Topic: Need some help with a Masstagger script (Read 2561 times) previous topic - next topic
There are times when the Capitalize function in Properties doesn't work as desired. Suppose a song title contains a hyphen (ie: The Times They Are A-Changin'). When I execute the Capitalize function, it changes the "C" to lower-case; I would prefer it not do that.
As a workaround, I use Masstagger:
$replace(%title%,A-changin,A-Changin)
But I am completely lost when I am working with titles containing an apostrophe. The above string will only work if I leave off the apostrophe at the end. But when the apostrophe occurs at the beginning of a word, as in Three O'Clock Blues (which gets changed to Three O'clock Blues after capitalization), I am a loss. I try this:
$replace(%title%,O'clock,O'Clock)
But it doesn't work.
Try using the '' (these are two ' characters) for a single '.
I don't know why that worked... but it worked!
It worked because "Help > Title formatting help" says
' (single quotation mark) -- (..) In order to insert a quotation mark character, use '' (two single quotation marks).
