems to be recognised as an edit or a metadata change.
Too bad...
And thanks for clarification abour Async and V2
I thought the first may have performance advantages...
So i will stay on V2.
EDIT:
@Falstaff
on_metadb_changed?
I tried already but got no luck...
How did you did it?
And about Async/V2:
I guess its useful for playlists or like marc2003 said if one wants the filepath.
But i think i'll stick on V2 for my cover script
"But the cover doesn't seems to be recognised as an edit or a metadata change.
Too bad..."
it does for me, just tested on adding image with Context menu "Tagging" > "Attach pictures" or "Remove pictures"
EDIT: here is the FULL script!
// ==PREPROCESSOR==
// @feature "v1.4"
// ==/PREPROCESSOR==
fb.trace("metadb_changed!");
open console, and check if it logs the trace on actions discribes above
HTH
are you sure? does nothing for me....
No, it doesn't...
It only gives the message on playback starting or i edit some tags, but not when i edit the attached pictures.
Tried it several times (with fb.trace and fb.ShowPopupmessage, no luck)
yep i'm sure, weird you don't have it working .... tested with DUI
Nope...
In DUI the same. Tried it still - no luck.
Have you opened console before hit play?
Then you'll see the message comes when opening the first track, not from editing the attached pictures.
EDIT:
The only message that comes to console after attached/removed a picture is:
Reopening played file after update: "C:\Users\Gerhard\Music\Image\Bonus Tracks\001. xxx - xxx.wv"
Falstaff
When adding/removing cover art, on_metadb_changed gets called only if playlist is autoplaylist.
Oh, yes.
Works with autoplaylists but not with normal ones.
As i said: too bad...
Another strage thing i realized: this fb.trace will be called three times on every start of a new track in my config, although no metadata is changed...
Guess its really time to rewrite my scripts...
EDIT:
Ah, found the bad one: not my scripts at all but Biography view panel!
If i delete it from my config, on_metadb_changed() won't called anymore when playback of a track starts.
that's normal. you usually have on_item_focus_change (which in turn calls on_metadb_changed) in these 2 callbacks.
on_playback_stop
it gets called a 3rd time if you have cursor follows playback enabled as well.
depending on what your on_metadb_changed function does, you can have it return if the metadata is the same as before. just store and compare it. i use this for my artist related scripts. if a user is half way down scrolling through a long bit of text, a selection or track change isn't going to reset the position so long as the artist is the same.
No, it shouldn't.
It should only "work" when metadata is changed not when focus has changed
And without biograhy view panel this console message does only appear when metadata is changed not when playback starts/stops or focus changes.
So its not my scripts fault (yippieh . No need to rewrite my whole scripts)
EDEIT:
No forget it...
Of course metadata changes when a new track is in focus/playback, but a script that only contains the code snippet posted by falstaff shouldn't give a message to console then.
Because the file and its metadata itself aren't touched by the snippet and as long no other script changes tags or infos this message shouldn't appear.
In other scripts containing on_metadb_changed, on_playback_new_track and on_playback_stop where metadata changes are asked of course this message should appear.
So i was mistakable, sorry
we must do things differently then. of course on_metadb_changed only works as a callback when tags change. but as i explained above, i have other events/callbacks trigger it as well.
See my edit (i'm always too fast in writing my thoughts down and that for easy mistakable )
Falstaff
i still don't know why, but still works for me even on "normal" playlist ...
Not for me...
Only when the playing file reaches one minute and playcount updates on_metadb_changed is called and the message appears.
And i tried several skins (my own, my new design i'm working at, HiFoo, foo_tunes, fooRazor) and blank CUI and DUI with your code snippet.
Still no luck...
Hello, everyone! I want to use two colors in one DrawString line, but I can't find the way to do this, can anyone help me?
In other computer language it can be use in "|cffFF0000XXX|r OOO" but I don't know the way in WSH.
PS. I use one line because I want the string align in center.
the only way i know of to do that requires that you use 2 lines of DrawString code.
there's no reason why it can't be done with 2 lines. calculate the width of the entire text. subtract that from the overall width of your "text area". divide that by 2. that gives x for the first bit of text. after calculating the width of the first colour text (plus a space), add that on to give the value of x for the second colour.
obviously this method would be useless for text spread over multiple lines but it should work fine for anything on a single line.
Maybe someone knows an answer for:
How to draw something like this in wsh panel mod:
(http://www.abload.de/img/spacetsuvt.png)
But amount of squares depending on the width of a panel.
(the colour depends on ui settings, otherwise i would use png image).
var w = 20;
var l = (ww - w) / w;
for (var i = 0; i < l; i++) {
for (var j = 0; j < 10; j++) {
if (i % 2 == 1 && j % 2 == 1) gr.FillSolidRect(w * i, w * j, w, w, 0xff000000);
function on_size() {
ww = window.Width;
wh = window.Height;
Wow, this was fast
I'll try it asoon.
too slow ... but i give it to you too
ww = window.Width;
wh = window.Height;
drawSquares(gr, 30, 5, ww, wh);
function drawSquares(gr, squareSize, paddingSize, panelW, panelH) {
// square colour
var colour = 0xffff0000;
// step size
var stepSize = squareSize + paddingSize;
// # of square in a line
var totalsq = Math.ceil(panelW / stepSize);
// # of lines to draw
var totalrow = Math.ceil(panelH / stepSize);
// let's draw the matrix
for(var j=0; j < totalrow; j++) {
for(var i=0; i < totalsq; i++) {
gr.FillSolidRect(i*stepSize, j*stepSize, squareSize, squareSize, colour);
edit: ah too slow as well.
kudos to ExtremeHunter !!!
Wow, thanks Falstaff
This is nearly exactly what i want.
One day if i understand this code i maybe found out how i get the a square at half width at the end
EDIT: Damn i'm that silly.
Understood this code now and its no problem to get what i want
Many thanks again
ok, replace drawSquares function by this one to get the center thing:
// square colour
// step size
// padding to center
var hpad = Math.round( ((stepSize * totalsq) - panelW - paddingSize) / 2);
var vpad = Math.round( ((stepSize * totalrow) - panelH - paddingSize) / 2);
gr.FillSolidRect(i*stepSize - hpad, j*stepSize - vpad, squareSize, squareSize, colour);
Hi, I would like to modify marc2003's Art Reader script so that when I drag and drop songs from the library to the Art Reader panel, it adds the songs at the end of the active playlist. Is this possible?
@Falstaff
Many many many thanks again. You're my hero
Btw. this one is needed for replacing my font style in my display panel with png.
But the background has to be drawn then. And that for is this matrix.
add this to the preprocessors (green text) at the top
// @feature "dragdrop"
then put this function anywhere in the script
function on_drag_drop(action) {
if (plman.PlaylistCount == 0) {
plman.CreatePlaylist(0, "New playlist");
plman.ActivePlaylist = 0;
action.ToPlaylist();
action.Playlist = plman.ActivePlaylist;
action.ToSelect = false;
ExtremeHunter
Can you modify your code at Post #2093 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=827343) so instead of background squares we get cross-hatch lines like you see in graph paper?
Here are some examples of what I'm talking about: (1) plain grid (http://www.printfree.com/Office_forms/FormImages/Graph_paper2.gif) (2) enhanced grid (http://people.rit.edu/andpph/misc/graph-paper-v-7x9.jpg)
Also, I would like the lines to be light-gray and the back to be dark-gray ....I want the pattern to look very subtle in the WSH panel.
this is just a plain grid. you can customise the first 4 lines as you like.
spacing = 20;
line_thickness = 1;
bg = RGB(65, 65, 65);
colour = RGB(192, 192, 192);
function RGB(r, g, b) {
return (0xff000000 | (r << 16) | (g << 8) | (b));
ww = window.Width;
wh = window.Height;
gr.FillSolidRect(0, 0, ww, wh, bg);
for(i = 0; i < Math.ceil(ww / spacing); i++) {
gr.DrawLine(i * spacing, 0, i * spacing, wh, line_thickness, colour);
for(i = 0; i < Math.ceil(wh / spacing); i++) {
gr.DrawLine(0, i * spacing, ww, i * spacing, line_thickness, colour);
enhanced grid version.
spacing = 8;
ww = window.Width;
wh = window.Height;
gr.DrawLine(i * spacing, 0, i * spacing, wh, i % 20 == 0 ? 4 : i % 10 == 0 ? 2 : 1, colour);
gr.DrawLine(0, i * spacing, ww, i * spacing, i % 20 == 0 ? 4 : i % 10 == 0 ? 2 : 1, colour);
Very nice
marc, thanks a lot +++++++++
ExtremeHunter,
I am too stupid and cannot put a turntable as background image in your "WSH Spinning Disc Image Viewer" code!
Can you please modify this code so it works please, thanks:
// @name "Spinning Disc Image Viewer" (2013-01-25-075628)
// @author "eXtremeHunter"
window.DlgCode = 0x0001; // arrow keys for DUI
var defaultDisc = gdi.Image(fb.FoobarPath + "addons\\wsh-spinning-disc\\disc.png"); //<<<<<<<<<<<< is used as animated foreground
var backgroundimage = gdi.Image(fb.FoobarPath + "addons\\wsh-spinning-disc\\turntable.png"); //<<<<<<<<<<<< is used as still background
var margin = window.GetProperty("Margin", 50);
var zoomStep = window.GetProperty("Zoom Step", 30);
var useDiscMask = window.GetProperty("Use Disc Mask", true);
var angle = 0;
var minSize = 20;
var disc = defaultDisc;
var discAlpha = 100; // disc transparency 0-255.
var rotationTimer;
backgroundimage && gr.DrawImage(backgroundimage, ww, ww, ww, wh, 0, 0, window.Width, window.Height);
disc && gr.DrawImage(resizedDisc, discX, discY, discW, discH, 0, 0, resizedDisc.Width, resizedDisc.Height, angle, discAlpha);
function on_mouse_wheel(step) {
if (utils.IsKeyPressed(16)) {
if (step == -1 && discW <= minSize) return;
var s = step * zoomStep;
margin = margin -= s;
window.SetProperty("Margin", margin);
on_size();
window.Repaint();
function on_key_down(vkey) {
if (vkey == 38) on_mouse_wheel(1) //UP ARROW
if (vkey == 40) on_mouse_wheel(-1); //DOWN ARROW
ww = window.Width;
wh = window.Height;
discW = Math.max(minSize, ww - margin);
discH = Math.max(minSize, wh - margin);
if (discH < discW) discW = discH;
else if (discW < discH) discH = discW;
discX = ww / 2 - discW / 2;
discY = wh / 2 - discH / 2;
resizedDisc = disc.resize(discW, discH);
if (useDiscMask) {
var discMask = gdi.CreateImage(discW, discH);
var g = discMask.GetGraphics();
g.FillSolidRect(0, 0, discW, discH, 0xffffffff);
g.SetSmoothingMode(2);
g.FillEllipse(1, 1, discW - 2, discH - 2, 0xff000000);
discMask.ReleaseGraphics(g);
resizedDisc.ApplyMask(discMask);
discMask.Dispose();
(function onRotationTimer() {
getDiscImage();
if (!fb.IsPlaying || fb.IsPaused) {
return;
angle += 10;
(discW >= ww || discH >= wh) ? window.Repaint() : window.RepaintRect(discX, discY, discW, discH);
function on_playback_stop(reason) {
if (reason != 2) {
getDiscImage();
state ? stopRotationTimer() : onRotationTimer();
onRotationTimer();
var tempAlbum;
function getDiscImage() {
if (!plman.PlaylistItemCount(plman.ActivePlaylist)) return;
var nowPlayingDisc;
var metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
if(!metadb) return;
var currentAlbum = fb.TitleFormat("%album%").EvalWithMetadb(metadb);
if (currentAlbum == tempAlbum) return;
nowPlayingDisc = utils.GetAlbumArtV2(metadb, 2);
nowPlayingDisc ? disc = nowPlayingDisc : disc = defaultDisc;
tempAlbum = currentAlbum;
on_size();
window.Repaint();
function on_selection_changed(metadb) {
if (!fb.IsPlaying) getDiscImage();
function on_playlist_items_removed() {
if (!plman.PlaylistItemCount(plman.ActivePlaylist)) disc = defaultDisc;
on_size();
window.Repaint();
Hi, thank you for quickly answer. But I have tried to use 2 draw text codes in long time ago, and I found the API about CalcTextWidth, CalcTextHeight, and EstimateLineWrap isn't very accurate, and my string shows in panel is 1~5 lines, so use 2 draw text is not useful for me. But anyway, thank you very much again!
added a few more favicon images to my musicbrainz script (when in links mode).
marc2003\common6.js
I just played your sample, it's awesome!
Would you like to add search album function in art.exe? (I can't understand the source...)
If you are not interesting in it, skip my comment.
that program is made for last.fm and it's not very good for album images. you could look at this instead.
http://www.hydrogenaudio.org/forums/index....showtopic=57392 (http://www.hydrogenaudio.org/forums/index.php?showtopic=57392)
BTW, i didn't make that art.exe program. the original is here:
http://www.hydrogenaudio.org/forums/index....showtopic=77425 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77425)
i had to modify it to work with WSH panel mod so i had to include my modified source. (i just commented out a line or 2)
Perfect, thank you very much!! And where could I find some documentation for those functions?
i just copy/pasted from the sample provided with the component. Drag Drop Basic.txt.
documentation will be in interfaces.txt and callbacks.txt (almost forgot preprocessors.txt)
derty2
backgroundimage && gr.DrawImage(backgroundimage, 0, 0, ww, wh, 0, 0, backgroundimage.Width, backgroundimage.Height);
Thankyou eXtremeHunter +++++++
Here is a screenshot of my panel in action:
(http://i.imgur.com/nw0Kt0e.jpg)
How can I adjust the X-Y coordinates of the disc in the panel so its hole sits exactly at same location as the turntable spindle? (i.e. I want to center the disc on the turntable platter).
By the way, I have been observing the behaviour and performance of your script (with the panel as you see above) and it is not perfect news :-( . . . . . . . when the panel is active it impacts the performance of all other foobar2000 functions. The panel itself no longer spins the disc smoothly; it spins with a stuttering, jerky action. If I try scrolling the playlist viewer, I get stuttering and lagging movement. If I try opening menus I get stuttering and freezing graphics, and CPU usage escalates to around 25%.
If you have time one day, maybe you can review your code; I think it needs some tweaking and optimizing. I wish I could do it myself by I am not a JS scripter (yet).
Thanks again for all your help eXtremeHunter +++++++
i do not believe there is anything that can be done in script to solve that. this component is not optimised for working with images like that.
i'd happily like to be corrected though.
if you want to tinker with x co-ordinate. on line 16
change to
gr.DrawImage(resizedVinylImage, vinylX - 100, vinylY, vinylW, vinylH, 0, 0, resizedVinylImage.Width, resizedVinylImage.Height, angle);
change the -100 if you like
edited to make simpler
Thanks for that marc, unfortunately if I resize the panel in the X-axis then we no longer have the same relative co-ordinate :-(
I'm guessing it is solvable with more math in the script.
you can either wait for ExtremeHunter to reply or i could attempt to have a go but i'd need the full script and images to test with.
derty2
use proportionality virtual center X/background width and virtual center Y/background hight as the center of origin of your rotating disc
your background (https://www.dropbox.com/s/n342cmbyldad460/nw0Kt0e.jpg)
Me again...
Hoping that someone can help me here again:
I'm on replacing the font used in my display with PNG's and it worked good so far, except one thing: the volume.
I have no clue how i can do it with the volume...
I used the format fb.Volume.toFixed(2).
Here is the working example code for playback time:
function TimeImage() {
this.image = gdi.CreateImage(120, 20);
this.currentTime = "";
this.init = function(time) {
gr = this.image.GetGraphics();
this.drawDigit(time, 0, 0);
this.drawDigit(time, 1, 0);
g_rowImage && gr.DrawImage(g_rowImage, 36, 0, 6, 20, 234, 0, 6, 20);
this.drawDigit(time, 3, -12);
this.drawDigit(time, 4, -12);
g_rowImage && gr.DrawImage(g_rowImage, 78, 0, 6, 20, 234, 0, 6, 20);
this.drawDigit(time, 6, -24);
this.drawDigit(time, 7, -24);
this.currentTime = time;
this.image.ReleaseGraphics(gr);
this.draw = function(time) {
if (this.currentTime == "") this.init(time);
else {
this.drawDigit = function(time, index, offset) {
var digitValue = time.charAt(index);
if (this.currentTime == null || this.currentTime == "" || digitValue != this.currentTime.charAt(index)) {
var xoffset = index * 18 + offset;
gr.FillSolidRect(xoffset, 0, 18, 20, ui_backcol);
drawSquares(gr, 2, 1, xoffset, 0, 18, 20);
g_rowImage && gr.DrawImage(g_rowImage, xoffset, 0, 18, 20, digitValue * 18, 0, 18, 20);
var g_timeImage = new TimeImage();
Later i call in on_paint:
var t_fmt = t_rem ? info.Remain : info.Elapse;
g_timeImage.draw(t_fmt);
gr.DrawImage(g_timeImage.image, Math.floor(ww / 2.55), 30, 120, 20, 0, 0, 120, 20);
g_noTimeImage && gr.DrawImage(g_noTimeImage, Math.floor(ww / 2.55), 30, 120, 20, 0, 0, 120, 20);
And as long the g_rowImage (where all needed numbers and signs are in) is there it works really well.
So i thought i could do something similar with the volume and rewrote it to this:
function VolumeImage() {
this.image = gdi.CreateImage(168, 20);
this.curVolume = "";
this.init = function(volume) {
this.drawDigit(volume, 0, 0);
this.drawDigit(volume, 1, 0);
this.drawDigit(volume, 2, 0);
this.drawDigit(volume, 3, 0);
g_rowImage && gr.DrawImage(g_rowImage, 72, 0, 6, 20, 240, 0, 6, 20);
this.drawDigit(volume, 5, -12);
this.drawDigit(volume, 6, -12);
g_rowImage && gr.DrawImage(g_rowImage, 114, 0, 18, 20, 216, 0, 18, 20);
g_rowImage && gr.DrawImage(g_rowImage, 132, 0, 36, 20, 264, 0, 36, 20);
this.curVolume = volume;
this.draw = function(volume) {
if (this.curVolume == "") this.init(volume);
else {
this.drawDigit = function(volume, index, offset) {
var digitValue = volume.charAt(index);
if (this.curVolume == null || this.curVolume == "" || digitValue != this.curVolume.charAt(index)) {
g_rowImage && gr.DrawImage(g_rowImage, xoffset, 0, 18, 20, digitValue == " " ? 216 : digitValue * 18, 0, 18, 20);
var g_volumeImage = new VolumeImage();
furthermore:
function pad_right(x, y, z) {
z || (z = ' ');
return x.length < y ? z.repeat(y - x.length) + x : x
And in on_paint:
var vol = fb.Volume.toFixed(2) + " db";
g_volumeImage.draw(pad_right(vol, 10));
gr.DrawImage(g_volumeImage.image, ww - 194, 30, 168, 20, 0, 0, 168, 20);
But always get script errors (overflow in the g_rowImage line in this.drawDigit part)...
Does anybody have a clue why ones working ones not?
I guess it may be the "-" before the volume?
How could i get rid of?
Btw. all other codes (for tracknumber, totaltracks and bitrate) i rewrote from the time code works well too.
Only the volume will not work...
Edit:
Oh, i forgot...
This is one of the rowImages i use (this one in red):
onv
Thanks for the "proportionality virtual center" tip and taking the time to post a diagram ++++
I think you are on the money here. . . .please show me some demo code to paste into the script I posted at Post #2105 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=827390). Thanks
derty2
at least for this I need a clean background picture, without disc
onvhere is an uploaded copy of the turntable image used as background in the panel:
turntable.png.rar - 2.3 MB, No Password
http://filebeam.com/9a42860bc83d58bc0f78dd4b4c10b909
derty2// ================================================== //
// @name "Spinning Disc Image Viewer (Jan 24, 2013)"
var defaultDisc = gdi.Image(fb.FoobarPath + "images\\disc.png");
var backgroundImage = gdi.Image(fb.FoobarPath + "images\\turntable.png");
var angle = 0;
var minSize = 20;
var rotationTimer;
backgroundImage && gr.DrawImage(backgroundImage, 0, 0, backW, backH, 0, 0, 1196, 944);
disc && gr.DrawImage(resizedDisc, discX, discY, discW, discH, 0, 0, resizedDisc.Width, resizedDisc.Height, angle);
on_size();
window.Repaint();
ww = window.Width;
wh = window.Height;
backW = ww;
backH = wh;
if (backH < backW) backW = backH*1.267;
else if (backW < backH) backH = backW/1.267;
discX = backW * 0.392 - discW / 2;
discY = backH * 0.493 - discH / 2;
if (useDiscMask) {
discMask.Dispose();
getDiscImage();
return;
angle += 10;
if (reason != 2) {
getDiscImage();
onRotationTimer();
var tempAlbum;
var nowPlayingDisc;
if(!metadb) return;
on_size();
window.Repaint();
on_size();
window.Repaint();
very quickly, perhaps not very accurately
so (http://www.youtube.com/watch?v=X4FyzIM14NI&feature=youtu.be)
eXtremeHuntersorry
Excellent work onv +++++++
you locked the aspect ratio of the turntable and added math calculations for resizing the disc to suit changing co-ordinates at function on_size() ....impressive ++++++
I've played with it a little bit as I type this ....it has a problem! ....panel will crash if I try resizing the panel in the Y-axis ....X-axis is OK
Man this is such a lovely visualization, I love it! ...I am a vinyl freak (if you didn't know :-) .....unfortunately, foobar2000 performance and usability are TOTALLY CRUSHED when this panel is working!!!!
It looks to me like this panel cannot be anything more than a proof-of-concept project .....a sad conclusion.
I think that Russian developer who made the "Analog VU Meter" ("foo_vis_vumeter") component —I think his name is DRON or something— could make something like this.
Maybe he should name it "Analog Turntable" ("foo_vis_turntable")
P.S. -- I tell you what would look really cool as the "Default Disc" in this panel .....watching the empty turntable platter spinning around !!!!!!
i had a go at fixing this and i've basically done it. the only problem is on album change where the UI freezes for 2-3 seconds. it uses next to no cpu once the album change is out of the way. i just need to tidy it up a bit and i'll post it later on.
Maybe using RegisterRect(window.ID,x,y,discW,discH) can reduce CPU loading
Hi all.
I'm currently using foo_uie_albumart and I'm looking for a replacement because I fear sooner or later it (or CUI itself) won't be compatible with fb2k.
So I had a look at marc's Art Reader and, while it works, it lacks some features I've grown accustomed to. I know the script is based on fb2k art reader and therefore my request should probably be addressed to Peter, but I don't think he's interested so I'll ask here just in case:
1) define multiple sources of images (with title formatting) and
automatically cycle through them; for example, my current uie_albumart shows cover and artist images (if any) through the following setup:
E:\My Music\covers\%artist%_%album%.*
E:\My Music\artists\$substr(%artist%,1,1)\%artist%_*.*
2) define multiple sources of no-cover images (with title formatting) and
automatically cycle through them; again, my current setup is
--$if($strcmp($left(%path%,4),http),E:\My Music\covers\onlineradio*.*,E:\My Music\covers\nocover*.*)
3) switch between currently playing and selected track (now, if I'm not mistaken, it always shows the art for the selected track)
Cheers.
Alessandro
i cut most of the old code out but here is my modified turntable script. https://dl.dropbox.com/u/22801321/2013/march/turntable.txt (https://dl.dropbox.com/u/22801321/2013/march/turntable.txt)
turntable image saved as .jpg here: https://dl.dropbox.com/u/22801321/2013/march/turntable.jpg (https://dl.dropbox.com/u/22801321/2013/march/turntable.jpg)
i'm not sure how memory usage goes after extended use as i haven't really had time to test it properly.
@mobyduck, my simple image viewer script can display images from multiple folders and cycle through them. there is no support for no cover images though.
edit: just realised that script won't work for you. it does not support wildcards for filenames. it only supports title formatting for folders and it automatically displays all the images inside.
and lastly, check the Selection mode submenu. by default it uses the settings found under file>preferences>display to choose whether to follow the playing/selected track but you can over-ride this on a per panel basis. that is far more functionality then you get from anything else.
RegisterRect()what's that ? how does it work? nothing in WSH Panel Mod docs about it ...
I had missed that, thanks (but, as far as usability goes, in foo_uie_albumart you can toggle that preference with a single click... ).
Well, I can always hope for some programmer to resurrect the plugin some day (source is available). Or I might just learn some C and do it myself.
Alessandro
it's really a single click? how do you know which mode it is in? i guess i need to streamline my 2 click approach.
and whilst on the subject of usability, doesn't that component crash foobar everytime you close it?
RegisterRect()
about RegisterRect (http://foobar2000.ru/forum/viewtopic.php?t=4061&start=140)
@onv:
ok, it's only concern foo_vis_vumeter.dll
@onv:
unfortunately, but it's true
little update for my version of the turntable script: https://dl.dropbox.com/u/22801321/2013/march/turntable.txt (https://dl.dropbox.com/u/22801321/2013/march/turntable.txt)
image: https://dl.dropbox.com/u/22801321/2013/march/turntable.jpg (https://dl.dropbox.com/u/22801321/2013/march/turntable.jpg)
the button now responds to clicks for play/pause.
i should say preliminary testing shows this uses around 60-70mb of ram. there is no load on cpu except very heavy usage at album change/panel resize causing the UI for freeze for a couple of seconds.
[a href="http://imageshack.us/photo/my-images/163/imgnd.jpg/" target="_blank"]
I was merely responding to your
more functionality then you get from anything else claim: didn't mean to criticize your brilliant work.
Not here. It has some glitches, granted, but I don't experience frequent crashes as its reputation seems to suggest (perhaps because I'm on XP, don't know).
Alessandro
marc2003
ideally it would be great to rotate synchronously with the disc and the ring with setting marks
But, if we want realism, will impose two areas highlight the blue and red rays, CPU even more sad...
and if add the angle of rotation of the tonearm as a stylized seekbar...
@mobdyduck, single click code for
simple image viewer. just stick it right at the end.
function on_mouse_mbtn_up(x, y) {
p.selection_mode = p.selection_mode == 2 ? 1 : 2;
im.folder = "";
on_item_focus_change();
>> onv: "and if add the angle of rotation of the tonearm as a stylized seekbar..."
don't forget to remove the tonearm locking clamp (look at the image again)
marc2003 - brilliant work mate, thanks a lot for putting all that effort and skill into this ++++++++++++++++++++++++++++++
marc2003
ermm, please excuse my stupidity ....I imported your script; yes it shows an image of a static turntable and the panel does not crash when resizing ...but where is the spinning disc?
Does your code do this? : Draws a spinning disc (disc.jpg) found in same location as selected track, ELSE draws a default spinning disc from a specified location.
*EDIT* sorry, upon further testing. . .
- I see it renders the disc.jpg at playing track location.
- I see your point about UI freezing! ....this only begins to happen if you have played a track ....if you restart fb2k and then resize the panel, there is no freezing
....if you play a track and then try resizing you get freezing ....if you play a track and then STOP playing and then try resizing, the panel freezing continues.
- Where is the default spinning disc when disc.jpg at playing track is not found? ...I was thinking of using an image of the empty turntable mat itself so the panel looks animated
it uses the core display preferences. make sure you set the
id variable in the script to match which type you want (i've given all the examples). i was using
front for testing because i don't have any disc art.
you can specify a default image under file>preferences>display>album art>TYPE>stub image path - no need for me to code this into the script.
right. resize before starting playback. why are people always resizing?
because of the overhead involved creating the images, there are no updates when playback is stopped. when you stop and select something else, you will still see the image from the previous album. it's only when playback starts again that the display will refresh.
_______________________________________________________
disc.jpg (used for "default disc" animation if disc.jpg at playing track is not found ....i.e. turntable platter contains no disc but looks like it is spinning)
(http://i.imgur.com/YgMb13Zl.jpg)
The above is a large thumbnail. The full size image can be found here: http://i.imgur.com/YgMb13Z.jpg
________________________________________________________
@marc2003
- I placed the above (default disc) image at <foobar_profile>\images\disc.jpg and I played some music having no disc.jpg at playing track ....your panel is not rendering the default disc.
- @fb2k . . . . . . File > Preferences > Display > Album art (section) > Disc (tab) . . . . . . I have disc.jpg as first item
- @script_config . . . . . . I have edited this line: var id = 2;
Ideally I want to keep this script and its resources in one subfolder. All user-made functions in my (portable) foobar2000 go to this location: <foobar_profile>\addons\<subfolder>
therefore I eventually want this WSH scripted panel to reference itself ONLY HERE:
<foobar_profile>\addons\wsh_vis_turntable\disc.jpg <<<<<<<<< the default disc . . . aka the turntable platter contains no disc but looks like it is spinning
<foobar_profile>\addons\wsh_vis_turntable\script.js <<<<<<<<< the working script
<foobar_profile>\addons\wsh_vis_turntable\turntable.jpg <<<<<<<<< the default background image
the artwork preferences don't know about your foobar profile\images folder. paths are relative to the playing track. how would it know to look in there? you'd have to specify the full path for that to work - with a drive letter. no good if you really need portable i suppose. it can be done in script by changing line 57.
replace
if (!img) return(window.Repaint());
with
if (!img) img = gdi.Image(fb.ProfilePath + "images\\disc.jpg");
Thanks for the information!
artistArt downloader is useful.
And I think I found the way to download image use jscript.
marc2003 - thanks again +++++++
The 'disc.jpg' (empty turntable platter mat) I posted at Post #2140 was not perfectly round, so I deleted it from the image hosting site.
This one here is perfectly round and will fill the the exact dimensions of the turntable platter without visual errors.
Click on the thumbnail to see/copy the full size image to your computer: (http://i.imgur.com/9MLgKxqs.jpg) (http://i.imgur.com/9MLgKxq.jpg)
And my next questions (hopefully the last ):
I have these two arrays in my script:
var c_arr = new Array(RGBA(191, 228, 255, 255), RGBA(128, 192, 255, 255), RGBA(0, 255, 0, 255), RGBA(255, 0, 0, 255), RGBA(255, 255, 255, 255), RGBA(255, 255, 0, 255));
var a_arr = new Array(RGBA(191, 228, 255, 8), RGBA(128, 192, 255, 8), RGBA(0, 255, 0, 8), RGBA(255, 0, 0, 8), RGBA(255, 255, 255, 8), RGBA(255, 255, 0, 8));
As you can see only alpha value changes.
This is for drawing rectangles according to a condition in full colour (in "on" mode) or semi-transparent (in "off" mode).
So is there a way to make it easier?
Is there anything like "blending" normal RGB() with alpha?
And is there anything like "blending" two colours (RGB() and RGB()) or substract one from another?
Then i could also use this on/off mode for text (since GdiDrawText doesn't seems to support an alpha value, i could then use a "off" colour depending on the c_arr colour and the background colour)
Okay, found the answer for question one.
Have again read the helpers.txt and found the setAlpha function (must have overread it before... shame on me).
But there is still my second question:
Is there a way to blend two colours like:
RGBA(19, 30, 38, 255) and RGBA(191, 228, 255, 10) will give RGBA(25, 38, 47, 255) (at least according to Paint.NET that i used for get the blend colour).
^haven't a clue, sorry.
just a note to say after a few problems with my scripts going by un-noticed recently, i've tested all of them to make sure they all work as i expect and i think they do. no doubt i've missed something...
i've tidied up a few bits, bumped the version numbers and updated the readme with a few more troubleshooting hints.
i've also created a new readme:
configuring the foobar2000 core to use Last.fm art fetched by my scripts (https://dl.dropbox.com/u/22801321/wsh/configuring%20the%20foobar2000%20core%20to%20display%20Last.fm%20artist%20art.pdf)
catchy title eh?
not sure what you want really as result for "blending" but i "blend" colour sometimes to get differents shades of a coulour with "&" and "|" :
i.e : RGBA(0, 255, 0, 255) | RGBA(0, 0, 255, 255) gives RGBA(0, 255, 255, 255)
but i generally play with the alpha channel ony to get the differents shades of a same colours by increasing or decresing the apha.
HTH
tedgomaybe this helps
// Combine two colors
// this [url=http://www.colortools.net/color_combination.html]http://www.colortools.net/color_combination.html[/url] web site uses similar formula
color1 = {
r : 0,
g : 255,
b : 0
color2 = {
r : 0,
g : 0,
b : 255
function combineColors(c1, c2, f){
// When fraction is 0, result is 100% color1, when f is 1, result is 100% color2.
var r = Math.round(c1.r + f * (c2.r - c1.r));
var g = Math.round(c1.g + f * (c2.g - c1.g));
var b = Math.round(c1.b + f * (c2.b - c1.b));
fb.trace("R = " + r + " G = " + g + " B = " + b);
var combinedColor = combineColors(color1, color2, 0.5);
function on_paint(gr){
gr.FillSolidRect(20,20, 100, 100, RGB(color1.r, color1.g, color1.b));
gr.FillSolidRect(140,20, 100, 100, RGB(color2.r, color2.g, color2.b));
gr.FillSolidRect(260,20, 100, 100, combinedColor);
Thanks Falstaff. New idea to play with
But i want more something like this formula:
first colour: RBA(r1, g1, b1, a1)
second colour: RGBA(r2, g2, b2, a2)
r = Math.min(255, r1/255*a1 + r2/255*a2)
g = Math.min(255, g1/255*a1 + g2/255*a2)
b = Math.min(255, b1/255*a1 + b2/255*a2)
a = 255
new colour: RGBA(r, g, b, a)
This would exactly do what i need.
But how could i do this in jscript?
Edit:
@ExtremeHunter
Thanks, i'll give it a try.
EDIT:
@ExtremeHunter
Thank you
This does what i need with an easier formula
But how could i rewrite this function to use the colours from my array and the background colour i set in my global script (both given as RGBA(r,g,b,a))?
I'd need it working like this:
var combinedColor = combineColors(RGBA(19, 30, 38), RGBA(191, 228, 255), 0.5);
Edit: typo...
tedgoI think this is what you need, but this script has lot of rgb conversions, maybe someone knows better way, like how to directly combine decimal colors without that RGB mambo jumbo.
return ( 0xff000000 | (r << 16) | (g << 8) | (b) );
var color1 = RGB(0,255,0);
var color2 = RGB(0,0,255);
function toRGB(d){ // convert back to RGB values
var d = d-0xff000000;
var r = d >> 16;
var g = d >> 8 & 0xFF;
var b = d & 0xFF;
return [r,g,b];
var c1 = toRGB(c1);
var c2 = toRGB(c2);
var r = Math.round(c1[0] + f * (c2[0] - c1[0]));
var g = Math.round(c1[1] + f * (c2[1] - c1[1]));
var b = Math.round(c1[2] + f * (c2[2] - c1[2]));
gr.FillSolidRect(20,20, 100, 100, color1);
gr.FillSolidRect(140,20, 100, 100, color2);
Wow, thank you man
Now it is exactly what i need.
i've updated my sample scripts. this applies to my
artreader,
cd jewel case and
now playing (all variants). until now i've always chosen to prefer embedded art first and fall back on the display preferences if nothing is found. i've never given people the choice before. but i've just been fumbling around in the foobar preferences and see it's now an option which the user can set.
file>preferences>advanced>display>album art
i don't know when that setting was implemented but my scripts now respect the choice made there.
use
Update script on the right click menu or the full download is here: https://dl.dropbox.com/u/22801321/samples.zip (https://dl.dropbox.com/u/22801321/samples.zip)
files changed:
marc2003\common6.js
@marc2003
Inspired by something you wrote in another thread I've just begun using your
Simple Text Reader, loading title reviews manually scraped from Rovi.
It's indeed a boring pursuit copying and pasting all day long from now and probably until kingdom come, but I've given up the hope that you or romor or someone else will ever write a script performing the task...
