Topic: foo bitrate plugin (Read 2614 times) previous topic - next topic
foo bitrate plugin
hiya
I know there was this option with winamp, you could either see the average bitrate or the actual bitrate at a set time. I'm not sure if it is possible with foobar. I don't actually wat to see the actual bitrate from within foobar, i'd like to be able to output it to a text file.
That way you could setup samurise (or a similar program) to output a line graph to see how the bitrate changes of a set time. Just thought it would be cool option. Not sure if it is possible, baybe intigrated into foo_text.
Just an idea anyway
Saint
"If you cannot read this, please ask the flight attendant for assistance."
- United Airlines Flight Safety Brochure
foo bitrate plugin
There is no common API for retrieving the current bitrate from a running input.
