Topic: Case's Meier Crossfeed Component (Read 48377 times) previous topic - next topic
Re: Case's Meier Crossfeed Component
Reply #50
I made a 64-bit version in October last year and it can be downloaded from http://www.saunalahti.fi/~cse/temp/MeierCrossfeedVSTx64.zip. When I made it I tested it in various VST hosts and while it worked fine in others, Equalizer APO crashed if one tried to access configuration. This component relies on the host to draw the sliders it needs and it looked like EqAPO didn't support that.
Reply #51
I found out that the Peace GUI EqAPO has a MeierCrossfeed functionality.
Reply #52
You can change the Strength parameter in Equalizer APO by editing the command. Note that a space must be appended by enclosing it in double quotes because the current plugin expects it. The value is 0.1 by default and has a range of 0 to 1.
Example command
VSTPlugin: Library MeierCrossfeed.dll "Strength " 0.1
Reply #53
Hey guys, I'm new to headphones but not to hi-fi. I really like the crossfeed idea. Does Case's Meier Crossfeed tool work with Audirvana? I'm using Tidal as my source and Audirvana is the only player that works with it.
Reply #54
I just downloaded the zip file. I must be completely ignorant, I don't know how to use this. A window popped up with a bunch of code and it says at the top : This program cannot be run in DOS mode.
How do I get this plugin to work?
Reply #55
Did you download the FB2K component, or the VST plugin version? The component you should should just be able to double click and it will automatically install, for the VST version you'll need a VST plugin host such as a DAW. No need to install VST version into FB2K when there's a native component version available.
Reply #56
I really love 20 on my Etymotic ER4SR, I can finally listen to metal without it sound like wall of mush fighting for space.
Got locked out on a password i didn't remember. :/
Reply #57
May I ask for the source code? (the part which does the actual processing)
I'm going to try replicating the effect to use in another player (not competing with foobar, as it's mainly for different platforms where foobar can't be run normally), and if I ever release that at all, it'll be open source & free and with the proper credits, of course.
I believe it's the extended version based on what the person who converted the hardware design to C code has written. But frankly the math behind the operation isn't too clear to me.
Is that piece in public access somewhere?
Reply #59
Here's the sources of the component if you wish to take a look anyway.
Reply #60
Thank you so much!
Reply #61
Hi Case,
I'm afraid the link to the 64bit version is dead. Would you please post another link. Also, as a note, I've been using the 32bit version on Win7 64bit computer with some, though limited success. The crossfeed function does work, but only the left channel moves towards the center -- the right channel remains static. All to say that I'd sure be interested in trying the 64bit version. Help appreciated.
Reply #62
@rontokyo
foobar2000 v2.0 32bit 64bit
provided as standard
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, Bose QuietComfort 45 (made a Upgrade/Balanced Cable by myself)
Reply #63
Thanks @Air KEN. According to the notes in the component repository, the Meier crossfeed only works on 32bit machines [though I've had some success with it on my 64bit Win7]. Are you saying that the Meier crossfeed in fact supports 64bit machines as well?
Reply #64
Meier Crossfeed
https://www.foobar2000.org/components/view/foo_dsp_meiercf
https://foobar.hyv.fi/1.4/?view=foo_dsp_meiercf
What download site are you talking about?
for old version.
Why not try it yourself with a portable installation?
Reply #65
In fb2k v2 it is built-in as a part of Standard DSP Array.  So, yes, it "supports 64bit machines". Just go to DSP Manager and add "Meier Crossfeed" to Active DSPs.
Reply #66
for old version.
https://drive.google.com/file/d/13Qe3xVzaxV0BVQHDu5qXXj6R9a35KTRg/view?usp=drive_link
I was unable to post the image, but checking the image uploaded to Drive you'll notice that it's stated:  "Supported processor architecture: x86 32-bit."
Apologies, but it should've been clear that I'm currently using the Meier crossfeed plugin.
Reply #67
@Bogozo,
I think the problem I'm having with the Meier xfeed may be that I haven't updated to v.2 of foobar2k. Hmm. Think I'll do that now :-). Thanks.
Reply #68
Reply #62 https://hydrogenaud.io/index.php/topic,108412.msg1031148.html#msg1031148
There is no download site because it is standard equipment.
Try foobar2000 v2.0 64bit portable installation
Reply #69
I updated to v.2 [32bit] and was "notified" during the installation that my "current" version of Meier crossfeed was outdated and could not be imported. And opening the new installation I could see that in Foobar v.2, as you've mentioned, Meier crossfeed is installed as standard. Using it now and it works properly.
Two questions:  one, I read on another site that the the Meier crossfeed does not work in the 64bit version of v.2 [and for that reason I installed the 32bit version]. Can you verify if that's true. And two, why do you recommend the portable install? Thanks again.
Reply #70
Because it is easy to introduce a portable installation.
You can add as many as you want.
Uninstalling is just deleting the folder.
This is recommended for TEST.
I'm using 64bit.
It's easy to install, so it's faster and more reliable to try it yourself
Reply #71
Sounds easy enough. I'll give it a go. Thanks.
Reply #72
Portable installation:
Start Setup。
https://foobar2000.xrea.jp/up/files/up1590.png
Select Portable installation。
https://foobar2000.xrea.jp/up/files/up1591.png
The default installation destination is Desktop. Do not specify any other folder.
https://foobar2000.xrea.jp/up/files/up1592.png
Uncheck boot.
https://foobar2000.xrea.jp/up/files/up1593.png
Save the "foobar2000" folder created on the desktop in a folder created such as "foobar2000 v2.x Portable".
When using it, create a folder such as "foobar2000 v2.x Portable-02" and put the "foobar2000" folder there to create a shortcut. Please put it in any folder.
Now you can add any number of portable installations. Especially useful for Test.
Update just overwrites the foobar2000 folder with the foobar2000 folder.
Reply #73
Could you share the 64-bit version of the MeierCrosfeed VST plugin with me, please? I use it's 32-bit version in Reaper and it works great.  I think 64-bit version is supposed to work even better and faster with my 4-core CPU.
