Topic: foobar2000 DeskBand Controls (Read 334022 times) previous topic - next topic
Re: foobar2000 DeskBand Controls
Reply #750
Bero1707 : Nice one. Need to rewrite UI in WPF or Avalonia.. Maybe some time in the future..
This happens when I turn my PC first and than display later.
When I turn my display first the settings window looks normal but hand icon (pointer finger) on seekbar looks very small.
Reply #752
Hi eldarien, how do I change the settings so the displaying text on the desktop bar would be the file name of the audio file and not the Artist and Track tags?
Reply #753
Replace [%artist% - ]%title% with %filename% in settings/texts/default text/format.
You can access settings with right click on DeskBand Controls on desktop bar.
Reply #754
Thank you! :)
Reply #755
I made this account to thank you for making this wonderful plugin. It's exactly what I'm looking for, and the customizability is wonderful!
Attached is my current implementation of the toolbar:
Reply #757
Any plans about Windows 11 since they've apparently removed the ability to have toolbars in the new taskbar?
I upgraded my laptop to check if everything still works properly before upgrading the main PC and... I'm already missing deskband very much :'(
Reply #758
Other than a floating window completely independent from the actual taskbar, I don't see what else can be done??
The taskbar is utterly gimped in windows 11. You can't drag files from fb2k to another app by hovering over the icon and vice versa. The notification area tooltips are ruined too. They have a very low fixed width and the display of ampersands is totally broken.
During beta, they even managed to break the taskbar entirely just by pushing out a bad advert. Yeah, you read that right.
And then there are context menus in Explorer which have to be rewritten from scratch just to get new entries added. The old options are hidden behind a "more options" so now everything takes more clicks. And setting defaults by app? Forget it. Then you have ugly scrollbars, menus and checkboxes and it's starts looking very unappealing for fb2k users.
Reply #759
Yeah that's what I'm afraid of :/
The OS upgrade itself went surprisingly smoothly, but this taskbar... brings nothing new and only removes useful functionality and user control, with the scrollbars and menus adding insult to injury.
I don't know what they've been smoking, but the dosage was too high.
Hopefully there will be an OpenShell-like utility for the taskbar at some point...
Edit: ah, I've just tried https://www.startallback.com/ and the 'enhanced classic taskbar' restores the toolbar functionality, which makes DeskBand appear again \o/
I'll add that to my default installs up until the hypothetical day when MS decides to fix what they broke...
Reply #761
Good to know actual toolbar functionality is still there.. For now.
Personally, I will not upgrade to 11 it seems. I'm still on 7 and happy.
Also they have decided that my machine with QuadCore Intel Core i5-4690K and 32Gb RAM is not good enough, so you know..
Reply #762
Microsoft are now giving instructions on how to bypass the TPM requirements but avoiding it in general is a much better idea!
https://support.microsoft.com/en-us/windows/ways-to-install-windows-11-e0edbbfb-cfc5-4011-868b-2ce77ac7c70e
Reply #763
Microsoft are now giving instructions on how to bypass the TPM requirements . . .
Looks like only a CPU thing.  Or TPM 1.2 if you want, but I know of no fTPM that is 1.2, only discrete TPM (chip).  TPM 2.0 has been around since before Intel put a fTPM in ME so no fTPM 1.2 is around (and it'd have been updated if there had been).  If a TPM is holding you back, you can't use that method from Msft.  There is one method that gets around that, but it's a youtube thing and . . . need I say more?  For the Go_To_11 crowd (good for you), I present
https://www.youtube.com/watch?v=57yI6TMgIFI
Good luck!  Oh, well, let's hope you have auto-start-AV off.
BANNED
Reply #764
Yeah the hardware 'requirement' thing is just about as nonsensical as straight-up removing useful functionality and user control for no reason whatsoever... (you can't even move the taskbar to a non-primary monitor... which fortunately startallback restores as well because that would have been a *major* annoyance on the main PC and its 3 monitors...)
The i7-7820k of my laptop is officially unsupported, even though the Q and X versions are on 'the list'. I upgraded from the ISO anyway since there's technically no reason for this CPU to have any issue, and it went just fine.
It would have been a pretty seamless upgrade from Win10 if they hadn't broken the main UI element used to interact with the OS...
Oh well, it's workable enough for me now with startallback, we'll see what they do moving forward (not holding my breath). As long as there's still a way to get DeskBand to work, life can go on :)
Reply #765
I use the floating window mode, but the toolbar component still occupies a blank area in the taskbar. Is there a way to remove it?
Reply #766
Hi, Is there an option to reset as defaults the settings of the complement more than delete the JSON file in "AppData\Roaming\DeskbandControls"?
Have you tried turning it off and on again??
Reply #767
It should not use any space except 10 pixels wide section - it is reserved for context menu access.
If you need more help on your case please post a screenshot and json config file.
Reply #768
No other way right now.