Problem is, that in my opinion the text is too small; the
normal_font is o.k. in lists and so on, but used in body text on a 1920x1080 monitor it's not an easy reading font size.
It's pure flagellation if I try to make changes in the huge
Common6.js – not to mention that it's frequently updated, and it's probably only necessary to have the choice of selecting larger font sizes in text heavy panels such as the
Simple Text Reader and e.g. your
Last.fm Biography mod script.
I found an old
common4.js in my archives and edited the latter to use
normal_font = 14
(instead of 12) and
row_height = 1.2 * normal_font.Height
(row_height being leading/line spacing), that helped my old eyes a lot.
It would however be much more elegant if you implemented some sort of font (size) handling in the context menus, if it's doable with the WSH Panel mod without to much hassle?
Your collection of scripts is highly valued and appreciated, I use 6-7 of them in my DUI layout!
a perfectly reasonable request. i'll probably get that done tonight sometime.
edit: just had a quick bash at it now. click (http://dl.dropbox.com/u/22801321/2013/march/text%20size.png)
i just need to test it doesn't break anything else before i put it online.
You're fantastic, marc2003, the preview looks promising!
^ok, done. just use Update script from the right click menu.
it will apply to last.fm bio mod, now playing with last.fm bio mod, simple text reader, and simple tag reader.
the scripts in the panels haven't changed - just using the update feature above updates the common file they all share.
... the update is exactly what I had in mind. Simple Text Reader and the last.fm bio mod look perfect.
I'll stick to '14' for now and maybe begin using '16' in a couple of years . The leading is fine too. (normally a factor 1.1 to 1.2 is used in type setting.)
marc2003, you earn 5 stars for service and support. And speed!
if you need it any of my "list" scripts like last.fm similar artists, charts, musicbrainz, discogs, etc then give me a shout and i can probably work it in.
marc2003your vinyl turntable script has decided to crash unexpectedly.
I started foobar2000 and selected a playlist, then played a track (whose folder contains a "disc.jpg") which has previously worked fine with your script . . . . not this time!
Here is the console output:
Opening track for playback: "F:\music\lib\rhythm\curtis mayfield\(1972) superfly\vinyl - buddah records, usa, original pressing\02. pusherman.flac"
Error: WSH Panel Mod ({40845811-E334-4CB0-B4C5-DE5B1B33E36F}): Microsoft JScript runtime error:
'images[...]' is null or not an object
File: <main>
Ln: 94, Col: 3
Here is line 94 (red) in my script:
function calc() {
if (!img) return;
for (i = 0; i < images.length; i++) {
try { images.Dispose(); } catch(e) {}
images = [];
for (i = 0; i < 36; i ++) {
images = gdi.CreateImage(nw, nh);
var temp_gr = images.GetGraphics();
temp_gr.SetInterpolationMode(6);
temp_gr.DrawImage(bg, 0, 0, nw, nh, 0, 0, bg.width, bg.height);
temp_gr.DrawImage(img, disc_x, disc_y, disc_size, disc_size, 0, 0, img.Width, img.Height, i * 10);
images.ReleaseGraphics(temp_gr);
temp_gr = null;
I right-clicked the crashed panel, went to the "WSH Panel Mod Configuration" window, clicked the "Apply" button . . . . . and the panel started working again!
Can you make sense of the reasons for the crash?
*EDIT*In the past, I remember having another WSH image viewing panel which decided to crash one day with the "null image" report at the console.
Here is the original lines in that script . . . which would occasionally crash:
if (Properties.Image.Sort == ImageSort.Shuffle)
NewItems = NewItems.sort(function(){return (Math.random() > 0.5) ? -1 : 1;});
return NewItems;
I fixed the problem by adding the line in red . . . the panel never crashed again after this edit:
CollectGarbage();
return NewItems;
not got a clue. if you can make it fail in a way that i can reproduce reliably then it's worth looking at but otherwise....
edit: you can try replacing the for loop with this. it might give me something useful in the console if it happens again..
try {
images[i] = gdi.CreateImage(nw, nh);
var temp_gr = images[i].GetGraphics();
images[i].ReleaseGraphics(temp_gr);
temp_gr = null;
} catch(e) {
fb.trace("image:" + i);
fb.trace("nw: " + nw);
fb.trace("nh: " + nh);
fb.trace(typeof images[i]);
fb.trace("width: " + images[i].Width);
fb.trace("height: " + images[i].Height);
incidentally, this is the bit of code that causes the UI lag on album change. the original script overlaid one image on top of another every 50ms and this caused the silly CPU usage. my idea was to create a slide show but to do that i need to create 36 "flattened" images of these 2 layers first. so i draw the background and then the disc art on top rotated a bit each time. once i've done that, and i have an array of 36 images to loop through, there is no CPU usage at all.
If I was to insert CollectGarbage(); inside the function calc() field, can you tell me after which line it would be added, thanks.
*EDIT*
Thanks for your edit
it has nothing to do with that at all.
Hey guys I am new to writing code in the wsh panel for foobar but am trying to learn, in the meantime I am using eXtremeHunter's code to display a rotating image of a vinyl:
var defaultDisc = gdi.Image(fb.FoobarPath + "images\\record2.png");
var angle = 0;
var minSize = 20;
var rotationInterval = 50;
var rotationTimer;
var rotationTimerStarted = false;
function on_paint(gr) {
gr.FillGradRect(0, 0, ww, wh, 65, RGB(0, 0, 0), RGB(0, 0, 0), 0.5);
on_size();
window.Repaint();
ww = window.Width;
wh = window.Height;
// if (discH < discW) discW = discH;
// else if (discW < discH) discH = discW;
if (useDiscMask) {
discMask.Dispose();
getDiscImage();
return;
if (!rotationTimerStarted) {
rotationTimer = window.SetInterval(function () {
if (angle >= 360) angle = 0;
angle += 10;
}, rotationInterval);
rotationTimerStarted = true;
function stopRotationTimer() {
window.ClearInterval(rotationTimer);
if (reason != 2) {
stopRotationTimer();
getDiscImage();
function on_playback_pause(state) {
onRotationTimer();
var tempAlbum;
var nowPlayingDisc;
if(!metadb) return;
on_size();
window.Repaint();
on_size();
window.Repaint();
The code works fine except I want to make one small tweak and I am unsure of how to implement it into the code. Essentially I want the image to to be resized AFTER it is rotated. I want the circular vinyl to be resized to an ellipse before every iteration of the rotation so that the vinyl appears as if it was being viewed from the side and above, with its axis of rotation being neither parallel nor perpendicular (as it is displayed currently) to the monitor. I realize it may be difficult to understand what I want and so I can better clarify if needed. Any help will be greatly appreciated.
^i have no idea how to implment that.
samples updated. right click>
Update script or the full download is here: https://dl.dropbox.com/u/22801321/samples.zip (https://dl.dropbox.com/u/22801321/samples.zip)
musicbrainz.
when in
links mode, unescape characters before displaying them to make it look nicer.
also added checking for
musicbrainz artist id. this is what picard writes to mp3s but i only checked for
musicbrainz_artistid previously because that is what foo_musicbrainz writes (and it's the standard for vorbis/apev2). it's not compulsory to tag files with this info because the script will search based on artist name - but it will use the first entry it matches which may be wrong if there is more than artist with the same name.
artreader / cd jewel case add
Google image search to the context menu. having a large panel has made me realise not all my art is up to scratch. i prefer to find stuff manually rather than use programs to do it so i've added this item which opens your browser looking for artist/album. also added
Refresh option for cd jewel case. artreader already had it. this just updates the panel if you've edited/replaced the image while a track is playing.
files changed:
marc2003\common6.js
I am hoping you can help me Marc. I am completely new to foobar2000 and am using a pretty advanced theme not compiled by myself so I am certainly in over my head.
For some reason unbeknown to me the 'last.fm Charts' does not initialise/crashes. It used to work a few days ago but I have no real idea what I have done to change things.
The error from console is as follows:
Error: WSH Panel Mod (Last.fm Charts v6.2012-12-05.01 by marc2003): Microsoft JScript runtime error:
Object doesn't support this property or method
File: <main>
Ln: 15, Col: 1
I downloaded your newest 'samples' folder linked above and tried replacing the common6 file but it made no difference.
I am not sure if this is even releant but this is the code I get when I select 'configure'.
// ==PREPROCESSOR==
// @import "%fb2k_profile_path%marc2003\common6.js"
// @name "Last.fm Charts"
// @author "marc2003"
// @version "6.2012-12-05.01"
var p = new panel("Last.fm Charts", ["lastfm_charts"]);
var l = new lastfm();
var li = new list(6, 30, p.w - 12, p.h - 30);
var b = new buttons();
b.buttons.but1 = new button(p.w - 56, 8, 50, 18, {normal: "lastfm_red_small.gif"}, function() { p.browser(l.url); }, l.url);
li.lastfm_charts_load();
function on_notify_data(name, data) {
l.notify_data(name, data);
p.size();
b.buttons.but1.x = p.w - 56;
li.w = p.w - 12;
li.h = p.h - 30;
li.size();
p.draw_background(gr);
p.header(gr, l.username + ": " + li.lastfm_charts_periods_display[li.lastfm_charts_period] + " " + li.lastfm_charts_types[li.lastfm_charts_type] + " charts");
b.draw(gr);
switch(true) {
case l.username.length == 0:
p.centre_text(gr, l.username_error, p.normal_font, p.textcolour, 0, 0, p.w, p.h);
break;
case li.items > 0:
li.draw(gr);
break;
default:
p.centre_text(gr, "[nothing found]", p.normal_font, p.textcolour, 0, 0, p.w, p.h);
break;
li.wheel(step);
p.move(x, y);
if (b.move(x, y)) return;
if (li.move(x, y)) return;
if (b.lbtn_up(x, y)) return;
if (li.lbtn_up(x, y)) return;
function on_mouse_rbtn_up(x, y) {
p.rbtn_up(x, y);
return true;
Any guidance would be truly appreciated. Please remember that I have no idea what I am doing. Cheers.
just update the charts script in the panel. an updated common6.js broke it back in january. obviously it kept working until now because you didn't update yours.
http://www.hydrogenaudio.org/forums/index....mp;#entry821841 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&st=2000&p=821841&hl=charts&#entry821841)
you can always check the latest panel versions here: https://dl.dropbox.com/u/22801321/wsh/versions.txt (https://dl.dropbox.com/u/22801321/wsh/versions.txt)
i try not to change panel scripts often but sometimes it is unavoidable. most of the constant work/updating goes on in the main common6.js file.
i've updated my
last.fm bio mod script. it has now been renamed to
last.fm & wikipedia biography. i think from the rename alone, you can tell what it does. i've just added a context menu item allowing you to switch between the two.
(https://dl.dropbox.com/u/22801321/2013/march/wikipedia.png)
some other minor changes too.
new / changed files:
marc2003\common6.js
samples\last.fm & wikipedia biography.txt
samples\now playing with track list.txt
samples\now playing with last.fm & wikipedia biography.txt
Thanks Marc updating the script fixed it for me. Now that I have the functionality to update the script from within foobar2000 I suspect I will have fairly smooth sailing from here!
^just incase it wasn't clear, using Update script can only update the common file and not what is in the panel. there is still potential for problems if i change things in the future but i hope not. the general rule of thumb is that if you have files from the same zip, you won't go far wrong.
i've updated my
thumbs script. it now has options to align thumbs along the top and to the right of the panel - in addition to left and bottom that it had previously.
also, you can now turn thumbs
off completely which makes my
simple image viewer script redundant. support for that has been dropped.
(http://dl.dropbox.com/u/22801321/2013/march/new%20thumbs.png)
use right click>
files changed:
marc2003\common6.js
samples\simple image viewer.txt <<removed
I have a problem with this script in my config:
// ==PREPROCESSOR==
// @name "DarkOne Display Panel"
// @version "4.0"
// @author "super-gau and tedGo, includes partial codes by fbuser, Br3tt and T.P Wang"
// @import "%fb2k_path%themes\DarkOne_v4.0\Others\WSH Scripts\DO 4.0 Global Script.js"
// ----- VARIABLES -----
var g_timer = v_timer = g_alpha = s_alpha = p_alpha = null;
var g_interval, fileinfo, g_trackinfo;
var v_change = false;
var t_rem = window.GetProperty("Remain Time on", false);
// ----- COLOURS -----
var d_arr = new Array("Default", "Blue", "Green", "Red", "White", "Yellow");
var c_arr = new Array(RGB(191, 228, 255), RGB(128, 192, 255), RGB(0, 255, 0), RGB(255, 0, 0), RGB(255, 255, 255), RGB(255, 255, 0));
function InitColours() {
d_col = window.GetProperty("Display Colour", 0);
g_dcol = d_arr[d_col];
g_acol = c_arr[d_col];
g_fact = g_acol == -65536 ? 0.09 : 0.03;
g_bcol = combColours(ui_backcol, g_acol, g_fact);
InitColours();
// ----- CREATE HELPERS -----
String.prototype.repeat = function(n) {
return (new Array(n + 1)).join(this);
function pad(x, y, z) {
z || (z = ' ');
return x.length < y ? x + z.repeat(y - x.length) : x;
z || (z = ' ');
function TimeFmt(t) {
var zpad = function(n) {
var str = n.toString();
return str.length < 2 ? "0" + str : str;
var h = Math.floor(t / 3600);
t -= h * 3600;
var m = Math.floor(t / 60);
t -= m * 60;
var s = Math.floor(t);
return zpad(h) + ":" + zpad(m) + ":" + zpad(s);
function drawSquares(gr, squareSize, paddingSize, x, y, w, h) {
var totalsq = Math.ceil(w / stepSize);
var totalrow = Math.ceil(h / stepSize);
for(var j = 0; j < totalrow; j++) {
for(var i = 0; i < totalsq; i++) {
gr.FillSolidRect(i * stepSize + x, j * stepSize + y, squareSize, squareSize, g_bcol);
// ----- CREATE INFO -----
Info.prototype.setColours = function() {
var metadb = fb.GetNowPlaying();
if (metadb) {
fileinfo = metadb.GetFileInfo();
this.Colours[0] = fileinfo.InfoValue(fileinfo.InfoFind("encoding")) == "lossless" ? g_acol : g_bcol;
this.Colours[1] = fileinfo.InfoValue(fileinfo.InfoFind("encoding")) == "lossless" ? g_bcol : g_acol;
this.Colours[2] = fileinfo.InfoValue(fileinfo.InfoFind("md5")) ? g_acol : g_bcol;
this.Colours[3] = fb.TitleFormat("[%replaygain_track_gain%]").Eval() ? g_acol : g_bcol;
this.Colours[4] = fileinfo.MetaValue(fileinfo.MetaFind("tracknumber"), 0) ? ui_btntxtcol : g_bcol;
this.Colours[5] = fileinfo.MetaValue(fileinfo.MetaFind("totaltracks"), 0) ? ui_btntxtcol : g_bcol;
this.Colours[6] = ui_btntxtcol;
} else for (var i = 0; i < this.Colours.length; i++) this.Colours[i] = g_bcol;
Info.prototype.setTrackNo = function() {
var a, b;
if (metadb) {
var c = fileinfo.MetaValue(fileinfo.MetaFind("tracknumber"), 0);
var d = fileinfo.MetaValue(fileinfo.MetaFind("totaltracks"), 0);
var e = c ? pad_right(c, 2, "0") : " ";
var f = d ? pad_right(d, 2, "0") : " ";
a = pad(e, 3);
b = pad(f, 3);
this.TrackNo = a;
this.TotalNo = b;
g_trackinfo = fb.PlaybackLength <= 0 ? 2 : metadb.RawPath.indexOf("FOO_LASTFM") == 0 ? 1 : 0;
} else {
this.TrackNo = "";
this.TotalNo = "";
Info.prototype.setPBTime = function() {
this.Elapse = TimeFmt(fb.PlaybackTime);
this.Remain = fb.PlaybackLength <= 0 ? "" : TimeFmt(fb.PlaybackLength - fb.PlaybackTime);
Info.prototype.setBitrate = function() {
this.Bitrate = pad_right(fb.TitleFormat("%bitrate%").Eval(), 4);
Info.prototype.setInfo = function() {
this.setColours();
this.setTrackNo();
this.setPBTime();
this.setBitrate();
function Info() {
this.Colours = new Array(7);
this.setInfo();
info = new Info();
// ----- BASE IMAGE OBJECT -----
function BaseImage() {
this.image = null;
this.curVal = "";
this.reset = function() {
this.curVal = "";
this.dispose = function() {
this.image && this.image.Dispose();
this.isDrawDigit = function(digitValue, index) {
return (this.curVal == null || this.curVal == "" || digitValue != this.curVal.charAt(index));
// ----- CREATE TRACKNUMBER IMAGE -----
function NumImage() {
this.image = gdi.CreateImage(54, 20);
this.init = function(curNo) {
this.drawDigit(curNo, 0);
this.drawDigit(curNo, 1);
this.drawDigit(curNo, 2);
this.curVal = curNo;
this.draw = function(curNo) {
this.init(curNo);
this.drawDigit = function(curNo, index) {
var digitValue = curNo.charAt(index);
if (this.isDrawDigit(digitValue, index)) {
var xoffset = index * 18;
g_signs && gr.DrawImage(g_signs, xoffset, 0, 18, 20, digitValue == " " ? 216 : digitValue * 18, d_col * 22, 18, 20);
NumImage.prototype = new BaseImage();
var g_trackNoImage = new NumImage();
var g_totalNoImage = new NumImage();
// ----- CREATE TIME IMAGE -----
g_signs && gr.DrawImage(g_signs, 36, 0, 6, 20, 234, d_col * 22, 6, 20);
g_signs && gr.DrawImage(g_signs, 78, 0, 6, 20, 234, d_col * 22, 6, 20);
this.curVal = time;
if (this.curVal == "") this.init(time);
else {
this.curVal = time;
g_signs && gr.DrawImage(g_signs, xoffset, 0, 18, 20, digitValue * 18, d_col * 22, 18, 20);
TimeImage.prototype = new BaseImage();
// ----- CREATE BITRATE IMAGE -----
function BitrateImage() {
this.image = gdi.CreateImage(72, 20);
this.init = function(bitrate) {
this.drawDigit(bitrate, 0);
this.drawDigit(bitrate, 1);
this.drawDigit(bitrate, 2);
this.drawDigit(bitrate, 3);
this.curVal = bitrate;
this.draw = function(bitrate) {
this.init(bitrate);
this.drawDigit = function(bitrate, index) {
var digitValue = bitrate.charAt(index);
BitrateImage.prototype = new BaseImage();
var g_bitrateImage = new BitrateImage();
// ----- CREATE VOLUME IMAGE -----
g_signs && gr.DrawImage(g_signs, 72, 0, 6, 20, 240, d_col * 22, 6, 20);
g_signs && gr.DrawImage(g_signs, 114, 0, 18, 20, 216, d_col * 22, 18, 20);
g_signs && gr.DrawImage(g_signs, 132, 0, 36, 20, 264, d_col * 22, 36, 20);
this.curVal = volume;
if (this.curVal == "") this.init(volume);
else {
g_signs && gr.DrawImage(g_signs, xoffset, 0, 18, 20, digitValue == " " ? 216 : digitValue == "-" ? 246 : digitValue * 18, d_col * 22, 18, 20);
VolumeImage.prototype = new BaseImage();
// ----- CREATE MENU -----
function CustomMenu(x, y) {
var a = window.CreatePopupMenu();
var idx;
for (var i = 0; i < d_arr.length; i++) {
a.AppendMenuItem(0, 1 + i, d_arr[i]);
a.CheckMenuRadioItem(1, 6, d_col + 1);
a.AppendMenuSeparator();
a.AppendMenuItem(0, 7, "Properties");
a.AppendMenuItem(0, 8, "Configure...");
idx = a.TrackPopupMenu(x, y);
switch (true) {
case (idx >= 1 && idx <= 6):
window.SetProperty("Display Colour", idx - 1);
InitColours();
info.setColours();
g_trackNoImage.reset();
g_totalNoImage.reset();
g_timeImage.reset();
g_bitrateImage.reset();
g_volumeImage.reset();
window.Repaint();
break;
case (idx == 7):
window.ShowProperties();
break;
case (idx == 8):
window.ShowConfigure();
break;
a.Dispose();
// ----- DRAW -----
!window.IsTransparent && gr.FillSolidRect(0, 0, ww, wh, ui_backcol);
drawSquares(gr, 2, 1, 0, 30, ww - 26, 20);
gr.DrawRect(1, 0, ww * 17 / 70, 10, 1, info.Colours[0]);
gr.DrawRect(ww * 71 / 280, 0, ww * 17 / 70, 10, 1, info.Colours[1]);
gr.DrawRect(ww * 141 / 280, 0, ww * 17 / 70, 10, 1, info.Colours[2]);
gr.DrawRect(ww * 211 / 280, 0, ww * 17 / 70, 10, 1, info.Colours[3]);
gr.GdiDrawText("LOSSLESS", btn_font, info.Colours[0], ww / 8 - 33, 0, 70, 10, 37);
gr.GdiDrawText("LOSSY", btn_font, info.Colours[1], ww / 8 * 3 - 34, 0, 70, 10, 37);
gr.GdiDrawText("AUDIO MD5", btn_font, info.Colours[2], ww / 8 * 5 - 34, 0, 70, 10, 37);
gr.GdiDrawText("REPLAYGAIN", btn_font, info.Colours[3], ww - ww / 8 - 33, 0, 70, 10, 37);
gr.GdiDrawText("TRACK", btn_font, info.Colours[4], 0, 18, 27, 10, 37);
gr.GdiDrawText("TOTAL", btn_font, info.Colours[5], 60, 18, 27, 10, 37);
gr.GdiDrawText("ELAPSED", btn_font, v_change || t_rem ? g_bcol : info.Colours[6], ww / 2 - 38, 18, 35, 10, 38);
gr.GdiDrawText("TIME", btn_font, v_change ? g_bcol : info.Colours[6], ww / 2 + 5, 18, 20, 10, 38);
gr.GdiDrawText("REMAINING", btn_font, v_change || !t_rem ? g_bcol : info.Colours[6], ww / 2 + 33, 18, 46, 10, 38);
gr.GdiDrawText("VOLUME", btn_font, v_change ? ui_btntxtcol : g_bcol, ww - 88, 18, 34, 10, 37);
gr.GdiDrawText("KBPS", btn_font, v_change ? g_bcol : info.Colours[6], ww - 46, 18, 20, 10, 37);
if (fb.IsPlaying) {
if (g_trackinfo == 0) {
g_trackNoImage.draw(info.TrackNo);
gr.DrawImage(g_trackNoImage.image, 0, 30, 54, 20, 0, 0, 54, 20);
g_totalNoImage.draw(info.TotalNo);
gr.DrawImage(g_totalNoImage.image, 60, 30, 54, 20, 0, 0, 54, 20);
} else {
var noTrack = g_trackinfo == 1 ? 534 : 420;
g_signs && gr.DrawImage(g_signs, 0, 30, 114, 20, noTrack, d_col * 22, 114, 20);
g_signs && gr.DrawImage(g_signs, ww / 2 - 63, 30, 18, 20, fb.IsPaused ? 197 : 179, d_col * 22, 18, 20);
if (v_change) {
gr.DrawImage(g_volumeImage.image, ww - 191, 30, 165, 20, 0, 0, 165, 20);
} else {
if (fb.IsPlaying) {
var t_play = t_rem && fb.PlaybackLength <= 0 ? false : true;
t_play && g_timeImage.draw(t_fmt);
t_play && gr.DrawImage(g_timeImage.image, ww / 2 - 38, 30, 120, 20, 0, 0, 120, 20);
!t_play && g_signs && gr.DrawImage(g_signs, ww / 2 - 38, 30, 120, 20, 300, d_col * 22, 120, 20);
g_bitrateImage.draw(info.Bitrate);
gr.DrawImage(g_bitrateImage.image, ww - 94, 30, 69, 20, 0, 0, 69, 20);
g_alpha = g_fact == 0.09 ? 20 : 7;
s_alpha = fb.StopAfterCurrent ? 255 : g_alpha;
g_signs && gr.DrawImage(g_signs, ww - 18, 21, 18, 12, 648, d_col * 22, 18, 12, 0, s_alpha);
p_alpha = fb.IsPlaying ? 255 : g_alpha;
g_signs && gr.DrawImage(g_signs, ww - 18, 38, 18, 12, 668 + fb.PlaybackOrder * 20, d_col * 22, 18, 12, 0, p_alpha);
!window.IsTransparent && gr.FillGradRect(0, -25, ww, 75, 90, RGBA(63, 100, 127, 128), 0);
// ----- MOUSE ACTIONS -----
CustomMenu(x, y);
return true;
// ----- EVENTS -----
ww = window.Width;
wh = window.Height;
function on_volume_change(val) {
if (v_timer) {
window.ClearTimeout(v_timer);
v_timer = null;
v_timer = window.SetTimeout(
function () {
window.RepaintRect(ww / 2 - 38, 18, ww - (ww / 2 - 12), 32);
v_timer = null;
v_change = false;
}, 3000);
v_change = true;
function on_playback_order_changed(new_order) {
window.RepaintRect(ww - 18, 38, 18, 12);
function on_playback_time(time) {
info.setPBTime();
window.RepaintRect(ww / 2 - 38, 30, 120, 20);
function on_playback_dynamic_info() {
info.setBitrate()
window.RepaintRect(ww - 94, 30, 69, 20);
function on_playback_edited() {
info.setInfo();
window.Repaint();
function on_playback_new_track(metadb) {
info.setInfo();
window.Repaint();
window.RepaintRect(ww / 2 - 62, 30, 18, 20);
if (fileinfo) fileinfo.Dispose();
if (reason != 2) {
info.setInfo();
fb.RunMainMenuCommand("ELPlaylist/Redraw");
window.Repaint();
function on_playlist_stop_after_current_changed(state) {
window.RepaintRect(ww - 18, 21, 18, 12);
function on_notify_data(name, info) {
if (name == "remTime") {
window.SetProperty("Remain Time on", info == true ? true : false);
t_rem = window.GetProperty("Remain Time on");
window.RepaintRect(ww / 2 - 38, 18, 120, 38);
function on_script_unload() {
g_trackNoImage && g_trackNoImage.dispose();
g_totalNoImage && g_totalNoImage.dispose();
g_timeImage && g_timeImage.dispose();
g_bitrateImage && g_bitrateImage.dispose();
g_volumeImage && g_volumeImage.dispose();
g_signs && g_signs.Dispose();
The global script that is loaded looks like this:
// DarkOne v4.0 Global Script
// Code by tedGo, using partial code by eXtremeHunter1972
var configPath = fb.FoobarPath + "themes\\DarkOne_v4.0\\";
var imgPath = configPath + "Images\\";
var g_signs = gdi.Image(imgPath + "Signs.png");
var btn_font = gdi.Font("Arial Black", 7, 0);
var ui_type = window.InstanceType;
var ww = 0; wh = 0;
// ----- CREATE RGB(A) -----
function RGBA(r, g, b, a) {
return ((a << 24) | (r << 16) | (g << 8) | (b));
// ----- CREATE CUSTOM COLOURS -----
function CustomColour(colour){
tempc = colour.split("-");
return ((tempc[3] << 24) | (tempc[0]<<16) | (tempc[1]<<8) | (tempc[2]));
function setAlpha(color, a) {
return ((color & 0x00ffffff) | (a << 24));
function toRGB(d){
var d, r, g, b;
d = d - 0xff000000; r = d >> 16; g = d >> 8 & 0xFF; b = d & 0xFF;
return [r,g,b];
function combColours(c1, c2, f){
var c1, c2;
c1 = toRGB(c1); c2 = toRGB(c2);
var r, g, b;
r = Math.round(c1[0] + f * (c2[0] - c1[0])); g = Math.round(c1[1] + f * (c2[1] - c1[1])); b = Math.round(c1[2] + f * (c2[2] - c1[2]));
// ----- GET UI COLOURS -----
function get_colors() {
ui_backcol = ui_type == 0 ? window.GetColorCUI(3) : window.GetColorDUI(1);
ui_textcol = ui_type == 0 ? window.GetColorCUI(0) : window.GetColorDUI(0);
ui_btntxtcol = ui_type == 0 ? window.GetColorCUI(2) : window.GetColorDUI(0);
get_colors();
function on_colors_changed() {
get_colors();
window.Repaint();
Some users of my config have random crashes of the panel - but with FLAC files only! - with this error message:
Error: WSH Panel Mod (DarkOne Display Panel v4.0 by super-gau and tedGo, includes partial codes by fbuser, Br3tt and T.P Wang): Microsoft JScript runtime error:
Overflow
File: <main>
Ln: 176, Col: 4
And i don't know why...
The line that causes the crash is:
(All variables are defined before)
Could anybody take a look at and point me to the right direction?
If someone wants to try the script, this is the Signs.png file: http://www.abload.de/image.php?img=signs1gujt.png (http://www.abload.de/image.php?img=signs1gujt.png)
As I said on deviantArt: The problem occurs when a track number contains a period (i.e. "21.").
Yes, and not only on flac files (was an accident that it only happens with flac files until now).
I now know whats the reason - i haven't respected that users may tag tracknumber with letters/signs besides numbers.
I have a workaround that should work (will update the download, too):
Go to the Script and change line 93 from:
to:
var c = fb.TitleFormat("$if2($num(%tracknumber%,0),)").Eval();
Then it should work without crashes
Confirmed. Fix works.
marc2003
Thanks for the hard work.
btw, could you make more options in displaying artist picture in your thumbs script, like keep aspect raito(centre), stretch, not only crop ?
@Marc
I tried your scripts (thumbs, np last fm+wikipedia) on a machine that I stream to using foo_upnp as a renderer.
While the scripts are working well on the machine that i stream from (upnp server + controler), on the renderer i do not see any artist images (only the text and the album art appear in n.p. script and nothing appears in thumbs).
Note:
- I can see that folders inside the wsh_lastfm directory are created on the target machine, with the "artist get info" and "echonext" json files but no images.
- If I use the standard lastfm bio plugin (foo_uie_biography), it shows images.
Do you have any idea? Thanks.
@kjllmeplz, i'll have a look into it.
@NEMO7538, as the script is obviously getting artist metadata ok for the other parts of the script to work, perhaps it's the art.exe program that i bundle that's not working? can you browse the marc2003 folder and run it from a command prompt? it will tell you the parameters it needs and you can try something manually.
@NEMO7538, i completely forgot to mention checking the
automatic download options on the context menu first. by default, it only automatically downloads images for tracks that are monitored as part of your library (and have no images existing already). you can change this to
all tracks.
the manual trigger should always work regardless of this setting.
@kjllmeplz, done. https://dl.dropbox.com/u/22801321/samples.zip (https://dl.dropbox.com/u/22801321/samples.zip)
thumbs and all now playing scripts have these options. the scripts in the panels need updating though.
files changed:
marc2003\common6.js
samples\now playing.txt
samples\thumbs.txt
Thanks .... I'll have a look but unfortunately the context menu doe not work (on both machines). When I right click I only get "Properties" and "Configure" ....
the context menu not working is a new one for me. i cannot fathom how that could even be possible. it's not even part of the script that goes in the panel. it's all handled by my common file (the imported script in the preprocessor section).
accessing the properties dialog bypasses most of the context menu options - if you know what to set. setting image_auto_download to all would at least get automatic downloads going.
marc2003
thank you so much! you are the best
samples updated: use right click>Update script or the full download is here. https://dl.dropbox.com/u/22801321/samples.zip (https://dl.dropbox.com/u/22801321/samples.zip)
thumbs: bugfix. right aligned thumbs would not always scroll properly.
and a reminder to anyone using thumbs or any now playing scripts and are finding the new crop/centre/stretch options have no effect. this means you need to download the latest zip and re-import the script.
ooh another update. this time i've added more options to allow you to filter and display release type on my
musicbrainz script.
files changed:
marc2003\common6.js
right click>
Update script should work for most people but the full download link is in the post above.
awesome, two thumbs up!
oh yay, another update.
this applies to all scripts that use artist metadata to perform lookups online. bugfix: do not try to search with blank/missing tags.
just right click any one>Update script.
Nevermind ... I got the latest version of foo_uie_wsh_panel_mod and it works.
Now what about if I want to directly access the properties and manually change some parameters (e.g. set the download limit to 6 images) ?
have you not seen the Limit option on the context menu? from there you can set 1,3,5,10 or 20.
you can of course edit the properties if you really must have 6. image_limit is the one you want.
Yes I have seen it but how do I access the properties?
Edit: Using the Layout Editing mode ...
hold shift when you right click.
i hide it for most people because all settings are usually set via the context menu. the one exception being the tweaking of numerical values such as the limit.
Thanks Marc for your hard work .... Some comments below:
- Sometimes it seems that artist pictures do not show up immediately, I have to manually "Re-scan folder" to have them appear. I guess it takes some time when requesting several images at once (or one after the other ?)
- What happens if I have several panels within tabs (eg. Now Playing + thumbs), will the source be queried several times or is there some sort of optimization
you shouldn't have to re-scan the folder. it does refresh automatically when downloading is complete. it can take awhile depending on how last.fm is behaving. sometimes it's pretty much instant, other times it can take 5 seconds+.
and there was no optimisation. in your case, it would lookup twice as those panels are independent of each other. however, i've just added in panel notifications. if you Update script, restart when prompted and then turn off automatic download in all panels but one, the "downloading" one should now notify others when downloading is complete.
a few more bugfixes:
simple text reader / simple tag reader: fix crash if tag/filename input dialog is left blank.
simple text reader: fix font size not working on fixed width font.
last.fm similar artists: spotify buttons did not work properly if it was set to pause foobar before launching. i think this was reported before and i thought i'd fixed it but i just stumbled across it again realising i hadn't fixed it at all.
for those, a simple right click>Update script will do.
Oh sweet I found the properties dialog using shift, now I can set the thumb size to fit my layout perfectly, awesome stuff.
marc2003your vinyl turntable script has eventually decided to crash again (using your tracing code modification at Post #2160 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=828073)).
Opening track for playback: "F:\music\lib\rock\iggy pop and the stooges\(1973) raw power\vinyl - columbia kc 32111, usa\02. gimme danger.flac"
image:0
nw: 0
nh: 0
object
Object required
File: <main>
Ln: 170, Col: 9
Here is line 170 (red) in my script:
function calc() {
if (!img) return;
images = [];
try {
temp_gr = null;
} catch(e) {
fb.trace(typeof images);
fb.trace("width: " + images.Width);
fb.trace("height: " + images.Height);
I went to the containing folder of the track and there is no "disc.jpg", therefore (if no error) default disc should have been used.
I right-clicked the crashed panel, went to the "WSH Panel Mod Configuration" window, clicked the "Apply" button . . . . . and the panel started working again.
hasn't the novelty worn off yet?
try this updated version... https://dl.dropbox.com/u/22801321/2013/march/turntable.txt (https://dl.dropbox.com/u/22801321/2013/march/turntable.txt)
marc2003
That is an EXCELLENT update of your turntable script!
-It works slightly faster than the previous script!
-Freezing is no longer perceptible if choosing another track from the same containing folder!
-Console reports nothing irregular!
Brilliant work mate ++++++++++++
> hasn't the novelty worn off yet? ...
I think these guys need your advice more than I do: "The Prisoner Appreciation Society" (http://www.netreach.net/~sixofone/)
Who/What is TPAS?
