Topic: how to disable pop-up balloon/tooltip (Read 760 times) previous topic - next topic
These pop-up balloons serve no purpose and are a bit annoying:
Is there a way to disable them?
T.I.A.!
Re: how to disable pop-up balloon/tooltip
They're called "tool tips".  Should give you a clue what to look for...
I looked, and I did not find settings for them.
Would you care to explain how to disable them?
I don't know whether you can, and don't have access to my FB2K installation at present sorry.
I have checked all settings that I could find, and then checked them again.
But it looks like this behaviour is not user configurable.
How can I raise this issue so that it has a chance of getting addressed/resolved?
From your first post, those controls look like they've been added by a JScript panel – am I right?  In which case you should be looking in the JScript for that component.
If it is JScript, then you can modify the code yourself even if you need help to do that.  Post a query in the relevant thread for that component.
If it's not JScript and is baked into the FB2K code, add it to the wishlist thread.  You are then reliant on the developer considering it's worth his time and of sufficient interest.
I'm not sure why you are looking for 3rd party components that may be causing this.
It's easily replicated using a plain vanilla clean foobar2000 install:
