Topic: foobar2000 v 1.4 b13 & command line (Read 1041 times) previous topic - next topic
Through :
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Components_0.9/Run_Commands_(foo_runcmd)
eg
RUN; $ foobar_exe $ | / runcmd = Playback / Order / default
RUN; $ foobar_exe $ | / runcmd = Playback / Order / Random
Command line works
original command line - does not work!:
RUN; $ foobar_exe $ | / command: default
Here it does not switch automatically (if the "loop" command was previously selected)
RUN; $ foobar_exe $ | / command: Random
This command works only at the time of sending
I try different options for View> Visualizations
Commands do not work at all