They are fanatical fans of the 1967 British TV series "The Prisoner" (http://en.wikipedia.org/wiki/The_Prisoner) . . . . Only one season and 17 episodes were ever made,
yet these fans meet up once a year at the same location where the series was made and re-enact scenes from the show,
and they have not stopped doing this since 1967 !!!!
i think you're experiencing good old placebo. the changes were very minor.
if playback is running when the panel is loaded, i've actually increased the delay from 200ms to 300ms so it's slower to load the first image. the difference is negligible but it ain't faster. and there is no change in the code when switching albums. the freeze is still very noticeable.
i'm not sure what you mean. it still uses %album% as the title formatting to trigger a change. there was never any freezing when switching tracks with the same %album% tag. but as mentioned above, the freeze is most definitely still there when albums change.
well to be fair the old one only crashed for you twice (well that's what you've reported anyway). it could happen to this one still.
the thing that proved useful from the debugging message you posted was the values of nw and nh which were 0. these should get set on startup and will change if you resize the panel. i've put in some checking to make sure it does not attempt to create any images if those values are 0. i'm hoping it won't crash but as it's not been possible to reliably reproduce it, there's no way i can test for sure.
i've updated my
now playing script. you can now toggle various elements on or off via the context menu. because displaying an artist bio is now optional, i've ditched the separate script i had for that.
here are 2 instances running side by side: screenshot (https://dl.dropbox.com/u/22801321/2013/march/now%20playing%20new.jpg)
files changed:
marc2003\common6.js
samples\now playing with last.fm & wikipedia biography <<deleted
i stupidly bodged the now playing.txt file in my previous update. the fixed version is in the zip from the post above.
(one of the settings wasn't loaded properly on startup. not serious but could be puzzling/annoying )
i've updated my now playing script. you can now toggle various elements on or off via the context menu. because displaying an artist bio is now optional, i've ditched the separate script i had for that.
files changed:
marc2003\common6.js
Great scripts, really appreciate your work on these. Could you make the track info and rating elements separate? I'd like to display the track info but I don't use the rating stars and would like to remove these. I do it manually by editing the script already, but it would be easier if it was selectable in the menu. Many thanks.
the trouble with making the rating separate, is where to put it if people turn the track info off. i'll try and think of something.
Thanks Marc, I think the ratings location won't be a problem, it would look fine where it is without the track info. If someone has got to the point where they are using your scripts, they would know what all of the separate elements do, I'm sure.
Thanks again.
it looks ok with CD cover off but not when it's on. it looks stupid sat next to it on it's own.
anyway, rather than make it independent, the script now checks for foo_playcount. if it's missing, the rating will not display.
files changed:
marc2003\common6.js
to make it easier for people to edit the track info display, i've put this at the top of the script.
var line1 = {text: "", tf: "%artist%", font: gdi.Font("Segoe UI", 30, 1), colour: RGB(240, 240, 240), y: 0}
var line2 = {text: "", tf: "%title%", font: gdi.Font("Segoe UI", 22, 1), colour: RGB(210, 210, 210), y: 0}
var line3 = {text: "", tf: "[[%album%] '('%date%')']", font: gdi.Font("Segoe UI", 18, 1), colour: RGB(180, 180, 180), y: 0}
leave the text empty. customise title formatting how you like. changing the font is easy too. it's simply font/size/style. the style set to 1 indicates bold text. other values:
Regular: 0,
Bold: 1,
Italic: 2,
BoldItalic: 3,
Underline: 4,
Strikeout: 8
colour is straight forward again and you can tweak the value of y. this is used to shift the vertical position from it's default. you might need to do this if changing font sizes.
Hi thanks again. This work around wouldn't actually work for me as I do have foo_playcount installed so that I can record a files %added% data, but not for rating the tracks. So, for me, the rating stars will still appear even though I won't be using foo_playcount for that function. Any other way you can think to remove the stars where you'll be happy with the layout?
Really appreciate this, thanks.
edit line 36:
var np_rating_check = utils.CheckComponent("foo_playcount", true);
to become
var np_rating_check = false;
edit line 36:
to become
Brilliant, that's perfect, many thanks!
Hello Marc - I really love your scripts.
I would love to edit the width of the biography txt column. Something like this:
(http://i47.tinypic.com/2co4kfo.jpg)
Thanx in advance
Natasha
line 74 is
t.x = p.w - Math.round(p.w / 3);
that represents 1/3 of the panel width. you could try changing it to 4 for a quarter. or you can fix the size in pixels....
t.x = p.w - 200;
Marc, - line 74
Beautiful!
4 is fine, and 5 is nice for fullscreen (1920x1080)
Thank you Marc2003!
Thanks Marc for your nice work
I have tweaked () the NP script, see below (quick and dirty: larger albumart size + placed on top with track info + merged thumbs + large track info fonts)
// ==PREPROCESSOR==
// @name "Now Playing"
// @version "6.2013-03-27.01"
// @feature "v1.4"
// @feature "watch-metadb"
// ==/PREPROCESSOR==
var th = new thumbs();
//first argument is any arbitrary text to name the panel. it will use in the console and popup boxes.
//seconds argument is an array of features. i'll post a full list of acceptable/required values at some point. it's mostly for handling right click menus.
var p = new panel("Now Playing", ["remap", "cd", "images", "metadb", "thumbs"]);
//force the panel to always prefer the playing track regardless of selection
p.selection_mode = 1;
//setup a new cd cover: x, y co-ords and width & height
//var c = new cd(10, p.h - 190, 200, 200);
var c = new cd(0, -20, 360, 360);
//setup rating, x, y co-ords and button size
//var r = new rating(220, p.h - 35, 24);
//note that because some co-ords are relative to panel size (p.w is width, p.h is height), we need to update these values in the on_size function later
//setup images, x, y, width, height,
var im = new images(0, 0, p.w, p.h);
//setup buttons
b.buttons = {}
b.update = function() {
//only add web link buttons if we have a valid selection
if (p.metadb) {
var artist = encodeURIComponent(p.eval("%artist%"));
var title = encodeURIComponent(p.eval("%title%"));
var myspace = "http://www.myspace.com/search/music?q=" + artist;
var lastfm = "http://www.last.fm/music/" + artist + "/_/" + title;
var youtube = "http://www.youtube.com/results?search_query=" + artist + "+" + title;
var discogs = "http://www.discogs.com/search?q=" + artist;
var allmusic = "http://www.allmusic.com/search/artists/" + artist;
b.buttons = {
but5: new button(p.w - 163, 0, 32, 32, {normal: "myspace.png", hover: "myspace_h.png"}, function() { p.browser(myspace); }, myspace),
but6: new button(p.w - 131, 0, 32, 32, {normal: "lastfm.png", hover: "lastfm_h.png"}, function() { p.browser(lastfm); }, lastfm),
but7: new button(p.w - 99, 0, 32, 32, {normal: "youtube.png", hover: "youtube_h.png"}, function() { p.browser(youtube); }, youtube),
but8: new button(p.w - 67, 0, 32, 32, {normal: "discogs.png", hover: "discogs_h.png"}, function() { p.browser(discogs); }, discogs),
but9: new button(p.w - 35, 0, 32, 32, {normal: "allmusic.png", hover: "allmusic_h.png"}, function() { p.browser(allmusic); }, allmusic)
window.RepaintRect(0, 0, 160, 32);
//setup 3 lines of text for the display. editing this should be self explanaotory. if you change the font sizes, adjustments may need
//to be made to the positions in the on_paint function
var line1 = {text: "", tf: "$if($strcmp($strstr(%artist%,','),0),%artist%,$cut(%artist%,$sub($strstr(%artist%,','),1)))", font: gdi.Font("Segoe UI", 48, 1), colour: RGB(250, 250, 250)}
var line2 = {text: "", tf: "%title%", font: gdi.Font("Segoe UI", 36, 1), colour: RGB(230, 230, 230)}
var line3 = {text: "", tf: "[[%album%] '('%date%')'] ['['# %tracknumber%']']", font: gdi.Font("Segoe UI", 28, 1), colour: RGB(190, 190, 190)}
//startup
//b.update();
//this function handles the cycling of images if enabled.
im.playback_time(time);
function on_size() {
//always call p.size to update the values of p.w and p.h
p.size();
//cd case y co-ord updated relative to bottom of panel
//c.y = p.h - 190;
//further updates to co-ords/sizes
//r.y = p.h - 35;
//im.w = p.w;
//im.h = p.h;
//b.update();
th.calc();
//my own helper functions. note some things need to layered on top of each other.
//first draw the background. you'll only see this if there are no images to display
//now we draw the background image as everything else goes on top
//im.images is an array of images. im.index is the current image. this value changes when scrolling the mouse or when cycling is enabled
//p.draw_image(gr, im.images[im.index], im.x, im.y, im.w, im.h, im.type);
if (im.images.length > 0) {
th.draw(gr);
if (th.mode == "grid") {
if (th.overlay) p.draw_image(gr, im.images[im.index], im.x, im.y, im.w, im.h, "centre");
} else {
} else {
p.centre_text(gr, p.metadb ? "[no image]" : "[no selection]", p.normal_font, p.textcolour, 0, 0, p.w, p.h);
//"crop" can also be "centre" or "stretch"
//this function also takes 2 additional arguments: border colour and alpha eg.
//a red border
//p.draw_image(gr, im.images[im.index], im.x, im.y, im.w, im.h, "crop", RGB(255, 0, 0));
//no border but alpha level of 128. values can be between 0 and 255
//p.draw_image(gr, im.images[im.index], im.x, im.y, im.w, im.h, "crop", null, 128);
//draw the slightly transparent rectangle at bottom
gr.FillSolidRect(0, 35, p.w, 145, RGBA(0, 0, 0, 156));
//draw the cd cover
c.draw(gr);
//web link buttons
//b.draw(gr);
//draw the rating panel
//r.draw(gr);
//draw the text. the last 4 values are x,y,w,h
p.left_text(gr, line1.text, line1.font, line1.colour, 365, 45, p.w - 365, 40);
p.left_text(gr, line2.text, line2.font, line2.colour, 365, 95, p.w - 365, 32);
p.left_text(gr, line3.text, line3.font, line3.colour, 365, 145, p.w - 365, 20);
//call these functions when selection changes/tag updates are made
//buttons. links are based off artist/track metadata
//b.update();
//cd
c.metadb_changed();
//rating
//r.metadb_changed();
//images
im.metadb_changed();
//only update text if we have a valid selection
if (p.metadb) {
line1.text = p.eval(line1.tf);
line2.text = p.eval(line2.tf);
line3.text = p.eval(line3.tf);
window.Repaint();
//we need to update buttons whenever their state could be changed. as these are playback buttons, we need to call
//updates when this happens.
function on_playback_stop() {
//b.update();
function on_playback_pause() {
//b.update();
function on_playback_starting() {
//b.update();
function on_get_album_art_done(metadb, art_id, im, ip) {
//used by cd cover for updates
c.get_album_art_done(im, ip);
function on_mouse_wheel(step) {
th.wheel(step);
//this scrolls through multiple images
im.wheel(step);
//we only need to call p.move if there elements in our panel which require scrollling as i need to track where the mouse is. do not return after it.
p.move(x, y);
th.move(x, y);
//if mouse detected over rating, no point in checking the rest
//if (r.move(x, y)) return;
//buttons -update tooltips
//if (b.move(x,y)) return;
//cd - tooltip
if (c.move(x, y)) return;
//note the order. because the buttons are on top of the cd, we need to check that first
//check for button clicks
//if (b.lbtn_up(x, y)) return;
//check for rating clicks
//if (r.lbtn_up(x, y)) return;
th.lbtn_up(x, y);
function on_mouse_lbtn_dblclk(x, y) {
//double click to open images
//cd
if (c.lbtn_dblclk(x, y)) return;
//image
if (im.lbtn_dblclk(x, y)) return;
//again we need to check order because the image covers the whole panel so we need to return if the cd was double clicked first
So here are a few suggestions :
- Option to put the album art + track info on top (/bottom)
- Option to right-justify the weblinks
- Option to left-justify the bio (above/below album art)
- Property to control the album art size (and adjust track info placement accordingly)
- Merge thumbs (as I did), very nice effect when thumbs are right justified
i like what you've done. i'll have a go at implementing those things.
now playing updated: https://dl.dropbox.com/u/22801321/samples.zip (https://dl.dropbox.com/u/22801321/samples.zip)
files changed:
marc2003\common6.js
changes:
new common file has broken compatibility with
now playing dated the 30th march people will have to update but older versions should still work because they don't have a context menus like these new ones.
implemented thumbs (off by default)
variable CD art size. just scroll your mouse wheel over it
top/bottom alignment for CD art/track info.
everything can be enabled/disabled from the context menu
a few example layouts here: screenshot (http://dl.dropbox.com/u/22801321/2013/april/now%20playing%2001.jpg)
obviously i didn't test all combinations like i should have. there is a bug with top aligned thumbs and bottom aligned cd/track info.
files changed:
Marc noticed a few bugs in your thumbs script. The cycle of 5 seconds works fine but 10 and 20 are not changing the picture. The crop code isn't working, it does nothing.
because the context menu is controlled by my common file, you must have updated that but not the script in the panel. i did mention it when i pushed that update a few days back....
i know i don't make it easy for people to keep a track of things.
and cycle works fine for me. due to the way it's coded, if it works for one value, it
has to work for others.
Sorry I'm always in a rush when I get time to go on here so overlooked/forgot it.
Actually I updated the script using update script in the context menu, I just pasted the new sample in from the samples zip and it's working now but I thought that's what the update script option does? So it's not actually updating I still need to paste in the updated sample zip?
like i said, it's really not your fault -rather it's mine. you can't really be expected to trawl the thread looking for every update. i'll have to try and manage updates better - i have a few ideas.
the vast majority of code is in the common file and updates work well for the most part. this problem occurred because your updated common file had all the code for handling the context menu in it. but the basic layout and positioning of the image happens in the panel. that's why it needed updating - it was hardcoded to crop images and it did not recognise the fact that there were new user settings it could use.
my goal when doing my last major update was not to update panel scripts but i have had to do it far more often than i'd like. i guess that's the price i pay for being an amateur bodger. i never plan anything in advance.
Lol well I don't mind keeping an eye on your samples, I guess I better bookmark the download link. Could you not put all the code into the common file that way updating the script will cover all of your new code changes? My apologies if that is a naive suggestion
Also it's a shame the code doesn't retain when importing .flc skins as I share my layout with friends and family who want to use your scripts too.
panel script settings do get properly saved as part of .fcl files. remember you'd have to share the entire marc2003 folder as well for it to work. (and the WSH panel mod component) back when i used to use columns UI, i shared a few themes with no problems at all.
you'll find most themes on deviant art have WSH panels as well.
putting all the code in external files is a nice idea but it doesn't really suit me at the moment. it's something i might think about looking at again. i dunno.
Marc .... I am tweaking the NP script and have this error sometimes ... when changing the rating
Error: WSH Panel Mod (Now Playing v6.2013-04-01.03 by marc2003): Erreur d'exécution Microsoft JScript:
Dépassement de capacité (Capacity overflow)
File: C:\Program Files (x86)\foobar 1.2\marc2003\common6.js
Ln: 1328, Col: 3
reproduced here when using the top style - using bottom, it's fine. i have to say i'm completely stumped. that line is refers to this inside my CD drawing function.
window.RepaintRect(this.x, this.y, this.w, this.h);
you could replace it with a simple
window.Repaint();
to make it work for now. i'll try and find the cause and a proper solution.
EDIT: i'm finding even more unrelated bugs inside the
now playing script now. it's been removed from my samples.zip to stop anyone else stumbling across it.
Thanks .... it works now, and here is my tweaked script below. I only changed the placement of the rating and the web links.
(Please note the common6b.js at the beginning).
// ==PREPROCESSOR==
// @import "%fb2k_profile_path%marc2003\common6b.js"
// @version "6.2013-04-01.03"
// @feature "v1.4"
var line1 = {text: "", tf: "$if($strcmp($strstr(%artist%,','),0),%artist%,$cut(%artist%,$sub($strstr(%artist%,','),1)))", font: gdi.Font("Segoe UI", 48, 1), colour: RGB(250, 250, 250), y: 0}
var line2 = {text: "", tf: "%title%", font: gdi.Font("Segoe UI", 36, 1), colour: RGB(230, 230, 230), y: 55}
var line3 = {text: "", tf: "[[%album%] '('%date%')']", font: gdi.Font("Segoe UI", 28, 1), colour: RGB(190, 190, 190), y: 100}
leave the text empty. customise tf (title formatting) how you like. changing the font is easy too. it's simply font/size/style.
0: Regular
1: Bold
2: Italic
3: BoldItalic
4: Underline
8: Strikeout
you might need to do this if changing font sizes. negative numbers shift up and postive goes down.
var p = new panel("Now Playing", ["custom_background", "now_playing", "lastfm_bio_mod", "remap"]);
var np_cd = window.GetProperty("np_cd", true);
var np_cd_size = window.GetProperty("np_cd_size", 200);
var np_track = window.GetProperty("np_track", true);
var np_track_top = window.GetProperty("np_track_top", false);
var np_buttons = window.GetProperty("np_buttons", true);
var np_bio = window.GetProperty("np_bio", true);
var np_rating = window.GetProperty("np_rating", true);
window.GetProperty("thumbs_mode", "off");
var c = new cd(0, 0, np_cd_size, np_cd_size);
var r = new rating(0, 0, 24);
var t = new text(0, 0, 0, 0);
var im = new images(0, 0, 0, 0);
var th = new thumbs(0, 0 , 0, 0)
var bar1y = 0;
var bar1h = 0;
var bar2y = 0;
var bar2h = 0;
b.buttons = {}
if (p.metadb) {
b.buttons = {
but5: new button(im.x + im.w - 160, bar2y - 1, 32, 32, {normal: "myspace.png", hover: "myspace_h.png"}, function() { p.browser(myspace); }, myspace),
but6: new button(im.x + im.w - 128, bar2y - 1, 32, 32, {normal: "lastfm.png", hover: "lastfm_h.png"}, function() { p.browser(lastfm); }, lastfm),
but7: new button(im.x + im.w - 96, bar2y - 1, 32, 32, {normal: "youtube.png", hover: "youtube_h.png"}, function() { p.browser(youtube); }, youtube),
but8: new button(im.x + im.w - 64, bar2y - 1, 32, 32, {normal: "discogs.png", hover: "discogs_h.png"}, function() { p.browser(discogs); }, discogs),
but9: new button(im.x + im.w - 32, bar2y - 1, 32, 32, {normal: "allmusic.png", hover: "allmusic_h.png"}, function() { p.browser(allmusic); }, allmusic)
but5: new button(im.x + p.w - 160, np_track_top ? -1 : im.y + im.h - 33, 32, 32, {normal: "myspace.png", hover: "myspace_h.png"}, function() { p.browser(myspace); }, myspace),
but6: new button(im.x + p.w - 128, np_track_top ? -1 : im.y + im.h - 33, 32, 32, {normal: "lastfm.png", hover: "lastfm_h.png"}, function() { p.browser(lastfm); }, lastfm),
but7: new button(im.x + p.w - 96, np_track_top ? -1 : im.y + im.h - 33, 32, 32, {normal: "youtube.png", hover: "youtube_h.png"}, function() { p.browser(youtube); }, youtube),
but8: new button(im.x + p.w - 64, np_track_top ? -1 : im.y + im.h - 33, 32, 32, {normal: "discogs.png", hover: "discogs_h.png"}, function() { p.browser(discogs); }, discogs),
but9: new button(im.x + p.w - 32, np_track_top ? -1 : im.y + im.h - 33, 32, 32, {normal: "allmusic.png", hover: "allmusic_h.png"}, function() { p.browser(allmusic); }, allmusic)
on_item_focus_change();
p.size();
th.calc();
c.x = im.x;
switch(true) {
case np_track_top:
c.y = im.y - (np_cd_size * 0.05);
//bar1y = 0;
//bar1h = np_track ? 100 : 0;
//bar2y = bar1h;
bar1y = 35;
bar1h = np_track ? 145 : 0;
bar2y = bar1h + bar1y;
//bar2h = np_buttons || np_rating ? 30 : 0;
bar2h = 0;
//t.y = bar1h + bar2h;
t.y = bar1y + bar1h + bar2h;
break;
default:
c.y = im.y + im.h - np_cd_size + (np_cd_size * 0.05);
//bar1y = im.y + (np_rating || np_buttons ? im.h - 130 : im.h - 100);
bar1y = im.y + im.h - 180;
bar2y = im.y + im.h - 30;
bar2h = 0;
t.y = im.y;
break;
//r.y = bar2y + 3;
r.y = bar1y + 10;
line1.ny = bar1y + line1.y;
line2.ny = bar1y + line2.y;
line3.ny = bar1y + line3.y;
t.x = im.x + im.w - Math.round(im.w / 3);
t.w = im.x + im.w - t.x - 15;
//t.h = im.h - bar1h - bar2h;
t.h = im.h - bar1h - 35 - bar2h;
t.size();
b.update();
th.draw(gr);
} else {
tix = im.x + (np_cd ? np_cd_size : 10);
//r.x = tix;
r.x = p.w - 130;
if (np_track) {
//gr.FillSolidRect(im.x, bar1y, im.w, bar1h, RGBA(0, 0, 0, 196));
gr.FillSolidRect(im.x, bar1y, p.w, bar1h, RGBA(0, 0, 0, 156))
//p.left_text(gr, line1.text, line1.font, line1.colour, tix, line1.ny, im.w - tix - 10, line1.font.Height);
//p.left_text(gr, line2.text, line2.font, line2.colour, tix, line2.ny, im.w - tix - 10, line2.font.Height);
//p.left_text(gr, line3.text, line3.font, line3.colour, tix, line3.ny, im.w - tix - 10, line3.font.Height);
p.left_text(gr, line1.text, line1.font, line1.colour, tix, line1.ny, np_rating ? p.w - tix - 140 : p.w - tix - 10, line1.font.Height);
p.left_text(gr, line2.text, line2.font, line2.colour, tix, line2.ny, p.w - tix - 10, line2.font.Height);
p.left_text(gr, line3.text, line3.font, line3.colour, tix, line3.ny, p.w - tix - 10, line3.font.Height);
if (np_rating || np_buttons) gr.FillSolidRect(im.x, bar2y, im.w, bar2h, RGBA(0, 0, 0, 136));
if (np_cd) c.draw(gr);
if (np_rating) r.draw(gr);
if (np_buttons) b.draw(gr);
if (np_bio) {
gr.FillSolidRect(t.x - 15, t.y, t.w + 30, t.h, RGBA(0, 0, 0, 156));
t.draw(gr, RGB(240, 240, 240));
b.update();
c.metadb_changed();
r.metadb_changed();
t.metadb_changed();
if (p.metadb) {
window.Repaint();
b.update();
b.update();
b.update();
if (np_cd && c.trace(p.mx, p.my)) {
np_cd_size += step * 25;
if (np_cd_size < 200) np_cd_size = 200;
if (np_cd_size > 400) np_cd_size = 400;
window.SetProperty("np_cd_size", np_cd_size);
c.y = Math.round(np_track_top ? im.y - (np_cd_size * 0.05) : im.y + im.h - np_cd_size + (np_cd_size * 0.05));
c.w = np_cd_size;
c.h = np_cd_size;
window.Repaint();
return;
if (th.wheel(step)) return;
if (np_bio && t.wheel(step)) return;
im.wheel(step);
p.move(x, y);
if (np_rating && r.move(x, y)) return;
if (np_buttons && b.move(x,y)) return;
if (th.move(x, y)) return;
if (np_bio && t.move(x, y)) return;
if (np_cd && c.move(x, y)) return;
if (np_rating && r.lbtn_up(x, y)) return;
if (np_buttons && b.lbtn_up(x, y)) return;
if (th.lbtn_up(x, y)) return;
if (np_bio && t.lbtn_up(x, y)) return;
if (np_cd && c.lbtn_dblclk(x, y)) return;
samples updated: https://dl.dropbox.com/u/22801321/samples.zip (https://dl.dropbox.com/u/22801321/samples.zip)
-major version bumpage meaning full
marc2003 folder has be extracted again and all scripts imported again to take advantage of it. all old scripts will continue to work as normal as this does not affect them.
-a changelog (https://dl.dropbox.com/u/22801321/wsh/changelog.txt) which i promise to update
02-04-2013
NEW: Can now check if scripts in panels are current after using "Update script". You will be prompted if they need updating.
NEW: Add "pattern" option to "Background" menu in some scripts such as "Now playing", "Thumbs" and "CD Jewel Case".
FIX: Lots of bugs squished in "Now playing".
CHG: Renamed lots of settings internally for consistency so you might find a few of them have been "forgotten". Just use the right click menu to set them again.
All important data such as cached images, online feed data, saved autoplaylist queries and last.fm username are untouched.
-using
Update script on previous versions now results in nothing happening. because i deleted the online copy, you will see a 404 error from dropbox in the console. i removed the file so you don't get the false impression it's up to date. that's what would happen if i left it there.
edit: and i'm off to a bad start already. found and fixed a few more bugs in
now playing since i posted. starting to hate this script now
Guys, can you please comment on the efficiency of using a shared *.js script and importing it everywhere instead of copy-pasting things (the ones which are needed, obviously).
I currently use these two panels:
http://pastebin.com/Nd81uR23 (http://pastebin.com/Nd81uR23) (used to display CUETools logs named either rip.txt, or rip (%discnumber%).txt for multi-disc albums)
http://pastebin.com/b9M83BxQ (http://pastebin.com/b9M83BxQ) (used to display album art)
And I'm wondering if there are ways I could improve them. Huge thanks to marc2003 for the basics + inspiration.
you could argue my scripts loading a shared file into memory for every panel is wasteful when most of the code won't be used. but in the grand scheme of things, it doesn't really matter. for me, it's made my life easier to manage them all as i have over 20 now.
only you can answer the question about improving yours. if they do what you need already then leave them be. i wouldn't lock panel sizes on scripts you share though. some people might find that undesirable.
@marc: i was toying around with your now playing script and stumbled upon background > splitter
i don't get the usage point of it...in DUI that is...is this something that's only supposed to be useful for panel stack splitter? if not, what's the point i'm missing?
the Background menu is shared between many scripts and the splitter option is mainly useful for button scripts like this....
(https://dl.dropbox.com/u/22801321/2013/april/splitter.png)
it's a system colour and it's meant to blend in with the standard look. it will change if you use a 3rd party windows theme.
ah, okay, i get it now
once more, thx for all your scripts!
samples updated: right click>Update script will only work for those people using the new full update from yesterday (2nd april)
full download: https://dl.dropbox.com/u/22801321/samples.zip (https://dl.dropbox.com/u/22801321/samples.zip)
changelog: https://dl.dropbox.com/u/22801321/wsh/changelog.txt (https://dl.dropbox.com/u/22801321/wsh/changelog.txt)
I've been using my own modded MNLT2 theme (all I did was change the colors, font and added a filter panel) for several months now, and now the WSH panel with the progress bar starts crashing everytime I start playing a song. I've tried starting from a fresh download of the skin and re-changed the colors/fonts and added the filter bar and it works fine for the duration my computer is on, but when I turn it on the next day and open up foobar, the progress bar just crashes again. I haven't actually started messing with WSH for myself, but does anyone have an idea of what could be causing this? Thanks in advance.
do you have any idea how useless your report is?
checking the foobar console and posting the offending errors/code would be a start.
marc2003I am still enjoying your
WSH Vinyl Turntable script; the novelty hasn't worn off . . . mainly because I am a die-hard vinyl freak. It's purring along nicely; It looks like you permanently solved the crashing issue.
If I was a CD freak, I wouldn't be asking you this question . . . however vinyl records are different; they contain more than one label.
If you have ripped a vinyl record, you have ripped two sides and each label is different. Therefore for every track using
disc.jpg, there should actually be a choice between
disc1.jpg or
disc2.jpg representing side1 and side2 of the record.
For all my vinyl rips, I was thinking of modifying the
%tracknumber% tag to have multiple values like these examples:
This is 1 vinyl record — it has 4 tracks , 2 are on side1 , 2 are on side2 — here is the %tracknumber% tags:01;1
02;1
03;2
04;2
[/size][/font]
This is 2 vinyl records (a 2-LP album) — it has 8 tracks , 2 are on side1 , 2 are on side2 , 2 are on side3 , 2 are on side4 — here is the %tracknumber% tags:01;1
02;1
03;2
04;2
05;3
06;3
07;4
08;4
[/size][/font]
As you can see, the second value in the tracknumber tag is a number representing a side of a record.
How can your script be modified to flag this tag value and choose the appropriate image from
disc1.jpg | disc2.jpg | disc3.jpg| ... | disc(n).jpgThanks.
you shouldn't need to modify the script. this should be set in the main foobar2000 artwork preferences dialog.
marc
I changed foobar200 artwork preferences for disc exactly as you specified.
I set up a test album . . . some tracks were tagged with %discnumber% value 1, some tracks were tagged with %discnumber% value 2.
Your WSH Turntable panel did not refresh to disc2 at any time . . . "play this, stop, play that" actions had no effect; it continued to play disc1 at all times.
Actually previous line is not totally true . . . If I play a track from another album and then go back to the test album and play a track, the panel will refresh.
oops, i forgot to mention you'll need to edit what triggers a change. change %album% on line56 to whatever you like. just adding %discnumber% should be sufficient.
you are referring to the item here in red I presume?:
if (!metadb) return;
var temp_album = fb.TitleFormat("%album%").EvalWithMetadb(metadb);
if (temp_album == album) return;
album = temp_album;
img = utils.GetAlbumArtV2(metadb, id);
if (img) {
mask();
calc();
window.Repaint();
Yeah, it worked . . . . thanks +++++++
you presume right. i'm not sure why you had to ask.
it's more educational for everyone viewing
marcit still has a small problem . . .
if i change to an album containing one
disc.jpg and no %discnumber% tag filled, then the default disc image will show (rather than
disc.jpg at track location).
*EDIT*I think I fixed it by changing this item (in red) in the script from this:
var temp_album = fb.TitleFormat("%discnumber%").EvalWithMetadb(metadb);
to this:
var temp_album = fb.TitleFormat("$if2(%discnumber%,%album%)").EvalWithMetadb(metadb);
you're getting it all mixed up. first of all, i said you should
add %discnumber% to the %album% string. with your code, it won't update when switching albums if the %discnumber% remains the same.
then the default disc image will show (rather than disc.jpg at track location)
this is dictated by what is set in the artwork preferences and what i already gave you should account for that.
now you've got me confused. . .
> i said you should add %discnumber% to the %album% string . . .
please show me the exact code line which is correct in your eyes, thanks.
this is what i said.
original code on line56:
add %discnumber%
var temp_album = fb.TitleFormat("%album%%discnumber%").EvalWithMetadb(metadb);
stop me if i'm going too fast...
penny has dropped . . . . thanks ++++++
i suppose i should have put discnumber in the original script but because all my multi-disc CD rips have the same art, i didn't think to do that. i've updated it now:
script: https://dl.dropbox.com/u/22801321/2013/march/turntable.txt (https://dl.dropbox.com/u/22801321/2013/march/turntable.txt)
turntable image: https://dl.dropbox.com/u/22801321/2013/march/turntable.jpg (https://dl.dropbox.com/u/22801321/2013/march/turntable.jpg)
[!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--]function on_playback_new_track() {
album = temp_album;
if (img) {
mask();
calc();
window.Repaint();
}[/size][/color]
just FYI, no need to grab the metadb of the playing item in this function, because you have it in input argument, so simply add it in args and remove the first line :
[!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--]function on_playback_new_track(metadb) {
album = temp_album;
if (img) {
mask();
calc();
window.Repaint();
}[/size][/color]
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]EDIT: typo[/size]
given the absolutely horrible performance of this script on album change, i don't think this change will make much difference. but thanks anyway.
does this do something? i haven't followed previous discussion about it but just pasted in a WSH panel Mod with image set in the right folder, nothing happens on new track playing ... ?asking to quickly, id set to 2 = cd image, i've none better with id = 0 for me...
Falstaff
marc2003 forgot to share one more image . . . default disc when no 'disc.jpg' exists for the album, giving the effect of an empty spinning turntable platter:
empty platter image (click to see/copy full size): (http://i.imgur.com/9MLgKxqs.jpg) (http://i.imgur.com/9MLgKxq.jpg)
new script:
small web linksdescription from the full changelog: https://dl.dropbox.com/u/22801321/wsh/changelog.txt (https://dl.dropbox.com/u/22801321/wsh/changelog.txt)
08.04.2013.01
NEW: "Small Web Links"
Unlike my old "Web Links" which generates 5 buttons
based on track metadata, this new script uses the same
backend as my "Musicbrainz" script to fetch real links.
Unlike my "Musicbrainz" script which displayed a list
of wesbites, this displays a more compact row of
buttons. The most common wesbites have familiar logos.
For ones that don't, you'll see a tooltip
when hovering your mouse. If already using the "Musicbrainz"
script in "links" mode, it should be removed (or kept in
"releases" mode). Lastly, it can take a second or two
for buttons to appear on artists that haven't been played
before due to background web requests that have to be made.
edit2: rewrote changelog.
Does someone know a way to display a simple dialog box, with two button yes/No, and use the result in a WSH script ?
(I'm adding a menu for quick tagging things like genre, date, but i want to avoid bad clics and get all my library re-tagged..)
you need to disable safe mode in the preferences for this to work.
put this code somewhere and don't edit it
var vb = new ActiveXObject("ScriptControl");
vb.Language = "VBScript";
function MsgBox(prompt, buttons, title) {
prompt = prompt.replace(/"/g, '" + Chr(34) + "');
prompt = prompt.replace(/\n/g, '" + Chr(13) + "');
title = title.replace(/"/g, '" + Chr(34) + "');
return vb.eval('MsgBox' + '("' + prompt + '", "' + buttons + '", "' + title + '")');
now you can use some custom code like this.
var result = MsgBox("Open preferences?", 4, "Question");
if (result == 6) fb.ShowPreferences();
note i passed 4 as the buttons argument. that's a simple Yes/no. i check to see if the result was 6 because that means Yes was clicked.
see all codes here- http://msdn.microsoft.com/en-us/library/sf...v=vs.84%29.aspx (http://msdn.microsoft.com/en-us/library/sfw6660x%28v=vs.84%29.aspx)
Is there any way to apply actions with a button for a bunch of files instead of only one selected or nowplaying?
Like File Operations/Delete files or tagging actions
For now i tried with fb.RunContextCommandWithMetadb(..., fb.GetFocusItem()) but it only applies to the first file of a selection...
fb.GetSelections()
Instead of fb.GetFocusItem()
Is it new? (i haven't engaged with wsh panel mod's new interfaces for a long time...)
EDIT: Thanks btw. ...
it's been around since 1.4.0 so quite awhile.
one other thing you might find useful is the flags..
// [1.4.0] Changed: Accept IFbMetadbHandleList interface for metadb handle list.
// [1.5.0 Preview 2] Changed: Add new "flags" parameter
// flags: 0 - default (depends on whether SHIFT key is pressed, flag_view_reduced or flag_view_full is selected)
// 4 - flag_view_reduced
// 8 - flag_view_full
boolean RunContextCommandWithMetadb(command, handle_or_handles, flags = 0);
if you set it to 8, it will even work on context commands that have been hidden by the user. i've found it very handy as people generally like to hide the foo_customdb/last.fm options used by my last.fm playcount script.
Oh, then i must have overread it all the time (or confused with GetSelection...)
EDIT (according to yours):
Wow, i should really read the interfaces.html carefully and play with all the new unknown stuff
dropbox are now using a new domain/URL re-direction which has broken my
update script feature. i've had to make changes which need to be downloaded manually.
snippet from changelog (https://dl.dropboxusercontent.com/u/22801321/wsh/changelog.txt):
10.04.2013.01
Due to recent changes made by dropbox, you may see
"HTTP error: 0" in your foobar2000 console when trying to run
"Update script". The only way around this is to download this
file manually and save it in the "marc2003" folder.
https://dl.dropboxusercontent.com/u/2280132...2003/common7.js (https://dl.dropboxusercontent.com/u/22801321/wsh/marc2003/common7.js)
this only affects people using the full zip posted on or after the 2nd april. previous versions don't update any more.
the full download is available here: https://dl.dropboxusercontent.com/u/22801321/samples.zip (https://dl.dropboxusercontent.com/u/22801321/samples.zip)
Thanks a lot, this code snippet which allow to use vbscript functions will be useful fore sure
And do you know a way to open the properties dialog ? (The one you see when you right-click selected items in a playlist)
my post just up the page shows the documentation for that.
http://www.hydrogenaudio.org/forums/index....st&p=830729 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=77883&view=findpost&p=830729)
in your case, the command would simply be "Properties".
