I've been playing with the source code for ogg123 and added in some lines to print to a file the instantaneous bitrates so I can plot them w.r.t.
Anyway, after a short 5 min mucking around, I got these two beautiful graphs to share with everyone. (x axis is time in seconds, y axis is bitrate in kbps)
Bitrates for GT3b1 (q5) on harp40_1.wav
Enjoy
You can try an oggspot (http://hmd.c58.ru/files/oggspot-0.1.tar.gz) that I've written some time ago for that purpose, rather than using ogg123.
It's still early development, but should suffice for what you wanted.
I wanted to do something in the lines of what EncSpot does, but have no time for that now.
Can you post a win32 binary, please ?
This program does not have a GUI yet, I don't have time for that.
But here's the gnuplot-generated graph of Linkin Park - In The End for each block:
(http://hmd.c58.ru/temp/websound/oggenc10.png)
Axis X - time, in seconds.
Axis Y - bitrate, in bits per second.
Every vorbis block is represented as dot on this graph.
Encoded with libvorbis 1.0 and oggenc 1.0 with -q5 key.
We can see practically three layers of different block types - near-nominal (most of the stream), high-bitrate (presumably, on sharp attacks and hard to encode blocks), and low-bitrate (presumably, on very easy to encode blocks).
Here's graph of the same song encoded with libvorbis 20030903 CVS:
(http://hmd.c58.ru/temp/websound/oggenc20030903.png)
And here's encoded with Garf's GTune 3 beta 1 (linux binary from his webpage):
(http://hmd.c58.ru/temp/websound/oggencgt.png)
To see the difference between libvorbis 1.0 and libvorbis 20030903 CVS, you'll need to open these files in two windows and switch between them:
Encoded with libvorbis 1.0 (http://hmd.c58.ru/temp/websound/oggenc10.png)
Encoded with libvorbis 20030903 CVS (http://hmd.c58.ru/temp/websound/oggenc20030903.png)
I observe that all short blocks with high bitrate now use more bytes. Same tendency on low-bitrate blocks - they have now more bits for detail.
Encoded with Garf's GTune3b1 (http://hmd.c58.ru/temp/websound/oggencgt.png)
The picture of Garf's GTune is drastically different - the bitrate scale of graph has to be adjusted, since it adds another very-high-bitrate layer of blocks, moving half of them from high-bitrate layer. Also, this encode also adds a teeny bit of just-below-nominal bitrate blocks too.
Hi
I know there's a win32 version around but the link I get is 404. Can anyone tell me where can I download it? (or pm me to mail it to me)
Thanks in advance!
