Topic: Way wanted to generate Album and Artist list (Read 1942 times) previous topic - next topic
Hello,
I'm running Logitech's Squeezebox server with some 900 ripped (to flac) albums. Recently I've bought a couple of duplicate albums by mistake :-( I've put a question on the slimdevices forum. I've had a suggestion to used Album Art Downloader, which coincidentally I run. But I can't see a way to export the generated album/artist list. Can any body else help or suggest an alternative simple technique. Thanks in advance.
(I've tried maintaining a list manually but this is a bit error prone and and certainly not automatic.)
Alan
Alan Chartered Engineer and music lover
I'm not sure I understand what you're after...  Most media player software will sort/list your music by artist, album, song, genre, etc...  (I use Winamp, and sometimes iTunes.)
If this is about exporting the tags to be used in a spreadsheet, JRIver can do that.
Simply send all audio to a playlist and export it.
You can also load all files in MP3 tag and do an export
TheWellTemperedComputer.com