Okey, thanks. Now, it seems pretty obvious, shame on me for missing it (maybe the documentation should include some basic descriptions of each functions utility)
(http://savepic.org/3294368m.jpg) (http://savepic.org/3294368.htm)
Help please.
i just tested my musicbrainz script with Iron Maiden set as the artist and it works for me so something must have have corrupted the download of the file??
you can force a fresh download by doing this.
-first of all close foobar
-browse your foobar2000 profile folder in explorer and into the wsh_lastfm folder.
-search for and delete all files named musicbrainz_URLs.json
-lastly open internet explorer and clear the temporary files. (even if you don't use the browser, it still caches data used by my scripts so it needs to be cleared.)
now start foobar and a fresh copy should be downloaded.
edit: completely unrelated to this but discogs seems to be having major server problems at the moment. if anybody finds my script not updating/working, you now know why.
I just did an update of the scripts and now they all crash.
Error: WSH Panel Mod (Art Reader by marc2003): Microsoft JScript runtime error:
'panel' is undefined
File: <main>
Ln: 9, Col: 1
Did I mess something up?
when i do major updates, files inside the marc2003 folder change so you just need to extract it again.
if you think you have extracted it, then you've put it in the wrong place. the readme will tell you.
Did you do another major update after the one on April 10? I manually extracted and replaced everything then and it was working fine until today.
EDIT: Never mind, I fixed it. Looks like the common7.js file somehow got screwed up when I ran the update scripts command. It was only 1 kb so obviously something was wrong. I just replaced it manually and it's ok now.
sorry about that. it looks like i need to do some more robust checking on file contents before over-writing existing files. i rely on the http server response code of 200 (which means "OK") from dropbox and assume it's safe to update if version numbers don't match. obviously it went a bit wrong when you did your update.
edit: i've now put some checking in. here's a direct link in case you don't trust Update script in the current version.
Hi Marc,
I'd like to say that your work with wsh/fb2k sure is appreciated by many and myself, and you are quite generous in helping others with questions.
I was wondering if you would you be so kind as to help me with a minor change to "nowplaying". I need the ratings stars to read/edit a custom metatag instead of the playback statistics db or standard "rating" metatag as it currently does. I found a post where someone asked the same, but it was many versions ago and didnt apply to your much updated lib and script.
Many thanks
i couldn't be bothered to implement it properly (such as giving people a choice between foo_playcount or file tags) so i just did a quick bodge job.
https://dl.dropboxusercontent.com/u/2280132...ating%20tag.txt (https://dl.dropboxusercontent.com/u/22801321/2013/april/now%20playing%20%2B%20rating%20tag.txt)
1000 thank you very muches
i don't really use my discogs script much but added it today and noticed it's returns anything containing the search term. i've changed it to filter out all the results that don't exactly match.
this is a before/after screenshot. https://dl.dropboxusercontent.com/u/2280132...ril/discogs.png (https://dl.dropboxusercontent.com/u/22801321/2013/april/discogs.png)
if this causes issues, i might make an option to toggle the behaviour on/off.
just right click>Update script.
if nothing happens check the foobar console. if it's http error code 0, you should see the changelog entry dated 10.04.2013
https://dl.dropboxusercontent.com/u/2280132...h/changelog.txt (https://dl.dropboxusercontent.com/u/22801321/wsh/changelog.txt)
if it's a 404 error, your package is out of date and you need extract the full zip and update the scripts in the panels.
new users should also download this zip and there are full instructions inside.
is it possible to have individual right-click context menus for different buttons in the same WSH panel?
i plan to make a simple playback panel with the usual play, pause, stop, prev, next.
> the Play button will have "Play random track" in it's right-context menu
> the Stop button will have "Stop after current"
> the Next button will have the 3 Shuffle playback orders
also i have been wondering if this can be achieved with a <keyboardKey + mouseClick> event so i can do a shift+mouseLeftClick
i am not much of a WSH coder so i'd like to know upfront if this is possible before i set out on a wild goose chase
yes that's definitely possible.
this is the callback for a left mouse click and you can check whether shift was held.
if (utils.IsKeyPressed(0x10)) {
//shift key was pressed. do something
} else {
//do something else
great!
thanks for the help marc, much appreciated.
Hi marc!
Your News / Reviews / Blogs wsh panel crashes when scrolling down (mouse wheel) on 'Reviews' view if the artist name contains an ampersand.
ex: Emerson, Lake & Palmer; Bog Seger & The Silver Bullet Band.
Error: WSH Panel Mod (News / Reviews / Blogs by marc2003): Microsoft JScript runtime error:
Invalid procedure call or argument
File: C:\My Applications\Placebo Monolithic\foobar2000\marc2003\common7.js
Ln: 1615, Col: 6
it's not the ampersands. i can't explain why but some of the article's text consists of a single space and that is causing the problem. anyway, fixed version uploaded. right click>Update script.
changelog - https://dl.dropboxusercontent.com/u/2280132...h/changelog.txt (https://dl.dropboxusercontent.com/u/22801321/wsh/changelog.txt)
full download - https://dl.dropboxusercontent.com/u/22801321/samples.zip (https://dl.dropboxusercontent.com/u/22801321/samples.zip)
That did the trick...thanks!
hey marc,
say my code for a button for the time being is:
//tipText = {normal: "Next", alternate: "Random"}
//func = function(){fb.next();}
//altFunc = function(){fb.random();}
function Button(x, y, w, h, defaultImage, hotImage, func, tipText, altFunc)
if(altFunc === null){
this.altFuncFlag = false;
else{
this.altFuncFlag = true;
this.altFunc = altFunc;
what i want to do is check if the altFunc parameter was passed within the button function.
so i start the if condition to do my business as:
if(is there an altFunc?){...}
but how should i go about it?
that looks rather complicated. for buttons without an alternate function, just assign the normal function to the variable.
that looks rather complicated...
true that but i am basically modding T.P. Wang & Tedgo's script for the moment.
So, i am kinda messing it up (progressively but i am happy with the results)
i did, however, achieve this (thanks to this link at stackoverflow (http://stackoverflow.com/questions/411352/how-best-to-determine-if-an-argument-is-not-sent-to-the-javascript-function))
now, i have it done this way:
//func_alt = function(){fb.random();}
function Button(x, y, w, h, img_src, func, tiptext, func_alt) {
this.func = func;
if(typeof func_alt === 'undefined'){
this.func_alt_flag = false;
else{
this.func_alt_flag = true;
this.func_alt = func_alt;
and for buttons without any alternate function, it doesn't matter cuz that's where the the flag comes handy (the only place it comes handy)
this is how i'd do it.
this.func = func;
this.func_alt = func_alt || func;
if func_alt is undefined, it will use the default function.
lol
that's even better
*sigh*
thanks
Hi!
I am using this script as a volume bar;
// vi:set ft=javascript ff=dos ts=4 sts=4 sw=4 et:
// ==PREPROCESSOR==
// @name "Volbar"
// @author "T.P Wang"
function RGB(r, g, b) {
return (0xff000000 | (r << 16) | (g << 8) | (b));
// gdi.Font is changed, the last paramter is style flags
// FontStyleRegular = 0,
// FontStyleBold = 1,
// FontStyleItalic = 2,
// FontStyleBoldItalic = 3,
// FontStyleUnderline = 4,
// FontStyleStrikeout = 8
// Here is 0, means FontStyleRegular
var g_font = gdi.Font("Tahoma", 12, 0);
var g_drag = 0;
function on_paint(gr) {
gr.SetTextRenderingHint(5);
var ww = window.Width;
var wh = window.Height;
var volume = fb.Volume;
var pos = window.Width * ((100 + volume) / 100);
var txt = (Math.ceil(volume)) + "dB";
gr.FillGradRect(0, 0, pos, wh, 90, RGB(240, 240, 240), RGB(100, 230, 100));
gr.FillGradRect(pos, 0, ww - pos, wh, 90, RGB(240, 240, 240), RGB(190, 190, 190));
gr.DrawString(txt, g_font, RGB(64, 64, 128), 0, 0, ww, wh, 0x11005000);
gr.DrawRect(0, 0, ww - 1, wh - 1, 1.0, RGB(150, 150, 150));
function on_mouse_lbtn_down(x, y) {
g_drag = 1;
on_mouse_move(x, y);
g_drag = 0;
if (g_drag) {
var v = x / window.Width;
v = (v < 0) ? 0 : (v < 1) ? v : 1;
v = -100 * (1 - v);
if (fb.Volume != v) fb.Volume = v;
function on_mouse_wheel(delta) {
if (delta > 0) fb.VolumeUp();
else fb.VolumeDown();
window.Repaint();
Is there any way of modifying this script to act as a seekbar?
curly... you want to modify this sample or simply want a seekbar?
cuz imho, to make this a seekbar is as good as modifying the entire script.
if you want a similar type seekbar then check this post:
http://www.hydrogenaudio.org/forums/index....st&p=628170 (http://www.hydrogenaudio.org/forums/index.php?showtopic=70363&view=findpost&p=628170)
...the one starting with "var DT_TOP = 0x00000000;"
Thanks for the help! Got it working.
} else {
//do something else
hey marc, i was reading Flags.html and was wondering whether i can skip "utils.IsKeyPressed(...)" and use the flag mask "MK_SHIFT" in, say, "on_mouse_lbtn_up(x, y, mask) {}".
but since i don't have much experience in WSH/jscript per say, i am unable to get this to work.
i am doing it so:
var MK_SHIFT = 0x0004;
function on_mouse_lbtn_up(x,y,MK_SHIFT){
fb.trace("something");
but it ignores the mask and works like a normal mouse callback function.
i can't figure out what i may be doing wrong.
function on_mouse_lbtn_up(x, y, mask){
if (mask == 4) {
} else {
//do something else
aah...
thanks
samples updated: https://dl.dropboxusercontent.com/u/22801321/samples.zip (https://dl.dropboxusercontent.com/u/22801321/samples.zip)
changelog: https://dl.dropboxusercontent.com/u/2280132...h/changelog.txt (https://dl.dropboxusercontent.com/u/22801321/wsh/changelog.txt)
added new "last.fm album info" script. just be aware
many albums have no content. however, clicking the
logo should open the last.fm website on
most album pages.
new script:
spectrogram seekbar(https://dl.dropboxusercontent.com/u/22801321/2013/april/spectrogram%20seekbar.png)
notes-
-it requires ffmpeg and SOX. download links are in the script.
-because it uses ffmpeg for decoding files, you're limited to the codecs it supports. what foobar input components you might have are irrelevant.
-images are generated automatically as songs are played. there can be a delay of a few seconds when playing something for the first time. foo_wave_seekbar users should be used to this.
-current settings create images around 80KB in size per track. these are stored in a folder inside your foobar2000 profile.
-tooltips indicate track position without having to drag
-does not support cuesheets
files changed / added:
marc2003\common7.js
samples\spectrogram seekbar.txt
changelog: https://dl.dropboxusercontent.com/u/2280132...h/changelog.txt (https://dl.dropboxusercontent.com/u/2280132...h/changelog.txt)
7.2013.04.25.02
"Spectrogram seekbar". Bugfix. Panel would show previous
spectrogram when switching to an unsupported format like
a stream.
files changed:
marc2003\common7.js
samples updated. same links as above. added a few options to my
spectrogram seekbar script.
(https://dl.dropboxusercontent.com/u/22801321/2013/april/clear%20seekbar.png)
other seekbars have been cleaned up slightly.
files changed:
marc2003\common7.js
samples\nyan cat seekbar.txt
samples\simple seekbar.txt
samples\themed seekbar.txt
Hi marc. Nice addition to your panels. Couple suggestions, feel free to ignore them
- Name is quite long as you use the full path. I'm not sure how much you can put in a filename in windows 7/8 but i'm surprised my system doesn't complain names are too long. This might cause some issues if the path is compicated. Maybe using some sort of crc32 or hash of the music file would be better. Not sure it's possible.
- Reading the panel size from and producing a spectro image fitting the panel would give a cleaner display.
- You can reduce the size of the png images in the cache ( to about 2/3 of their size in my tests) by using OptiPNG (http://optipng.sourceforge.net/). It's only a 97k command line portable tool (and open source like all tools you've used so far).
BTW, as i was posting this, i just had your "Now Playing" panel crash on me out of the blue
WSH Panel Mod (Now Playing by marc2003): initialized in 17 ms
Error: WSH Panel Mod (Now Playing by marc2003): Erreur d'exécution Microsoft JScript:
Objet requis
File: C:\Users\Roland\AppData\Roaming\foobar2000\marc2003\common7.js
Ln: 1393, Col: 4
Looks like it's pointing to this part of common7.js
function cd(x, y, w, h) {
this.draw = function(gr) {
if (this.shadow) p.draw_image(gr, this.shadow_img, this.x, this.y, this.w, this.h, "centre");
p.draw_image(gr, this.case_img, this.x, this.y, this.w, this.h, "centre");
if (this.img) {
→ this.ratio = Math.min(this.w / this.case_img.Width, this.h / this.case_img.Height);
this.nw = 488 * this.ratio;
this.nh = 476 * this.ratio;
this.nx = Math.round((this.w - (452 * this.ratio)) / 2);
this.ny = Math.round((this.h - this.nh) / 2);
p.draw_image(gr, this.img, this.nx + this.x, this.ny + this.y, this.nw, this.nh, "crop");
p.draw_image(gr, this.semi_img, this.x, this.y, this.w, this.h, "centre");
if (this.gloss) p.draw_image(gr, this.gloss_img, this.x, this.y, this.w, this.h, "centre");
This all occured at the same time i had my Router crash, as i've noticed when trying to post this i no longer had internet connection. Probably related to the LastFM biography.
EDIT : On the other hand, it might be totally unrelated. I have the panel crashed again right now, and still have Internet access.
i've just removed the spectrogram seekbar from the zip temporarily because it randomly crashes on track changes and i can't figure out why. it's been fine all afternoon but it's just started playing up now.
spectrogram seekbar has been restored. it should be ok now. just right click>update script to fix.
@r0k, that error would suggest it can't find the case images. but if you've been using it for sometime without issue then i have no idea what would cause it to go wrong all of a sudden.
OK. I re-extracted the zip and it's working again. For whatever reason this picture had gone missing. Don't know how it got removed ...
about your other points, i'll consider adding an option where you can specify SOX parameters yourself for image creation.
@marc2003 | Spectrogram Seekbar
Thank you very much for your latest brainchild . The time tooltip is one of those details that comes in very handy.
A minor problem (for me, that is) has however popped up: Either ffmpeg or Sound eXchange are having problems with at least some 'foreign' characters resulting in nil output to screen and disk.
No blurps from the Console with
fb.trace activated in the front end script:
Opening track for playback: "H:\Rhythmic\K\Aiko Kitahara\Piece Of Love\05 - サヨナラを告げた日が近すぎて.mp3"
cmd /c ""C:\Users\PG\AppData\Roaming\foobar2000\sox\ffmpeg.exe" -i "H:\Rhythmic\K\Aiko Kitahara\Piece Of Love\05 - サヨナラを告げた日が近すぎて.mp3" -f
sox - | "C:\Users\PG\AppData\Roaming\foobar2000\sox\sox.exe" -p -n channels 2 spectrogram -d 3:27 -Y 2000 -r -o
"C:\Users\PG\AppData\Roaming\foobar2000\spectrogram_cache\HRhythmicKAiko KitaharaPiece Of Love05 - サヨナラを告げた日が近すぎて.mp3.png""
Opening track for playback: "H:\Rhythmic\M\Magma\Üdü Wüdü\01 - Üdü Ẁüdü.flac"
cmd /c ""C:\Users\PG\AppData\Roaming\foobar2000\sox\ffmpeg.exe" -i "H:\Rhythmic\M\Magma\Üdü Wüdü\01 - Üdü Ẁüdü.flac" -f
sox - | "C:\Users\PG\AppData\Roaming\foobar2000\sox\sox.exe" -p -n channels 2 spectrogram -d 4:17 -Y 2000 -r -o
"C:\Users\PG\AppData\Roaming\foobar2000\spectrogram_cache\HRhythmicMMagmaÜdü Wüdü01 - Üdü Ẁüdü.flac.png""
Notice the 'Ẁ'.
I've changed
channels to
2 and the
Y parameter to
2000, but the innate values make of course no difference.
A shot in the dark: creating png file and writing to disk fails. Maybe another file naming schema would eliminate the problem? md5 or what do I know?
Btw, I'm trying to figure out how to change SoX' standard colours to something that's matching my layout. Not an easy task it seems.
^i now use the $crc32 title formatting function on the path. hopefully that will resolve it.
right click>
Update script should work for current users.
7.2013.04.26.01
"Spectrogram seekbar". The naming scheme for images has
been changed so you should clear all old files using the
right click menu. You can now set SOX parameters via a
dialog. See sox.pdf for all options. These
parameters also form part of the cached image filename
so changing them will update the display immediately.
(https://dl.dropboxusercontent.com/u/22801321/2013/april/sox%20dialog.png)
files changed:
marc2003\common7.js
i meant to edit my previous post and not post a new reply. delete me please.
Yes, problem solved!
Very nice with the enhanced right click possibilities and that parametric changes are reflected immediately. Thanks a lot.
marc2003I'm trying to tweak your "
WSH Vinyl Turntable" script a little more . . .
I want to add a right-click context menu item named "
View with external viewer" (i.e. opens with system default image viewer).
Could you give me a few quick code lines I can add to the script please.
_____________________________________________________________________________________________
QUICK TIP to anybody else using this panel . . .
I added a really cool enhancement to the interface:
Mouse Left Click Down on spinning disc pauses playback / Mouse Left Click Up continues playback
. . . giving the effect of putting your finger on the turntable platter, stopping it from spinning.
Add these lines to the script configuration:
fb.Pause();
fb.Play();
The code above replaces the original lines added by
marc2003 (these original lines by
marc2003 didn't do anything useful!! ...as far as I can tell):
if (trace(x, y)) fb.PlayOrPause();
ANOTHER INTERESTING EFFECT POSSIBILITY . . . Mouse-left-click-down-and-moving in the disc area changes playback tempo/speed, giving the effect of interactivity
. . . analogous to playing the record by spinning it with your finger
. . . no mouse movement = no sound | movement = sound | faster movement = sound+faster tempo | slower movement = sound+slower tempo
. . . if you could move (spin) the disc at default display speed then you would get exact playback speed !!!
What do you think
marc ?
I just dropped by to say that my WSH playlist is released here (http://browse.deviantart.com/art/CaTRoX-beta1-368146015) with my new theme.
If you find some bugs please let me know!
(these original lines by marc2003 didn't do anything useful!! ...as far as I can tell):
it was only code to make the start/stop button work on the image.
i should have documented that..... oh wait, i did. it's the first line of the notes at the top of the script.
i think it's more practical than sitting there holding down your mouse button to pause playback. but whatever works best for you....
@ExtremeHunter, nice. i'll definitely be checking that out later.
marc2003
throw it, kick it, shake it, smash it, I'm sure there are some bugs lurking in the dark corners.
> marc2003: "it was only code to make the start/stop button work on the image."
So, leaving your lines enabled AND including my lines is the right approach for my case, yes?
*EDIT*
disregard that question . . . the answer is obviously a choice: "mine or yours" .
But I must say, enabling/disabling your lines had no effect on whether the start/stop buttons work on the image ...unless I am misunderstanding your description of this.
Could you pass me a few lines to add for the context menu item please.
@ExtremeHunter, really liking the playlist. i could never, ever make something like that. i'm far too stupid.
only one bug found so far. when you click an item that isn't selected, moving your mouse up/down should select tracks above/below. but your script starts moving it straight away. other playlists only do that when the item you've clicked on is already selected.
my original script works. perhaps you didn't undo your modifications properly? fb.PlayOrPause() is self explanatory really.
if playback is stopped, it plays.
if playback is um... playing, it pauses.
if playback is paused, it plays.
the image stops/starts spinning accordingly.
and of course you can have the panel do different things on mouse clicks. it not a case of either/or. that would be stupid. you just have to track where the mouse is clicked which is what i do to detect it's over the button.
open image feature added here: https://dl.dropboxusercontent.com/u/2280132...h/turntable.txt (https://dl.dropboxusercontent.com/u/22801321/2013/march/turntable.txt)
turntable image: https://dl.dropboxusercontent.com/u/2280132...h/turntable.jpg (https://dl.dropboxusercontent.com/u/22801321/2013/march/turntable.jpg)
> marc2003: "..i could never, ever make something like that. i'm far too stupid.."
No fucking way in the world i can believe that marc. To me you are a JS guru (with different motivations to the other gurus).
Honest question: if your life depended on making something like that, what chance do you give yourself of making it?
> if playback is playing, it pauses.
Got it . . . I see what your code does. I think I'll stick to my edit, but I might add a descriptive note next to your (disabled) code in the script.
Thanks again for your help marc ++++++++
marc2003
Glad you like it
I don't consider that as a bug, it just that this feature is not available in my Playlist, maybe I should add it in the future.
He he and who is stupid here?
One day I looked your biography script and thought how hard can it be to make my self a nice bio panel,
but huh ... that web stuff is not for my poor brain.
ha, ok then.
i find the web stuff easy because you can always google for help.
i must admit my major flaw is that i give up too easily when i get stuck. i did start a playlist sometime ago but gave up after awhile. i just didn't have the patience.
EDIT: Wow, I figured it out by accident:
Renaming
on_timer to
on_timer1 fixed it!
ORIGINAL post:
I made a seekbar/progressbar based on Marc2003's but it seems to update in real-time, instead of every 1 second, which looks ugly. Other WSH scripts around seem to have the same issue.
Does anyone have a solution to this?
// ==PREPROCESSOR==
// @name "Simple Seekbar"
// @author "marc2003"
function RGBA(r, g, b, a) {
return ((a << 24) | (r << 16) | (g << 8) | (b));
var g_drag = 0;
var g_drag_seek = 0;
var g_timer = window.CreateTimerInterval(1000);
ww = window.Width;
wh = window.Height;
var x;
gr.DrawRect(4, 3, ww-7, wh-7, 1,RGB(72,66,58)); //BACKGROUND RECTANGLE
if (fb.IsPlaying && fb.PlaybackLength > 0) {
if (g_drag) //WHEN DRAGGING SEEKBAR
t = fb.PlaybackLength * g_drag_seek;
h = Math.floor(t / 3600);
m = Math.floor((t -= h * 3600) / 60);
s = Math.floor(t -= m * 60);
pos = ww * g_drag_seek;
//text = (h > 0 ? h + ":" + (m < 10 ? "0" + m : m) : m) + ":" + (s < 10 ? "0" + s : s);
// prevent slider from being obscured by borders
if (pos<5) {x=5;}
else if (ww-pos<5) {x=ww-5;}
else {x=pos;}
gr.FillGradRect(1, 1, pos-2, wh-2, 90, RGBA(112,106,98,255), RGBA(82,76,68,255)); //PROGRESS RECTANGLE
gr.FillGradRect(x-(wh/2), 1, wh-2, wh-2, 90, RGB(161,115,74), RGB(121,75,34)); //SLIDER
else { //NORMAL PASSIVE DISPLAY
pos = ww * (fb.PlaybackTime / fb.PlaybackLength);
if (pos<5) {x=5;}
else {x=pos;}
//GRAY SEEKBAR RGB(185,145,40), RGB(125,85,0)
function on_timer(g_timer) {
if (!fb.IsPlaying || fb.IsPaused) return;
window.Repaint();
function on_playback_seek(time) {
window.Repaint();
window.Repaint();
fb.PlaybackTime = fb.PlaybackTime + delta;
g_drag_seek = x < 0 ? 0 : x > ww ? 1 : x / ww;
if (y > wh) g_drag = 0;
if (g_drag) window.Repaint();
if (fb.IsPlaying && fb.PlaybackLength > 0) g_drag = 1;
if (!g_drag) return;
g_drag = 0;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
^that post is complete and utter gibberish.
my script updates every 150ms which makes the seekbar movement look smooth(-ish). you actually want it to update just once a second? that looks like crap to me.
secondly, you've already edited the timer to 1000ms (1 second) which is what you want so i have no idea why you posted in the first place
lastly, by renaming that function so it doesn't run, the seekbar won't ever update during playback. :/
also, that is based on a very old script using obsolete functions. you'll see this message in your foobar2000 console...
WSH Panel Mod: Warning: Obsolete: window.CreateTimerInterval() is now obsolete, please use window.SetInterval() in new script.
-I did use SetInterval() subsequently which didn't change anything.
-The function needs to be renamed everywhere it appears, of course.
-Real-time updating maybe appears ugly only on old PCs(mine has an AthlonXP)
// ==PREPROCESSOR==
var g_drag = 0;
var g_timer = window.SetInterval(on_timer1,1000);
ww = window.Width;
wh = window.Height;
var x;
gr.DrawRect(4, 5, ww-8, wh-10, 1,RGB(140,130,105)); //BACKGROUND RECTANGLE
if (pos<5) {x=5;}
else {x=pos;}
gr.FillGradRect(1, 8, pos-2, wh-8, 90, RGBA(95,94,94,255), RGBA(55,55,55,255)); //PROGRESS RECTANGLE
gr.FillGradRect(x-(wh/2), 1, wh-2, wh-2, 90, RGB(181,135,94), RGB(121,75,34)); //SLIDER
if (pos<5) {x=5;}
else {x=pos;}
//GRAY SEEKBAR
gr.FillGradRect(3, 3, pos-2, wh-6, 90, RGBA(95,94,94,255), RGBA(55,55,55,255)); //PROGRESS RECTANGLE
window.Repaint();
window.Repaint();
function on_timer1(g_timer) {
window.Repaint();
g_drag = 0;
now that you're using window.SetInterval, i see why you had to rename your function. it conflicts with the built in on_timer callback.
i still don't get why you posted originally. using the old timer functions with the interval of 1000ms would have done what you wanted.
anyway, so long as what you have is working now.
Lucky LucianoTry out this Seekbar config in a WSH panel and see what it does for you (edit it if you like) . . .
// Script for foobar2000 component "WSH Panel Mod"
// Description........: Horizontal seekbar with 1-second refresh intervals, time display, and mouse hover effects: tooltips and glowing panel edges
// Author.............: Maxim Terpilovsky (http://terpilovsky.ru)
// this edition modified by derty2
var DT_CENTER = 0x00000001;
var DT_VCENTER = 0x00000004;
var DT_SINGLELINE = 0x00000020;
var DT_CALCRECT = 0x00000400;
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); } //---orig---> function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
function RGBA(r,g,b,a){ return ((a<<24)|(r<<16)|(g<<8)|(b)); }
function TimeFmt(t) {
var zpad = function(n) {
var str = n.toString();
return (str.length<2) ? "0"+str : str;
var h = Math.floor(t/3600); t-=h*3600;
var m = Math.floor(t/60); t-=m*60;
var s = Math.floor(t);
if(h>0) return h.toString()+":"+zpad(m)+":"+zpad(s);
return m.toString()+":"+zpad(s);
// Here we are using 0, meaning FontStyleRegular
if ( utils.CheckFont( "Verdana" ) ) { //---orig---> if ( utils.CheckFont( "Segoe UI" ) ) {
var g_font = gdi.Font("Verdana", 11, 2); //---orig---> var g_font = gdi.Font("Segoe UI", 11);
} else {
var g_font = gdi.Font("Tahoma", 12);
var g_titlefmt = fb.TitleFormat("%playback_time% / %length%"); //--orig--> //var g_titlefmt = fb.TitleFormat("$if(%ispaused%,Paused '//' ,)[%artist% - %title% ]%playback_time% / %length%");
var g_fileinfo = null;
//---------------------------- COLOR SCHEMES FOR TIME ELAPSED BAR
//var g_colors = new Array(RGB(0,120,0), RGB(0,110,0), RGB(0,75,0), RGB(0,65,0));
//var g_colors = new Array(RGB(105,125,160), RGB(85,105,160), RGB(46,48,63), RGB(46,48,63));
//var g_colors = new Array(RGB(64,54,39), RGB(162,98,10), RGB(88,70,44), RGB(88,70,44));
//var g_colors = new Array(RGB(6,53,46), RGB(34,28,0), RGB(0,120,30), RGB(100,162,95));
//var g_colors = new Array(RGB(0,50,0), RGB(120,10,90), RGB(40,0,40), RGB(46,48,63));
var g_colors = new Array(RGB(0,0,0), RGB(0,0,0), RGB(0,0,0), RGB(46,48,63));
var g_drag = 0;
var g_hover_seek;
var g_hover;
var g_clicked = 0;
//------------------------------------------------------------------ function on_paint(gr) START
function on_paint(gr){
var spos = 0;
var length = fb.PlaybackLength;
var stxt;
gr.SetSmoothingMode(2);
if(length <= 0) { stxt = "0:00 / 0:00"; }
if(length > 0) {
if ( g_drag && g_drag_seek ) {
spos = window.Width * g_drag_seek;
stxt = "Seek " + TimeFmt(g_drag_seek * length) + " / " + TimeFmt(length);
else if ( g_drag ) {
spos = window.Width;
spos = window.Width * (fb.PlaybackTime / length);
stxt = g_titlefmt.Eval();
else if ( fb.PlaybackTime ) { stxt = "Streaming..."; }
gr.FillSolidRect(0, 80, ww-20, wh+20, RGB(0,0,0)); //---orig---> gr.FillSolidRect(0, 0, ww, wh, RGB(120,120,120));
gr.FillGradRect( 0, 0, spos, wh, 10, g_colors[2], g_colors[1], g_colors[1]); //---orig---> gr.FillGradRect( 0, 0, spos, wh, 90, g_colors[0], g_colors[2]);
//--- fills unused space with color:
// gr.FillGradRect( spos, 0, ww-spos, wh, 90, RGB(100,100,100), RGB(140,140,140)); <<<<<<<<<<<< original
// gr.FillGradRect( spos, 0, ww-spos, wh, 0, RGB(64,70,85), RGB(80,70,85)); <<<<<<<<<<<< previous = mid-grey
gr.FillGradRect( spos, 0, ww-spos, wh, -90, RGB(20,20,20), RGB(40,40,40));
gr.GdiDrawText(stxt, g_font, RGB(214,147,95), 0, 0, ww, wh, DT_CENTER | DT_VCENTER | DT_SINGLELINE); //--orig: gr.GdiDrawText(stxt, g_font, RGB(255,255,255), 0, 0, ww, wh, DT_CENTER | DT_VCENTER | DT_SINGLELINE);
gr.DrawRect( ww-1, 0, 0, wh, 1.0, RGB(0,0,0));
//--- draws thin border
// gr.DrawRect(-1,0, ww+1, wh-1, 1.0, RGB(150,150,150)); <<<<<<<<<<<< original
// gr.DrawRect(0, 0, ww-1, wh-1, 1.0, RGB(116,90,90)); <<<<<<<<<<<< my previous = orange-grey
// gr.DrawRect(0, 0, ww-1, wh-1, 1.0, RGB(64,77,85)); <<<<<<<<<<<< previous
gr.DrawRect(0, 0, ww-1, wh-1, 1.0, RGB(64,120,85)); //<<<<<<<<<<<< Green
if ( g_clicked ) {
gr.DrawRoundRect(0, 0, ww-1, wh-1, 1, 1, 1, RGBA(70,240,60,200)); //---orig---> gr.DrawRoundRect(0, 0, ww-1, wh-1, 4, 4, 1, RGBA(255,255,255,200));
else if ( g_hover ) {
//--- displays a thin border frame when mouse hovers over the panel:
// gr.DrawRoundRect(0, 0, ww-1, wh-1, 4, 4, 1, RGBA(255,255,255,100)); <<<<<<<<<<<<<<< Original
// gr.DrawRoundRect(0, 0, ww-1, wh-1, 1, 1, 1, RGBA(207,121,5,200)); <<<<<<<<<<<<<<< My previous choice = orange, thin
// gr.DrawRoundRect(0, 0, ww-1, wh-1, 1, 1, 1, RGBA(20,20,20,20)); <<<<<<<<<<<<<<< My previous choice = black-grey
gr.DrawRoundRect(0, 0, ww-1, wh-1, 1, 1, 1, RGBA(117,231,172,120));
if ( g_hover_seek ) {
var text_w = gr.CalcTextWidth(g_hover_seek, g_font) + 5;
if ( (g_hover + text_w) > ww) g_hover -= text_w + 4;
gr.FillSolidRect(g_hover - 2, 3, text_w + 2, wh-6, RGB(0,0,150));
gr.GdiDrawText(g_hover_seek, g_font, RGB(255,255,255), g_hover, 4, text_w, wh-8, DT_CENTER | DT_VCENTER | DT_SINGLELINE | DT_CALCRECT);
//------------------------------------------------------------------ function on_paint(gr) END
function on_mouse_lbtn_down(x,y){
g_drag = 1;
g_clicked = 1;
g_hover = 0;
on_mouse_move(x,y);
if( g_drag ) {
g_drag = 0;
g_drag_seek = x / window.Width;
g_drag_seek = (g_drag_seek<0) ? 0 : (g_drag_seek<1) ? g_drag_seek : 1;
g_clicked = 0;
function on_mouse_move(x,y) {
window.SetCursor(32649);
if(g_drag) {
g_hover_seek = null;
if ( x <= window.Width && fb.PlaybackLength > 0) {
g_hover_seek = x / (window.Width);
g_hover_seek = (g_hover_seek<0) ? 0 : (g_hover_seek<1) ? g_hover_seek : 1;
g_hover_seek = TimeFmt(g_hover_seek * fb.PlaybackLength);
else { g_hover_seek = null; }
g_hover = x + 4;
window.Repaint();
function on_mouse_leave() {
g_hover = null;
g_clicked = 0;
window.SetCursor(32512);
window.Repaint();
function on_mouse_wheel(delta){
if(delta>0)
fb.VolumeUp();
else
fb.VolumeDown();
function on_playback_new_track(info){
window.Repaint();
function on_playback_stop(){
window.Repaint();
function on_playback_seek(time){
window.Repaint();
function on_playback_pause(state){
window.Repaint();
function on_playback_time(time){
window.Repaint();
function on_volume_change(val){
window.Repaint();
//EOF
Here my new Playlist Viewer script, i hope you'll give it a try and report me any bugs you may found. Thanks
http://fav.me/d63owft (http://fav.me/d63owft)
preview of the rendering into a WSH Panel Mod panel:
(http://img834.imageshack.us/img834/856/playlistd.png)
^nice. i'll be giving that a test later.
just a little bugfix for my
spectrogram seekbarhttps://dl.dropboxusercontent.com/u/2280132...h/changelog.txt (https://dl.dropboxusercontent.com/u/22801321/wsh/changelog.txt)
7.2013.05.01.02
"Spectrogram seekbar". Fix marker not showing on
very short tracks.
right click>
Update script to fix.
full download here: https://dl.dropboxusercontent.com/u/22801321/samples.zip (https://dl.dropboxusercontent.com/u/22801321/samples.zip)
files changed:
marc2003\common7.js
@falstaff, first of all, that is some seriously impressive stuff making customisable/drag-able columns. i'll definitely be using this as it's so easy to customise.
a few things:
drag/drop doesn't appear to work. tried from album list/esplaylist.
some useless (to me) stuff is written to the console eg init groups delay = 1 /handleList count=37
using ctrl+click doesn't de-select group headers. i think it should.
could the title headers align to match the contents? (such as time being right aligned)
could you move the edit column option so it's not under the columns submenu. <<i understand if you don't want to do this one as it's your choice.
thanx for this reporting marc
you are trying to drag external items to the playlist viewer ? ok i'll check
(opposit isn't possible due to WSH panel mod limitation or it can be mimics to another WSH panel mod)
well see, i'll remove that trace
my behaviour choice, but i may reconsider it... will see
i saw it just before posting, it will be done in next release
it makes sense, i will.
