rjamorim gets mentioned in "Wired"
Reply #35 – 2005-12-08 18:57:06
I think we are missing the timeline - different profiles of AAC were used for different claims, so I see no contradiction unless we forget that important fact while "filling the blanks" So the wording might be a mistake according to somebody - but for sure there is not a word mentioning statistical transparency which is something quite harder for a codec to achieve (what MP3 cannot achieve even at 320 kbps, for instance) Right, and thats exactly what i tried to point out: You complain about the wired article being misleading because important info is missing. Nero on its website is doing exactly the same - certain info was intentionally left out, so that the reader gets a wrong and misleading impression of the codecs performance. If you want to be treated fairly, tread others fairly. Another point which can be derived from the above is something which i mentioned earlier, and which kornchild explained in more details again: Why does Nero feel the need to paint an exaggerated picture of their encoder's performance? Would they need to do that if their encoder would indeed be so much significantly better that it makes up for the far lower software/hardware support/compatibility? Well, thats exactly the problem of all those "modern" lossy codecs: Besides of narrowband, their advantages are just not significant enough for most people to make up for the worse support. Would a normal user give up the "play-everywhere"-support of mp3, for 10% lower filesize? No. 20%? No. 30%? Maybe. 40%? Probably, but it just isn't so. MP3 is "good enough" for most people and the newer codecs advantages simply cannot deliver a significant enough gain to justify switching to them - so the company's behind them resort to exaggerations instead to "justify" their use. But when a user or magazine then take's those exaggerated suggestions as "true" and judges them by those criteria - then they complain about "unfair comparisions". And here, we come full-circle... - Lyx
