Topic: how can i correct write drive offeset (negative value ) in cuetools ? (Read 1366 times) previous topic - next topic
hi
 yesterday I have ripped some cds with eac and i would like to burn with imgburn or anyburn or another good audio burning software ,under mac there is X Lossless Decoder (XLD) mac only
according to eac the read offset is +6 and burning a test cd is 0 , so the write offset is +6-0 = -6 , right?
I don't know if i have to use encode ->default or fix
I would like to fix the write offset just to make a perfect copy without burning with eac
In short , I would like to rip the burned cd and have the accurate rip values ,offset and hash
I have read many topics but they are pretty old , may I ask you if the write offset -6 is right and if the option on cuetools are right?
thanks
the screenshots
Re: how can i correct write drive offeset (negative value ) in cuetools ?
You definitely DO NOT want to use 'fix offset'
There was a recent topic on that
CUETools - Custom scripts (fix offset)
Everything else looks okay.
Notes: Don't forget Track 01 pregap or (HTOA), if any.
If the original was only available as an enhanced CD with data track, you will not be able to burn a CD that will 'verify' to the original.
korth
Hi Korth
ok
1) i will not use "fix offset"
2) I have ripped several cds with offset +6 with the same drive ASUS DRW-2014L1T , in the link you have posted , but i don't want to be offtopic
3) i want to burn some cds ripped with eac with reading offset +6 with imgburn or anyburn ,they can burn much better
since with eac the drive burning offset is 0 ,reading is +6 ,  +6 - 0 = -6 , so my write offset is -6 , i guess it's the right number
so just to be clear , to burn one of these cds , i can use cuetools and set
action =encode
mode =image+cue
extra  offset=-6
output =wav
4) when i will re-rip the burned cd with eac ,will I  have same the same data ,accurate rip as the original cd i have ripped and stored on my computer in flac ?
thanks korth
Your 'write offset' correction calculation seems okay.
CUETools settings okay.
The original TOC is important for an AccurateRip match in EAC. If your original rip was made to individual tracks, you should have the EAC extraction logfile in the same folder as the original rip or use a cue sheet created by EAC from the original CD when using CUETools to create the Image+CUE for burning. This will catch Track 01 pregap, if any.
In some cases you will not be able to make a copy of the CD that verifies after ripping in EAC, such as an enhanced CD with data track, but should be able to use the original rip's EAC extraction logfile in the same folder as the new rip to verify.
korth
Hi Korth
about original in Eac I have this
REM GENRE Rock
REM DATE 1969
REM DISCID 080F1012
REM COMMENT "ExactAudioCopy v1.3"
PERFORMER "The Moody Blues"
TITLE "To Our Children's Children's Children"
FILE "The Moody Blues - To Our Children's Children's Children.flac" WAVE
  TRACK 01 AUDIO
    TITLE "Higher And Higher"
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    TITLE "Eyes Of A Child I"
    INDEX 01 04:06:50
  TRACK 03 AUDIO
    TITLE "Floating"
    INDEX 01 07:30:36
  TRACK 04 AUDIO
    TITLE "Eyes Of A Child II"
    INDEX 01 10:29:24
I have performed with foobar2000 -> verify album with accurate rip and i got this
Track 1: AccurateRip Verified Confidence 151, Pressing Offset +12 [ARv2 CRC A9C125DC]
Track 2: AccurateRip Verified Confidence 150, Pressing Offset +12 [ARv2 CRC BD430DDC]
Track 3: AccurateRip Verified Confidence 151, Pressing Offset +12 [ARv2 CRC 6E7BCC33]
Track 4: AccurateRip Verified Confidence 151, Pressing Offset +12 [ARv2 CRC 6A6EA7F8]
I think the original toc should be related to all tracks included the first track
  TRACK 01 AUDIO
    INDEX 01 00:00:00
on the file i have this
[CTDB TOCID: TR0pbNFCD0OaqsroLP_2D2ucIBQ-] found.
        [ CTDBID ] Status
        [7b469ee0] (134/137) Accurately ripped
        [5cbd6d7a] (001/137) No match
        [ddb92487] (001/137) No match
        [b95b9c46] (001/137) No match
[AccurateRip ID: 0025c6c2-02003de2-080f1012] found.
Track   [ CRC    ] Status
 01     [9ceab55c] (000/134) No match but offset
 02     [f3481c96] (000/134) No match but offset
 03     [fac7c61e] (000/135) No match but offset
 04     [d72ef8b6] (000/135) No match but offset
 05     [3fa84a1c] (000/135) No match but offset
 06     [1961c018] (000/134) No match but offset
 07     [74a94a94] (000/134) No match but offset
 08     [7d30c2c8] (000/135) No match but offset
 09     [cc22fd93] (000/134) No match but offset
 10     [233bbe63] (000/135) No match but offset
 11     [83babd40] (000/135) No match but offset
 12     [5df20f44] (000/135) No match but offset
 13     [817ca329] (000/133) No match but offset
 14     [9334c2f9] (000/128) No match but offset
 15     [f6045056] (000/130) No match but offset
 16     [8f37b364] (000/129) No match but offset
 17     [56d12295] (000/130) No match but offset
 18     [05224cba] (000/130) No match but offset
AccurateRip v2:
 01     [9a39f0c4] (011/134) Accurately ripped
 02     [5ae7a793] (011/134) Accurately ripped
 03     [e7bf7a76] (011/135) Accurately ripped
 04     [70f626cf] (011/135) Accurately ripped
 05     [50088a6e] (011/135) Accurately ripped
 06     [3718a86f] (011/134) Accurately ripped
 07     [87c49a25] (011/134) Accurately ripped
 08     [f03f351b] (011/135) Accurately ripped
 09     [1377fe3a] (011/134) Accurately ripped
 10     [d05abab3] (011/135) Accurately ripped
 11     [56c05e5c] (011/135) Accurately ripped
 12     [a7466507] (011/135) Accurately ripped
 13     [ef716b0c] (011/133) Accurately ripped
 14     [b3761667] (010/128) Accurately ripped
 15     [4ee3cbb7] (011/130) Accurately ripped
 16     [085f26e2] (011/129) Accurately ripped
 17     [1b85af09] (010/130) Accurately ripped
 18     [cf182675] (010/130) Accurately ripped
I have selected only 4 files ,just to don't flood too much the topic
now to burn with anyburn or imgburn or if could suggest a good burner software like BurnAware
i will use cuetools like this , after i will burn with any burning software
i have cds with the first data track for what i know
Thanks Korth for everything , i really appreciate , i have bookmared this topic
I've used AnyBurn and ImgBurn. Either should work for you. I'm not familiar with BurnAware.
korth