WSH Playlist Viewers everywhere!
Excellent work Falstaff, congratulations ++++++
Having said that . . .
I wish somebody would script the WSH equivalent of the CUI Library Filters columns.
That would be super useful, especially for DUI users,
foobar2000 out-of-the-box does not have this library viewing functionality; the only way to have this is to use the "foo_facets (Facets)" component. However, there are numerous "features" built into Facets which can not be disabled to allow a simple layout of Filter columns ONLY. i.e., if you choose to use Facets, then you must have the kitchen sink!, you cannot completely detach the Filters functionality from the rest of the components other features.
An interesting advantage to making a Library Filter Columns panel using WSH Panel Mod,
is the fact that this is one of the few ways you can bypass the limitations of color usage when using the Default User Interface. i.e., you can program panels for DUI using color functions ("$RGB(x,y,z)") and emulate panels from CUI.
Summing up,
I believe a WSH panel containing customizable columns of Library Filters would be a superb JS scripting project for the benefit of ALL foobar2000 users. It would help build a bridge for current CUI users who want to eventually migrate to DUI . . . especially given the fact that CUI is now classed as "Seemingly Abandonware" and the developer ("musicmusic") has not set foot at HydrogenAudio since 2011 !!!!!!!
not possible because there are no library functions in WSH panel mod.
That's great! So one can program Playlist Viewers even NASA programmers would be proud of . . . but trying to create a bunch of simple Library Filter columns is not possible!!!!!!
So what is the solution, how can this limitation be overcome?
if it's so simple, you can always write a native foobar component using the SDK here: http://www.foobar2000.org/SDK (http://www.foobar2000.org/SDK)
or if you want to extend WSH panel mod to include this functionality, the source code is here: http://code.google.com/p/foo-wsh-panel-mod/source/checkout (http://code.google.com/p/foo-wsh-panel-mod/source/checkout)
WSH playlist Viewer updated!
[Change Log]
* v0.0.2 (2013-05-01 15:05 GMT+1):
- toolbar headers now are following column text alignment
- column name "N°" changed to "#" because of some problem with asian code pages ...
- Right click context menu on toolbar Header => Edit Column moved to top of the menu, no more in "Columns" submenu
- drag'n drop in this panel => support added
- some useless traces still wrote to the console removed!
[Change Log]
Putting my "faux-developer" cap on for a moment . . .
So I have a choice between
(1) programming a C++ component from scratch
(2) updating a current C++ component whose source code is freely available.
If I was to do this, then
if I choose (1), then I can not bypass the limited DUI color usage options, therefore the advantages are minimal when compared to Facets (foo_facets_.
if I choose (2), then we open up a new world of exploration for DUI users and programmers, and can bypass foobar2000 built-in limitations, and help bridge the gap between "DUI" and "[Seemingly Abandonware] CUI"
I would choose (2).
i bodged my spectrogram seekbar fix earlier. it was worse than the marker not showing on shorter tracks. right click>Update script to try again. depending on size of panel, you may see a few percent CPU usage.
@falstaff, thanks for fixes. i note the playlist header doesn't update when drag/drop adds tracks.
also a feature request rather than a bug. can you track the position of dropped tracks so they can be inserted between existing items in the playlist? i'm not sure if this is possible but no harm in asking.
thanx, refresh of the top playlist header will be fixed next (no refresh too on items add or remove)
for the insert point, i'll check that asap
another couple of requests
when you have a short playlist with no scrollbar, could the group header text align to the last "proper" column - in this example, Time.
can you make your mood column heart stay red when the item is playing/selected?
@marc2003's now playing script:
neither crop center nor crop top are imho good solutions
changing line 1103 of common7.js
var sy = type == "crop top" ? 0 : Math.round((img.Height - ch) / 2);
to
var sy = type == "crop top" ? 0 : Math.round((img.Height - ch) / 4);
gives a much more better crop focusing on the upper part of the picture (if you select the crop on center, thats what i changed here; actually i wanted to change the crop top but alas i'm too stupid to make it work)
marc2003, I think something recently (perhaps in an update in the last day or so) changed in common7 that results in no information found for artists in your musicbrainz script, and strange behavior of the "update script" action. . I tried the "update script" action in one of your scripts, and it always returns that an update was available, downloaded, and asks to restart foobar2000. It will continue to report that a new script was available and downloaded when I try "update script" even if I had just done so and restarted foobar2000, and it will continue to do so every time I now hit "update script".
None of the updated common7 files fixed the musicbrainz script. I then tried deleting all json files in my stored image folders - no change in behavior. I then reverted back to a April 3 version of common7 and the musicbrainz script now works.
Thanks very much for such great scripts!
can you explain why, preferably with a screen shot? i really don't understand what the problem is.
@godrick, thanks for pointing out i broke the
Update script feature. i did this earlier today. i think i've fixed it. of course another update/restart is required.
as for musicbrainz, not working, i have it active in my layout and it's been fine through all my recent changes?? the panel script hasn't changed so all i can suggest is holding shift when right clicking the panel>properties>clear. that will reset any settings.
Updates now works, and musicbrainz script works with the common7 that was automatically downloaded. All is good - thanks again!
@falstaff, a couple more things:
(https://dl.dropboxusercontent.com/u/22801321/2013/may/playlist%20issues.png)
overlapping text and inaccurate calcuation of group length.
marc2003, it looks like I was incorrect in thinking that my musicbrainz issue was fixed with the update script fix. The old common7 created new json files for the artist I was viewing and I didn't check to see if the latest common7 would create new json files for another artist. When I checked with a different artist that did not have existing json files, the new common7 did not create them.
In looking over the latest and old (from April 3) common7 scripts, I noticed the following:
for the April 3 version of common7,
- the echoed url for links was
http://www.musicbrainz.org/ws/2/artist/8347dd6d-b9a2-4e96-a610-d1ed67b189f1
?inc=url-rels&fmt=json
- the echoed url for releases was
http://www.musicbrainz.org/ws/2/release-group?artist=8347dd6d-b9a2-4e96-a610-d1ed67b189f1
&limit=100&offset=0&fmt=json
for the latest common7,
http://search.musicbrainz.org/ws/2/artist/?query=artist:steve%20roach&fmt=json
...and the results of the latest common7 musicbrainz urls echoes the following in the console:
Musicbrainz: <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en-GB" lang="en-GB">
<head>
<title>502 Bad Gateway</title>
<link rel="stylesheet" href="/.proxy/httperror.css" type="text/css" />
</head>
<body>
<div id="bg">
<img src="/.proxy/MusicBrainzLogo-Q.png" />
</div>
<h1>Server being naughty</h1>
<p>One of our servers appears to be misbehaving. Please try again later.</p>
<p id="http">502 Bad Gateway</p>
</body>
</html>
I cleared the panel and restarted each time I changed which common7 script I was using. I echoed the urls from the end of the "musicbrainz" case in this.get = function(). It looks like something isn't right with this.musicbrainz_id in the lastest common7 script in my setup.
If this doesn't make sense, isn't what you are seeing or more info is needed, please let me know.
edit: tried to fix the url references
thanx
@godrick, fixed. right click>yada yada.
marc2003, you probably figured this out or have something better, but if I replace the following in the latest common7:
this.musicbrainz_id = p.eval("$if3(%musicbrainz_artistid%,%musicbrainz artist id%," + p.read(fn1) + ",)");
if (this.musicbrainz_id.length == 0) {
with the equivalent in the April 3 version of common7:
this.musicbrainz_id = p.eval("$if3(%musicbrainz_artistid%,%musicbrainz artist id%,)");
if (this.musicbrainz_id.length == 0) this.musicbrainz_id = p.read(fn1);
...I can get the latest common7 to work
i thought i tested abusing $if3 like that but evidently not well enough. anyway, i did spot it before you posted.
and i think that server error could appear when doing any MBID lookup so i'm pretty sure that part wasn't my fault.
1. right text now aligned to the last column as pointed, will be available in v0.0.5 (release this evening or tomorrow...)
2. making group header more editable is one of the things i've planed with the use of my WSH inputbox script object , you'll have to wait a little to let me finish this part
3. edit: maybe but only if i can draw an outline around the heart to give contrast when bg colour on selected track is near to the red/pink colour used
EDIT: v0.0.5 released (http://fav.me/d63owft (http://fav.me/d63owft))
edit: one more thing... can you make your mood column heart stay red when the item is playing/selected?
done for v0.0.6 that will be released tomorrow, here is the look of the new "heart" of the mood columns
(http://img811.imageshack.us/img811/9513/captureheart2.png)
^nice.
still a problem with length calculation though in 0.0.5 (changelog says it's fixed?)
(https://dl.dropboxusercontent.com/u/22801321/2013/may/group%20header.png)
the time in the playlist header is right but not the group.
also, thanks for all your updates so far.
there is no real problem, just my preference and i wanted to share.
if you do classic photography the "rule of thirds" is very common and a lot of pics are following these principles. the head/eyes is usually on the level of the upper line
(http://youmakemedia.com/wp-content/uploads/2007/09/karengirl.jpg)
if you do a top crop of a classic portrait half the face is cut of or overlayed by the trackinfo/albumcover (green-box)
if you do a center crop the eyes are nearly cut off (blue-box)
based on my experience a crop focusing on the upper third-line works very good for a lot of photos. (i used 16:9 ratio for the crop-boxes as my "now playing" panel is)
(http://i.imgur.com/KGqy1fs.png)
but of course it's not perfect either, maybe you do some face recognition and crop on those ;P
thanks for the clear explanation. i had no idea about of any of that.
just change the value of the 0 in this line you posted.
that code is just a shorthand way of writing this.
if (type == "crop top") {
var sy = 0;
} else {
var sy = Math.round((img.Height - ch) / 2);
new permanent link for my scripts: https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip (https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip)
changelog link is still the same: https://dl.dropboxusercontent.com/u/2280132...h/changelog.txt (https://dl.dropboxusercontent.com/u/22801321/wsh/changelog.txt)
(i just moved it into a folder making it easier for me to update)
Can anybody direct me to information required to make the Volbar sample (included in WSH Panel Mod) use a logarithmic scale instead of a linear?
if you search this thread or the main WSH panel mod thread, i'm pretty sure you'll find what you're looking for.
(use the box on the bottom left to search within a thread)
The things that were previously posted here didn't make much sense, sorry. However, reading this thread (http://www.hydrogenaudio.org/forums/index.php?showtopic=33197) helped me a lot, so now I have everything figured out.
About the rule of thirds, this is the exact problem I had with the thumbs script, top was cutting off the bottom of thier heads and center was cutting off the top, thanks ehrgeiz. You should make this part of the script marc. Also is thumbs discontinued now? Now playing does everything thumbs can do and more??
I would choose (2).
(3)
Track down musicmusic and give him lots of money
Bratman, I think we are going off topic and too deep into this man. . .
My initial comments on this were left at Post #2320 (if anybody wants to go and have a read).
Firstly, I would like to say:
I WAS WRONG . . . IT IS POSSIBLE to have a DUI panel with ONLY Filter columns by using foo_facets (Facets) component.
Secondly, my discussion was related to this concept:
Using WSH Panel Mod to create Library viewing panels with RGB color options, bypassing the DUI limitations. Also, it would have the added benefit of bridging the gap between DUI and CUI, considering that CUI is seemingly abandonware.
Continued development of CUI was not really part of my discussion.
@ehrgeiz & bratman, i've done some testing with a wider panel and the suggested method does look better. because i generally have my panels in portrait, i didn't see any issue with what i was doing before. you still get the issue of the odd top of head cut off but i believe it solves more problems than it causes. script updated. right click>
Update script.
full download: https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip (https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip)
files changed:
marc2003\common7.js
@falstaff, thanks for the 0.0.6 playlist update. no complaints at all now. i hope you implement the group header title formatting options. then it will be perfect.
RGB color options
that seemingly simple thing would be extremely hard to do in WSH panel mod. it might not be impossible but i'd never take it on. it would take a supreme amount of effort.
@falstaff, just one more niggle with your playlist. it should repaint when the last track in playlist has finished because it shows the playing icon when it shouldn't
i see it only repaints when the reason is 0 (stopped by user) but you should include 1 (EOF) as well.
thanx, will be fixed in v0.0.7 which will bring a new option : artist image as wallpaper bg image
@ehrgeiz & bratman, i've done some testing with a wider panel and the suggested method does look better. because i generally have my panels in portrait, i didn't see any issue with what i was doing before. you still get the issue of the odd top of head cut off but i believe it solves more problems than it causes. script updated. right click>Update script.
files changed:
marc2003\common7.js
RGB color options
Thanks marc2003, I see you updated the crop top values that's done it, the majority of thumbnails are cropped better too. It definitely solves more problems than it causes, it was a bit of a problem before but now most of the images are cropped pretty well. I have the panel pretty wide:
(http://imageshack.us/a/img571/3083/78768437.png)
(http://imageshack.us/a/img547/4457/68116738.jpg)
Honestly before the new crop value their legs or heads was cropped, but now look at the thumbnails, mostly good.
Just a suggestions whilst I'm here if you're interested...
Similar Artists - Have the spotify icons only coloured green if the artist is in the library, then any artist with a green icon can be clicked which would play the clicked artist from the library? Would be cool if the spotify icons was a quicksearch icon which could search for the same artist and send to playlist and play?
I'm just getting to spend more time using your other scripts, I am using six so far. Thumbs, Similar Artists, Lastm/Wiki Bio, News and Musicbrainz. I'll post back soon if I can think of any ideas or improvements, great work marc I was looking at the script and it's very clever stuff, I hope I can learn to do it some day.
eh? why would you want a spotify button to find music in your own library?
the main purpose is to find new music from artists you don't have but are similar to what you are listening to. i had 6 months of spotify premium for free with my last ISP so that's why i created it. i don't use it much now.
also, i can't check the library for an existence of any artist even if i wanted to.
but you can right click>buttons>autoplaylist. that will replace spotify with
autoplaylist buttons to search your library for each artist instead.
I meant click the link not the button, I was going to say I don't use spotify (never will) but I figured you'd be keeping the icons. Shame about the artist checking and the autoplaylist button is cool but it would be better if it played and wasn't an autoplaylist which has to be deleted afterwards.
Got another suggestion being how about the option to list the similar artists as a wall of text, you can fit more in this way.
you can scroll to see the maximum amount of artists that are fetched.
it's just isn't feasible to list all artists in a paragraph - well not if you want things to be clickable. (even if you don't, i won't be making the changes. )
I know that but isn't it best to display information without wasting space and have a script that is more customizable to different layouts? You say it isn't feasible, so it's not worth putting the code in?
(even with my wonky botch job).
I've had this crash on the musicbrainz script twice, do you know what it is?
Error: WSH Panel Mod (Musicbrainz by marc2003): JavaScript runtime error:
Out of stack space
File: C:\Users\Nate\AppData\Roaming\foobar2000\marc2003\common7.js
Ln: 2310, Col: 4
making an image isn't going to change my mind. it's not like i didn't know what you meant first time around so you've wasted your own time there.
if that was just normal HTML, it would be very easy indeed. you just list all the names/urls in anchor tags and the browser takes care of the rest. with WSH panel mod, it's not so easy. i have to calculate the size and position of every piece of text on screen and track the mouse on every move to make it respond to clicks. there is no way you'll ever see anything like that from me.
that error certainly is a new one for me. i'll have to get my googling hat on to see what i can find.
edit: based on what i've googled, i've put in some checks to hopefully stop that happening. i have no idea whether it will work or not because it's not something i've been able to re-produce.
Lol well I was hoping it might, that does sound like too much work for what it's worth, damn WSH Panel Mod sounds like a pain, can you not put html in javascript? (http://www.webmaster-talk.com/javascript-forum/88031-adding-html-into-javascript.html)
Thanks I'll let you know if it happens again.
Two more suggestions.
1) In thumbs grid view how about combining two squares and having an option of portrait thumbs? I'm using 150pixel thumbs giving 4 columns and 2 rows of images, but having just 4 columns would look very cool. This could be an option instead of having a wide image, divide it into portrait images.
2) In grid mode, it displays all different album artists by image and upon clicking the image of the artist it will play that artist, image link (http://imageshack.us/a/img507/7780/23419568.png) Like all the images are different artists with their albums below, double clicking an artist will display the albums of that artist. Just an idea mind.
no. you still need a browser to render it.
custom sized thumbs is a more interesting idea. i
might think about it.
and it's a big fat no for your last point. i can't list artists/albums because i have no way to query the library. also drawing multiple images is quite CPU intensive. doing a panel that size with so many thumbnails will lag. my script is fine with the default of 5 it downloads from last.fm but if you have lots of images, you will notice a delay.
Damn that's a shame you could of done a WSH Panel that displays the youtube video of the song. Is it possible to display a video instead of an image? To play music videos in the library, I guess not as it's not a video player.
Well I have the 20 images selected and it's not lagging, seems fine to me!
no video and no library support. how many more times does it have to be said before it sinks in?
@falstaff, is it ok if i post a little modification of your playlist? i've edited the "mood" column so people can love/unlove tracks on last.fm by clicking the heart of any playlist item. all i've done is replace your mouse button up code with a single line of code (window.NotifyOthers) to tell my script which track to process.
I forgot even video would need library support, sorry for being dumb!
it's ok
^thanks. i posted a little "how to" in my main last.fm playcount thread:
http://www.hydrogenaudio.org/forums/index....st&p=833547 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=76772&view=findpost&p=833547)
quick overview: currently my "last.fm love/unlove" button only works on the playing track (or selected track when playback is stopped). with falstaff's WSH playlist, this modification allows you to love/unlove any track in any playlist regardless of what is currently playing, simply by clicking the inline "heart" icons.
what's this vinyl script I've seen mention of? does someone have a link? It's not in marc's samples folder
check the artwork type (id) and path settings in the script for where to save the image. i've not bundled it because the image is large and the lag on startup/album change is pretty crappy.
nice one marc, thanks
I need some help please . . .
I want to display a single image by itself in a WSH panel and I want the image to always resize to fit the panel dimensions. What is the JS code to do this?
More specifically, I am trying to do this:
If playing track has one channel, display image "A"
else if playing track has two channels, display image "B"
and resize images to fit panel dimensions at all times.
Once I figure this out, I will show you guys an interesting visual enhancement of the default foobar2000 built-in spectrogram (used as a custom-colored panel).
It actually looks quite nice when used side-by-side together with marc2003's sox spectrogram script.
Hi, I can't install WSH pannel on my foobar. I'm on Windows xp Service Pack 3. I upload a video of foobar. Plz check this out http://youtu.be/pebwM_4D3r4 (http://youtu.be/pebwM_4D3r4)
WSH Playlist 2013 updated to v0.0.8
LINK (http://fav.me/d63owft)
last changelog:
* v0.0.7 (2013-05-05 10:20 GMT+1):
- some bugs fixed
- wallpaper feature enhanced, now, you can set the wallpaper to the now playing artist image (check panel properties)
* v0.0.8 (2013-05-08 11:50 GMT+1):
- bug fixed to avoid crash on dragging group when auto-collapse is active
@derty2, try this.... https://dl.dropboxusercontent.com/u/2280132.../may/derty2.txt (https://dl.dropboxusercontent.com/u/22801321/2013/may/derty2.txt)
@aNewDay_, have you done anything stupid like use nlite to reduce the size of your install disk which chops out important system files?
No, i never use nlite for any reason. My copy of xp is genuine. 4 or 5 months ago i tried br3tt's WSH Playlist viewer v2.0 and it did work at that time. But now WSH pannel don't work on my pc. To end my doubt yesterday i tried to install foobar and WSH pannel on my friend's pc and yes it's working, but today when i tried to install a new skin fooEKo_v6 'Elato' from Foo-Nation which use WSH pannel it give me script error. I don't know why. Whatever i do with foobar, i do it with portable version.
you using the latest version from here?
http://code.google.com/p/foo-wsh-panel-mod/downloads/list (http://code.google.com/p/foo-wsh-panel-mod/downloads/list)
may help: http://leftosa.wordpress.com/2013/05/08/fi...-create-object/ (http://leftosa.wordpress.com/2013/05/08/fix-for-automation-server-cant-create-object/)
marc2003
thanks for code at Post #2374 for drawing images in a panel . . . but the code doesn't work; panel crashes . . .
The console reports "Type Mismatch" at subroutine "function on_paint(gr) {"
I cannot believe such a simple task, drawing an image in a panel and making it always resize to fit the panel dimensions, is beyond me ... I am totally fucking useless with JS coding !!!!
@marc2003 Yes, i am using the latest version of WSH pannel from your given link.
@Falstaff You're Mr. Br3tt? Your work is commendable. Thanks for the link. I do changes values to the reg keys but this time i'm unable to understand.
@derty, i made quite a large mistake. lines 2&3....
var img_a = fb.ProfilePath + "images\\a.png"; //1 channel
var img_b = fb.ProfilePath + "images\\b.png"; //2 channels
should really be
var img_a = gdi.Image(fb.ProfilePath + "images\\a.png"); //1 channel
var img_b = gdi.Image(fb.ProfilePath + "images\\b.png"); //2 channels
Excellent marc, it works now +++++
Is it possible to make the image adjust its sharpness, especially if the panel is resized larger resulting in blurring?
Is there JS code which can be added to the script to control the graphical qualities?
About your SoX spectrogram script (in a WSHPM panel)...
Observations of the panel working with .CUE sheets(+ single audio image):
I have quite a few albums which are CUE+IMAGE. I have just noticed that your script does not work on the CUE at all; it only works by clicking on the single audio image.
In the CUE case, all we see is a blank background but the marker and mouse hover and seek will work correctly.
Is it not possible to extrapolate track duration indexes from the CUE sheet and parse the info to the programs (Sox/FFMPEG)?
Observations of the panel working with .MKA (standalone audio container):
I have quite a few albums converted to a single .MKA file. In this case we have a different type of 'wrong' behaviour.
I click track 1 and your spectrogram renders the track 1 spectrogram image . . . I click on any other track in the album and the spectrogram image never changes, but the marker and mouse hover and seek will work correctly. . . If I change focus to tracks from another album and then go back to the .MKA album, the problem continues as before; i.e. marker, mouse hover and seek will update and work, but always with track 1 spectrogram image as background.
you can put this as the first line inside
on_paint()gr.SetInterpolationMode(7);
it's useful for maintaining quality when resizing large images into a smaller panel. trying to stretch smaller images to fit isn't going to work so well. as the old saying goes, you can't polish a turd.
as for cuesheets, the reason why the marker works is because the length of the track is provided by foobar title formatting. i can't get a start point within the file though. i don't know how to write a cuesheet parser from scratch.
and it looks like i should be excluding .mka files as well. i've not encountered those before.
i've updated my
spectrogram seekbar to exclude scanning of tracks with a subsong index of more than 0. i have no other way to determine if tracks contain multiple chapters. i don't want to assume anything based on just the codec/container.
existing users: right click>
Update scriptfull download: https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip (https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip)
files changed:
marc2003\common7.js
Good stuff marc you are the king of kings. Please add some support to thumbs/now playing for three horizontal images. Using grid view to display three artist images at the same time is laggy and no cycle because it's the thumbnails.
Got a crash on now playing
Error: WSH Panel Mod (Now Playing by marc2003): JavaScript runtime error:
Overflow
File: <main>
Ln: 77, Col: 2
Happens when I move a panel stack splitter.
i don't know what causes that crash because i'm not installing columns/PSS to test. in default UI, i did manage to make it hang foobar completely when resizing the panel to a ridiculously small size so i've fixed that. it might help?
can you illustrate what you mean with the thumbnails because i don't really understand.
Awesome that has fixed it!
I mean like this, at the moment that is using big 220 pixel thumbnails to give 3 images but that way is slow as there is lots of thumbs under the graphical browser panel so when you slide it up and down it lags bad. Also no cycle as thumbs don't cycle, maybe have an option to limit how many thumbs can be shown? I understand if I'm being stupid
(http://img18.imageshack.us/img18/810/threeartists.jpg)
well i did say the other day it's slow with multiple images but you said it was fine?
if you lock the panel size, that should pretty much sort it. you'd only get a little delay on artist change.
It is fine with multiple smaller images
Locking the WSH panel has no effect, dragging with one image is super fast, dragging with three is slow because the other big thumbs begin to display as the splitter becomes larger, now if I could drag with only three thumbs or images enabled it would just zoom/crop into them just like having thumbs off. I guess I'll just display one image instead as I think it's getting a bit too much of a niche problem.
On the plus side foobar is loading in 2 seconds, whatever you did to your scripts since a few weeks ago is much faster.
large improvements ahoy for thumbs & now playing. there is no lag on panel resize with thumbs enabled - apart from resizing the width in grid mode.
existing users: right click>Update script
edit: just realised i bodged the thumbs grid mode update. in the unlikely event anyone downloaded it in the last 20 minutes since i posted, just Update script again.
That would be me
Nicely done! It's really zero lag when re sizing now Small problem though,
(http://img716.imageshack.us/img716/656/uuung.jpg)
Dragging graphical browser down is fine but once I drag it up PAST the top thumbs, they disappear, skipping song brings them back?
Is thumbs faster than now playing? The only thing thumbs has that now playing doesn't is a selection mode option in the right-click menu.
Marc you really need your own thread for your scripts, they are just dominating this one lol.
the thumbs not showing when you resize smaller than the thumbnail dimension is intentional. it not coming back when the panel is resized larger again is a bug which i've just fixed.
thumbs also has grid mode. now playing does not because it would interfere with the mouse clicks and it would probably look like crap behind the bio text as well.
Hi Marc.
about last.fm playback script:
Can i love tracks using a globlal hotkey? I tried it, it shows loved track in WSH panel, but doesnt update last.fm.
If already asked, sorry .
And thanks for your awesome work with WSH!
you'll have to use foo_softplaylists (http://www.hydrogenaudio.org/forums/index.php?showtopic=76133) if you want global hotkeys to love/unlove tracks. obviously my script won't detect this but if you do it before the scheduled playcount update half way through the track, it should update then.
Thanks, it works nicely using two global hotkeys (CustomdbLove 1 + Last.fm Love Track).
Yep that's fixed it marc, about the thumbs/nowplaying I know what you mean but then again bio can be turned off? Although fair enough with mouse clicks.
I got a request to have folder.jpg as an image source in thumbs, sometimes I have thumbs fully spread out in foobar with a playlist on the right, would be nice to have a choice to display the album cover. Shouldn't cause much extra cpu as it's just one more path and it turns thumbs into an album viewer too, bonus?
P.S I know you have created art reader for that purpose but having the option in thumbs would still be nice even without having the other features like front/disc/back.
I love this layout with album cover, but then I have to load up the thumbs script to enable lastfm artist images, why not merge art reader and thumbs?
(http://img18.imageshack.us/img18/5493/hjkhjkn.jpg)
Now I don't regret choosing 1200x1200 album covers.
That original size tooltip is very nice, good attention to detail and the google image search is great too.
it's a lot more effort than you might think for me to add the front cover into all the images used in my thumbs script. how they update is fundamentally different.
either have 2 panels, or use now playing with everything turned off but the CD cover.edit: i forgot there is already the functionality to have more than 1 folder in
custom folder mode. obviously it won't download art from last.fm but if you have stuff already acquired, you can use it like this.
d:\applications\foobar2000\wsh_lastfm\$crc32(%artist%)|$directory_path(%path%)
note each folder is separated by a | with no spaces. the first uses my art downloaded from last.fm. you'd have to modify the path to your foobar profile folder. the 2nd path is the folder containing the playing/selected track.
example of front cover added to artist images: https://dl.dropboxusercontent.com/u/2280132...%2B%20cover.png (https://dl.dropboxusercontent.com/u/22801321/2013/may/thumbs%20%2B%20cover.png)
Falstaff, you might be aware of this, but when you choose a single song (at least with flac), it does not accurately report the length. Also would it be possible to set it up so that instead of counting backwards it lists it as (Time in song/Length) For example 2 minutes and 30 seconds into a 4 minute song would look like (2:30/4:00)
i have a request for falstaff as well. can you get rid of the thin top line when the top toolbar is hidden?
edit: never mind. although i couldn't find and remove it myself, i've just drawn a white line over the top of it. that works well enough for me.
please shot me screenshot of the not accurate length. thank you
http://imgbox.com/aceRdVY9 (http://imgbox.com/aceRdVY9) See it says 1 song, 10 minutes, but the song is half that length.
just updated my discogs script. a few weeks back i didn't like all the partial matches you get so i made it show exact matches only. i've now decided to make this a toggable option that can be turned on or off.
edit: i forgot there is already the functionality to have more than 1 folder in custom folder mode. obviously it won't download art from last.fm but if you have stuff already acquired, you can use it like this.
You're right I checked the scripts, that's a shame. I wish the now playing cover didn't have a limit so it could be made big enough to fit the panel. I guess I'll use two panels, gives me a reason to use the buttons I spent ages creating but ended up not needing. I'll try the custom folder mode not a bad solution for me.
Which do you prefer discogs or musicbrainz? I prefer having exact artist match or this happens http://img16.imageshack.us/img16/4996/discogsv.jpg (http://img16.imageshack.us/img16/4996/discogsv.jpg)
i much prefer musicbrainz for the cleaner output. but i have both active because there can be differences. i have all mine in tabs so it's no effort to hide them out of the way most of the time.
Yeah me too and musicbrainz gets more of the obscure artists nearly everytime, I use panel stack splitters to slide panels in and out. I still get this crash in musicbrainz though:
Out of stack space
Ln: 2332, Col: 4
I'm trying to workout what is causing it, it was happening randomly not very often. Some songs it crashed on I couldn't reproduce with the same song. Then I noticed it crashes with ELPlaylist when selecting multiple songs, if I try and make it crash by drag selecting say five songs fast up and down it crashes every time. I've put it to prefer now playing which seems to have fixed the problem.
I also get this crash in now playing:
Overflow
File: <main>
Ln: 77, Col: 2
This happens when I reduce the panel to size 0, sometimes I don't want to show the panel so I slide it up and close it, this crashes it, I know you said you fixed this but it still crashes on Windows 8 using Jscript9, (it doesn't crash using Jscript though). I think it was you or Brett who said use Jscript9, on Windows 8 due to high cpu bug?
Edit* Just tested it on jscript and it's much faster than jscript9, that was giving 10-15% cpu usage just moving the mouse over it, now with jscript it's hitting 1% max. So which should be used jscript or j9 for win8?
Edit* It's the same on all your scripts, much much faster in jscript, I had them running jscript9 all this time because bretts wsh playlist needs j9 for windows 8.
well don't do it then. you can achieve the same effect by hiding panels instead.
the windows 8/jscript9 thing has been reported before in the main component thread. i guess i should update my readme telling windows 8 users not to use it.
http://www.hydrogenaudio.org/forums/index....st&p=816938 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=70363&view=findpost&p=816938)
it's nothing to do with any script - it's the function that detects mouse movement that is problematic.
I don't like hiding panels, I like having freedom to resize them with the mouse, to be able to move the layout around.
Are you using Windows 8 Marc because I've just tested this on your panels. Using jscript and moving the mouse around is doing nothing to the cpu in task manager, it's at 0-1% never goes higher. Using Jscript9 eats upto 15% CPU. This was the opposite using bretts wsh playlist.
I know it's not your scripts as it does it even with an empty WSH panel.
Also jscript has fixed that panel size 0 crash, it's all good .
no, i don't use windows 8 which is why i posted a link to someone else reporting that problem.
i've never told anyone to use jscript9. new panels always default to using jscript.
So you're right. Is this reported often because I don't think it's a problem with Windows 8, at least not mine. To me it is the opposite, I think it would be a bad move to tell W8 users not to use it.
Now I remember it was hunter who told me about J9.
~eXtremeHunter1972 Apr 27, 2013
"on mouse move high CPU"
I assume you are on windows 8? if so then right click while holding shift key on playlist and select WSH configure and
on left top Script Engine select jscript (other people who have installed Internet explorer 9 should select jscript9).
This is known bug on WSH panel but so far not fixed.
Weird as it's the opposite of what he said for me, I'll have to test on some other Windows 8 machines.
your post might as well be written in japanese for all the sense it makes to me.
lmao, basically Jscript9 sucks on Windows 8, people told me to use it though, which I'm not now.
Marc musicbrainz is still crashing
Error: WSH Panel Mod (Musicbrainz by marc2003): Microsoft JScript compilation error:
Unterminated string constant
Ln: 2297, Col: 7
<head>
</head>
<body>
<div id="bg">
</div>
</body>
</html>
*Edit I guess that's not your script, it's their server. Ignore this.
the script shouldn't crash because of the dodgy server response. i've just updated it to fix that.
Damn you're quick on fixes, it's not crashed at all since the fix, cheers dude
What are you working on at the moment? A VU meter by any chance?
Got a link request, it's a must have for guitar players.
http://www.ultimate-guitar.com/search.php?value=$replace(%artist%, ,+)&search_type=band
Bratman
Maybe you didn't understand me or i explained poorly, if you are on windows 8 DON'T use jscript9, if you are on xp or vista or seven and you have installed internet explorer 9 then use jscript9.
Windows 8 uses jscript10 engine and thats why there is some complications when jscript9 is enabled on your machine.
T.P. Wang has written:
v1.5.0 Beta 1
- ADD: Add support for new JScript engine (aka "Chakra") from IE9.
In order to get it work, select "JScript9" from the script editior, and ensure the IE9 is installled, or it will fallback to the default JScript engine.
Are there any advantages to using JScript9 over the default JScript?
Wikipedia Jscript9 (http://en.wikipedia.org/wiki/Chakra_%28JScript_engine%29)
Test it on your machine with this script, in my old core2duo with jscript9 calculation takes 25 ms with jscript it takes 349 ms.
var from = new Date();
for (var i = 0; i < 1000000; i++) {
var result = Math.sqrt(i);
var to = new Date();
gr.SetTextRenderingHint(5);
gr.DrawString("Calculation took: " + (to - from) + "ms", gdi.font("Segoe Ui", 20, 0), 0xFF000000, 30, 30, 1000, 30);
jscript9 certainly looks far faster performing 1 million calculations like that but have you tested your own scripts? i just tested a few of my own and it's far less conclusive. i even have jscript consistently beating jscript9 in a few of them (to be fair, the difference is less than 10ms).
of course the most expensive operation in WSH panel mod is the display and it's not going to help with that at all.
It's faster in WSH playlist initialization when there is some 50000 tracks to init,
but most of the time the difference is negligible and I personally don't bother to switch jscript9.
Wanted to edit my last post.
Ehh we really need option to delete post!
Delete me please.
i just added 13 of my own panels plus falstaff's WSH playlist to a default UI layout and restarted foobar 5 times for each test. these are the startup times reported in the console.
jscript0:00.485566
0:00.476765
0:00.485435
0:00.497912
0:00.485515
jscript9 0:00.591191
0:00.588813
0:00.605242
0:00.596497
0:00.591015
although the difference is small, it's certainly consistent. this was on windows 7 x64 with IE9 installed.
Hunter, reading your comment again makes sense now, my bad.
I tested the calculation script and I get 25ms in jscript9 compared to 145ms in jscript.
When I am using Marcs scripts, I get high cpu usage moving the mouse cursor over them with jscript9.
So jscript9 IS faster but the downside is it lags with mouse activity?
But then Marcs last reply proves jscript9 is slower (at least with his scripts) , I'm a BIT confused.
like i said before, it has nothing to do with my, or anyone else's scripts. it's a problem with the component. you can verify this yourself by adding a blank panel and adding only this code to it. close the dialog and move your mouse over it.
function on_mouse_move(x,y) {}
jscript9 is faster at pure number crunching. that snippet extremehunter posted has it performing a million calculations and it certainly looks far superior doing that one task.
but i've found that in real world usage - at least using my scripts - it's slower.
a little update:
7.2013-05-13.01
"Discogs". As discogs uses something like $swapprefix, this
script needs to use it if the "exact artist match" option is
enabled. Also, the output has been tidied up by removing
all extraneous spaces.
changelog: https://dl.dropboxusercontent.com/u/2280132...h/changelog.txt (https://dl.dropboxusercontent.com/u/22801321/wsh/changelog.txt)
files changed:
marc2003\common7.js
Your scripts are faster in Jscript though, it might depend on the script because sometimes jscript9 is faster on certain scripts. Maybe that is wrong, it's just what I've seen.
I'll just use Jscript I agree it's faster in real world usage.
Musicbrainz has been crashing again on me, a new error.
Error: WSH Panel Mod (Musicbrainz by marc2003): Microsoft JScript runtime error:
'this.data.length' is null or not an object
Ln: 2107, Col: 21
Somethings up with the code, it's not working at all even after pasting in from samples.
*nvm, your latest dropbox sample rar has fixed it.
I have created a context menu item to open the now playing track in an external spectrum analyzer program (SPEK.EXE)
But it does not work . . . SPEK opens with a blank interface but does not load the track (i.e. the file path)
Why ???? . . . this program accepts basic commands like
spek.exe [file] , therefore it should work.
Here is the context menu function in the script:
function on_mouse_rbtn_up(x, y) {
metadb = fb.GetNowPlaying();
_menu = window.CreatePopupMenu();
_menu.AppendMenuItem(MF_STRING, 1, "Open active track with SPEK");
_menu.AppendMenuSeparator();
_menu.AppendMenuItem(MF_STRING, 2, "Configure");
idx = _menu.TrackPopupMenu(x, y);
if (idx == 1) try {
var path_to_target_file = metadb.Path;
WshShell.Run(fb.ProfilePath + "addons\\wsh-enhanced-fb2k-spectrogram\\spek.exe" + "path_to_target_file");
catch(e) { }
if (idx == 2) window.ShowConfigure();
_menu.Dispose();
return true;
you've put the variable name in quotes so it's getting sent as plain text.
also, you need to consider spaces in your paths/filenames. try this.
WshShell.Run("\"" + fb.ProfilePath + "addons\\wsh-enhanced-fb2k-spectrogram\\spek.exe\" \"" + path_to_target_file + "\"");
You nailed it marc, thanks +++++++++++++++++++++++++++++++
another 'nice to have' feature would be a script that calculates a fingerprint with chromaprint/fpcalc.exe [1] for the current track, queries the acoustID database to extract the musicbrainz recording-id [2] and then pulls artist-credits via the musicbrainz webservice [3] for display.
eg.:
S'posin'by Frank Sinatra
writer: Paul Denniker, Andy Razaf
arranger: John Guarnieri
bass: Herman Albert
guitar: Tony Mottola
lead vocals: Frank Sinatra
piano: John Guarnieri
sadly i don't know how to do that but maybe someone else who thinks that'd be nice3
[1] http://acoustid.org/chromaprint (http://acoustid.org/chromaprint)
[2] http://acoustid.org/webservice (http://acoustid.org/webservice) ; e.g.: http://api.acoustid.org/v2/lookup?format=x...oDx1AAhAEFEMEAA (http://api.acoustid.org/v2/lookup?format=xml&client=8XaBELgH&meta=recordingids&duration=167&fingerprint=AQADtEmUaEkSRZEGHJCBI8cj8DiSnDjizyiVBk9wonk--Dua47qQxyNkLUcfhPmN68bx5Wi4A7aO45_xI71CFe2H5Iku4PB1nBu-3HhRRw9xHT9ONMeL40mOH8nEnEKYKNnx40fzE1X44scn9AmaHyeNME-UI9lxHp1yhLEb6BIC92HwpTeeZMbDJ6h0NOpXJH-OXITTZMFFwgtVHVeaBK6Mh7nwFX2E5mJx6viO6JAq6jDVQM8RSlKegklyfOCjrGDy5Dj2IMyY63ik4x98i8LlQm_wIN-O4xd8Dg_2YdnzIc8XJHfwTscUOUIPjsdz_Cmiq4SmH4-i4IfIHM9Q_vhw5EmES0w045SuoKbRvBl-qriOqeqRSy10ZDkp4QlG_oEX_bhOXLrwKHmQREZ6MWByH8-CPJI-nHlwSQn0SwgXPkLChZeE0MfDrJhswz1M6RdCPyN05BLxAE8SHZcO5_ilIVfWBN8M5csRPfiKK_rRH9Z2nEf_4k4yXFmKKyHxccef4R98HTmP5MND4ZKiEXceOI_wA-_RPES7PDEu6TjSN4mg8EV-eK_wiPiSKMUeND5KnbiPKmGuoHkW7GHwJNiFG8kVfcgTYTqa40kSXMajhwgFORkfnMoSb2BQ9mguCW8i4sYPbsuMZ8mToWQfNBaPk9AP5U1xQ_2hHefRsWhCZYFG4umDlwhTo7eK78WfwJJ09Ay-jAh56EKeYfpyMNlDKZiy9KiMr0fyTETonEEzHQ-Pn1j74I8Gl0eiIzqe4EosPMdlHs8i3WguHuPlIPGP7EHy1IisF9WO8ziz2MJzNFXiJUgdpqKQjMKzaMePporEoj9GxxGRLckFxdeIvEFTheiH-0fPBeeP6j2eHT9OXFOORxeO76gS-UTq61BWJTr6iqheZDxOffCUHE_VoDkuTseVJVFUdLPQ7DzoJWqCc5WhwA_6o_kX4uFTmGFyXNGRx9A-NHeRLCsmS3hCHS-V42mbgf_wCzuaUDnapOpxicTq5bilLsj-BEkuGm8VPM7Q5xf6B89FXEKeH3qO9A-eC1eI_Ifn9Lim48qD58V_aD2a_YV-4kl6_CmexkWkzJTB_Djix0iaPIcZnbgypsEnlEyOhgd743mwJWF-qMoOH39wlRh5HWXyGZsyxUfFok-GZLmQPFGuoHxg1DJ-hmiWpcEH54wRPjuS4w_xiEc5H01UNiMuOGuQT9C9EWeEHsKPtGPx40X6D4eVJEcy6jhhdk2F60cd5UHTJzj-HM-yTELOpUhOoo_QhBme7RbwxMG-4ymSJ0WuPPB04skLTr2J_Wj0o9KaHT_u5EguBTlzmPljXMnR_EIf4A9cMTP-I4oV5kESL6SEJtdQxU5CTEwewuPRJ8eVI3uRNMfFB3OiXEWPJmfwHzG3HPqRE82PUsWHHmHOTNCtESG1w02YtOipY3bB5CJCZllO6AipoMlyPMSdwx_O7MOZR1AuND8mRSyPf9gZLVHxJIefI3-QHP8CK3mIK3WOj33Q5Aneo4mz4yeu5EnQTMmhnS_2DD_4rMP3GE2So9rxQ__h8imOa8ooPOSDHlT1HPkK5VIQXhd-fGrxlcPzoVkvFReaP3jGI4d2HXGWEBXHMPgV9Deapjt-4dbxfEdPD_mCpsKP5kNy-E2GP8J5WPnxHz6Dp4ReXFrChWir4y9KHk0colG0o06OX7jgOnim4zq8IGnyBPH14T6Mo69RK8GTHTmRLOfQi7i6HHOiPGjqFP3xYB-eow-SxclD5EcPo2-Q08aFH79TNI8QdtFxH1dH2PiJ7ZjzByEPLc-RJ9kzXDmF8EtjJMsxis_xTAmFf43xE9MfbEilB8mekTjx08MlHc-iC8ezHA5zCrsdHH9U_Hh2XNlzvB3K5oHPiEGYJsQP6E9RSR9SJhr6i8P1oJnUERWjo7_QT9EQXjmSJS-eC1ee42mH64RfPPgyIoeWKLqMUjoT4UT4Hameo16Cb9CyIPxxN8iPZMlRpmlwW_CPPz2eTRSuPGg-JOePdGwcnD4qXcGTLAtODXijI1LyB8mePWByHdP34smKK8FzYzpTNOeDn8TaGxWP5rnwJDlyPIf2MESY8MkS_KJQfXDVw0atXpgP8wcr5cIT7cGUv-iDXkIzORfCJkl5JMtP_DkudEzwad6wVcwxTcO7oy_C5Ej2LEczicbVODE8ZhYu4k8unMUtavhxD4H24Q-eJcfRjMfzBPKFB88QHk-WB9e-4eyMZjmORzfOJcRz9EuIiwyDcw-a8fiNOyT2SUaDxlmIq8f_YIyvCc0sKUOfG0f6rEguRXiSyEbzB1Ve4VeT4ikuEU_CRAj_mPCjDNWadHjCB8ffYD_-ohEmfdD14MlSQfOhkT1iMT-e7PiLJ8eV-OiTDE1yHd8S7Ug-MUGO5khmr4j4o0l2LTGYX9ijEEeDSH5yJFcuNFXQ5MN_JFczhNGboRRzgtSDJrbQ08gjpkHyJDjMD2cw-knwK8h3yFESbZUQFlZe5DHKZyyeRDuuGffRvOidBnKPXxWexCn0HQijHb3y4oye4EezPAn-DPUq4jtyWA9kKYmOXMyEdopLNBep4PNT7GGMXj-aRTiSH-lDvDbuBz9yZYWeSCnCN0ifLUZy7Qum6sSjo3zQxJyEOsmLpidxZkdy5EpyHF-yHA959EIzJqKKu4sQvYFU5cgVDs3RH1dQitbxJc_Qtcf348eRQ3ryCGEiH08yJcct7BeaRxmS_EZ-oszngEnkHY8ioknGozeO5hIS3QkR5mKHJ0k0wXUxJtlxMT6eSGkOd-KQSzmSo1nR5gseLaUAaFIRYZxCGDDCYcSMkIIwQphyBgzDiHBGcACcIQIhRTRTCjUDGTLEWQIYAkAMIwgQwkAFHAHMGAwUAYYAqAAihgImtDKGMG-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)
[3] http://musicbrainz.org/doc/Development/XML...rvice/Version_2 (http://musicbrainz.org/doc/Development/XML_Web_Service/Version_2) ; e.g.: http://musicbrainz.org/ws/2/recording/9c7a...k-rels+url-rels (http://musicbrainz.org/ws/2/recording/9c7ae097-408a-43a3-be2a-5094b45fe441?inc=recording-rels+artist-rels+work-rels+url-rels)
i'd consider making more musicbrainz scripts provided files are tagged with proper MBIDs before hand. i'm not really keen on doing the lookups first when people can easily use picard (http://musicbrainz.org/doc/MusicBrainz_Picard) to tag their files.
good thing i tag my files with picard
bad thing is that foobar can't read the MUSICBRAINZ_TRACKID field picard is writing to store the MBID
[1] for that specific recording as it is using the UFID
[2] field for that.
so for specific track-credits you'd have to make two queries, one to get all recordingIDs from the current release and then with help of the tracknumber get the recording/track ID to query the specific credits i guess. dunno if thats easier than using the fingerprinter. maybe i'm just a fan of these open-source/open-data projects that i want to see them used in my favourite mediaplayer^^
[1] http://musicbrainz.org/doc/MusicBrainz_Picard/Tags/Mapping (http://musicbrainz.org/doc/MusicBrainz_Picard/Tags/Mapping)
[2] http://id3.org/id3v2.3.0#sec4.1 (http://id3.org/id3v2.3.0#sec4.1)
i had a quick search (http://forums.musicbrainz.org/viewtopic.php?id=3244) and you can configure picard to write a TXXX frame in the scripting section of the options.
$copy(_id3:TXXX:MUSICBRAINZ TRACK ID,musicbrainz_recordingid)
what's really bugging me at the moment is the inconsistency between the id3 & flac/vorbis tag mapping. why use
MUSICBRAINZ ARTIST ID and
MUSICBRAINZ_ARTISTID when they could use one OR the other?
I don't really know what to do with this component. Every time I try to load it, it crashes. This last time the console gave me this, but I have no idea what it means. Any help?
WSH Panel Mod ({ED89F4DA-FDCC-4CBC-8DDB-58D202FD6BF3}): initialized in 28 ms
Error: WSH Panel Mod ({1F73EB63-C052-4E32-8A7A-BF4FBF6C1430}): Microsoft JScript runtime error:
Invalid procedure call or argument
File: <main>
Ln: 88, Col: 5
Error: WSH Panel Mod ({82E26BE2-93C2-497A-BFE4-C40892B2AFDD}): Microsoft JScript runtime error:
File: <main>
Ln: 25, Col: 5
Error: WSH Panel Mod ({ED89F4DA-FDCC-4CBC-8DDB-58D202FD6BF3}): Microsoft JScript runtime error:
File: <main>
Ln: 46, Col: 5
the console is telling you that 3 scripts have crashed and it tells you where to look for the errant code in each one.
i'm guessing you didn't create these scripts but are using someone else's configuration (or theme)?? if it's from deviantart, your best bet would be to ask the author there.
Hi marc2003, thank you so much for your scripts, i'm having some fun lately with the spectrogram seekbar, really clever
I know it's probably too hard, but i was wondering if it's possible to add the possibility to change the spectrogram colours like in the native fb2k spectrogram.
It would be perfect to integrate it in some skins!!
samples updated:
artreader and
cd jewel case now have options to launch Album Art Downloader (http://www.hydrogenaudio.org/forums/index.php?showtopic=57392) from the right click menu, sending the current artist/album as search terms.
(https://dl.dropboxusercontent.com/u/22801321/2013/may/cd%20aad.jpg)
files changed:
marc2003\common7.js
@foomark, right click>
SoX options. then look at page 33 of the
sox.pdf file. play with the -h, -m and -p options. you can't easily choose colours but you might find something better suited than the default.
remember that playing with these options will render all previous images obsolete so you might want to clear them using the right click menu.
Fantastic cover art update, works like a charm.
it's possible that recent updates over the last day or so have broken the Update script feature causing all my scripts to crash on a restart.
if this has happened to you, save this file in your foobar profile\marc2003 folder and restart foobar.
https://dl.dropboxusercontent.com/u/2280132...2003/common7.js (https://dl.dropboxusercontent.com/u/22801321/wsh/marc2003/common7.js)
apologies for the inconvenience.
Hey Guys. I'm using one of marc2003's configs he posted a few years ago.
I reinstalled Windows 7 on my PC and reinstalled foo 1.1, and set everything back up. Now I'm getting these errors on Startup.
A couple of errors;
Scripting Engine Initialization Failed (GUID: E71AC80A-2F79-4BCB-8A51-3508849A40A2, CODE: 0x80020101)
Check the console for more detailed information (Always caused by unexcepted script error).
Scripting Engine Initialization Failed (GUID: FFE1F23C-1D2D-40CF-B721-B83160A9DCC4, CODE: 0x80020101)
and here's a dump from the console;
http://pastebin.com/q0CShRDm (http://pastebin.com/q0CShRDm)
Any help would be awesome.
the very first line should be easy enough to interpret:
WSH Panel Mod (GUID: E71AC80A-2F79-4BCB-8A51-3508849A40A2): Parsing file "C:\Program Files (x86)\foobar2000\scripts\marc2003\v2\common.js": Failed to load
quite simply you haven't extracted the files in the zip to the right place.
that looks to be a very old script though. it's been a very long time since i've placed files in main foobar progam folder. these days the folder should be placed in the foobar profile folder. my latest scripts are available here:
or if you're using my last.fm playcount sync script: https://dl.dropboxusercontent.com/u/2280132...ount%20sync.zip (https://dl.dropboxusercontent.com/u/22801321/wsh/playcount%20sync.zip)
further questions should go in this thread: http://www.hydrogenaudio.org/forums/index....showtopic=77883 (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883)
Thanks Marc.
Quick question, how do I embed Esplaylist with Playlist View?
Thanks Marc.
Nevermind, figured it out.
@foomark, right click>SoX options. then look at page 33 of the sox.pdf file. play with the -h, -m and -p options. you can't easily choose colours but you might find something better suited than the default.
Thank you , i didn't know about these parameters, really nice to have them.
The customization's not "total" but it can fit a lot of configurations, great work, thank you again marc2003.
marc would it be possible to create a script that shows the top tracks for the currently playing artist?
it might not be obvious from the name, but my last.fm similar artists script already does this. it is mentioned in the readme though.
you can switch to it on the right click menu.
you can use foo_facets for that. you can create an artist pane to select an artist. then add a track pane with 2 columns - the title and playcount. reverse sort the playcount by clicking on the header.
And you can use the sort function too in preferences / advanced / display / standard sort patterns
Then use the sort menu command from Edit / Sort
play count=$sub(999,%play_count%)
awesome, thanks!
Marc I want to share a layout on Deviant Art using your scripts, wanted to check if it's okay with you? They are all updated to the latest version and I'll include the readme and what not.
These are the scripts:
now playing
last fm and wiki bio
musicbrainz
yeah, that's fine. it makes a change for someone to ask. plenty of people have used them before without checking.
Awesome thanks I'll be sure to credit you of course, you've done amazing work.
bugfix for my musicbrainz script.
7.2013-05-20.01
"musicbrainz". In "releases" mode, a recent change prevented
all links being clickable. This should now be fixed.
files changed:
marc2003\common7.js
Maybe it's been already asked but...why not to add by default Wiki and Google to the Web Links?
I have the right images that match the style of other web link's buttons if needed
i already have the google image from the same icon pack i got most of the others from. let's see your wikipedia image.
I saw you do have wiki in the small web links script so i thought it would be nice to have it also in the standard web links script.
I have these two png that i think could match the style of other buttons:
(http://i.imgur.com/f6t4w7E.png)
and
(http://i.imgur.com/hroBCql.png)
You can download them from this zip
https://mega.co.nz/#!xxAxXYza!Ixfqq...eaX_q-Hz7XPs4aQ (https://mega.co.nz/#!xxAxXYza!IxfqqWi1MMv0dddpJAWdyzqvL3F0eaX_q-Hz7XPs4aQ)
it's much easier to get those. i simply use favicons from the websites.
with the larger web links they really need to be the same style for it not to look horrible. i'll see if the image you provided fits.
Ok, it was just an idea of course.
I did a quick test and my images do look like this between the other buttons, maybe they need a small roundings on the corners?
(http://i.imgur.com/ej7NTsb.png)
i'm useless at editing images so i've just added the google one for now because the image is from the same pack.
a full download is required because of changes to files and new images: https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip (https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip)
files changed / added:
marc2003\common7.js
samples\web links.txt
I'm not a graphic but i tried to edit them better, i think the result is quite good but maybe we do have different standards
Normal:
marc, another question. Is there a way I can enable click and drag for the text panels?
not easily. i couldn't even think how to implement it so i searched the thread and found T.P Wang has a draggable text example bundled with the component. i also found you were asking about it 3 years ago.
but the way mine handles scrolling/layout/calculation of text height is completely different and it would require some major changes to the way mine works. i admit it would be nice to have and i may consider it sometime.
samples updated: i just noticed my
last.fm charts wasn't updating automatically. my own stupid fault again.
files changed:
marc2003\common7.js
@icedtea, i tried implementing drag in text scripts but i failed miserably. it's beyond me at the moment.
marc2003The context menu for my "enhanced spectrogram visualization" panel has a bug; it will crash if I right click on it when there is no active track (i.e. playback is stopped).
Console error reports "Object required" at Line 102
Here is the code (Line 102 error is in red):
var path_to_spek = fb.ProfilePath + "addons\\wsh-enhanced-fb2k-spectrogram\\spek.exe";
var path_to_active_track = metadb.Path;
_menu.AppendMenuItem(fso.FileExists(path_to_spek) ? MF_STRING : MF_GRAYED, 1, "Analyze active track with SPEK");
if (idx == 1) try {
WshShell.Run("\"" + path_to_spek + "\" \"" + path_to_active_track + "\"");
catch(e) { }
_menu.Dispose();
return true;
How do I change that line in red to stop the crash from happening?
var path_to_active_track = metadb ? metadb.Path : "";
Try this:
if (!metadb) return;
if (idx == 1) try {
catch(e) { }
_menu.Dispose();
Righto . . . Solved! . . . Thanks for the answers guys +++++
The code also needed one more little tweak (all new edits are in red):
_menu.AppendMenuItem(fso.FileExists(path_to_spek) && metadb ? MF_STRING : MF_GRAYED, 1, "Analyze active track with SPEK");
if (idx == 1) try {
catch(e) { }
_menu.Dispose();
return true;
Hi
This is the error that I get when I try the themed seekbar
WSH Panel Mod (Themed Seekbar by marc2003): Parsing file "C:\Users\Aldem\AppData\Roaming\foobar2000\marc2003\common7.js"
Error: WSH Panel Mod (Themed Seekbar by marc2003): Erreur d'exécution Microsoft JScript:
'this.themed_header' a la valeur Null ou n'est pas un objet
File: C:\Users\Aldem\AppData\Roaming\foobar2000\marc2003\common7.js
Ln: 986, Col: 6
I'm using Foobar2000 on Windows 7 - 32 Bits
it works on any theme apart from windows classic. i guess that is your issue.
You were right, thanks for the tip and for the good work !
marc why did you take out the option to select a different language in the biography context menu?
I've got a couple of people asking how to do it.
that change was made sometime ago and i put this note in the panel to explain why:
//due to recent changes at Last.fm which truncate the artist bio to just
//300 characters, this script now uses an alternate source for the bio.
//it's English only and there is no support for other languages.
last.fm announcement: http://www.last.fm/group/Last.fm+Web+Servi...21604/_/2201974 (http://www.last.fm/group/Last.fm+Web+Services/forum/21604/_/2201974)
old screenshot showing the difference: https://dl.dropboxusercontent.com/u/2280132...20new%20bio.png (https://dl.dropboxusercontent.com/u/22801321/old%20new%20bio.png)
Stupid last.fm, oh well I have to agree with the decision.
samples updated. i made a quite a serious **** up about a week ago but no one has reported any problems. i won't mention what i did but this fixes it.
i also updated my
last.fm & wikipedia biography script. when in
wikipedia mode, i've tidied up the text by removing where it says
edit: on some section headers.
files changed:
marc2003\common7.js
Is it possible to do multiline tooltips? If yes, how exactly?
i don't think so.
I have a simple question.
I don't want to see the id 3 (Artwork id 3 Icon)
how must I modify the mouse wheel function?
I don't get it...
function on_mouse_wheel(delta) {
id -= delta;
if (id < 0) id = 4;
if (id > 4) id = 0;
window.SetProperty("id", id);
update_image();
id -= delta;
if (id == 3) id -= delta;
if (id < 0) id = 4;
if (id > 4) id = 0;
update_image();
Thank You!!! It's working
I played a litle bit with the SetInterval function.
I want on playback new track that the text pop up in my pannel.
But only once and not untill eternity...
here Is my modified code from page 80
// @name "TXT FX Alpha"
function RGB(r,g,b){return (0xff000000|(r<<16)|(g<<8)|(b));}
DT_LEFT=0x00000000;
DT_CALCRECT = 0x00000400;
DT_VCENTER = 0x00000004;
DT_SINGLELINE = 0x00000020;
DT_NOPREFIX = 0x00000800;
var special_font = "Calibri";
var font_h = 1;
var font_h1 = 12;
gr.GdiDrawText("XXXXXXXXXXXXXXX", gdi.Font(special_font, font_h, 1), RGB(0, 255, 0), 1,10, 404, 16, DT_LEFT | DT_CALCRECT | DT_VCENTER | DT_SINGLELINE | DT_NOPREFIX);
var TXT_Interval = 150;
var TXT_Timer;
var TXT_TimerStarted = false;
function onTXT_Timer() {
if (!TXT_TimerStarted) {
TXT_Timer = window.SetInterval(function () {
if (font_h >= font_h1) font_h = 0;
font_h += 1;
window.Repaint();
}, TXT_Interval);
TXT_TimerStarted = true;
function stopTXT_Timer() {
window.ClearInterval(TXT_Timer);
function on_playback_stop(reason) {
if (reason != 2) {
stopTXT_Timer();
function on_playback_pause(state) {
if (state) stopTXT_Timer();
else onTXT_Timer();
onTXT_Timer();
I hope somebody can help me.
Thank You
Try this.
font_h = 0;
font_h += 1;
if (font_h >= font_h1) {
stopTXT_Timer();
window.Repaint();
}, TXT_Interval);
Thank You Hunter!
Now it works.
Here is the Code...
// @name "TXT FX Working"
DT_CENTER = 0x00000001;
var size_a0 = 12;
var size_a1 = 12;
var size_b0 = 11;
var size_b1 = 11;
gr.GdiDrawText("FOOBAR", gdi.Font(special_font, size_a0, 1), RGB(0, 255, 0), 0,10, window.Width, 16, DT_CENTER | DT_CALCRECT | DT_VCENTER | DT_SINGLELINE | DT_NOPREFIX);
gr.GdiDrawText("2000", gdi.Font(special_font, size_b0, 0), RGB(0, 255, 0), 0,30, window.Width, 16, DT_CENTER | DT_CALCRECT | DT_VCENTER | DT_SINGLELINE | DT_NOPREFIX);
var TXT_Interval = 75;
var TXT_Timer;
size_a0 = 1;
size_b0 = 1;
size_a0 += 1;
size_b0 += 1;
if (size_b0 >= size_b1) size_b0 = size_b1;
if (size_a0 >= size_a1) {
stopTXT_Timer();
window.Repaint();
}, TXT_Interval);
onTXT_Timer();
Hi @marc2033, thanks for all your work.
I'm using Now Playing v1.4, and it's great. I've been trying to make a change, I want the thumbs to move forward one step on every image cycle.
I thought im.images was an array, so I've tried to do a .shift, and I've tried to change this.offset on every step, but I can't get it to work.
Is there some variable with the current image index? maybe I could use it to call this.wheel(index).
Let me know if it's feasible (and please consider a script update if you think it's worthy).
How do I get library RelativePath in wshpanel mod.
I`m coding "WSH libray search and viewer" but I don`t know how to get library RelativePath;
WSH panel mod (http://thanhdat1710.deviantart.com/art/WSH-library-search-V1-0-376360761)
@patanpatan, i might think about making that change but it won't be for a good few days.
@vothanhdat, there are no library features at all in WSH panel mod.
samples updated.
7.2013-06-09.01
"Thumbs" / "Now playing". Fix stupid bug where image cycle
mode would only work when the mouse pointer is over the
panel.
files changed:
marc2003\common7.js
antheo
Here's very simple script for rotating image on playback time.
var image = gdi.Image(fb.FoobarPath + "images\\vinyl.jpg");
var angle = 0;
gr.DrawImage(image, 0, 0, 500, 500, 0, 0, image.width, image.height, angle);
function on_playback_time(time){
if(angle >= 360) angle = 0;
angle += 60;
window.Repaint();
I tested it with this Vinyl image (http://www.senpaigamer.com/sites/default/files/news/sony/2012/03/21-black-panther-yakuza-2-ashura-original-vinyl-record-3.jpg)
Being a complete coding noob, how would I be able to get this to work with a folder not in the foobar media library stored with png files that have been saved as "%album artist% - %album%.png".
The other catch is that the filenames of the images are all lower case, while in the foobar media library they are effectively title case (I'm not sure if that makes a difference for wsh panel).
First off I'm a totally new to Jscript or WSH Panel Mod but I'm trying to create a skin for foobar so I need it.
What I'm looking for is a script for a seek bar which is a half circle which slowly progresses as the song progresses.
And a similar one for the volume control. Where full volume would be and complete half circle and muted no circle.
I was wondering if this is at all possible. And if so, if somebody can help me with it.
Greetings,
Pure
Example (PopupMenu): change and restore playlists.
foo_playcount is required to view the history and new.
// Use with MenuManager()
var MF_SEPARATOR = 0x00000800;
var MF_ENABLED = 0x00000000;
var MF_GRAYED = 0x00000001;
var MF_DISABLED = 0x00000002;
var MF_UNCHECKED = 0x00000000;
var MF_CHECKED = 0x00000008;
var MF_STRING = 0x00000000;
var MF_POPUP = 0x00000010;
var MF_RIGHTJUSTIFY = 0x00004000;
function on_mouse_lbtn_up(x, y, mask) {
switch_playlist_menu(x, y);
return true;
function isQueuePlaylistPresent() {
for (var i = 0; i < plman.PlaylistCount; i++) {
if (plman.GetPlaylistName(i) == "Queue Content") {
return i;
return -1;
function isLibraryPlaylistPresent() {
if (plman.GetPlaylistName(i) == "Library") {
return i;
return -1;
function isHistoryPlaylistPresent() {
if (plman.GetPlaylistName(i) == "History") {
return i;
return -1;
function isNewPlaylistPresent() {
if (plman.GetPlaylistName(i) == "New") {
return i;
return -1;
function ShowPlaylistQueue(focus_id) {
var total_pl = plman.PlaylistCount;
var queue_pl_idx = isQueuePlaylistPresent();
if (queue_pl_idx < 0) {
plman.CreatePlaylist(total_pl, "Queue Content");
queue_pl_idx = total_pl;
plman.ActivePlaylist = queue_pl_idx;
} else {
fb.ClearPlaylist();
var queue_total = plman.GetPlaybackQueueCount();
var vbarr = plman.GetPlaybackQueueContents();
var arr = vbarr.toArray();
var q_handlelist = plman.GetPlaylistSelectedItems(queue_pl_idx);
q_handlelist.RemoveAll();
for (var i = 0; i < queue_total; i++) {
q_handlelist.Add(arr[i].Handle);
plman.InsertPlaylistItems(queue_pl_idx, i, q_handlelist, false);
plman.SetPlaylistFocusItem(queue_pl_idx, focus_id);
function RenamePL(idx) {
fb.ActivePlaylist = idx;
fb.RunMainMenuCommand("File/Rename Playlist");
function switch_playlist_menu(x, y) {
var p = window.CreatePopupMenu();
var pr = window.CreatePopupMenu();
var act = plman.ActivePlaylist;
var ply_act = plman.PlayingPlaylist;
var prm = plman.PlaylistRecyclerManager;
var pl_count = plman.PlaylistCount;
p.AppendMenuItem(MF_STRING, 2000, "New playlist");
p.AppendMenuItem(MF_STRING, 895, "Autoplaylist...");
p.AppendMenuItem(MF_STRING, 2001, "Load playlist...");
if (pl_count >= 2) {
p.AppendMenuItem(MF_SEPARATOR, 0, 0);
for (var i = 0; i < pl_count; i++) {
if (plman.GetPlaylistName(i) != "New" && plman.GetPlaylistName(i) != "History" && plman.GetPlaylistName(i) != "Queue Content" && plman.GetPlaylistName(i) != "Library") {
var np = i == plman.PlayingPlaylist ? " (playing)" : "";
//var ap = fb.IsAutoPlaylist(i) ? "*" : "";
p.AppendMenuItem(MF_STRING, 2003 + i, plman.GetPlaylistName(i) + np);
try {
p.CheckMenuRadioItem(2003, 2003 + i, act + 2003);
} catch (e) {}
p.AppendMenuItem(MF_STRING, 983, "Show Library" + (plman.GetPlaylistName(ply_act) == "Library" ? " (playing)" : ""));
p.AppendMenuItem(MF_STRING, 981, "Show New" + (plman.GetPlaylistName(ply_act) == "New" ? " (playing)" : ""));
p.AppendMenuItem(MF_STRING, 980, "Show History" + (plman.GetPlaylistName(ply_act) == "History" ? " (playing)" : ""));
var q_count = plman.PlaylistItemCount(isQueuePlaylistPresent());
var count_plq = (q_count > 0 ? " - " + q_count + (q_count > 1 ? " songs" : " song") : "");
p.AppendMenuItem(plman.IsPlaybackQueueActive() ? MF_STRING : MF_GRAYED | MF_DISABLED, 982, "Show Queue" + count_plq);
var pl_prd = plman.GetPlaylistName(act) == "New" ? 981 : plman.GetPlaylistName(act) == "History" ? 980 : plman.GetPlaylistName(act) == "Queue Content" ? 982 : plman.GetPlaylistName(act) == "Library" ? 983 : false;
p.CheckMenuRadioItem(980, 983, pl_prd);
pr.AppendTo(p, prm.Count >= 1 ? MF_STRING : MF_GRAYED | MF_DISABLED, "Restore");
if (prm.Count >= 1) {
for (var irm = 0; irm < prm.Count; irm++) {
pr.AppendMenuItem(MF_STRING, 3001 + irm, prm.Name(irm));
var ret = p.TrackPopupMenu(x, y);
if (ret < 1000) {
switch (ret) {
case 980:
var history_pl_idx = isHistoryPlaylistPresent();
if (history_pl_idx < 0) {
fb.ActivePlaylist = fb.CreateAutoPlaylist(fb.PlaylistCount, "History", "%last_played% DURING LAST 1 DAY SORT DESCENDING BY %last_played%", "", true);
history_pl_idx = total_pl;
plman.ActivePlaylist = history_pl_idx;
} else {
fb.ClearPlaylist();
break;
case 981:
var new_pl_idx = isNewPlaylistPresent();
if (new_pl_idx < 0) {
fb.ActivePlaylist = fb.CreateAutoPlaylist(fb.PlaylistCount, "New", "%added% DURING LAST 1 WEEK SORT DESCENDING BY %added%", "", true);
new_pl_idx = total_pl;
plman.ActivePlaylist = new_pl_idx;
} else {
fb.ClearPlaylist();
break;
case 982:
ShowPlaylistQueue(0);
break;
case 983:
var library_pl_idx = isLibraryPlaylistPresent();
if (library_pl_idx < 0) {
fb.ActivePlaylist = fb.CreateAutoPlaylist(fb.PlaylistCount, "Library", "%path% PRESENT");
library_pl_idx = total_pl;
plman.ActivePlaylist = library_pl_idx;
} else {
fb.ClearPlaylist();
break;
case 895:
fb.ActivePlaylist = fb.CreateAutoPlaylist(fb.PlaylistCount, "", "");
RenamePL(fb.ActivePlaylist);
fb.ShowAutoPlaylistUI(fb.ActivePlaylist);
break;
} else {
switch (ret) {
case 2000:
fb.RunMainMenuCommand("File/New playlist");
break;
case 2001:
fb.RunMainMenuCommand("File/Load playlist...");
break;
default:
plman.ActivePlaylist = (ret - 2003);
if (ret > 3000) {
switch (ret) {
default:
(prm.Count >= 1) && prm.Restore(ret - 3001);
p.Dispose();
pr.Dispose();
return true;
I'm finding Marc's weblinks (preferrably small weblinks version) quite useful, but I dont like the idea of it needing to generate web traffic to gather the artist links from the json data everytime a song is played. Would it be feasable and efficient enough to store successful retrieval of such data in a textfile or some other database type using WSH, and having an update button to manually update? If so, is there a script around already which works with a text/db file that does the same thing so I might could try to build something like this on my own, rather than begging Marc to do it?
it already caches data for each artist. it is stored for one week before it checks again for updates.
Hey marc, thanks again for the scripts, I've been using them for a while now.
Just out of curiosity, is it possible to hide the buttons (Myspace/Discogs/Allmusic/etc) in the Now Playing script by commenting some of it out? Could you maybe point me to the lines I would need for that? Lines 69-73 seem to work, but I just want to double check.
Edit: I want to keep the Youtube button, so I tried swapping that one with the one that appears in the last line and commenting the rest out. It works okay at first, but then whenever I re-launch foobar all the buttons are back until I open the panel config and hit apply again. It doesn't help that I actually have no idea what I'm doing.
on line 60, replace the whole b.update function with this..
b.update = function() {
if (p.metadb) {
var artist = encodeURIComponent(p.eval("%artist%"));
var title = encodeURIComponent(p.eval("%title%"));
var youtube = "http://www.youtube.com/results?search_query=" + artist + "+" + title;
b.buttons.youtube = new button(im.x + im.w - 32, bar2y - 1, 32, 32, {normal: "youtube.png", hover: "youtube_h.png"}, function() { p.browser(youtube); }, youtube);
window.RepaintRect(0, bar2y, im.w, bar2h);
Works perfect, thank you!
