Topic: FLAC & cuesheet tag (Read 5795 times) previous topic - next topic
FLAC & cuesheet tag
I wonder why cuesheet tags won't work with FLAC files when adding them through the "show file info" option. I know FLAC has its own cuesheet tagging system, but I don't like it since I can't edit it through foobar and it doesn't support artist/track title names.
Correct me if I'm wrong
FLAC & cuesheet tag
Copying the code from foo_ape would be trivial but I don't want to compete against official cue sheet standard FLAC has set for itself. Therefore it hasn't been added.
FLAC & cuesheet tag
Hmm, too bad I guess. I'll just stick with APE then, as the hassle of tagging the FLAC files would be too much for a lazy person like me
Thanks anyway.
FLAC & cuesheet tag
just use metaflac.exe.  It is fairly simple (metaflac.exe --import-cuesheet-from=filename.cue filename.flac if i remember correctly.)
Or the other option is to use external cue sheets (as i have decided to do)
