Topic: using foo_runcmd component to start automatically with a given playlist (Read 735 times) previous topic - next topic
Hello
I would like automatically start on a given playlist named web_radios.fpl) when foobar2000 is started.
I have added the following to the foobar2000.exe  /runcmd= "Switch to playlist/web_radios.fpl" /runcmd="Playback/play"
However it keeps starting on the playlist that was played when foobar was closed.
What did I miss?
piscvau
Re: using foo_runcmd component to start automatically with a given playlist
foo_runcmd only works with fixed name main menu items. Playlist names are dynamically generated and not supported.
You can try my foo_run_main component. It supports dynamic menu items, link in sig.
edit: it requires fb2k v2.
For the stable version 1.6.x, not a v2 beta... ::)
https://github.com/marc2k3/fb2k-archive/releases
You may also set a startup playlist using Playlist Manager (my sig).
Spoiler (click to show/hide)
And this only works for the last played playlist -on previous session- (as far as I know):
https://www.foobar2000.org/components/view/foo_playlist_attributes