Hi marc,
Is it possible to add blur effect for cover artwork?
pretty much like the background on Poweramp Music Player for Android : https://play.google.com/store/apps/details?...layer&hl=en (https://play.google.com/store/apps/details?id=com.maxmpz.audioplayer&hl=en)
one more thing, the last.fm charts codes from your sample, Is there any way to make the background transparent,
or at least change its color?
thank you very much!
you can draw any image you like behind the artwork display. are you looking to edit the CD jewel case or artreader panel?
as for the transparent background, edit line 9...
var p = new panel("Last.fm Charts", ["lastfm_charts"]);
so it becomes
var p = new panel("Last.fm Charts", ["lastfm_charts", "custom_background"]);
now you can right click the panel>Background>None (None only appears when using columns UI - it's obviously not available when using default UI)
thanks marc,
the artreader panel, so the bigger & blurred artwork for the background, and draw the smaller one on top of it (with shadow effect if it's possible).
i'll be honest and say i don't really know what you mean. i can't make anything out from the screenshots in that link as they're all very small on a 1080p screen - i guess the page is more optimised for mobile devices.
also, i should say i'm useless at making things look pretty so i doubt i'd be able to implement it anyway.
sorry my bad
here's what I meant anyway : http://tinypic.com/r/2iup7oj/5 (http://tinypic.com/r/2iup7oj/5)
if that background image is dynamically generated from the colours in the artwork, i can't do that. it would be possible to use your own "wallpaper" image as a background. the shadow effect should be possible but i don't know how. i'll have to dig around and see if i can find someone else's code that does it.
hopefully someone with more artistic flair will read this and have a suggestion.
sorry my bad
i like the idea, i may consider it for a art cover panel
here's a couple of quick bodge jobs i've made. it requires the marc2003 folder from my samples package and also this image saved inside your foobar profile marc2003\images folder.
https://dl.dropboxusercontent.com/u/2280132.../july/splat.jpg (https://dl.dropboxusercontent.com/u/22801321/2013/july/splat.jpg)
if you want to use your own background, you can edit the filename on line 14.
first one is just a plain front cover on the background...
screenshot - https://dl.dropboxusercontent.com/u/2280132...3/july/art1.png (https://dl.dropboxusercontent.com/u/22801321/2013/july/art1.png)
download - https://dl.dropboxusercontent.com/u/2280132...3/july/art1.txt (https://dl.dropboxusercontent.com/u/22801321/2013/july/art1.txt)
the second one has a seekbar and track details.
screenshot - https://dl.dropboxusercontent.com/u/2280132...3/july/art2.png (https://dl.dropboxusercontent.com/u/22801321/2013/july/art2.png)
download - https://dl.dropboxusercontent.com/u/2280132...3/july/art2.txt (https://dl.dropboxusercontent.com/u/22801321/2013/july/art2.txt)
(note the right click options to change centre/crop/stretch do not work. i'm not going to edit my common file just for this)
Is there a way to send a command that jumps to the currently playing playlist, and highlights the playing track?
Basically I'd want a button that does the exact same thing as double clicking the status bar.
I know how to make the button I just don't know what the command would be, or if it is possible!
thanks!
edit: this is in DUI if that is relevant.
Well, I've found a solution if anybody else turns out to be curious, no thanks to me, but to finding the necessary code in a coverflow panel by "Br3tt aka Falstaff."
It used this function (very slightly modified to remove dependencies):
function ShowNowPlaying() {
if(fb.IsPlaying) {
if(plman.PlaylistItemCount(plman.PlayingPlaylist)==0) {
return true;
plman.ClearPlaylistSelection(plman.PlayingPlaylist);
var nowplaying = plman.GetPlayingItemLocation();
var pid = nowplaying.PlaylistItemIndex;
if(pid>=0 && pid<plman.PlaylistItemCount(plman.PlayingPlaylist)) {
plman.SetPlaylistFocusItem(plman.PlayingPlaylist, pid);
plman.SetPlaylistSelectionSingle(plman.PlayingPlaylist, pid, true);
plman.ActivePlaylist = plman.PlayingPlaylist;
} else {
if(plman.PlaylistItemCount(plman.ActivePlaylist)==0 || !fb.GetFocusItem(false)) return true;
plman.ClearPlaylistSelection(plman.ActivePlaylist);
var pid = plman.GetPlaylistFocusItemIndex(plman.ActivePlaylist);
plman.SetPlaylistFocusItem(plman.ActivePlaylist, pid);
plman.SetPlaylistSelectionSingle(plman.ActivePlaylist, pid, true);
I'm not sure what the purpose of the code in the else statement is though, it appears to behave the same without it.
when I last worked on my foobar config, WSH panel was just released... and turns out I completely underestimated the potential of this component. What you guys accomplished is beyond amazing
@Marc2003:
I am just trying to adapt some of your great panels for my config, and I stumbled upon a small issue concering the last.fm panel (and similar) when using "Selection Mode / Use Display Preferences" (set to "prefer current selection" in Preferences):
When I select a group in el_playlist by clicking on the group header, the panels switch back to the now playing artist for a very brief moment. Only happens during playback/pause, its fine while stopped.
Some function (item_focus_change() I think) is triggered twice, probably because el_playlist clears the selection before making a new one, or something like that.
I tried fixing it myself by adding a tiny delay time in various parts of the script, without success (obviously...). I'm afraid this is to difficult for me, just having started with WSH panel and having next to no JScript experience
Anyways, thanks for those awesome scripts
i can't seem to reproduce that issue but i know the selection can change back to now playing when the playlist loses focus. i guess you're seeing this.
instead you can right click panel>selection mode>follow selected track. that should always stay with selection even when the playlist loses focus.
That album background camouflage effect is cool I always wished this was possible with channel spectrum so the spectrum bars changed colour with the album art above.
well, thats probably because I have a kind of unusual setup... I use two playlists that are visible all the time, one for playback and one for viewing the library. The playback one is always kept active (I use a script for that).
"Follow selected track" doesn't work well for that, it sticks to one playlist
Still a bit confused how all of this works, with focused/selected items/playlists....
Anyway, I found a solution:
function on_selection_changed() {
nowplaying = fb.GetNowPlaying()
focused = fb.GetSelection()
if (fb.IsPlaying && fb.TitleFormat("%artist%").EvalWithMetadb(nowplaying) == fb.TitleFormat("%artist%").EvalWithMetadb(focused)){
var timer
timer = window.SetTimeout(function (){
p.item_focus_change();
}, 200);
} else {
Same for on_item_focus_change
I know, hideous code, there gotta be a more elegant method of comparing the playing and the selected item, but I couldn't figure it out and used something i found somewhere.
But it solved my problem and only adds this tiny delay when its necessary.
What could improve this solution is if I could determine the reason for the selection change- wether it was because I made a new selection or whatever el_playlist does on group selection that causes the selection to jump to now playing.
But I guess thats not possible, or is it?
Doesn't really matter, what I got now is good enough
I wonder if you guys could help me. I'm using Br3tt/Falstaff's WSH Playlist this one here (http://br3tt.deviantart.com/art/WSH-Playlist-2013-v0-0-8-368997689), and I'm trying to get the artist image to display as a wallpaper.
I CAN get it to work when I place the artist.jpg in the album folder. BUT, some artists I have have over 20 albums or so, and rather than having the same artist image in every folder, I would like to just have the artist.jpg saved in the I:\Music\Artist folder. My Library is set up "Music\Artist\Albums".
I am using Biography Server which automatically downloads the artist.jpg from last.fm, the script I am using to save the image to the artist folder is
$replace($directory_path(%path%),\%directory%,)\artist
Which is working fine. What I am struggling with however, is getting the WSH Playlist to look here for the artist image.
(http://i.imgur.com/mPa6QhA.png)
I've also tried using the same code in Preferences>Display>Artist, but it's not working.
CUSTOM Default Wallpaper Path is ... for the default Wallpaper when no "artist" pic is found, so just point the path to a single picture you want to use for this usage.
so, now, to get artist picture from a centralized folder like you want (and like i do), it's quite easy:
1) be sure that all your artists images are saved in this folder and named with the artist name plus the file extension (.jpg i asume)
2) in fb2k Preferences > Display > "artitst" tab, enter the path of this centralized folder with the pattern thaht match the filename of the image of course, in our case, the TAG %artist% give the name of the filname right ?
so enter this: I:\Music\Artist\%artist%.jpg
3) nothing else, the WSH panel properties are already set : CUSTOM Show Wallpaper AND CUSTOM Use Artist Image As Wallpaper are already set to TRUE
HTH
HTH
YES, thank you it's working.
In the Biography Server Last.fm section, I have the cache file path set to:
I:\Documents\Foobar\Artist\%artist%
And under Preferences>Display>Artist I have:
Thanks again, man. Such a good WSH Playlist.
one line is enough
I:\Documents\Foobar\Artist\%artist%.*
one line is enough
Ah, learn something new every day. Cheers.
Hi marc,
can you show me how to turn the rating panel from horizontal mode to vertical? pretty much like this :
(http://i42.tinypic.com/2u88mx0.jpg)
by the way thanks for your help on previous posts, I'm sure I posted thanks but it's deleted somehow.
it would take very large changes to make that work. i might have a go if i get bored over the weekend.
I have found a way for that, thanks
Eh?
Meaning you found a solution and then signed a NDA with yourself?
Edit: Typo
doing it top/down is easy enough. but i was thinking it would look better with 1 star at the bottom and working upwards towards 5. that would have required a bit more effort. which way did you do it?
Eh?
Edit: Typo
sorry I don't understand what you mean
from top to bottom, it's more suitable on my skin.
Since I also use the default horizontal layout, I copy the code from common7.js file, paste it to WSH Panel then edit it.
// ==PREPROCESSOR==
// @import "%fb2k_path%skins\tests\Scripts\common7.js"
// @name "Rating"
// @author "marc2003"
// @feature "v1.4"
// @feature "watch-metadb"
// ==/PREPROCESSOR==
function rating(x, y, bs) {
this.draw = function(gr) {
if (!p.metadb) return;
for (i = 1; i < 6; i++) {
this.img = i > (this.hover ? this.lrating : this.rating) ? this.off_img : this.on_img;
p.draw_image(gr, this.img, this.x, this.y + this.bs * (i - 1), this.bs, this.bs, "centre");
this.metadb_changed = function() {
if (!p.metadb) return false;
this.hover = false;
this.rating = p.eval("$if2(%rating%,0)");
this.tiptext = p.eval(this.tiptext_tf);
this.lrating = this.rating;
window.RepaintRect(this.x, this.y, this.bs, this.w);
return true;
this.trace = function(x, y) {
return x > this.x && x < this.x + this.bs && y < this.y + (this.bs * 5) && y > this.y;
this.move = function(x, y) {
if (!this.trace(x, y)) {
if (this.hover) this.leave();
return false;
if (p.metadb) {
if (y > this.y) p.tt(this.tiptext);
this.hover = true;
this.lrating = Math.ceil((y - this.y) / this.bs);
return true;
this.lbtn_up = function(x, y) {
if (!this.trace(x, y)) return false;
if (this.check) {
if (this.lrating != this.rating && this.hover == 1) fb.RunContextCommandWithMetadb("Rating/" + (this.lrating == 0 ? "<not set>" : this.lrating), p.metadb, 8);
} else {
p.MsgBox(this.error_text, 0, p.name);
p.browser("http://www.foobar2000.org/components/view/foo_playcount");
return true;
this.leave = function() {
p.ttd();
this.hover = false;
this.x = x;
this.y = y;
this.bs = bs;
this.w = this.bs * 5;
this.hover = false;
this.rating = null;
this.lrating = null;
this.img = null;
this.off_img = gdi.Image(p.images_path + "off.png");
this.on_img = gdi.Image(p.images_path + "on.png");
this.check = utils.CheckComponent("foo_playcount", true);
this.error_text = "This script requires foo_playcount.";
this.tiptext_tf = this.check ? 'Rate "%title%" by "%artist%"' : this.error_text;
var p = new panel("Rating", ["custom_background", "metadb"]);
p.version = "7.2013-04-02.01";
p.filename = "rating.txt";
var r = new rating(0, 0, 18);
p.check_version();
on_item_focus_change();
function on_size() {
p.size();
r.x = Math.round((p.w - r.w) / 52);
r.y = Math.round((p.h - r.bs) / 5);
function on_paint(gr) {
p.draw_background(gr);
r.draw(gr);
r.metadb_changed();
r.move(x, y);
r.lbtn_up(x, y);
I need a smaller panel, so I resized it too.
sorry my bad
I noticed no one responded to your question about this. I can't give you exact code for your theme, but this should give you a place to start.
You'll need to have two copies of the album art. This code assumes you're loading the album art into an image called albumart. I'd suggest, loading it once and then drawing it into the background image like so:
bgImage = gdi.CreateImage(1920,1080);
background = bgImage.GetGraphics();
background.DrawImage(albumart, 0, 0, 1920, 1080, 0, 0, albumart.Width, albumart.Height);
bgImage.ReleaseGraphics(background);
bgImage.BoxBlur(40, 5);
I went with a medium amount of BoxBlur and then 5 iterations which should give you a nice diffuse background image.
Then just draw bgImage to cover the panel and draw albumart on top of it. I didn't test this code, so apologies if there are any bugs.
Hi, thanks for your response. I'll test it as soon as I can
um.... http://www.hydrogenaudio.org/forums/index....st&p=839573 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=77883&view=findpost&p=839573)
admittedly mine uses a static background wallpaper so if yours generates nice colours on the fly then it is better.
var angle = 0;
angle += 60;
window.Repaint();
ExtremeHunter please can you help me?
I use WSH panel mod 1.4.2. I can't use new version, because it brakes my skin.
This skript work's good, but it is slow. How to set speed in WSH panel mod 1.4.2?
Seems to older version don't recognize ''window.ClearInterval'' , ''window.SetInterval'' and simmilar action's..
I slightly modified the old spinning disc script so that you can use it with 1.4.2 wsh panel mod. pastepin link (http://pastebin.com/nfnwQWK8)
Oh, Thank's Extreme Hunter, you're the best
Hi ExtremeHunter, last time I tried your spinning disk script (for the current version of wsh panel mod, the rotation wan't as smooth as I expected. Is it possible to simulate the effect on this website: http://fanart.tv/artist/477b8c0c-c5fc-4ad2...uuren-van-armin (http://fanart.tv/artist/477b8c0c-c5fc-4ad2-b5b2-191f0bf2a9df/buuren-van-armin) (scroll down to the CDART section)? I'd also like to be able to have the image be linked to actual CDart saved in same folder as the album with the naming scheme: [CD Art] %album artist% - %album%
My spinning disc script already does that, you need to set disc image location in foobar Preferences->Display->Disc
"the rotation wasn't as smooth" This component is not meant for such a heavy animation.
I have a novice question as I am a novice .. but I've not been able to understand what is causing a panel to react as it does ..
I have some simple code that I downloaded that displays "now playing" info in a wsh panel. The panel works fine. But, when I right click on the mouse .. it shows a menu for properties and configuration and I can click on "configuration" and go into edit regardless of whether I have layout editing mode enabled or not. All of my other panels do not react to a right mouse click this way.
I want to disable the "configuration" menu unless I have "layout editing" enabled.
The code in this panel has no "right mouse" button functions defined ..
The code in this panel has no functions working with the popup context menu ...
There are no pre-processors loading other code. ...
Can someone explain why I get this context popup menu on right click with layout edit mode disabled (and not for other panels).... and how I may disable it so one can not go into configuration edit unless layout edit mode is enabled?
add this function to your wsh panel script
return true;
thanks. adding that fixed the problem ... I'm not sure how I could have figured that out on my own ...
I don't see problem in animation. You can simulate that smooth efect from website..
I got the same speed and smooth like in website..
Go to script and set ''angle += 1''
, and ''var rotationInterval = 15;'' .
Set rotationInterval speed how you like..
Hope that helps..
I made a modified xch4nge menu, which allows you to easily add as much panel and WSH scripts in CUI, as you want: http://mire777.deviantart.com/art/xch4nge-...oobar-359868460 (http://mire777.deviantart.com/art/xch4nge-can-acts-as-the-DUI-foobar-359868460)
But I noticed that when you starting foobar, if you have a lot of WSH panel, it parsing all WSH script together at startup.. Even if you don't have all that panel active, it start all WSH, and thus slows down the rising time.
Is there a way to make something, which would specify to raise only selected WSH scripts in selected panel at startup, and others to be inactive?
Or to specify that in each script separately ?
I'm trying to find a way to disable-enable installed WSH script at startup...
you can try the delay load checkbox in the editor. but having numerous scripts really shouldn't affect startup time much at all. i guess it depends on what your script does. i have 17 scripts in my layout and it adds 0.2 seconds to the startup time compared to without. that's nothing in the grand scheme of things.
Well i have 12 scripts, and startup time is 0.04 sec. It's nothing, but it would be good to add something, that would (disable-enable) script that I don't use that often.
Maybe some WSH client, with dropdown menu, then i can choose, what script i want to use in that panel..
But I don't know if it would help at all..
Marc, i edited your script to show 'album art' on my WSH 1.4.2. , and it works beautifuly. There's no better script anywhere. No image distortion at all, like in other script i try.
But i have small problem, when i click on button in xch4nge to enlarge panel, image for a short shaking, then stop.
It happens especially when the image is large..
Do you know what causes this? And can you help me to fix this?
Here is script: http://pastebin.com/pCTpyvDD (http://pastebin.com/pCTpyvDD)
i have no idea what you mean by this. all i know is that my script behaves just like any other panel when resized normally in a standard default UI or columns UI layout. i'm certainly not downloading the theme to test it.
perhaps the issue is with the panel stack splitter code used to resize panels? have you tried other panels in its place?
I tested, it behaves normal in DUI, but in xch4nge it has some interaction with WSH panel stack splitter, because it has fast resizing..
Sorry I bothered you with that...
May I ask a question, How to show or hide a Columns UI panel using WSH script ?
quick reply on the way to do it but not a full example (not time and no example on the hand ... just how i've done it in my skin TECH for example ==> http://br3tt.deviant.art (http://br3tt.deviant.art))
So, the only way i've found (and use) is to use file as parameters, to share/update panel status between a WSH panel (the WSH panel create the file, update its status on action in the WSH panel) and a Panel Stack Splitter in Columns UI (use the $findfile command to read the file created from WSH panel to get the value of the status, 0 panel is to hide (cf. $showpanel ... commands , read Panel Stack Splitter help file for more information)
that's it.
for example, if i want to hide/show a panel like "album list", in the WSH panel, i create in a settings folder (i.e foobar2000/WSH_settings/) the file "albumlist_0"
and in the PSS panel, i get the last character of the filename that begins with "albumlist_" with $right($findfile(albumlist_*),1) and so i retrieve "0" or "1", depending of that value with a $select, i execute a $showpanel_c(...) set to visible or hidden of the album list panel...
tips, when updating the file from WSH, to force Panel Stack Splitter to refresh, you have to code in the WSH panel a Pause & Play foobar2000 command
there is the function i use to do it:
function RefreshBG() {
if(fb.IsPlaying||fb.IsPaused) {
fb.RunMainMenuCommand("Playback/Play or Pause");
} else {
fb.RunMainMenuCommand("Playback/Play");
fb.RunMainMenuCommand("Playback/Stop");
HTH
@Falstaff : Thanks you so much!
I am sorry, May I ask is it possible to drag&drop new songs like below?
for example:
playlist before drag&drop
1. SONG ONE
2. SONG TWO
playlist after drag&drop (I want to drop "SONG THREE" between "SONG ONE" and "SONG TWO")
1. SONG ONE
2. SONG THREE
3. SONG TWO
but not
1. SONG ONE
2. SONG TWO
3. SONG THREE
I am now viewing the old replies on this post, but it's very long, hope anyone can help me.
thank you very much
Could someone tell me where to download the latest samples from please ?
(I think i'm interested in thumbs.txt and last fm bio etc)
The links I've found here seem to be down
Thanks a lot
here: https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip (https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip)
make sure to check the readme. also, i saw your other post about reading the contents of a text file. there is a script in here called simple text reader which can do that.
ExtremeHunterI've been playing around again with your
Spinning Disc Image Viewer script, version 2013-08-08, which you pasted online here [pastebin.com] (http://pastebin.com/nfnwQWK8) .
I've been editing your script for the past few hours, trying to create a context menu having these three items:
Open folder of this disc
Open folder of this panel
Configure...-------------------------------
The context menu works except for
one problem . . . . . Selecting "Open folder of this disc" opens the "Now Playing" folder and the active track is selected in Windows Explorer.
Unfortunately, this is not what I want . . . . . What I want is to open the folder containing the current spinning disc image and the image is selected in Windows Explorer.
Here is the code I have added to your script:
var WshShell = new ActiveXObject("WScript.Shell");
var fso = new ActiveXObject("Scripting.FileSystemObject");
var folder_path_disc = metadb ? metadb.Path : "";
var folder_path_panel = fb.ProfilePath + "user-addons\\wsh-spinning-disc-image";
var _menu = window.CreatePopupMenu();
var idx = 0;
_menu.AppendMenuItem(fso.FileExists(folder_path_disc) && metadb ? MF_STRING : MF_GRAYED, 1, "Open folder of this disc");
_menu.AppendMenuItem(fso.FolderExists(folder_path_panel) && metadb ? MF_STRING : MF_GRAYED, 2, "Open folder of this panel");
_menu.AppendMenuItem(MF_STRING, 100, "Configure...");
if (idx == 1) try {
WshShell.Run("explorer /select," + "\"" + folder_path_disc + "\"");
catch(e) { }
if (idx == 2) try {
WshShell.Run("explorer /n," + folder_path_panel);
catch(e) { }
if (idx == 100) window.ShowConfigure();
_menu.Dispose();
return true;
NOTES:
I use foobar2000 in portable mode.
All default resources used for this panel are contained in one folder: "<fb2k_dir>\user-addons\wsh-spinning-disc-image\"
All disc image targets for the script are placed at the same location as the tracks.
ONE MORE QUESTION:
If I was to add one more context menu item named
Help, and if this is selected a Message Box pops up with some text,
does anybody have the code for doing this?
fb.ShowPopupMessage("Some help text.", "Window title");
you can put in
\n if you want line breaks. i'll let Extremehunter answer the rest.
edited: i forgot you can customise the window title as well but it's optional. if you omit it, it will just display
WSH Panel Mod.
derty2
pastebin link (http://pastebin.com/gzexrerN)
i think derty2 was asking for it to work in portable mode. this line of code only works on a standard install.
var folder_path_panel = WshShell.ExpandEnvironmentStrings("%APPDATA%") + "\\foobar2000\\user-addons\\wsh-spinning-disc-image";
you should use
fb.ProfilePath as that caters for both scenarios. it points to
%appdata%\foobar2000 when running a standard foobar install. if running a portable install, it points directly at the foobar2000 program folder.
I know fb.ProfilePath .
I misunderstood "<fb2k_dir>\user-addons\wsh-spinning-disc-image\"
I tried to access default installation %appdata% <fb2k_user_profile_dir> from portable version
<fb2k_dir>
i'd assume that to mean the program folder, not
%appdata%\foobar2000.
your code would only work if his portable install was inside his %appdata% folder. why hardcode something when you have the flexibility to let people use whatever mode they like and if using portable mode, they can put their foobar folder anywhere and it will just work.
edit: i see you've edited your post. hopefully it's cleared up now.
Sorry for the stupid questions, but i need help.
Which function to call to cycle image. I want to cycle the front, back and icon image, and set time delay for that.
Here is script: http://pastebin.com/jvQ9z6Jc (http://pastebin.com/jvQ9z6Jc)
this might work (untested)
window.SetInterval(function() {
a.id++;
if (a.id > 4) a.id = 0;
a.metadb_changed();
}, 5000);
the 5000 is milliseconds. you can edit that bit.
a.id++;
a.metadb_changed();
}, 5000);
I got error: object doesn't suport that property or metod. i guess that is because i use wsh 1.4.2.
var timer = window.CreateTimerInterval(5000);
function on_timer() {
a.id++;
a.metadb_changed();
a.id++;
a.metadb_changed();
Oh, works great now.. thank you so much Marc !
ExtremeHunterThankyou for the new script of your
Spinning Disc Image Viewer, version 2013-09-12, pasted online here [pastebin.com] (http://pastebin.com/gzexrerN)
I still have a problem with your edition of the context-menu item
Open folder of this disc; it doesn't work exactly as I want.
I performed this action in foobar2000 (with your new script):
Start playing a track whose containing folder is known to contain a target disc image . . . Panel displays the target disc.
Right click the Panel and choose "Open folder of this disc" . . . Explorer opens with target disc selected.
While playback continues, change playlists.
Start playing a track whose containing folder is known to not contain a target disc image . . . Panel displays the default disc.
Right click the Panel and choose "Open folder of this disc" . . . Explorer opens with previous target disc selected !!!!!!!!!!
Stopped playback and restarted foobar2000 (to refresh all).
Start playing the track whose containing folder is known to not contain a target disc image . . . and the Panel displays the default disc.
Right click the Panel and choose "Open folder of this disc" . . . and the context-menu item "Open folder of this disc" is grayed out.
It seems there is some kind of refresh bug.
What I specifically want from the the context-menu item
Open folder of this disc is this:
. . . never be grayed out; this context-menu item is always selectable.
. . . if default disc is showing, then Explorer opens with default disc selected.
. . . if target disc is showing, then Explorer opens with target disc selected.
Your code needs to be modified with some kind of IF...ELSE statement for the context-menu item. Can you please have another look. Thanks ++++
_______________________________________________________________
I also enhanced your script with more functionality.
I added this code (read the comments):
// --- mouse left-click effects.
// --- simulate putting your finger on the turntable platter stopping it from spinning,
// --- and playback pauses until mouse is released.
function on_mouse_lbtn_down(x, y) {
if (!fb.IsPaused) fb.Pause();
else return;
if (fb.IsPaused) fb.Play();
else return;
function on_mouse_lbtn_dblclk() {
marc2003 - thanks a lot for the code to make the popup message box +++++++
Sorry I forgot to add default image path before.
It should work now.
pastebin (http://pastebin.com/gzexrerN#)
ExtremeHunter, thankyou for the new edit to the script. It has fixed the "Default Disc vs. Target Disc" issue ++++
Unfortunately for me, I noticed
another problem with your current script . . .
In my foobar2000 at "
Preferences > Display > Album art - Disc (tab)" I have this search pattern:
disc*[%discnumber%].*It is only one line; I have no other search patterns for 'Disc'.
My tagging scheme for Vinyl Rips is to use the
%discnumber% tag as a reference to the sides ...and to choose a disc image to load.
EXAMPLE 1:
A 1-LP album having 4 tracks: 2 are on Side-A | 2 are on Side-B
- The folder containing the tracks will have two disc images: disc-a.jpg, disc-b.jpg
- In the %discnumber% Tag of the tracks:
Track No: 1 has value: A
Track No: 2 has value: A
Track No: 3 has value: B
Track No: 4 has value: B
EXAMPLE 2:
A 2-LP album having 8 tracks: 2 are on Disc-1/Side-A | 2 are on Disc-1/Side-B | 2 are on Disc-2/Side-A | 2 are on Disc-2/Side-B
- The folder containing the tracks will have four disc images: disc-1a.jpg, disc-1b.jpg, disc-2a.jpg, disc-2b.jpg
Track No: 1 has value: 1A
Track No: 2 has value: 1A
Track No: 3 has value: 1B
Track No: 4 has value: 1B
Track No: 5 has value: 2A
Track No: 6 has value: 2A
Track No: 7 has value: 2B
Track No: 8 has value: 2B
The current script does not take into account my artwork loading preference for disc image, which is conditional on the discnumber tag.
I'm not sure where in your script I can make the appropriate edit.
FYI, I had the same problem with the WSH Vinyl Turntable script by
marc2003, and marc helped me to fix it. See this post here... (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=830405)
Thanks +++++
One more feature request (if you are going to dig into the code again). . .
I want to add another right-click context menu item named
Resize disc to fit the panelI have no idea what the code is for this. Do you have some code for this please.
Thanks again ++++++
* EDIT *ExtremeHunter, you can ignore the first part of my post (regarding loading multiple disc images for an album) . . . .
I fixed it!I had another read of my discussion with marc2003 and dived into your code myself. The fix was pretty much identical, change one line like this:
old: var currentAlbum = fb.TitleFormat("%album%").EvalWithMetadb(metadb);
new: var currentAlbum = fb.TitleFormat("%album%%discnumber%").EvalWithMetadb(metadb);
Added Fit image to context menu.
pastebin (http://pastebin.com/gzexrerN)
Marc, i set Auto Cycle Image, i only have one question. How to tell script to skip image if no exist in attached pictures? I want that cycling always be on, and if more image exist then to cycle, if not then to show only front image?
http://pastebin.com/MpAUVKcg (http://pastebin.com/MpAUVKcg)
line 350 is this:
this.img = utils.GetAlbumArtV2(p.metadb, this.id);
insert this after it.
if (!this.img) {
this.id++;
if (this.id > 4) this.id = 0;
this.metadb_changed();
return;
i see a lot of your global callbacks at the start contain these 2 lines.
a.metadb_changed();
you can remove the first line because it gets called as a result of the p.item_focus_change function.
line 350 is this:
if (!this.img) {
this.id++;
return;
a.metadb_changed();
ok, i enter this line , but it still cycle image
it cycles images that are present but skips any type that is missing. that's what you asked for? previously it would sit waiting with a blank screen if there wasn't an image for the current type.
mire777
I also improved your timers, they were mess.
pastebin (http://pastebin.com/dsTqY6G1)
oh yes after i clear properties, it work's. Thanks Marc
thank's ExtremeHunter i will try how it work
ExtremeHunter thanks again. I tried your script edit, works much beter than mine. But i was have error ''out of memory'', and foobar crashes if i didn't set ''no artist image'' in preferences..
Also i can't change front,back,icon... manualy from menu.
*EDIT: ok, it can do that because auto cycle is on.
I try to fix this...
I edited script, and fix problem.
Thanks Marc and ExtremeHunter for help..
http://pastebin.com/qe9ysR2s (http://pastebin.com/qe9ysR2s)
I have a problem with display of special characters. The same code results in a different outputs in two different panels.
In the first WSH panel is the following line of code:
gr.DrawString("★", gdi.Font("segoe ui symbol", 17, 1), RGB(250,0,0), 10, 10, ww, wh);
The result is to display the "★" properly.
I now cut and paste the same code into a different WSH panel within the same application. In this panel, the displayed output is completely different:
The result is something like this (as shown between the quotemarks): "â~..."
What would cause the code to display the star differently in the second panel?
marc2003, can't state strongly enough how much I enjoy your scripts. I use your Musicbrainz script quite a bit to understand the releases of artists as I play music, and appreciate the ability to use the primary and secondary filters you've included. It would be great if you could consider adding filters for MB secondary types of "compilation" and "remix" (in addition to the existing filter for the secondary type of "live"). If it's a pain, don't bother, but if straightforward it would be much appreciated.
done. just right click>Update script.
full download here: https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip (https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip)
changelog: https://dl.dropboxusercontent.com/u/2280132...h/changelog.txt (https://dl.dropboxusercontent.com/u/22801321/wsh/changelog.txt)
Thanks - works great!
I need help..
I played a little with Br3tt Library Search, and add some genre preset, and change the look: http://pastebin.com/twt4qigJ (http://pastebin.com/twt4qigJ)
I love how it works...
The only thing I don't know is how to tell script to search, not only Library but single playlist?
Does anyone know how to do that?
Hey guys, I'm working on a rather large WSH script which has as an optional feature the lyrics panel that Falstaff wrote 3 years ago. He (and now I) is using the FSO object to open the text files on your computer and then parsing and displaying them. This works great, except for the little problem with Unicode characters. They show up as gibberish on the screen.
Someone asked him about the Unicode issue, and he said it wasn't possible to read them correctly from files (http://www.hydrogenaudio.org/forums/index.php?showtopic=77883&view=findpost&p=731871). I'm not entirely convinced this is true, because the FSO.OpenTextFile function has an optional 4th parameter, where if you pass -1 you can open the file as Unicode (http://www.w3schools.com/asp/met_opentextfile.asp). However, when I do this, it's not just the unicode characters that are gibberish, it's even the ASCII characters. Last file I tried it on had Unicode apostrophe's and when I open it as Unicode, the entire thing shows as Chinese characters for some reason. Has anybody seen this before and figured out how to work around it?
i use utils.ReadTextFile(filename).
Well that simplifies things quite a bit and I can rip out all the old FSO stuff that Falstaff was originally using (in rereading this thread it seems that at some point he did the same although he never published that code), however I still have the same problem. My .lrc files which have unicode in them are still showing the unicode characters as gibberish:
See for yourself with the following sample .lrc file (https://dl.dropboxusercontent.com/u/23987869/Halford%20-%20Temptation.lrc).
My code essentially looks like this:
fb.trace(utils.ReadTextFile(pathName));
and the first line of lyrics is shown in the console as: [00:19.29]I know what’s going on inside your crooked mind
Obviously I can keep doing what I'm doing, and replace special characters that I know about, but this won't work for lyrics with foreign characters in them which seems extremely bad.
that function takes an optional argument of a codepage...
utils.ReadTextFile(filename, codepage)
there is a codepages.txt file listing them all in the docs folder of the component but i tried the one for your file and it doesn't work
utils.ReadTextFile(filename, 28605);
it changes slightly but it's still not right.
edit: codebox removed, the forum or browser is mangling what WSH panel mod is displaying. it looks like this...
(https://dl.dropboxusercontent.com/u/22801321/2013/september/wrong.png)
can you change how the lrc files are saved in the first place? other than that, i have no idea. i'll be honest and say i don't really understand all this codepage stuff because i've never needed it.
Thanks for looking into it.
As far as I know, nothing is happening to the lrc files when they're saved. I just use the lyrics_show_panel3 to download them because I don't have the capability to search and don't want to reinvent the wheel when someone is doing it much better than I could. What I don't get is why the lyrics can load perfectly in every other editor, but not from WSHPanelMod.
After further playing around with it, and doing a little light reading, it turns out that the encoding listed is actually wrong. There's also no way to read the codepage from the file. You either have to know it, or you have to guess it using heuristics, which is seemingly what almost everybody does.
Loading that file as UTF-8 (codepage 65001) correctly fixes everything. Of course, that's only useful for 8-bit characters. If I were to get a UTF-16 file (i.e. Japanese lyrics) it would completely barf on them. Not sure what I can do about that. I'll see if things are generally okay with Roman alphabets if I use 65001 for everything.
Edit:
Actually, I'm wrong and stupid. UTF-8 can handle multibyte characters (i.e. Japanese)... that's why they are multibyte in the first place. UTF-16 would be 16-bit wide characters and isn't very common. Since UTF-8 is the web standard, and typically these lyrics are being downloaded from the web I think it's safe to assume that's what they are. I'll test it and make sure, but I think I'm okay now.
I interested for lyrics script you work, i also edited falstaff lyrics, and add posibility to force save option in lyrics show 3, so you can see lyrics at first play, exactly in same time when it's find from net.. http://mire777.deviantart.com/art/Lyrics-R...h4nge-393946997 (http://mire777.deviantart.com/art/Lyrics-Reader-For-Xch4nge-393946997)
Please upload your script when you finish. Thanks..
I found a way to disable WSH script to load on startup and parsing file if their panel is hidden.
This is useful if you have a lot of scripts that are not in use.
(http://imageshack.us/a/img407/163/8lm.png)
You can see that 'Tabed Playlist', 'Album Art' and 'Spinning disc' are initialized in 0 sec.
This can be done simply adding backslash before @import.
//==PREPROCESSOR==
//@name"Tabed Playlist"
///@import"%fb2k_profile_path%scripts\WSH scripts\Tabed Playlist.txt"
//==/PREPROCESSOR==
I think now if posible to make some menu, that can manipulate with this caracter at the beginning, and disable-enable script in panel.
If that menu initialize on startup in 5sec or less it can be useful, because it will consuming less memory than script do on startup..
really? doing that breaks my scripts because the file isn't loaded at all.
as for delaying load, what is the point? we're talking fractions of a second on startup. i have 17 scripts taking around 0.4s. honestly, what is this going to affect.... nothing.
edited: my scripts add around 0.4s to foobar's startup time, not 0.3s as i said originally.
This is pointless as marc2003 already mentioned. Besides this, this is not possible anyway.
Yes it stops, and you can enable script later if you want to use it again.
It is useful, because you can't have all script active in same time,it waste your space, it's not possible..(but they are running in the background, even if you don't use them).
If you have option to disable some of them, you can save your memory on startup. I was now disable 3 of them i don't use, and my startup is faster for 2sec now.
Only problem is i must do this manually...
what kind of numbers are we talking about here? i presume you've been looking at task manager....
what are you doing with this memory that you have "saved"?
Ok, i don't look in task manager at all.I looked in console. I now that 2sec is nothing..
But if i dont use some script now, i want to have it fast acessible in menu for later use, then i want to disable them.
Because, i have possibility to add more than 50 sripts in my config in drop-down menu, do you think that this will not affect performance, if i fill all 50?
I need that saved memory for later use.
If you haven't, you should try the latest beta of foo_uie_lyrics3 (http://code.google.com/p/foo-uie-lyrics3/downloads/list). It now supports batch downloading and has always (AFAIK) supported auto saving, so I'm not sure exactly what you did.
It'll be part of a much larger script (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=77413&view=findpost&p=841225) that I'll be uploading very shortly. The lyrics are just a small component, but if somebody really needs them standalone, I can probably rip them out into their own script. Falstaff may already be doing this in some of his themes, but I have no idea... I just know he hasn't posted it in here in 3 years.
Once I get the last couple kinks worked out, I need to find a good screencasting program so that I can create a youtube video to show all the features my script has. It's hard to explain everything succinctly with just pictures. If anybody has some recommendations, I'd love to hear them.
I used to put my saved memory under a mattress, but then my house burned down and I lost it all. Now I have it stored in an offshore account where it's earning 6% interest every year.
what script(s) are you using that takes 2 seconds? that does seem like a long time for just a few.
as i mentioned, i have 17 taking less than 400ms. that's just over 20ms or 0.02seconds each. i know one of my scripts depends on how many images there are in a folder. i just tested it on a folder with the most artist images in it and it took 0.7 seconds which is a bit more noticeable.
I found this beta yesterday.. in last version lyrics3, you had to press 'save' , that lyrics be seen in WSH lyrics rader. I just added the 'force save' option in WSH, and set that script continuously check whether there are lyrics in the folder or not. Great if they fix this problem..
Wow, this looks great I can't wait to see what config all includes.
.. and If you resolve problem with display unicode characters in lyrics, i'd like to have this version..
My startup time was 0:04, and now is 0:02.7.
Only for test this, i disabled 'tabed playlist' from br3tt, 'album art' that i was made with your help and 'Spinning Disc'.
I don't now how this posibble
a couple of minor updates for my samples:
7.2013-09-30.03
"Now playing" & "Thumbs" now show newest images first based
on their last modified times.
7.2013-09-30.02
"Discogs" & "Musicbrainz" scripts now check for updates if
data is over a day old. Before this change, it waited a week.
existing users: right click>
Update scriptfull download: https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip (https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip)
Hey marc2003, I looked and as I guessed, you were using fso to cache those text files on the local drive. From the documentation I've read on FSO, it seems like you can only create Text files, and what I'd really love to do would be to cache images to handle slow network connections. Is there anyway to do this with FSO, or some other object?
i don't really understand. where are the images from and how are you downloading them?
Actually, a little further reading might have solved the issue. The images are album artwork/disk images and are on a network share. Most of them are in the 500K-1MB range, and since my script has a playlist manager (thanks ExtremeHunter!), a lot of images are being loaded initially as well. I access this network share from the same machine (obviously fast), wi-fi (still pretty fast), and remotely using SSH (really f'n slow), all using mapped drives so the paths are consistent.
However, I think all I need to do is this:
f = fso.GetFile("N:\\Audio\\Artist - Album\\folder.jpg");
f.Copy(fb.ProfilePath + "cache\\Artist - Album.jpg");
And then when retrieving in the future, just check the file sizes against each other and if they differ, get a new one from the network location.
Thanks so much for all your effort with this mod, but I'm getting an error whenever I try to add a script and I can't find a solution! I installed the mod, Safe Mode is unchecked, marc2003 is in my %appdata%\foobar2000 folder, I'm running as an admin, but when I add any of the scripts to the panel I get:
WSH Panel Mod (Art Reader by marc2003): Parsing file "C:\Users\Sean\AppData\Roaming\foobar2000\marc2003\common7.js"
Error: WSH Panel Mod (Art Reader by marc2003): Unknown error code: 0x800700b6File: C:\Users\Sean\AppData\Roaming\foobar2000\marc2003\common7.js
Ln: 1304, Col: 2
Line 1304 is
this.doc = new ActiveXObject("htmlfile");
that error code would suggest something is wrong with your windows install. some missing/corrupt files perhaps? i'm just guessing but i'm pretty sure nothing in my scripts can cause that.
you can try commenting that line out because it's not even required by that script.
just add to slashes like this...
//this.doc = new ActiveXObject("htmlfile");
@marc2003 That worked, thanks a lot!
i should mention commenting that line out will break the news/reviews/blogs and last.fm album info panels but it won't affect any of the others.
Marc, i use your wsh biography to catch biography text.
My script is litle modified. I don't know is it already exist in original script...
I would like to have button in menu to download all biography text, for selected track in playlist? And for images also?
Is it possible?
i really don't see the point of this. it's not like the info can be viewed or be of use with anything else. it takes barely a second to download the bio text if there isn't a cached version. you can even right click>selection mode>follow selected track. now you can select items in the playlist manually and bio text will be downloaded regardless of what is playing.
to answer the question, it is possible but i really can't be bothered to help with it.
and if you do try and make something yourself, make sure you register at the echonest and get your own API key. i will be seriously pissed off if you make multiple requests and get the key blocked for me and everyone else who uses my scripts. search for the line of code in the common file that begins....
url = "http://developer.echonest.com/api/v4/artist/biographies?api_key=
and put in your own.
http://developer.echonest.com/docs/v4 (http://developer.echonest.com/docs/v4)
Ok, thank you Marc. Your script runs faster than standard foo_uie_bigoraphy. And without this is perfect for me.
Thanks...
Ok, i have my API key, i don't even use this in script. I think everyone should purchase own API.
All people use this, so it's little insecure for me. Earlier i was used Romor's API , and he stopped working.
Because of that, i will continue to use my API..
I don't know how much is limit on echonest site. So this my request for adding download option is not good.
Thanks again..
*And maybe you should not put yours API in script at all,but let people to enter own from menu?
purchase is the wrong word as it's absolutely free. but perhaps english isn't your first language?
obviously i'm happy for people to use my scripts with the API key i supply because it's unlikely to ever get blocked if you use my scripts as intended. before you build up a cache, you're not likely to be making more than one request every 3-4 minutes (based on standard song length). and if you listen to full albums, it could be an up to an hour between looking up different artists.
i just ask that anybody who modifies the default behaviour use their own API key.
Sorry for my bad English, you'r right it's not my first language.
Today I went on echonest site. It appears that they reduced limit to 20 calls per minute. In order to increase the limit you have to go on your account, and tell something about yourself and your program you develop and click upgrade, then you will have 120 calls again. If you did not do that, just to inform...
thanks but i've already upgraded my account.
updated my musicbrainz script....
7.2013-10-08.01
"Musicbrainz". Now handles multi-value artist MBID tags if
present - it looks up the first one. Also works around the
fact picard doesn't not write proper multi-value tags to mp3.
if your files do not have MBID tags but your artist tags have multiple values, you should use the
Artist field remapping option found on the right click menu and use something like
$meta(artist,0)
files changed:
marc2003\common7.js
Can I use this or something similar :fb.Titleformat("$puts(example,teststring)"); to pass it to DUI?
no.
no.
Too bad, It would have solved my multi value sorting problems in DUI.
a few more updates:
7.2013-10-11.02
"Musicbrainz". Added some new favicon images for
"Links" mode. This requires that you download the full
zip and extract the "marc2003" folder again.
The "Small Web Links" script also needs these new images.
7.2013-10-11.01
"Now playing" & "Thumbs". Bugfix. Images did not always update
properly after deleting a file using the right click
menu option on Windows XP.
full changelog: https://dl.dropboxusercontent.com/u/2280132...h/changelog.txt (https://dl.dropboxusercontent.com/u/22801321/wsh/changelog.txt)
files changed/added:
marc2003\common7.js
i also need to correct myself about a comment i made about musicbrainz picard the other day. i said it doesn't write "proper" multi value tags. i was wrong and it is behaving as expected. according to the id3v2 spec, only single values should be written to TXXX frames.
It's confusing because foobar will happily write and read multiple values in TXXX frames, but many other taggers can't especially if they're using a compliant lib like id3lib. It's pretty frustrating because if you want to add your own non-standard tag, it's going to be a TXXX frame, and then you have issues.
Extremehunter, i use your Spinning Disc Image Viewer, for WSH panel mod 1.4.2. http://pastebin.com/nfnwQWK8 (http://pastebin.com/nfnwQWK8)
It works well, but when scrolling playlists, it is struggling to spin. I use EL playlist.
Why is this happening?
Also when i add folder in Media Library. System becomes unresponsible for a while, i can not start any other program, until foobar complete is adding.
Is there something wrong with my config?
Hey Guys, long time lurker, first time poster.
First, thank you everyone for all the amazing scripts you post in this thread, it's chalk full of very cool additions.
At the moment I add a lot of different tag fields to my music: including record label and catalog number. I have my Foobar setup to show artist information that is pulled from Last.FM. I am wondering if it's possible to do the same for the record label? I'd love to see a picture, biography, and relevant URLs for the record label in a panel on my config. I'd even consider adding this to a tag field, but i'm unsure how to do it best.
Maybe pull from a folder where there is a set of images with the record label name? Also, there could be a text file with the record label name. That way, when a file is selected with Label X, this script would show Label X.jpg/png/gif and Label X.txt. Ideally I could control how the text is formatted with maybe html or something similar?
Any ideas?
my
simple text reader script can display the contents of a text file based on title formatting.
d:\labels\%label%.txt
obviously, it's only plain text. you can't style it apart from changing the font/colours in your main display preferences.
my
thumbs script can display images from any custom folders you like. you have to specify the folder name though - and it would display all images inside that folder.
d:\labels\%label%
by default it downloads images from last.fm so you'd have to right click the panel
image source>custom folder.
as with all my scripts, all these options are found on the right click menus.
Last.fm has crappy logos. There might be good information about them, at least for the major labels, but the logos will typically look awful. Fortunately for you, I'm about to release my theme which uses record labels, about half of which I created myself and the rest were uploaded by other users of fanart.tv.
Download recordlabels.rar (http://goo.gl/3yeFT6).
The images come in two sizes: 400x270 which is the majority, and 161x109 (which is 2.48x smaller than the larger ones). The smaller size ones generally suck, but they are hard to find good art to replace. My theme strips out " Music", " Records" and " Recordings" so that I don't have to keep two images when musicbrainz or other places decide to list a label as "Electra Records" in one place and "Electra" in another.
Here's the code I'm using to retrieve them from a specific folder where you've unrar'd them, but I'll leave it up to you how you want to display them:
pref["label_base"] = fb.ProfilePath+"images/recordlabel/";
function LoadLabelImage(publisherString) {
recordLabel = null;
d = new Date();
labelStr = fb.TitleFormat(publisherString).Eval().replace(']','').replace('[','').replace(':',"");
if (labelStr) {
/* First check for record label folder */
lastSrchYear = d.getFullYear();
fb.trace(lastSrchYear);
dir = pref["label_base"]; // also used below
if (utils.FileTest(dir+labelStr, "d") ||
utils.FileTest(dir + (labelStr = labelStr.replace(/ Records$/,"").replace(/ Recordings$/,"").replace(/ Music$/,"")),"d")) {
year = parseInt(fb.TitleFormat("%date%").Eval());
for (; year <= lastSrchYear; year++) {
yearFolder = dir + labelStr + "\\" + year;
if (utils.FileTest(yearFolder, "d")) {
fb.trace("Found folder for "+labelStr+" for year "+year+".");
dir += labelStr+"\\"+ year + "\\";
break;
if (year > lastSrchYear) {
dir += labelStr+"\\"; /* we didn't find a year folder so use the "default" logo in the root */
/* actually load the label from either the directory we found above, or the base record label folder */
labelStr = fb.TitleFormat(publisherString).Eval().replace(']','').replace('[','').replace(':',""); // start over with the original string to be safe
label = dir+labelStr+".png";
if (utils.FileTest(label, "e"))
recordLabel = gdi.Image(label);
else {
labelStr = labelStr.replace(/ Records$/,"").replace(/ Recordings$/,"").replace(/ Music$/,"");
if (utils.FileTest(label, "e")) {
} else {
label = dir+labelStr+" Records.png";
return recordLabel;
This assumes you unrar the file to "%appdata%/foobar2000/images/". publisherString would be a title formatted string something like: $meta(label,0), although in my theme I build up an array of strings to try, and then iterate through them looking for labels which allows me to display more than one label if needed. One of the cool features is that for labels that have changed their logo over time (like Epic) I have a sub folder with different years for when the logo changed. So an album with %date% of 1975 would pull from "Epic/1976/epic.png" to display the old sunburst logo while anything after 2010 would use the current Epic logo.
Thanks marc2003 for all your works, and above all, your sharings !
My foobar config must have at least 7 scripts from you, and all awesome.
But, I have a little problem with thumbs script, yesterday it downloaded artist pics perfectly and today it's not working, it says, no fetching art... My tags are good and I tried on several artists, I don't know why I'm getting this...
Is this a well known bug with Last FM ? When I "Online Update", my console says : Thumbs: HTTP error: 0
I tried your thumbs script and thumbs2, not working. Weird no ?
the rotten gits at last.fm have deprecated the service. it's no surprise as they did remove the documentation some time ago. now they've finally turned it off.
<lfm status="failed"><error code="27">
The artist.getImages method has been deprecated.
</error></lfm>
i'll have to try and find another source.
as for your update error, that was introduced when my host (dropbox) messed around with their domain name and re-directions. you need to extract the marc2003 folder from the full zip here- https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip (https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip) - make sure the scripts in panels get updated as well. all future updates should work.
Thanks for the explanations marc2003
samples updated
7.2013-10-18.01
"Now playing" & "Thumbs". Last.fm have removed their artist
images service so I've disabled the menu options.
http://www.last.fm/group/Last.fm+Web+Services/forum/21604/_/2216689
obviously the script will continue to display any images you've already acquired or you can put it into custom folder mode via the right click menu.
(https://dl.dropboxusercontent.com/u/22801321/2013/october/thumbs.png)
Update script.
Hi marc2003, is it possible to add a search button next to the artist name like on your last.fm similar artists script on the Last FM Charts script ?
^it's certainly possible. i'll think about it.
for anyone who is suffering withdrawal symptoms from not being able to download last.fm images for the last day or so, i've made a little replacement
if anyone wants to test it, save these 2 files in your marc2003 folder
https://dl.dropboxusercontent.com/u/2280132...temp/common7.js (https://dl.dropboxusercontent.com/u/22801321/wsh/temp/common7.js)
https://dl.dropboxusercontent.com/u/2280132...mp/download.vbs (https://dl.dropboxusercontent.com/u/22801321/wsh/temp/download.vbs) << you might need to right click the saved file>properties>unblock.
if foobar is running, you'll need to restart.
Marc, which version WSH you use, and where to download?
1.5.6: http://code.google.com/p/foo-wsh-panel-mod/downloads/list (http://code.google.com/p/foo-wsh-panel-mod/downloads/list)
Thank you, works fine.. No problems
Tested...
I am satisfied how it works. Well done Marc..
We would be lost without you.
I am more than happy
I Only must to modify script for my config. It would be good if you provide support for the WSH before 1.5.6 , (problem is only in ''AppendTo'' ,menu)
If you have time and if you want. Thanks a lot for this..
no chance.
no chance.
FYI, the only differences between v1.5.4 and the v1.5.6 are:
- FIX: Fix a bug that preprocessor "tooltip" didn't work at all.
- ADD: Added GetColorScheme() method to IGdiBitmap interface.
so if these two features are not used, you can use v1.5.4 as well, it make sense when you know that v1.5.6 is not stable when using complex script that use timers and create a lot of objects (even if they are free from memory properly). The fix about tooltip brought by v1.5.5 & v1.5.6 has broken something in the handle of memory usage
TIPS: a way to fix this bug in v1.5.6 is to code a CollectGarbage() many times in the life of the script / memory usage done.
my scripts only require 1.5.0 but IIRC from a previous post, mire777 is using that hacked 1.4. something for aero.
edit: i've never encountered memory problems in 1.5.6 and i don't use garbage collection in any of my scripts. i'll try 1.5.4 to see if usage is lower???
edit2: from the hints/tips...
11. Consider using Dispose() method instead of CollectGarbage() function.
i do use Dispose on images and menu items but that's it. i don't even know what else it can be used on??
issue with v1.5.6 is only linked with timers use and refreshing on_paint, a kind of overflow may appear then and will make panels crash (not only the source one but other wsh panel mod that may use some graphics methods) and sometimes worth with a total lock/unresponse of foobar2000 itself.
it's extremely rare but it's happens if you do not take care. v1.5.4 is clear of this kind of issue.
it's just an information for those who may encounter a such issue, since T.P Wang is no more involved in this component.
New panel i'm working on: Album browser like itunes does, but better than the original in some ways (scroll, expands ...):
(http://imageshack.us/a/img594/2262/i1e9.png)
my seekbars all user timers with an interval of 150 and they've been fine in 1.5.6 for me. i don't know how many other people use them but i've had no reports of any problems.
your new panel looks pretty cool. i assume it's getting colours from the album art? very clever.
happens with smaller interval size and heavy work on repaint. "Normal" scripts are not affected.
Yep, thanx, background color based on the cover color scheme, that's why i need v1.5.6
samples updated:
7.2013-10-20.02
"Simple tag reader". Now displays a warning if foobar v1.3 is detected.
Because of internal changes made to the handling of extra long tags, this
script is unable to display them anymore. Depending on what happens with
foobar v1.3 final, I might remove the script entirely.
7.2013-10-20.01
"Now playing" & "Thumbs". Restore Last.fm image download
functionality. The only difference is that it's restricted to
a max limit of 5.
How small an interval size? I typically have about 2-3 interval timers going with the shortest one often as low as 35ms and firing off a RepaintRect. My on_paint is currently about 1000 lines of code and does a lot of image drawing (full refresh takes about 200ms fully optimized, although the interval redraws for my seekbar typically are only 1-2ms). I've never noticed an issue with memory usage either.
Has TP Wang really disappeared? I thought he was participating in this thread fairly recently.
according to his profile (http://www.hydrogenaudio.org/forums/index.php?showuser=44175), he's not even browsed the site while logged in since last december.
I would suggest future request for thumbs:
I noticed that on_metadb_changed(), script not search for image, only when you press play it search image from last.fm. Because of that we have empty panel(or am I missing something in the settings).
I changed this in script for me..
About speed for catch image(it's good), but script wait that folder be full of 5 images, and after that it display's it in foobar.
If you click re-scan, you will see that it is alredy download 1-3 images. It would be good that script not wait, and immediately show that 1-3 images.
And finally. It would be good, that script continues to cycle images even if not pressed play.
besides this, script is perfect...
that's intended. when foobar isn't playing, selection changes can be rapid and i don't want to trigger loads of requests at once.
for performance reasons, the thumbnail strip you see is actually one image generated by "stitching" all the images together. rescanning the folder destroys all the current images, gets a list of files, creates new image objects and creates the "stitched" image from scratch. if you ever see a delay when loading folders full of images that already exist, it's because of this "stitching". i don't think it would be a good idea to trigger this after each image has been downloaded.
whilst i'm not really sure why you'd be looking at the images in foobar when nothing is playing, i suppose i could use a timer to cycle images instead.
Ok,i don't like an empty panel, so i changed this for me, now it search images on_metadb_changed().
Here script don't uses api, so i think it's not problem..
About re-scan i think you're right, i modified script to do that only once after 5 sec. play, and work ok.
Only that cycle is what missing..
done. right click>
Update script.
done. right click>Update script.
Great Marc, thanks a lot!
Ugh, that sucks. I recently saw he posted two pages ago in the official WSH component thread, but I hadn't realized that was almost a year ago.
At least all the code is in a public repository so someone can make changes and improvements if he's really gone for good.
update for a silly bug i introduced. right click>
Update script.
7.2013-10-21.03
"Now playing" & "Thumbs". A change earlier today meant images with
uppercase lettters in their filename extension were ignored.
This has now been fixed.
yep, someone to take the relay of T.P seems to be the way to go, unfortunatly for T.P that miss some news about him... but who is interrested and have the skills and time for ?
the problem is that all the people who are interested in it don't have the skills -afterall, that's why we're using it. and the people with the skills probably aren't interested.
Bug report for Thumbs & Now Playing:
In some cases, right click menu becomes unresponsible until ''download.vbs'' search image..
sorry but it's kind of unavoidable. i don't want to spawn multiple processes downloading all the images at once plus i'd have no way to tell when it's finished and when to rescan the folder.
That's not necessarily true. I'm guessing I have most of the skills required and could probably pick up the rest if really needed. But I'd prefer not to as I don't really have the time to chase down hard to reproduce bugs.
After saying that I had never encountered this, I might have encountered it yesterday. Can you explain what the symptom is? Does foobar crash? Does the WSHPanel script crash? Does foobar's memory usage skyrocket?
oh that's cool. we can start directing all bugs and feature requests at you now.
generally panel crash on a gdiDrawText method, or if not crashing the panel become white (no repaint) for a little lapse of time, then came back on mouse move. Experiencing this repaint bug more than 2 times generate WSH panel Mod panel to freeze (a WSH panel mod window open over the fooobar2000 window and foobar2000 freezed until it crashed.
that's the common symptoms encountered.
if you run 'download.vbs' as a fully independent process, and set that wsh only check folder if is full with 5 images, maybe you can do something.. Or that wsh monitor process in task mngr. , and when it ends to rescan folder.
It stuck because wsh wait .vbs to end.
I'm sure that you can prevent this..
Not big problem, but it's best to fix...
If not possible at all, ok...
i've already given the reasons for why i'm not changing it. if you can't suppress your need to right click the panel for a few seconds then don't use it.
i have updated it to display a little hourglass when it's working. at least that shows it's doing something. right click>Update script.
That's great . Not problem at all, i use it, and love. in many ways it's better than the standard 'foo_uie_biography' was.
I just asked if possible, if you missed something...
Hi marc2003, i'd like to visualize the seven weblinks buttons in the middle of the wsh panel, would it be possible?
Reading the script i can see that changing the first number for every button i can move it orizzontally, but i'd like to have it always centered, also if i resize the panel.
Is there a way to achieve it?
if you have 7 buttons and they are each 32px in width, that's 224. now subtract that from the panel width and divide it by 2. that gives you the x co-ordinate of where the first button should be....
var but_x = Math.round((p.w - 224) / 2);
use but_x for the first button and then increment each one by 32 (but_x + 32, but_x + 64 etc)
you also need to make sure you call the
b.update() function inside the
on_size function like this...
p.size();
b.update();
you also need to make sure you call the b.update() function inside the on_size function like this...
p.size();
b.update();
This shouldn't be hard at all, but i'm missing something...
That's the panel where i'd like to center the icons:
(http://i.imgur.com/y4lZafg.jpg)
That's how i edited your original weblinks script:
// ==PREPROCESSOR==
// @import "%fb2k_profile_path%marc2003\common7.js"
// @name "Web Links"
// @author "marc2003. Images by komodomedia.com and mjm716"
// @feature "v1.4"
var p = new panel("Web Links", ["custom_background", "metadb"]);
p.version = "7.2013-04-20.02";
p.filename = "web links.txt";
var b = new buttons();
p.check_version();
b.update = function() {
var artist = encodeURIComponent(p.eval("%artist%"));
var title = encodeURIComponent(p.eval("%title%"));
var lastfm = "http://www.last.fm/music/" + artist + "/_/" + title;
var google = "https://www.google.co.uk/search?q=" + artist;
var wikipedia = "http://en.wikipedia.org/wiki/" + artist;
var youtube = "http://www.youtube.com/results?search_query=" + artist + "+" + title;
var discogs = "http://www.discogs.com/search?q=" + artist;
var myspace = "http://www.myspace.com/search/music?q=" + artist;
var allmusic = "http://www.allmusic.com/search/artists/" + artist;
b.buttons = {
lastfm: new button(but_x, 0, 32, 32, {normal: "lastfm.png", hover: "lastfm_h.png"}, function() { p.browser(lastfm); }, lastfm),
google: new button(but_x+32, 0, 32, 32, {normal: "google.png", hover: "google_h.png"}, function() { p.browser(google); }, google),
youtube: new button(but_x+64, 0, 32, 32, {normal: "youtube.png", hover: "youtube_h.png"}, function() { p.browser(youtube); }, youtube),
wikipedia: new button(but_x+96, 0, 32, 32, {normal: "wikipedia.png", hover: "wikipedia_h.png"}, function() { p.browser(wikipedia); }, wikipedia),
discogs: new button(but_x+128, 0, 32, 32, {normal: "discogs.png", hover: "discogs_h.png"}, function() { p.browser(discogs); }, discogs),
myspace: new button(but_x+160, 0, 32, 32, {normal: "myspace.png", hover: "myspace_h.png"}, function() { p.browser(myspace); }, myspace),
allmusic: new button(but_x+192, 0, 32, 32, {normal: "allmusic.png", hover: "allmusic_h.png"}, function() { p.browser(allmusic); }, allmusic),
window.Repaint();
p.size();
b.update();
b.draw(gr);
b.update();
b.move(x, y);
b.lbtn_up(x, y);
And that's how i end up having the panel:
(http://i.imgur.com/ODf6k9b.jpg)
There's no doubt i'm a noob, sorry...
sorry it's my fault for not being clear. this...
should go inside the b.update() function.
b.buttons = {
lastfm:
b.buttons = {
lastfm:
I did some "random" test with the position of the string but i didn't the right one
Thank you very much, it's perfect now!!
I didn't thought that I will enjoy in this 'wait image'
(http://imageshack.us/a/img543/8175/y5tr.png)
How to make this image to spin?
If split this in 8 images
This code is not debugged or tested in anyway, so there will probably need to be changes.
This assumes all the images are saves as wait_img0.png, wait_img1.png, etc. The path variable contains the path to those images.
var waitImgs = [];
var curWaitImg;
var curWaitIndex = 0;
for (i=0;i<8;i++)
waitImgs.push(gdi.image(path + "/wait_img" + i + ".png");
curWaitImg=waitImgs[curWaitIndex++];
waitTimer = window.SetInterval(function() {
curWaitIndex = (curWaitIndex + 1) % 8;
curWaitImg = waitImgs[curWaitIndex];
window.Refresh();
}, 100);
Then just draw curWaitImg in the on_paint. You'd probably want to use a refresh rect and pass it the coordinates of where you want the wait image to be shown.
Sounds like that isn't what I ran into then. My theme crashed in an unexpected spot for no reason I could understand.
I did encounter a weird redraw bug though that might be related. The window would just stop updating. It was going through the on_paint, but the screen only redrew when I paused playback. Never went white though and the theme was still responsive to the mouse (menus would still drop down, etc.) I've seen stuff like that before where it's attempting to redraw too fast, or something else is stealing all the CPU cycles, but that shouldn't have been the issue in this case.
samples updated;
for my thumbs & now playing scripts, when there weren't enough thumbs to fill the whole strip, you'd see an ugly gap with your default background colour. i've now improved this by taking up the whole panel with the main image and drawing thumbs over the top.
(https://dl.dropboxusercontent.com/u/22801321/2013/october/new%20thumbs.png)
Maybe somebody can help me:
If I update a tag using IFbMetadbHandle.UpdateFileInfoSimple and then try to read it using IFbFileInfo.MetaValue without a delay, it reads the previous value back. I suppose the reason is that the file content itself is not updated immediately.
Does anybody have a best practice on how to avoid this?
as you've written the value, why do you need to read it back immediately? you'll get prompted if tag updates fail - just like you would if you were updating the usual way through the properties dialog.
I need it to perform some calculations afterwards like getting average values of certain track groups. I think I can solve it by just passing in the changed values manually in the calculation, but I was just wondering. Actually I would expect the read and write operations to be properly synchronized.
if you've not seen any tag update errors, i think it's fair to assume the values you have written are ok to use. try using UpdateFileInfoSimple on a read only file and you'll see what i mean.
edit: bad advice removed.
Ok, thanks for the hint, I might take that route.
Also thanks for your plugin, the customizations you can do with it are really great!
i completely forgot, you could use the
on_metadb_changed callback for this. that gets called automatically when tags are updated.
you need this preprocessor stuff at the start..
// ==PREPROCESSOR==
// @feature "v1.4"
// @feature "watch-metadb"
// ==/PREPROCESSOR==
then use this
//something
why having 8 images when it's easy to rotate the image with gr.DrawImage() ? Increase angle value by (360 / 8) at each time interval you want (with a timer and a public variable for the angle) and just use this angle value in the gr.DrawImage() as parameter.
void DrawImage(IGdiBitmap, dstX, dstY, dstW, dstH, srcX, srcY, srcW, srcH,
angle = 0, alpha = 255);
i would say don't attempt to draw a spinning image over the top of any kind of background image because the CPU usage is ridiculous. it might be ok in a blank panel.
you only need 2 positions to create the same illusion... alternate between your example as is and same rotated 22.5deg
void DrawImage(IGdiBitmap, dstX, dstY, dstW, dstH, srcX, srcY, srcW, srcH, angle = 0, alpha = 255);
You're right.. this is simple rotate scipt, but i don't know where to put it inside 'Thumbs' script, to display only when downloading image:
var wait = gdi.Image(fb.FoobarPath + "images\\wait5.png");
var angle = 0;
function on_paint(gr) {
gr.DrawImage(wait, 0, 0, 30, 30, 0, 0, wait.width, wait.height, angle);
var timer = window.CreateTimerInterval(10);
if(angle >= 360) angle = 10;
angle += 10;
window.Repaint();
you really want to use it inside the thumbs script?
luckily for you there is a variable which you can check the value of:
im.working.
if (im.working) ....
also, i'd use window.RepaintRect so it doesn't redraw the whole panel.
but even re-drawing such a small area, i still think you'll have CPU usage issues. try it and look at task manager.
Since you're talking also about the Thumbs script i have a question...
In my config it doesn't work anymore, it tries to load pics from Lastfm but nothing appears. [No image].
Is there something i can do to have it working?
last.fm made some changes last week which means my old script stopped working. i've updated it with a workaround so you just need to right click>Update script.
you might find it's slower now but i can't do anything about that. like it or lump it.
I already tried it but with no luck...
It found an update, i restarted foobar but i can't still see any image in the thumbs panel.
I'll try to recreate the whole panel, maybe something it's corrupted idk
are you trying it manually or using the automatic download option? the latter only works when you start playing a track and no images exist for that artist.
look inside the marc2003 folder and see if a file named download.vbs exists. the script should download it if it's not found but this might have failed?? also check the foobar console? any messages/HTTP error codes?
Tried both method and the download.vsb file it's in the right folder...
In console i can see a "Thumbs: HTTP error: 0 " !
have you been trying many different artists? are you getting that error with all of them?
you could try clearing the temp files in internet explorer to see if that helps. even if you don't use the browser, this script still uses parts of it to work.
luckily for you there is a variable which you can check the value of: im.working.
cpu usage is 8-12 if you set slow spining. Looking nice, but i will consider will i use it?
to meditate : why having a cpu if it's not for using it ?
^if the flashing play icon in your playlist took 10% cpu, you wouldn't enable it.
cpu is not important. But i'm not able to do what I intended. so i'll leave it to you, to make, if some of you or Marc thinks that it is useful..you will do this better..
10% is saying nothing, all depends of the cpu power of course
on an atom (1st gen.) it's quite acceptable even for a flashinf icon
CPU usage isn't necessarily the important part, it's the time it takes in the on_paint. It's a small image, so it wouldn't take that long, unless you have a lot of different images below, or around it. Probably 5-10ms tops. If you do it with 8 images the way I wrote it (even if you just load one image, but draw it rotated into 8 different images that you create) it's probably <1ms to draw. All depends on what you want to do.
I'm trying to combine the 'Now Playing' script with the simple text reader script. Instead of pulling info from Last.FM or Wikipedia to populate the artist info, can I pull that info from a text file instead? Not sure what to change to get that done.
Thanks so much!
that's nice and easy. find line 33...
var p = new panel("Now Playing", ["custom_background", "now_playing", "lastfm_wiki", "remap"]);
replace "lastfm_wiki" with "simple_text" so it becomes...
var p = new panel("Now Playing", ["custom_background", "now_playing", "simple_text", "remap"]);
to configure the text file options, make sure you right click over the text area.
Hey marc2003, don't hate me but i have another question about one of your script...
I use DUI and i'm looking for a component that display the tags and info of tracks, and i'd like to have one that allows me to follow the selected track, not only the currently playing one.
Your script seems perfect for that aim, but if i create a panel with your script it stay all empty, with only the title of the track at the top.
if you're using a Selection properties panel then go to file>preferences>display>selection viewers>prefer current selection.
It works with the standard playlist viewer but it won't work with the WSH Playlist that i'm currently using.
ok, i might knock something up.
Thank you
I don't know if it's a "bug" or it's just wanted as this form the developer of the wsh playlist...
i don't have a deviantart account otherwise i'd write him about it
so here's my quick bodge, tested with falstaff's WSH playlist to select items.
(https://dl.dropboxusercontent.com/u/22801321/2013/october/item%20details.png)
it only displays the detail of a single item, regardless of how many you select. scroll with your mouse wheel if there is too much to display.
first save this in your marc2003 folder...
https://dl.dropboxusercontent.com/u/2280132...2003/common7.js (https://dl.dropboxusercontent.com/u/22801321/wsh/marc2003/common7.js)
then this is the script that goes in the new panel.
https://dl.dropboxusercontent.com/u/2280132...m%20details.txt (https://dl.dropboxusercontent.com/u/22801321/wsh/samples/item%20details.txt)
it defaults to prefer the playing track but you can change that via the right click menu.
it's also included inside my full pack of scripts here: https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip (https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip)
wow, i didn't expect it so soon, so fast!
Thank you, it's perfect.
Wonderful, thank you so much marc2003
Another question for you regarding the Selection Panel you have just described. Is there a way to easily turn the "Now Playing" script into a script where I can choose whether to track the selected track or currently playing track?
edit the same line 33 as above, adding "metadb"
var p = new panel("Now Playing", ["custom_background", "now_playing", "simple_text", "remap", "metadb"]);
also you need to delete line 41 which is
p.selection_mode = 1;
now you'll have a menu like most other scripts.
Marc, is possible to change something in thumbs script, that image names be saved in format %artist%. example: "jennifer lopez_1,, 2..3... and so on.. Then with mp3tag editor, i can use that image to tag mp3 files? I know that this is not intended, but would be good. and for bio text too... can you point me where to edit this. i hope that i'm not bothering you too much.. thanks
no but if you read this pdf about how to get foobar to display images downloaded by my script, you can use exactly the same folder location when batch attaching images in foobar itself (via the tagging menu)
https://dl.dropboxusercontent.com/u/2280132...rtist%20art.pdf (https://dl.dropboxusercontent.com/u/22801321/wsh/configuring%20the%20foobar2000%20core%20to%20display%20Last.fm%20artist%20art.pdf)
Wow, this is great! Actually this is what i wanted to do..
